[GRASS-SVN] r72269 - grass/trunk/raster/r.info
svn_grass at osgeo.org
Wed Feb 21 13:19:09 PST 2018
Author: mmetz
Date: 2018-02-21 13:19:09 -0800 (Wed, 21 Feb 2018)
New Revision: 72269
grass/trunk/raster/r.info/main.c
r.info: use grass_int64 and j length modifier for total cells and number of non-null cells
Modified: grass/trunk/raster/r.info/main.c
--- grass/trunk/raster/r.info/main.c 2018-02-21 21:14:37 UTC (rev 72268)
+++ grass/trunk/raster/r.info/main.c 2018-02-21 21:19:09 UTC (rev 72269)
@@ -197,14 +197,8 @@
compose_line(out, " Rows: %d", cellhd.rows);
compose_line(out, " Columns: %d", cellhd.cols);
-#ifdef HAVE_LONG_LONG_INT
- compose_line(out, " Total Cells: %llu",
- (unsigned long long)cellhd.rows * cellhd.cols);
-#else
- compose_line(out,
- " Total Cells: %lu (accuracy - see r.info manual)",
- (unsigned long)cellhd.rows * cellhd.cols);
-#endif
+ compose_line(out, " Total Cells: %ju",
+ (grass_int64)cellhd.rows * cellhd.cols);
/* This is printed as a guide to what the following eastings and
* northings are printed in. This data is NOT from the values
@@ -353,8 +347,8 @@
fprintf(out, "rows=%d\n", cellhd.rows);
fprintf(out, "cols=%d\n", cellhd.cols);
- fprintf(out, "cells=%lld\n",
- (long long)cellhd.rows * cellhd.cols);
+ fprintf(out, "cells=%jd\n",
fprintf(out, "datatype=%s\n",
(data_type == CELL_TYPE ? "CELL" :
@@ -436,11 +430,7 @@
mean = (double)(rstats.sum / rstats.count);
sd = sqrt(rstats.sumsq / rstats.count - (mean * mean));
- fprintf(out, "n=%lld\n", (long long int)rstats.count);
-#else
- fprintf(out, "n=%.0f\n", (double)rstats.count);
-#endif
+ fprintf(out, "n=%jd\n", rstats.count);
if (!rflag->answer) {
fprintf(out, "min=%.15g\n", zmin);
