[GRASS-SVN] r72279 - grass-addons/grass7/raster/r.sentinel/r.sentinel.download
svn_grass at osgeo.org
Mon Feb 26 02:13:00 PST 2018
Author: martinl
Date: 2018-02-26 02:13:00 -0800 (Mon, 26 Feb 2018)
New Revision: 72279
grass-addons/grass7/raster/r.sentinel/r.sentinel.download/r.sentinel.download.html
grass-addons/grass7/raster/r.sentinel/r.sentinel.download/r.sentinel.download.py
r.sentinel.download: user, password changed to settings option (sync with r.modis)
interactive prompt also supported
i18n
manual updated
Modified: grass-addons/grass7/raster/r.sentinel/r.sentinel.download/r.sentinel.download.html
--- grass-addons/grass7/raster/r.sentinel/r.sentinel.download/r.sentinel.download.html 2018-02-25 15:28:44 UTC (rev 72278)
+++ grass-addons/grass7/raster/r.sentinel/r.sentinel.download/r.sentinel.download.html 2018-02-26 10:13:00 UTC (rev 72279)
@@ -3,13 +3,34 @@
Hub</a>.
<p>
-To connect Copernicus Open Access Hub a <b>user</b>
-and <b>password</b> are required,
+To connect Copernicus Open Access Hub a <em>user</em>
+and <em>password</em> are required,
see <a href="https://scihub.copernicus.eu/dhus/#/self-registration">Register
new account</a> page for signing up.
+<p><em>r.sentinel.download</em> reads user credentials
+from <b>settings</b> file. The file must contain at least two lines:
+<div class="code"><pre>
+myusername
+mypassword
+</pre></div>
+Optionally on third line custom API URL can be defined. Note that
+empty lines in settings file are silently skipped.
<h2>NOTES</h2>
+<p>User credentials can be also defined interactively
+when <b>settings=-</b> is given. Note that interactive prompt does not
+work in GUI.
+Insert username: myusername
+Insert password:
+Insert API URL (leave empty for https://scihub.copernicus.eu/dhus):
+</pre></div>
<p>
By default Sentinel products are sorted by <i>cloudcoverpercentage</i>
and <i>ingestiondate</i> (see <b>sort</b> option). By default,
@@ -43,7 +64,7 @@
Find S2MSI1C products in last 60 days covering current computation region extent.
-r.sentinel.download -l user=myusername password=mypassword
+r.sentinel.download -l settings=sentinel.txt
1 Sentinel product(s) found
ae1c33ec-aa33-4303-a525-9e6481709614 2017-12-08T10:23:59Z 18% S2MSI1C
@@ -52,7 +73,7 @@
Find all S2MSI2Ap products in 2017.
-r.sentinel.download -l user=myusername password=mypassword producttype=S2MSI2Ap start=2017-01-01 end=2017-12-31
+r.sentinel.download -l settings=sentinel.txt producttype=S2MSI2Ap start=2017-01-01 end=2017-12-31
7 Sentinel product(s) found
e5df8b4f-a4c6-47bd-88f3-e16b7540cc7a 2017-05-27T10:20:31Z 2% S2MSI2Ap
@@ -67,7 +88,7 @@
Sort products by <b>ingestiondate</b>, limit cloud coverage to 5% per scene.
-r.sentinel.download -l user=myusername password=mypassword producttype=S2MSI2Ap start=2017-01-01 end=2017-12-31 sort=ingestiondate order=desc clouds=5
+r.sentinel.download -l settings=sentinel.txt producttype=S2MSI2Ap start=2017-01-01 end=2017-12-31 sort=ingestiondate order=desc clouds=5
3 Sentinel product(s) found
9a6bc289-98e9-4489-84eb-1aac95aaa056 2017-08-15T10:20:21Z 3% S2MSI2Ap
@@ -78,7 +99,7 @@
Create vector map with <b>footprints</b>.
-r.sentinel.download -l user=myusername password=mypassword producttype=S2MSI2Ap start=2017-01-01 end=2017-12-31 footprints=ft
+r.sentinel.download -l settings=sentinel.txt producttype=S2MSI2Ap start=2017-01-01 end=2017-12-31 footprints=ft
</pre></div>
<h3>Download Sentinel products</h3>
@@ -86,7 +107,7 @@
Download first (<b>limit=1</b>) found S2MSI2Ap product into <i>data</i> directory.
-r.sentinel.download user=myusername password=mypassword producttype=S2MSI2Ap start=2017-01-01 end=2017-12-31 limit=1 output=data
+r.sentinel.download settings=sentinel.txt producttype=S2MSI2Ap start=2017-01-01 end=2017-12-31 limit=1 output=data
</pre></div>
Such downloaded data can be easily imported into GRASS
Modified: grass-addons/grass7/raster/r.sentinel/r.sentinel.download/r.sentinel.download.py
--- grass-addons/grass7/raster/r.sentinel/r.sentinel.download/r.sentinel.download.py 2018-02-25 15:28:44 UTC (rev 72278)
+++ grass-addons/grass7/raster/r.sentinel/r.sentinel.download/r.sentinel.download.py 2018-02-26 10:13:00 UTC (rev 72279)
@@ -14,7 +14,7 @@
-#%Module
+#%module
#% description: Downloads Sentinel data from Copernicus Open Access Hub using sentinelsat library.
#% keyword: raster
#% keyword: imagery
@@ -21,18 +21,11 @@
#% keyword: sentinel
#% keyword: download
#%end
-#%option
-#% key: user
-#% type: string
-#% description: Username for connecting SciHub
-#% required: yes
+#%option G_OPT_F_INPUT
+#% key: settings
+#% label: Full path to settings file (user, password)
+#% description: '-' for standard input
#%end
-#%option
-#% key: password
-#% type: string
-#% description: Password for connecting SciHub
-#% required: yes
-#%end
#%option G_OPT_M_DIR
#% key: output
#% description: Name for output directory where to store downloaded Sentinel data
@@ -140,15 +133,15 @@
class SentinelDownloader(object):
- def __init__(self, user, password):
+ def __init__(self, user, password, api_url='https://scihub.copernicus.eu/dhus'):
try:
from sentinelsat import SentinelAPI
except ImportError as e:
- gs.fatal("Module requires sentinelsat library: {}".format(e))
+ gs.fatal(_("Module requires sentinelsat library: {}").format(e))
try:
import pandas
- gs.fatal("Module requires pandas library: {}".format(e))
+ gs.fatal(_("Module requires pandas library: {}").format(e))
# init logger
root = logging.getLogger()
@@ -157,8 +150,8 @@
# connect SciHub via API
- self._api = SentinelAPI(options['user'], options['password'],
- api_url='https://scihub.copernicus.eu/dhus'
+ self._api = SentinelAPI(user, password,
+ api_url=api_url
self._products_df_sorted = None
@@ -187,7 +180,7 @@
products_df = self._api.to_dataframe(products)
if len(products_df) < 1:
- gs.message('No product found')
+ gs.message(_('No product found'))
return
# sort and limit to first sorted product
@@ -200,7 +193,7 @@
if limit:
self._products_df_sorted = self._products_df_sorted.head(int(limit))
- gs.message('{} Sentinel product(s) found'.format(len(self._products_df_sorted)))
+ gs.message(_('{} Sentinel product(s) found').format(len(self._products_df_sorted)))
def list(self):
if self._products_df_sorted is None:
@@ -220,7 +213,7 @@
if not os.path.exists(output):
os.makedirs(output)
- gs.message('Downloading data into <{}>...'.format(output))
+ gs.message(_('Downloading data into <{}>...').format(output))
for idx in range(len(self._products_df_sorted)):
gs.message('{} -> {}.SAFE'.format(
self._products_df_sorted['uuid'][idx],
@@ -243,9 +236,9 @@
try:
from osgeo import ogr, osr
- gs.fatal("Option <footprints> requires GDAL library: {}".format(e))
+ gs.fatal(_("Option <footprints> requires GDAL library: {}").format(e))
- gs.message("Writing footprints into <{}>...".format(map_name))
+ gs.message(_("Writing footprints into <{}>...").format(map_name))
driver = ogr.GetDriverByName("GPKG")
tmp_name = gs.tempfile() + '.gpkg'
data_source = driver.CreateDataSource(tmp_name)
@@ -287,20 +280,50 @@
def main():
+ user = password = None
+ api_url='https://scihub.copernicus.eu/dhus'
+ if options['settings'] == '-':
+ # stdin
+ import getpass
+ user = raw_input(_('Insert username: '))
+ password = getpass.getpass(_('Insert password: '))
+ url = raw_input(_('Insert API URL (leave empty for {}): ').format(api_url))
+ if url:
+ api_url = url
+ else:
+ try:
+ with open(options['settings'], 'r') as fd:
+ lines = filter(None, (line.rstrip() for line in fd)) # non-blank lines only
+ if len(lines) < 2:
+ gs.fatal(_("Invalid settings file"))
+ user = lines[0].strip()
+ password = lines[1].strip()
+ if len(lines) > 2:
+ api_url = lines[2].strip()
+ except IOError as e:
+ gs.fatal(_("Unable to open settings file: {}").format(e))
+ if user is None or password is None:
+ gs.fatal(_("No user or password given"))
map_box = get_aoi_box(options['map'])
- downloader = SentinelDownloader(options['user'], options['password'])
+ try:
+ downloader = SentinelDownloader(user, password, api_url)
- downloader.filter(area=map_box,
- area_relation=options['area_relation'],
- clouds=options['clouds'],
- producttype=options['producttype'],
- limit=options['limit'],
- start=options['start'],
- end=options['end'],
- sortby=options['sort'].split(','),
- asc=options['order'] == 'asc'
+ downloader.filter(area=map_box,
+ area_relation=options['area_relation'],
+ clouds=options['clouds'],
+ producttype=options['producttype'],
+ limit=options['limit'],
+ start=options['start'],
+ end=options['end'],
+ sortby=options['sort'].split(','),
+ asc=options['order'] == 'asc'
+ except StandardError as e:
+ gs.fatal(_('Unable to connect Copernicus Open Access Hub: {}').format(e))
if options['footprints']:
downloader.save_footprints(options['footprints'])
