[GRASS-SVN] r72280 - grass-addons/grass7/raster/r.sentinel/r.sentinel.import
svn_grass at osgeo.org
Mon Feb 26 02:14:11 PST 2018
Author: martinl
Date: 2018-02-26 02:14:11 -0800 (Mon, 26 Feb 2018)
New Revision: 72280
grass-addons/grass7/raster/r.sentinel/r.sentinel.import/r.sentinel.import.py
r.sentinel.import: i18n
Modified: grass-addons/grass7/raster/r.sentinel/r.sentinel.import/r.sentinel.import.py
--- grass-addons/grass7/raster/r.sentinel/r.sentinel.import/r.sentinel.import.py 2018-02-26 10:13:00 UTC (rev 72279)
+++ grass-addons/grass7/raster/r.sentinel/r.sentinel.import/r.sentinel.import.py 2018-02-26 10:14:11 UTC (rev 72280)
@@ -55,7 +55,7 @@
class SentinelImporter(object):
def __init__(self, input_dir):
if not os.path.exists(input_dir):
- gs.fatal('{} not exists'.format(input_dir))
+ gs.fatal(_('{} not exists').format(input_dir))
self.input_dir = input_dir
def filter(self, pattern=None):
@@ -97,8 +97,8 @@
for f in self.files:
if link or (not link and not reproject):
if not self._check_projection(f):
- gs.fatal('Projection of dataset does not appear to match current location. '
- 'Force reprojecting dataset by -r flag.')
+ gs.fatal(_('Projection of dataset does not appear to match current location. '
+ 'Force reprojecting dataset by -r flag.'))
self._import_file(f, module, args)
@@ -115,7 +115,7 @@
try:
from osgeo import gdal
except ImportError as e:
- gs.fatal("Flag -r requires GDAL library: {}".format(e))
+ gs.fatal(_("Flag -r requires GDAL library: {}").format(e))
dsn = gdal.Open(filename)
trans = dsn.GetGeoTransform()
@@ -123,7 +123,7 @@
def _import_file(self, filename, module, args):
mapname = os.path.splitext(os.path.basename(filename))[0]
- gs.message('Processing <{}>...'.format(mapname))
+ gs.message(_('Processing <{}>...').format(mapname))
if module == 'r.import':
args['resolution_value'] = self._raster_resolution(filename)
try:
