[GRASS-SVN] r72252 - in grass/branches/releasebranch_7_4/raster: r.external r.in.gdal
svn_grass at osgeo.org
Sat Feb 17 05:34:52 PST 2018
Author: mmetz
Date: 2018-02-17 05:34:52 -0800 (Sat, 17 Feb 2018)
New Revision: 72252
grass/branches/releasebranch_7_4/raster/r.external/proj.c
grass/branches/releasebranch_7_4/raster/r.in.gdal/main.c
grass/branches/releasebranch_7_4/raster/r.in.gdal/proj.c
r.in.gdal/r.external: add test if OGR spatial reference is NULL (backport trunk r72251)
Modified: grass/branches/releasebranch_7_4/raster/r.external/proj.c
--- grass/branches/releasebranch_7_4/raster/r.external/proj.c 2018-02-17 13:33:50 UTC (rev 72251)
+++ grass/branches/releasebranch_7_4/raster/r.external/proj.c 2018-02-17 13:34:52 UTC (rev 72252)
@@ -35,9 +35,10 @@
OGRSpatialReferenceH hSRS;
hSRS = OSRNewSpatialReference(wkt);
- GPJ_osr_to_grass(cellhd, &proj_info, &proj_units, hSRS, 0);
+ if (hSRS != NULL)
+ GPJ_osr_to_grass(cellhd, &proj_info, &proj_units, hSRS, 0);
- if (!OSRIsProjected(hSRS) && !OSRIsGeographic(hSRS)) {
+ if (!hSRS || (!OSRIsProjected(hSRS) && !OSRIsGeographic(hSRS))) {
G_important_message(_("Input contains an invalid SRS. "
"WKT definition:\n%s"), wkt);
Modified: grass/branches/releasebranch_7_4/raster/r.in.gdal/main.c
--- grass/branches/releasebranch_7_4/raster/r.in.gdal/main.c 2018-02-17 13:33:50 UTC (rev 72251)
+++ grass/branches/releasebranch_7_4/raster/r.in.gdal/main.c 2018-02-17 13:34:52 UTC (rev 72252)
@@ -476,11 +476,6 @@
check_projection(&cellhd, hDS, parm.outloc->answer, flag_c->answer,
flag_o->answer, flag_j->answer);
- if (GDALGetRasterCount(hDS) > 1) {
- G_message(_("Importing %d raster bands..."),
- GDALGetRasterCount(hDS));
/* Set the active window to match the available data. */
@@ -580,6 +575,11 @@
n_bands++;
+ if (GDALGetRasterCount(hDS) > 1 && n_bands != 1) {
+ G_message(_("Importing %d raster bands..."),
+ (n_bands > 1 ? n_bands : GDALGetRasterCount(hDS)));
if ((GDALGetRasterCount(hDS) > 1 && n_bands != 1)
|| GDALGetGCPCount(hDS) > 0)
force_imagery = TRUE;
Modified: grass/branches/releasebranch_7_4/raster/r.in.gdal/proj.c
--- grass/branches/releasebranch_7_4/raster/r.in.gdal/proj.c 2018-02-17 13:33:50 UTC (rev 72251)
+++ grass/branches/releasebranch_7_4/raster/r.in.gdal/proj.c 2018-02-17 13:34:52 UTC (rev 72252)
@@ -35,9 +35,10 @@
+ if (hSRS != NULL)
