[GRASS-SVN] r72270 - grass-addons/grass7/vector/v.mapcalc
svn_grass at osgeo.org
Thu Feb 22 01:06:06 PST 2018
Author: neteler
Date: 2018-02-22 01:06:05 -0800 (Thu, 22 Feb 2018)
New Revision: 72270
grass-addons/grass7/vector/v.mapcalc/v.mapcalc.html
v.mapcalc manual: minor updates
Modified: grass-addons/grass7/vector/v.mapcalc/v.mapcalc.html
--- grass-addons/grass7/vector/v.mapcalc/v.mapcalc.html 2018-02-21 21:19:09 UTC (rev 72269)
+++ grass-addons/grass7/vector/v.mapcalc/v.mapcalc.html 2018-02-22 09:06:05 UTC (rev 72270)
@@ -1,9 +1,11 @@
-<h2>DESCRIPTION</h2>
+<h2>DESCRIPTION</h2>
-<em>v.mapcalc</em> performs overlay and buffer functions on vector map layers. New vector map layers can be created which are
-expressions of existing vector map layers, boolean vector operations and buffer functions.
+<em>v.mapcalc</em> performs overlay and buffer functions on
+vector map layers. New vector map layers can be created which are
+expressions of existing vector map layers, boolean vector operations
+and buffer functions.
-<h3>PROGRAM USE</h3>
+<h3>PROGRAM USE</h3>
The module expects its input as expression in the following form: <br>
<br>
<b> result = expression </b>
@@ -19,20 +21,20 @@
<div class="code"><pre>v.mapcalc expression="A = B"</pre></div>
Where <b>A</b> is the new vector map layer that will be equal to the existing vector map layer <b>B</b> in this case. <br>
<div class="code"><pre>v.mapcalc "A = B"</pre></div>
-Will give the same result.
-<br>
-<br>
+will give the same result.
<h3>OPERATORS AND FUNCTIONS</h3>
The module supports the following boolean vector operations: <br>
- Boolean Name Operator Meaning Precedence Correspondent function
- AND & Intersection 1 (v.overlay operator=and)
- OR | Union 1 (v.overlay operator=or)
- DISJOINT OR + Disjoint union 1 (v.patch)
- XOR ^ Symmetric difference 1 (v.overlay operator=xor)
- NOT ~ Complement 1 (v.overlay operator=not)
+ Boolean Name Operator Meaning Precedence Correspondent function
+ AND & Intersection 1 (v.overlay operator=and)
+ OR | Union 1 (v.overlay operator=or)
+ DISJOINT OR + Disjoint union 1 (v.patch)
+ XOR ^ Symmetric difference 1 (v.overlay operator=xor)
+ NOT ~ Complement 1 (v.overlay operator=not)
</pre></div>
@@ -42,12 +44,11 @@
buff_l(A, size) Buffer the lines of vector map layer A with size
buff_a(A, size) Buffer the areas of vector map layer A with size
</pre></div>
-<br>
<h2>NOTES</h2>
As shown in the operator table above, the boolean vector operators do not have different precedence.
In default setting the expression will be left associatively evaluated. To define specific precedence use parentheses
-around these expressions, for example: <br>
+around these expressions, for example:<br>
v.mapcalc expression="D = A & B | C"
@@ -54,7 +55,7 @@
</pre></div>
Here the first intermediate result is the intersection of vector map layers <b>A & B</b>.
This intermediate vector map layer is taken to create the union with vector map <b>C</b> to get the final result <b>D</b>.
-It represents the default behaviour of left associativity.
+It represents the default behaviour of left associativity.
v.mapcalc expression="D = A & (B | C)"
@@ -68,8 +69,10 @@
Different order of operations can lead to a different result.
<h2>EXAMPLES</h2>
This example needed specific region setting. It should work in UTM and LL test locations. <br>
First set the regions extent and create two vector maps with one random points, respectively:
g.region s=0 n=30 w=0 e=50 b=0 t=50 res=10 res3=10 -p3
@@ -79,7 +82,9 @@
v.info point_2
</pre></div>
-Then the vector algebra is used to create buffers around those points, cut out a subset and apply different boolean operation on the subsets in one statement:
+Then the vector algebra is used to create buffers around those points, cut out a subset and apply different boolean operation
+on the subsets in one statement:
v.mapcalc --o expr="buff_and = (buff_p(point_1, 30.0) ~ buff_p(point_1, 20.0)) & \
(buff_p(point_2, 35) ~ buff_p(point_2, 25))"
@@ -93,8 +98,18 @@
<h2>REFERENCES</h2>
-<tt><a href="http://www.dabeaz.com/ply/">PLY(Python-Lex-Yacc)</a></tt>
+The use of this module requires the following software to be installed:
+<a href="http://www.dabeaz.com/ply/">PLY(Python-Lex-Yacc)</a>
+<p>
+<div class="code"><pre>
+# Ubuntu/Debian
+sudo apt-get install python-ply
+# Fedora
+sudo dnf install python-ply
+</pre></div>
<h2>SEE ALSO</h2>
<em>
@@ -105,7 +120,7 @@
</em>
-<h2>AUTHOR</h2>
+<h2>AUTHORS</h2>
Thomas Leppelt, Soeren Gebbert, Thuenen Institut, Germany <br>
