[GRASS-SVN] r72037 - grass/trunk/locale/po
svn_grass at osgeo.org
Sat Jan 6 03:29:23 PST 2018
Author: neteler
Date: 2018-01-06 03:29:23 -0800 (Sat, 06 Jan 2018)
New Revision: 72037
Removed:
grass/trunk/locale/po/grasswxpy_id.po
grass/trunk/locale/po/grasswxpy_id_ID.po
i18N: grasswxpy_id.po --> grasswxpy_id_ID.po
Deleted: grass/trunk/locale/po/grasswxpy_id.po
--- grass/trunk/locale/po/grasswxpy_id.po 2018-01-06 11:14:56 UTC (rev 72036)
+++ grass/trunk/locale/po/grasswxpy_id.po 2018-01-06 11:29:23 UTC (rev 72037)
@@ -1,20651 +0,0 @@
-# translation of grasswxpy_id.po to Indonesian
-# Firman Hadi <jalmiburung at gmail.com>, 2008.
-# This file is distributed under the same license as the GRASS package.
-# Copyright (C) 2008, GRASS Development Team
-msgid ""
-msgstr ""
-"Project-Id-Version: grasswxpy_id\n"
-"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2016-11-14 14:55+0100\n"
-"PO-Revision-Date: 2009-04-10 21:13+0700\n"
-"Last-Translator: Firman Hadi <jalmiburung at gmail.com>\n"
-"Language-Team: deutsch <grass-translations at lists.osgeo.org>\n"
-"Language: id_ID\n"
-"MIME-Version: 1.0\n"
-"Content-Type: text/plain; charset=UTF-8\n"
-"Content-Transfer-Encoding: 8bit\n"
-"X-Generator: KBabel 1.11.4\n"
-"Plural-Forms: nplurals=3; plural=(n%10==1 && n%100!=11 ? 0 : n != 0 ? 1 : "
-"2);\n"
-"X-Poedit-Language: Indonesian\n"
-"X-Poedit-Country: INDONESIA\n"
-#: ../gui/wxpython/gcp/manager.py:143
-msgid "Setup for georectification"
-msgstr "Pengaturan untuk georektifikasi"
-#: ../gui/wxpython/gcp/manager.py:176 ../gui/wxpython/gcp/manager.py:180
-msgid "Georectifying setup canceled."
-msgstr "Pengaturan georektifikasi dibatalkan."
-#: ../gui/wxpython/gcp/manager.py:345
-msgid "Select map type and location/mapset"
-msgstr "Pilih tipe peta dan location/mapset"
-#: ../gui/wxpython/gcp/manager.py:359
-msgid "Map type to georectify"
-msgstr "Tipe peta untuk georektifikasi"
-#: ../gui/wxpython/gcp/manager.py:360 ../gui/wxpython/psmap/dialogs.py:907
-#: ../gui/wxpython/gmodeler/frame.py:1650
-#: ../gui/wxpython/gui_core/dialogs.py:1452
-#: ../gui/wxpython/gui_core/dialogs.py:1697
-msgid "raster"
-msgstr "raster"
-#: ../gui/wxpython/gcp/manager.py:360 ../gui/wxpython/psmap/dialogs.py:910
-#: ../gui/wxpython/gmodeler/frame.py:1651
-msgid "vector"
-msgstr "vektor "
-#: ../gui/wxpython/gcp/manager.py:370
-msgid "Select source location:"
-msgstr "Pilih sumber location:"
-#: ../gui/wxpython/gcp/manager.py:391
-msgid "Select source mapset:"
-msgstr "Pilih sumber mapset:"
-#: ../gui/wxpython/gcp/manager.py:447
-msgid "You must select a valid location before selecting a mapset"
-msgstr ""
-"Anda harus memilih sebuah location yang valid sebelum memilih mapset tertentu"
-#: ../gui/wxpython/gcp/manager.py:460
-msgid "You must select a valid location and mapset in order to continue"
-msgstr ""
-"Anda harus memilih sebuah location dan mapset yang valid untuk melanjutkan"
-#: ../gui/wxpython/gcp/manager.py:482
-msgid "Select image/map group to georectify"
-msgstr "Pilih grup image/map untuk georektifikasi"
-#: ../gui/wxpython/gcp/manager.py:504
-msgid "Select group:"
-msgstr "Pilih grup:"
-#: ../gui/wxpython/gcp/manager.py:521
-msgid "Create group if none exists"
-msgstr "Buat grup jika tidak ada"
-#: ../gui/wxpython/gcp/manager.py:531 ../gui/wxpython/iclass/dialogs.py:78
-msgid "Create/edit group..."
-msgstr "Buat/edit grup ..."
-#: ../gui/wxpython/gcp/manager.py:535
-#, fuzzy
-msgid "Add vector map to group..."
-msgstr "Tambahkan layer peta vektor"
-#: ../gui/wxpython/gcp/manager.py:555 ../gui/wxpython/gcp/manager.py:2969
-msgid "Extension for output maps:"
-msgstr "Ekstensi untuk peta output:"
-#: ../gui/wxpython/gcp/manager.py:619
-msgid "You must select a valid image/map group in order to continue"
-msgstr ""
-"Anda harus memilih sebuah grup image/map yang valid untuk dapat melanjutkan"
-#: ../gui/wxpython/gcp/manager.py:626
-msgid "You must enter an map name extension in order to continue"
-msgstr "Anda harus memasukkan nama ekstensi peta untuk dapat melanjutkan"
-#: ../gui/wxpython/gcp/manager.py:695
-#, fuzzy
-msgid "Select maps to display for ground control point (GCP) creation"
-msgstr ""
-"Pilih image/peta untuk ditampilkan dalam pembuatan ground control point (GCP)"
-#: ../gui/wxpython/gcp/manager.py:707 ../gui/wxpython/gcp/manager.py:2864
-#, fuzzy
-msgid "Select source map to display:"
-#: ../gui/wxpython/gcp/manager.py:733 ../gui/wxpython/gcp/manager.py:2878
-#, fuzzy
-msgid "Select target raster map to display:"
-msgstr "Pilih peta raster untuk dibuat profil"
-#: ../gui/wxpython/gcp/manager.py:756 ../gui/wxpython/gcp/manager.py:2892
-#, fuzzy
-msgid "Select target vector map to display:"
-#: ../gui/wxpython/gcp/manager.py:828
-#, fuzzy
-msgid "You must select a source map in order to continue"
-msgstr "Anda harus memilih image/peta yang valid untuk dapat melanjutkan"
-#: ../gui/wxpython/gcp/manager.py:855 ../gui/wxpython/gcp/manager.py:886
-#, python-format
-msgid ""
-"No maps in selected group <%s>.\n"
-"Please edit group or select another group."
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:916
-#, fuzzy
-msgid "Manage Ground Control Points"
-msgstr "Ground Control Points"
-#: ../gui/wxpython/gcp/manager.py:1181
-#, fuzzy, python-format
-msgid "At least %d GCPs required. Operation canceled."
-msgstr "Paling tidak dibutuhkan %d GCP. Operasi dibatalkan."
-#: ../gui/wxpython/gcp/manager.py:1324
-#, fuzzy
-msgid "source"
-msgstr "Cost surface"
-#: ../gui/wxpython/gcp/manager.py:1326
-msgid "target"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1328
-#, fuzzy
-msgid "Set GCP coordinates"
-msgstr "Konversi koordinat "
-#: ../gui/wxpython/gcp/manager.py:1330
-#, python-format
-msgid ""
-"Set %(coor)s coordinates for GCP No. %(key)s? \n"
-"\n"
-"East: %(coor0)s \n"
-"North: %(coor1)s"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1408
-msgid "Writing POINTS file failed"
-msgstr "Penulisan berkas POINTS gagal"
-#: ../gui/wxpython/gcp/manager.py:1420
-msgid "POINTS file saved for group <%s>"
-msgstr "Berkas POINTS berhasil disimpan"
-#: ../gui/wxpython/gcp/manager.py:1436
-msgid "source mapwin not defined"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1441
-msgid "target mapwin not defined"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1471
-msgid "Reading POINTS file failed"
-msgstr "Pembacaan berkas POINTS gagal"
-#: ../gui/wxpython/gcp/manager.py:1556
-msgid ""
-"Insufficient points defined and active (checked) for selected rectification "
-"method (order: %d).\n"
-"3+ points needed for 1st order,\n"
-"6+ points for 2nd order, and\n"
-"10+ points for 3rd order."
-msgstr ""
-"Tidak cukup titik yang didefinisikan dan diaktifkan (dipilih) untuk metoda "
-"rektifkasi terpilih.\n"
-"3+ titik diperlukan untuk Orde 1,\n"
-"6+ titik diperlukan untuk Orde 2, dan\n"
-"10+ titik diperlukan untuk Orde 3."
-#: ../gui/wxpython/gcp/manager.py:1584
-#, fuzzy
-msgid "Rectifying images, please wait..."
-msgstr "Rektifikasi citra atau raster"
-#: ../gui/wxpython/gcp/manager.py:1624
-msgid "Transforming <%s>..."
-msgstr "Transformasi citra"
-#: ../gui/wxpython/gcp/manager.py:1629
-msgid "Rectifying vector map <%s>, please wait..."
-#: ../gui/wxpython/gcp/manager.py:1663
-msgid "Georectification of vector map <%s> failed"
-msgstr "Penambahan fitur baru untuk peta vektor <%s> gagal."
-#: ../gui/wxpython/gcp/manager.py:1669
-#, fuzzy
-msgid "GCP Manager settings"
-msgstr "Pengaturan Layer Maager"
-#: ../gui/wxpython/gcp/manager.py:1716
-msgid "Quit GCP Manager"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1717
-#, fuzzy
-msgid "Save ground control points?"
-msgstr "Pengaturan GCP"
-#: ../gui/wxpython/gcp/manager.py:1796
-msgid ""
-"Could not calculate RMS Error.\n"
-"Possible error with m.transform."
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1924
-msgid ""
-"Could not calculate new extends.\n"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2056
-msgid "Adjust source display to target display"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2061
-msgid "Adjust target display to source display"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2135 ../gui/wxpython/gcp/manager.py:2153
-#: ../gui/wxpython/vnet/vnet_data.py:259 ../gui/wxpython/vnet/widgets.py:85
-msgid "use"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2136 ../gui/wxpython/gcp/manager.py:2154
-#, fuzzy
-msgid "source E"
-#: ../gui/wxpython/gcp/manager.py:2137 ../gui/wxpython/gcp/manager.py:2155
-#, fuzzy
-msgid "source N"
-#: ../gui/wxpython/gcp/manager.py:2138 ../gui/wxpython/gcp/manager.py:2156
-#, fuzzy
-msgid "target E"
-msgstr "Grup target"
-#: ../gui/wxpython/gcp/manager.py:2139 ../gui/wxpython/gcp/manager.py:2157
-#, fuzzy
-msgid "target N"
-#: ../gui/wxpython/gcp/manager.py:2140 ../gui/wxpython/gcp/manager.py:2158
-msgid "Forward error"
-msgstr "Forward error"
-#: ../gui/wxpython/gcp/manager.py:2141 ../gui/wxpython/gcp/manager.py:2159
-msgid "Backward error"
-msgstr "Backward error"
-#: ../gui/wxpython/gcp/manager.py:2296
-#, fuzzy
-msgid "Invalid coordinate value. Operation canceled."
-msgstr "Nilai koordinat tidak valid. Operasi dibatalkan."
-#: ../gui/wxpython/gcp/manager.py:2343
-#, fuzzy
-msgid "Create vector map group"
-msgstr "Buat peta vektor baru"
-#: ../gui/wxpython/gcp/manager.py:2418
-#, fuzzy
-msgid "Select vector map(s) to add to group:"
-msgstr "Pilih peta vektor"
-#: ../gui/wxpython/gcp/manager.py:2469
-msgid "Edit GCP"
-msgstr "Edit GCP"
-#: ../gui/wxpython/gcp/manager.py:2481
-#, fuzzy
-msgid "Ground Control Point No."
-msgstr "Ground Control Point"
-#: ../gui/wxpython/gcp/manager.py:2500
-#, fuzzy
-msgid "source E:"
-#: ../gui/wxpython/gcp/manager.py:2501
-msgid "target E:"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2502
-#, fuzzy
-msgid "source N:"
-#: ../gui/wxpython/gcp/manager.py:2503
-msgid "target N:"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2609 ../gui/wxpython/wxplot/dialogs.py:829
-#: ../gui/wxpython/wxplot/dialogs.py:1428 ../gui/wxpython/vnet/dialogs.py:1307
-#: ../gui/wxpython/iscatt/dialogs.py:397
-msgid "Apply changes for the current session"
-msgstr "Terapkan perubahan untuk sesi saat ini"
-#: ../gui/wxpython/gcp/manager.py:2612 ../gui/wxpython/wxplot/dialogs.py:836
-#: ../gui/wxpython/wxplot/dialogs.py:1432 ../gui/wxpython/vnet/dialogs.py:1310
-#: ../gui/wxpython/gui_core/preferences.py:98
-#: ../gui/wxpython/iscatt/dialogs.py:400
-msgid ""
-"Apply and save changes to user settings file (default for next sessions)"
-msgstr ""
-"Terapkan dan simpan perubahan ke berkas pengaturan milik pengguna (standar "
-"untuk sesi berikutnya)"
-#: ../gui/wxpython/gcp/manager.py:2614 ../gui/wxpython/vnet/dialogs.py:1312
-#: ../gui/wxpython/web_services/dialogs.py:144
-#: ../gui/wxpython/web_services/dialogs.py:899
-#: ../gui/wxpython/iscatt/dialogs.py:402
-#: ../gui/wxpython/modules/import_export.py:110
-#: ../gui/wxpython/modules/import_export.py:663
-#, fuzzy
-msgid "Close dialog"
-msgstr "Tutup dialog di akhir perintah"
-#: ../gui/wxpython/gcp/manager.py:2640 ../gui/wxpython/psmap/dialogs.py:2643
-#: ../gui/wxpython/vdigit/preferences.py:98
-msgid "Symbology"
-msgstr "Simbolisasi"
-#: ../gui/wxpython/gcp/manager.py:2649
-msgid "Highlight highest RMS error only"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2662
-msgid "Highlight RMS error > M + SD * factor:"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2666
-msgid ""
-"Highlight GCPs with an RMS error larger than \n"
-"mean + standard deviation * given factor. \n"
-"Recommended values for this factor are between 1 and 2."
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2689
-msgid "Symbol settings"
-msgstr "Pengaturan simbol"
-#: ../gui/wxpython/gcp/manager.py:2697 ../gui/wxpython/psmap/dialogs.py:2362
-#: ../gui/wxpython/psmap/dialogs.py:2523 ../gui/wxpython/nviz/tools.py:1423
-#: ../gui/wxpython/nviz/tools.py:2154 ../gui/wxpython/nviz/tools.py:2296
-#: ../gui/wxpython/nviz/preferences.py:372
-#: ../gui/wxpython/nviz/preferences.py:574
-#: ../gui/wxpython/nviz/preferences.py:640
-#: ../gui/wxpython/gui_core/preferences.py:1454
-#: ../gui/wxpython/mapswipe/dialogs.py:280
-msgid "Color:"
-msgstr "Warna: "
-#: ../gui/wxpython/gcp/manager.py:2717
-msgid "Color for high RMS error:"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2737
-#, fuzzy
-msgid "Color for selected GCP:"
-msgstr "Bersihkan GCP terpilih"
-#: ../gui/wxpython/gcp/manager.py:2757
-#, fuzzy
-msgid "Color for unused GCPs:"
-msgstr "Aturan warna "
-#: ../gui/wxpython/gcp/manager.py:2773
-#, fuzzy
-msgid "Show unused GCPs"
-msgstr "Garis aliran "
-#: ../gui/wxpython/gcp/manager.py:2790
-#: ../gui/wxpython/gui_core/preferences.py:1381
-#, fuzzy
-msgid "Symbol size:"
-#: ../gui/wxpython/gcp/manager.py:2812 ../gui/wxpython/psmap/dialogs.py:6800
-#: ../gui/wxpython/vnet/dialogs.py:1279
-#: ../gui/wxpython/gui_core/preferences.py:1364
-#: ../gui/wxpython/mapswipe/dialogs.py:327
-#, fuzzy
-msgid "Line width:"
-msgstr "Lebar garis"
-#: ../gui/wxpython/gcp/manager.py:2918
-#, fuzzy
-msgid "Rectification"
-msgstr "Toolbar Georektifikasi"
-#: ../gui/wxpython/gcp/manager.py:2927
-#, fuzzy
-msgid "Select rectification order"
-msgstr "Pilih metoda rektifikasi untuk raster "
-#: ../gui/wxpython/gcp/manager.py:2929
-msgid "1st order"
-msgstr "Orde 1 "
-#: ../gui/wxpython/gcp/manager.py:2930
-msgid "2nd order"
-msgstr "Orde 2 "
-#: ../gui/wxpython/gcp/manager.py:2931
-msgid "3rd order"
-msgstr "Orde 3 "
-#: ../gui/wxpython/gcp/manager.py:2943
-#, fuzzy
-msgid "Select interpolation method:"
-#: ../gui/wxpython/gcp/manager.py:2959
-#, fuzzy
-msgid "clip to computational region in target location"
-msgstr "Perbesaran ke computational region (g.region)"
-#: ../gui/wxpython/gcp/manager.py:3010
-msgid "RMS threshold factor must be > 0"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:3013
-msgid ""
-"RMS threshold factor is < 1\n"
-"Too many points might be highlighted"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:3197
-msgid "GCP Manager settings saved to file '%s'."
-msgstr "Pengaturan profil disimpan ke dalam berkas '%s'."
-#: ../gui/wxpython/gcp/statusbar.py:38
-msgid "Go to GCP No."
-msgstr ""
-#: ../gui/wxpython/gcp/statusbar.py:55
-#, fuzzy
-msgid "Valid Range:"
-msgstr "Rentang yang valid"
-#: ../gui/wxpython/gcp/statusbar.py:121
-#, fuzzy
-msgid "RMS error"
-msgstr "Kesalahan RMS"
-#: ../gui/wxpython/gcp/statusbar.py:125
-#, python-format
-msgid "Forward: %(forw)s, Backward: %(back)s"
-msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:50
-#, fuzzy
-msgid "GRASS GIS Manage Ground Control Points"
-#: ../gui/wxpython/gcp/mapdisplay.py:176
-#, fuzzy
-msgid "GCP List"
-msgstr "Daftar "
-#: ../gui/wxpython/gcp/mapdisplay.py:181
-#, fuzzy
-msgid "Source Display"
-msgstr "Hapus tampilan"
-#: ../gui/wxpython/gcp/mapdisplay.py:185
-#, fuzzy
-msgid "Target Display"
-#: ../gui/wxpython/gcp/mapdisplay.py:261
-#: ../gui/wxpython/rlisetup/sampling_frame.py:102
-#: ../gui/wxpython/iclass/frame.py:312 ../gui/wxpython/mapdisp/frame.py:510
-#: ../gui/wxpython/mapswipe/frame.py:291
-msgid "Map Toolbar"
-msgstr "Map Toolbar"
-#: ../gui/wxpython/gcp/mapdisplay.py:275
-#, fuzzy
-msgid "GCP Display toolbar"
-msgstr "Tampilkan peta"
-#: ../gui/wxpython/gcp/mapdisplay.py:288
-#, fuzzy
-msgid "GCP Manager toolbar"
-msgstr "Kelola warna"
-#: ../gui/wxpython/gcp/mapdisplay.py:382 ../gui/wxpython/mapdisp/frame.py:805
-#: ../gui/wxpython/mapswipe/frame.py:550
-#, fuzzy
-msgid "Nothing to render (empty map). Operation canceled."
-msgstr "Tidak ada layer peta terpilih. Operasi digagalkan."
-#: ../gui/wxpython/gcp/mapdisplay.py:397 ../gui/wxpython/mapdisp/frame.py:646
-#: ../gui/wxpython/gmodeler/frame.py:652 ../gui/wxpython/mapswipe/frame.py:556
-#: ../gui/wxpython/modules/histogram.py:471
-msgid "Choose a file name to save the image (no need to add extension)"
-msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:426 ../gui/wxpython/psmap/toolbars.py:76
-#: ../gui/wxpython/mapdisp/frame.py:816 ../gui/wxpython/wxplot/base.py:610
-#: ../gui/wxpython/modules/histogram.py:500
-#: ../gui/wxpython/menustrings.py:1985
-msgid "Page setup"
-msgstr "Pengaturan halaman"
-#: ../gui/wxpython/gcp/mapdisplay.py:430 ../gui/wxpython/mapdisp/frame.py:820
-#: ../gui/wxpython/wxplot/base.py:611 ../gui/wxpython/modules/histogram.py:504
-msgid "Print preview"
-msgstr "Tampilan cetak"
-#: ../gui/wxpython/gcp/mapdisplay.py:434 ../gui/wxpython/mapdisp/frame.py:824
-#: ../gui/wxpython/wxplot/base.py:612 ../gui/wxpython/gui_core/toolbars.py:67
-#: ../gui/wxpython/modules/histogram.py:508
-msgid "Print display"
-msgstr "Cetak tampilan"
-#: ../gui/wxpython/gcp/mapdisplay.py:474
-msgid "Zoom to computational region (set with g.region)"
-#: ../gui/wxpython/gcp/mapdisplay.py:479 ../gui/wxpython/mapdisp/frame.py:1388
-msgid "Zoom to default region"
-msgstr "Perbesaran sesuai dengan region standar"
-#: ../gui/wxpython/gcp/mapdisplay.py:483 ../gui/wxpython/mapdisp/frame.py:1390
-msgid "Zoom to saved region"
-msgstr "Perbesaran sesuai dengan region tersimpan"
-#: ../gui/wxpython/gcp/mapdisplay.py:488
-msgid "Set computational region from display"
-msgstr "Set region komputasi berdasarkan tampilan"
-#: ../gui/wxpython/gcp/mapdisplay.py:493 ../gui/wxpython/mapdisp/frame.py:1400
-msgid "Save display geometry to named region"
-msgstr "Simpan geometri tampilan ke region tertentu"
-#: ../gui/wxpython/psmap/dialogs.py:218
-msgid "Units:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:229
-msgid ""
-"Position of the top left corner\n"
-"from the top left edge of the paper"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:231
-#: ../gui/wxpython/animation/dialogs.py:1137
-#, fuzzy
-msgid "X:"
-msgstr "X:"
-#: ../gui/wxpython/psmap/dialogs.py:233
-#: ../gui/wxpython/animation/dialogs.py:1139
-#, fuzzy
-msgid "Y:"
-msgstr "X:"
-#: ../gui/wxpython/psmap/dialogs.py:258
-#, fuzzy
-msgid "Position is given:"
-msgstr "Proyeksi:"
-#: ../gui/wxpython/psmap/dialogs.py:260
-#, fuzzy
-msgid "relative to paper"
-msgstr "Karakteristik"
-#: ../gui/wxpython/psmap/dialogs.py:262
-#, fuzzy
-msgid "by map coordinates"
-#: ../gui/wxpython/psmap/dialogs.py:292
-msgid ""
-"Position from the top left\n"
-"edge of the paper"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:383
-#, fuzzy
-msgid "Font:"
-msgstr "Tema ikon:"
-#: ../gui/wxpython/psmap/dialogs.py:385 ../gui/wxpython/psmap/dialogs.py:4966
-#: ../gui/wxpython/gui_core/dialogs.py:2471
-#, fuzzy
-msgid "Font size:"
-#: ../gui/wxpython/psmap/dialogs.py:411
-#, fuzzy
-msgid "Choose color:"
-#: ../gui/wxpython/psmap/dialogs.py:460
-#, fuzzy
-msgid "Close dialog and apply changes"
-msgstr "Tutup dialog dan abaikan perubahan"
-#: ../gui/wxpython/psmap/dialogs.py:462 ../gui/wxpython/wxplot/dialogs.py:838
-#: ../gui/wxpython/wxplot/dialogs.py:1433
-#: ../gui/wxpython/vdigit/preferences.py:70
-#: ../gui/wxpython/gmodeler/preferences.py:696
-#: ../gui/wxpython/gui_core/preferences.py:101
-msgid "Close dialog and ignore changes"
-#: ../gui/wxpython/psmap/dialogs.py:466 ../gui/wxpython/vdigit/dialogs.py:151
-#: ../gui/wxpython/web_services/dialogs.py:684
-#, fuzzy
-msgid "Apply changes"
-msgstr "Simpan perubahan"
-#: ../gui/wxpython/psmap/dialogs.py:511
-msgid "Units"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:512
-#: ../gui/wxpython/animation/dialogs.py:926
-msgid "Format"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:513
-#, fuzzy
-msgid "Orientation"
-msgstr "Rotasi:"
-#: ../gui/wxpython/psmap/dialogs.py:514 ../gui/wxpython/psmap/dialogs.py:2875
-#, fuzzy
-msgid "Width"
-msgstr "Lebar:"
-#: ../gui/wxpython/psmap/dialogs.py:515
-#, fuzzy
-msgid "Height"
-msgstr "Berat:"
-#: ../gui/wxpython/psmap/dialogs.py:516
-msgid "Left"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:517
-#, fuzzy
-msgid "Right"
-msgstr "Penyorotan"
-#: ../gui/wxpython/psmap/dialogs.py:518
-#: ../gui/wxpython/location_wizard/dialogs.py:276
-msgid "Top"
-msgstr "Atas"
-#: ../gui/wxpython/psmap/dialogs.py:519
-#: ../gui/wxpython/location_wizard/dialogs.py:284
-msgid "Bottom"
-msgstr "Bawah"
-#: ../gui/wxpython/psmap/dialogs.py:581
-msgid "Literal is not allowed!"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:582 ../gui/wxpython/psmap/dialogs.py:1408
-#: ../gui/wxpython/psmap/dialogs.py:1432 ../gui/wxpython/psmap/dialogs.py:1483
-#: ../gui/wxpython/psmap/dialogs.py:5091 ../gui/wxpython/wxplot/dialogs.py:602
-#: ../gui/wxpython/animation/controller.py:295
-#: ../gui/wxpython/animation/dialogs.py:743
-#, fuzzy
-msgid "Invalid input"
-msgstr "Region tidak valid"
-#: ../gui/wxpython/psmap/dialogs.py:595
-#, fuzzy
-msgid "Page size"
-#: ../gui/wxpython/psmap/dialogs.py:599
-msgid "Margins"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:606
-#, fuzzy
-msgid "Portrait"
-msgstr "Titik "
-#, fuzzy
-msgid "Landscape"
-msgstr "Analisis lansekap"
-#: ../gui/wxpython/psmap/dialogs.py:689 ../gui/wxpython/psmap/dialogs.py:710
-#: ../gui/wxpython/location_wizard/wizard.py:2177
-#, fuzzy
-msgid "custom"
-msgstr "Bebas min."
-#: ../gui/wxpython/psmap/dialogs.py:752
-#, fuzzy
-msgid "Map settings"
-msgstr "Pengaturan umum"
-#: ../gui/wxpython/psmap/dialogs.py:762
-#, fuzzy
-msgid "Map frame settings"
-msgstr "Pengaturan raster"
-#: ../gui/wxpython/psmap/dialogs.py:820 ../gui/wxpython/psmap/dialogs.py:874
-#: ../gui/wxpython/psmap/toolbars.py:82 ../gui/wxpython/menustrings.py:2000
-#, fuzzy
-msgid "Map frame"
-msgstr "Skala peta"
-#: ../gui/wxpython/psmap/dialogs.py:880
-#, fuzzy
-msgid "Map frame options:"
-msgstr "Pengaturan proyeksi"
-#: ../gui/wxpython/psmap/dialogs.py:881
-#, fuzzy
-msgid "fit frame to match selected map"
-msgstr "Perbesaran sesuai peta terpilih "
-#: ../gui/wxpython/psmap/dialogs.py:882
-#, fuzzy
-msgid "fit frame to match saved region"
-#: ../gui/wxpython/psmap/dialogs.py:883
-#, fuzzy
-msgid "fit frame to match current computational region"
-#: ../gui/wxpython/psmap/dialogs.py:884
-msgid "fixed scale and map center"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:901 ../gui/wxpython/psmap/dialogs.py:1211
-#, fuzzy
-msgid "Map selection"
-#: ../gui/wxpython/psmap/dialogs.py:914 ../gui/wxpython/psmap/dialogs.py:1702
-#, fuzzy
-msgid "Map:"
-msgstr "Mapset:"
-#, fuzzy
-msgid "Region:"
-msgstr "Region "
-#: ../gui/wxpython/psmap/dialogs.py:971
-#, fuzzy
-msgid "Map scale and center"
-#: ../gui/wxpython/psmap/dialogs.py:975
-#, fuzzy
-msgid "Center:"
-msgstr "Render"
-#: ../gui/wxpython/psmap/dialogs.py:976
-#, fuzzy
-msgid "E:"
-msgstr "X:"
-#: ../gui/wxpython/psmap/dialogs.py:977
-#, fuzzy
-msgid "N:"
-msgstr "X:"
-#: ../gui/wxpython/psmap/dialogs.py:984 ../gui/wxpython/psmap/dialogs.py:5847
-#, fuzzy
-msgid "Scale:"
-msgstr "Gaya:"
-#: ../gui/wxpython/psmap/dialogs.py:985
-msgid "1 :"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1049
-msgid "Map max resolution (dpi):"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1086 ../gui/wxpython/psmap/dialogs.py:3696
-#, fuzzy
-msgid "Border"
-msgstr "Orde 1 "
-#: ../gui/wxpython/psmap/dialogs.py:1092
-msgid "draw border around map frame"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1099
-#, fuzzy
-msgid "border color:"
-msgstr "Warna garis"
-#: ../gui/wxpython/psmap/dialogs.py:1101
-#, fuzzy
-msgid "border width (pts):"
-msgstr "Lebar garis (dalam piksel)"
-#: ../gui/wxpython/psmap/dialogs.py:1220
-msgid ""
-"Region is set to match this map,\n"
-"raster or vector map must be added later"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1227
-#, fuzzy
-msgid "Region selection"
-msgstr "Potongan melintang"
-#: ../gui/wxpython/psmap/dialogs.py:1407
-#, fuzzy
-msgid "No map selected!"
-msgstr "Tidak ada layer peta yang dipilih untuk kueri."
-#: ../gui/wxpython/psmap/dialogs.py:1431
-#, fuzzy
-msgid "No region selected!"
-#: ../gui/wxpython/psmap/dialogs.py:1482
-msgid "Invalid scale or map center!"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1527
-#: ../gui/wxpython/lmgr/layertree.py:1015
-#: ../gui/wxpython/nviz/mapwindow.py:1675 ../gui/wxpython/nviz/tools.py:827
-#: ../gui/wxpython/menustrings.py:2002
-#, fuzzy
-msgid "Raster map"
-msgstr "Peta raster:"
-#: ../gui/wxpython/psmap/dialogs.py:1552
-#, fuzzy
-msgid "Choose raster map"
-#: ../gui/wxpython/psmap/dialogs.py:1557
-#, fuzzy
-msgid "no raster map"
-#: ../gui/wxpython/psmap/dialogs.py:1560
-#, fuzzy
-msgid "raster:"
-msgstr "raster"
-#: ../gui/wxpython/psmap/dialogs.py:1622 ../gui/wxpython/psmap/frame.py:635
-#: ../gui/wxpython/psmap/frame.py:660
-msgid "Please, create map frame first."
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1685 ../gui/wxpython/gmodeler/model.py:797
-#, fuzzy
-msgid "Vector maps"
-msgstr "Titik perturbasi"
-#: ../gui/wxpython/psmap/dialogs.py:1698
-#, fuzzy
-msgid "Add map"
-msgstr "Tambahkan grup layer"
-#: ../gui/wxpython/psmap/dialogs.py:1706 ../gui/wxpython/psmap/dialogs.py:2167
-#, fuzzy
-msgid "points"
-msgstr "Titik "
-#: ../gui/wxpython/psmap/dialogs.py:1706 ../gui/wxpython/psmap/dialogs.py:2169
-#, fuzzy
-msgid "lines"
-msgstr "Garis"
-#, fuzzy
-msgid "areas"
-#: ../gui/wxpython/psmap/dialogs.py:1712
-#, fuzzy
-msgid "Data Type"
-msgstr "Tipe data"
-#: ../gui/wxpython/psmap/dialogs.py:1717 ../gui/wxpython/dbmgr/base.py:2346
-#: ../gui/wxpython/animation/dialogs.py:776
-msgid "Add"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1746
-#, fuzzy
-msgid "Manage vector maps"
-msgstr "Bersihkan peta vektor"
-#: ../gui/wxpython/psmap/dialogs.py:1751
-msgid "The topmost vector map overlaps the others"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1755 ../gui/wxpython/psmap/dialogs.py:3653
-#: ../gui/wxpython/web_services/widgets.py:255
-msgid "Up"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1756 ../gui/wxpython/psmap/dialogs.py:3654
-#: ../gui/wxpython/web_services/widgets.py:257
-msgid "Down"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1757 ../gui/wxpython/nviz/tools.py:1364
-#: ../gui/wxpython/nviz/tools.py:2367 ../gui/wxpython/nviz/tools.py:2419
-#: ../gui/wxpython/menustrings.py:172 ../gui/wxpython/menustrings.py:1157
-#: ../gui/wxpython/menustrings.py:2018
-msgid "Delete"
-msgstr "Hapus "
-#: ../gui/wxpython/psmap/dialogs.py:1758
-#, fuzzy
-msgid "Properties..."
-#: ../gui/wxpython/psmap/dialogs.py:2001
-#, fuzzy
-msgid "Raster map settings"
-#: ../gui/wxpython/psmap/dialogs.py:2049
-#, fuzzy
-msgid "Vector maps settings"
-msgstr "Pengaturan teks"
-#: ../gui/wxpython/psmap/dialogs.py:2097
-msgid "%s properties"
-#: ../gui/wxpython/psmap/dialogs.py:2152
-#, fuzzy
-msgid "Data selection"
-#: ../gui/wxpython/psmap/dialogs.py:2163
-#: ../gui/wxpython/gui_core/forms.py:2007
-#: ../gui/wxpython/modules/import_export.py:75
-#, fuzzy
-msgid "Feature type"
-msgstr "ID Fitur"
-#: ../gui/wxpython/psmap/dialogs.py:2167
-#, fuzzy
-msgid "centroids"
-msgstr "Tambahkan centroid"
-#: ../gui/wxpython/psmap/dialogs.py:2169
-#, fuzzy
-msgid "boundaries"
-msgstr "Edit garis/batas "
-#: ../gui/wxpython/psmap/dialogs.py:2207
-#, fuzzy
-msgid "Layer selection"
-#: ../gui/wxpython/psmap/dialogs.py:2214
-msgid "Database connection is not defined in DB file."
-msgstr "Koneksi basisdata tidak didefinisikan dalam berkas DB"
-#: ../gui/wxpython/psmap/dialogs.py:2215
-#, fuzzy
-msgid "Select layer:"
-msgstr "Pilih garis"
-#: ../gui/wxpython/psmap/dialogs.py:2244
-msgid "list of categories (e.g. 1,3,5-7)"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2297 ../gui/wxpython/nviz/tools.py:977
-#: ../gui/wxpython/nviz/tools.py:2817 ../gui/wxpython/menustrings.py:323
-#: ../gui/wxpython/menustrings.py:1229
-msgid "Mask"
-msgstr "Mask"
-#: ../gui/wxpython/psmap/dialogs.py:2301
-#, fuzzy
-msgid "Use current mask"
-msgstr "Tutup workspace saat ini"
-#: ../gui/wxpython/psmap/dialogs.py:2320 ../gui/wxpython/psmap/dialogs.py:2476
-#, fuzzy
-msgid "Colors"
-msgstr "Warna"
-#: ../gui/wxpython/psmap/dialogs.py:2329 ../gui/wxpython/psmap/dialogs.py:2485
-#, fuzzy
-msgid "Outline"
-msgstr "Garis"
-#: ../gui/wxpython/psmap/dialogs.py:2334 ../gui/wxpython/psmap/dialogs.py:2495
-msgid "draw outline"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2337 ../gui/wxpython/psmap/dialogs.py:2500
-#: ../gui/wxpython/psmap/dialogs.py:5272 ../gui/wxpython/psmap/dialogs.py:5280
-#, fuzzy
-msgid "Width (pts):"
-msgstr "Lebar:"
-#: ../gui/wxpython/psmap/dialogs.py:2401 ../gui/wxpython/psmap/dialogs.py:2562
-#: ../gui/wxpython/wxplot/dialogs.py:1137
-#: ../gui/wxpython/wxplot/dialogs.py:1218
-#, fuzzy
-msgid "Fill"
-msgstr "Berkas"
-#: ../gui/wxpython/psmap/dialogs.py:2406
-#, fuzzy
-msgid "fill color"
-#: ../gui/wxpython/psmap/dialogs.py:2412 ../gui/wxpython/psmap/dialogs.py:2570
-#, fuzzy
-msgid "choose color:"
-#: ../gui/wxpython/psmap/dialogs.py:2427 ../gui/wxpython/psmap/dialogs.py:2586
-msgid "color from map table column:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2498
-msgid "No effect for fill color from table column"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2567
-#, fuzzy
-msgid "Color of lines:"
-#: ../gui/wxpython/psmap/dialogs.py:2634 ../gui/wxpython/psmap/dialogs.py:2866
-#: ../gui/wxpython/psmap/dialogs.py:2991
-#, fuzzy
-msgid "Size and style"
-msgstr "Bentuk garis"
-#: ../gui/wxpython/psmap/dialogs.py:2648 ../gui/wxpython/nviz/tools.py:1717
-#, fuzzy
-msgid "symbol:"
-#: ../gui/wxpython/psmap/dialogs.py:2662
-#, fuzzy
-msgid "eps file:"
-msgstr "Berkas WKT:"
-#: ../gui/wxpython/psmap/dialogs.py:2666 ../gui/wxpython/psmap/dialogs.py:3008
-#: ../gui/wxpython/psmap/dialogs.py:5783 ../gui/wxpython/nviz/tools.py:626
-#: ../gui/wxpython/animation/dialogs.py:508
-#: ../gui/wxpython/animation/dialogs.py:1080
-#: ../gui/wxpython/animation/dialogs.py:1198
-#: ../gui/wxpython/animation/dialogs.py:1234
-#: ../gui/wxpython/animation/dialogs.py:1258
-#: ../gui/wxpython/animation/dialogs.py:1289
-#: ../gui/wxpython/location_wizard/wizard.py:113
-#: ../gui/wxpython/location_wizard/wizard.py:1273
-#: ../gui/wxpython/location_wizard/wizard.py:1349
-#: ../gui/wxpython/location_wizard/wizard.py:1439
-#: ../gui/wxpython/location_wizard/wizard.py:1667
-#: ../gui/wxpython/gui_core/forms.py:1802
-#: ../gui/wxpython/gui_core/forms.py:1886
-#: ../gui/wxpython/gui_core/gselect.py:1176
-#: ../gui/wxpython/gui_core/gselect.py:1490
-#: ../gui/wxpython/gui_core/gselect.py:1506
-#: ../gui/wxpython/gui_core/gselect.py:1553
-#: ../gui/wxpython/gui_core/gselect.py:1589
-#: ../gui/wxpython/modules/import_export.py:745
-msgid "Browse"
-msgstr "Jelajah "
-#: ../gui/wxpython/psmap/dialogs.py:2667 ../gui/wxpython/psmap/dialogs.py:3009
-msgid "Type filename or click browse to choose file"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2668 ../gui/wxpython/psmap/dialogs.py:3010
-#, fuzzy
-msgid "Choose a file"
-msgstr "Pilih berkas workspace"
-#: ../gui/wxpython/psmap/dialogs.py:2717 ../gui/wxpython/psmap/dialogs.py:3791
-#: ../gui/wxpython/psmap/dialogs.py:4839
-#: ../gui/wxpython/wxplot/dialogs.py:1123
-#: ../gui/wxpython/wxplot/dialogs.py:1204
-msgid "Size"
-msgstr "Ukuran"
-#: ../gui/wxpython/psmap/dialogs.py:2722 ../gui/wxpython/nviz/tools.py:1659
-#, fuzzy
-msgid "size:"
-msgstr "Ukuran"
-#: ../gui/wxpython/psmap/dialogs.py:2727
-#, fuzzy
-msgid "size from map table column:"
-msgstr "Hapus semua kolom"
-#: ../gui/wxpython/psmap/dialogs.py:2729
-#, fuzzy
-msgid "scale:"
-msgstr "Skala-ulang "
-#: ../gui/wxpython/psmap/dialogs.py:2794
-#, fuzzy
-msgid "Rotation"
-msgstr "Rotasi:"
-#: ../gui/wxpython/psmap/dialogs.py:2799
-msgid "rotate symbols:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2801
-msgid "counterclockwise in degrees:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2805
-#, fuzzy
-msgid "from map table column:"
-#: ../gui/wxpython/psmap/dialogs.py:2880
-#, fuzzy
-msgid "Set width (pts):"
-#: ../gui/wxpython/psmap/dialogs.py:2897
-#, fuzzy
-msgid "multiply width by category value"
-msgstr "Mengubah nilai kategori secara interaktif "
-#: ../gui/wxpython/psmap/dialogs.py:2929 ../gui/wxpython/psmap/dialogs.py:6794
-#: ../gui/wxpython/wxplot/dialogs.py:1072
-msgid "Line style"
-#: ../gui/wxpython/psmap/dialogs.py:2934
-#, fuzzy
-msgid "Choose line style:"
-#: ../gui/wxpython/psmap/dialogs.py:2947
-#, fuzzy
-msgid "Choose linecap:"
-#: ../gui/wxpython/psmap/dialogs.py:3000
-#, fuzzy
-msgid "Pattern"
-msgstr "raster"
-#: ../gui/wxpython/psmap/dialogs.py:3005
-msgid "use pattern:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3007
-#, fuzzy
-msgid "Choose pattern file:"
-#: ../gui/wxpython/psmap/dialogs.py:3015
-#, fuzzy
-msgid "pattern line width (pts):"
-#: ../gui/wxpython/psmap/dialogs.py:3019
-msgid "pattern scale factor:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3379
-#, fuzzy
-msgid "Raster legend"
-msgstr "Seri raster"
-#: ../gui/wxpython/psmap/dialogs.py:3384
-#: ../gui/wxpython/animation/dialogs.py:473
-#, fuzzy
-msgid "Show raster legend"
-msgstr "Tampilkan legenda"
-#: ../gui/wxpython/psmap/dialogs.py:3398
-#, fuzzy
-msgid "Source raster"
-msgstr "Nama kolom"
-#: ../gui/wxpython/psmap/dialogs.py:3403
-#, fuzzy
-msgid "current raster"
-msgstr "Vektor ke raster "
-#: ../gui/wxpython/psmap/dialogs.py:3406
-#, fuzzy
-msgid "select raster"
-msgstr "Peta raster hasil kode-ulang:"
-#: ../gui/wxpython/psmap/dialogs.py:3413 ../gui/wxpython/psmap/dialogs.py:4428
-#, python-format
-msgid "%(rast)s: type %(type)s"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3462
-#, fuzzy
-msgid "Type of legend"
-#: ../gui/wxpython/psmap/dialogs.py:3467
-msgid "discrete legend (categorical maps)"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3471
-msgid "continuous color gradient legend (floating point map)"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3497
-#, fuzzy
-msgid "Advanced legend settings"
-msgstr "Pengaturan lebih lanjut"
-#: ../gui/wxpython/psmap/dialogs.py:3502
-msgid "draw \"no data\" box"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3511
-msgid "draw ticks across color table"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3524
-#: ../gui/wxpython/modules/colorrules.py:972
-#: ../gui/wxpython/modules/colorrules.py:1654
-#: ../gui/wxpython/modules/colorrules.py:1658
-#, fuzzy
-msgid "range"
-msgstr "Garis"
-#: ../gui/wxpython/psmap/dialogs.py:3603
-#, fuzzy
-msgid "Vector legend"
-#: ../gui/wxpython/psmap/dialogs.py:3608
-#, fuzzy
-msgid "Show vector legend"
-#: ../gui/wxpython/psmap/dialogs.py:3622
-#, fuzzy
-msgid "Source vector maps"
-msgstr "Tumpang-susun peta vektor"
-#: ../gui/wxpython/psmap/dialogs.py:3627
-msgid "Choose vector maps and their order in legend"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3631
-#: ../gui/wxpython/lmgr/layertree.py:1019 ../gui/wxpython/nviz/tools.py:1453
-#: ../gui/wxpython/menustrings.py:2004
-#, fuzzy
-msgid "Vector map"
-msgstr "Peta vektor baru"
-#: ../gui/wxpython/psmap/dialogs.py:3632
-#: ../gui/wxpython/gmodeler/dialogs.py:492
-#: ../gui/wxpython/gmodeler/dialogs.py:604
-#: ../gui/wxpython/gmodeler/frame.py:1790
-#, fuzzy
-msgid "Label"
-msgstr "Layer"
-#: ../gui/wxpython/psmap/dialogs.py:3655 ../gui/wxpython/psmap/dialogs.py:4135
-#, fuzzy
-msgid "Edit label"
-msgstr "Tambahkan label"
-#: ../gui/wxpython/psmap/dialogs.py:3701
-msgid "draw border around legend"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3759
-msgid "Size and position"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3785 ../gui/wxpython/psmap/dialogs.py:4505
-#: ../gui/wxpython/psmap/dialogs.py:4783 ../gui/wxpython/psmap/dialogs.py:5364
-#: ../gui/wxpython/psmap/dialogs.py:5372 ../gui/wxpython/psmap/dialogs.py:5932
-#: ../gui/wxpython/psmap/dialogs.py:5941 ../gui/wxpython/psmap/dialogs.py:6516
-#: ../gui/wxpython/psmap/dialogs.py:6525 ../gui/wxpython/nviz/tools.py:1050
-#: ../gui/wxpython/nviz/tools.py:2021
-#, fuzzy
-msgid "Position"
-msgstr "Deskripsi"
-#: ../gui/wxpython/psmap/dialogs.py:3818
-#: ../gui/wxpython/rdigit/toolbars.py:100
-#: ../gui/wxpython/nviz/preferences.py:559
-#: ../gui/wxpython/gmodeler/preferences.py:184
-#: ../gui/wxpython/gmodeler/preferences.py:350
-#: ../gui/wxpython/gmodeler/preferences.py:462
-#: ../gui/wxpython/gmodeler/preferences.py:578
-#: ../gui/wxpython/gui_core/dialogs.py:1933
-msgid "Width:"
-msgstr "Lebar:"
-#: ../gui/wxpython/psmap/dialogs.py:3829
-msgid "Leave the edit field empty, to use default values."
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3836 ../gui/wxpython/psmap/dialogs.py:4053
-#: ../gui/wxpython/psmap/dialogs.py:4844 ../gui/wxpython/nviz/tools.py:366
-#: ../gui/wxpython/nviz/tools.py:1285 ../gui/wxpython/nviz/tools.py:2126
-#: ../gui/wxpython/gmodeler/preferences.py:210
-#: ../gui/wxpython/gmodeler/preferences.py:376
-#: ../gui/wxpython/gmodeler/preferences.py:488
-#: ../gui/wxpython/gmodeler/preferences.py:604
-#: ../gui/wxpython/gui_core/dialogs.py:1937
-#, fuzzy
-msgid "Height:"
-msgstr "Berat:"
-#: ../gui/wxpython/psmap/dialogs.py:3869
-msgid ""
-"Width of the color symbol (for lines)\n"
-"in front of the legend text"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3875 ../gui/wxpython/psmap/dialogs.py:4040
-#, fuzzy
-msgid "Columns:"
-msgstr "Volume"
-#: ../gui/wxpython/psmap/dialogs.py:3885
-#, fuzzy
-msgid "column span:"
-msgstr "Tambah kolom"
-#: ../gui/wxpython/psmap/dialogs.py:3887
-msgid ""
-"Column separation distance between the left edges\n"
-"of two columns in a multicolumn legend"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3934 ../gui/wxpython/psmap/dialogs.py:4541
-#: ../gui/wxpython/psmap/dialogs.py:5205 ../gui/wxpython/wxplot/dialogs.py:751
-#: ../gui/wxpython/gui_core/dialogs.py:2416
-#: ../gui/wxpython/gui_core/preferences.py:472
-#: ../gui/wxpython/gui_core/preferences.py:752
-msgid "Font settings"
-msgstr "Jenis huruf"
-#: ../gui/wxpython/psmap/dialogs.py:4134
-msgid "Edit legend label:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4181
-#, fuzzy
-msgid "No raster map selected!"
-#: ../gui/wxpython/psmap/dialogs.py:4182
-#, fuzzy
-msgid "No raster"
-msgstr "raster"
-#: ../gui/wxpython/psmap/dialogs.py:4472
-#, fuzzy
-msgid "Mapinfo settings"
-#: ../gui/wxpython/psmap/dialogs.py:4576
-#, fuzzy
-msgid "Color settings"
-#: ../gui/wxpython/psmap/dialogs.py:4582
-msgid "use border color:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4584
-#, fuzzy
-msgid "use background color:"
-msgstr "Background peta vektor"
-#: ../gui/wxpython/psmap/dialogs.py:4843
-#, fuzzy
-msgid "Length:"
-msgstr "panjang"
-#: ../gui/wxpython/psmap/dialogs.py:4849
-msgid "Scalebar length is given in map units"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4854
-msgid "Scalebar height is real height on paper"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4856
-#, fuzzy
-msgid "default"
-msgstr "&Tentukan standar"
-#: ../gui/wxpython/psmap/dialogs.py:4929
-#: ../gui/wxpython/wxplot/dialogs.py:1164
-#: ../gui/wxpython/wxplot/dialogs.py:1245
-msgid "Style"
-msgstr "Gaya"
-#: ../gui/wxpython/psmap/dialogs.py:4933
-#, fuzzy
-msgid "Type:"
-msgstr "Tipe"
-#: ../gui/wxpython/psmap/dialogs.py:4952
-#, fuzzy
-msgid "Number of segments:"
-msgstr "Ubah nama mapset"
-#: ../gui/wxpython/psmap/dialogs.py:4958
-msgid "Label every "
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4959
-#, fuzzy
-msgid "segments"
-msgstr "Legenda"
-#: ../gui/wxpython/psmap/dialogs.py:4972
-msgid "transparent text background"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5090
-msgid "Length of scale bar is not defined"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5172 ../gui/wxpython/psmap/dialogs.py:5181
-#: ../gui/wxpython/psmap/toolbars.py:91
-#: ../gui/wxpython/animation/dialogs.py:1537
-#: ../gui/wxpython/menustrings.py:2012
-#, fuzzy
-msgid "Text"
-msgstr "Tes"
-#: ../gui/wxpython/psmap/dialogs.py:5184
-msgid "Enter text:"
-msgstr "Masukkan teks:"
-#: ../gui/wxpython/psmap/dialogs.py:5255
-#, fuzzy
-msgid "Text effects"
-#: ../gui/wxpython/psmap/dialogs.py:5261
-msgid "text background"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5266
-#, fuzzy
-msgid "highlight"
-msgstr "Menyorot"
-#: ../gui/wxpython/psmap/dialogs.py:5275
-#, fuzzy
-msgid "text border"
-msgstr "Orde 1 "
-#: ../gui/wxpython/psmap/dialogs.py:5384
-msgid "Offset"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5388
-msgid "horizontal (pts):"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5390
-msgid "vertical (pts):"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5429
-#, fuzzy
-msgid " Reference point"
-msgstr "Klik kiri: titik baru"
-#: ../gui/wxpython/psmap/dialogs.py:5483
-#, fuzzy
-msgid "Text rotation"
-#: ../gui/wxpython/psmap/dialogs.py:5489
-msgid "rotate text (counterclockwise)"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5581
-msgid "No text entered!"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5581 ../gui/wxpython/lmgr/layertree.py:974
-#: ../gui/wxpython/gis_set.py:277 ../gui/wxpython/gis_set.py:672
-#: ../gui/wxpython/gis_set.py:716 ../gui/wxpython/vdigit/dialogs.py:253
-#: ../gui/wxpython/vdigit/dialogs.py:447
-#: ../gui/wxpython/gmodeler/frame.py:1086
-#: ../gui/wxpython/location_wizard/dialogs.py:142
-#: ../gui/wxpython/location_wizard/dialogs.py:161
-#: ../gui/wxpython/location_wizard/dialogs.py:490
-#: ../gui/wxpython/location_wizard/wizard.py:603
-#: ../gui/wxpython/location_wizard/wizard.py:792
-#: ../gui/wxpython/location_wizard/wizard.py:1941
-#: ../gui/wxpython/core/workspace.py:1610 ../gui/wxpython/core/gcmd.py:113
-#: ../gui/wxpython/gui_core/preferences.py:238
-#: ../gui/wxpython/gui_core/preferences.py:1859
-#: ../gui/wxpython/gui_core/preferences.py:1892
-#: ../gui/wxpython/gui_core/preferences.py:1904
-#: ../gui/wxpython/gui_core/preferences.py:1916
-msgid "Error"
-msgstr "Kesalahan "
-#: ../gui/wxpython/psmap/dialogs.py:5707 ../gui/wxpython/psmap/dialogs.py:5769
-#: ../gui/wxpython/psmap/toolbars.py:99
-#: ../gui/wxpython/animation/dialogs.py:1536
-#: ../gui/wxpython/menustrings.py:2014
-#, fuzzy
-msgid "Image"
-msgstr "Citra"
-#: ../gui/wxpython/psmap/dialogs.py:5781 ../gui/wxpython/nviz/tools.py:624
-#, fuzzy
-msgid "Choose a directory:"
-msgstr "Pilih direktori data GRASS:"
-#: ../gui/wxpython/psmap/dialogs.py:5782
-#, fuzzy
-msgid "Choose a directory with images"
-#: ../gui/wxpython/psmap/dialogs.py:5825
-msgid "Note: only EPS format supported"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5841
-#, fuzzy
-msgid "Scale And Rotation"
-msgstr "Skala dan arah Utara"
-#: ../gui/wxpython/psmap/dialogs.py:5882 ../gui/wxpython/psmap/dialogs.py:6464
-#, fuzzy
-msgid "Rotation angle (deg):"
-msgstr "Rotasi:"
-#: ../gui/wxpython/psmap/dialogs.py:5898 ../gui/wxpython/psmap/dialogs.py:6486
-msgid "Counterclockwise rotation in degrees"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6024
-msgid ""
-"PIL\n"
-"missing"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6044
-msgid "Unable to read file %s"
-msgstr "Tidak dapat membaca daftar: %s"
-#: ../gui/wxpython/psmap/dialogs.py:6105
-#, python-format
-msgid "size: %(width)s x %(height)s pts"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6127
-#, fuzzy
-msgid "No image selected."
-#: ../gui/wxpython/psmap/dialogs.py:6231 ../gui/wxpython/psmap/toolbars.py:101
-#: ../gui/wxpython/nviz/tools.py:2332 ../gui/wxpython/menustrings.py:2016
-#, fuzzy
-msgid "North Arrow"
-#: ../gui/wxpython/psmap/dialogs.py:6234
-#, fuzzy
-msgid "North Arrow settings"
-msgstr "Perlihatkan pengaturan "
-#: ../gui/wxpython/psmap/dialogs.py:6245
-msgid "Compute convergence"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6266 ../gui/wxpython/psmap/toolbars.py:103
-#: ../gui/wxpython/vdigit/preferences.py:800
-#: ../gui/wxpython/gui_core/gselect.py:2325
-msgid "Point"
-msgstr "Titik "
-#: ../gui/wxpython/psmap/dialogs.py:6316
-#, fuzzy
-msgid "Symbol"
-#: ../gui/wxpython/psmap/dialogs.py:6323
-#, fuzzy
-msgid "Select symbol:"
-msgstr "Pilih dengan kotak"
-#: ../gui/wxpython/psmap/dialogs.py:6340
-msgid ""
-"Note: Selected symbol is not displayed\n"
-"in draft mode (only in preview mode)"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6365 ../gui/wxpython/psmap/dialogs.py:6725
-#: ../gui/wxpython/iclass/dialogs.py:396 ../gui/wxpython/nviz/tools.py:976
-#: ../gui/wxpython/nviz/tools.py:2816 ../gui/wxpython/wxplot/dialogs.py:1109
-#: ../gui/wxpython/wxplot/dialogs.py:1191
-#: ../gui/wxpython/gmodeler/preferences.py:107
-#: ../gui/wxpython/gmodeler/preferences.py:421
-#: ../gui/wxpython/gmodeler/preferences.py:533
-msgid "Color"
-msgstr "Warna"
-#: ../gui/wxpython/psmap/dialogs.py:6373 ../gui/wxpython/psmap/dialogs.py:6732
-#, fuzzy
-msgid "Outline color:"
-#: ../gui/wxpython/psmap/dialogs.py:6376 ../gui/wxpython/psmap/dialogs.py:6403
-#: ../gui/wxpython/psmap/dialogs.py:6735 ../gui/wxpython/psmap/dialogs.py:6765
-#: ../gui/wxpython/gui_core/dialogs.py:1778
-#, fuzzy
-msgid "transparent"
-msgstr "Transparans"
-#: ../gui/wxpython/psmap/dialogs.py:6400 ../gui/wxpython/psmap/dialogs.py:6762
-#, fuzzy
-msgid "Fill color:"
-#: ../gui/wxpython/psmap/dialogs.py:6439
-#, fuzzy
-msgid "Size and Rotation"
-#: ../gui/wxpython/psmap/dialogs.py:6447
-#, fuzzy
-msgid "Size (pt):"
-msgstr "Ukuran"
-#: ../gui/wxpython/psmap/dialogs.py:6450
-#, fuzzy
-msgid "Symbol size in points"
-#: ../gui/wxpython/psmap/dialogs.py:6685
-#, fuzzy
-msgid "Rectangle settings"
-msgstr "Ubah pengaturan "
-#: ../gui/wxpython/psmap/dialogs.py:6687
-#, fuzzy
-msgid "Line settings"
-#: ../gui/wxpython/psmap/dialogs.py:6821
-#, fuzzy
-msgid "Line width in points"
-#: ../gui/wxpython/psmap/dialogs.py:6895
-#, fuzzy
-msgid "Vector labels"
-msgstr "label vektor"
-#: ../gui/wxpython/psmap/dialogs.py:6915
-msgid "Vector label files created beforehand by v.label module"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6932
-msgid "You can select multiple label files."
-msgstr ""
-#: ../gui/wxpython/psmap/utils.py:105
-msgid "inch"
-msgstr ""
-#: ../gui/wxpython/psmap/utils.py:106 ../gui/wxpython/modules/vclean.py:222
-#, fuzzy
-msgid "point"
-msgstr "Titik "
-#: ../gui/wxpython/psmap/utils.py:107
-#, fuzzy
-msgid "centimeter"
-msgstr "Render"
-#: ../gui/wxpython/psmap/utils.py:108
-#, fuzzy
-msgid "millimeter"
-msgstr "Parameter"
-#: ../gui/wxpython/psmap/utils.py:112
-#, fuzzy
-msgid "meters"
-msgstr "Parameter"
-#: ../gui/wxpython/psmap/utils.py:115
-#, fuzzy
-msgid "kilometers"
-msgstr "Parameter"
-#: ../gui/wxpython/psmap/utils.py:118
-#, fuzzy
-msgid "feet"
-msgstr "Barat"
-#: ../gui/wxpython/psmap/utils.py:121
-#, fuzzy
-msgid "miles"
-msgstr "Berkas"
-#: ../gui/wxpython/psmap/utils.py:124 ../gui/wxpython/psmap/utils.py:128
-msgid "nautical miles"
-msgstr ""
-#: ../gui/wxpython/psmap/utils.py:126
-msgid "pixel"
-msgstr ""
-#: ../gui/wxpython/psmap/utils.py:127
-#, fuzzy
-msgid "meter"
-msgstr "Render"
-#: ../gui/wxpython/psmap/utils.py:130
-#, fuzzy
-msgid "degree"
-msgstr "Vertex"
-#: ../gui/wxpython/psmap/utils.py:397
-#, fuzzy
-msgid "Unable to run `ps.map -b`"
-msgstr "Tidak berhasil memperbaharui peta vektor."
-#: ../gui/wxpython/psmap/instructions.py:139
-msgid ""
-"Unable to open file\n"
-"%s"
-msgstr "Tidak mampu membuka berkas <%s> untuk dibaca."
-#: ../gui/wxpython/psmap/instructions.py:498
-#, python-format
-msgid "Instruction file will be loaded with following region: %s\n"
-msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:504
-#, python-format
-msgid ""
-"Region cannot be set\n"
-"%s"
-msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:664
-#: ../gui/wxpython/psmap/instructions.py:863
-#: ../gui/wxpython/psmap/instructions.py:996
-#: ../gui/wxpython/psmap/instructions.py:1074
-#: ../gui/wxpython/psmap/instructions.py:1248
-#: ../gui/wxpython/psmap/instructions.py:1315
-#: ../gui/wxpython/psmap/instructions.py:1382
-#: ../gui/wxpython/psmap/instructions.py:1466
-#: ../gui/wxpython/psmap/instructions.py:1588
-#: ../gui/wxpython/psmap/instructions.py:1733
-#: ../gui/wxpython/psmap/instructions.py:1787
-#: ../gui/wxpython/psmap/instructions.py:2158
-msgid "Failed to read instruction %s"
-#: ../gui/wxpython/psmap/instructions.py:679
-#, python-format
-msgid ""
-"Scale has changed, old value: %(old)s\n"
-"new value: %(new)s"
-msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:683
-#, python-format
-msgid ""
-"Failed to read instruction %s.\n"
-"Use 1:25000 notation."
-msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:693
-#, python-format
-msgid ""
-"Map frame position changed, old value: %(old1)s %(old2)s\n"
-"new value: %(new1)s %(new2)s"
-msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:704
-#, python-format
-msgid ""
-"Map frame size changed, old value: %(old1)s %(old2)s\n"
-msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:771
-msgid ""
-"Failed to read instruction %(file)s.\n"
-"Unknown format %(for)s"
-#: ../gui/wxpython/psmap/instructions.py:786
-msgid "Failed to read instruction %s."
-#: ../gui/wxpython/psmap/instructions.py:936
-#: ../gui/wxpython/psmap/instructions.py:2006
-#, python-format
-msgid ""
-"Characters on position %s are not supported by ISO-8859-1 (Latin 1) encoding "
-"which is required by module ps.map."
-msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:940
-#: ../gui/wxpython/psmap/instructions.py:2010
-msgid ""
-"Not all characters are supported by ISO-8859-1 (Latin 1) encoding which is "
-"required by module ps.map."
-msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:1077
-msgid "Failed to read instruction %(inst)s: file %(file)s not found."
-#: ../gui/wxpython/psmap/frame.py:53
-#, fuzzy
-msgid "GRASS GIS Cartographic Composer"
-msgstr "Bantuan GRASS GIS GUI"
-#: ../gui/wxpython/psmap/frame.py:213
-msgid ""
-"Python Imaging Library is not available.\n"
-"'Preview' functionality won't work."
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:267
-msgid "Program ps2pdf is not available. Please install it first to create PDF."
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:311
-#, fuzzy
-msgid "Generating PDF..."
-#: ../gui/wxpython/psmap/frame.py:313
-msgid "Generating PostScript..."
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:315
-#, fuzzy
-msgid "Generating preview..."
-#: ../gui/wxpython/psmap/frame.py:332
-#, python-format
-msgid "Ps.map exited with return code %s"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:368
-#, python-format
-msgid "%(prg)s exited with return code %(code)s"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:372
-#, fuzzy
-msgid "PDF generated"
-#: ../gui/wxpython/psmap/frame.py:375
-#, python-format
-msgid ""
-"Program ps2pdf is not available. Please install it to create PDF.\n"
-"\n"
-" %s"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:378
-#, fuzzy
-msgid "PostScript file generated"
-#: ../gui/wxpython/psmap/frame.py:387
-#, fuzzy
-msgid "Generating preview, wait please"
-#: ../gui/wxpython/psmap/frame.py:403
-#, fuzzy
-msgid "Preview not available"
-msgstr "Toolbar digitasi vektor"
-#: ../gui/wxpython/psmap/frame.py:405
-msgid ""
-"Preview is not available probably because Ghostscript is not installed or "
-"not on PATH."
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:408
-msgid "Please follow instructions on GRASS Trac Wiki."
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:419
-msgid "Preview generated"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:451
-#, fuzzy
-msgid "Save file as"
-msgstr "Simpan berkas sebagai ..."
-#: ../gui/wxpython/psmap/frame.py:498
-msgid "Failed to read file %s."
-#: ../gui/wxpython/psmap/frame.py:677
-#, fuzzy
-msgid "Scalebar is not appropriate for this projection"
-msgstr "Masukkan parameter untuk"
-#: ../gui/wxpython/psmap/frame.py:1166
-msgid "Press button with green triangle icon to generate preview."
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1189
-msgid "wxGUI Cartographic Composer"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1240
-msgid "MAP FRAME"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1241
-msgid "RASTER LEGEND"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1242
-msgid "VECTOR LEGEND"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1243
-msgid "MAP INFO"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1244
-msgid "SCALE BAR"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1245
-msgid "IMAGE"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1246
-msgid "NORTH ARROW"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1522
-msgid "Click and drag to resize object"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:2467
-#, fuzzy
-msgid "labels: "
-#: ../gui/wxpython/psmap/toolbars.py:68 ../gui/wxpython/menustrings.py:1990
-msgid "Generate text file with mapping instructions"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:70 ../gui/wxpython/menustrings.py:1988
-msgid "Load text file with mapping instructions"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:72 ../gui/wxpython/menustrings.py:1992
-#, fuzzy
-msgid "Generate PostScript output"
-msgstr "Utilitas output peta dalam bentuk cetak PostScript"
-#: ../gui/wxpython/psmap/toolbars.py:74 ../gui/wxpython/menustrings.py:1994
-#, fuzzy
-msgid "Generate PDF output"
-msgstr "Hasilkan titik"
-#: ../gui/wxpython/psmap/toolbars.py:77 ../gui/wxpython/menustrings.py:1986
-msgid "Specify paper size, margins and orientation"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:79
-msgid "Full extent"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:80
-#, fuzzy
-msgid "Zoom to full extent"
-#: ../gui/wxpython/psmap/toolbars.py:83
-msgid "Click and drag to place map frame"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:85 ../gui/wxpython/menustrings.py:2019
-#, fuzzy
-msgid "Delete selected object"
-msgstr "Hapus location terpilih"
-#: ../gui/wxpython/psmap/toolbars.py:87
-#, fuzzy
-msgid "Show preview"
-msgstr "Tampilkan grid"
-#: ../gui/wxpython/psmap/toolbars.py:89
-#, fuzzy
-msgid "Quit Cartographic Composer"
-#: ../gui/wxpython/psmap/toolbars.py:93 ../gui/wxpython/menustrings.py:2008
-#, fuzzy
-msgid "Map info"
-msgstr "Tambahkan legenda"
-#: ../gui/wxpython/psmap/toolbars.py:95 ../gui/wxpython/wxplot/dialogs.py:1087
-#: ../gui/wxpython/wxplot/dialogs.py:1150
-#: ../gui/wxpython/wxplot/dialogs.py:1231
-msgid "Legend"
-msgstr "Legenda"
-#: ../gui/wxpython/psmap/toolbars.py:97 ../gui/wxpython/nviz/tools.py:2381
-#: ../gui/wxpython/menustrings.py:2010
-#, fuzzy
-msgid "Scale bar"
-msgstr "Tambahkan layer"
-#: ../gui/wxpython/psmap/toolbars.py:105
-#: ../gui/wxpython/vdigit/preferences.py:801
-msgid "Line"
-msgstr "Garis"
-#: ../gui/wxpython/psmap/toolbars.py:107
-#: ../gui/wxpython/rlisetup/wizard.py:1181
-#: ../gui/wxpython/rlisetup/wizard.py:1354
-#: ../gui/wxpython/rlisetup/wizard.py:1444
-#, fuzzy
-msgid "Rectangle"
-msgstr "Pilih dangle"
-#: ../gui/wxpython/psmap/toolbars.py:109
-#, fuzzy
-msgid "Add overlays"
-msgstr "Tambahkan overlay label grid atau vektor"
-#: ../gui/wxpython/psmap/toolbars.py:111 ../gui/wxpython/lmgr/layertree.py:102
-msgid "Add labels"
-#: ../gui/wxpython/psmap/toolbars.py:203
-msgid "Add simple graphics: points"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:219
-msgid "Add simple graphics: lines"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:235
-msgid "Add simple graphics: rectangles"
-msgstr ""
-#: ../gui/wxpython/icons/icon.py:38
-#, python-format
-msgid "Unknown iconset '%s', using default 'grass'...\n"
-msgstr ""
-#: ../gui/wxpython/icons/icon.py:56
-msgid "Unable to load icon theme. Reason: %s. Quiting wxGUI..."
-msgstr "ikon ikon."
-#: ../gui/wxpython/timeline/frame.py:39
-msgid ""
-"The Timeline Tool needs the \"matplotlib\" (python-matplotlib) package to be "
-"installed. {}"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:77
-#, fuzzy
-msgid "GRASS GIS Timeline Tool"
-msgstr "Buat histogram dari berkas citra atau raster"
-#: ../gui/wxpython/timeline/frame.py:133 ../gui/wxpython/tplot/frame.py:276
-#: ../gui/wxpython/nviz/tools.py:850 ../gui/wxpython/nviz/tools.py:1889
-#: ../gui/wxpython/nviz/preferences.py:405
-msgid "Draw"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:135 ../gui/wxpython/tplot/frame.py:279
-#: ../gui/wxpython/menustrings.py:1978 ../gui/wxpython/menustrings.py:2021
-#, fuzzy
-msgid "Help"
-msgstr "Bantuan"
-#: ../gui/wxpython/timeline/frame.py:139
-msgid "3D plot of spatio-temporal extents"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:142
-msgid "3D plot of spatio-temporal extents (matplotlib >= 1.0.0)"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:147
-#, fuzzy
-msgid "Select space time dataset(s):"
-#: ../gui/wxpython/timeline/frame.py:178 ../gui/wxpython/tplot/frame.py:308
-#: ../gui/wxpython/tplot/frame.py:419
-msgid "Dataset <%s> not found in temporal database"
-msgstr "ERROR: Mapset <%s> tidak ada"
-#: ../gui/wxpython/timeline/frame.py:194 ../gui/wxpython/tplot/frame.py:326
-#: ../gui/wxpython/tplot/frame.py:438
-msgid ""
-"Datasets have different temporal type (absolute x relative), which is not "
-"allowed."
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:213 ../gui/wxpython/tplot/frame.py:343
-#: ../gui/wxpython/tplot/frame.py:448
-msgid "Datasets have different time unit which is not allowed."
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:234
-#, python-brace-format
-msgid "Dataset <{name}> is empty"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:292
-#, python-format
-msgid "X [%s]"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:293
-#, python-format
-msgid "Y [%s]"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:295
-#, fuzzy
-msgid "X"
-msgstr "X:"
-#: ../gui/wxpython/timeline/frame.py:296
-#, fuzzy
-msgid "Y"
-msgstr "X:"
-#: ../gui/wxpython/timeline/frame.py:301
-#: ../gui/wxpython/animation/dialogs.py:1967
-#, fuzzy
-msgid "Time"
-msgstr "Catatan waktu"
-#: ../gui/wxpython/timeline/frame.py:371 ../gui/wxpython/tplot/frame.py:591
-#: ../gui/wxpython/tplot/frame.py:638 ../gui/wxpython/tplot/frame.py:676
-msgid "Time [%s]"
-#: ../gui/wxpython/timeline/frame.py:461 ../gui/wxpython/tplot/frame.py:801
-#: ../gui/wxpython/animation/utils.py:70 ../gui/wxpython/animation/utils.py:79
-#: ../gui/wxpython/animation/temporal_manager.py:242
-msgid "Space time dataset <%s> not found."
-#: ../gui/wxpython/timeline/frame.py:476 ../gui/wxpython/tplot/frame.py:816
-#, python-format
-msgid "Please specify the space time dataset <%s>."
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:478 ../gui/wxpython/tplot/frame.py:819
-msgid "Ambiguous dataset name"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:562 ../gui/wxpython/tplot/frame.py:953
-msgid "Space time raster dataset: %s"
-msgstr "Impor peta raster "
-#: ../gui/wxpython/timeline/frame.py:564 ../gui/wxpython/tplot/frame.py:955
-msgid "Space time vector dataset: %s"
-msgstr "Impor peta vektor "
-#: ../gui/wxpython/timeline/frame.py:566 ../gui/wxpython/tplot/frame.py:957
-msgid "Space time 3D raster dataset: %s"
-#: ../gui/wxpython/timeline/frame.py:568
-msgid "Mapset: %s"
-msgstr "Mapset:"
-#: ../gui/wxpython/timeline/frame.py:569
-msgid "Map name: %s"
-#: ../gui/wxpython/timeline/frame.py:571
-#, python-format
-msgid "Start time: %s"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:574
-msgid "End time: %s"
-#: ../gui/wxpython/timeline/frame.py:578
-#, fuzzy
-msgid "WARNING: invalid topology"
-msgstr "Buat/bangun-ulang topologi"
-#: ../gui/wxpython/timeline/frame.py:580
-msgid ""
-"\n"
-"Press Del to dismiss."
-msgstr ""
-msgid ""
-"The Temporal Plot Tool needs the \"matplotlib\" (python-matplotlib) package "
-"to be installed. {}"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:97
-#, fuzzy
-msgid "GRASS GIS Temporal Plot Tool"
-#: ../gui/wxpython/tplot/frame.py:180
-#, fuzzy
-msgid "Raster temporal dataset (strds)"
-#: ../gui/wxpython/tplot/frame.py:187
-msgid "X and Y coordinates separated by comma:"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:199
-msgid ""
-"Coordinates can be obtained for example by right-clicking on Map Display."
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:214
-msgid "STRDS"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:222
-msgid ""
-"Vector temporal dataset (strds)\n"
-"Please press enter if you digit the name instead select with combobox"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:237
-#, fuzzy
-msgid "Select attribute column"
-msgstr "Atribut"
-#: ../gui/wxpython/tplot/frame.py:250
-#, fuzzy
-msgid "Select category of vector(s)"
-msgstr "Pilih fitur vektor"
-#: ../gui/wxpython/tplot/frame.py:268
-msgid "STVDS"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:296 ../gui/wxpython/tplot/frame.py:716
-#: ../gui/wxpython/tplot/frame.py:720 ../gui/wxpython/tplot/frame.py:741
-#: ../gui/wxpython/tplot/frame.py:867
-#, fuzzy
-msgid "Invalid input coordinates"
-#: ../gui/wxpython/tplot/frame.py:385
-msgid "Category {ca} is not on vector map {ma} and it will be used"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:404
-msgid ""
-"Both coordinates and categories are set, coordinates will be used. The use "
-"categories remove text from coordinate form"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:409
-msgid "With Vector temporal dataset you have to select an attribute column"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:461
-msgid ""
-"Difference number of vector layers and maps in the vector temporal dataset"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:503
-msgid "No connection between vector map {vmap} and layer {la}"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:577 ../gui/wxpython/tplot/frame.py:619
-#: ../gui/wxpython/tplot/frame.py:662
-msgid ""
-"Problem getting data from raster temporal dataset. Empty list of values."
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:589 ../gui/wxpython/tplot/frame.py:636
-#: ../gui/wxpython/tplot/frame.py:674
-msgid "Temporal resolution: %s"
-msgstr "Mode kategori"
-#: ../gui/wxpython/tplot/frame.py:709
-msgid "Incorrect coordinates format, should be: x,y"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:725
-#, fuzzy
-msgid "Seed point outside the current region"
-msgstr "Hasilkan area untuk region saat ini"
-#: ../gui/wxpython/tplot/frame.py:737
-#, fuzzy
-msgid "Invalid input raster dataset"
-#: ../gui/wxpython/tplot/frame.py:754
-#, fuzzy
-msgid "Invalid input vector dataset"
-#: ../gui/wxpython/tplot/frame.py:860 ../gui/wxpython/tplot/frame.py:908
-#, fuzzy
-msgid "Invalid input temporal dataset"
-#: ../gui/wxpython/tplot/frame.py:929
-msgid "Datasets have different number of values"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:959
-msgid "Value for {date} is {val}"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:962
-msgid "Press Del to dismiss."
-msgstr ""
-#: ../gui/wxpython/tplot/g.gui.tplot.py:106
-msgid "With stvds you have to set 'attr' option"
-msgstr ""
-#: ../gui/wxpython/tplot/g.gui.tplot.py:110
-msgid ""
-"With stvds it is not possible to use 'coordinates' and 'cats' options "
-"together"
-msgstr ""
-#: ../gui/wxpython/tplot/g.gui.tplot.py:113
-msgid "With stvds you have to use 'coordinates' or 'cats' option"
-msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:42
-#, python-format
-msgid "Welcome to wxGUI Interactive Python Shell %s"
-msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:43
-#, python-format
-msgid "Type %s for more GRASS scripting related information."
-msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:44
-#, python-format
-msgid "Type %s to add raster or vector to the layer tree."
-msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:54
-msgid "Delete all text from the shell"
-msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:57
-#, fuzzy
-msgid "Simple &editor"
-msgstr "Sederhana"
-#: ../gui/wxpython/lmgr/pyshell.py:60 ../gui/wxpython/lmgr/toolbars.py:165
-msgid "Open a simple Python code editor"
-msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:113
-msgid "Raster or vector map <%s> not found"
-#: ../gui/wxpython/lmgr/pyshell.py:120
-msgid "Raster map <%s> added"
-#: ../gui/wxpython/lmgr/pyshell.py:122
-msgid "Vector map <%s> added"
-#: ../gui/wxpython/lmgr/layertree.py:56
-#: ../gui/wxpython/modules/import_export.py:371
-#: ../gui/wxpython/menustrings.py:35 ../gui/wxpython/menustrings.py:1020
-#, fuzzy
-msgid "Import raster data"
-#: ../gui/wxpython/lmgr/layertree.py:58
-#: ../gui/wxpython/modules/import_export.py:369
-#: ../gui/wxpython/menustrings.py:157 ../gui/wxpython/menustrings.py:1142
-#, fuzzy
-msgid "Link external raster data"
-#: ../gui/wxpython/lmgr/layertree.py:60
-#, fuzzy
-msgid "Unpack GRASS raster map"
-msgstr "Gabungkan peta raster"
-#: ../gui/wxpython/lmgr/layertree.py:62
-#, fuzzy
-msgid "Set raster output format"
-msgstr "Pilih jenis huruf"
-#: ../gui/wxpython/lmgr/layertree.py:64
-#: ../gui/wxpython/modules/import_export.py:512
-#: ../gui/wxpython/menustrings.py:65 ../gui/wxpython/menustrings.py:1050
-#, fuzzy
-msgid "Import vector data"
-#: ../gui/wxpython/lmgr/layertree.py:66
-#: ../gui/wxpython/modules/import_export.py:510
-#: ../gui/wxpython/menustrings.py:159 ../gui/wxpython/menustrings.py:1144
-#, fuzzy
-msgid "Link external vector data"
-#: ../gui/wxpython/lmgr/layertree.py:68
-#, fuzzy
-msgid "Unpack GRASS vector map"
-msgstr "Gabungkan peta vektor"
-#: ../gui/wxpython/lmgr/layertree.py:70
-#, fuzzy
-msgid "Set vector output format"
-#: ../gui/wxpython/lmgr/layertree.py:72
-#, fuzzy
-msgid "Import data from WMS server"
-msgstr "Unduh dan impor data dari server WMS."
-#: ../gui/wxpython/lmgr/layertree.py:74
-msgid "Add command layer"
-msgstr "Tambahkan layer perintah"
-#: ../gui/wxpython/lmgr/layertree.py:76
-#: ../gui/wxpython/gui_core/toolbars.py:73 ../gui/wxpython/menustrings.py:1997
-msgid "Quit"
-msgstr "Keluar "
-#: ../gui/wxpython/lmgr/layertree.py:78
-#: ../gui/wxpython/gui_core/toolbars.py:75
-#, fuzzy
-msgid "Add raster map layer"
-msgstr "Tambahkan layer peta raster"
-#: ../gui/wxpython/lmgr/layertree.py:80 ../gui/wxpython/iclass/toolbars.py:58
-#: ../gui/wxpython/gui_core/simplelmgr.py:480
-#, fuzzy
-msgid "Add RGB map layer"
-msgstr "Tambahkan layer RGB"
-#: ../gui/wxpython/lmgr/layertree.py:82
-#, fuzzy
-msgid "Add HIS map layer"
-msgstr "Tambahkan layer HIS"
-#: ../gui/wxpython/lmgr/layertree.py:84
-msgid "Add shaded relief map layer"
-msgstr "Tambahkan layer peta relief berbayang"
-#: ../gui/wxpython/lmgr/layertree.py:86
-msgid "Add raster flow arrows"
-msgstr "Tambahkan panah aliran raster"
-#: ../gui/wxpython/lmgr/layertree.py:88
-msgid "Add raster cell numbers"
-msgstr "Tambahkan nomor sel raster"
-#: ../gui/wxpython/lmgr/layertree.py:90
-#: ../gui/wxpython/gui_core/toolbars.py:77
-#, fuzzy
-msgid "Add vector map layer"
-msgstr "vektor "
-#: ../gui/wxpython/lmgr/layertree.py:92
-#, fuzzy
-msgid "Add thematic (choropleth) vector map layer"
-msgstr "Tambahkan layer diagram tematik"
-#: ../gui/wxpython/lmgr/layertree.py:94
-msgid "Add thematic chart layer"
-#: ../gui/wxpython/lmgr/layertree.py:96
-msgid "Add grid layer"
-msgstr "Tambahkan layer grid"
-#: ../gui/wxpython/lmgr/layertree.py:98
-msgid "Add geodesic line layer"
-msgstr "Tambahkan sebuah layer garis geodesi"
-#: ../gui/wxpython/lmgr/layertree.py:100
-msgid "Add rhumbline layer"
-msgstr "Tambahkan sebuah layer rhumbline"
-#: ../gui/wxpython/lmgr/layertree.py:104
-#: ../gui/wxpython/gui_core/simplelmgr.py:478
-#: ../gui/wxpython/gui_core/simplelmgr.py:479
-#, fuzzy
-msgid "Add 3D raster map layer"
-#: ../gui/wxpython/lmgr/layertree.py:105
-msgid "Note that 3D raster data are rendered only in 3D view mode"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:107
-#, fuzzy
-msgid "Add WMS layer."
-#: ../gui/wxpython/lmgr/layertree.py:109
-#: ../gui/wxpython/animation/dialogs.py:475
-msgid "Set options"
-msgstr "Pilihan pengaturan"
-#: ../gui/wxpython/lmgr/layertree.py:111
-#, fuzzy
-msgid "Editing mode"
-#: ../gui/wxpython/lmgr/layertree.py:113
-#, fuzzy
-msgid "Background vector map"
-#: ../gui/wxpython/lmgr/layertree.py:209
-msgid "Map Layers"
-msgstr "Layer peta"
-#: ../gui/wxpython/lmgr/layertree.py:442 ../gui/wxpython/rlisetup/frame.py:140
-#: ../gui/wxpython/animation/dialogs.py:780
-#: ../gui/wxpython/animation/dialogs.py:1012
-#: ../gui/wxpython/gmodeler/frame.py:1444
-#: ../gui/wxpython/gui_core/simplelmgr.py:463
-#: ../gui/wxpython/menustrings.py:918 ../gui/wxpython/menustrings.py:1824
-msgid "Remove"
-msgstr "Hapus"
-#: ../gui/wxpython/lmgr/layertree.py:451 ../gui/wxpython/rlisetup/frame.py:146
-#: ../gui/wxpython/menustrings.py:170 ../gui/wxpython/menustrings.py:916
-#: ../gui/wxpython/menustrings.py:1155 ../gui/wxpython/menustrings.py:1822
-msgid "Rename"
-msgstr "Ubah nama "
-#: ../gui/wxpython/lmgr/layertree.py:475 ../gui/wxpython/iscatt/frame.py:580
-msgid "Change opacity level"
-msgstr "Ubah tingkat opasitas"
-#: ../gui/wxpython/lmgr/layertree.py:486
-#: ../gui/wxpython/gmodeler/frame.py:1511
-msgid "Properties"
-#: ../gui/wxpython/lmgr/layertree.py:498
-#, fuzzy
-msgid "3D view properties"
-#: ../gui/wxpython/lmgr/layertree.py:509
-#, fuzzy
-msgid "Zoom to selected map(s)"
-#: ../gui/wxpython/lmgr/layertree.py:521
-#, fuzzy
-msgid "Set computational region from selected map(s)"
-msgstr "Tentukan region komputasi dari peta terpilih"
-#: ../gui/wxpython/lmgr/layertree.py:541
-#, fuzzy
-msgid "Export common formats"
-msgstr "Ekspor peta vektor "
-#: ../gui/wxpython/lmgr/layertree.py:558
-#, fuzzy
-msgid "Export PostGIS"
-#: ../gui/wxpython/lmgr/layertree.py:572 ../gui/wxpython/iclass/dialogs.py:790
-#, fuzzy
-msgid "Export attribute table"
-msgstr "Perlihatkan tabel atribut"
-#: ../gui/wxpython/lmgr/layertree.py:587 ../gui/wxpython/lmgr/layertree.py:736
-#, fuzzy
-msgid "Create pack"
-msgstr "Buat RGB "
-#: ../gui/wxpython/lmgr/layertree.py:603 ../gui/wxpython/lmgr/layertree.py:752
-#, fuzzy
-msgid "Make a copy in the current mapset"
-msgstr "Hapus berkas elemen basis data dari mapset saat ini milik pengguna."
-#: ../gui/wxpython/lmgr/layertree.py:608 ../gui/wxpython/lmgr/layertree.py:760
-#: ../gui/wxpython/lmgr/layertree.py:832
-#, fuzzy
-msgid "Set color table"
-msgstr "Tabel warna "
-#: ../gui/wxpython/lmgr/layertree.py:617
-msgid "Show attribute data"
-msgstr "Perlihatkan data atribut"
-#: ../gui/wxpython/lmgr/layertree.py:635
-msgid "Start editing"
-msgstr "Mulai edit"
-#: ../gui/wxpython/lmgr/layertree.py:644
-msgid "Stop editing"
-msgstr "Stop edit"
-#: ../gui/wxpython/lmgr/layertree.py:665
-#, fuzzy
-msgid "Rebuild topology"
-#: ../gui/wxpython/lmgr/layertree.py:698 ../gui/wxpython/lmgr/layertree.py:818
-#: ../gui/wxpython/lmgr/layertree.py:852
-#: ../gui/wxpython/gmodeler/preferences.py:668
-msgid "Metadata"
-msgstr "Metadata"
-#: ../gui/wxpython/lmgr/layertree.py:708
-#, fuzzy
-msgid "Zoom to selected map(s) (ignore NULLs)"
-msgstr "Perbesar ke peta terpilih (abaikan NULL)"
-#: ../gui/wxpython/lmgr/layertree.py:720
-#: ../gui/wxpython/animation/dialogs.py:934 ../gui/wxpython/menustrings.py:946
-#: ../gui/wxpython/menustrings.py:1852
-#, fuzzy
-msgid "Export"
-msgstr "Ekspor MPEG-1"
-#: ../gui/wxpython/lmgr/layertree.py:767
-#, fuzzy
-msgid "Set color table interactively"
-msgstr "Pengkodean-ulang secara interaktif "
-#: ../gui/wxpython/lmgr/layertree.py:776 ../gui/wxpython/menustrings.py:740
-#: ../gui/wxpython/menustrings.py:1646
-msgid "Histogram"
-msgstr "Histogram"
-#: ../gui/wxpython/lmgr/layertree.py:785 ../gui/wxpython/lmgr/layertree.py:841
-#: ../gui/wxpython/menustrings.py:523 ../gui/wxpython/menustrings.py:1429
-msgid "Univariate raster statistics"
-msgstr "Statistik raster univariat"
-#: ../gui/wxpython/lmgr/layertree.py:797
-#, fuzzy
-msgid "Report raster statistics"
-msgstr "Laporan dan statistik."
-#: ../gui/wxpython/lmgr/layertree.py:809
-msgid "Profile"
-msgstr "Profil"
-#: ../gui/wxpython/lmgr/layertree.py:865
-msgid "Save web service layer"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:972
-msgid "Unable to create profile of raster map."
-msgstr "Tidak mampu membuat profil dari peta raster."
-#: ../gui/wxpython/lmgr/layertree.py:1023 ../gui/wxpython/nviz/tools.py:1866
-#, fuzzy
-msgid "3D raster map"
-#: ../gui/wxpython/lmgr/layertree.py:1025
-#, fuzzy, python-format
-msgid "Unsupported map type <%s>"
-msgstr "Tidak dapat melakukan render layer peta <%s>."
-#: ../gui/wxpython/lmgr/layertree.py:1031
-msgid "Enter name for the new %s in the current mapset:"
-msgstr "Masukkan nama untuk mapset baru:"
-#: ../gui/wxpython/lmgr/layertree.py:1033
-#, python-format
-msgid "Make a copy of %s <%s>"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1051
-msgid ""
-"%s <%s> already exists in the current mapset. Do you want to overwrite it?"
-msgstr "Berkas region <%s> sudah ada. Anda ingin menimpanya?"
-#: ../gui/wxpython/lmgr/layertree.py:1056
-#: ../gui/wxpython/datacatalog/tree.py:219
-#: ../gui/wxpython/datacatalog/tree.py:679
-#: ../gui/wxpython/rdigit/dialogs.py:104
-#: ../gui/wxpython/gui_core/dialogs.py:475
-#: ../gui/wxpython/modules/colorrules.py:679
-msgid "Overwrite?"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1063
-msgid "Unable to make copy of <%s>"
-msgstr "Tidak bisa membuat sebuah peta vektor baru <%s>."
-#: ../gui/wxpython/lmgr/layertree.py:1071
-msgid "Unable to make copy of <%s>. Mapset <%s> is not current mapset."
-#: ../gui/wxpython/lmgr/layertree.py:1097
-#, fuzzy
-msgid "Unable to display histogram of raster map. No map name defined."
-msgstr "Tidak mampu menampilkan histogram dari peta raster."
-#: ../gui/wxpython/lmgr/layertree.py:1146 ../gui/wxpython/mapdisp/frame.py:279
-#: ../gui/wxpython/mapdisp/frame.py:339 ../gui/wxpython/mapdisp/toolbars.py:97
-#: ../gui/wxpython/mapdisp/toolbars.py:301
-#: ../gui/wxpython/animation/data.py:45
-msgid "2D view"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1148 ../gui/wxpython/mapdisp/frame.py:281
-msgid ""
-"Unable to start wxGUI vector digitizer.\n"
-"Details: %s"
-msgstr "Tidak dapat memasukkan rekap baru"
-#: ../gui/wxpython/lmgr/layertree.py:1207
-#: ../gui/wxpython/gui_core/simplelmgr.py:288
-#, python-format
-msgid "Set opacity of <%s>"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1319
-msgid "Layer group:"
-msgstr "Grup layer:"
-#: ../gui/wxpython/lmgr/layertree.py:1325
-#: ../gui/wxpython/lmgr/layertree.py:1866
-#, fuzzy
-msgid "Click to edit layer settings"
-msgstr "Klik di sini untuk menyembunyikan pengaturan 3D"
-#: ../gui/wxpython/lmgr/layertree.py:1392
-msgid "(double click to set properties)"
-msgstr "(klik ganda untuk menentuk karakteristik)"
-#: ../gui/wxpython/lmgr/layertree.py:1641
-#, fuzzy
-msgid "Please wait, updating data..."
-msgstr "Silakan tunggu, sedang menampilkan data atribut ..."
-#: ../gui/wxpython/lmgr/layertree.py:1946 ../gui/wxpython/lmgr/frame.py:2353
-msgid "opacity:"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1964
-#: ../gui/wxpython/animation/utils.py:97
-#: ../gui/wxpython/animation/utils.py:105
-#: ../gui/wxpython/mapswipe/frame.py:420
-msgid "Map <%s> not found."
-#: ../gui/wxpython/lmgr/frame.py:99 ../gui/wxpython/lmgr/frame.py:1202
-#: ../gui/wxpython/mapdisp/frame.py:258 ../gui/wxpython/gui_core/ghelp.py:118
-#: ../gui/wxpython/gui_core/ghelp.py:923
-#, fuzzy
-msgid "Unable to get GRASS version\n"
-msgstr "Masuk ke sesi GRASS"
-#: ../gui/wxpython/lmgr/frame.py:101
-msgid "GRASS GIS %s Layer Manager"
-msgstr "GRASS GIS Attribute Table Manager"
-#: ../gui/wxpython/lmgr/frame.py:151
-#, fuzzy
-msgid "Workspace Toolbar"
-msgstr "Workspace "
-#: ../gui/wxpython/lmgr/frame.py:154
-#, fuzzy
-msgid "Data Toolbar"
-#: ../gui/wxpython/lmgr/frame.py:157 ../gui/wxpython/animation/frame.py:182
-#: ../gui/wxpython/mapswipe/frame.py:315
-#, fuzzy
-msgid "Misc Toolbar"
-#: ../gui/wxpython/lmgr/frame.py:160
-#, fuzzy
-msgid "Tools Toolbar"
-#: ../gui/wxpython/lmgr/frame.py:163
-#, fuzzy
-msgid "Vector Toolbar"
-#: ../gui/wxpython/lmgr/frame.py:166
-#, fuzzy
-msgid "3D view Toolbar"
-#: ../gui/wxpython/lmgr/frame.py:283 ../gui/wxpython/lmgr/frame.py:1690
-#, fuzzy
-msgid "Rename Map Display"
-msgstr "Tampilan"
-#: ../gui/wxpython/lmgr/frame.py:322
-#: ../gui/wxpython/gui_core/preferences.py:1180
-#, fuzzy
-msgid "Layers"
-msgstr "Layer"
-#: ../gui/wxpython/lmgr/frame.py:339
-#, fuzzy
-msgid "Console"
-msgstr "Perintah berhasil dijalankan (%d detik)"
-#: ../gui/wxpython/lmgr/frame.py:364
-#: ../gui/wxpython/gui_core/preferences.py:330
-#: ../gui/wxpython/gui_core/preferences.py:1069
-msgid "Modules"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:378 ../gui/wxpython/nviz/tools.py:96
-#: ../gui/wxpython/gmodeler/preferences.py:250
-#, fuzzy
-msgid "Data"
-msgstr "Basisdata"
-#: ../gui/wxpython/lmgr/frame.py:388
-#: ../gui/wxpython/gui_core/preferences.py:347
-#, fuzzy
-msgid "Python"
-msgstr "Deskripsi layer"
-#: ../gui/wxpython/lmgr/frame.py:440 ../gui/wxpython/mapdisp/toolbars.py:104
-#: ../gui/wxpython/animation/data.py:46
-msgid "3D view"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:483
-#, python-format
-msgid ""
-"Location <%s> created.\n"
-"\n"
-"Do you want to switch to the new location?"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:486
-#, fuzzy
-msgid "Switch to new location?"
-msgstr "Buat location baru?"
-#: ../gui/wxpython/lmgr/frame.py:502 ../gui/wxpython/lmgr/frame.py:1051
-#: ../gui/wxpython/datacatalog/frame.py:119
-#, python-format
-msgid ""
-"Current location is <%(loc)s>.\n"
-"Current mapset is <%(mapset)s>."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:510 ../gui/wxpython/gis_set.py:573
-msgid "Do you want to set the default region extents and resolution now?"
-msgstr ""
-"Apakah Anda hendak menset batas dan resolusi dari region standar sekarang?"
-#: ../gui/wxpython/lmgr/frame.py:512 ../gui/wxpython/gis_set.py:572
-#, python-format
-msgid "Location <%s> created"
-msgstr "Location <%s> telah dibuat"
-#: ../gui/wxpython/lmgr/frame.py:594
-#, fuzzy
-msgid "Choose model to run"
-msgstr "Tutup dialog di akhir perintah"
-#: ../gui/wxpython/lmgr/frame.py:596 ../gui/wxpython/gmodeler/frame.py:445
-#: ../gui/wxpython/gmodeler/frame.py:505
-msgid "GRASS Model File (*.gxm)|*.gxm"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:659 ../gui/wxpython/lmgr/frame.py:2443
-#, fuzzy
-msgid "Do you want to save changes in the workspace?"
-msgstr "Apakah Anda ingin menyimpan perubahan dalam peta vektor <%s>?"
-#: ../gui/wxpython/lmgr/frame.py:661 ../gui/wxpython/lmgr/frame.py:2445
-#, fuzzy
-msgid "Do you want to store current settings to workspace file?"
-msgstr ""
-"Workspace tidak kosong. Apakah Anda hendak menyimpan pengaturan saat ini ke "
-"berkas workspace?"
-#: ../gui/wxpython/lmgr/frame.py:669
-msgid "Close Map Display %s"
-msgstr "GRASS GIS Map Display: "
-#: ../gui/wxpython/lmgr/frame.py:745
-#, python-format
-msgid ""
-"Command '%s' not yet implemented in the WxGUI. Try adding it as a command "
-"layer instead."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:923 ../gui/wxpython/lmgr/frame.py:1955
-msgid "Selected map layer is not vector."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:929
-msgid "Editing is allowed only for vector maps from the current mapset."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:955
-#, fuzzy
-msgid "Choose script file to run"
-#: ../gui/wxpython/lmgr/frame.py:957
-msgid "Python script (*.py)|*.py|Bash script (*.sh)|*.sh"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:970
-msgid ""
-"Due to the limitations of your operating system, the script path cannot "
-"contain certain non-ascii characters. Please rename the script or move it to "
-"a different location."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:977
-msgid "Script file '%s' doesn't exist. Operation canceled."
-msgstr "Tidak ada layer peta terpilih. Operasi digagalkan."
-#: ../gui/wxpython/lmgr/frame.py:986
-#, python-format
-msgid ""
-"Script <%s> is not executable. Do you want to set the permissions that "
-"allows you to run this script (note that you must be the owner of the file)?"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:991
-#, fuzzy
-msgid "Set permission?"
-msgstr "Set region"
-#: ../gui/wxpython/lmgr/frame.py:1001
-#, fuzzy
-msgid "Unable to set permission. Operation canceled."
-msgstr "Nilai koordinat tidak valid. Operasi dibatalkan."
-#: ../gui/wxpython/lmgr/frame.py:1015
-#, python-format
-msgid ""
-"Directory '%s' is not defined in GRASS_ADDON_PATH. Do you want add this "
-"directory to GRASS_ADDON_PATH?"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1017
-msgid "Update Addons path?"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1023
-#, python-format
-msgid "Launching script '%s'..."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1037
-#, fuzzy
-msgid "No location/mapset provided. Operation canceled."
-#: ../gui/wxpython/lmgr/frame.py:1058 ../gui/wxpython/gis_set.py:955
-msgid "Enter name for new mapset:"
-#: ../gui/wxpython/lmgr/frame.py:1059 ../gui/wxpython/gis_set.py:558
-#: ../gui/wxpython/gis_set.py:956 ../gui/wxpython/menustrings.py:235
-msgid "Create new mapset"
-msgstr "Buat mapset baru"
-#: ../gui/wxpython/lmgr/frame.py:1065 ../gui/wxpython/lmgr/frame.py:1086
-#, fuzzy
-msgid "No mapset provided. Operation canceled."
-#: ../gui/wxpython/lmgr/frame.py:1074 ../gui/wxpython/lmgr/frame.py:1096
-#: ../gui/wxpython/datacatalog/frame.py:127
-msgid "Current mapset is <%s>."
-msgstr "Ubah mapset saat ini."
-#: ../gui/wxpython/lmgr/frame.py:1118
-#, python-format
-msgid ""
-"Working directory changed to:\n"
-"\"%s\""
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1125
-#, fuzzy
-msgid "Changes current working directory for this GUI."
-msgstr "Ubah lingkungan kerja "
-#: ../gui/wxpython/lmgr/frame.py:1127
-#, fuzzy
-msgid "Usage: cd [directory]"
-#: ../gui/wxpython/lmgr/frame.py:1128
-msgid "Without parameters it opens a dialog."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1132
-msgid ""
-"If ~ (tilde) is present as the first directory on the path, it is replaced "
-"by user's home directory."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1146
-msgid "More than one parameter provided."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1166
-#, fuzzy
-msgid "Choose a working directory"
-#: ../gui/wxpython/lmgr/frame.py:1211
-msgid "System Info"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1226
-#, fuzzy
-msgid "GRASS version"
-#: ../gui/wxpython/lmgr/frame.py:1226 ../gui/wxpython/gui_core/ghelp.py:132
-#, fuzzy
-msgid "unknown version"
-msgstr "tidak diketahui"
-#: ../gui/wxpython/lmgr/frame.py:1227
-#, fuzzy
-msgid "GRASS SVN revision"
-msgstr "Proyeksi:"
-#: ../gui/wxpython/lmgr/frame.py:1229
-#, fuzzy
-msgid "Build date"
-msgstr "Pembuat SQL"
-#: ../gui/wxpython/lmgr/frame.py:1231
-msgid "Build platform"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1244
-msgid "Platform"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1306
-#, fuzzy
-msgid ""
-"Current workspace is not empty. Do you want to store current settings to "
-"workspace file?"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1309
-#, fuzzy
-msgid "Create new workspace?"
-msgstr "Buat sebuah berkas workspace baru"
-#: ../gui/wxpython/lmgr/frame.py:1336
-msgid "Choose workspace file"
-#: ../gui/wxpython/lmgr/frame.py:1338 ../gui/wxpython/lmgr/frame.py:1571
-msgid "GRASS Workspace File (*.gxw)|*.gxw"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1373 ../gui/wxpython/animation/nviztask.py:43
-msgid ""
-"Reading workspace file <%s> failed.\n"
-"Invalid file, unable to parse XML document."
-msgstr ""
-"Gagal dalam pembacaan berkas workspace <%s>. Berkas tidak valid, tidak mampu "
-"membaca dokumen XML."
-#: ../gui/wxpython/lmgr/frame.py:1378 ../gui/wxpython/lmgr/frame.py:1545
-msgid "Please wait, loading workspace..."
-msgstr "Silakan tunggu, sedang memuat workspace ..."
-#: ../gui/wxpython/lmgr/frame.py:1525
-msgid "Choose GRC file to load"
-msgstr "Pilih berkas GRC untuk dimuat"
-#: ../gui/wxpython/lmgr/frame.py:1527
-msgid "Old GRASS Workspace File (*.grc)|*.grc"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1569
-msgid "Choose file to save current workspace"
-msgstr "Pilih berkas untuk menyimpan workspace saat ini"
-#: ../gui/wxpython/lmgr/frame.py:1589 ../gui/wxpython/lmgr/frame.py:1610
-#, python-format
-msgid "Workspace file <%s> already exists. Do you want to overwrite this file?"
-msgstr "Berkas Workspace <%s> sudah ada. Anda ingin menimpanya?"
-#: ../gui/wxpython/lmgr/frame.py:1592 ../gui/wxpython/lmgr/frame.py:1613
-msgid "Save workspace"
-msgstr "Simpan workspace"
-#: ../gui/wxpython/lmgr/frame.py:1637
-#, fuzzy
-msgid "Writing current settings to workspace file failed."
-msgstr "Penulisan pengaturan saat ini ke berkas workspace gagal (%s)."
-#: ../gui/wxpython/lmgr/frame.py:1649 ../gui/wxpython/gmodeler/frame.py:1084
-msgid "Unable to open file <%s> for writing."
-#: ../gui/wxpython/lmgr/frame.py:1689
-#, fuzzy
-msgid "Enter new name:"
-#: ../gui/wxpython/lmgr/frame.py:1698
-#, fuzzy, python-brace-format
-msgid "GRASS GIS {version} Map Display: {name} - Location: {loc}"
-#: ../gui/wxpython/lmgr/frame.py:1784
-#, python-format
-msgid ""
-"Unable to launch \"Supervised Classification Tool\".\n"
-"\n"
-"Reason: %s"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1826
-#, fuzzy
-msgid "Unable to start Timeline Tool."
-#: ../gui/wxpython/lmgr/frame.py:1837
-#, fuzzy
-msgid "Unable to start Temporal Plot Tool."
-#: ../gui/wxpython/lmgr/frame.py:2079
-#, fuzzy
-msgid "Add selected map layers into layer tree"
-msgstr "Tampilkan layer peta ke dalam layer tree"
-#: ../gui/wxpython/lmgr/frame.py:2112 ../gui/wxpython/lmgr/frame.py:2149
-msgid "Unsupported map layer type <%s>."
-#: ../gui/wxpython/lmgr/frame.py:2278
-msgid ""
-"Note that cell values can only be displayed for regions of less than 10,000 "
-"cells."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:2361
-msgid ""
-"Do you want to remove map layer(s)\n"
-"%s\n"
-"from layer tree?"
-msgstr "Apakah Anda hendak menghapus layer peta <%s> dari layer tree?"
-#: ../gui/wxpython/lmgr/frame.py:2364
-#, fuzzy
-msgid "Do you want to remove selected map layer(s) from layer tree?"
-msgstr "Apakah Anda hendak menghapus layer peta terpilih dari layer tree?"
-#: ../gui/wxpython/lmgr/frame.py:2370
-msgid "Remove map layer"
-msgstr "Hapus layer peta"
-#: ../gui/wxpython/lmgr/frame.py:2452
-#, fuzzy
-msgid "Quit GRASS GUI"
-msgstr "Tentang GRASS GIS"
-#: ../gui/wxpython/lmgr/frame.py:2484
-#, fuzzy
-msgid "Unable to exit GRASS shell: unknown PID"
-#: ../gui/wxpython/lmgr/frame.py:2494 ../gui/wxpython/mapdisp/frame.py:599
-#: ../gui/wxpython/gui_core/vselect.py:277
-#, fuzzy
-msgid "No map layer selected. Operation canceled."
-#: ../gui/wxpython/lmgr/frame.py:2495 ../gui/wxpython/gis_set.py:658
-#: ../gui/wxpython/gis_set.py:701 ../gui/wxpython/core/gcmd.py:151
-msgid "Message"
-msgstr "Pesan"
-#: ../gui/wxpython/lmgr/frame.py:2504
-msgid ""
-"Display resolution is currently not constrained to computational settings. "
-"It's suggested to constrain map to region geometry. Do you want to constrain "
-"the resolution?"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:2513
-msgid "Constrain map to region geometry?"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:49
-#, fuzzy
-msgid "Start new map display"
-msgstr "Mulai tampilan baru"
-#: ../gui/wxpython/lmgr/toolbars.py:52
-#, fuzzy
-msgid "Create new workspace (Ctrl+N)"
-#: ../gui/wxpython/lmgr/toolbars.py:55
-#, fuzzy
-msgid "Open existing workspace file (Ctrl+O)"
-msgstr "Buka berkas workspace yang telah ada "
-#: ../gui/wxpython/lmgr/toolbars.py:58
-#, fuzzy
-msgid "Save current workspace to file (Ctrl+S)"
-msgstr "Simpan workspace ke dalam berkas"
-#: ../gui/wxpython/lmgr/toolbars.py:89
-#, fuzzy
-msgid "Add multiple raster or vector map layers (Ctrl+Shift+L)"
-#: ../gui/wxpython/lmgr/toolbars.py:91
-#, fuzzy
-msgid "Add raster map layer (Ctrl+Shift+R)"
-#: ../gui/wxpython/lmgr/toolbars.py:94
-#, fuzzy
-msgid "Add various raster map layers (RGB, HIS, shaded relief...)"
-#: ../gui/wxpython/lmgr/toolbars.py:96
-#, fuzzy
-msgid "Add vector map layer (Ctrl+Shift+V)"
-msgstr "Tambahkan layer peta vektor"
-#: ../gui/wxpython/lmgr/toolbars.py:99
-#, fuzzy
-msgid "Add various vector map layers (thematic, chart...)"
-#: ../gui/wxpython/lmgr/toolbars.py:102
-msgid "Add web service layer (WMS, WMTS, NASA OnEarth)"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:105
-#, fuzzy
-msgid "Add group"
-msgstr "Tambahkan grup layer"
-#: ../gui/wxpython/lmgr/toolbars.py:108
-#, fuzzy
-msgid "Add various overlays"
-#: ../gui/wxpython/lmgr/toolbars.py:111
-#, fuzzy
-msgid "Remove selected map layer(s) from layer tree"
-#: ../gui/wxpython/lmgr/toolbars.py:153
-#, fuzzy
-msgid "Import/link raster or vector data"
-#: ../gui/wxpython/lmgr/toolbars.py:155
-#, fuzzy
-msgid "Raster Map Calculator"
-msgstr "Kalkulator peta raster 3D"
-#: ../gui/wxpython/lmgr/toolbars.py:157 ../gui/wxpython/gui_core/forms.py:1413
-#, fuzzy
-msgid "Graphical Modeler"
-#: ../gui/wxpython/lmgr/toolbars.py:159
-#, fuzzy
-msgid "Georectifier"
-msgstr "Georektifikasi "
-#: ../gui/wxpython/lmgr/toolbars.py:161 ../gui/wxpython/menustrings.py:200
-#: ../gui/wxpython/menustrings.py:1918
-msgid "Cartographic Composer"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:163
-#, fuzzy
-msgid "Launch user-defined script"
-#: ../gui/wxpython/lmgr/toolbars.py:203
-#, fuzzy
-msgid "GUI settings"
-msgstr "Pengaturan GUI User"
-#: ../gui/wxpython/lmgr/toolbars.py:204
-#, fuzzy
-msgid "GRASS manual"
-msgstr "Peta bayangan "
-#: ../gui/wxpython/lmgr/toolbars.py:232
-#, fuzzy
-msgid "Edit selected vector map"
-msgstr "Edit rekap terpilih"
-#: ../gui/wxpython/lmgr/toolbars.py:235
-#, fuzzy
-msgid "Show attribute data for selected vector map"
-#: ../gui/wxpython/lmgr/toolbars.py:267
-#, fuzzy
-msgid "Generate command for m.nviz.image"
-msgstr "Hasilkan garis kontur"
-#: ../gui/wxpython/lmgr/toolbars.py:268
-#, fuzzy
-msgid "Generate command for m.nviz.image based on current state"
-#: ../gui/wxpython/lmgr/toolbars.py:271
-#, fuzzy
-msgid "3D view mode settings"
-msgstr "Pengaturan umum"
-#: ../gui/wxpython/lmgr/toolbars.py:272
-#, fuzzy
-msgid "Show 3D view mode settings dialog"
-#: ../gui/wxpython/lmgr/toolbars.py:275
-#, fuzzy
-msgid "Show 3D view mode manual"
-#: ../gui/wxpython/lmgr/menudata.py:44
-msgid ""
-"Unable to parse user toolboxes XML files. Default main menu will be loaded."
-msgstr ""
-#: ../gui/wxpython/lmgr/menudata.py:68
-msgid ""
-"Unable to parse user toolboxes XML files. Default module tree will be loaded."
-msgstr ""
-#: ../gui/wxpython/datacatalog/catalog.py:33
-#, fuzzy
-msgid "Data catalog"
-msgstr "Potongan melintang"
-#: ../gui/wxpython/datacatalog/dialogs.py:30
-#: ../gui/wxpython/modules/import_export.py:851
-#, fuzzy
-msgid "Reprojection"
-msgstr "Proyeksi:"
-#: ../gui/wxpython/datacatalog/dialogs.py:64
-#: ../gui/wxpython/gui_core/forms.py:680
-#: ../gui/wxpython/modules/import_export.py:98
-msgid "Close dialog on finish"
-#: ../gui/wxpython/datacatalog/dialogs.py:76
-#, fuzzy
-msgid "Reproject"
-msgstr "Proyeksi:"
-#: ../gui/wxpython/datacatalog/dialogs.py:78
-#, fuzzy
-msgid "Reproject raster"
-#: ../gui/wxpython/datacatalog/dialogs.py:80
-#, fuzzy
-msgid "Reproject vector"
-msgstr "Kode proyeksi:"
-#: ../gui/wxpython/datacatalog/dialogs.py:90
-#, fuzzy
-msgid "The copied layer needs to be reprojected:"
-msgstr "Layer yang akan dihapus"
-#: ../gui/wxpython/datacatalog/frame.py:36
-#, fuzzy
-msgid "GRASS GIS Data Catalog"
-msgstr "Kalkulator Peta GRASS %s"
-#: ../gui/wxpython/datacatalog/frame.py:66
-#, fuzzy
-msgid "Close GRASS GIS Data Catalog"
-#: ../gui/wxpython/datacatalog/toolbars.py:25
-#, fuzzy
-msgid "Reload GRASS locations"
-msgstr "Definisikan GRASS Location baru"
-#: ../gui/wxpython/datacatalog/toolbars.py:28
-msgid "Reload current GRASS mapset only"
-msgstr ""
-#: ../gui/wxpython/datacatalog/toolbars.py:31
-msgid "Click to restrict editing to current mapset only"
-msgstr ""
-#: ../gui/wxpython/datacatalog/toolbars.py:34
-#, fuzzy
-msgid "Click to allow editing other mapsets"
-#: ../gui/wxpython/datacatalog/toolbars.py:54
-msgid "Search:"
-msgstr ""
-#: ../gui/wxpython/datacatalog/toolbars.py:56
-msgid ""
-"Type to search database by map type or name. Use prefix 'r:', 'v:' and "
-"'r3:'to show only raster, vector or 3D raster data, respectively. Use Python "
-"regular expressions to refine your search."
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:121
-msgid "Failed to read mapsets from location <{l}>."
-#: ../gui/wxpython/datacatalog/tree.py:142
-msgid "Failed to read maps from location <{l}>."
-#: ../gui/wxpython/datacatalog/tree.py:214
-msgid ""
-"Map of type {elem} <{name}> already exists in mapset <{mapset}>. Do you want "
-"to overwrite it?"
-#: ../gui/wxpython/datacatalog/tree.py:301
-#, fuzzy
-msgid "GRASS locations in {}"
-msgstr "Pilih location dan mapset proyek"
-#: ../gui/wxpython/datacatalog/tree.py:569
-msgid ""
-"Map <{layer}> marked for copying. You can paste it to the current mapset "
-"<{mapset}>."
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:583
-#: ../gui/wxpython/datacatalog/tree.py:643
-#, fuzzy
-msgid "New name"
-#: ../gui/wxpython/datacatalog/tree.py:584
-#, fuzzy
-msgid "Rename map"
-#: ../gui/wxpython/datacatalog/tree.py:596
-msgid "Editing {name}"
-msgstr "Rentang yang valid"
-#: ../gui/wxpython/datacatalog/tree.py:615
-msgid "Renaming map <{name}>..."
-#: ../gui/wxpython/datacatalog/tree.py:629
-msgid "{cmd} -- completed"
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:637
-#, fuzzy
-msgid "No map selected for copying."
-msgstr "Tidak ada peta vektor yang dipilih untuk diubah."
-#: ../gui/wxpython/datacatalog/tree.py:644
-#, fuzzy
-msgid "Copy map"
-msgstr "Salin tabel"
-#: ../gui/wxpython/datacatalog/tree.py:655
-#, fuzzy
-msgid "Failed to copy map: new map has the same name"
-#: ../gui/wxpython/datacatalog/tree.py:675
-msgid ""
-"Map <{map}> already exists in the current mapset. Do you want to overwrite "
-"it?"
-#: ../gui/wxpython/datacatalog/tree.py:689
-msgid "Copying <{name}>..."
-msgstr "Tampilan"
-#: ../gui/wxpython/datacatalog/tree.py:710
-msgid "g.copy completed"
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:714
-msgid "Reprojection is not implemented for 3D rasters"
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:751
-msgid ""
-"Do you really want to delete map <{m}> of type <{etype}> from mapset "
-"<{mapset}> in location <{loc}>?"
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:756
-#, fuzzy
-msgid "Delete map"
-msgstr "Hapus mapset"
-#: ../gui/wxpython/datacatalog/tree.py:757
-msgid "Deleting {name}..."
-msgstr "Hapus "
-#: ../gui/wxpython/datacatalog/tree.py:773
-#, fuzzy
-msgid "g.remove completed"
-msgstr "Periksa untuk duplikasi"
-#: ../gui/wxpython/datacatalog/tree.py:783
-msgid "Displaying {name}..."
-msgstr "Tampilan"
-#: ../gui/wxpython/datacatalog/tree.py:786
-#: ../gui/wxpython/datacatalog/tree.py:795
-msgid " -- completed. Go to Layers tab for further operations."
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:800
-msgid "Failed to display layer: not in current mapset or invalid layer"
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:818
-#, fuzzy
-msgid "Moving maps not implemented"
-msgstr "Tampilkan batas luar komputasi"
-#: ../gui/wxpython/datacatalog/tree.py:826
-#, fuzzy
-msgid "Maps can be copied only to current mapset"
-#: ../gui/wxpython/datacatalog/tree.py:904
-#, fuzzy
-msgid "&Copy"
-msgstr "Salin "
-#: ../gui/wxpython/datacatalog/tree.py:908
-#: ../gui/wxpython/datacatalog/tree.py:940
-#: ../gui/wxpython/datacatalog/tree.py:958
-#, fuzzy
-msgid "&Paste"
-msgstr "Raster"
-#. GTC Delete mapset
-#: ../gui/wxpython/datacatalog/tree.py:914 ../gui/wxpython/gis_set.py:207
-#, fuzzy
-msgid "&Delete"
-msgstr "Hapus "
-#. GTC Rename mapset
-#: ../gui/wxpython/datacatalog/tree.py:919 ../gui/wxpython/gis_set.py:203
-#: ../gui/wxpython/dbmgr/base.py:2394
-msgid "&Rename"
-msgstr "&Ubah nama"
-#: ../gui/wxpython/datacatalog/tree.py:927
-#, fuzzy
-msgid "&Display layer"
-msgstr "Tampilkan peta"
-#: ../gui/wxpython/datacatalog/tree.py:946
-#, fuzzy
-msgid "&Switch mapset"
-msgstr "Buat mapset"
-#: ../gui/wxpython/gis_set.py:120
-#, fuzzy
-msgid "1. Select GRASS GIS database directory"
-#: ../gui/wxpython/gis_set.py:123
-#, fuzzy
-msgid "2. Select GRASS Location"
-msgstr "Pilih tipe peta dan location/mapset"
-#: ../gui/wxpython/gis_set.py:126
-#, fuzzy
-msgid "3. Select GRASS Mapset"
-#: ../gui/wxpython/gis_set.py:144
-msgid "GRASS GIS database directory contains Locations."
-msgstr ""
-#: ../gui/wxpython/gis_set.py:148
-msgid ""
-"All data in one Location is in the same coordinate reference system "
-"(projection). One Location can be one project. Location contains Mapsets."
-msgstr ""
-#: ../gui/wxpython/gis_set.py:156
-msgid ""
-"Mapset contains GIS data related to one project, task within one project, "
-"subregion or user."
-msgstr ""
-#: ../gui/wxpython/gis_set.py:171
-#, fuzzy
-msgid "Start &GRASS session"
-#: ../gui/wxpython/gis_set.py:177
-#, fuzzy
-msgid "&Browse"
-msgstr "Jelajah "
-#. GTC New mapset
-#: ../gui/wxpython/gis_set.py:180
-msgid "&New"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:182
-#, fuzzy
-msgid "Create a new Mapset in selected Location"
-msgstr ""
-"Buat mapset baru\n"
-"dalam location terpilih"
-#. GTC New location
-#: ../gui/wxpython/gis_set.py:185
-msgid "N&ew"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:188
-msgid ""
-"Create a new location using location wizard. After location is created "
-"successfully, GRASS session is started."
-msgstr ""
-#. GTC Rename location
-#: ../gui/wxpython/gis_set.py:193
-msgid "Ren&ame"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:195 ../gui/wxpython/gis_set.py:688
-msgid "Rename selected location"
-msgstr "Ubah nama location terpilih"
-#. GTC Delete location
-#: ../gui/wxpython/gis_set.py:198
-#, fuzzy
-msgid "De&lete"
-msgstr "Hapus "
-#: ../gui/wxpython/gis_set.py:200 ../gui/wxpython/gis_set.py:771
-msgid "Delete selected location"
-#: ../gui/wxpython/gis_set.py:204 ../gui/wxpython/gis_set.py:645
-msgid "Rename selected mapset"
-msgstr "Ubah nama mapset terpilih"
-#: ../gui/wxpython/gis_set.py:208 ../gui/wxpython/gis_set.py:743
-msgid "Delete selected mapset"
-msgstr "Hapus mapset terpilih"
-#: ../gui/wxpython/gis_set.py:253
-msgid "GRASS GIS %s startup%s"
-#: ../gui/wxpython/gis_set.py:258
-msgid "Enter GRASS session"
-#: ../gui/wxpython/gis_set.py:278
-msgid "Unable to set GRASS database. Check your locale settings."
-msgstr ""
-#: ../gui/wxpython/gis_set.py:298
-msgid "ERROR: Location <%s> not found\n"
-msgstr "ERROR: Location <%s> tidak ada"
-#: ../gui/wxpython/gis_set.py:316
-msgid "ERROR: Mapset <%s> not found\n"
-#: ../gui/wxpython/gis_set.py:477
-#, python-format
-msgid "Invalid line in GISRC file (%s):%s\n"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:508
-msgid "Error: {text}"
-#: ../gui/wxpython/gis_set.py:542
-#, python-format
-msgid "Do you want to import <%(name)s> to the newly created location?"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:545
-#, fuzzy
-msgid "Import data?"
-#: ../gui/wxpython/gis_set.py:557
-#, fuzzy
-msgid "Do you want to create new mapset?"
-msgstr "Apakah Anda hendak membuat GRASS location <%s>?"
-#: ../gui/wxpython/gis_set.py:616
-msgid ""
-"Import of <%(name)s> failed.\n"
-"Reason: %(msg)s"
-msgstr "Penambahan fitur baru untuk peta vektor <%s> gagal."
-#: ../gui/wxpython/gis_set.py:623
-#, python-format
-msgid ""
-"Data file <%(name)s> imported successfully. The location's default region "
-"was set from this imported map."
-msgstr ""
-#: ../gui/wxpython/gis_set.py:637
-msgid ""
-"Mapset <PERMANENT> is required for valid GRASS location.\n"
-"\n"
-"This mapset cannot be renamed."
-msgstr ""
-#: ../gui/wxpython/gis_set.py:643 ../gui/wxpython/gis_set.py:686
-msgid ""
-"Current name: %s\n"
-"\n"
-"Enter new name:"
-msgstr ""
-"Nama saat ini: %s\n"
-"Masukkan nama baru:"
-#: ../gui/wxpython/gis_set.py:659
-msgid ""
-"Unable to rename mapset.\n"
-"\n"
-"Mapset <%s> already exists in location."
-msgstr ""
-"Tidak dapat membuat sebuah tabel baru. Nama tabel atau nama kolom kunci "
-"tidak dapat ditemukan "
-#: ../gui/wxpython/gis_set.py:673
-msgid ""
-"\n"
-"%s"
-msgstr "Tidak dapat merubah nama mapset"
-#: ../gui/wxpython/gis_set.py:702
-msgid ""
-"Unable to rename location.\n"
-"\n"
-"Location <%s> already exists in GRASS database."
-msgstr ""
-#: ../gui/wxpython/gis_set.py:717
-msgid ""
-"\n"
-"%s"
-msgstr "Tidak dapat merubah nama location"
-#: ../gui/wxpython/gis_set.py:731
-msgid ""
-"\n"
-"This mapset cannot be deleted."
-msgstr ""
-#: ../gui/wxpython/gis_set.py:738
-#, python-format
-msgid ""
-"Do you want to continue with deleting mapset <%(mapset)s> from location <"
-"%(location)s>?\n"
-"\n"
-"ALL MAPS included in this mapset will be PERMANENTLY DELETED!"
-msgstr ""
-"Apakah Anda hendak melanjutkan untuk menghapus mapset <%(mapset)s> dari "
-"location <%(location)s>?\n"
-"\n"
-"SEMUA PETA termasuk yang ada di dalam mapset akan DIHAPUS SECARA PERMANEN!"
-#: ../gui/wxpython/gis_set.py:752
-msgid "Unable to delete mapset"
-msgstr "Tidak dapat menghapus mapset"
-#: ../gui/wxpython/gis_set.py:766
-#, python-format
-msgid ""
-"Do you want to continue with deleting location <%s>?\n"
-"\n"
-"ALL MAPS included in this location will be PERMANENTLY DELETED!"
-msgstr ""
-"Apakah Anda hendak melanjutkan untuk menghapus location<%s>?\n"
-"\n"
-"SEMUA PETA termasuk yang ada di dalam location ini akan DIHAPUS SECARA "
-"PERMANEN!"
-#: ../gui/wxpython/gis_set.py:782
-msgid "Unable to delete location"
-msgstr "Tidak dapat menghapus location"
-#: ../gui/wxpython/gis_set.py:792
-msgid "Unicode error detected. Check your locale settings. Details: {}"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:804
-#, python-format
-msgid ""
-"No GRASS Location found in '%s'. Create a new Location or choose different "
-"GRASS database directory."
-msgstr ""
-#: ../gui/wxpython/gis_set.py:926
-#, python-format
-msgid "Path '%s' doesn't exist."
-msgstr ""
-#: ../gui/wxpython/gis_set.py:941 ../gui/wxpython/gui_core/gselect.py:1175
-#, fuzzy
-msgid "Choose GIS Data Directory"
-msgstr "Pilih Direktori Data SIG:"
-#: ../gui/wxpython/gis_set.py:970
-#, python-format
-msgid "Mapset <%s> already exists."
-msgstr ""
-#: ../gui/wxpython/gis_set.py:977
-#, python-format
-msgid ""
-"Mapset <%s> is reserved for direct read access to OGR layers. Please "
-"consider to use another name for your mapset.\n"
-"\n"
-"Are you really sure that you want to create this mapset?"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:982
-#, fuzzy
-msgid "Reserved mapset name"
-#: ../gui/wxpython/gis_set.py:1014
-#, python-format
-msgid "Unable to create new mapset: %s"
-msgstr "Tidak mampu membuat mapset baru: %s"
-#: ../gui/wxpython/gis_set.py:1029
-#, python-format
-msgid ""
-"GRASS is already running in selected mapset <%(mapset)s>\n"
-"(file %(lock)s found).\n"
-"\n"
-"Concurrent use not allowed.\n"
-"\n"
-"Do you want to try to remove .gislock (note that you need permission for "
-"this operation) and continue?"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:1035 ../gui/wxpython/gis_set.py:1048
-#, fuzzy
-msgid "Lock file found"
-msgstr "berkas tidak ditemukan"
-#: ../gui/wxpython/gis_set.py:1044
-msgid ""
-"ARE YOU REALLY SURE?\n"
-"\n"
-"If you really are running another GRASS session doing this could corrupt "
-"your data. Have another look in the processor manager just to be sure..."
-msgstr ""
-#: ../gui/wxpython/gis_set.py:1058
-msgid ""
-"Unable to remove '%(lock)s'.\n"
-"\n"
-"Details: %(reason)s"
-msgstr "Tidak dapat melakukan perbesar peta vektor <%s>."
-#: ../gui/wxpython/gis_set.py:1108
-#, python-format
-msgid ""
-"Name <%(name)s> is not a valid name for location or mapset. Please use only "
-"ASCII characters excluding %(chars)s and space."
-msgstr ""
-#: ../gui/wxpython/gis_set.py:1113 ../gui/wxpython/gui_core/widgets.py:844
-#, fuzzy
-msgid "Invalid name"
-msgstr "Region tidak valid"
-#: ../gui/wxpython/gis_set.py:1189
-msgid ""
-"GRASS needs a directory (GRASS database) in which to store its data. Create "
-"one now if you have not already done so. A popular choice is \"grassdata\", "
-"located in your home directory. Press Browse button to select the directory."
-msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:23
-#, fuzzy
-msgid "Modify the configuration file"
-msgstr "Ubah nama location"
-#: ../gui/wxpython/rlisetup/frame.py:37
-msgid "View and modify the configuration file '{name}'"
-#: ../gui/wxpython/rlisetup/frame.py:89
-msgid ""
-"Are you sure that you want modify r.li configuration file {name}?\n"
-"You could broke the configuration file..."
-msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:94
-msgid "WARNING"
-msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:114
-msgid "GRASS GIS Setup for r.li modules"
-msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:132
-msgid "Available sampling area configuration files"
-msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:141
-msgid "Remove a configuration file"
-msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:143 ../gui/wxpython/menustrings.py:914
-#: ../gui/wxpython/menustrings.py:1820
-#, fuzzy
-msgid "Create"
-msgstr "Buat RGB "
-#: ../gui/wxpython/rlisetup/frame.py:144
-#, fuzzy
-msgid "Create a new configuration file"
-#: ../gui/wxpython/rlisetup/frame.py:147
-#, fuzzy
-msgid "Rename a configuration file"
-#: ../gui/wxpython/rlisetup/frame.py:149
-#, fuzzy
-msgid "View/Edit"
-msgstr "Edit GCP"
-#: ../gui/wxpython/rlisetup/frame.py:150
-#, fuzzy
-msgid "View and edit a configuration file"
-#: ../gui/wxpython/rlisetup/frame.py:225
-msgid "Do you want remove r.li configuration file <%s>?"
-#: ../gui/wxpython/rlisetup/frame.py:228
-#, fuzzy
-msgid "Remove new r.li configuration file?"
-#: ../gui/wxpython/rlisetup/frame.py:251 ../gui/wxpython/rlisetup/frame.py:271
-msgid "You have to select a configuration file"
-msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:254
-#, python-format
-msgid ""
-"Set the new name for %s \" "
-"\"configuration file"
-msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:256
-#, fuzzy
-msgid "Rename configuration file"
-#: ../gui/wxpython/rlisetup/sampling_frame.py:217
-#: ../gui/wxpython/rlisetup/sampling_frame.py:326
-#, python-format
-msgid "The raster file %s already exists, please change name"
-msgstr ""
-#: ../gui/wxpython/rlisetup/sampling_frame.py:243
-msgid "Raster map not created. Please redraw region."
-msgstr ""
-#: ../gui/wxpython/rlisetup/sampling_frame.py:349
-msgid "Raster map not created. redraw region again."
-msgstr ""
-#: ../gui/wxpython/rlisetup/sampling_frame.py:403
-#: ../gui/wxpython/rlisetup/wizard.py:818
-#, fuzzy
-msgid "Draw sampling frame"
-#: ../gui/wxpython/rlisetup/sampling_frame.py:404
-msgid "Draw sampling frame by clicking and dragging"
-msgstr ""
-#: ../gui/wxpython/rlisetup/sampling_frame.py:407
-#, fuzzy
-msgid "Draw sampling rectangle"
-#: ../gui/wxpython/rlisetup/sampling_frame.py:408
-msgid "Draw sampling rectangle by clicking and dragging"
-msgstr ""
-#: ../gui/wxpython/rlisetup/sampling_frame.py:411
-#, fuzzy
-msgid "Draw sampling circle"
-#: ../gui/wxpython/rlisetup/sampling_frame.py:412
-msgid "Draw sampling circle radius by clicking and dragging"
-msgstr ""
-#: ../gui/wxpython/rlisetup/sampling_frame.py:415
-#: ../gui/wxpython/rlisetup/wizard.py:1129
-#: ../gui/wxpython/rlisetup/wizard.py:1490
-#, fuzzy
-msgid "Draw sampling region"
-#: ../gui/wxpython/rlisetup/sampling_frame.py:416
-msgid "Draw sampling region by polygon. Right Double click to end drawing"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:52
-#, fuzzy
-msgid "Create new configuration file for r.li modules"
-msgstr "Editor konfigurasi untuk r.li.'index'"
-msgid "Do you want to create r.li configuration file <%s>?"
-#: ../gui/wxpython/rlisetup/wizard.py:121
-#, fuzzy
-msgid "Create new r.li configuration file?"
-#: ../gui/wxpython/rlisetup/wizard.py:133
-#, fuzzy
-msgid "r.li.setup wizard canceled. Configuration file not created."
-msgstr "Location wizard dibatalkan. Location tidak dibuat."
-#: ../gui/wxpython/rlisetup/wizard.py:479
-#, fuzzy
-msgid "Select maps and define name"
-#: ../gui/wxpython/rlisetup/wizard.py:492
-#, fuzzy
-msgid "Name for new configuration file to create"
-msgstr "Nama untuk peta vektor baru:"
-#: ../gui/wxpython/rlisetup/wizard.py:505
-#, fuzzy
-msgid "Raster map to use to select areas"
-msgstr "Pengaturan raster"
-#: ../gui/wxpython/rlisetup/wizard.py:516
-#, fuzzy
-msgid "Vector map to use to select areas"
-msgstr "Pengaturan teks"
-#: ../gui/wxpython/rlisetup/wizard.py:527
-#, fuzzy
-msgid "Vector map layer to use to select areas"
-#: ../gui/wxpython/rlisetup/wizard.py:539
-msgid "Define sampling region (region for analysis)"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:542
-#: ../gui/wxpython/rlisetup/wizard.py:877
-#, fuzzy
-msgid "Whole map layer"
-#: ../gui/wxpython/rlisetup/wizard.py:543
-#, fuzzy
-msgid "Keyboard setting"
-msgstr "Perlihatkan pengaturan "
-#: ../gui/wxpython/rlisetup/wizard.py:544
-msgid "Draw the sampling frame"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:586
-#, python-format
-msgid "The configuration file %s already exists, please change name"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:648
-#, python-format
-msgid "Vector %s was not found, please select another vector"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:652
-#, python-format
-msgid "Vector %s has no areas, please select another vector"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:657
-#, python-format
-msgid "Vector %s has no table connected, please select another vector"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:701
-#, fuzzy
-msgid "Insert sampling frame parameter"
-msgstr "Parameter medan"
-#: ../gui/wxpython/rlisetup/wizard.py:711
-msgid "Column of upper left corner"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:725
-msgid "Row of upper left corner"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:740
-#: ../gui/wxpython/rlisetup/wizard.py:754
-msgid "Row length of sampling frame"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:870
-#, fuzzy
-msgid "Insert sampling areas"
-#: ../gui/wxpython/rlisetup/wizard.py:878
-#, fuzzy
-msgid "Regions"
-msgstr "Region "
-#: ../gui/wxpython/rlisetup/wizard.py:879
-#, fuzzy
-msgid "Sample units"
-msgstr "Transek cuplikan"
-#: ../gui/wxpython/rlisetup/wizard.py:880 ../gui/wxpython/menustrings.py:328
-#: ../gui/wxpython/menustrings.py:1234
-msgid "Moving window"
-msgstr "Window bergerak "
-#: ../gui/wxpython/rlisetup/wizard.py:881
-#, fuzzy
-msgid ""
-"Select areas from the\n"
-"overlayed vector map"
-#: ../gui/wxpython/rlisetup/wizard.py:892
-#, fuzzy
-msgid "Choose a method"
-msgstr "Pilih berkas workspace"
-#: ../gui/wxpython/rlisetup/wizard.py:894
-msgid "Use keyboard to enter sampling area"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:895
-msgid "Use mouse to draw sampling area"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:899
-msgid "This option is not supported yet"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:911
-#, fuzzy
-msgid "Number of regions to draw:"
-msgstr "Ubah nama mapset"
-#: ../gui/wxpython/rlisetup/wizard.py:926
-#, fuzzy
-msgid "Do you want to overwrite existing temporal maps if they exist?"
-#: ../gui/wxpython/rlisetup/wizard.py:931
-#, fuzzy
-msgid "Do you want to check vector areas?"
-#: ../gui/wxpython/rlisetup/wizard.py:933
-#, fuzzy
-msgid "Select if use area by area"
-msgstr "Kelola warna citra"
-#: ../gui/wxpython/rlisetup/wizard.py:935
-msgid "All the features will be used"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:952
-#, fuzzy
-msgid "Analysing all vector features..."
-#: ../gui/wxpython/rlisetup/wizard.py:1050
-#, fuzzy
-msgid "Analysing vector"
-#: ../gui/wxpython/rlisetup/wizard.py:1066
-msgid "All feature are been analyzed."
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1070
-msgid "An error occurred"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1102
-#, fuzzy
-msgid "Draw sampling regions"
-#: ../gui/wxpython/rlisetup/wizard.py:1119
-#, fuzzy
-msgid "Draw sample region "
-#: ../gui/wxpython/rlisetup/wizard.py:1127
-#: ../gui/wxpython/rlisetup/wizard.py:1484
-#, fuzzy
-msgid "Draw moving windows region"
-#: ../gui/wxpython/rlisetup/wizard.py:1166
-msgid "Select sample units from keyboard"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1180
-#: ../gui/wxpython/rlisetup/wizard.py:1353
-#: ../gui/wxpython/rlisetup/wizard.py:1443
-#, fuzzy
-msgid "Select type of shape"
-msgstr "Pilih peta vektor"
-msgid "Circle"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1207
-#: ../gui/wxpython/rlisetup/wizard.py:1365
-#: ../gui/wxpython/rlisetup/wizard.py:1380
-#, fuzzy
-msgid "Width size (in cells)?"
-msgstr "Lebar:"
-#: ../gui/wxpython/rlisetup/wizard.py:1208
-#: ../gui/wxpython/rlisetup/wizard.py:1381
-msgid "What radius size (in meters)?"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1209
-#: ../gui/wxpython/rlisetup/wizard.py:1372
-#: ../gui/wxpython/rlisetup/wizard.py:1382
-msgid "Height size (in cells)?"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1210
-#: ../gui/wxpython/rlisetup/wizard.py:1383
-#, fuzzy
-msgid "Name of the circle mask"
-msgstr "Peta raster hasil kode-ulang:"
-#: ../gui/wxpython/rlisetup/wizard.py:1218
-msgid "Select method of sampling unit distribution"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1220
-msgid "Random non overlapping"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1221
-#, fuzzy
-msgid "Systematic contiguos"
-msgstr "diagram tematik"
-#: ../gui/wxpython/rlisetup/wizard.py:1222
-msgid "Stratified random"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1223
-msgid "Systematic non contiguos"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1224
-msgid "Centered over sites"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1229
-#: ../gui/wxpython/rlisetup/wizard.py:1294
-msgid "What number of Sampling Units to use?"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1308
-#, fuzzy
-msgid "Insert number of row strates"
-#: ../gui/wxpython/rlisetup/wizard.py:1309
-msgid "Insert number of column strates"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1315
-msgid "Insert distance between units"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1345
-#, fuzzy
-msgid "Set sample units"
-#: ../gui/wxpython/rlisetup/wizard.py:1394
-#, fuzzy
-msgid "Set moving windows"
-#: ../gui/wxpython/rlisetup/wizard.py:1437
-#: ../gui/wxpython/rlisetup/wizard.py:1535
-#, fuzzy
-msgid "Draw sampling units"
-#: ../gui/wxpython/rlisetup/wizard.py:1455
-#, fuzzy
-msgid "Number of sampling area to draw:"
-#: ../gui/wxpython/rlisetup/wizard.py:1552
-#, fuzzy
-msgid "Draw Sampling "
-#: ../gui/wxpython/rlisetup/wizard.py:1606
-#, fuzzy
-msgid "Select sampling areas"
-#: ../gui/wxpython/rlisetup/wizard.py:1615
-msgid "Is this area ok?"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1638
-#, fuzzy
-msgid "Select sample area "
-#: ../gui/wxpython/rlisetup/wizard.py:1665
-#: ../gui/wxpython/rlisetup/functions.py:138
-#, python-format
-msgid ""
-"The raster map <%s> already exists. Please remove or rename the maps with "
-"the prefix '%s' or select the option to overwrite existing maps"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1706
-#: ../gui/wxpython/rlisetup/functions.py:127
-msgid "The polygon seems to have 0 areas"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1709
-#, fuzzy
-msgid "Select sample area 1 of "
-#: ../gui/wxpython/rlisetup/wizard.py:1732
-#: ../gui/wxpython/location_wizard/wizard.py:2000
-msgid "Summary"
-msgstr "Ringkasan"
-#: ../gui/wxpython/rlisetup/wizard.py:1739
-msgid "Configuration file name:"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1748
-#, fuzzy
-msgid "Raster name:"
-msgstr "Raster"
-#: ../gui/wxpython/rlisetup/wizard.py:1758
-#, fuzzy
-msgid "Vector name:"
-msgstr "Pilih garis"
-#: ../gui/wxpython/rlisetup/wizard.py:1767
-#, fuzzy
-msgid "Region type:"
-msgstr "Region "
-#: ../gui/wxpython/rlisetup/wizard.py:1785
-msgid "Sampling area type:"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1848
-#, fuzzy
-msgid "Region keyboard values:"
-msgstr "Batas region"
-#: ../gui/wxpython/rlisetup/wizard.py:1862
-#: ../gui/wxpython/rlisetup/wizard.py:1887
-#: ../gui/wxpython/rlisetup/wizard.py:1891
-#, fuzzy
-msgid "Type of shape:"
-#: ../gui/wxpython/rlisetup/wizard.py:1865
-#: ../gui/wxpython/rlisetup/wizard.py:1894
-msgid "Radius size:"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1866
-#: ../gui/wxpython/rlisetup/wizard.py:1895
-#, fuzzy
-msgid "Name circle mask:"
-#: ../gui/wxpython/rlisetup/wizard.py:1868
-#: ../gui/wxpython/rlisetup/wizard.py:1897
-#, fuzzy
-msgid "Width size:"
-msgstr "Lebar:"
-#: ../gui/wxpython/rlisetup/wizard.py:1869
-#: ../gui/wxpython/rlisetup/wizard.py:1898
-#, fuzzy
-msgid "Height size:"
-msgstr "Tema ikon:"
-#: ../gui/wxpython/rlisetup/wizard.py:1872
-msgid "Method of distribution:"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1875
-#, fuzzy
-msgid "Number sampling units:"
-#: ../gui/wxpython/rlisetup/wizard.py:1878
-#, fuzzy
-msgid "Distance between units:"
-msgstr "Fitur terdekat"
-#: ../gui/wxpython/rlisetup/wizard.py:1881
-#, fuzzy
-msgid "Number row strates:"
-#: ../gui/wxpython/rlisetup/wizard.py:1883
-#, fuzzy
-msgid "Number column strates:"
-msgstr "Kolom kunci"
-#: ../gui/wxpython/iclass/dialogs.py:44 ../gui/wxpython/iclass/toolbars.py:40
-#: ../gui/wxpython/iscatt/toolbars.py:46
-#, fuzzy
-msgid "Select imagery group"
-msgstr "Pilih grup:"
-#: ../gui/wxpython/iclass/dialogs.py:85
-#, fuzzy
-msgid "Name of imagery group is missing."
-#: ../gui/wxpython/iclass/dialogs.py:92
-#, fuzzy
-msgid "Name of imagery group:"
-#: ../gui/wxpython/iclass/dialogs.py:107
-#, fuzzy
-msgid "Name of imagery subgroup:"
-#: ../gui/wxpython/iclass/dialogs.py:182
-msgid "Please choose a subgroup."
-msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:186
-msgid "Subgroup <%s> not found in group <%s>"
-msgstr "ERROR: Mapset <%s> tidak ada"
-#: ../gui/wxpython/iclass/dialogs.py:193
-#, python-format
-msgid ""
-"No data found in subgroup <%s> of group <%s>.\n"
-msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:198
-msgid ""
-"No data found in group <%s>.\n"
-#: ../gui/wxpython/iclass/dialogs.py:202
-#: ../gui/wxpython/iclass/g.gui.iclass.py:79
-msgid "Group <%s> not found"
-#: ../gui/wxpython/iclass/dialogs.py:250
-#, fuzzy
-msgid "Name of map is missing."
-#: ../gui/wxpython/iclass/dialogs.py:257
-#: ../gui/wxpython/gmodeler/dialogs.py:89
-#, fuzzy
-msgid "Name of raster map:"
-#: ../gui/wxpython/iclass/dialogs.py:259
-#: ../gui/wxpython/gmodeler/dialogs.py:91
-#: ../gui/wxpython/gui_core/dialogs.py:239
-#, fuzzy
-msgid "Name of vector map:"
-#: ../gui/wxpython/iclass/dialogs.py:280 ../gui/wxpython/iclass/toolbars.py:37
-#, fuzzy
-msgid "Class manager"
-msgstr "Klasifikasi citra"
-#: ../gui/wxpython/iclass/dialogs.py:295 ../gui/wxpython/iscatt/frame.py:140
-msgid "Classes"
-msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:395 ../gui/wxpython/iscatt/frame.py:413
-#, fuzzy
-msgid "Class name"
-#: ../gui/wxpython/iclass/dialogs.py:429 ../gui/wxpython/iscatt/frame.py:451
-msgid "Please use only ASCII characters."
-msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:545
-#, fuzzy
-msgid "Zoom to training areas of selected class"
-msgstr "Perbesaran sesuai peta terpilih "
-#: ../gui/wxpython/iclass/dialogs.py:607
-#, fuzzy
-msgid "Save signature file"
-#: ../gui/wxpython/iclass/dialogs.py:668
-#, fuzzy
-msgid "Enter name of signature file:"
-#: ../gui/wxpython/iclass/dialogs.py:680
-#, fuzzy
-msgid "Signature file path:"
-msgstr "Simpan berkas sebagai ..."
-#: ../gui/wxpython/iclass/dialogs.py:730
-#, fuzzy
-msgid "Export training areas"
-#: ../gui/wxpython/iclass/dialogs.py:777 ../gui/wxpython/iscatt/dialogs.py:281
-#, fuzzy
-msgid "Enter name of new vector map:"
-#: ../gui/wxpython/iclass/dialogs.py:793
-#, fuzzy
-msgid "Export attribute table containing computed statistical data"
-msgstr "Impor tabel atribut dalam beragam format."
-#: ../gui/wxpython/iclass/dialogs.py:832
-msgid "Vector map <%s> already exists. Do you want to overwrite it?"
-#: ../gui/wxpython/iclass/dialogs.py:835
-msgid "Vector <%s> exists"
-msgstr "Peta vektor baru"
-#: ../gui/wxpython/iclass/statistics.py:29
-#, fuzzy
-msgid "Loading imagery lib failed"
-msgstr ""
-"Pemuatan data atribut gagal. Pernyataan SQL 'select' tidak valid.\n"
-"\n"
-"'%s'"
-#: ../gui/wxpython/iclass/digit.py:61
-msgid ""
-"You are trying to create a training area outside the computational region. "
-"Please, use g.region to set the appropriate region first."
-msgstr ""
-#: ../gui/wxpython/iclass/digit.py:72
-msgid ""
-"In order to create a training area, you have to select class first.\n"
-"\n"
-"There is no class yet, do you want to create one?"
-msgstr ""
-#: ../gui/wxpython/iclass/digit.py:76
-#: ../gui/wxpython/iscatt/controllers.py:413
-#, fuzzy
-msgid "No class selected"
-msgstr "Tidak ada layer peta yang dipilih untuk kueri."
-#: ../gui/wxpython/iclass/g.gui.iclass.py:75
-#, fuzzy
-msgid "Name of subgroup required"
-#: ../gui/wxpython/iclass/g.gui.iclass.py:84
-msgid "Subgroup <%s> not found"
-#: ../gui/wxpython/iclass/g.gui.iclass.py:91
-#: ../gui/wxpython/nviz/wxnviz.py:344 ../gui/wxpython/nviz/wxnviz.py:355
-#: ../gui/wxpython/mapswipe/g.gui.mapswipe.py:79
-#: ../gui/wxpython/modules/histogram.py:399
-msgid "Raster map <%s> not found"
-#: ../gui/wxpython/iclass/g.gui.iclass.py:98
-#: ../gui/wxpython/nviz/wxnviz.py:432 ../gui/wxpython/dbmgr/g.gui.dbmgr.py:48
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:62
-msgid "Vector map <%s> not found"
-#: ../gui/wxpython/iclass/g.gui.iclass.py:121
-msgid "Loading raster map <%s>..."
-#: ../gui/wxpython/iclass/g.gui.iclass.py:124
-msgid "Loading training map <%s>..."
-#: ../gui/wxpython/iclass/plots.py:73
-#, fuzzy
-msgid "Histograms"
-msgstr "Histogram"
-#: ../gui/wxpython/iclass/plots.py:74
-msgid "Coincident plots"
-msgstr ""
-#: ../gui/wxpython/iclass/plots.py:75
-#, fuzzy
-msgid "Scatter plots"
-msgstr "Titik perturbasi"
-#: ../gui/wxpython/iclass/plots.py:99
-#, python-format
-msgid ""
-"Scatter plot functionality is disabled.\n"
-"\n"
-"Reason: Unable to import packages needed for scatter plot.\n"
-"%s"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:39
-msgid ""
-"Loading imagery lib failed.\n"
-"%s"
-msgstr ""
-"\n"
-"'%s'"
-#: ../gui/wxpython/iclass/frame.py:79
-#, fuzzy
-msgid "GRASS GIS Supervised Classification Tool"
-msgstr "Toolbar Georektifikasi"
-#: ../gui/wxpython/iclass/frame.py:325
-#, fuzzy
-msgid "IClass Toolbar"
-msgstr "Map Toolbar"
-#: ../gui/wxpython/iclass/frame.py:337
-#, fuzzy
-msgid "IClass Misc Toolbar"
-#: ../gui/wxpython/iclass/frame.py:364
-#, fuzzy
-msgid "Digitization Toolbar"
-msgstr "Pengaturan digitasi"
-#: ../gui/wxpython/iclass/frame.py:388
-msgid "Plots"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:408
-#, fuzzy
-msgid "Preview Display"
-msgstr "Cetak tampilan"
-#: ../gui/wxpython/iclass/frame.py:411
-#, fuzzy
-msgid "Training Areas Display"
-msgstr "Hapus tampilan"
-#: ../gui/wxpython/iclass/frame.py:485
-msgid "Adjust Training Area Display to Preview Display"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:487
-msgid "Adjust Preview display to Training Area Display"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:489
-#, fuzzy
-msgid "Display synchronization ON"
-msgstr "Tampilan region"
-#: ../gui/wxpython/iclass/frame.py:491
-#, fuzzy
-msgid "Display synchronization OFF"
-#: ../gui/wxpython/iclass/frame.py:564
-msgid "All changes will be lost. Do you want to continue?"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:573
-#, fuzzy
-msgid "Import vector map"
-#: ../gui/wxpython/iclass/frame.py:593
-msgid "No areas in vector map <%s>.\n"
-#: ../gui/wxpython/iclass/frame.py:595
-#, python-format
-msgid "Vector map <%s> contains points or lines, these features are ignored."
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:622
-msgid "Unable to open vector map <%s>"
-#: ../gui/wxpython/iclass/frame.py:633
-msgid "Unable to copy vector features from <%s>"
-#: ../gui/wxpython/iclass/frame.py:645
-#, fuzzy
-msgid "Unable to open temporary vector map"
-#: ../gui/wxpython/iclass/frame.py:741
-#, fuzzy
-msgid "No training areas to export."
-msgstr "Tidak ada yang dapat diekstrak."
-#: ../gui/wxpython/iclass/frame.py:754
-#, python-format
-msgid "%d training areas (%d classes) exported to vector map <%s>."
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:994
-#, fuzzy
-msgid "Failed to create temporary vector map."
-#: ../gui/wxpython/iclass/frame.py:1090
-#, python-format
-msgid "No area in category %s. Category skipped."
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:1094
-#, fuzzy
-msgid "Analysis failed."
-msgstr "Analisis LIDAR"
-#: ../gui/wxpython/iclass/frame.py:1101
-msgid "results"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:1107
-#, fuzzy
-msgid "No imagery group selected."
-#: ../gui/wxpython/iclass/frame.py:1114
-msgid ""
-"Due to recent changes in classes, signatures can be outdated and should be "
-"recalculated. Do you still want to continue?"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:1117
-msgid "Outdated signatures"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:1135
-msgid ""
-"A signature file named %s already exists.\n"
-"Do you want to replace it?"
-#: ../gui/wxpython/iclass/frame.py:1138 ../gui/wxpython/gmodeler/frame.py:525
-msgid "File already exists"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:1188
-#, fuzzy
-msgid "No imagery group selected. Operation canceled."
-#: ../gui/wxpython/iclass/frame.py:1199
-msgid ""
-"Group <%(group)s> does not have enough files (it has %(files)d files). "
-"Operation canceled."
-#: ../gui/wxpython/iclass/frame.py:1207
-#, fuzzy
-msgid "No areas given. Operation canceled."
-#: ../gui/wxpython/iclass/frame.py:1222
-#, fuzzy
-msgid "Vector features are outside raster layers. Operation canceled."
-msgstr "Paling tidak dibutuhkan %d GCP. Operasi dibatalkan."
-#: ../gui/wxpython/iclass/toolbars.py:34
-#, fuzzy
-msgid "Set opacity level"
-#: ../gui/wxpython/iclass/toolbars.py:43
-msgid "Run analysis, update histogram and coincidence plots"
-msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:46
-#, fuzzy
-msgid "Save signature file for i.maxlik"
-#: ../gui/wxpython/iclass/toolbars.py:49
-#, fuzzy
-msgid "Remove selected map layer"
-msgstr "Hapus layer terpilih"
-#: ../gui/wxpython/iclass/toolbars.py:52
-#, fuzzy
-msgid "Export training areas to vector map"
-#: ../gui/wxpython/iclass/toolbars.py:55
-#, fuzzy
-msgid "Import training areas from vector map"
-msgstr "Impor peta raster "
-#: ../gui/wxpython/iclass/toolbars.py:76
-#, fuzzy
-msgid "Training"
-msgstr "Peringatan"
-#: ../gui/wxpython/modules/colorrules.py:582
-#, fuzzy
-msgid "Preview"
-msgstr "Tampilan cetak"
-#: ../gui/wxpython/iclass/toolbars.py:82
-msgid "Set map canvas for "
-msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:84
-#, fuzzy
-msgid "/ Zoom to map"
-#: ../gui/wxpython/iclass/toolbars.py:260
-#: ../gui/wxpython/iclass/toolbars.py:269
-msgid "std dev"
-msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:343
-#, fuzzy
-msgid "Add raster map"
-msgstr "Peta raster:"
-#: ../gui/wxpython/rdigit/controller.py:123
-#, fuzzy
-msgid "Please select first the raster map"
-msgstr "Tool untuk membersihkan topologi peta vektor."
-#: ../gui/wxpython/rdigit/controller.py:155
-msgid "Right click to finish area"
-msgstr ""
-#: ../gui/wxpython/rdigit/controller.py:160
-msgid "Right click to finish line"
-msgstr ""
-#: ../gui/wxpython/rdigit/controller.py:303
-#, fuzzy
-msgid "Do you want to save changes?"
-#: ../gui/wxpython/rdigit/controller.py:304
-#, fuzzy
-msgid "Save raster map changes"
-msgstr "Simpan perubahan"
-#: ../gui/wxpython/rdigit/controller.py:378
-#, fuzzy
-msgid "Failed to create backup copy of edited raster map."
-#: ../gui/wxpython/rdigit/controller.py:397
-#, fuzzy
-msgid "Failed to create new raster map."
-#: ../gui/wxpython/rdigit/controller.py:488
-#: ../gui/wxpython/rdigit/controller.py:516
-#, fuzzy
-msgid "Rasterizing..."
-msgstr "Render"
-#: ../gui/wxpython/rdigit/controller.py:556
-#, fuzzy
-msgid "Failed to set default color table for edited raster map"
-msgstr "Buat tabel warna baru menggunakan color rules"
-#: ../gui/wxpython/rdigit/dialogs.py:34
-#, fuzzy
-msgid "Create new raster map"
-msgstr "Buat peta vektor baru"
-#: ../gui/wxpython/rdigit/dialogs.py:53
-#, fuzzy
-msgid "Name for new raster map:"
-#: ../gui/wxpython/rdigit/dialogs.py:58
-#, fuzzy
-msgid "Optionally select background raster map:"
-#: ../gui/wxpython/rdigit/dialogs.py:62
-#, fuzzy
-msgid "New raster map type:"
-#: ../gui/wxpython/rdigit/dialogs.py:92
-#, fuzzy
-msgid "Please specify name for a new raster map"
-msgstr "Menghitung indeks bentuk pada sebuah peta raster"
-#: ../gui/wxpython/rdigit/dialogs.py:100
-msgid ""
-"Raster map <%s> already exists in the current mapset. Do you want to "
-"overwrite it?"
-#: ../gui/wxpython/rdigit/toolbars.py:27
-#, fuzzy
-msgid "Digitize area"
-msgstr "Digitasi garis baru "
-#: ../gui/wxpython/rdigit/toolbars.py:29
-#, fuzzy
-msgid "Digitize line"
-#: ../gui/wxpython/rdigit/toolbars.py:31
-#, fuzzy
-msgid "Digitize point"
-msgstr "Digitasi titik baru "
-#: ../gui/wxpython/rdigit/toolbars.py:32
-#, fuzzy
-msgid "Save raster map"
-msgstr "Gabungkan peta raster"
-#: ../gui/wxpython/rdigit/toolbars.py:33
-#: ../gui/wxpython/vdigit/toolbars.py:184
-msgid "Undo"
-msgstr "Gagalkan"
-#: ../gui/wxpython/rdigit/toolbars.py:34
-#, fuzzy
-msgid "Quit raster digitizer"
-msgstr "Toolbar digitasi vektor"
-#: ../gui/wxpython/rdigit/toolbars.py:50
-#, fuzzy
-msgid "Select raster map"
-#: ../gui/wxpython/rdigit/toolbars.py:65
-msgid "Set drawing color (not raster cell color)"
-msgstr ""
-#: ../gui/wxpython/rdigit/toolbars.py:86
-#, fuzzy
-msgid "Cell value:"
-msgstr "Nilai sel"
-#: ../gui/wxpython/rdigit/toolbars.py:99
-msgid ""
-"Width of currently digitized line or diameter of a digitized point in map "
-"units."
-msgstr ""
-#: ../gui/wxpython/rdigit/toolbars.py:138
-#, fuzzy
-msgid "New raster map"
-#: ../gui/wxpython/nviz/mapwindow.py:244
-msgid ""
-"Opening 3D view was not successful. Please try to change the value of depth "
-"buffer in GUI Settings dialog > tab Map Display > Advanced and restart GUI."
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:509
-#, python-format
-msgid ""
-"Image is too large, your OpenGL implementation supports maximum texture size "
-"%d px."
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1021
-#, fuzzy
-msgid "Easting"
-msgstr "Timur"
-#: ../gui/wxpython/nviz/mapwindow.py:1022
-#, fuzzy
-msgid "Northing"
-msgstr "Utara"
-#: ../gui/wxpython/nviz/mapwindow.py:1023
-msgid "Elevation"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1029
-#, fuzzy
-msgid "Surface map name"
-msgstr "Nama kolom"
-#: ../gui/wxpython/nviz/mapwindow.py:1032
-#, fuzzy
-msgid "Surface map elevation"
-msgstr "Program pembentukan permukaan dari kontur raster."
-#: ../gui/wxpython/nviz/mapwindow.py:1034
-#, fuzzy
-msgid "Surface map color"
-#: ../gui/wxpython/nviz/mapwindow.py:1045
-msgid "XY distance from previous"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1048
-msgid "XYZ distance from previous"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1051
-#, fuzzy
-msgid "Distance along surface"
-msgstr "Jarak sepanjang transek"
-#: ../gui/wxpython/nviz/mapwindow.py:1055
-#, fuzzy
-msgid "Distance along exag. surface"
-#: ../gui/wxpython/nviz/mapwindow.py:1059
-#, fuzzy
-msgid "No point on surface"
-msgstr "Cost surface"
-#: ../gui/wxpython/nviz/mapwindow.py:1539
-#, fuzzy
-msgid "Loading raster map"
-#: ../gui/wxpython/nviz/mapwindow.py:1543
-#, fuzzy
-msgid "Loading 3d raster map"
-#: ../gui/wxpython/nviz/mapwindow.py:1551
-#, fuzzy
-msgid "failed"
-msgstr "Profil"
-#: ../gui/wxpython/nviz/mapwindow.py:1554
-#, python-format
-msgid "Unsupported layer type '%s'"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1674
-#, fuzzy
-msgid "Unable to unload raster map"
-msgstr "Tidak berhasil memperbaharui peta vektor."
-#: ../gui/wxpython/nviz/mapwindow.py:1679
-#, fuzzy
-msgid "Unable to unload 3d raster map"
-msgstr "Tidak dapat memperbesar ke peta raster <%s>"
-#: ../gui/wxpython/nviz/mapwindow.py:1680
-#, fuzzy
-msgid "3d raster map"
-#: ../gui/wxpython/nviz/mapwindow.py:1692
-msgid "unloaded successfully"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1748
-msgid "Loading vector map <%(name)s> (%(type)s) failed"
-msgstr "Nilai casting '%(value)' ke %(tipe) gagal."
-#: ../gui/wxpython/nviz/mapwindow.py:1811
-msgid "Unable to unload vector map <%(name)s> (%(type)s)"
-#: ../gui/wxpython/nviz/mapwindow.py:1815
-#, python-format
-msgid "Vector map <%(name)s> (%(type)s) unloaded successfully"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:2192
-#, python-format
-msgid "Vector point layer not found (id = %d)"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:2194
-#, python-format
-msgid "Unable to set data layer properties (id = %d)"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:2198
-#, python-format
-msgid ""
-"Setting data layer properties failed.\n"
-"\n"
-"%s"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:2253
-#: ../gui/wxpython/nviz/mapwindow.py:2272 ../gui/wxpython/nviz/tools.py:2679
-#: ../gui/wxpython/nviz/tools.py:2728 ../gui/wxpython/nviz/tools.py:5172
-msgid "constant#"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:92 ../gui/wxpython/nviz/preferences.py:69
-#: ../gui/wxpython/nviz/preferences.py:74
-msgid "View"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:100
-#: ../gui/wxpython/gui_core/preferences.py:464
-msgid "Appearance"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:104
-#, fuzzy
-msgid "Analysis"
-#: ../gui/wxpython/nviz/tools.py:107 ../gui/wxpython/nviz/tools.py:502
-#, fuzzy
-msgid "Animation"
-msgstr "Kuantisasi "
-#: ../gui/wxpython/nviz/tools.py:252
-msgid "Control View"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:276
-msgid "Adjusts the distance and angular perspective of the image viewpoint"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:292 ../gui/wxpython/nviz/preferences.py:86
-#, fuzzy
-msgid "Perspective:"
-msgstr "Karakteristik"
-#: ../gui/wxpython/nviz/tools.py:304
-msgid "Tilts the plane of the surface from the horizontal"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:316 ../gui/wxpython/nviz/tools.py:1263
-msgid "Tilt:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:329
-msgid ""
-"Adjusts the viewing height above the surface (angle of view automatically "
-"adjusts to maintain the same center of view)"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:345
-msgid "Adjusts the relative height of features above the plane of the surface"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:387 ../gui/wxpython/nviz/preferences.py:176
-msgid "Z-exag:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:412
-msgid "Look:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:415
-#, fuzzy
-msgid "here"
-msgstr "Vertex"
-#: ../gui/wxpython/nviz/tools.py:418
-msgid ""
-"Allows you to select a point on the surface that becomes the new center of "
-"view. Click on the button and then on the surface."
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:424
-#, fuzzy
-msgid "center"
-msgstr "Render"
-#: ../gui/wxpython/nviz/tools.py:428
-msgid "Resets the view to the original default center of view"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:432
-#, fuzzy
-msgid "top"
-msgstr "Atas"
-#: ../gui/wxpython/nviz/tools.py:436
-msgid ""
-"Sets the viewer directly over the scene's center position. This top view "
-"orients approximately north south."
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:440
-#, fuzzy
-msgid "reset"
-msgstr "Barat"
-#: ../gui/wxpython/nviz/tools.py:441
-#, fuzzy
-msgid "Reset to default view"
-msgstr "Kembalikan aturan ke standar"
-#: ../gui/wxpython/nviz/tools.py:458 ../gui/wxpython/nviz/preferences.py:198
-msgid "Image Appearance"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:465 ../gui/wxpython/nviz/preferences.py:204
-#: ../gui/wxpython/animation/dialogs.py:1864
-#: ../gui/wxpython/web_services/widgets.py:305
-#: ../gui/wxpython/gui_core/preferences.py:856
-#, fuzzy
-msgid "Background color:"
-msgstr "Background peta vektor"
-#: ../gui/wxpython/nviz/tools.py:510
-msgid ""
-"Press 'Record' button and start changing the view. It is recommended to use "
-"fly-through mode (Map Display toolbar) to achieve smooth motion."
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:521
-#, fuzzy
-msgid "Record"
-msgstr "Render"
-#: ../gui/wxpython/nviz/tools.py:523
-msgid "Play"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:525 ../gui/wxpython/animation/toolbars.py:42
-msgid "Pause"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:527 ../gui/wxpython/animation/toolbars.py:39
-msgid "Stop"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:544
-#, fuzzy
-msgid "Total number of frames :"
-#: ../gui/wxpython/nviz/tools.py:551
-msgid "Frame rate (FPS):"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:559
-msgid "Frames are recorded with given frequency (FPS). "
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:615
-msgid "Save image sequence"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:625
-#, fuzzy
-msgid "Choose a directory for images"
-msgstr "Pilih direktori data GRASS:"
-#: ../gui/wxpython/nviz/tools.py:632 ../gui/wxpython/animation/dialogs.py:1187
-msgid "File prefix:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:638
-msgid ""
-"Generated files names will look like this: prefix_1.ppm, prefix_2.ppm, ..."
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:640 ../gui/wxpython/animation/dialogs.py:1191
-#, fuzzy
-msgid "File format:"
-msgstr "Koordinat"
-#: ../gui/wxpython/nviz/tools.py:705 ../gui/wxpython/nviz/tools.py:2236
-#: ../gui/wxpython/nviz/preferences.py:398
-#, fuzzy
-msgid "Surface"
-#: ../gui/wxpython/nviz/tools.py:713 ../gui/wxpython/nviz/tools.py:1345
-#, fuzzy
-msgid "Constant surface"
-#: ../gui/wxpython/nviz/tools.py:720 ../gui/wxpython/nviz/preferences.py:546
-#, fuzzy
-msgid "Vector"
-msgstr "Vektor"
-#: ../gui/wxpython/nviz/tools.py:728 ../gui/wxpython/gui_core/dialogs.py:1452
-#, fuzzy
-msgid "3D raster"
-msgstr "raster"
-#: ../gui/wxpython/nviz/tools.py:766 ../gui/wxpython/nviz/preferences.py:287
-#, fuzzy
-msgid "Lighting"
-msgstr "Penyorotan"
-#: ../gui/wxpython/nviz/tools.py:773
-#, fuzzy
-msgid "Fringe"
-msgstr "Garis"
-#: ../gui/wxpython/nviz/tools.py:782 ../gui/wxpython/animation/dialogs.py:929
-#, fuzzy
-msgid "Decorations"
-msgstr "Deskripsi"
-#: ../gui/wxpython/nviz/tools.py:804 ../gui/wxpython/nviz/tools.py:1146
-msgid "Cutting planes"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:856 ../gui/wxpython/nviz/tools.py:1896
-#: ../gui/wxpython/nviz/preferences.py:414
-#, fuzzy
-msgid "Mode:"
-msgstr "Mode"
-#: ../gui/wxpython/nviz/tools.py:859 ../gui/wxpython/nviz/preferences.py:420
-msgid "coarse"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:860 ../gui/wxpython/nviz/preferences.py:421
-#, fuzzy
-msgid "fine"
-msgstr "Garis"
-#: ../gui/wxpython/nviz/tools.py:861 ../gui/wxpython/nviz/preferences.py:422
-#, fuzzy
-msgid "both"
-msgstr "Utara"
-#: ../gui/wxpython/nviz/tools.py:871 ../gui/wxpython/nviz/tools.py:1162
-#: ../gui/wxpython/nviz/tools.py:1910
-#, fuzzy
-msgid "Shading:"
-msgstr "Snapping"
-#: ../gui/wxpython/nviz/tools.py:874 ../gui/wxpython/nviz/tools.py:1913
-msgid "flat"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:875 ../gui/wxpython/nviz/tools.py:1914
-msgid "gouraud"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:883
-#, fuzzy
-msgid "Set to all"
-#: ../gui/wxpython/nviz/tools.py:884
-msgid "Use draw settings for all loaded surfaces"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:896 ../gui/wxpython/nviz/preferences.py:466
-#, fuzzy
-msgid "Coarse mode:"
-msgstr "Bentuk garis"
-#: ../gui/wxpython/nviz/tools.py:899 ../gui/wxpython/nviz/tools.py:945
-#: ../gui/wxpython/nviz/preferences.py:447
-#: ../gui/wxpython/nviz/preferences.py:478
-#, fuzzy
-msgid "resolution:"
-msgstr "Resolusi Atas-Bawah"
-#: ../gui/wxpython/nviz/tools.py:914 ../gui/wxpython/nviz/preferences.py:496
-#, fuzzy
-msgid "style:"
-msgstr "Gaya"
-#: ../gui/wxpython/nviz/tools.py:917 ../gui/wxpython/nviz/preferences.py:502
-msgid "wire"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:918 ../gui/wxpython/nviz/preferences.py:503
-#, fuzzy
-msgid "surface"
-#: ../gui/wxpython/nviz/tools.py:930
-#, fuzzy
-msgid "Change wire color"
-msgstr "Warna garis"
-#: ../gui/wxpython/nviz/tools.py:941 ../gui/wxpython/nviz/preferences.py:435
-#, fuzzy
-msgid "Fine mode:"
-msgstr "Garis"
-#: ../gui/wxpython/nviz/tools.py:969
-#, fuzzy
-msgid "Surface attributes"
-msgstr "Ubah atribut"
-#: ../gui/wxpython/nviz/tools.py:978 ../gui/wxpython/nviz/tools.py:2818
-#, fuzzy
-msgid "Transparency"
-msgstr "Transparans"
-#: ../gui/wxpython/nviz/tools.py:979 ../gui/wxpython/nviz/tools.py:2819
-msgid "Shininess"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:985 ../gui/wxpython/nviz/tools.py:2839
-msgid "map"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:988 ../gui/wxpython/nviz/tools.py:2844
-msgid "unset"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:993 ../gui/wxpython/nviz/tools.py:2849
-msgid "constant"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1055
-msgid "Changes the x, y, and z position of the current surface"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1072 ../gui/wxpython/nviz/tools.py:1322
-#: ../gui/wxpython/nviz/tools.py:2041 ../gui/wxpython/nviz/tools.py:3042
-#, fuzzy
-msgid "Reset"
-msgstr "Barat"
-#: ../gui/wxpython/nviz/tools.py:1073 ../gui/wxpython/nviz/tools.py:2042
-#, fuzzy
-msgid "Reset to default position"
-#: ../gui/wxpython/nviz/tools.py:1152
-msgid "Active cutting plane:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1164
-msgid "clear"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1165
-#, fuzzy
-msgid "top color"
-msgstr "Y coord"
-#: ../gui/wxpython/nviz/tools.py:1166
-#, fuzzy
-msgid "bottom color"
-msgstr "Y coord"
-#: ../gui/wxpython/nviz/tools.py:1167
-msgid "blend"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1168
-msgid "shaded"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1180
-msgid "Horizontal X:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1182
-msgid "Sets the X coordinate of the current cutting plane"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1210
-msgid "Horizontal Y:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1212
-msgid "Sets the Y coordinate of the current cutting plane"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1241
-msgid "Rotation:"
-msgstr "Rotasi:"
-#: ../gui/wxpython/nviz/tools.py:1243
-msgid "Rotates the current cutting plane about vertical axis"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1265
-msgid "Rotates the current cutting plane about horizontal axis"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1288
-msgid ""
-"Sets the Z coordinate of the current cutting plane (only meaningful when "
-"tilt is not 0)"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1360 ../gui/wxpython/menustrings.py:6
-#: ../gui/wxpython/menustrings.py:1935
-msgid "New"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1385
-#, fuzzy
-msgid "Fine resolution:"
-#: ../gui/wxpython/nviz/tools.py:1399
-#, fuzzy
-msgid "Value:"
-msgstr "Volume"
-#: ../gui/wxpython/nviz/tools.py:1411 ../gui/wxpython/nviz/tools.py:3031
-#, fuzzy
-msgid "Transparency:"
-#: ../gui/wxpython/nviz/tools.py:1477
-#, fuzzy
-msgid "Show vector lines"
-#: ../gui/wxpython/nviz/tools.py:1487 ../gui/wxpython/nviz/preferences.py:552
-#, fuzzy
-msgid "Vector lines"
-#: ../gui/wxpython/nviz/tools.py:1493
-#, fuzzy
-msgid "Line:"
-msgstr "Garis"
-#: ../gui/wxpython/nviz/tools.py:1496
-#, fuzzy
-msgid "width:"
-msgstr "Lebar:"
-#: ../gui/wxpython/nviz/tools.py:1512 ../gui/wxpython/nviz/tools.py:1684
-#, fuzzy
-msgid "color:"
-msgstr "Warna: "
-#: ../gui/wxpython/nviz/tools.py:1529 ../gui/wxpython/nviz/tools.py:1733
-msgid "use color for thematic mapping"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1532
-msgid "use width for thematic mapping"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1547 ../gui/wxpython/nviz/tools.py:1560
-#: ../gui/wxpython/nviz/tools.py:1756 ../gui/wxpython/nviz/tools.py:1773
-#, fuzzy
-msgid "Set options..."
-msgstr "Pilihan pengaturan"
-#: ../gui/wxpython/nviz/tools.py:1574 ../gui/wxpython/nviz/tools.py:1788
-#: ../gui/wxpython/vdigit/preferences.py:161
-msgid "Display"
-msgstr "Tampilan"
-#: ../gui/wxpython/nviz/tools.py:1579 ../gui/wxpython/nviz/tools.py:5442
-#: ../gui/wxpython/nviz/tools.py:5497
-#, fuzzy
-msgid "on surface(s):"
-#: ../gui/wxpython/nviz/tools.py:1580 ../gui/wxpython/nviz/tools.py:5442
-msgid "as 3D"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1589 ../gui/wxpython/nviz/tools.py:1796
-msgid "Height above surface:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1640
-#, fuzzy
-msgid "Show vector points"
-msgstr "IDW dari peta vektor"
-#: ../gui/wxpython/nviz/tools.py:1649 ../gui/wxpython/nviz/preferences.py:592
-#, fuzzy
-msgid "Vector points"
-#: ../gui/wxpython/nviz/tools.py:1656
-#, fuzzy
-msgid "Icon:"
-#: ../gui/wxpython/nviz/tools.py:1736
-msgid "use size for thematic mapping"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1899
-#, fuzzy
-msgid "isosurfaces"
-#: ../gui/wxpython/nviz/tools.py:1900
-msgid "slices"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1923
-#, fuzzy
-msgid "Resolution:"
-#: ../gui/wxpython/nviz/tools.py:1937
-msgid "Draw wire box"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1953 ../gui/wxpython/nviz/tools.py:4279
-#, fuzzy
-msgid "List of isosurfaces"
-msgstr "Daftar layer"
-#: ../gui/wxpython/nviz/tools.py:2087
-#, fuzzy
-msgid "Show light model"
-msgstr "Garis aliran "
-#: ../gui/wxpython/nviz/tools.py:2100
-#, fuzzy
-msgid "Light source position"
-msgstr "Pilih sumber location:"
-#: ../gui/wxpython/nviz/tools.py:2117
-msgid "Adjusts the light height"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2148
-msgid "Light color and intensity"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2166 ../gui/wxpython/nviz/preferences.py:345
-#, fuzzy
-msgid "Brightness:"
-msgstr "Keragaman"
-#: ../gui/wxpython/nviz/tools.py:2168
-msgid "Adjusts the brightness of the light"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2183 ../gui/wxpython/nviz/preferences.py:359
-msgid "Ambient:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2185
-msgid "Adjusts the ambient light"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2250
-msgid "Edges with fringe"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2252
-msgid "N && W"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2253
-msgid "N && E"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2254
-msgid "S && W"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2255
-msgid "S && E"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2272 ../gui/wxpython/vnet/dialogs.py:945
-#: ../gui/wxpython/gui_core/toolbars.py:84
-#: ../gui/wxpython/iscatt/toolbars.py:48
-#: ../gui/wxpython/iscatt/toolbars.py:146
-msgid "Settings"
-msgstr "Pengaturan"
-#: ../gui/wxpython/nviz/tools.py:2280
-msgid "Elevation of fringe from bottom:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2337
-msgid "Arrow length (in map units):"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2349
-#, fuzzy
-msgid "Arrow color:"
-#: ../gui/wxpython/nviz/tools.py:2361
-msgid "Place arrow"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2386
-msgid "Scale bar length (in map units):"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2398
-#, fuzzy
-msgid "Scale bar color:"
-#: ../gui/wxpython/nviz/tools.py:2410
-#, fuzzy
-msgid "Place new scale bar"
-msgstr "Tambahkan layer"
-#: ../gui/wxpython/nviz/tools.py:2482
-msgid "Do you want to record new animation without saving the previous one?"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2485
-msgid "Animation already axists"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2655
-msgid "No file prefix given."
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2659
-#, python-format
-msgid "Directory %s does not exist."
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2800
-#, fuzzy
-msgid "Isosurface attributes"
-#: ../gui/wxpython/nviz/tools.py:2806
-msgid "toggle normal direction"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2815
-#, fuzzy
-msgid "Isosurface value"
-#: ../gui/wxpython/nviz/tools.py:2932
-#, fuzzy
-msgid "Slice attributes"
-msgstr "Perbaharui atribut"
-#: ../gui/wxpython/nviz/tools.py:2941
-msgid "Slice parallel to axis:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:3099
-msgid "W"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:3100
-#, fuzzy
-msgid "N"
-msgstr "N:"
-#: ../gui/wxpython/nviz/tools.py:3101
-msgid "S"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:3102
-#, fuzzy
-msgid "E"
-msgstr "E:"
-#: ../gui/wxpython/nviz/tools.py:3103
-#, fuzzy
-msgid "NW"
-msgstr "N:"
-#: ../gui/wxpython/nviz/tools.py:3104
-#, fuzzy
-msgid "NE"
-msgstr "N:"
-#: ../gui/wxpython/nviz/tools.py:3105
-#, fuzzy
-msgid "SE"
-msgstr "E:"
-#: ../gui/wxpython/nviz/tools.py:3106
-msgid "SW"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:3624 ../gui/wxpython/nviz/tools.py:5560
-msgid "Level"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4285
-#, fuzzy
-msgid "List of slices"
-msgstr "Daftar duplikasi"
-#: ../gui/wxpython/nviz/tools.py:4483 ../gui/wxpython/nviz/tools.py:4485
-#, python-brace-format
-msgid "Level {level}"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4493 ../gui/wxpython/nviz/tools.py:4497
-msgid "Slice parallel to {axis}"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4785 ../gui/wxpython/nviz/tools.py:5573
-msgid "Slice parallel to"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5017
-#, fuzzy, python-format
-msgid "Scalebar %d"
-#: ../gui/wxpython/nviz/tools.py:5179
-msgid "None"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5181 ../gui/wxpython/menustrings.py:485
-#: ../gui/wxpython/menustrings.py:1391
-msgid "Plane"
-msgstr "Planimetrik"
-#: ../gui/wxpython/nviz/tools.py:5381
-#, fuzzy
-msgid "Vector map is 3D"
-#: ../gui/wxpython/nviz/tools.py:5384
-#, fuzzy
-msgid "Vector map is 2D"
-#: ../gui/wxpython/nviz/tools.py:5386
-#, python-format
-msgid "%(features)d features (%(points)d points)"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5444 ../gui/wxpython/nviz/tools.py:5499
-#, fuzzy
-msgid "on surface"
-#: ../gui/wxpython/nviz/tools.py:5597
-#, fuzzy
-msgid "range:"
-msgstr "Garis"
-#: ../gui/wxpython/nviz/tools.py:5676 ../gui/wxpython/nviz/tools.py:5687
-#, fuzzy
-msgid "North edge:"
-msgstr "Utara"
-#: ../gui/wxpython/nviz/tools.py:5677 ../gui/wxpython/nviz/tools.py:5688
-#, fuzzy
-msgid "South edge:"
-msgstr "Selatan"
-#: ../gui/wxpython/nviz/tools.py:5678 ../gui/wxpython/nviz/tools.py:5685
-#: ../gui/wxpython/nviz/tools.py:5694
-#, fuzzy
-msgid "West edge:"
-msgstr "Deteksi tepian"
-#: ../gui/wxpython/nviz/tools.py:5679 ../gui/wxpython/nviz/tools.py:5686
-#: ../gui/wxpython/nviz/tools.py:5695
-msgid "East edge:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5681 ../gui/wxpython/nviz/tools.py:5692
-#: ../gui/wxpython/nviz/tools.py:5700
-#, fuzzy
-msgid "Northing (Y):"
-msgstr "Utara"
-#: ../gui/wxpython/nviz/tools.py:5682 ../gui/wxpython/nviz/tools.py:5691
-#: ../gui/wxpython/nviz/tools.py:5701
-#, fuzzy
-msgid "Height (Z):"
-msgstr "Berat:"
-#: ../gui/wxpython/nviz/tools.py:5683 ../gui/wxpython/nviz/tools.py:5690
-#: ../gui/wxpython/nviz/tools.py:5699
-#, fuzzy
-msgid "Easting (X):"
-msgstr "Timur"
-#: ../gui/wxpython/nviz/tools.py:5696
-#, fuzzy
-msgid "Bottom edge:"
-msgstr "Bawah"
-#: ../gui/wxpython/nviz/tools.py:5697
-msgid "Top edge:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5808
-msgid "Adjusts the distance and direction of the image viewpoint"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5843
-msgid ""
-"Adjusts the light direction. Click and drag the puck to change the light "
-"direction."
-msgstr ""
-#: ../gui/wxpython/nviz/wxnviz.py:33
-msgid ""
-"This module requires the NumPy module, which could not be imported. It "
-"probably is not installed (it's not part of the standard Python "
-"distribution). See the Numeric Python site (http://numpy.scipy.org) for "
-"information on downloading source or binaries."
-msgstr ""
-#: ../gui/wxpython/nviz/wxnviz.py:502 ../gui/wxpython/nviz/wxnviz.py:514
-msgid "3d raster map <%s> not found"
-#: ../gui/wxpython/nviz/preferences.py:35
-#, fuzzy
-msgid "3D view default settings"
-msgstr "Pengaturan umum"
-#: ../gui/wxpython/nviz/preferences.py:62
-#, fuzzy
-msgid "Revert settings to default, changes are not applied"
-msgstr "Kembalikan pengaturan ke standar dan terapkan perubahan"
-#: ../gui/wxpython/nviz/preferences.py:90
-#: ../gui/wxpython/nviz/preferences.py:161
-#: ../gui/wxpython/nviz/preferences.py:180
-#, fuzzy
-msgid "value:"
-msgstr "Volume"
-#: ../gui/wxpython/nviz/preferences.py:103
-#, fuzzy
-msgid "step:"
-msgstr "Tahapan"
-#: ../gui/wxpython/nviz/preferences.py:118
-#: ../gui/wxpython/nviz/preferences.py:300
-#, fuzzy
-msgid "Position:"
-msgstr "Proyeksi:"
-#: ../gui/wxpython/nviz/preferences.py:122
-#: ../gui/wxpython/nviz/preferences.py:304
-#, fuzzy
-msgid "x:"
-msgstr "X:"
-#: ../gui/wxpython/nviz/preferences.py:157
-#, fuzzy
-msgid "Twist:"
-msgstr "Daftar "
-#: ../gui/wxpython/nviz/preferences.py:237
-msgid "Fly-through"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:241
-#: ../gui/wxpython/mapdisp/toolbars.py:68
-msgid "Fly-through mode"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:247
-#, fuzzy
-msgid "Move exag:"
-msgstr "Pindahkan vertex "
-#: ../gui/wxpython/nviz/preferences.py:260
-msgid "Turn exag:"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:292
-#, fuzzy
-msgid "Light"
-#: ../gui/wxpython/nviz/preferences.py:330
-#, fuzzy
-msgid "z:"
-msgstr "X:"
-#: ../gui/wxpython/nviz/preferences.py:517
-#, fuzzy
-msgid "wire color:"
-#: ../gui/wxpython/nviz/preferences.py:598
-msgid "Automatic size"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:599
-msgid "Icon size is set automatically based on landscape dimensions."
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:607
-#: ../gui/wxpython/mapswipe/dialogs.py:350
-#, fuzzy
-msgid "Size:"
-msgstr "Ukuran"
-#: ../gui/wxpython/nviz/preferences.py:623
-#, fuzzy
-msgid "Marker:"
-msgstr "Layer"
-#: ../gui/wxpython/nviz/preferences.py:724
-msgid "3D view settings saved to file <%s>."
-msgstr "Pengesetan disimpan pada berkas '%s'."
-#: ../gui/wxpython/dbmgr/g.gui.dbmgr.py:52
-msgid "Loading attribute data for vector map <%s>..."
-msgstr ""
-"\n"
-"'%s'"
-#: ../gui/wxpython/dbmgr/g.gui.dbmgr.py:56
-msgid "GRASS GIS Attribute Table Manager"
-msgstr "GRASS GIS Attribute Table Manager"
-#: ../gui/wxpython/dbmgr/manager.py:72
-#, fuzzy
-msgid "GRASS GIS Attribute Table Manager - "
-#: ../gui/wxpython/dbmgr/manager.py:74
-msgid "READONLY - "
-msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:92
-#, python-format
-msgid ""
-"Database connection for vector map <%s> is not defined in DB file. You can "
-"define new connection in 'Manage layers' tab."
-msgstr ""
-"Koneksi basisdata ke peta vektor <%s> tidak didefinisikan dalam berkas DB. "
-"Anda dapat mendefinisikan sebuah koneksi baru dalam tab 'Kelola layer'."
-#: ../gui/wxpython/dbmgr/manager.py:98
-msgid "Please wait, loading attribute data..."
-msgstr "Silakan tunggu, sedang menampilkan data atribut ..."
-#: ../gui/wxpython/dbmgr/manager.py:107
-msgid "Browse data"
-msgstr "Jelajah data"
-#: ../gui/wxpython/dbmgr/manager.py:115
-msgid "Manage tables"
-msgstr "Kelola tabel"
-#: ../gui/wxpython/dbmgr/manager.py:122
-msgid "Manage layers"
-msgstr "Kelola layer"
-#: ../gui/wxpython/dbmgr/manager.py:133
-#, fuzzy
-msgid "Close Attribute Table Manager"
-msgstr "Attribute Table Manager"
-#: ../gui/wxpython/dbmgr/manager.py:136
-#, fuzzy
-msgid "Reload currently selected attribute data"
-#: ../gui/wxpython/dbmgr/manager.py:139
-msgid "Reload all attribute data (drop current selection)"
-msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:215 ../gui/wxpython/dbmgr/base.py:302
-#: ../gui/wxpython/dbmgr/base.py:904 ../gui/wxpython/dbmgr/base.py:1074
-#: ../gui/wxpython/dbmgr/base.py:1429 ../gui/wxpython/dbmgr/base.py:2081
-#, python-format
-msgid "Number of loaded records: %d"
-msgstr "Jumlah rekap yang dimuat: %d"
-#: ../gui/wxpython/dbmgr/dialogs.py:79
-#, python-format
-msgid ""
-"No attribute table found.\n"
-"\n"
-"Do you want to create a new attribute table and defined a link to vector map "
-"<%s>?"
-msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:83
-#, fuzzy
-msgid "Create table?"
-msgstr "&Buat tabel"
-#: ../gui/wxpython/dbmgr/dialogs.py:104
-msgid "Close dialog on submit"
-msgstr "Tutup dialog saat submit"
-#: ../gui/wxpython/dbmgr/dialogs.py:116
-#, fuzzy
-msgid "No attributes found"
-msgstr "Perlihatkan data atribut"
-#: ../gui/wxpython/dbmgr/dialogs.py:122 ../gui/wxpython/menustrings.py:671
-#: ../gui/wxpython/menustrings.py:1577
-msgid "Update attributes"
-#: ../gui/wxpython/dbmgr/dialogs.py:124
-#, fuzzy
-msgid "Define attributes"
-#: ../gui/wxpython/dbmgr/dialogs.py:126
-msgid "Display attributes"
-msgstr "Tampilkan atribut"
-#: ../gui/wxpython/dbmgr/dialogs.py:130
-msgid "&Reload"
-msgstr "&Muat-ulang"
-#: ../gui/wxpython/dbmgr/dialogs.py:131 ../gui/wxpython/dbmgr/dialogs.py:625
-msgid "&Submit"
-msgstr "&Submit"
-#: ../gui/wxpython/dbmgr/dialogs.py:149 ../gui/wxpython/vdigit/dialogs.py:175
-#, fuzzy
-msgid "Feature id:"
-msgstr "ID Fitur"
-#: ../gui/wxpython/dbmgr/dialogs.py:237
-msgid "Column <%(col)s>: Value '%(value)s' needs to be entered as %(type)s."
-#: ../gui/wxpython/dbmgr/dialogs.py:451
-#, fuzzy
-msgid "Unknown"
-msgstr "tidak diketahui"
-#: ../gui/wxpython/dbmgr/dialogs.py:512 ../gui/wxpython/dbmgr/base.py:2937
-#: ../gui/wxpython/dbmgr/base.py:3058 ../gui/wxpython/dbmgr/base.py:3324
-#: ../gui/wxpython/vdigit/dialogs.py:116 ../gui/wxpython/vdigit/dialogs.py:576
-#: ../gui/wxpython/vdigit/preferences.py:612
-#: ../gui/wxpython/vdigit/preferences.py:615
-msgid "Layer"
-msgstr "Layer"
-#: ../gui/wxpython/dbmgr/dialogs.py:512 ../gui/wxpython/dbmgr/dialogs.py:640
-#: ../gui/wxpython/vdigit/dialogs.py:123 ../gui/wxpython/vdigit/dialogs.py:577
-msgid "Category"
-msgstr "Kategori"
-#: ../gui/wxpython/dbmgr/dialogs.py:788 ../gui/wxpython/dbmgr/base.py:2304
-#: ../gui/wxpython/dbmgr/base.py:2368
-#, fuzzy
-msgid "Column"
-msgstr "Volume"
-#: ../gui/wxpython/dbmgr/dialogs.py:799 ../gui/wxpython/dbmgr/base.py:2323
-#: ../gui/wxpython/gmodeler/preferences.py:255
-#: ../gui/wxpython/web_services/widgets.py:923
-msgid "Type"
-msgstr "Tipe"
-#: ../gui/wxpython/dbmgr/dialogs.py:810 ../gui/wxpython/dbmgr/base.py:2339
-#, fuzzy
-msgid "Length"
-msgstr "panjang"
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:95 ../gui/wxpython/dbmgr/base.py:2261
-msgid "Database connection"
-msgstr "Koneksi basis data"
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:111 ../gui/wxpython/menustrings.py:882
-#: ../gui/wxpython/menustrings.py:1788
-msgid "Query"
-msgstr "Kueri"
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:127
-#, fuzzy
-msgid "Set SQL statement to default"
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:130
-#, fuzzy
-msgid "Apply SQL statement in Attribute Table Manager"
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:132
-#, fuzzy
-msgid "Close the dialog"
-msgstr "Tutup dialog di akhir perintah"
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:219
-#, fuzzy
-msgid "Columns"
-msgstr "Volume"
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:233
-#, fuzzy
-msgid "Interactive insertion"
-msgstr "Potongan melintang"
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:247
-#, fuzzy
-msgid "Values"
-msgstr "Volume"
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:257
-#, fuzzy
-msgid "Get all values"
-msgstr "Nilai sel"
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:262
-#, fuzzy
-msgid "Get sample"
-msgstr "Tetapkan nilai"
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:264
-msgid "Get first 256 unique values as sample"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:283
-#, fuzzy
-msgid "Go to:"
-msgstr "Ekspor MPEG-1"
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:296
-#, fuzzy
-msgid "Close dialog on apply"
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:471
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:616
-#, python-format
-msgid "GRASS SQL Builder (%(type)s) - <%(map)s>"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:474
-msgid "Column to show (SELECT clause)"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:475
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:620
-msgid "Constraint for query (WHERE clause)"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:487 ../gui/wxpython/dbmgr/base.py:1198
-#: ../gui/wxpython/dbmgr/base.py:1224
-#, python-format
-msgid "Example: %s"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:491
-#, fuzzy
-msgid "Verify"
-msgstr "Georektifikasi "
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:492
-#, fuzzy
-msgid "Verify SQL statement"
-msgstr "Pernyataan SQL"
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:500
-#, fuzzy
-msgid "SQL statement not verified"
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:544
-#, fuzzy
-msgid "SQL statement is not valid"
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:546
-#, python-format
-msgid ""
-"SQL statement is not valid.\n"
-"\n"
-"%s"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:548
-#, fuzzy
-msgid "SQL statement is valid"
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:619
-msgid "Column to set (SET clause)"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:621
-msgid "Calculate column value to set"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:693
-#, fuzzy
-msgid "Functions"
-msgstr "Arah"
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:726
-#, fuzzy
-msgid "SQL statement was not applied"
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:728
-#, fuzzy
-msgid "SQL statement applied"
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:762
-msgid "Dbf driver does not support usage of SQL functions."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:154 ../gui/wxpython/iscatt/controllers.py:139
-msgid "Loading data..."
-msgstr "Menampilkan data..."
-#: ../gui/wxpython/dbmgr/base.py:161
-#, python-format
-msgid ""
-"Attribute table <%s> not found. For creating the table switch to 'Manage "
-"layers' tab."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:172
-msgid "Column <%(column)s> not found in in the table <%(table)s>."
-msgstr "Kolom <%(column)> sudah ada di dalam tabel <%(table)>."
-#: ../gui/wxpython/dbmgr/base.py:245
-msgid "Can display only 256 columns."
-msgstr "Hanya dapat menampilkan 256 kolom."
-#: ../gui/wxpython/dbmgr/base.py:264
-msgid "Inconsistent number of columns in the table <%(table)s>."
-#: ../gui/wxpython/dbmgr/base.py:274
-#, fuzzy
-msgid "Viewing limit: 100000 records."
-msgstr "Batasi hingga 100000 rekap"
-#: ../gui/wxpython/dbmgr/base.py:326
-#, fuzzy
-msgid "Unknown value"
-#: ../gui/wxpython/dbmgr/base.py:332
-msgid "Unable to decode value. Set encoding in GUI preferences ('Attributes')."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:343
-msgid ""
-"Error loading attribute data. Record number: %(rec)d. Unable to convert "
-"value '%(val)s' in key column (%(key)s) to integer.\n"
-"\n"
-"Details: %(detail)s"
-msgstr ""
-"Ada kesalahan dalam memuat data atribut. Nomor rekaman: %d. Tidak dapat "
-"menampilkan nilai'%s' dalam kolom kunci (%s) menjadi integer.\n"
-"\n"
-"Detil: %s"
-#: ../gui/wxpython/dbmgr/base.py:437
-#, fuzzy
-msgid "Sort ascending"
-msgstr "Mulai edit"
-#: ../gui/wxpython/dbmgr/base.py:438
-#, fuzzy
-msgid "Sort descending"
-#: ../gui/wxpython/dbmgr/base.py:442
-msgid "Calculate (only numeric columns)"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:445
-#, fuzzy
-msgid "Field calculator"
-msgstr "Kalkulator peta "
-#: ../gui/wxpython/dbmgr/base.py:447 ../gui/wxpython/wxplot/dialogs.py:290
-#, fuzzy
-msgid "Statistics"
-msgstr "Statistik umum"
-#: ../gui/wxpython/dbmgr/base.py:452 ../gui/wxpython/dbmgr/base.py:2292
-#: ../gui/wxpython/modules/colorrules.py:1139
-#, fuzzy
-msgid "Add column"
-msgstr "Tambah kolom"
-#: ../gui/wxpython/dbmgr/base.py:464
-msgid "Area size"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:465
-#, fuzzy
-msgid "Line length"
-msgstr "panjang"
-#: ../gui/wxpython/dbmgr/base.py:468
-msgid "Compactness of an area"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:470
-msgid "Fractal dimension of boundary defining a polygon"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:473
-msgid "Perimeter length of an area"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:475
-msgid "Number of features for each category"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:478
-msgid "Slope steepness of 3D line"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:479
-#, fuzzy
-msgid "Line sinuousity"
-#: ../gui/wxpython/dbmgr/base.py:480
-#, fuzzy
-msgid "Line azimuth"
-msgstr "Lebar garis"
-#: ../gui/wxpython/dbmgr/base.py:614
-msgid "Add column to table <%s>"
-#: ../gui/wxpython/dbmgr/base.py:1010
-msgid "Unable to add column to the table. No column name defined."
-msgstr ""
-"Tidak mampu menambah kolom ke dalam tabel. Tidak ada nama kolom yang "
-"diberikan."
-#: ../gui/wxpython/dbmgr/base.py:1024
-#, python-format
-msgid "Column <%(column)s> already exists in table <%(table)s>."
-msgstr "Kolom <%(column)s> sudah ada di dalam tabel <%(table)s>."
-#: ../gui/wxpython/dbmgr/base.py:1107
-msgid "Attribute data - right-click to edit/manage records"
-msgstr "Data atribut - klik-kanan untuk edit/kelola rekap"
-#: ../gui/wxpython/dbmgr/base.py:1122 ../gui/wxpython/dbmgr/base.py:2245
-#: ../gui/wxpython/dbmgr/base.py:2940 ../gui/wxpython/dbmgr/base.py:3075
-#: ../gui/wxpython/dbmgr/base.py:3344
-msgid "Table"
-msgstr "Tabel"
-#: ../gui/wxpython/dbmgr/base.py:1124 ../gui/wxpython/dbmgr/base.py:2247
-msgid " (readonly)"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1138
-msgid "SQL Query"
-msgstr "Kueri SQL"
-#: ../gui/wxpython/dbmgr/base.py:1168
-msgid "Simple"
-msgstr "Sederhana"
-#: ../gui/wxpython/dbmgr/base.py:1175
-msgid "Apply SELECT statement and reload data records"
-msgstr "Terapkan pernyataan SELECT dan tampilkan ulang rekap data"
-#: ../gui/wxpython/dbmgr/base.py:1209
-#, fuzzy
-msgid "Builder"
-msgstr "Pembuat SQL"
-#: ../gui/wxpython/dbmgr/base.py:1214
-msgid "SQL Builder"
-#: ../gui/wxpython/dbmgr/base.py:1391 ../gui/wxpython/core/settings.py:863
-msgid "Edit selected record"
-msgstr "Edit rekap terpilih"
-#: ../gui/wxpython/dbmgr/base.py:1396 ../gui/wxpython/dbmgr/base.py:1585
-msgid "Insert new record"
-msgstr "Masukkan rekap baru "
-#: ../gui/wxpython/dbmgr/base.py:1397
-msgid "Delete selected record(s)"
-msgstr "Hapus rekap terpilih"
-#: ../gui/wxpython/dbmgr/base.py:1398
-msgid "Delete all records"
-msgstr "Hapus semua rekap"
-#: ../gui/wxpython/dbmgr/base.py:1404 ../gui/wxpython/gui_core/dialogs.py:768
-#: ../gui/wxpython/gui_core/dialogs.py:836
-#: ../gui/wxpython/gui_core/dialogs.py:1576
-#: ../gui/wxpython/gui_core/widgets.py:953
-msgid "Select all"
-msgstr "Pilih semua"
-#: ../gui/wxpython/dbmgr/base.py:1405 ../gui/wxpython/gui_core/dialogs.py:1578
-#: ../gui/wxpython/gui_core/widgets.py:954
-msgid "Deselect all"
-msgstr "Tidak-pilih semua"
-#: ../gui/wxpython/dbmgr/base.py:1407
-#: ../gui/wxpython/gui_core/preferences.py:1447
-#, fuzzy
-msgid "Highlight selected features"
-msgstr "Digitasi fitur garis"
-#: ../gui/wxpython/dbmgr/base.py:1410
-msgid "Highlight selected features and zoom"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1414 ../gui/wxpython/dbmgr/base.py:1925
-#, fuzzy
-msgid "Extract selected features"
-msgstr "Ekstrak yang terpilih"
-#: ../gui/wxpython/dbmgr/base.py:1415
-#, fuzzy
-msgid "Delete selected features"
-#: ../gui/wxpython/dbmgr/base.py:1423 ../gui/wxpython/dbmgr/base.py:2573
-#: ../gui/wxpython/vdigit/dialogs.py:290
-#: ../gui/wxpython/gmodeler/dialogs.py:851
-#: ../gui/wxpython/gmodeler/dialogs.py:1017
-msgid "Reload"
-msgstr "Muat-ulang"
-#: ../gui/wxpython/dbmgr/base.py:1478
-msgid "Update existing record"
-msgstr "Perbaharui rekap yang sudah ada"
-#: ../gui/wxpython/dbmgr/base.py:1505 ../gui/wxpython/dbmgr/base.py:1618
-msgid "Value '%(value)s' needs to be entered as %(type)s."
-#: ../gui/wxpython/dbmgr/base.py:1524
-msgid ""
-"Unable to update existing record.\n"
-"%s"
-msgstr "Tidak dapat memperbaharui rekaman yang ada."
-#: ../gui/wxpython/dbmgr/base.py:1596
-#, python-format
-msgid "Record with category number %d already exists in the table."
-msgstr "Rekap dengan nomor kategori %d sudah ada di dalam tabel."
-#: ../gui/wxpython/dbmgr/base.py:1606
-#, python-format
-msgid "Category number (column %s) is missing."
-msgstr "Nomor kategori (kolom %s) tidak ada."
-#: ../gui/wxpython/dbmgr/base.py:1630
-msgid ""
-"Unable to insert new record.\n"
-"%s"
-msgstr "Tidak dapat memasukkan rekap baru"
-#: ../gui/wxpython/dbmgr/base.py:1683
-#, python-format
-msgid ""
-"Selected data records (%d) will be permanently deleted from table. Do you "
-"want to delete them?"
-msgstr ""
-"Rekaman data terpilih (%d) akan dihapus secara permanen dari tabel. Anda "
-"benar-benar ingin menghapusnya?"
-#: ../gui/wxpython/dbmgr/base.py:1686 ../gui/wxpython/dbmgr/base.py:1736
-msgid "Delete records"
-msgstr "Hapus rekap"
-#: ../gui/wxpython/dbmgr/base.py:1733
-#, python-format
-msgid ""
-"All data records (%d) will be permanently deleted from table. Do you want to "
-"delete them?"
-msgstr ""
-"Semua rekaman data (%d) akan dihapus secara permanen dari tabel. Apakah Anda "
-#: ../gui/wxpython/dbmgr/base.py:1920
-msgid "Nothing to extract."
-#: ../gui/wxpython/dbmgr/base.py:1954
-#, fuzzy
-msgid "Nothing to delete."
-#: ../gui/wxpython/dbmgr/base.py:2025 ../gui/wxpython/dbmgr/base.py:2061
-msgid ""
-"Loading attribute data failed.\n"
-"\n"
-"%s"
-msgstr ""
-"\n"
-"'%s'"
-#: ../gui/wxpython/dbmgr/base.py:2044
-msgid ""
-"Invalid SQL select statement.\n"
-"\n"
-"%s"
-msgstr ""
-"\n"
-"'%s'"
-#: ../gui/wxpython/dbmgr/base.py:2280
-msgid "Table <%s> - right-click to delete column(s)"
-msgstr "Tabel %s - klik-kanan untuk menghapus rekaman"
-#: ../gui/wxpython/dbmgr/base.py:2355 ../gui/wxpython/menustrings.py:900
-#: ../gui/wxpython/menustrings.py:1806
-msgid "Rename column"
-msgstr "Ubah nama kolom"
-#: ../gui/wxpython/dbmgr/base.py:2384 ../gui/wxpython/gmodeler/dialogs.py:359
-msgid "To"
-msgstr "Ke"
-#: ../gui/wxpython/dbmgr/base.py:2502
-msgid "Unable to rename column. No column name defined."
-msgstr "Tidak mampu merubah kolom. Tidak ada nama kolom seperti yang diminta."
-#: ../gui/wxpython/dbmgr/base.py:2510
-#, python-format
-msgid ""
-"Unable to rename column <%(column)s> to <%(columnTo)s>. Column already "
-"exists in the table <%(table)s>."
-msgstr ""
-"Tidak mampu merubah nama kolom <%(column)s> ke <%(columnTo)s>. Kolom sudah "
-"ada dalam tabel <%(table)s>."
-#: ../gui/wxpython/dbmgr/base.py:2528
-#, python-format
-msgid ""
-"Unable to rename column. Column <%(column)s> doesn't exist in the table <"
-"%(table)s>."
-msgstr ""
-"Tidak mampu merubah nama kolom. Kolom <%(column)s> tidak ada di dalam tabel <"
-"%(table)s>."
-#: ../gui/wxpython/dbmgr/base.py:2567
-msgid "Drop selected column"
-msgstr "Hapus kolom terpilih"
-#: ../gui/wxpython/dbmgr/base.py:2571
-msgid "Drop all columns"
-msgstr "Hapus semua kolom"
-#: ../gui/wxpython/dbmgr/base.py:2603
-msgid ""
-"Selected %s will PERMANENTLY removed from table. Do you want to drop the "
-"column?"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2606 ../gui/wxpython/dbmgr/base.py:2650
-#, fuzzy
-msgid "Drop column(s)"
-#: ../gui/wxpython/dbmgr/base.py:2647
-msgid ""
-"Selected columns\n"
-"%s\n"
-"will PERMANENTLY removed from table. Do you want to drop the columns?"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2753
-msgid "List of layers"
-#: ../gui/wxpython/dbmgr/base.py:2838 ../gui/wxpython/dbmgr/base.py:3266
-#: ../gui/wxpython/dbmgr/base.py:3698
-#, python-format
-msgid "Drop also linked attribute table (%s)"
-msgstr "Hapus juga tabel atribut terpaut (%s)"
-#: ../gui/wxpython/dbmgr/base.py:2881
-msgid "Column name"
-#: ../gui/wxpython/dbmgr/base.py:2881 ../gui/wxpython/gmodeler/frame.py:1636
-#: ../gui/wxpython/gmodeler/frame.py:1689
-msgid "Data type"
-msgstr "Tipe data"
-msgid "Data length"
-msgstr "Panjang data"
-#: ../gui/wxpython/dbmgr/base.py:2938 ../gui/wxpython/dbmgr/base.py:3064
-#: ../gui/wxpython/dbmgr/base.py:3332
-msgid "Driver"
-msgstr "Driver"
-#: ../gui/wxpython/dbmgr/base.py:2939 ../gui/wxpython/dbmgr/base.py:3069
-#: ../gui/wxpython/dbmgr/base.py:3338 ../gui/wxpython/gui_core/gselect.py:1421
-msgid "Database"
-msgstr "Basisdata"
-#: ../gui/wxpython/dbmgr/base.py:2941
-msgid "Key"
-msgstr "Kunci"
-#: ../gui/wxpython/dbmgr/base.py:3040
-msgid "Add layer"
-#: ../gui/wxpython/dbmgr/base.py:3050
-msgid "Layer description"
-msgstr "Deskripsi layer"
-#: ../gui/wxpython/dbmgr/base.py:3080 ../gui/wxpython/dbmgr/base.py:3124
-#: ../gui/wxpython/dbmgr/base.py:3350
-msgid "Key column"
-#: ../gui/wxpython/dbmgr/base.py:3085
-msgid "Insert record for each category into table"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3107
-msgid "You need to add categories by v.category module."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3111
-msgid "Table description"
-msgstr "Deskripsi tabel"
-#: ../gui/wxpython/dbmgr/base.py:3119
-msgid "Table name"
-msgstr "Nama tabel"
-#: ../gui/wxpython/dbmgr/base.py:3133
-msgid "&Create table"
-#: ../gui/wxpython/dbmgr/base.py:3137
-#: ../gui/wxpython/web_services/dialogs.py:536
-msgid "&Add layer"
-msgstr "&Tambahkan layer"
-#: ../gui/wxpython/dbmgr/base.py:3141
-msgid "&Set default"
-msgstr "&Tentukan standar"
-#: ../gui/wxpython/dbmgr/base.py:3245
-#, fuzzy
-msgid "Remove layer"
-msgstr "Hapus layer peta"
-#: ../gui/wxpython/dbmgr/base.py:3248
-#, fuzzy
-msgid "Layer to remove"
-msgstr "Layer yang akan dihapus"
-#: ../gui/wxpython/dbmgr/base.py:3274
-#, fuzzy
-msgid "&Remove layer"
-#: ../gui/wxpython/dbmgr/base.py:3317
-#, fuzzy
-msgid "Modify layer"
-msgstr "&Modifikasi layer"
-#: ../gui/wxpython/dbmgr/base.py:3393
-msgid "&Modify layer"
-#: ../gui/wxpython/dbmgr/base.py:3442
-msgid ""
-"Unable to get list of tables.\n"
-"Please use db.connect to set database parameters."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3539
-msgid "Unable to create new table. Table name or key column name is missing."
-msgstr ""
-"Tidak dapat membuat sebuah tabel baru. Nama tabel atau nama kolom kunci "
-"tidak dapat ditemukan "
-#: ../gui/wxpython/dbmgr/base.py:3546
-msgid "Unable to create new table. Table <%s> already exists in the database."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3587
-msgid ""
-"Unable to add new layer to vector map <%(vector)s>. Layer %(layer)d already "
-"exists."
-msgstr ""
-"Tidak dapat menambahkan sebuah layer baru pada peta vektor <%(vektor)s>. "
-"Layer %(layer)d sudah ada."
-#: ../gui/wxpython/dbmgr/base.py:3756
-#, fuzzy
-msgid "Field statistics"
-#: ../gui/wxpython/dbmgr/base.py:3777
-#, fuzzy
-msgid "Copy statistics the clipboard (Ctrl+C)"
-msgstr "Salin perintah saat ini ke clipboard"
-#: ../gui/wxpython/dbmgr/base.py:3844
-msgid "Statistics is not support for DBF tables."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3871
-#, fuzzy
-msgid "Unable to calculte statistics."
-msgstr "Tidak mampu mengeset"
-#: ../gui/wxpython/dbmgr/base.py:3879
-#, python-format
-msgid ""
-"Unable to calculte statistics. Invalid number of lines %d (should be %d)."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3899
-#, fuzzy
-msgid "Unable to calculte standard deviation."
-msgstr "Tidak mampu membuat location baru"
-#: ../gui/wxpython/dbmgr/base.py:3905
-msgid "Field statistics <%s>"
-#: ../gui/wxpython/mapdisp/gprint.py:154
-msgid ""
-"There was a problem printing.\n"
-"Perhaps your current printer is not set correctly?"
-msgstr ""
-#: ../gui/wxpython/mapdisp/test_mapdisp.py:89
-#: ../gui/wxpython/core/render.py:779 ../gui/wxpython/gui_core/mapdisp.py:133
-#, python-format
-msgid "GRASS module '%s' not found. Unable to start map display window."
-msgstr ""
-#: ../gui/wxpython/mapdisp/test_mapdisp.py:147
-#, fuzzy
-msgid "Map window test frame"
-msgstr "Skala peta"
-#: ../gui/wxpython/mapdisp/test_mapdisp.py:166
-#, fuzzy
-msgid "Map display test"
-msgstr "Tampilan"
-#: ../gui/wxpython/mapdisp/test_mapdisp.py:176
-msgid "Map window API test frame"
-msgstr ""
-#: ../gui/wxpython/mapdisp/test_mapdisp.py:206
-msgid "Map window distance measurement test frame"
-msgstr ""
-#: ../gui/wxpython/mapdisp/test_mapdisp.py:237
-msgid "Map window profile tool test frame"
-msgstr ""
-#: ../gui/wxpython/mapdisp/test_mapdisp.py:284
-msgid "Map window rlisetup test frame"
-msgstr ""
-#: ../gui/wxpython/mapdisp/test_mapdisp.py:345
-#, python-format
-msgid "Unknown value %s of test parameter."
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:418
-msgid "Render"
-msgstr "Render"
-#: ../gui/wxpython/mapdisp/statusbar.py:422
-msgid "Enable/disable auto-rendering"
-msgstr "Hidupkan/matikan render otomatis"
-#: ../gui/wxpython/mapdisp/statusbar.py:454
-msgid "Show comp. extent"
-msgstr "Tampilkan batas luar komputasi"
-#: ../gui/wxpython/mapdisp/statusbar.py:458
-msgid "Show computational extent"
-msgstr "Tampilkan batas komputasi"
-#: ../gui/wxpython/mapdisp/statusbar.py:464
-msgid ""
-"Show/hide computational region extent (set with g.region). Display region "
-"drawn as a blue box inside the computational region, computational region "
-"inside a display region as a red box)."
-msgstr ""
-"Tampilkan/sembunyikan batas region komputasi (tentukan dengan g.region). "
-"Region display ditampilkan sebagai sebuah kotak biru di dalam region "
-"komputasi, region komputasi di dalam region display sebagai sebuah kotak "
-"merah)."
-#: ../gui/wxpython/mapdisp/statusbar.py:515
-msgid "Display mode"
-msgstr "Mode tampilan"
-#: ../gui/wxpython/mapdisp/statusbar.py:520
-#: ../gui/wxpython/gui_core/preferences.py:880
-msgid "Align region extent based on display size"
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:526
-#, fuzzy
-msgid ""
-"Align region extent based on display size from center point. Default value "
-"for new map displays can be set up in 'User GUI settings' dialog."
-msgstr ""
-"Batas resolusi display sesuai pengaturan region komputasi. Nilai standar "
-"untuk tampilan peta baru dapat diatur di dalam dialog 'User GUI setting'."
-#: ../gui/wxpython/mapdisp/statusbar.py:560
-#, fuzzy
-msgid "Display resolution"
-#: ../gui/wxpython/mapdisp/statusbar.py:563
-#: ../gui/wxpython/gui_core/preferences.py:896
-msgid "Constrain display resolution to computational settings"
-msgstr "Batas resolusi display sesuai pengaturan komputasi"
-#: ../gui/wxpython/mapdisp/statusbar.py:569
-msgid ""
-"Constrain display resolution to computational region settings. Default value "
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:607
-msgid "Map scale"
-#: ../gui/wxpython/mapdisp/statusbar.py:624
-msgid ""
-"As everyone's monitors and resolutions are set differently these values are "
-"not true map scales, but should get you into the right neighborhood."
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:677
-msgid "Go to"
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:700
-#: ../gui/wxpython/mapdisp/statusbar.py:770
-#: ../gui/wxpython/mapdisp/statusbar.py:1009
-#: ../gui/wxpython/mapdisp/statusbar.py:1084
-msgid "Projection not defined (check the settings)"
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:787
-#: ../gui/wxpython/mapdisp/statusbar.py:1024
-#: ../gui/wxpython/mapdisp/statusbar.py:1125
-msgid "Error in projection (check the settings)"
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:824
-#: ../gui/wxpython/gui_core/preferences.py:1629
-#, fuzzy
-msgid "Projection"
-msgstr "Proyeksi:"
-#: ../gui/wxpython/mapdisp/statusbar.py:826
-#, fuzzy
-msgid "Use defined projection"
-msgstr "Pilih proyeksi"
-#: ../gui/wxpython/mapdisp/statusbar.py:841
-msgid ""
-"Reproject coordinates displayed in the statusbar. Projection can be defined "
-"in GUI preferences dialog (tab 'Projection')"
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:873
-msgid "MASK"
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:921
-msgid "Display geometry"
-msgstr "Geometri tampilan"
-#: ../gui/wxpython/mapdisp/statusbar.py:947
-msgid "Coordinates"
-msgstr "Koordinat"
-#: ../gui/wxpython/mapdisp/statusbar.py:1039
-msgid "Extent"
-msgstr "Batas luar"
-#: ../gui/wxpython/mapdisp/statusbar.py:1152
-#: ../gui/wxpython/web_services/dialogs.py:873
-#, fuzzy
-msgid "Computational region"
-msgstr "Perbesaran ke computational region (g.region)"
-#: ../gui/wxpython/mapdisp/frame.py:70
-msgid "GRASS GIS - Map display"
-msgstr "GRASS GIS - Map display"
-#: ../gui/wxpython/mapdisp/frame.py:248
-msgid ""
-"Failed to run command '{command}'. Details:\n"
-"{error}"
-msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:262
-msgid ""
-"GRASS GIS %(version)s Map Display: %(id)s - Location: %(loc)s@%(mapset)s"
-msgstr "GRASS GIS Map Display: "
-#: ../gui/wxpython/mapdisp/frame.py:319
-#, fuzzy
-msgid "Vector Digitizer Toolbar"
-#: ../gui/wxpython/mapdisp/frame.py:342
-#, python-format
-msgid ""
-"Unable to switch to 3D display mode.\n"
-"The Nviz python extension was not found or loaded properly.\n"
-"Switching back to 2D display mode.\n"
-"\n"
-"Details: %s"
-msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:377
-#, fuzzy
-msgid "Starting 3D view mode..."
-msgstr "Rentang yang valid"
-#: ../gui/wxpython/mapdisp/frame.py:379
-#, fuzzy
-msgid "Please wait, loading data..."
-#: ../gui/wxpython/mapdisp/frame.py:462
-#, fuzzy
-msgid "Please wait, unloading data..."
-#: ../gui/wxpython/mapdisp/frame.py:464
-#, fuzzy
-msgid "Switching back to 2D view mode..."
-#: ../gui/wxpython/mapdisp/frame.py:519
-#: ../gui/wxpython/mapdisp/toolbars.py:116
-#: ../gui/wxpython/vdigit/toolbars.py:953
-#, fuzzy
-msgid "Vector digitizer"
-#: ../gui/wxpython/mapdisp/frame.py:722 ../gui/wxpython/mapdisp/frame.py:730
-#: ../gui/wxpython/mapdisp/frame.py:745
-msgid "Failed to run d.to.rast:\n"
-msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:761
-msgid "d.to.rast can be used only in 2D mode."
-msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:893
-msgid "Vector map <%s> opened for editing - skipped."
-msgstr "Tidak ada peta vektor yang dipilih untuk diubah."
-#: ../gui/wxpython/mapdisp/frame.py:900 ../gui/wxpython/mapswipe/frame.py:674
-#, fuzzy
-msgid "No raster or vector map layer selected for querying."
-msgstr "Tidak ada peta vektor terpilih untuk kueri."
-#: ../gui/wxpython/mapdisp/frame.py:964
-msgid ""
-"Failed to query vector map(s) <{maps}>. Check database settings and topology."
-msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:1393
-#, fuzzy
-msgid "Set computational region extent from display"
-msgstr "Set region komputasi berdasarkan tampilan"
-#: ../gui/wxpython/mapdisp/frame.py:1395
-#, fuzzy
-msgid "Set computational region extent interactively"
-#: ../gui/wxpython/mapdisp/frame.py:1397
-#, fuzzy
-msgid "Set computational region from named region"
-#: ../gui/wxpython/mapdisp/frame.py:1402
-#, fuzzy
-msgid "Save computational region to named region"
-#: ../gui/wxpython/mapdisp/frame.py:1535
-#, fuzzy
-msgid "Raster Digitizer Toolbar"
-#: ../gui/wxpython/mapdisp/toolbars.py:29
-#: ../gui/wxpython/mapswipe/toolbars.py:36
-#, fuzzy
-msgid "Query raster/vector map(s)"
-msgstr "Kueri peta vektor/raster terpilih"
-#: ../gui/wxpython/mapdisp/toolbars.py:30
-#: ../gui/wxpython/mapswipe/toolbars.py:37
-msgid "Query selected raster/vector map(s)"
-#: ../gui/wxpython/mapdisp/toolbars.py:32
-#, fuzzy
-msgid "Select vector feature(s)"
-msgstr "Pilih fitur vektor"
-#: ../gui/wxpython/mapdisp/toolbars.py:33
-#, fuzzy
-msgid "Select features interactively from vector map"
-msgstr "Tidak bisa membuat sebuah peta vektor baru <%s>."
-#: ../gui/wxpython/mapdisp/toolbars.py:35
-#, fuzzy
-msgid "Add scale bar"
-#: ../gui/wxpython/mapdisp/toolbars.py:37
-#, fuzzy
-msgid "Add raster legend"
-msgstr "Tampilkan legenda"
-#: ../gui/wxpython/mapdisp/toolbars.py:39
-#, fuzzy
-msgid "Add vector legend"
-msgstr "Pilih garis"
-#: ../gui/wxpython/mapdisp/toolbars.py:41 ../gui/wxpython/menustrings.py:2017
-#, fuzzy
-msgid "Add north arrow"
-msgstr "Tambahkan skala garis dan arah utara"
-#: ../gui/wxpython/mapdisp/toolbars.py:43
-msgid "Analyze map"
-msgstr "Analisa peta"
-#: ../gui/wxpython/mapdisp/toolbars.py:44
-msgid "Measuring, profiling, histogramming, ..."
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:46
-msgid "Measure distance"
-msgstr "Pengukuran jarak"
-#: ../gui/wxpython/mapdisp/toolbars.py:48
-#, fuzzy
-msgid "Measure area"
-#: ../gui/wxpython/mapdisp/toolbars.py:50
-msgid "Profile surface map"
-msgstr "Profil peta permukaan"
-#: ../gui/wxpython/mapdisp/toolbars.py:52
-#, fuzzy
-msgid "Create bivariate scatterplot of raster maps"
-#: ../gui/wxpython/mapdisp/toolbars.py:54
-#: ../gui/wxpython/animation/dialogs.py:988
-#: ../gui/wxpython/menustrings.py:2013
-#, fuzzy
-msgid "Add text"
-msgstr "Tambahkan layer teks"
-#: ../gui/wxpython/mapdisp/toolbars.py:56
-#, fuzzy
-msgid "Create histogram of raster map"
-msgstr "Buat histogram dari berkas citra atau raster"
-#: ../gui/wxpython/mapdisp/toolbars.py:58 ../gui/wxpython/menustrings.py:627
-#: ../gui/wxpython/menustrings.py:1533
-#, fuzzy
-msgid "Vector network analysis tool"
-msgstr "Analisis jaringan"
-#: ../gui/wxpython/mapdisp/toolbars.py:64
-msgid "Rotate 3D scene"
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:65
-#, fuzzy
-msgid "Drag with mouse to rotate 3D scene"
-msgstr "Tarik dengan tetikus untuk menggeser "
-#: ../gui/wxpython/mapdisp/toolbars.py:70
-msgid ""
-"Drag with mouse, hold Ctrl down for different mode or Shift to accelerate"
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:73
-#, fuzzy
-msgid "Click mouse to zoom"
-msgstr "Tarik atau klik tetikus untuk memperbesar "
-#: ../gui/wxpython/mapdisp/toolbars.py:75
-#, fuzzy
-msgid "Click mouse to unzoom"
-msgstr "Tarik atau klik tetikus untuk memperkecil "
-#: ../gui/wxpython/mapdisp/toolbars.py:110
-msgid "3D view mode not available"
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:111
-#: ../gui/wxpython/mapdisp/toolbars.py:123
-msgid "Reason: %s"
-msgstr "Region "
-#: ../gui/wxpython/mapdisp/toolbars.py:122
-#, fuzzy
-msgid "Vector digitizer not available"
-#: ../gui/wxpython/mapdisp/toolbars.py:126
-msgid ""
-"Note that the wxGUI's vector digitizer is currently disabled (hopefully this "
-"will be fixed soon). Please keep an eye out for updated versions of GRASS. "
-"In the meantime you can use \"v.digit\" from the Develop Vector menu."
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:133
-#, fuzzy
-msgid "Raster digitizer"
-#: ../gui/wxpython/mapdisp/main.py:187
-msgid "Unsupported command %s."
-msgstr "Tidak dapat melakukan render layer peta <%s>."
-#: ../gui/wxpython/mapdisp/main.py:281
-msgid "Unable to read cmdfile '%(cmd)s'. Details: %(det)s"
-msgstr "Tidak dapat membaca kode EPSG: %s"
-#: ../gui/wxpython/mapdisp/main.py:604
-msgid "Starting map display <%s>..."
-msgstr "Mulai tampilan baru"
-#: ../gui/wxpython/mapdisp/main.py:610
-msgid "Unable to create file <%s>"
-msgstr "Tidak dapat membaca daftar: %s"
-#: ../gui/wxpython/mapdisp/main.py:626
-msgid "Stopping map display <%s>..."
-#: ../gui/wxpython/wxplot/profile.py:49
-#, fuzzy
-msgid "GRASS Profile Analysis Tool"
-msgstr "Analisis profil"
-#: ../gui/wxpython/wxplot/profile.py:65 ../gui/wxpython/wxplot/profile.py:173
-msgid "Profile of"
-msgstr "Profil dari"
-#: ../gui/wxpython/wxplot/profile.py:94
-#, python-format
-msgid "Distance (%s)"
-msgstr "Jarak (%s)"
-#: ../gui/wxpython/wxplot/profile.py:96
-msgid "Distance along transect"
-#: ../gui/wxpython/wxplot/profile.py:97
-msgid "Cell values"
-msgstr "Nilai sel"
-#: ../gui/wxpython/wxplot/profile.py:166
-msgid "Not all points of profile lie inside computational region."
-msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:237
-msgid "Raster values"
-msgstr "Nilai raster"
-#: ../gui/wxpython/wxplot/profile.py:290
-msgid "You must draw a transect to profile in the map display window."
-msgstr ""
-"Anda harus menggambar sebuah transet untuk membuat profil di dalam window "
-"map display."
-#: ../gui/wxpython/wxplot/profile.py:291
-msgid "Nothing to profile"
-msgstr "Tidak ada yang dapat dibuat profil"
-#: ../gui/wxpython/wxplot/profile.py:359
-msgid "Choose prefix for file(s) where to save profile values..."
-msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:361
-msgid "Comma separated value (*.csv)|*.csv"
-msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:372
-#: ../gui/wxpython/gmodeler/frame.py:1981
-#: ../gui/wxpython/gui_core/pyedit.py:333
-msgid "File <%s> already exists. Do you want to overwrite this file?"
-msgstr "Berkas Workspace <%s> sudah ada. Anda ingin menimpanya?"
-#: ../gui/wxpython/wxplot/profile.py:375
-msgid "Overwrite file?"
-msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:386
-msgid ""
-"Unable to open file <%s> for writing.\n"
-"Reason: %s"
-msgstr "Tidak mampu membuka berkas <%s> untuk dibaca."
-#: ../gui/wxpython/wxplot/profile.py:402
-#, python-format
-msgid ""
-"%d files created:\n"
-"%s"
-msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:405
-#, fuzzy
-msgid "No files generated."
-msgstr "Tidak ada layer peta yang dipilih untuk kueri."
-#: ../gui/wxpython/wxplot/profile.py:413
-#, fuzzy
-msgid "Statistics for Profile(s)"
-msgstr "Statistik untuk sel yang berkelompok (clumped cells)"
-#: ../gui/wxpython/wxplot/dialogs.py:41
-#, fuzzy
-msgid "Select raster maps to profile"
-msgstr "Pilih peta raster untuk dibuat profil"
-#: ../gui/wxpython/wxplot/dialogs.py:81
-#, fuzzy
-msgid "Select raster map(s) to profile:"
-#: ../gui/wxpython/wxplot/dialogs.py:132
-#, fuzzy
-msgid "Select pairs of raster maps for scatterplots"
-#: ../gui/wxpython/wxplot/dialogs.py:180
-msgid "Select pairs of raster maps for bivariate scatterplots:"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:195 ../gui/wxpython/wxplot/dialogs.py:502
-msgid "Number of bins (for FP maps)"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:360
-#, fuzzy
-msgid "C&opy"
-msgstr "Salin "
-#: ../gui/wxpython/wxplot/dialogs.py:362
-#, fuzzy
-msgid "Copy regression statistics the clipboard (Ctrl+C)"
-#: ../gui/wxpython/wxplot/dialogs.py:403
-#, fuzzy
-msgid "Regression statistics copied to clipboard"
-msgstr "'%s' berhasil disalin ke clipboard"
-#: ../gui/wxpython/wxplot/dialogs.py:414
-#, fuzzy
-msgid "Select raster map or imagery group to histogram"
-msgstr "Pilih peta raster 2 (opsional):"
-#: ../gui/wxpython/wxplot/dialogs.py:442
-#, fuzzy
-msgid "Histogram single raster"
-#: ../gui/wxpython/wxplot/dialogs.py:445
-msgid "Histogram imagery group"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:467
-#: ../gui/wxpython/modules/colorrules.py:413
-#, fuzzy
-msgid "Select raster map:"
-msgstr "Peta raster hasil kode-ulang:"
-#: ../gui/wxpython/wxplot/dialogs.py:486
-#, fuzzy
-msgid "Select image group:"
-msgstr "Pilih grup:"
-#: ../gui/wxpython/wxplot/dialogs.py:515
-#, fuzzy
-msgid "Histogram type"
-msgstr "Histogram"
-#: ../gui/wxpython/wxplot/dialogs.py:601
-#, fuzzy
-msgid "Selected group must be in current mapset"
-msgstr "Hapus berkas elemen basis data dari mapset saat ini milik pengguna."
-#: ../gui/wxpython/wxplot/dialogs.py:664 ../gui/wxpython/wxplot/base.py:517
-#: ../gui/wxpython/wxplot/base.py:584
-msgid "Text settings"
-msgstr "Pengaturan teks"
-#: ../gui/wxpython/wxplot/dialogs.py:674
-msgid "Profile title:"
-msgstr "Judul profil:"
-#: ../gui/wxpython/wxplot/dialogs.py:688
-msgid "Title font size (pts):"
-msgstr "Ukuran huruf judul (points):"
-#: ../gui/wxpython/wxplot/dialogs.py:705
-#, fuzzy
-msgid "X-axis label:"
-msgstr "Label Y-axis:"
-#: ../gui/wxpython/wxplot/dialogs.py:719
-msgid "Y-axis label:"
-#: ../gui/wxpython/wxplot/dialogs.py:733
-msgid "Label font size (pts):"
-msgstr "Ukuran huruf label (points):"
-#: ../gui/wxpython/wxplot/dialogs.py:761
-msgid "Font family:"
-msgstr "Jenis huruf:"
-#: ../gui/wxpython/wxplot/dialogs.py:777
-msgid "Style:"
-msgstr "Gaya:"
-#: ../gui/wxpython/wxplot/dialogs.py:793
-msgid "Weight:"
-msgstr "Berat:"
-#: ../gui/wxpython/wxplot/dialogs.py:832
-#: ../gui/wxpython/wxplot/dialogs.py:1430
-#, fuzzy
-msgid "Apply changes for the current session and close dialog"
-msgstr "Terapkan perubahan untuk sesi saat ini"
-#: ../gui/wxpython/wxplot/dialogs.py:904
-msgid "Plot text sizes saved to file '%s'."
-msgstr "Pengaturan profil disimpan ke dalam berkas '%s'."
-#: ../gui/wxpython/wxplot/dialogs.py:964
-#, fuzzy
-msgid "No map or image group selected to plot."
-#: ../gui/wxpython/wxplot/dialogs.py:965
-#: ../gui/wxpython/mapwin/buffered.py:2136
-#: ../gui/wxpython/core/workspace.py:1629 ../gui/wxpython/core/gcmd.py:140
-msgid "Warning"
-msgstr "Peringatan"
-#: ../gui/wxpython/wxplot/dialogs.py:986 ../gui/wxpython/wxplot/base.py:521
-#: ../gui/wxpython/wxplot/base.py:598
-#, fuzzy
-msgid "Plot settings"
-msgstr "Jenis huruf"
-#: ../gui/wxpython/wxplot/dialogs.py:1007
-msgid "Map/image plotted"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1019
-#, fuzzy
-msgid "Settings for selected map"
-msgstr "Tentukan region komputasi dari peta terpilih"
-#: ../gui/wxpython/wxplot/dialogs.py:1037
-msgid "Line color"
-#: ../gui/wxpython/wxplot/dialogs.py:1054
-#: ../gui/wxpython/vdigit/preferences.py:166
-msgid "Line width"
-#: ../gui/wxpython/wxplot/dialogs.py:1104
-msgid "Transect segment marker settings"
-msgstr "Pengaturan penanda segmen transek"
-#: ../gui/wxpython/wxplot/dialogs.py:1186
-#, fuzzy
-msgid "Scatterplot points"
-msgstr "Titik perturbasi"
-#: ../gui/wxpython/wxplot/dialogs.py:1268
-msgid "Axis settings"
-msgstr "Pengaturan axis"
-#: ../gui/wxpython/wxplot/dialogs.py:1274
-msgid "X-Axis"
-msgstr "X-Axis"
-#: ../gui/wxpython/wxplot/dialogs.py:1275
-msgid "Y-Axis"
-msgstr "Y-Axis"
-#: ../gui/wxpython/wxplot/dialogs.py:1284
-#, fuzzy
-msgid "Scale"
-msgstr "Gaya:"
-#: ../gui/wxpython/wxplot/dialogs.py:1296
-msgid ""
-"Automatic axis scaling, custom max and min, or scale matches data range (min)"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1304
-msgid "Custom min"
-msgstr "Bebas min."
-#: ../gui/wxpython/wxplot/dialogs.py:1321
-msgid "Custom max"
-msgstr "Bebas maks."
-#: ../gui/wxpython/wxplot/dialogs.py:1335
-msgid "Log scale"
-msgstr "Skala log"
-#: ../gui/wxpython/wxplot/dialogs.py:1359
-msgid "Grid and Legend settings"
-msgstr "Pengaturan grid dan legenda"
-#: ../gui/wxpython/wxplot/dialogs.py:1364
-msgid "Grid color"
-msgstr "Warna grid"
-#: ../gui/wxpython/wxplot/dialogs.py:1374
-msgid "Show grid"
-msgstr "Tampilkan grid"
-#: ../gui/wxpython/wxplot/dialogs.py:1383
-msgid "Legend font size"
-msgstr "Ukuran huruf legenda"
-#: ../gui/wxpython/wxplot/dialogs.py:1397
-msgid "Show legend"
-#: ../gui/wxpython/wxplot/dialogs.py:1597
-msgid "Plot settings saved to file '%s'."
-#: ../gui/wxpython/wxplot/histogram.py:43
-#, fuzzy
-msgid "GRASS GIS Histogramming Tool"
-#: ../gui/wxpython/wxplot/histogram.py:51
-#, fuzzy
-msgid "Histogram of"
-msgstr "Histogram"
-#: ../gui/wxpython/wxplot/histogram.py:52
-#: ../gui/wxpython/wxplot/histogram.py:156
-#: ../gui/wxpython/wxplot/scatter.py:52 ../gui/wxpython/wxplot/scatter.py:53
-#, fuzzy
-msgid "Raster cell values"
-#: ../gui/wxpython/wxplot/histogram.py:53
-#: ../gui/wxpython/wxplot/histogram.py:162
-#, fuzzy
-msgid "Cell counts"
-msgstr "Nilai sel"
-#: ../gui/wxpython/wxplot/histogram.py:141
-msgid "Histogram of image group <%s>"
-msgstr "Histogram"
-#: ../gui/wxpython/wxplot/histogram.py:145
-msgid "Histogram of raster map <%s>"
-#: ../gui/wxpython/wxplot/histogram.py:147
-#, fuzzy
-msgid "Histogram of selected raster maps"
-#: ../gui/wxpython/wxplot/histogram.py:154
-msgid "Raster cell values %s"
-#: ../gui/wxpython/wxplot/histogram.py:164
-msgid "Percent of total cells"
-msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:166
-#, fuzzy
-msgid "Area"
-msgstr "Simpan perubahan"
-#: ../gui/wxpython/wxplot/histogram.py:252
-msgid "Statistics for Map(s) Histogrammed"
-msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:257
-msgid "Statistics for raster map <%s>"
-msgstr "Statistik laporan untuk layer peta raster."
-#: ../gui/wxpython/wxplot/scatter.py:44
-msgid "GRASS Bivariate Scatterplot Tool"
-msgstr ""
-#: ../gui/wxpython/wxplot/scatter.py:51
-msgid "Bivariate Scatterplot"
-msgstr ""
-#: ../gui/wxpython/wxplot/scatter.py:102 ../gui/wxpython/wxplot/scatter.py:254
-#, fuzzy
-msgid "Nothing to plot."
-msgstr "Tidak ada yang dapat diekstrak."
-#: ../gui/wxpython/wxplot/scatter.py:113
-#, fuzzy
-msgid "At least 2 raster maps must be specified"
-msgstr "Pilih peta raster 1 (diperlukan):"
-#: ../gui/wxpython/wxplot/scatter.py:136
-msgid "Bivariate Scatterplot of "
-msgstr ""
-#: ../gui/wxpython/wxplot/scatter.py:157 ../gui/wxpython/wxplot/scatter.py:158
-msgid "Raster <%s> cell values"
-#: ../gui/wxpython/wxplot/scatter.py:162 ../gui/wxpython/wxplot/scatter.py:166
-msgid ": %s"
-msgstr "Deil:"
-#: ../gui/wxpython/wxplot/scatter.py:260
-#, fuzzy
-msgid "Regression Statistics for Scatterplot(s)"
-#: ../gui/wxpython/wxplot/scatter.py:271
-#, python-format
-msgid ""
-"Regression equation for raster map <%(rast1)s> vs. <%(rast2)s>:\n"
-"\n"
-msgstr ""
-#: ../gui/wxpython/wxplot/base.py:37
-#, fuzzy
-msgid "Draw/re-draw plot"
-msgstr "Gambar/gambar-ulang profil"
-#: ../gui/wxpython/wxplot/base.py:40
-msgid "Draw transect in map display window to profile"
-msgstr "Gambar transek dalam jendela tampilan peta untuk membuat profil"
-#: ../gui/wxpython/wxplot/base.py:43
-#, fuzzy
-msgid "Plot options"
-#: ../gui/wxpython/wxplot/base.py:46
-#, fuzzy
-msgid "Plot statistics"
-#: ../gui/wxpython/wxplot/base.py:49
-#, fuzzy
-msgid "Save profile data to CSV file"
-msgstr "Simpan tampilan ke dalam berkas PNG"
-#: ../gui/wxpython/wxplot/base.py:51
-msgid "Quit plot tool"
-msgstr ""
-#: ../gui/wxpython/wxplot/base.py:485
-#, fuzzy
-msgid "Left Mouse Down at Point:"
-msgstr "Klik kiri: titik baru"
-#: ../gui/wxpython/wxplot/base.py:534
-msgid "This feature is not yet functional"
-msgstr ""
-#: ../gui/wxpython/wxplot/base.py:535
-msgid "Under Construction"
-msgstr ""
-#: ../gui/wxpython/vdigit/g.gui.vdigit.py:69
-#, fuzzy
-msgid "GRASS GIS Vector Digitizer"
-msgstr "Toolbar digitasi vektor"
-#: ../gui/wxpython/vdigit/g.gui.vdigit.py:85
-msgid "Vector digitizer not available. %s"
-#: ../gui/wxpython/vdigit/g.gui.vdigit.py:90
-msgid ""
-"Vector map <%s> not found in current mapset. New vector map can be created "
-"by providing '-c' flag."
-msgstr "ERROR: Mapset <%s> tidak ada"
-#: ../gui/wxpython/vdigit/g.gui.vdigit.py:94
-msgid "New vector map <%s> created"
-msgstr "Peta vektor baru"
-#: ../gui/wxpython/vdigit/g.gui.vdigit.py:101
-msgid "Unable to create new vector map <%s>"
-#: ../gui/wxpython/vdigit/wxdisplay.py:1017
-#, python-format
-msgid ""
-"Topology for vector map <%s> is not available. Topology is required by "
-"digitizer. Do you want to rebuild topology (takes some time) and open the "
-"vector map for editing?"
-msgstr ""
-#: ../gui/wxpython/vdigit/wxdisplay.py:1022
-msgid "Topology missing"
-msgstr ""
-#: ../gui/wxpython/vdigit/mapwindow.py:424
-msgid "Update categories"
-msgstr "Perbaharui kategori"
-#: ../gui/wxpython/vdigit/mapwindow.py:548
-#: ../gui/wxpython/vdigit/mapwindow.py:957
-msgid "No vector map selected for editing."
-#: ../gui/wxpython/vdigit/mapwindow.py:557
-msgid "Nothing to do. Choose appropriate tool from digitizer toolbar."
-msgstr ""
-#: ../gui/wxpython/vdigit/mapwindow.py:1091
-msgid "Z bulk-labeling dialog"
-msgstr "Dialog pelabelan Z"
-#: ../gui/wxpython/vdigit/dialogs.py:79
-#, fuzzy
-msgid "List of categories - right-click to delete"
-#: ../gui/wxpython/vdigit/dialogs.py:110
-msgid "Add new category"
-msgstr "Tambahkan kategori baru"
-#: ../gui/wxpython/vdigit/dialogs.py:153
-msgid "Ignore changes and close dialog"
-msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:155
-#: ../gui/wxpython/web_services/dialogs.py:689
-#, fuzzy
-msgid "Apply changes and close dialog"
-msgstr "Terapkan perubahan untuk sesi ini"
-#: ../gui/wxpython/vdigit/dialogs.py:248 ../gui/wxpython/vdigit/dialogs.py:472
-#, python-format
-msgid ""
-"Unable to add new layer/category <%(layer)s/%(category)s>.\n"
-"Layer and category number must be integer.\n"
-"Layer number must be greater than zero."
-msgstr ""
-"Tidak mampu menambahkan layer/kategori baru <%(layer)s/%(category)s>.\n"
-"Layer dan kategori harus integer.\n"
-"Nomor layer harus lebih besar dari nol."
-#: ../gui/wxpython/vdigit/dialogs.py:284
-#: ../gui/wxpython/gmodeler/dialogs.py:844
-#: ../gui/wxpython/gmodeler/dialogs.py:1013
-msgid "Delete selected"
-msgstr "Hapus yang terpilih"
-#: ../gui/wxpython/vdigit/dialogs.py:288
-#: ../gui/wxpython/gmodeler/dialogs.py:845
-msgid "Delete all"
-msgstr "Hapus semua"
-#: ../gui/wxpython/vdigit/dialogs.py:446
-msgid "Unable to update vector map."
-msgstr "Tidak berhasil memperbaharui peta vektor."
-#: ../gui/wxpython/vdigit/dialogs.py:622
-#, python-format
-msgid "%d lines selected for z bulk-labeling"
-msgstr "%d garis dipilih untuk pelabelan z"
-#: ../gui/wxpython/vdigit/dialogs.py:630
-msgid "Set value"
-#: ../gui/wxpython/vdigit/dialogs.py:637
-msgid "Starting value"
-msgstr "Nilai awal"
-#: ../gui/wxpython/vdigit/dialogs.py:649
-msgid "Step"
-msgstr "Tahapan"
-#: ../gui/wxpython/vdigit/dialogs.py:692
-msgid "List of duplicates"
-#: ../gui/wxpython/vdigit/dialogs.py:801
-msgid "Feature id"
-msgstr "ID Fitur"
-#: ../gui/wxpython/vdigit/dialogs.py:802
-msgid "Layer (Categories)"
-msgstr "Layer (Kategori)"
-#: ../gui/wxpython/vdigit/toolbars.py:107
-msgid "Select area/boundary/centroid tool"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:133
-msgid "Digitize new point"
-msgstr "Digitasi titik baru "
-#: ../gui/wxpython/vdigit/toolbars.py:134
-#: ../gui/wxpython/vdigit/toolbars.py:143
-#: ../gui/wxpython/vdigit/toolbars.py:146
-msgid "Left: new point"
-#: ../gui/wxpython/vdigit/toolbars.py:136
-msgid "Digitize new line"
-msgstr "Digitasi garis baru "
-#: ../gui/wxpython/vdigit/toolbars.py:137
-#: ../gui/wxpython/vdigit/toolbars.py:140
-#: ../gui/wxpython/vdigit/toolbars.py:164
-#, fuzzy
-msgid "Left: new point; Ctrl+Left: undo last point; Right: close line"
-msgstr ""
-"Klik kiri: titik baru; Klik tengah: gagalkan titik terakhir; Klik kanan: "
-"tutup garis"
-#: ../gui/wxpython/vdigit/toolbars.py:139
-msgid "Digitize new boundary"
-msgstr "Digitasi batas baru "
-#: ../gui/wxpython/vdigit/toolbars.py:142
-msgid "Digitize new centroid"
-msgstr "Digitasi centroid baru "
-#: ../gui/wxpython/vdigit/toolbars.py:145
-#, fuzzy
-msgid "Digitize new area (boundary without category)"
-#: ../gui/wxpython/vdigit/toolbars.py:148
-#, fuzzy
-msgid "Add new vertex to line or boundary"
-msgstr "Bangun polyline dari garis atau batas."
-#: ../gui/wxpython/vdigit/toolbars.py:149
-#: ../gui/wxpython/vdigit/toolbars.py:152
-#: ../gui/wxpython/vdigit/toolbars.py:155
-#: ../gui/wxpython/vdigit/toolbars.py:167
-#: ../gui/wxpython/vdigit/toolbars.py:170
-#: ../gui/wxpython/vdigit/toolbars.py:173
-#: ../gui/wxpython/vdigit/toolbars.py:182
-#, fuzzy
-msgid "Left: Select; Ctrl+Left: Unselect; Right: Confirm"
-msgstr "Klik kiri: Pilih; Klik tengah: Tidak jadi pilih; Klik kanan: Tetapkan"
-#: ../gui/wxpython/vdigit/toolbars.py:151
-#, fuzzy
-msgid "Delete selected point(s), line(s), boundary(ies) or centroid(s)"
-msgstr "Tarik garis/batas terpilih (hanya ke simpul)"
-#: ../gui/wxpython/vdigit/toolbars.py:154
-#, fuzzy
-msgid "Delete selected area(s)"
-#: ../gui/wxpython/vdigit/toolbars.py:157
-msgid "Display/update attributes"
-msgstr "Tampilkan/ubah atribut"
-#: ../gui/wxpython/vdigit/toolbars.py:158
-#: ../gui/wxpython/vdigit/toolbars.py:161
-msgid "Left: Select"
-msgstr "Klik kiri: Pilih"
-#: ../gui/wxpython/vdigit/toolbars.py:160
-msgid "Display/update categories"
-msgstr "Tampilkan/ubah kategori"
-#: ../gui/wxpython/vdigit/toolbars.py:163
-#, fuzzy
-msgid "Edit selected line/boundary"
-msgstr "Balikkan garis/batas terpilih"
-#: ../gui/wxpython/vdigit/toolbars.py:166
-#, fuzzy
-msgid "Move selected point(s), line(s), boundary(ies) or centroid(s)"
-#: ../gui/wxpython/vdigit/toolbars.py:169
-#, fuzzy
-msgid "Move selected vertex"
-#: ../gui/wxpython/vdigit/toolbars.py:172
-#, fuzzy
-msgid "Remove selected vertex"
-msgstr "Ubah nama mapset terpilih"
-#: ../gui/wxpython/vdigit/toolbars.py:174
-#: ../gui/wxpython/vdigit/preferences.py:33
-msgid "Digitization settings"
-msgstr "Pengaturan digitasi"
-#: ../gui/wxpython/vdigit/toolbars.py:175
-#, fuzzy
-msgid "Quit digitizer"
-#: ../gui/wxpython/vdigit/toolbars.py:176
-msgid "Quit digitizer and save changes"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:177
-#, fuzzy
-msgid "Vector Digitizer manual"
-#: ../gui/wxpython/vdigit/toolbars.py:178
-#, fuzzy
-msgid "Show Vector Digitizer manual"
-#: ../gui/wxpython/vdigit/toolbars.py:180
-msgid "Additional tools (copy, flip, connect, etc.)"
-msgstr "Perkakas tambahan (salin, putar, hubungkan, dsb.)"
-#: ../gui/wxpython/vdigit/toolbars.py:185
-msgid "Undo previous changes"
-msgstr "Gagalkan perubahan sebelumnya"
-#: ../gui/wxpython/vdigit/toolbars.py:187
-msgid "Redo"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:188
-#, fuzzy
-msgid "Redo previous changes"
-#: ../gui/wxpython/vdigit/toolbars.py:558
-msgid "Break selected lines/boundaries at intersection"
-msgstr "Potong garis/batas terpilih pada interseksi"
-#: ../gui/wxpython/vdigit/toolbars.py:560
-msgid "Connect selected lines/boundaries"
-msgstr "Hubungkan garis/batas terpilih"
-#: ../gui/wxpython/vdigit/toolbars.py:562
-msgid "Copy categories"
-msgstr "Salin kategori "
-#: ../gui/wxpython/vdigit/toolbars.py:564
-msgid "Copy features from (background) vector map"
-msgstr "Salin fitur dari peta vektor (background)"
-#: ../gui/wxpython/vdigit/toolbars.py:566
-#, fuzzy
-msgid "Copy attributes"
-#: ../gui/wxpython/vdigit/toolbars.py:568
-msgid "Feature type conversion"
-msgstr "Konversi tipe fitur"
-#: ../gui/wxpython/vdigit/toolbars.py:570
-msgid "Flip selected lines/boundaries"
-#: ../gui/wxpython/vdigit/toolbars.py:572
-msgid "Merge selected lines/boundaries"
-msgstr "Gabungkan garis/batas terpilih"
-#: ../gui/wxpython/vdigit/toolbars.py:574
-msgid "Snap selected lines/boundaries (only to nodes)"
-#: ../gui/wxpython/vdigit/toolbars.py:576
-msgid "Split line/boundary"
-msgstr "Pecah garis/batas"
-#: ../gui/wxpython/vdigit/toolbars.py:578
-#, fuzzy
-msgid "Query features"
-msgstr "Fitur terdekat"
-#: ../gui/wxpython/vdigit/toolbars.py:580
-msgid "Z bulk-labeling of 3D lines"
-msgstr "Pelabelan Z dari garis 3D"
-#: ../gui/wxpython/vdigit/toolbars.py:602 ../gui/wxpython/vdigit/wxdigit.py:63
-#, fuzzy
-msgid "No vector map open for editing."
-#: ../gui/wxpython/vdigit/toolbars.py:607
-#, fuzzy
-msgid "Select background vector map"
-msgstr "Pilih peta vektor"
-#: ../gui/wxpython/vdigit/toolbars.py:767
-#, fuzzy
-msgid "Vector map is not 3D. Operation canceled."
-msgstr "Tidak ada layer peta terpilih. Operasi digagalkan."
-#: ../gui/wxpython/vdigit/toolbars.py:841
-#: ../gui/wxpython/vdigit/toolbars.py:998
-#: ../gui/wxpython/vdigit/toolbars.py:1096
-#: ../gui/wxpython/gui_core/dialogs.py:213
-msgid "Select vector map"
-#: ../gui/wxpython/vdigit/toolbars.py:873
-#, python-format
-msgid ""
-"digitizer.\n"
-"Do you want to rebuild topology (takes some time) and open the vector map "
-"for editing?"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:878
-#, fuzzy
-msgid "Digitizer error"
-#: ../gui/wxpython/vdigit/toolbars.py:903
-msgid "Please wait, opening vector map <%s> for editing..."
-#: ../gui/wxpython/vdigit/toolbars.py:941
-msgid ""
-"Unsupported feature type '%(type)s'. Unable to edit OGR layer <%(layer)s>."
-msgstr "Nilai koordinat tidak valid. Operasi dibatalkan."
-#: ../gui/wxpython/vdigit/toolbars.py:1011
-#, python-format
-msgid "Do you want to save changes in vector map <%s>?"
-msgstr "Apakah Anda ingin menyimpan perubahan dalam peta vektor <%s>?"
-#: ../gui/wxpython/vdigit/toolbars.py:1014
-msgid "Save changes?"
-msgstr "Simpan perubahan?"
-#: ../gui/wxpython/vdigit/toolbars.py:1021
-msgid "Please wait, closing and rebuilding topology of vector map <%s>..."
-msgstr "Tool untuk membersihkan topologi peta vektor."
-#: ../gui/wxpython/vdigit/toolbars.py:1039
-msgid "Editing of vector map <%s> successfully finished"
-#: ../gui/wxpython/vdigit/toolbars.py:1104
-#: ../gui/wxpython/vdigit/toolbars.py:1111
-msgid "New vector map"
-#: ../gui/wxpython/vdigit/preferences.py:64
-msgid "Apply changes for this session"
-#: ../gui/wxpython/vdigit/preferences.py:68
-msgid "Close dialog and save changes to user settings file"
-msgstr ""
-"Tutup dialog dan simpan perubahan ke dalam berkas pengaturan milik pengguna"
-#: ../gui/wxpython/vdigit/preferences.py:150
-#: ../gui/wxpython/animation/dialogs.py:340
-#: ../gui/wxpython/animation/dialogs.py:1854
-#: ../gui/wxpython/gmodeler/preferences.py:54
-#: ../gui/wxpython/gui_core/preferences.py:281
-msgid "General"
-msgstr "Umum"
-#: ../gui/wxpython/vdigit/preferences.py:202
-msgid "Snapping"
-msgstr "Snapping"
-#: ../gui/wxpython/vdigit/preferences.py:211
-msgid "Snapping threshold"
-msgstr "Batas snapping"
-#: ../gui/wxpython/vdigit/preferences.py:220
-msgid "screen pixels"
-msgstr ""
-msgid "map units"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:240
-msgid "Snap also to vertex"
-msgstr "Snap juga ke vertex"
-#: ../gui/wxpython/vdigit/preferences.py:250
-#: ../gui/wxpython/vdigit/preferences.py:905
-#: ../gui/wxpython/vdigit/preferences.py:919
-#: ../gui/wxpython/vdigit/preferences.py:923
-#, python-format
-msgid "Snapping threshold is %(value).1f %(units)s"
-msgstr "Batasan snapping adalah %(value).1f %(units)s"
-#: ../gui/wxpython/vdigit/preferences.py:268
-msgid "Select vector features"
-#: ../gui/wxpython/vdigit/preferences.py:288
-msgid "Select threshold"
-msgstr "Pilih batas"
-#: ../gui/wxpython/vdigit/preferences.py:309
-msgid "Select only features inside of selection bounding box"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:316
-msgid ""
-"By default are selected all features overlapping selection bounding box "
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:319
-msgid "Check for duplicates"
-msgstr "Periksa untuk duplikasi"
-#: ../gui/wxpython/vdigit/preferences.py:345
-#, fuzzy
-msgid "Digitize lines/boundaries"
-#: ../gui/wxpython/vdigit/preferences.py:349
-#, fuzzy
-msgid "Break lines at intersection"
-msgstr "Potong garis pada interseksi"
-#: ../gui/wxpython/vdigit/preferences.py:372
-#, fuzzy
-msgid "Digitize areas"
-#: ../gui/wxpython/vdigit/preferences.py:376
-msgid "Close boundary (snap to the start node)"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:399
-msgid "Save changes"
-#: ../gui/wxpython/vdigit/preferences.py:402
-msgid "Save changes on exit"
-msgstr "Simpan perubahan saat keluar"
-#: ../gui/wxpython/vdigit/preferences.py:423
-msgid "Query tool"
-msgstr "Alat kueri"
-#: ../gui/wxpython/vdigit/preferences.py:434
-msgid "Choose query tool"
-msgstr "Pilih tool kueri"
-#: ../gui/wxpython/vdigit/preferences.py:442
-msgid "Select by box"
-msgstr "Pilih dengan kotak"
-#: ../gui/wxpython/vdigit/preferences.py:460
-#: ../gui/wxpython/vdigit/preferences.py:694
-msgid "length"
-msgstr "panjang"
-#: ../gui/wxpython/vdigit/preferences.py:472
-msgid "Select lines"
-#: ../gui/wxpython/vdigit/preferences.py:475
-#: ../gui/wxpython/vdigit/preferences.py:529
-msgid "shorter than"
-msgstr "lebih pendek dari"
-msgid "longer than"
-msgstr "lebih jauh dari"
-#: ../gui/wxpython/vdigit/preferences.py:514
-msgid "dangle"
-msgstr "dangle"
-#: ../gui/wxpython/vdigit/preferences.py:526
-msgid "Select dangles"
-msgstr "Pilih dangle"
-#: ../gui/wxpython/vdigit/preferences.py:582
-#: ../gui/wxpython/gui_core/preferences.py:1438
-msgid "Attributes"
-msgstr "Atribut"
-#: ../gui/wxpython/vdigit/preferences.py:593
-msgid "Digitize new feature"
-msgstr "Digitasi fitur baru"
-#: ../gui/wxpython/vdigit/preferences.py:598
-msgid "Add new record into table"
-msgstr "Tambahkan rekap baru ke dalam tabel"
-#: ../gui/wxpython/vdigit/preferences.py:613
-msgid "Mode"
-msgstr "Mode"
-#: ../gui/wxpython/vdigit/preferences.py:645
-msgid "Next to use"
-msgstr "Selanjutnya yang akan digunakan"
-#: ../gui/wxpython/vdigit/preferences.py:627
-msgid "Category number"
-msgstr "Nomor kategori"
-#: ../gui/wxpython/vdigit/preferences.py:643
-msgid "Category mode"
-msgstr "Mode kategori"
-msgid "Manual entry"
-msgstr "Input manual"
-msgid "No category"
-msgstr "Tidak ada kategori"
-#: ../gui/wxpython/vdigit/preferences.py:668
-msgid "Delete existing feature(s)"
-msgstr "Hapus fitur yang ada"
-#: ../gui/wxpython/vdigit/preferences.py:673
-msgid "Delete record from table"
-msgstr "Hapus rekap dari tabel"
-#: ../gui/wxpython/vdigit/preferences.py:691
-#, fuzzy
-msgid "Geometry attributes"
-msgstr "Kueri dengan atribut"
-#: ../gui/wxpython/vdigit/preferences.py:695
-#: ../gui/wxpython/modules/vclean.py:226
-msgid "area"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:696
-#, fuzzy
-msgid "perimeter"
-msgstr "Parameter"
-#: ../gui/wxpython/vdigit/preferences.py:767
-msgid ""
-"Note: These settings are stored in the workspace not in the vector digitizer "
-"preferences."
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:796
-#, fuzzy
-msgid "Digitize new line segment"
-#: ../gui/wxpython/vdigit/preferences.py:797
-#, fuzzy
-msgid "Digitize new line/boundary"
-#: ../gui/wxpython/vdigit/preferences.py:798
-msgid "Highlight"
-msgstr "Menyorot"
-#: ../gui/wxpython/vdigit/preferences.py:799
-msgid "Highlight (duplicates)"
-msgstr "Menyorot (duplikat)"
-#: ../gui/wxpython/vdigit/preferences.py:802
-msgid "Boundary (no area)"
-msgstr "Batas (bukan area)"
-#: ../gui/wxpython/vdigit/preferences.py:803
-msgid "Boundary (one area)"
-msgstr "Batas (satu area)"
-#: ../gui/wxpython/vdigit/preferences.py:804
-msgid "Boundary (two areas)"
-msgstr "Batas (dua area)"
-#: ../gui/wxpython/vdigit/preferences.py:805
-msgid "Centroid (in area)"
-msgstr "Centroid (dalam area)"
-#: ../gui/wxpython/vdigit/preferences.py:806
-msgid "Centroid (outside area)"
-msgstr "Centroid (di luar area)"
-#: ../gui/wxpython/vdigit/preferences.py:807
-msgid "Centroid (duplicate in area)"
-msgstr "Centroid (duplikasi dalam area)"
-#: ../gui/wxpython/vdigit/preferences.py:808
-msgid "Node (one line)"
-msgstr "Simpul (satu garis)"
-#: ../gui/wxpython/vdigit/preferences.py:809
-msgid "Node (two lines)"
-msgstr "Simpul (dua garis)"
-#: ../gui/wxpython/vdigit/preferences.py:810
-msgid "Vertex"
-msgstr "Vertex"
-#: ../gui/wxpython/vdigit/preferences.py:811
-msgid "Area (closed boundary + centroid)"
-msgstr "Area (batas tertutup + centroid)"
-#: ../gui/wxpython/vdigit/preferences.py:812
-msgid "Direction"
-msgstr "Arah"
-#: ../gui/wxpython/vdigit/preferences.py:896
-#, fuzzy
-msgid "Snapping disabled"
-#: ../gui/wxpython/vdigit/preferences.py:900
-#, fuzzy, python-format
-msgid "Snapping threshold is %(value).1f %(units)s (based on comp. resolution)"
-msgstr "Batasan snapping adalah %(value).1f%(units)"
-#: ../gui/wxpython/vdigit/preferences.py:956
-#, python-format
-msgid "Vector digitizer settings saved to file <%s>."
-msgstr "Pengaturan digitasi vektor disimpan ke dalam berkas <%s>."
-#: ../gui/wxpython/vdigit/wxdigit.py:56
-#, fuzzy
-msgid "Digitization Error"
-#: ../gui/wxpython/vdigit/wxdigit.py:61
-msgid "Unable to open vector map <%s>."
-#: ../gui/wxpython/vdigit/wxdigit.py:64
-#, fuzzy
-msgid "Operation canceled."
-#: ../gui/wxpython/vdigit/wxdigit.py:71
-msgid ""
-"Writing new feature failed. Operation canceled.\n"
-"\n"
-"Reason: %s"
-#: ../gui/wxpython/vdigit/wxdigit.py:80
-msgid "Reading feature id %d failed. Operation canceled."
-#: ../gui/wxpython/vdigit/wxdigit.py:88
-msgid "Database link %d not available. Operation canceled."
-#: ../gui/wxpython/vdigit/wxdigit.py:96
-msgid "Unable to start database driver <%s>. Operation canceled."
-#: ../gui/wxpython/vdigit/wxdigit.py:106
-msgid ""
-"Unable to open database <%(db)s> by driver <%(driver)s>. Operation canceled."
-#: ../gui/wxpython/vdigit/wxdigit.py:114
-msgid "Unable to execute SQL query '%s'. Operation canceled."
-#: ../gui/wxpython/vdigit/wxdigit.py:122
-msgid "Feature id %d is marked as dead. Operation canceled."
-msgstr "Paling tidak dibutuhkan %d GCP. Operasi dibatalkan."
-#: ../gui/wxpython/vdigit/wxdigit.py:130
-msgid "Unsupported feature type %d. Operation canceled."
-#: ../gui/wxpython/vdigit/wxdigit.py:500
-msgid "Unknown feature type '%s'"
-msgstr "ID Fitur"
-#: ../gui/wxpython/vdigit/wxdigit.py:505
-#, fuzzy
-msgid "Not enough points for line"
-msgstr "Buat titik sepanjang garis"
-#: ../gui/wxpython/animation/controller.py:234
-#, python-format
-msgid "Maximum number of animations is %s."
-msgstr ""
-#: ../gui/wxpython/animation/controller.py:262
-#: ../gui/wxpython/animation/dialogs.py:887
-msgid ""
-"More animations are using one window. Please select different window for "
-"each animation."
-msgstr ""
-#: ../gui/wxpython/animation/controller.py:443
-#, fuzzy
-msgid "Failed to display legend."
-#: ../gui/wxpython/animation/controller.py:475
-msgid "Inconsistent number of maps, please check input data."
-msgstr ""
-#: ../gui/wxpython/animation/controller.py:505
-#, fuzzy
-msgid "No animation to export."
-#: ../gui/wxpython/animation/controller.py:542
-#, fuzzy
-msgid "Preparing export, please wait..."
-msgstr "Rektifikasi citra atau raster"
-#: ../gui/wxpython/animation/controller.py:598
-#: ../gui/wxpython/animation/frame.py:605
-#, python-format
-msgid "%(from)s %(dash)s %(to)s"
-msgstr ""
-#: ../gui/wxpython/animation/controller.py:605
-#, python-format
-msgid "%(start)s %(unit)s"
-msgstr ""
-#: ../gui/wxpython/animation/controller.py:624
-#, fuzzy
-msgid "Exporting animation, please wait..."
-#: ../gui/wxpython/animation/data.py:66
-#, fuzzy
-msgid "No animation name selected."
-#: ../gui/wxpython/animation/data.py:132
-#, fuzzy
-msgid "No workspace file selected."
-msgstr "Pilih berkas workspace"
-#: ../gui/wxpython/animation/data.py:135
-msgid "File %s not found"
-msgstr "berkas tidak ditemukan"
-#: ../gui/wxpython/animation/data.py:144
-msgid "Animation %d"
-msgstr "Kuantisasi "
-#: ../gui/wxpython/animation/dialogs.py:53
-msgid "Adjust speed of animation"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:100
-#, fuzzy
-msgid "Simple mode"
-msgstr "Sederhana"
-#: ../gui/wxpython/animation/dialogs.py:105
-#, fuzzy
-msgid "Frame duration:"
-msgstr "Resolusi Atas-Bawah"
-#: ../gui/wxpython/animation/dialogs.py:106
-#: ../gui/wxpython/animation/dialogs.py:147
-msgid "ms"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:139
-#, fuzzy
-msgid "Temporal mode"
-#: ../gui/wxpython/animation/dialogs.py:144
-msgid "Time unit:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:146
-#, fuzzy
-msgid "Duration of time unit:"
-msgstr "Pilihan pengaturan"
-#: ../gui/wxpython/animation/dialogs.py:218
-msgid "year"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:219
-msgid "month"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:220
-msgid "day"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:221
-msgid "hour"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:222
-msgid "minute"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:223
-msgid "second"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:288
-msgid "Animation speed is too high."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:324
-#: ../gui/wxpython/animation/toolbars.py:51
-#: ../gui/wxpython/animation/toolbars.py:52
-#, fuzzy
-msgid "Add new animation"
-#: ../gui/wxpython/animation/dialogs.py:326
-#, fuzzy
-msgid "Edit animation"
-#: ../gui/wxpython/animation/dialogs.py:344
-msgid "Advanced"
-msgstr "Lebih lanjut"
-#: ../gui/wxpython/animation/dialogs.py:375
-#, fuzzy
-msgid "top left"
-msgstr "Daftar tabel"
-#: ../gui/wxpython/animation/dialogs.py:376
-#, fuzzy
-msgid "top right"
-msgstr "Salin "
-#: ../gui/wxpython/animation/dialogs.py:377
-#, fuzzy
-msgid "bottom left"
-msgstr "Y coord"
-#: ../gui/wxpython/animation/dialogs.py:378
-#, fuzzy
-msgid "bottom right"
-msgstr "Y coord"
-#: ../gui/wxpython/animation/dialogs.py:394
-#, fuzzy
-msgid "Select 2D or 3D view"
-msgstr "Pilih berkas WKT"
-#: ../gui/wxpython/animation/dialogs.py:402
-#: ../gui/wxpython/vnet/dialogs.py:1643
-#: ../gui/wxpython/gmodeler/preferences.py:706
-#: ../gui/wxpython/gui_core/gselect.py:1551
-#: ../gui/wxpython/gui_core/gselect.py:1566
-#: ../gui/wxpython/gui_core/gselect.py:1568
-#: ../gui/wxpython/gui_core/widgets.py:1279
-#, fuzzy
-msgid "Name:"
-msgstr "Ubah nama "
-#: ../gui/wxpython/animation/dialogs.py:409
-#, fuzzy
-msgid "Window position:"
-msgstr "Bentuk garis"
-#: ../gui/wxpython/animation/dialogs.py:419
-#, fuzzy
-msgid "View mode:"
-msgstr "Garis"
-#: ../gui/wxpython/animation/dialogs.py:430
-msgid ""
-"For 3D animation, please select only one space-time dataset\n"
-"or one series of map layers."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:496
-#, fuzzy
-msgid "3D view parameters"
-msgstr "Karakteristik"
-#: ../gui/wxpython/animation/dialogs.py:504
-#, fuzzy
-msgid "Workspace file:"
-msgstr "Workspace "
-#: ../gui/wxpython/animation/dialogs.py:506
-msgid "Choose workspace file to import 3D view parameters"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:515
-#, fuzzy
-msgid "Parameter for animation:"
-msgstr "Kelola informasi kategori"
-#: ../gui/wxpython/animation/dialogs.py:554
-msgid "Animate region change (2D view only)"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:558
-#, fuzzy
-msgid "Start region:"
-msgstr "Simpan region:"
-#: ../gui/wxpython/animation/dialogs.py:568
-#, fuzzy
-msgid "End region:"
-msgstr "Muat region:"
-#: ../gui/wxpython/animation/dialogs.py:574
-#, fuzzy
-msgid "Zoom value:"
-msgstr "Volume"
-#: ../gui/wxpython/animation/dialogs.py:575
-msgid "N-S/E-W distances in map units used to gradually reduce region."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:582
-msgid "N-S:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:585
-msgid "E-W:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:683
-msgid "Only one series or space-time dataset is accepted for 3D mode."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:691
-#, fuzzy
-msgid "No map series or space-time dataset added."
-msgstr "Hasilkan dari basisdata"
-#: ../gui/wxpython/animation/dialogs.py:719
-msgid "Region information is not complete"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:753
-msgid "Add, edit or remove animations"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:765
-#, fuzzy
-msgid "List of animations"
-msgstr "Daftar kategori"
-#: ../gui/wxpython/animation/dialogs.py:778
-#, fuzzy
-msgid "Edit"
-msgstr "Edit GCP"
-#: ../gui/wxpython/animation/dialogs.py:837
-#, python-format
-msgid "Maximum number of animations is %d."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:907
-#: ../gui/wxpython/animation/toolbars.py:59
-#: ../gui/wxpython/animation/toolbars.py:60
-#, fuzzy
-msgid "Export animation"
-#, fuzzy
-msgid "Add time stamp"
-msgstr "Catatan waktu"
-#: ../gui/wxpython/menustrings.py:2015
-#, fuzzy
-msgid "Add image"
-msgstr "Tambahkan grup layer"
-#: ../gui/wxpython/animation/dialogs.py:1030
-msgid "Add time stamp, image or text decoration by one of the buttons above."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1032
-msgid "Add image or text decoration by one of the buttons above."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1053
-#, fuzzy
-msgid "Font settings:"
-#: ../gui/wxpython/animation/dialogs.py:1058
-#, fuzzy
-msgid "Sample text"
-msgstr "Transek cuplikan"
-#: ../gui/wxpython/animation/dialogs.py:1061
-#: ../gui/wxpython/gui_core/preferences.py:494
-#: ../gui/wxpython/gui_core/preferences.py:771
-msgid "Set font"
-msgstr "Tentukan jenis huruf"
-#: ../gui/wxpython/animation/dialogs.py:1078
-#, fuzzy
-msgid "Image file:"
-msgstr "Pengaturan halaman"
-#: ../gui/wxpython/animation/dialogs.py:1079
-#, fuzzy
-msgid "Choose image file"
-#: ../gui/wxpython/animation/dialogs.py:1095
-#, fuzzy
-msgid "Text:"
-msgstr "Tes"
-#: ../gui/wxpython/animation/dialogs.py:1116
-msgid "Placement as percentage of screen coordinates (X: 0, Y: 0 is top left):"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1151
-#, fuzzy
-msgid "image sequence"
-msgid "animated GIF"
-msgstr ""
-msgid "SWF"
-msgstr ""
-msgid "AVI"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1162
-#, fuzzy
-msgid "Export to:"
-msgstr "Ekspor MPEG-1"
-#: ../gui/wxpython/animation/dialogs.py:1189
-#, fuzzy
-msgid "animation_"
-#: ../gui/wxpython/animation/dialogs.py:1196
-#: ../gui/wxpython/gui_core/gselect.py:1504
-#: ../gui/wxpython/gui_core/gselect.py:1587
-#, fuzzy
-msgid "Directory:"
-msgstr "Arah"
-#: ../gui/wxpython/animation/dialogs.py:1197
-#, fuzzy
-msgid "Choose directory for export"
-msgstr "Pilih direktori data GRASS:"
-#: ../gui/wxpython/animation/dialogs.py:1232
-#, fuzzy
-msgid "GIF file:"
-msgstr "Kode EPSG:"
-#: ../gui/wxpython/animation/dialogs.py:1233
-#: ../gui/wxpython/animation/dialogs.py:1257
-#: ../gui/wxpython/animation/dialogs.py:1288
-#, fuzzy
-msgid "Choose file to save animation"
-msgstr "Pilih berkas GRC untuk dimuat"
-#: ../gui/wxpython/animation/dialogs.py:1256
-#, fuzzy
-msgid "SWF file:"
-msgstr "Berkas WKT:"
-#: ../gui/wxpython/animation/dialogs.py:1279
-msgid ""
-"Program 'ffmpeg' was not found.\n"
-"Please install it first and make sure\n"
-"it's in the PATH variable."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1287
-#, fuzzy
-msgid "AVI file:"
-#: ../gui/wxpython/animation/dialogs.py:1295
-msgid "Video codec:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1299
-#, fuzzy
-msgid "Additional options:"
-#: ../gui/wxpython/animation/dialogs.py:1303
-msgid ""
-"Consider adding '-sameq' or '-qscale 1' if not satisfied with video quality. "
-"Options depend on ffmpeg version."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1340
-#, python-format
-msgid "Current frame rate: %.2f fps"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1472
-msgid "File %s not found."
-#: ../gui/wxpython/animation/dialogs.py:1476
-msgid "Decoration image file is missing."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1485
-msgid "Directory %s not found."
-#: ../gui/wxpython/animation/dialogs.py:1489
-#, fuzzy
-msgid "Export directory is missing."
-msgstr "Ekspor peta vektor "
-#: ../gui/wxpython/animation/dialogs.py:1493
-#: ../gui/wxpython/animation/dialogs.py:1497
-#, fuzzy
-msgid "Export file is missing."
-msgstr "Kode EPSG tidak ada."
-#: ../gui/wxpython/animation/dialogs.py:1535
-#, fuzzy
-msgid "Time stamp"
-#: ../gui/wxpython/animation/dialogs.py:1613
-#, fuzzy
-msgid "Add space-time dataset layer"
-#: ../gui/wxpython/animation/dialogs.py:1638
-#, fuzzy
-msgid "Multiple raster maps"
-msgstr "Tumpang-susun peta raster"
-#: ../gui/wxpython/animation/dialogs.py:1639
-#, fuzzy
-msgid "Multiple vector maps"
-msgstr "Bersihkan peta vektor"
-#: ../gui/wxpython/animation/dialogs.py:1640
-#, fuzzy
-msgid "Multiple 3D raster maps"
-#: ../gui/wxpython/animation/dialogs.py:1641
-#, fuzzy
-msgid "Space time raster dataset"
-msgstr "Impor peta raster "
-#: ../gui/wxpython/animation/dialogs.py:1642
-#, fuzzy
-msgid "Space time vector dataset"
-msgstr "Impor peta vektor "
-#: ../gui/wxpython/animation/dialogs.py:1643
-#, fuzzy
-msgid "Space time 3D raster dataset"
-#: ../gui/wxpython/animation/dialogs.py:1682
-#, fuzzy
-msgid "Input data type:"
-msgstr "Tipe data"
-#: ../gui/wxpython/animation/dialogs.py:1763
-#, fuzzy
-msgid "Select raster/vector maps."
-#: ../gui/wxpython/animation/dialogs.py:1792
-#, fuzzy
-msgid "Please select maps or dataset first."
-#: ../gui/wxpython/animation/dialogs.py:1821
-#, fuzzy
-msgid "Animation Tool settings"
-#: ../gui/wxpython/animation/dialogs.py:1885
-msgid "Number of parallel processes:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1914
-#, fuzzy
-msgid "Text foreground color:"
-msgstr "Background peta vektor"
-#: ../gui/wxpython/animation/dialogs.py:1935
-#, fuzzy
-msgid "Text background color:"
-#: ../gui/wxpython/animation/dialogs.py:1977
-#, fuzzy
-msgid "Absolute time format:"
-msgstr "Koordinat"
-#: ../gui/wxpython/animation/dialogs.py:1997
-msgid ""
-"Click and then press key up or down to preview different date and time "
-"formats. Type custom format string."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:2008
-msgid "Learn more about formatting options"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:2022
-msgid "Display instances with no data"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:2025
-msgid ""
-"When animating instant-based data which have irregular timestamps you can "
-"display 'no data frame' (checked option) or keep last frame."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:2056
-#, fuzzy
-msgid "Invalid"
-msgstr "Nilai tidak valid: %s"
-#: ../gui/wxpython/animation/g.gui.animation.py:92
-#, python-format
-msgid "%s=, %s=, %s= and %s= are mutually exclusive."
-msgstr ""
-#: ../gui/wxpython/animation/utils.py:182
-msgid "The number of maps in space-time datasets has to be the same."
-msgstr ""
-#: ../gui/wxpython/animation/utils.py:186
-msgid ""
-"The temporal type (absolute/relative) of space-time datasets has to be the "
-"same."
-msgstr ""
-#: ../gui/wxpython/animation/utils.py:190
-msgid ""
-"The map type (point/interval) of space-time datasets has to be the same."
-msgstr ""
-#: ../gui/wxpython/animation/utils.py:194
-msgid ""
-"The temporal extents of maps in space-time datasets have to be the same."
-msgstr ""
-#: ../gui/wxpython/animation/utils.py:202
-msgid "The number of maps to animate has to be the same for each map series."
-msgstr ""
-#: ../gui/wxpython/animation/utils.py:207
-msgid ""
-"The number of maps to animate has to be the same as the number of maps in "
-"temporal dataset."
-msgstr ""
-#: ../gui/wxpython/animation/nviztask.py:53
-msgid "No 3d view information in workspace file <%s>."
-msgstr "Pengesetan disimpan pada berkas '%s'."
-#: ../gui/wxpython/animation/nviztask.py:285
-#, fuzzy
-msgid "Please add only one layer in the list."
-msgstr "Tampilkan layer peta ke dalam layer tree"
-#: ../gui/wxpython/animation/nviztask.py:292
-#, fuzzy
-msgid "No map series nor space-time dataset is added."
-#: ../gui/wxpython/animation/frame.py:51
-#, fuzzy
-msgid "GRASS GIS Animation tool"
-#: ../gui/wxpython/animation/frame.py:160
-#: ../gui/wxpython/mapswipe/frame.py:303
-#, fuzzy
-msgid "Main Toolbar"
-msgstr "Map Toolbar"
-#: ../gui/wxpython/animation/frame.py:170
-#, fuzzy
-msgid "Animation Toolbar"
-#: ../gui/wxpython/animation/frame.py:282
-#, fuzzy
-msgid "Loading data"
-msgstr "Menampilkan data..."
-#: ../gui/wxpython/animation/frame.py:290
-#, python-brace-format
-msgid " ({c} out of {p})"
-msgstr ""
-#: ../gui/wxpython/animation/frame.py:610
-#, python-format
-msgid "to %(to)s"
-msgstr ""
-#: ../gui/wxpython/animation/provider.py:417
-#, fuzzy
-msgid "Rendering map layers"
-#: ../gui/wxpython/animation/provider.py:530
-#, fuzzy
-msgid "Overlaying map layers"
-#: ../gui/wxpython/animation/provider.py:757
-#, fuzzy, python-brace-format
-msgid "Directory {t} not removed."
-#: ../gui/wxpython/animation/toolbars.py:30
-#, fuzzy
-msgid "Change animation speed"
-msgstr "Buat mapset"
-#: ../gui/wxpython/animation/toolbars.py:33
-msgid "Play forward"
-msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:36
-msgid "Play back"
-msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:45
-msgid "Repeat"
-msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:48
-msgid "Play back and forward"
-msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:55
-#: ../gui/wxpython/animation/toolbars.py:56
-msgid "Add, edit or remove animation"
-msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:68
-#, fuzzy
-msgid "Add space-time dataset or series of map layers"
-msgstr "Tambahkan layer peta relief berbayang"
-#: ../gui/wxpython/animation/toolbars.py:69
-msgid "Add space-time dataset or series of map layers for animation"
-msgstr ""
-#: ../gui/wxpython/animation/temporal_manager.py:110
-msgid ""
-"It is not allowed to display data with different temporal types (absolute "
-"and relative)."
-msgstr ""
-#: ../gui/wxpython/animation/temporal_manager.py:125
-#, python-format
-msgid "It is not allowed to display data with different units (%s)."
-msgstr ""
-#: ../gui/wxpython/animation/temporal_manager.py:137
-msgid ""
-"You are going to display data with different temporal types of maps "
-"(interval and point). It is recommended to use data of one temporal type to "
-"avoid confusion."
-msgstr ""
-#: ../gui/wxpython/animation/temporal_manager.py:347
-#, python-format
-msgid "Topology of Space time dataset %s is invalid."
-msgstr ""
-#: ../gui/wxpython/mapwin/decorations.py:178
-#: ../gui/wxpython/mapwin/decorations.py:265
-msgid ""
-"Please install Python Imaging Library (PIL)\n"
-"for better control of legend and other decorations."
-msgstr ""
-#: ../gui/wxpython/mapwin/decorations.py:197
-#, fuzzy
-msgid "Remove text"
-msgstr "Hapus vertex "
-#: ../gui/wxpython/mapwin/decorations.py:220
-#, fuzzy
-msgid "Remove scale bar"
-msgstr "Tambahkan layer"
-#: ../gui/wxpython/mapwin/decorations.py:232
-#, fuzzy
-msgid "Remove north arrow"
-#: ../gui/wxpython/mapwin/decorations.py:244
-#, fuzzy
-msgid "Remove vector legend"
-#: ../gui/wxpython/mapwin/decorations.py:256
-#, fuzzy
-msgid "Remove legend"
-msgstr "Seri raster"
-#: ../gui/wxpython/mapwin/buffered.py:252
-#, fuzzy
-msgid "Copy coordinates to clipboard"
-#: ../gui/wxpython/mapwin/buffered.py:260
-#, fuzzy
-msgid "Hide toolbars"
-msgstr "Tampilkan peta"
-#: ../gui/wxpython/mapwin/buffered.py:262
-#, fuzzy
-msgid "Show toolbars"
-#: ../gui/wxpython/mapwin/buffered.py:269
-msgid "Hide statusbar"
-msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:270
-#, fuzzy
-msgid "Show statusbar"
-msgstr "Perlihatkan pengaturan "
-#: ../gui/wxpython/mapwin/buffered.py:287
-#, fuzzy
-msgid "Resize legend"
-#: ../gui/wxpython/mapwin/buffered.py:694
-#: ../gui/wxpython/modules/histogram.py:190
-#, fuzzy
-msgid "Please wait, exporting image..."
-msgstr "Silakan tunggu, sedang menampilkan data atribut ..."
-#: ../gui/wxpython/mapwin/buffered.py:985
-msgid "Unable to draw registered graphics. The graphics was unregistered."
-msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:2074
-msgid "Zoom to saved region extents"
-msgstr "Tampilan ke batas region tersimpan"
-#: ../gui/wxpython/mapwin/buffered.py:2076
-#, fuzzy
-msgid "Set compulational region from named region"
-#: ../gui/wxpython/mapwin/buffered.py:2089
-msgid "Region <%s> not found. Operation canceled."
-#: ../gui/wxpython/mapwin/buffered.py:2119
-#, fuzzy
-msgid "Save display extents to region file"
-msgstr "Simpan geometri tampilan ke region tertentu"
-#: ../gui/wxpython/mapwin/buffered.py:2121
-#, fuzzy
-msgid "Save computational region to region file"
-#: ../gui/wxpython/mapwin/buffered.py:2133
-#, python-format
-msgid "Region file <%s> already exists. Do you want to overwrite it?"
-msgstr "Berkas region <%s> sudah ada. Anda ingin menimpanya?"
-#: ../gui/wxpython/mapwin/base.py:204
-#, python-format
-msgid ""
-"Error occurred during calling of handler: %s \n"
-"Handler was unregistered."
-msgstr ""
-#: ../gui/wxpython/mapwin/base.py:285
-#, python-format
-msgid ""
-"Error occurred during unregistration of handler: %s \n"
-" Handler was unregistered."
-msgstr ""
-#: ../gui/wxpython/mapwin/base.py:314
-#, python-format
-msgid "Handler: %s was not registered"
-msgstr ""
-#: ../gui/wxpython/mapwin/base.py:318
-#, python-format
-msgid ""
-" Handler was unregistered"
-msgstr ""
-#: ../gui/wxpython/mapwin/analysis.py:228
-#: ../gui/wxpython/mapwin/analysis.py:350
-#, fuzzy
-msgid "Measuring finished"
-#: ../gui/wxpython/mapwin/analysis.py:246
-#: ../gui/wxpython/mapwin/analysis.py:362
-#, python-format
-msgid ""
-"Click and drag with left mouse button to measure.%sDouble click with left "
-"button to clear."
-msgstr ""
-"Klik dan geser dengan tombol kiri tetikus untuk mengukur.%sKlik ganda dengan "
-"tombol kiri untuk membersihkan."
-#: ../gui/wxpython/mapwin/analysis.py:252
-msgid "Measuring distance"
-#: ../gui/wxpython/mapwin/analysis.py:255
-msgid "Measuring distance:"
-msgstr "Pengukuran jarak:"
-#: ../gui/wxpython/mapwin/analysis.py:263
-#, python-format
-msgid ""
-"Geodesic distance calculation is not available.\n"
-"Reason: %s"
-msgstr ""
-#: ../gui/wxpython/mapwin/analysis.py:301
-#: ../gui/wxpython/mapwin/analysis.py:308
-#, fuzzy
-msgid "segment"
-msgstr "Legenda"
-#: ../gui/wxpython/mapwin/analysis.py:302
-#: ../gui/wxpython/mapwin/analysis.py:309
-#, fuzzy
-msgid "total distance"
-#: ../gui/wxpython/mapwin/analysis.py:303
-#, fuzzy
-msgid "bearing"
-#: ../gui/wxpython/mapwin/analysis.py:304
-msgid "degrees (clockwise from grid-north)"
-msgstr ""
-#: ../gui/wxpython/mapwin/analysis.py:366
-#, fuzzy
-msgid "Measuring area:"
-#: ../gui/wxpython/mapwin/analysis.py:386
-msgid "Units not recognized, measurement failed."
-msgstr ""
-#: ../gui/wxpython/mapwin/analysis.py:391
-#: ../gui/wxpython/mapwin/analysis.py:393
-msgid "Area: {area} {unit}\n"
-msgstr ""
-#: ../gui/wxpython/mapwin/graphics.py:277
-#: ../gui/wxpython/mapwin/graphics.py:453
-#, python-format
-msgid "Property does not exist: %s"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:116
-#, fuzzy
-msgid "Unable to perform analysis."
-#: ../gui/wxpython/vnet/vnet_core.py:226
-msgid ""
-"Temporary map '%s' with result was changed outside vector network analysis "
-"tool.\n"
-"Showed result may not correspond original analysis result."
-#: ../gui/wxpython/vnet/vnet_core.py:231
-msgid "Result changed outside"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:268
-#, fuzzy
-msgid "Map can be created only in current mapset"
-#: ../gui/wxpython/vnet/vnet_core.py:275 ../gui/wxpython/vnet/vnet_core.py:352
-msgid "Vector map %s already exists. Do you want to overwrite it?"
-#: ../gui/wxpython/vnet/vnet_core.py:278 ../gui/wxpython/vnet/vnet_core.py:355
-#, fuzzy
-msgid "Overwrite vector map"
-#: ../gui/wxpython/vnet/vnet_core.py:304
-#, fuzzy
-msgid "Creation of turntable failed."
-msgstr "Penambahan fitur baru untuk peta vektor <%s> gagal."
-#: ../gui/wxpython/vnet/vnet_core.py:324
-msgid "Vector map with analysis result does not exist."
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:345
-msgid "Map can be saved only to currently set mapset"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:427 ../gui/wxpython/vnet/vnet_core.py:632
-#, python-format
-msgid "Please choose '%s' and '%s' point."
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:639
-msgid "Please choose at least two points."
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:932
-msgid ""
-"Input map '%s' for analysis was changed outside vector network analysis "
-"tool.\n"
-"Topology column may not correspond to changed situation."
-#: ../gui/wxpython/vnet/vnet_core.py:937
-msgid "Input changed outside"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:1011
-msgid ""
-"Temporary map %s already exists.\n"
-"Do you want to continue in analysis and overwrite it?"
-#: ../gui/wxpython/vnet/vnet_core.py:1038
-#, fuzzy
-msgid "Unable to use ctypes. \n"
-msgstr "Tidak mampu mengeset"
-#: ../gui/wxpython/vnet/vnet_core.py:1039
-#: ../gui/wxpython/vnet/vnet_core.py:1062
-msgid "Snapping mode can not be activated."
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:1069
-msgid "Do you really want to activate snapping and overwrite it?"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:1079
-msgid ""
-"Temporary map '%s' was changed outside vector analysis tool.\n"
-"Do you really want to activate snapping and overwrite it? "
-#: ../gui/wxpython/vnet/vnet_core.py:1084
-#, fuzzy
-msgid "Overwrite map"
-#: ../gui/wxpython/vnet/dialogs.py:70
-#, fuzzy
-msgid "GRASS GIS Vector Network Analysis Tool"
-#: ../gui/wxpython/vnet/dialogs.py:187
-#, fuzzy
-msgid "Point list toolbar"
-#: ../gui/wxpython/vnet/dialogs.py:194
-#, fuzzy
-msgid "Analysis toolbar"
-#: ../gui/wxpython/vnet/dialogs.py:228
-#, fuzzy
-msgid "Points for analysis:"
-#: ../gui/wxpython/vnet/dialogs.py:231
-#, fuzzy
-msgid "Analysis settings:"
-#: ../gui/wxpython/vnet/dialogs.py:235
-#, fuzzy
-msgid "Points"
-msgstr "Titik "
-#: ../gui/wxpython/vnet/dialogs.py:248
-msgid "Maximum distance of point to the network:"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:265
-#, fuzzy
-msgid "Iso lines:"
-msgstr "Garis aliran "
-#: ../gui/wxpython/vnet/dialogs.py:345
-#: ../gui/wxpython/modules/mcalc_builder.py:134
-#: ../gui/wxpython/modules/vkrige.py:154
-msgid "Output"
-msgstr "Output "
-#: ../gui/wxpython/vnet/dialogs.py:362
-#: ../gui/wxpython/location_wizard/wizard.py:1451
-#: ../gui/wxpython/location_wizard/wizard.py:1679
-msgid "Parameters"
-msgstr "Parameter"
-#: ../gui/wxpython/vnet/dialogs.py:404
-#, fuzzy
-msgid "Add vector map into layer tree"
-#: ../gui/wxpython/vnet/dialogs.py:524
-#, fuzzy
-msgid "Input tables"
-#: ../gui/wxpython/vnet/dialogs.py:552
-#, fuzzy
-msgid "Result tables"
-#: ../gui/wxpython/vnet/dialogs.py:565
-#, fuzzy
-msgid "Loading tables..."
-#: ../gui/wxpython/vnet/dialogs.py:701
-#, fuzzy
-msgid "Creating turntable..."
-#: ../gui/wxpython/vnet/dialogs.py:866
-#, fuzzy
-msgid "Input vector map does not exist."
-#: ../gui/wxpython/vnet/dialogs.py:889
-#, fuzzy
-msgid "Analysing..."
-msgstr "Analisis LIDAR"
-#: ../gui/wxpython/vnet/dialogs.py:1012
-msgid "Computing nodes..."
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1210
-#, fuzzy
-msgid "Other settings"
-msgstr "Pengaturan raster"
-#: ../gui/wxpython/vnet/dialogs.py:1213
-#, fuzzy
-msgid "Point style:"
-#: ../gui/wxpython/vnet/dialogs.py:1216
-msgid "Analysis result style:"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1228
-msgid "Color table style %s:"
-msgstr "Tabel warna "
-#: ../gui/wxpython/vnet/dialogs.py:1245
-msgid "Invert colors %s:"
-msgstr "Konversi koordinat "
-#: ../gui/wxpython/vnet/dialogs.py:1256
-#, fuzzy
-msgid "Line color:"
-msgstr "Warna garis"
-#: ../gui/wxpython/vnet/dialogs.py:1259
-#, fuzzy
-msgid "Color for unused point:"
-msgstr "Aturan warna "
-#: ../gui/wxpython/vnet/dialogs.py:1262
-msgid "Color for Start/From/Source/Used point:"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1265
-msgid "Color for End/To/Sink point:"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1268
-#, fuzzy
-msgid "Color for selected point:"
-msgstr "Bersihkan GCP terpilih"
-#: ../gui/wxpython/vnet/dialogs.py:1280
-#, fuzzy
-msgid "Point size:"
-msgstr "Tema ikon:"
-#: ../gui/wxpython/vnet/dialogs.py:1281
-#, fuzzy
-msgid "Point width:"
-msgstr "Lebar garis"
-#: ../gui/wxpython/vnet/dialogs.py:1282 ../gui/wxpython/iscatt/dialogs.py:372
-#, fuzzy
-msgid "Snapping threshold in pixels:"
-#: ../gui/wxpython/vnet/dialogs.py:1283
-msgid "Maximum number of results in history:"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1481
-#, fuzzy
-msgid "New vector map with turntable"
-#: ../gui/wxpython/vnet/dialogs.py:1627
-msgid "Save analysis result"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1743
-msgid "Edit intersection turns costs"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1786
-msgid "Define Global Turn Costs"
-msgstr ""
-#: ../gui/wxpython/vnet/toolbars.py:52
-#, fuzzy
-msgid "Insert points from Map Display"
-msgstr "Tampilan"
-#: ../gui/wxpython/vnet/toolbars.py:55
-msgid "Activate snapping to nodes"
-msgstr ""
-#: ../gui/wxpython/vnet/toolbars.py:58
-msgid "Activate mode for turns editing"
-msgstr ""
-#: ../gui/wxpython/vnet/toolbars.py:61
-msgid "Activate mode for global turns editing"
-msgstr ""
-#: ../gui/wxpython/vnet/toolbars.py:64
-#, fuzzy
-msgid "Add new point"
-msgstr "Ground Control Point"
-#: ../gui/wxpython/vnet/toolbars.py:67
-#, fuzzy
-msgid "Delete selected point"
-msgstr "Hapus location terpilih"
-#: ../gui/wxpython/vnet/toolbars.py:120
-#, fuzzy
-msgid "Execute analysis"
-msgstr "Analisis medan"
-#: ../gui/wxpython/vnet/toolbars.py:123
-msgid "Go to previous analysis result"
-msgstr ""
-#: ../gui/wxpython/vnet/toolbars.py:126
-msgid "Go to next analysis result"
-msgstr ""
-#: ../gui/wxpython/vnet/toolbars.py:129
-#, fuzzy
-msgid "Show analysis result"
-#: ../gui/wxpython/vnet/toolbars.py:132
-msgid "Save temporary result"
-msgstr ""
-#: ../gui/wxpython/vnet/toolbars.py:134
-#, fuzzy
-msgid "Vector network analysis settings"
-#: ../gui/wxpython/vnet/toolbars.py:137
-#: ../gui/wxpython/gui_core/toolbars.py:71
-#: ../gui/wxpython/iscatt/toolbars.py:51
-#, fuzzy
-msgid "Show manual"
-msgstr "Peta bayangan "
-#: ../gui/wxpython/vnet/toolbars.py:206
-#, fuzzy
-msgid "Availiable analyses"
-msgstr "Analisis traveling salesman"
-#: ../gui/wxpython/vnet/vnet_data.py:162
-#, python-format
-msgid "Module <%s> does not support turns costs."
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:169
-msgid "Vector map '%s' does not exist."
-#: ../gui/wxpython/vnet/vnet_data.py:172
-#, fuzzy
-msgid "Vector map was not chosen."
-#: ../gui/wxpython/vnet/vnet_data.py:181
-#, fuzzy
-msgid "arc layer"
-msgstr "Layer peta"
-#: ../gui/wxpython/vnet/vnet_data.py:182
-#, fuzzy
-msgid "node layer"
-#: ../gui/wxpython/vnet/vnet_data.py:183
-#, fuzzy
-msgid "turntable layer"
-msgstr "Kelola layer"
-#: ../gui/wxpython/vnet/vnet_data.py:184
-#, fuzzy
-msgid "unique categories layer"
-msgstr "Kelola atau laporkan kategori"
-#: ../gui/wxpython/vnet/vnet_data.py:190
-#, python-format
-msgid "Chosen %s '%s' does not exist in vector map '%s'.\n"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:193
-msgid "Choose existing %s.\n"
-msgstr "Pilih %s"
-#: ../gui/wxpython/vnet/vnet_data.py:203
-msgid ""
-"Chosen column '%s' does not exist in attribute table of layer '%s' of vector "
-"map '%s'.\n"
-msgstr ""
-"Ubah nama sebuah kolom dari tabel atribut yang terhubung ke satu peta vektor "
-"tertentu."
-#: ../gui/wxpython/vnet/vnet_data.py:259
-#: ../gui/wxpython/gui_core/vselect.py:49
-#, fuzzy
-msgid "type"
-msgstr "Tipe data"
-#, fuzzy
-msgid "topology"
-msgstr "Buat/bangun-ulang topologi"
-#: ../gui/wxpython/vnet/vnet_data.py:261 ../gui/wxpython/vnet/vnet_data.py:769
-#, fuzzy
-msgid "Start point"
-msgstr "Titik "
-#, fuzzy
-msgid "End Point"
-msgstr "Titik "
-#: ../gui/wxpython/vnet/vnet_data.py:560 ../gui/wxpython/vnet/vnet_data.py:569
-#: ../gui/wxpython/vnet/vnet_data.py:572
-#, fuzzy
-msgid "new point"
-#: ../gui/wxpython/vnet/vnet_data.py:746
-msgid "Arc forward/both direction(s) cost column:"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:747
-msgid "arc forward/both"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:750
-msgid "Arc backward direction cost column:"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:751
-msgid "arc backward"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:754
-msgid "Arcs' cost column (for both directions):"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:755
-msgid "arc"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:759
-#, fuzzy
-msgid "Node cost column:"
-msgstr "Kolom kunci"
-#: ../gui/wxpython/vnet/vnet_data.py:760
-msgid "node"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:766
-msgid "Shortest path %s"
-msgstr "Jalur terdekat"
-#: ../gui/wxpython/vnet/vnet_data.py:770
-#, fuzzy
-msgid "End point"
-msgstr "Titik "
-#: ../gui/wxpython/vnet/vnet_data.py:786
-msgid "Traveling salesman %s"
-#: ../gui/wxpython/vnet/vnet_data.py:802
-#, python-format
-msgid "Maximum flow %s"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:805
-#, fuzzy
-msgid "Source point"
-msgstr "Nama kolom"
-#: ../gui/wxpython/vnet/vnet_data.py:806
-#, fuzzy
-msgid "Sink point"
-#: ../gui/wxpython/vnet/vnet_data.py:821
-#, python-format
-msgid "Subnets for nearest centers %s"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:837
-#, python-format
-msgid "Steiner tree for the network and given terminals %s"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:851
-#, python-format
-msgid "Shortest distance via the network %s"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:870
-#, python-format
-msgid "Cost isolines %s"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:960
-#, fuzzy
-msgid "Overwrite map layer"
-msgstr "Hapus layer peta"
-#: ../gui/wxpython/vnet/widgets.py:378
-#, fuzzy
-msgid "Invalid value inserted. Operation canceled."
-#: ../gui/wxpython/vnet/widgets.py:539
-#, fuzzy
-msgid "Edit point"
-msgstr "Titik "
-#: ../gui/wxpython/gmodeler/model.py:66
-#, fuzzy
-msgid "model"
-msgstr "Mode"
-#: ../gui/wxpython/gmodeler/model.py:67
-#, fuzzy
-msgid "Script generated by wxGUI Graphical Modeler."
-msgstr "Hasilkan informasi dasar tentang sebuah layer peta raster."
-#: ../gui/wxpython/gmodeler/model.py:492 ../gui/wxpython/gmodeler/model.py:555
-msgid "undefined variable '%s'"
-msgstr "Tambahkan sebuah vertex baru"
-#: ../gui/wxpython/gmodeler/model.py:589
-msgid "Running model..."
-msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:608
-msgid "Model is empty. Nothing to run."
-msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:617 ../gui/wxpython/gmodeler/frame.py:607
-#, fuzzy
-msgid "Validating model..."
-msgstr "Rentang yang valid"
-#: ../gui/wxpython/gmodeler/model.py:625
-#, python-format
-msgid ""
-"Model is not valid. Do you want to run the model anyway?\n"
-"\n"
-"%s"
-msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:628
-msgid "Run model?"
-msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:667
-msgid "Variables below not defined:"
-msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:791
-#, fuzzy
-msgid "Raster maps"
-msgstr "Peta raster:"
-#: ../gui/wxpython/gmodeler/model.py:794
-#, fuzzy
-msgid "3D raster maps"
-#: ../gui/wxpython/gmodeler/model.py:1122
-#: ../gui/wxpython/gmodeler/model.py:1228 ../gui/wxpython/core/gconsole.py:663
-#: ../gui/wxpython/gui_core/ghelp.py:232
-msgid "unknown"
-msgstr "tidak diketahui"
-#: ../gui/wxpython/gmodeler/model.py:1501
-msgid "<not defined>"
-msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:1615
-#, fuzzy
-msgid "Condition: "
-msgstr "Opsional"
-#: ../gui/wxpython/gmodeler/model.py:1617
-msgid "Condition: not defined"
-msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:1755
-msgid "if-else"
-msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:1863
-msgid "empty"
-msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:1865
-msgid "Details: unsupported tag name '{}'."
-msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:2776
-#, fuzzy
-msgid "Model parameters"
-msgstr "Parameter medan"
-#: ../gui/wxpython/gmodeler/model.py:2801
-#, fuzzy
-msgid "Delete intermediate data when finish"
-msgstr "Hapus yang tersaring"
-#: ../gui/wxpython/gmodeler/model.py:2809
-#: ../gui/wxpython/gmodeler/frame.py:1887
-#: ../gui/wxpython/gui_core/forms.py:591 ../gui/wxpython/gui_core/menu.py:170
-#: ../gui/wxpython/modules/mcalc_builder.py:148
-#: ../gui/wxpython/modules/vclean.py:173 ../gui/wxpython/modules/vkrige.py:210
-msgid "&Run"
-msgstr "&Jalankan"
-#: ../gui/wxpython/gmodeler/model.py:2853
-#: ../gui/wxpython/gmodeler/frame.py:153
-#, fuzzy
-msgid "Variables"
-msgstr "Volume"
-#: ../gui/wxpython/gmodeler/dialogs.py:49
-#, fuzzy
-msgid "Data properties"
-#: ../gui/wxpython/gmodeler/dialogs.py:94
-#: ../gui/wxpython/gmodeler/dialogs.py:112
-#, fuzzy
-msgid "Name of element:"
-msgstr "Ubah nama mapset"
-#: ../gui/wxpython/gmodeler/dialogs.py:105
-#, fuzzy
-msgid "Type of element:"
-#: ../gui/wxpython/gmodeler/dialogs.py:163
-msgid "Add GRASS command to the model"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:192
-#: ../gui/wxpython/gmodeler/dialogs.py:493
-#: ../gui/wxpython/gmodeler/dialogs.py:605
-#: ../gui/wxpython/gmodeler/frame.py:1793
-#: ../gui/wxpython/gmodeler/preferences.py:102
-msgid "Command"
-msgstr "Perintah"
-#: ../gui/wxpython/gmodeler/dialogs.py:194
-msgid "Label and comment"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:235
-#: ../gui/wxpython/gmodeler/frame.py:1538
-#, fuzzy
-msgid "Label:"
-msgstr "Layer"
-#: ../gui/wxpython/gmodeler/dialogs.py:239
-#: ../gui/wxpython/gmodeler/frame.py:829
-#: ../gui/wxpython/gmodeler/frame.py:1552
-#, fuzzy
-msgid "Comment:"
-msgstr "Perintah"
-#: ../gui/wxpython/gmodeler/dialogs.py:292
-msgid ""
-"Command not defined.\n"
-"\n"
-"Unable to add new action to the model."
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:299
-#, python-format
-msgid ""
-"'%s' is not a GRASS module.\n"
-"\n"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:335
-#, fuzzy
-msgid "Relation properties"
-#: ../gui/wxpython/gmodeler/dialogs.py:357
-msgid "From"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:401
-msgid "Data: %s"
-msgstr "Deil:"
-#: ../gui/wxpython/gmodeler/dialogs.py:407
-#, fuzzy
-msgid "Command:"
-msgstr "Perintah"
-#: ../gui/wxpython/gmodeler/dialogs.py:413
-#, fuzzy
-msgid "Option:"
-msgstr "Opsional"
-#: ../gui/wxpython/gmodeler/dialogs.py:428
-msgid ""
-"Relation doesn't start with data item.\n"
-"Unable to add relation."
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:435
-msgid ""
-"Relation doesn't point to GRASS command.\n"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:448
-msgid ""
-"No relevant option found.\n"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:487
-#, fuzzy
-msgid "Condition"
-msgstr "Opsional"
-#: ../gui/wxpython/gmodeler/dialogs.py:515
-#, fuzzy
-msgid "Loop properties"
-#: ../gui/wxpython/gmodeler/dialogs.py:521
-#, fuzzy
-msgid "List of items in loop"
-#: ../gui/wxpython/gmodeler/dialogs.py:524
-msgid "Series"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:526
-msgid "Define map series as condition for the loop"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:571
-msgid "Define series of maps"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:589
-#, fuzzy
-msgid "If-else properties"
-#: ../gui/wxpython/gmodeler/dialogs.py:596
-msgid "List of items in 'if' block"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:602
-msgid "List of items in 'else' block"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:772
-msgid "Variable <%s> already exists in the model. Adding variable failed."
-msgstr ""
-"Tidak dapat membuat sebuah tabel baru. Nama tabel atau nama kolom kunci "
-"tidak dapat ditemukan "
-#: ../gui/wxpython/gmodeler/dialogs.py:803
-#, fuzzy
-msgid "Do you want to delete all variables from the model?"
-msgstr "Apakah Anda hendak menghapus layer peta terpilih dari layer tree?"
-#: ../gui/wxpython/gmodeler/dialogs.py:805
-#, fuzzy
-msgid "Delete variables"
-#: ../gui/wxpython/gmodeler/dialogs.py:919
-#: ../gui/wxpython/location_wizard/wizard.py:860
-#: ../gui/wxpython/gui_core/gselect.py:2083
-#, fuzzy
-msgid "No"
-msgstr "N:"
-#: ../gui/wxpython/gmodeler/dialogs.py:921
-#: ../gui/wxpython/gui_core/gselect.py:2085
-msgid "Yes"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:65
-#, fuzzy
-msgid "GRASS GIS Graphical Modeler"
-msgstr "Bantuan GRASS GIS GUI"
-#: ../gui/wxpython/gmodeler/frame.py:146
-#, fuzzy
-msgid "Model"
-msgstr "Mode"
-#: ../gui/wxpython/gmodeler/frame.py:149
-msgid "Items"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:157
-msgid "Python editor"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:161
-#: ../gui/wxpython/gui_core/forms.py:2224
-#: ../gui/wxpython/modules/vkrige.py:135
-msgid "Command output"
-msgstr "Output perintah"
-#: ../gui/wxpython/gmodeler/frame.py:243
-msgid "Python script contains local modifications"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:245
-#: ../gui/wxpython/gmodeler/frame.py:2044
-msgid "Python script is up-to-date"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:262
-#, fuzzy
-msgid "Redrawing model..."
-#: ../gui/wxpython/gmodeler/frame.py:298
-#, fuzzy
-msgid "Do you want to save changes in the model?"
-#: ../gui/wxpython/gmodeler/frame.py:300
-#, fuzzy
-msgid "Do you want to store current model settings to model file?"
-msgstr ""
-"Workspace tidak kosong. Apakah Anda hendak menyimpan pengaturan saat ini ke "
-"berkas workspace?"
-#: ../gui/wxpython/gmodeler/frame.py:306
-#, fuzzy
-msgid "Quit Graphical Modeler"
-#: ../gui/wxpython/gmodeler/frame.py:360
-#, fuzzy
-msgid "No intermediate data to delete."
-#: ../gui/wxpython/gmodeler/frame.py:366
-msgid "Do you want to permanently delete data?%s"
-#: ../gui/wxpython/gmodeler/frame.py:368
-#, fuzzy
-msgid "Delete intermediate data?"
-#: ../gui/wxpython/gmodeler/frame.py:385
-msgid "%d maps deleted from current mapset"
-msgstr "Hapus berkas elemen basis data dari mapset saat ini milik pengguna."
-#: ../gui/wxpython/gmodeler/frame.py:403 ../gui/wxpython/gmodeler/frame.py:553
-#, fuzzy
-msgid ""
-"Current model is not empty. Do you want to store current settings to model "
-"file?"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:406 ../gui/wxpython/gmodeler/frame.py:556
-#, fuzzy
-msgid "Create new model?"
-msgstr "Buat mapset baru"
-#: ../gui/wxpython/gmodeler/frame.py:443
-#, fuzzy
-msgid "Choose model file"
-msgstr "Pilih berkas kode EPSG"
-#: ../gui/wxpython/gmodeler/frame.py:466
-#, python-format
-msgid "%(items)d items (%(actions)d actions) loaded into model"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:478 ../gui/wxpython/gmodeler/frame.py:522
-msgid "Model file <%s> already exists. Do you want to overwrite this file?"
-msgstr "Berkas Workspace <%s> sudah ada. Anda ingin menimpanya?"
-#: ../gui/wxpython/gmodeler/frame.py:481 ../gui/wxpython/menustrings.py:1940
-#, fuzzy
-msgid "Save model"
-#: ../gui/wxpython/gmodeler/frame.py:490 ../gui/wxpython/gmodeler/frame.py:540
-msgid "File <%s> saved"
-msgstr "Berkas POINTS <%s> berhasil disimpan"
-#: ../gui/wxpython/gmodeler/frame.py:503
-#, fuzzy
-msgid "Choose file to save current model"
-msgstr "Pilih berkas untuk menyimpan workspace saat ini"
-#: ../gui/wxpython/gmodeler/frame.py:604
-msgid "Model is empty. Nothing to validate."
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:614
-#, python-format
-msgid ""
-"Model is not valid.\n"
-"\n"
-"%s"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:618
-msgid "Model is valid."
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:680 ../gui/wxpython/gmodeler/frame.py:687
-#, python-format
-msgid "Model exported to <%s>"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:830 ../gui/wxpython/menustrings.py:1965
-#, fuzzy
-msgid "Add comment"
-msgstr "Tambahkan layer perintah"
-#: ../gui/wxpython/gmodeler/frame.py:840
-msgid "Empty comment. Nothing to add to the model."
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:876
-msgid "wxGUI Graphical Modeler"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:995
-msgid ""
-"Reading model file <%s> failed.\n"
-"Invalid file, unable to parse XML document.\n"
-"\n"
-"%s"
-msgstr ""
-"Gagal dalam pembacaan berkas workspace <%s>. Berkas tidak valid, tidak mampu "
-"membaca dokumen XML."
-#: ../gui/wxpython/gmodeler/frame.py:1007
-#, fuzzy
-msgid "Please wait, loading model..."
-#: ../gui/wxpython/gmodeler/frame.py:1073
-#, fuzzy
-msgid "Writing current settings to model file failed."
-msgstr "Penulisan pengaturan saat ini ke berkas workspace gagal (%s)."
-#: ../gui/wxpython/gmodeler/frame.py:1448
-#, fuzzy
-msgid "Disable"
-#: ../gui/wxpython/gmodeler/frame.py:1454
-#, fuzzy
-msgid "Enable"
-msgstr "Tabel"
-#: ../gui/wxpython/gmodeler/frame.py:1462
-#: ../gui/wxpython/gmodeler/frame.py:1539
-#, fuzzy
-msgid "Set label"
-msgstr "Tambahkan label"
-#: ../gui/wxpython/gmodeler/frame.py:1468
-#: ../gui/wxpython/gmodeler/frame.py:1553
-#, fuzzy
-msgid "Set comment"
-#: ../gui/wxpython/gmodeler/frame.py:1478
-#, fuzzy
-msgid "Add control point"
-#: ../gui/wxpython/gmodeler/frame.py:1485
-#, fuzzy
-msgid "Remove control point"
-msgstr "Hilangkan outlier dalam titik"
-#: ../gui/wxpython/gmodeler/frame.py:1497
-msgid "Intermediate"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1630
-#, fuzzy
-msgid "List of variables - right-click to delete"
-msgstr "Tabel %s - klik-kanan untuk menghapus rekaman"
-#: ../gui/wxpython/gmodeler/frame.py:1635
-#: ../gui/wxpython/gmodeler/frame.py:1682
-#: ../gui/wxpython/web_services/widgets.py:922
-#: ../gui/wxpython/gui_core/ghelp.py:398 ../gui/wxpython/gui_core/ghelp.py:400
-#: ../gui/wxpython/gui_core/ghelp.py:474
-#, fuzzy
-msgid "Name"
-#: ../gui/wxpython/gmodeler/frame.py:1637
-#: ../gui/wxpython/gmodeler/frame.py:1695
-#, fuzzy
-msgid "Default value"
-msgstr "Tetapkan nilai"
-#: ../gui/wxpython/gmodeler/frame.py:1638
-#: ../gui/wxpython/gmodeler/frame.py:1702
-#: ../gui/wxpython/location_wizard/wizard.py:411
-#: ../gui/wxpython/location_wizard/wizard.py:938
-#: ../gui/wxpython/location_wizard/wizard.py:1119
-#: ../gui/wxpython/location_wizard/wizard.py:1450
-#: ../gui/wxpython/location_wizard/wizard.py:1678
-msgid "Description"
-msgstr "Deskripsi"
-#: ../gui/wxpython/gmodeler/frame.py:1643
-#, fuzzy
-msgid "Add new variable"
-#: ../gui/wxpython/gmodeler/frame.py:1647
-#, fuzzy
-msgid "integer"
-msgstr "Pointer"
-#: ../gui/wxpython/gmodeler/frame.py:1648
-msgid "float"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1649
-#, fuzzy
-msgid "string"
-msgstr "Tiling "
-#: ../gui/wxpython/gmodeler/frame.py:1652
-#, fuzzy
-msgid "region"
-msgstr "Region "
-#: ../gui/wxpython/gmodeler/frame.py:1653
-#, fuzzy
-msgid "mapset"
-msgstr "Mapset"
-#: ../gui/wxpython/gmodeler/frame.py:1654
-#: ../gui/wxpython/gui_core/forms.py:1801
-#, fuzzy
-msgid "file"
-msgstr "Profil"
-#: ../gui/wxpython/gmodeler/frame.py:1655
-msgid "dir"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1662
-msgid "Add new variable to the model"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1785
-#, fuzzy
-msgid "List of items - right-click to delete"
-#: ../gui/wxpython/gmodeler/frame.py:1791
-msgid "In loop"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1792
-#, fuzzy
-msgid "Parameterized"
-msgstr "Parameter"
-#: ../gui/wxpython/gmodeler/frame.py:1848
-#, fuzzy
-msgid "No items to selected."
-msgstr "Tidak ada layer peta yang dipilih untuk kueri."
-#: ../gui/wxpython/gmodeler/frame.py:1884
-#, fuzzy
-msgid "Python script"
-msgstr "Deskripsi layer"
-#: ../gui/wxpython/gmodeler/frame.py:1888
-#, fuzzy
-msgid "Run python script"
-#: ../gui/wxpython/gmodeler/frame.py:1891
-#, fuzzy
-msgid "Save python script to file"
-msgstr "Simpan workspace ke dalam berkas"
-#: ../gui/wxpython/gmodeler/frame.py:1894
-msgid ""
-"Refresh python script based on the model.\n"
-"It will discards all local changes."
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1932
-#: ../gui/wxpython/gui_core/pyedit.py:279
-msgid "Unable to launch Python script. %s"
-msgstr "Tidak bisa membuat sebuah peta vektor baru <%s>."
-#: ../gui/wxpython/gmodeler/frame.py:1959
-#: ../gui/wxpython/gui_core/pyedit.py:315
-#, fuzzy
-msgid "Choose file to save"
-#: ../gui/wxpython/gmodeler/frame.py:1964
-#: ../gui/wxpython/gui_core/pyedit.py:317
-#: ../gui/wxpython/gui_core/pyedit.py:379
-msgid "Python script (*.py)|*.py"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1984
-#: ../gui/wxpython/gui_core/pyedit.py:335
-#, fuzzy
-msgid "Save file"
-msgstr "Simpan berkas sebagai ..."
-#: ../gui/wxpython/gmodeler/frame.py:2021
-msgid ""
-"Python script is locally modificated. Refresh will discard all changes. Do "
-"you really want to continue?"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:2024
-msgid "Update"
-msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:32
-#: ../gui/wxpython/menustrings.py:1953
-#, fuzzy
-msgid "Modeler settings"
-msgstr "Pengaturan umum"
-#: ../gui/wxpython/gmodeler/preferences.py:59
-#, fuzzy
-msgid "Item properties"
-#: ../gui/wxpython/gmodeler/preferences.py:66
-#, fuzzy
-msgid "Disabled:"
-#: ../gui/wxpython/gmodeler/preferences.py:114
-#: ../gui/wxpython/gmodeler/preferences.py:428
-#: ../gui/wxpython/gmodeler/preferences.py:540
-msgid "Valid:"
-msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:132
-#, fuzzy
-msgid "Invalid:"
-#: ../gui/wxpython/gmodeler/preferences.py:150
-msgid "Running:"
-msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:177
-#: ../gui/wxpython/gmodeler/preferences.py:343
-#: ../gui/wxpython/gmodeler/preferences.py:455
-#: ../gui/wxpython/gmodeler/preferences.py:571
-#, fuzzy
-msgid "Shape size"
-msgstr "Indeks bentuk "
-#: ../gui/wxpython/gmodeler/preferences.py:262
-#, fuzzy
-msgid "Raster:"
-msgstr "Raster"
-#: ../gui/wxpython/gmodeler/preferences.py:280
-#, fuzzy
-msgid "3D raster:"
-msgstr "raster"
-#: ../gui/wxpython/gmodeler/preferences.py:298
-#, fuzzy
-msgid "Vector:"
-msgstr "Vektor"
-#: ../gui/wxpython/gmodeler/preferences.py:316
-#, fuzzy
-msgid "Table:"
-msgstr "Tabel"
-#: ../gui/wxpython/gmodeler/preferences.py:416
-msgid "Loop"
-msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:528
-#, fuzzy
-msgid "Comment"
-msgstr "Perintah"
-#: ../gui/wxpython/gmodeler/preferences.py:661
-#: ../gui/wxpython/menustrings.py:1969
-#, fuzzy
-msgid "Model properties"
-#: ../gui/wxpython/gmodeler/preferences.py:670
-#, fuzzy
-msgid "Commands"
-msgstr "Perintah"
-#: ../gui/wxpython/gmodeler/preferences.py:682
-#: ../gui/wxpython/gui_core/preferences.py:1087
-#: ../gui/wxpython/modules/mcalc_builder.py:269
-#: ../gui/wxpython/modules/vclean.py:145 ../gui/wxpython/modules/vkrige.py:187
-#: ../gui/wxpython/modules/import_export.py:89
-msgid "Allow output files to overwrite existing files"
-msgstr "Ijinkan berkas output untuk menimpa berkas yang ada"
-#: ../gui/wxpython/gmodeler/preferences.py:694
-#, fuzzy
-msgid "Apply properties"
-#: ../gui/wxpython/gmodeler/preferences.py:715
-#, fuzzy
-msgid "Description:"
-msgstr "Deskripsi"
-#: ../gui/wxpython/gmodeler/preferences.py:724
-msgid "Author(s):"
-msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:38
-msgid "Set default region extent and resolution"
-msgstr "Tentukan batas dan resolusi dari region standar"
-#: ../gui/wxpython/location_wizard/dialogs.py:109
-msgid "&Set region"
-msgstr "&Tentukan region"
-#: ../gui/wxpython/location_wizard/dialogs.py:141
-msgid "Invalid location selected."
-msgstr "Location yang dipilih tidak valid."
-#: ../gui/wxpython/location_wizard/dialogs.py:160
-msgid "Invalid region"
-msgstr "Region tidak valid"
-#: ../gui/wxpython/location_wizard/dialogs.py:191
-msgid "Click here to show 3D settings"
-msgstr "Klik di sini untuk menampilkan pengaturan 3D"
-#: ../gui/wxpython/location_wizard/dialogs.py:192
-msgid "Click here to hide 3D settings"
-msgstr "Klik di sini untuk menyembunyikan pengaturan 3D"
-#: ../gui/wxpython/location_wizard/dialogs.py:218
-#: ../gui/wxpython/location_wizard/dialogs.py:517
-#, python-format
-msgid "Rows: %d"
-msgstr "Baris: %d"
-#: ../gui/wxpython/location_wizard/dialogs.py:219
-#: ../gui/wxpython/location_wizard/dialogs.py:518
-#, python-format
-msgid "Cols: %d"
-msgstr "Kolom: %d"
-#: ../gui/wxpython/location_wizard/dialogs.py:220
-#: ../gui/wxpython/location_wizard/dialogs.py:519
-#, python-format
-msgid "Cells: %d"
-msgstr "Sel: %d"
-#: ../gui/wxpython/location_wizard/dialogs.py:268
-#: ../gui/wxpython/location_wizard/dialogs.py:521
-#, python-format
-msgid "Depth: %d"
-msgstr "Kedalaman: %d"
-#: ../gui/wxpython/location_wizard/dialogs.py:272
-#: ../gui/wxpython/location_wizard/dialogs.py:522
-#, python-format
-msgid "3D Cells: %d"
-msgstr "Sel 3D: %d"
-#: ../gui/wxpython/location_wizard/dialogs.py:295
-msgid "T-B resolution"
-#: ../gui/wxpython/location_wizard/dialogs.py:360
-msgid "North"
-msgstr "Utara"
-#: ../gui/wxpython/location_wizard/dialogs.py:368
-msgid "West"
-msgstr "Barat"
-#: ../gui/wxpython/location_wizard/dialogs.py:390
-msgid "East"
-msgstr "Timur"
-#: ../gui/wxpython/location_wizard/dialogs.py:399
-msgid "South"
-msgstr "Selatan"
-#: ../gui/wxpython/location_wizard/dialogs.py:403
-msgid "N-S resolution"
-msgstr "Resolusi Utara - Selatan"
-#: ../gui/wxpython/location_wizard/dialogs.py:411
-msgid "E-W resolution"
-msgstr "Resolusi Timur - Barat"
-#: ../gui/wxpython/location_wizard/dialogs.py:489
-#, python-format
-msgid "Invalid value: %s"
-#: ../gui/wxpython/location_wizard/dialogs.py:577
-msgid "Select datum transformation"
-msgstr "Pilih transformasi datum"
-#: ../gui/wxpython/location_wizard/dialogs.py:603
-#, fuzzy
-msgid "Select from list of datum transformations"
-msgstr "Daftar transformasi datum"
-#: ../gui/wxpython/location_wizard/wizard.py:106
-msgid "Define GRASS Database and Location Name"
-msgstr "Definisikan basisdata GRASS dan Nama Location"
-#: ../gui/wxpython/location_wizard/wizard.py:126
-msgid "GIS Data Directory:"
-msgstr "Direktori Data GIS:"
-msgid "Project Location"
-msgstr "Project Location"
-#: ../gui/wxpython/location_wizard/wizard.py:146
-#, fuzzy
-msgid "Name of location directory in GIS Data Directory"
-msgstr "Pilih Direktori Data SIG:"
-#: ../gui/wxpython/location_wizard/wizard.py:161
-#, fuzzy
-msgid "Location Title"
-msgstr "Nama Location:"
-#: ../gui/wxpython/location_wizard/wizard.py:163
-msgid "Optional location title, you can leave this field blank."
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:185
-#, python-format
-msgid ""
-"Name <%(name)s> is not a valid name for location. Please use only ASCII "
-"characters excluding %(chars)s and space."
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:193
-#, fuzzy
-msgid "Invalid location name"
-#: ../gui/wxpython/location_wizard/wizard.py:208
-msgid "Choose GRASS data directory:"
-#: ../gui/wxpython/location_wizard/wizard.py:222
-#: ../gui/wxpython/location_wizard/wizard.py:2482
-msgid "Location already exists in GRASS Database."
-msgstr "Location sudah ada dalam basisdata GRASS"
-#: ../gui/wxpython/location_wizard/wizard.py:226
-msgid "Unable to create location"
-msgstr "Tidak bisa membuat location"
-#: ../gui/wxpython/location_wizard/wizard.py:240
-msgid ""
-"Title of the location is limited only to one line and 256 characters. The "
-"rest of the text will be ignored."
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:250
-msgid "Choose method for creating a new location"
-msgstr "Silakan pilih metoda untuk membuat sebuah location baru"
-#: ../gui/wxpython/location_wizard/wizard.py:257
-#, fuzzy
-msgid "Select EPSG code of spatial reference system"
-msgstr "Pilih kode EPSG dari sistem koordinat"
-#: ../gui/wxpython/location_wizard/wizard.py:263
-msgid "Read projection and datum terms from a georeferenced data file"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:267
-msgid "Read projection and datum terms from a Well Known Text (WKT) .prj file"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:270
-#, fuzzy
-msgid "Select coordinate system parameters from a list"
-msgstr "Pilih sistem koordinat"
-#: ../gui/wxpython/location_wizard/wizard.py:273
-msgid "Specify projection and datum terms using custom PROJ.4 parameters"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:276
-#, fuzzy
-msgid "Create a generic Cartesian coordinate system (XY)"
-msgstr "Gunakan sistem koordinat XY"
-#: ../gui/wxpython/location_wizard/wizard.py:280
-#, fuzzy
-msgid "Simple methods:"
-msgstr "Sederhana"
-#: ../gui/wxpython/location_wizard/wizard.py:292
-#, fuzzy
-msgid "Advanced methods:"
-#: ../gui/wxpython/location_wizard/wizard.py:395
-msgid "Choose projection"
-msgstr "Pilih proyeksi"
-#: ../gui/wxpython/location_wizard/wizard.py:1449
-#: ../gui/wxpython/location_wizard/wizard.py:1677
-msgid "Code"
-msgstr "Kode"
-#: ../gui/wxpython/location_wizard/wizard.py:415
-msgid "Projection code:"
-msgstr "Kode proyeksi:"
-#: ../gui/wxpython/location_wizard/wizard.py:423
-#: ../gui/wxpython/location_wizard/wizard.py:951
-#: ../gui/wxpython/location_wizard/wizard.py:1136
-msgid "Search in description:"
-msgstr "Cari dalam deskripsi:"
-#: ../gui/wxpython/location_wizard/wizard.py:602
-#, python-format
-msgid "Unable to read list: %s"
-msgstr "Tidak dapat membaca daftar: %s"
-#: ../gui/wxpython/location_wizard/wizard.py:707
-#, fuzzy
-msgid "Choose projection parameters"
-#: ../gui/wxpython/location_wizard/wizard.py:721
-#, fuzzy
-msgid "Select datum or ellipsoid (next page)"
-msgstr "Pilih datum dengan ellipsoid terkait"
-#: ../gui/wxpython/location_wizard/wizard.py:729
-#, fuzzy
-msgid "Datum with associated ellipsoid"
-#: ../gui/wxpython/location_wizard/wizard.py:732
-#, fuzzy
-msgid "Ellipsoid only"
-msgstr "Ellipsoid"
-#: ../gui/wxpython/location_wizard/wizard.py:790
-#, python-format
-msgid "You must enter a value for %s"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:809
-#: ../gui/wxpython/location_wizard/wizard.py:830
-msgid " Enter parameters for %s projection "
-msgstr "Masukkan parameter untuk"
-#: ../gui/wxpython/location_wizard/wizard.py:915
-msgid "Specify geodetic datum"
-msgstr "Tentukan datum geodetik"
-msgid "Ellipsoid"
-msgstr "Ellipsoid"
-#: ../gui/wxpython/location_wizard/wizard.py:942
-msgid "Datum code:"
-msgstr "Kode datum:"
-#: ../gui/wxpython/location_wizard/wizard.py:1090
-msgid "Specify ellipsoid"
-msgstr "Tentukan ellipsoid"
-#: ../gui/wxpython/location_wizard/wizard.py:1107
-#, fuzzy
-msgid "Earth based"
-msgstr "Basisdata"
-#: ../gui/wxpython/location_wizard/wizard.py:1110
-msgid "Planetary bodies"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1124
-msgid "Ellipsoid code:"
-msgstr "Kode ellipsoid:"
-#: ../gui/wxpython/location_wizard/wizard.py:1266
-#: ../gui/wxpython/location_wizard/wizard.py:1326
-msgid "Select georeferenced file"
-msgstr "Pilih berkas georeferensi"
-#: ../gui/wxpython/location_wizard/wizard.py:1271
-msgid "Georeferenced file:"
-msgstr "Berkas georeferensi:"
-#: ../gui/wxpython/location_wizard/wizard.py:1342
-#: ../gui/wxpython/location_wizard/wizard.py:1400
-msgid "Select Well Known Text (WKT) .prj file"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1347
-#, fuzzy
-msgid "WKT .prj file:"
-#: ../gui/wxpython/location_wizard/wizard.py:1418
-msgid "Choose EPSG Code"
-msgstr "Pilih Kode EPSG"
-#: ../gui/wxpython/location_wizard/wizard.py:1427
-msgid "Path to the EPSG-codes file:"
-msgstr "Path ke berkas kode EPSG"
-#: ../gui/wxpython/location_wizard/wizard.py:1430
-#: ../gui/wxpython/gui_core/preferences.py:1662
-msgid "EPSG code:"
-#: ../gui/wxpython/location_wizard/wizard.py:1591
-msgid "Choose EPSG codes file"
-#: ../gui/wxpython/location_wizard/wizard.py:1624
-#: ../gui/wxpython/gui_core/preferences.py:1850
-#, fuzzy
-msgid "Unable to read EPGS codes: {}"
-msgstr "Tidak dapat membaca kode EPSG: %s"
-#: ../gui/wxpython/location_wizard/wizard.py:1642
-#, fuzzy
-msgid "Choose IAU Code"
-#: ../gui/wxpython/location_wizard/wizard.py:1651
-#, fuzzy
-msgid "Path to the IAU-codes file:"
-#: ../gui/wxpython/location_wizard/wizard.py:1654
-#, fuzzy
-msgid "IAU code:"
-#: ../gui/wxpython/location_wizard/wizard.py:1836
-#, fuzzy
-msgid "Choose IAU codes file"
-#: ../gui/wxpython/location_wizard/wizard.py:1871
-#, fuzzy
-msgid "Unable to read IAU codes: {}"
-#: ../gui/wxpython/location_wizard/wizard.py:1891
-msgid "Choose method of specifying georeferencing parameters"
-msgstr "Pilih metoda untuk menentukan parameter georeferensi"
-#: ../gui/wxpython/location_wizard/wizard.py:1900
-msgid "Enter PROJ.4 parameters string:"
-msgstr "Masukkan karakter parameter PROJ.4"
-#: ../gui/wxpython/location_wizard/wizard.py:1956
-#: ../gui/wxpython/location_wizard/wizard.py:1960
-msgid "Datum transform is required."
-msgstr "Transformasi datum dibutuhkan."
-#: ../gui/wxpython/location_wizard/wizard.py:2042
-msgid "GRASS Database:"
-msgstr "Basisdata GRASS:"
-#: ../gui/wxpython/location_wizard/wizard.py:2048
-msgid "Location Name:"
-#: ../gui/wxpython/location_wizard/wizard.py:2054
-#, fuzzy
-msgid "Location Title:"
-#: ../gui/wxpython/location_wizard/wizard.py:2060
-msgid "Projection:"
-msgstr "Proyeksi:"
-#: ../gui/wxpython/location_wizard/wizard.py:2068
-#, fuzzy
-msgid ""
-"PROJ.4 definition:\n"
-" (non-definitive)"
-msgstr "Definisi PROJ.4:"
-#: ../gui/wxpython/location_wizard/wizard.py:2192
-#, python-format
-msgid "Do you want to create GRASS location <%s>?"
-msgstr "Apakah Anda hendak membuat GRASS location <%s>?"
-#: ../gui/wxpython/location_wizard/wizard.py:2194
-msgid "Create new location?"
-msgstr "Buat location baru?"
-#: ../gui/wxpython/location_wizard/wizard.py:2242
-msgid "Define new GRASS Location"
-msgstr "Definisikan GRASS Location baru"
-#: ../gui/wxpython/location_wizard/wizard.py:2339
-#, fuzzy, python-format
-msgid ""
-"Unable to create new location. Location <%(loc)s> not created.\n"
-"\n"
-"Details: %(err)s"
-msgstr ""
-"Tidak mampu membuat location baru. Location <%s> tidak berhasil dibuat."
-#: ../gui/wxpython/location_wizard/wizard.py:2347
-msgid "Location wizard canceled. Location not created."
-msgstr "Location wizard dibatalkan. Location tidak dibuat."
-#: ../gui/wxpython/location_wizard/wizard.py:2480
-msgid "Unable to create new location"
-msgstr "Tidak mampu membuat location baru"
-#: ../gui/wxpython/location_wizard/wizard.py:2501
-#, python-format
-msgid ""
-"Location <%(loc)s> will be created in GIS data directory <%(dir)s>. You will "
-"need to change the default GIS data directory in the GRASS startup screen."
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2506
-#, fuzzy
-msgid "New GIS data directory"
-#: ../gui/wxpython/location_wizard/wizard.py:2537
-msgid "EPSG code missing."
-#: ../gui/wxpython/location_wizard/wizard.py:2547
-#, fuzzy
-msgid "IAU code missing."
-#: ../gui/wxpython/location_wizard/wizard.py:2558
-#: ../gui/wxpython/location_wizard/wizard.py:2567
-msgid "File <%s> not found."
-#: ../gui/wxpython/core/debug.py:48
-msgid "Wx debug level {}."
-msgstr ""
-#: ../gui/wxpython/core/debug.py:53
-msgid ""
-"WARNING: Ignoring unsupported wx debug level (must be >=0 and <=5). {}\n"
-msgstr ""
-#: ../gui/wxpython/core/gconsole.py:502
-#, python-format
-msgid ""
-"Unable to run command:\n"
-"%(cmd)s\n"
-"\n"
-"Option <%(opt)s>: read from standard input is not supported by wxGUI"
-msgstr ""
-#: ../gui/wxpython/core/gconsole.py:526
-msgid "Module <%s> not found."
-#: ../gui/wxpython/core/gconsole.py:656
-#, python-format
-msgid "%d sec"
-msgstr ""
-#: ../gui/wxpython/core/gconsole.py:659
-#, python-format
-msgid "%(min)d min %(sec)d sec"
-msgstr ""
-#: ../gui/wxpython/core/gconsole.py:667
-#, fuzzy
-msgid ""
-"Please note that the data are left in inconsistent state and may be corrupted"
-msgstr ""
-"Harap dicatat bahwa data dibiarkan dalam tahap inkonsisten dan bisa menjadi "
-"rusak"
-#: ../gui/wxpython/core/gconsole.py:669
-msgid "Command aborted"
-msgstr "Perintah dibatalkan"
-#: ../gui/wxpython/core/gconsole.py:671
-#, fuzzy
-msgid "Command finished"
-msgstr "Perintah berhasil dijalankan (%d detik)"
-#: ../gui/wxpython/core/gconsole.py:747
-#: ../gui/wxpython/gui_core/goutput.py:497
-msgid ""
-"Unable to write file '%(filePath)s'.\n"
-"\n"
-"Details: %(error)s"
-msgstr "Tidak dapat melakukan perbesar peta vektor <%s>."
-#: ../gui/wxpython/core/menutree.py:143
-msgid "Unknow tag %s"
-#: ../gui/wxpython/core/utils.py:60
-#, python-format
-msgid "Syntax error: %s"
-msgstr ""
-#: ../gui/wxpython/core/utils.py:351
-msgid "Vector map <%(map)s>: %(msg)s\n"
-msgstr "Peta vektor baru"
-#: ../gui/wxpython/core/utils.py:535
-#, fuzzy
-msgid "failed to open '{}'"
-msgstr "Tidak dapat membuka berkas"
-#: ../gui/wxpython/core/utils.py:841
-#, python-format
-msgid "ERROR: Unable to determine GRASS version. Details: %s"
-msgstr ""
-#: ../gui/wxpython/core/utils.py:882
-msgid "Unable to open file '%s'\n"
-msgstr "Tidak mampu membuka berkas <%s> untuk dibaca."
-#: ../gui/wxpython/core/utils.py:892
-#, python-format
-msgid ""
-"%s: line skipped - unable to parse '%s'\n"
-"Reason: %s\n"
-msgstr ""
-#: ../gui/wxpython/core/utils.py:897
-msgid "Duplicated key: %s\n"
-msgstr "Perbaharui atribut"
-#: ../gui/wxpython/core/utils.py:913
-msgid "Unable to create file '%s'\n"
-#: ../gui/wxpython/core/utils.py:996 ../gui/wxpython/gui_core/forms.py:1712
-msgid "Select Color"
-msgstr "Pilih warna"
-#: ../gui/wxpython/core/render.py:151
-msgid "<%(name)s>: layer type <%(type)s> is not supported"
-msgstr "<%(name)s>: type layer<%(type)s> belum didukung."
-#: ../gui/wxpython/core/render.py:170
-msgid "Command '%s' failed\n"
-#: ../gui/wxpython/core/render.py:173
-msgid "Details: %s\n"
-msgstr "Deil:"
-#: ../gui/wxpython/core/render.py:258
-msgid "Unsupported map layer type '%s'"
-msgstr "Tidak dapat melakukan render layer peta <%s>."
-#: ../gui/wxpython/core/render.py:623
-msgid "Rendering failed: %s"
-#: ../gui/wxpython/core/render.py:666
-#, fuzzy
-msgid "Rendering aborted"
-msgstr "Render"
-#: ../gui/wxpython/core/render.py:697
-#, fuzzy
-msgid "Downloading data "
-#: ../gui/wxpython/core/render.py:707
-#, fuzzy
-msgid "Rendering & "
-msgstr "Render"
-#: ../gui/wxpython/core/render.py:709
-#, fuzzy
-msgid "Rendering..."
-msgstr "Render"
-#: ../gui/wxpython/core/render.py:754
-#, fuzzy
-msgid "Trying to recover from default region..."
-msgstr "Perbesaran sesuai dengan region standar"
-#: ../gui/wxpython/core/render.py:814
-#, python-format
-msgid "Error: Unable to open '%(file)s'. Reason: %(ret)s. wxGUI exited.\n"
-msgstr ""
-#: ../gui/wxpython/core/render.py:824
-msgid ""
-"\n"
-"ERROR: Unable to read WIND file: %s\n"
-#: ../gui/wxpython/core/render.py:928
-msgid "Invalid map size %d,%d\n"
-#: ../gui/wxpython/core/render.py:1009
-msgid "Unable to zoom to raster map <%s>."
-msgstr "Tidak dapat memperbesar ke peta raster <%s>"
-#: ../gui/wxpython/core/render.py:1010 ../gui/wxpython/core/render.py:1013
-#: ../gui/wxpython/core/render.py:1016 ../gui/wxpython/core/gcmd.py:435
-msgid "Details:"
-msgstr "Deil:"
-#: ../gui/wxpython/core/render.py:1012
-msgid "Unable to zoom to vector map <%s>."
-#: ../gui/wxpython/core/render.py:1015
-msgid "Unable to zoom to 3d raster map <%s>."
-#: ../gui/wxpython/core/render.py:1019
-msgid ""
-"Unable to get current geographic extent. Force quiting wxGUI. Please "
-"manually run g.region to fix the problem."
-msgstr ""
-#: ../gui/wxpython/core/ws.py:51
-msgid ""
-"Unable to load GDAL Python bindings.\n"
-"WMS layers can not be displayed without the bindings.\n"
-msgstr ""
-#: ../gui/wxpython/core/workspace.py:1608
-#, python-format
-msgid "Unable to open file <%s> for reading."
-#: ../gui/wxpython/core/workspace.py:1625
-msgid ""
-"Some lines were skipped when reading settings from file <%(file)s>.\n"
-"See 'Command output' window for details.\n"
-"\n"
-"Number of skipped lines: %(line)d"
-msgstr ""
-"Beberapa baris diabaikan ketika membaca standar dari berkas<%s>.\n"
-"Lihat jendela 'Command output' untuk lebih jelasnya.\n"
-"\n"
-"Jumlah baris yang diabaikan: %d"
-#: ../gui/wxpython/core/workspace.py:1850
-#, python-format
-msgid " row %d:"
-msgstr " baris %d:"
-#: ../gui/wxpython/core/gcmd.py:126
-#, fuzzy
-msgid "Reason"
-msgstr "Region "
-#: ../gui/wxpython/core/gcmd.py:432
-msgid "Execution failed:"
-msgstr "Eksekusi gagal:"
-#: ../gui/wxpython/core/gcmd.py:437 ../gui/wxpython/core/gcmd.py:444
-#, fuzzy
-msgid "Error: "
-msgstr "Kesalahan "
-#: ../gui/wxpython/core/gcmd.py:521
-msgid "Unable to exectute command: '%s'"
-msgstr "Tidak dapat menganalisis kesalahan perintah %s"
-#: ../gui/wxpython/core/gcmd.py:747 ../gui/wxpython/gui_core/forms.py:2709
-msgid "Error in %s"
-#: ../gui/wxpython/core/settings.py:491
-msgid "Segment break"
-msgstr "Segment break"
-#: ../gui/wxpython/core/settings.py:557
-#, fuzzy
-msgid "Data point"
-msgstr "Titik "
-#: ../gui/wxpython/core/settings.py:631
-#, fuzzy
-msgid "animation"
-msgstr "Kuantisasi "
-#: ../gui/wxpython/core/settings.py:854
-msgid "Collapse all except PERMANENT and current"
-msgstr "Putus semua kecuali PERMANENT dan current"
-#: ../gui/wxpython/core/settings.py:855
-msgid "Collapse all except PERMANENT"
-msgstr "Putuskan semua kecuali PERMANENT"
-#: ../gui/wxpython/core/settings.py:856
-#, fuzzy
-msgid "Collapse all except current"
-#: ../gui/wxpython/core/settings.py:857
-msgid "Collapse all"
-msgstr "Tutup semua"
-#: ../gui/wxpython/core/settings.py:858
-msgid "Expand all"
-msgstr "Kembangkan semua"
-#: ../gui/wxpython/core/settings.py:863
-msgid "Display selected"
-msgstr "Tampilkan yang terpilih"
-#: ../gui/wxpython/core/settings.py:872
-msgid "Classic (labels only)"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:873
-msgid "Combined (labels and module names)"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:874
-msgid "Expert (module names only)"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:879
-msgid "Basic top"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:880
-msgid "Basic left"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:881
-msgid "Fancy green"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:882
-#, fuzzy
-msgid "List left"
-msgstr "Daftar tabel"
-#: ../gui/wxpython/core/settings.py:889
-msgid "Zoom and recenter"
-msgstr ""
-#, fuzzy
-msgid "Zoom to mouse cursor"
-msgstr "Perbesaran sesuai dengan region tersimpan"
-#, fuzzy
-msgid "Nothing"
-msgstr "Utara"
-#: ../gui/wxpython/core/settings.py:891
-msgid "Scroll forward to zoom in"
-msgstr ""
-msgid "Scroll back to zoom in"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:924 ../gui/wxpython/core/settings.py:936
-msgid "box"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:925
-msgid "sphere"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:926
-msgid "cube"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:927
-msgid "diamond"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:928
-#, fuzzy
-msgid "aster"
-msgstr "raster"
-#: ../gui/wxpython/core/settings.py:929
-msgid "gyro"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:930
-#, fuzzy
-msgid "histogram"
-msgstr "Histogram"
-#: ../gui/wxpython/core/settings.py:936
-msgid "cross"
-msgstr ""
-msgid "circle"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:969
-msgid "Unable to read settings file <%s>\n"
-#: ../gui/wxpython/core/settings.py:995
-msgid ""
-"Error: Reading settings from file <%(file)s> failed.\n"
-"\t\tDetails: %(detail)s\n"
-"\t\tLine: '%(line)s'\n"
-msgstr ""
-"Kesalahan: Pembacaan standar dari berkas <%s> gagal.\n"
-"Detil: %s\n"
-"Garis: '%s'"
-#: ../gui/wxpython/core/settings.py:1013
-#, fuzzy
-msgid "Unable to create settings directory"
-msgstr "Tidak dapat memperbaharui rekaman yang ada."
-#: ../gui/wxpython/core/settings.py:1062
-msgid ""
-"Writing settings to file <%(file)s> failed.\n"
-"\n"
-"Details: %(detail)s"
-msgstr ""
-"Penyimpanan pengaturan ke berkas <%s> gagal.\n"
-"\n"
-"Detil: %s"
-#: ../gui/wxpython/core/settings.py:1168
-msgid "Unable to set "
-#: ../gui/wxpython/core/settings.py:1204 ../gui/wxpython/core/settings.py:1214
-msgid "Unable to parse settings '%s'"
-#: ../gui/wxpython/core/toolboxes.py:217
-msgid "Unable to parse user toolboxes XML files. Default files will be loaded."
-msgstr ""
-#: ../gui/wxpython/core/toolboxes.py:261
-#, fuzzy
-msgid "Unable to create toolboxes directory."
-#: ../gui/wxpython/core/toolboxes.py:485
-#, fuzzy
-msgid "Custom toolboxes"
-msgstr "Bebas maks."
-#: ../gui/wxpython/core/toolboxes.py:509
-msgid "List of addons cannot be obtained because g.extension failed."
-msgstr ""
-#: ../gui/wxpython/core/toolboxes.py:565
-msgid "Addons"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:95
-#, fuzzy
-msgid " Server settings "
-#: ../gui/wxpython/web_services/dialogs.py:98
-#, fuzzy
-msgid "Server:"
-msgstr "Driver"
-#: ../gui/wxpython/web_services/dialogs.py:102
-#, fuzzy
-msgid "&Connect"
-msgstr "Koneksikan"
-#: ../gui/wxpython/web_services/dialogs.py:103
-msgid "Connect to the server"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:107
-#, fuzzy
-msgid "Show advanced connection settings"
-msgstr "Pengaturan lebih lanjut"
-#: ../gui/wxpython/web_services/dialogs.py:108
-#, fuzzy
-msgid "Hide advanced connection settings"
-#: ../gui/wxpython/web_services/dialogs.py:126
-#, fuzzy
-msgid " Layer Manager Settings "
-msgstr "Pengaturan Layer Maager"
-#: ../gui/wxpython/web_services/dialogs.py:130
-#, fuzzy
-msgid "Output layer name:"
-msgstr "Nama tabel"
-#: ../gui/wxpython/web_services/dialogs.py:256
-#, fuzzy
-msgid "Username:"
-msgstr "Ubah nama "
-#: ../gui/wxpython/web_services/dialogs.py:260
-msgid "Password:"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:301
-#: ../gui/wxpython/gui_core/gselect.py:1942
-msgid "No data source defined, settings are not saved."
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:386
-#, python-format
-msgid "Connecting to <%s>..."
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:454
-msgid "Available web services"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:467
-#, python-format
-msgid "Connected to <%s>"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:473
-msgid "Unable to connect to <%s>"
-#: ../gui/wxpython/web_services/dialogs.py:523
-#: ../gui/wxpython/menustrings.py:27 ../gui/wxpython/menustrings.py:28
-#, fuzzy
-msgid "Add web service layer"
-msgstr "Tambahkan layer grid"
-#: ../gui/wxpython/web_services/dialogs.py:538
-#, fuzzy
-msgid "Add selected web service layers as map layer into layer tree"
-#: ../gui/wxpython/web_services/dialogs.py:636
-#, fuzzy
-msgid "Web service layer properties"
-msgstr "Karakteristik"
-#: ../gui/wxpython/web_services/dialogs.py:683
-msgid "&Apply"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:688
-msgid "&OK"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:856
-#, fuzzy
-msgid "Name for output raster map:"
-msgstr "Nama untuk peta vektor baru:"
-#: ../gui/wxpython/web_services/dialogs.py:866
-#, fuzzy
-msgid "Export region"
-msgstr "Set region"
-#: ../gui/wxpython/web_services/dialogs.py:871
-#: ../gui/wxpython/menustrings.py:18
-#, fuzzy
-msgid "Map display"
-msgstr "Tampilan"
-#: ../gui/wxpython/web_services/dialogs.py:875
-#, fuzzy
-msgid "Named region"
-msgstr "Muat region:"
-#: ../gui/wxpython/web_services/dialogs.py:877
-msgid "Extent and resolution are based on Map Display geometry."
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:879
-#, fuzzy
-msgid "Extent and resolution are based on computational region."
-msgstr "Batas resolusi display sesuai pengaturan komputasi"
-#: ../gui/wxpython/web_services/dialogs.py:881
-#, fuzzy
-msgid "Extent and resolution are based on named region."
-msgstr "Set region komputasi berdasarkan tampilan"
-#: ../gui/wxpython/web_services/dialogs.py:886
-#, fuzzy
-msgid "Overwrite existing raster map"
-msgstr "timpa berkas yang ada"
-#: ../gui/wxpython/web_services/dialogs.py:891
-#, fuzzy
-msgid "Choose named region:"
-#: ../gui/wxpython/web_services/dialogs.py:904
-#, fuzzy
-msgid "&Save layer"
-#: ../gui/wxpython/web_services/dialogs.py:905
-#, fuzzy
-msgid "Save web service layer as raster map"
-#: ../gui/wxpython/web_services/dialogs.py:1026
-msgid "Missing output raster."
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:1030
-#, fuzzy
-msgid "Output map can be added only to current mapset."
-#: ../gui/wxpython/web_services/dialogs.py:1034
-#, python-format
-msgid "Output map <%s> already exists"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:1055
-msgid "Region <%s> does not exist."
-#: ../gui/wxpython/web_services/dialogs.py:1084
-#, fuzzy
-msgid "Downloading data..."
-#: ../gui/wxpython/web_services/dialogs.py:1111
-#, fuzzy
-msgid "Unable to fetch data.\n"
-#: ../gui/wxpython/web_services/widgets.py:131
-#, fuzzy
-msgid " Requested data settings "
-#: ../gui/wxpython/web_services/widgets.py:158
-#, fuzzy
-msgid "Request"
-msgstr "Dibutuhkan"
-#: ../gui/wxpython/web_services/widgets.py:163
-#, fuzzy
-msgid "List of layers "
-msgstr "Daftar layer"
-#: ../gui/wxpython/web_services/widgets.py:181
-#, fuzzy
-msgid "Source projection:"
-#: ../gui/wxpython/web_services/widgets.py:242
-#, fuzzy
-msgid "Advanced request settings"
-#: ../gui/wxpython/web_services/widgets.py:250
-#, fuzzy
-msgid "Order of layers in raster"
-msgstr "Tumpang-susunkan raster"
-#: ../gui/wxpython/web_services/widgets.py:263
-#, fuzzy
-msgid "Reprojection method:"
-#: ../gui/wxpython/web_services/widgets.py:270
-#, fuzzy
-msgid "Nearest neighbor"
-msgstr "Cuplik-ulang dengan tetangga-terdekat "
-#: ../gui/wxpython/web_services/widgets.py:271
-#, fuzzy
-msgid "Linear interpolation"
-msgstr "Regresi linier "
-#: ../gui/wxpython/web_services/widgets.py:272
-#, fuzzy
-msgid "Cubic interpolation"
-msgstr "Pilih peta vektor"
-#: ../gui/wxpython/web_services/widgets.py:273
-msgid "Cubic spline interpolation"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:277
-msgid "Maximum columns to request from server at time:"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:283
-msgid "Maximum rows to request from server at time:"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:300
-msgid "Do not request transparent data"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:315
-#, fuzzy
-msgid "Additional query parameters for server:"
-#: ../gui/wxpython/web_services/widgets.py:528
-msgid ""
-"Unable to download %s capabilities file\n"
-"from <%s>:\n"
-#: ../gui/wxpython/web_services/widgets.py:545
-#, python-format
-msgid ""
-"%s web service was not found in fetched capabilities file from <%s>:\n"
-"%s\n"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:831
-#, fuzzy
-msgid "Source image format"
-msgstr "Koordinat"
-#: ../gui/wxpython/web_services/widgets.py:867
-#, fuzzy
-msgid "Select layer in layer list.\n"
-msgstr "Tampilkan layer peta ke dalam layer tree"
-#: ../gui/wxpython/web_services/widgets.py:872
-#, fuzzy
-msgid "Select source image format.\n"
-msgstr "Pilih sumber mapset:"
-#: ../gui/wxpython/web_services/widgets.py:877
-#, fuzzy
-msgid "Select source projection.\n"
-msgstr "Pilih sumber location:"
-#: ../gui/wxpython/web_services/widgets.py:881
-msgid "Choose output layer name.\n"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:925
-#: ../gui/wxpython/gui_core/forms.py:2006
-#: ../gui/wxpython/modules/import_export.py:72
-#, fuzzy
-msgid "Layer name"
-#: ../gui/wxpython/web_services/widgets.py:962
-#, fuzzy
-msgid "layer"
-msgstr "Layer"
-#: ../gui/wxpython/web_services/widgets.py:982
-#, fuzzy
-msgid "style"
-msgstr "Gaya"
-#: ../gui/wxpython/web_services/widgets.py:1155
-#, fuzzy
-msgid "Add default"
-msgstr "&Tentukan standar"
-#: ../gui/wxpython/web_services/widgets.py:1172
-#, python-format
-msgid ""
-"User defined server with same name as default server <%s> already exists.\n"
-"Keeping user defined server"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:72
-msgid "Required item is not set."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:103
-#, fuzzy
-msgid "Select GRASS location and mapset"
-msgstr "Pilih location dan mapset proyek"
-#: ../gui/wxpython/gui_core/dialogs.py:122
-#, fuzzy
-msgid "Location or mapset is not defined."
-msgstr "Komputasi aliran untuk grid masif (versi float)."
-#: ../gui/wxpython/gui_core/dialogs.py:132
-#, fuzzy
-msgid "Name of GRASS location:"
-#: ../gui/wxpython/gui_core/dialogs.py:143
-#: ../gui/wxpython/gui_core/dialogs.py:200
-#, fuzzy
-msgid "Name of mapset:"
-#: ../gui/wxpython/gui_core/dialogs.py:172
-#, fuzzy
-msgid "Select mapset in GRASS location"
-msgstr "Pilih tipe peta dan location/mapset"
-#: ../gui/wxpython/gui_core/dialogs.py:192
-#, fuzzy
-msgid "Name of mapset is missing."
-#: ../gui/wxpython/gui_core/dialogs.py:233
-#, fuzzy
-msgid "Name of vector map is missing."
-#: ../gui/wxpython/gui_core/dialogs.py:264
-#: ../gui/wxpython/gui_core/dialogs.py:402 ../gui/wxpython/menustrings.py:539
-#: ../gui/wxpython/menustrings.py:1445
-msgid "Create new vector map"
-msgstr "Buat peta vektor baru"
-#: ../gui/wxpython/gui_core/dialogs.py:286
-#, fuzzy
-msgid "Create attribute table"
-msgstr "Perlihatkan tabel atribut"
-#: ../gui/wxpython/gui_core/dialogs.py:306
-#: ../gui/wxpython/gui_core/preferences.py:1115
-#, fuzzy
-msgid "Add created map into layer tree"
-#: ../gui/wxpython/gui_core/dialogs.py:320
-#, fuzzy
-msgid "Name of new vector map is missing."
-#: ../gui/wxpython/gui_core/dialogs.py:332
-msgid "Name for new vector map:"
-#: ../gui/wxpython/gui_core/dialogs.py:351
-#: ../gui/wxpython/gui_core/preferences.py:1595
-#, fuzzy
-msgid "Key column:"
-#: ../gui/wxpython/gui_core/dialogs.py:435
-#, python-format
-msgid "Unable to create vector map <%s>."
-#: ../gui/wxpython/gui_core/dialogs.py:440
-msgid ""
-"Invalid or empty key column.\n"
-"Unable to create vector map <%s>."
-#: ../gui/wxpython/gui_core/dialogs.py:471
-msgid ""
-"Vector map <%s> already exists in the current mapset. Do you want to "
-"overwrite it?"
-msgstr "Berkas region <%s> sudah ada. Anda ingin menimpanya?"
-#: ../gui/wxpython/gui_core/dialogs.py:561
-msgid "Load region:"
-#: ../gui/wxpython/gui_core/dialogs.py:567
-msgid "Save region:"
-msgstr "Simpan region:"
-#: ../gui/wxpython/gui_core/dialogs.py:619
-msgid ""
-"Name cannot begin with '.' and must not contain space, quotes, '/', ''', "
-"'@', ',', '=', '*', and all other non-alphanumeric characters."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:635
-#, fuzzy
-msgid "Create or edit imagery groups"
-msgstr "Buat/edit grup"
-#: ../gui/wxpython/gui_core/dialogs.py:669
-#, fuzzy
-msgid "Apply changes to selected group and close dialog"
-msgstr "Terapkan perubahan untuk sesi ini"
-#: ../gui/wxpython/gui_core/dialogs.py:670
-#, fuzzy
-msgid "Apply changes to selected group"
-#: ../gui/wxpython/gui_core/dialogs.py:671
-#, fuzzy
-msgid "Close dialog, changes are not applied"
-msgstr "Kembalikan pengaturan ke standar dan terapkan perubahan"
-#: ../gui/wxpython/gui_core/dialogs.py:712
-#: ../gui/wxpython/gui_core/dialogs.py:1509
-msgid ""
-"Put here a regular expression. Characters '.*' stand for anything, character "
-"'^' stands for the beginning and '$' for the end."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:719
-msgid "Select existing group or enter name of new group:"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:730
-msgid "Edit/create subgroup"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:743
-msgid "Select existing subgroup or enter name of new subgroup:"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:777
-#: ../gui/wxpython/gui_core/dialogs.py:845
-#: ../gui/wxpython/gui_core/dialogs.py:1494
-#, fuzzy
-msgid "Pattern:"
-msgstr "raster"
-#: ../gui/wxpython/gui_core/dialogs.py:795
-#: ../gui/wxpython/gui_core/dialogs.py:863
-#: ../gui/wxpython/gui_core/dialogs.py:1518
-msgid "List of maps:"
-msgstr "Daftar peta:"
-#: ../gui/wxpython/gui_core/dialogs.py:811
-msgid "Select map layers and add them to the list."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:816
-#, fuzzy
-msgid "Remove selected layer(s) from list."
-#: ../gui/wxpython/gui_core/dialogs.py:873
-msgid "Check maps from group to be included into subgroup."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1037
-#, fuzzy
-msgid "Add selected map layers into group"
-#: ../gui/wxpython/gui_core/dialogs.py:1174
-#, python-format
-msgid "Group <%s> was changed, do you want to apply changes?"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1177
-#: ../gui/wxpython/gui_core/dialogs.py:1193
-#, fuzzy
-msgid "Unapplied changes"
-msgstr "Simpan perubahan"
-#: ../gui/wxpython/gui_core/dialogs.py:1190
-#, python-format
-msgid "Subgroup <%s> was changed, do you want to apply changes?"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1247
-#, fuzzy
-msgid "No raster maps selected."
-#: ../gui/wxpython/gui_core/dialogs.py:1276
-#, python-format
-msgid "No changes to apply in group <%s>."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1279
-#, python-format
-msgid "Group <%s> was successfully created."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1281
-#, python-format
-msgid "Group <%s> was successfully changed."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1284
-msgid "Creating of new group <%s> failed."
-msgstr "Penambahan fitur baru untuk peta vektor <%s> gagal."
-#: ../gui/wxpython/gui_core/dialogs.py:1286
-#, python-format
-msgid "Changing of group <%s> failed."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1324
-#, fuzzy
-msgid "No group selected."
-#: ../gui/wxpython/gui_core/dialogs.py:1329
-#, fuzzy
-msgid "No subgroup selected."
-#: ../gui/wxpython/gui_core/dialogs.py:1436
-msgid "Use fully-qualified map names"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1462
-#, fuzzy
-msgid "Map type:"
-msgstr "Tipe layer peta:"
-#: ../gui/wxpython/gui_core/dialogs.py:1477
-#, fuzzy
-msgid "Select toggle"
-msgstr "Pilih dangle"
-#: ../gui/wxpython/gui_core/dialogs.py:1484
-msgid "Mapset:"
-msgstr "Mapset:"
-#: ../gui/wxpython/gui_core/dialogs.py:1577
-#, fuzzy
-msgid "Invert selection"
-msgstr "Potongan melintang"
-#: ../gui/wxpython/gui_core/dialogs.py:1720
-#, python-format
-msgid "Dynamic series (%s)"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1747
-#, fuzzy
-msgid "Set Map Layer Opacity"
-#: ../gui/wxpython/gui_core/dialogs.py:1781
-msgid "opaque"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1879
-msgid "Set image size"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1894
-#, fuzzy
-msgid "Image size"
-msgstr "Pengaturan halaman"
-#: ../gui/wxpython/gui_core/dialogs.py:1941
-msgid "Template:"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1981
-#, fuzzy
-msgid "GRASS GIS SQL Query Utility"
-msgstr "GRASS GIS - Map display"
-#: ../gui/wxpython/gui_core/dialogs.py:1997
-#, fuzzy
-msgid " SQL statement "
-msgstr "Pernyataan SQL"
-#: ../gui/wxpython/gui_core/dialogs.py:2045
-#, fuzzy
-msgid "Symbols"
-msgstr "Simbolisasi"
-#: ../gui/wxpython/gui_core/dialogs.py:2080
-#, fuzzy
-msgid "Symbol directory:"
-msgstr "Pengaturan simbol"
-#: ../gui/wxpython/gui_core/dialogs.py:2092
-#, fuzzy
-msgid "Symbol name:"
-#: ../gui/wxpython/gui_core/dialogs.py:2326
-#: ../gui/wxpython/gui_core/dialogs.py:2351 ../gui/wxpython/menustrings.py:208
-#, fuzzy
-msgid "Quit GRASS GIS"
-msgstr "Tentang GRASS GIS"
-#: ../gui/wxpython/gui_core/dialogs.py:2344
-msgid "Do you want to quit GRASS including shell prompt or just close the GUI?"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2348 ../gui/wxpython/menustrings.py:206
-#, fuzzy
-msgid "Close GUI"
-msgstr "Kode"
-#: ../gui/wxpython/gui_core/dialogs.py:2422
-#, fuzzy
-msgid "Select font:"
-msgstr "Pilih jenis huruf"
-#: ../gui/wxpython/gui_core/dialogs.py:2453
-msgid "Character encoding:"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2518
-#, fuzzy
-msgid "Example"
-msgstr "Sederhana"
-#: ../gui/wxpython/gui_core/forms.py:545
-#, fuzzy
-msgid "Enter parameters for '"
-#: ../gui/wxpython/gui_core/forms.py:557
-#: ../gui/wxpython/mapswipe/dialogs.py:193 ../gui/wxpython/menustrings.py:14
-#: ../gui/wxpython/menustrings.py:1943
-#, fuzzy
-msgid "Close"
-msgstr "Kode"
-#: ../gui/wxpython/gui_core/forms.py:561
-msgid "Close this window without executing the command (Ctrl+Q)"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:592
-#, fuzzy
-msgid "Run the command (Ctrl+R)"
-msgstr "Jalankan perintah"
-#: ../gui/wxpython/gui_core/forms.py:607 ../gui/wxpython/menustrings.py:166
-#: ../gui/wxpython/menustrings.py:1151
-msgid "Copy"
-msgstr "Salin "
-#: ../gui/wxpython/gui_core/forms.py:611
-#: ../gui/wxpython/modules/mcalc_builder.py:159
-#, fuzzy
-msgid "Copy the current command string to the clipboard"
-msgstr "Salin perintah saat ini ke clipboard"
-#: ../gui/wxpython/gui_core/forms.py:620
-#, fuzzy
-msgid "Show manual page of the command (Ctrl+H)"
-msgstr "Tampilkan halaman manual dari perintah"
-#: ../gui/wxpython/gui_core/forms.py:659
-#, fuzzy
-msgid "Add created map(s) into layer tree"
-#: ../gui/wxpython/gui_core/forms.py:689
-msgid ""
-"Close dialog when command is successfully finished. Change this settings in "
-"Preferences dialog ('Command' tab)."
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:865
-#, python-format
-msgid "'%s' copied to clipboard"
-msgstr "'%s' berhasil disalin ke clipboard"
-#: ../gui/wxpython/gui_core/forms.py:945 ../gui/wxpython/gui_core/forms.py:959
-msgid "Required"
-#: ../gui/wxpython/gui_core/forms.py:948 ../gui/wxpython/gui_core/forms.py:960
-msgid "Optional"
-msgstr "Opsional"
-#: ../gui/wxpython/gui_core/forms.py:1043
-#: ../gui/wxpython/gui_core/forms.py:2034
-#, fuzzy
-msgid "Parameterized in model"
-msgstr "Parameter tidak ditemukan: %s"
-#: ../gui/wxpython/gui_core/forms.py:1112
-msgid "This option is required"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1133
-msgid "[multiple]"
-msgstr "[berganda]"
-#: ../gui/wxpython/gui_core/forms.py:1191
-#, fuzzy
-msgid "valid range"
-#: ../gui/wxpython/gui_core/forms.py:1301
-#: ../gui/wxpython/gui_core/forms.py:2665
-#: ../gui/wxpython/gui_core/toolbars.py:69
-msgid "Select font"
-#: ../gui/wxpython/gui_core/forms.py:1419
-#: ../gui/wxpython/gui_core/preferences.py:744
-#, fuzzy
-msgid "Map Display"
-msgstr "Tampilan"
-#: ../gui/wxpython/gui_core/forms.py:1532
-msgid "Show graphical representation of temporal extent of dataset(s) ."
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1762
-#: ../gui/wxpython/gui_core/preferences.py:1312
-#: ../gui/wxpython/gui_core/preferences.py:1347
-msgid "Transparent"
-msgstr "Transparans"
-#: ../gui/wxpython/gui_core/forms.py:1798
-#: ../gui/wxpython/gui_core/forms.py:1882
-#, python-format
-msgid "Choose %s"
-msgstr "Pilih %s"
-#: ../gui/wxpython/gui_core/forms.py:1833
-#: ../gui/wxpython/modules/mcalc_builder.py:155
-#, fuzzy
-msgid "&Load"
-msgstr "Memuat"
-#: ../gui/wxpython/gui_core/forms.py:1835
-#, fuzzy
-msgid "Load and edit content of a file"
-msgstr "Ubah nama location"
-#: ../gui/wxpython/gui_core/forms.py:1838
-#, fuzzy
-msgid "&Save as"
-#: ../gui/wxpython/gui_core/forms.py:1840
-msgid "Save content to a file for further use"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1845
-#, fuzzy
-msgid "or enter values directly:"
-msgstr "Pengkodean-ulang secara interaktif "
-#: ../gui/wxpython/gui_core/forms.py:1847
-msgid ""
-"Enter file content directly instead of specifying a file. Temporary file "
-"will be automatically created."
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1885
-#: ../gui/wxpython/gui_core/gselect.py:1417
-#, fuzzy
-msgid "Directory"
-msgstr "Arah"
-#: ../gui/wxpython/gui_core/forms.py:2005
-#: ../gui/wxpython/modules/import_export.py:71
-#: ../gui/wxpython/modules/import_export.py:862
-#, fuzzy
-msgid "Layer id"
-msgstr "Layer"
-#: ../gui/wxpython/gui_core/forms.py:2008
-#: ../gui/wxpython/modules/import_export.py:76
-#: ../gui/wxpython/modules/import_export.py:78
-#, fuzzy
-msgid "Projection match"
-msgstr "Proyeksi:"
-#: ../gui/wxpython/gui_core/forms.py:2237
-msgid "Manual"
-msgstr "Manual"
-#: ../gui/wxpython/gui_core/forms.py:2281
-#, fuzzy
-msgid "Nothing to load."
-msgstr "Tidak ada yang dapat diekstrak."
-#: ../gui/wxpython/gui_core/forms.py:2289
-msgid ""
-"Unable to load file.\n"
-"\n"
-"Reason: %s"
-#: ../gui/wxpython/gui_core/forms.py:2315
-#: ../gui/wxpython/modules/colorrules.py:690
-#, fuzzy
-msgid "Nothing to save."
-#: ../gui/wxpython/gui_core/forms.py:2319
-#, fuzzy
-msgid "Save input as..."
-#: ../gui/wxpython/gui_core/forms.py:2652
-#, fuzzy
-msgid "No dataset given."
-#: ../gui/wxpython/gui_core/forms.py:2821
-#: ../gui/wxpython/gui_core/forms.py:2838
-msgid "Unable to parse command '%s'"
-#: ../gui/wxpython/gui_core/forms.py:2845
-#, python-format
-msgid "%(cmd)s: parameter '%(key)s' not available"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:2927
-msgid "Try to set up GRASS_ADDON_PATH or GRASS_ADDON_BASE variable."
-msgstr ""
-#: ../gui/wxpython/gui_core/vselect.py:48
-#, fuzzy
-msgid "category"
-msgstr "Kategori"
-#: ../gui/wxpython/gui_core/vselect.py:73
-#, fuzzy
-msgid "Select features"
-msgstr "Pilih fitur vektor"
-#: ../gui/wxpython/gui_core/vselect.py:136
-#, fuzzy
-msgid "Create a new map"
-#: ../gui/wxpython/gui_core/vselect.py:265
-msgid "Selected map <%s> has been disabled for rendering. Operation canceled."
-msgstr "Tidak ada layer peta terpilih. Operasi digagalkan."
-#: ../gui/wxpython/gui_core/vselect.py:297
-msgid "Failed to query vector map(s) <%s>."
-#: ../gui/wxpython/gui_core/vselect.py:322
-#, fuzzy
-msgid "No features selected"
-#: ../gui/wxpython/gui_core/vselect.py:346
-msgid "Vector map <%s> was created"
-#: ../gui/wxpython/gui_core/vselect.py:349
-msgid ""
-"Unable to create a new vector map.\n"
-"\n"
-"Reason: %s"
-#: ../gui/wxpython/gui_core/menu.py:149
-msgid "Double-click or Ctrl-Enter to run selected module"
-msgstr ""
-#: ../gui/wxpython/gui_core/menu.py:171
-#, fuzzy
-msgid "Run selected module from the tree"
-#: ../gui/wxpython/gui_core/goutput.py:127
-#, fuzzy
-msgid "Click here to show search module engine"
-#: ../gui/wxpython/gui_core/goutput.py:129
-#, fuzzy
-msgid "Click here to hide search module engine"
-#: ../gui/wxpython/gui_core/goutput.py:146
-#, fuzzy
-msgid "Command prompt"
-#: ../gui/wxpython/gui_core/goutput.py:151
-#, fuzzy
-msgid "Output window"
-msgstr "Output "
-#: ../gui/wxpython/gui_core/goutput.py:159
-#, fuzzy
-msgid "Clear output window content"
-#: ../gui/wxpython/gui_core/goutput.py:161
-msgid "Clear command prompt content"
-msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:164
-msgid "Save output window content to the file"
-msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:166
-#, fuzzy
-msgid "Abort running command"
-msgstr "Batalkan perintah yang sedang berjalan"
-#: ../gui/wxpython/gui_core/goutput.py:170
-#, fuzzy
-msgid "&Log file"
-msgstr "Skala log"
-#: ../gui/wxpython/gui_core/goutput.py:172
-msgid ""
-"Toggle to save list of executed commands into a file; content saved when "
-"switching off."
-msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:421
-#: ../gui/wxpython/gui_core/goutput.py:517
-msgid "Save file as..."
-#: ../gui/wxpython/gui_core/goutput.py:423
-#: ../gui/wxpython/gui_core/goutput.py:519
-#, python-format
-msgid "%(txt)s (*.txt)|*.txt|%(files)s (*)|*"
-msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:424
-#: ../gui/wxpython/gui_core/goutput.py:520
-#, fuzzy
-msgid "Text files"
-msgstr "Pengaturan teks"
-#: ../gui/wxpython/gui_core/goutput.py:425
-#: ../gui/wxpython/gui_core/goutput.py:521
-#, fuzzy
-msgid "Files"
-msgstr "Berkas"
-#: ../gui/wxpython/gui_core/goutput.py:438
-msgid ""
-"Unable to write file '%(path)s'.\n"
-"\n"
-#: ../gui/wxpython/gui_core/goutput.py:443
-msgid "Command output saved into '%s'"
-#: ../gui/wxpython/gui_core/goutput.py:502
-msgid "Command log saved to '%s'"
-#: ../gui/wxpython/gui_core/ghelp.py:53 ../gui/wxpython/menustrings.py:1015
-#: ../gui/wxpython/menustrings.py:1016
-msgid "About GRASS GIS"
-#: ../gui/wxpython/gui_core/ghelp.py:75
-msgid "Info"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:76
-#, fuzzy
-msgid "Copyright"
-msgstr "Salin "
-#: ../gui/wxpython/gui_core/ghelp.py:77
-#, fuzzy
-msgid "License"
-msgstr "Garis"
-#: ../gui/wxpython/gui_core/ghelp.py:78
-#, fuzzy
-msgid "Citation"
-msgstr "Rotasi:"
-#: ../gui/wxpython/gui_core/ghelp.py:79
-msgid "Authors"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:80
-#, fuzzy
-msgid "Contributors"
-msgstr "Atribut"
-#: ../gui/wxpython/gui_core/ghelp.py:81
-#, fuzzy
-msgid "Extra contributors"
-msgstr "Atribut"
-#: ../gui/wxpython/gui_core/ghelp.py:82
-#, fuzzy
-msgid "Translators"
-#: ../gui/wxpython/gui_core/ghelp.py:83
-#, fuzzy
-msgid "Translation status"
-#: ../gui/wxpython/gui_core/ghelp.py:148
-msgid "Official GRASS site:"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:159
-#, fuzzy
-msgid "Code Revision"
-msgstr "Proyeksi:"
-#: ../gui/wxpython/gui_core/ghelp.py:170
-msgid "Build Date"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:224 ../gui/wxpython/gui_core/ghelp.py:482
-#, fuzzy
-msgid "Language"
-msgstr "Kelola"
-#: ../gui/wxpython/gui_core/ghelp.py:253 ../gui/wxpython/gui_core/ghelp.py:278
-#: ../gui/wxpython/gui_core/ghelp.py:329 ../gui/wxpython/gui_core/ghelp.py:392
-#: ../gui/wxpython/gui_core/ghelp.py:466 ../gui/wxpython/gui_core/ghelp.py:632
-msgid "%s file missing"
-msgstr "Kode EPSG tidak ada."
-#: ../gui/wxpython/gui_core/ghelp.py:301
-msgid ""
-"Unable to provide citation suggestion, see GRASS GIS website instead. The "
-"error was: {}"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:377 ../gui/wxpython/gui_core/ghelp.py:450
-#, python-format
-msgid "Error when reading file '%s'."
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:378 ../gui/wxpython/gui_core/ghelp.py:451
-#, fuzzy
-msgid "Lines:"
-msgstr "Garis"
-#: ../gui/wxpython/gui_core/ghelp.py:478
-msgid "E-mail"
-msgstr ""
-msgid "Country"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:400
-msgid "OSGeo_ID"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:486
-#, fuzzy
-msgid "Nation"
-msgstr "Rotasi:"
-#: ../gui/wxpython/gui_core/ghelp.py:536
-#, python-format
-msgid " %d translated"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:540 ../gui/wxpython/gui_core/ghelp.py:566
-#, python-format
-msgid " %d fuzzy"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:544 ../gui/wxpython/gui_core/ghelp.py:575
-#, python-format
-msgid " %d untranslated"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:557
-#, python-format
-msgid "%d translated"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:629
-msgid "File <%s> not found"
-msgstr "berkas tidak ditemukan"
-#: ../gui/wxpython/gui_core/ghelp.py:802
-#, fuzzy
-msgid "&Next"
-msgstr "&Keluar"
-#: ../gui/wxpython/gui_core/ghelp.py:805
-#, fuzzy
-msgid "&Previous"
-msgstr "Tampilan cetak"
-#: ../gui/wxpython/gui_core/toolbars.py:36
-msgid "Display map"
-msgstr "Tampilkan peta"
-#: ../gui/wxpython/gui_core/toolbars.py:37
-#, fuzzy
-msgid "Re-render modified map layers only"
-msgstr "Hapus layer peta"
-#: ../gui/wxpython/gui_core/toolbars.py:39
-#, fuzzy
-msgid "Render map"
-msgstr "Render-ulang peta"
-#: ../gui/wxpython/gui_core/toolbars.py:40
-#, fuzzy
-msgid "Force re-rendering all map layers"
-msgstr "Render-ulang secara paksa semua layer"
-#: ../gui/wxpython/gui_core/toolbars.py:42
-msgid "Erase display"
-msgstr "Hapus tampilan"
-#: ../gui/wxpython/gui_core/toolbars.py:43
-msgid "Erase display canvas with given background color"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:45
-msgid "Pointer"
-msgstr "Pointer"
-#: ../gui/wxpython/gui_core/toolbars.py:47
-msgid "Zoom in"
-msgstr "Perbesar"
-#: ../gui/wxpython/gui_core/toolbars.py:48
-msgid "Drag or click mouse to zoom"
-msgstr "Tarik atau klik tetikus untuk memperbesar "
-#: ../gui/wxpython/gui_core/toolbars.py:50
-msgid "Zoom out"
-msgstr "Perkecil tampilan "
-#: ../gui/wxpython/gui_core/toolbars.py:51
-msgid "Drag or click mouse to unzoom"
-msgstr "Tarik atau klik tetikus untuk memperkecil "
-#: ../gui/wxpython/gui_core/toolbars.py:53
-msgid "Return to previous zoom"
-msgstr "Kembali ke tampilan sebelumnya"
-#: ../gui/wxpython/gui_core/toolbars.py:55
-#, fuzzy
-msgid "Various zoom options"
-msgstr "Pilihan perbesaran"
-#: ../gui/wxpython/gui_core/toolbars.py:56
-#, fuzzy
-msgid "Zoom to default or saved region, save to named region, ..."
-msgstr "Perbesaran ke computational region (g.region)"
-#: ../gui/wxpython/gui_core/toolbars.py:58
-#, fuzzy
-msgid "Zoom to selected map layer(s)"
-msgstr "Perbesaran sesuai peta terpilih "
-#: ../gui/wxpython/gui_core/toolbars.py:60
-#, fuzzy
-msgid "Zoom to computational region extent"
-#: ../gui/wxpython/gui_core/toolbars.py:62
-msgid "Pan"
-msgstr "Geser "
-#: ../gui/wxpython/gui_core/toolbars.py:63
-msgid "Drag with mouse to pan"
-msgstr "Tarik dengan tetikus untuk menggeser "
-#: ../gui/wxpython/gui_core/toolbars.py:65
-#, fuzzy
-msgid "Save display to file"
-msgstr "Simpan tampilan ke dalam berkas PNG"
-#: ../gui/wxpython/gui_core/toolbars.py:79
-#, fuzzy
-msgid "Add map elements"
-msgstr "Tambahkan legenda"
-#: ../gui/wxpython/gui_core/toolbars.py:80
-msgid "Overlay elements like scale and legend onto map"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:82
-#, fuzzy
-msgid "Create histogram with d.histogram"
-msgstr "Skala-ulang dengan histogram"
-#: ../gui/wxpython/gui_core/toolbars.py:259
-#, fuzzy
-msgid "Select graphics tool"
-msgstr "Pilih jenis huruf tampilan standar"
-#: ../gui/wxpython/gui_core/gselect.py:61
-#, python-format
-msgid ""
-"Unable to import pyGRASS: %s\n"
-"Some functionality will be not accessible"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:490
-#, fuzzy
-msgid "Not selectable element"
-msgstr "Hapus kolom terpilih"
-#: ../gui/wxpython/gui_core/gselect.py:527
-#: ../gui/wxpython/gui_core/preferences.py:2137
-msgid "Mapset"
-msgstr "Mapset"
-#: ../gui/wxpython/gui_core/gselect.py:539
-#, fuzzy
-msgid "Type: "
-msgstr "Tipe"
-#: ../gui/wxpython/gui_core/gselect.py:557
-#, python-format
-msgid "GSelect: invalid item: %s"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1394
-#, fuzzy
-msgid "Output settings"
-#: ../gui/wxpython/gui_core/gselect.py:1396
-#, fuzzy
-msgid "Source input"
-msgstr "Nama kolom"
-#: ../gui/wxpython/gui_core/gselect.py:1407
-#, fuzzy
-msgid "Native"
-#: ../gui/wxpython/gui_core/gselect.py:1413
-msgid "File"
-msgstr "Berkas"
-#: ../gui/wxpython/gui_core/gselect.py:1425
-msgid "Protocol"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1436
-#, fuzzy
-msgid "Output type"
-msgstr "Output "
-#: ../gui/wxpython/gui_core/gselect.py:1438
-msgid "Source type"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1460
-#, fuzzy
-msgid "All files"
-msgstr "Nilai sel"
-#: ../gui/wxpython/gui_core/gselect.py:1476
-#, fuzzy
-msgid "ZIP files"
-msgstr "Nilai sel"
-#: ../gui/wxpython/gui_core/gselect.py:1477
-#, fuzzy
-msgid "GZIP files"
-msgstr "Nilai sel"
-#: ../gui/wxpython/gui_core/gselect.py:1478
-#, fuzzy
-msgid "TAR files"
-msgstr "Nilai sel"
-#: ../gui/wxpython/gui_core/gselect.py:1480
-#, fuzzy
-msgid "TARGZ files"
-msgstr "Nilai sel"
-#: ../gui/wxpython/gui_core/gselect.py:1488
-#, fuzzy
-msgid "File:"
-msgstr "Berkas"
-#: ../gui/wxpython/gui_core/gselect.py:1489
-#, fuzzy
-msgid "Choose file to import"
-msgstr "Pilih berkas GRC untuk dimuat"
-#: ../gui/wxpython/gui_core/gselect.py:1505
-#: ../gui/wxpython/gui_core/gselect.py:1588
-#, fuzzy
-msgid "Choose input directory"
-msgstr "Pilih direktori data GRASS:"
-#: ../gui/wxpython/gui_core/gselect.py:1522
-#, fuzzy
-msgid "Extension:"
-msgstr "Proyeksi:"
-#: ../gui/wxpython/gui_core/gselect.py:1552
-#, fuzzy
-msgid "Choose file"
-msgstr "Pilih berkas workspace"
-#: ../gui/wxpython/gui_core/gselect.py:1573
-#: ../gui/wxpython/gui_core/gselect.py:2333
-#, fuzzy
-msgid "Feature type:"
-msgstr "ID Fitur"
-#: ../gui/wxpython/gui_core/gselect.py:1575
-#, fuzzy
-msgid "simple features"
-msgstr "Fitur terdekat"
-#: ../gui/wxpython/gui_core/gselect.py:1576
-#, fuzzy
-msgid "topological"
-msgstr "Buat/bangun-ulang topologi"
-#: ../gui/wxpython/gui_core/gselect.py:1687
-#: ../gui/wxpython/gui_core/gselect.py:1718
-#: ../gui/wxpython/gui_core/gselect.py:1769
-#: ../gui/wxpython/gui_core/gselect.py:1807
-#, fuzzy
-msgid "Creation options:"
-msgstr "Pilihan pengaturan"
-#: ../gui/wxpython/gui_core/gselect.py:1701
-#: ../gui/wxpython/gui_core/gselect.py:1740
-#: ../gui/wxpython/gui_core/gselect.py:1792
-msgid "Format:"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1799
-#, fuzzy
-msgid "Protocol:"
-#: ../gui/wxpython/gui_core/gselect.py:1822
-#, fuzzy
-msgid "No settings available"
-msgstr "Toolbar digitasi vektor"
-#: ../gui/wxpython/gui_core/gselect.py:2325
-#, fuzzy
-msgid "LineString"
-msgstr "Penyorotan"
-msgid "Polygon"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:2544
-#, fuzzy
-msgid "No vector map selected in layer manager. Operation canceled."
-#: ../gui/wxpython/gui_core/gselect.py:2557
-#, fuzzy
-msgid "Input vector map is not selected"
-msgstr "ERROR: Mapset <%s> tidak ada"
-#: ../gui/wxpython/gui_core/gselect.py:2561
-msgid ""
-"Input vector map <%s> and selected map <%s> in layer manager are different. "
-"Operation canceled."
-#: ../gui/wxpython/gui_core/query.py:31
-#, fuzzy
-msgid "Query results"
-msgstr "Tumpang-susun peta raster"
-#: ../gui/wxpython/gui_core/query.py:43
-msgid "Right click to copy selected values to clipboard."
-msgstr ""
-#: ../gui/wxpython/gui_core/query.py:49
-#, fuzzy
-msgid "Feature"
-msgstr "ID Fitur"
-#, fuzzy
-msgid "Value"
-msgstr "Volume"
-#: ../gui/wxpython/gui_core/query.py:71
-#, fuzzy
-msgid "Copy all to clipboard"
-#: ../gui/wxpython/gui_core/query.py:74
-#, fuzzy
-msgid "Redirect to console"
-#: ../gui/wxpython/gui_core/query.py:136 ../gui/wxpython/gui_core/query.py:139
-msgid "Copy from '%s' column"
-msgstr "Hapus semua kolom"
-#: ../gui/wxpython/gui_core/query.py:141
-#, fuzzy
-msgid "Copy selected lines"
-#: ../gui/wxpython/gui_core/query.py:144 ../gui/wxpython/gui_core/query.py:149
-msgid "Copy '%s'"
-msgstr "Salin "
-#: ../gui/wxpython/gui_core/query.py:151
-#, fuzzy
-msgid "Copy line"
-msgstr "Salin tabel"
-#: ../gui/wxpython/gui_core/query.py:178
-#, fuzzy
-msgid "Query results:"
-#: ../gui/wxpython/gui_core/query.py:181
-msgid " "
-msgstr ""
-#: ../gui/wxpython/gui_core/query.py:270
-#, fuzzy
-msgid "east, north"
-msgstr "Tes kenormalan"
-#: ../gui/wxpython/gui_core/query.py:281
-#, fuzzy
-msgid "Nothing found"
-#: ../gui/wxpython/gui_core/simplelmgr.py:109
-#, fuzzy
-msgid "Toolbar"
-msgstr "Map Toolbar"
-#: ../gui/wxpython/gui_core/simplelmgr.py:145
-#, fuzzy
-msgid "Copy map names to clipboard (top to bottom)"
-#: ../gui/wxpython/gui_core/simplelmgr.py:146
-#, fuzzy
-msgid "Copy map names to clipboard (bottom to top)"
-#: ../gui/wxpython/gui_core/simplelmgr.py:464
-#, fuzzy
-msgid "Remove selected map(s) from list"
-msgstr "Apakah Anda hendak menghapus layer peta terpilih dari layer tree?"
-#: ../gui/wxpython/gui_core/simplelmgr.py:466
-#, fuzzy
-msgid "Layer up"
-msgstr "Grup layer:"
-#: ../gui/wxpython/gui_core/simplelmgr.py:467
-#, fuzzy
-msgid "Move selected layer(s) up"
-#: ../gui/wxpython/gui_core/simplelmgr.py:469
-#, fuzzy
-msgid "Layer down"
-msgstr "Layer"
-#: ../gui/wxpython/gui_core/simplelmgr.py:470
-#, fuzzy
-msgid "Move selected layer(s) down"
-#: ../gui/wxpython/gui_core/simplelmgr.py:472
-#: ../gui/wxpython/gui_core/simplelmgr.py:473
-#, fuzzy
-msgid "Edit layer properties"
-#: ../gui/wxpython/gui_core/simplelmgr.py:475
-#, fuzzy
-msgid "Change opacity"
-msgstr "Ubah tingkat opasitas"
-#: ../gui/wxpython/gui_core/simplelmgr.py:476
-#, fuzzy
-msgid "Change layer opacity"
-#: ../gui/wxpython/gui_core/pyedit.py:377
-#, fuzzy
-msgid "Open file"
-#: ../gui/wxpython/gui_core/pyedit.py:448
-msgid "Replace the content by the template?"
-msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:450
-msgid "Replace the content by the example?"
-msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:452
-msgid "Replace the current content by the file content?"
-msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:458
-msgid "Replace content"
-msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:470
-#, fuzzy
-msgid "Set parameters for the script"
-#: ../gui/wxpython/gui_core/pyedit.py:471
-msgid "Specify command line parameters for the script separated by spaces:"
-msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:521
-msgid "Open (Ctrl+O)"
-msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:523
-msgid "Save (Ctrl+S)"
-msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:525
-#, fuzzy
-msgid "Run (Ctrl+R)"
-#: ../gui/wxpython/gui_core/pyedit.py:528
-msgid "Activate overwrite"
-msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:530
-msgid "Deactive overwrite"
-msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:581
-#, fuzzy
-msgid "GRASS GIS Simple Python Editor"
-#: ../gui/wxpython/gui_core/preferences.py:59
-#, fuzzy
-msgid "User settings"
-msgstr "Pengaturan GUI User"
-#: ../gui/wxpython/gui_core/preferences.py:83
-msgid "Set to default"
-msgstr "Kembalikan aturan ke standar"
-#: ../gui/wxpython/gui_core/preferences.py:91
-#, fuzzy
-msgid "Revert settings to default"
-#: ../gui/wxpython/gui_core/preferences.py:94
-#, fuzzy
-msgid "Apply changes for the current session only and close"
-msgstr "Terapkan perubahan untuk sesi saat ini"
-#: ../gui/wxpython/gui_core/preferences.py:95
-#, fuzzy
-msgid "Save for this session only"
-#: ../gui/wxpython/gui_core/preferences.py:165
-msgid "Settings applied to current session but not saved"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:237
-msgid "Key column cannot be empty string."
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:256
-#, fuzzy
-msgid "GUI Settings"
-#: ../gui/wxpython/gui_core/preferences.py:291
-msgid "Layer Manager settings"
-#: ../gui/wxpython/gui_core/preferences.py:301
-msgid "Ask when removing map layer from layer tree"
-msgstr "Konfirmasi ketika menghapus layer peta dari layer tree"
-#: ../gui/wxpython/gui_core/preferences.py:314
-msgid "Ask when quiting wxGUI or closing display"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:329
-#: ../gui/wxpython/gui_core/preferences.py:346
-#, python-format
-msgid "Hide '%s' tab (requires GUI restart)"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:366
-msgid "Automatically copy selected text to clipboard (in the Console tab)"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:394
-#, fuzzy
-msgid "Workspace settings"
-msgstr "Pengaturan raster"
-#: ../gui/wxpython/gui_core/preferences.py:401
-msgid "Suppress positioning Map Display Window(s)"
-msgstr "Suppress positioning Map Display Window(s)"
-#: ../gui/wxpython/gui_core/preferences.py:417
-msgid "Suppress positioning Layer Manager window"
-msgstr "Suppress positioning Layer Manager window"
-#: ../gui/wxpython/gui_core/preferences.py:432
-msgid "Save current window layout as default"
-msgstr "Simpan layout window saat ini sebagai standar"
-#: ../gui/wxpython/gui_core/preferences.py:441
-msgid ""
-"Save current position and size of Layer Manager window and opened Map "
-"Display window(s) and use as default for next sessions."
-msgstr ""
-"Simpan posisi dan ukuran window Layer Manager saat ini dan window Map "
-"Display yang dibuka dan gunakan sebagai standar untuk sesi berikutnya."
-#: ../gui/wxpython/gui_core/preferences.py:489
-#, fuzzy
-msgid "Font for command output:"
-msgstr "Output perintah"
-#: ../gui/wxpython/gui_core/preferences.py:507
-#, fuzzy
-msgid "Language settings"
-msgstr "Ubah pengaturan "
-#: ../gui/wxpython/gui_core/preferences.py:523
-msgid "Choose language (requires to save and GRASS restart):"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:556
-#, fuzzy
-msgid "Appearance settings"
-#: ../gui/wxpython/gui_core/preferences.py:566
-msgid "Element list:"
-msgstr "Daftar elemen:"
-#: ../gui/wxpython/gui_core/preferences.py:596
-msgid "Menu style (requires to save and GUI restart):"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:631
-msgid "Height of map selection popup window (in pixels):"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:671
-msgid "Icon theme (requires GUI restart):"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:698
-#, fuzzy
-msgid "Module dialog style:"
-msgstr "Pengaturan dialog perintah"
-#: ../gui/wxpython/gui_core/preferences.py:765
-msgid "Default font for GRASS displays:"
-msgstr "Jenis huruf standar untuk tampilan GRASS:"
-#: ../gui/wxpython/gui_core/preferences.py:792
-msgid "Default display settings"
-msgstr "Pengaturan tampilan standar"
-#: ../gui/wxpython/gui_core/preferences.py:802
-msgid "Display driver:"
-msgstr "Driver tampilan:"
-#: ../gui/wxpython/gui_core/preferences.py:828
-msgid "Statusbar mode:"
-msgstr "Mode statusbar:"
-#: ../gui/wxpython/gui_core/preferences.py:912
-msgid "Enable auto-rendering"
-msgstr "Jalankan rendering otomatis"
-#: ../gui/wxpython/gui_core/preferences.py:929
-#, fuzzy
-msgid "Enable auto-zooming to selected map layer"
-#: ../gui/wxpython/gui_core/preferences.py:945
-msgid "Mouse wheel action:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:971
-#, fuzzy
-msgid "Mouse scrolling direction:"
-#: ../gui/wxpython/gui_core/preferences.py:1012
-#, fuzzy
-msgid "Advanced display settings"
-#: ../gui/wxpython/gui_core/preferences.py:1021
-msgid "3D view depth buffer (possible values are 16, 24, 32):"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1076
-#, fuzzy
-msgid "Module dialog settings"
-#: ../gui/wxpython/gui_core/preferences.py:1101
-#, fuzzy
-msgid "Close dialog when module is successfully finished"
-msgstr "Tutup dialog di akhir perintah"
-#: ../gui/wxpython/gui_core/preferences.py:1130
-#, fuzzy
-msgid "Allow interactive input"
-#: ../gui/wxpython/gui_core/preferences.py:1144
-msgid "Verbosity level:"
-msgstr "Level verbosity:"
-#: ../gui/wxpython/gui_core/preferences.py:1190
-#, fuzzy
-msgid "Default raster settings"
-#: ../gui/wxpython/gui_core/preferences.py:1200
-msgid "Make null cells opaque"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1215
-#, fuzzy
-msgid "Default color table"
-msgstr "Tabel warna "
-#: ../gui/wxpython/gui_core/preferences.py:1261
-#, fuzzy
-msgid "Default vector settings"
-#: ../gui/wxpython/gui_core/preferences.py:1267
-#, fuzzy
-msgid "Display:"
-msgstr "Tampilan"
-#: ../gui/wxpython/gui_core/preferences.py:1292
-#, fuzzy
-msgid "Feature color:"
-msgstr "Warna garis"
-#: ../gui/wxpython/gui_core/preferences.py:1332
-#, fuzzy
-msgid "Area fill color:"
-#: ../gui/wxpython/gui_core/preferences.py:1393
-#, fuzzy
-msgid "Symbol:"
-#: ../gui/wxpython/gui_core/preferences.py:1476
-#, fuzzy
-msgid "Line width (in pixels):"
-msgstr "Lebar garis (dalam piksel)"
-#: ../gui/wxpython/gui_core/preferences.py:1492
-#, fuzzy
-msgid "Automatically hightlight selected features in map display"
-msgstr "Digitasi fitur garis"
-#: ../gui/wxpython/gui_core/preferences.py:1516
-msgid "Data browser"
-msgstr "Penjelajah data"
-#: ../gui/wxpython/gui_core/preferences.py:1524
-#, fuzzy
-msgid "Left mouse double click:"
-msgstr "Klik kiri ganda"
-#: ../gui/wxpython/gui_core/preferences.py:1549
-msgid "Encoding (e.g. utf-8, ascii, iso8859-1, koi8-r):"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1564
-msgid "Ask when deleting data record(s) from table"
-msgstr "Konfirmasi ketika menghapus rekap data data dari tabel"
-#: ../gui/wxpython/gui_core/preferences.py:1588
-#, fuzzy
-msgid "Create table"
-msgstr "&Buat tabel"
-#: ../gui/wxpython/gui_core/preferences.py:1638
-#, fuzzy
-msgid "Projection statusbar settings"
-msgstr "Pengaturan teks profil"
-#: ../gui/wxpython/gui_core/preferences.py:1647
-msgid ""
-"\n"
-"Note: This only controls the coordinates displayed in the lower-left of the "
-"Map Display\n"
-"window's status bar. It is purely cosmetic and does not affect the working "
-"location's\n"
-"projection in any way. You will need to enable the Projection check box in "
-"the drop-down\n"
-"menu located at the bottom of the Map Display window.\n"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1680
-msgid "Proj.4 string (required):"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1697
-#, fuzzy
-msgid "EPSG file:"
-msgstr "Kode EPSG:"
-#: ../gui/wxpython/gui_core/preferences.py:1714
-msgid ""
-"Load EPSG codes (be patient), enter EPSG code or insert Proj.4 string "
-"directly."
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1722
-#, fuzzy
-msgid "&Load EPSG codes"
-#: ../gui/wxpython/gui_core/preferences.py:1742
-#, fuzzy
-msgid "Coordinates format"
-msgstr "Koordinat"
-#: ../gui/wxpython/gui_core/preferences.py:1750
-#, fuzzy
-msgid "Lat/long projections"
-msgstr "Pengaturan proyeksi"
-#: ../gui/wxpython/gui_core/preferences.py:1771
-#, fuzzy
-msgid "Precision:"
-msgstr "Proyeksi:"
-#: ../gui/wxpython/gui_core/preferences.py:1857
-msgid "Unable to read EPSG codes: %s"
-#: ../gui/wxpython/gui_core/preferences.py:1890
-#: ../gui/wxpython/gui_core/preferences.py:1902
-#: ../gui/wxpython/gui_core/preferences.py:1914
-msgid "EPSG code %s not found"
-msgstr "ERROR: Location <%s> tidak ada"
-#: ../gui/wxpython/gui_core/preferences.py:1924
-msgid "Select default display font"
-#: ../gui/wxpython/gui_core/preferences.py:1938
-msgid "Failed to set default display font. Try different font."
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1957
-#, fuzzy
-msgid "Select default output font"
-#: ../gui/wxpython/gui_core/preferences.py:2046
-#, fuzzy
-msgid "Manage access to mapsets"
-msgstr "Ubah mapset saat ini."
-#: ../gui/wxpython/gui_core/preferences.py:2061
-#, fuzzy
-msgid ""
-"Check a mapset to make it accessible, uncheck it to hide it.\n"
-" Notes:\n"
-" - The current mapset is always accessible.\n"
-" - You may only write to the current mapset.\n"
-" - You may only write to mapsets which you own."
-msgstr ""
-"Centang mapset untuk membuatnya dapat diakses, jangan centang untuk "
-"menyembunyikannya.%Catatan: PERMANEN dan mapset saat ini akan selalu dapat "
-"diakses."
-#: ../gui/wxpython/gui_core/preferences.py:2138
-msgid "Owner"
-msgstr "Pemilik"
-#: ../gui/wxpython/gui_core/widgets.py:101
-msgid " (...)"
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:839
-#, python-format
-msgid ""
-"Name <%(name)s> is not a valid name for GRASS map. Please use only ASCII "
-"characters excluding %(chars)s and space."
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1067
-msgid "Fulltext search"
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1069
-msgid "Type to search in all modules. Press Enter for next match."
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1136
-msgid "Searching, please type more characters."
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1145
-#, python-format
-msgid "%d modules match"
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1215
-#, fuzzy
-msgid "Profiles"
-msgstr "Profil"
-#: ../gui/wxpython/gui_core/widgets.py:1221
-#, fuzzy
-msgid "Save current settings"
-msgstr "Pengaturan umum"
-#: ../gui/wxpython/gui_core/widgets.py:1225
-#, fuzzy
-msgid "Delete currently selected settings"
-msgstr "Hapus mapset terpilih"
-#: ../gui/wxpython/gui_core/widgets.py:1248
-#, fuzzy
-msgid "Load:"
-msgstr "Memuat"
-#: ../gui/wxpython/gui_core/widgets.py:1266
-msgid "Settings <%s> not found"
-#: ../gui/wxpython/gui_core/widgets.py:1280
-#: ../gui/wxpython/gui_core/widgets.py:1300
-#, fuzzy
-msgid "Save settings"
-#: ../gui/wxpython/gui_core/widgets.py:1285
-msgid "Name not given, settings is not saved."
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1297
-msgid "Settings <%s> already exists. Do you want to overwrite the settings?"
-msgstr "Berkas Workspace <%s> sudah ada. Anda ingin menimpanya?"
-#: ../gui/wxpython/gui_core/widgets.py:1348
-#, fuzzy
-msgid "No settings is defined. Operation canceled."
-#: ../gui/wxpython/gui_core/widgets.py:1386
-#, fuzzy
-msgid "Unable to save settings"
-msgstr "Tidak mampu mengeset"
-#: ../gui/wxpython/iscatt/dialogs.py:40
-#, fuzzy
-msgid "Add scatter plots"
-msgstr "Peta raster:"
-#: ../gui/wxpython/iscatt/dialogs.py:59
-msgid "x axis:"
-msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:66
-msgid "y axis:"
-msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:105
-msgid "Bands of scatter plots to be added (x y):"
-msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:155
-#, fuzzy
-msgid "No scatter plots selected."
-msgstr "Tidak ada layer peta yang dipilih untuk kueri."
-#: ../gui/wxpython/iscatt/dialogs.py:203
-msgid "Select both x and y bands."
-msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:207
-#, fuzzy
-msgid "Selected bands must be different."
-msgstr "Hapus berkas elemen basis data dari mapset saat ini milik pengguna."
-#: ../gui/wxpython/iscatt/dialogs.py:214
-msgid ""
-"Scatter plot with same bands combination (regardless x y order) has been "
-"already added into the list."
-msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:323
-msgid "Raster map <%s> already exists. Do you want to overwrite it?"
-#: ../gui/wxpython/iscatt/dialogs.py:326
-msgid "Raster <%s> exists"
-#: ../gui/wxpython/iscatt/dialogs.py:352
-msgid "Show confidence ellipses"
-msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:359
-#, fuzzy
-msgid "Selection polygon color:"
-#: ../gui/wxpython/iscatt/dialogs.py:360
-#, fuzzy
-msgid "Color of selection polygon vertex:"
-msgstr "Bersihkan GCP terpilih"
-#: ../gui/wxpython/iscatt/dialogs.py:361
-#, fuzzy
-msgid "Selected area color:"
-msgstr "Kelola warna citra"
-#: ../gui/wxpython/iscatt/dialogs.py:373
-#, fuzzy
-msgid "Selected area opacity:"
-msgstr "Pilih grup:"
-#: ../gui/wxpython/iscatt/dialogs.py:412
-#, fuzzy
-msgid "Selection style:"
-msgstr "Pilih dengan kotak"
-#: ../gui/wxpython/iscatt/dialogs.py:439
-#, fuzzy
-msgid "Ellipses settings:"
-msgstr "Pengaturan axis"
-#: ../gui/wxpython/iscatt/iscatt_core.py:110
-#: ../gui/wxpython/iscatt/iscatt_core.py:160
-#, fuzzy
-msgid "Select category for editing."
-msgstr "Pilih peta raster 3 (opsional):"
-#: ../gui/wxpython/iscatt/iscatt_core.py:151
-#, fuzzy
-msgid "Computing of scatter plots failed."
-#: ../gui/wxpython/iscatt/iscatt_core.py:298
-msgid "Patching category raster conditions file failed."
-msgstr ""
-#: ../gui/wxpython/iscatt/iscatt_core.py:321
-#, python-format
-msgid ""
-"v.build failed:\n"
-"%s"
-msgstr ""
-#: ../gui/wxpython/iscatt/iscatt_core.py:339
-#, python-format
-msgid ""
-"v.to.rast failed:\n"
-"%s"
-msgstr ""
-#: ../gui/wxpython/iscatt/core_c.py:23
-#, fuzzy
-msgid "Loading ctypes libs failed"
-msgstr ""
-"Pemuatan data atribut gagal. Pernyataan SQL 'select' tidak valid.\n"
-"\n"
-"'%s'"
-#: ../gui/wxpython/iscatt/plots.py:42
-msgid ""
-"The Scatterplot Tool needs the \"matplotlib\" (python-matplotlib) package to "
-"be installed. {}"
-msgstr ""
-#: ../gui/wxpython/iscatt/plots.py:617
-#, fuzzy
-msgid "Zoom to scatter plot extend"
-msgstr "Tampilan ke batas region tersimpan"
-#: ../gui/wxpython/iscatt/frame.py:166
-#, fuzzy
-msgid "GRASS GIS Interactive Scatter Plot Tool"
-msgstr "Toolbar Georektifikasi"
-#: ../gui/wxpython/iscatt/frame.py:398
-#, fuzzy
-msgid "scatter plot"
-msgstr "Titik perturbasi"
-#: ../gui/wxpython/iscatt/frame.py:476
-msgid "Maximum limit of categories number was reached."
-msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:572
-#, fuzzy
-msgid "Rename class"
-msgstr "Ubah nama kolom"
-#: ../gui/wxpython/iscatt/frame.py:576
-#, fuzzy
-msgid "Set color"
-msgstr "Y coord"
-#: ../gui/wxpython/iscatt/frame.py:584
-msgid "Hide"
-msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:586
-#, fuzzy
-msgid "Show"
-msgstr "Tampilkan grid"
-#: ../gui/wxpython/iscatt/frame.py:601
-msgid "Move to top"
-msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:607
-msgid "Move to bottom"
-msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:615
-#, fuzzy
-msgid "Move category up"
-msgstr "Tidak ada kategori"
-#: ../gui/wxpython/iscatt/frame.py:621
-#, fuzzy
-msgid "Move category down"
-#: ../gui/wxpython/iscatt/frame.py:629
-#, fuzzy
-msgid "Export class raster"
-msgstr "Impor peta raster "
-#: ../gui/wxpython/iscatt/frame.py:701
-#, fuzzy, python-format
-msgid "Change opacity of class <%s>"
-#: ../gui/wxpython/iscatt/frame.py:726
-msgid "Empty name was inserted."
-msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:54
-#, fuzzy
-msgid "Add scatter plot"
-#: ../gui/wxpython/iscatt/toolbars.py:57
-#, fuzzy
-msgid "Select area with polygon"
-#: ../gui/wxpython/iscatt/toolbars.py:60
-#, fuzzy
-msgid "Pan mode for scatter plots"
-msgstr "Pilih peta raster untuk dibuat profil"
-#: ../gui/wxpython/iscatt/toolbars.py:63
-msgid "Zoom mode for scatter plots (left mouse button, wheel)"
-msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:66
-msgid ""
-"Zoom to scatter plot data extend mode (click on scatter plot for zooming to "
-"extend)"
-msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:69
-#, fuzzy
-msgid "Show/hide class manager"
-msgstr "Klasifikasi citra"
-#: ../gui/wxpython/iscatt/toolbars.py:175
-#: ../gui/wxpython/iscatt/toolbars.py:176
-#, fuzzy
-msgid "Include selected area to class"
-msgstr "Kueri peta vektor/raster terpilih"
-#: ../gui/wxpython/iscatt/toolbars.py:178
-#: ../gui/wxpython/iscatt/toolbars.py:179
-#, fuzzy
-msgid "Exclude selected area from class"
-#: ../gui/wxpython/iscatt/toolbars.py:181
-msgid "Add new vertex"
-msgstr "Tambahkan sebuah vertex baru"
-#: ../gui/wxpython/iscatt/toolbars.py:182
-msgid "Add new vertex to polygon boundary scatter plot"
-msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:184
-#, fuzzy
-msgid "Create selection polygon"
-#: ../gui/wxpython/iscatt/toolbars.py:185
-msgid "Add new vertex between last and first points of the boundary"
-msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:187
-msgid "Move vertex"
-msgstr "Pindahkan vertex "
-#: ../gui/wxpython/iscatt/toolbars.py:188
-#, fuzzy
-msgid "Move boundary vertex"
-#: ../gui/wxpython/iscatt/toolbars.py:190
-msgid "Remove vertex"
-msgstr "Hapus vertex "
-#: ../gui/wxpython/iscatt/toolbars.py:191
-#, fuzzy
-msgid "Remove boundary vertex"
-#: ../gui/wxpython/iscatt/toolbars.py:193
-msgid "Remove polygon (click on scatter plot for removing it's polygon)"
-msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:271
-#, fuzzy
-msgid "Add class"
-msgstr "Tambahkan label"
-#: ../gui/wxpython/iscatt/toolbars.py:273
-#, fuzzy
-msgid "Remove selected class"
-msgstr "Ubah nama mapset terpilih"
-#: ../gui/wxpython/iscatt/controllers.py:204
-#, fuzzy
-msgid "No data set."
-#: ../gui/wxpython/iscatt/controllers.py:222
-#, python-format
-msgid ""
-"Interactive Scatter Plot Tool can not be used.\n"
-"Number of cells (rows*cols) <%d> in current regionis higher than maximum "
-"limit <%d>.\n"
-"\n"
-"You can reduce number of cells in current region using <g.region> command."
-msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:231
-#, python-format
-msgid ""
-"Number of cells (rows*cols) <%d> in current region is higher than "
-"recommended threshold <%d>.\n"
-"It is strongly advised to reduce number of cells in current region below "
-"recommend threshold.\n"
-" It can be done by <g.region> command.\n"
-"\n"
-"Do you want to continue using Interactive Scatter Plot Tool with this region?"
-msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:288
-msgid ""
-"Scatter plot with same band combination (regardless x y order) is already "
-"displayed."
-msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:301
-#, python-format
-msgid "Band <%s> is not CELL (integer) type.\n"
-msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:304
-#, fuzzy
-msgid "Scatter plot cannot be added.\n"
-#: ../gui/wxpython/iscatt/controllers.py:310
-#, python-format
-msgid ""
-"Scatter plot cannot be added.\n"
-"Multiple of bands ranges <%s:%d * %s:%d = %d> is higher than maximum limit <"
-"%d>.\n"
-msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:320
-#, python-format
-msgid ""
-"Multiple of bands ranges <%s:%d * %s:%d = %d> is higher than recommended "
-"limit <%d>.\n"
-"It is strongly advised to reduce range extend of bands(e. g. using r."
-"rescale) below recommended threshold.\n"
-"\n"
-"Do you really want to add this scatter plot?"
-msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:409
-msgid ""
-"In order to select arrea in scatter plot, you have to select class first.\n"
-"\n"
-"There is no class yet, do you want to create one?"
-msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:444
-#, python-format
-msgid ""
-"Error occurred during computation of scatter plot category:\n"
-"%s"
-msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:764
-#, python-format
-msgid "Export scatter plot raster of class <%s>"
-msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:782
-#, python-format
-msgid "Scatter plot raster of class <%s> exported to raster map <%s>."
-msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:786
-#, python-format
-msgid ""
-"Export of scatter plot raster of class <%s> to map <%s> failed.\n"
-"%s"
-msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:44
-#: ../gui/wxpython/mapswipe/toolbars.py:33
-#, fuzzy
-msgid "Select raster maps"
-msgstr "Peta raster hasil kode-ulang:"
-#: ../gui/wxpython/mapswipe/dialogs.py:130
-#, fuzzy
-msgid "Name of top/left raster map:"
-#: ../gui/wxpython/mapswipe/dialogs.py:139
-#, fuzzy
-msgid "Name of bottom/right raster map:"
-#: ../gui/wxpython/mapswipe/dialogs.py:185
-#, fuzzy
-msgid "Switch to advanced mode"
-msgstr "Buat location baru?"
-#: ../gui/wxpython/mapswipe/dialogs.py:186
-msgid "Cancel"
-msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:192
-#, fuzzy
-msgid "Switch to simple mode"
-msgstr "Sederhana"
-#: ../gui/wxpython/mapswipe/dialogs.py:217
-msgid "Name of the first map is missing."
-msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:220
-#, fuzzy
-msgid "Name of the second map is missing."
-msgstr "Nomor kategori (kolom %s) tidak ada."
-#: ../gui/wxpython/mapswipe/dialogs.py:253
-#, fuzzy
-msgid "Map Swipe settings"
-#: ../gui/wxpython/mapswipe/dialogs.py:269
-#: ../gui/wxpython/mapswipe/toolbars.py:118
-#, fuzzy
-msgid "Mirror mode"
-msgstr "Bentuk garis"
-#: ../gui/wxpython/mapswipe/dialogs.py:272
-#, fuzzy
-msgid "Mirrored cursor"
-#: ../gui/wxpython/mapswipe/dialogs.py:301
-#, fuzzy
-msgid "Shape:"
-msgstr "Indeks bentuk "
-#: ../gui/wxpython/mapswipe/frame.py:44
-#, fuzzy
-msgid "GRASS GIS Map Swipe"
-msgstr "GRASS GIS Map Display: "
-#: ../gui/wxpython/mapswipe/frame.py:417
-msgid "Map <%s> not found. "
-#: ../gui/wxpython/mapswipe/toolbars.py:29
-#: ../gui/wxpython/modules/vclean.py:518
-msgid "Tools"
-msgstr ""
-#: ../gui/wxpython/mapswipe/toolbars.py:31
-msgid "Quit Map Swipe"
-msgstr ""
-#: ../gui/wxpython/mapswipe/toolbars.py:117
-#, fuzzy
-msgid "Swipe mode"
-msgstr "Garis"
-#: ../gui/wxpython/mapswipe/toolbars.py:130
-#, fuzzy
-msgid "Choose view mode"
-msgstr "Pilih Kode EPSG"
-#: ../gui/wxpython/mapswipe/toolbars.py:154
-#, fuzzy
-msgid "Switch orientation"
-msgstr "Rotasi:"
-#: ../gui/wxpython/mapswipe/toolbars.py:157
-msgid "Switch maps"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:55
-#, fuzzy
-msgid "GRASS GIS Raster Map Calculator"
-msgstr "Kalkulator Peta GRASS %s"
-#: ../gui/wxpython/modules/mcalc_builder.py:58
-#, fuzzy
-msgid "GRASS GIS 3D Raster Map Calculator"
-#: ../gui/wxpython/modules/mcalc_builder.py:74
-#, fuzzy
-msgid "mapcalc statement"
-#: ../gui/wxpython/modules/mcalc_builder.py:132
-#, fuzzy
-msgid "Operators"
-#: ../gui/wxpython/modules/mcalc_builder.py:136
-msgid "Operands"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:138
-#, fuzzy
-msgid "Expression"
-msgstr "Proyeksi:"
-#: ../gui/wxpython/modules/mcalc_builder.py:153
-#, fuzzy
-msgid "Save expression to file"
-msgstr "Simpan workspace ke dalam berkas"
-#: ../gui/wxpython/modules/mcalc_builder.py:156
-#, fuzzy
-msgid "Load expression from file"
-#: ../gui/wxpython/modules/mcalc_builder.py:163
-msgid "exponent"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:165
-msgid "divide"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:167
-msgid "add"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:170
-#, fuzzy
-msgid "subtract"
-msgstr "Cost surface"
-#: ../gui/wxpython/modules/mcalc_builder.py:172
-msgid "modulus"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:175
-#, fuzzy
-msgid "multiply"
-#: ../gui/wxpython/modules/mcalc_builder.py:183
-msgid "left shift"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:186
-msgid "right shift"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:189
-msgid "right shift (unsigned)"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:191
-#, fuzzy
-msgid "greater than"
-msgstr "lebih pendek dari"
-#: ../gui/wxpython/modules/mcalc_builder.py:194
-#, fuzzy
-msgid "greater than or equal to"
-#: ../gui/wxpython/modules/mcalc_builder.py:196
-#, fuzzy
-msgid "less than"
-msgstr "lebih jauh dari"
-#: ../gui/wxpython/modules/mcalc_builder.py:199
-msgid "less than or equal to"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:201
-msgid "equal to"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:204
-msgid "not equal to"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:208
-#, fuzzy
-msgid "one's complement"
-msgstr "Tampilkan batas luar komputasi"
-#: ../gui/wxpython/modules/mcalc_builder.py:210
-msgid "NOT"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:213
-msgid "bitwise AND"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:216
-msgid "bitwise OR"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:219
-msgid "logical AND"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:222
-msgid "logical AND (ignores NULLs)"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:224
-msgid "logical OR"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:227
-msgid "logical OR (ignores NULLs)"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:232
-#, fuzzy
-msgid "conditional"
-msgstr "Opsional"
-#: ../gui/wxpython/modules/mcalc_builder.py:247
-#, fuzzy
-msgid "Name for new 3D raster map to create"
-#: ../gui/wxpython/modules/mcalc_builder.py:249
-#, fuzzy
-msgid "Name for new raster map to create"
-#: ../gui/wxpython/modules/mcalc_builder.py:254
-#, fuzzy
-msgid "Insert existing 3D raster map"
-#: ../gui/wxpython/modules/mcalc_builder.py:256
-#, fuzzy
-msgid "Insert existing raster map"
-#: ../gui/wxpython/modules/mcalc_builder.py:261
-#, fuzzy
-msgid "Insert mapcalc function"
-#: ../gui/wxpython/modules/mcalc_builder.py:278
-#, fuzzy
-msgid "Generate random seed for rand()"
-msgstr "Hasilkan titik acak"
-#: ../gui/wxpython/modules/mcalc_builder.py:280
-msgid "Seed:"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:284
-msgid "Integer seed for rand() function"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:291
-#, fuzzy
-msgid "Add created raster map into layer tree"
-#: ../gui/wxpython/modules/mcalc_builder.py:628
-#, fuzzy
-msgid "You must enter the name of a new raster map to create."
-msgstr "Anda harus memasukkan nama ekstensi peta untuk dapat melanjutkan"
-#: ../gui/wxpython/modules/mcalc_builder.py:639
-#, fuzzy
-msgid "You must enter an expression to create a new raster map."
-#: ../gui/wxpython/modules/mcalc_builder.py:699
-#, fuzzy
-msgid "Choose a file name to save the expression"
-#: ../gui/wxpython/modules/mcalc_builder.py:700
-#: ../gui/wxpython/modules/mcalc_builder.py:722
-#, fuzzy
-msgid "Expression file (*)|*"
-msgstr "Proyeksi:"
-#: ../gui/wxpython/modules/mcalc_builder.py:721
-#, fuzzy
-msgid "Choose a file name to load the expression"
-#: ../gui/wxpython/modules/mcalc_builder.py:757
-#, fuzzy, python-brace-format
-msgid "'{cmd}' copied to clipboard"
-#: ../gui/wxpython/modules/vclean.py:34 ../gui/wxpython/modules/vclean.py:120
-#, fuzzy
-msgid "Set up vector cleaning tools"
-#: ../gui/wxpython/modules/vclean.py:75
-#, fuzzy
-msgid "break lines/boundaries"
-msgstr "Gabungkan garis/batas terpilih"
-#: ../gui/wxpython/modules/vclean.py:76
-#, fuzzy
-msgid "remove duplicates"
-msgstr "Periksa untuk duplikasi"
-#: ../gui/wxpython/modules/vclean.py:77
-#, fuzzy
-msgid "remove dangles"
-#: ../gui/wxpython/modules/vclean.py:78
-msgid "change boundary dangles to lines"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:79
-#, fuzzy
-msgid "remove bridges"
-msgstr "Hapus tabel"
-#: ../gui/wxpython/modules/vclean.py:80
-msgid "change bridges to lines"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:81
-#, fuzzy
-msgid "snap lines/boundaries"
-msgstr "Balikkan garis/batas terpilih"
-#: ../gui/wxpython/modules/vclean.py:82
-msgid "remove duplicate area centroids"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:83
-msgid "break polygons"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:84
-#, fuzzy
-msgid "prune lines/boundaries"
-#: ../gui/wxpython/modules/vclean.py:85
-#, fuzzy
-msgid "remove small areas"
-#: ../gui/wxpython/modules/vclean.py:86
-#, fuzzy
-msgid "remove lines/boundaries of zero length"
-msgstr "Potong garis/batas terpilih pada interseksi"
-#: ../gui/wxpython/modules/vclean.py:87
-msgid "remove small angles at nodes"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:122
-msgid "Choose cleaning tools and set thresholds"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:126
-#, fuzzy
-msgid "Select input vector map:"
-#: ../gui/wxpython/modules/vclean.py:132
-#, fuzzy
-msgid " Feature type: "
-msgstr "ID Fitur"
-#: ../gui/wxpython/modules/vclean.py:136
-#, fuzzy
-msgid "Select output vector map:"
-#: ../gui/wxpython/modules/vclean.py:177
-#, fuzzy
-msgid "Copy the current command string to the clipboard (Ctrl+C)"
-#: ../gui/wxpython/modules/vclean.py:223
-#, fuzzy
-msgid "line"
-msgstr "Garis"
-#: ../gui/wxpython/modules/vclean.py:224
-#, fuzzy
-msgid "boundary"
-msgstr "Edit garis/batas "
-#: ../gui/wxpython/modules/vclean.py:225
-#, fuzzy
-msgid "centroid"
-msgstr "Tambahkan centroid"
-#: ../gui/wxpython/modules/vclean.py:227
-#, fuzzy
-msgid "face"
-#: ../gui/wxpython/modules/vclean.py:401
-#, python-format
-msgid "%s. cleaning tool removed, will be ignored"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:404
-msgid "Please select a cleaning tool to remove"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:428
-msgid "%s. cleaning tool moved up"
-msgstr "Tool untuk membersihkan topologi peta vektor."
-#: ../gui/wxpython/modules/vclean.py:430
-msgid "1. cleaning tool can not be moved up "
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:432
-#, fuzzy
-msgid "Please select a cleaning tool to move up"
-#: ../gui/wxpython/modules/vclean.py:460
-#, python-format
-msgid "%s. cleaning tool moved down"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:462
-msgid "Last cleaning tool can not be moved down "
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:464
-msgid "Please select a cleaning tool to move down"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:478
-#, python-format
-msgid "cleaning tool: '%s'"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:488
-#, python-format
-msgid "Threshold for %(num)s. tool '%(tool)s': %(thresh)s"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:516
-#, fuzzy
-msgid "Name of input vector map"
-msgstr "Nama untuk peta vektor baru:"
-#: ../gui/wxpython/modules/vclean.py:517
-#, fuzzy
-msgid "Name for output vector map"
-#: ../gui/wxpython/modules/vclean.py:519
-#, fuzzy
-msgid "Threshold"
-msgstr "Pilih batas"
-#: ../gui/wxpython/modules/vclean.py:521
-#, python-format
-msgid "'%s' not defined"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:523
-msgid ""
-"Some parameters not defined. Operation canceled.\n"
-"\n"
-"%s"
-#: ../gui/wxpython/modules/vclean.py:528
-msgid "Executing selected cleaning operations..."
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:585
-msgid "Vector cleaning command copied to clipboard"
-msgstr ""
-#: ../gui/wxpython/modules/histogram.py:292
-#, fuzzy
-msgid "GRASS GIS Histogramming Tool (d.histogram)"
-msgstr "Buat histogram dari berkas citra atau raster"
-#: ../gui/wxpython/modules/histogram.py:424
-msgid "Select font for histogram text"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:79
-#, fuzzy
-msgid "Check all"
-#: ../gui/wxpython/modules/colorrules.py:82
-#, fuzzy
-msgid "Clear all"
-#: ../gui/wxpython/modules/colorrules.py:140
-#, fuzzy
-msgid "Enter vector attribute values"
-msgstr "Kueri data atribut vektor"
-#: ../gui/wxpython/modules/colorrules.py:311
-msgid "Bad color format. Use color format '0:0:0'"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:415
-#, fuzzy
-msgid "Select vector map:"
-msgstr "Pilih peta vektor"
-#: ../gui/wxpython/modules/colorrules.py:435
-#, fuzzy
-msgid "Import or export color table:"
-#: ../gui/wxpython/modules/colorrules.py:440
-#, fuzzy
-msgid "Choose file to load color table"
-#: ../gui/wxpython/modules/colorrules.py:441
-#, fuzzy
-msgid "Load"
-msgstr "Memuat"
-#: ../gui/wxpython/modules/colorrules.py:443
-msgid "Type filename or click to choose file and load color table"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:449
-#, fuzzy
-msgid "Choose file to save color table"
-#: ../gui/wxpython/modules/colorrules.py:451
-msgid "Type filename or click to choose file and save color table"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:453 ../gui/wxpython/menustrings.py:10
-#: ../gui/wxpython/menustrings.py:1939
-#, fuzzy
-msgid "Save"
-#: ../gui/wxpython/modules/colorrules.py:465
-#, fuzzy
-msgid "&Set"
-msgstr "Pengaturan"
-#: ../gui/wxpython/modules/colorrules.py:473
-#, fuzzy
-msgid "Load color table:"
-#: ../gui/wxpython/modules/colorrules.py:479
-#, fuzzy
-msgid "Load color table from file:"
-#: ../gui/wxpython/modules/colorrules.py:487
-#, fuzzy
-msgid "Save color table to file:"
-#: ../gui/wxpython/modules/colorrules.py:519
-#, fuzzy
-msgid "Reload default table"
-#: ../gui/wxpython/modules/colorrules.py:587
-msgid "Show preview of map (current Map Display extent is used)."
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:619
-#: ../gui/wxpython/modules/colorrules.py:1889
-msgid "No valid color rules given."
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:676
-msgid "File <%s> already already exists. Do you want to overwrite it?"
-#: ../gui/wxpython/modules/colorrules.py:723
-#, fuzzy
-msgid "Invalid color table format"
-#: ../gui/wxpython/modules/colorrules.py:804
-#, python-format
-msgid "Invalid rule value '%s'. Unable to apply color table."
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:890
-#, fuzzy
-msgid "Create new color table for raster map"
-msgstr "Buat tabel warna baru menggunakan color rules"
-#: ../gui/wxpython/modules/colorrules.py:968
-#, fuzzy
-msgid "Enter raster category values or percents"
-msgstr "Mengubah nilai kategori secara interaktif "
-#: ../gui/wxpython/modules/colorrules.py:974
-#, fuzzy
-msgid "fp range"
-msgstr "Rentang yang valid"
-#: ../gui/wxpython/modules/colorrules.py:976
-#, python-format
-msgid "Enter raster category values or percents (%(range)s = %(min)d-%(max)d)"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1083
-#, fuzzy
-msgid "Create new color rules for vector map"
-#: ../gui/wxpython/modules/colorrules.py:1096
-#: ../gui/wxpython/modules/colorrules.py:1673
-#, fuzzy
-msgid "Enter vector attribute values or percents:"
-#: ../gui/wxpython/modules/colorrules.py:1098
-#: ../gui/wxpython/modules/colorrules.py:1675
-#, fuzzy
-msgid "Enter vector attribute values:"
-#: ../gui/wxpython/modules/colorrules.py:1109
-#, fuzzy
-msgid "Select vector columns"
-#: ../gui/wxpython/modules/colorrules.py:1111
-#, fuzzy
-msgid "Layer:"
-msgstr "Layer"
-#: ../gui/wxpython/modules/colorrules.py:1113
-#, fuzzy
-msgid "Attribute column:"
-msgstr "Atribut"
-#: ../gui/wxpython/modules/colorrules.py:1116
-#, fuzzy
-msgid "Load color from column:"
-#, fuzzy
-msgid "Save color to column:"
-#: ../gui/wxpython/modules/colorrules.py:1118
-#, fuzzy
-msgid "Load size from column:"
-#, fuzzy
-msgid "Save size to column:"
-msgstr "Serangkaian raster ke dalam volume"
-#: ../gui/wxpython/modules/colorrules.py:1120
-#, fuzzy
-msgid "Load width from column:"
-msgid "Save width to column:"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1125
-msgid "Use color column instead of color table:"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1141
-#, fuzzy
-msgid "Add GRASSRGB column to current attribute table."
-msgstr "Hapus juga tabel atribut terpaut (%s)"
-#: ../gui/wxpython/modules/colorrules.py:1200
-#: ../gui/wxpython/modules/colorrules.py:1256
-#, fuzzy
-msgid "Import or export color table"
-#: ../gui/wxpython/modules/colorrules.py:1270
-msgid ""
-"Database connection for vector map <%s> is not defined in DB file. Do you "
-"want to create and connect new attribute table?"
-msgstr ""
-"Koneksi basisdata ke peta vektor <%s> tidak didefinisikan dalam berkas DB. "
-"Anda dapat mendefinisikan sebuah koneksi baru dalam tab 'Kelola layer'."
-#: ../gui/wxpython/modules/colorrules.py:1274
-#, fuzzy
-msgid "No database connection defined"
-msgstr "Koneksi vektor basisdata"
-#: ../gui/wxpython/modules/colorrules.py:1347
-#, python-format
-msgid ""
-"Selected map <%(map)s> is not in current mapset <%(mapset)s>. Attribute "
-"table cannot be edited."
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1518
-#, python-format
-msgid "%s column already exists."
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1552
-#, fuzzy
-msgid "Please wait, loading data from attribute table..."
-msgstr "Silakan tunggu, sedang menampilkan data atribut ..."
-#: ../gui/wxpython/modules/colorrules.py:1613
-#, python-format
-msgid ""
-"Number of loaded records reached %d, displaying all the records will be time-"
-"consuming and may lead to computer freezing, do you still want to continue?"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1617
-msgid "Too many records"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1664
-msgid "Enter vector attribute values or percents %s:"
-#: ../gui/wxpython/modules/colorrules.py:1668
-msgid "Enter vector attribute values %s:"
-#: ../gui/wxpython/modules/colorrules.py:1821
-#, fuzzy
-msgid "Please select column to save values to."
-#: ../gui/wxpython/modules/colorrules.py:1857
-#, fuzzy
-msgid "No color column defined. Operation canceled."
-#: ../gui/wxpython/modules/colorrules.py:1874
-msgid "Thematic mapping for vector map in 3D view"
-msgstr ""
-#: ../gui/wxpython/modules/vkrige.py:33
-msgid "No GRASS-python library found."
-msgstr ""
-#: ../gui/wxpython/modules/vkrige.py:72
-msgid "Input Data"
-msgstr ""
-#: ../gui/wxpython/modules/vkrige.py:82
-msgid "Point dataset:"
-msgstr ""
-#: ../gui/wxpython/modules/vkrige.py:98
-#, fuzzy
-msgid "Numeric column:"
-msgstr "Kolom kunci"
-#: ../gui/wxpython/modules/vkrige.py:116
-#, fuzzy
-msgid "Kriging"
-msgstr "Tiling "
-#: ../gui/wxpython/modules/vkrige.py:161
-#, fuzzy
-msgid "Name for the output raster map:"
-#: ../gui/wxpython/modules/vkrige.py:169
-#, fuzzy
-msgid "Export variance map as well: "
-msgstr "Ekspor peta raster "
-#: ../gui/wxpython/modules/vkrige.py:404
-msgid "Kriging Module"
-msgstr ""
-#: ../gui/wxpython/modules/vkrige.py:413
-#, fuzzy
-msgid "Ready."
-msgstr "Muat-ulang"
-#: ../gui/wxpython/modules/vkrige.py:443
-msgid "Variogram fitting"
-msgstr ""
-#: ../gui/wxpython/modules/vkrige.py:463
-msgid "Plot/refresh variogram"
-msgstr ""
-#: ../gui/wxpython/modules/vkrige.py:488
-#, fuzzy
-msgid ":"
-msgstr "X:"
-#: ../gui/wxpython/modules/vkrige.py:534
-msgid "Kriging techniques"
-msgstr ""
-#: ../gui/wxpython/modules/vkrige.py:553
-#, fuzzy
-msgid "Block size:"
-msgstr "Tema ikon:"
-#: ../gui/wxpython/modules/vkrige.py:607
-msgid "Auto-fit variogram"
-msgstr ""
-#: ../gui/wxpython/modules/vkrige.py:635
-#, fuzzy
-msgid "Model: "
-msgstr "Mode"
-#: ../gui/wxpython/modules/vkrige.py:758
-msgid "Work in progress! No functionality provided."
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:41
-msgid "Fetch & install extension from GRASS Addons"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:58
-msgid "Repository (leave empty to use the official one)"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:61
-#, fuzzy
-msgid "List of extensions - double-click to install"
-msgstr "Tabel %s - klik-kanan untuk menghapus rekaman"
-#: ../gui/wxpython/modules/extensions.py:85
-#, fuzzy
-msgid "Options"
-msgstr "Opsional"
-#: ../gui/wxpython/modules/extensions.py:113
-msgid "&Fetch"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:114
-msgid "Fetch list of available modules from GRASS Addons SVN repository"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:118
-msgid "&Install"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:120
-msgid "Install selected add-ons GRASS module"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:123
-msgid "Show g.extension manual page"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:187
-msgid "Extension not defined"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:211
-msgid "Fetching list of modules from GRASS-Addons SVN (be patient)..."
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:226
-msgid "%d extensions loaded"
-msgstr "Daftar kategori"
-#: ../gui/wxpython/modules/extensions.py:238
-msgid "Install"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:243
-#, fuzzy
-msgid "Show manual page"
-msgstr "Peta bayangan "
-#: ../gui/wxpython/modules/extensions.py:344
-msgid "Unable to load extensions. %s"
-#: ../gui/wxpython/modules/extensions.py:390
-#, fuzzy
-msgid "Manage installed GRASS Addons extensions"
-#: ../gui/wxpython/modules/extensions.py:406
-#, fuzzy
-msgid "List of installed extensions"
-#: ../gui/wxpython/modules/extensions.py:414
-#, fuzzy
-msgid "Uninstall"
-#: ../gui/wxpython/modules/extensions.py:416
-#, fuzzy
-msgid "Uninstall selected Addons extensions"
-#: ../gui/wxpython/modules/extensions.py:420
-msgid "Reinstall"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:422
-#, fuzzy
-msgid "Reinstall selected Addons extensions"
-#: ../gui/wxpython/modules/extensions.py:463
-#, fuzzy
-msgid "No extension selected. Operation canceled."
-#: ../gui/wxpython/modules/extensions.py:490
-#, python-format
-msgid ""
-"List of files to be removed:\n"
-"%(files)s\n"
-"\n"
-"Do you want really to remove <%(ext)s> extension?"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:494
-#, fuzzy
-msgid "Remove extension"
-#: ../gui/wxpython/modules/extensions.py:527
-#, fuzzy
-msgid "Extension"
-msgstr "Proyeksi:"
-#: ../gui/wxpython/modules/import_export.py:45
-#, fuzzy
-msgid "Multiple import"
-msgstr "Impor WMS"
-#: ../gui/wxpython/modules/import_export.py:62
-#, fuzzy
-msgid "List of raster layers"
-msgstr "Daftar layer"
-#: ../gui/wxpython/modules/import_export.py:64
-#, fuzzy
-msgid "List of vector layers"
-#: ../gui/wxpython/modules/import_export.py:66
-msgid "List of %s layers"
-#: ../gui/wxpython/modules/import_export.py:68
-#: ../gui/wxpython/modules/import_export.py:885
-msgid "right click to (un)select all"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:73
-#, fuzzy
-msgid "Name for output GRASS map (editable)"
-#: ../gui/wxpython/modules/import_export.py:85
-msgid "Override projection check (use current location's projection)"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:116
-#: ../gui/wxpython/modules/import_export.py:393
-#: ../gui/wxpython/modules/import_export.py:534
-msgid "&Import"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:117
-#: ../gui/wxpython/modules/import_export.py:394
-#: ../gui/wxpython/modules/import_export.py:535
-#, fuzzy
-msgid "Import selected layers"
-msgstr "Hapus layer terpilih"
-#: ../gui/wxpython/modules/import_export.py:128
-#, fuzzy
-msgid "Source settings"
-#: ../gui/wxpython/modules/import_export.py:149
-#, fuzzy
-msgid "Import settings"
-msgstr "Jenis huruf"
-#: ../gui/wxpython/modules/import_export.py:379
-#: ../gui/wxpython/modules/import_export.py:520
-#, fuzzy
-msgid "Add linked layers into layer tree"
-msgstr "Tampilkan layer peta ke dalam layer tree"
-#: ../gui/wxpython/modules/import_export.py:381
-#: ../gui/wxpython/modules/import_export.py:522
-#: ../gui/wxpython/modules/import_export.py:751
-#, fuzzy
-msgid "Add imported layers into layer tree"
-#: ../gui/wxpython/modules/import_export.py:390
-#: ../gui/wxpython/modules/import_export.py:531
-#, fuzzy
-msgid "&Link"
-msgstr "Garis"
-#: ../gui/wxpython/modules/import_export.py:391
-#: ../gui/wxpython/modules/import_export.py:532
-#, fuzzy
-msgid "Link selected layers"
-msgstr "Modifikasi layer terpilih"
-#: ../gui/wxpython/modules/import_export.py:414
-#: ../gui/wxpython/modules/import_export.py:555
-#, fuzzy
-msgid "No layers selected. Operation canceled."
-#: ../gui/wxpython/modules/import_export.py:440
-#, fuzzy
-msgid "Unable to determine number of raster bands"
-msgstr "Tidak mampu membuat profil dari peta raster."
-#: ../gui/wxpython/modules/import_export.py:655
-#, fuzzy
-msgid "Define output format for vector data"
-msgstr "Impor peta vektor "
-#: ../gui/wxpython/modules/import_export.py:657
-#, fuzzy
-msgid "Define output format for raster data"
-#: ../gui/wxpython/modules/import_export.py:665
-#, fuzzy
-msgid "Set external format and close dialog"
-msgstr "Terapkan perubahan untuk sesi ini"
-#: ../gui/wxpython/modules/import_export.py:722
-#, fuzzy
-msgid "No data source selected."
-#: ../gui/wxpython/modules/import_export.py:737
-msgid "Import DXF layers"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:744
-#, fuzzy
-msgid "Choose DXF file to import"
-#: ../gui/wxpython/modules/import_export.py:773
-#, fuzzy
-msgid "No layers selected."
-#: ../gui/wxpython/modules/import_export.py:863
-#, fuzzy
-msgid "Name for output GRASS map"
-#: ../gui/wxpython/modules/import_export.py:881
-msgid ""
-"Projection of following layers do not match with projection of current "
-"location. "
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:883
-#, fuzzy
-msgid "Layers to be reprojected"
-msgstr "Layer yang akan dihapus"
-#: ../gui/wxpython/modules/import_export.py:897
-msgid "&Import && reproject"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:898
-#, fuzzy
-msgid "Reproject selected layers"
-#: ../gui/wxpython/menustrings.py:4 ../gui/wxpython/menustrings.py:1934
-#: ../gui/wxpython/menustrings.py:1984
-#, fuzzy
-msgid "&File"
-msgstr "Berkas"
-#: ../gui/wxpython/menustrings.py:5
-msgid "Workspace"
-msgstr "Workspace "
-#: ../gui/wxpython/menustrings.py:7
-#, fuzzy
-msgid "Create new workspace"
-msgstr "Buat sebuah berkas workspace baru"
-#: ../gui/wxpython/menustrings.py:8 ../gui/wxpython/menustrings.py:1937
-msgid "Open"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:9
-#, fuzzy
-msgid "Load workspace from file"
-#: ../gui/wxpython/menustrings.py:12 ../gui/wxpython/menustrings.py:1941
-#, fuzzy
-msgid "Save as"
-msgstr "Simpan perubahan"
-#: ../gui/wxpython/menustrings.py:13
-#, fuzzy
-msgid "Save workspace to file"
-#: ../gui/wxpython/menustrings.py:15
-#, fuzzy
-msgid "Close workspace file"
-#: ../gui/wxpython/menustrings.py:16
-msgid "Load GRC file (Tcl/Tk GUI)"
-msgstr "Tampilkan berkas GRC (GUI Tcl/Tk)"
-#: ../gui/wxpython/menustrings.py:17
-#, fuzzy
-msgid "Load map layers from GRC file to layer tree"
-#, fuzzy
-msgid "Add raster"
-msgstr "raster"
-#: ../gui/wxpython/menustrings.py:20
-#, fuzzy
-msgid "Add raster map layer to current display"
-msgstr "Tambahkan layer peta raster"
-#: ../gui/wxpython/menustrings.py:21
-#, fuzzy
-msgid "Add vector"
-msgstr "vektor "
-#: ../gui/wxpython/menustrings.py:22
-#, fuzzy
-msgid "Add vector map layer to current display"
-msgstr "Tambahkan layer peta vektor"
-#: ../gui/wxpython/menustrings.py:23
-msgid "Add multiple rasters or vectors"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:24
-#, fuzzy
-msgid "Add multiple raster or vector map layers to current display"
-#: ../gui/wxpython/menustrings.py:25
-#, fuzzy
-msgid "Add RGB raster layer"
-msgstr "Tambahkan layer RGB"
-#: ../gui/wxpython/menustrings.py:26
-#, fuzzy
-msgid "Add RGB raster map layer to current display"
-#: ../gui/wxpython/menustrings.py:29
-#, fuzzy
-msgid "New map display window"
-msgstr "Gambar transek dalam jendela tampilan peta untuk membuat profil"
-#: ../gui/wxpython/menustrings.py:30
-#, fuzzy
-msgid "Open new map display window"
-#: ../gui/wxpython/menustrings.py:31 ../gui/wxpython/menustrings.py:32
-#, fuzzy
-msgid "Close current map display window"
-#: ../gui/wxpython/menustrings.py:33 ../gui/wxpython/menustrings.py:34
-#, fuzzy
-msgid "Close all open map display windows"
-#: ../gui/wxpython/menustrings.py:36 ../gui/wxpython/menustrings.py:1021
-#, fuzzy
-msgid "Common formats import"
-msgstr "Koordinat"
-#: ../gui/wxpython/menustrings.py:37 ../gui/wxpython/menustrings.py:1022
-#, fuzzy
-msgid "Imports raster data into a GRASS raster map using GDAL library."
-#: ../gui/wxpython/menustrings.py:38 ../gui/wxpython/menustrings.py:68
-#: ../gui/wxpython/menustrings.py:1023 ../gui/wxpython/menustrings.py:1053
-#, fuzzy
-msgid "Import of common formats with reprojection"
-msgstr "Ekspor peta vektor "
-#: ../gui/wxpython/menustrings.py:39 ../gui/wxpython/menustrings.py:1024
-#, fuzzy
-msgid ""
-"Imports raster data into a GRASS raster map using GDAL library and "
-"reprojects on the fly."
-#: ../gui/wxpython/menustrings.py:40 ../gui/wxpython/menustrings.py:1025
-msgid "ASCII x,y,z point import and gridding"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:41 ../gui/wxpython/menustrings.py:1026
-#, fuzzy
-msgid ""
-"Creates a raster map from an assemblage of many coordinates using univariate "
-"statistics."
-msgstr ""
-"Buat sebuah peta raster dari satu himpunan koordinat dengan statistik "
-"univariat"
-#: ../gui/wxpython/menustrings.py:42 ../gui/wxpython/menustrings.py:1027
-msgid "ASCII grid import"
-msgstr "Impor grid ASCII"
-#: ../gui/wxpython/menustrings.py:43 ../gui/wxpython/menustrings.py:1028
-#, fuzzy
-msgid "Converts a GRASS ASCII raster file to binary raster map."
-msgstr "Ubah berkas ASCII raster ke layer peta raster biner."
-#: ../gui/wxpython/menustrings.py:44 ../gui/wxpython/menustrings.py:1029
-#, fuzzy
-msgid "ASCII polygons, lines, and point import"
-msgstr "Impor poligon dan garis ASCII"
-#: ../gui/wxpython/menustrings.py:45 ../gui/wxpython/menustrings.py:1030
-msgid "Creates raster maps from ASCII polygon/line/point data files."
-msgstr "Buat peta raster dari berkas data poligon/garis/titik ASCII."
-#: ../gui/wxpython/menustrings.py:46 ../gui/wxpython/menustrings.py:1031
-#, fuzzy
-msgid "Raw binary array import"
-msgstr "Impor Matlab dan MapGen"
-#: ../gui/wxpython/menustrings.py:47 ../gui/wxpython/menustrings.py:1032
-msgid "Import a binary raster file into a GRASS raster map layer."
-msgstr "Impor berkas raster biner ke dalam layer peta raster GRASS."
-#: ../gui/wxpython/menustrings.py:48 ../gui/wxpython/menustrings.py:1033
-msgid "GRIDATB.FOR import"
-msgstr "Impor GRIDATB.FOR"
-#: ../gui/wxpython/menustrings.py:49 ../gui/wxpython/menustrings.py:1034
-#, fuzzy
-msgid "Imports GRIDATB.FOR map file (TOPMODEL) into a GRASS raster map."
-msgstr ""
-"Impor berkas peta GRIDATB.FOR (TOPMODEL) ke dalam sebauh peta raster GRASS"
-#: ../gui/wxpython/menustrings.py:50 ../gui/wxpython/menustrings.py:1035
-#, fuzzy
-msgid "Matlab 2D array import"
-#: ../gui/wxpython/menustrings.py:51 ../gui/wxpython/menustrings.py:1036
-msgid "Imports a binary MAT-File(v4) to a GRASS raster."
-msgstr "Impor MAT-File (v4) biner ke raster GRASS."
-#: ../gui/wxpython/menustrings.py:52 ../gui/wxpython/menustrings.py:1037
-#, fuzzy
-msgid "PNG import"
-msgstr "Ekspor PNG"
-#: ../gui/wxpython/menustrings.py:53 ../gui/wxpython/menustrings.py:1038
-#, fuzzy
-msgid "Imports non-georeferenced PNG format image."
-msgstr "Ekspor raster GRASS ke dalam format PNG tidak bergeoreferensi."
-#: ../gui/wxpython/menustrings.py:54 ../gui/wxpython/menustrings.py:1039
-msgid "SPOT NDVI import"
-msgstr "Impor SPOT NDVI"
-#: ../gui/wxpython/menustrings.py:55 ../gui/wxpython/menustrings.py:1040
-#, fuzzy
-msgid "Imports SPOT VGT NDVI data into a raster map."
-msgstr "Impor berkas SPOT VGT NDVI ke dalam sebuah peta raster"
-#: ../gui/wxpython/menustrings.py:56 ../gui/wxpython/menustrings.py:1041
-msgid "SRTM HGT import"
-msgstr "Impor SRTM HGT"
-#: ../gui/wxpython/menustrings.py:57 ../gui/wxpython/menustrings.py:1042
-#, fuzzy
-msgid "Imports SRTM HGT files into raster map."
-#: ../gui/wxpython/menustrings.py:58 ../gui/wxpython/menustrings.py:1043
-msgid "Terra ASTER HDF import"
-msgstr "Impor Terra ASTER HDF"
-#: ../gui/wxpython/menustrings.py:59 ../gui/wxpython/menustrings.py:1044
-#, fuzzy
-msgid ""
-"Georeference, rectify, and import Terra-ASTER imagery and relative DEMs "
-"using gdalwarp."
-msgstr ""
-"Georeferensi, rektifikasi dan impor citra Terra-ASTER dan DEM dengan "
-"gdalwarp."
-#: ../gui/wxpython/menustrings.py:60 ../gui/wxpython/menustrings.py:84
-#: ../gui/wxpython/menustrings.py:1045 ../gui/wxpython/menustrings.py:1069
-#, fuzzy
-msgid "LAS LiDAR points import"
-msgstr "Ekspor ASCII x,y,z"
-#: ../gui/wxpython/menustrings.py:61 ../gui/wxpython/menustrings.py:1046
-#, fuzzy
-msgid "Unpack raster map"
-msgstr "Gabungkan peta raster"
-#: ../gui/wxpython/menustrings.py:62 ../gui/wxpython/menustrings.py:1047
-#, fuzzy
-msgid ""
-"Imports a raster map as GRASS GIS specific archive file (packed with r.pack)"
-#: ../gui/wxpython/menustrings.py:63 ../gui/wxpython/menustrings.py:281
-#: ../gui/wxpython/menustrings.py:1048 ../gui/wxpython/menustrings.py:1187
-#, fuzzy
-msgid "Reproject raster map from different GRASS location"
-msgstr ""
-"Proyeksi-ulang sebuah peta raster dari satu location ke location saat ini."
-#: ../gui/wxpython/menustrings.py:64 ../gui/wxpython/menustrings.py:282
-#: ../gui/wxpython/menustrings.py:1049 ../gui/wxpython/menustrings.py:1188
-#, fuzzy
-msgid "Re-projects a raster map from given location to the current location."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:66 ../gui/wxpython/menustrings.py:97
-#: ../gui/wxpython/menustrings.py:1051 ../gui/wxpython/menustrings.py:1082
-#, fuzzy
-msgid "Common import formats"
-msgstr "Koordinat"
-#: ../gui/wxpython/menustrings.py:67 ../gui/wxpython/menustrings.py:1052
-#, fuzzy
-msgid "Imports vector data into a GRASS vector map using OGR library."
-msgstr "Ubah layer vektor OGR ke dalam peta vektor GRASS."
-#: ../gui/wxpython/menustrings.py:69 ../gui/wxpython/menustrings.py:1054
-#, fuzzy
-msgid ""
-"Imports vector data into a GRASS vector map using OGR library and reprojects "
-"on the fly."
-#: ../gui/wxpython/menustrings.py:70 ../gui/wxpython/menustrings.py:1055
-#, fuzzy
-msgid "ASCII points or GRASS ASCII format"
-msgstr "Impor titik ASCII/vektor GRASS ASCII"
-#: ../gui/wxpython/menustrings.py:71 ../gui/wxpython/menustrings.py:1056
-#, fuzzy
-msgid "Creates a vector map from an ASCII points file or ASCII vector file."
-msgstr ""
-"Buat sebuah peta vektor dari berkas titik ASCII atau berkas vektor ASCII."
-#: ../gui/wxpython/menustrings.py:72 ../gui/wxpython/menustrings.py:1057
-#, fuzzy
-msgid "ASCII points as a vector lines"
-#: ../gui/wxpython/menustrings.py:73 ../gui/wxpython/menustrings.py:1058
-msgid "Imports ASCII x,y[,z] coordinates as a series of lines."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:74 ../gui/wxpython/menustrings.py:1059
-msgid "DXF import"
-msgstr "Impor DXF"
-#: ../gui/wxpython/menustrings.py:75 ../gui/wxpython/menustrings.py:1060
-msgid "Converts files in DXF format to GRASS vector map format."
-msgstr "Impor berkas dalam format DXF ke format vektor GRASS."
-#: ../gui/wxpython/menustrings.py:76 ../gui/wxpython/menustrings.py:1061
-msgid "WFS"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:77 ../gui/wxpython/menustrings.py:1062
-#, fuzzy
-msgid "Imports GetFeature from a WFS server."
-msgstr "Unduh dan impor data dari server WMS."
-#: ../gui/wxpython/menustrings.py:78 ../gui/wxpython/menustrings.py:1063
-msgid "ESRI e00 import"
-msgstr "Impor ESRI e00"
-#: ../gui/wxpython/menustrings.py:79 ../gui/wxpython/menustrings.py:1064
-#, fuzzy
-msgid "Imports E00 file into a vector map."
-msgstr "Impor berkas E00 ke dalam peta vektor."
-#: ../gui/wxpython/menustrings.py:80 ../gui/wxpython/menustrings.py:1065
-#, fuzzy
-msgid "Geonames import"
-msgstr "Impor GEOnet"
-#: ../gui/wxpython/menustrings.py:81 ../gui/wxpython/menustrings.py:1066
-#, fuzzy
-msgid "Imports geonames.org country files into a vector points map."
-msgstr ""
-"Impor berkas US-NGA GEOnet Names Server (GNS) ke dalam sebuah peta titik "
-"vektor GRASS."
-#: ../gui/wxpython/menustrings.py:82 ../gui/wxpython/menustrings.py:1067
-#, fuzzy
-msgid "Matlab array or Mapgen format import"
-#: ../gui/wxpython/menustrings.py:83 ../gui/wxpython/menustrings.py:1068
-#, fuzzy
-msgid "Imports Mapgen or Matlab-ASCII vector maps into GRASS."
-msgstr "Impor peta vektor Mapgen atau Matlab ke dalam GRASS."
-#: ../gui/wxpython/menustrings.py:85 ../gui/wxpython/menustrings.py:1070
-#, fuzzy
-msgid "Unpack vector map"
-msgstr "Gabungkan peta vektor"
-#: ../gui/wxpython/menustrings.py:86 ../gui/wxpython/menustrings.py:1071
-#, fuzzy
-msgid ""
-"Imports a vector map as GRASS GIS specific archive file (packed with v.pack)"
-#: ../gui/wxpython/menustrings.py:87 ../gui/wxpython/menustrings.py:559
-#: ../gui/wxpython/menustrings.py:1072 ../gui/wxpython/menustrings.py:1465
-#, fuzzy
-msgid "Reproject vector map from different GRASS location"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:88 ../gui/wxpython/menustrings.py:560
-#: ../gui/wxpython/menustrings.py:1073 ../gui/wxpython/menustrings.py:1466
-#, fuzzy
-msgid "Re-projects a vector map from one location to the current location."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:89 ../gui/wxpython/menustrings.py:1074
-#, fuzzy
-msgid "Import 3D raster data"
-#: ../gui/wxpython/menustrings.py:90 ../gui/wxpython/menustrings.py:1075
-msgid "ASCII 3D import"
-msgstr "Impor ASCII 3D"
-#: ../gui/wxpython/menustrings.py:91 ../gui/wxpython/menustrings.py:1076
-#, fuzzy
-msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map."
-msgstr "Ubah berkas teks raster 3D ASCII ke layer peta raster 3D (biner)"
-#: ../gui/wxpython/menustrings.py:92 ../gui/wxpython/menustrings.py:1077
-#, fuzzy
-msgid "Raw binary array 3D import"
-#: ../gui/wxpython/menustrings.py:93 ../gui/wxpython/menustrings.py:1078
-#, fuzzy
-msgid "Imports a binary raster file into a GRASS 3D raster map."
-#: ../gui/wxpython/menustrings.py:94 ../gui/wxpython/menustrings.py:1079
-msgid "Vis5D import"
-msgstr "Impor Vis5D"
-#: ../gui/wxpython/menustrings.py:95 ../gui/wxpython/menustrings.py:1080
-#, fuzzy
-msgid "Import 3-dimensional Vis5D files."
-msgstr "Ekspor peta raster GRASS 3D ke dalam sebuah berkas 3-dimensi Vis5D."
-#: ../gui/wxpython/menustrings.py:96 ../gui/wxpython/menustrings.py:1081
-msgid "Import database table"
-msgstr "Impor tabel basisdata"
-#: ../gui/wxpython/menustrings.py:98 ../gui/wxpython/menustrings.py:1083
-msgid "Imports attribute tables in various formats."
-msgstr "Impor tabel atribut dalam beragam format."
-#: ../gui/wxpython/menustrings.py:99 ../gui/wxpython/menustrings.py:1084
-#, fuzzy
-msgid "Export raster map"
-#: ../gui/wxpython/menustrings.py:100 ../gui/wxpython/menustrings.py:129
-#: ../gui/wxpython/menustrings.py:154 ../gui/wxpython/menustrings.py:1085
-#: ../gui/wxpython/menustrings.py:1114 ../gui/wxpython/menustrings.py:1139
-#, fuzzy
-msgid "Common export formats"
-msgstr "Koordinat"
-#: ../gui/wxpython/menustrings.py:101 ../gui/wxpython/menustrings.py:1086
-#, fuzzy
-msgid "Exports GRASS raster maps into GDAL supported formats."
-msgstr "Ekspor peta raster GRASS ke dalam format yang didukung GDAL."
-#: ../gui/wxpython/menustrings.py:102 ../gui/wxpython/menustrings.py:1087
-msgid "ASCII grid export"
-msgstr "Ekspor grid ASCII"
-#: ../gui/wxpython/menustrings.py:103 ../gui/wxpython/menustrings.py:1088
-#, fuzzy
-msgid "Converts a raster map layer into a GRASS ASCII text file."
-msgstr "Ubah sebuah layer peta raster menjadi berkas teks ASCII."
-#: ../gui/wxpython/menustrings.py:104 ../gui/wxpython/menustrings.py:1089
-#, fuzzy
-msgid "ASCII x,y,z points export"
-#: ../gui/wxpython/menustrings.py:105 ../gui/wxpython/menustrings.py:1090
-#, fuzzy
-msgid ""
-"Exports a raster map to a text file as x,y,z values based on cell centers."
-msgstr ""
-"Ekspor sebuah peta raster ke dalam sebuah berkas teks sebagai nilai x,y,z "
-"pada pusat sel."
-#: ../gui/wxpython/menustrings.py:106 ../gui/wxpython/menustrings.py:1091
-msgid "GRIDATB.FOR export"
-msgstr "Ekspor GRIDATB.FOR"
-#: ../gui/wxpython/menustrings.py:107 ../gui/wxpython/menustrings.py:1092
-#, fuzzy
-msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)."
-msgstr "Ekspor peta raster GRASS ke berkas beta GRIDATB.FOR (TOPMODEL)"
-#: ../gui/wxpython/menustrings.py:108 ../gui/wxpython/menustrings.py:1093
-#, fuzzy
-msgid "Matlab 2D array export"
-#: ../gui/wxpython/menustrings.py:109 ../gui/wxpython/menustrings.py:1094
-msgid "Exports a GRASS raster to a binary MAT-File."
-msgstr "Ekspor raster GRASS ke MAT-File biner."
-#: ../gui/wxpython/menustrings.py:110 ../gui/wxpython/menustrings.py:1095
-#, fuzzy
-msgid "Raw binary array export"
-#: ../gui/wxpython/menustrings.py:111 ../gui/wxpython/menustrings.py:1096
-msgid "Exports a GRASS raster to a binary array."
-msgstr "Ekspor raster GRASS ke array biner."
-#: ../gui/wxpython/menustrings.py:112 ../gui/wxpython/menustrings.py:1097
-msgid "MPEG-1 export"
-msgstr "Ekspor MPEG-1"
-#: ../gui/wxpython/menustrings.py:113 ../gui/wxpython/menustrings.py:1098
-#, fuzzy
-msgid "Converts raster map series to MPEG movie."
-msgstr "Program konversi Raster File Series ke MPEG."
-#: ../gui/wxpython/menustrings.py:114 ../gui/wxpython/menustrings.py:1099
-msgid "PNG export"
-#: ../gui/wxpython/menustrings.py:115 ../gui/wxpython/menustrings.py:1100
-#, fuzzy
-msgid "Export a GRASS raster map as a non-georeferenced PNG image."
-#: ../gui/wxpython/menustrings.py:116 ../gui/wxpython/menustrings.py:1101
-msgid "PPM export"
-msgstr "Ekspor PPM"
-#: ../gui/wxpython/menustrings.py:117 ../gui/wxpython/menustrings.py:1102
-#, fuzzy
-msgid "Converts a GRASS raster map to a PPM image file."
-msgstr "Ubah sebuah peta raster ke dalam sebuah layer peta vektor."
-#: ../gui/wxpython/menustrings.py:118 ../gui/wxpython/menustrings.py:1103
-msgid "PPM from RGB export"
-msgstr "Ekspor RGB ke PPM"
-#: ../gui/wxpython/menustrings.py:119 ../gui/wxpython/menustrings.py:1104
-#, fuzzy
-msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file."
-msgstr ""
-"Ubah 3 layer raster GRASS (R,G,B) ke sebuah berkas gambar PPM dengan "
-"resolusi piksel dari region terdefinisi."
-#: ../gui/wxpython/menustrings.py:120 ../gui/wxpython/menustrings.py:136
-#: ../gui/wxpython/menustrings.py:1105 ../gui/wxpython/menustrings.py:1121
-msgid "POV-Ray export"
-msgstr "Ekspor POV-Ray"
-#: ../gui/wxpython/menustrings.py:121 ../gui/wxpython/menustrings.py:1106
-#, fuzzy
-msgid "Converts a raster map layer into a height-field file for POV-Ray."
-msgstr "Ubah layer peta raster ke berkas titik tinggi untuk POVRAY."
-#: ../gui/wxpython/menustrings.py:122 ../gui/wxpython/menustrings.py:1107
-msgid "VRML export"
-msgstr "Ekspor VRML"
-#: ../gui/wxpython/menustrings.py:123 ../gui/wxpython/menustrings.py:1108
-#, fuzzy
-msgid "Exports a raster map to the Virtual Reality Modeling Language (VRML)."
-msgstr ""
-"Ekspor sebuah peta raster ke format Virtual Reality Modeling Language (VRML)"
-#: ../gui/wxpython/menustrings.py:124 ../gui/wxpython/menustrings.py:140
-#: ../gui/wxpython/menustrings.py:151 ../gui/wxpython/menustrings.py:1109
-#: ../gui/wxpython/menustrings.py:1125 ../gui/wxpython/menustrings.py:1136
-msgid "VTK export"
-msgstr "Ekspor VTK"
-#: ../gui/wxpython/menustrings.py:125 ../gui/wxpython/menustrings.py:1110
-#, fuzzy
-msgid "Converts raster maps into the VTK-ASCII format."
-msgstr "Ubah peta raster ke dalam format VTK-Ascii"
-#: ../gui/wxpython/menustrings.py:126 ../gui/wxpython/menustrings.py:1111
-#, fuzzy
-msgid "Pack raster map"
-#: ../gui/wxpython/menustrings.py:127 ../gui/wxpython/menustrings.py:1112
-#, fuzzy
-msgid "Exports a raster map as GRASS GIS specific archive file"
-#: ../gui/wxpython/menustrings.py:128 ../gui/wxpython/menustrings.py:1113
-msgid "Export vector map"
-#: ../gui/wxpython/menustrings.py:130 ../gui/wxpython/menustrings.py:1115
-#, fuzzy
-msgid ""
-"Exports a vector map layer to any of the supported OGR vector formats. By "
-"default a vector map layer is exported to Esri Shapefile format."
-msgstr "Ubah ke dalam salah satu format vektor OGR."
-#: ../gui/wxpython/menustrings.py:131 ../gui/wxpython/menustrings.py:1116
-#, fuzzy
-msgid "ASCII points or GRASS ASCII vector export"
-msgstr "Ekspor titik ASCII/vektor GRASS ASCII"
-#: ../gui/wxpython/menustrings.py:132 ../gui/wxpython/menustrings.py:1117
-msgid ""
-"Exports a vector map to a GRASS ASCII vector representation. By default only "
-"features with category are exported. To export all features use 'layer=-1'."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:133 ../gui/wxpython/menustrings.py:1118
-msgid "DXF export"
-msgstr "Ekspor DXF"
-#: ../gui/wxpython/menustrings.py:134 ../gui/wxpython/menustrings.py:1119
-#, fuzzy
-msgid "Exports vector map to DXF file format."
-msgstr "Ekspor layer peta vektor GRASS ke dalam berkas format DXF."
-#: ../gui/wxpython/menustrings.py:135 ../gui/wxpython/menustrings.py:1120
-#, fuzzy
-msgid "PostGIS export"
-#: ../gui/wxpython/menustrings.py:137 ../gui/wxpython/menustrings.py:1122
-#, fuzzy
-msgid "Converts GRASS x,y,z points to POV-Ray x,z,y format."
-msgstr "Ubah ke format POV-Ray, GRASS x,y,z -> POV-Ray x,z,y"
-#: ../gui/wxpython/menustrings.py:138 ../gui/wxpython/menustrings.py:1123
-msgid "SVG export"
-msgstr "Ekspor SVG"
-#: ../gui/wxpython/menustrings.py:139 ../gui/wxpython/menustrings.py:1124
-#, fuzzy
-msgid "Exports a vector map to SVG file."
-msgstr "Ekspor sebuah peta vektor GRASS ke SVG."
-#: ../gui/wxpython/menustrings.py:141 ../gui/wxpython/menustrings.py:1126
-#, fuzzy
-msgid "Converts a vector map to VTK ASCII output."
-msgstr "Ubah sebuah peta vektor GRASS biner ke dalam VTK ASCII."
-#: ../gui/wxpython/menustrings.py:142 ../gui/wxpython/menustrings.py:1127
-#, fuzzy
-msgid "Pack vector map"
-#: ../gui/wxpython/menustrings.py:143 ../gui/wxpython/menustrings.py:1128
-#, fuzzy
-msgid "Exports a vector map as GRASS GIS specific archive file"
-#: ../gui/wxpython/menustrings.py:144 ../gui/wxpython/menustrings.py:1129
-#, fuzzy
-msgid "Export 3D raster maps"
-#: ../gui/wxpython/menustrings.py:145 ../gui/wxpython/menustrings.py:1130
-msgid "ASCII 3D export"
-msgstr "Ekspor ASCII 3D"
-#: ../gui/wxpython/menustrings.py:146 ../gui/wxpython/menustrings.py:1131
-#, fuzzy
-msgid "Converts a 3D raster map layer into a ASCII text file."
-msgstr "Ubah layer peta raster 3D ke berkas teks ASCII"
-#: ../gui/wxpython/menustrings.py:147 ../gui/wxpython/menustrings.py:1132
-#, fuzzy
-msgid "Raw binary array 3D export"
-#: ../gui/wxpython/menustrings.py:148 ../gui/wxpython/menustrings.py:1133
-#, fuzzy
-msgid "Exports a GRASS 3D raster map to a binary array."
-#: ../gui/wxpython/menustrings.py:149 ../gui/wxpython/menustrings.py:1134
-msgid "Vis5D export"
-msgstr "Ekspor Vis5D"
-#: ../gui/wxpython/menustrings.py:150 ../gui/wxpython/menustrings.py:1135
-#, fuzzy
-msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
-#: ../gui/wxpython/menustrings.py:152 ../gui/wxpython/menustrings.py:1137
-#, fuzzy
-msgid "Converts 3D raster maps into the VTK-ASCII format."
-#: ../gui/wxpython/menustrings.py:153 ../gui/wxpython/menustrings.py:1138
-#, fuzzy
-msgid "Export database table"
-#: ../gui/wxpython/menustrings.py:155 ../gui/wxpython/menustrings.py:1140
-#, fuzzy
-msgid "Exports attribute tables into various formats."
-#: ../gui/wxpython/menustrings.py:156 ../gui/wxpython/menustrings.py:1141
-#, fuzzy
-msgid "Link external data"
-msgstr "Tidak berhasil memperbaharui peta vektor."
-#: ../gui/wxpython/menustrings.py:158 ../gui/wxpython/menustrings.py:1143
-#, fuzzy
-msgid "Link GDAL supported raster data as a pseudo GRASS raster map layer."
-msgstr "Impor berkas raster GDAL ke dalam layer peta raster biner."
-#: ../gui/wxpython/menustrings.py:160 ../gui/wxpython/menustrings.py:1145
-#, fuzzy
-msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer."
-msgstr ""
-"Buat sebuah layer peta vektor dengan menggabungkan layer peta vektor lainnya."
-#: ../gui/wxpython/menustrings.py:161 ../gui/wxpython/menustrings.py:1146
-#, fuzzy
-msgid "Output format for raster data"
-#: ../gui/wxpython/menustrings.py:162 ../gui/wxpython/menustrings.py:1147
-msgid "Defines raster output format utilizing GDAL library."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:163 ../gui/wxpython/menustrings.py:1148
-#, fuzzy
-msgid "Output format for vector data"
-#: ../gui/wxpython/menustrings.py:164 ../gui/wxpython/menustrings.py:1149
-msgid "Defines vector output format utilizing OGR library."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:165 ../gui/wxpython/menustrings.py:1150
-#, fuzzy
-msgid "Manage maps"
-msgstr "Bersihkan peta vektor"
-#: ../gui/wxpython/menustrings.py:167 ../gui/wxpython/menustrings.py:1152
-#, fuzzy
-msgid ""
-"Copies available data files in the current mapset search path to the user's "
-"current mapset."
-msgstr ""
-"Salin berkas data yang tersedia ke dalam mapset search path dan location "
-"pengguna ke dalam direktori yang sesuai di bawah mapset pengguna saat ini."
-#: ../gui/wxpython/menustrings.py:168 ../gui/wxpython/menustrings.py:928
-#: ../gui/wxpython/menustrings.py:1153 ../gui/wxpython/menustrings.py:1834
-msgid "List"
-msgstr "Daftar "
-#: ../gui/wxpython/menustrings.py:169 ../gui/wxpython/menustrings.py:1154
-#, fuzzy
-msgid ""
-"Lists available GRASS data base files of the user-specified data type "
-"optionally using the search pattern."
-msgstr ""
-"Susun berkas basis data GRASS yang tersedia dari tipe data spesifik ke dalam "
-"output standar"
-#: ../gui/wxpython/menustrings.py:171 ../gui/wxpython/menustrings.py:1156
-msgid "Renames data base element files in the user's current mapset."
-msgstr ""
-"Ubah nama berkas elemen basis data dalam mapset saat ini milik pengguna"
-#: ../gui/wxpython/menustrings.py:173 ../gui/wxpython/menustrings.py:1158
-#, fuzzy
-msgid ""
-"Removes data base element files from the user's current mapset using the "
-"search pattern."
-#: ../gui/wxpython/menustrings.py:174 ../gui/wxpython/menustrings.py:305
-#: ../gui/wxpython/menustrings.py:597 ../gui/wxpython/menustrings.py:829
-#: ../gui/wxpython/menustrings.py:1211 ../gui/wxpython/menustrings.py:1503
-#: ../gui/wxpython/menustrings.py:1735
-msgid "Map type conversions"
-msgstr "Konversi tipe peta "
-#: ../gui/wxpython/menustrings.py:175 ../gui/wxpython/menustrings.py:306
-#: ../gui/wxpython/menustrings.py:1212
-msgid "Raster to vector"
-msgstr "Raster ke vektor "
-#: ../gui/wxpython/menustrings.py:176 ../gui/wxpython/menustrings.py:307
-#: ../gui/wxpython/menustrings.py:1213
-#, fuzzy
-msgid "Converts a raster map into a vector map."
-#: ../gui/wxpython/menustrings.py:177 ../gui/wxpython/menustrings.py:308
-#: ../gui/wxpython/menustrings.py:1214
-#, fuzzy
-msgid "Raster series to 3D raster"
-#: ../gui/wxpython/menustrings.py:178 ../gui/wxpython/menustrings.py:309
-#: ../gui/wxpython/menustrings.py:1215
-msgid "Converts 2D raster map slices to one 3D raster volume map."
-msgstr "Ubah potongan peta raster2D ke satu peta volume raster 3D."
-#: ../gui/wxpython/menustrings.py:179 ../gui/wxpython/menustrings.py:310
-#: ../gui/wxpython/menustrings.py:1216
-#, fuzzy
-msgid "Raster 2.5D to 3D raster"
-msgstr "Raster 2.5D ke volume "
-#: ../gui/wxpython/menustrings.py:180 ../gui/wxpython/menustrings.py:311
-#: ../gui/wxpython/menustrings.py:1217
-msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
-msgstr ""
-"Buat sebuah peta volume 3D menggunakan peta elevasi 2D dan nilai raster."
-#: ../gui/wxpython/menustrings.py:181 ../gui/wxpython/menustrings.py:598
-#: ../gui/wxpython/menustrings.py:1504
-msgid "Vector to raster"
-msgstr "Vektor ke raster "
-#: ../gui/wxpython/menustrings.py:182 ../gui/wxpython/menustrings.py:599
-#: ../gui/wxpython/menustrings.py:1505
-#, fuzzy
-msgid "Converts (rasterize) a vector map into a raster map."
-msgstr ""
-"Ubah sebuah layer peta vektor GRASS biner ke dalam sebuah layer peta raster "
-"GRASS."
-#: ../gui/wxpython/menustrings.py:183 ../gui/wxpython/menustrings.py:600
-#: ../gui/wxpython/menustrings.py:1506
-#, fuzzy
-msgid "Vector to 3D raster"
-#: ../gui/wxpython/menustrings.py:184 ../gui/wxpython/menustrings.py:601
-#: ../gui/wxpython/menustrings.py:1507
-#, fuzzy
-msgid "Converts a vector map (only points) into a 3D raster map."
-msgstr ""
-"Ubah sebuah layer peta vektor GRASS biner (hanya titik) ke dalam sebuah "
-"layer peta raster GRASS 3D."
-#: ../gui/wxpython/menustrings.py:185 ../gui/wxpython/menustrings.py:602
-#: ../gui/wxpython/menustrings.py:1508
-#, fuzzy
-msgid "2D vector to 3D vector"
-#: ../gui/wxpython/menustrings.py:186 ../gui/wxpython/menustrings.py:603
-#: ../gui/wxpython/menustrings.py:1509
-msgid "Performs transformation of 2D vector features to 3D."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:187
-#, fuzzy
-msgid "3D raster to raster series"
-msgstr "Volume ke rangkaian raster"
-#: ../gui/wxpython/menustrings.py:188 ../gui/wxpython/menustrings.py:831
-#: ../gui/wxpython/menustrings.py:1737
-msgid "Converts 3D raster maps to 2D raster maps"
-msgstr "Ubah peta raster 3D ke peta raster 2D"
-#: ../gui/wxpython/menustrings.py:189 ../gui/wxpython/menustrings.py:1920
-msgid "Georectify"
-msgstr "Georektifikasi "
-#: ../gui/wxpython/menustrings.py:190 ../gui/wxpython/menustrings.py:1921
-#, fuzzy
-msgid "Manage Ground Control Points for Georectification"
-msgstr "Ground Control Points"
-#: ../gui/wxpython/menustrings.py:191 ../gui/wxpython/menustrings.py:1922
-msgid "Graphical modeler"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:192 ../gui/wxpython/menustrings.py:1923
-msgid "Launch Graphical modeler"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:193 ../gui/wxpython/menustrings.py:1973
-msgid "Run model"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:194
-msgid "Run model prepared by Graphical modeler"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:195
-#, fuzzy
-msgid "3D image rendering"
-msgstr "Jalankan rendering otomatis"
-#: ../gui/wxpython/menustrings.py:196 ../gui/wxpython/menustrings.py:1002
-#: ../gui/wxpython/menustrings.py:1908 ../gui/wxpython/menustrings.py:1915
-#, fuzzy
-msgid "Animation tool"
-msgstr "Kuantisasi "
-#: ../gui/wxpython/menustrings.py:197 ../gui/wxpython/menustrings.py:1003
-#: ../gui/wxpython/menustrings.py:1909 ../gui/wxpython/menustrings.py:1916
-msgid "Launch animation tool."
-msgstr ""
-msgid "Bearing/distance to coordinates"
-msgstr "Arah/jarak ke koordinat"
-#: ../gui/wxpython/menustrings.py:199
-msgid ""
-"A simple utility for converting bearing and distance measurements to "
-"coordinates and vice versa. It assumes a cartesian coordinate system"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:201 ../gui/wxpython/menustrings.py:1919
-msgid "Launch Cartographic Composer"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:202 ../gui/wxpython/menustrings.py:1926
-#, fuzzy
-msgid "Map Swipe"
-msgstr "Tipe layer peta:"
-#: ../gui/wxpython/menustrings.py:203 ../gui/wxpython/menustrings.py:1927
-#, fuzzy
-msgid "Launch Map Swipe"
-msgstr "Deskripsi layer"
-#: ../gui/wxpython/menustrings.py:204
-#, fuzzy
-msgid "Launch script"
-#: ../gui/wxpython/menustrings.py:205
-#, fuzzy
-msgid "Launches script file."
-msgstr "Pilih berkas workspace"
-#: ../gui/wxpython/menustrings.py:207
-#, fuzzy
-msgid "Quit wxGUI session."
-msgstr "Keluar GUI"
-#: ../gui/wxpython/menustrings.py:209
-msgid "Quit wxGUI session and exit GRASS shell."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:210 ../gui/wxpython/menustrings.py:1951
-#, fuzzy
-msgid "&Settings"
-#: ../gui/wxpython/menustrings.py:211
-msgid "Region"
-msgstr "Region "
-#: ../gui/wxpython/menustrings.py:212
-msgid "Display region"
-msgstr "Tampilan region"
-#: ../gui/wxpython/menustrings.py:213 ../gui/wxpython/menustrings.py:215
-msgid "Manages the boundary definitions for the geographic region."
-msgstr "Kelola definisi batas untuk region geografik."
-#: ../gui/wxpython/menustrings.py:214
-msgid "Set region"
-msgstr "Set region"
-#: ../gui/wxpython/menustrings.py:216
-msgid "GRASS working environment"
-msgstr "Lingkungan kerja GRASS "
-#: ../gui/wxpython/menustrings.py:217
-msgid "Mapset access"
-msgstr "Akses mapset "
-#: ../gui/wxpython/menustrings.py:218
-msgid "Set/unset access to other mapsets in current location"
-msgstr "Hidupkan/matikan akses ke mapset lain dalam location saat ini"
-#: ../gui/wxpython/menustrings.py:219
-msgid "User access"
-msgstr "Akses pengguna "
-#: ../gui/wxpython/menustrings.py:220
-#, fuzzy
-msgid ""
-"Controls access to the current mapset for other users on the system. If no "
-"option given, prints current status."
-msgstr "Kendalikan akses ke mapset saat ini untuk pengguna lain dalam sistem."
-#: ../gui/wxpython/menustrings.py:221
-msgid "Change working environment"
-msgstr "Ubah lingkungan kerja "
-#: ../gui/wxpython/menustrings.py:222
-msgid ""
-"Changes/reports current mapset. Optionally create new mapset or list "
-"available mapsets in given location."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:223
-#, fuzzy
-msgid "Change location and mapset"
-msgstr "Pilih location dan mapset proyek"
-#: ../gui/wxpython/menustrings.py:224
-#, fuzzy
-msgid "Change current location and mapset."
-#: ../gui/wxpython/menustrings.py:225
-#, fuzzy
-msgid "Change mapset"
-msgstr "Buat mapset"
-#: ../gui/wxpython/menustrings.py:226
-msgid "Change current mapset."
-msgstr "Ubah mapset saat ini."
-#: ../gui/wxpython/menustrings.py:227 ../gui/wxpython/menustrings.py:228
-#, fuzzy
-msgid "Change working directory"
-#: ../gui/wxpython/menustrings.py:229
-msgid "Show settings"
-msgstr "Perlihatkan pengaturan "
-#: ../gui/wxpython/menustrings.py:230
-msgid "Outputs and modifies the user's current GRASS variable settings."
-msgstr ""
-"Keluaran dan mofikasi pengaturan variabel GRASS dari pengguna saat ini."
-#: ../gui/wxpython/menustrings.py:231
-msgid "Change settings"
-msgstr "Ubah pengaturan "
-#: ../gui/wxpython/menustrings.py:232
-#, fuzzy
-msgid ""
-"Outputs and modifies the user's current GRASS variable settings. Prints all "
-"defined GRASS variables if no option is given."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:233
-#, fuzzy
-msgid "Create new location"
-#: ../gui/wxpython/menustrings.py:234
-#, fuzzy
-msgid "Launches location wizard to create new GRASS location."
-msgstr "Apakah Anda hendak membuat GRASS location <%s>?"
-#: ../gui/wxpython/menustrings.py:236
-#, fuzzy
-msgid "Creates new mapset in the current location, changes current mapset."
-#: ../gui/wxpython/menustrings.py:237
-#, fuzzy
-msgid "Version and copyright"
-msgstr "Tampilkan versi dan informasi copyright."
-#: ../gui/wxpython/menustrings.py:238
-msgid "Displays version and copyright information."
-#: ../gui/wxpython/menustrings.py:239
-#, fuzzy
-msgid "Map projections"
-msgstr "Pengaturan proyeksi"
-#: ../gui/wxpython/menustrings.py:240
-#, fuzzy
-msgid "Display map projection"
-#: ../gui/wxpython/menustrings.py:241
-#, fuzzy
-msgid ""
-"Converts co-ordinate system descriptions (i.e. projection information) "
-"between various formats (including GRASS format)."
-msgstr ""
-"Ubah deskripsi sistem koordinat (yaitu informasi proyeksi) antara beragam "
-"format (termasuk format GRASS). Dapat juga digunakan untuk membuat GRASS "
-"location."
-#: ../gui/wxpython/menustrings.py:242
-msgid "Manage projections"
-#: ../gui/wxpython/menustrings.py:243
-msgid ""
-"Prints or modifies GRASS projection information files (in various co-"
-"ordinate system descriptions). Can also be used to create new GRASS "
-"locations."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:244
-msgid "Convert coordinates"
-msgstr "Konversi koordinat "
-#: ../gui/wxpython/menustrings.py:245
-#, fuzzy
-msgid "Converts coordinates from one projection to another (cs2cs frontend)."
-msgstr ""
-"Ubah koordinat dari satu proyeksi ke proyeksi lainnya (cs2cs frontend)."
-#: ../gui/wxpython/menustrings.py:246
-#, fuzzy
-msgid "Addons extensions"
-#: ../gui/wxpython/menustrings.py:247
-#, fuzzy
-msgid "Install extension from addons"
-#: ../gui/wxpython/menustrings.py:248
-msgid "Installs new extension from GRASS AddOns SVN repository."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:249
-#, fuzzy
-msgid "Manage installed extension"
-#: ../gui/wxpython/menustrings.py:250
-#, fuzzy
-msgid "Updates or removes installed GRASS AddOns extension(s)."
-#: ../gui/wxpython/menustrings.py:251 ../gui/wxpython/menustrings.py:1952
-msgid "Preferences"
-msgstr "Pilihan pengaturan"
-#: ../gui/wxpython/menustrings.py:252
-msgid "User GUI preferences (display font, commands, digitizer, etc.)"
-msgstr ""
-"Pilihan pengaturan GUI untuk pengguna (jenis huruf display, perintah, "
-"digitasi, dsb.)"
-#: ../gui/wxpython/menustrings.py:253 ../gui/wxpython/menustrings.py:1159
-#, fuzzy
-msgid "&Raster"
-msgstr "Raster"
-#: ../gui/wxpython/menustrings.py:254 ../gui/wxpython/menustrings.py:1160
-msgid "Develop raster map"
-msgstr "Bangun peta raster"
-#: ../gui/wxpython/menustrings.py:255 ../gui/wxpython/menustrings.py:1161
-msgid "Compress/decompress"
-msgstr "Kompresi/dekompresi "
-#: ../gui/wxpython/menustrings.py:256 ../gui/wxpython/menustrings.py:1162
-msgid "Compresses and decompresses raster maps."
-msgstr "Kompresi dan dekompresi peta raster."
-#: ../gui/wxpython/menustrings.py:257 ../gui/wxpython/menustrings.py:1163
-msgid "Region boundaries"
-msgstr "Batas region"
-#: ../gui/wxpython/menustrings.py:258 ../gui/wxpython/menustrings.py:1164
-msgid "Sets the boundary definitions for a raster map."
-msgstr "Tentukan definisi batas untuk sebuah peta raster."
-#: ../gui/wxpython/menustrings.py:259 ../gui/wxpython/menustrings.py:1165
-msgid "Manage NULL values"
-msgstr "Kelola nilai NULL"
-#: ../gui/wxpython/menustrings.py:260 ../gui/wxpython/menustrings.py:1166
-msgid "Manages NULL-values of given raster map."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:261 ../gui/wxpython/menustrings.py:1167
-msgid "Quantization"
-#: ../gui/wxpython/menustrings.py:262 ../gui/wxpython/menustrings.py:1168
-msgid "Produces the quantization file for a floating-point map."
-msgstr "Hasilkan berkas kuantisasi untuk peta floating-point."
-#: ../gui/wxpython/menustrings.py:263 ../gui/wxpython/menustrings.py:1169
-msgid "Timestamp"
-msgstr "Catatan waktu"
-#: ../gui/wxpython/menustrings.py:264 ../gui/wxpython/menustrings.py:1170
-#, fuzzy
-msgid ""
-"Modifies a timestamp for a raster map. Print/add/remove a timestamp for a "
-"raster map."
-msgstr "Cetak/tambah/hapus catatan waktu untuk peta raster 3D"
-#: ../gui/wxpython/menustrings.py:265 ../gui/wxpython/menustrings.py:1171
-msgid "Resample using aggregate statistics"
-msgstr "Cuplik-ulang menggunakan statistik rerata"
-#: ../gui/wxpython/menustrings.py:266 ../gui/wxpython/menustrings.py:1172
-#, fuzzy
-msgid "Resamples raster map layers to a coarser grid using aggregation."
-msgstr "Cuplik-ulang layer peta raster dengan agregasi."
-#: ../gui/wxpython/menustrings.py:267 ../gui/wxpython/menustrings.py:1173
-msgid "Resample using multiple methods"
-msgstr "Cuplik-ulang dengan metoda berganda "
-#: ../gui/wxpython/menustrings.py:268 ../gui/wxpython/menustrings.py:1174
-#, fuzzy
-msgid "Resamples raster map to a finer grid using interpolation."
-msgstr "Cuplik-ulang layer peta raster dengan interpolasi."
-#: ../gui/wxpython/menustrings.py:269 ../gui/wxpython/menustrings.py:1175
-msgid "Resample using nearest neighbor"
-msgstr "Cuplik-ulang dengan tetangga-terdekat "
-#: ../gui/wxpython/menustrings.py:270 ../gui/wxpython/menustrings.py:1176
-msgid "GRASS raster map layer data resampling capability."
-msgstr "Kemampuan cuplik-ulang data dari layer peta raster GRASS."
-#: ../gui/wxpython/menustrings.py:271 ../gui/wxpython/menustrings.py:1177
-msgid "Resample using spline tension"
-msgstr "Cuplik-ulang dengan spline tension "
-#: ../gui/wxpython/menustrings.py:272 ../gui/wxpython/menustrings.py:1178
-msgid ""
-"Reinterpolates and optionally computes topographic analysis from input "
-"raster map to a new raster map (possibly with different resolution) using "
-"regularized spline with tension and smoothing."
-msgstr ""
-"Interpolasi-ulang dan secara opsional menghitung analisis topografik dari "
-"input peta raster ke peta raster baru (bisa dengan resolusi yang berbeda) "
-"menggunakan regularized spline with tension dan smoothing."
-#: ../gui/wxpython/menustrings.py:273 ../gui/wxpython/menustrings.py:1179
-#, fuzzy
-msgid "Resample using bspline"
-#: ../gui/wxpython/menustrings.py:274 ../gui/wxpython/menustrings.py:1180
-#, fuzzy
-msgid ""
-"Performs bilinear or bicubic spline interpolation with Tykhonov "
-"regularization."
-msgstr ""
-"Interpolasi bikubik atau bilinear spline dengan regularisasi Thykhonov."
-#: ../gui/wxpython/menustrings.py:275 ../gui/wxpython/menustrings.py:1181
-#, fuzzy
-msgid "Resample using analytic kernel"
-#: ../gui/wxpython/menustrings.py:276 ../gui/wxpython/menustrings.py:1182
-#, fuzzy
-msgid "Resamples raster map layers using an analytic kernel."
-#: ../gui/wxpython/menustrings.py:277 ../gui/wxpython/menustrings.py:561
-#: ../gui/wxpython/menustrings.py:1183 ../gui/wxpython/menustrings.py:1467
-msgid "Support file maintenance"
-msgstr "Dukungan pemeliharaan berkas"
-#: ../gui/wxpython/menustrings.py:278 ../gui/wxpython/menustrings.py:1184
-msgid "Allows creation and/or modification of raster map layer support files."
-msgstr ""
-"Ijinkan pembuatan dan/atau modifikasi berkas dukungan layer peta raster."
-#: ../gui/wxpython/menustrings.py:279 ../gui/wxpython/menustrings.py:1185
-msgid "Update map statistics"
-msgstr "Perbaharui statistik peta "
-#: ../gui/wxpython/menustrings.py:280 ../gui/wxpython/menustrings.py:1186
-msgid "Update raster map statistics"
-msgstr "Perbaharui statistik peta raster"
-#: ../gui/wxpython/menustrings.py:283 ../gui/wxpython/menustrings.py:1189
-#, fuzzy
-msgid "Tiling"
-msgstr "Tiling "
-#: ../gui/wxpython/menustrings.py:284 ../gui/wxpython/menustrings.py:1190
-msgid ""
-"Produces tilings of the source projection for use in the destination region "
-"and projection."
-msgstr ""
-"Hasilkan tilings dari proyeksi asal untuk digunakan dalam region dan "
-"proyeksi target."
-#: ../gui/wxpython/menustrings.py:285 ../gui/wxpython/menustrings.py:580
-#: ../gui/wxpython/menustrings.py:1191 ../gui/wxpython/menustrings.py:1486
-msgid "Manage colors"
-msgstr "Kelola warna"
-#: ../gui/wxpython/menustrings.py:286 ../gui/wxpython/menustrings.py:581
-#: ../gui/wxpython/menustrings.py:1192 ../gui/wxpython/menustrings.py:1487
-msgid "Color tables"
-msgstr "Tabel warna "
-#: ../gui/wxpython/menustrings.py:287 ../gui/wxpython/menustrings.py:1193
-#, fuzzy
-msgid "Creates/modifies the color table associated with a raster map."
-msgstr "Buat/modifikasi tabel warna berkaitan dengan sebuah layer peta raster."
-#: ../gui/wxpython/menustrings.py:288 ../gui/wxpython/menustrings.py:1194
-#, fuzzy
-msgid "Color tables (stddev)"
-#: ../gui/wxpython/menustrings.py:289 ../gui/wxpython/menustrings.py:1195
-msgid "Sets color rules based on stddev from a raster map's mean value."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:290 ../gui/wxpython/menustrings.py:583
-#: ../gui/wxpython/menustrings.py:1196 ../gui/wxpython/menustrings.py:1489
-#, fuzzy
-msgid "Manage color rules interactively"
-msgstr "Pengkodean-ulang secara interaktif "
-#: ../gui/wxpython/menustrings.py:291 ../gui/wxpython/menustrings.py:1197
-#, fuzzy
-msgid "Interactive management of raster color tables."
-#: ../gui/wxpython/menustrings.py:292 ../gui/wxpython/menustrings.py:585
-#: ../gui/wxpython/menustrings.py:1198 ../gui/wxpython/menustrings.py:1491
-#, fuzzy
-msgid "Export color table"
-#: ../gui/wxpython/menustrings.py:293 ../gui/wxpython/menustrings.py:1199
-#, fuzzy
-msgid "Exports the color table associated with a raster map."
-#: ../gui/wxpython/menustrings.py:294 ../gui/wxpython/menustrings.py:1200
-msgid "Blend 2 color rasters"
-msgstr "Campurkan 2 warna raster"
-#: ../gui/wxpython/menustrings.py:295 ../gui/wxpython/menustrings.py:1201
-msgid "Blends color components of two raster maps by a given ratio."
-msgstr ""
-"Campurkan komponen warna dari dua peta raster berdasarkan rasio tertentu."
-#: ../gui/wxpython/menustrings.py:296 ../gui/wxpython/menustrings.py:1202
-msgid "Create RGB"
-msgstr "Buat RGB "
-#: ../gui/wxpython/menustrings.py:297 ../gui/wxpython/menustrings.py:1203
-#, fuzzy
-msgid ""
-"Combines red, green and blue raster maps into a single composite raster map."
-msgstr ""
-"Gabungkan layer peta red, green dan blue menjadi satu layer peta komposit."
-#: ../gui/wxpython/menustrings.py:298 ../gui/wxpython/menustrings.py:736
-#: ../gui/wxpython/menustrings.py:1204 ../gui/wxpython/menustrings.py:1642
-msgid "RGB to HIS"
-msgstr "RGB ke HIS "
-#: ../gui/wxpython/menustrings.py:299 ../gui/wxpython/menustrings.py:1205
-#, fuzzy
-msgid ""
-"Generates red, green and blue (RGB) raster map layers combining hue, "
-"intensity and saturation (HIS) values from user-specified input raster map "
-"layers."
-msgstr ""
-"Hasilkan layer peta red, green dan blue dengan menggabungkan nilai hue, "
-"intensity dan saturation (HIS) dari layer peta input raster yang ditentukan "
-"oleh pengguna."
-#: ../gui/wxpython/menustrings.py:300 ../gui/wxpython/menustrings.py:1206
-#, fuzzy
-msgid "Query raster maps"
-msgstr "Tumpang-susun peta raster"
-#: ../gui/wxpython/menustrings.py:301 ../gui/wxpython/menustrings.py:1207
-#, fuzzy
-msgid "Query values by coordinates"
-msgstr "Kueri dengan koordinat"
-#: ../gui/wxpython/menustrings.py:302 ../gui/wxpython/menustrings.py:1208
-#, fuzzy
-msgid "Queries raster maps on their category values and category labels."
-msgstr "Kueri layer peta raster berdasarkan nilai dan label kategori."
-#: ../gui/wxpython/menustrings.py:303 ../gui/wxpython/menustrings.py:1209
-#, fuzzy
-msgid "Query colors by value"
-#: ../gui/wxpython/menustrings.py:304 ../gui/wxpython/menustrings.py:1210
-#, fuzzy
-msgid "Queries colors for a raster map layer."
-msgstr "Statistik laporan untuk layer peta raster."
-#: ../gui/wxpython/menustrings.py:312 ../gui/wxpython/menustrings.py:1218
-#, fuzzy
-msgid "Raster buffers and distance"
-msgstr "Pengukuran jarak"
-#: ../gui/wxpython/menustrings.py:313 ../gui/wxpython/menustrings.py:1219
-msgid "Buffer rasters"
-msgstr "Buffer raster"
-#: ../gui/wxpython/menustrings.py:314 ../gui/wxpython/menustrings.py:1220
-#, fuzzy
-msgid ""
-"Creates a raster map showing buffer zones surrounding cells that contain non-"
-"NULL category values."
-msgstr ""
-"Buat sebuah layer peta raster yang memperlihatkan zona buffer di sekeliling "
-"sel yang mengandung nilai kategori non-NULL."
-#: ../gui/wxpython/menustrings.py:315 ../gui/wxpython/menustrings.py:1221
-msgid "Concentric circles"
-msgstr "Lingkaran konsentrik"
-#: ../gui/wxpython/menustrings.py:316 ../gui/wxpython/menustrings.py:1222
-msgid "Creates a raster map containing concentric rings around a given point."
-msgstr ""
-"Membuat sebuah peta raster yang memiliki cincin konsentrik di sekitar titik "
-"tertentu."
-#: ../gui/wxpython/menustrings.py:317 ../gui/wxpython/menustrings.py:1223
-msgid "Closest points"
-msgstr "Titik terdekat"
-#: ../gui/wxpython/menustrings.py:318 ../gui/wxpython/menustrings.py:1224
-msgid "Locates the closest points between objects in two raster maps."
-msgstr "Cari titik terdekat antara obyek-obyek dalam dua peta raster."
-#: ../gui/wxpython/menustrings.py:319 ../gui/wxpython/menustrings.py:1225
-msgid "Grow by one cell"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:320 ../gui/wxpython/menustrings.py:383
-#: ../gui/wxpython/menustrings.py:1226 ../gui/wxpython/menustrings.py:1289
-msgid "Generates a raster map layer with contiguous areas grown by one cell."
-msgstr ""
-"Hasilkan sebuah layer peta raster dengan area bersambungan yang dikembangkan "
-"dari satu sel."
-#: ../gui/wxpython/menustrings.py:321 ../gui/wxpython/menustrings.py:375
-#: ../gui/wxpython/menustrings.py:1227 ../gui/wxpython/menustrings.py:1281
-#, fuzzy
-msgid "Distance to features"
-msgstr "Fitur terdekat"
-#: ../gui/wxpython/menustrings.py:322 ../gui/wxpython/menustrings.py:376
-#: ../gui/wxpython/menustrings.py:1228 ../gui/wxpython/menustrings.py:1282
-#, fuzzy
-msgid "Generates a raster map containing distances to nearest raster features."
-msgstr ""
-"dari satu sel."
-#: ../gui/wxpython/menustrings.py:324 ../gui/wxpython/menustrings.py:1230
-#, fuzzy
-msgid "Creates a MASK for limiting raster operation."
-msgstr "Buat sebuah MASK untuk membatasi operasi raster"
-#: ../gui/wxpython/menustrings.py:325 ../gui/wxpython/menustrings.py:326
-#: ../gui/wxpython/menustrings.py:1231 ../gui/wxpython/menustrings.py:1232
-#, fuzzy
-msgid "Raster map calculator"
-msgstr "Kalkulator peta raster 3D"
-#: ../gui/wxpython/menustrings.py:327 ../gui/wxpython/menustrings.py:1233
-msgid "Neighborhood analysis"
-msgstr "Analisis tetangga-terdekat "
-#: ../gui/wxpython/menustrings.py:329 ../gui/wxpython/menustrings.py:1235
-msgid ""
-"Makes each cell category value a function of the category values assigned to "
-"the cells around it, and stores new cell values in an output raster map "
-"layer."
-msgstr ""
-"Buat setiap nilai kategori sel sebuah fungsi dari nilai kategori yang "
-"ditetapkan pada sel di sekitarnya, dan simpan nilai sel baru dalam sebuah "
-"layer peta raster output."
-#: ../gui/wxpython/menustrings.py:330 ../gui/wxpython/menustrings.py:1236
-msgid "Neighborhood points"
-msgstr "Titik tetangga-terdekat "
-#: ../gui/wxpython/menustrings.py:331 ../gui/wxpython/menustrings.py:1237
-#, fuzzy
-msgid ""
-"Neighborhood analysis tool for vector point maps. Makes each cell value a "
-"function of the attribute values assigned to the vector points or centroids "
-"around it, and stores new cell values in an output raster map."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:332 ../gui/wxpython/menustrings.py:1238
-msgid "Overlay rasters"
-msgstr "Tumpang-susunkan raster"
-#: ../gui/wxpython/menustrings.py:333 ../gui/wxpython/menustrings.py:1239
-msgid "Cross product"
-msgstr "Produk gabungan "
-#: ../gui/wxpython/menustrings.py:334 ../gui/wxpython/menustrings.py:1240
-msgid ""
-"Creates a cross product of the category values from multiple raster map "
-"layers."
-msgstr ""
-"Buat sebuah produk gabungan nilai kategori dari banyak layer peta raster."
-#: ../gui/wxpython/menustrings.py:335 ../gui/wxpython/menustrings.py:1241
-msgid "Patch raster maps"
-#: ../gui/wxpython/menustrings.py:336 ../gui/wxpython/menustrings.py:1242
-msgid ""
-"Creates a composite raster map layer by using known category values from one "
-"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
-msgstr ""
-"Buat sebuah layer peta raster komposit dengan menggunakan nilai kategori "
-"yang diketahui dari satu (atau lebih) layer peta untuk mengisi area \"no data"
-"\" dari layer peta yang lain."
-#: ../gui/wxpython/menustrings.py:337 ../gui/wxpython/menustrings.py:1243
-#, fuzzy
-msgid "Raster series aggregation"
-msgstr "Seri raster"
-#: ../gui/wxpython/menustrings.py:338 ../gui/wxpython/menustrings.py:1244
-msgid ""
-"Makes each output cell value a function of the values assigned to the "
-"corresponding cells in the input raster map layers."
-msgstr ""
-"Buat setiap nilai sel output sebuah fungsi dari nilai yang ditetapkan ke sel "
-"yang terkait dalam layer peta raster input."
-#: ../gui/wxpython/menustrings.py:339 ../gui/wxpython/menustrings.py:1245
-#, fuzzy
-msgid "Raster series accumulation"
-#: ../gui/wxpython/menustrings.py:340 ../gui/wxpython/menustrings.py:1246
-#, fuzzy
-msgid ""
-"Makes each output cell value a accumulationfunction of the values assigned "
-"to the corresponding cells in the input raster map layers."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:341 ../gui/wxpython/menustrings.py:1247
-msgid "Statistical overlay"
-msgstr "Tumpang-susun berbasis statistik "
-#: ../gui/wxpython/menustrings.py:342 ../gui/wxpython/menustrings.py:1248
-#, fuzzy
-msgid ""
-"Calculates category or object oriented statistics (accumulator-based "
-"statistics)."
-msgstr "Hitung kategori atau statistik berbasis obyek."
-#: ../gui/wxpython/menustrings.py:343 ../gui/wxpython/menustrings.py:1249
-#, fuzzy
-msgid "Quantiles overlay"
-#: ../gui/wxpython/menustrings.py:344 ../gui/wxpython/menustrings.py:1250
-msgid "Compute category quantiles using two passes."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:345 ../gui/wxpython/menustrings.py:1251
-msgid "Solar radiance and shadows"
-msgstr "Radiansi matahari dan bayangan "
-#: ../gui/wxpython/menustrings.py:346 ../gui/wxpython/menustrings.py:1252
-msgid "LatLong map"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:347 ../gui/wxpython/menustrings.py:1253
-#, fuzzy
-msgid "Creates a latitude/longitude raster map."
-msgstr "Buat peta vektor baru"
-#: ../gui/wxpython/menustrings.py:348 ../gui/wxpython/menustrings.py:1254
-msgid "Solar irradiance and irradiation"
-msgstr "Irradiansi matahari dan irradiasi"
-#: ../gui/wxpython/menustrings.py:349 ../gui/wxpython/menustrings.py:1255
-msgid ""
-"Solar irradiance and irradiation model. Computes direct (beam), diffuse and "
-"reflected solar irradiation raster maps for given day, latitude, surface and "
-"atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, "
-"declination, extraterrestrial irradiance, daylight length) are saved in the "
-"map history file. Alternatively, a local time can be specified to compute "
-"solar incidence angle and/or irradiance raster maps. The shadowing effect of "
-"the topography is optionally incorporated."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:350 ../gui/wxpython/menustrings.py:1256
-msgid "Shadows map"
-#: ../gui/wxpython/menustrings.py:351 ../gui/wxpython/menustrings.py:1257
-msgid ""
-"Calculates cast shadow areas from sun position and elevation raster map. "
-"Either exact sun position (A) is specified, or date/time to calculate the "
-"sun position (B) by r.sunmask itself."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:352 ../gui/wxpython/menustrings.py:1258
-#, fuzzy
-msgid "Sunshine hours and solar angles"
-#: ../gui/wxpython/menustrings.py:353 ../gui/wxpython/menustrings.py:1259
-msgid ""
-"Calculates solar elevation, solar azimuth, and sun hours. Solar elevation: "
-"the angle between the direction of the geometric center of the sun's "
-"apparent disk and the (idealized) horizon. Solar azimuth: the angle from due "
-"north in clockwise direction."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:354 ../gui/wxpython/menustrings.py:1260
-msgid "Terrain analysis"
-msgstr "Analisis medan"
-#: ../gui/wxpython/menustrings.py:355 ../gui/wxpython/menustrings.py:1261
-msgid "Generate contour lines"
-msgstr "Hasilkan garis kontur"
-#: ../gui/wxpython/menustrings.py:356 ../gui/wxpython/menustrings.py:1262
-#, fuzzy
-msgid "Produces a vector map of specified contours from a raster map."
-msgstr ""
-"Hasilkan sebuah layer peta vektor kontur tertentu dari sebuah layer peta "
-"raster."
-#: ../gui/wxpython/menustrings.py:357 ../gui/wxpython/menustrings.py:1263
-msgid "Cost surface"
-msgstr "Cost surface"
-#: ../gui/wxpython/menustrings.py:358 ../gui/wxpython/menustrings.py:1264
-#, fuzzy
-msgid ""
-"Creates a raster map showing the cumulative cost of moving between different "
-"geographic locations on an input raster map whose cell category values "
-"represent cost."
-msgstr ""
-"Keluaran sebuah layer peta raster yang memperlihatkan biaya kumulatif "
-"pergerakan antara lokasi geografis yang berbeda pada sebuah layer peta "
-"raster input yang nilai kategori selnya menggambarkan biaya."
-#: ../gui/wxpython/menustrings.py:359 ../gui/wxpython/menustrings.py:1265
-msgid "Cumulative movement costs"
-msgstr "Biaya pergerakan kumulatif "
-#: ../gui/wxpython/menustrings.py:360 ../gui/wxpython/menustrings.py:1266
-#, fuzzy
-msgid ""
-"Creates a raster map showing the anisotropic cumulative cost of moving "
-"between different geographic locations on an input raster map whose cell "
-"category values represent cost."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:361 ../gui/wxpython/menustrings.py:1267
-msgid "Least cost route or flow"
-msgstr "Rute atau aliran biaya termurah "
-#: ../gui/wxpython/menustrings.py:362 ../gui/wxpython/menustrings.py:1268
-#, fuzzy
-msgid ""
-"Traces a flow through an elevation model or cost surface on a raster map."
-msgstr ""
-"Menjejak sebuah aliran melalui sebuah model ketinggi dari satu layer peta "
-"raster. "
-#: ../gui/wxpython/menustrings.py:363 ../gui/wxpython/menustrings.py:1269
-#, fuzzy
-msgid "Compute shaded relief"
-msgstr "Relief berbayang "
-#: ../gui/wxpython/menustrings.py:364 ../gui/wxpython/menustrings.py:1270
-#, fuzzy
-msgid "Creates shaded relief map from an elevation map (DEM). "
-msgstr "Membuat sebuah peta relief bayangan dari satu peta ketinggian (DEM)."
-#: ../gui/wxpython/menustrings.py:365 ../gui/wxpython/menustrings.py:1271
-#, fuzzy
-msgid "Apply shade to raster"
-#: ../gui/wxpython/menustrings.py:366 ../gui/wxpython/menustrings.py:1272
-msgid "Drapes a color raster over an shaded relief or aspect map."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:367 ../gui/wxpython/menustrings.py:1273
-msgid "Slope and aspect"
-msgstr "Kemiringan dan aspek "
-#: ../gui/wxpython/menustrings.py:368 ../gui/wxpython/menustrings.py:1274
-#, fuzzy
-msgid ""
-"Generates raster maps of slope, aspect, curvatures and partial derivatives "
-"from an elevation raster map. Aspect is calculated counterclockwise from "
-"east."
-msgstr ""
-"Menghasilkan layer peta raster kemiringan, aspek, curvature dan turunan "
-"parsialnya dari satu layer peta raster nilai ketinggian. Aspek dihitung "
-"berlawanan arah jarum jam dari timur."
-#: ../gui/wxpython/menustrings.py:369 ../gui/wxpython/menustrings.py:1275
-msgid "Terrain parameters"
-msgstr "Parameter medan"
-#: ../gui/wxpython/menustrings.py:370 ../gui/wxpython/menustrings.py:1276
-msgid ""
-"Extracts terrain parameters from a DEM. Uses a multi-scale approach by "
-"taking fitting quadratic parameters to any size window (via least squares)."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:371 ../gui/wxpython/menustrings.py:1277
-msgid "Textural features"
-msgstr "Fitur tekstural "
-#: ../gui/wxpython/menustrings.py:372 ../gui/wxpython/menustrings.py:1278
-msgid "Generate images with textural features from a raster map."
-msgstr "Hasilkan citra dengan fitur tekstur dari sebuah peta raster."
-#: ../gui/wxpython/menustrings.py:373 ../gui/wxpython/menustrings.py:1279
-msgid "Visibility"
-msgstr "Visibilitas "
-#: ../gui/wxpython/menustrings.py:374 ../gui/wxpython/menustrings.py:1280
-#, fuzzy
-msgid ""
-"Computes the viewshed of a point on an elevation raster map. Default format: "
-"NULL (invisible), vertical angle wrt viewpoint (visible)."
-msgstr ""
-"Menghitung kontras dari index kepadatan tepian terbeban pada sebuah peta "
-"raster "
-#: ../gui/wxpython/menustrings.py:377 ../gui/wxpython/menustrings.py:1283
-msgid "Horizon angle"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:378 ../gui/wxpython/menustrings.py:1284
-msgid ""
-"Computes horizon angle height from a digital elevation model. The module has "
-"two different modes of operation: 1. Computes the entire horizon around a "
-"single point whose coordinates are given with the 'coord' option. The "
-"horizon height (in radians). 2. Computes one or more raster maps of the "
-"horizon height in a single direction. The input for this is the angle (in "
-"degrees), which is measured counterclockwise with east=0, north=90 etc. The "
-"output is the horizon height in radians."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:379 ../gui/wxpython/menustrings.py:1285
-msgid "Transform features"
-msgstr "Transformasi fitur "
-#: ../gui/wxpython/menustrings.py:380 ../gui/wxpython/menustrings.py:1286
-msgid "Clump"
-msgstr "Clump"
-#: ../gui/wxpython/menustrings.py:381 ../gui/wxpython/menustrings.py:1287
-#, fuzzy
-msgid ""
-"Recategorizes data in a raster map by grouping cells that form physically "
-"discrete areas into unique categories."
-msgstr ""
-"Kategori-ulang data dalam sebuah layer peta raster dengan mengelompokkan sel "
-"yang secara fisik membentuk area diskrit ke dalam sebuah kategori unik. "
-#: ../gui/wxpython/menustrings.py:382 ../gui/wxpython/menustrings.py:1288
-msgid "Grow"
-msgstr "Kembangan "
-#: ../gui/wxpython/menustrings.py:384 ../gui/wxpython/menustrings.py:1290
-msgid "Thin"
-msgstr "Tipis"
-#: ../gui/wxpython/menustrings.py:385 ../gui/wxpython/menustrings.py:1291
-#, fuzzy
-msgid "Thins non-null cells that denote linear features in a raster map layer."
-msgstr ""
-"Sel thin non-zero yang mewakili fitur linear dalam sebuah layer peta raster."
-#: ../gui/wxpython/menustrings.py:386 ../gui/wxpython/menustrings.py:1292
-msgid "Hydrologic modeling"
-msgstr "Pemodelan hidrologis "
-#: ../gui/wxpython/menustrings.py:387 ../gui/wxpython/menustrings.py:1293
-msgid "Carve stream channels"
-msgstr "Pahat kanal sungai"
-#: ../gui/wxpython/menustrings.py:388 ../gui/wxpython/menustrings.py:1294
-msgid ""
-"Generates stream channels. Takes vector stream data, transforms it to raster "
-"and subtracts depth from the output DEM."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:389 ../gui/wxpython/menustrings.py:1295
-msgid "Fill lake"
-msgstr "Isi danau "
-#: ../gui/wxpython/menustrings.py:390 ../gui/wxpython/menustrings.py:1296
-#, fuzzy
-msgid "Fills lake at given point to given level."
-msgstr "Isi danau dari seed pada level tertentu"
-#: ../gui/wxpython/menustrings.py:391 ../gui/wxpython/menustrings.py:1297
-msgid "Depressionless map and flowlines"
-msgstr "Peta depressionless dan garis aliran"
-#: ../gui/wxpython/menustrings.py:392 ../gui/wxpython/menustrings.py:1298
-#, fuzzy
-msgid ""
-"Filters and generates a depressionless elevation map and a flow direction "
-"map from a given elevation raster map."
-msgstr ""
-"Saring dan hasilkan peta ketinggian depressionless dan sebuah peta arah "
-"aliran dari satu layer ketinggian tertentu."
-#: ../gui/wxpython/menustrings.py:393 ../gui/wxpython/menustrings.py:1299
-msgid "Flow accumulation"
-msgstr "Akumulasi aliran "
-#: ../gui/wxpython/menustrings.py:394 ../gui/wxpython/menustrings.py:1300
-#, fuzzy
-msgid "Performs flow computation for massive grids. Float version."
-msgstr "Komputasi aliran untuk grid masif (versi float)."
-#: ../gui/wxpython/menustrings.py:395 ../gui/wxpython/menustrings.py:1301
-msgid "Flow lines"
-msgstr "Garis aliran "
-#: ../gui/wxpython/menustrings.py:396 ../gui/wxpython/menustrings.py:1302
-msgid ""
-"Constructs flowlines. Computes flowlines, flowpath lengths, and "
-"flowaccumulation (contributing areas) from a elevation raster map."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:397 ../gui/wxpython/menustrings.py:1303
-msgid "Watershed analysis"
-msgstr "Analisis tangkapan air "
-#: ../gui/wxpython/menustrings.py:398 ../gui/wxpython/menustrings.py:1304
-msgid "Calculates hydrological parameters and RUSLE factors."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:399 ../gui/wxpython/menustrings.py:1305
-msgid "Watershed subbasins"
-msgstr "Subbasin tangkapan air "
-#: ../gui/wxpython/menustrings.py:400 ../gui/wxpython/menustrings.py:1306
-#, fuzzy
-msgid "Generates watershed subbasins raster map."
-msgstr "Menghasilkan statistik area untuk layer peta raster."
-#: ../gui/wxpython/menustrings.py:401 ../gui/wxpython/menustrings.py:1307
-msgid "Watershed basin creation"
-msgstr "Pembuatan basin tangkapan air"
-#: ../gui/wxpython/menustrings.py:402 ../gui/wxpython/menustrings.py:1308
-#, fuzzy
-msgid "Creates watershed basins from a drainage direction map."
-#: ../gui/wxpython/menustrings.py:403 ../gui/wxpython/menustrings.py:1309
-msgid "Extraction of stream networks"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:404 ../gui/wxpython/menustrings.py:1310
-#, fuzzy
-msgid "Performs stream network extraction."
-msgstr "Pemeliharaan jaringan"
-#: ../gui/wxpython/menustrings.py:405 ../gui/wxpython/menustrings.py:1311
-msgid "SIMWE Overland flow modeling"
-msgstr "Pemodelan aliran SIMWE overland"
-#: ../gui/wxpython/menustrings.py:406 ../gui/wxpython/menustrings.py:1312
-#, fuzzy
-msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
-msgstr ""
-"Simulasi hidrologis aliran overland dengan metoda path sampling (SIMWE)"
-#: ../gui/wxpython/menustrings.py:407 ../gui/wxpython/menustrings.py:1313
-msgid "SIMWE Sediment flux modeling"
-msgstr "Pemodelan fluks sedimen SIMWE"
-#: ../gui/wxpython/menustrings.py:408 ../gui/wxpython/menustrings.py:1314
-#, fuzzy
-msgid ""
-"Sediment transport and erosion/deposition simulation using path sampling "
-"method (SIMWE)."
-msgstr ""
-"Transpor sedimen dan simulasi erosi/deposisi dengan metoda path sampling "
-"(SIMWE)"
-#: ../gui/wxpython/menustrings.py:409 ../gui/wxpython/menustrings.py:1315
-msgid "Topographic index map"
-msgstr "Peta indeks topografi "
-#: ../gui/wxpython/menustrings.py:410 ../gui/wxpython/menustrings.py:1316
-#, fuzzy
-msgid ""
-"Creates a topographic index (wetness index) raster map from an elevation "
-"raster map."
-msgstr "Buat peta indeks topografi [ln(a/tan(beta))] dari peta ketinggian. "
-#: ../gui/wxpython/menustrings.py:411 ../gui/wxpython/menustrings.py:1317
-msgid "TOPMODEL simulation"
-msgstr "Simulasi TOPMODEL "
-#: ../gui/wxpython/menustrings.py:412 ../gui/wxpython/menustrings.py:1318
-msgid "Simulates TOPMODEL which is a physically based hydrologic model."
-msgstr "Simulasi TOPMODEL yang didasarkan pada model hidrologi berbasis fisik."
-#: ../gui/wxpython/menustrings.py:413 ../gui/wxpython/menustrings.py:1319
-msgid "USLE K-factor"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:414 ../gui/wxpython/menustrings.py:1320
-msgid "Computes USLE Soil Erodibility Factor (K)."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:415 ../gui/wxpython/menustrings.py:1321
-msgid "USLE R-factor"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:416 ../gui/wxpython/menustrings.py:1322
-msgid "Computes USLE R factor, Rainfall erosivity index."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:417 ../gui/wxpython/menustrings.py:842
-#: ../gui/wxpython/menustrings.py:1323 ../gui/wxpython/menustrings.py:1748
-#, fuzzy
-msgid "Groundwater modeling"
-msgstr "Ground Control Point"
-#: ../gui/wxpython/menustrings.py:418 ../gui/wxpython/menustrings.py:1324
-msgid "Groundwater flow"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:419 ../gui/wxpython/menustrings.py:1325
-msgid ""
-"Numerical calculation program for transient, confined and unconfined "
-"groundwater flow in two dimensions."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:420 ../gui/wxpython/menustrings.py:1326
-msgid "Groundwater solute transport"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:421 ../gui/wxpython/menustrings.py:1327
-msgid ""
-"Numerical calculation program for transient, confined and unconfined solute "
-"transport in two dimensions"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:422 ../gui/wxpython/menustrings.py:1328
-msgid "Landscape patch analysis"
-msgstr "Analisis petak lansekap"
-#: ../gui/wxpython/menustrings.py:423 ../gui/wxpython/menustrings.py:1329
-msgid "Set up sampling and analysis framework"
-msgstr "Pengaturan kerangka kerja dan analisis cuplikan"
-#: ../gui/wxpython/menustrings.py:424 ../gui/wxpython/menustrings.py:1330
-msgid "Configuration editor for r.li.'index'"
-msgstr "Editor konfigurasi untuk r.li.'index'"
-#: ../gui/wxpython/menustrings.py:425 ../gui/wxpython/menustrings.py:1331
-msgid "Edge density"
-msgstr "Kepadatan tepian "
-#: ../gui/wxpython/menustrings.py:426 ../gui/wxpython/menustrings.py:1332
-msgid ""
-"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
-"Menghitung indek kepadatan tepian pada peta raster, dengan algoritma 4 "
-"neighbour"
-#: ../gui/wxpython/menustrings.py:427 ../gui/wxpython/menustrings.py:1333
-msgid "Contrast weighted edge density"
-msgstr "Kepadatan kontras tepian terbeban "
-#: ../gui/wxpython/menustrings.py:428 ../gui/wxpython/menustrings.py:1334
-msgid "Calculates contrast weighted edge density index on a raster map"
-msgstr ""
-"raster "
-#: ../gui/wxpython/menustrings.py:429 ../gui/wxpython/menustrings.py:1335
-msgid "Patch area mean"
-msgstr "Rerata wilayah petak"
-#: ../gui/wxpython/menustrings.py:430 ../gui/wxpython/menustrings.py:1336
-msgid ""
-"Calculates mean patch size index on a raster map, using a 4 neighbour "
-"algorithm"
-msgstr ""
-"Menghitung rerata indeks ukuran petak pada sebuah peta raster, dengan "
-"algoritma 4 neighbour"
-#: ../gui/wxpython/menustrings.py:431 ../gui/wxpython/menustrings.py:1337
-msgid "Patch area range"
-msgstr "Rentang luas petak"
-#: ../gui/wxpython/menustrings.py:432 ../gui/wxpython/menustrings.py:1338
-msgid "Calculates range of patch area size on a raster map"
-msgstr "Menghitung rentang ukuran area petak pada sebuah peta raster"
-#: ../gui/wxpython/menustrings.py:433 ../gui/wxpython/menustrings.py:1339
-msgid "Patch area Std Dev"
-msgstr "Simpangan baku luas petak"
-#: ../gui/wxpython/menustrings.py:434 ../gui/wxpython/menustrings.py:1340
-msgid "Calculates standard deviation of patch area a raster map"
-msgstr "Menghitung simpangan baku area petak pada peta raster"
-#: ../gui/wxpython/menustrings.py:435 ../gui/wxpython/menustrings.py:1341
-msgid "Patch area Coeff Var"
-msgstr "Variansi koefisien luas petak"
-#: ../gui/wxpython/menustrings.py:436 ../gui/wxpython/menustrings.py:1342
-msgid "Calculates coefficient of variation of patch area on a raster map"
-msgstr "Menghitung variasi koefisien area petak pada sebuah peta raster"
-#: ../gui/wxpython/menustrings.py:437 ../gui/wxpython/menustrings.py:1343
-msgid "Patch density"
-msgstr "Kepadatan petak"
-#: ../gui/wxpython/menustrings.py:438 ../gui/wxpython/menustrings.py:1344
-msgid ""
-"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
-"Menghitung indeks kepadatan petak pada sebuah peta raster, dengan algoritma "
-"4 neighbour"
-#: ../gui/wxpython/menustrings.py:439 ../gui/wxpython/menustrings.py:1345
-msgid "Patch number"
-msgstr "Jumlah petak"
-#: ../gui/wxpython/menustrings.py:440 ../gui/wxpython/menustrings.py:1346
-msgid ""
-"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
-msgstr ""
-"Menghitung indeks jumlah petak pada sebuah peta raster, dengan algoritma 4 "
-"neighbour."
-#: ../gui/wxpython/menustrings.py:441 ../gui/wxpython/menustrings.py:1347
-msgid "Dominance's diversity"
-msgstr "Keragaman berdasarkan Dominansi "
-#: ../gui/wxpython/menustrings.py:442 ../gui/wxpython/menustrings.py:1348
-msgid "Calculates dominance's diversity index on a raster map"
-msgstr "Menghitung indeks keragaman dominan pada sebuah peta raster"
-#: ../gui/wxpython/menustrings.py:443 ../gui/wxpython/menustrings.py:1349
-msgid "Shannon's diversity"
-msgstr "Keragaman berdasarkan Shannon "
-#: ../gui/wxpython/menustrings.py:444 ../gui/wxpython/menustrings.py:1350
-msgid "Calculates Shannon's diversity index on a raster map"
-msgstr "Menghitung indeks keragaman Shannon pada sebuah peta raster"
-#: ../gui/wxpython/menustrings.py:445 ../gui/wxpython/menustrings.py:1351
-msgid "Simpson's diversity"
-msgstr "Keragaman berdasarkan Simpson "
-#: ../gui/wxpython/menustrings.py:446 ../gui/wxpython/menustrings.py:1352
-msgid "Calculates Simpson's diversity index on a raster map"
-msgstr "Menghitung indeks keragaman Simpsons pada sebuah peta raster"
-#: ../gui/wxpython/menustrings.py:447 ../gui/wxpython/menustrings.py:1353
-msgid "Richness"
-msgstr "Keragaman"
-#: ../gui/wxpython/menustrings.py:448 ../gui/wxpython/menustrings.py:1354
-#, fuzzy
-msgid "Calculates richness index on a raster map"
-msgstr "Menghitung indeks bentuk pada sebuah peta raster"
-#: ../gui/wxpython/menustrings.py:449 ../gui/wxpython/menustrings.py:1355
-msgid "Shape index"
-msgstr "Indeks bentuk "
-#: ../gui/wxpython/menustrings.py:450 ../gui/wxpython/menustrings.py:1356
-msgid "Calculates shape index on a raster map"
-#: ../gui/wxpython/menustrings.py:451 ../gui/wxpython/menustrings.py:1357
-msgid "Wildfire modeling"
-msgstr "Pemodelan kebakaran hutan "
-#: ../gui/wxpython/menustrings.py:452 ../gui/wxpython/menustrings.py:1358
-msgid "Rate of spread"
-msgstr "Laju persebaran "
-#: ../gui/wxpython/menustrings.py:453 ../gui/wxpython/menustrings.py:1359
-msgid ""
-"Generates rate of spread raster maps. Generates three, or four raster map "
-"layers showing the base (perpendicular) rate of spread (ROS), the maximum "
-"(forward) ROS, the direction of the maximum ROS, and optionally the maximum "
-"potential spotting distance for fire spread simulation."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:454 ../gui/wxpython/menustrings.py:1360
-msgid "Least-cost spread paths"
-msgstr "Jalur penyebaran berbasis biaya-termurah "
-#: ../gui/wxpython/menustrings.py:455 ../gui/wxpython/menustrings.py:1361
-msgid ""
-"Recursively traces the least cost path backwards to cells from which the "
-"cumulative cost was determined."
-msgstr ""
-"Menjejak secara berulang, jalur biaya termurah secara terbalik (backward) ke "
-"sel dimana biaya kumulatifnya telah ditentukan."
-#: ../gui/wxpython/menustrings.py:456 ../gui/wxpython/menustrings.py:1362
-msgid "Anisotropic spread simulation"
-msgstr "Simulasi penyebaran anisotropik "
-#: ../gui/wxpython/menustrings.py:457 ../gui/wxpython/menustrings.py:1363
-msgid ""
-"Simulates elliptically anisotropic spread. Generates a raster map of the "
-"cumulative time of spread, given raster maps containing the rates of spread "
-"(ROS), the ROS directions and the spread origins. It optionally produces "
-"raster maps to contain backlink UTM coordinates for tracing spread paths. "
-"Usable for fire spread simulations."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:458 ../gui/wxpython/menustrings.py:1364
-msgid "Change category values and labels"
-msgstr "Ubah nilai kategori dan label "
-#: ../gui/wxpython/menustrings.py:459 ../gui/wxpython/menustrings.py:509
-#: ../gui/wxpython/menustrings.py:1365 ../gui/wxpython/menustrings.py:1415
-msgid "Manage category information"
-msgstr "Kelola informasi kategori"
-#: ../gui/wxpython/menustrings.py:460 ../gui/wxpython/menustrings.py:510
-#: ../gui/wxpython/menustrings.py:1366 ../gui/wxpython/menustrings.py:1416
-msgid ""
-"Manages category values and labels associated with user-specified raster map "
-"layers."
-msgstr ""
-"Kelola nilai kategori dan label yang terkait dengan layer peta raster milik "
-"pengguna."
-#: ../gui/wxpython/menustrings.py:461 ../gui/wxpython/menustrings.py:1367
-msgid "Interactively edit category values"
-msgstr "Mengubah nilai kategori secara interaktif "
-#: ../gui/wxpython/menustrings.py:462 ../gui/wxpython/menustrings.py:1368
-#, fuzzy
-msgid "Edits cell values in a raster map."
-msgstr "Secara interaktif melakukan edit nilai sel dalam sebuah peta raster."
-#: ../gui/wxpython/menustrings.py:463 ../gui/wxpython/menustrings.py:1369
-msgid "Reclassify by size"
-msgstr "Klasifikasi-ulang berdasarkan ukuran"
-#: ../gui/wxpython/menustrings.py:464 ../gui/wxpython/menustrings.py:1370
-#, fuzzy
-msgid ""
-"Reclasses a raster map greater or less than user specified area size (in "
-"hectares)."
-msgstr ""
-"Klasifikasi-ulang sebuah peta raster yang lebih besar atau lebih kecil "
-"dibandingan ukuran wilayah yang ditentukan oleh pengguna (dalam hektar)"
-#: ../gui/wxpython/menustrings.py:465 ../gui/wxpython/menustrings.py:669
-#: ../gui/wxpython/menustrings.py:1371 ../gui/wxpython/menustrings.py:1575
-#, fuzzy
-msgid "Reclassify"
-#: ../gui/wxpython/menustrings.py:466 ../gui/wxpython/menustrings.py:1372
-msgid ""
-"Reclassify raster map based on category values. Creates a new raster map "
-"whose category values are based upon a reclassification of the categories in "
-"an existing raster map."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:467 ../gui/wxpython/menustrings.py:1373
-#, fuzzy
-msgid "Recode"
-msgstr "Render"
-#: ../gui/wxpython/menustrings.py:468 ../gui/wxpython/menustrings.py:1374
-#, fuzzy
-msgid "Recodes categorical raster maps."
-msgstr "Peta raster hasil kode-ulang:"
-#: ../gui/wxpython/menustrings.py:469 ../gui/wxpython/menustrings.py:1375
-msgid "Rescale"
-msgstr "Skala-ulang "
-#: ../gui/wxpython/menustrings.py:470 ../gui/wxpython/menustrings.py:1376
-msgid "Rescales the range of category values in a raster map layer."
-msgstr "Skala-ulang rentang nilai kategori dalam sebuah layer peta raster."
-#: ../gui/wxpython/menustrings.py:471 ../gui/wxpython/menustrings.py:1377
-msgid "Rescale with histogram"
-msgstr "Skala-ulang dengan histogram"
-#: ../gui/wxpython/menustrings.py:472 ../gui/wxpython/menustrings.py:1378
-msgid ""
-"Rescales histogram equalized the range of category values in a raster map "
-"layer."
-msgstr ""
-"Skala-ulang rentang nilai kategori dengan histogram equalied dalam sebuah "
-"layer peta raster."
-#: ../gui/wxpython/menustrings.py:473 ../gui/wxpython/menustrings.py:1379
-msgid "Generate random cells"
-msgstr "Hasilkan sel acak"
-#: ../gui/wxpython/menustrings.py:474 ../gui/wxpython/menustrings.py:1380
-msgid "Random cells"
-msgstr "Sel acak"
-#: ../gui/wxpython/menustrings.py:475 ../gui/wxpython/menustrings.py:1381
-msgid "Generates random cell values with spatial dependence."
-msgstr "Menghasilkan nilai sel acak dengan ketergantungan spasial."
-#: ../gui/wxpython/menustrings.py:476 ../gui/wxpython/menustrings.py:1382
-msgid "Random cells and vector points"
-msgstr "Sel dan titik vektor acak"
-#: ../gui/wxpython/menustrings.py:477 ../gui/wxpython/menustrings.py:1383
-#, fuzzy
-msgid ""
-"Creates a raster map layer and vector point map containing randomly located "
-"points."
-msgstr ""
-"Buat sebuah layer peta raster dan peta titik vektor yang memiliki titik "
-"dengan lokasi acak."
-#: ../gui/wxpython/menustrings.py:478 ../gui/wxpython/menustrings.py:1384
-msgid "Generate surfaces"
-msgstr "Hasilkan permukaan"
-#: ../gui/wxpython/menustrings.py:479 ../gui/wxpython/menustrings.py:1385
-msgid "Fractal surface"
-msgstr "Permukaan fraktal"
-#: ../gui/wxpython/menustrings.py:480 ../gui/wxpython/menustrings.py:1386
-msgid "Creates a fractal surface of a given fractal dimension."
-msgstr "Membuat sebuah permukaan fraktal pada dimensi fraktal tertentu."
-#: ../gui/wxpython/menustrings.py:481 ../gui/wxpython/menustrings.py:1387
-msgid "Gaussian kernel density surface"
-msgstr "Permukaan kepadatan kernel Gaussian"
-#: ../gui/wxpython/menustrings.py:482 ../gui/wxpython/menustrings.py:1388
-#, fuzzy
-msgid ""
-"Generates a raster density map from vector points map. Density is computed "
-"using a moving kernel. Optionally generates a vector density map on a vector "
-"network."
-msgstr ""
-"Hasilkan sebuah peta kepadatan raster dari data titik vektor dengan "
-"menggunakan sebuah kernel Gaussian isotropik 2D bergerak atau secara "
-"opsional menghasilkan sebuah peta kepadatan vektor pada jaringan vektor "
-"dalam sebuah kernel 1D."
-#: ../gui/wxpython/menustrings.py:483 ../gui/wxpython/menustrings.py:1389
-msgid "Gaussian deviates surface"
-msgstr "Permukaan simpangan Gaussian"
-#: ../gui/wxpython/menustrings.py:484 ../gui/wxpython/menustrings.py:1390
-#, fuzzy
-msgid ""
-"Generates a raster map using gaussian random number generator. Mean and "
-"standard deviation of gaussian deviates can be expressed by the user."
-msgstr ""
-"dari satu sel."
-#: ../gui/wxpython/menustrings.py:486 ../gui/wxpython/menustrings.py:1392
-msgid ""
-"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
-"point."
-msgstr ""
-"Membuat peta raster dengan dip (inklinasi), aspek (azimut) dan satu titik "
-"yang ditentukan."
-#: ../gui/wxpython/menustrings.py:487 ../gui/wxpython/menustrings.py:1393
-msgid "Random deviates surface"
-msgstr "Permukaan simpangan acak"
-#: ../gui/wxpython/menustrings.py:488 ../gui/wxpython/menustrings.py:1394
-#, fuzzy
-msgid ""
-"Produces a raster surface map of uniform random deviates with defined range."
-msgstr ""
-"Menghasilkan sebuah layer peta raster dari simpangan acak uniform yang "
-"rentangnya dapat ditentukan oleh pengguna."
-#: ../gui/wxpython/menustrings.py:489 ../gui/wxpython/menustrings.py:1395
-msgid "Random surface with spatial dependence"
-msgstr "Permukaan acak dengan dependensi spasial"
-#: ../gui/wxpython/menustrings.py:490 ../gui/wxpython/menustrings.py:1396
-msgid "Generates random surface(s) with spatial dependence."
-msgstr "Menghasilkan permukaan acak dengan ketergantungan spasial."
-#: ../gui/wxpython/menustrings.py:491 ../gui/wxpython/menustrings.py:1397
-msgid "Interpolate surfaces"
-msgstr "Interpolasikan permukaan"
-#: ../gui/wxpython/menustrings.py:492 ../gui/wxpython/menustrings.py:1398
-msgid "Bilinear and bicubic from vector points"
-msgstr "Bilinear dan bikubik dari titik vektor"
-#: ../gui/wxpython/menustrings.py:493 ../gui/wxpython/menustrings.py:1399
-#, fuzzy
-msgid ""
-"Performs bicubic or bilinear spline interpolation with Tykhonov "
-"regularization."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:494 ../gui/wxpython/menustrings.py:1400
-msgid "IDW from raster points"
-msgstr "IDW dari titik raster"
-#: ../gui/wxpython/menustrings.py:495 ../gui/wxpython/menustrings.py:1401
-#, fuzzy
-msgid ""
-"Provides surface interpolation from raster point data by Inverse Distance "
-"Squared Weighting."
-msgstr ""
-"Interpolasi permukaan dari data titik vektor dengan Inverse Distance Squared "
-"Weighting."
-#: ../gui/wxpython/menustrings.py:496 ../gui/wxpython/menustrings.py:1402
-msgid "IDW from vector points"
-msgstr "IDW dari peta vektor"
-#: ../gui/wxpython/menustrings.py:497 ../gui/wxpython/menustrings.py:1403
-#, fuzzy
-msgid ""
-"Provides surface interpolation from vector point data by Inverse Distance "
-msgstr ""
-"Weighting."
-#: ../gui/wxpython/menustrings.py:498 ../gui/wxpython/menustrings.py:1404
-msgid "Raster contours"
-msgstr "Kontur raster"
-#: ../gui/wxpython/menustrings.py:499 ../gui/wxpython/menustrings.py:1405
-#, fuzzy
-msgid "Generates surface raster map from rasterized contours."
-msgstr "Program pembentukan permukaan dari kontur raster."
-#: ../gui/wxpython/menustrings.py:500 ../gui/wxpython/menustrings.py:1406
-msgid "Regularized spline tension"
-msgstr "Regularized spline tension"
-#: ../gui/wxpython/menustrings.py:501 ../gui/wxpython/menustrings.py:1407
-#, fuzzy
-msgid ""
-"Performs surface interpolation from vector points map by splines. Spatial "
-"approximation and topographic analysis from given point or isoline data in "
-"vector format to floating point raster format using regularized spline with "
-"tension."
-msgstr ""
-"Perkiraan spasial dan analisis topografik dari titik tertentu atau data "
-"isoline dalam format vektor ke dalam format titik raster floating point "
-"dengan regularized spline tension."
-#: ../gui/wxpython/menustrings.py:502 ../gui/wxpython/menustrings.py:1408
-#, fuzzy
-msgid "Raster series interpolation"
-msgstr "Regresi linier "
-#: ../gui/wxpython/menustrings.py:503 ../gui/wxpython/menustrings.py:1409
-msgid ""
-"Interpolates raster maps located (temporal or spatial) in between input "
-"raster maps at specific sampling positions."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:504 ../gui/wxpython/menustrings.py:1410
-msgid "Fill NULL cells"
-msgstr "Isi sel NULL"
-#: ../gui/wxpython/menustrings.py:505 ../gui/wxpython/menustrings.py:1411
-#, fuzzy
-msgid "Fills no-data areas in raster maps using spline interpolation."
-msgstr ""
-"Isi area dengan no-data dalam peta raster dengan interpolasi v.surf.rst"
-#: ../gui/wxpython/menustrings.py:506 ../gui/wxpython/menustrings.py:708
-#: ../gui/wxpython/menustrings.py:818 ../gui/wxpython/menustrings.py:990
-#: ../gui/wxpython/menustrings.py:1412 ../gui/wxpython/menustrings.py:1614
-#: ../gui/wxpython/menustrings.py:1724 ../gui/wxpython/menustrings.py:1896
-msgid "Reports and statistics"
-msgstr "Laporan dan statistik"
-#: ../gui/wxpython/menustrings.py:507 ../gui/wxpython/menustrings.py:1413
-msgid "Basic raster metadata"
-msgstr "Metadata dasar peta raster"
-#: ../gui/wxpython/menustrings.py:508 ../gui/wxpython/menustrings.py:1414
-#, fuzzy
-msgid "Outputs basic information about a raster map."
-msgstr "Hasilkan informasi dasar tentang sebuah layer peta raster."
-#: ../gui/wxpython/menustrings.py:511 ../gui/wxpython/menustrings.py:1417
-msgid "General statistics"
-msgstr "Statistik umum"
-#: ../gui/wxpython/menustrings.py:512 ../gui/wxpython/menustrings.py:1418
-#, fuzzy
-msgid "Generates area statistics for raster map."
-#: ../gui/wxpython/menustrings.py:513 ../gui/wxpython/menustrings.py:1419
-msgid "Quantiles for large data sets"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:514 ../gui/wxpython/menustrings.py:1420
-msgid "Compute quantiles using two passes."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:515 ../gui/wxpython/menustrings.py:1421
-msgid "Range of category values"
-msgstr "Rentang nilai kategori"
-#: ../gui/wxpython/menustrings.py:516 ../gui/wxpython/menustrings.py:1422
-msgid "Prints terse list of category values found in a raster map layer."
-msgstr ""
-"Cetak daftar nilai kategori yang ditemukan pada sebuah layer peta raster."
-#: ../gui/wxpython/menustrings.py:517 ../gui/wxpython/menustrings.py:1423
-msgid "Sum area by raster map and category"
-msgstr "Hitung luas peta raster dan kategori"
-#: ../gui/wxpython/menustrings.py:518 ../gui/wxpython/menustrings.py:1424
-#, fuzzy
-msgid "Reports statistics for raster maps."
-#: ../gui/wxpython/menustrings.py:519 ../gui/wxpython/menustrings.py:1425
-msgid "Statistics for clumped cells"
-msgstr "Statistik untuk sel yang berkelompok (clumped cells)"
-#: ../gui/wxpython/menustrings.py:520 ../gui/wxpython/menustrings.py:1426
-#, fuzzy
-msgid ""
-"Calculates the volume of data \"clumps\". Optionally produces a GRASS vector "
-"points map containing the calculated centroids of these clumps."
-msgstr ""
-"Hitung volume dari data \"clump\", secara (opsional) menghasilkan sebuah "
-"titik vektor GRASS dengan kandungan hitungan centroid dari clump ini."
-#: ../gui/wxpython/menustrings.py:521 ../gui/wxpython/menustrings.py:1427
-msgid "Total corrected area"
-msgstr "Total area yang dikoreksi"
-#: ../gui/wxpython/menustrings.py:522 ../gui/wxpython/menustrings.py:1428
-#, fuzzy
-msgid "Prints estimation of surface area for raster map."
-#: ../gui/wxpython/menustrings.py:524 ../gui/wxpython/menustrings.py:1430
-msgid ""
-"Calculates univariate statistics from the non-null cells of a raster map. "
-"Statistics include number of cells counted, minimum and maximum cell values, "
-"range, arithmetic mean, population variance, standard deviation, coefficient "
-"of variation, and sum."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:525 ../gui/wxpython/menustrings.py:1431
-msgid "Sample transects"
-msgstr "Transek cuplikan"
-#: ../gui/wxpython/menustrings.py:526 ../gui/wxpython/menustrings.py:1432
-msgid "Outputs the raster map layer values lying on user-defined line(s)."
-msgstr ""
-"Keluaran nilai layer peta raster berdasarkan gari yang ditentukan oleh "
-"pengguna."
-#: ../gui/wxpython/menustrings.py:527 ../gui/wxpython/menustrings.py:1433
-msgid "Sample transects (bearing/distance)"
-msgstr "Transek cuplikan (bearing/distance) "
-#: ../gui/wxpython/menustrings.py:528 ../gui/wxpython/menustrings.py:1434
-msgid ""
-"Outputs raster map layer values lying along user defined transect line(s)."
-msgstr ""
-"Keluaran nilai layer peta raster berdasarkan garis transek yang ditentukan "
-"oleh pengguna."
-#: ../gui/wxpython/menustrings.py:529 ../gui/wxpython/menustrings.py:1435
-msgid "Covariance/correlation"
-msgstr "Kovarians/korelasi "
-#: ../gui/wxpython/menustrings.py:530 ../gui/wxpython/menustrings.py:1436
-msgid ""
-"Outputs a covariance/correlation matrix for user-specified raster map "
-"layer(s)."
-msgstr ""
-"Keluaran matriks kovariansi/korelasi untuk layer peta raster yang ditentukan "
-"pengguna."
-#: ../gui/wxpython/menustrings.py:531 ../gui/wxpython/menustrings.py:1437
-msgid "Linear regression"
-#: ../gui/wxpython/menustrings.py:532 ../gui/wxpython/menustrings.py:1438
-#, fuzzy
-msgid "Calculates linear regression from two raster maps: y = a + b*x."
-msgstr "Menghitung regresi linear untuk dua peta raster: y= a + b*x"
-#: ../gui/wxpython/menustrings.py:533 ../gui/wxpython/menustrings.py:1439
-#, fuzzy
-msgid "Multiple regression"
-#: ../gui/wxpython/menustrings.py:534 ../gui/wxpython/menustrings.py:1440
-#, fuzzy
-msgid "Calculates multiple linear regression from raster maps."
-#: ../gui/wxpython/menustrings.py:535 ../gui/wxpython/menustrings.py:1441
-msgid "Mutual category occurrences"
-msgstr "Mutual category occurences"
-#: ../gui/wxpython/menustrings.py:536 ../gui/wxpython/menustrings.py:1442
-msgid ""
-"Tabulates the mutual occurrence (coincidence) of categories for two raster "
-"map layers."
-msgstr "Hitung koinsindensi kategori untuk dua layer peta raster."
-#: ../gui/wxpython/menustrings.py:537 ../gui/wxpython/menustrings.py:1443
-#, fuzzy
-msgid "&Vector"
-msgstr "Vektor"
-#: ../gui/wxpython/menustrings.py:538 ../gui/wxpython/menustrings.py:1444
-msgid "Develop vector map"
-msgstr "Pembangunan peta vektor"
-#: ../gui/wxpython/menustrings.py:540 ../gui/wxpython/menustrings.py:1446
-msgid "Create new empty vector map"
-msgstr "Buat peta vektor kosong baru"
-#: ../gui/wxpython/menustrings.py:541 ../gui/wxpython/menustrings.py:1447
-#, fuzzy
-msgid "Edit vector map (non-interactively)"
-#: ../gui/wxpython/menustrings.py:542 ../gui/wxpython/menustrings.py:1448
-msgid ""
-"Edits a vector map, allows adding, deleting and modifying selected vector "
-"features."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:543 ../gui/wxpython/menustrings.py:1449
-msgid "Convert object types"
-msgstr "Konversi tipe obyek"
-#: ../gui/wxpython/menustrings.py:544 ../gui/wxpython/menustrings.py:1450
-#, fuzzy
-msgid "Changes type of vector features."
-msgstr "Pilih fitur vektor"
-#: ../gui/wxpython/menustrings.py:545 ../gui/wxpython/menustrings.py:1451
-msgid "Parallel lines"
-msgstr "Garis paralel"
-#: ../gui/wxpython/menustrings.py:546 ../gui/wxpython/menustrings.py:1452
-#, fuzzy
-msgid "Creates parallel line to input vector lines."
-msgstr "Buat garis paralel ke input garis"
-#: ../gui/wxpython/menustrings.py:547 ../gui/wxpython/menustrings.py:1453
-msgid "Dissolve boundaries"
-msgstr "Urai batas"
-#: ../gui/wxpython/menustrings.py:548 ../gui/wxpython/menustrings.py:1454
-msgid ""
-"Dissolves boundaries between adjacent areas sharing a common category number "
-"or attribute."
-msgstr ""
-"Urai batas antara area yang berdekatan yang memiliki nomor kategori atau "
-"atribut yang sama."
-#: ../gui/wxpython/menustrings.py:549 ../gui/wxpython/menustrings.py:1455
-msgid "Create 3D vector over raster"
-msgstr "Buat vektor 3D di atas raster"
-#: ../gui/wxpython/menustrings.py:550 ../gui/wxpython/menustrings.py:1456
-#, fuzzy
-msgid "Converts 2D vector features to 3D by sampling of elevation raster map."
-msgstr "Ubah peta vektor ke 3D dengan mencuplik ketinggian dari peta raster."
-#: ../gui/wxpython/menustrings.py:551 ../gui/wxpython/menustrings.py:1457
-msgid "Extrude 3D vector map"
-msgstr "Ekstrud peta vektor 3D"
-#: ../gui/wxpython/menustrings.py:552 ../gui/wxpython/menustrings.py:1458
-msgid ""
-"Extrudes flat vector features to 3D vector features with defined height. "
-"Optionally the height can be derived from sampling of elevation raster map."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:553 ../gui/wxpython/menustrings.py:1459
-msgid "Create labels"
-msgstr "Buat label"
-#: ../gui/wxpython/menustrings.py:554 ../gui/wxpython/menustrings.py:1460
-msgid "Creates paint labels for a vector map from attached attributes."
-msgstr "Buat label untuk sebuah peta vektor dari atributnya."
-#: ../gui/wxpython/menustrings.py:555 ../gui/wxpython/menustrings.py:1461
-msgid "Reposition vector map"
-msgstr "Posisi-ulang peta vektor"
-#: ../gui/wxpython/menustrings.py:556 ../gui/wxpython/menustrings.py:1462
-#, fuzzy
-msgid ""
-"Performs an affine transformation (shift, scale and rotate) on vector map."
-msgstr ""
-"Melakukan sebuah transformasi affine (geser, skala dan rotasi atau GPC) pada "
-"peta vektor."
-#: ../gui/wxpython/menustrings.py:557 ../gui/wxpython/menustrings.py:1463
-#, fuzzy
-msgid "Rectify vector map"
-msgstr "Pilih peta vektor"
-#: ../gui/wxpython/menustrings.py:558 ../gui/wxpython/menustrings.py:1464
-#, fuzzy
-msgid ""
-"Rectifies a vector by computing a coordinate transformation for each object "
-"in the vector based on the control points."
-msgstr ""
-"Rektifikasi sebuah citra dengan menghitung sebuah transformasi koordinat "
-"untuk setiap piksel dalam citra berdasarkan titik kontrol"
-#: ../gui/wxpython/menustrings.py:562 ../gui/wxpython/menustrings.py:1468
-#, fuzzy
-msgid "Updates vector map metadata."
-msgstr "Metadata dasar peta vektor"
-#: ../gui/wxpython/menustrings.py:563 ../gui/wxpython/menustrings.py:1469
-#, fuzzy
-msgid "Topology maintenance"
-#: ../gui/wxpython/menustrings.py:564 ../gui/wxpython/menustrings.py:1470
-#, fuzzy
-msgid "Create or rebuild topology"
-msgstr "Buat/bangun-ulang topologi"
-#: ../gui/wxpython/menustrings.py:565 ../gui/wxpython/menustrings.py:1471
-msgid ""
-"Creates topology for vector map. Optionally also checks for topological "
-"errors."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:566 ../gui/wxpython/menustrings.py:1472
-#, fuzzy
-msgid "Rebuild topology on all vector maps"
-msgstr "Buat topologi untuk peta vektor GRASS."
-#: ../gui/wxpython/menustrings.py:567 ../gui/wxpython/menustrings.py:1473
-#, fuzzy
-msgid "Rebuilds topology on all vector maps in the current mapset."
-#: ../gui/wxpython/menustrings.py:568 ../gui/wxpython/menustrings.py:1474
-msgid "Build polylines"
-msgstr "Bangun polyline"
-#: ../gui/wxpython/menustrings.py:569 ../gui/wxpython/menustrings.py:1475
-msgid "Builds polylines from lines or boundaries."
-msgstr "Bangun polyline dari garis atau batas."
-#: ../gui/wxpython/menustrings.py:570 ../gui/wxpython/menustrings.py:1476
-#, fuzzy
-msgid "Split lines"
-msgstr "Pecah polyline"
-#: ../gui/wxpython/menustrings.py:571 ../gui/wxpython/menustrings.py:1477
-msgid "Splits vector lines to shorter segments."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:572 ../gui/wxpython/menustrings.py:1478
-msgid "Split polylines"
-#: ../gui/wxpython/menustrings.py:573 ../gui/wxpython/menustrings.py:1479
-msgid "Creates points/segments from input vector lines and positions."
-msgstr "Buat segmen/titik dari input vektor garis dan posisi."
-#: ../gui/wxpython/menustrings.py:574 ../gui/wxpython/menustrings.py:1480
-msgid "Clean vector map"
-msgstr "Bersihkan peta vektor"
-#: ../gui/wxpython/menustrings.py:575 ../gui/wxpython/menustrings.py:1481
-msgid "Toolset for cleaning topology of vector map."
-msgstr "Tool untuk membersihkan topologi peta vektor."
-#: ../gui/wxpython/menustrings.py:576 ../gui/wxpython/menustrings.py:1482
-msgid "Smooth or simplify"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:577 ../gui/wxpython/menustrings.py:1483
-#, fuzzy
-msgid "Performs vector based generalization."
-msgstr "Generalisasi berbasis vektor."
-#: ../gui/wxpython/menustrings.py:578 ../gui/wxpython/menustrings.py:1484
-msgid "Add centroids"
-msgstr "Tambahkan centroid"
-#: ../gui/wxpython/menustrings.py:579 ../gui/wxpython/menustrings.py:1485
-msgid "Adds missing centroids to closed boundaries."
-msgstr "Tambahkan centroid yang hilang ke batas yang tertutup."
-#: ../gui/wxpython/menustrings.py:582 ../gui/wxpython/menustrings.py:1488
-#, fuzzy
-msgid "Creates/modifies the color table associated with a vector map."
-#: ../gui/wxpython/menustrings.py:584 ../gui/wxpython/menustrings.py:1490
-msgid "Interactive management of vector color tables."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:586 ../gui/wxpython/menustrings.py:1492
-#, fuzzy
-msgid "Exports the color table associated with a vector map."
-#: ../gui/wxpython/menustrings.py:587 ../gui/wxpython/menustrings.py:1493
-#, fuzzy
-msgid "Query vector map"
-msgstr "Tumpang-susun peta vektor"
-#: ../gui/wxpython/menustrings.py:588 ../gui/wxpython/menustrings.py:1494
-msgid "Query with coordinate(s)"
-#: ../gui/wxpython/menustrings.py:589 ../gui/wxpython/menustrings.py:1495
-#, fuzzy
-msgid "Queries a vector map at given locations."
-msgstr "Kueri sebuah layer peta vektor pada lokasi tertentu."
-#: ../gui/wxpython/menustrings.py:590 ../gui/wxpython/menustrings.py:885
-#: ../gui/wxpython/menustrings.py:1496 ../gui/wxpython/menustrings.py:1791
-msgid "Query vector attribute data"
-msgstr "Kueri data atribut vektor"
-#: ../gui/wxpython/menustrings.py:591 ../gui/wxpython/menustrings.py:886
-#: ../gui/wxpython/menustrings.py:1497 ../gui/wxpython/menustrings.py:1792
-msgid "Prints vector map attributes."
-msgstr "Cetak atribut peta vektor."
-#: ../gui/wxpython/menustrings.py:592 ../gui/wxpython/menustrings.py:1498
-#, fuzzy
-msgid "Feature selection"
-msgstr "Potongan melintang"
-#: ../gui/wxpython/menustrings.py:593 ../gui/wxpython/menustrings.py:1499
-#, fuzzy
-msgid "Select by attributes"
-msgstr "Perbaharui atribut"
-#: ../gui/wxpython/menustrings.py:594 ../gui/wxpython/menustrings.py:1500
-#, fuzzy
-msgid ""
-"Selects vector features from an existing vector map and creates a new vector "
-"map containing only the selected features."
-msgstr ""
-"Pilih obyek vektor dari peta vektor yang ada dan buat sebuah peta baru yang "
-"hanya memiliki obyek terpilih saja."
-#: ../gui/wxpython/menustrings.py:595 ../gui/wxpython/menustrings.py:1501
-#, fuzzy
-msgid "Select by another map"
-#: ../gui/wxpython/menustrings.py:596 ../gui/wxpython/menustrings.py:1502
-#, fuzzy
-msgid ""
-"Selects features from vector map (A) by features from other vector map (B)."
-msgstr "Pilih fitur dari ainput dengan fitur dari binput"
-#: ../gui/wxpython/menustrings.py:604 ../gui/wxpython/menustrings.py:1510
-msgid "Buffer vectors"
-msgstr "Buffer peta vektor"
-#: ../gui/wxpython/menustrings.py:605 ../gui/wxpython/menustrings.py:1511
-#, fuzzy
-msgid "Creates a buffer around vector features of given type."
-msgstr ""
-"Buat sebuah buffer di sekitar fitur tertentu (area harus memiliki centroid)."
-#: ../gui/wxpython/menustrings.py:606 ../gui/wxpython/menustrings.py:1512
-msgid "Lidar analysis"
-msgstr "Analisis LIDAR"
-#: ../gui/wxpython/menustrings.py:607 ../gui/wxpython/menustrings.py:1513
-msgid "Identify and remove outliers"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:608 ../gui/wxpython/menustrings.py:705
-#: ../gui/wxpython/menustrings.py:1514 ../gui/wxpython/menustrings.py:1611
-msgid "Removes outliers from vector point data."
-msgstr "Hilangkan outlier dari data vektor titik."
-#: ../gui/wxpython/menustrings.py:609 ../gui/wxpython/menustrings.py:1515
-msgid "Detect edges"
-msgstr "Deteksi tepian"
-#: ../gui/wxpython/menustrings.py:610 ../gui/wxpython/menustrings.py:1516
-msgid "Detects the object's edges from a LIDAR data set."
-msgstr "Deteksi obyek-obyek di tepian dari sebuah data LIDAR."
-#: ../gui/wxpython/menustrings.py:611 ../gui/wxpython/menustrings.py:1517
-msgid "Detect interiors"
-msgstr "Deteksi interior"
-#: ../gui/wxpython/menustrings.py:612 ../gui/wxpython/menustrings.py:1518
-msgid ""
-"Building contour determination and Region Growing algorithm for determining "
-"the building inside"
-msgstr ""
-"Pembuatan determinasi kontur dan algoritma pengembangan wilayah (Region "
-"Growing) untuk menentukan bangunan di dalamnya"
-#: ../gui/wxpython/menustrings.py:613 ../gui/wxpython/menustrings.py:1519
-msgid "Correct and reclassify objects"
-msgstr "Koreksi dan klasifikasi-ulang obyek"
-#: ../gui/wxpython/menustrings.py:614 ../gui/wxpython/menustrings.py:1520
-#, fuzzy
-msgid ""
-"Corrects the v.lidar.growing output. It is the last of the three algorithms "
-"for LIDAR filtering."
-msgstr ""
-"Koreksi keluaran dari v.lidar.growing. Modul ini adalah yang terakhir dari "
-"tiga algoritma untuk penyarian LIDAR."
-#: ../gui/wxpython/menustrings.py:615 ../gui/wxpython/menustrings.py:1521
-msgid "Linear referencing"
-msgstr "Referensi linier"
-#: ../gui/wxpython/menustrings.py:616 ../gui/wxpython/menustrings.py:1522
-msgid "Create LRS"
-msgstr "Buat LRS"
-#: ../gui/wxpython/menustrings.py:617 ../gui/wxpython/menustrings.py:1523
-#, fuzzy
-msgid "Creates a linear reference system."
-msgstr "Buat Sistem Referensi Linear"
-#: ../gui/wxpython/menustrings.py:618 ../gui/wxpython/menustrings.py:1524
-msgid "Create stationing"
-msgstr "Buat stationing"
-#: ../gui/wxpython/menustrings.py:619 ../gui/wxpython/menustrings.py:1525
-#, fuzzy
-msgid "Creates stationing from input lines, and linear reference system."
-msgstr "Buat stationing dari input garis dan sistem referensi linear"
-#: ../gui/wxpython/menustrings.py:620 ../gui/wxpython/menustrings.py:1526
-msgid "Create points/segments"
-msgstr "Buat titik/segmen"
-#: ../gui/wxpython/menustrings.py:621 ../gui/wxpython/menustrings.py:1527
-msgid ""
-"Creates points/segments from input lines, linear reference system and "
-"positions read from stdin or a file."
-msgstr ""
-"Buat titik/segmen dari input garis, sistem referensi linear dan posisi yang "
-"dibaca dari stdin atau sebuah berkas."
-#: ../gui/wxpython/menustrings.py:622 ../gui/wxpython/menustrings.py:1528
-msgid "Find line id and offset"
-msgstr "Cari id garis dan offset"
-#: ../gui/wxpython/menustrings.py:623 ../gui/wxpython/menustrings.py:1529
-msgid ""
-"Finds line id and real km+offset for given points in vector map using linear "
-"reference system."
-msgstr ""
-"Cari identitas garis dan km+offset sebenarnya untuk titik tertentu dalam "
-"peta vektor menggunakan sistem referensi linear."
-#: ../gui/wxpython/menustrings.py:624 ../gui/wxpython/menustrings.py:1530
-msgid "Nearest features"
-#: ../gui/wxpython/menustrings.py:625 ../gui/wxpython/menustrings.py:1531
-msgid ""
-"Finds the nearest element in vector map 'to' for elements in vector map "
-"'from'."
-msgstr ""
-"Cari elemen terdekat dalam peta vektor 'to' untuk elemen dalam peta vektor "
-"'from'."
-#: ../gui/wxpython/menustrings.py:626 ../gui/wxpython/menustrings.py:1532
-msgid "Network analysis"
-msgstr "Analisis jaringan"
-#: ../gui/wxpython/menustrings.py:628 ../gui/wxpython/menustrings.py:1534
-msgid "Tool for interactive vector network analysis."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:629 ../gui/wxpython/menustrings.py:1535
-#, fuzzy
-msgid "Network preparation"
-#: ../gui/wxpython/menustrings.py:630 ../gui/wxpython/menustrings.py:1536
-#, fuzzy
-msgid "Performs network maintenance."
-#: ../gui/wxpython/menustrings.py:631 ../gui/wxpython/menustrings.py:1537
-msgid "Allocate subnets"
-msgstr "Alokasi subjaringan"
-#: ../gui/wxpython/menustrings.py:632 ../gui/wxpython/menustrings.py:1538
-msgid ""
-"Allocates subnets for nearest centers (direction from center). center node "
-"must be opened (costs >= 0). Costs of center node are used in calculation"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:633 ../gui/wxpython/menustrings.py:1539
-msgid "Split net"
-msgstr "Pecah jaringan"
-#: ../gui/wxpython/menustrings.py:634 ../gui/wxpython/menustrings.py:1540
-msgid ""
-"Splits net by cost isolines. Splits net to bands between cost isolines "
-"(direction from center). Center node must be opened (costs >= 0). Costs of "
-"center node are used in calculation."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:635 ../gui/wxpython/menustrings.py:1541
-msgid "Shortest path"
-msgstr "Jalur terdekat"
-#: ../gui/wxpython/menustrings.py:636 ../gui/wxpython/menustrings.py:1542
-msgid "Finds shortest path on vector network."
-msgstr "Cari jarak terdekat dalam sebuah jaringan vektor."
-#: ../gui/wxpython/menustrings.py:637 ../gui/wxpython/menustrings.py:1543
-#, fuzzy
-msgid "Shortest path for sets of features"
-#: ../gui/wxpython/menustrings.py:638 ../gui/wxpython/menustrings.py:1544
-msgid ""
-"Computes shortest distance via the network between the given sets of "
-"features. Finds the shortest paths from each 'from' point to the nearest "
-"'to' feature and various information about this relation are uploaded to the "
-"attribute table."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:639 ../gui/wxpython/menustrings.py:1545
-#, fuzzy
-msgid "Shortest path using timetables"
-#: ../gui/wxpython/menustrings.py:640 ../gui/wxpython/menustrings.py:1546
-#, fuzzy
-msgid "Finds shortest path using timetables."
-#: ../gui/wxpython/menustrings.py:641 ../gui/wxpython/menustrings.py:1547
-#, fuzzy
-msgid "Shortest path for all pairs"
-#: ../gui/wxpython/menustrings.py:642 ../gui/wxpython/menustrings.py:1548
-msgid "Computes the shortest path between all pairs of nodes in the network."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:643 ../gui/wxpython/menustrings.py:1549
-msgid "Visibility network"
-msgstr "Visibilitas jaringan"
-#: ../gui/wxpython/menustrings.py:644 ../gui/wxpython/menustrings.py:1550
-#, fuzzy
-msgid "Performs visibility graph construction."
-msgstr "Pembangunan grafik visibilitas."
-#: ../gui/wxpython/menustrings.py:645 ../gui/wxpython/menustrings.py:1551
-msgid "Bridges and articulation points"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:646 ../gui/wxpython/menustrings.py:1552
-msgid "Computes bridges and articulation points in the network."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:647 ../gui/wxpython/menustrings.py:1553
-msgid "Maximum flow"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:648 ../gui/wxpython/menustrings.py:1554
-msgid "Computes the maximum flow between two sets of nodes in the network."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:649 ../gui/wxpython/menustrings.py:1555
-#, fuzzy
-msgid "Vertex connectivity"
-msgstr "Koneksi vektor basisdata"
-#: ../gui/wxpython/menustrings.py:650 ../gui/wxpython/menustrings.py:1556
-msgid "Computes vertex connectivity between two sets of nodes in the network."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:651 ../gui/wxpython/menustrings.py:1557
-#, fuzzy
-msgid "Components"
-msgstr "Principal component"
-#: ../gui/wxpython/menustrings.py:652 ../gui/wxpython/menustrings.py:1558
-msgid "Computes strongly and weakly connected components in the network."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:653 ../gui/wxpython/menustrings.py:1559
-#, fuzzy
-msgid "Centrality"
-msgstr "Tes kenormalan"
-#: ../gui/wxpython/menustrings.py:654 ../gui/wxpython/menustrings.py:1560
-msgid ""
-"Computes degree, centrality, betweeness, closeness and eigenvector "
-"centrality measures in the network."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:655 ../gui/wxpython/menustrings.py:1561
-msgid "Steiner tree"
-msgstr "Steiner tree"
-#: ../gui/wxpython/menustrings.py:656 ../gui/wxpython/menustrings.py:1562
-msgid ""
-"Creates Steiner tree for the network and given terminals. Note that 'Minimum "
-"Steiner Tree' problem is NP-hard and heuristic algorithm is used in this "
-"module so the result may be sub optimal."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:657 ../gui/wxpython/menustrings.py:1563
-msgid "Minimum spanning tree"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:658 ../gui/wxpython/menustrings.py:1564
-msgid "Computes minimum spanning tree for the network."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:659 ../gui/wxpython/menustrings.py:1565
-msgid "Traveling salesman analysis"
-msgstr "Analisis traveling salesman"
-#: ../gui/wxpython/menustrings.py:660 ../gui/wxpython/menustrings.py:1566
-msgid ""
-"Creates a cycle connecting given nodes (Traveling salesman problem). Note "
-"that TSP is NP-hard, heuristic algorithm is used by this module and created "
-"cycle may be sub optimal"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:661 ../gui/wxpython/menustrings.py:662
-#: ../gui/wxpython/menustrings.py:1567 ../gui/wxpython/menustrings.py:1568
-msgid "Overlay vector maps"
-#: ../gui/wxpython/menustrings.py:663 ../gui/wxpython/menustrings.py:1569
-msgid ""
-"Overlays two vector maps offering clip, intersection, difference, "
-"symmetrical difference, union operators."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:664 ../gui/wxpython/menustrings.py:1570
-msgid "Patch vector maps"
-msgstr "Gabungkan peta vektor"
-#: ../gui/wxpython/menustrings.py:665 ../gui/wxpython/menustrings.py:1571
-#, fuzzy
-msgid "Creates a new vector map by combining other vector maps."
-msgstr ""
-"Buat sebuah layer peta vektor dengan menggabungkan layer peta vektor lainnya."
-#: ../gui/wxpython/menustrings.py:666 ../gui/wxpython/menustrings.py:1572
-#, fuzzy
-msgid "Manage categories"
-msgstr "Kelola atau laporkan kategori"
-#: ../gui/wxpython/menustrings.py:667 ../gui/wxpython/menustrings.py:1573
-#, fuzzy
-msgid "Change or report categories"
-#: ../gui/wxpython/menustrings.py:668 ../gui/wxpython/menustrings.py:1574
-#, fuzzy
-msgid "Attaches, deletes or reports vector categories to map geometry."
-msgstr "Tempel, hapus atau laporkan kategori vektor ke geometri peta."
-#: ../gui/wxpython/menustrings.py:670 ../gui/wxpython/menustrings.py:1576
-msgid ""
-"Changes vector category values for an existing vector map according to "
-"results of SQL queries or a value in attribute table column."
-msgstr ""
-"Ubah nilai kategori vektor dari sebuah peta vektor yang ada sesuai dengan "
-"hasil dari kueri SQL atau sebuah nilai dalam kolom tabel atribut."
-#: ../gui/wxpython/menustrings.py:672 ../gui/wxpython/menustrings.py:1578
-msgid "Update area attributes from raster"
-msgstr "Perbaharui atribut area dari raster"
-#: ../gui/wxpython/menustrings.py:673 ../gui/wxpython/menustrings.py:1579
-#, fuzzy
-msgid ""
-"Calculates univariate statistics from a raster map based on a vector map and "
-"uploads statistics to new attribute columns."
-msgstr ""
-"Hitung statistik univariat dari sebuah peta raster GRASS berdasarkan poligon "
-"vektor dan unggah statistik ke dalam kolom atribut yang baru."
-#: ../gui/wxpython/menustrings.py:674 ../gui/wxpython/menustrings.py:1580
-#, fuzzy
-msgid "Update area attributes from vector"
-#: ../gui/wxpython/menustrings.py:675 ../gui/wxpython/menustrings.py:1581
-#, fuzzy
-msgid "Count points in areas, calculate statistics from point attributes."
-msgstr ""
-"Menghitung statistik univariat dari sebuah peta raster dengan sel non-null."
-#: ../gui/wxpython/menustrings.py:676 ../gui/wxpython/menustrings.py:1582
-msgid "Update point attributes from areas"
-msgstr "Perbaharui atritbut titik dari area"
-#: ../gui/wxpython/menustrings.py:677 ../gui/wxpython/menustrings.py:1583
-msgid "Uploads vector values at positions of vector points to the table."
-msgstr "Unggah nilai vektor pada posisi vektor titik ke dalam tabel."
-#: ../gui/wxpython/menustrings.py:678 ../gui/wxpython/menustrings.py:1584
-#, fuzzy
-msgid "Update database values from vector"
-msgstr "Isi nilai basisdata dari fitur vektor."
-#: ../gui/wxpython/menustrings.py:679 ../gui/wxpython/menustrings.py:1585
-#, fuzzy
-msgid "Populates attribute values from vector features."
-#: ../gui/wxpython/menustrings.py:680 ../gui/wxpython/menustrings.py:1586
-msgid "Sample raster maps at point locations"
-msgstr "Cuplikan peta raster pada lokasi titik"
-#: ../gui/wxpython/menustrings.py:681 ../gui/wxpython/menustrings.py:1587
-msgid "Uploads raster values at positions of vector points to the table."
-msgstr "Unggah nilai raster pada posisi vektor titik ke dalam tabel."
-#: ../gui/wxpython/menustrings.py:682 ../gui/wxpython/menustrings.py:1588
-msgid "Sample raster neighborhood around points"
-msgstr "Cuplik ketetanggaan raster di sekitar titik"
-#: ../gui/wxpython/menustrings.py:683 ../gui/wxpython/menustrings.py:1589
-msgid "Samples a raster map at vector point locations."
-msgstr "Cuplik sebuah peta raster pada lokasi vektor titik."
-#: ../gui/wxpython/menustrings.py:684 ../gui/wxpython/menustrings.py:1590
-msgid "Generate area for current region"
-msgstr "Hasilkan area untuk region saat ini"
-#: ../gui/wxpython/menustrings.py:685 ../gui/wxpython/menustrings.py:1591
-#, fuzzy
-msgid "Creates a vector polygon from the current region extent."
-msgstr "Buat sebuah vektor dari region saat ini."
-#: ../gui/wxpython/menustrings.py:686 ../gui/wxpython/menustrings.py:1592
-msgid "Generate areas from points"
-msgstr "Hasilkan area dari titik"
-#: ../gui/wxpython/menustrings.py:687 ../gui/wxpython/menustrings.py:1593
-msgid "Convex hull"
-msgstr "Convex hull"
-#: ../gui/wxpython/menustrings.py:688 ../gui/wxpython/menustrings.py:1594
-#, fuzzy
-msgid "Produces a 2D/3D convex hull for a given vector map."
-msgstr "Buat tabel warna baru menggunakan color rules"
-#: ../gui/wxpython/menustrings.py:689 ../gui/wxpython/menustrings.py:1595
-msgid "Delaunay triangles"
-msgstr "Segitiga delaunay"
-#: ../gui/wxpython/menustrings.py:690 ../gui/wxpython/menustrings.py:1596
-msgid ""
-"Creates a Delaunay triangulation from an input vector map containing points "
-"or centroids."
-msgstr ""
-"Buat sebuah segitiga Delaunay dari satu input peta vektor yang mengandung "
-"titik atau centroid."
-#: ../gui/wxpython/menustrings.py:691 ../gui/wxpython/menustrings.py:1597
-msgid "Voronoi diagram/Thiessen polygons"
-msgstr "Diagram Voronoi/Poligon Thiessen "
-#: ../gui/wxpython/menustrings.py:692 ../gui/wxpython/menustrings.py:1598
-#, fuzzy
-msgid ""
-"Creates a Voronoi diagram in current region from an input vector map "
-"containing points or centroids."
-msgstr ""
-"Buat sebuah diagram Voronoi dari satu input peta vektor yang mengandung "
-#: ../gui/wxpython/menustrings.py:693 ../gui/wxpython/menustrings.py:1599
-msgid "Generate grid"
-msgstr "Hasilkan grid"
-#: ../gui/wxpython/menustrings.py:694 ../gui/wxpython/menustrings.py:1600
-#, fuzzy
-msgid "Creates a vector map of a user-defined grid."
-msgstr "Buat sebuah peta vektor GRASS dari grid tertentu."
-#: ../gui/wxpython/menustrings.py:695 ../gui/wxpython/menustrings.py:1601
-msgid "Generate points"
-msgstr "Hasilkan titik"
-#: ../gui/wxpython/menustrings.py:696 ../gui/wxpython/menustrings.py:1602
-msgid "Generate from database"
-msgstr "Hasilkan dari basisdata"
-#: ../gui/wxpython/menustrings.py:697 ../gui/wxpython/menustrings.py:1603
-msgid ""
-"Creates new vector (points) map from database table containing coordinates."
-msgstr ""
-"Buat peta vektor baru (titik) dari tabel basisdata yang mengandung koordinat."
-#: ../gui/wxpython/menustrings.py:698 ../gui/wxpython/menustrings.py:1604
-msgid "Generate points along lines"
-msgstr "Buat titik sepanjang garis"
-#: ../gui/wxpython/menustrings.py:699 ../gui/wxpython/menustrings.py:1605
-#, fuzzy
-msgid "Creates points along input lines in new vector map with 2 layers."
-msgstr "Buat titik sepanjang input garis dalam vektor baru dengan 2 layer."
-#: ../gui/wxpython/menustrings.py:700 ../gui/wxpython/menustrings.py:1606
-msgid "Generate random points"
-msgstr "Hasilkan titik acak"
-#: ../gui/wxpython/menustrings.py:701 ../gui/wxpython/menustrings.py:1607
-#, fuzzy
-msgid "Generates random 2D/3D vector points."
-msgstr "Hasilkan peta vektor titik 2D/3D secara acak."
-#: ../gui/wxpython/menustrings.py:702 ../gui/wxpython/menustrings.py:1608
-msgid "Perturb points"
-msgstr "Titik perturbasi"
-#: ../gui/wxpython/menustrings.py:703 ../gui/wxpython/menustrings.py:1609
-#, fuzzy
-msgid "Random location perturbations of vector points."
-msgstr "Lokasi perturbasi acak dari vektor titik GRASS"
-#: ../gui/wxpython/menustrings.py:704 ../gui/wxpython/menustrings.py:1610
-msgid "Remove outliers in point sets"
-msgstr "Hilangkan outlier dalam titik"
-#: ../gui/wxpython/menustrings.py:706 ../gui/wxpython/menustrings.py:1612
-msgid "Test/training point sets"
-msgstr "Titik pengambilan cuplikan (training point)"
-#: ../gui/wxpython/menustrings.py:707 ../gui/wxpython/menustrings.py:1613
-msgid "Randomly partition points into test/train sets."
-msgstr "Bagi titik-titik secara acak menjadi titik cuplikan (training set)."
-#: ../gui/wxpython/menustrings.py:709 ../gui/wxpython/menustrings.py:1615
-msgid "Basic vector metadata"
-#: ../gui/wxpython/menustrings.py:710 ../gui/wxpython/menustrings.py:1616
-#, fuzzy
-msgid "Outputs basic information about a vector map."
-#: ../gui/wxpython/menustrings.py:711 ../gui/wxpython/menustrings.py:1617
-#, fuzzy
-msgid "Classify attribute data"
-msgstr "Perlihatkan data atribut"
-#: ../gui/wxpython/menustrings.py:712 ../gui/wxpython/menustrings.py:1618
-msgid "Classifies attribute data, e.g. for thematic mapping"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:713 ../gui/wxpython/menustrings.py:1619
-msgid "Report topology by category"
-msgstr "Laporkan topologi berdasarkan kategori"
-#: ../gui/wxpython/menustrings.py:714 ../gui/wxpython/menustrings.py:1620
-#, fuzzy
-msgid "Reports geometry statistics for vector maps."
-msgstr "Laporan statistik geometri untuk vektor."
-#: ../gui/wxpython/menustrings.py:715 ../gui/wxpython/menustrings.py:1621
-#, fuzzy
-msgid "Univariate attribute statistics for points"
-msgstr "Statistik atribut univariat"
-#: ../gui/wxpython/menustrings.py:716 ../gui/wxpython/menustrings.py:1622
-msgid ""
-"Calculates univariate statistics of vector map features. Variance and "
-"standard deviation is calculated only for points if specified."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:717 ../gui/wxpython/menustrings.py:1623
-#, fuzzy
-msgid "Univariate statistics for attribute columns"
-#: ../gui/wxpython/menustrings.py:718 ../gui/wxpython/menustrings.py:1624
-#, fuzzy
-msgid ""
-"Calculates univariate statistics on selected table column for a GRASS vector "
-"map."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:719 ../gui/wxpython/menustrings.py:1625
-msgid "Quadrat indices"
-msgstr "Indeks kuadrat"
-#: ../gui/wxpython/menustrings.py:720 ../gui/wxpython/menustrings.py:1626
-#, fuzzy
-msgid "Indices for quadrat counts of vector point lists."
-msgstr "Indeks untuk jumlah kuadrat dari daftar titik."
-#: ../gui/wxpython/menustrings.py:721 ../gui/wxpython/menustrings.py:1627
-msgid "Test normality"
-#: ../gui/wxpython/menustrings.py:722 ../gui/wxpython/menustrings.py:1628
-#, fuzzy
-msgid "Tests for normality for vector points."
-msgstr "Tes kenormalan untuk titik."
-#: ../gui/wxpython/menustrings.py:723 ../gui/wxpython/menustrings.py:1629
-#, fuzzy
-msgid "&Imagery"
-msgstr "Citra"
-#: ../gui/wxpython/menustrings.py:724 ../gui/wxpython/menustrings.py:1630
-msgid "Develop images and groups"
-msgstr "Buat citra dan grup"
-#: ../gui/wxpython/menustrings.py:725 ../gui/wxpython/menustrings.py:1631
-msgid "Create/edit group"
-msgstr "Buat/edit grup"
-#: ../gui/wxpython/menustrings.py:726 ../gui/wxpython/menustrings.py:1632
-#, fuzzy
-msgid "Creates, edits, and lists groups of imagery files."
-msgstr "Buat, edit dan daftar grup dan subgrup dari berkas citra."
-#: ../gui/wxpython/menustrings.py:727 ../gui/wxpython/menustrings.py:1633
-msgid "Target group"
-msgstr "Grup target"
-#: ../gui/wxpython/menustrings.py:728 ../gui/wxpython/menustrings.py:1634
-msgid "Targets an imagery group to a GRASS location and mapset."
-msgstr "Target grup citra ke satu location dan mapset GRASS."
-#: ../gui/wxpython/menustrings.py:729 ../gui/wxpython/menustrings.py:1635
-msgid "Mosaic images"
-msgstr "Gabungkan citra"
-#: ../gui/wxpython/menustrings.py:730 ../gui/wxpython/menustrings.py:1636
-#, fuzzy
-msgid "Mosaics several images and extends colormap."
-msgstr "Mosaik hingga 4 citra dan perluas colormap; buat peta *.mosaik"
-#: ../gui/wxpython/menustrings.py:731 ../gui/wxpython/menustrings.py:1637
-msgid "Manage image colors"
-msgstr "Kelola warna citra"
-#: ../gui/wxpython/menustrings.py:732 ../gui/wxpython/menustrings.py:1638
-msgid "Color balance for RGB"
-msgstr "Keseimbangan warna RGB"
-#: ../gui/wxpython/menustrings.py:733 ../gui/wxpython/menustrings.py:1639
-#, fuzzy
-msgid "Performs auto-balancing of colors for RGB images."
-msgstr "Penyeimbangan warna secara otomatis untuk citra LANDSAT"
-#: ../gui/wxpython/menustrings.py:734 ../gui/wxpython/menustrings.py:1640
-msgid "HIS to RGB"
-msgstr "HIS ke RGB"
-#: ../gui/wxpython/menustrings.py:735 ../gui/wxpython/menustrings.py:1641
-msgid ""
-"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
-"RGB (Red-Green-Blue) color space."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:737 ../gui/wxpython/menustrings.py:1643
-msgid ""
-"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
-"Intensity-Saturation) color space."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:738 ../gui/wxpython/menustrings.py:1644
-msgid "Rectify image or raster"
-msgstr "Rektifikasi citra atau raster"
-#: ../gui/wxpython/menustrings.py:739 ../gui/wxpython/menustrings.py:1645
-#, fuzzy
-msgid ""
-"Rectifies an image by computing a coordinate transformation for each pixel "
-"in the image based on the control points."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:741 ../gui/wxpython/menustrings.py:1647
-msgid "Generate histogram of image"
-msgstr "Hasilkan histogram dari citra"
-#: ../gui/wxpython/menustrings.py:742 ../gui/wxpython/menustrings.py:1648
-msgid "Spectral response"
-msgstr "Respons spektral"
-#: ../gui/wxpython/menustrings.py:743 ../gui/wxpython/menustrings.py:1649
-#, fuzzy
-msgid ""
-"Displays spectral response at user specified locations in group or images."
-msgstr "tampilkan respon spektral pada lokasi tertentu dalam grup atau citra"
-#: ../gui/wxpython/menustrings.py:744 ../gui/wxpython/menustrings.py:1650
-#, fuzzy
-msgid "Pan sharpening"
-msgstr "Penajaman citra dengan Brovey"
-#: ../gui/wxpython/menustrings.py:745 ../gui/wxpython/menustrings.py:1651
-#, fuzzy
-msgid ""
-"Image fusion algorithms to sharpen multispectral with high-res panchromatic "
-"channels"
-msgstr ""
-"Transformasi Brovey untuk menggabungkan kanal multispektral dan pankromatik "
-"resolusi tinggi"
-#: ../gui/wxpython/menustrings.py:746 ../gui/wxpython/menustrings.py:1652
-msgid "Classify image"
-msgstr "Klasifikasi citra"
-#: ../gui/wxpython/menustrings.py:747 ../gui/wxpython/menustrings.py:1653
-msgid "Clustering input for unsupervised classification"
-msgstr "Input klaster untuk klasifikasi tak-terbimbing"
-#: ../gui/wxpython/menustrings.py:748 ../gui/wxpython/menustrings.py:1654
-msgid ""
-"Generates spectral signatures for land cover types in an image using a "
-"clustering algorithm. The resulting signature file is used as input for i."
-"maxlik, to generate an unsupervised image classification."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:749 ../gui/wxpython/menustrings.py:1655
-msgid "Input for supervised MLC"
-msgstr "Input untuk klasifikasi terbimbing MLC"
-#: ../gui/wxpython/menustrings.py:750 ../gui/wxpython/menustrings.py:1656
-#, fuzzy
-msgid "Generates statistics for i.maxlik from raster map."
-msgstr "Menghasilkan statistik untuk i.maxlik dari layer peta raster."
-#: ../gui/wxpython/menustrings.py:751 ../gui/wxpython/menustrings.py:1657
-msgid "Maximum likelihood classification (MLC)"
-msgstr "Klasifikasi Maximum Likelihood (MLC)"
-#: ../gui/wxpython/menustrings.py:752 ../gui/wxpython/menustrings.py:1658
-msgid ""
-"Classifies the cell spectral reflectances in imagery data. Classification is "
-"based on the spectral signature information generated by either i.cluster, g."
-"gui.iclass, or i.gensig."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:753 ../gui/wxpython/menustrings.py:1659
-#: ../gui/wxpython/menustrings.py:1924
-#, fuzzy
-msgid "Interactive input for supervised classification"
-#: ../gui/wxpython/menustrings.py:754 ../gui/wxpython/menustrings.py:1660
-#: ../gui/wxpython/menustrings.py:1925
-msgid ""
-"Generates spectral signatures by allowing the user to outline training areas."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:755 ../gui/wxpython/menustrings.py:1661
-msgid "Input for supervised SMAP"
-msgstr "Input untuk klasifikasi terbimbing SMAP"
-#: ../gui/wxpython/menustrings.py:756 ../gui/wxpython/menustrings.py:1662
-#, fuzzy
-msgid "Generates statistics for i.smap from raster map."
-msgstr "Hasilkan statistik untuk i.smap dari layer peta raster"
-#: ../gui/wxpython/menustrings.py:757 ../gui/wxpython/menustrings.py:1663
-msgid "Sequential maximum a posteriori classification (SMAP)"
-msgstr "Klasifikasi sequential maximum a posteriori (SMAP)"
-#: ../gui/wxpython/menustrings.py:758 ../gui/wxpython/menustrings.py:1664
-msgid ""
-"Performs contextual image classification using sequential maximum a "
-"posteriori (SMAP) estimation."
-msgstr ""
-"Melakukan klasifikasi citra kontekstual dengan perkiraan sequential maximum "
-"a posteriori (SMAP)"
-#: ../gui/wxpython/menustrings.py:759 ../gui/wxpython/menustrings.py:1665
-#, fuzzy
-msgid "Object segmentation"
-msgstr "Rotasi:"
-#: ../gui/wxpython/menustrings.py:760 ../gui/wxpython/menustrings.py:1666
-msgid "Identifies segments (objects) from imagery data."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:761 ../gui/wxpython/menustrings.py:1667
-msgid "Filter image"
-msgstr "Filter citra"
-#: ../gui/wxpython/menustrings.py:762 ../gui/wxpython/menustrings.py:1668
-msgid "Edge detection"
-#: ../gui/wxpython/menustrings.py:763 ../gui/wxpython/menustrings.py:1669
-msgid "Zero-crossing \"edge detection\" raster function for image processing."
-msgstr "Fungsi raster zero-crossing \"edge detection\" untuk pengolahan citra."
-#: ../gui/wxpython/menustrings.py:764 ../gui/wxpython/menustrings.py:1670
-msgid "Matrix/convolving filter"
-msgstr "Filter matriks/convolving"
-#: ../gui/wxpython/menustrings.py:765 ../gui/wxpython/menustrings.py:1671
-#, fuzzy
-msgid "Performs raster map matrix filter."
-msgstr "Matriks filter peta raster"
-#: ../gui/wxpython/menustrings.py:766 ../gui/wxpython/menustrings.py:1672
-msgid "Transform image"
-msgstr "Transformasi citra"
-#: ../gui/wxpython/menustrings.py:767 ../gui/wxpython/menustrings.py:1673
-msgid "Canonical correlation"
-msgstr "Korelasi kanonikal"
-#: ../gui/wxpython/menustrings.py:768 ../gui/wxpython/menustrings.py:1674
-#, fuzzy
-msgid "Canonical components analysis (CCA) program for image processing."
-msgstr "Program analisis komponen kanonikal (cca) untuk pengolahan citra."
-#: ../gui/wxpython/menustrings.py:769 ../gui/wxpython/menustrings.py:1675
-msgid "Principal components"
-#: ../gui/wxpython/menustrings.py:770 ../gui/wxpython/menustrings.py:1676
-#, fuzzy
-msgid "Principal components analysis (PCA) for image processing."
-msgstr "Program analisis principal component (pca) untuk pengolahan citra."
-#: ../gui/wxpython/menustrings.py:771 ../gui/wxpython/menustrings.py:1677
-msgid "Fast Fourier"
-msgstr "Fast Fourier"
-#: ../gui/wxpython/menustrings.py:772 ../gui/wxpython/menustrings.py:1678
-msgid "Fast Fourier Transform (FFT) for image processing."
-msgstr "Fast Fourier Transform (FFT) untuk pengolahan citra."
-#: ../gui/wxpython/menustrings.py:773 ../gui/wxpython/menustrings.py:1679
-msgid "Inverse Fast Fourier"
-msgstr "Inverse Fast Fourier"
-#: ../gui/wxpython/menustrings.py:774 ../gui/wxpython/menustrings.py:1680
-msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
-msgstr "Inverse Fast Fourier Transform (IFFT) untuk pengolahan citra."
-#: ../gui/wxpython/menustrings.py:775 ../gui/wxpython/menustrings.py:1681
-msgid "Satellite images tools"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:776 ../gui/wxpython/menustrings.py:1682
-msgid "Aster DN to radiance/reflectance"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:777 ../gui/wxpython/menustrings.py:1683
-msgid ""
-"Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature "
-"from ASTER DN."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:778 ../gui/wxpython/menustrings.py:1684
-msgid "Landsat DN to radiance/reflectance"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:779 ../gui/wxpython/menustrings.py:1685
-msgid ""
-"Calculates top-of-atmosphere radiance or reflectance and temperature for "
-"Landsat MSS/TM/ETM+/OLI"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:780 ../gui/wxpython/menustrings.py:1686
-msgid "Landsat cloud cover assessment"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:781 ../gui/wxpython/menustrings.py:1687
-msgid "Performs Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA)."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:782 ../gui/wxpython/menustrings.py:1688
-msgid "Modis quality control"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:783 ../gui/wxpython/menustrings.py:1689
-#, fuzzy
-msgid "Extracts quality control parameters from MODIS QC layers."
-msgstr "Masukkan parameter untuk"
-#: ../gui/wxpython/menustrings.py:784 ../gui/wxpython/menustrings.py:1690
-#, fuzzy
-msgid "Atmospheric correction"
-#: ../gui/wxpython/menustrings.py:785 ../gui/wxpython/menustrings.py:1691
-msgid ""
-"Performs atmospheric correction using the 6S algorithm. 6S - Second "
-"Simulation of Satellite Signal in the Solar Spectrum."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:786 ../gui/wxpython/menustrings.py:1692
-#, fuzzy
-msgid "Topographic correction"
-#: ../gui/wxpython/menustrings.py:787 ../gui/wxpython/menustrings.py:1693
-msgid "Computes topographic correction of reflectance."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:788 ../gui/wxpython/menustrings.py:1694
-msgid "Satellite images products"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:789 ../gui/wxpython/menustrings.py:1695
-#, fuzzy
-msgid "Vegetation indices"
-msgstr "Batas region"
-#: ../gui/wxpython/menustrings.py:790 ../gui/wxpython/menustrings.py:1696
-msgid ""
-"Calculates different types of vegetation indices. Uses red and nir bands "
-"mostly, and some indices require additional bands."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:791 ../gui/wxpython/menustrings.py:1697
-msgid "Tasseled cap vegetation index"
-msgstr "Indeks vegetasi tasseled cap"
-#: ../gui/wxpython/menustrings.py:792 ../gui/wxpython/menustrings.py:1698
-#, fuzzy
-msgid "Performs Tasseled Cap (Kauth Thomas) transformation."
-msgstr "Transformasi Tasseled Cap (Kauth Thomas) untuk data LANDSAT - TM"
-#: ../gui/wxpython/menustrings.py:793 ../gui/wxpython/menustrings.py:1699
-msgid "Albedo"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:794 ../gui/wxpython/menustrings.py:1700
-msgid "Computes broad band albedo from surface reflectance."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:795 ../gui/wxpython/menustrings.py:1701
-#, fuzzy
-msgid "Emissivity"
-msgstr "Visibilitas "
-#: ../gui/wxpython/menustrings.py:796 ../gui/wxpython/menustrings.py:1702
-msgid "Computes emissivity from NDVI, generic method for sparse land."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:797 ../gui/wxpython/menustrings.py:1703
-msgid "Biomass growth"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:798 ../gui/wxpython/menustrings.py:1704
-msgid "Computes biomass growth, precursor of crop yield calculation."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:799 ../gui/wxpython/menustrings.py:1705
-msgid "Evapotranspiration calculation"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:800 ../gui/wxpython/menustrings.py:1706
-msgid "Instantaneaous Net Radiation"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:801 ../gui/wxpython/menustrings.py:1707
-msgid "Net radiation approximation (Bastiaanssen, 1995)."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:802 ../gui/wxpython/menustrings.py:1708
-msgid "Soil heat flux"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:803 ../gui/wxpython/menustrings.py:1709
-msgid "Soil heat flux approximation (Bastiaanssen, 1995)."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:804 ../gui/wxpython/menustrings.py:1710
-msgid "Sensible heat flux"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:805 ../gui/wxpython/menustrings.py:1711
-msgid "Computes sensible heat flux iteration SEBAL 01."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:806 ../gui/wxpython/menustrings.py:1712
-msgid "Evaporative fraction"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:807 ../gui/wxpython/menustrings.py:1713
-msgid "Computes evaporative fraction and root zone soil moisture."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:808 ../gui/wxpython/menustrings.py:1714
-msgid "Actual Evapotranspiration"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:809 ../gui/wxpython/menustrings.py:1715
-msgid "Actual evapotranspiration for diurnal period (Bastiaanssen, 1995)."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:810 ../gui/wxpython/menustrings.py:1716
-msgid "Temporal integration of ETa"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:811 ../gui/wxpython/menustrings.py:1717
-msgid ""
-"Computes temporal integration of satellite ET actual (ETa) following the "
-"daily ET reference (ETo) from meteorological station(s)."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:812 ../gui/wxpython/menustrings.py:1718
-msgid "Hargreaves methods Evapotranspiration"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:813 ../gui/wxpython/menustrings.py:1719
-msgid ""
-"Computes evapotranspiration calculation modified or original Hargreaves "
-"formulation, 2001."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:814 ../gui/wxpython/menustrings.py:1720
-msgid "Penman-Monteith Evapotranspiration"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:815 ../gui/wxpython/menustrings.py:1721
-msgid ""
-"Computes potential evapotranspiration calculation with hourly Penman-"
-"Monteith."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:816 ../gui/wxpython/menustrings.py:1722
-msgid "Priestley-Taylor Evapotranspiration"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:817 ../gui/wxpython/menustrings.py:1723
-msgid ""
-"Computes evapotranspiration calculation Priestley and Taylor formulation, "
-"1972."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:819 ../gui/wxpython/menustrings.py:1725
-msgid "Kappa analysis"
-msgstr "Analisis Kappa"
-#: ../gui/wxpython/menustrings.py:820 ../gui/wxpython/menustrings.py:1726
-#, fuzzy
-msgid ""
-"Calculates error matrix and kappa parameter for accuracy assessment of "
-"classification result."
-msgstr ""
-"Menghitung matriks kesalahan dan parameter kappa untuk uji akurasi dari "
-"hasil klasifikasi."
-#: ../gui/wxpython/menustrings.py:821 ../gui/wxpython/menustrings.py:1727
-msgid "OIF for LandSat TM"
-msgstr "OIF untuk Landsat TM"
-#: ../gui/wxpython/menustrings.py:822 ../gui/wxpython/menustrings.py:1728
-#, fuzzy
-msgid "Calculates Optimum-Index-Factor table for spectral bands"
-msgstr ""
-"Menghitung tabel Optimum-Index-Factor (OIF) untuk LANDSAT TM kanal 1-5, & 7"
-#: ../gui/wxpython/menustrings.py:823 ../gui/wxpython/menustrings.py:1729
-#, fuzzy
-msgid "3D r&aster"
-msgstr "raster"
-#: ../gui/wxpython/menustrings.py:824 ../gui/wxpython/menustrings.py:1730
-#, fuzzy
-msgid "Develop 3D raster map"
-msgstr "Bangun peta raster"
-#: ../gui/wxpython/menustrings.py:825 ../gui/wxpython/menustrings.py:1731
-msgid "Manage 3D NULL values"
-msgstr "Mengelola nilai NULL 3D"
-#: ../gui/wxpython/menustrings.py:826 ../gui/wxpython/menustrings.py:1732
-msgid "Explicitly create the 3D NULL-value bitmap file."
-msgstr "Membuat berkas bitmap nilai NULL 3D secara eksplisit"
-#: ../gui/wxpython/menustrings.py:827 ../gui/wxpython/menustrings.py:1733
-msgid "Manage timestamp"
-msgstr "Mengelola catatat waktu"
-#: ../gui/wxpython/menustrings.py:828 ../gui/wxpython/menustrings.py:1734
-#, fuzzy
-msgid ""
-"Modifies a timestamp for a 3D raster map. Print/add/remove a timestamp for a "
-"3D raster map."
-msgstr "Cetak/tambah/hapus catatan waktu untuk peta raster 3D"
-#: ../gui/wxpython/menustrings.py:830 ../gui/wxpython/menustrings.py:1736
-#, fuzzy
-msgid "3D rasters to raster series"
-msgstr "Volume ke rangkaian raster"
-#: ../gui/wxpython/menustrings.py:832 ../gui/wxpython/menustrings.py:1738
-#, fuzzy
-msgid "3D color tables"
-msgstr "Tabel warna "
-#: ../gui/wxpython/menustrings.py:833 ../gui/wxpython/menustrings.py:1739
-#, fuzzy
-msgid "Creates/modifies the color table associated with a 3D raster map."
-msgstr "Buat/modifikasi tabel warna berkaitan dengan sebuah layer peta raster."
-#: ../gui/wxpython/menustrings.py:834 ../gui/wxpython/menustrings.py:1740
-#, fuzzy
-msgid "Export 3D color table"
-#: ../gui/wxpython/menustrings.py:835 ../gui/wxpython/menustrings.py:1741
-#, fuzzy
-msgid "Exports the color table associated with a 3D raster map."
-#: ../gui/wxpython/menustrings.py:836 ../gui/wxpython/menustrings.py:1742
-msgid "3D mask"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:837 ../gui/wxpython/menustrings.py:1743
-msgid "Establishes the current working 3D raster mask."
-msgstr "Menetapkan mask untuk raster 3D saat ini "
-#: ../gui/wxpython/menustrings.py:838 ../gui/wxpython/menustrings.py:839
-#: ../gui/wxpython/menustrings.py:1744 ../gui/wxpython/menustrings.py:1745
-#, fuzzy
-msgid "3D raster map calculator"
-msgstr "Kalkulator peta raster 3D"
-#: ../gui/wxpython/menustrings.py:840 ../gui/wxpython/menustrings.py:1746
-msgid "Cross section"
-#: ../gui/wxpython/menustrings.py:841 ../gui/wxpython/menustrings.py:1747
-#, fuzzy
-msgid ""
-"Creates cross section 2D raster map from 3D raster map based on 2D elevation "
-"map"
-msgstr ""
-"Buat potongan melintang peta raster 2D dari peta raster 3D berdasarkan peta "
-"ketinggian 2D"
-#: ../gui/wxpython/menustrings.py:843 ../gui/wxpython/menustrings.py:1749
-msgid ""
-"Numerical calculation program for transient, confined groundwater flow in "
-"three dimensions."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:844 ../gui/wxpython/menustrings.py:1750
-#, fuzzy
-msgid "Interpolate 3D raster from points"
-msgstr "Interpolasi volume dari titik"
-#: ../gui/wxpython/menustrings.py:845 ../gui/wxpython/menustrings.py:1751
-#, fuzzy
-msgid ""
-"Interpolates point data to a 3D raster map using regularized spline with "
-"tension (RST) algorithm."
-msgstr ""
-"Interpolasi data titik dari sebuah volume grid 3D dengan algoritma "
-"regularized spline with tension (RST)."
-#: ../gui/wxpython/menustrings.py:846 ../gui/wxpython/menustrings.py:1752
-#, fuzzy
-msgid "Reports and Statistics"
-#: ../gui/wxpython/menustrings.py:847 ../gui/wxpython/menustrings.py:1753
-#, fuzzy
-msgid "Basic 3D raster metadata"
-#: ../gui/wxpython/menustrings.py:848 ../gui/wxpython/menustrings.py:1754
-msgid "Outputs basic information about a user-specified 3D raster map layer."
-msgstr "Keluaran informasi dasar tentang layer peta raster 3D milik pengguna."
-#: ../gui/wxpython/menustrings.py:849 ../gui/wxpython/menustrings.py:1755
-#, fuzzy
-msgid "3D raster statistics"
-msgstr "Laporan dan statistik."
-#: ../gui/wxpython/menustrings.py:850 ../gui/wxpython/menustrings.py:1756
-#, fuzzy
-msgid "Generates volume statistics for 3D raster maps."
-msgstr "Menghasilkan statistik area untuk layer peta raster."
-#: ../gui/wxpython/menustrings.py:851 ../gui/wxpython/menustrings.py:1757
-#, fuzzy
-msgid "Univariate statistics for 3D rasters"
-msgstr "Statistik raster univariat"
-#: ../gui/wxpython/menustrings.py:852 ../gui/wxpython/menustrings.py:1758
-msgid ""
-"Calculates univariate statistics from the non-null cells of a 3D raster map. "
-msgstr ""
-#: ../gui/wxpython/menustrings.py:853 ../gui/wxpython/menustrings.py:1759
-#, fuzzy
-msgid "&Database"
-msgstr "Basisdata"
-#: ../gui/wxpython/menustrings.py:854 ../gui/wxpython/menustrings.py:1760
-msgid "Database information"
-msgstr "Informasi basisdata"
-#: ../gui/wxpython/menustrings.py:855 ../gui/wxpython/menustrings.py:1761
-#, fuzzy
-msgid "List databases"
-msgstr "Daftar tabel"
-#: ../gui/wxpython/menustrings.py:856 ../gui/wxpython/menustrings.py:1762
-#, fuzzy
-msgid "Lists all databases for a given driver and location."
-msgstr "Daftar semua tabel untuk basisdata tertentu."
-#: ../gui/wxpython/menustrings.py:857 ../gui/wxpython/menustrings.py:1763
-msgid "List drivers"
-msgstr "Daftar driver"
-#: ../gui/wxpython/menustrings.py:858 ../gui/wxpython/menustrings.py:1764
-#, fuzzy
-msgid "Lists all database drivers."
-msgstr "Daftar semua driver basisdata."
-#: ../gui/wxpython/menustrings.py:859 ../gui/wxpython/menustrings.py:1765
-msgid "List tables"
-#: ../gui/wxpython/menustrings.py:860 ../gui/wxpython/menustrings.py:1766
-msgid "Lists all tables for a given database."
-#: ../gui/wxpython/menustrings.py:861 ../gui/wxpython/menustrings.py:1767
-msgid "Describe table"
-msgstr "Deskripsi tabel"
-#: ../gui/wxpython/menustrings.py:862 ../gui/wxpython/menustrings.py:1768
-msgid "Describes a table in detail."
-msgstr "Deskripsi sebuah tabel dengan detil."
-#: ../gui/wxpython/menustrings.py:863 ../gui/wxpython/menustrings.py:1769
-msgid "List columns"
-msgstr "Daftar kolom"
-#: ../gui/wxpython/menustrings.py:864 ../gui/wxpython/menustrings.py:1770
-msgid "List all columns for a given table."
-msgstr "Daftar semua kolom untuk tabel tertentu."
-#: ../gui/wxpython/menustrings.py:865 ../gui/wxpython/menustrings.py:1771
-msgid "Manage databases"
-msgstr "Kelola basisdata"
-#: ../gui/wxpython/menustrings.py:866 ../gui/wxpython/menustrings.py:1772
-msgid "Connect"
-msgstr "Koneksikan"
-#: ../gui/wxpython/menustrings.py:867 ../gui/wxpython/menustrings.py:1773
-#, fuzzy
-msgid "Prints/sets general DB connection for current mapset."
-msgstr ""
-"Cetak/tentukan koneksi basisdata umum untuk mapset saat ini dan keluar."
-#: ../gui/wxpython/menustrings.py:868 ../gui/wxpython/menustrings.py:1774
-msgid "Login"
-msgstr "Login"
-#: ../gui/wxpython/menustrings.py:869 ../gui/wxpython/menustrings.py:1775
-#, fuzzy
-msgid "Sets user/password for DB driver/database."
-msgstr "Tentukan pengguna/kata kunci untuk driver/basisdata."
-#: ../gui/wxpython/menustrings.py:870 ../gui/wxpython/menustrings.py:1776
-#, fuzzy
-msgid "Create database"
-msgstr "&Buat tabel"
-#: ../gui/wxpython/menustrings.py:871 ../gui/wxpython/menustrings.py:1777
-#, fuzzy
-msgid "Creates an empty database."
-#: ../gui/wxpython/menustrings.py:872 ../gui/wxpython/menustrings.py:1778
-#, fuzzy
-msgid "Drop database"
-msgstr "Basisdata"
-#: ../gui/wxpython/menustrings.py:873 ../gui/wxpython/menustrings.py:1779
-#, fuzzy
-msgid "Removes an existing database."
-#: ../gui/wxpython/menustrings.py:874 ../gui/wxpython/menustrings.py:1780
-#, fuzzy
-msgid "Drop table"
-msgstr "Salin tabel"
-#: ../gui/wxpython/menustrings.py:875 ../gui/wxpython/menustrings.py:1781
-#, fuzzy
-msgid "Drops an attribute table."
-msgstr "Perlihatkan tabel atribut"
-#: ../gui/wxpython/menustrings.py:876 ../gui/wxpython/menustrings.py:1782
-msgid "Copy table"
-#: ../gui/wxpython/menustrings.py:877 ../gui/wxpython/menustrings.py:1783
-msgid ""
-"Copy a table. Either 'from_table' (optionally with 'where') can be used or "
-"'select' option, but not 'from_table' and 'select' at the same time."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:878 ../gui/wxpython/menustrings.py:898
-#: ../gui/wxpython/menustrings.py:1784 ../gui/wxpython/menustrings.py:1804
-#, fuzzy
-msgid "Drop column"
-msgstr "Hapus semua kolom"
-#: ../gui/wxpython/menustrings.py:879 ../gui/wxpython/menustrings.py:1785
-#, fuzzy
-msgid "Drops a column from selected attribute table."
-msgstr "Hapus juga tabel atribut terpaut (%s)"
-#: ../gui/wxpython/menustrings.py:880 ../gui/wxpython/menustrings.py:1786
-msgid "Test"
-msgstr "Tes"
-#: ../gui/wxpython/menustrings.py:881 ../gui/wxpython/menustrings.py:1787
-msgid "Test database driver, database must exist and set by db.connect."
-msgstr "Tes driver basisdata, basisdata harus ada dan diset dengan db.connect."
-#: ../gui/wxpython/menustrings.py:883 ../gui/wxpython/menustrings.py:1789
-msgid "Query any table"
-msgstr "Kueri sembarang tabel"
-#: ../gui/wxpython/menustrings.py:884 ../gui/wxpython/menustrings.py:1790
-#, fuzzy
-msgid "Selects data from attribute table. Performs SQL query statement(s)."
-msgstr "Silakan tunggu, sedang menampilkan data atribut ..."
-#: ../gui/wxpython/menustrings.py:887 ../gui/wxpython/menustrings.py:1793
-msgid "SQL statement"
-msgstr "Pernyataan SQL"
-#: ../gui/wxpython/menustrings.py:888 ../gui/wxpython/menustrings.py:1794
-msgid "Executes any SQL statement. For SELECT statements use 'db.select'."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:889 ../gui/wxpython/menustrings.py:1795
-msgid "Vector database connections"
-#: ../gui/wxpython/menustrings.py:890 ../gui/wxpython/menustrings.py:1796
-msgid "New table"
-msgstr "Tabel baru"
-#: ../gui/wxpython/menustrings.py:891 ../gui/wxpython/menustrings.py:1797
-#, fuzzy
-msgid ""
-"Creates and connects a new attribute table to a given layer of an existing "
-"vector map."
-msgstr ""
-"Buat dan tambah sebuah tabel atribut baru ke layer tertentu dari sebuah peta "
-"vektor yang ada."
-#: ../gui/wxpython/menustrings.py:892 ../gui/wxpython/menustrings.py:1798
-msgid "Remove table"
-msgstr "Hapus tabel"
-#: ../gui/wxpython/menustrings.py:893 ../gui/wxpython/menustrings.py:1799
-#, fuzzy
-msgid "Removes existing attribute table of a vector map."
-msgstr ""
-"Ubah nama sebuah kolom dari tabel atribut yang terhubung ke satu peta vektor "
-"tertentu."
-#: ../gui/wxpython/menustrings.py:894 ../gui/wxpython/menustrings.py:1800
-#, fuzzy
-msgid "Join table"
-#: ../gui/wxpython/menustrings.py:895 ../gui/wxpython/menustrings.py:1801
-#, fuzzy
-msgid "Joins a database table to a vector map table."
-msgstr ""
-"Ijinkan untuk perubahan sebuah kolom dalam tabel atribut yang terhubung "
-"dengan satu peta vektor."
-#: ../gui/wxpython/menustrings.py:896 ../gui/wxpython/menustrings.py:1802
-msgid "Add columns"
-msgstr "Tambah kolom"
-#: ../gui/wxpython/menustrings.py:897 ../gui/wxpython/menustrings.py:1803
-msgid ""
-"Adds one or more columns to the attribute table connected to a given vector "
-"map."
-msgstr ""
-"Tambah satu atau lebih kolom pada tabel atribut yang terhubung ke peta "
-"vektor tertentu."
-#: ../gui/wxpython/menustrings.py:899 ../gui/wxpython/menustrings.py:1805
-#, fuzzy
-msgid ""
-"Drops a column from the attribute table connected to a given vector map."
-msgstr ""
-"tertentu."
-#: ../gui/wxpython/menustrings.py:901 ../gui/wxpython/menustrings.py:1807
-msgid ""
-"Renames a column in the attribute table connected to a given vector map."
-msgstr ""
-"tertentu."
-#: ../gui/wxpython/menustrings.py:902 ../gui/wxpython/menustrings.py:1808
-msgid "Change values"
-msgstr "Ubah nilai"
-#: ../gui/wxpython/menustrings.py:903 ../gui/wxpython/menustrings.py:1809
-#, fuzzy
-msgid "Updates a column in the attribute table connected to a vector map."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:904 ../gui/wxpython/menustrings.py:1810
-msgid "Drop row"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:905 ../gui/wxpython/menustrings.py:1811
-#, fuzzy
-msgid "Removes a vector feature from a vector map through attribute selection."
-msgstr "Cetak/tentukan koneksi basisdata sebuah peta vektor ke tabel atribut."
-#: ../gui/wxpython/menustrings.py:906 ../gui/wxpython/menustrings.py:1812
-#, fuzzy
-msgid "Reconnect vectors to database"
-msgstr "Koneksi-ulang vektor ke basisdata"
-#: ../gui/wxpython/menustrings.py:907 ../gui/wxpython/menustrings.py:1813
-#, fuzzy
-msgid ""
-"Reconnects attribute tables for all vector maps from the current mapset to a "
-"new database."
-#: ../gui/wxpython/menustrings.py:908 ../gui/wxpython/menustrings.py:1814
-msgid "Set vector map - database connection"
-msgstr "Tentukan koneksi peta vektor - basisdata"
-#: ../gui/wxpython/menustrings.py:909 ../gui/wxpython/menustrings.py:1815
-msgid "Prints/sets DB connection for a vector map to attribute table."
-#: ../gui/wxpython/menustrings.py:910 ../gui/wxpython/menustrings.py:1816
-#, fuzzy
-msgid "&Temporal"
-msgstr "Mode kategori"
-#: ../gui/wxpython/menustrings.py:911 ../gui/wxpython/menustrings.py:1817
-#, fuzzy
-msgid "Manage datasets"
-#: ../gui/wxpython/menustrings.py:912 ../gui/wxpython/menustrings.py:1818
-#, fuzzy
-msgid "Connect temporal database"
-#: ../gui/wxpython/menustrings.py:913 ../gui/wxpython/menustrings.py:1819
-#, fuzzy
-msgid ""
-"Prints/sets general temporal GIS database connection for current mapset."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:915 ../gui/wxpython/menustrings.py:1821
-#, fuzzy
-msgid "Creates a space time dataset."
-#: ../gui/wxpython/menustrings.py:917 ../gui/wxpython/menustrings.py:1823
-#, fuzzy
-msgid "Renames a space time dataset"
-#: ../gui/wxpython/menustrings.py:919 ../gui/wxpython/menustrings.py:1825
-#, fuzzy
-msgid "Removes space time datasets from temporal database."
-#: ../gui/wxpython/menustrings.py:920 ../gui/wxpython/menustrings.py:1826
-#, fuzzy
-msgid "Update metadata"
-#: ../gui/wxpython/menustrings.py:921 ../gui/wxpython/menustrings.py:1827
-msgid "Modifies the metadata of a space time dataset."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:922 ../gui/wxpython/menustrings.py:1828
-msgid "Merge"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:923 ../gui/wxpython/menustrings.py:1829
-#, fuzzy
-msgid "Merges several space time datasets into a single space time dataset."
-#: ../gui/wxpython/menustrings.py:924 ../gui/wxpython/menustrings.py:1830
-#, fuzzy
-msgid "Temporally shift"
-#: ../gui/wxpython/menustrings.py:925 ../gui/wxpython/menustrings.py:1831
-#, fuzzy
-msgid "Shifts temporally the maps of a space time dataset."
-#: ../gui/wxpython/menustrings.py:926 ../gui/wxpython/menustrings.py:1832
-#, fuzzy
-msgid "Snap maps of dataset"
-msgstr "Impor peta raster "
-#: ../gui/wxpython/menustrings.py:927 ../gui/wxpython/menustrings.py:1833
-#, fuzzy
-msgid "Snaps temporally the maps of a space time dataset."
-#: ../gui/wxpython/menustrings.py:929 ../gui/wxpython/menustrings.py:1835
-#, fuzzy
-msgid "Lists space time datasets and maps registered in the temporal database."
-#: ../gui/wxpython/menustrings.py:930 ../gui/wxpython/menustrings.py:1836
-#, fuzzy
-msgid "Manage maps in datasets"
-#: ../gui/wxpython/menustrings.py:931 ../gui/wxpython/menustrings.py:1837
-#, fuzzy
-msgid "Register maps in datasets"
-msgstr "Pengaturan raster"
-#: ../gui/wxpython/menustrings.py:932 ../gui/wxpython/menustrings.py:1838
-msgid "Registers raster, vector and raster3d maps in a space time datasets."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:933 ../gui/wxpython/menustrings.py:1839
-#, fuzzy
-msgid "Unregister maps from datasets"
-#: ../gui/wxpython/menustrings.py:934 ../gui/wxpython/menustrings.py:1840
-msgid ""
-"Unregisters raster, vector and raster3d maps from the temporal database or a "
-"specific space time dataset."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:935 ../gui/wxpython/menustrings.py:1841
-#, fuzzy
-msgid "List raster dataset maps"
-msgstr "Daftar layer"
-#: ../gui/wxpython/menustrings.py:936 ../gui/wxpython/menustrings.py:1842
-#, fuzzy
-msgid "Lists registered maps of a space time raster dataset."
-#: ../gui/wxpython/menustrings.py:937 ../gui/wxpython/menustrings.py:1843
-#, fuzzy
-msgid "List vector dataset maps"
-#: ../gui/wxpython/menustrings.py:938 ../gui/wxpython/menustrings.py:1844
-#, fuzzy
-msgid "Lists registered maps of a space time vector dataset."
-msgstr "Impor peta vektor "
-#: ../gui/wxpython/menustrings.py:939 ../gui/wxpython/menustrings.py:1845
-#, fuzzy
-msgid "List 3D raster dataset maps"
-#: ../gui/wxpython/menustrings.py:940 ../gui/wxpython/menustrings.py:1846
-#, fuzzy
-msgid "Lists registered maps of a space time raster3d dataset."
-#: ../gui/wxpython/menustrings.py:941 ../gui/wxpython/menustrings.py:1847
-#, fuzzy
-msgid "Import"
-#: ../gui/wxpython/menustrings.py:942 ../gui/wxpython/menustrings.py:1848
-#, fuzzy
-msgid "Import raster dataset"
-#: ../gui/wxpython/menustrings.py:943 ../gui/wxpython/menustrings.py:1849
-#, fuzzy
-msgid "Imports space time raster dataset."
-#: ../gui/wxpython/menustrings.py:944 ../gui/wxpython/menustrings.py:1850
-#, fuzzy
-msgid "Import vector dataset"
-#: ../gui/wxpython/menustrings.py:945 ../gui/wxpython/menustrings.py:1851
-#, fuzzy
-msgid ""
-"Imports a space time vector dataset from a GRASS GIS specific archive file."
-#: ../gui/wxpython/menustrings.py:947 ../gui/wxpython/menustrings.py:1853
-#, fuzzy
-msgid "Export raster dataset"
-#: ../gui/wxpython/menustrings.py:948 ../gui/wxpython/menustrings.py:1854
-#, fuzzy
-msgid "Exports space time raster dataset."
-#: ../gui/wxpython/menustrings.py:949 ../gui/wxpython/menustrings.py:1855
-msgid "Export raster dataset as VTK time series"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:950 ../gui/wxpython/menustrings.py:1856
-#, fuzzy
-msgid "Exports space time raster dataset as VTK time series."
-#: ../gui/wxpython/menustrings.py:951 ../gui/wxpython/menustrings.py:1857
-#, fuzzy
-msgid "Export vector dataset"
-#: ../gui/wxpython/menustrings.py:952 ../gui/wxpython/menustrings.py:1858
-#, fuzzy
-msgid "Exports a space time vector dataset as GRASS GIS specific archive file."
-#: ../gui/wxpython/menustrings.py:953 ../gui/wxpython/menustrings.py:1859
-#, fuzzy
-msgid "Convert raster dataset to 3D raster"
-msgstr "Program konversi Raster File Series ke MPEG."
-#: ../gui/wxpython/menustrings.py:954 ../gui/wxpython/menustrings.py:1860
-#, fuzzy
-msgid "Converts a space time raster dataset into a 3D raster map."
-msgstr ""
-"Ubah sebuah layer peta vektor GRASS biner ke dalam sebuah layer peta raster "
-"GRASS."
-#: ../gui/wxpython/menustrings.py:955 ../gui/wxpython/menustrings.py:1861
-#, fuzzy
-msgid "Extraction"
-msgstr "Pengaturan teks"
-#: ../gui/wxpython/menustrings.py:956 ../gui/wxpython/menustrings.py:1862
-#, fuzzy
-msgid "Extract subset of raster dataset"
-#: ../gui/wxpython/menustrings.py:957 ../gui/wxpython/menustrings.py:1863
-#, fuzzy
-msgid "Extracts a subset of a space time raster datasets."
-#: ../gui/wxpython/menustrings.py:958 ../gui/wxpython/menustrings.py:1864
-#, fuzzy
-msgid "Extract subset of vector dataset"
-#: ../gui/wxpython/menustrings.py:959 ../gui/wxpython/menustrings.py:1865
-#, fuzzy
-msgid "Extracts a subset of a space time vector dataset."
-#: ../gui/wxpython/menustrings.py:960 ../gui/wxpython/menustrings.py:1866
-#, fuzzy
-msgid "Extract subset of 3D raster dataset"
-#: ../gui/wxpython/menustrings.py:961 ../gui/wxpython/menustrings.py:1867
-#, fuzzy
-msgid "Extracts a subset of a space time 3D raster dataset."
-#: ../gui/wxpython/menustrings.py:962 ../gui/wxpython/menustrings.py:1868
-#, fuzzy
-msgid "Query vector dataset attribute data"
-#: ../gui/wxpython/menustrings.py:963 ../gui/wxpython/menustrings.py:1869
-#, fuzzy
-msgid ""
-"Prints attributes of vector maps registered in a space time vector dataset."
-msgstr "Buat label untuk sebuah peta vektor dari atributnya."
-#: ../gui/wxpython/menustrings.py:964 ../gui/wxpython/menustrings.py:1870
-#, fuzzy
-msgid "Raster dataset color table"
-#: ../gui/wxpython/menustrings.py:965 ../gui/wxpython/menustrings.py:1871
-#, fuzzy
-msgid ""
-"Creates/modifies the color table associated with each raster map of the "
-"space time raster dataset."
-#: ../gui/wxpython/menustrings.py:966 ../gui/wxpython/menustrings.py:1872
-#, fuzzy
-msgid "Raster calculations"
-#: ../gui/wxpython/menustrings.py:967 ../gui/wxpython/menustrings.py:1873
-#, fuzzy
-msgid ""
-"Performs spatio-temporal mapcalc expressions on temporally sampled maps of "
-"space time raster datasets."
-#: ../gui/wxpython/menustrings.py:968 ../gui/wxpython/menustrings.py:1874
-#, fuzzy
-msgid "3D raster calculations"
-#: ../gui/wxpython/menustrings.py:969 ../gui/wxpython/menustrings.py:1875
-#, fuzzy
-msgid ""
-"Performs r3.mapcalc expressions on maps of sampled space time 3D raster "
-"datasets."
-#: ../gui/wxpython/menustrings.py:970 ../gui/wxpython/menustrings.py:1876
-#, fuzzy
-msgid "Interpolate gaps in raster datasets"
-#: ../gui/wxpython/menustrings.py:971 ../gui/wxpython/menustrings.py:1877
-#, fuzzy
-msgid ""
-"Replaces gaps in a space time raster dataset with interpolated raster maps."
-msgstr ""
-"GRASS."
-#: ../gui/wxpython/menustrings.py:972 ../gui/wxpython/menustrings.py:1878
-#, fuzzy
-msgid "Aggregation"
-msgstr "Rotasi:"
-#: ../gui/wxpython/menustrings.py:973 ../gui/wxpython/menustrings.py:1879
-#, fuzzy
-msgid "Neighborhood analysis in raster dataset"
-msgstr "Analisis tetangga-terdekat "
-#: ../gui/wxpython/menustrings.py:974 ../gui/wxpython/menustrings.py:1880
-msgid ""
-"Performs a neighborhood analysis for each map in a space time raster dataset."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:975 ../gui/wxpython/menustrings.py:1881
-#, fuzzy
-msgid "Aggregation in raster datasets"
-#: ../gui/wxpython/menustrings.py:976 ../gui/wxpython/menustrings.py:1882
-msgid ""
-"Performs different aggregation algorithms from r.series on all or a subset "
-"of raster maps in a space time raster dataset."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:977 ../gui/wxpython/menustrings.py:1883
-#, fuzzy
-msgid "Temporal aggregation"
-#: ../gui/wxpython/menustrings.py:978 ../gui/wxpython/menustrings.py:1884
-#, fuzzy
-msgid ""
-"Aggregates temporally the maps of a space time raster dataset by a user "
-"defined granularity."
-#: ../gui/wxpython/menustrings.py:979 ../gui/wxpython/menustrings.py:1885
-msgid "Temporal aggregation by dataset"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:980 ../gui/wxpython/menustrings.py:1886
-msgid ""
-"Aggregates data of an existing space time raster dataset using the time "
-"intervals of a second space time dataset."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:981 ../gui/wxpython/menustrings.py:1887
-#, fuzzy
-msgid "Sampling"
-msgstr "Transek cuplikan"
-#: ../gui/wxpython/menustrings.py:982 ../gui/wxpython/menustrings.py:1888
-#, fuzzy
-msgid "Sample a space time raster dataset at point coordinates"
-msgstr ""
-"GRASS."
-#: ../gui/wxpython/menustrings.py:983 ../gui/wxpython/menustrings.py:1889
-msgid ""
-"Sample a space time raster dataset at specific vector point coordinates and "
-"write the output to stdout using different layouts"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:984 ../gui/wxpython/menustrings.py:1890
-#, fuzzy
-msgid "Query raster dataset by vector points dataset"
-#: ../gui/wxpython/menustrings.py:985 ../gui/wxpython/menustrings.py:1891
-#, fuzzy
-msgid ""
-"Stores raster map values at spatial and temporal positions of vector points "
-"as vector attributes."
-#: ../gui/wxpython/menustrings.py:986 ../gui/wxpython/menustrings.py:1892
-msgid "Observe specific locations in raster dataset"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:987 ../gui/wxpython/menustrings.py:1893
-msgid ""
-"Observes specific locations in a space time raster dataset over a period of "
-"time using vector points."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:988 ../gui/wxpython/menustrings.py:1894
-#, fuzzy
-msgid "Temporal sampling"
-#: ../gui/wxpython/menustrings.py:989 ../gui/wxpython/menustrings.py:1895
-msgid ""
-"Samples the input space time dataset(s) with a sample space time dataset and "
-"print the result to stdout."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:991 ../gui/wxpython/menustrings.py:1897
-#, fuzzy
-msgid "Space time datasets metadata"
-#: ../gui/wxpython/menustrings.py:992 ../gui/wxpython/menustrings.py:1898
-#, fuzzy
-msgid "Lists information about space time datasets and maps."
-msgstr "Hasilkan informasi dasar tentang sebuah layer peta raster."
-#: ../gui/wxpython/menustrings.py:993 ../gui/wxpython/menustrings.py:1899
-#, fuzzy
-msgid "Univariate raster dataset statistics"
-#: ../gui/wxpython/menustrings.py:994 ../gui/wxpython/menustrings.py:1900
-#, fuzzy
-msgid ""
-"Calculates univariate statistics from the non-null cells for each registered "
-"raster map of a space time raster dataset."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:995 ../gui/wxpython/menustrings.py:1901
-#, fuzzy
-msgid "Univariate vector dataset statistics"
-#: ../gui/wxpython/menustrings.py:996 ../gui/wxpython/menustrings.py:1902
-#, fuzzy
-msgid ""
-"Calculates univariate statistics of attributes for each registered vector "
-"map of a space time vector dataset"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:997 ../gui/wxpython/menustrings.py:1903
-#, fuzzy
-msgid "Univariate 3D raster dataset statistics"
-#: ../gui/wxpython/menustrings.py:998 ../gui/wxpython/menustrings.py:1904
-#, fuzzy
-msgid ""
-"3D raster map of a space time 3D raster dataset."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:999 ../gui/wxpython/menustrings.py:1905
-#, fuzzy
-msgid "Report temporal topology"
-msgstr "Buat/bangun-ulang topologi"
-#: ../gui/wxpython/menustrings.py:1000 ../gui/wxpython/menustrings.py:1906
-#, fuzzy
-msgid "Lists temporal topology of a space time dataset."
-#: ../gui/wxpython/menustrings.py:1001 ../gui/wxpython/menustrings.py:1907
-#: ../gui/wxpython/menustrings.py:1914
-msgid "GUI tools"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:1004 ../gui/wxpython/menustrings.py:1910
-#: ../gui/wxpython/menustrings.py:1930
-#, fuzzy
-msgid "Timeline tool"
-msgstr "Map Toolbar"
-#: ../gui/wxpython/menustrings.py:1005 ../gui/wxpython/menustrings.py:1911
-#: ../gui/wxpython/menustrings.py:1931
-#, fuzzy
-msgid "Plot temporal extents."
-msgstr "Tampilkan batas komputasi"
-#: ../gui/wxpython/menustrings.py:1006 ../gui/wxpython/menustrings.py:1912
-#: ../gui/wxpython/menustrings.py:1928
-#, fuzzy
-msgid "Temporal plot tool"
-msgstr "Buat histogram dari berkas citra atau raster"
-#: ../gui/wxpython/menustrings.py:1007 ../gui/wxpython/menustrings.py:1913
-#: ../gui/wxpython/menustrings.py:1929
-#, fuzzy
-msgid "Plot temporal values."
-#: ../gui/wxpython/menustrings.py:1008 ../gui/wxpython/menustrings.py:1977
-#: ../gui/wxpython/menustrings.py:2020
-#, fuzzy
-msgid "&Help"
-msgstr "Bantuan"
-#: ../gui/wxpython/menustrings.py:1009
-#, fuzzy
-msgid "GRASS help"
-msgstr "Bantuan GRASS GIS"
-#: ../gui/wxpython/menustrings.py:1010 ../gui/wxpython/menustrings.py:1012
-#, fuzzy
-msgid "Display the HTML man pages of GRASS GIS"
-msgstr "Tampilkan halaman manual HTML dari GRASS"
-#: ../gui/wxpython/menustrings.py:1011
-#, fuzzy
-msgid "GUI help"
-#: ../gui/wxpython/menustrings.py:1013
-msgid "About system"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:1014
-#, fuzzy
-msgid "Prints system information"
-#: ../gui/wxpython/menustrings.py:1019
-#, fuzzy
-msgid "Import, export and link data"
-#: ../gui/wxpython/menustrings.py:1917
-#, fuzzy
-msgid "Attribute table manager"
-msgstr "Attribute Table Manager"
-#: ../gui/wxpython/menustrings.py:1936
-#, fuzzy
-msgid "Create new model"
-msgstr "Buat mapset baru"
-#: ../gui/wxpython/menustrings.py:1938
-#, fuzzy
-msgid "Load model from file"
-msgstr "Pilih berkas workspace"
-#: ../gui/wxpython/menustrings.py:1942
-#, fuzzy
-msgid "Save model to file"
-msgstr "Simpan workspace ke dalam berkas"
-#: ../gui/wxpython/menustrings.py:1944
-#, fuzzy
-msgid "Close model file"
-#: ../gui/wxpython/menustrings.py:1945
-#, fuzzy
-msgid "Export to image"
-msgstr "Ekspor peta vektor "
-#: ../gui/wxpython/menustrings.py:1946
-#, fuzzy
-msgid "Export model to image"
-#: ../gui/wxpython/menustrings.py:1947
-#, fuzzy
-msgid "Export to Python"
-#: ../gui/wxpython/menustrings.py:1948
-msgid "Export model to Python script"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:1949
-msgid "Quit modeler"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:1950
-#, fuzzy
-msgid "Close modeler window"
-msgstr "Window bergerak "
-#: ../gui/wxpython/menustrings.py:1954
-#, fuzzy
-msgid "&Model"
-msgstr "Mode"
-#: ../gui/wxpython/menustrings.py:1955
-#, fuzzy
-msgid "Add command"
-msgstr "Tambahkan layer perintah"
-#: ../gui/wxpython/menustrings.py:1956
-msgid "Add action (GRASS command) to model"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:1957
-msgid "Add data"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:1958
-msgid "Add data item to model"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:1959
-#, fuzzy
-msgid "Define relation"
-msgstr "Definisikan location baru"
-#: ../gui/wxpython/menustrings.py:1960
-msgid "Define relation between data and action items"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:1961
-#, fuzzy
-msgid "Add loop / series"
-msgstr "Tambahkan grup layer"
-#: ../gui/wxpython/menustrings.py:1962
-msgid "Adds loop (series) to model"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:1963
-#, fuzzy
-msgid "Add condition"
-#: ../gui/wxpython/menustrings.py:1964
-msgid "Adds condition (if/else) to model"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:1966
-#, fuzzy
-msgid "Adds comment to model"
-#: ../gui/wxpython/menustrings.py:1967
-#, fuzzy
-msgid "Remove item"
-#: ../gui/wxpython/menustrings.py:1968
-#, fuzzy
-msgid "Remove action/data from model"
-#: ../gui/wxpython/menustrings.py:1970
-msgid "Model properties (name, purpose, etc.)"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:1971
-#, fuzzy
-msgid "Delete intermediate data"
-msgstr "Hapus yang tersaring"
-#: ../gui/wxpython/menustrings.py:1972
-msgid "Delete intermediate data defined in the model"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:1974
-msgid "Run entire model"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:1975
-msgid "Validate model"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:1976
-msgid "Validate entire model"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:1979
-#, fuzzy
-msgid "Display the HTML man pages of Graphical modeler"
-#: ../gui/wxpython/menustrings.py:1980
-msgid "About Graphical Modeler"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:1981
-#, fuzzy
-msgid "Display information about Graphical Modeler"
-#: ../gui/wxpython/menustrings.py:1987
-#, fuzzy
-msgid "Load instruction file"
-msgstr "Tidak dapat membaca daftar: %s"
-#: ../gui/wxpython/menustrings.py:1989
-#, fuzzy
-msgid "Export instruction file"
-#: ../gui/wxpython/menustrings.py:1991
-#, fuzzy
-msgid "Export to PostScript"
-#: ../gui/wxpython/menustrings.py:1993
-#, fuzzy
-msgid "Export to PDF"
-msgstr "Ekspor MPEG-1"
-#: ../gui/wxpython/menustrings.py:1995 ../gui/wxpython/menustrings.py:1996
-#, fuzzy
-msgid "Launch ps.map dialog"
-msgstr "Deskripsi layer"
-#: ../gui/wxpython/menustrings.py:1998
-#, fuzzy
-msgid "Close Cartographic Composer"
-msgstr "Bantuan GRASS GIS GUI"
-#: ../gui/wxpython/menustrings.py:1999
-msgid "&Insert"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:2001
-#, fuzzy
-msgid "Add or edit map frame"
-msgstr "Tambahkan layer peta raster"
-#: ../gui/wxpython/menustrings.py:2003
-#, fuzzy
-msgid "Add or edit raster map"
-msgstr "Peta raster:"
-#: ../gui/wxpython/menustrings.py:2005
-#, fuzzy
-msgid "Add or edit vector map"
-#: ../gui/wxpython/menustrings.py:2006
-#, fuzzy
-msgid "Map legend"
-msgstr "Tambahkan legenda"
-#: ../gui/wxpython/menustrings.py:2007
-#, fuzzy
-msgid "Add or edit raster and vector legend"
-msgstr "Tampilkan layer peta ke dalam layer tree"
-#: ../gui/wxpython/menustrings.py:2009
-#, fuzzy
-msgid "Add or edit map info"
-#: ../gui/wxpython/menustrings.py:2011
-#, fuzzy
-msgid "Add or edit scale bar"
-msgstr "Tambahkan layer"
-#: ../gui/wxpython/menustrings.py:2022
-#, fuzzy
-msgid "Display the HTML man pages of Cartographic Composer"
-#: ../gui/wxpython/menustrings.py:2023
-#, fuzzy
-msgid "About Cartographic Composer"
-#: ../gui/wxpython/menustrings.py:2024
-#, fuzzy
-msgid "Display information about Cartographic Composer"
-#, fuzzy
-#~ msgid ""
-#~ "Creates a raster map from LAS LiDAR points using univariate statistics."
-#~ msgstr ""
-#~ "Buat sebuah peta raster dari satu himpunan koordinat dengan statistik "
-#~ "univariat"
-#, fuzzy
-#~ msgid "Converts LAS LiDAR point clouds to a GRASS vector map with libLAS."
-#~ msgstr "Ubah layer vektor OGR ke dalam peta vektor GRASS."
-#, fuzzy
-#~ msgid "legend"
-#~ msgstr "Legenda"
-#, fuzzy
-#~ msgid "Hide {overlay}"
-#~ msgstr "Tambahkan overlay label grid atau vektor"
-#, fuzzy
-#~ msgid "Show text object"
-#~ msgstr "Tampilkan batas luar komputasi"
-#~ msgid ""
-#~ "Drag text with mouse in pointer mode to position.\n"
-#~ "Double-click to change options"
-#~ msgstr ""
-#~ "Tarik teks dengan tetikus dalam mode pointer ke dalam posisi.\n"
-#~ "Klik-ganda untuk merubah pilihan"
-#, fuzzy
-#~ msgid "Failed to copy map: action is allowed only within the same location."
-#~ msgstr "Perbesaran ke computational region (g.region)"
-#~ msgid "Add text layer"
-#~ msgstr "Tambahkan layer teks"
-#, fuzzy
-#~ msgid "Show/hide scale bar"
-#~ msgstr "Tampilkan/sembunyikan skala dan arah Utara"
-#~ msgid "Show/hide legend"
-#~ msgstr "Tampilkan/sembunyikan legenda"
-#, fuzzy
-#~ msgid "Show/hide north arrow"
-#, fuzzy
-#~ msgid "Exports a vector map layer to PostGIS feature table."
-#~ msgstr "Ekspor sebuah peta vektor GRASS ke SVG."
-#~ msgid "Overlays two vector maps."
-#~ msgstr "Tumpang-susun dua peta vektor."
-#~ msgid "Print/add/remove a timestamp for a 3D raster map"
-#~ msgstr "Cetak/tambah/hapus catatan waktu untuk peta raster 3D"
-#, fuzzy
-#~ msgid "Map layers"
-#~ msgstr "Layer peta"
-#, fuzzy
-#~ msgid "Do you really want to delete map <{m}>?"
-#~ msgstr "Apakah Anda hendak membuat GRASS location <%s>?"
-#, fuzzy
-#~ msgid "Vector map %s already exists. "
-#~ msgstr "ERROR: Mapset <%s> tidak ada"
-#, fuzzy
-#~ msgid "Temporary map %s already exists.\n"
-#, fuzzy
-#~ msgid "Exit GUI"
-#~ msgstr "Keluar GUI"
-#, fuzzy
-#~ msgid "Invalid input data"
-#~ msgstr "Region tidak valid"
-#, fuzzy
-#~ msgid "No mapsets readable"
-#~ msgstr "Toolbar digitasi vektor"
-#, fuzzy
-#~ msgid "Editing"
-#~ msgstr "Rentang yang valid"
-#, fuzzy
-#~ msgid "Renaming"
-#~ msgstr "Ubah nama "
-#, fuzzy
-#~ msgid "Copying"
-#~ msgstr "Salin tabel"
-#, fuzzy
-#~ msgid "List raster3D dataset maps"
-#~ msgstr "Daftar layer"
-#, fuzzy
-#~ msgid "Extract subset of raster3D dataset"
-#~ msgstr "Impor peta raster "
-#, fuzzy
-#~ msgid "Raster3D calculations"
-#~ msgstr "Kalkulator peta raster 3D"
-#, fuzzy
-#~ msgid "Univariate raster3D dataset statistics"
-#~ msgstr "Statistik raster univariat"
-#, fuzzy
-#~ msgid "Load settings:"
-#~ msgstr "Perlihatkan pengaturan "
-#~ msgid "Unable to render map layer <%s>."
-#~ msgstr "Tidak dapat melakukan render layer peta <%s>."
-#~ msgid "Unable to render overlay <%s>."
-#~ msgstr "Tidak dapat merender overlay <%s>."
-#, fuzzy
-#~ msgid "Historical GRASS vector import"
-#~ msgstr "Impor vektor GRASS versi lama"
-#, fuzzy
-#~ msgid "Historical GRASS vector import (all maps)"
-#, fuzzy
-#~ msgid ""
-#~ "Converts all older versions of GRASS vector maps in current mapset to "
-#~ "current format."
-#~ msgstr "Impor peta vektor GRASS versi lama."
-#, fuzzy
-#~ msgid "GPS data import"
-#~ msgstr "Impor GPSBabel GPS"
-#~ msgid "GEOnet import"
-#~ msgstr "Impor GEOnet"
-#, fuzzy
-#~ msgid "Unpacks a vector map packed with v.pack."
-#~ msgstr "Metadata dasar peta vektor"
-#~ msgid "Multiple import formats using OGR"
-#~ msgstr "Impor beragam format dengan OGR"
-#, fuzzy
-#~ msgid "Multiple GPS export formats using GPSBabel"
-#~ msgstr "Ekspor beragam format dengan OGR"
-#, fuzzy
-#~ msgid ""
-#~ "Exports a vector map to a GPS receiver or file format supported by "
-#~ "GPSBabel."
-#~ msgstr "Ekspor layer peta vektor GRASS ke dalam berkas format DXF."
-#, fuzzy
-#~ msgid "Common export formats using OGR"
-#, fuzzy
-#~ msgid "Create optimally placed labels"
-#~ msgstr "Buat label"
-#~ msgid "Bit pattern comparison "
-#~ msgstr "Perbandingan pola bit "
-#, fuzzy
-#~ msgid "Launches graphical attribute table manager."
-#~ msgstr "Attribute Table Manager"
-#, fuzzy
-#~ msgid "Select space time raster dataset(s):"
-#~ msgstr "Pilih sumber mapset:"
-#, fuzzy
-#~ msgid "Set computational region from selected map(s) (ignore NULLs)"
-#~ msgstr "Tentukan region komputasi dari peta terpilih (abaikan NULL)"
-#, fuzzy
-#~ msgid "Add default servers"
-#~ msgstr "Tambahkan grup layer"
-#~ msgid "Choose project location and mapset"
-#~ msgstr "Pilih location dan mapset proyek"
-#~ msgid "Manage"
-#~ msgstr "Kelola"
-#, fuzzy
-#~ msgid ""
-#~ "Welcome to GRASS GIS %s%s\n"
-#~ "The world's leading open source GIS"
-#~ msgstr ""
-#~ "Selamat datang di GRASS GIS %s\n"
-#~ "Perangkat lunak SIG berbasis kode terbuka terunggul di dunia"
-#~ msgid ""
-#~ "Select an existing project location and mapset\n"
-#~ "or define a new location"
-#~ msgstr ""
-#~ "Pilih location dan mapset proyek yang sudah ada\n"
-#~ "atau definisikan location baru"
-#~ msgid ""
-#~ "Project location\n"
-#~ "(projection/coordinate system)"
-#~ msgstr ""
-#~ "(proyeksi/sistem koordinat)"
-#~ msgid ""
-#~ "Accessible mapsets\n"
-#~ "(directories of GIS files)"
-#~ msgstr ""
-#~ "Mapset yang dapat diakses\n"
-#~ "(direktori dari berkas SIG)"
-#~ msgid "Define new location"
-#~ msgstr "Definisikan location baru"
-#~ msgid ""
-#~ "Rename/delete selected\n"
-#~ "mapset or location"
-#~ msgstr ""
-#~ "Ubah nama/hapus\n"
-#~ "mapset atau location terpilih"
-#, fuzzy
-#~ msgid "Start &GRASS"
-#~ msgstr "Jalankan GRASS"
-#, fuzzy
-#~ msgid "&Location wizard"
-#~ msgstr "Location wizard"
-#~ msgid "Rename mapset"
-#~ msgstr "Ubah nama mapset"
-#~ msgid "Rename location"
-#~ msgstr "Ubah nama location"
-#~ msgid "Delete mapset"
-#~ msgstr "Hapus mapset"
-#~ msgid "Delete location"
-#~ msgstr "Hapus location"
-#~ msgid "Welcome to GRASS GIS"
-#~ msgstr "Selamat datang di GRASS GIS"
-#, fuzzy
-#~ msgid "Warning: "
-#~ msgstr "Peringatan"
-#, fuzzy
-#~ msgid "Develop 3D rasters"
-#~ msgstr "Bangun peta raster"
-#, fuzzy
-#~ msgid "Add linked layers into layer tree ({mightNotWork})"
-#~ msgstr "Tampilkan layer peta ke dalam layer tree"
-#, fuzzy
-#~ msgid "Add imported layers into layer tree ({mightNotWork})"
-#~ msgid "Imports older versions of GRASS vector maps."
-#~ msgid "Vector to volume"
-#~ msgstr "Vektor ke volume "
-#~ msgid "Sites to vector"
-#~ msgstr "Titik ke vektor "
-#, fuzzy
-#~ msgid "Raster map calculator."
-#, fuzzy
-#~ msgid "V&olumes"
-#~ msgstr "Volume"
-#~ msgid "Develop volumes"
-#~ msgstr "Membangun volume"
-#~ msgid "3D Mask"
-#~ msgstr "Mask 3D"
-#, fuzzy
-#~ msgid "Volume calculator"
-#~ msgstr "Kalkulator peta "
-#~ msgid "Basic volume metadata"
-#~ msgstr "Metadata dasar volume"
-#, fuzzy
-#~ msgid "Voxel statistics"
-#~ msgstr "Statistik umum"
-#, fuzzy
-#~ msgid "Volume"
-#~ msgstr "Volume"
-#~ msgid ""
-#~ "Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS "
-#~ "vector points map."
-#~ msgstr ""
-#~ "Impor berkas US-NGA GEOnet Names Server (GNS) ke dalam sebuah peta titik "
-#~ "vektor GRASS."
-#, fuzzy
-#~ msgid ""
-#~ "Outputs a raster map showing the anisotropic cumulative cost. Computes "
-#~ "anisotropic cumulative cost of moving between different geographic "
-#~ "locations on an input elevation raster map whose cell category values "
-#~ "represent elevation combined with an input raster map layer whose cell "
-#~ "values represent friction cost."
-#~ msgstr ""
-#~ "Keluaran layer peta raster yang memperlihatkan biaya kumulatif "
-#~ "anisotropis dari pergerakan antara lokasi geografis yang berbeda pada "
-#~ "satu input layer peta ketinggian yang mana nilai kategori selnya mewakili "
-#~ "ketinggian hasil kombinasi dari layer peta raster input dengan nilai sel "
-#~ "mewakili friction cost."
-#, fuzzy
-#~ msgid "Surface interpolation utility for raster map."
-#~ msgstr "Utilitas interpolasi permukaan untuk layer peta raster"
-#, fuzzy
-#~ msgid "Surface generation program."
-#~ msgstr "Program pembentukan permukaan dari kontur raster."
-#~ msgid "Compares bit patterns with a raster map."
-#~ msgstr "Membandingkan pola bit dengan sebuah peta raster"
-#, fuzzy
-#~ msgid ""
-#~ "Calculates univariate statistics from the non-null cells for each "
-#~ "registered raster3d map of a space time raster3d dataset."
-#~ msgstr ""
-#~ "Menghitung statistik univariat dari sebuah peta raster dengan sel non-"
-#~ "null."
-#, fuzzy
-#~ msgid "Digitize"
-#~ msgstr "Digitasi garis baru "
Modified: grass/trunk/locale/po/grasswxpy_id_ID.po
--- grass/trunk/locale/po/grasswxpy_id_ID.po 2018-01-06 11:14:56 UTC (rev 72036)
+++ grass/trunk/locale/po/grasswxpy_id_ID.po 2018-01-06 11:29:23 UTC (rev 72037)
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grasslibs_id_ID\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2017-05-22 23:12-0700\n"
+"POT-Creation-Date: 2016-11-14 14:55+0100\n"
"PO-Revision-Date: 2017-05-23 21:08+0200\n"
"Language-Team: Indonesian (Indonesia) (https://www.transifex.com/grass-gis/teams/45198/id_ID/)\n"
"Language: id_ID\n"
@@ -16,5921 +16,5765 @@
"Content-Transfer-Encoding: 8bit\n"
"Plural-Forms: nplurals=1; plural=0;\n"
-#: ../gui/wxpython/core/utils.py:60
-#, python-format
-msgid "Syntax error: %s"
+#: ../gui/wxpython/gcp/manager.py:143
+msgid "Setup for georectification"
msgstr ""
-#: ../gui/wxpython/core/utils.py:351
-#, python-format
-msgid "Vector map <%(map)s>: %(msg)s\n"
+#: ../gui/wxpython/gcp/manager.py:176 ../gui/wxpython/gcp/manager.py:180
+msgid "Georectifying setup canceled."
msgstr ""
-#: ../gui/wxpython/core/utils.py:535
-#, python-brace-format
-msgid "failed to open '{0}'"
+#: ../gui/wxpython/gcp/manager.py:345
+msgid "Select map type and location/mapset"
msgstr ""
-#: ../gui/wxpython/core/utils.py:841
-#, python-format
-msgid "ERROR: Unable to determine GRASS version. Details: %s"
+#: ../gui/wxpython/gcp/manager.py:359
+msgid "Map type to georectify"
msgstr ""
-#: ../gui/wxpython/core/utils.py:882
-#, python-format
-msgid "Unable to open file '%s'\n"
+#: ../gui/wxpython/gcp/manager.py:360 ../gui/wxpython/psmap/dialogs.py:907
+#: ../gui/wxpython/gmodeler/frame.py:1650
+#: ../gui/wxpython/gui_core/dialogs.py:1452
+#: ../gui/wxpython/gui_core/dialogs.py:1697
+msgid "raster"
msgstr ""
-#: ../gui/wxpython/core/utils.py:892
-#, python-format
-msgid ""
-"%s: line skipped - unable to parse '%s'\n"
-"Reason: %s\n"
+#: ../gui/wxpython/gcp/manager.py:360 ../gui/wxpython/psmap/dialogs.py:910
+#: ../gui/wxpython/gmodeler/frame.py:1651
+msgid "vector"
msgstr ""
-#: ../gui/wxpython/core/utils.py:897
-#, python-format
-msgid "Duplicated key: %s\n"
+#: ../gui/wxpython/gcp/manager.py:370
+msgid "Select source location:"
msgstr ""
-#: ../gui/wxpython/core/utils.py:913
-#, python-format
-msgid "Unable to create file '%s'\n"
+#: ../gui/wxpython/gcp/manager.py:391
+msgid "Select source mapset:"
msgstr ""
-#: ../gui/wxpython/core/utils.py:996 ../gui/wxpython/gui_core/forms.py:1711
-msgid "Select Color"
+#: ../gui/wxpython/gcp/manager.py:447
+msgid "You must select a valid location before selecting a mapset"
msgstr ""
-#: ../gui/wxpython/core/ws.py:51
-msgid ""
-"Unable to load GDAL Python bindings.\n"
-"WMS layers can not be displayed without the bindings.\n"
+#: ../gui/wxpython/gcp/manager.py:460
+msgid "You must select a valid location and mapset in order to continue"
msgstr ""
-#: ../gui/wxpython/core/workspace.py:1608
-#, python-format
-msgid "Unable to open file <%s> for reading."
+#: ../gui/wxpython/gcp/manager.py:482
+msgid "Select image/map group to georectify"
msgstr ""
-#: ../gui/wxpython/core/workspace.py:1610 ../gui/wxpython/core/gcmd.py:113
-#: ../gui/wxpython/vdigit/dialogs.py:253 ../gui/wxpython/vdigit/dialogs.py:447
-#: ../gui/wxpython/gis_set.py:277 ../gui/wxpython/gis_set.py:657
-#: ../gui/wxpython/gis_set.py:701 ../gui/wxpython/psmap/dialogs.py:5581
-#: ../gui/wxpython/gmodeler/frame.py:1086 ../gui/wxpython/lmgr/layertree.py:993
-#: ../gui/wxpython/gui_core/preferences.py:238
-#: ../gui/wxpython/gui_core/preferences.py:1894
-#: ../gui/wxpython/gui_core/preferences.py:1927
-#: ../gui/wxpython/gui_core/preferences.py:1939
-#: ../gui/wxpython/gui_core/preferences.py:1951
-#: ../gui/wxpython/location_wizard/wizard.py:625
-#: ../gui/wxpython/location_wizard/wizard.py:814
-#: ../gui/wxpython/location_wizard/wizard.py:1963
-#: ../gui/wxpython/location_wizard/dialogs.py:142
-#: ../gui/wxpython/location_wizard/dialogs.py:161
-#: ../gui/wxpython/location_wizard/dialogs.py:490
-msgid "Error"
+#: ../gui/wxpython/gcp/manager.py:504
+msgid "Select group:"
msgstr ""
-#: ../gui/wxpython/core/workspace.py:1625
-#, python-format
-msgid ""
-"Some lines were skipped when reading settings from file <%(file)s>.\n"
-"See 'Command output' window for details.\n"
-"\n"
-"Number of skipped lines: %(line)d"
+#: ../gui/wxpython/gcp/manager.py:521
+msgid "Create group if none exists"
msgstr ""
-#: ../gui/wxpython/core/workspace.py:1629 ../gui/wxpython/core/gcmd.py:140
-#: ../gui/wxpython/wxplot/dialogs.py:965
-#: ../gui/wxpython/mapwin/buffered.py:2136
-msgid "Warning"
+#: ../gui/wxpython/gcp/manager.py:531 ../gui/wxpython/iclass/dialogs.py:78
+msgid "Create/edit group..."
msgstr ""
-#: ../gui/wxpython/core/workspace.py:1850
-#, python-format
-msgid " row %d:"
+#: ../gui/wxpython/gcp/manager.py:535
+msgid "Add vector map to group..."
msgstr ""
-#: ../gui/wxpython/core/settings.py:498
-msgid "Segment break"
+#: ../gui/wxpython/gcp/manager.py:555 ../gui/wxpython/gcp/manager.py:2969
+msgid "Extension for output maps:"
msgstr ""
-#: ../gui/wxpython/core/settings.py:564
-msgid "Data point"
+#: ../gui/wxpython/gcp/manager.py:619
+msgid "You must select a valid image/map group in order to continue"
msgstr ""
-#: ../gui/wxpython/core/settings.py:638
-msgid "animation"
+#: ../gui/wxpython/gcp/manager.py:626
+msgid "You must enter an map name extension in order to continue"
msgstr ""
-#: ../gui/wxpython/core/settings.py:861
-msgid "Collapse all except PERMANENT and current"
+#: ../gui/wxpython/gcp/manager.py:695
+msgid "Select maps to display for ground control point (GCP) creation"
msgstr ""
-#: ../gui/wxpython/core/settings.py:862
-msgid "Collapse all except PERMANENT"
+#: ../gui/wxpython/gcp/manager.py:707 ../gui/wxpython/gcp/manager.py:2864
+msgid "Select source map to display:"
msgstr ""
-#: ../gui/wxpython/core/settings.py:863
-msgid "Collapse all except current"
+#: ../gui/wxpython/gcp/manager.py:733 ../gui/wxpython/gcp/manager.py:2878
+msgid "Select target raster map to display:"
msgstr ""
-#: ../gui/wxpython/core/settings.py:864
-msgid "Collapse all"
+#: ../gui/wxpython/gcp/manager.py:756 ../gui/wxpython/gcp/manager.py:2892
+msgid "Select target vector map to display:"
msgstr ""
-#: ../gui/wxpython/core/settings.py:865
-msgid "Expand all"
+#: ../gui/wxpython/gcp/manager.py:828
+msgid "You must select a source map in order to continue"
msgstr ""
-#: ../gui/wxpython/core/settings.py:870 ../gui/wxpython/dbmgr/base.py:1391
-msgid "Edit selected record"
+#: ../gui/wxpython/gcp/manager.py:855 ../gui/wxpython/gcp/manager.py:886
+#, python-format
+msgid ""
+"No maps in selected group <%s>.\n"
+"Please edit group or select another group."
msgstr ""
-msgid "Display selected"
+#: ../gui/wxpython/gcp/manager.py:916
+msgid "Manage Ground Control Points"
msgstr ""
-#: ../gui/wxpython/core/settings.py:879
-msgid "Classic (labels only)"
+#: ../gui/wxpython/gcp/manager.py:1181
+#, python-format
+msgid "At least %d GCPs required. Operation canceled."
msgstr ""
-#: ../gui/wxpython/core/settings.py:880
-msgid "Combined (labels and module names)"
+#: ../gui/wxpython/gcp/manager.py:1324
+msgid "source"
msgstr ""
-#: ../gui/wxpython/core/settings.py:881
-msgid "Expert (module names only)"
+#: ../gui/wxpython/gcp/manager.py:1326
+msgid "target"
msgstr ""
-#: ../gui/wxpython/core/settings.py:886
-msgid "Basic top"
+#: ../gui/wxpython/gcp/manager.py:1328
+msgid "Set GCP coordinates"
msgstr ""
-#: ../gui/wxpython/core/settings.py:887
-msgid "Basic left"
+#: ../gui/wxpython/gcp/manager.py:1330
+#, python-format
+msgid ""
+"Set %(coor)s coordinates for GCP No. %(key)s? \n"
+"\n"
+"East: %(coor0)s \n"
+"North: %(coor1)s"
msgstr ""
-#: ../gui/wxpython/core/settings.py:888
-msgid "Fancy green"
+#: ../gui/wxpython/gcp/manager.py:1408
+msgid "Writing POINTS file failed"
msgstr ""
-#: ../gui/wxpython/core/settings.py:889
-msgid "List left"
+#: ../gui/wxpython/gcp/manager.py:1420
+#, python-format
+msgid "POINTS file saved for group <%s>"
msgstr ""
-#: ../gui/wxpython/core/settings.py:896
-msgid "Zoom and recenter"
+#: ../gui/wxpython/gcp/manager.py:1436
+msgid "source mapwin not defined"
msgstr ""
-msgid "Zoom to mouse cursor"
+#: ../gui/wxpython/gcp/manager.py:1441
+msgid "target mapwin not defined"
msgstr ""
-msgid "Nothing"
+#: ../gui/wxpython/gcp/manager.py:1471
+msgid "Reading POINTS file failed"
msgstr ""
-#: ../gui/wxpython/core/settings.py:898
-msgid "Scroll forward to zoom in"
+#: ../gui/wxpython/gcp/manager.py:1556
+#, python-format
+msgid ""
+"Insufficient points defined and active (checked) for selected rectification method (order: %d).\n"
+"3+ points needed for 1st order,\n"
+"6+ points for 2nd order, and\n"
+"10+ points for 3rd order."
msgstr ""
-msgid "Scroll back to zoom in"
+#: ../gui/wxpython/gcp/manager.py:1584
+msgid "Rectifying images, please wait..."
msgstr ""
-#: ../gui/wxpython/core/settings.py:931 ../gui/wxpython/core/settings.py:943
-msgid "box"
+#: ../gui/wxpython/gcp/manager.py:1624
+#, python-format
+msgid "Transforming <%s>..."
msgstr ""
-#: ../gui/wxpython/core/settings.py:932
-msgid "sphere"
+#: ../gui/wxpython/gcp/manager.py:1629
+#, python-format
+msgid "Rectifying vector map <%s>, please wait..."
msgstr ""
-#: ../gui/wxpython/core/settings.py:933
-msgid "cube"
+#: ../gui/wxpython/gcp/manager.py:1663
+#, python-format
+msgid "Georectification of vector map <%s> failed"
msgstr ""
-#: ../gui/wxpython/core/settings.py:934
-msgid "diamond"
+#: ../gui/wxpython/gcp/manager.py:1669
+msgid "GCP Manager settings"
msgstr ""
-#: ../gui/wxpython/core/settings.py:935
-msgid "aster"
+#: ../gui/wxpython/gcp/manager.py:1716
+msgid "Quit GCP Manager"
msgstr ""
-#: ../gui/wxpython/core/settings.py:936
-msgid "gyro"
+#: ../gui/wxpython/gcp/manager.py:1717
+msgid "Save ground control points?"
msgstr ""
-#: ../gui/wxpython/core/settings.py:937
-msgid "histogram"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:943
-msgid "cross"
-msgstr ""
-msgid "circle"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:976
-#, python-format
-msgid "Unable to read settings file <%s>\n"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:1002
-#, python-format
+#: ../gui/wxpython/gcp/manager.py:1796
msgid ""
-"Error: Reading settings from file <%(file)s> failed.\n"
-"\t\tDetails: %(detail)s\n"
-"\t\tLine: '%(line)s'\n"
+"Could not calculate RMS Error.\n"
+"Possible error with m.transform."
msgstr ""
-#: ../gui/wxpython/core/settings.py:1020
-msgid "Unable to create settings directory"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:1069
-#, python-format
+#: ../gui/wxpython/gcp/manager.py:1924
msgid ""
-"Writing settings to file <%(file)s> failed.\n"
-"\n"
-"Details: %(detail)s"
+"Could not calculate new extends.\n"
msgstr ""
-#: ../gui/wxpython/core/settings.py:1175
-msgid "Unable to set "
+#: ../gui/wxpython/gcp/manager.py:2056
+msgid "Adjust source display to target display"
msgstr ""
-#: ../gui/wxpython/core/settings.py:1211 ../gui/wxpython/core/settings.py:1221
-#, python-format
-msgid "Unable to parse settings '%s'"
+#: ../gui/wxpython/gcp/manager.py:2061
+msgid "Adjust target display to source display"
msgstr ""
-#: ../gui/wxpython/core/gcmd.py:126
-msgid "Reason"
+#: ../gui/wxpython/gcp/manager.py:2135 ../gui/wxpython/gcp/manager.py:2153
+#: ../gui/wxpython/vnet/vnet_data.py:259 ../gui/wxpython/vnet/widgets.py:85
+msgid "use"
msgstr ""
-#: ../gui/wxpython/core/gcmd.py:151 ../gui/wxpython/gis_set.py:643
-#: ../gui/wxpython/gis_set.py:686 ../gui/wxpython/lmgr/frame.py:2506
-msgid "Message"
+#: ../gui/wxpython/gcp/manager.py:2136 ../gui/wxpython/gcp/manager.py:2154
+msgid "source E"
msgstr ""
-#: ../gui/wxpython/core/gcmd.py:432
-msgid "Execution failed:"
+#: ../gui/wxpython/gcp/manager.py:2137 ../gui/wxpython/gcp/manager.py:2155
+msgid "source N"
msgstr ""
-#: ../gui/wxpython/core/gcmd.py:435 ../gui/wxpython/core/render.py:1010
-#: ../gui/wxpython/core/render.py:1013 ../gui/wxpython/core/render.py:1016
-msgid "Details:"
+#: ../gui/wxpython/gcp/manager.py:2138 ../gui/wxpython/gcp/manager.py:2156
+msgid "target E"
msgstr ""
-#: ../gui/wxpython/core/gcmd.py:437 ../gui/wxpython/core/gcmd.py:444
-msgid "Error: "
+#: ../gui/wxpython/gcp/manager.py:2139 ../gui/wxpython/gcp/manager.py:2157
+msgid "target N"
msgstr ""
-#: ../gui/wxpython/core/gcmd.py:521
-#, python-format
-msgid "Unable to exectute command: '%s'"
+#: ../gui/wxpython/gcp/manager.py:2140 ../gui/wxpython/gcp/manager.py:2158
+msgid "Forward error"
msgstr ""
-#: ../gui/wxpython/core/gcmd.py:747 ../gui/wxpython/gui_core/forms.py:2713
-#, python-format
-msgid "Error in %s"
+#: ../gui/wxpython/gcp/manager.py:2141 ../gui/wxpython/gcp/manager.py:2159
+msgid "Backward error"
msgstr ""
-#: ../gui/wxpython/core/toolboxes.py:217
-msgid "Unable to parse user toolboxes XML files. Default files will be loaded."
+#: ../gui/wxpython/gcp/manager.py:2296
+msgid "Invalid coordinate value. Operation canceled."
msgstr ""
-#: ../gui/wxpython/core/toolboxes.py:261
-msgid "Unable to create toolboxes directory."
+#: ../gui/wxpython/gcp/manager.py:2343
+msgid "Create vector map group"
msgstr ""
-#: ../gui/wxpython/core/toolboxes.py:485
-msgid "Custom toolboxes"
+#: ../gui/wxpython/gcp/manager.py:2418
+msgid "Select vector map(s) to add to group:"
msgstr ""
-#: ../gui/wxpython/core/toolboxes.py:509
-msgid "List of addons cannot be obtained because g.extension failed."
+#: ../gui/wxpython/gcp/manager.py:2469
+msgid "Edit GCP"
msgstr ""
-#: ../gui/wxpython/core/toolboxes.py:565
-msgid "Addons"
+#: ../gui/wxpython/gcp/manager.py:2481
+msgid "Ground Control Point No."
msgstr ""
-#: ../gui/wxpython/core/render.py:151
-#, python-format
-msgid "<%(name)s>: layer type <%(type)s> is not supported"
+#: ../gui/wxpython/gcp/manager.py:2500
+msgid "source E:"
msgstr ""
-#: ../gui/wxpython/core/render.py:170
-#, python-format
-msgid "Command '%s' failed\n"
+#: ../gui/wxpython/gcp/manager.py:2501
+msgid "target E:"
msgstr ""
-#: ../gui/wxpython/core/render.py:173
-#, python-format
-msgid "Details: %s\n"
+#: ../gui/wxpython/gcp/manager.py:2502
+msgid "source N:"
msgstr ""
-#: ../gui/wxpython/core/render.py:258
-#, python-format
-msgid "Unsupported map layer type '%s'"
+#: ../gui/wxpython/gcp/manager.py:2503
+msgid "target N:"
msgstr ""
-#: ../gui/wxpython/core/render.py:623
-#, python-format
-msgid "Rendering failed: %s"
+#: ../gui/wxpython/gcp/manager.py:2609 ../gui/wxpython/wxplot/dialogs.py:829
+#: ../gui/wxpython/wxplot/dialogs.py:1428 ../gui/wxpython/vnet/dialogs.py:1307
+#: ../gui/wxpython/iscatt/dialogs.py:397
+msgid "Apply changes for the current session"
msgstr ""
-#: ../gui/wxpython/core/render.py:666
-msgid "Rendering aborted"
+#: ../gui/wxpython/gcp/manager.py:2612 ../gui/wxpython/wxplot/dialogs.py:836
+#: ../gui/wxpython/wxplot/dialogs.py:1432 ../gui/wxpython/vnet/dialogs.py:1310
+#: ../gui/wxpython/gui_core/preferences.py:98
+#: ../gui/wxpython/iscatt/dialogs.py:400
+msgid "Apply and save changes to user settings file (default for next sessions)"
msgstr ""
-#: ../gui/wxpython/core/render.py:697
-msgid "Downloading data "
+#: ../gui/wxpython/gcp/manager.py:2614 ../gui/wxpython/vnet/dialogs.py:1312
+#: ../gui/wxpython/web_services/dialogs.py:144
+#: ../gui/wxpython/web_services/dialogs.py:899
+#: ../gui/wxpython/iscatt/dialogs.py:402
+#: ../gui/wxpython/modules/import_export.py:110
+#: ../gui/wxpython/modules/import_export.py:663
+msgid "Close dialog"
msgstr ""
-#: ../gui/wxpython/core/render.py:707
-msgid "Rendering & "
+#: ../gui/wxpython/gcp/manager.py:2640 ../gui/wxpython/psmap/dialogs.py:2643
+#: ../gui/wxpython/vdigit/preferences.py:98
+msgid "Symbology"
msgstr ""
-#: ../gui/wxpython/core/render.py:709
-msgid "Rendering..."
+#: ../gui/wxpython/gcp/manager.py:2649
+msgid "Highlight highest RMS error only"
msgstr ""
-#: ../gui/wxpython/core/render.py:754
-msgid "Trying to recover from default region..."
+#: ../gui/wxpython/gcp/manager.py:2662
+msgid "Highlight RMS error > M + SD * factor:"
msgstr ""
-#: ../gui/wxpython/core/render.py:779
-#: ../gui/wxpython/mapdisp/test_mapdisp.py:89
-#: ../gui/wxpython/gui_core/mapdisp.py:133
-#, python-format
-msgid "GRASS module '%s' not found. Unable to start map display window."
-msgstr ""
-#: ../gui/wxpython/core/render.py:814
-#, python-format
-msgid "Error: Unable to open '%(file)s'. Reason: %(ret)s. wxGUI exited.\n"
-msgstr ""
-#: ../gui/wxpython/core/render.py:824
-#, python-format
+#: ../gui/wxpython/gcp/manager.py:2666
msgid ""
-"\n"
-"ERROR: Unable to read WIND file: %s\n"
+"Highlight GCPs with an RMS error larger than \n"
+"mean + standard deviation * given factor. \n"
+"Recommended values for this factor are between 1 and 2."
msgstr ""
-#: ../gui/wxpython/core/render.py:928
-#, python-format
-msgid "Invalid map size %d,%d\n"
+#: ../gui/wxpython/gcp/manager.py:2689
+msgid "Symbol settings"
msgstr ""
-#: ../gui/wxpython/core/render.py:1009
-#, python-format
-msgid "Unable to zoom to raster map <%s>."
+#: ../gui/wxpython/gcp/manager.py:2697 ../gui/wxpython/psmap/dialogs.py:2362
+#: ../gui/wxpython/psmap/dialogs.py:2523 ../gui/wxpython/nviz/tools.py:1423
+#: ../gui/wxpython/nviz/tools.py:2154 ../gui/wxpython/nviz/tools.py:2296
+#: ../gui/wxpython/nviz/preferences.py:372
+#: ../gui/wxpython/nviz/preferences.py:574
+#: ../gui/wxpython/nviz/preferences.py:640
+#: ../gui/wxpython/gui_core/preferences.py:1454
+#: ../gui/wxpython/mapswipe/dialogs.py:280
+msgid "Color:"
msgstr ""
-#: ../gui/wxpython/core/render.py:1012
-#, python-format
-msgid "Unable to zoom to vector map <%s>."
+#: ../gui/wxpython/gcp/manager.py:2717
+msgid "Color for high RMS error:"
msgstr ""
-#: ../gui/wxpython/core/render.py:1015
-#, python-format
-msgid "Unable to zoom to 3d raster map <%s>."
+#: ../gui/wxpython/gcp/manager.py:2737
+msgid "Color for selected GCP:"
msgstr ""
-#: ../gui/wxpython/core/render.py:1019
-msgid "Unable to get current geographic extent. Force quiting wxGUI. Please manually run g.region to fix the problem."
+#: ../gui/wxpython/gcp/manager.py:2757
+msgid "Color for unused GCPs:"
msgstr ""
-#: ../gui/wxpython/core/menutree.py:143
-#, python-format
-msgid "Unknow tag %s"
+#: ../gui/wxpython/gcp/manager.py:2773
+msgid "Show unused GCPs"
msgstr ""
-#: ../gui/wxpython/core/debug.py:48
-msgid "Wx debug level {0}."
+#: ../gui/wxpython/gcp/manager.py:2790
+#: ../gui/wxpython/gui_core/preferences.py:1381
+msgid "Symbol size:"
msgstr ""
-#: ../gui/wxpython/core/debug.py:53
-msgid "WARNING: Ignoring unsupported wx debug level (must be >=0 and <=5). {0}\n"
+#: ../gui/wxpython/gcp/manager.py:2812 ../gui/wxpython/psmap/dialogs.py:6800
+#: ../gui/wxpython/vnet/dialogs.py:1279
+#: ../gui/wxpython/gui_core/preferences.py:1364
+#: ../gui/wxpython/mapswipe/dialogs.py:327
+msgid "Line width:"
msgstr ""
-#: ../gui/wxpython/core/gconsole.py:502
-#, python-format
-msgid ""
-"Unable to run command:\n"
-"%(cmd)s\n"
-"\n"
-"Option <%(opt)s>: read from standard input is not supported by wxGUI"
+#: ../gui/wxpython/gcp/manager.py:2918
+msgid "Rectification"
msgstr ""
-#: ../gui/wxpython/core/gconsole.py:526
-#, python-format
-msgid "Module <%s> not found."
+#: ../gui/wxpython/gcp/manager.py:2927
+msgid "Select rectification order"
msgstr ""
-#: ../gui/wxpython/core/gconsole.py:656
-#, python-format
-msgid "%d sec"
+#: ../gui/wxpython/gcp/manager.py:2929
+msgid "1st order"
msgstr ""
-#: ../gui/wxpython/core/gconsole.py:659
-#, python-format
-msgid "%(min)d min %(sec)d sec"
+#: ../gui/wxpython/gcp/manager.py:2930
+msgid "2nd order"
msgstr ""
-#: ../gui/wxpython/core/gconsole.py:663 ../gui/wxpython/gmodeler/model.py:1122
-#: ../gui/wxpython/gmodeler/model.py:1228 ../gui/wxpython/gui_core/ghelp.py:227
-msgid "unknown"
+#: ../gui/wxpython/gcp/manager.py:2931
+msgid "3rd order"
msgstr ""
-#: ../gui/wxpython/core/gconsole.py:667
-msgid "Please note that the data are left in inconsistent state and may be corrupted"
+#: ../gui/wxpython/gcp/manager.py:2943
+msgid "Select interpolation method:"
msgstr ""
-#: ../gui/wxpython/core/gconsole.py:669
-msgid "Command aborted"
+#: ../gui/wxpython/gcp/manager.py:2959
+msgid "clip to computational region in target location"
msgstr ""
-#: ../gui/wxpython/core/gconsole.py:671
-msgid "Command finished"
+#: ../gui/wxpython/gcp/manager.py:3010
+msgid "RMS threshold factor must be > 0"
msgstr ""
-#: ../gui/wxpython/core/gconsole.py:747 ../gui/wxpython/gui_core/goutput.py:492
-#, python-format
+#: ../gui/wxpython/gcp/manager.py:3013
msgid ""
-"Unable to write file '%(filePath)s'.\n"
-"\n"
-"Details: %(error)s"
+"RMS threshold factor is < 1\n"
+"Too many points might be highlighted"
msgstr ""
-#: ../gui/wxpython/datacatalog/frame.py:36
-msgid "GRASS GIS Data Catalog"
-msgstr ""
-#: ../gui/wxpython/datacatalog/frame.py:66
-msgid "Close GRASS GIS Data Catalog"
-msgstr ""
-#: ../gui/wxpython/datacatalog/frame.py:119 ../gui/wxpython/lmgr/frame.py:502
-#: ../gui/wxpython/lmgr/frame.py:1051
+#: ../gui/wxpython/gcp/manager.py:3197
#, python-format
-msgid ""
-"Current location is <%(loc)s>.\n"
-"Current mapset is <%(mapset)s>."
+msgid "GCP Manager settings saved to file '%s'."
msgstr ""
-#: ../gui/wxpython/datacatalog/frame.py:127 ../gui/wxpython/lmgr/frame.py:1074
-#: ../gui/wxpython/lmgr/frame.py:1096
-#, python-format
-msgid "Current mapset is <%s>."
+#: ../gui/wxpython/gcp/statusbar.py:38
+msgid "Go to GCP No."
msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:134
-msgid "Failed to read mapsets from location <{l}>."
+#: ../gui/wxpython/gcp/statusbar.py:55
+msgid "Valid Range:"
msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:155
-msgid "Failed to read maps from location <{l}>."
+#: ../gui/wxpython/gcp/statusbar.py:121
+msgid "RMS error"
msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:227
-msgid "Map of type {elem} <{name}> already exists in mapset <{mapset}>. Do you want to overwrite it?"
+#: ../gui/wxpython/gcp/statusbar.py:125
+#, python-format
+msgid "Forward: %(forw)s, Backward: %(back)s"
msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:232
-#: ../gui/wxpython/datacatalog/tree.py:692
-#: ../gui/wxpython/modules/colorrules.py:679
-#: ../gui/wxpython/rdigit/dialogs.py:104 ../gui/wxpython/lmgr/layertree.py:1075
-#: ../gui/wxpython/gui_core/dialogs.py:475
-msgid "Overwrite?"
+#: ../gui/wxpython/gcp/mapdisplay.py:50
+msgid "GRASS GIS Manage Ground Control Points"
msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:314
-msgid "GRASS locations in {0}"
+#: ../gui/wxpython/gcp/mapdisplay.py:176
+msgid "GCP List"
msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:582
-msgid "Map <{layer}> marked for copying. You can paste it to the current mapset <{mapset}>."
+#: ../gui/wxpython/gcp/mapdisplay.py:181
+msgid "Source Display"
msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:596
-#: ../gui/wxpython/datacatalog/tree.py:656
-msgid "New name"
+#: ../gui/wxpython/gcp/mapdisplay.py:185
+msgid "Target Display"
msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:597
-msgid "Rename map"
+#: ../gui/wxpython/gcp/mapdisplay.py:261
+#: ../gui/wxpython/rlisetup/sampling_frame.py:102
+#: ../gui/wxpython/iclass/frame.py:312 ../gui/wxpython/mapdisp/frame.py:510
+#: ../gui/wxpython/mapswipe/frame.py:291
+msgid "Map Toolbar"
msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:609
-msgid "Editing {name}"
+#: ../gui/wxpython/gcp/mapdisplay.py:275
+msgid "GCP Display toolbar"
msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:628
-msgid "Renaming map <{name}>..."
+#: ../gui/wxpython/gcp/mapdisplay.py:288
+msgid "GCP Manager toolbar"
msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:642
-msgid "{cmd} -- completed"
+#: ../gui/wxpython/gcp/mapdisplay.py:382 ../gui/wxpython/mapdisp/frame.py:805
+#: ../gui/wxpython/mapswipe/frame.py:550
+msgid "Nothing to render (empty map). Operation canceled."
msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:650
-msgid "No map selected for copying."
+#: ../gui/wxpython/gcp/mapdisplay.py:397 ../gui/wxpython/mapdisp/frame.py:646
+#: ../gui/wxpython/gmodeler/frame.py:652 ../gui/wxpython/mapswipe/frame.py:556
+#: ../gui/wxpython/modules/histogram.py:471
+msgid "Choose a file name to save the image (no need to add extension)"
msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:657
-msgid "Copy map"
+#: ../gui/wxpython/gcp/mapdisplay.py:426 ../gui/wxpython/psmap/toolbars.py:76
+#: ../gui/wxpython/mapdisp/frame.py:816 ../gui/wxpython/wxplot/base.py:610
+#: ../gui/wxpython/modules/histogram.py:500 ../gui/wxpython/menustrings.py:1985
+msgid "Page setup"
msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:668
-msgid "Failed to copy map: new map has the same name"
+#: ../gui/wxpython/gcp/mapdisplay.py:430 ../gui/wxpython/mapdisp/frame.py:820
+#: ../gui/wxpython/wxplot/base.py:611 ../gui/wxpython/modules/histogram.py:504
+msgid "Print preview"
msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:688
-msgid "Map <{map}> already exists in the current mapset. Do you want to overwrite it?"
+#: ../gui/wxpython/gcp/mapdisplay.py:434 ../gui/wxpython/mapdisp/frame.py:824
+#: ../gui/wxpython/wxplot/base.py:612 ../gui/wxpython/gui_core/toolbars.py:67
+#: ../gui/wxpython/modules/histogram.py:508
+msgid "Print display"
msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:702
-msgid "Copying <{name}>..."
+#: ../gui/wxpython/gcp/mapdisplay.py:474
+msgid "Zoom to computational region (set with g.region)"
msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:723
-msgid "g.copy completed"
+#: ../gui/wxpython/gcp/mapdisplay.py:479 ../gui/wxpython/mapdisp/frame.py:1388
+msgid "Zoom to default region"
msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:727
-msgid "Failed to copy map: action is allowed only within the same location."
+#: ../gui/wxpython/gcp/mapdisplay.py:483 ../gui/wxpython/mapdisp/frame.py:1390
+msgid "Zoom to saved region"
msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:758
-msgid "Do you really want to delete map <{m}> of type <{etype}> from mapset <{mapset}> in location <{loc}>?"
+#: ../gui/wxpython/gcp/mapdisplay.py:488
+msgid "Set computational region from display"
msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:763
-msgid "Delete map"
+#: ../gui/wxpython/gcp/mapdisplay.py:493 ../gui/wxpython/mapdisp/frame.py:1400
+msgid "Save display geometry to named region"
msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:764
-msgid "Deleting {name}..."
+#: ../gui/wxpython/psmap/dialogs.py:218
+msgid "Units:"
msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:780
-msgid "g.remove completed"
+#: ../gui/wxpython/psmap/dialogs.py:229
+msgid ""
+"Position of the top left corner\n"
+"from the top left edge of the paper"
msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:790
-msgid "Displaying {name}..."
+#: ../gui/wxpython/psmap/dialogs.py:231
+#: ../gui/wxpython/animation/dialogs.py:1137
+msgid "X:"
msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:793
-#: ../gui/wxpython/datacatalog/tree.py:802
-msgid " -- completed. Go to Layers tab for further operations."
+#: ../gui/wxpython/psmap/dialogs.py:233
+#: ../gui/wxpython/animation/dialogs.py:1139
+msgid "Y:"
msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:807
-msgid "Failed to display layer: not in current mapset or invalid layer"
+#: ../gui/wxpython/psmap/dialogs.py:258
+msgid "Position is given:"
msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:825
-msgid "Moving maps not implemented"
+#: ../gui/wxpython/psmap/dialogs.py:260
+msgid "relative to paper"
msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:833
-msgid "Maps can be copied only to current mapset"
+#: ../gui/wxpython/psmap/dialogs.py:262
+msgid "by map coordinates"
msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:907
-msgid "&Copy"
+#: ../gui/wxpython/psmap/dialogs.py:292
+msgid ""
+"Position from the top left\n"
+"edge of the paper"
msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:912
-#: ../gui/wxpython/datacatalog/tree.py:945
-#: ../gui/wxpython/datacatalog/tree.py:963
-msgid "&Paste"
+#: ../gui/wxpython/psmap/dialogs.py:383
+msgid "Font:"
msgstr ""
-#. GTC Delete mapset
-#: ../gui/wxpython/datacatalog/tree.py:920 ../gui/wxpython/gis_set.py:207
-msgid "&Delete"
+#: ../gui/wxpython/psmap/dialogs.py:385 ../gui/wxpython/psmap/dialogs.py:4966
+#: ../gui/wxpython/gui_core/dialogs.py:2471
+msgid "Font size:"
msgstr ""
-#. GTC Rename mapset
-#: ../gui/wxpython/datacatalog/tree.py:925 ../gui/wxpython/gis_set.py:203
-#: ../gui/wxpython/dbmgr/base.py:2394
-msgid "&Rename"
+#: ../gui/wxpython/psmap/dialogs.py:411
+msgid "Choose color:"
msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:933
-msgid "&Display layer"
+#: ../gui/wxpython/psmap/dialogs.py:460
+msgid "Close dialog and apply changes"
msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:951
-msgid "&Switch mapset"
+#: ../gui/wxpython/psmap/dialogs.py:462 ../gui/wxpython/wxplot/dialogs.py:838
+#: ../gui/wxpython/wxplot/dialogs.py:1433
+#: ../gui/wxpython/vdigit/preferences.py:70
+#: ../gui/wxpython/gmodeler/preferences.py:696
+#: ../gui/wxpython/gui_core/preferences.py:101
+msgid "Close dialog and ignore changes"
msgstr ""
-#: ../gui/wxpython/datacatalog/toolbars.py:25
-msgid "Reload GRASS locations"
+#: ../gui/wxpython/psmap/dialogs.py:466 ../gui/wxpython/vdigit/dialogs.py:151
+#: ../gui/wxpython/web_services/dialogs.py:684
+msgid "Apply changes"
msgstr ""
-#: ../gui/wxpython/datacatalog/toolbars.py:28
-msgid "Reload current GRASS mapset only"
+#: ../gui/wxpython/psmap/dialogs.py:511
+msgid "Units"
msgstr ""
-#: ../gui/wxpython/datacatalog/toolbars.py:31
-msgid "Click to restrict editing to current mapset only"
+#: ../gui/wxpython/psmap/dialogs.py:512
+#: ../gui/wxpython/animation/dialogs.py:926
+msgid "Format"
msgstr ""
-#: ../gui/wxpython/datacatalog/toolbars.py:34
-msgid "Click to allow editing other mapsets"
+#: ../gui/wxpython/psmap/dialogs.py:513
+msgid "Orientation"
msgstr ""
-#: ../gui/wxpython/datacatalog/toolbars.py:54
-msgid "Search:"
+#: ../gui/wxpython/psmap/dialogs.py:514 ../gui/wxpython/psmap/dialogs.py:2875
+msgid "Width"
msgstr ""
-#: ../gui/wxpython/datacatalog/toolbars.py:56
-msgid "Type to search database by map type or name. Use prefix 'r:', 'v:' and 'r3:'to show only raster, vector or 3D raster data, respectively. Use Python regular expressions to refine your search."
+#: ../gui/wxpython/psmap/dialogs.py:515
+msgid "Height"
msgstr ""
-#: ../gui/wxpython/datacatalog/catalog.py:33
-msgid "Data catalog"
+#: ../gui/wxpython/psmap/dialogs.py:516
+msgid "Left"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:39
-msgid "The Timeline Tool needs the \"matplotlib\" (python-matplotlib) package to be installed. {0}"
+#: ../gui/wxpython/psmap/dialogs.py:517
+msgid "Right"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:77
-msgid "GRASS GIS Timeline Tool"
+#: ../gui/wxpython/psmap/dialogs.py:518
+#: ../gui/wxpython/location_wizard/dialogs.py:276
+msgid "Top"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:135 ../gui/wxpython/nviz/tools.py:850
-#: ../gui/wxpython/nviz/tools.py:1889 ../gui/wxpython/nviz/preferences.py:405
-#: ../gui/wxpython/tplot/frame.py:277
-msgid "Draw"
+#: ../gui/wxpython/psmap/dialogs.py:519
+#: ../gui/wxpython/location_wizard/dialogs.py:284
+msgid "Bottom"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:137 ../gui/wxpython/tplot/frame.py:280
-#: ../gui/wxpython/menustrings.py:2053 ../gui/wxpython/menustrings.py:2096
-msgid "Help"
+#: ../gui/wxpython/psmap/dialogs.py:581
+msgid "Literal is not allowed!"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:141
-msgid "3D plot of spatio-temporal extents"
+#: ../gui/wxpython/psmap/dialogs.py:582 ../gui/wxpython/psmap/dialogs.py:1408
+#: ../gui/wxpython/psmap/dialogs.py:1432 ../gui/wxpython/psmap/dialogs.py:1483
+#: ../gui/wxpython/psmap/dialogs.py:5091 ../gui/wxpython/wxplot/dialogs.py:602
+#: ../gui/wxpython/animation/controller.py:295
+#: ../gui/wxpython/animation/dialogs.py:743
+msgid "Invalid input"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:144
-msgid "3D plot of spatio-temporal extents (matplotlib >= 1.0.0)"
+#: ../gui/wxpython/psmap/dialogs.py:595
+msgid "Page size"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:149
-msgid "Select space time dataset(s):"
+#: ../gui/wxpython/psmap/dialogs.py:599
+msgid "Margins"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:180 ../gui/wxpython/tplot/frame.py:309
-#: ../gui/wxpython/tplot/frame.py:420
-#, python-format
-msgid "Dataset <%s> not found in temporal database"
+#: ../gui/wxpython/psmap/dialogs.py:606
+msgid "Portrait"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:196 ../gui/wxpython/tplot/frame.py:327
-#: ../gui/wxpython/tplot/frame.py:439
-msgid "Datasets have different temporal type (absolute x relative), which is not allowed."
+msgid "Landscape"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:215 ../gui/wxpython/tplot/frame.py:344
-#: ../gui/wxpython/tplot/frame.py:449
-msgid "Datasets have different time unit which is not allowed."
+#: ../gui/wxpython/psmap/dialogs.py:689 ../gui/wxpython/psmap/dialogs.py:710
+#: ../gui/wxpython/location_wizard/wizard.py:2177
+msgid "custom"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:236
-msgid "Dataset <{name}> is empty"
+#: ../gui/wxpython/psmap/dialogs.py:752
+msgid "Map settings"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:294
-#, python-format
-msgid "X [%s]"
+#: ../gui/wxpython/psmap/dialogs.py:762
+msgid "Map frame settings"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:295
-#, python-format
-msgid "Y [%s]"
+#: ../gui/wxpython/psmap/dialogs.py:820 ../gui/wxpython/psmap/dialogs.py:874
+#: ../gui/wxpython/psmap/toolbars.py:82 ../gui/wxpython/menustrings.py:2000
+msgid "Map frame"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:297
-msgid "X"
+#: ../gui/wxpython/psmap/dialogs.py:880
+msgid "Map frame options:"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:298
-msgid "Y"
+#: ../gui/wxpython/psmap/dialogs.py:881
+msgid "fit frame to match selected map"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:303
-#: ../gui/wxpython/animation/dialogs.py:1967
-msgid "Time"
+#: ../gui/wxpython/psmap/dialogs.py:882
+msgid "fit frame to match saved region"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:373 ../gui/wxpython/tplot/frame.py:592
-#: ../gui/wxpython/tplot/frame.py:639 ../gui/wxpython/tplot/frame.py:677
-#, python-format
-msgid "Time [%s]"
+#: ../gui/wxpython/psmap/dialogs.py:883
+msgid "fit frame to match current computational region"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:463 ../gui/wxpython/animation/utils.py:70
-#: ../gui/wxpython/animation/utils.py:79
-#: ../gui/wxpython/animation/temporal_manager.py:242
-#: ../gui/wxpython/tplot/frame.py:802
-#, python-format
-msgid "Space time dataset <%s> not found."
+#: ../gui/wxpython/psmap/dialogs.py:884
+msgid "fixed scale and map center"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:478 ../gui/wxpython/tplot/frame.py:817
-#, python-format
-msgid "Please specify the space time dataset <%s>."
+#: ../gui/wxpython/psmap/dialogs.py:901 ../gui/wxpython/psmap/dialogs.py:1211
+msgid "Map selection"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:480 ../gui/wxpython/tplot/frame.py:820
-msgid "Ambiguous dataset name"
+#: ../gui/wxpython/psmap/dialogs.py:914 ../gui/wxpython/psmap/dialogs.py:1702
+msgid "Map:"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:564 ../gui/wxpython/tplot/frame.py:954
-#, python-format
-msgid "Space time raster dataset: %s"
+msgid "Region:"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:566 ../gui/wxpython/tplot/frame.py:956
-#, python-format
-msgid "Space time vector dataset: %s"
+#: ../gui/wxpython/psmap/dialogs.py:971
+msgid "Map scale and center"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:568 ../gui/wxpython/tplot/frame.py:958
-#, python-format
-msgid "Space time 3D raster dataset: %s"
+#: ../gui/wxpython/psmap/dialogs.py:975
+msgid "Center:"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:570
-#, python-format
-msgid "Mapset: %s"
+#: ../gui/wxpython/psmap/dialogs.py:976
+msgid "E:"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:571
-#, python-format
-msgid "Map name: %s"
+#: ../gui/wxpython/psmap/dialogs.py:977
+msgid "N:"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:573
-#, python-format
-msgid "Start time: %s"
+#: ../gui/wxpython/psmap/dialogs.py:984 ../gui/wxpython/psmap/dialogs.py:5847
+msgid "Scale:"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:576
-#, python-format
-msgid "End time: %s"
+#: ../gui/wxpython/psmap/dialogs.py:985
+msgid "1 :"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:580
-msgid "WARNING: invalid topology"
+#: ../gui/wxpython/psmap/dialogs.py:1049
+msgid "Map max resolution (dpi):"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:582
-msgid ""
-"\n"
-"Press Del to dismiss."
+#: ../gui/wxpython/psmap/dialogs.py:1086 ../gui/wxpython/psmap/dialogs.py:3696
+msgid "Border"
msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:79
-msgid "List of categories - right-click to delete"
+#: ../gui/wxpython/psmap/dialogs.py:1092
+msgid "draw border around map frame"
msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:110
-msgid "Add new category"
+#: ../gui/wxpython/psmap/dialogs.py:1099
+msgid "border color:"
msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:116 ../gui/wxpython/vdigit/dialogs.py:576
-#: ../gui/wxpython/vdigit/preferences.py:612
-#: ../gui/wxpython/vdigit/preferences.py:615 ../gui/wxpython/dbmgr/base.py:2937
-#: ../gui/wxpython/dbmgr/base.py:3058 ../gui/wxpython/dbmgr/base.py:3324
-#: ../gui/wxpython/dbmgr/dialogs.py:512
-msgid "Layer"
+#: ../gui/wxpython/psmap/dialogs.py:1101
+msgid "border width (pts):"
msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:123 ../gui/wxpython/vdigit/dialogs.py:577
-#: ../gui/wxpython/dbmgr/dialogs.py:512 ../gui/wxpython/dbmgr/dialogs.py:640
-msgid "Category"
-msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:151 ../gui/wxpython/psmap/dialogs.py:466
-#: ../gui/wxpython/web_services/dialogs.py:684
-msgid "Apply changes"
-msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:153
-msgid "Ignore changes and close dialog"
-msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:155
-#: ../gui/wxpython/web_services/dialogs.py:689
-msgid "Apply changes and close dialog"
-msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:175 ../gui/wxpython/dbmgr/dialogs.py:149
-msgid "Feature id:"
-msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:248 ../gui/wxpython/vdigit/dialogs.py:472
-#, python-format
+#: ../gui/wxpython/psmap/dialogs.py:1220
msgid ""
-"Unable to add new layer/category <%(layer)s/%(category)s>.\n"
-"Layer and category number must be integer.\n"
-"Layer number must be greater than zero."
+"Region is set to match this map,\n"
+"raster or vector map must be added later"
msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:284
-#: ../gui/wxpython/gmodeler/dialogs.py:844
-#: ../gui/wxpython/gmodeler/dialogs.py:1013
-msgid "Delete selected"
+#: ../gui/wxpython/psmap/dialogs.py:1227
+msgid "Region selection"
msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:288
-#: ../gui/wxpython/gmodeler/dialogs.py:845
-msgid "Delete all"
+#: ../gui/wxpython/psmap/dialogs.py:1407
+msgid "No map selected!"
msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:290 ../gui/wxpython/dbmgr/base.py:1423
-#: ../gui/wxpython/dbmgr/base.py:2573 ../gui/wxpython/gmodeler/dialogs.py:851
-#: ../gui/wxpython/gmodeler/dialogs.py:1017
-msgid "Reload"
+#: ../gui/wxpython/psmap/dialogs.py:1431
+msgid "No region selected!"
msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:446
-msgid "Unable to update vector map."
+#: ../gui/wxpython/psmap/dialogs.py:1482
+msgid "Invalid scale or map center!"
msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:622
-#, python-format
-msgid "%d lines selected for z bulk-labeling"
+#: ../gui/wxpython/psmap/dialogs.py:1527 ../gui/wxpython/lmgr/layertree.py:1015
+#: ../gui/wxpython/nviz/mapwindow.py:1675 ../gui/wxpython/nviz/tools.py:827
+#: ../gui/wxpython/menustrings.py:2002
+msgid "Raster map"
msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:630
-msgid "Set value"
+#: ../gui/wxpython/psmap/dialogs.py:1552
+msgid "Choose raster map"
msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:637
-msgid "Starting value"
+#: ../gui/wxpython/psmap/dialogs.py:1557
+msgid "no raster map"
msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:649
-msgid "Step"
+#: ../gui/wxpython/psmap/dialogs.py:1560
+msgid "raster:"
msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:692
-msgid "List of duplicates"
+#: ../gui/wxpython/psmap/dialogs.py:1622 ../gui/wxpython/psmap/frame.py:635
+#: ../gui/wxpython/psmap/frame.py:660
+msgid "Please, create map frame first."
msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:801
-msgid "Feature id"
+#: ../gui/wxpython/psmap/dialogs.py:1685 ../gui/wxpython/gmodeler/model.py:797
+msgid "Vector maps"
msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:802
-msgid "Layer (Categories)"
+#: ../gui/wxpython/psmap/dialogs.py:1698
+msgid "Add map"
msgstr ""
-#: ../gui/wxpython/vdigit/g.gui.vdigit.py:69
-msgid "GRASS GIS Vector Digitizer"
+#: ../gui/wxpython/psmap/dialogs.py:1706 ../gui/wxpython/psmap/dialogs.py:2167
+msgid "points"
msgstr ""
-#: ../gui/wxpython/vdigit/g.gui.vdigit.py:85
-#, python-format
-msgid "Vector digitizer not available. %s"
+#: ../gui/wxpython/psmap/dialogs.py:1706 ../gui/wxpython/psmap/dialogs.py:2169
+msgid "lines"
msgstr ""
-#: ../gui/wxpython/vdigit/g.gui.vdigit.py:90
-#, python-format
-msgid "Vector map <%s> not found in current mapset. New vector map can be created by providing '-c' flag."
+msgid "areas"
msgstr ""
-#: ../gui/wxpython/vdigit/g.gui.vdigit.py:94
-#, python-format
-msgid "New vector map <%s> created"
+#: ../gui/wxpython/psmap/dialogs.py:1712
+msgid "Data Type"
msgstr ""
-#: ../gui/wxpython/vdigit/g.gui.vdigit.py:101
-#, python-format
-msgid "Unable to create new vector map <%s>"
+#: ../gui/wxpython/psmap/dialogs.py:1717 ../gui/wxpython/dbmgr/base.py:2346
+#: ../gui/wxpython/animation/dialogs.py:776
+msgid "Add"
msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:56
-msgid "Digitization Error"
+#: ../gui/wxpython/psmap/dialogs.py:1746
+msgid "Manage vector maps"
msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:61
-#, python-format
-msgid "Unable to open vector map <%s>."
+#: ../gui/wxpython/psmap/dialogs.py:1751
+msgid "The topmost vector map overlaps the others"
msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:63 ../gui/wxpython/vdigit/toolbars.py:602
-msgid "No vector map open for editing."
+#: ../gui/wxpython/psmap/dialogs.py:1755 ../gui/wxpython/psmap/dialogs.py:3653
+#: ../gui/wxpython/web_services/widgets.py:255
+msgid "Up"
msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:64
-msgid "Operation canceled."
+#: ../gui/wxpython/psmap/dialogs.py:1756 ../gui/wxpython/psmap/dialogs.py:3654
+#: ../gui/wxpython/web_services/widgets.py:257
+msgid "Down"
msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:71
-#, python-format
-msgid ""
-"Writing new feature failed. Operation canceled.\n"
-"\n"
-"Reason: %s"
+#: ../gui/wxpython/psmap/dialogs.py:1757 ../gui/wxpython/nviz/tools.py:1364
+#: ../gui/wxpython/nviz/tools.py:2367 ../gui/wxpython/nviz/tools.py:2419
+#: ../gui/wxpython/menustrings.py:172 ../gui/wxpython/menustrings.py:1157
+#: ../gui/wxpython/menustrings.py:2018
+msgid "Delete"
msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:80
-#, python-format
-msgid "Reading feature id %d failed. Operation canceled."
+#: ../gui/wxpython/psmap/dialogs.py:1758
+msgid "Properties..."
msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:88
-#, python-format
-msgid "Database link %d not available. Operation canceled."
+#: ../gui/wxpython/psmap/dialogs.py:2001
+msgid "Raster map settings"
msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:96
-#, python-format
-msgid "Unable to start database driver <%s>. Operation canceled."
+#: ../gui/wxpython/psmap/dialogs.py:2049
+msgid "Vector maps settings"
msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:106
+#: ../gui/wxpython/psmap/dialogs.py:2097
#, python-format
-msgid "Unable to open database <%(db)s> by driver <%(driver)s>. Operation canceled."
+msgid "%s properties"
msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:114
-#, python-format
-msgid "Unable to execute SQL query '%s'. Operation canceled."
+#: ../gui/wxpython/psmap/dialogs.py:2152
+msgid "Data selection"
msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:122
-#, python-format
-msgid "Feature id %d is marked as dead. Operation canceled."
+#: ../gui/wxpython/psmap/dialogs.py:2163 ../gui/wxpython/gui_core/forms.py:2007
+#: ../gui/wxpython/modules/import_export.py:75
+msgid "Feature type"
msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:130
-#, python-format
-msgid "Unsupported feature type %d. Operation canceled."
+#: ../gui/wxpython/psmap/dialogs.py:2167
+msgid "centroids"
msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:500
-#, python-format
-msgid "Unknown feature type '%s'"
+#: ../gui/wxpython/psmap/dialogs.py:2169
+msgid "boundaries"
msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:505
-msgid "Not enough points for line"
+#: ../gui/wxpython/psmap/dialogs.py:2207
+msgid "Layer selection"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:33
-#: ../gui/wxpython/vdigit/toolbars.py:174
-msgid "Digitization settings"
+#: ../gui/wxpython/psmap/dialogs.py:2214
+msgid "Database connection is not defined in DB file."
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:64
-msgid "Apply changes for this session"
+#: ../gui/wxpython/psmap/dialogs.py:2215
+msgid "Select layer:"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:68
-msgid "Close dialog and save changes to user settings file"
+#: ../gui/wxpython/psmap/dialogs.py:2244
+msgid "list of categories (e.g. 1,3,5-7)"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:70
-#: ../gui/wxpython/psmap/dialogs.py:462
-#: ../gui/wxpython/gmodeler/preferences.py:696
-#: ../gui/wxpython/wxplot/dialogs.py:838 ../gui/wxpython/wxplot/dialogs.py:1433
-#: ../gui/wxpython/gui_core/preferences.py:101
-msgid "Close dialog and ignore changes"
+#: ../gui/wxpython/psmap/dialogs.py:2297 ../gui/wxpython/nviz/tools.py:977
+#: ../gui/wxpython/nviz/tools.py:2817 ../gui/wxpython/menustrings.py:323
+#: ../gui/wxpython/menustrings.py:1229
+msgid "Mask"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:98
-#: ../gui/wxpython/psmap/dialogs.py:2643 ../gui/wxpython/gcp/manager.py:2640
-msgid "Symbology"
+#: ../gui/wxpython/psmap/dialogs.py:2301
+msgid "Use current mask"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:150
-#: ../gui/wxpython/animation/dialogs.py:340
-#: ../gui/wxpython/animation/dialogs.py:1854
-#: ../gui/wxpython/gmodeler/preferences.py:54
-#: ../gui/wxpython/gui_core/preferences.py:281
-msgid "General"
+#: ../gui/wxpython/psmap/dialogs.py:2320 ../gui/wxpython/psmap/dialogs.py:2476
+msgid "Colors"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:161 ../gui/wxpython/nviz/tools.py:1574
-#: ../gui/wxpython/nviz/tools.py:1788
-msgid "Display"
+#: ../gui/wxpython/psmap/dialogs.py:2329 ../gui/wxpython/psmap/dialogs.py:2485
+msgid "Outline"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:166
-#: ../gui/wxpython/wxplot/dialogs.py:1054
-msgid "Line width"
+#: ../gui/wxpython/psmap/dialogs.py:2334 ../gui/wxpython/psmap/dialogs.py:2495
+msgid "draw outline"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:202
-msgid "Snapping"
+#: ../gui/wxpython/psmap/dialogs.py:2337 ../gui/wxpython/psmap/dialogs.py:2500
+#: ../gui/wxpython/psmap/dialogs.py:5272 ../gui/wxpython/psmap/dialogs.py:5280
+msgid "Width (pts):"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:211
-msgid "Snapping threshold"
+#: ../gui/wxpython/psmap/dialogs.py:2401 ../gui/wxpython/psmap/dialogs.py:2562
+#: ../gui/wxpython/wxplot/dialogs.py:1137
+#: ../gui/wxpython/wxplot/dialogs.py:1218
+msgid "Fill"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:220
-msgid "screen pixels"
+#: ../gui/wxpython/psmap/dialogs.py:2406
+msgid "fill color"
msgstr ""
-msgid "map units"
+#: ../gui/wxpython/psmap/dialogs.py:2412 ../gui/wxpython/psmap/dialogs.py:2570
+msgid "choose color:"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:240
-msgid "Snap also to vertex"
+#: ../gui/wxpython/psmap/dialogs.py:2427 ../gui/wxpython/psmap/dialogs.py:2586
+msgid "color from map table column:"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:250
-#: ../gui/wxpython/vdigit/preferences.py:905
-#: ../gui/wxpython/vdigit/preferences.py:919
-#: ../gui/wxpython/vdigit/preferences.py:923
-#, python-format
-msgid "Snapping threshold is %(value).1f %(units)s"
+#: ../gui/wxpython/psmap/dialogs.py:2498
+msgid "No effect for fill color from table column"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:268
-msgid "Select vector features"
+#: ../gui/wxpython/psmap/dialogs.py:2567
+msgid "Color of lines:"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:288
-msgid "Select threshold"
+#: ../gui/wxpython/psmap/dialogs.py:2634 ../gui/wxpython/psmap/dialogs.py:2866
+#: ../gui/wxpython/psmap/dialogs.py:2991
+msgid "Size and style"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:309
-msgid "Select only features inside of selection bounding box"
+#: ../gui/wxpython/psmap/dialogs.py:2648 ../gui/wxpython/nviz/tools.py:1717
+msgid "symbol:"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:316
-msgid "By default are selected all features overlapping selection bounding box "
+#: ../gui/wxpython/psmap/dialogs.py:2662
+msgid "eps file:"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:319
-msgid "Check for duplicates"
+#: ../gui/wxpython/psmap/dialogs.py:2666 ../gui/wxpython/psmap/dialogs.py:3008
+#: ../gui/wxpython/psmap/dialogs.py:5783 ../gui/wxpython/nviz/tools.py:626
+#: ../gui/wxpython/animation/dialogs.py:508
+#: ../gui/wxpython/animation/dialogs.py:1080
+#: ../gui/wxpython/animation/dialogs.py:1198
+#: ../gui/wxpython/animation/dialogs.py:1234
+#: ../gui/wxpython/animation/dialogs.py:1258
+#: ../gui/wxpython/animation/dialogs.py:1289
+#: ../gui/wxpython/location_wizard/wizard.py:113
+#: ../gui/wxpython/location_wizard/wizard.py:1273
+#: ../gui/wxpython/location_wizard/wizard.py:1349
+#: ../gui/wxpython/location_wizard/wizard.py:1439
+#: ../gui/wxpython/location_wizard/wizard.py:1667
+#: ../gui/wxpython/gui_core/forms.py:1802
+#: ../gui/wxpython/gui_core/forms.py:1886
+#: ../gui/wxpython/gui_core/gselect.py:1176
+#: ../gui/wxpython/gui_core/gselect.py:1490
+#: ../gui/wxpython/gui_core/gselect.py:1506
+#: ../gui/wxpython/gui_core/gselect.py:1553
+#: ../gui/wxpython/gui_core/gselect.py:1589
+#: ../gui/wxpython/modules/import_export.py:745
+msgid "Browse"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:345
-msgid "Digitize lines/boundaries"
+#: ../gui/wxpython/psmap/dialogs.py:2667 ../gui/wxpython/psmap/dialogs.py:3009
+msgid "Type filename or click browse to choose file"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:349
-msgid "Break lines at intersection"
+#: ../gui/wxpython/psmap/dialogs.py:2668 ../gui/wxpython/psmap/dialogs.py:3010
+msgid "Choose a file"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:372
-msgid "Digitize areas"
+#: ../gui/wxpython/psmap/dialogs.py:2717 ../gui/wxpython/psmap/dialogs.py:3791
+#: ../gui/wxpython/psmap/dialogs.py:4839 ../gui/wxpython/wxplot/dialogs.py:1123
+#: ../gui/wxpython/wxplot/dialogs.py:1204
+msgid "Size"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:376
-msgid "Close boundary (snap to the start node)"
+#: ../gui/wxpython/psmap/dialogs.py:2722 ../gui/wxpython/nviz/tools.py:1659
+msgid "size:"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:399
-msgid "Save changes"
+#: ../gui/wxpython/psmap/dialogs.py:2727
+msgid "size from map table column:"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:402
-msgid "Save changes on exit"
+#: ../gui/wxpython/psmap/dialogs.py:2729
+msgid "scale:"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:423
-msgid "Query tool"
+#: ../gui/wxpython/psmap/dialogs.py:2794
+msgid "Rotation"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:434
-msgid "Choose query tool"
+#: ../gui/wxpython/psmap/dialogs.py:2799
+msgid "rotate symbols:"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:442
-msgid "Select by box"
+#: ../gui/wxpython/psmap/dialogs.py:2801
+msgid "counterclockwise in degrees:"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:460
-#: ../gui/wxpython/vdigit/preferences.py:694
-msgid "length"
+#: ../gui/wxpython/psmap/dialogs.py:2805
+msgid "from map table column:"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:472
-msgid "Select lines"
+#: ../gui/wxpython/psmap/dialogs.py:2880
+msgid "Set width (pts):"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:475
-#: ../gui/wxpython/vdigit/preferences.py:529
-msgid "shorter than"
+#: ../gui/wxpython/psmap/dialogs.py:2897
+msgid "multiply width by category value"
msgstr ""
-msgid "longer than"
+#: ../gui/wxpython/psmap/dialogs.py:2929 ../gui/wxpython/psmap/dialogs.py:6794
+#: ../gui/wxpython/wxplot/dialogs.py:1072
+msgid "Line style"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:514
-msgid "dangle"
+#: ../gui/wxpython/psmap/dialogs.py:2934
+msgid "Choose line style:"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:526
-msgid "Select dangles"
+#: ../gui/wxpython/psmap/dialogs.py:2947
+msgid "Choose linecap:"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:582
-#: ../gui/wxpython/gui_core/preferences.py:1473
-msgid "Attributes"
+#: ../gui/wxpython/psmap/dialogs.py:3000
+msgid "Pattern"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:593
-msgid "Digitize new feature"
+#: ../gui/wxpython/psmap/dialogs.py:3005
+msgid "use pattern:"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:598
-msgid "Add new record into table"
+#: ../gui/wxpython/psmap/dialogs.py:3007
+msgid "Choose pattern file:"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:613
-msgid "Mode"
+#: ../gui/wxpython/psmap/dialogs.py:3015
+msgid "pattern line width (pts):"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:645
-msgid "Next to use"
+#: ../gui/wxpython/psmap/dialogs.py:3019
+msgid "pattern scale factor:"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:627
-msgid "Category number"
+#: ../gui/wxpython/psmap/dialogs.py:3379
+msgid "Raster legend"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:643
-msgid "Category mode"
+#: ../gui/wxpython/psmap/dialogs.py:3384
+#: ../gui/wxpython/animation/dialogs.py:473
+msgid "Show raster legend"
msgstr ""
-msgid "Manual entry"
+#: ../gui/wxpython/psmap/dialogs.py:3398
+msgid "Source raster"
msgstr ""
-msgid "No category"
+#: ../gui/wxpython/psmap/dialogs.py:3403
+msgid "current raster"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:668
-msgid "Delete existing feature(s)"
+#: ../gui/wxpython/psmap/dialogs.py:3406
+msgid "select raster"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:673
-msgid "Delete record from table"
+#: ../gui/wxpython/psmap/dialogs.py:3413 ../gui/wxpython/psmap/dialogs.py:4428
+#, python-format
+msgid "%(rast)s: type %(type)s"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:691
-msgid "Geometry attributes"
+#: ../gui/wxpython/psmap/dialogs.py:3462
+msgid "Type of legend"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:695
-#: ../gui/wxpython/modules/vclean.py:226
-msgid "area"
+#: ../gui/wxpython/psmap/dialogs.py:3467
+msgid "discrete legend (categorical maps)"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:696
-msgid "perimeter"
+#: ../gui/wxpython/psmap/dialogs.py:3471
+msgid "continuous color gradient legend (floating point map)"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:767
-msgid "Note: These settings are stored in the workspace not in the vector digitizer preferences."
+#: ../gui/wxpython/psmap/dialogs.py:3497
+msgid "Advanced legend settings"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:796
-msgid "Digitize new line segment"
+#: ../gui/wxpython/psmap/dialogs.py:3502
+msgid "draw \"no data\" box"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:797
-msgid "Digitize new line/boundary"
+#: ../gui/wxpython/psmap/dialogs.py:3511
+msgid "draw ticks across color table"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:798
-msgid "Highlight"
+#: ../gui/wxpython/psmap/dialogs.py:3524
+#: ../gui/wxpython/modules/colorrules.py:972
+#: ../gui/wxpython/modules/colorrules.py:1654
+#: ../gui/wxpython/modules/colorrules.py:1658
+msgid "range"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:799
-msgid "Highlight (duplicates)"
+#: ../gui/wxpython/psmap/dialogs.py:3603
+msgid "Vector legend"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:800
-#: ../gui/wxpython/psmap/dialogs.py:6266 ../gui/wxpython/psmap/toolbars.py:103
-#: ../gui/wxpython/gui_core/gselect.py:2327
-msgid "Point"
+#: ../gui/wxpython/psmap/dialogs.py:3608
+msgid "Show vector legend"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:801
-#: ../gui/wxpython/psmap/toolbars.py:105
-msgid "Line"
+#: ../gui/wxpython/psmap/dialogs.py:3622
+msgid "Source vector maps"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:802
-msgid "Boundary (no area)"
+#: ../gui/wxpython/psmap/dialogs.py:3627
+msgid "Choose vector maps and their order in legend"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:803
-msgid "Boundary (one area)"
+#: ../gui/wxpython/psmap/dialogs.py:3631 ../gui/wxpython/lmgr/layertree.py:1019
+#: ../gui/wxpython/nviz/tools.py:1453 ../gui/wxpython/menustrings.py:2004
+msgid "Vector map"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:804
-msgid "Boundary (two areas)"
+#: ../gui/wxpython/psmap/dialogs.py:3632
+#: ../gui/wxpython/gmodeler/dialogs.py:492
+#: ../gui/wxpython/gmodeler/dialogs.py:604
+#: ../gui/wxpython/gmodeler/frame.py:1790
+msgid "Label"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:805
-msgid "Centroid (in area)"
+#: ../gui/wxpython/psmap/dialogs.py:3655 ../gui/wxpython/psmap/dialogs.py:4135
+msgid "Edit label"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:806
-msgid "Centroid (outside area)"
+#: ../gui/wxpython/psmap/dialogs.py:3701
+msgid "draw border around legend"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:807
-msgid "Centroid (duplicate in area)"
+#: ../gui/wxpython/psmap/dialogs.py:3759
+msgid "Size and position"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:808
-msgid "Node (one line)"
+#: ../gui/wxpython/psmap/dialogs.py:3785 ../gui/wxpython/psmap/dialogs.py:4505
+#: ../gui/wxpython/psmap/dialogs.py:4783 ../gui/wxpython/psmap/dialogs.py:5364
+#: ../gui/wxpython/psmap/dialogs.py:5372 ../gui/wxpython/psmap/dialogs.py:5932
+#: ../gui/wxpython/psmap/dialogs.py:5941 ../gui/wxpython/psmap/dialogs.py:6516
+#: ../gui/wxpython/psmap/dialogs.py:6525 ../gui/wxpython/nviz/tools.py:1050
+#: ../gui/wxpython/nviz/tools.py:2021
+msgid "Position"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:809
-msgid "Node (two lines)"
+#: ../gui/wxpython/psmap/dialogs.py:3818 ../gui/wxpython/rdigit/toolbars.py:100
+#: ../gui/wxpython/nviz/preferences.py:559
+#: ../gui/wxpython/gmodeler/preferences.py:184
+#: ../gui/wxpython/gmodeler/preferences.py:350
+#: ../gui/wxpython/gmodeler/preferences.py:462
+#: ../gui/wxpython/gmodeler/preferences.py:578
+#: ../gui/wxpython/gui_core/dialogs.py:1933
+msgid "Width:"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:810
-msgid "Vertex"
+#: ../gui/wxpython/psmap/dialogs.py:3829
+msgid "Leave the edit field empty, to use default values."
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:811
-msgid "Area (closed boundary + centroid)"
+#: ../gui/wxpython/psmap/dialogs.py:3836 ../gui/wxpython/psmap/dialogs.py:4053
+#: ../gui/wxpython/psmap/dialogs.py:4844 ../gui/wxpython/nviz/tools.py:366
+#: ../gui/wxpython/nviz/tools.py:1285 ../gui/wxpython/nviz/tools.py:2126
+#: ../gui/wxpython/gmodeler/preferences.py:210
+#: ../gui/wxpython/gmodeler/preferences.py:376
+#: ../gui/wxpython/gmodeler/preferences.py:488
+#: ../gui/wxpython/gmodeler/preferences.py:604
+#: ../gui/wxpython/gui_core/dialogs.py:1937
+msgid "Height:"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:812
-msgid "Direction"
+#: ../gui/wxpython/psmap/dialogs.py:3869
+msgid ""
+"Width of the color symbol (for lines)\n"
+"in front of the legend text"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:896
-msgid "Snapping disabled"
+#: ../gui/wxpython/psmap/dialogs.py:3875 ../gui/wxpython/psmap/dialogs.py:4040
+msgid "Columns:"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:900
-#, python-format
-msgid "Snapping threshold is %(value).1f %(units)s (based on comp. resolution)"
+#: ../gui/wxpython/psmap/dialogs.py:3885
+msgid "column span:"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:956
-#, python-format
-msgid "Vector digitizer settings saved to file <%s>."
+#: ../gui/wxpython/psmap/dialogs.py:3887
+msgid ""
+"Column separation distance between the left edges\n"
+"of two columns in a multicolumn legend"
msgstr ""
-#: ../gui/wxpython/vdigit/wxdisplay.py:1017
-#, python-format
-msgid "Topology for vector map <%s> is not available. Topology is required by digitizer. Do you want to rebuild topology (takes some time) and open the vector map for editing?"
+#: ../gui/wxpython/psmap/dialogs.py:3934 ../gui/wxpython/psmap/dialogs.py:4541
+#: ../gui/wxpython/psmap/dialogs.py:5205 ../gui/wxpython/wxplot/dialogs.py:751
+#: ../gui/wxpython/gui_core/dialogs.py:2416
+#: ../gui/wxpython/gui_core/preferences.py:472
+#: ../gui/wxpython/gui_core/preferences.py:752
+msgid "Font settings"
msgstr ""
-#: ../gui/wxpython/vdigit/wxdisplay.py:1022
-msgid "Topology missing"
+#: ../gui/wxpython/psmap/dialogs.py:4134
+msgid "Edit legend label:"
msgstr ""
-#: ../gui/wxpython/vdigit/mapwindow.py:424
-msgid "Update categories"
+#: ../gui/wxpython/psmap/dialogs.py:4181
+msgid "No raster map selected!"
msgstr ""
-#: ../gui/wxpython/vdigit/mapwindow.py:548
-#: ../gui/wxpython/vdigit/mapwindow.py:957
-msgid "No vector map selected for editing."
+#: ../gui/wxpython/psmap/dialogs.py:4182
+msgid "No raster"
msgstr ""
-#: ../gui/wxpython/vdigit/mapwindow.py:557
-msgid "Nothing to do. Choose appropriate tool from digitizer toolbar."
+#: ../gui/wxpython/psmap/dialogs.py:4472
+msgid "Mapinfo settings"
msgstr ""
-#: ../gui/wxpython/vdigit/mapwindow.py:1091
-msgid "Z bulk-labeling dialog"
+#: ../gui/wxpython/psmap/dialogs.py:4576
+msgid "Color settings"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:107
-msgid "Select area/boundary/centroid tool"
+#: ../gui/wxpython/psmap/dialogs.py:4582
+msgid "use border color:"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:133
-msgid "Digitize new point"
+#: ../gui/wxpython/psmap/dialogs.py:4584
+msgid "use background color:"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:134
-#: ../gui/wxpython/vdigit/toolbars.py:143
-#: ../gui/wxpython/vdigit/toolbars.py:146
-msgid "Left: new point"
+#: ../gui/wxpython/psmap/dialogs.py:4843
+msgid "Length:"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:136
-msgid "Digitize new line"
+#: ../gui/wxpython/psmap/dialogs.py:4849
+msgid "Scalebar length is given in map units"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:137
-#: ../gui/wxpython/vdigit/toolbars.py:140
-#: ../gui/wxpython/vdigit/toolbars.py:164
-msgid "Left: new point; Ctrl+Left: undo last point; Right: close line"
+#: ../gui/wxpython/psmap/dialogs.py:4854
+msgid "Scalebar height is real height on paper"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:139
-msgid "Digitize new boundary"
+#: ../gui/wxpython/psmap/dialogs.py:4856
+msgid "default"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:142
-msgid "Digitize new centroid"
+#: ../gui/wxpython/psmap/dialogs.py:4929 ../gui/wxpython/wxplot/dialogs.py:1164
+#: ../gui/wxpython/wxplot/dialogs.py:1245
+msgid "Style"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:145
-msgid "Digitize new area (boundary without category)"
+#: ../gui/wxpython/psmap/dialogs.py:4933
+msgid "Type:"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:148
-msgid "Add new vertex to line or boundary"
+#: ../gui/wxpython/psmap/dialogs.py:4952
+msgid "Number of segments:"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:149
-#: ../gui/wxpython/vdigit/toolbars.py:152
-#: ../gui/wxpython/vdigit/toolbars.py:155
-#: ../gui/wxpython/vdigit/toolbars.py:167
-#: ../gui/wxpython/vdigit/toolbars.py:170
-#: ../gui/wxpython/vdigit/toolbars.py:173
-#: ../gui/wxpython/vdigit/toolbars.py:182
-msgid "Left: Select; Ctrl+Left: Unselect; Right: Confirm"
+#: ../gui/wxpython/psmap/dialogs.py:4958
+msgid "Label every "
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:151
-msgid "Delete selected point(s), line(s), boundary(ies) or centroid(s)"
+#: ../gui/wxpython/psmap/dialogs.py:4959
+msgid "segments"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:154
-msgid "Delete selected area(s)"
+#: ../gui/wxpython/psmap/dialogs.py:4972
+msgid "transparent text background"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:157
-msgid "Display/update attributes"
+#: ../gui/wxpython/psmap/dialogs.py:5090
+msgid "Length of scale bar is not defined"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:158
-#: ../gui/wxpython/vdigit/toolbars.py:161
-msgid "Left: Select"
+#: ../gui/wxpython/psmap/dialogs.py:5172 ../gui/wxpython/psmap/dialogs.py:5181
+#: ../gui/wxpython/psmap/toolbars.py:91
+#: ../gui/wxpython/animation/dialogs.py:1537
+#: ../gui/wxpython/menustrings.py:2012
+msgid "Text"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:160
-msgid "Display/update categories"
+#: ../gui/wxpython/psmap/dialogs.py:5184
+msgid "Enter text:"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:163
-msgid "Edit selected line/boundary"
+#: ../gui/wxpython/psmap/dialogs.py:5255
+msgid "Text effects"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:166
-msgid "Move selected point(s), line(s), boundary(ies) or centroid(s)"
+#: ../gui/wxpython/psmap/dialogs.py:5261
+msgid "text background"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:169
-msgid "Move selected vertex"
+#: ../gui/wxpython/psmap/dialogs.py:5266
+msgid "highlight"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:172
-msgid "Remove selected vertex"
+#: ../gui/wxpython/psmap/dialogs.py:5275
+msgid "text border"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:175
-msgid "Quit digitizer"
+#: ../gui/wxpython/psmap/dialogs.py:5384
+msgid "Offset"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:176
-msgid "Quit digitizer and save changes"
+#: ../gui/wxpython/psmap/dialogs.py:5388
+msgid "horizontal (pts):"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:177
-msgid "Vector Digitizer manual"
+#: ../gui/wxpython/psmap/dialogs.py:5390
+msgid "vertical (pts):"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:178
-msgid "Show Vector Digitizer manual"
+#: ../gui/wxpython/psmap/dialogs.py:5429
+msgid " Reference point"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:180
-msgid "Additional tools (copy, flip, connect, etc.)"
+#: ../gui/wxpython/psmap/dialogs.py:5483
+msgid "Text rotation"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:184 ../gui/wxpython/rdigit/toolbars.py:33
-msgid "Undo"
+#: ../gui/wxpython/psmap/dialogs.py:5489
+msgid "rotate text (counterclockwise)"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:185
-msgid "Undo previous changes"
+#: ../gui/wxpython/psmap/dialogs.py:5581
+msgid "No text entered!"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:187
-msgid "Redo"
+#: ../gui/wxpython/psmap/dialogs.py:5581 ../gui/wxpython/lmgr/layertree.py:974
+#: ../gui/wxpython/gis_set.py:277 ../gui/wxpython/gis_set.py:672
+#: ../gui/wxpython/gis_set.py:716 ../gui/wxpython/vdigit/dialogs.py:253
+#: ../gui/wxpython/vdigit/dialogs.py:447 ../gui/wxpython/gmodeler/frame.py:1086
+#: ../gui/wxpython/location_wizard/dialogs.py:142
+#: ../gui/wxpython/location_wizard/dialogs.py:161
+#: ../gui/wxpython/location_wizard/dialogs.py:490
+#: ../gui/wxpython/location_wizard/wizard.py:603
+#: ../gui/wxpython/location_wizard/wizard.py:792
+#: ../gui/wxpython/location_wizard/wizard.py:1941
+#: ../gui/wxpython/core/workspace.py:1610 ../gui/wxpython/core/gcmd.py:113
+#: ../gui/wxpython/gui_core/preferences.py:238
+#: ../gui/wxpython/gui_core/preferences.py:1859
+#: ../gui/wxpython/gui_core/preferences.py:1892
+#: ../gui/wxpython/gui_core/preferences.py:1904
+#: ../gui/wxpython/gui_core/preferences.py:1916
+msgid "Error"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:188
-msgid "Redo previous changes"
+#: ../gui/wxpython/psmap/dialogs.py:5707 ../gui/wxpython/psmap/dialogs.py:5769
+#: ../gui/wxpython/psmap/toolbars.py:99
+#: ../gui/wxpython/animation/dialogs.py:1536
+#: ../gui/wxpython/menustrings.py:2014
+msgid "Image"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:558
-msgid "Break selected lines/boundaries at intersection"
+#: ../gui/wxpython/psmap/dialogs.py:5781 ../gui/wxpython/nviz/tools.py:624
+msgid "Choose a directory:"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:560
-msgid "Connect selected lines/boundaries"
+#: ../gui/wxpython/psmap/dialogs.py:5782
+msgid "Choose a directory with images"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:562
-msgid "Copy categories"
+#: ../gui/wxpython/psmap/dialogs.py:5825
+msgid "Note: only EPS format supported"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:564
-msgid "Copy features from (background) vector map"
+#: ../gui/wxpython/psmap/dialogs.py:5841
+msgid "Scale And Rotation"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:566
-msgid "Copy attributes"
+#: ../gui/wxpython/psmap/dialogs.py:5882 ../gui/wxpython/psmap/dialogs.py:6464
+msgid "Rotation angle (deg):"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:568
-msgid "Feature type conversion"
+#: ../gui/wxpython/psmap/dialogs.py:5898 ../gui/wxpython/psmap/dialogs.py:6486
+msgid "Counterclockwise rotation in degrees"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:570
-msgid "Flip selected lines/boundaries"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:572
-msgid "Merge selected lines/boundaries"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:574
-msgid "Snap selected lines/boundaries (only to nodes)"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:576
-msgid "Split line/boundary"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:578
-msgid "Query features"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:580
-msgid "Z bulk-labeling of 3D lines"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:607
-msgid "Select background vector map"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:767
-msgid "Vector map is not 3D. Operation canceled."
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:840
-#: ../gui/wxpython/vdigit/toolbars.py:997
-#: ../gui/wxpython/vdigit/toolbars.py:1095
-#: ../gui/wxpython/gui_core/dialogs.py:213
-msgid "Select vector map"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:872
-#, python-format
+#: ../gui/wxpython/psmap/dialogs.py:6024
msgid ""
-"Topology for vector map <%s> is not available. Topology is required by digitizer.\n"
-"Do you want to rebuild topology (takes some time) and open the vector map for editing?"
+"PIL\n"
+"missing"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:877
-msgid "Digitizer error"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:902
+#: ../gui/wxpython/psmap/dialogs.py:6044
#, python-format
-msgid "Please wait, opening vector map <%s> for editing..."
+msgid "Unable to read file %s"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:940
+#: ../gui/wxpython/psmap/dialogs.py:6105
#, python-format
-msgid "Unsupported feature type '%(type)s'. Unable to edit OGR layer <%(layer)s>."
+msgid "size: %(width)s x %(height)s pts"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:952 ../gui/wxpython/mapdisp/frame.py:519
-#: ../gui/wxpython/mapdisp/toolbars.py:116
-msgid "Vector digitizer"
+#: ../gui/wxpython/psmap/dialogs.py:6127
+msgid "No image selected."
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:1010
-#, python-format
-msgid "Do you want to save changes in vector map <%s>?"
+#: ../gui/wxpython/psmap/dialogs.py:6231 ../gui/wxpython/psmap/toolbars.py:101
+#: ../gui/wxpython/nviz/tools.py:2332 ../gui/wxpython/menustrings.py:2016
+msgid "North Arrow"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:1013
-msgid "Save changes?"
+#: ../gui/wxpython/psmap/dialogs.py:6234
+msgid "North Arrow settings"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:1020
-#, python-format
-msgid "Please wait, closing and rebuilding topology of vector map <%s>..."
+#: ../gui/wxpython/psmap/dialogs.py:6245
+msgid "Compute convergence"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:1038
-#, python-format
-msgid "Editing of vector map <%s> successfully finished"
+#: ../gui/wxpython/psmap/dialogs.py:6266 ../gui/wxpython/psmap/toolbars.py:103
+#: ../gui/wxpython/vdigit/preferences.py:800
+#: ../gui/wxpython/gui_core/gselect.py:2325
+msgid "Point"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:1103
-#: ../gui/wxpython/vdigit/toolbars.py:1110
-msgid "New vector map"
+#: ../gui/wxpython/psmap/dialogs.py:6316
+msgid "Symbol"
msgstr ""
-#: ../gui/wxpython/mapswipe/frame.py:44
-msgid "GRASS GIS Map Swipe"
+#: ../gui/wxpython/psmap/dialogs.py:6323
+msgid "Select symbol:"
msgstr ""
-#: ../gui/wxpython/mapswipe/frame.py:291 ../gui/wxpython/gcp/mapdisplay.py:261
-#: ../gui/wxpython/rlisetup/sampling_frame.py:102
-#: ../gui/wxpython/mapdisp/frame.py:510 ../gui/wxpython/iclass/frame.py:312
-msgid "Map Toolbar"
+#: ../gui/wxpython/psmap/dialogs.py:6340
+msgid ""
+"Note: Selected symbol is not displayed\n"
+"in draft mode (only in preview mode)"
msgstr ""
-#: ../gui/wxpython/mapswipe/frame.py:303 ../gui/wxpython/animation/frame.py:160
-msgid "Main Toolbar"
+#: ../gui/wxpython/psmap/dialogs.py:6365 ../gui/wxpython/psmap/dialogs.py:6725
+#: ../gui/wxpython/iclass/dialogs.py:396 ../gui/wxpython/nviz/tools.py:976
+#: ../gui/wxpython/nviz/tools.py:2816 ../gui/wxpython/wxplot/dialogs.py:1109
+#: ../gui/wxpython/wxplot/dialogs.py:1191
+#: ../gui/wxpython/gmodeler/preferences.py:107
+#: ../gui/wxpython/gmodeler/preferences.py:421
+#: ../gui/wxpython/gmodeler/preferences.py:533
+msgid "Color"
msgstr ""
-#: ../gui/wxpython/mapswipe/frame.py:315 ../gui/wxpython/animation/frame.py:182
-#: ../gui/wxpython/lmgr/frame.py:157
-msgid "Misc Toolbar"
+#: ../gui/wxpython/psmap/dialogs.py:6373 ../gui/wxpython/psmap/dialogs.py:6732
+msgid "Outline color:"
msgstr ""
-#: ../gui/wxpython/mapswipe/frame.py:417
-#, python-format
-msgid "Map <%s> not found. "
+#: ../gui/wxpython/psmap/dialogs.py:6376 ../gui/wxpython/psmap/dialogs.py:6403
+#: ../gui/wxpython/psmap/dialogs.py:6735 ../gui/wxpython/psmap/dialogs.py:6765
+#: ../gui/wxpython/gui_core/dialogs.py:1778
+msgid "transparent"
msgstr ""
-#: ../gui/wxpython/mapswipe/frame.py:420 ../gui/wxpython/animation/utils.py:97
-#: ../gui/wxpython/animation/utils.py:105
-#: ../gui/wxpython/lmgr/layertree.py:1983
-#, python-format
-msgid "Map <%s> not found."
+#: ../gui/wxpython/psmap/dialogs.py:6400 ../gui/wxpython/psmap/dialogs.py:6762
+msgid "Fill color:"
msgstr ""
-#: ../gui/wxpython/mapswipe/frame.py:550 ../gui/wxpython/gcp/mapdisplay.py:382
-#: ../gui/wxpython/mapdisp/frame.py:805
-msgid "Nothing to render (empty map). Operation canceled."
+#: ../gui/wxpython/psmap/dialogs.py:6439
+msgid "Size and Rotation"
msgstr ""
-#: ../gui/wxpython/mapswipe/frame.py:556 ../gui/wxpython/gcp/mapdisplay.py:397
-#: ../gui/wxpython/modules/histogram.py:471
-#: ../gui/wxpython/gmodeler/frame.py:652 ../gui/wxpython/mapdisp/frame.py:646
-msgid "Choose a file name to save the image (no need to add extension)"
+#: ../gui/wxpython/psmap/dialogs.py:6447
+msgid "Size (pt):"
msgstr ""
-#: ../gui/wxpython/mapswipe/frame.py:674 ../gui/wxpython/mapdisp/frame.py:900
-msgid "No raster or vector map layer selected for querying."
+#: ../gui/wxpython/psmap/dialogs.py:6450
+msgid "Symbol size in points"
msgstr ""
-#: ../gui/wxpython/mapswipe/g.gui.mapswipe.py:79
-#: ../gui/wxpython/nviz/wxnviz.py:345 ../gui/wxpython/nviz/wxnviz.py:356
-#: ../gui/wxpython/modules/histogram.py:399
-#: ../gui/wxpython/iclass/g.gui.iclass.py:91
-#, python-format
-msgid "Raster map <%s> not found"
+#: ../gui/wxpython/psmap/dialogs.py:6685
+msgid "Rectangle settings"
msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:44
-#: ../gui/wxpython/mapswipe/toolbars.py:33
-msgid "Select raster maps"
+#: ../gui/wxpython/psmap/dialogs.py:6687
+msgid "Line settings"
msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:130
-msgid "Name of top/left raster map:"
+#: ../gui/wxpython/psmap/dialogs.py:6821
+msgid "Line width in points"
msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:139
-msgid "Name of bottom/right raster map:"
+#: ../gui/wxpython/psmap/dialogs.py:6895
+msgid "Vector labels"
msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:185
-msgid "Switch to advanced mode"
+#: ../gui/wxpython/psmap/dialogs.py:6915
+msgid "Vector label files created beforehand by v.label module"
msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:186
-msgid "Cancel"
+#: ../gui/wxpython/psmap/dialogs.py:6932
+msgid "You can select multiple label files."
msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:192
-msgid "Switch to simple mode"
+#: ../gui/wxpython/psmap/utils.py:105
+msgid "inch"
msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:193
-#: ../gui/wxpython/gui_core/forms.py:556 ../gui/wxpython/menustrings.py:14
-#: ../gui/wxpython/menustrings.py:2018
-msgid "Close"
+#: ../gui/wxpython/psmap/utils.py:106 ../gui/wxpython/modules/vclean.py:222
+msgid "point"
msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:217
-msgid "Name of the first map is missing."
+#: ../gui/wxpython/psmap/utils.py:107
+msgid "centimeter"
msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:220
-msgid "Name of the second map is missing."
+#: ../gui/wxpython/psmap/utils.py:108
+msgid "millimeter"
msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:253
-msgid "Map Swipe settings"
+#: ../gui/wxpython/psmap/utils.py:112
+msgid "meters"
msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:269
-#: ../gui/wxpython/mapswipe/toolbars.py:118
-msgid "Mirror mode"
+#: ../gui/wxpython/psmap/utils.py:115
+msgid "kilometers"
msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:272
-msgid "Mirrored cursor"
+#: ../gui/wxpython/psmap/utils.py:118
+msgid "feet"
msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:280 ../gui/wxpython/nviz/tools.py:1423
-#: ../gui/wxpython/nviz/tools.py:2154 ../gui/wxpython/nviz/tools.py:2296
-#: ../gui/wxpython/nviz/preferences.py:372
-#: ../gui/wxpython/nviz/preferences.py:574
-#: ../gui/wxpython/nviz/preferences.py:640
-#: ../gui/wxpython/psmap/dialogs.py:2362 ../gui/wxpython/psmap/dialogs.py:2523
-#: ../gui/wxpython/gcp/manager.py:2697
-#: ../gui/wxpython/gui_core/preferences.py:1489
-msgid "Color:"
+#: ../gui/wxpython/psmap/utils.py:121
+msgid "miles"
msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:301
-msgid "Shape:"
+#: ../gui/wxpython/psmap/utils.py:124 ../gui/wxpython/psmap/utils.py:128
+msgid "nautical miles"
msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:327
-#: ../gui/wxpython/psmap/dialogs.py:6800 ../gui/wxpython/gcp/manager.py:2812
-#: ../gui/wxpython/vnet/dialogs.py:1279
-#: ../gui/wxpython/gui_core/preferences.py:1399
-msgid "Line width:"
+#: ../gui/wxpython/psmap/utils.py:126
+msgid "pixel"
msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:350
-#: ../gui/wxpython/nviz/preferences.py:607
-msgid "Size:"
+#: ../gui/wxpython/psmap/utils.py:127
+msgid "meter"
msgstr ""
-#: ../gui/wxpython/mapswipe/toolbars.py:29
-#: ../gui/wxpython/modules/vclean.py:518
-msgid "Tools"
+#: ../gui/wxpython/psmap/utils.py:130
+msgid "degree"
msgstr ""
-#: ../gui/wxpython/mapswipe/toolbars.py:31
-msgid "Quit Map Swipe"
+#: ../gui/wxpython/psmap/utils.py:397
+msgid "Unable to run `ps.map -b`"
msgstr ""
-#: ../gui/wxpython/mapswipe/toolbars.py:36
-#: ../gui/wxpython/mapdisp/toolbars.py:29
-msgid "Query raster/vector map(s)"
+#: ../gui/wxpython/psmap/instructions.py:139
+#, python-format
+msgid ""
+"Unable to open file\n"
+"%s"
msgstr ""
-#: ../gui/wxpython/mapswipe/toolbars.py:37
-#: ../gui/wxpython/mapdisp/toolbars.py:30
-msgid "Query selected raster/vector map(s)"
+#: ../gui/wxpython/psmap/instructions.py:498
+#, python-format
+msgid "Instruction file will be loaded with following region: %s\n"
msgstr ""
-#: ../gui/wxpython/mapswipe/toolbars.py:117
-msgid "Swipe mode"
+#: ../gui/wxpython/psmap/instructions.py:504
+#, python-format
+msgid ""
+"Region cannot be set\n"
+"%s"
msgstr ""
-#: ../gui/wxpython/mapswipe/toolbars.py:130
-msgid "Choose view mode"
+#: ../gui/wxpython/psmap/instructions.py:664
+#: ../gui/wxpython/psmap/instructions.py:863
+#: ../gui/wxpython/psmap/instructions.py:996
+#: ../gui/wxpython/psmap/instructions.py:1074
+#: ../gui/wxpython/psmap/instructions.py:1248
+#: ../gui/wxpython/psmap/instructions.py:1315
+#: ../gui/wxpython/psmap/instructions.py:1382
+#: ../gui/wxpython/psmap/instructions.py:1466
+#: ../gui/wxpython/psmap/instructions.py:1588
+#: ../gui/wxpython/psmap/instructions.py:1733
+#: ../gui/wxpython/psmap/instructions.py:1787
+#: ../gui/wxpython/psmap/instructions.py:2158
+#, python-format
+msgid "Failed to read instruction %s"
msgstr ""
-#: ../gui/wxpython/mapswipe/toolbars.py:154
-msgid "Switch orientation"
+#: ../gui/wxpython/psmap/instructions.py:679
+#, python-format
+msgid ""
+"Scale has changed, old value: %(old)s\n"
+"new value: %(new)s"
msgstr ""
-#: ../gui/wxpython/mapswipe/toolbars.py:157
-msgid "Switch maps"
+#: ../gui/wxpython/psmap/instructions.py:683
+#, python-format
+msgid ""
+"Failed to read instruction %s.\n"
+"Use 1:25000 notation."
msgstr ""
-#: ../gui/wxpython/iscatt/core_c.py:23
-msgid "Loading ctypes libs failed"
+#: ../gui/wxpython/psmap/instructions.py:693
+#, python-format
+msgid ""
+"Map frame position changed, old value: %(old1)s %(old2)s\n"
+"new value: %(new1)s %(new2)s"
msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:140 ../gui/wxpython/iclass/dialogs.py:295
-msgid "Classes"
+#: ../gui/wxpython/psmap/instructions.py:704
+#, python-format
+msgid ""
+"Map frame size changed, old value: %(old1)s %(old2)s\n"
msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:166
-msgid "GRASS GIS Interactive Scatter Plot Tool"
+#: ../gui/wxpython/psmap/instructions.py:771
+#, python-format
+msgid ""
+"Failed to read instruction %(file)s.\n"
+"Unknown format %(for)s"
msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:398
-msgid "scatter plot"
+#: ../gui/wxpython/psmap/instructions.py:786
+#, python-format
+msgid "Failed to read instruction %s."
msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:413 ../gui/wxpython/iclass/dialogs.py:395
-msgid "Class name"
+#: ../gui/wxpython/psmap/instructions.py:936
+#: ../gui/wxpython/psmap/instructions.py:2006
+#, python-format
+msgid "Characters on position %s are not supported by ISO-8859-1 (Latin 1) encoding which is required by module ps.map."
msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:451 ../gui/wxpython/iclass/dialogs.py:429
-msgid "Please use only ASCII characters."
+#: ../gui/wxpython/psmap/instructions.py:940
+#: ../gui/wxpython/psmap/instructions.py:2010
+msgid "Not all characters are supported by ISO-8859-1 (Latin 1) encoding which is required by module ps.map."
msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:476
-msgid "Maximum limit of categories number was reached."
+#: ../gui/wxpython/psmap/instructions.py:1077
+#, python-format
+msgid "Failed to read instruction %(inst)s: file %(file)s not found."
msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:572
-msgid "Rename class"
+#: ../gui/wxpython/psmap/frame.py:53
+msgid "GRASS GIS Cartographic Composer"
msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:576
-msgid "Set color"
+#: ../gui/wxpython/psmap/frame.py:213
+msgid ""
+"Python Imaging Library is not available.\n"
+"'Preview' functionality won't work."
msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:580 ../gui/wxpython/lmgr/layertree.py:475
-msgid "Change opacity level"
+#: ../gui/wxpython/psmap/frame.py:267
+msgid "Program ps2pdf is not available. Please install it first to create PDF."
msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:584
-msgid "Hide"
+#: ../gui/wxpython/psmap/frame.py:311
+msgid "Generating PDF..."
msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:586
-msgid "Show"
+#: ../gui/wxpython/psmap/frame.py:313
+msgid "Generating PostScript..."
msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:601
-msgid "Move to top"
+#: ../gui/wxpython/psmap/frame.py:315
+msgid "Generating preview..."
msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:607
-msgid "Move to bottom"
+#: ../gui/wxpython/psmap/frame.py:332
+#, python-format
+msgid "Ps.map exited with return code %s"
msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:615
-msgid "Move category up"
+#: ../gui/wxpython/psmap/frame.py:368
+#, python-format
+msgid "%(prg)s exited with return code %(code)s"
msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:621
-msgid "Move category down"
+#: ../gui/wxpython/psmap/frame.py:372
+msgid "PDF generated"
msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:629
-msgid "Export class raster"
-msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:701
+#: ../gui/wxpython/psmap/frame.py:375
#, python-format
-msgid "Change opacity of class <%s>"
+msgid ""
+"Program ps2pdf is not available. Please install it to create PDF.\n"
+"\n"
+" %s"
msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:726
-msgid "Empty name was inserted."
+#: ../gui/wxpython/psmap/frame.py:378
+msgid "PostScript file generated"
msgstr ""
-#: ../gui/wxpython/iscatt/iscatt_core.py:110
-#: ../gui/wxpython/iscatt/iscatt_core.py:160
-msgid "Select category for editing."
+#: ../gui/wxpython/psmap/frame.py:387
+msgid "Generating preview, wait please"
msgstr ""
-#: ../gui/wxpython/iscatt/iscatt_core.py:151
-msgid "Computing of scatter plots failed."
+#: ../gui/wxpython/psmap/frame.py:403
+msgid "Preview not available"
msgstr ""
-#: ../gui/wxpython/iscatt/iscatt_core.py:298
-msgid "Patching category raster conditions file failed."
+#: ../gui/wxpython/psmap/frame.py:405
+msgid "Preview is not available probably because Ghostscript is not installed or not on PATH."
msgstr ""
-#: ../gui/wxpython/iscatt/iscatt_core.py:321
-#, python-format
-msgid ""
-"v.build failed:\n"
-"%s"
+#: ../gui/wxpython/psmap/frame.py:408
+msgid "Please follow instructions on GRASS Trac Wiki."
msgstr ""
-#: ../gui/wxpython/iscatt/iscatt_core.py:339
-#, python-format
-msgid ""
-"v.to.rast failed:\n"
-"%s"
+#: ../gui/wxpython/psmap/frame.py:419
+msgid "Preview generated"
msgstr ""
-#: ../gui/wxpython/iscatt/plots.py:42
-#, python-brace-format
-msgid "The Scatterplot Tool needs the \"matplotlib\" (python-matplotlib) package to be installed. {0}"
+#: ../gui/wxpython/psmap/frame.py:451
+msgid "Save file as"
msgstr ""
-#: ../gui/wxpython/iscatt/plots.py:617
-msgid "Zoom to scatter plot extend"
+#: ../gui/wxpython/psmap/frame.py:498
+#, python-format
+msgid "Failed to read file %s."
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:40
-msgid "Add scatter plots"
+#: ../gui/wxpython/psmap/frame.py:677
+msgid "Scalebar is not appropriate for this projection"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:59
-msgid "x axis:"
+#: ../gui/wxpython/psmap/frame.py:1166
+msgid "Press button with green triangle icon to generate preview."
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:66
-msgid "y axis:"
+#: ../gui/wxpython/psmap/frame.py:1189
+msgid "wxGUI Cartographic Composer"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:105
-msgid "Bands of scatter plots to be added (x y):"
+#: ../gui/wxpython/psmap/frame.py:1240
+msgid "MAP FRAME"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:155
-msgid "No scatter plots selected."
+#: ../gui/wxpython/psmap/frame.py:1241
+msgid "RASTER LEGEND"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:203
-msgid "Select both x and y bands."
+#: ../gui/wxpython/psmap/frame.py:1242
+msgid "VECTOR LEGEND"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:207
-msgid "Selected bands must be different."
+#: ../gui/wxpython/psmap/frame.py:1243
+msgid "MAP INFO"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:214
-msgid "Scatter plot with same bands combination (regardless x y order) has been already added into the list."
+#: ../gui/wxpython/psmap/frame.py:1244
+msgid "SCALE BAR"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:281 ../gui/wxpython/iclass/dialogs.py:777
-msgid "Enter name of new vector map:"
+#: ../gui/wxpython/psmap/frame.py:1245
+msgid "IMAGE"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:323
-#, python-format
-msgid "Raster map <%s> already exists. Do you want to overwrite it?"
+#: ../gui/wxpython/psmap/frame.py:1246
+msgid "NORTH ARROW"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:326
-#, python-format
-msgid "Raster <%s> exists"
+#: ../gui/wxpython/psmap/frame.py:1522
+msgid "Click and drag to resize object"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:352
-msgid "Show confidence ellipses"
+#: ../gui/wxpython/psmap/frame.py:2467
+msgid "labels: "
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:359
-msgid "Selection polygon color:"
+#: ../gui/wxpython/psmap/toolbars.py:68 ../gui/wxpython/menustrings.py:1990
+msgid "Generate text file with mapping instructions"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:360
-msgid "Color of selection polygon vertex:"
+#: ../gui/wxpython/psmap/toolbars.py:70 ../gui/wxpython/menustrings.py:1988
+msgid "Load text file with mapping instructions"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:361
-msgid "Selected area color:"
+#: ../gui/wxpython/psmap/toolbars.py:72 ../gui/wxpython/menustrings.py:1992
+msgid "Generate PostScript output"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:372 ../gui/wxpython/vnet/dialogs.py:1282
-msgid "Snapping threshold in pixels:"
+#: ../gui/wxpython/psmap/toolbars.py:74 ../gui/wxpython/menustrings.py:1994
+msgid "Generate PDF output"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:373
-msgid "Selected area opacity:"
+#: ../gui/wxpython/psmap/toolbars.py:77 ../gui/wxpython/menustrings.py:1986
+msgid "Specify paper size, margins and orientation"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:397 ../gui/wxpython/gcp/manager.py:2609
-#: ../gui/wxpython/vnet/dialogs.py:1307 ../gui/wxpython/wxplot/dialogs.py:829
-#: ../gui/wxpython/wxplot/dialogs.py:1428
-msgid "Apply changes for the current session"
+#: ../gui/wxpython/psmap/toolbars.py:79
+msgid "Full extent"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:400 ../gui/wxpython/gcp/manager.py:2612
-#: ../gui/wxpython/vnet/dialogs.py:1310 ../gui/wxpython/wxplot/dialogs.py:836
-#: ../gui/wxpython/wxplot/dialogs.py:1432
-#: ../gui/wxpython/gui_core/preferences.py:98
-msgid "Apply and save changes to user settings file (default for next sessions)"
+#: ../gui/wxpython/psmap/toolbars.py:80
+msgid "Zoom to full extent"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:402 ../gui/wxpython/gcp/manager.py:2614
-#: ../gui/wxpython/web_services/dialogs.py:144
-#: ../gui/wxpython/web_services/dialogs.py:899
-#: ../gui/wxpython/modules/import_export.py:110
-#: ../gui/wxpython/modules/import_export.py:663
-#: ../gui/wxpython/vnet/dialogs.py:1312
-msgid "Close dialog"
+#: ../gui/wxpython/psmap/toolbars.py:83
+msgid "Click and drag to place map frame"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:412
-msgid "Selection style:"
+#: ../gui/wxpython/psmap/toolbars.py:85 ../gui/wxpython/menustrings.py:2019
+msgid "Delete selected object"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:439
-msgid "Ellipses settings:"
+#: ../gui/wxpython/psmap/toolbars.py:87
+msgid "Show preview"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:46 ../gui/wxpython/iclass/dialogs.py:44
-#: ../gui/wxpython/iclass/toolbars.py:40
-msgid "Select imagery group"
+#: ../gui/wxpython/psmap/toolbars.py:89
+msgid "Quit Cartographic Composer"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:48 ../gui/wxpython/iscatt/toolbars.py:146
-#: ../gui/wxpython/nviz/tools.py:2272 ../gui/wxpython/vnet/dialogs.py:945
-#: ../gui/wxpython/gui_core/toolbars.py:84
-msgid "Settings"
+#: ../gui/wxpython/psmap/toolbars.py:93 ../gui/wxpython/menustrings.py:2008
+msgid "Map info"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:51 ../gui/wxpython/vnet/toolbars.py:137
-#: ../gui/wxpython/gui_core/toolbars.py:71
-msgid "Show manual"
+#: ../gui/wxpython/psmap/toolbars.py:95 ../gui/wxpython/wxplot/dialogs.py:1087
+#: ../gui/wxpython/wxplot/dialogs.py:1150
+#: ../gui/wxpython/wxplot/dialogs.py:1231
+msgid "Legend"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:54
-msgid "Add scatter plot"
+#: ../gui/wxpython/psmap/toolbars.py:97 ../gui/wxpython/nviz/tools.py:2381
+#: ../gui/wxpython/menustrings.py:2010
+msgid "Scale bar"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:57
-msgid "Select area with polygon"
+#: ../gui/wxpython/psmap/toolbars.py:105
+#: ../gui/wxpython/vdigit/preferences.py:801
+msgid "Line"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:60
-msgid "Pan mode for scatter plots"
+#: ../gui/wxpython/psmap/toolbars.py:107
+#: ../gui/wxpython/rlisetup/wizard.py:1181
+#: ../gui/wxpython/rlisetup/wizard.py:1354
+#: ../gui/wxpython/rlisetup/wizard.py:1444
+msgid "Rectangle"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:63
-msgid "Zoom mode for scatter plots (left mouse button, wheel)"
+#: ../gui/wxpython/psmap/toolbars.py:109
+msgid "Add overlays"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:66
-msgid "Zoom to scatter plot data extend mode (click on scatter plot for zooming to extend)"
+#: ../gui/wxpython/psmap/toolbars.py:111 ../gui/wxpython/lmgr/layertree.py:102
+msgid "Add labels"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:69
-msgid "Show/hide class manager"
+#: ../gui/wxpython/psmap/toolbars.py:203
+msgid "Add simple graphics: points"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:175
-#: ../gui/wxpython/iscatt/toolbars.py:176
-msgid "Include selected area to class"
+#: ../gui/wxpython/psmap/toolbars.py:219
+msgid "Add simple graphics: lines"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:178
-#: ../gui/wxpython/iscatt/toolbars.py:179
-msgid "Exclude selected area from class"
+#: ../gui/wxpython/psmap/toolbars.py:235
+msgid "Add simple graphics: rectangles"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:181
-msgid "Add new vertex"
+#: ../gui/wxpython/icons/icon.py:38
+#, python-format
+msgid "Unknown iconset '%s', using default 'grass'...\n"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:182
-msgid "Add new vertex to polygon boundary scatter plot"
+#: ../gui/wxpython/icons/icon.py:56
+#, python-format
+msgid "Unable to load icon theme. Reason: %s. Quiting wxGUI..."
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:184
-msgid "Create selection polygon"
+#: ../gui/wxpython/timeline/frame.py:39
+msgid "The Timeline Tool needs the \"matplotlib\" (python-matplotlib) package to be installed. {}"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:185
-msgid "Add new vertex between last and first points of the boundary"
+#: ../gui/wxpython/timeline/frame.py:77
+msgid "GRASS GIS Timeline Tool"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:187
-msgid "Move vertex"
+#: ../gui/wxpython/timeline/frame.py:133 ../gui/wxpython/tplot/frame.py:276
+#: ../gui/wxpython/nviz/tools.py:850 ../gui/wxpython/nviz/tools.py:1889
+#: ../gui/wxpython/nviz/preferences.py:405
+msgid "Draw"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:188
-msgid "Move boundary vertex"
+#: ../gui/wxpython/timeline/frame.py:135 ../gui/wxpython/tplot/frame.py:279
+#: ../gui/wxpython/menustrings.py:1978 ../gui/wxpython/menustrings.py:2021
+msgid "Help"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:190
-msgid "Remove vertex"
+#: ../gui/wxpython/timeline/frame.py:139
+msgid "3D plot of spatio-temporal extents"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:191
-msgid "Remove boundary vertex"
+#: ../gui/wxpython/timeline/frame.py:142
+msgid "3D plot of spatio-temporal extents (matplotlib >= 1.0.0)"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:193
-msgid "Remove polygon (click on scatter plot for removing it's polygon)"
+#: ../gui/wxpython/timeline/frame.py:147
+msgid "Select space time dataset(s):"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:271
-msgid "Add class"
+#: ../gui/wxpython/timeline/frame.py:178 ../gui/wxpython/tplot/frame.py:308
+#: ../gui/wxpython/tplot/frame.py:419
+#, python-format
+msgid "Dataset <%s> not found in temporal database"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:273
-msgid "Remove selected class"
+#: ../gui/wxpython/timeline/frame.py:194 ../gui/wxpython/tplot/frame.py:326
+#: ../gui/wxpython/tplot/frame.py:438
+msgid "Datasets have different temporal type (absolute x relative), which is not allowed."
msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:139 ../gui/wxpython/dbmgr/base.py:154
-msgid "Loading data..."
+#: ../gui/wxpython/timeline/frame.py:213 ../gui/wxpython/tplot/frame.py:343
+#: ../gui/wxpython/tplot/frame.py:448
+msgid "Datasets have different time unit which is not allowed."
msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:204
-msgid "No data set."
+#: ../gui/wxpython/timeline/frame.py:234
+#, python-brace-format
+msgid "Dataset <{name}> is empty"
msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:222
+#: ../gui/wxpython/timeline/frame.py:292
#, python-format
-msgid ""
-"Interactive Scatter Plot Tool can not be used.\n"
-"Number of cells (rows*cols) <%d> in current regionis higher than maximum limit <%d>.\n"
-"\n"
-"You can reduce number of cells in current region using <g.region> command."
+msgid "X [%s]"
msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:231
+#: ../gui/wxpython/timeline/frame.py:293
#, python-format
-msgid ""
-"Number of cells (rows*cols) <%d> in current region is higher than recommended threshold <%d>.\n"
-"It is strongly advised to reduce number of cells in current region below recommend threshold.\n"
-" It can be done by <g.region> command.\n"
-"\n"
-"Do you want to continue using Interactive Scatter Plot Tool with this region?"
+msgid "Y [%s]"
msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:288
-msgid "Scatter plot with same band combination (regardless x y order) is already displayed."
+#: ../gui/wxpython/timeline/frame.py:295
+msgid "X"
msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:301
-#, python-format
-msgid "Band <%s> is not CELL (integer) type.\n"
+#: ../gui/wxpython/timeline/frame.py:296
+msgid "Y"
msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:304
-msgid "Scatter plot cannot be added.\n"
+#: ../gui/wxpython/timeline/frame.py:301
+#: ../gui/wxpython/animation/dialogs.py:1967
+msgid "Time"
msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:310
+#: ../gui/wxpython/timeline/frame.py:371 ../gui/wxpython/tplot/frame.py:591
+#: ../gui/wxpython/tplot/frame.py:638 ../gui/wxpython/tplot/frame.py:676
#, python-format
-msgid ""
-"Scatter plot cannot be added.\n"
-"Multiple of bands ranges <%s:%d * %s:%d = %d> is higher than maximum limit <%d>.\n"
+msgid "Time [%s]"
msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:320
+#: ../gui/wxpython/timeline/frame.py:461 ../gui/wxpython/tplot/frame.py:801
+#: ../gui/wxpython/animation/utils.py:70 ../gui/wxpython/animation/utils.py:79
+#: ../gui/wxpython/animation/temporal_manager.py:242
#, python-format
-msgid ""
-"Multiple of bands ranges <%s:%d * %s:%d = %d> is higher than recommended limit <%d>.\n"
-"It is strongly advised to reduce range extend of bands(e. g. using r.rescale) below recommended threshold.\n"
-"\n"
-"Do you really want to add this scatter plot?"
+msgid "Space time dataset <%s> not found."
msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:409
-msgid ""
-"In order to select arrea in scatter plot, you have to select class first.\n"
-"\n"
-"There is no class yet, do you want to create one?"
+#: ../gui/wxpython/timeline/frame.py:476 ../gui/wxpython/tplot/frame.py:816
+#, python-format
+msgid "Please specify the space time dataset <%s>."
msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:413 ../gui/wxpython/iclass/digit.py:76
-msgid "No class selected"
+#: ../gui/wxpython/timeline/frame.py:478 ../gui/wxpython/tplot/frame.py:819
+msgid "Ambiguous dataset name"
msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:444
+#: ../gui/wxpython/timeline/frame.py:562 ../gui/wxpython/tplot/frame.py:953
#, python-format
-msgid ""
-"Error occurred during computation of scatter plot category:\n"
-"%s"
+msgid "Space time raster dataset: %s"
msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:764
+#: ../gui/wxpython/timeline/frame.py:564 ../gui/wxpython/tplot/frame.py:955
#, python-format
-msgid "Export scatter plot raster of class <%s>"
+msgid "Space time vector dataset: %s"
msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:782
+#: ../gui/wxpython/timeline/frame.py:566 ../gui/wxpython/tplot/frame.py:957
#, python-format
-msgid "Scatter plot raster of class <%s> exported to raster map <%s>."
+msgid "Space time 3D raster dataset: %s"
msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:786
+#: ../gui/wxpython/timeline/frame.py:568
#, python-format
-msgid ""
-"Export of scatter plot raster of class <%s> to map <%s> failed.\n"
-"%s"
+msgid "Mapset: %s"
msgstr ""
-#: ../gui/wxpython/animation/data.py:45 ../gui/wxpython/lmgr/layertree.py:1165
-#: ../gui/wxpython/mapdisp/frame.py:279 ../gui/wxpython/mapdisp/frame.py:339
-#: ../gui/wxpython/mapdisp/toolbars.py:97
-#: ../gui/wxpython/mapdisp/toolbars.py:301
-msgid "2D view"
+#: ../gui/wxpython/timeline/frame.py:569
+#, python-format
+msgid "Map name: %s"
msgstr ""
-#: ../gui/wxpython/animation/data.py:46 ../gui/wxpython/lmgr/frame.py:440
-#: ../gui/wxpython/mapdisp/toolbars.py:104
-msgid "3D view"
-msgstr ""
-#: ../gui/wxpython/animation/data.py:66
-msgid "No animation name selected."
-msgstr ""
-#: ../gui/wxpython/animation/data.py:132
-msgid "No workspace file selected."
-msgstr ""
-#: ../gui/wxpython/animation/data.py:135
+#: ../gui/wxpython/timeline/frame.py:571
#, python-format
-msgid "File %s not found"
+msgid "Start time: %s"
msgstr ""
-#: ../gui/wxpython/animation/data.py:144
+#: ../gui/wxpython/timeline/frame.py:574
#, python-format
-msgid "Animation %d"
+msgid "End time: %s"
msgstr ""
-#: ../gui/wxpython/animation/frame.py:51
-msgid "GRASS GIS Animation tool"
+#: ../gui/wxpython/timeline/frame.py:578
+msgid "WARNING: invalid topology"
msgstr ""
-#: ../gui/wxpython/animation/frame.py:170
-msgid "Animation Toolbar"
+#: ../gui/wxpython/timeline/frame.py:580
+msgid ""
+"\n"
+"Press Del to dismiss."
msgstr ""
-#: ../gui/wxpython/animation/frame.py:282
-msgid "Loading data"
+msgid "The Temporal Plot Tool needs the \"matplotlib\" (python-matplotlib) package to be installed. {}"
msgstr ""
-#: ../gui/wxpython/animation/frame.py:290
-msgid " ({c} out of {p})"
+#: ../gui/wxpython/tplot/frame.py:97
+msgid "GRASS GIS Temporal Plot Tool"
msgstr ""
-#: ../gui/wxpython/animation/frame.py:605
-#: ../gui/wxpython/animation/controller.py:598
-#, python-format
-msgid "%(from)s %(dash)s %(to)s"
+#: ../gui/wxpython/tplot/frame.py:180
+msgid "Raster temporal dataset (strds)"
msgstr ""
-#: ../gui/wxpython/animation/frame.py:610
-#, python-format
-msgid "to %(to)s"
+#: ../gui/wxpython/tplot/frame.py:187
+msgid "X and Y coordinates separated by comma:"
msgstr ""
-#: ../gui/wxpython/animation/provider.py:417
-msgid "Rendering map layers"
+#: ../gui/wxpython/tplot/frame.py:199
+msgid "Coordinates can be obtained for example by right-clicking on Map Display."
msgstr ""
-#: ../gui/wxpython/animation/provider.py:530
-msgid "Overlaying map layers"
+#: ../gui/wxpython/tplot/frame.py:214
+msgid "STRDS"
msgstr ""
-#: ../gui/wxpython/animation/provider.py:757
-msgid "Directory {t} not removed."
+#: ../gui/wxpython/tplot/frame.py:222
+msgid ""
+"Vector temporal dataset (strds)\n"
+"Please press enter if you digit the name instead select with combobox"
msgstr ""
-#: ../gui/wxpython/animation/utils.py:182
-msgid "The number of maps in space-time datasets has to be the same."
+#: ../gui/wxpython/tplot/frame.py:237
+msgid "Select attribute column"
msgstr ""
-#: ../gui/wxpython/animation/utils.py:186
-msgid "The temporal type (absolute/relative) of space-time datasets has to be the same."
+#: ../gui/wxpython/tplot/frame.py:250
+msgid "Select category of vector(s)"
msgstr ""
-#: ../gui/wxpython/animation/utils.py:190
-msgid "The map type (point/interval) of space-time datasets has to be the same."
+#: ../gui/wxpython/tplot/frame.py:268
+msgid "STVDS"
msgstr ""
-#: ../gui/wxpython/animation/utils.py:194
-msgid "The temporal extents of maps in space-time datasets have to be the same."
+#: ../gui/wxpython/tplot/frame.py:296 ../gui/wxpython/tplot/frame.py:716
+#: ../gui/wxpython/tplot/frame.py:720 ../gui/wxpython/tplot/frame.py:741
+#: ../gui/wxpython/tplot/frame.py:867
+msgid "Invalid input coordinates"
msgstr ""
-#: ../gui/wxpython/animation/utils.py:202
-msgid "The number of maps to animate has to be the same for each map series."
+#: ../gui/wxpython/tplot/frame.py:385
+msgid "Category {ca} is not on vector map {ma} and it will be used"
msgstr ""
-#: ../gui/wxpython/animation/utils.py:207
-msgid "The number of maps to animate has to be the same as the number of maps in temporal dataset."
+#: ../gui/wxpython/tplot/frame.py:404
+msgid "Both coordinates and categories are set, coordinates will be used. The use categories remove text from coordinate form"
msgstr ""
-#: ../gui/wxpython/animation/nviztask.py:43 ../gui/wxpython/lmgr/frame.py:1373
-#, python-format
-msgid ""
-"Reading workspace file <%s> failed.\n"
-"Invalid file, unable to parse XML document."
+#: ../gui/wxpython/tplot/frame.py:409
+msgid "With Vector temporal dataset you have to select an attribute column"
msgstr ""
-#: ../gui/wxpython/animation/nviztask.py:53
-#, python-format
-msgid "No 3d view information in workspace file <%s>."
+#: ../gui/wxpython/tplot/frame.py:461
+msgid "Difference number of vector layers and maps in the vector temporal dataset"
msgstr ""
-#: ../gui/wxpython/animation/nviztask.py:285
-msgid "Please add only one layer in the list."
+#: ../gui/wxpython/tplot/frame.py:503
+msgid "No connection between vector map {vmap} and layer {la}"
msgstr ""
-#: ../gui/wxpython/animation/nviztask.py:292
-msgid "No map series nor space-time dataset is added."
+#: ../gui/wxpython/tplot/frame.py:577 ../gui/wxpython/tplot/frame.py:619
+#: ../gui/wxpython/tplot/frame.py:662
+msgid "Problem getting data from raster temporal dataset. Empty list of values."
msgstr ""
-#: ../gui/wxpython/animation/temporal_manager.py:110
-msgid "It is not allowed to display data with different temporal types (absolute and relative)."
-msgstr ""
-#: ../gui/wxpython/animation/temporal_manager.py:125
+#: ../gui/wxpython/tplot/frame.py:589 ../gui/wxpython/tplot/frame.py:636
+#: ../gui/wxpython/tplot/frame.py:674
#, python-format
-msgid "It is not allowed to display data with different units (%s)."
+msgid "Temporal resolution: %s"
msgstr ""
-#: ../gui/wxpython/animation/temporal_manager.py:137
-msgid "You are going to display data with different temporal types of maps (interval and point). It is recommended to use data of one temporal type to avoid confusion."
+#: ../gui/wxpython/tplot/frame.py:709
+msgid "Incorrect coordinates format, should be: x,y"
msgstr ""
-#: ../gui/wxpython/animation/temporal_manager.py:347
-#, python-format
-msgid "Topology of Space time dataset %s is invalid."
+#: ../gui/wxpython/tplot/frame.py:725
+msgid "Seed point outside the current region"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:53
-msgid "Adjust speed of animation"
+#: ../gui/wxpython/tplot/frame.py:737
+msgid "Invalid input raster dataset"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:100
-msgid "Simple mode"
+#: ../gui/wxpython/tplot/frame.py:754
+msgid "Invalid input vector dataset"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:105
-msgid "Frame duration:"
+#: ../gui/wxpython/tplot/frame.py:860 ../gui/wxpython/tplot/frame.py:908
+msgid "Invalid input temporal dataset"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:106
-#: ../gui/wxpython/animation/dialogs.py:147
-msgid "ms"
+#: ../gui/wxpython/tplot/frame.py:929
+msgid "Datasets have different number of values"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:139
-msgid "Temporal mode"
+#: ../gui/wxpython/tplot/frame.py:959
+msgid "Value for {date} is {val}"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:144
-msgid "Time unit:"
+#: ../gui/wxpython/tplot/frame.py:962
+msgid "Press Del to dismiss."
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:146
-msgid "Duration of time unit:"
+#: ../gui/wxpython/tplot/g.gui.tplot.py:106
+msgid "With stvds you have to set 'attr' option"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:218
-msgid "year"
+#: ../gui/wxpython/tplot/g.gui.tplot.py:110
+msgid "With stvds it is not possible to use 'coordinates' and 'cats' options together"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:219
-msgid "month"
+#: ../gui/wxpython/tplot/g.gui.tplot.py:113
+msgid "With stvds you have to use 'coordinates' or 'cats' option"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:220
-msgid "day"
+#: ../gui/wxpython/lmgr/pyshell.py:42
+#, python-format
+msgid "Welcome to wxGUI Interactive Python Shell %s"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:221
-msgid "hour"
+#: ../gui/wxpython/lmgr/pyshell.py:43
+#, python-format
+msgid "Type %s for more GRASS scripting related information."
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:222
-msgid "minute"
+#: ../gui/wxpython/lmgr/pyshell.py:44
+#, python-format
+msgid "Type %s to add raster or vector to the layer tree."
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:223
-msgid "second"
+#: ../gui/wxpython/lmgr/pyshell.py:54
+msgid "Delete all text from the shell"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:288
-msgid "Animation speed is too high."
+#: ../gui/wxpython/lmgr/pyshell.py:57
+msgid "Simple &editor"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:324
-#: ../gui/wxpython/animation/toolbars.py:51
-#: ../gui/wxpython/animation/toolbars.py:52
-msgid "Add new animation"
+#: ../gui/wxpython/lmgr/pyshell.py:60 ../gui/wxpython/lmgr/toolbars.py:165
+msgid "Open a simple Python code editor"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:326
-msgid "Edit animation"
+#: ../gui/wxpython/lmgr/pyshell.py:113
+#, python-format
+msgid "Raster or vector map <%s> not found"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:344
-msgid "Advanced"
+#: ../gui/wxpython/lmgr/pyshell.py:120
+#, python-format
+msgid "Raster map <%s> added"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:375
-msgid "top left"
+#: ../gui/wxpython/lmgr/pyshell.py:122
+#, python-format
+msgid "Vector map <%s> added"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:376
-msgid "top right"
+#: ../gui/wxpython/lmgr/layertree.py:56
+#: ../gui/wxpython/modules/import_export.py:371
+#: ../gui/wxpython/menustrings.py:35 ../gui/wxpython/menustrings.py:1020
+msgid "Import raster data"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:377
-msgid "bottom left"
+#: ../gui/wxpython/lmgr/layertree.py:58
+#: ../gui/wxpython/modules/import_export.py:369
+#: ../gui/wxpython/menustrings.py:157 ../gui/wxpython/menustrings.py:1142
+msgid "Link external raster data"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:378
-msgid "bottom right"
+#: ../gui/wxpython/lmgr/layertree.py:60
+msgid "Unpack GRASS raster map"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:394
-msgid "Select 2D or 3D view"
+#: ../gui/wxpython/lmgr/layertree.py:62
+msgid "Set raster output format"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:402
-#: ../gui/wxpython/gmodeler/preferences.py:706
-#: ../gui/wxpython/vnet/dialogs.py:1643
-#: ../gui/wxpython/gui_core/gselect.py:1552
-#: ../gui/wxpython/gui_core/gselect.py:1567
-#: ../gui/wxpython/gui_core/gselect.py:1569
-#: ../gui/wxpython/gui_core/widgets.py:1279
-msgid "Name:"
+#: ../gui/wxpython/lmgr/layertree.py:64
+#: ../gui/wxpython/modules/import_export.py:512
+#: ../gui/wxpython/menustrings.py:65 ../gui/wxpython/menustrings.py:1050
+msgid "Import vector data"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:409
-msgid "Window position:"
+#: ../gui/wxpython/lmgr/layertree.py:66
+#: ../gui/wxpython/modules/import_export.py:510
+#: ../gui/wxpython/menustrings.py:159 ../gui/wxpython/menustrings.py:1144
+msgid "Link external vector data"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:419
-msgid "View mode:"
+#: ../gui/wxpython/lmgr/layertree.py:68
+msgid "Unpack GRASS vector map"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:430
-msgid ""
-"For 3D animation, please select only one space-time dataset\n"
-"or one series of map layers."
+#: ../gui/wxpython/lmgr/layertree.py:70
+msgid "Set vector output format"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:473
-#: ../gui/wxpython/psmap/dialogs.py:3384
-msgid "Show raster legend"
+#: ../gui/wxpython/lmgr/layertree.py:72
+msgid "Import data from WMS server"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:475
-#: ../gui/wxpython/lmgr/layertree.py:110
-msgid "Set options"
+#: ../gui/wxpython/lmgr/layertree.py:74
+msgid "Add command layer"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:496
-msgid "3D view parameters"
+#: ../gui/wxpython/lmgr/layertree.py:76 ../gui/wxpython/gui_core/toolbars.py:73
+#: ../gui/wxpython/menustrings.py:1997
+msgid "Quit"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:504
-msgid "Workspace file:"
+#: ../gui/wxpython/lmgr/layertree.py:78 ../gui/wxpython/gui_core/toolbars.py:75
+msgid "Add raster map layer"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:506
-msgid "Choose workspace file to import 3D view parameters"
+#: ../gui/wxpython/lmgr/layertree.py:80 ../gui/wxpython/iclass/toolbars.py:58
+#: ../gui/wxpython/gui_core/simplelmgr.py:480
+msgid "Add RGB map layer"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:508
-#: ../gui/wxpython/animation/dialogs.py:1080
-#: ../gui/wxpython/animation/dialogs.py:1198
-#: ../gui/wxpython/animation/dialogs.py:1234
-#: ../gui/wxpython/animation/dialogs.py:1258
-#: ../gui/wxpython/animation/dialogs.py:1289 ../gui/wxpython/nviz/tools.py:626
-#: ../gui/wxpython/psmap/dialogs.py:2666 ../gui/wxpython/psmap/dialogs.py:3008
-#: ../gui/wxpython/psmap/dialogs.py:5783
-#: ../gui/wxpython/modules/import_export.py:745
-#: ../gui/wxpython/gui_core/gselect.py:1176
-#: ../gui/wxpython/gui_core/gselect.py:1491
-#: ../gui/wxpython/gui_core/gselect.py:1507
-#: ../gui/wxpython/gui_core/gselect.py:1554
-#: ../gui/wxpython/gui_core/gselect.py:1590
-#: ../gui/wxpython/gui_core/forms.py:1801
-#: ../gui/wxpython/gui_core/forms.py:1893
-#: ../gui/wxpython/location_wizard/wizard.py:113
-#: ../gui/wxpython/location_wizard/wizard.py:1295
-#: ../gui/wxpython/location_wizard/wizard.py:1371
-#: ../gui/wxpython/location_wizard/wizard.py:1461
-#: ../gui/wxpython/location_wizard/wizard.py:1689
-msgid "Browse"
+#: ../gui/wxpython/lmgr/layertree.py:82
+msgid "Add HIS map layer"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:515
-msgid "Parameter for animation:"
+#: ../gui/wxpython/lmgr/layertree.py:84
+msgid "Add shaded relief map layer"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:554
-msgid "Animate region change (2D view only)"
+#: ../gui/wxpython/lmgr/layertree.py:86
+msgid "Add raster flow arrows"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:558
-msgid "Start region:"
+#: ../gui/wxpython/lmgr/layertree.py:88
+msgid "Add raster cell numbers"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:568
-msgid "End region:"
+#: ../gui/wxpython/lmgr/layertree.py:90 ../gui/wxpython/gui_core/toolbars.py:77
+msgid "Add vector map layer"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:574
-msgid "Zoom value:"
+#: ../gui/wxpython/lmgr/layertree.py:92
+msgid "Add thematic (choropleth) vector map layer"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:575
-msgid "N-S/E-W distances in map units used to gradually reduce region."
+#: ../gui/wxpython/lmgr/layertree.py:94
+msgid "Add thematic chart layer"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:582
-msgid "N-S:"
+#: ../gui/wxpython/lmgr/layertree.py:96
+msgid "Add grid layer"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:585
-msgid "E-W:"
+#: ../gui/wxpython/lmgr/layertree.py:98
+msgid "Add geodesic line layer"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:683
-msgid "Only one series or space-time dataset is accepted for 3D mode."
+#: ../gui/wxpython/lmgr/layertree.py:100
+msgid "Add rhumbline layer"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:691
-msgid "No map series or space-time dataset added."
+#: ../gui/wxpython/lmgr/layertree.py:104
+#: ../gui/wxpython/gui_core/simplelmgr.py:478
+#: ../gui/wxpython/gui_core/simplelmgr.py:479
+msgid "Add 3D raster map layer"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:719
-msgid "Region information is not complete"
+#: ../gui/wxpython/lmgr/layertree.py:105
+msgid "Note that 3D raster data are rendered only in 3D view mode"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:743
-#: ../gui/wxpython/animation/controller.py:295
-#: ../gui/wxpython/psmap/dialogs.py:582 ../gui/wxpython/psmap/dialogs.py:1408
-#: ../gui/wxpython/psmap/dialogs.py:1432 ../gui/wxpython/psmap/dialogs.py:1483
-#: ../gui/wxpython/psmap/dialogs.py:5091 ../gui/wxpython/wxplot/dialogs.py:602
-msgid "Invalid input"
+#: ../gui/wxpython/lmgr/layertree.py:107
+msgid "Add WMS layer."
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:753
-msgid "Add, edit or remove animations"
+#: ../gui/wxpython/lmgr/layertree.py:109
+#: ../gui/wxpython/animation/dialogs.py:475
+msgid "Set options"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:765
-msgid "List of animations"
+#: ../gui/wxpython/lmgr/layertree.py:111
+msgid "Editing mode"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:776
-#: ../gui/wxpython/psmap/dialogs.py:1717 ../gui/wxpython/dbmgr/base.py:2346
-msgid "Add"
+#: ../gui/wxpython/lmgr/layertree.py:113
+msgid "Background vector map"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:778
-msgid "Edit"
+#: ../gui/wxpython/lmgr/layertree.py:209
+msgid "Map Layers"
msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:442 ../gui/wxpython/rlisetup/frame.py:140
#: ../gui/wxpython/animation/dialogs.py:780
#: ../gui/wxpython/animation/dialogs.py:1012
-#: ../gui/wxpython/gmodeler/frame.py:1444 ../gui/wxpython/lmgr/layertree.py:443
-#: ../gui/wxpython/rlisetup/frame.py:140
-#: ../gui/wxpython/gui_core/simplelmgr.py:458
-#: ../gui/wxpython/menustrings.py:945 ../gui/wxpython/menustrings.py:1888
+#: ../gui/wxpython/gmodeler/frame.py:1444
+#: ../gui/wxpython/gui_core/simplelmgr.py:463
+#: ../gui/wxpython/menustrings.py:918 ../gui/wxpython/menustrings.py:1824
msgid "Remove"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:837
-#, python-format
-msgid "Maximum number of animations is %d."
+#: ../gui/wxpython/lmgr/layertree.py:451 ../gui/wxpython/rlisetup/frame.py:146
+#: ../gui/wxpython/menustrings.py:170 ../gui/wxpython/menustrings.py:916
+#: ../gui/wxpython/menustrings.py:1155 ../gui/wxpython/menustrings.py:1822
+msgid "Rename"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:887
-#: ../gui/wxpython/animation/controller.py:262
-msgid "More animations are using one window. Please select different window for each animation."
+#: ../gui/wxpython/lmgr/layertree.py:475 ../gui/wxpython/iscatt/frame.py:580
+msgid "Change opacity level"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:907
-#: ../gui/wxpython/animation/toolbars.py:59
-#: ../gui/wxpython/animation/toolbars.py:60
-msgid "Export animation"
+#: ../gui/wxpython/lmgr/layertree.py:486 ../gui/wxpython/gmodeler/frame.py:1511
+msgid "Properties"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:926
-#: ../gui/wxpython/psmap/dialogs.py:512
-msgid "Format"
+#: ../gui/wxpython/lmgr/layertree.py:498
+msgid "3D view properties"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:929 ../gui/wxpython/nviz/tools.py:782
-msgid "Decorations"
+#: ../gui/wxpython/lmgr/layertree.py:509
+msgid "Zoom to selected map(s)"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:934
-#: ../gui/wxpython/lmgr/layertree.py:727 ../gui/wxpython/menustrings.py:973
-#: ../gui/wxpython/menustrings.py:1916
-msgid "Export"
+#: ../gui/wxpython/lmgr/layertree.py:521
+msgid "Set computational region from selected map(s)"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:988
-msgid "Add time stamp"
+#: ../gui/wxpython/lmgr/layertree.py:541
+msgid "Export common formats"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:988 ../gui/wxpython/menustrings.py:2090
-msgid "Add image"
+#: ../gui/wxpython/lmgr/layertree.py:558
+msgid "Export PostGIS"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:54 ../gui/wxpython/menustrings.py:2088
-msgid "Add text"
+#: ../gui/wxpython/lmgr/layertree.py:572 ../gui/wxpython/iclass/dialogs.py:790
+msgid "Export attribute table"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1030
-msgid "Add time stamp, image or text decoration by one of the buttons above."
+#: ../gui/wxpython/lmgr/layertree.py:587 ../gui/wxpython/lmgr/layertree.py:736
+msgid "Create pack"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1032
-msgid "Add image or text decoration by one of the buttons above."
+#: ../gui/wxpython/lmgr/layertree.py:603 ../gui/wxpython/lmgr/layertree.py:752
+msgid "Make a copy in the current mapset"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1053
-msgid "Font settings:"
+#: ../gui/wxpython/lmgr/layertree.py:608 ../gui/wxpython/lmgr/layertree.py:760
+#: ../gui/wxpython/lmgr/layertree.py:832
+msgid "Set color table"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1058
-msgid "Sample text"
+#: ../gui/wxpython/lmgr/layertree.py:617
+msgid "Show attribute data"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1061
-#: ../gui/wxpython/gui_core/preferences.py:529
-#: ../gui/wxpython/gui_core/preferences.py:806
-msgid "Set font"
+#: ../gui/wxpython/lmgr/layertree.py:635
+msgid "Start editing"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1078
-msgid "Image file:"
+#: ../gui/wxpython/lmgr/layertree.py:644
+msgid "Stop editing"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1079
-msgid "Choose image file"
+#: ../gui/wxpython/lmgr/layertree.py:665
+msgid "Rebuild topology"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1095
-msgid "Text:"
+#: ../gui/wxpython/lmgr/layertree.py:698 ../gui/wxpython/lmgr/layertree.py:818
+#: ../gui/wxpython/lmgr/layertree.py:852
+#: ../gui/wxpython/gmodeler/preferences.py:668
+msgid "Metadata"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1116
-msgid "Placement as percentage of screen coordinates (X: 0, Y: 0 is top left):"
+#: ../gui/wxpython/lmgr/layertree.py:708
+msgid "Zoom to selected map(s) (ignore NULLs)"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1137
-#: ../gui/wxpython/psmap/dialogs.py:231
-msgid "X:"
+#: ../gui/wxpython/lmgr/layertree.py:720
+#: ../gui/wxpython/animation/dialogs.py:934 ../gui/wxpython/menustrings.py:946
+#: ../gui/wxpython/menustrings.py:1852
+msgid "Export"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1139
-#: ../gui/wxpython/psmap/dialogs.py:233
-msgid "Y:"
+#: ../gui/wxpython/lmgr/layertree.py:767
+msgid "Set color table interactively"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1151
-msgid "image sequence"
+#: ../gui/wxpython/lmgr/layertree.py:776 ../gui/wxpython/menustrings.py:740
+#: ../gui/wxpython/menustrings.py:1646
+msgid "Histogram"
msgstr ""
-msgid "animated GIF"
+#: ../gui/wxpython/lmgr/layertree.py:785 ../gui/wxpython/lmgr/layertree.py:841
+#: ../gui/wxpython/menustrings.py:523 ../gui/wxpython/menustrings.py:1429
+msgid "Univariate raster statistics"
msgstr ""
-msgid "SWF"
+#: ../gui/wxpython/lmgr/layertree.py:797
+msgid "Report raster statistics"
msgstr ""
-msgid "AVI"
+#: ../gui/wxpython/lmgr/layertree.py:809
+msgid "Profile"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1162
-msgid "Export to:"
+#: ../gui/wxpython/lmgr/layertree.py:865
+msgid "Save web service layer"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1187 ../gui/wxpython/nviz/tools.py:632
-msgid "File prefix:"
+#: ../gui/wxpython/lmgr/layertree.py:972
+msgid "Unable to create profile of raster map."
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1189
-msgid "animation_"
+#: ../gui/wxpython/lmgr/layertree.py:1023 ../gui/wxpython/nviz/tools.py:1866
+msgid "3D raster map"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1191 ../gui/wxpython/nviz/tools.py:640
-msgid "File format:"
+#: ../gui/wxpython/lmgr/layertree.py:1025
+#, python-format
+msgid "Unsupported map type <%s>"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1196
-#: ../gui/wxpython/gui_core/gselect.py:1505
-#: ../gui/wxpython/gui_core/gselect.py:1588
-msgid "Directory:"
+#: ../gui/wxpython/lmgr/layertree.py:1031
+#, python-format
+msgid "Enter name for the new %s in the current mapset:"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1197
-msgid "Choose directory for export"
+#: ../gui/wxpython/lmgr/layertree.py:1033
+#, python-format
+msgid "Make a copy of %s <%s>"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1232
-msgid "GIF file:"
+#: ../gui/wxpython/lmgr/layertree.py:1051
+#, python-format
+msgid "%s <%s> already exists in the current mapset. Do you want to overwrite it?"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1233
-#: ../gui/wxpython/animation/dialogs.py:1257
-#: ../gui/wxpython/animation/dialogs.py:1288
-msgid "Choose file to save animation"
+#: ../gui/wxpython/lmgr/layertree.py:1056
+#: ../gui/wxpython/datacatalog/tree.py:219
+#: ../gui/wxpython/datacatalog/tree.py:679
+#: ../gui/wxpython/rdigit/dialogs.py:104
+#: ../gui/wxpython/gui_core/dialogs.py:475
+#: ../gui/wxpython/modules/colorrules.py:679
+msgid "Overwrite?"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1256
-msgid "SWF file:"
+#: ../gui/wxpython/lmgr/layertree.py:1063
+#, python-format
+msgid "Unable to make copy of <%s>"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1279
-msgid ""
-"Program 'ffmpeg' was not found.\n"
-"Please install it first and make sure\n"
-"it's in the PATH variable."
+#: ../gui/wxpython/lmgr/layertree.py:1071
+#, python-format
+msgid "Unable to make copy of <%s>. Mapset <%s> is not current mapset."
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1287
-msgid "AVI file:"
+#: ../gui/wxpython/lmgr/layertree.py:1097
+msgid "Unable to display histogram of raster map. No map name defined."
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1295
-msgid "Video codec:"
+#: ../gui/wxpython/lmgr/layertree.py:1146 ../gui/wxpython/mapdisp/frame.py:279
+#: ../gui/wxpython/mapdisp/frame.py:339 ../gui/wxpython/mapdisp/toolbars.py:97
+#: ../gui/wxpython/mapdisp/toolbars.py:301 ../gui/wxpython/animation/data.py:45
+msgid "2D view"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1299
-msgid "Additional options:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1303
-msgid "Consider adding '-sameq' or '-qscale 1' if not satisfied with video quality. Options depend on ffmpeg version."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1340
+#: ../gui/wxpython/lmgr/layertree.py:1148 ../gui/wxpython/mapdisp/frame.py:281
#, python-format
-msgid "Current frame rate: %.2f fps"
+msgid ""
+"Unable to start wxGUI vector digitizer.\n"
+"Details: %s"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1472
+#: ../gui/wxpython/lmgr/layertree.py:1207
+#: ../gui/wxpython/gui_core/simplelmgr.py:288
#, python-format
-msgid "File %s not found."
+msgid "Set opacity of <%s>"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1476
-msgid "Decoration image file is missing."
+#: ../gui/wxpython/lmgr/layertree.py:1319
+msgid "Layer group:"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1485
-#, python-format
-msgid "Directory %s not found."
+#: ../gui/wxpython/lmgr/layertree.py:1325
+#: ../gui/wxpython/lmgr/layertree.py:1866
+msgid "Click to edit layer settings"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1489
-msgid "Export directory is missing."
+#: ../gui/wxpython/lmgr/layertree.py:1392
+msgid "(double click to set properties)"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1493
-#: ../gui/wxpython/animation/dialogs.py:1497
-msgid "Export file is missing."
+#: ../gui/wxpython/lmgr/layertree.py:1641
+msgid "Please wait, updating data..."
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1535
-msgid "Time stamp"
+#: ../gui/wxpython/lmgr/layertree.py:1946 ../gui/wxpython/lmgr/frame.py:2353
+msgid "opacity:"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1536
-#: ../gui/wxpython/psmap/dialogs.py:5707 ../gui/wxpython/psmap/dialogs.py:5769
-#: ../gui/wxpython/psmap/toolbars.py:99 ../gui/wxpython/menustrings.py:2089
-msgid "Image"
+#: ../gui/wxpython/lmgr/layertree.py:1964 ../gui/wxpython/animation/utils.py:97
+#: ../gui/wxpython/animation/utils.py:105 ../gui/wxpython/mapswipe/frame.py:420
+#, python-format
+msgid "Map <%s> not found."
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1537
-#: ../gui/wxpython/psmap/dialogs.py:5172 ../gui/wxpython/psmap/dialogs.py:5181
-#: ../gui/wxpython/psmap/toolbars.py:91 ../gui/wxpython/menustrings.py:2087
-msgid "Text"
+#: ../gui/wxpython/lmgr/frame.py:99 ../gui/wxpython/lmgr/frame.py:1202
+#: ../gui/wxpython/mapdisp/frame.py:258 ../gui/wxpython/gui_core/ghelp.py:118
+#: ../gui/wxpython/gui_core/ghelp.py:923
+msgid "Unable to get GRASS version\n"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1613
-msgid "Add space-time dataset layer"
+#: ../gui/wxpython/lmgr/frame.py:101
+#, python-format
+msgid "GRASS GIS %s Layer Manager"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1638
-msgid "Multiple raster maps"
+#: ../gui/wxpython/lmgr/frame.py:151
+msgid "Workspace Toolbar"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1639
-msgid "Multiple vector maps"
+#: ../gui/wxpython/lmgr/frame.py:154
+msgid "Data Toolbar"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1640
-msgid "Multiple 3D raster maps"
+#: ../gui/wxpython/lmgr/frame.py:157 ../gui/wxpython/animation/frame.py:182
+#: ../gui/wxpython/mapswipe/frame.py:315
+msgid "Misc Toolbar"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1641
-msgid "Space time raster dataset"
+#: ../gui/wxpython/lmgr/frame.py:160
+msgid "Tools Toolbar"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1642
-msgid "Space time vector dataset"
+#: ../gui/wxpython/lmgr/frame.py:163
+msgid "Vector Toolbar"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1643
-msgid "Space time 3D raster dataset"
+#: ../gui/wxpython/lmgr/frame.py:166
+msgid "3D view Toolbar"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1682
-msgid "Input data type:"
+#: ../gui/wxpython/lmgr/frame.py:283 ../gui/wxpython/lmgr/frame.py:1690
+msgid "Rename Map Display"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1763
-msgid "Select raster/vector maps."
+#: ../gui/wxpython/lmgr/frame.py:322
+#: ../gui/wxpython/gui_core/preferences.py:1180
+msgid "Layers"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1792
-msgid "Please select maps or dataset first."
+#: ../gui/wxpython/lmgr/frame.py:339
+msgid "Console"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1821
-msgid "Animation Tool settings"
+#: ../gui/wxpython/lmgr/frame.py:364
+#: ../gui/wxpython/gui_core/preferences.py:330
+#: ../gui/wxpython/gui_core/preferences.py:1069
+msgid "Modules"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1864 ../gui/wxpython/nviz/tools.py:465
-#: ../gui/wxpython/nviz/preferences.py:204
-#: ../gui/wxpython/web_services/widgets.py:305
-#: ../gui/wxpython/gui_core/preferences.py:891
-msgid "Background color:"
+#: ../gui/wxpython/lmgr/frame.py:378 ../gui/wxpython/nviz/tools.py:96
+#: ../gui/wxpython/gmodeler/preferences.py:250
+msgid "Data"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1885
-msgid "Number of parallel processes:"
+#: ../gui/wxpython/lmgr/frame.py:388
+#: ../gui/wxpython/gui_core/preferences.py:347
+msgid "Python"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1914
-msgid "Text foreground color:"
+#: ../gui/wxpython/lmgr/frame.py:440 ../gui/wxpython/mapdisp/toolbars.py:104
+#: ../gui/wxpython/animation/data.py:46
+msgid "3D view"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1935
-msgid "Text background color:"
+#: ../gui/wxpython/lmgr/frame.py:483
+#, python-format
+msgid ""
+"Location <%s> created.\n"
+"\n"
+"Do you want to switch to the new location?"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1977
-msgid "Absolute time format:"
+#: ../gui/wxpython/lmgr/frame.py:486
+msgid "Switch to new location?"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1997
-msgid "Click and then press key up or down to preview different date and time formats. Type custom format string."
+#: ../gui/wxpython/lmgr/frame.py:502 ../gui/wxpython/lmgr/frame.py:1051
+#: ../gui/wxpython/datacatalog/frame.py:119
+#, python-format
+msgid ""
+"Current location is <%(loc)s>.\n"
+"Current mapset is <%(mapset)s>."
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:2008
-msgid "Learn more about formatting options"
+#: ../gui/wxpython/lmgr/frame.py:510 ../gui/wxpython/gis_set.py:573
+msgid "Do you want to set the default region extents and resolution now?"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:2022
-msgid "Display instances with no data"
+#: ../gui/wxpython/lmgr/frame.py:512 ../gui/wxpython/gis_set.py:572
+#, python-format
+msgid "Location <%s> created"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:2025
-msgid "When animating instant-based data which have irregular timestamps you can display 'no data frame' (checked option) or keep last frame."
+#: ../gui/wxpython/lmgr/frame.py:594
+msgid "Choose model to run"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:2056
-msgid "Invalid"
+#: ../gui/wxpython/lmgr/frame.py:596 ../gui/wxpython/gmodeler/frame.py:445
+#: ../gui/wxpython/gmodeler/frame.py:505
+msgid "GRASS Model File (*.gxm)|*.gxm"
msgstr ""
-#: ../gui/wxpython/animation/controller.py:234
-#, python-format
-msgid "Maximum number of animations is %s."
+#: ../gui/wxpython/lmgr/frame.py:659 ../gui/wxpython/lmgr/frame.py:2443
+msgid "Do you want to save changes in the workspace?"
msgstr ""
-#: ../gui/wxpython/animation/controller.py:443
-msgid "Failed to display legend."
+#: ../gui/wxpython/lmgr/frame.py:661 ../gui/wxpython/lmgr/frame.py:2445
+msgid "Do you want to store current settings to workspace file?"
msgstr ""
-#: ../gui/wxpython/animation/controller.py:475
-msgid "Inconsistent number of maps, please check input data."
+#: ../gui/wxpython/lmgr/frame.py:669
+#, python-format
+msgid "Close Map Display %s"
msgstr ""
-#: ../gui/wxpython/animation/controller.py:505
-msgid "No animation to export."
+#: ../gui/wxpython/lmgr/frame.py:745
+#, python-format
+msgid "Command '%s' not yet implemented in the WxGUI. Try adding it as a command layer instead."
msgstr ""
-#: ../gui/wxpython/animation/controller.py:542
-msgid "Preparing export, please wait..."
+#: ../gui/wxpython/lmgr/frame.py:923 ../gui/wxpython/lmgr/frame.py:1955
+msgid "Selected map layer is not vector."
msgstr ""
-#: ../gui/wxpython/animation/controller.py:605
-#, python-format
-msgid "%(start)s %(unit)s"
+#: ../gui/wxpython/lmgr/frame.py:929
+msgid "Editing is allowed only for vector maps from the current mapset."
msgstr ""
-#: ../gui/wxpython/animation/controller.py:624
-msgid "Exporting animation, please wait..."
+#: ../gui/wxpython/lmgr/frame.py:955
+msgid "Choose script file to run"
msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:30
-msgid "Change animation speed"
+#: ../gui/wxpython/lmgr/frame.py:957
+msgid "Python script (*.py)|*.py|Bash script (*.sh)|*.sh"
msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:33
-msgid "Play forward"
+#: ../gui/wxpython/lmgr/frame.py:970
+msgid "Due to the limitations of your operating system, the script path cannot contain certain non-ascii characters. Please rename the script or move it to a different location."
msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:36
-msgid "Play back"
+#: ../gui/wxpython/lmgr/frame.py:977
+#, python-format
+msgid "Script file '%s' doesn't exist. Operation canceled."
msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:39 ../gui/wxpython/nviz/tools.py:527
-msgid "Stop"
+#: ../gui/wxpython/lmgr/frame.py:986
+#, python-format
+msgid "Script <%s> is not executable. Do you want to set the permissions that allows you to run this script (note that you must be the owner of the file)?"
msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:42 ../gui/wxpython/nviz/tools.py:525
-msgid "Pause"
+#: ../gui/wxpython/lmgr/frame.py:991
+msgid "Set permission?"
msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:45
-msgid "Repeat"
+#: ../gui/wxpython/lmgr/frame.py:1001
+msgid "Unable to set permission. Operation canceled."
msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:48
-msgid "Play back and forward"
+#: ../gui/wxpython/lmgr/frame.py:1015
+#, python-format
+msgid "Directory '%s' is not defined in GRASS_ADDON_PATH. Do you want add this directory to GRASS_ADDON_PATH?"
msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:55
-#: ../gui/wxpython/animation/toolbars.py:56
-msgid "Add, edit or remove animation"
+#: ../gui/wxpython/lmgr/frame.py:1017
+msgid "Update Addons path?"
msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:68
-msgid "Add space-time dataset or series of map layers"
+#: ../gui/wxpython/lmgr/frame.py:1023
+#, python-format
+msgid "Launching script '%s'..."
msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:69
-msgid "Add space-time dataset or series of map layers for animation"
+#: ../gui/wxpython/lmgr/frame.py:1037
+msgid "No location/mapset provided. Operation canceled."
msgstr ""
-#: ../gui/wxpython/animation/g.gui.animation.py:92
-#, python-format
-msgid "%s=, %s=, %s= and %s= are mutually exclusive."
+#: ../gui/wxpython/lmgr/frame.py:1058 ../gui/wxpython/gis_set.py:955
+msgid "Enter name for new mapset:"
msgstr ""
-#: ../gui/wxpython/gis_set.py:120
-msgid "1. Select GRASS GIS database directory"
+#: ../gui/wxpython/lmgr/frame.py:1059 ../gui/wxpython/gis_set.py:558
+#: ../gui/wxpython/gis_set.py:956 ../gui/wxpython/menustrings.py:235
+msgid "Create new mapset"
msgstr ""
-#: ../gui/wxpython/gis_set.py:123
-msgid "2. Select GRASS Location"
+#: ../gui/wxpython/lmgr/frame.py:1065 ../gui/wxpython/lmgr/frame.py:1086
+msgid "No mapset provided. Operation canceled."
msgstr ""
-#: ../gui/wxpython/gis_set.py:126
-msgid "3. Select GRASS Mapset"
+#: ../gui/wxpython/lmgr/frame.py:1074 ../gui/wxpython/lmgr/frame.py:1096
+#: ../gui/wxpython/datacatalog/frame.py:127
+#, python-format
+msgid "Current mapset is <%s>."
msgstr ""
-#: ../gui/wxpython/gis_set.py:144
-msgid "GRASS GIS database directory contains Locations."
+#: ../gui/wxpython/lmgr/frame.py:1118
+#, python-format
+msgid ""
+"Working directory changed to:\n"
+"\"%s\""
msgstr ""
-#: ../gui/wxpython/gis_set.py:148
-msgid "All data in one Location is in the same coordinate reference system (projection). One Location can be one project. Location contains Mapsets."
+#: ../gui/wxpython/lmgr/frame.py:1125
+msgid "Changes current working directory for this GUI."
msgstr ""
-#: ../gui/wxpython/gis_set.py:156
-msgid "Mapset contains GIS data related to one project, task within one project, subregion or user."
+#: ../gui/wxpython/lmgr/frame.py:1127
+msgid "Usage: cd [directory]"
msgstr ""
-#: ../gui/wxpython/gis_set.py:171
-msgid "Start &GRASS session"
+#: ../gui/wxpython/lmgr/frame.py:1128
+msgid "Without parameters it opens a dialog."
msgstr ""
-#: ../gui/wxpython/gis_set.py:177
-msgid "&Browse"
+#: ../gui/wxpython/lmgr/frame.py:1132
+msgid "If ~ (tilde) is present as the first directory on the path, it is replaced by user's home directory."
msgstr ""
-#. GTC New mapset
-#: ../gui/wxpython/gis_set.py:180
-msgid "&New"
+#: ../gui/wxpython/lmgr/frame.py:1146
+msgid "More than one parameter provided."
msgstr ""
-#: ../gui/wxpython/gis_set.py:182
-msgid "Create a new Mapset in selected Location"
+#: ../gui/wxpython/lmgr/frame.py:1166
+msgid "Choose a working directory"
msgstr ""
-#. GTC New location
-#: ../gui/wxpython/gis_set.py:185
-msgid "N&ew"
+#: ../gui/wxpython/lmgr/frame.py:1211
+msgid "System Info"
msgstr ""
-#: ../gui/wxpython/gis_set.py:188
-msgid "Create a new location using location wizard. After location is created successfully, GRASS session is started."
+#: ../gui/wxpython/lmgr/frame.py:1226
+msgid "GRASS version"
msgstr ""
-#. GTC Rename location
-#: ../gui/wxpython/gis_set.py:193
-msgid "Ren&ame"
+#: ../gui/wxpython/lmgr/frame.py:1226 ../gui/wxpython/gui_core/ghelp.py:132
+msgid "unknown version"
msgstr ""
-#: ../gui/wxpython/gis_set.py:195 ../gui/wxpython/gis_set.py:673
-msgid "Rename selected location"
+#: ../gui/wxpython/lmgr/frame.py:1227
+msgid "GRASS SVN revision"
msgstr ""
-#. GTC Delete location
-#: ../gui/wxpython/gis_set.py:198
-msgid "De&lete"
+#: ../gui/wxpython/lmgr/frame.py:1229
+msgid "Build date"
msgstr ""
-#: ../gui/wxpython/gis_set.py:200 ../gui/wxpython/gis_set.py:756
-msgid "Delete selected location"
+#: ../gui/wxpython/lmgr/frame.py:1231
+msgid "Build platform"
msgstr ""
-#: ../gui/wxpython/gis_set.py:204 ../gui/wxpython/gis_set.py:630
-msgid "Rename selected mapset"
+#: ../gui/wxpython/lmgr/frame.py:1244
+msgid "Platform"
msgstr ""
-#: ../gui/wxpython/gis_set.py:208 ../gui/wxpython/gis_set.py:728
-msgid "Delete selected mapset"
+#: ../gui/wxpython/lmgr/frame.py:1306
+msgid "Current workspace is not empty. Do you want to store current settings to workspace file?"
msgstr ""
-#: ../gui/wxpython/gis_set.py:253
-#, python-format
-msgid "GRASS GIS %s startup%s"
+#: ../gui/wxpython/lmgr/frame.py:1309
+msgid "Create new workspace?"
msgstr ""
-#: ../gui/wxpython/gis_set.py:258
-msgid "Enter GRASS session"
+#: ../gui/wxpython/lmgr/frame.py:1336
+msgid "Choose workspace file"
msgstr ""
-#: ../gui/wxpython/gis_set.py:278
-msgid "Unable to set GRASS database. Check your locale settings."
+#: ../gui/wxpython/lmgr/frame.py:1338 ../gui/wxpython/lmgr/frame.py:1571
+msgid "GRASS Workspace File (*.gxw)|*.gxw"
msgstr ""
-#: ../gui/wxpython/gis_set.py:298
+#: ../gui/wxpython/lmgr/frame.py:1373 ../gui/wxpython/animation/nviztask.py:43
#, python-format
-msgid "ERROR: Location <%s> not found\n"
+msgid ""
+"Reading workspace file <%s> failed.\n"
+"Invalid file, unable to parse XML document."
msgstr ""
-#: ../gui/wxpython/gis_set.py:316
-#, python-format
-msgid "ERROR: Mapset <%s> not found\n"
+#: ../gui/wxpython/lmgr/frame.py:1378 ../gui/wxpython/lmgr/frame.py:1545
+msgid "Please wait, loading workspace..."
msgstr ""
-#: ../gui/wxpython/gis_set.py:477
-#, python-format
-msgid "Invalid line in GISRC file (%s):%s\n"
+#: ../gui/wxpython/lmgr/frame.py:1525
+msgid "Choose GRC file to load"
msgstr ""
-#: ../gui/wxpython/gis_set.py:508
-msgid "Error: {text}"
+#: ../gui/wxpython/lmgr/frame.py:1527
+msgid "Old GRASS Workspace File (*.grc)|*.grc"
msgstr ""
-#: ../gui/wxpython/gis_set.py:542
-#, python-format
-msgid "Do you want to import <%(name)s> to the newly created location?"
+#: ../gui/wxpython/lmgr/frame.py:1569
+msgid "Choose file to save current workspace"
msgstr ""
-#: ../gui/wxpython/gis_set.py:545
-msgid "Import data?"
+#: ../gui/wxpython/lmgr/frame.py:1589 ../gui/wxpython/lmgr/frame.py:1610
+#, python-format
+msgid "Workspace file <%s> already exists. Do you want to overwrite this file?"
msgstr ""
-#: ../gui/wxpython/gis_set.py:559
-msgid "New mapset:"
+#: ../gui/wxpython/lmgr/frame.py:1592 ../gui/wxpython/lmgr/frame.py:1613
+msgid "Save workspace"
msgstr ""
-#: ../gui/wxpython/gis_set.py:560 ../gui/wxpython/gis_set.py:941
-#: ../gui/wxpython/lmgr/frame.py:1059 ../gui/wxpython/menustrings.py:243
-msgid "Create new mapset"
+#: ../gui/wxpython/lmgr/frame.py:1637
+msgid "Writing current settings to workspace file failed."
msgstr ""
-#: ../gui/wxpython/gis_set.py:601
+#: ../gui/wxpython/lmgr/frame.py:1649 ../gui/wxpython/gmodeler/frame.py:1084
#, python-format
-msgid ""
-"Import of <%(name)s> failed.\n"
-"Reason: %(msg)s"
+msgid "Unable to open file <%s> for writing."
msgstr ""
-#: ../gui/wxpython/gis_set.py:608
-#, python-format
-msgid "Data file <%(name)s> imported successfully. The location's default region was set from this imported map."
+#: ../gui/wxpython/lmgr/frame.py:1689
+msgid "Enter new name:"
msgstr ""
-#: ../gui/wxpython/gis_set.py:622
-msgid ""
-"Mapset <PERMANENT> is required for valid GRASS location.\n"
-"\n"
-"This mapset cannot be renamed."
+#: ../gui/wxpython/lmgr/frame.py:1698
+msgid "GRASS GIS {version} Map Display: {name} - Location: {loc}"
msgstr ""
-#: ../gui/wxpython/gis_set.py:628 ../gui/wxpython/gis_set.py:671
+#: ../gui/wxpython/lmgr/frame.py:1784
#, python-format
msgid ""
-"Current name: %s\n"
+"Unable to launch \"Supervised Classification Tool\".\n"
"\n"
-"Enter new name:"
+"Reason: %s"
msgstr ""
-#: ../gui/wxpython/gis_set.py:644
-#, python-format
-msgid ""
-"Unable to rename mapset.\n"
-"\n"
-"Mapset <%s> already exists in location."
+#: ../gui/wxpython/lmgr/frame.py:1826
+msgid "Unable to start Timeline Tool."
msgstr ""
-#: ../gui/wxpython/gis_set.py:658
-#, python-format
-msgid ""
-"\n"
-"%s"
+#: ../gui/wxpython/lmgr/frame.py:1837
+msgid "Unable to start Temporal Plot Tool."
msgstr ""
-#: ../gui/wxpython/gis_set.py:687
-#, python-format
-msgid ""
-"Unable to rename location.\n"
-"\n"
-"Location <%s> already exists in GRASS database."
+#: ../gui/wxpython/lmgr/frame.py:2079
+msgid "Add selected map layers into layer tree"
msgstr ""
-#: ../gui/wxpython/gis_set.py:702
+#: ../gui/wxpython/lmgr/frame.py:2112 ../gui/wxpython/lmgr/frame.py:2149
#, python-format
-msgid ""
-"\n"
-"%s"
+msgid "Unsupported map layer type <%s>."
msgstr ""
-#: ../gui/wxpython/gis_set.py:716
-msgid ""
-"\n"
-"This mapset cannot be deleted."
+#: ../gui/wxpython/lmgr/frame.py:2278
+msgid "Note that cell values can only be displayed for regions of less than 10,000 cells."
msgstr ""
-#: ../gui/wxpython/gis_set.py:723
+#: ../gui/wxpython/lmgr/frame.py:2361
#, python-format
msgid ""
-"Do you want to continue with deleting mapset <%(mapset)s> from location <%(location)s>?\n"
-"\n"
-"ALL MAPS included in this mapset will be PERMANENTLY DELETED!"
+"Do you want to remove map layer(s)\n"
+"%s\n"
+"from layer tree?"
msgstr ""
-#: ../gui/wxpython/gis_set.py:737
-msgid "Unable to delete mapset"
+#: ../gui/wxpython/lmgr/frame.py:2364
+msgid "Do you want to remove selected map layer(s) from layer tree?"
msgstr ""
-#: ../gui/wxpython/gis_set.py:751
-#, python-format
-msgid ""
-"Do you want to continue with deleting location <%s>?\n"
-"\n"
-"ALL MAPS included in this location will be PERMANENTLY DELETED!"
+#: ../gui/wxpython/lmgr/frame.py:2370
+msgid "Remove map layer"
msgstr ""
-#: ../gui/wxpython/gis_set.py:767
-msgid "Unable to delete location"
+#: ../gui/wxpython/lmgr/frame.py:2452
+msgid "Quit GRASS GUI"
msgstr ""
-#: ../gui/wxpython/gis_set.py:777
-#, python-brace-format
-msgid "Unicode error detected. Check your locale settings. Details: {0}"
+#: ../gui/wxpython/lmgr/frame.py:2484
+msgid "Unable to exit GRASS shell: unknown PID"
msgstr ""
-#: ../gui/wxpython/gis_set.py:789
-#, python-format
-msgid "No GRASS Location found in '%s'. Create a new Location or choose different GRASS database directory."
+#: ../gui/wxpython/lmgr/frame.py:2494 ../gui/wxpython/mapdisp/frame.py:599
+#: ../gui/wxpython/gui_core/vselect.py:277
+msgid "No map layer selected. Operation canceled."
msgstr ""
-#: ../gui/wxpython/gis_set.py:911
-#, python-format
-msgid "Path '%s' doesn't exist."
+#: ../gui/wxpython/lmgr/frame.py:2495 ../gui/wxpython/gis_set.py:658
+#: ../gui/wxpython/gis_set.py:701 ../gui/wxpython/core/gcmd.py:151
+msgid "Message"
msgstr ""
-#: ../gui/wxpython/gis_set.py:926 ../gui/wxpython/gui_core/gselect.py:1175
-msgid "Choose GIS Data Directory"
+#: ../gui/wxpython/lmgr/frame.py:2504
+msgid "Display resolution is currently not constrained to computational settings. It's suggested to constrain map to region geometry. Do you want to constrain the resolution?"
msgstr ""
-#: ../gui/wxpython/gis_set.py:940 ../gui/wxpython/lmgr/frame.py:1058
-msgid "Enter name for new mapset:"
+#: ../gui/wxpython/lmgr/frame.py:2513
+msgid "Constrain map to region geometry?"
msgstr ""
-#: ../gui/wxpython/gis_set.py:955
-#, python-format
-msgid "Mapset <%s> already exists."
+#: ../gui/wxpython/lmgr/toolbars.py:49
+msgid "Start new map display"
msgstr ""
-#: ../gui/wxpython/gis_set.py:962
-#, python-format
-msgid ""
-"Mapset <%s> is reserved for direct read access to OGR layers. Please consider to use another name for your mapset.\n"
-"\n"
-"Are you really sure that you want to create this mapset?"
+#: ../gui/wxpython/lmgr/toolbars.py:52
+msgid "Create new workspace (Ctrl+N)"
msgstr ""
-#: ../gui/wxpython/gis_set.py:967
-msgid "Reserved mapset name"
+#: ../gui/wxpython/lmgr/toolbars.py:55
+msgid "Open existing workspace file (Ctrl+O)"
msgstr ""
-#: ../gui/wxpython/gis_set.py:999
-#, python-format
-msgid "Unable to create new mapset: %s"
+#: ../gui/wxpython/lmgr/toolbars.py:58
+msgid "Save current workspace to file (Ctrl+S)"
msgstr ""
-#: ../gui/wxpython/gis_set.py:1014
-#, python-format
-msgid ""
-"GRASS is already running in selected mapset <%(mapset)s>\n"
-"(file %(lock)s found).\n"
-"\n"
-"Concurrent use not allowed.\n"
-"\n"
-"Do you want to try to remove .gislock (note that you need permission for this operation) and continue?"
+#: ../gui/wxpython/lmgr/toolbars.py:89
+msgid "Add multiple raster or vector map layers (Ctrl+Shift+L)"
msgstr ""
-#: ../gui/wxpython/gis_set.py:1020 ../gui/wxpython/gis_set.py:1033
-msgid "Lock file found"
+#: ../gui/wxpython/lmgr/toolbars.py:91
+msgid "Add raster map layer (Ctrl+Shift+R)"
msgstr ""
-#: ../gui/wxpython/gis_set.py:1029
-msgid ""
-"ARE YOU REALLY SURE?\n"
-"\n"
-"If you really are running another GRASS session doing this could corrupt your data. Have another look in the processor manager just to be sure..."
+#: ../gui/wxpython/lmgr/toolbars.py:94
+msgid "Add various raster map layers (RGB, HIS, shaded relief...)"
msgstr ""
-#: ../gui/wxpython/gis_set.py:1043
-#, python-format
-msgid ""
-"Unable to remove '%(lock)s'.\n"
-"\n"
-"Details: %(reason)s"
+#: ../gui/wxpython/lmgr/toolbars.py:96
+msgid "Add vector map layer (Ctrl+Shift+V)"
msgstr ""
-#: ../gui/wxpython/gis_set.py:1093
-#, python-format
-msgid "Name <%(name)s> is not a valid name for location or mapset. Please use only ASCII characters excluding %(chars)s and space."
+#: ../gui/wxpython/lmgr/toolbars.py:99
+msgid "Add various vector map layers (thematic, chart...)"
msgstr ""
-#: ../gui/wxpython/gis_set.py:1098 ../gui/wxpython/gui_core/widgets.py:844
-msgid "Invalid name"
+#: ../gui/wxpython/lmgr/toolbars.py:102
+msgid "Add web service layer (WMS, WMTS, NASA OnEarth)"
msgstr ""
-#: ../gui/wxpython/gis_set.py:1174
-msgid "GRASS needs a directory (GRASS database) in which to store its data. Create one now if you have not already done so. A popular choice is \"grassdata\", located in your home directory. Press Browse button to select the directory."
+#: ../gui/wxpython/lmgr/toolbars.py:105
+msgid "Add group"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:92 ../gui/wxpython/nviz/preferences.py:69
-#: ../gui/wxpython/nviz/preferences.py:74
-msgid "View"
+#: ../gui/wxpython/lmgr/toolbars.py:108
+msgid "Add various overlays"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:96 ../gui/wxpython/gmodeler/preferences.py:250
-#: ../gui/wxpython/lmgr/frame.py:378
-msgid "Data"
+#: ../gui/wxpython/lmgr/toolbars.py:111
+msgid "Remove selected map layer(s) from layer tree"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:100
-#: ../gui/wxpython/gui_core/preferences.py:499
-msgid "Appearance"
+#: ../gui/wxpython/lmgr/toolbars.py:153
+msgid "Import/link raster or vector data"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:104
-msgid "Analysis"
+#: ../gui/wxpython/lmgr/toolbars.py:155
+msgid "Raster Map Calculator"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:107 ../gui/wxpython/nviz/tools.py:502
-msgid "Animation"
+#: ../gui/wxpython/lmgr/toolbars.py:157 ../gui/wxpython/gui_core/forms.py:1413
+msgid "Graphical Modeler"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:252
-msgid "Control View"
+#: ../gui/wxpython/lmgr/toolbars.py:159
+msgid "Georectifier"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:276
-msgid "Adjusts the distance and angular perspective of the image viewpoint"
+#: ../gui/wxpython/lmgr/toolbars.py:161 ../gui/wxpython/menustrings.py:200
+#: ../gui/wxpython/menustrings.py:1918
+msgid "Cartographic Composer"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:292 ../gui/wxpython/nviz/preferences.py:86
-msgid "Perspective:"
+#: ../gui/wxpython/lmgr/toolbars.py:163
+msgid "Launch user-defined script"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:304
-msgid "Tilts the plane of the surface from the horizontal"
+#: ../gui/wxpython/lmgr/toolbars.py:203
+msgid "GUI settings"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:316 ../gui/wxpython/nviz/tools.py:1263
-msgid "Tilt:"
+#: ../gui/wxpython/lmgr/toolbars.py:204
+msgid "GRASS manual"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:329
-msgid "Adjusts the viewing height above the surface (angle of view automatically adjusts to maintain the same center of view)"
+#: ../gui/wxpython/lmgr/toolbars.py:232
+msgid "Edit selected vector map"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:345
-msgid "Adjusts the relative height of features above the plane of the surface"
+#: ../gui/wxpython/lmgr/toolbars.py:235
+msgid "Show attribute data for selected vector map"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:366 ../gui/wxpython/nviz/tools.py:1285
-#: ../gui/wxpython/nviz/tools.py:2126 ../gui/wxpython/psmap/dialogs.py:3836
-#: ../gui/wxpython/psmap/dialogs.py:4053 ../gui/wxpython/psmap/dialogs.py:4844
-#: ../gui/wxpython/gmodeler/preferences.py:210
-#: ../gui/wxpython/gmodeler/preferences.py:376
-#: ../gui/wxpython/gmodeler/preferences.py:488
-#: ../gui/wxpython/gmodeler/preferences.py:604
-#: ../gui/wxpython/gui_core/dialogs.py:1937
-msgid "Height:"
+#: ../gui/wxpython/lmgr/toolbars.py:267
+msgid "Generate command for m.nviz.image"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:387 ../gui/wxpython/nviz/preferences.py:176
-msgid "Z-exag:"
+#: ../gui/wxpython/lmgr/toolbars.py:268
+msgid "Generate command for m.nviz.image based on current state"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:412
-msgid "Look:"
+#: ../gui/wxpython/lmgr/toolbars.py:271
+msgid "3D view mode settings"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:415
-msgid "here"
+#: ../gui/wxpython/lmgr/toolbars.py:272
+msgid "Show 3D view mode settings dialog"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:418
-msgid "Allows you to select a point on the surface that becomes the new center of view. Click on the button and then on the surface."
+#: ../gui/wxpython/lmgr/toolbars.py:275
+msgid "Show 3D view mode manual"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:424
-msgid "center"
+#: ../gui/wxpython/lmgr/menudata.py:44
+msgid "Unable to parse user toolboxes XML files. Default main menu will be loaded."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:428
-msgid "Resets the view to the original default center of view"
+#: ../gui/wxpython/lmgr/menudata.py:68
+msgid "Unable to parse user toolboxes XML files. Default module tree will be loaded."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:432
-msgid "top"
+#: ../gui/wxpython/datacatalog/catalog.py:33
+msgid "Data catalog"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:436
-msgid "Sets the viewer directly over the scene's center position. This top view orients approximately north south."
+#: ../gui/wxpython/datacatalog/dialogs.py:30
+#: ../gui/wxpython/modules/import_export.py:851
+msgid "Reprojection"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:440
-msgid "reset"
+#: ../gui/wxpython/datacatalog/dialogs.py:64
+#: ../gui/wxpython/gui_core/forms.py:680
+#: ../gui/wxpython/modules/import_export.py:98
+msgid "Close dialog on finish"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:441
-msgid "Reset to default view"
-msgstr ""
+#: ../gui/wxpython/datacatalog/dialogs.py:76
+#, fuzzy
+msgid "Reproject"
+msgstr "Proyeksi:"
-#: ../gui/wxpython/nviz/tools.py:458 ../gui/wxpython/nviz/preferences.py:198
-msgid "Image Appearance"
-msgstr ""
+#: ../gui/wxpython/datacatalog/dialogs.py:78
+#, fuzzy
+msgid "Reproject raster"
+msgstr "Peta raster hasil kode-ulang:"
-#: ../gui/wxpython/nviz/tools.py:510
-msgid "Press 'Record' button and start changing the view. It is recommended to use fly-through mode (Map Display toolbar) to achieve smooth motion."
-msgstr ""
+#: ../gui/wxpython/datacatalog/dialogs.py:80
+#, fuzzy
+msgid "Reproject vector"
+msgstr "Kode proyeksi:"
-#: ../gui/wxpython/nviz/tools.py:521
-msgid "Record"
-msgstr ""
+#: ../gui/wxpython/datacatalog/dialogs.py:90
+#, fuzzy
+msgid "The copied layer needs to be reprojected:"
+msgstr "Layer yang akan dihapus"
-#: ../gui/wxpython/nviz/tools.py:523
-msgid "Play"
+#: ../gui/wxpython/datacatalog/frame.py:36
+msgid "GRASS GIS Data Catalog"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:544
-msgid "Total number of frames :"
+#: ../gui/wxpython/datacatalog/frame.py:66
+msgid "Close GRASS GIS Data Catalog"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:551
-msgid "Frame rate (FPS):"
+#: ../gui/wxpython/datacatalog/toolbars.py:25
+msgid "Reload GRASS locations"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:559
-msgid "Frames are recorded with given frequency (FPS). "
+#: ../gui/wxpython/datacatalog/toolbars.py:28
+msgid "Reload current GRASS mapset only"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:615
-msgid "Save image sequence"
+#: ../gui/wxpython/datacatalog/toolbars.py:31
+msgid "Click to restrict editing to current mapset only"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:624 ../gui/wxpython/psmap/dialogs.py:5781
-msgid "Choose a directory:"
+#: ../gui/wxpython/datacatalog/toolbars.py:34
+msgid "Click to allow editing other mapsets"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:625
-msgid "Choose a directory for images"
+#: ../gui/wxpython/datacatalog/toolbars.py:54
+msgid "Search:"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:638
-msgid "Generated files names will look like this: prefix_1.ppm, prefix_2.ppm, ..."
+#: ../gui/wxpython/datacatalog/toolbars.py:56
+msgid "Type to search database by map type or name. Use prefix 'r:', 'v:' and 'r3:'to show only raster, vector or 3D raster data, respectively. Use Python regular expressions to refine your search."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:705 ../gui/wxpython/nviz/tools.py:2236
-#: ../gui/wxpython/nviz/preferences.py:398
-msgid "Surface"
+#: ../gui/wxpython/datacatalog/tree.py:121
+#, python-brace-format
+msgid "Failed to read mapsets from location <{l}>."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:713 ../gui/wxpython/nviz/tools.py:1345
-msgid "Constant surface"
+#: ../gui/wxpython/datacatalog/tree.py:142
+msgid "Failed to read maps from location <{l}>."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:720 ../gui/wxpython/nviz/preferences.py:546
-msgid "Vector"
+#: ../gui/wxpython/datacatalog/tree.py:214
+msgid "Map of type {elem} <{name}> already exists in mapset <{mapset}>. Do you want to overwrite it?"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:728 ../gui/wxpython/gui_core/dialogs.py:1452
-msgid "3D raster"
-msgstr ""
+#: ../gui/wxpython/datacatalog/tree.py:301
+#, fuzzy
+msgid "GRASS locations in {}"
+msgstr "Pilih location dan mapset proyek"
-#: ../gui/wxpython/nviz/tools.py:766 ../gui/wxpython/nviz/preferences.py:287
-msgid "Lighting"
+#: ../gui/wxpython/datacatalog/tree.py:569
+msgid "Map <{layer}> marked for copying. You can paste it to the current mapset <{mapset}>."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:773
-msgid "Fringe"
+#: ../gui/wxpython/datacatalog/tree.py:583
+#: ../gui/wxpython/datacatalog/tree.py:643
+msgid "New name"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:804 ../gui/wxpython/nviz/tools.py:1146
-msgid "Cutting planes"
+#: ../gui/wxpython/datacatalog/tree.py:584
+msgid "Rename map"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:827 ../gui/wxpython/nviz/mapwindow.py:1675
-#: ../gui/wxpython/psmap/dialogs.py:1527 ../gui/wxpython/lmgr/layertree.py:1034
-#: ../gui/wxpython/menustrings.py:2077
-msgid "Raster map"
+#: ../gui/wxpython/datacatalog/tree.py:596
+msgid "Editing {name}"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:856 ../gui/wxpython/nviz/tools.py:1896
-#: ../gui/wxpython/nviz/preferences.py:414
-msgid "Mode:"
+#: ../gui/wxpython/datacatalog/tree.py:615
+msgid "Renaming map <{name}>..."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:859 ../gui/wxpython/nviz/preferences.py:420
-msgid "coarse"
+#: ../gui/wxpython/datacatalog/tree.py:629
+msgid "{cmd} -- completed"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:860 ../gui/wxpython/nviz/preferences.py:421
-msgid "fine"
+#: ../gui/wxpython/datacatalog/tree.py:637
+msgid "No map selected for copying."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:861 ../gui/wxpython/nviz/preferences.py:422
-msgid "both"
+#: ../gui/wxpython/datacatalog/tree.py:644
+msgid "Copy map"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:871 ../gui/wxpython/nviz/tools.py:1162
-#: ../gui/wxpython/nviz/tools.py:1910
-msgid "Shading:"
+#: ../gui/wxpython/datacatalog/tree.py:655
+msgid "Failed to copy map: new map has the same name"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:874 ../gui/wxpython/nviz/tools.py:1913
-msgid "flat"
+#: ../gui/wxpython/datacatalog/tree.py:675
+msgid "Map <{map}> already exists in the current mapset. Do you want to overwrite it?"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:875 ../gui/wxpython/nviz/tools.py:1914
-msgid "gouraud"
+#: ../gui/wxpython/datacatalog/tree.py:689
+msgid "Copying <{name}>..."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:883
-msgid "Set to all"
+#: ../gui/wxpython/datacatalog/tree.py:710
+msgid "g.copy completed"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:884
-msgid "Use draw settings for all loaded surfaces"
+#: ../gui/wxpython/datacatalog/tree.py:714
+msgid "Reprojection is not implemented for 3D rasters"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:896 ../gui/wxpython/nviz/preferences.py:466
-msgid "Coarse mode:"
+#: ../gui/wxpython/datacatalog/tree.py:751
+msgid "Do you really want to delete map <{m}> of type <{etype}> from mapset <{mapset}> in location <{loc}>?"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:899 ../gui/wxpython/nviz/tools.py:945
-#: ../gui/wxpython/nviz/preferences.py:447
-#: ../gui/wxpython/nviz/preferences.py:478
-msgid "resolution:"
+#: ../gui/wxpython/datacatalog/tree.py:756
+msgid "Delete map"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:914 ../gui/wxpython/nviz/preferences.py:496
-msgid "style:"
+#: ../gui/wxpython/datacatalog/tree.py:757
+msgid "Deleting {name}..."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:917 ../gui/wxpython/nviz/preferences.py:502
-msgid "wire"
+#: ../gui/wxpython/datacatalog/tree.py:773
+msgid "g.remove completed"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:918 ../gui/wxpython/nviz/preferences.py:503
-msgid "surface"
+#: ../gui/wxpython/datacatalog/tree.py:783
+msgid "Displaying {name}..."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:930
-msgid "Change wire color"
+#: ../gui/wxpython/datacatalog/tree.py:786
+#: ../gui/wxpython/datacatalog/tree.py:795
+msgid " -- completed. Go to Layers tab for further operations."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:941 ../gui/wxpython/nviz/preferences.py:435
-msgid "Fine mode:"
+#: ../gui/wxpython/datacatalog/tree.py:800
+msgid "Failed to display layer: not in current mapset or invalid layer"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:969
-msgid "Surface attributes"
+#: ../gui/wxpython/datacatalog/tree.py:818
+msgid "Moving maps not implemented"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:976 ../gui/wxpython/nviz/tools.py:2816
-#: ../gui/wxpython/psmap/dialogs.py:6365 ../gui/wxpython/psmap/dialogs.py:6725
-#: ../gui/wxpython/gmodeler/preferences.py:107
-#: ../gui/wxpython/gmodeler/preferences.py:421
-#: ../gui/wxpython/gmodeler/preferences.py:533
-#: ../gui/wxpython/wxplot/dialogs.py:1109
-#: ../gui/wxpython/wxplot/dialogs.py:1191 ../gui/wxpython/iclass/dialogs.py:396
-msgid "Color"
+#: ../gui/wxpython/datacatalog/tree.py:826
+msgid "Maps can be copied only to current mapset"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:977 ../gui/wxpython/nviz/tools.py:2817
-#: ../gui/wxpython/psmap/dialogs.py:2297 ../gui/wxpython/menustrings.py:331
-#: ../gui/wxpython/menustrings.py:1274
-msgid "Mask"
+#: ../gui/wxpython/datacatalog/tree.py:904
+msgid "&Copy"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:978 ../gui/wxpython/nviz/tools.py:2818
-msgid "Transparency"
+#: ../gui/wxpython/datacatalog/tree.py:908
+#: ../gui/wxpython/datacatalog/tree.py:940
+#: ../gui/wxpython/datacatalog/tree.py:958
+msgid "&Paste"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:979 ../gui/wxpython/nviz/tools.py:2819
-msgid "Shininess"
+#. GTC Delete mapset
+#: ../gui/wxpython/datacatalog/tree.py:914 ../gui/wxpython/gis_set.py:207
+msgid "&Delete"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:985 ../gui/wxpython/nviz/tools.py:2839
-msgid "map"
+#. GTC Rename mapset
+#: ../gui/wxpython/datacatalog/tree.py:919 ../gui/wxpython/gis_set.py:203
+#: ../gui/wxpython/dbmgr/base.py:2394
+msgid "&Rename"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:988 ../gui/wxpython/nviz/tools.py:2844
-msgid "unset"
+#: ../gui/wxpython/datacatalog/tree.py:927
+msgid "&Display layer"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:993 ../gui/wxpython/nviz/tools.py:2849
-msgid "constant"
+#: ../gui/wxpython/datacatalog/tree.py:946
+msgid "&Switch mapset"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1050 ../gui/wxpython/nviz/tools.py:2021
-#: ../gui/wxpython/psmap/dialogs.py:3785 ../gui/wxpython/psmap/dialogs.py:4505
-#: ../gui/wxpython/psmap/dialogs.py:4783 ../gui/wxpython/psmap/dialogs.py:5364
-#: ../gui/wxpython/psmap/dialogs.py:5372 ../gui/wxpython/psmap/dialogs.py:5932
-#: ../gui/wxpython/psmap/dialogs.py:5941 ../gui/wxpython/psmap/dialogs.py:6516
-#: ../gui/wxpython/psmap/dialogs.py:6525
-msgid "Position"
+#: ../gui/wxpython/gis_set.py:120
+msgid "1. Select GRASS GIS database directory"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1055
-msgid "Changes the x, y, and z position of the current surface"
+#: ../gui/wxpython/gis_set.py:123
+msgid "2. Select GRASS Location"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1072 ../gui/wxpython/nviz/tools.py:1322
-#: ../gui/wxpython/nviz/tools.py:2041 ../gui/wxpython/nviz/tools.py:3042
-msgid "Reset"
+#: ../gui/wxpython/gis_set.py:126
+msgid "3. Select GRASS Mapset"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1073 ../gui/wxpython/nviz/tools.py:2042
-msgid "Reset to default position"
+#: ../gui/wxpython/gis_set.py:144
+msgid "GRASS GIS database directory contains Locations."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1152
-msgid "Active cutting plane:"
+#: ../gui/wxpython/gis_set.py:148
+msgid "All data in one Location is in the same coordinate reference system (projection). One Location can be one project. Location contains Mapsets."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1164
-msgid "clear"
+#: ../gui/wxpython/gis_set.py:156
+msgid "Mapset contains GIS data related to one project, task within one project, subregion or user."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1165
-msgid "top color"
+#: ../gui/wxpython/gis_set.py:171
+msgid "Start &GRASS session"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1166
-msgid "bottom color"
+#: ../gui/wxpython/gis_set.py:177
+msgid "&Browse"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1167
-msgid "blend"
+#. GTC New mapset
+#: ../gui/wxpython/gis_set.py:180
+msgid "&New"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1168
-msgid "shaded"
+#: ../gui/wxpython/gis_set.py:182
+msgid "Create a new Mapset in selected Location"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1180
-msgid "Horizontal X:"
+#. GTC New location
+#: ../gui/wxpython/gis_set.py:185
+msgid "N&ew"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1182
-msgid "Sets the X coordinate of the current cutting plane"
+#: ../gui/wxpython/gis_set.py:188
+msgid "Create a new location using location wizard. After location is created successfully, GRASS session is started."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1210
-msgid "Horizontal Y:"
+#. GTC Rename location
+#: ../gui/wxpython/gis_set.py:193
+msgid "Ren&ame"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1212
-msgid "Sets the Y coordinate of the current cutting plane"
+#: ../gui/wxpython/gis_set.py:195 ../gui/wxpython/gis_set.py:688
+msgid "Rename selected location"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1241
-msgid "Rotation:"
+#. GTC Delete location
+#: ../gui/wxpython/gis_set.py:198
+msgid "De&lete"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1243
-msgid "Rotates the current cutting plane about vertical axis"
+#: ../gui/wxpython/gis_set.py:200 ../gui/wxpython/gis_set.py:771
+msgid "Delete selected location"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1265
-msgid "Rotates the current cutting plane about horizontal axis"
+#: ../gui/wxpython/gis_set.py:204 ../gui/wxpython/gis_set.py:645
+msgid "Rename selected mapset"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1288
-msgid "Sets the Z coordinate of the current cutting plane (only meaningful when tilt is not 0)"
+#: ../gui/wxpython/gis_set.py:208 ../gui/wxpython/gis_set.py:743
+msgid "Delete selected mapset"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1360 ../gui/wxpython/menustrings.py:6
-#: ../gui/wxpython/menustrings.py:2010
-msgid "New"
+#: ../gui/wxpython/gis_set.py:253
+#, python-format
+msgid "GRASS GIS %s startup%s"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1364 ../gui/wxpython/nviz/tools.py:2367
-#: ../gui/wxpython/nviz/tools.py:2419 ../gui/wxpython/psmap/dialogs.py:1757
-#: ../gui/wxpython/menustrings.py:179 ../gui/wxpython/menustrings.py:1202
-#: ../gui/wxpython/menustrings.py:2093
-msgid "Delete"
+#: ../gui/wxpython/gis_set.py:258
+msgid "Enter GRASS session"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1385
-msgid "Fine resolution:"
+#: ../gui/wxpython/gis_set.py:278
+msgid "Unable to set GRASS database. Check your locale settings."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1399
-msgid "Value:"
+#: ../gui/wxpython/gis_set.py:298
+#, python-format
+msgid "ERROR: Location <%s> not found\n"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1411 ../gui/wxpython/nviz/tools.py:3031
-msgid "Transparency:"
+#: ../gui/wxpython/gis_set.py:316
+#, python-format
+msgid "ERROR: Mapset <%s> not found\n"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1453 ../gui/wxpython/psmap/dialogs.py:3631
-#: ../gui/wxpython/lmgr/layertree.py:1038 ../gui/wxpython/menustrings.py:2079
-msgid "Vector map"
+#: ../gui/wxpython/gis_set.py:477
+#, python-format
+msgid "Invalid line in GISRC file (%s):%s\n"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1477
-msgid "Show vector lines"
+#: ../gui/wxpython/gis_set.py:508
+msgid "Error: {text}"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1487 ../gui/wxpython/nviz/preferences.py:552
-msgid "Vector lines"
+#: ../gui/wxpython/gis_set.py:542
+#, python-format
+msgid "Do you want to import <%(name)s> to the newly created location?"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1493
-msgid "Line:"
+#: ../gui/wxpython/gis_set.py:545
+msgid "Import data?"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1496
-msgid "width:"
+#: ../gui/wxpython/gis_set.py:557
+#, fuzzy
+msgid "Do you want to create new mapset?"
+msgstr "Apakah Anda hendak membuat GRASS location <%s>?"
+#: ../gui/wxpython/gis_set.py:616
+#, python-format
+msgid ""
+"Import of <%(name)s> failed.\n"
+"Reason: %(msg)s"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1512 ../gui/wxpython/nviz/tools.py:1684
-msgid "color:"
+#: ../gui/wxpython/gis_set.py:623
+#, python-format
+msgid "Data file <%(name)s> imported successfully. The location's default region was set from this imported map."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1529 ../gui/wxpython/nviz/tools.py:1733
-msgid "use color for thematic mapping"
+#: ../gui/wxpython/gis_set.py:637
+msgid ""
+"Mapset <PERMANENT> is required for valid GRASS location.\n"
+"\n"
+"This mapset cannot be renamed."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1532
-msgid "use width for thematic mapping"
+#: ../gui/wxpython/gis_set.py:643 ../gui/wxpython/gis_set.py:686
+#, python-format
+msgid ""
+"Current name: %s\n"
+"\n"
+"Enter new name:"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1547 ../gui/wxpython/nviz/tools.py:1560
-#: ../gui/wxpython/nviz/tools.py:1756 ../gui/wxpython/nviz/tools.py:1773
-msgid "Set options..."
+#: ../gui/wxpython/gis_set.py:659
+#, python-format
+msgid ""
+"Unable to rename mapset.\n"
+"\n"
+"Mapset <%s> already exists in location."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1579 ../gui/wxpython/nviz/tools.py:5442
-#: ../gui/wxpython/nviz/tools.py:5497
-msgid "on surface(s):"
+#: ../gui/wxpython/gis_set.py:673
+#, python-format
+msgid ""
+"\n"
+"%s"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1580 ../gui/wxpython/nviz/tools.py:5442
-msgid "as 3D"
+#: ../gui/wxpython/gis_set.py:702
+#, python-format
+msgid ""
+"Unable to rename location.\n"
+"\n"
+"Location <%s> already exists in GRASS database."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1589 ../gui/wxpython/nviz/tools.py:1796
-msgid "Height above surface:"
+#: ../gui/wxpython/gis_set.py:717
+#, python-format
+msgid ""
+"\n"
+"%s"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1640
-msgid "Show vector points"
+#: ../gui/wxpython/gis_set.py:731
+msgid ""
+"\n"
+"This mapset cannot be deleted."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1649 ../gui/wxpython/nviz/preferences.py:592
-msgid "Vector points"
+#: ../gui/wxpython/gis_set.py:738
+#, python-format
+msgid ""
+"Do you want to continue with deleting mapset <%(mapset)s> from location <%(location)s>?\n"
+"\n"
+"ALL MAPS included in this mapset will be PERMANENTLY DELETED!"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1656
-msgid "Icon:"
+#: ../gui/wxpython/gis_set.py:752
+msgid "Unable to delete mapset"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1659 ../gui/wxpython/psmap/dialogs.py:2722
-msgid "size:"
+#: ../gui/wxpython/gis_set.py:766
+#, python-format
+msgid ""
+"Do you want to continue with deleting location <%s>?\n"
+"\n"
+"ALL MAPS included in this location will be PERMANENTLY DELETED!"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1717 ../gui/wxpython/psmap/dialogs.py:2648
-msgid "symbol:"
+#: ../gui/wxpython/gis_set.py:782
+msgid "Unable to delete location"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1736
-msgid "use size for thematic mapping"
+#: ../gui/wxpython/gis_set.py:792
+msgid "Unicode error detected. Check your locale settings. Details: {}"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1866 ../gui/wxpython/lmgr/layertree.py:1042
-msgid "3D raster map"
+#: ../gui/wxpython/gis_set.py:804
+#, python-format
+msgid "No GRASS Location found in '%s'. Create a new Location or choose different GRASS database directory."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1899
-msgid "isosurfaces"
+#: ../gui/wxpython/gis_set.py:926
+#, python-format
+msgid "Path '%s' doesn't exist."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1900
-msgid "slices"
+#: ../gui/wxpython/gis_set.py:941 ../gui/wxpython/gui_core/gselect.py:1175
+msgid "Choose GIS Data Directory"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1923
-msgid "Resolution:"
+#: ../gui/wxpython/gis_set.py:970
+#, python-format
+msgid "Mapset <%s> already exists."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1937
-msgid "Draw wire box"
+#: ../gui/wxpython/gis_set.py:977
+#, python-format
+msgid ""
+"Mapset <%s> is reserved for direct read access to OGR layers. Please consider to use another name for your mapset.\n"
+"\n"
+"Are you really sure that you want to create this mapset?"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1953 ../gui/wxpython/nviz/tools.py:4279
-msgid "List of isosurfaces"
+#: ../gui/wxpython/gis_set.py:982
+msgid "Reserved mapset name"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2087
-msgid "Show light model"
+#: ../gui/wxpython/gis_set.py:1014
+#, python-format
+msgid "Unable to create new mapset: %s"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2100
-msgid "Light source position"
+#: ../gui/wxpython/gis_set.py:1029
+#, python-format
+msgid ""
+"GRASS is already running in selected mapset <%(mapset)s>\n"
+"(file %(lock)s found).\n"
+"\n"
+"Concurrent use not allowed.\n"
+"\n"
+"Do you want to try to remove .gislock (note that you need permission for this operation) and continue?"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2117
-msgid "Adjusts the light height"
+#: ../gui/wxpython/gis_set.py:1035 ../gui/wxpython/gis_set.py:1048
+msgid "Lock file found"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2148
-msgid "Light color and intensity"
+#: ../gui/wxpython/gis_set.py:1044
+msgid ""
+"ARE YOU REALLY SURE?\n"
+"\n"
+"If you really are running another GRASS session doing this could corrupt your data. Have another look in the processor manager just to be sure..."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2166 ../gui/wxpython/nviz/preferences.py:345
-msgid "Brightness:"
+#: ../gui/wxpython/gis_set.py:1058
+#, python-format
+msgid ""
+"Unable to remove '%(lock)s'.\n"
+"\n"
+"Details: %(reason)s"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2168
-msgid "Adjusts the brightness of the light"
+#: ../gui/wxpython/gis_set.py:1108
+#, python-format
+msgid "Name <%(name)s> is not a valid name for location or mapset. Please use only ASCII characters excluding %(chars)s and space."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2183 ../gui/wxpython/nviz/preferences.py:359
-msgid "Ambient:"
+#: ../gui/wxpython/gis_set.py:1113 ../gui/wxpython/gui_core/widgets.py:844
+msgid "Invalid name"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2185
-msgid "Adjusts the ambient light"
+#: ../gui/wxpython/gis_set.py:1189
+msgid "GRASS needs a directory (GRASS database) in which to store its data. Create one now if you have not already done so. A popular choice is \"grassdata\", located in your home directory. Press Browse button to select the directory."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2250
-msgid "Edges with fringe"
+#: ../gui/wxpython/rlisetup/frame.py:23
+msgid "Modify the configuration file"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2252
-msgid "N && W"
+#: ../gui/wxpython/rlisetup/frame.py:37
+msgid "View and modify the configuration file '{name}'"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2253
-msgid "N && E"
+#: ../gui/wxpython/rlisetup/frame.py:89
+msgid ""
+"Are you sure that you want modify r.li configuration file {name}?\n"
+"You could broke the configuration file..."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2254
-msgid "S && W"
+#: ../gui/wxpython/rlisetup/frame.py:94
+msgid "WARNING"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2255
-msgid "S && E"
+#: ../gui/wxpython/rlisetup/frame.py:114
+msgid "GRASS GIS Setup for r.li modules"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2280
-msgid "Elevation of fringe from bottom:"
+#: ../gui/wxpython/rlisetup/frame.py:132
+msgid "Available sampling area configuration files"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2332 ../gui/wxpython/psmap/dialogs.py:6231
-#: ../gui/wxpython/psmap/toolbars.py:101 ../gui/wxpython/menustrings.py:2091
-msgid "North Arrow"
+#: ../gui/wxpython/rlisetup/frame.py:141
+msgid "Remove a configuration file"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2337
-msgid "Arrow length (in map units):"
+#: ../gui/wxpython/rlisetup/frame.py:143 ../gui/wxpython/menustrings.py:914
+#: ../gui/wxpython/menustrings.py:1820
+msgid "Create"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2349
-msgid "Arrow color:"
+#: ../gui/wxpython/rlisetup/frame.py:144
+msgid "Create a new configuration file"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2361
-msgid "Place arrow"
+#: ../gui/wxpython/rlisetup/frame.py:147
+msgid "Rename a configuration file"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2381 ../gui/wxpython/psmap/toolbars.py:97
-#: ../gui/wxpython/menustrings.py:2085
-msgid "Scale bar"
+#: ../gui/wxpython/rlisetup/frame.py:149
+msgid "View/Edit"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2386
-msgid "Scale bar length (in map units):"
+#: ../gui/wxpython/rlisetup/frame.py:150
+msgid "View and edit a configuration file"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2398
-msgid "Scale bar color:"
+#: ../gui/wxpython/rlisetup/frame.py:225
+#, python-format
+msgid "Do you want remove r.li configuration file <%s>?"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2410
-msgid "Place new scale bar"
+#: ../gui/wxpython/rlisetup/frame.py:228
+msgid "Remove new r.li configuration file?"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2482
-msgid "Do you want to record new animation without saving the previous one?"
+#: ../gui/wxpython/rlisetup/frame.py:251 ../gui/wxpython/rlisetup/frame.py:271
+msgid "You have to select a configuration file"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2485
-msgid "Animation already axists"
+#: ../gui/wxpython/rlisetup/frame.py:254
+#, python-format
+msgid "Set the new name for %s \" \"configuration file"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2655
-msgid "No file prefix given."
+#: ../gui/wxpython/rlisetup/frame.py:256
+msgid "Rename configuration file"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2659
+#: ../gui/wxpython/rlisetup/sampling_frame.py:217
+#: ../gui/wxpython/rlisetup/sampling_frame.py:326
#, python-format
-msgid "Directory %s does not exist."
+msgid "The raster file %s already exists, please change name"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2679 ../gui/wxpython/nviz/tools.py:2728
-#: ../gui/wxpython/nviz/tools.py:5172 ../gui/wxpython/nviz/mapwindow.py:2253
-#: ../gui/wxpython/nviz/mapwindow.py:2272
-msgid "constant#"
+#: ../gui/wxpython/rlisetup/sampling_frame.py:243
+msgid "Raster map not created. Please redraw region."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2800
-msgid "Isosurface attributes"
+#: ../gui/wxpython/rlisetup/sampling_frame.py:349
+msgid "Raster map not created. redraw region again."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2806
-msgid "toggle normal direction"
+#: ../gui/wxpython/rlisetup/sampling_frame.py:403
+#: ../gui/wxpython/rlisetup/wizard.py:818
+msgid "Draw sampling frame"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2815
-msgid "Isosurface value"
+#: ../gui/wxpython/rlisetup/sampling_frame.py:404
+msgid "Draw sampling frame by clicking and dragging"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2932
-msgid "Slice attributes"
+#: ../gui/wxpython/rlisetup/sampling_frame.py:407
+msgid "Draw sampling rectangle"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2941
-msgid "Slice parallel to axis:"
+#: ../gui/wxpython/rlisetup/sampling_frame.py:408
+msgid "Draw sampling rectangle by clicking and dragging"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:3099
-msgid "W"
+#: ../gui/wxpython/rlisetup/sampling_frame.py:411
+msgid "Draw sampling circle"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:3100
-msgid "N"
+#: ../gui/wxpython/rlisetup/sampling_frame.py:412
+msgid "Draw sampling circle radius by clicking and dragging"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:3101
-msgid "S"
+#: ../gui/wxpython/rlisetup/sampling_frame.py:415
+#: ../gui/wxpython/rlisetup/wizard.py:1129
+#: ../gui/wxpython/rlisetup/wizard.py:1490
+msgid "Draw sampling region"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:3102
-msgid "E"
+#: ../gui/wxpython/rlisetup/sampling_frame.py:416
+msgid "Draw sampling region by polygon. Right Double click to end drawing"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:3103
-msgid "NW"
+#: ../gui/wxpython/rlisetup/wizard.py:52
+msgid "Create new configuration file for r.li modules"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:3104
-msgid "NE"
+#: ../gui/wxpython/rlisetup/wizard.py:118
+#, python-format
+msgid "Do you want to create r.li configuration file <%s>?"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:3105
-msgid "SE"
+#: ../gui/wxpython/rlisetup/wizard.py:121
+msgid "Create new r.li configuration file?"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:3106
-msgid "SW"
+#: ../gui/wxpython/rlisetup/wizard.py:133
+msgid "r.li.setup wizard canceled. Configuration file not created."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:3624 ../gui/wxpython/nviz/tools.py:5560
-msgid "Level"
+#: ../gui/wxpython/rlisetup/wizard.py:479
+msgid "Select maps and define name"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4285
-msgid "List of slices"
+#: ../gui/wxpython/rlisetup/wizard.py:492
+msgid "Name for new configuration file to create"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4483 ../gui/wxpython/nviz/tools.py:4485
-msgid "Level {level}"
+#: ../gui/wxpython/rlisetup/wizard.py:505
+msgid "Raster map to use to select areas"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4493 ../gui/wxpython/nviz/tools.py:4497
-msgid "Slice parallel to {axis}"
+#: ../gui/wxpython/rlisetup/wizard.py:516
+msgid "Vector map to use to select areas"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4785 ../gui/wxpython/nviz/tools.py:5573
-msgid "Slice parallel to"
+#: ../gui/wxpython/rlisetup/wizard.py:527
+msgid "Vector map layer to use to select areas"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5017
-#, python-format
-msgid "Scalebar %d"
+#: ../gui/wxpython/rlisetup/wizard.py:539
+msgid "Define sampling region (region for analysis)"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5179
-msgid "None"
+#: ../gui/wxpython/rlisetup/wizard.py:542
+#: ../gui/wxpython/rlisetup/wizard.py:877
+msgid "Whole map layer"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5181 ../gui/wxpython/menustrings.py:493
-#: ../gui/wxpython/menustrings.py:1436
-msgid "Plane"
+#: ../gui/wxpython/rlisetup/wizard.py:543
+msgid "Keyboard setting"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5381
-msgid "Vector map is 3D"
+#: ../gui/wxpython/rlisetup/wizard.py:544
+msgid "Draw the sampling frame"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5384
-msgid "Vector map is 2D"
+#: ../gui/wxpython/rlisetup/wizard.py:586
+#, python-format
+msgid "The configuration file %s already exists, please change name"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5386
+#: ../gui/wxpython/rlisetup/wizard.py:648
#, python-format
-msgid "%(features)d features (%(points)d points)"
+msgid "Vector %s was not found, please select another vector"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5444 ../gui/wxpython/nviz/tools.py:5499
-msgid "on surface"
+#: ../gui/wxpython/rlisetup/wizard.py:652
+#, python-format
+msgid "Vector %s has no areas, please select another vector"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5597
-msgid "range:"
+#: ../gui/wxpython/rlisetup/wizard.py:657
+#, python-format
+msgid "Vector %s has no table connected, please select another vector"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5676 ../gui/wxpython/nviz/tools.py:5687
-msgid "North edge:"
+#: ../gui/wxpython/rlisetup/wizard.py:701
+msgid "Insert sampling frame parameter"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5677 ../gui/wxpython/nviz/tools.py:5688
-msgid "South edge:"
+#: ../gui/wxpython/rlisetup/wizard.py:711
+msgid "Column of upper left corner"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5678 ../gui/wxpython/nviz/tools.py:5685
-#: ../gui/wxpython/nviz/tools.py:5694
-msgid "West edge:"
+#: ../gui/wxpython/rlisetup/wizard.py:725
+msgid "Row of upper left corner"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5679 ../gui/wxpython/nviz/tools.py:5686
-#: ../gui/wxpython/nviz/tools.py:5695
-msgid "East edge:"
+#: ../gui/wxpython/rlisetup/wizard.py:740
+#: ../gui/wxpython/rlisetup/wizard.py:754
+msgid "Row length of sampling frame"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5681 ../gui/wxpython/nviz/tools.py:5692
-#: ../gui/wxpython/nviz/tools.py:5700
-msgid "Northing (Y):"
+#: ../gui/wxpython/rlisetup/wizard.py:870
+msgid "Insert sampling areas"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5682 ../gui/wxpython/nviz/tools.py:5691
-#: ../gui/wxpython/nviz/tools.py:5701
-msgid "Height (Z):"
+#: ../gui/wxpython/rlisetup/wizard.py:878
+msgid "Regions"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5683 ../gui/wxpython/nviz/tools.py:5690
-#: ../gui/wxpython/nviz/tools.py:5699
-msgid "Easting (X):"
+#: ../gui/wxpython/rlisetup/wizard.py:879
+msgid "Sample units"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5696
-msgid "Bottom edge:"
+#: ../gui/wxpython/rlisetup/wizard.py:880 ../gui/wxpython/menustrings.py:328
+#: ../gui/wxpython/menustrings.py:1234
+msgid "Moving window"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5697
-msgid "Top edge:"
+#: ../gui/wxpython/rlisetup/wizard.py:881
+msgid ""
+"Select areas from the\n"
+"overlayed vector map"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5808
-msgid "Adjusts the distance and direction of the image viewpoint"
+#: ../gui/wxpython/rlisetup/wizard.py:892
+msgid "Choose a method"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5843
-msgid "Adjusts the light direction. Click and drag the puck to change the light direction."
+#: ../gui/wxpython/rlisetup/wizard.py:894
+msgid "Use keyboard to enter sampling area"
msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:35
-msgid "3D view default settings"
+#: ../gui/wxpython/rlisetup/wizard.py:895
+msgid "Use mouse to draw sampling area"
msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:62
-msgid "Revert settings to default, changes are not applied"
+#: ../gui/wxpython/rlisetup/wizard.py:899
+msgid "This option is not supported yet"
msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:90
-#: ../gui/wxpython/nviz/preferences.py:161
-#: ../gui/wxpython/nviz/preferences.py:180
-msgid "value:"
+#: ../gui/wxpython/rlisetup/wizard.py:911
+msgid "Number of regions to draw:"
msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:103
-msgid "step:"
+#: ../gui/wxpython/rlisetup/wizard.py:926
+msgid "Do you want to overwrite existing temporal maps if they exist?"
msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:118
-#: ../gui/wxpython/nviz/preferences.py:300
-msgid "Position:"
+#: ../gui/wxpython/rlisetup/wizard.py:931
+msgid "Do you want to check vector areas?"
msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:122
-#: ../gui/wxpython/nviz/preferences.py:304
-msgid "x:"
+#: ../gui/wxpython/rlisetup/wizard.py:933
+msgid "Select if use area by area"
msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:157
-msgid "Twist:"
+#: ../gui/wxpython/rlisetup/wizard.py:935
+msgid "All the features will be used"
msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:237
-msgid "Fly-through"
+#: ../gui/wxpython/rlisetup/wizard.py:952
+msgid "Analysing all vector features..."
msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:241
-#: ../gui/wxpython/mapdisp/toolbars.py:68
-msgid "Fly-through mode"
+#: ../gui/wxpython/rlisetup/wizard.py:1050
+msgid "Analysing vector"
msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:247
-msgid "Move exag:"
+#: ../gui/wxpython/rlisetup/wizard.py:1066
+msgid "All feature are been analyzed."
msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:260
-msgid "Turn exag:"
+#: ../gui/wxpython/rlisetup/wizard.py:1070
+msgid "An error occurred"
msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:292
-msgid "Light"
+#: ../gui/wxpython/rlisetup/wizard.py:1102
+msgid "Draw sampling regions"
msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:330
-msgid "z:"
+#: ../gui/wxpython/rlisetup/wizard.py:1119
+msgid "Draw sample region "
msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:517
-msgid "wire color:"
+#: ../gui/wxpython/rlisetup/wizard.py:1127
+#: ../gui/wxpython/rlisetup/wizard.py:1484
+msgid "Draw moving windows region"
msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:559
-#: ../gui/wxpython/psmap/dialogs.py:3818
-#: ../gui/wxpython/gmodeler/preferences.py:184
-#: ../gui/wxpython/gmodeler/preferences.py:350
-#: ../gui/wxpython/gmodeler/preferences.py:462
-#: ../gui/wxpython/gmodeler/preferences.py:578
-#: ../gui/wxpython/rdigit/toolbars.py:100
-#: ../gui/wxpython/gui_core/dialogs.py:1933
-msgid "Width:"
+#: ../gui/wxpython/rlisetup/wizard.py:1166
+msgid "Select sample units from keyboard"
msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:598
-msgid "Automatic size"
+#: ../gui/wxpython/rlisetup/wizard.py:1180
+#: ../gui/wxpython/rlisetup/wizard.py:1353
+#: ../gui/wxpython/rlisetup/wizard.py:1443
+msgid "Select type of shape"
msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:599
-msgid "Icon size is set automatically based on landscape dimensions."
+#: ../gui/wxpython/rlisetup/wizard.py:1181
+#: ../gui/wxpython/rlisetup/wizard.py:1354
+#: ../gui/wxpython/rlisetup/wizard.py:1444
+msgid "Circle"
msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:623
-msgid "Marker:"
+#: ../gui/wxpython/rlisetup/wizard.py:1207
+#: ../gui/wxpython/rlisetup/wizard.py:1365
+#: ../gui/wxpython/rlisetup/wizard.py:1380
+msgid "Width size (in cells)?"
msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:724
-#, python-format
-msgid "3D view settings saved to file <%s>."
+#: ../gui/wxpython/rlisetup/wizard.py:1208
+#: ../gui/wxpython/rlisetup/wizard.py:1381
+msgid "What radius size (in meters)?"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:244
-msgid "Opening 3D view was not successful. Please try to change the value of depth buffer in GUI Settings dialog > tab Map Display > Advanced and restart GUI."
+#: ../gui/wxpython/rlisetup/wizard.py:1209
+#: ../gui/wxpython/rlisetup/wizard.py:1372
+#: ../gui/wxpython/rlisetup/wizard.py:1382
+msgid "Height size (in cells)?"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:509
-#, python-format
-msgid "Image is too large, your OpenGL implementation supports maximum texture size %d px."
+#: ../gui/wxpython/rlisetup/wizard.py:1210
+#: ../gui/wxpython/rlisetup/wizard.py:1383
+msgid "Name of the circle mask"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1021
-msgid "Easting"
+#: ../gui/wxpython/rlisetup/wizard.py:1218
+msgid "Select method of sampling unit distribution"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1022
-msgid "Northing"
+#: ../gui/wxpython/rlisetup/wizard.py:1220
+msgid "Random non overlapping"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1023
-msgid "Elevation"
+#: ../gui/wxpython/rlisetup/wizard.py:1221
+msgid "Systematic contiguos"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1029
-msgid "Surface map name"
+#: ../gui/wxpython/rlisetup/wizard.py:1222
+msgid "Stratified random"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1032
-msgid "Surface map elevation"
+#: ../gui/wxpython/rlisetup/wizard.py:1223
+msgid "Systematic non contiguos"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1034
-msgid "Surface map color"
+#: ../gui/wxpython/rlisetup/wizard.py:1224
+msgid "Centered over sites"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1045
-msgid "XY distance from previous"
+#: ../gui/wxpython/rlisetup/wizard.py:1229
+#: ../gui/wxpython/rlisetup/wizard.py:1294
+msgid "What number of Sampling Units to use?"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1048
-msgid "XYZ distance from previous"
+#: ../gui/wxpython/rlisetup/wizard.py:1308
+msgid "Insert number of row strates"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1051
-msgid "Distance along surface"
+#: ../gui/wxpython/rlisetup/wizard.py:1309
+msgid "Insert number of column strates"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1055
-msgid "Distance along exag. surface"
+#: ../gui/wxpython/rlisetup/wizard.py:1315
+msgid "Insert distance between units"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1059
-msgid "No point on surface"
+#: ../gui/wxpython/rlisetup/wizard.py:1345
+msgid "Set sample units"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1539
-msgid "Loading raster map"
+#: ../gui/wxpython/rlisetup/wizard.py:1394
+msgid "Set moving windows"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1543
-msgid "Loading 3d raster map"
+#: ../gui/wxpython/rlisetup/wizard.py:1437
+#: ../gui/wxpython/rlisetup/wizard.py:1535
+msgid "Draw sampling units"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1551
-msgid "failed"
+#: ../gui/wxpython/rlisetup/wizard.py:1455
+msgid "Number of sampling area to draw:"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1554
-#, python-format
-msgid "Unsupported layer type '%s'"
+#: ../gui/wxpython/rlisetup/wizard.py:1552
+msgid "Draw Sampling "
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1674
-msgid "Unable to unload raster map"
+#: ../gui/wxpython/rlisetup/wizard.py:1606
+msgid "Select sampling areas"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1679
-msgid "Unable to unload 3d raster map"
+#: ../gui/wxpython/rlisetup/wizard.py:1615
+msgid "Is this area ok?"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1680
-msgid "3d raster map"
+#: ../gui/wxpython/rlisetup/wizard.py:1638
+msgid "Select sample area "
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1692
-msgid "unloaded successfully"
+#: ../gui/wxpython/rlisetup/wizard.py:1665
+#: ../gui/wxpython/rlisetup/functions.py:138
+#, python-format
+msgid "The raster map <%s> already exists. Please remove or rename the maps with the prefix '%s' or select the option to overwrite existing maps"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1748
-#, python-format
-msgid "Loading vector map <%(name)s> (%(type)s) failed"
+#: ../gui/wxpython/rlisetup/wizard.py:1706
+#: ../gui/wxpython/rlisetup/functions.py:127
+msgid "The polygon seems to have 0 areas"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1811
-#, python-format
-msgid "Unable to unload vector map <%(name)s> (%(type)s)"
+#: ../gui/wxpython/rlisetup/wizard.py:1709
+msgid "Select sample area 1 of "
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1815
-#, python-format
-msgid "Vector map <%(name)s> (%(type)s) unloaded successfully"
+#: ../gui/wxpython/rlisetup/wizard.py:1732
+#: ../gui/wxpython/location_wizard/wizard.py:2000
+msgid "Summary"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:2192
-#, python-format
-msgid "Vector point layer not found (id = %d)"
+#: ../gui/wxpython/rlisetup/wizard.py:1739
+msgid "Configuration file name:"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:2194
-#, python-format
-msgid "Unable to set data layer properties (id = %d)"
+#: ../gui/wxpython/rlisetup/wizard.py:1748
+msgid "Raster name:"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:2198
-#, python-format
-msgid ""
-"Setting data layer properties failed.\n"
-"\n"
-"%s"
+#: ../gui/wxpython/rlisetup/wizard.py:1758
+msgid "Vector name:"
msgstr ""
-#: ../gui/wxpython/nviz/wxnviz.py:33
-msgid "This module requires the NumPy module, which could not be imported. It probably is not installed (it's not part of the standard Python distribution). See the Numeric Python site (http://numpy.scipy.org) for information on downloading source or binaries."
+#: ../gui/wxpython/rlisetup/wizard.py:1767
+msgid "Region type:"
msgstr ""
-#: ../gui/wxpython/nviz/wxnviz.py:433 ../gui/wxpython/dbmgr/g.gui.dbmgr.py:48
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:62
-#: ../gui/wxpython/iclass/g.gui.iclass.py:98
-#, python-format
-msgid "Vector map <%s> not found"
+#: ../gui/wxpython/rlisetup/wizard.py:1785
+msgid "Sampling area type:"
msgstr ""
-#: ../gui/wxpython/nviz/wxnviz.py:503 ../gui/wxpython/nviz/wxnviz.py:515
-#, python-format
-msgid "3d raster map <%s> not found"
+#: ../gui/wxpython/rlisetup/wizard.py:1848
+msgid "Region keyboard values:"
msgstr ""
-#: ../gui/wxpython/tplot/frame.py:43
-msgid "The Temporal Plot Tool needs the \"matplotlib\" (python-matplotlib) package to be installed. {0}"
+#: ../gui/wxpython/rlisetup/wizard.py:1862
+#: ../gui/wxpython/rlisetup/wizard.py:1887
+#: ../gui/wxpython/rlisetup/wizard.py:1891
+msgid "Type of shape:"
msgstr ""
-#: ../gui/wxpython/tplot/frame.py:97
-msgid "GRASS GIS Temporal Plot Tool"
+#: ../gui/wxpython/rlisetup/wizard.py:1865
+#: ../gui/wxpython/rlisetup/wizard.py:1894
+msgid "Radius size:"
msgstr ""
-#: ../gui/wxpython/tplot/frame.py:180
-msgid "Raster temporal dataset (strds)"
+#: ../gui/wxpython/rlisetup/wizard.py:1866
+#: ../gui/wxpython/rlisetup/wizard.py:1895
+msgid "Name circle mask:"
msgstr ""
-#: ../gui/wxpython/tplot/frame.py:187
-msgid "X and Y coordinates separated by comma:"
+#: ../gui/wxpython/rlisetup/wizard.py:1868
+#: ../gui/wxpython/rlisetup/wizard.py:1897
+msgid "Width size:"
msgstr ""
-#: ../gui/wxpython/tplot/frame.py:199
-msgid "Coordinates can be obtained for example by right-clicking on Map Display."
+#: ../gui/wxpython/rlisetup/wizard.py:1869
+#: ../gui/wxpython/rlisetup/wizard.py:1898
+msgid "Height size:"
msgstr ""
-#: ../gui/wxpython/tplot/frame.py:214
-msgid "STRDS"
+#: ../gui/wxpython/rlisetup/wizard.py:1872
+msgid "Method of distribution:"
msgstr ""
-#: ../gui/wxpython/tplot/frame.py:222
-msgid ""
-"Vector temporal dataset (stvds)\n"
-"Press ENTER if you type the name of the stvds instead of selecting with the combobox"
+#: ../gui/wxpython/rlisetup/wizard.py:1875
+msgid "Number sampling units:"
msgstr ""
-#: ../gui/wxpython/tplot/frame.py:238
-msgid "Select attribute column"
+#: ../gui/wxpython/rlisetup/wizard.py:1878
+msgid "Distance between units:"
msgstr ""
-#: ../gui/wxpython/tplot/frame.py:251
-msgid "Select category of vector(s)"
+#: ../gui/wxpython/rlisetup/wizard.py:1881
+msgid "Number row strates:"
msgstr ""
-#: ../gui/wxpython/tplot/frame.py:269
-msgid "STVDS"
+#: ../gui/wxpython/rlisetup/wizard.py:1883
+msgid "Number column strates:"
msgstr ""
-#: ../gui/wxpython/tplot/frame.py:297 ../gui/wxpython/tplot/frame.py:717
-#: ../gui/wxpython/tplot/frame.py:721 ../gui/wxpython/tplot/frame.py:742
-#: ../gui/wxpython/tplot/frame.py:868
-msgid "Invalid input coordinates"
+#: ../gui/wxpython/iclass/dialogs.py:44 ../gui/wxpython/iclass/toolbars.py:40
+#: ../gui/wxpython/iscatt/toolbars.py:46
+msgid "Select imagery group"
msgstr ""
-#: ../gui/wxpython/tplot/frame.py:386
-msgid "Category {ca} is not on vector map {ma} and it will be used"
+#: ../gui/wxpython/iclass/dialogs.py:85
+msgid "Name of imagery group is missing."
msgstr ""
-#: ../gui/wxpython/tplot/frame.py:405
-msgid "Both coordinates and categories are set, coordinates will be used. The use categories remove text from coordinate form"
+#: ../gui/wxpython/iclass/dialogs.py:92
+msgid "Name of imagery group:"
msgstr ""
-#: ../gui/wxpython/tplot/frame.py:410
-msgid "With Vector temporal dataset you have to select an attribute column"
+#: ../gui/wxpython/iclass/dialogs.py:107
+msgid "Name of imagery subgroup:"
msgstr ""
-#: ../gui/wxpython/tplot/frame.py:462
-msgid "Difference number of vector layers and maps in the vector temporal dataset"
+#: ../gui/wxpython/iclass/dialogs.py:182
+msgid "Please choose a subgroup."
msgstr ""
-#: ../gui/wxpython/tplot/frame.py:504
-msgid "No connection between vector map {vmap} and layer {la}"
+#: ../gui/wxpython/iclass/dialogs.py:186
+#, python-format
+msgid "Subgroup <%s> not found in group <%s>"
msgstr ""
-#: ../gui/wxpython/tplot/frame.py:578 ../gui/wxpython/tplot/frame.py:620
-#: ../gui/wxpython/tplot/frame.py:663
-msgid "Problem getting data from raster temporal dataset. Empty list of values."
+#: ../gui/wxpython/iclass/dialogs.py:193
+#, python-format
+msgid ""
+"No data found in subgroup <%s> of group <%s>.\n"
msgstr ""
-#: ../gui/wxpython/tplot/frame.py:590 ../gui/wxpython/tplot/frame.py:637
-#: ../gui/wxpython/tplot/frame.py:675
+#: ../gui/wxpython/iclass/dialogs.py:198
#, python-format
-msgid "Temporal resolution: %s"
+msgid ""
+"No data found in group <%s>.\n"
msgstr ""
-#: ../gui/wxpython/tplot/frame.py:710
-msgid "Incorrect coordinates format, should be: x,y"
+#: ../gui/wxpython/iclass/dialogs.py:202
+#: ../gui/wxpython/iclass/g.gui.iclass.py:79
+#, python-format
+msgid "Group <%s> not found"
msgstr ""
-#: ../gui/wxpython/tplot/frame.py:726
-msgid "Seed point outside the current region"
+#: ../gui/wxpython/iclass/dialogs.py:250
+msgid "Name of map is missing."
msgstr ""
-#: ../gui/wxpython/tplot/frame.py:738
-msgid "Invalid input raster dataset"
+#: ../gui/wxpython/iclass/dialogs.py:257 ../gui/wxpython/gmodeler/dialogs.py:89
+msgid "Name of raster map:"
msgstr ""
-#: ../gui/wxpython/tplot/frame.py:755
-msgid "Invalid input vector dataset"
+#: ../gui/wxpython/iclass/dialogs.py:259 ../gui/wxpython/gmodeler/dialogs.py:91
+#: ../gui/wxpython/gui_core/dialogs.py:239
+msgid "Name of vector map:"
msgstr ""
-#: ../gui/wxpython/tplot/frame.py:861 ../gui/wxpython/tplot/frame.py:909
-msgid "Invalid input temporal dataset"
+#: ../gui/wxpython/iclass/dialogs.py:280 ../gui/wxpython/iclass/toolbars.py:37
+msgid "Class manager"
msgstr ""
-#: ../gui/wxpython/tplot/frame.py:930
-msgid "Datasets have different number of values"
+#: ../gui/wxpython/iclass/dialogs.py:295 ../gui/wxpython/iscatt/frame.py:140
+msgid "Classes"
msgstr ""
-#: ../gui/wxpython/tplot/frame.py:960
-msgid "Value for {date} is {val}"
+#: ../gui/wxpython/iclass/dialogs.py:395 ../gui/wxpython/iscatt/frame.py:413
+msgid "Class name"
msgstr ""
-#: ../gui/wxpython/tplot/frame.py:963
-msgid "Press Del to dismiss."
+#: ../gui/wxpython/iclass/dialogs.py:429 ../gui/wxpython/iscatt/frame.py:451
+msgid "Please use only ASCII characters."
msgstr ""
-#: ../gui/wxpython/tplot/g.gui.tplot.py:106
-msgid "With stvds you have to set 'attr' option"
+#: ../gui/wxpython/iclass/dialogs.py:545
+msgid "Zoom to training areas of selected class"
msgstr ""
-#: ../gui/wxpython/tplot/g.gui.tplot.py:110
-msgid "With stvds it is not possible to use 'coordinates' and 'cats' options together"
+#: ../gui/wxpython/iclass/dialogs.py:607
+msgid "Save signature file"
msgstr ""
-#: ../gui/wxpython/tplot/g.gui.tplot.py:113
-msgid "With stvds you have to use 'coordinates' or 'cats' option"
+#: ../gui/wxpython/iclass/dialogs.py:668
+msgid "Enter name of signature file:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:218
-msgid "Units:"
+#: ../gui/wxpython/iclass/dialogs.py:680
+msgid "Signature file path:"
msgstr ""
-msgid ""
-"Position of the top left corner\n"
-"from the top left edge of the paper"
+#: ../gui/wxpython/iclass/dialogs.py:730
+msgid "Export training areas"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:258
-msgid "Position is given:"
+#: ../gui/wxpython/iclass/dialogs.py:777 ../gui/wxpython/iscatt/dialogs.py:281
+msgid "Enter name of new vector map:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:260
-msgid "relative to paper"
+#: ../gui/wxpython/iclass/dialogs.py:793
+msgid "Export attribute table containing computed statistical data"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:262
-msgid "by map coordinates"
+#: ../gui/wxpython/iclass/dialogs.py:832
+#, python-format
+msgid "Vector map <%s> already exists. Do you want to overwrite it?"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:292
-msgid ""
-"Position from the top left\n"
-"edge of the paper"
+#: ../gui/wxpython/iclass/dialogs.py:835
+#, python-format
+msgid "Vector <%s> exists"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:383
-msgid "Font:"
+#: ../gui/wxpython/iclass/statistics.py:29
+msgid "Loading imagery lib failed"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:385 ../gui/wxpython/psmap/dialogs.py:4966
-#: ../gui/wxpython/gui_core/dialogs.py:2471
-msgid "Font size:"
+#: ../gui/wxpython/iclass/digit.py:61
+msgid "You are trying to create a training area outside the computational region. Please, use g.region to set the appropriate region first."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:411
-msgid "Choose color:"
+#: ../gui/wxpython/iclass/digit.py:72
+msgid ""
+"In order to create a training area, you have to select class first.\n"
+"\n"
+"There is no class yet, do you want to create one?"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:460
-msgid "Close dialog and apply changes"
+#: ../gui/wxpython/iclass/digit.py:76 ../gui/wxpython/iscatt/controllers.py:413
+msgid "No class selected"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:511
-msgid "Units"
+#: ../gui/wxpython/iclass/g.gui.iclass.py:75
+msgid "Name of subgroup required"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:513
-msgid "Orientation"
+#: ../gui/wxpython/iclass/g.gui.iclass.py:84
+#, python-format
+msgid "Subgroup <%s> not found"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:514 ../gui/wxpython/psmap/dialogs.py:2875
-msgid "Width"
+#: ../gui/wxpython/iclass/g.gui.iclass.py:91 ../gui/wxpython/nviz/wxnviz.py:344
+#: ../gui/wxpython/nviz/wxnviz.py:355
+#: ../gui/wxpython/mapswipe/g.gui.mapswipe.py:79
+#: ../gui/wxpython/modules/histogram.py:399
+#, python-format
+msgid "Raster map <%s> not found"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:515
-msgid "Height"
+#: ../gui/wxpython/iclass/g.gui.iclass.py:98 ../gui/wxpython/nviz/wxnviz.py:432
+#: ../gui/wxpython/dbmgr/g.gui.dbmgr.py:48
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:62
+#, python-format
+msgid "Vector map <%s> not found"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:516
-msgid "Left"
+#: ../gui/wxpython/iclass/g.gui.iclass.py:121
+#, python-format
+msgid "Loading raster map <%s>..."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:517
-msgid "Right"
+#: ../gui/wxpython/iclass/g.gui.iclass.py:124
+#, python-format
+msgid "Loading training map <%s>..."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:518
-#: ../gui/wxpython/location_wizard/dialogs.py:276
-msgid "Top"
+#: ../gui/wxpython/iclass/plots.py:73
+msgid "Histograms"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:519
-#: ../gui/wxpython/location_wizard/dialogs.py:284
-msgid "Bottom"
+#: ../gui/wxpython/iclass/plots.py:74
+msgid "Coincident plots"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:581
-msgid "Literal is not allowed!"
+#: ../gui/wxpython/iclass/plots.py:75
+msgid "Scatter plots"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:595
-msgid "Page size"
+#: ../gui/wxpython/iclass/plots.py:99
+#, python-format
+msgid ""
+"Scatter plot functionality is disabled.\n"
+"\n"
+"Reason: Unable to import packages needed for scatter plot.\n"
+"%s"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:599
-msgid "Margins"
+#: ../gui/wxpython/iclass/frame.py:39
+#, python-format
+msgid ""
+"Loading imagery lib failed.\n"
+"%s"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:606
-msgid "Portrait"
+#: ../gui/wxpython/iclass/frame.py:79
+msgid "GRASS GIS Supervised Classification Tool"
msgstr ""
-msgid "Landscape"
+#: ../gui/wxpython/iclass/frame.py:325
+msgid "IClass Toolbar"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:689 ../gui/wxpython/psmap/dialogs.py:710
-#: ../gui/wxpython/location_wizard/wizard.py:2199
-msgid "custom"
+#: ../gui/wxpython/iclass/frame.py:337
+msgid "IClass Misc Toolbar"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:752
-msgid "Map settings"
+#: ../gui/wxpython/iclass/frame.py:364
+msgid "Digitization Toolbar"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:762
-msgid "Map frame settings"
+#: ../gui/wxpython/iclass/frame.py:388
+msgid "Plots"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:820 ../gui/wxpython/psmap/dialogs.py:874
-#: ../gui/wxpython/psmap/toolbars.py:82 ../gui/wxpython/menustrings.py:2075
-msgid "Map frame"
+#: ../gui/wxpython/iclass/frame.py:408
+msgid "Preview Display"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:880
-msgid "Map frame options:"
+#: ../gui/wxpython/iclass/frame.py:411
+msgid "Training Areas Display"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:881
-msgid "fit frame to match selected map"
+#: ../gui/wxpython/iclass/frame.py:485
+msgid "Adjust Training Area Display to Preview Display"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:882
-msgid "fit frame to match saved region"
+#: ../gui/wxpython/iclass/frame.py:487
+msgid "Adjust Preview display to Training Area Display"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:883
-msgid "fit frame to match current computational region"
+#: ../gui/wxpython/iclass/frame.py:489
+msgid "Display synchronization ON"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:884
-msgid "fixed scale and map center"
+#: ../gui/wxpython/iclass/frame.py:491
+msgid "Display synchronization OFF"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:901 ../gui/wxpython/psmap/dialogs.py:1211
-msgid "Map selection"
+#: ../gui/wxpython/iclass/frame.py:564
+msgid "All changes will be lost. Do you want to continue?"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:907 ../gui/wxpython/gcp/manager.py:360
-#: ../gui/wxpython/gmodeler/frame.py:1650
-#: ../gui/wxpython/gui_core/dialogs.py:1452
-#: ../gui/wxpython/gui_core/dialogs.py:1697
-msgid "raster"
+#: ../gui/wxpython/iclass/frame.py:573
+msgid "Import vector map"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:910 ../gui/wxpython/gcp/manager.py:360
-#: ../gui/wxpython/gmodeler/frame.py:1651
-msgid "vector"
+#: ../gui/wxpython/iclass/frame.py:593
+#, python-format
+msgid "No areas in vector map <%s>.\n"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:914 ../gui/wxpython/psmap/dialogs.py:1702
-msgid "Map:"
+#: ../gui/wxpython/iclass/frame.py:595
+#, python-format
+msgid "Vector map <%s> contains points or lines, these features are ignored."
msgstr ""
-msgid "Region:"
+#: ../gui/wxpython/iclass/frame.py:622
+#, python-format
+msgid "Unable to open vector map <%s>"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:971
-msgid "Map scale and center"
+#: ../gui/wxpython/iclass/frame.py:633
+#, python-format
+msgid "Unable to copy vector features from <%s>"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:975
-msgid "Center:"
+#: ../gui/wxpython/iclass/frame.py:645
+msgid "Unable to open temporary vector map"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:976
-msgid "E:"
+#: ../gui/wxpython/iclass/frame.py:741
+msgid "No training areas to export."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:977
-msgid "N:"
+#: ../gui/wxpython/iclass/frame.py:754
+#, python-format
+msgid "%d training areas (%d classes) exported to vector map <%s>."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:984 ../gui/wxpython/psmap/dialogs.py:5847
-msgid "Scale:"
+#: ../gui/wxpython/iclass/frame.py:994
+msgid "Failed to create temporary vector map."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:985
-msgid "1 :"
+#: ../gui/wxpython/iclass/frame.py:1090
+#, python-format
+msgid "No area in category %s. Category skipped."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1049
-msgid "Map max resolution (dpi):"
+#: ../gui/wxpython/iclass/frame.py:1094
+msgid "Analysis failed."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1086 ../gui/wxpython/psmap/dialogs.py:3696
-msgid "Border"
+#: ../gui/wxpython/iclass/frame.py:1101
+msgid "results"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1092
-msgid "draw border around map frame"
+#: ../gui/wxpython/iclass/frame.py:1107
+msgid "No imagery group selected."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1099
-msgid "border color:"
+#: ../gui/wxpython/iclass/frame.py:1114
+msgid "Due to recent changes in classes, signatures can be outdated and should be recalculated. Do you still want to continue?"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1101
-msgid "border width (pts):"
+#: ../gui/wxpython/iclass/frame.py:1117
+msgid "Outdated signatures"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1220
+#: ../gui/wxpython/iclass/frame.py:1135
+#, python-format
msgid ""
-"Region is set to match this map,\n"
-"raster or vector map must be added later"
+"A signature file named %s already exists.\n"
+"Do you want to replace it?"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1227
-msgid "Region selection"
+#: ../gui/wxpython/iclass/frame.py:1138 ../gui/wxpython/gmodeler/frame.py:525
+msgid "File already exists"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1407
-msgid "No map selected!"
+#: ../gui/wxpython/iclass/frame.py:1188
+msgid "No imagery group selected. Operation canceled."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1431
-msgid "No region selected!"
+#: ../gui/wxpython/iclass/frame.py:1199
+#, python-format
+msgid "Group <%(group)s> does not have enough files (it has %(files)d files). Operation canceled."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1482
-msgid "Invalid scale or map center!"
+#: ../gui/wxpython/iclass/frame.py:1207
+msgid "No areas given. Operation canceled."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1552
-msgid "Choose raster map"
+#: ../gui/wxpython/iclass/frame.py:1222
+msgid "Vector features are outside raster layers. Operation canceled."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1557
-msgid "no raster map"
+#: ../gui/wxpython/iclass/toolbars.py:34
+msgid "Set opacity level"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1560
-msgid "raster:"
+#: ../gui/wxpython/iclass/toolbars.py:43
+msgid "Run analysis, update histogram and coincidence plots"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1622 ../gui/wxpython/psmap/frame.py:635
-#: ../gui/wxpython/psmap/frame.py:660
-msgid "Please, create map frame first."
+#: ../gui/wxpython/iclass/toolbars.py:46
+msgid "Save signature file for i.maxlik"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1685 ../gui/wxpython/gmodeler/model.py:797
-msgid "Vector maps"
+#: ../gui/wxpython/iclass/toolbars.py:49
+msgid "Remove selected map layer"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1698
-msgid "Add map"
+#: ../gui/wxpython/iclass/toolbars.py:52
+msgid "Export training areas to vector map"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1706 ../gui/wxpython/psmap/dialogs.py:2167
-msgid "points"
+#: ../gui/wxpython/iclass/toolbars.py:55
+msgid "Import training areas from vector map"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1706 ../gui/wxpython/psmap/dialogs.py:2169
-msgid "lines"
+#: ../gui/wxpython/iclass/toolbars.py:76
+msgid "Training"
msgstr ""
-msgid "areas"
+#: ../gui/wxpython/modules/colorrules.py:582
+msgid "Preview"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1712
-msgid "Data Type"
+#: ../gui/wxpython/iclass/toolbars.py:82
+msgid "Set map canvas for "
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1746
-msgid "Manage vector maps"
+#: ../gui/wxpython/iclass/toolbars.py:84
+msgid "/ Zoom to map"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1751
-msgid "The topmost vector map overlaps the others"
+#: ../gui/wxpython/iclass/toolbars.py:260
+#: ../gui/wxpython/iclass/toolbars.py:269
+msgid "std dev"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1755 ../gui/wxpython/psmap/dialogs.py:3653
-#: ../gui/wxpython/web_services/widgets.py:255
-msgid "Up"
+#: ../gui/wxpython/iclass/toolbars.py:343
+msgid "Add raster map"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1756 ../gui/wxpython/psmap/dialogs.py:3654
-#: ../gui/wxpython/web_services/widgets.py:257
-msgid "Down"
+#: ../gui/wxpython/rdigit/controller.py:123
+msgid "Please select first the raster map"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1758
-msgid "Properties..."
+#: ../gui/wxpython/rdigit/controller.py:155
+msgid "Right click to finish area"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2001
-msgid "Raster map settings"
+#: ../gui/wxpython/rdigit/controller.py:160
+msgid "Right click to finish line"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2049
-msgid "Vector maps settings"
+#: ../gui/wxpython/rdigit/controller.py:303
+msgid "Do you want to save changes?"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2097
-#, python-format
-msgid "%s properties"
+#: ../gui/wxpython/rdigit/controller.py:304
+msgid "Save raster map changes"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2152
-msgid "Data selection"
+#: ../gui/wxpython/rdigit/controller.py:378
+msgid "Failed to create backup copy of edited raster map."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2163
-#: ../gui/wxpython/modules/import_export.py:75
-#: ../gui/wxpython/gui_core/forms.py:2014
-msgid "Feature type"
+#: ../gui/wxpython/rdigit/controller.py:397
+msgid "Failed to create new raster map."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2167
-msgid "centroids"
+#: ../gui/wxpython/rdigit/controller.py:488
+#: ../gui/wxpython/rdigit/controller.py:516
+msgid "Rasterizing..."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2169
-msgid "boundaries"
+#: ../gui/wxpython/rdigit/controller.py:556
+msgid "Failed to set default color table for edited raster map"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2207
-msgid "Layer selection"
+#: ../gui/wxpython/rdigit/dialogs.py:34
+msgid "Create new raster map"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2214
-msgid "Database connection is not defined in DB file."
+#: ../gui/wxpython/rdigit/dialogs.py:53
+msgid "Name for new raster map:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2215
-msgid "Select layer:"
+#: ../gui/wxpython/rdigit/dialogs.py:58
+msgid "Optionally select background raster map:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2244
-msgid "list of categories (e.g. 1,3,5-7)"
+#: ../gui/wxpython/rdigit/dialogs.py:62
+msgid "New raster map type:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2301
-msgid "Use current mask"
+#: ../gui/wxpython/rdigit/dialogs.py:92
+msgid "Please specify name for a new raster map"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2320 ../gui/wxpython/psmap/dialogs.py:2476
-msgid "Colors"
+#: ../gui/wxpython/rdigit/dialogs.py:100
+#, python-format
+msgid "Raster map <%s> already exists in the current mapset. Do you want to overwrite it?"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2329 ../gui/wxpython/psmap/dialogs.py:2485
-msgid "Outline"
+#: ../gui/wxpython/rdigit/toolbars.py:27
+msgid "Digitize area"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2334 ../gui/wxpython/psmap/dialogs.py:2495
-msgid "draw outline"
+#: ../gui/wxpython/rdigit/toolbars.py:29
+msgid "Digitize line"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2337 ../gui/wxpython/psmap/dialogs.py:2500
-#: ../gui/wxpython/psmap/dialogs.py:5272 ../gui/wxpython/psmap/dialogs.py:5280
-msgid "Width (pts):"
+#: ../gui/wxpython/rdigit/toolbars.py:31
+msgid "Digitize point"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2401 ../gui/wxpython/psmap/dialogs.py:2562
-#: ../gui/wxpython/wxplot/dialogs.py:1137
-#: ../gui/wxpython/wxplot/dialogs.py:1218
-msgid "Fill"
+#: ../gui/wxpython/rdigit/toolbars.py:32
+msgid "Save raster map"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2406
-msgid "fill color"
+#: ../gui/wxpython/rdigit/toolbars.py:33 ../gui/wxpython/vdigit/toolbars.py:184
+msgid "Undo"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2412 ../gui/wxpython/psmap/dialogs.py:2570
-msgid "choose color:"
+#: ../gui/wxpython/rdigit/toolbars.py:34
+msgid "Quit raster digitizer"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2427 ../gui/wxpython/psmap/dialogs.py:2586
-msgid "color from map table column:"
+#: ../gui/wxpython/rdigit/toolbars.py:50
+msgid "Select raster map"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2498
-msgid "No effect for fill color from table column"
+#: ../gui/wxpython/rdigit/toolbars.py:65
+msgid "Set drawing color (not raster cell color)"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2567
-msgid "Color of lines:"
+#: ../gui/wxpython/rdigit/toolbars.py:86
+msgid "Cell value:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2634 ../gui/wxpython/psmap/dialogs.py:2866
-#: ../gui/wxpython/psmap/dialogs.py:2991
-msgid "Size and style"
+#: ../gui/wxpython/rdigit/toolbars.py:99
+msgid "Width of currently digitized line or diameter of a digitized point in map units."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2662
-msgid "eps file:"
+#: ../gui/wxpython/rdigit/toolbars.py:138
+msgid "New raster map"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2667 ../gui/wxpython/psmap/dialogs.py:3009
-msgid "Type filename or click browse to choose file"
+#: ../gui/wxpython/nviz/mapwindow.py:244
+msgid "Opening 3D view was not successful. Please try to change the value of depth buffer in GUI Settings dialog > tab Map Display > Advanced and restart GUI."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2668 ../gui/wxpython/psmap/dialogs.py:3010
-msgid "Choose a file"
+#: ../gui/wxpython/nviz/mapwindow.py:509
+#, python-format
+msgid "Image is too large, your OpenGL implementation supports maximum texture size %d px."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2717 ../gui/wxpython/psmap/dialogs.py:3791
-#: ../gui/wxpython/psmap/dialogs.py:4839 ../gui/wxpython/wxplot/dialogs.py:1123
-#: ../gui/wxpython/wxplot/dialogs.py:1204
-msgid "Size"
+#: ../gui/wxpython/nviz/mapwindow.py:1021
+msgid "Easting"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2727
-msgid "size from map table column:"
+#: ../gui/wxpython/nviz/mapwindow.py:1022
+msgid "Northing"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2729
-msgid "scale:"
+#: ../gui/wxpython/nviz/mapwindow.py:1023
+msgid "Elevation"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2794
-msgid "Rotation"
+#: ../gui/wxpython/nviz/mapwindow.py:1029
+msgid "Surface map name"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2799
-msgid "rotate symbols:"
+#: ../gui/wxpython/nviz/mapwindow.py:1032
+msgid "Surface map elevation"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2801
-msgid "counterclockwise in degrees:"
+#: ../gui/wxpython/nviz/mapwindow.py:1034
+msgid "Surface map color"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2805
-msgid "from map table column:"
+#: ../gui/wxpython/nviz/mapwindow.py:1045
+msgid "XY distance from previous"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2880
-msgid "Set width (pts):"
+#: ../gui/wxpython/nviz/mapwindow.py:1048
+msgid "XYZ distance from previous"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2897
-msgid "multiply width by category value"
+#: ../gui/wxpython/nviz/mapwindow.py:1051
+msgid "Distance along surface"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2929 ../gui/wxpython/psmap/dialogs.py:6794
-#: ../gui/wxpython/wxplot/dialogs.py:1072
-msgid "Line style"
+#: ../gui/wxpython/nviz/mapwindow.py:1055
+msgid "Distance along exag. surface"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2934
-msgid "Choose line style:"
+#: ../gui/wxpython/nviz/mapwindow.py:1059
+msgid "No point on surface"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2947
-msgid "Choose linecap:"
+#: ../gui/wxpython/nviz/mapwindow.py:1539
+msgid "Loading raster map"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3000
-msgid "Pattern"
+#: ../gui/wxpython/nviz/mapwindow.py:1543
+msgid "Loading 3d raster map"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3005
-msgid "use pattern:"
+#: ../gui/wxpython/nviz/mapwindow.py:1551
+msgid "failed"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3007
-msgid "Choose pattern file:"
+#: ../gui/wxpython/nviz/mapwindow.py:1554
+#, python-format
+msgid "Unsupported layer type '%s'"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3015
-msgid "pattern line width (pts):"
+#: ../gui/wxpython/nviz/mapwindow.py:1674
+msgid "Unable to unload raster map"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3019
-msgid "pattern scale factor:"
+#: ../gui/wxpython/nviz/mapwindow.py:1679
+msgid "Unable to unload 3d raster map"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3379
-msgid "Raster legend"
+#: ../gui/wxpython/nviz/mapwindow.py:1680
+msgid "3d raster map"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3398
-msgid "Source raster"
+#: ../gui/wxpython/nviz/mapwindow.py:1692
+msgid "unloaded successfully"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3403
-msgid "current raster"
+#: ../gui/wxpython/nviz/mapwindow.py:1748
+#, python-format
+msgid "Loading vector map <%(name)s> (%(type)s) failed"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3406
-msgid "select raster"
+#: ../gui/wxpython/nviz/mapwindow.py:1811
+#, python-format
+msgid "Unable to unload vector map <%(name)s> (%(type)s)"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3413 ../gui/wxpython/psmap/dialogs.py:4428
+#: ../gui/wxpython/nviz/mapwindow.py:1815
#, python-format
-msgid "%(rast)s: type %(type)s"
+msgid "Vector map <%(name)s> (%(type)s) unloaded successfully"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3462
-msgid "Type of legend"
+#: ../gui/wxpython/nviz/mapwindow.py:2192
+#, python-format
+msgid "Vector point layer not found (id = %d)"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3467
-msgid "discrete legend (categorical maps)"
+#: ../gui/wxpython/nviz/mapwindow.py:2194
+#, python-format
+msgid "Unable to set data layer properties (id = %d)"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3471
-msgid "continuous color gradient legend (floating point map)"
+#: ../gui/wxpython/nviz/mapwindow.py:2198
+#, python-format
+msgid ""
+"Setting data layer properties failed.\n"
+"\n"
+"%s"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3497
-msgid "Advanced legend settings"
+#: ../gui/wxpython/nviz/mapwindow.py:2253
+#: ../gui/wxpython/nviz/mapwindow.py:2272 ../gui/wxpython/nviz/tools.py:2679
+#: ../gui/wxpython/nviz/tools.py:2728 ../gui/wxpython/nviz/tools.py:5172
+msgid "constant#"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3502
-msgid "draw \"no data\" box"
+#: ../gui/wxpython/nviz/tools.py:92 ../gui/wxpython/nviz/preferences.py:69
+#: ../gui/wxpython/nviz/preferences.py:74
+msgid "View"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3511
-msgid "draw ticks across color table"
+#: ../gui/wxpython/nviz/tools.py:100
+#: ../gui/wxpython/gui_core/preferences.py:464
+msgid "Appearance"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3524
-#: ../gui/wxpython/modules/colorrules.py:972
-#: ../gui/wxpython/modules/colorrules.py:1654
-#: ../gui/wxpython/modules/colorrules.py:1658
-msgid "range"
+#: ../gui/wxpython/nviz/tools.py:104
+msgid "Analysis"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3603
-msgid "Vector legend"
+#: ../gui/wxpython/nviz/tools.py:107 ../gui/wxpython/nviz/tools.py:502
+msgid "Animation"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3608
-msgid "Show vector legend"
+#: ../gui/wxpython/nviz/tools.py:252
+msgid "Control View"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3622
-msgid "Source vector maps"
+#: ../gui/wxpython/nviz/tools.py:276
+msgid "Adjusts the distance and angular perspective of the image viewpoint"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3627
-msgid "Choose vector maps and their order in legend"
+#: ../gui/wxpython/nviz/tools.py:292 ../gui/wxpython/nviz/preferences.py:86
+msgid "Perspective:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3632
-#: ../gui/wxpython/gmodeler/dialogs.py:492
-#: ../gui/wxpython/gmodeler/dialogs.py:604
-#: ../gui/wxpython/gmodeler/frame.py:1790
-msgid "Label"
+#: ../gui/wxpython/nviz/tools.py:304
+msgid "Tilts the plane of the surface from the horizontal"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3655 ../gui/wxpython/psmap/dialogs.py:4135
-msgid "Edit label"
+#: ../gui/wxpython/nviz/tools.py:316 ../gui/wxpython/nviz/tools.py:1263
+msgid "Tilt:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3701
-msgid "draw border around legend"
+#: ../gui/wxpython/nviz/tools.py:329
+msgid "Adjusts the viewing height above the surface (angle of view automatically adjusts to maintain the same center of view)"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3759
-msgid "Size and position"
+#: ../gui/wxpython/nviz/tools.py:345
+msgid "Adjusts the relative height of features above the plane of the surface"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3829
-msgid "Leave the edit field empty, to use default values."
+#: ../gui/wxpython/nviz/tools.py:387 ../gui/wxpython/nviz/preferences.py:176
+msgid "Z-exag:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3869
-msgid ""
-"Width of the color symbol (for lines)\n"
-"in front of the legend text"
+#: ../gui/wxpython/nviz/tools.py:412
+msgid "Look:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3875 ../gui/wxpython/psmap/dialogs.py:4040
-msgid "Columns:"
+#: ../gui/wxpython/nviz/tools.py:415
+msgid "here"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3885
-msgid "column span:"
+#: ../gui/wxpython/nviz/tools.py:418
+msgid "Allows you to select a point on the surface that becomes the new center of view. Click on the button and then on the surface."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3887
-msgid ""
-"Column separation distance between the left edges\n"
-"of two columns in a multicolumn legend"
+#: ../gui/wxpython/nviz/tools.py:424
+msgid "center"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3934 ../gui/wxpython/psmap/dialogs.py:4541
-#: ../gui/wxpython/psmap/dialogs.py:5205 ../gui/wxpython/wxplot/dialogs.py:751
-#: ../gui/wxpython/gui_core/preferences.py:507
-#: ../gui/wxpython/gui_core/preferences.py:787
-#: ../gui/wxpython/gui_core/dialogs.py:2416
-msgid "Font settings"
+#: ../gui/wxpython/nviz/tools.py:428
+msgid "Resets the view to the original default center of view"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4134
-msgid "Edit legend label:"
+#: ../gui/wxpython/nviz/tools.py:432
+msgid "top"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4181
-msgid "No raster map selected!"
+#: ../gui/wxpython/nviz/tools.py:436
+msgid "Sets the viewer directly over the scene's center position. This top view orients approximately north south."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4182
-msgid "No raster"
+#: ../gui/wxpython/nviz/tools.py:440
+msgid "reset"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4472
-msgid "Mapinfo settings"
+#: ../gui/wxpython/nviz/tools.py:441
+msgid "Reset to default view"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4576
-msgid "Color settings"
+#: ../gui/wxpython/nviz/tools.py:458 ../gui/wxpython/nviz/preferences.py:198
+msgid "Image Appearance"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4582
-msgid "use border color:"
+#: ../gui/wxpython/nviz/tools.py:465 ../gui/wxpython/nviz/preferences.py:204
+#: ../gui/wxpython/animation/dialogs.py:1864
+#: ../gui/wxpython/web_services/widgets.py:305
+#: ../gui/wxpython/gui_core/preferences.py:856
+msgid "Background color:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4584
-msgid "use background color:"
+#: ../gui/wxpython/nviz/tools.py:510
+msgid "Press 'Record' button and start changing the view. It is recommended to use fly-through mode (Map Display toolbar) to achieve smooth motion."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4843
-msgid "Length:"
+#: ../gui/wxpython/nviz/tools.py:521
+msgid "Record"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4849
-msgid "Scalebar length is given in map units"
+#: ../gui/wxpython/nviz/tools.py:523
+msgid "Play"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4854
-msgid "Scalebar height is real height on paper"
+#: ../gui/wxpython/nviz/tools.py:525 ../gui/wxpython/animation/toolbars.py:42
+msgid "Pause"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4856
-msgid "default"
+#: ../gui/wxpython/nviz/tools.py:527 ../gui/wxpython/animation/toolbars.py:39
+msgid "Stop"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4929 ../gui/wxpython/wxplot/dialogs.py:1164
-#: ../gui/wxpython/wxplot/dialogs.py:1245
-msgid "Style"
+#: ../gui/wxpython/nviz/tools.py:544
+msgid "Total number of frames :"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4933
-msgid "Type:"
+#: ../gui/wxpython/nviz/tools.py:551
+msgid "Frame rate (FPS):"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4952
-msgid "Number of segments:"
+#: ../gui/wxpython/nviz/tools.py:559
+msgid "Frames are recorded with given frequency (FPS). "
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4958
-msgid "Label every "
+#: ../gui/wxpython/nviz/tools.py:615
+msgid "Save image sequence"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4959
-msgid "segments"
+#: ../gui/wxpython/nviz/tools.py:625
+msgid "Choose a directory for images"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4972
-msgid "transparent text background"
+#: ../gui/wxpython/nviz/tools.py:632 ../gui/wxpython/animation/dialogs.py:1187
+msgid "File prefix:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5090
-msgid "Length of scale bar is not defined"
+#: ../gui/wxpython/nviz/tools.py:638
+msgid "Generated files names will look like this: prefix_1.ppm, prefix_2.ppm, ..."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5184
-msgid "Enter text:"
+#: ../gui/wxpython/nviz/tools.py:640 ../gui/wxpython/animation/dialogs.py:1191
+msgid "File format:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5255
-msgid "Text effects"
+#: ../gui/wxpython/nviz/tools.py:705 ../gui/wxpython/nviz/tools.py:2236
+#: ../gui/wxpython/nviz/preferences.py:398
+msgid "Surface"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5261
-msgid "text background"
+#: ../gui/wxpython/nviz/tools.py:713 ../gui/wxpython/nviz/tools.py:1345
+msgid "Constant surface"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5266
-msgid "highlight"
+#: ../gui/wxpython/nviz/tools.py:720 ../gui/wxpython/nviz/preferences.py:546
+msgid "Vector"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5275
-msgid "text border"
+#: ../gui/wxpython/nviz/tools.py:728 ../gui/wxpython/gui_core/dialogs.py:1452
+msgid "3D raster"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5384
-msgid "Offset"
+#: ../gui/wxpython/nviz/tools.py:766 ../gui/wxpython/nviz/preferences.py:287
+msgid "Lighting"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5388
-msgid "horizontal (pts):"
+#: ../gui/wxpython/nviz/tools.py:773
+msgid "Fringe"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5390
-msgid "vertical (pts):"
+#: ../gui/wxpython/nviz/tools.py:782 ../gui/wxpython/animation/dialogs.py:929
+msgid "Decorations"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5429
-msgid " Reference point"
+#: ../gui/wxpython/nviz/tools.py:804 ../gui/wxpython/nviz/tools.py:1146
+msgid "Cutting planes"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5483
-msgid "Text rotation"
+#: ../gui/wxpython/nviz/tools.py:856 ../gui/wxpython/nviz/tools.py:1896
+#: ../gui/wxpython/nviz/preferences.py:414
+msgid "Mode:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5489
-msgid "rotate text (counterclockwise)"
+#: ../gui/wxpython/nviz/tools.py:859 ../gui/wxpython/nviz/preferences.py:420
+msgid "coarse"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5581
-msgid "No text entered!"
+#: ../gui/wxpython/nviz/tools.py:860 ../gui/wxpython/nviz/preferences.py:421
+msgid "fine"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5782
-msgid "Choose a directory with images"
+#: ../gui/wxpython/nviz/tools.py:861 ../gui/wxpython/nviz/preferences.py:422
+msgid "both"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5825
-msgid "Note: only EPS format supported"
+#: ../gui/wxpython/nviz/tools.py:871 ../gui/wxpython/nviz/tools.py:1162
+#: ../gui/wxpython/nviz/tools.py:1910
+msgid "Shading:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5841
-msgid "Scale And Rotation"
+#: ../gui/wxpython/nviz/tools.py:874 ../gui/wxpython/nviz/tools.py:1913
+msgid "flat"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5882 ../gui/wxpython/psmap/dialogs.py:6464
-msgid "Rotation angle (deg):"
+#: ../gui/wxpython/nviz/tools.py:875 ../gui/wxpython/nviz/tools.py:1914
+msgid "gouraud"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5898 ../gui/wxpython/psmap/dialogs.py:6486
-msgid "Counterclockwise rotation in degrees"
+#: ../gui/wxpython/nviz/tools.py:883
+msgid "Set to all"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6024
-msgid ""
-"PIL\n"
-"missing"
+#: ../gui/wxpython/nviz/tools.py:884
+msgid "Use draw settings for all loaded surfaces"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6044
-#, python-format
-msgid "Unable to read file %s"
+#: ../gui/wxpython/nviz/tools.py:896 ../gui/wxpython/nviz/preferences.py:466
+msgid "Coarse mode:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6105
-#, python-format
-msgid "size: %(width)s x %(height)s pts"
+#: ../gui/wxpython/nviz/tools.py:899 ../gui/wxpython/nviz/tools.py:945
+#: ../gui/wxpython/nviz/preferences.py:447
+#: ../gui/wxpython/nviz/preferences.py:478
+msgid "resolution:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6127
-msgid "No image selected."
+#: ../gui/wxpython/nviz/tools.py:914 ../gui/wxpython/nviz/preferences.py:496
+msgid "style:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6234
-msgid "North Arrow settings"
+#: ../gui/wxpython/nviz/tools.py:917 ../gui/wxpython/nviz/preferences.py:502
+msgid "wire"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6245
-msgid "Compute convergence"
+#: ../gui/wxpython/nviz/tools.py:918 ../gui/wxpython/nviz/preferences.py:503
+msgid "surface"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6316
-msgid "Symbol"
+#: ../gui/wxpython/nviz/tools.py:930
+msgid "Change wire color"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6323
-msgid "Select symbol:"
+#: ../gui/wxpython/nviz/tools.py:941 ../gui/wxpython/nviz/preferences.py:435
+msgid "Fine mode:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6340
-msgid ""
-"Note: Selected symbol is not displayed\n"
-"in draft mode (only in preview mode)"
+#: ../gui/wxpython/nviz/tools.py:969
+msgid "Surface attributes"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6373 ../gui/wxpython/psmap/dialogs.py:6732
-msgid "Outline color:"
+#: ../gui/wxpython/nviz/tools.py:978 ../gui/wxpython/nviz/tools.py:2818
+msgid "Transparency"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6376 ../gui/wxpython/psmap/dialogs.py:6403
-#: ../gui/wxpython/psmap/dialogs.py:6735 ../gui/wxpython/psmap/dialogs.py:6765
-#: ../gui/wxpython/gui_core/dialogs.py:1778
-msgid "transparent"
+#: ../gui/wxpython/nviz/tools.py:979 ../gui/wxpython/nviz/tools.py:2819
+msgid "Shininess"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6400 ../gui/wxpython/psmap/dialogs.py:6762
-msgid "Fill color:"
+#: ../gui/wxpython/nviz/tools.py:985 ../gui/wxpython/nviz/tools.py:2839
+msgid "map"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6439
-msgid "Size and Rotation"
+#: ../gui/wxpython/nviz/tools.py:988 ../gui/wxpython/nviz/tools.py:2844
+msgid "unset"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6447
-msgid "Size (pt):"
+#: ../gui/wxpython/nviz/tools.py:993 ../gui/wxpython/nviz/tools.py:2849
+msgid "constant"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6450
-msgid "Symbol size in points"
+#: ../gui/wxpython/nviz/tools.py:1055
+msgid "Changes the x, y, and z position of the current surface"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6685
-msgid "Rectangle settings"
+#: ../gui/wxpython/nviz/tools.py:1072 ../gui/wxpython/nviz/tools.py:1322
+#: ../gui/wxpython/nviz/tools.py:2041 ../gui/wxpython/nviz/tools.py:3042
+msgid "Reset"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6687
-msgid "Line settings"
+#: ../gui/wxpython/nviz/tools.py:1073 ../gui/wxpython/nviz/tools.py:2042
+msgid "Reset to default position"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6821
-msgid "Line width in points"
+#: ../gui/wxpython/nviz/tools.py:1152
+msgid "Active cutting plane:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6895
-msgid "Vector labels"
+#: ../gui/wxpython/nviz/tools.py:1164
+msgid "clear"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6915
-msgid "Vector label files created beforehand by v.label module"
+#: ../gui/wxpython/nviz/tools.py:1165
+msgid "top color"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6932
-msgid "You can select multiple label files."
+#: ../gui/wxpython/nviz/tools.py:1166
+msgid "bottom color"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:53
-msgid "GRASS GIS Cartographic Composer"
+#: ../gui/wxpython/nviz/tools.py:1167
+msgid "blend"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:213
-msgid ""
-"Python Imaging Library is not available.\n"
-"'Preview' functionality won't work."
+#: ../gui/wxpython/nviz/tools.py:1168
+msgid "shaded"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:267
-msgid "Program ps2pdf is not available. Please install it first to create PDF."
+#: ../gui/wxpython/nviz/tools.py:1180
+msgid "Horizontal X:"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:311
-msgid "Generating PDF..."
+#: ../gui/wxpython/nviz/tools.py:1182
+msgid "Sets the X coordinate of the current cutting plane"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:313
-msgid "Generating PostScript..."
+#: ../gui/wxpython/nviz/tools.py:1210
+msgid "Horizontal Y:"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:315
-msgid "Generating preview..."
+#: ../gui/wxpython/nviz/tools.py:1212
+msgid "Sets the Y coordinate of the current cutting plane"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:332
-#, python-format
-msgid "Ps.map exited with return code %s"
+#: ../gui/wxpython/nviz/tools.py:1241
+msgid "Rotation:"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:368
-#, python-format
-msgid "%(prg)s exited with return code %(code)s"
+#: ../gui/wxpython/nviz/tools.py:1243
+msgid "Rotates the current cutting plane about vertical axis"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:372
-msgid "PDF generated"
+#: ../gui/wxpython/nviz/tools.py:1265
+msgid "Rotates the current cutting plane about horizontal axis"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:375
-#, python-format
-msgid ""
-"Program ps2pdf is not available. Please install it to create PDF.\n"
-"\n"
-" %s"
+#: ../gui/wxpython/nviz/tools.py:1288
+msgid "Sets the Z coordinate of the current cutting plane (only meaningful when tilt is not 0)"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:378
-msgid "PostScript file generated"
+#: ../gui/wxpython/nviz/tools.py:1360 ../gui/wxpython/menustrings.py:6
+#: ../gui/wxpython/menustrings.py:1935
+msgid "New"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:387
-msgid "Generating preview, wait please"
+#: ../gui/wxpython/nviz/tools.py:1385
+msgid "Fine resolution:"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:403
-msgid "Preview not available"
+#: ../gui/wxpython/nviz/tools.py:1399
+msgid "Value:"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:405
-msgid "Preview is not available probably because Ghostscript is not installed or not on PATH."
+#: ../gui/wxpython/nviz/tools.py:1411 ../gui/wxpython/nviz/tools.py:3031
+msgid "Transparency:"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:408
-msgid "Please follow instructions on GRASS Trac Wiki."
+#: ../gui/wxpython/nviz/tools.py:1477
+msgid "Show vector lines"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:419
-msgid "Preview generated"
+#: ../gui/wxpython/nviz/tools.py:1487 ../gui/wxpython/nviz/preferences.py:552
+msgid "Vector lines"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:451
-msgid "Save file as"
+#: ../gui/wxpython/nviz/tools.py:1493
+msgid "Line:"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:498
-#, python-format
-msgid "Failed to read file %s."
+#: ../gui/wxpython/nviz/tools.py:1496
+msgid "width:"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:677
-msgid "Scalebar is not appropriate for this projection"
+#: ../gui/wxpython/nviz/tools.py:1512 ../gui/wxpython/nviz/tools.py:1684
+msgid "color:"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1166
-msgid "Press button with green triangle icon to generate preview."
+#: ../gui/wxpython/nviz/tools.py:1529 ../gui/wxpython/nviz/tools.py:1733
+msgid "use color for thematic mapping"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1189
-msgid "wxGUI Cartographic Composer"
+#: ../gui/wxpython/nviz/tools.py:1532
+msgid "use width for thematic mapping"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1240
-msgid "MAP FRAME"
+#: ../gui/wxpython/nviz/tools.py:1547 ../gui/wxpython/nviz/tools.py:1560
+#: ../gui/wxpython/nviz/tools.py:1756 ../gui/wxpython/nviz/tools.py:1773
+msgid "Set options..."
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1241
-msgid "RASTER LEGEND"
+#: ../gui/wxpython/nviz/tools.py:1574 ../gui/wxpython/nviz/tools.py:1788
+#: ../gui/wxpython/vdigit/preferences.py:161
+msgid "Display"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1242
-msgid "VECTOR LEGEND"
+#: ../gui/wxpython/nviz/tools.py:1579 ../gui/wxpython/nviz/tools.py:5442
+#: ../gui/wxpython/nviz/tools.py:5497
+msgid "on surface(s):"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1243
-msgid "MAP INFO"
+#: ../gui/wxpython/nviz/tools.py:1580 ../gui/wxpython/nviz/tools.py:5442
+msgid "as 3D"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1244
-msgid "SCALE BAR"
+#: ../gui/wxpython/nviz/tools.py:1589 ../gui/wxpython/nviz/tools.py:1796
+msgid "Height above surface:"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1245
-msgid "IMAGE"
+#: ../gui/wxpython/nviz/tools.py:1640
+msgid "Show vector points"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1246
-msgid "NORTH ARROW"
+#: ../gui/wxpython/nviz/tools.py:1649 ../gui/wxpython/nviz/preferences.py:592
+msgid "Vector points"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1522
-msgid "Click and drag to resize object"
+#: ../gui/wxpython/nviz/tools.py:1656
+msgid "Icon:"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:2467
-msgid "labels: "
+#: ../gui/wxpython/nviz/tools.py:1736
+msgid "use size for thematic mapping"
msgstr ""
-#: ../gui/wxpython/psmap/utils.py:105
-msgid "inch"
+#: ../gui/wxpython/nviz/tools.py:1899
+msgid "isosurfaces"
msgstr ""
-#: ../gui/wxpython/psmap/utils.py:106 ../gui/wxpython/modules/vclean.py:222
-msgid "point"
+#: ../gui/wxpython/nviz/tools.py:1900
+msgid "slices"
msgstr ""
-#: ../gui/wxpython/psmap/utils.py:107
-msgid "centimeter"
+#: ../gui/wxpython/nviz/tools.py:1923
+msgid "Resolution:"
msgstr ""
-#: ../gui/wxpython/psmap/utils.py:108
-msgid "millimeter"
+#: ../gui/wxpython/nviz/tools.py:1937
+msgid "Draw wire box"
msgstr ""
-#: ../gui/wxpython/psmap/utils.py:112
-msgid "meters"
+#: ../gui/wxpython/nviz/tools.py:1953 ../gui/wxpython/nviz/tools.py:4279
+msgid "List of isosurfaces"
msgstr ""
-#: ../gui/wxpython/psmap/utils.py:115
-msgid "kilometers"
+#: ../gui/wxpython/nviz/tools.py:2087
+msgid "Show light model"
msgstr ""
-#: ../gui/wxpython/psmap/utils.py:118
-msgid "feet"
+#: ../gui/wxpython/nviz/tools.py:2100
+msgid "Light source position"
msgstr ""
-#: ../gui/wxpython/psmap/utils.py:121
-msgid "miles"
+#: ../gui/wxpython/nviz/tools.py:2117
+msgid "Adjusts the light height"
msgstr ""
-#: ../gui/wxpython/psmap/utils.py:124 ../gui/wxpython/psmap/utils.py:128
-msgid "nautical miles"
+#: ../gui/wxpython/nviz/tools.py:2148
+msgid "Light color and intensity"
msgstr ""
-#: ../gui/wxpython/psmap/utils.py:126
-msgid "pixel"
+#: ../gui/wxpython/nviz/tools.py:2166 ../gui/wxpython/nviz/preferences.py:345
+msgid "Brightness:"
msgstr ""
-#: ../gui/wxpython/psmap/utils.py:127
-msgid "meter"
+#: ../gui/wxpython/nviz/tools.py:2168
+msgid "Adjusts the brightness of the light"
msgstr ""
-#: ../gui/wxpython/psmap/utils.py:130
-msgid "degree"
+#: ../gui/wxpython/nviz/tools.py:2183 ../gui/wxpython/nviz/preferences.py:359
+msgid "Ambient:"
msgstr ""
-#: ../gui/wxpython/psmap/utils.py:397
-msgid "Unable to run `ps.map -b`"
+#: ../gui/wxpython/nviz/tools.py:2185
+msgid "Adjusts the ambient light"
msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:139
-#, python-format
-msgid ""
-"Unable to open file\n"
-"%s"
+#: ../gui/wxpython/nviz/tools.py:2250
+msgid "Edges with fringe"
msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:498
-#, python-format
-msgid "Instruction file will be loaded with following region: %s\n"
+#: ../gui/wxpython/nviz/tools.py:2252
+msgid "N && W"
msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:504
-#, python-format
-msgid ""
-"Region cannot be set\n"
-"%s"
+#: ../gui/wxpython/nviz/tools.py:2253
+msgid "N && E"
msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:664
-#: ../gui/wxpython/psmap/instructions.py:863
-#: ../gui/wxpython/psmap/instructions.py:996
-#: ../gui/wxpython/psmap/instructions.py:1074
-#: ../gui/wxpython/psmap/instructions.py:1248
-#: ../gui/wxpython/psmap/instructions.py:1315
-#: ../gui/wxpython/psmap/instructions.py:1382
-#: ../gui/wxpython/psmap/instructions.py:1466
-#: ../gui/wxpython/psmap/instructions.py:1588
-#: ../gui/wxpython/psmap/instructions.py:1733
-#: ../gui/wxpython/psmap/instructions.py:1787
-#: ../gui/wxpython/psmap/instructions.py:2158
-#, python-format
-msgid "Failed to read instruction %s"
+#: ../gui/wxpython/nviz/tools.py:2254
+msgid "S && W"
msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:679
-#, python-format
-msgid ""
-"Scale has changed, old value: %(old)s\n"
-"new value: %(new)s"
+#: ../gui/wxpython/nviz/tools.py:2255
+msgid "S && E"
msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:683
-#, python-format
-msgid ""
-"Failed to read instruction %s.\n"
-"Use 1:25000 notation."
+#: ../gui/wxpython/nviz/tools.py:2272 ../gui/wxpython/vnet/dialogs.py:945
+#: ../gui/wxpython/gui_core/toolbars.py:84
+#: ../gui/wxpython/iscatt/toolbars.py:48 ../gui/wxpython/iscatt/toolbars.py:146
+msgid "Settings"
msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:693
-#, python-format
-msgid ""
-"Map frame position changed, old value: %(old1)s %(old2)s\n"
-"new value: %(new1)s %(new2)s"
+#: ../gui/wxpython/nviz/tools.py:2280
+msgid "Elevation of fringe from bottom:"
msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:704
-#, python-format
-msgid ""
-"Map frame size changed, old value: %(old1)s %(old2)s\n"
+#: ../gui/wxpython/nviz/tools.py:2337
+msgid "Arrow length (in map units):"
msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:771
-#, python-format
-msgid ""
-"Failed to read instruction %(file)s.\n"
-"Unknown format %(for)s"
+#: ../gui/wxpython/nviz/tools.py:2349
+msgid "Arrow color:"
msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:786
-#, python-format
-msgid "Failed to read instruction %s."
+#: ../gui/wxpython/nviz/tools.py:2361
+msgid "Place arrow"
msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:936
-#: ../gui/wxpython/psmap/instructions.py:2006
-#, python-format
-msgid "Characters on position %s are not supported by ISO-8859-1 (Latin 1) encoding which is required by module ps.map."
+#: ../gui/wxpython/nviz/tools.py:2386
+msgid "Scale bar length (in map units):"
msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:940
-#: ../gui/wxpython/psmap/instructions.py:2010
-msgid "Not all characters are supported by ISO-8859-1 (Latin 1) encoding which is required by module ps.map."
+#: ../gui/wxpython/nviz/tools.py:2398
+msgid "Scale bar color:"
msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:1077
-#, python-format
-msgid "Failed to read instruction %(inst)s: file %(file)s not found."
+#: ../gui/wxpython/nviz/tools.py:2410
+msgid "Place new scale bar"
msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:68 ../gui/wxpython/menustrings.py:2065
-msgid "Generate text file with mapping instructions"
+#: ../gui/wxpython/nviz/tools.py:2482
+msgid "Do you want to record new animation without saving the previous one?"
msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:70 ../gui/wxpython/menustrings.py:2063
-msgid "Load text file with mapping instructions"
+#: ../gui/wxpython/nviz/tools.py:2485
+msgid "Animation already axists"
msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:72 ../gui/wxpython/menustrings.py:2067
-msgid "Generate PostScript output"
+#: ../gui/wxpython/nviz/tools.py:2655
+msgid "No file prefix given."
msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:74 ../gui/wxpython/menustrings.py:2069
-msgid "Generate PDF output"
+#: ../gui/wxpython/nviz/tools.py:2659
+#, python-format
+msgid "Directory %s does not exist."
msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:76 ../gui/wxpython/gcp/mapdisplay.py:426
-#: ../gui/wxpython/modules/histogram.py:500 ../gui/wxpython/wxplot/base.py:610
-#: ../gui/wxpython/mapdisp/frame.py:816 ../gui/wxpython/menustrings.py:2060
-msgid "Page setup"
+#: ../gui/wxpython/nviz/tools.py:2800
+msgid "Isosurface attributes"
msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:77 ../gui/wxpython/menustrings.py:2061
-msgid "Specify paper size, margins and orientation"
+#: ../gui/wxpython/nviz/tools.py:2806
+msgid "toggle normal direction"
msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:79
-msgid "Full extent"
+#: ../gui/wxpython/nviz/tools.py:2815
+msgid "Isosurface value"
msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:80
-msgid "Zoom to full extent"
+#: ../gui/wxpython/nviz/tools.py:2932
+msgid "Slice attributes"
msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:83
-msgid "Click and drag to place map frame"
+#: ../gui/wxpython/nviz/tools.py:2941
+msgid "Slice parallel to axis:"
msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:85 ../gui/wxpython/menustrings.py:2094
-msgid "Delete selected object"
+#: ../gui/wxpython/nviz/tools.py:3099
+msgid "W"
msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:87
-msgid "Show preview"
+#: ../gui/wxpython/nviz/tools.py:3100
+msgid "N"
msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:89
-msgid "Quit Cartographic Composer"
+#: ../gui/wxpython/nviz/tools.py:3101
+msgid "S"
msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:93 ../gui/wxpython/menustrings.py:2083
-msgid "Map info"
+#: ../gui/wxpython/nviz/tools.py:3102
+msgid "E"
msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:95 ../gui/wxpython/wxplot/dialogs.py:1087
-#: ../gui/wxpython/wxplot/dialogs.py:1150
-#: ../gui/wxpython/wxplot/dialogs.py:1231
-msgid "Legend"
+#: ../gui/wxpython/nviz/tools.py:3103
+msgid "NW"
msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:107
-#: ../gui/wxpython/rlisetup/wizard.py:1181
-#: ../gui/wxpython/rlisetup/wizard.py:1354
-#: ../gui/wxpython/rlisetup/wizard.py:1444
-msgid "Rectangle"
+#: ../gui/wxpython/nviz/tools.py:3104
+msgid "NE"
msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:109
-msgid "Add overlays"
+#: ../gui/wxpython/nviz/tools.py:3105
+msgid "SE"
msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:111 ../gui/wxpython/lmgr/layertree.py:103
-msgid "Add labels"
+#: ../gui/wxpython/nviz/tools.py:3106
+msgid "SW"
msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:203
-msgid "Add simple graphics: points"
+#: ../gui/wxpython/nviz/tools.py:3624 ../gui/wxpython/nviz/tools.py:5560
+msgid "Level"
msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:219
-msgid "Add simple graphics: lines"
+#: ../gui/wxpython/nviz/tools.py:4285
+msgid "List of slices"
msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:235
-msgid "Add simple graphics: rectangles"
+#: ../gui/wxpython/nviz/tools.py:4483 ../gui/wxpython/nviz/tools.py:4485
+#, python-brace-format
+msgid "Level {level}"
msgstr ""
-#: ../gui/wxpython/gcp/statusbar.py:38
-msgid "Go to GCP No."
+#: ../gui/wxpython/nviz/tools.py:4493 ../gui/wxpython/nviz/tools.py:4497
+msgid "Slice parallel to {axis}"
msgstr ""
-#: ../gui/wxpython/gcp/statusbar.py:55
-msgid "Valid Range:"
+#: ../gui/wxpython/nviz/tools.py:4785 ../gui/wxpython/nviz/tools.py:5573
+msgid "Slice parallel to"
msgstr ""
-#: ../gui/wxpython/gcp/statusbar.py:121
-msgid "RMS error"
+#: ../gui/wxpython/nviz/tools.py:5017
+#, python-format
+msgid "Scalebar %d"
msgstr ""
-#: ../gui/wxpython/gcp/statusbar.py:125
-#, python-format
-msgid "Forward: %(forw)s, Backward: %(back)s"
+#: ../gui/wxpython/nviz/tools.py:5179
+msgid "None"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:143
-msgid "Setup for georectification"
+#: ../gui/wxpython/nviz/tools.py:5181 ../gui/wxpython/menustrings.py:485
+#: ../gui/wxpython/menustrings.py:1391
+msgid "Plane"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:176 ../gui/wxpython/gcp/manager.py:180
-msgid "Georectifying setup canceled."
+#: ../gui/wxpython/nviz/tools.py:5381
+msgid "Vector map is 3D"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:345
-msgid "Select map type and location/mapset"
+#: ../gui/wxpython/nviz/tools.py:5384
+msgid "Vector map is 2D"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:359
-msgid "Map type to georectify"
+#: ../gui/wxpython/nviz/tools.py:5386
+#, python-format
+msgid "%(features)d features (%(points)d points)"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:370
-msgid "Select source location:"
+#: ../gui/wxpython/nviz/tools.py:5444 ../gui/wxpython/nviz/tools.py:5499
+msgid "on surface"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:391
-msgid "Select source mapset:"
+#: ../gui/wxpython/nviz/tools.py:5597
+msgid "range:"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:447
-msgid "You must select a valid location before selecting a mapset"
+#: ../gui/wxpython/nviz/tools.py:5676 ../gui/wxpython/nviz/tools.py:5687
+msgid "North edge:"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:460
-msgid "You must select a valid location and mapset in order to continue"
+#: ../gui/wxpython/nviz/tools.py:5677 ../gui/wxpython/nviz/tools.py:5688
+msgid "South edge:"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:482
-msgid "Select image/map group to georectify"
+#: ../gui/wxpython/nviz/tools.py:5678 ../gui/wxpython/nviz/tools.py:5685
+#: ../gui/wxpython/nviz/tools.py:5694
+msgid "West edge:"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:504
-msgid "Select group:"
+#: ../gui/wxpython/nviz/tools.py:5679 ../gui/wxpython/nviz/tools.py:5686
+#: ../gui/wxpython/nviz/tools.py:5695
+msgid "East edge:"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:521
-msgid "Create group if none exists"
+#: ../gui/wxpython/nviz/tools.py:5681 ../gui/wxpython/nviz/tools.py:5692
+#: ../gui/wxpython/nviz/tools.py:5700
+msgid "Northing (Y):"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:531 ../gui/wxpython/iclass/dialogs.py:78
-msgid "Create/edit group..."
+#: ../gui/wxpython/nviz/tools.py:5682 ../gui/wxpython/nviz/tools.py:5691
+#: ../gui/wxpython/nviz/tools.py:5701
+msgid "Height (Z):"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:535
-msgid "Add vector map to group..."
+#: ../gui/wxpython/nviz/tools.py:5683 ../gui/wxpython/nviz/tools.py:5690
+#: ../gui/wxpython/nviz/tools.py:5699
+msgid "Easting (X):"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:555 ../gui/wxpython/gcp/manager.py:2969
-msgid "Extension for output maps:"
+#: ../gui/wxpython/nviz/tools.py:5696
+msgid "Bottom edge:"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:619
-msgid "You must select a valid image/map group in order to continue"
+#: ../gui/wxpython/nviz/tools.py:5697
+msgid "Top edge:"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:626
-msgid "You must enter an map name extension in order to continue"
+#: ../gui/wxpython/nviz/tools.py:5808
+msgid "Adjusts the distance and direction of the image viewpoint"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:695
-msgid "Select maps to display for ground control point (GCP) creation"
+#: ../gui/wxpython/nviz/tools.py:5843
+msgid "Adjusts the light direction. Click and drag the puck to change the light direction."
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:707 ../gui/wxpython/gcp/manager.py:2864
-msgid "Select source map to display:"
+#: ../gui/wxpython/nviz/wxnviz.py:33
+msgid "This module requires the NumPy module, which could not be imported. It probably is not installed (it's not part of the standard Python distribution). See the Numeric Python site (http://numpy.scipy.org) for information on downloading source or binaries."
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:733 ../gui/wxpython/gcp/manager.py:2878
-msgid "Select target raster map to display:"
+#: ../gui/wxpython/nviz/wxnviz.py:502 ../gui/wxpython/nviz/wxnviz.py:514
+#, python-format
+msgid "3d raster map <%s> not found"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:756 ../gui/wxpython/gcp/manager.py:2892
-msgid "Select target vector map to display:"
+#: ../gui/wxpython/nviz/preferences.py:35
+msgid "3D view default settings"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:828
-msgid "You must select a source map in order to continue"
+#: ../gui/wxpython/nviz/preferences.py:62
+msgid "Revert settings to default, changes are not applied"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:855 ../gui/wxpython/gcp/manager.py:886
-#, python-format
-msgid ""
-"No maps in selected group <%s>.\n"
-"Please edit group or select another group."
+#: ../gui/wxpython/nviz/preferences.py:90
+#: ../gui/wxpython/nviz/preferences.py:161
+#: ../gui/wxpython/nviz/preferences.py:180
+msgid "value:"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:916
-msgid "Manage Ground Control Points"
+#: ../gui/wxpython/nviz/preferences.py:103
+msgid "step:"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1181
-#, python-format
-msgid "At least %d GCPs required. Operation canceled."
+#: ../gui/wxpython/nviz/preferences.py:118
+#: ../gui/wxpython/nviz/preferences.py:300
+msgid "Position:"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1324
-msgid "source"
+#: ../gui/wxpython/nviz/preferences.py:122
+#: ../gui/wxpython/nviz/preferences.py:304
+msgid "x:"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1326
-msgid "target"
+#: ../gui/wxpython/nviz/preferences.py:157
+msgid "Twist:"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1328
-msgid "Set GCP coordinates"
+#: ../gui/wxpython/nviz/preferences.py:237
+msgid "Fly-through"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1330
-#, python-format
-msgid ""
-"Set %(coor)s coordinates for GCP No. %(key)s? \n"
-"\n"
-"East: %(coor0)s \n"
-"North: %(coor1)s"
+#: ../gui/wxpython/nviz/preferences.py:241
+#: ../gui/wxpython/mapdisp/toolbars.py:68
+msgid "Fly-through mode"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1408
-msgid "Writing POINTS file failed"
+#: ../gui/wxpython/nviz/preferences.py:247
+msgid "Move exag:"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1420
-#, python-format
-msgid "POINTS file saved for group <%s>"
+#: ../gui/wxpython/nviz/preferences.py:260
+msgid "Turn exag:"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1436
-msgid "source mapwin not defined"
+#: ../gui/wxpython/nviz/preferences.py:292
+msgid "Light"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1441
-msgid "target mapwin not defined"
+#: ../gui/wxpython/nviz/preferences.py:330
+msgid "z:"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1471
-msgid "Reading POINTS file failed"
+#: ../gui/wxpython/nviz/preferences.py:517
+msgid "wire color:"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1556
-#, python-format
-msgid ""
-"Insufficient points defined and active (checked) for selected rectification method (order: %d).\n"
-"3+ points needed for 1st order,\n"
-"6+ points for 2nd order, and\n"
-"10+ points for 3rd order."
+#: ../gui/wxpython/nviz/preferences.py:598
+msgid "Automatic size"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1584
-msgid "Rectifying images, please wait..."
+#: ../gui/wxpython/nviz/preferences.py:599
+msgid "Icon size is set automatically based on landscape dimensions."
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1624
-#, python-format
-msgid "Transforming <%s>..."
+#: ../gui/wxpython/nviz/preferences.py:607
+#: ../gui/wxpython/mapswipe/dialogs.py:350
+msgid "Size:"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1629
+#: ../gui/wxpython/nviz/preferences.py:623
+msgid "Marker:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:724
#, python-format
-msgid "Rectifying vector map <%s>, please wait..."
+msgid "3D view settings saved to file <%s>."
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1663
+#: ../gui/wxpython/dbmgr/g.gui.dbmgr.py:52
#, python-format
-msgid "Georectification of vector map <%s> failed"
+msgid "Loading attribute data for vector map <%s>..."
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1669
-msgid "GCP Manager settings"
+#: ../gui/wxpython/dbmgr/g.gui.dbmgr.py:56
+msgid "GRASS GIS Attribute Table Manager"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1716
-msgid "Quit GCP Manager"
+#: ../gui/wxpython/dbmgr/manager.py:72
+msgid "GRASS GIS Attribute Table Manager - "
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1717
-msgid "Save ground control points?"
+#: ../gui/wxpython/dbmgr/manager.py:74
+msgid "READONLY - "
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1796
-msgid ""
-"Could not calculate RMS Error.\n"
-"Possible error with m.transform."
+#: ../gui/wxpython/dbmgr/manager.py:92
+#, python-format
+msgid "Database connection for vector map <%s> is not defined in DB file. You can define new connection in 'Manage layers' tab."
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1924
-msgid ""
-"Could not calculate new extends.\n"
+#: ../gui/wxpython/dbmgr/manager.py:98
+msgid "Please wait, loading attribute data..."
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2056
-msgid "Adjust source display to target display"
+#: ../gui/wxpython/dbmgr/manager.py:107
+msgid "Browse data"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2061
-msgid "Adjust target display to source display"
+#: ../gui/wxpython/dbmgr/manager.py:115
+msgid "Manage tables"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2135 ../gui/wxpython/gcp/manager.py:2153
-#: ../gui/wxpython/vnet/vnet_data.py:259 ../gui/wxpython/vnet/widgets.py:85
-msgid "use"
+#: ../gui/wxpython/dbmgr/manager.py:122
+msgid "Manage layers"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2136 ../gui/wxpython/gcp/manager.py:2154
-msgid "source E"
+#: ../gui/wxpython/dbmgr/manager.py:133
+msgid "Close Attribute Table Manager"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2137 ../gui/wxpython/gcp/manager.py:2155
-msgid "source N"
+#: ../gui/wxpython/dbmgr/manager.py:136
+msgid "Reload currently selected attribute data"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2138 ../gui/wxpython/gcp/manager.py:2156
-msgid "target E"
+#: ../gui/wxpython/dbmgr/manager.py:139
+msgid "Reload all attribute data (drop current selection)"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2139 ../gui/wxpython/gcp/manager.py:2157
-msgid "target N"
+#: ../gui/wxpython/dbmgr/manager.py:215 ../gui/wxpython/dbmgr/base.py:302
+#: ../gui/wxpython/dbmgr/base.py:904 ../gui/wxpython/dbmgr/base.py:1074
+#: ../gui/wxpython/dbmgr/base.py:1429 ../gui/wxpython/dbmgr/base.py:2081
+#, python-format
+msgid "Number of loaded records: %d"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2140 ../gui/wxpython/gcp/manager.py:2158
-msgid "Forward error"
+#: ../gui/wxpython/dbmgr/dialogs.py:79
+#, python-format
+msgid ""
+"No attribute table found.\n"
+"\n"
+"Do you want to create a new attribute table and defined a link to vector map <%s>?"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2141 ../gui/wxpython/gcp/manager.py:2159
-msgid "Backward error"
+#: ../gui/wxpython/dbmgr/dialogs.py:83
+msgid "Create table?"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2296
-msgid "Invalid coordinate value. Operation canceled."
+#: ../gui/wxpython/dbmgr/dialogs.py:104
+msgid "Close dialog on submit"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2343
-msgid "Create vector map group"
+#: ../gui/wxpython/dbmgr/dialogs.py:116
+msgid "No attributes found"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2418
-msgid "Select vector map(s) to add to group:"
+#: ../gui/wxpython/dbmgr/dialogs.py:122 ../gui/wxpython/menustrings.py:671
+#: ../gui/wxpython/menustrings.py:1577
+msgid "Update attributes"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2469
-msgid "Edit GCP"
+#: ../gui/wxpython/dbmgr/dialogs.py:124
+msgid "Define attributes"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2481
-msgid "Ground Control Point No."
+#: ../gui/wxpython/dbmgr/dialogs.py:126
+msgid "Display attributes"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2500
-msgid "source E:"
+#: ../gui/wxpython/dbmgr/dialogs.py:130
+msgid "&Reload"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2501
-msgid "target E:"
+#: ../gui/wxpython/dbmgr/dialogs.py:131 ../gui/wxpython/dbmgr/dialogs.py:625
+msgid "&Submit"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2502
-msgid "source N:"
+#: ../gui/wxpython/dbmgr/dialogs.py:149 ../gui/wxpython/vdigit/dialogs.py:175
+msgid "Feature id:"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2503
-msgid "target N:"
+#: ../gui/wxpython/dbmgr/dialogs.py:237
+#, python-format
+msgid "Column <%(col)s>: Value '%(value)s' needs to be entered as %(type)s."
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2649
-msgid "Highlight highest RMS error only"
+#: ../gui/wxpython/dbmgr/dialogs.py:451
+msgid "Unknown"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2662
-msgid "Highlight RMS error > M + SD * factor:"
+#: ../gui/wxpython/dbmgr/dialogs.py:512 ../gui/wxpython/dbmgr/base.py:2937
+#: ../gui/wxpython/dbmgr/base.py:3058 ../gui/wxpython/dbmgr/base.py:3324
+#: ../gui/wxpython/vdigit/dialogs.py:116 ../gui/wxpython/vdigit/dialogs.py:576
+#: ../gui/wxpython/vdigit/preferences.py:612
+#: ../gui/wxpython/vdigit/preferences.py:615
+msgid "Layer"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2666
-msgid ""
-"Highlight GCPs with an RMS error larger than \n"
-"mean + standard deviation * given factor. \n"
-"Recommended values for this factor are between 1 and 2."
+#: ../gui/wxpython/dbmgr/dialogs.py:512 ../gui/wxpython/dbmgr/dialogs.py:640
+#: ../gui/wxpython/vdigit/dialogs.py:123 ../gui/wxpython/vdigit/dialogs.py:577
+msgid "Category"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2689
-msgid "Symbol settings"
+#: ../gui/wxpython/dbmgr/dialogs.py:788 ../gui/wxpython/dbmgr/base.py:2304
+#: ../gui/wxpython/dbmgr/base.py:2368
+msgid "Column"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2717
-msgid "Color for high RMS error:"
+#: ../gui/wxpython/dbmgr/dialogs.py:799 ../gui/wxpython/dbmgr/base.py:2323
+#: ../gui/wxpython/gmodeler/preferences.py:255
+#: ../gui/wxpython/web_services/widgets.py:923
+msgid "Type"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2737
-msgid "Color for selected GCP:"
+#: ../gui/wxpython/dbmgr/dialogs.py:810 ../gui/wxpython/dbmgr/base.py:2339
+msgid "Length"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2757
-msgid "Color for unused GCPs:"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:95 ../gui/wxpython/dbmgr/base.py:2261
+msgid "Database connection"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2773
-msgid "Show unused GCPs"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:111 ../gui/wxpython/menustrings.py:882
+#: ../gui/wxpython/menustrings.py:1788
+msgid "Query"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2790
-#: ../gui/wxpython/gui_core/preferences.py:1416
-msgid "Symbol size:"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:127
+msgid "Set SQL statement to default"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2918
-msgid "Rectification"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:130
+msgid "Apply SQL statement in Attribute Table Manager"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2927
-msgid "Select rectification order"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:132
+msgid "Close the dialog"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2929
-msgid "1st order"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:219
+msgid "Columns"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2930
-msgid "2nd order"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:233
+msgid "Interactive insertion"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2931
-msgid "3rd order"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:247
+msgid "Values"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2943
-msgid "Select interpolation method:"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:257
+msgid "Get all values"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2959
-msgid "clip to computational region in target location"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:262
+msgid "Get sample"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:3010
-msgid "RMS threshold factor must be > 0"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:264
+msgid "Get first 256 unique values as sample"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:3013
-msgid ""
-"RMS threshold factor is < 1\n"
-"Too many points might be highlighted"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:283
+msgid "Go to:"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:3197
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:296
+msgid "Close dialog on apply"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:471
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:616
#, python-format
-msgid "GCP Manager settings saved to file '%s'."
+msgid "GRASS SQL Builder (%(type)s) - <%(map)s>"
msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:50
-msgid "GRASS GIS Manage Ground Control Points"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:474
+msgid "Column to show (SELECT clause)"
msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:176
-msgid "GCP List"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:475
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:620
+msgid "Constraint for query (WHERE clause)"
msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:181
-msgid "Source Display"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:487 ../gui/wxpython/dbmgr/base.py:1198
+#: ../gui/wxpython/dbmgr/base.py:1224
+#, python-format
+msgid "Example: %s"
msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:185
-msgid "Target Display"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:491
+msgid "Verify"
msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:275
-msgid "GCP Display toolbar"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:492
+msgid "Verify SQL statement"
msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:288
-msgid "GCP Manager toolbar"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:500
+msgid "SQL statement not verified"
msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:430
-#: ../gui/wxpython/modules/histogram.py:504 ../gui/wxpython/wxplot/base.py:611
-#: ../gui/wxpython/mapdisp/frame.py:820
-msgid "Print preview"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:544
+msgid "SQL statement is not valid"
msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:434
-#: ../gui/wxpython/modules/histogram.py:508 ../gui/wxpython/wxplot/base.py:612
-#: ../gui/wxpython/mapdisp/frame.py:824 ../gui/wxpython/gui_core/toolbars.py:67
-msgid "Print display"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:546
+#, python-format
+msgid ""
+"SQL statement is not valid.\n"
+"\n"
+"%s"
msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:474
-msgid "Zoom to computational region (set with g.region)"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:548
+msgid "SQL statement is valid"
msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:479 ../gui/wxpython/mapdisp/frame.py:1388
-msgid "Zoom to default region"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:619
+msgid "Column to set (SET clause)"
msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:483 ../gui/wxpython/mapdisp/frame.py:1390
-msgid "Zoom to saved region"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:621
+msgid "Calculate column value to set"
msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:488
-msgid "Set computational region from display"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:693
+msgid "Functions"
msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:493 ../gui/wxpython/mapdisp/frame.py:1400
-msgid "Save display geometry to named region"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:726
+msgid "SQL statement was not applied"
msgstr ""
-#: ../gui/wxpython/icons/icon.py:38
-#, python-format
-msgid "Unknown iconset '%s', using default 'grass'...\n"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:728
+msgid "SQL statement applied"
msgstr ""
-#: ../gui/wxpython/icons/icon.py:56
-#, python-format
-msgid "Unable to load icon theme. Reason: %s. Quiting wxGUI..."
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:762
+msgid "Dbf driver does not support usage of SQL functions."
msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:154 ../gui/wxpython/iscatt/controllers.py:139
+msgid "Loading data..."
+msgstr ""
#: ../gui/wxpython/dbmgr/base.py:161
#, python-format
msgid "Attribute table <%s> not found. For creating the table switch to 'Manage layers' tab."
@@ -5954,13 +5798,6 @@
msgid "Viewing limit: 100000 records."
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:302 ../gui/wxpython/dbmgr/base.py:904
-#: ../gui/wxpython/dbmgr/base.py:1074 ../gui/wxpython/dbmgr/base.py:1429
-#: ../gui/wxpython/dbmgr/base.py:2081 ../gui/wxpython/dbmgr/manager.py:215
-#, python-format
-msgid "Number of loaded records: %d"
-msgstr ""
#: ../gui/wxpython/dbmgr/base.py:326
msgid "Unknown value"
msgstr ""
@@ -6078,12 +5915,6 @@
msgid "Apply SELECT statement and reload data records"
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1198 ../gui/wxpython/dbmgr/base.py:1224
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:487
-#, python-format
-msgid "Example: %s"
-msgstr ""
#: ../gui/wxpython/dbmgr/base.py:1209
msgid "Builder"
msgstr ""
@@ -6092,6 +5923,10 @@
msgid "SQL Builder"
msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1391 ../gui/wxpython/core/settings.py:863
+msgid "Edit selected record"
+msgstr ""
#: ../gui/wxpython/dbmgr/base.py:1396 ../gui/wxpython/dbmgr/base.py:1585
msgid "Insert new record"
msgstr ""
@@ -6117,7 +5952,7 @@
msgstr ""
#: ../gui/wxpython/dbmgr/base.py:1407
-#: ../gui/wxpython/gui_core/preferences.py:1482
+#: ../gui/wxpython/gui_core/preferences.py:1447
msgid "Highlight selected features"
msgstr ""
@@ -6133,6 +5968,13 @@
msgid "Delete selected features"
msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1423 ../gui/wxpython/dbmgr/base.py:2573
+#: ../gui/wxpython/vdigit/dialogs.py:290
+#: ../gui/wxpython/gmodeler/dialogs.py:851
+#: ../gui/wxpython/gmodeler/dialogs.py:1017
+msgid "Reload"
+msgstr ""
#: ../gui/wxpython/dbmgr/base.py:1478
msgid "Update existing record"
msgstr ""
@@ -6205,32 +6047,13 @@
"%s"
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2261 ../gui/wxpython/dbmgr/sqlbuilder.py:95
-msgid "Database connection"
-msgstr ""
#: ../gui/wxpython/dbmgr/base.py:2280
#, python-format
msgid "Table <%s> - right-click to delete column(s)"
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2304 ../gui/wxpython/dbmgr/base.py:2368
-#: ../gui/wxpython/dbmgr/dialogs.py:788
-msgid "Column"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2323 ../gui/wxpython/dbmgr/dialogs.py:799
-#: ../gui/wxpython/web_services/widgets.py:923
-#: ../gui/wxpython/gmodeler/preferences.py:255
-msgid "Type"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2339 ../gui/wxpython/dbmgr/dialogs.py:810
-msgid "Length"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2355 ../gui/wxpython/menustrings.py:927
-#: ../gui/wxpython/menustrings.py:1870
+#: ../gui/wxpython/dbmgr/base.py:2355 ../gui/wxpython/menustrings.py:900
+#: ../gui/wxpython/menustrings.py:1806
msgid "Rename column"
msgstr ""
@@ -6306,7 +6129,7 @@
msgstr ""
#: ../gui/wxpython/dbmgr/base.py:2939 ../gui/wxpython/dbmgr/base.py:3069
-#: ../gui/wxpython/dbmgr/base.py:3338 ../gui/wxpython/gui_core/gselect.py:1422
+#: ../gui/wxpython/dbmgr/base.py:3338 ../gui/wxpython/gui_core/gselect.py:1421
msgid "Database"
msgstr ""
@@ -6426,2189 +6249,2361 @@
msgid "Field statistics <%s>"
msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:72
-msgid "GRASS GIS Attribute Table Manager - "
+#: ../gui/wxpython/mapdisp/gprint.py:154
+msgid ""
+"There was a problem printing.\n"
+"Perhaps your current printer is not set correctly?"
msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:74
-msgid "READONLY - "
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:89
+#: ../gui/wxpython/core/render.py:779 ../gui/wxpython/gui_core/mapdisp.py:133
+#, python-format
+msgid "GRASS module '%s' not found. Unable to start map display window."
msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:92
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:147
+msgid "Map window test frame"
+msgstr ""
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:166
+msgid "Map display test"
+msgstr ""
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:176
+msgid "Map window API test frame"
+msgstr ""
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:206
+msgid "Map window distance measurement test frame"
+msgstr ""
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:237
+msgid "Map window profile tool test frame"
+msgstr ""
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:284
+msgid "Map window rlisetup test frame"
+msgstr ""
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:345
#, python-format
-msgid "Database connection for vector map <%s> is not defined in DB file. You can define new connection in 'Manage layers' tab."
+msgid "Unknown value %s of test parameter."
msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:98
-msgid "Please wait, loading attribute data..."
+#: ../gui/wxpython/mapdisp/statusbar.py:418
+msgid "Render"
msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:107
-msgid "Browse data"
+#: ../gui/wxpython/mapdisp/statusbar.py:422
+msgid "Enable/disable auto-rendering"
msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:115
-msgid "Manage tables"
+#: ../gui/wxpython/mapdisp/statusbar.py:454
+msgid "Show comp. extent"
msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:122
-msgid "Manage layers"
+#: ../gui/wxpython/mapdisp/statusbar.py:458
+msgid "Show computational extent"
msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:133
-msgid "Close Attribute Table Manager"
+#: ../gui/wxpython/mapdisp/statusbar.py:464
+msgid "Show/hide computational region extent (set with g.region). Display region drawn as a blue box inside the computational region, computational region inside a display region as a red box)."
msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:136
-msgid "Reload currently selected attribute data"
+#: ../gui/wxpython/mapdisp/statusbar.py:515
+msgid "Display mode"
msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:139
-msgid "Reload all attribute data (drop current selection)"
+#: ../gui/wxpython/mapdisp/statusbar.py:520
+#: ../gui/wxpython/gui_core/preferences.py:880
+msgid "Align region extent based on display size"
msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:79
-#, python-format
-msgid ""
-"No attribute table found.\n"
-"\n"
-"Do you want to create a new attribute table and defined a link to vector map <%s>?"
+#: ../gui/wxpython/mapdisp/statusbar.py:526
+msgid "Align region extent based on display size from center point. Default value for new map displays can be set up in 'User GUI settings' dialog."
msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:83
-msgid "Create table?"
+#: ../gui/wxpython/mapdisp/statusbar.py:560
+msgid "Display resolution"
msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:104
-msgid "Close dialog on submit"
+#: ../gui/wxpython/mapdisp/statusbar.py:563
+#: ../gui/wxpython/gui_core/preferences.py:896
+msgid "Constrain display resolution to computational settings"
msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:116
-msgid "No attributes found"
+#: ../gui/wxpython/mapdisp/statusbar.py:569
+msgid "Constrain display resolution to computational region settings. Default value for new map displays can be set up in 'User GUI settings' dialog."
msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:122 ../gui/wxpython/menustrings.py:694
-#: ../gui/wxpython/menustrings.py:1637
-msgid "Update attributes"
+#: ../gui/wxpython/mapdisp/statusbar.py:607
+msgid "Map scale"
msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:124
-msgid "Define attributes"
+#: ../gui/wxpython/mapdisp/statusbar.py:624
+msgid "As everyone's monitors and resolutions are set differently these values are not true map scales, but should get you into the right neighborhood."
msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:126
-msgid "Display attributes"
+#: ../gui/wxpython/mapdisp/statusbar.py:677
+msgid "Go to"
msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:130
-msgid "&Reload"
+#: ../gui/wxpython/mapdisp/statusbar.py:700
+#: ../gui/wxpython/mapdisp/statusbar.py:770
+#: ../gui/wxpython/mapdisp/statusbar.py:1009
+#: ../gui/wxpython/mapdisp/statusbar.py:1084
+msgid "Projection not defined (check the settings)"
msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:131 ../gui/wxpython/dbmgr/dialogs.py:625
-msgid "&Submit"
+#: ../gui/wxpython/mapdisp/statusbar.py:787
+#: ../gui/wxpython/mapdisp/statusbar.py:1024
+#: ../gui/wxpython/mapdisp/statusbar.py:1125
+msgid "Error in projection (check the settings)"
msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:237
+#: ../gui/wxpython/mapdisp/statusbar.py:824
+#: ../gui/wxpython/gui_core/preferences.py:1629
+msgid "Projection"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:826
+msgid "Use defined projection"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:841
+msgid "Reproject coordinates displayed in the statusbar. Projection can be defined in GUI preferences dialog (tab 'Projection')"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:873
+msgid "MASK"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:921
+msgid "Display geometry"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:947
+msgid "Coordinates"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:1039
+msgid "Extent"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:1152
+#: ../gui/wxpython/web_services/dialogs.py:873
+msgid "Computational region"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:70
+msgid "GRASS GIS - Map display"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:248
+msgid ""
+"Failed to run command '{command}'. Details:\n"
+"{error}"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:262
#, python-format
-msgid "Column <%(col)s>: Value '%(value)s' needs to be entered as %(type)s."
+msgid "GRASS GIS %(version)s Map Display: %(id)s - Location: %(loc)s@%(mapset)s"
msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:451
-msgid "Unknown"
+#: ../gui/wxpython/mapdisp/frame.py:319
+msgid "Vector Digitizer Toolbar"
msgstr ""
-#: ../gui/wxpython/dbmgr/g.gui.dbmgr.py:52
+#: ../gui/wxpython/mapdisp/frame.py:342
#, python-format
-msgid "Loading attribute data for vector map <%s>..."
+msgid ""
+"Unable to switch to 3D display mode.\n"
+"The Nviz python extension was not found or loaded properly.\n"
+"Switching back to 2D display mode.\n"
+"\n"
+"Details: %s"
msgstr ""
-#: ../gui/wxpython/dbmgr/g.gui.dbmgr.py:56
-msgid "GRASS GIS Attribute Table Manager"
+#: ../gui/wxpython/mapdisp/frame.py:377
+msgid "Starting 3D view mode..."
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:111 ../gui/wxpython/menustrings.py:909
-#: ../gui/wxpython/menustrings.py:1852
-msgid "Query"
+#: ../gui/wxpython/mapdisp/frame.py:379
+msgid "Please wait, loading data..."
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:127
-msgid "Set SQL statement to default"
+#: ../gui/wxpython/mapdisp/frame.py:462
+msgid "Please wait, unloading data..."
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:130
-msgid "Apply SQL statement in Attribute Table Manager"
+#: ../gui/wxpython/mapdisp/frame.py:464
+msgid "Switching back to 2D view mode..."
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:132
-msgid "Close the dialog"
+#: ../gui/wxpython/mapdisp/frame.py:519 ../gui/wxpython/mapdisp/toolbars.py:116
+#: ../gui/wxpython/vdigit/toolbars.py:953
+msgid "Vector digitizer"
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:219
-msgid "Columns"
+#: ../gui/wxpython/mapdisp/frame.py:722 ../gui/wxpython/mapdisp/frame.py:730
+#: ../gui/wxpython/mapdisp/frame.py:745
+msgid "Failed to run d.to.rast:\n"
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:233
-msgid "Interactive insertion"
+#: ../gui/wxpython/mapdisp/frame.py:761
+msgid "d.to.rast can be used only in 2D mode."
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:247
-msgid "Values"
+#: ../gui/wxpython/mapdisp/frame.py:893
+#, python-format
+msgid "Vector map <%s> opened for editing - skipped."
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:257
-msgid "Get all values"
+#: ../gui/wxpython/mapdisp/frame.py:900 ../gui/wxpython/mapswipe/frame.py:674
+msgid "No raster or vector map layer selected for querying."
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:262
-msgid "Get sample"
+#: ../gui/wxpython/mapdisp/frame.py:964
+msgid "Failed to query vector map(s) <{maps}>. Check database settings and topology."
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:264
-msgid "Get first 256 unique values as sample"
+#: ../gui/wxpython/mapdisp/frame.py:1393
+msgid "Set computational region extent from display"
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:283
-msgid "Go to:"
+#: ../gui/wxpython/mapdisp/frame.py:1395
+msgid "Set computational region extent interactively"
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:296
-msgid "Close dialog on apply"
+#: ../gui/wxpython/mapdisp/frame.py:1397
+msgid "Set computational region from named region"
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:471
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:616
-#, python-format
-msgid "GRASS SQL Builder (%(type)s) - <%(map)s>"
+#: ../gui/wxpython/mapdisp/frame.py:1402
+msgid "Save computational region to named region"
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:474
-msgid "Column to show (SELECT clause)"
+#: ../gui/wxpython/mapdisp/frame.py:1535
+msgid "Raster Digitizer Toolbar"
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:475
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:620
-msgid "Constraint for query (WHERE clause)"
+#: ../gui/wxpython/mapdisp/toolbars.py:29
+#: ../gui/wxpython/mapswipe/toolbars.py:36
+msgid "Query raster/vector map(s)"
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:491
-msgid "Verify"
+#: ../gui/wxpython/mapdisp/toolbars.py:30
+#: ../gui/wxpython/mapswipe/toolbars.py:37
+msgid "Query selected raster/vector map(s)"
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:492
-msgid "Verify SQL statement"
+#: ../gui/wxpython/mapdisp/toolbars.py:32
+msgid "Select vector feature(s)"
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:500
-msgid "SQL statement not verified"
+#: ../gui/wxpython/mapdisp/toolbars.py:33
+msgid "Select features interactively from vector map"
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:544
-msgid "SQL statement is not valid"
+#: ../gui/wxpython/mapdisp/toolbars.py:35
+msgid "Add scale bar"
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:546
-#, python-format
-msgid ""
-"SQL statement is not valid.\n"
-"\n"
-"%s"
+#: ../gui/wxpython/mapdisp/toolbars.py:37
+msgid "Add raster legend"
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:548
-msgid "SQL statement is valid"
+#: ../gui/wxpython/mapdisp/toolbars.py:39
+msgid "Add vector legend"
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:619
-msgid "Column to set (SET clause)"
+#: ../gui/wxpython/mapdisp/toolbars.py:41 ../gui/wxpython/menustrings.py:2017
+msgid "Add north arrow"
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:621
-msgid "Calculate column value to set"
+#: ../gui/wxpython/mapdisp/toolbars.py:43
+msgid "Analyze map"
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:693
-msgid "Functions"
+#: ../gui/wxpython/mapdisp/toolbars.py:44
+msgid "Measuring, profiling, histogramming, ..."
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:726
-msgid "SQL statement was not applied"
+#: ../gui/wxpython/mapdisp/toolbars.py:46
+msgid "Measure distance"
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:728
-msgid "SQL statement applied"
+#: ../gui/wxpython/mapdisp/toolbars.py:48
+msgid "Measure area"
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:762
-msgid "Dbf driver does not support usage of SQL functions."
+#: ../gui/wxpython/mapdisp/toolbars.py:50
+msgid "Profile surface map"
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:95
-msgid " Server settings "
+#: ../gui/wxpython/mapdisp/toolbars.py:52
+msgid "Create bivariate scatterplot of raster maps"
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:98
-msgid "Server:"
+#: ../gui/wxpython/mapdisp/toolbars.py:54
+#: ../gui/wxpython/animation/dialogs.py:988 ../gui/wxpython/menustrings.py:2013
+msgid "Add text"
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:102
-msgid "&Connect"
+#: ../gui/wxpython/mapdisp/toolbars.py:56
+msgid "Create histogram of raster map"
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:103
-msgid "Connect to the server"
+#: ../gui/wxpython/mapdisp/toolbars.py:58 ../gui/wxpython/menustrings.py:627
+#: ../gui/wxpython/menustrings.py:1533
+msgid "Vector network analysis tool"
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:107
-msgid "Show advanced connection settings"
+#: ../gui/wxpython/mapdisp/toolbars.py:64
+msgid "Rotate 3D scene"
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:108
-msgid "Hide advanced connection settings"
+#: ../gui/wxpython/mapdisp/toolbars.py:65
+msgid "Drag with mouse to rotate 3D scene"
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:126
-msgid " Layer Manager Settings "
+#: ../gui/wxpython/mapdisp/toolbars.py:70
+msgid "Drag with mouse, hold Ctrl down for different mode or Shift to accelerate"
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:130
-msgid "Output layer name:"
+#: ../gui/wxpython/mapdisp/toolbars.py:73
+msgid "Click mouse to zoom"
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:256
-msgid "Username:"
+#: ../gui/wxpython/mapdisp/toolbars.py:75
+msgid "Click mouse to unzoom"
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:260
-msgid "Password:"
+#: ../gui/wxpython/mapdisp/toolbars.py:110
+msgid "3D view mode not available"
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:301
-#: ../gui/wxpython/gui_core/gselect.py:1943
-msgid "No data source defined, settings are not saved."
+#: ../gui/wxpython/mapdisp/toolbars.py:111
+#: ../gui/wxpython/mapdisp/toolbars.py:123
+#, python-format
+msgid "Reason: %s"
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:386
+#: ../gui/wxpython/mapdisp/toolbars.py:122
+msgid "Vector digitizer not available"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:126
+msgid "Note that the wxGUI's vector digitizer is currently disabled (hopefully this will be fixed soon). Please keep an eye out for updated versions of GRASS. In the meantime you can use \"v.digit\" from the Develop Vector menu."
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:133
+msgid "Raster digitizer"
+msgstr ""
+#: ../gui/wxpython/mapdisp/main.py:187
#, python-format
-msgid "Connecting to <%s>..."
+msgid "Unsupported command %s."
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:454
-msgid "Available web services"
+#: ../gui/wxpython/mapdisp/main.py:281
+#, python-format
+msgid "Unable to read cmdfile '%(cmd)s'. Details: %(det)s"
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:467
+#: ../gui/wxpython/mapdisp/main.py:604
#, python-format
-msgid "Connected to <%s>"
+msgid "Starting map display <%s>..."
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:473
+#: ../gui/wxpython/mapdisp/main.py:610
#, python-format
-msgid "Unable to connect to <%s>"
+msgid "Unable to create file <%s>"
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:523
-#: ../gui/wxpython/menustrings.py:27 ../gui/wxpython/menustrings.py:28
-msgid "Add web service layer"
+#: ../gui/wxpython/mapdisp/main.py:626
+#, python-format
+msgid "Stopping map display <%s>..."
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:538
-msgid "Add selected web service layers as map layer into layer tree"
+#: ../gui/wxpython/wxplot/profile.py:49
+msgid "GRASS Profile Analysis Tool"
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:636
-msgid "Web service layer properties"
+#: ../gui/wxpython/wxplot/profile.py:65 ../gui/wxpython/wxplot/profile.py:173
+msgid "Profile of"
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:683
-msgid "&Apply"
+#: ../gui/wxpython/wxplot/profile.py:94
+#, python-format
+msgid "Distance (%s)"
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:688
-msgid "&OK"
+#: ../gui/wxpython/wxplot/profile.py:96
+msgid "Distance along transect"
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:856
-msgid "Name for output raster map:"
+#: ../gui/wxpython/wxplot/profile.py:97
+msgid "Cell values"
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:866
-msgid "Export region"
+#: ../gui/wxpython/wxplot/profile.py:166
+msgid "Not all points of profile lie inside computational region."
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:871
-msgid "Map display"
+#: ../gui/wxpython/wxplot/profile.py:237
+msgid "Raster values"
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:873
-#: ../gui/wxpython/mapdisp/statusbar.py:1152
-msgid "Computational region"
+#: ../gui/wxpython/wxplot/profile.py:290
+msgid "You must draw a transect to profile in the map display window."
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:875
-msgid "Named region"
+#: ../gui/wxpython/wxplot/profile.py:291
+msgid "Nothing to profile"
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:877
-msgid "Extent and resolution are based on Map Display geometry."
+#: ../gui/wxpython/wxplot/profile.py:359
+msgid "Choose prefix for file(s) where to save profile values..."
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:879
-msgid "Extent and resolution are based on computational region."
+#: ../gui/wxpython/wxplot/profile.py:361
+msgid "Comma separated value (*.csv)|*.csv"
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:881
-msgid "Extent and resolution are based on named region."
+#: ../gui/wxpython/wxplot/profile.py:372 ../gui/wxpython/gmodeler/frame.py:1981
+#: ../gui/wxpython/gui_core/pyedit.py:333
+#, python-format
+msgid "File <%s> already exists. Do you want to overwrite this file?"
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:886
-msgid "Overwrite existing raster map"
+#: ../gui/wxpython/wxplot/profile.py:375
+msgid "Overwrite file?"
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:891
-msgid "Choose named region:"
+#: ../gui/wxpython/wxplot/profile.py:386
+#, python-format
+msgid ""
+"Unable to open file <%s> for writing.\n"
+"Reason: %s"
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:904
-msgid "&Save layer"
+#: ../gui/wxpython/wxplot/profile.py:402
+#, python-format
+msgid ""
+"%d files created:\n"
+"%s"
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:905
-msgid "Save web service layer as raster map"
+#: ../gui/wxpython/wxplot/profile.py:405
+msgid "No files generated."
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:1026
-msgid "Missing output raster."
+#: ../gui/wxpython/wxplot/profile.py:413
+msgid "Statistics for Profile(s)"
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:1030
-msgid "Output map can be added only to current mapset."
+#: ../gui/wxpython/wxplot/dialogs.py:41
+msgid "Select raster maps to profile"
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:1034
-#, python-format
-msgid "Output map <%s> already exists"
+#: ../gui/wxpython/wxplot/dialogs.py:81
+msgid "Select raster map(s) to profile:"
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:1055
-#, python-format
-msgid "Region <%s> does not exist."
+#: ../gui/wxpython/wxplot/dialogs.py:132
+msgid "Select pairs of raster maps for scatterplots"
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:1084
-msgid "Downloading data..."
+#: ../gui/wxpython/wxplot/dialogs.py:180
+msgid "Select pairs of raster maps for bivariate scatterplots:"
msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:1111
-msgid "Unable to fetch data.\n"
+#: ../gui/wxpython/wxplot/dialogs.py:195 ../gui/wxpython/wxplot/dialogs.py:502
+msgid "Number of bins (for FP maps)"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:131
-msgid " Requested data settings "
+#: ../gui/wxpython/wxplot/dialogs.py:360
+msgid "C&opy"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:158
-msgid "Request"
+#: ../gui/wxpython/wxplot/dialogs.py:362
+msgid "Copy regression statistics the clipboard (Ctrl+C)"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:163
-msgid "List of layers "
+#: ../gui/wxpython/wxplot/dialogs.py:403
+msgid "Regression statistics copied to clipboard"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:181
-msgid "Source projection:"
+#: ../gui/wxpython/wxplot/dialogs.py:414
+msgid "Select raster map or imagery group to histogram"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:242
-msgid "Advanced request settings"
+#: ../gui/wxpython/wxplot/dialogs.py:442
+msgid "Histogram single raster"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:250
-msgid "Order of layers in raster"
+#: ../gui/wxpython/wxplot/dialogs.py:445
+msgid "Histogram imagery group"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:263
-msgid "Reprojection method:"
+#: ../gui/wxpython/wxplot/dialogs.py:467
+#: ../gui/wxpython/modules/colorrules.py:413
+msgid "Select raster map:"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:270
-msgid "Nearest neighbor"
+#: ../gui/wxpython/wxplot/dialogs.py:486
+msgid "Select image group:"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:271
-msgid "Linear interpolation"
+#: ../gui/wxpython/wxplot/dialogs.py:515
+msgid "Histogram type"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:272
-msgid "Cubic interpolation"
+#: ../gui/wxpython/wxplot/dialogs.py:601
+msgid "Selected group must be in current mapset"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:273
-msgid "Cubic spline interpolation"
+#: ../gui/wxpython/wxplot/dialogs.py:664 ../gui/wxpython/wxplot/base.py:517
+#: ../gui/wxpython/wxplot/base.py:584
+msgid "Text settings"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:277
-msgid "Maximum columns to request from server at time:"
+#: ../gui/wxpython/wxplot/dialogs.py:674
+msgid "Profile title:"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:283
-msgid "Maximum rows to request from server at time:"
+#: ../gui/wxpython/wxplot/dialogs.py:688
+msgid "Title font size (pts):"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:300
-msgid "Do not request transparent data"
+#: ../gui/wxpython/wxplot/dialogs.py:705
+msgid "X-axis label:"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:315
-msgid "Additional query parameters for server:"
+#: ../gui/wxpython/wxplot/dialogs.py:719
+msgid "Y-axis label:"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:528
-#, python-format
-msgid ""
-"Unable to download %s capabilities file\n"
-"from <%s>:\n"
+#: ../gui/wxpython/wxplot/dialogs.py:733
+msgid "Label font size (pts):"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:545
-#, python-format
-msgid ""
-"%s web service was not found in fetched capabilities file from <%s>:\n"
-"%s\n"
+#: ../gui/wxpython/wxplot/dialogs.py:761
+msgid "Font family:"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:831
-msgid "Source image format"
+#: ../gui/wxpython/wxplot/dialogs.py:777
+msgid "Style:"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:867
-msgid "Select layer in layer list.\n"
+#: ../gui/wxpython/wxplot/dialogs.py:793
+msgid "Weight:"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:872
-msgid "Select source image format.\n"
+#: ../gui/wxpython/wxplot/dialogs.py:832 ../gui/wxpython/wxplot/dialogs.py:1430
+msgid "Apply changes for the current session and close dialog"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:877
-msgid "Select source projection.\n"
+#: ../gui/wxpython/wxplot/dialogs.py:904
+#, python-format
+msgid "Plot text sizes saved to file '%s'."
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:881
-msgid "Choose output layer name.\n"
+#: ../gui/wxpython/wxplot/dialogs.py:964
+msgid "No map or image group selected to plot."
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:922
-#: ../gui/wxpython/gmodeler/frame.py:1635
-#: ../gui/wxpython/gmodeler/frame.py:1682 ../gui/wxpython/gui_core/ghelp.py:393
-#: ../gui/wxpython/gui_core/ghelp.py:395 ../gui/wxpython/gui_core/ghelp.py:469
-msgid "Name"
+#: ../gui/wxpython/wxplot/dialogs.py:965
+#: ../gui/wxpython/mapwin/buffered.py:2136
+#: ../gui/wxpython/core/workspace.py:1629 ../gui/wxpython/core/gcmd.py:140
+msgid "Warning"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:925
-#: ../gui/wxpython/modules/import_export.py:72
-#: ../gui/wxpython/gui_core/forms.py:2013
-msgid "Layer name"
+#: ../gui/wxpython/wxplot/dialogs.py:986 ../gui/wxpython/wxplot/base.py:521
+#: ../gui/wxpython/wxplot/base.py:598
+msgid "Plot settings"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:962
-msgid "layer"
+#: ../gui/wxpython/wxplot/dialogs.py:1007
+msgid "Map/image plotted"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:982
-msgid "style"
+#: ../gui/wxpython/wxplot/dialogs.py:1019
+msgid "Settings for selected map"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:1155
-msgid "Add default"
+#: ../gui/wxpython/wxplot/dialogs.py:1037
+msgid "Line color"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:1172
-#, python-format
-msgid ""
-"User defined server with same name as default server <%s> already exists.\n"
-"Keeping user defined server"
+#: ../gui/wxpython/wxplot/dialogs.py:1054
+#: ../gui/wxpython/vdigit/preferences.py:166
+msgid "Line width"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:41
-msgid "Fetch & install extension from GRASS Addons"
+#: ../gui/wxpython/wxplot/dialogs.py:1104
+msgid "Transect segment marker settings"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:58
-msgid "Repository (leave empty to use the official one)"
+#: ../gui/wxpython/wxplot/dialogs.py:1186
+msgid "Scatterplot points"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:61
-msgid "List of extensions - double-click to install"
+#: ../gui/wxpython/wxplot/dialogs.py:1268
+msgid "Axis settings"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:85
-msgid "Options"
+#: ../gui/wxpython/wxplot/dialogs.py:1274
+msgid "X-Axis"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:113
-msgid "&Fetch"
+#: ../gui/wxpython/wxplot/dialogs.py:1275
+msgid "Y-Axis"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:114
-msgid "Fetch list of available modules from GRASS Addons SVN repository"
+#: ../gui/wxpython/wxplot/dialogs.py:1284
+msgid "Scale"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:118
-msgid "&Install"
+#: ../gui/wxpython/wxplot/dialogs.py:1296
+msgid "Automatic axis scaling, custom max and min, or scale matches data range (min)"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:120
-msgid "Install selected add-ons GRASS module"
+#: ../gui/wxpython/wxplot/dialogs.py:1304
+msgid "Custom min"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:123
-msgid "Show g.extension manual page"
+#: ../gui/wxpython/wxplot/dialogs.py:1321
+msgid "Custom max"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:187
-msgid "Extension not defined"
+#: ../gui/wxpython/wxplot/dialogs.py:1335
+msgid "Log scale"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:211
-msgid "Fetching list of modules from GRASS-Addons SVN (be patient)..."
+#: ../gui/wxpython/wxplot/dialogs.py:1359
+msgid "Grid and Legend settings"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:226
-#, python-format
-msgid "%d extensions loaded"
+#: ../gui/wxpython/wxplot/dialogs.py:1364
+msgid "Grid color"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:238
-msgid "Install"
+#: ../gui/wxpython/wxplot/dialogs.py:1374
+msgid "Show grid"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:243
-msgid "Show manual page"
+#: ../gui/wxpython/wxplot/dialogs.py:1383
+msgid "Legend font size"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:344
+#: ../gui/wxpython/wxplot/dialogs.py:1397
+msgid "Show legend"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1597
#, python-format
-msgid "Unable to load extensions. %s"
+msgid "Plot settings saved to file '%s'."
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:390
-msgid "Manage installed GRASS Addons extensions"
+#: ../gui/wxpython/wxplot/histogram.py:43
+msgid "GRASS GIS Histogramming Tool"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:406
-msgid "List of installed extensions"
+#: ../gui/wxpython/wxplot/histogram.py:51
+msgid "Histogram of"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:414
-msgid "Uninstall"
+#: ../gui/wxpython/wxplot/histogram.py:52
+#: ../gui/wxpython/wxplot/histogram.py:156 ../gui/wxpython/wxplot/scatter.py:52
+#: ../gui/wxpython/wxplot/scatter.py:53
+msgid "Raster cell values"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:416
-msgid "Uninstall selected Addons extensions"
+#: ../gui/wxpython/wxplot/histogram.py:53
+#: ../gui/wxpython/wxplot/histogram.py:162
+msgid "Cell counts"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:420
-msgid "Reinstall"
+#: ../gui/wxpython/wxplot/histogram.py:141
+#, python-format
+msgid "Histogram of image group <%s>"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:422
-msgid "Reinstall selected Addons extensions"
+#: ../gui/wxpython/wxplot/histogram.py:145
+#, python-format
+msgid "Histogram of raster map <%s>"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:463
-msgid "No extension selected. Operation canceled."
+#: ../gui/wxpython/wxplot/histogram.py:147
+msgid "Histogram of selected raster maps"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:490
+#: ../gui/wxpython/wxplot/histogram.py:154
#, python-format
-msgid ""
-"List of files to be removed:\n"
-"%(files)s\n"
-"\n"
-"Do you want really to remove <%(ext)s> extension?"
+msgid "Raster cell values %s"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:494
-msgid "Remove extension"
+#: ../gui/wxpython/wxplot/histogram.py:164
+msgid "Percent of total cells"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:527
-msgid "Extension"
+#: ../gui/wxpython/wxplot/histogram.py:166
+msgid "Area"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:34 ../gui/wxpython/modules/vclean.py:120
-msgid "Set up vector cleaning tools"
+#: ../gui/wxpython/wxplot/histogram.py:252
+msgid "Statistics for Map(s) Histogrammed"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:75
-msgid "break lines/boundaries"
+#: ../gui/wxpython/wxplot/histogram.py:257
+#, python-format
+msgid "Statistics for raster map <%s>"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:76
-msgid "remove duplicates"
+#: ../gui/wxpython/wxplot/scatter.py:44
+msgid "GRASS Bivariate Scatterplot Tool"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:77
-msgid "remove dangles"
+#: ../gui/wxpython/wxplot/scatter.py:51
+msgid "Bivariate Scatterplot"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:78
-msgid "change boundary dangles to lines"
+#: ../gui/wxpython/wxplot/scatter.py:102 ../gui/wxpython/wxplot/scatter.py:254
+msgid "Nothing to plot."
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:79
-msgid "remove bridges"
+#: ../gui/wxpython/wxplot/scatter.py:113
+msgid "At least 2 raster maps must be specified"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:80
-msgid "change bridges to lines"
+#: ../gui/wxpython/wxplot/scatter.py:136
+msgid "Bivariate Scatterplot of "
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:81
-msgid "snap lines/boundaries"
+#: ../gui/wxpython/wxplot/scatter.py:157 ../gui/wxpython/wxplot/scatter.py:158
+#, python-format
+msgid "Raster <%s> cell values"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:82
-msgid "remove duplicate area centroids"
+#: ../gui/wxpython/wxplot/scatter.py:162 ../gui/wxpython/wxplot/scatter.py:166
+#, python-format
+msgid ": %s"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:83
-msgid "break polygons"
+#: ../gui/wxpython/wxplot/scatter.py:260
+msgid "Regression Statistics for Scatterplot(s)"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:84
-msgid "prune lines/boundaries"
+#: ../gui/wxpython/wxplot/scatter.py:271
+#, python-format
+msgid ""
+"Regression equation for raster map <%(rast1)s> vs. <%(rast2)s>:\n"
+"\n"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:85
-msgid "remove small areas"
+#: ../gui/wxpython/wxplot/base.py:37
+msgid "Draw/re-draw plot"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:86
-msgid "remove lines/boundaries of zero length"
+#: ../gui/wxpython/wxplot/base.py:40
+msgid "Draw transect in map display window to profile"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:87
-msgid "remove small angles at nodes"
+#: ../gui/wxpython/wxplot/base.py:43
+msgid "Plot options"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:122
-msgid "Choose cleaning tools and set thresholds"
+#: ../gui/wxpython/wxplot/base.py:46
+msgid "Plot statistics"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:126
-msgid "Select input vector map:"
+#: ../gui/wxpython/wxplot/base.py:49
+msgid "Save profile data to CSV file"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:132
-msgid " Feature type: "
+#: ../gui/wxpython/wxplot/base.py:51
+msgid "Quit plot tool"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:136
-msgid "Select output vector map:"
+#: ../gui/wxpython/wxplot/base.py:485
+msgid "Left Mouse Down at Point:"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:145
-#: ../gui/wxpython/modules/import_export.py:89
-#: ../gui/wxpython/modules/mcalc_builder.py:269
-#: ../gui/wxpython/gmodeler/preferences.py:682
-#: ../gui/wxpython/gui_core/preferences.py:1122
-msgid "Allow output files to overwrite existing files"
+#: ../gui/wxpython/wxplot/base.py:534
+msgid "This feature is not yet functional"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:173
-#: ../gui/wxpython/modules/mcalc_builder.py:148
-#: ../gui/wxpython/gmodeler/model.py:2809
-#: ../gui/wxpython/gmodeler/frame.py:1887 ../gui/wxpython/gui_core/menu.py:170
-#: ../gui/wxpython/gui_core/forms.py:590
-msgid "&Run"
+#: ../gui/wxpython/wxplot/base.py:535
+msgid "Under Construction"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:177
-msgid "Copy the current command string to the clipboard (Ctrl+C)"
+#: ../gui/wxpython/vdigit/g.gui.vdigit.py:69
+msgid "GRASS GIS Vector Digitizer"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:223
-msgid "line"
+#: ../gui/wxpython/vdigit/g.gui.vdigit.py:85
+#, python-format
+msgid "Vector digitizer not available. %s"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:224
-msgid "boundary"
+#: ../gui/wxpython/vdigit/g.gui.vdigit.py:90
+#, python-format
+msgid "Vector map <%s> not found in current mapset. New vector map can be created by providing '-c' flag."
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:225
-msgid "centroid"
+#: ../gui/wxpython/vdigit/g.gui.vdigit.py:94
+#, python-format
+msgid "New vector map <%s> created"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:227
-msgid "face"
+#: ../gui/wxpython/vdigit/g.gui.vdigit.py:101
+#, python-format
+msgid "Unable to create new vector map <%s>"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:401
+#: ../gui/wxpython/vdigit/wxdisplay.py:1017
#, python-format
-msgid "%s. cleaning tool removed, will be ignored"
+msgid "Topology for vector map <%s> is not available. Topology is required by digitizer. Do you want to rebuild topology (takes some time) and open the vector map for editing?"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:404
-msgid "Please select a cleaning tool to remove"
+#: ../gui/wxpython/vdigit/wxdisplay.py:1022
+msgid "Topology missing"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:428
-#, python-format
-msgid "%s. cleaning tool moved up"
+#: ../gui/wxpython/vdigit/mapwindow.py:424
+msgid "Update categories"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:430
-msgid "1. cleaning tool can not be moved up "
+#: ../gui/wxpython/vdigit/mapwindow.py:548
+#: ../gui/wxpython/vdigit/mapwindow.py:957
+msgid "No vector map selected for editing."
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:432
-msgid "Please select a cleaning tool to move up"
+#: ../gui/wxpython/vdigit/mapwindow.py:557
+msgid "Nothing to do. Choose appropriate tool from digitizer toolbar."
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:460
-#, python-format
-msgid "%s. cleaning tool moved down"
+#: ../gui/wxpython/vdigit/mapwindow.py:1091
+msgid "Z bulk-labeling dialog"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:462
-msgid "Last cleaning tool can not be moved down "
+#: ../gui/wxpython/vdigit/dialogs.py:79
+msgid "List of categories - right-click to delete"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:464
-msgid "Please select a cleaning tool to move down"
+#: ../gui/wxpython/vdigit/dialogs.py:110
+msgid "Add new category"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:478
-#, python-format
-msgid "cleaning tool: '%s'"
+#: ../gui/wxpython/vdigit/dialogs.py:153
+msgid "Ignore changes and close dialog"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:488
+#: ../gui/wxpython/vdigit/dialogs.py:155
+#: ../gui/wxpython/web_services/dialogs.py:689
+msgid "Apply changes and close dialog"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:248 ../gui/wxpython/vdigit/dialogs.py:472
#, python-format
-msgid "Threshold for %(num)s. tool '%(tool)s': %(thresh)s"
+msgid ""
+"Unable to add new layer/category <%(layer)s/%(category)s>.\n"
+"Layer and category number must be integer.\n"
+"Layer number must be greater than zero."
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:516
-msgid "Name of input vector map"
+#: ../gui/wxpython/vdigit/dialogs.py:284
+#: ../gui/wxpython/gmodeler/dialogs.py:844
+#: ../gui/wxpython/gmodeler/dialogs.py:1013
+msgid "Delete selected"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:517
-msgid "Name for output vector map"
+#: ../gui/wxpython/vdigit/dialogs.py:288
+#: ../gui/wxpython/gmodeler/dialogs.py:845
+msgid "Delete all"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:519
-msgid "Threshold"
+#: ../gui/wxpython/vdigit/dialogs.py:446
+msgid "Unable to update vector map."
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:521
+#: ../gui/wxpython/vdigit/dialogs.py:622
#, python-format
-msgid "'%s' not defined"
+msgid "%d lines selected for z bulk-labeling"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:523
-#, python-format
-msgid ""
-"Some parameters not defined. Operation canceled.\n"
-"\n"
-"%s"
+#: ../gui/wxpython/vdigit/dialogs.py:630
+msgid "Set value"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:528
-msgid "Executing selected cleaning operations..."
+#: ../gui/wxpython/vdigit/dialogs.py:637
+msgid "Starting value"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:585
-msgid "Vector cleaning command copied to clipboard"
+#: ../gui/wxpython/vdigit/dialogs.py:649
+msgid "Step"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:79
-msgid "Check all"
+#: ../gui/wxpython/vdigit/dialogs.py:692
+msgid "List of duplicates"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:82
-msgid "Clear all"
+#: ../gui/wxpython/vdigit/dialogs.py:801
+msgid "Feature id"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:140
-msgid "Enter vector attribute values"
+#: ../gui/wxpython/vdigit/dialogs.py:802
+msgid "Layer (Categories)"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:311
-msgid "Bad color format. Use color format '0:0:0'"
+#: ../gui/wxpython/vdigit/toolbars.py:107
+msgid "Select area/boundary/centroid tool"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:413
-#: ../gui/wxpython/wxplot/dialogs.py:467
-msgid "Select raster map:"
+#: ../gui/wxpython/vdigit/toolbars.py:133
+msgid "Digitize new point"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:415
-msgid "Select vector map:"
+#: ../gui/wxpython/vdigit/toolbars.py:134
+#: ../gui/wxpython/vdigit/toolbars.py:143
+#: ../gui/wxpython/vdigit/toolbars.py:146
+msgid "Left: new point"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:435
-msgid "Import or export color table:"
+#: ../gui/wxpython/vdigit/toolbars.py:136
+msgid "Digitize new line"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:440
-msgid "Choose file to load color table"
+#: ../gui/wxpython/vdigit/toolbars.py:137
+#: ../gui/wxpython/vdigit/toolbars.py:140
+#: ../gui/wxpython/vdigit/toolbars.py:164
+msgid "Left: new point; Ctrl+Left: undo last point; Right: close line"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:441
-msgid "Load"
+#: ../gui/wxpython/vdigit/toolbars.py:139
+msgid "Digitize new boundary"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:443
-msgid "Type filename or click to choose file and load color table"
+#: ../gui/wxpython/vdigit/toolbars.py:142
+msgid "Digitize new centroid"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:449
-msgid "Choose file to save color table"
+#: ../gui/wxpython/vdigit/toolbars.py:145
+msgid "Digitize new area (boundary without category)"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:451
-msgid "Type filename or click to choose file and save color table"
+#: ../gui/wxpython/vdigit/toolbars.py:148
+msgid "Add new vertex to line or boundary"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:453 ../gui/wxpython/menustrings.py:10
-#: ../gui/wxpython/menustrings.py:2014
-msgid "Save"
+#: ../gui/wxpython/vdigit/toolbars.py:149
+#: ../gui/wxpython/vdigit/toolbars.py:152
+#: ../gui/wxpython/vdigit/toolbars.py:155
+#: ../gui/wxpython/vdigit/toolbars.py:167
+#: ../gui/wxpython/vdigit/toolbars.py:170
+#: ../gui/wxpython/vdigit/toolbars.py:173
+#: ../gui/wxpython/vdigit/toolbars.py:182
+msgid "Left: Select; Ctrl+Left: Unselect; Right: Confirm"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:465
-msgid "&Set"
+#: ../gui/wxpython/vdigit/toolbars.py:151
+msgid "Delete selected point(s), line(s), boundary(ies) or centroid(s)"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:473
-msgid "Load color table:"
+#: ../gui/wxpython/vdigit/toolbars.py:154
+msgid "Delete selected area(s)"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:479
-msgid "Load color table from file:"
+#: ../gui/wxpython/vdigit/toolbars.py:157
+msgid "Display/update attributes"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:487
-msgid "Save color table to file:"
+#: ../gui/wxpython/vdigit/toolbars.py:158
+#: ../gui/wxpython/vdigit/toolbars.py:161
+msgid "Left: Select"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:519
-msgid "Reload default table"
+#: ../gui/wxpython/vdigit/toolbars.py:160
+msgid "Display/update categories"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:582
-#: ../gui/wxpython/iclass/toolbars.py:76
-msgid "Preview"
+#: ../gui/wxpython/vdigit/toolbars.py:163
+msgid "Edit selected line/boundary"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:587
-msgid "Show preview of map (current Map Display extent is used)."
+#: ../gui/wxpython/vdigit/toolbars.py:166
+msgid "Move selected point(s), line(s), boundary(ies) or centroid(s)"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:619
-#: ../gui/wxpython/modules/colorrules.py:1889
-msgid "No valid color rules given."
+#: ../gui/wxpython/vdigit/toolbars.py:169
+msgid "Move selected vertex"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:676
-#, python-format
-msgid "File <%s> already already exists. Do you want to overwrite it?"
+#: ../gui/wxpython/vdigit/toolbars.py:172
+msgid "Remove selected vertex"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:690
-#: ../gui/wxpython/gui_core/forms.py:2319
-msgid "Nothing to save."
+#: ../gui/wxpython/vdigit/toolbars.py:174
+#: ../gui/wxpython/vdigit/preferences.py:33
+msgid "Digitization settings"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:723
-msgid "Invalid color table format"
+#: ../gui/wxpython/vdigit/toolbars.py:175
+msgid "Quit digitizer"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:804
-#, python-format
-msgid "Invalid rule value '%s'. Unable to apply color table."
+#: ../gui/wxpython/vdigit/toolbars.py:176
+msgid "Quit digitizer and save changes"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:890
-msgid "Create new color table for raster map"
+#: ../gui/wxpython/vdigit/toolbars.py:177
+msgid "Vector Digitizer manual"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:968
-msgid "Enter raster category values or percents"
+#: ../gui/wxpython/vdigit/toolbars.py:178
+msgid "Show Vector Digitizer manual"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:974
-msgid "fp range"
+#: ../gui/wxpython/vdigit/toolbars.py:180
+msgid "Additional tools (copy, flip, connect, etc.)"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:976
-#, python-format
-msgid "Enter raster category values or percents (%(range)s = %(min)d-%(max)d)"
+#: ../gui/wxpython/vdigit/toolbars.py:185
+msgid "Undo previous changes"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1083
-msgid "Create new color rules for vector map"
+#: ../gui/wxpython/vdigit/toolbars.py:187
+msgid "Redo"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1096
-#: ../gui/wxpython/modules/colorrules.py:1673
-msgid "Enter vector attribute values or percents:"
+#: ../gui/wxpython/vdigit/toolbars.py:188
+msgid "Redo previous changes"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1098
-#: ../gui/wxpython/modules/colorrules.py:1675
-msgid "Enter vector attribute values:"
+#: ../gui/wxpython/vdigit/toolbars.py:558
+msgid "Break selected lines/boundaries at intersection"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1109
-msgid "Select vector columns"
+#: ../gui/wxpython/vdigit/toolbars.py:560
+msgid "Connect selected lines/boundaries"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1111
-msgid "Layer:"
+#: ../gui/wxpython/vdigit/toolbars.py:562
+msgid "Copy categories"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1113
-msgid "Attribute column:"
+#: ../gui/wxpython/vdigit/toolbars.py:564
+msgid "Copy features from (background) vector map"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1116
-msgid "Load color from column:"
+#: ../gui/wxpython/vdigit/toolbars.py:566
+msgid "Copy attributes"
msgstr ""
-msgid "Save color to column:"
+#: ../gui/wxpython/vdigit/toolbars.py:568
+msgid "Feature type conversion"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1118
-msgid "Load size from column:"
+#: ../gui/wxpython/vdigit/toolbars.py:570
+msgid "Flip selected lines/boundaries"
msgstr ""
-msgid "Save size to column:"
+#: ../gui/wxpython/vdigit/toolbars.py:572
+msgid "Merge selected lines/boundaries"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1120
-msgid "Load width from column:"
+#: ../gui/wxpython/vdigit/toolbars.py:574
+msgid "Snap selected lines/boundaries (only to nodes)"
msgstr ""
-msgid "Save width to column:"
+#: ../gui/wxpython/vdigit/toolbars.py:576
+msgid "Split line/boundary"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1125
-msgid "Use color column instead of color table:"
+#: ../gui/wxpython/vdigit/toolbars.py:578
+msgid "Query features"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1141
-msgid "Add GRASSRGB column to current attribute table."
+#: ../gui/wxpython/vdigit/toolbars.py:580
+msgid "Z bulk-labeling of 3D lines"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1200
-#: ../gui/wxpython/modules/colorrules.py:1256
-msgid "Import or export color table"
+#: ../gui/wxpython/vdigit/toolbars.py:602 ../gui/wxpython/vdigit/wxdigit.py:63
+msgid "No vector map open for editing."
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1270
-#, python-format
-msgid "Database connection for vector map <%s> is not defined in DB file. Do you want to create and connect new attribute table?"
+#: ../gui/wxpython/vdigit/toolbars.py:607
+msgid "Select background vector map"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1274
-msgid "No database connection defined"
+#: ../gui/wxpython/vdigit/toolbars.py:767
+msgid "Vector map is not 3D. Operation canceled."
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1347
+#: ../gui/wxpython/vdigit/toolbars.py:841
+#: ../gui/wxpython/vdigit/toolbars.py:998
+#: ../gui/wxpython/vdigit/toolbars.py:1096
+#: ../gui/wxpython/gui_core/dialogs.py:213
+msgid "Select vector map"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:873
#, python-format
-msgid "Selected map <%(map)s> is not in current mapset <%(mapset)s>. Attribute table cannot be edited."
+msgid ""
+"Topology for vector map <%s> is not available. Topology is required by digitizer.\n"
+"Do you want to rebuild topology (takes some time) and open the vector map for editing?"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1518
+#: ../gui/wxpython/vdigit/toolbars.py:878
+msgid "Digitizer error"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:903
#, python-format
-msgid "%s column already exists."
+msgid "Please wait, opening vector map <%s> for editing..."
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1552
-msgid "Please wait, loading data from attribute table..."
+#: ../gui/wxpython/vdigit/toolbars.py:941
+#, python-format
+msgid "Unsupported feature type '%(type)s'. Unable to edit OGR layer <%(layer)s>."
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1613
+#: ../gui/wxpython/vdigit/toolbars.py:1011
#, python-format
-msgid "Number of loaded records reached %d, displaying all the records will be time-consuming and may lead to computer freezing, do you still want to continue?"
+msgid "Do you want to save changes in vector map <%s>?"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1617
-msgid "Too many records"
+#: ../gui/wxpython/vdigit/toolbars.py:1014
+msgid "Save changes?"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1664
+#: ../gui/wxpython/vdigit/toolbars.py:1021
#, python-format
-msgid "Enter vector attribute values or percents %s:"
+msgid "Please wait, closing and rebuilding topology of vector map <%s>..."
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1668
+#: ../gui/wxpython/vdigit/toolbars.py:1039
#, python-format
-msgid "Enter vector attribute values %s:"
+msgid "Editing of vector map <%s> successfully finished"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1821
-msgid "Please select column to save values to."
+#: ../gui/wxpython/vdigit/toolbars.py:1104
+#: ../gui/wxpython/vdigit/toolbars.py:1111
+msgid "New vector map"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1857
-msgid "No color column defined. Operation canceled."
+#: ../gui/wxpython/vdigit/preferences.py:64
+msgid "Apply changes for this session"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1874
-msgid "Thematic mapping for vector map in 3D view"
+#: ../gui/wxpython/vdigit/preferences.py:68
+msgid "Close dialog and save changes to user settings file"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:45
-msgid "Multiple import"
+#: ../gui/wxpython/vdigit/preferences.py:150
+#: ../gui/wxpython/animation/dialogs.py:340
+#: ../gui/wxpython/animation/dialogs.py:1854
+#: ../gui/wxpython/gmodeler/preferences.py:54
+#: ../gui/wxpython/gui_core/preferences.py:281
+msgid "General"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:62
-msgid "List of raster layers"
+#: ../gui/wxpython/vdigit/preferences.py:202
+msgid "Snapping"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:64
-msgid "List of vector layers"
+#: ../gui/wxpython/vdigit/preferences.py:211
+msgid "Snapping threshold"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:66
+#: ../gui/wxpython/vdigit/preferences.py:220
+msgid "screen pixels"
+msgstr ""
+msgid "map units"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:240
+msgid "Snap also to vertex"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:250
+#: ../gui/wxpython/vdigit/preferences.py:905
+#: ../gui/wxpython/vdigit/preferences.py:919
+#: ../gui/wxpython/vdigit/preferences.py:923
#, python-format
-msgid "List of %s layers"
+msgid "Snapping threshold is %(value).1f %(units)s"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:68
-#: ../gui/wxpython/modules/import_export.py:885
-msgid "right click to (un)select all"
+#: ../gui/wxpython/vdigit/preferences.py:268
+msgid "Select vector features"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:71
-#: ../gui/wxpython/modules/import_export.py:862
-#: ../gui/wxpython/gui_core/forms.py:2012
-msgid "Layer id"
+#: ../gui/wxpython/vdigit/preferences.py:288
+msgid "Select threshold"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:73
-msgid "Name for output GRASS map (editable)"
+#: ../gui/wxpython/vdigit/preferences.py:309
+msgid "Select only features inside of selection bounding box"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:76
-#: ../gui/wxpython/modules/import_export.py:78
-#: ../gui/wxpython/gui_core/forms.py:2015
-msgid "Projection match"
+#: ../gui/wxpython/vdigit/preferences.py:316
+msgid "By default are selected all features overlapping selection bounding box "
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:85
-msgid "Override projection check (use current location's projection)"
+#: ../gui/wxpython/vdigit/preferences.py:319
+msgid "Check for duplicates"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:98
-#: ../gui/wxpython/gui_core/forms.py:679
-msgid "Close dialog on finish"
+#: ../gui/wxpython/vdigit/preferences.py:345
+msgid "Digitize lines/boundaries"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:116
-#: ../gui/wxpython/modules/import_export.py:393
-#: ../gui/wxpython/modules/import_export.py:534
-msgid "&Import"
+#: ../gui/wxpython/vdigit/preferences.py:349
+msgid "Break lines at intersection"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:117
-#: ../gui/wxpython/modules/import_export.py:394
-#: ../gui/wxpython/modules/import_export.py:535
-msgid "Import selected layers"
+#: ../gui/wxpython/vdigit/preferences.py:372
+msgid "Digitize areas"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:128
-msgid "Source settings"
+#: ../gui/wxpython/vdigit/preferences.py:376
+msgid "Close boundary (snap to the start node)"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:149
-msgid "Import settings"
+#: ../gui/wxpython/vdigit/preferences.py:399
+msgid "Save changes"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:369
-#: ../gui/wxpython/lmgr/layertree.py:59 ../gui/wxpython/menustrings.py:164
-#: ../gui/wxpython/menustrings.py:1187
-msgid "Link external raster data"
+#: ../gui/wxpython/vdigit/preferences.py:402
+msgid "Save changes on exit"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:371
-#: ../gui/wxpython/lmgr/layertree.py:57 ../gui/wxpython/menustrings.py:35
-#: ../gui/wxpython/menustrings.py:1058
-msgid "Import raster data"
+#: ../gui/wxpython/vdigit/preferences.py:423
+msgid "Query tool"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:379
-#: ../gui/wxpython/modules/import_export.py:520
-msgid "Add linked layers into layer tree"
+#: ../gui/wxpython/vdigit/preferences.py:434
+msgid "Choose query tool"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:381
-#: ../gui/wxpython/modules/import_export.py:522
-#: ../gui/wxpython/modules/import_export.py:751
-msgid "Add imported layers into layer tree"
+#: ../gui/wxpython/vdigit/preferences.py:442
+msgid "Select by box"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:390
-#: ../gui/wxpython/modules/import_export.py:531
-msgid "&Link"
+#: ../gui/wxpython/vdigit/preferences.py:460
+#: ../gui/wxpython/vdigit/preferences.py:694
+msgid "length"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:391
-#: ../gui/wxpython/modules/import_export.py:532
-msgid "Link selected layers"
+#: ../gui/wxpython/vdigit/preferences.py:472
+msgid "Select lines"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:414
-#: ../gui/wxpython/modules/import_export.py:555
-msgid "No layers selected. Operation canceled."
+#: ../gui/wxpython/vdigit/preferences.py:475
+#: ../gui/wxpython/vdigit/preferences.py:529
+msgid "shorter than"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:440
-msgid "Unable to determine number of raster bands"
+msgid "longer than"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:510
-#: ../gui/wxpython/lmgr/layertree.py:67 ../gui/wxpython/menustrings.py:166
-#: ../gui/wxpython/menustrings.py:1189
-msgid "Link external vector data"
+#: ../gui/wxpython/vdigit/preferences.py:514
+msgid "dangle"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:512
-#: ../gui/wxpython/lmgr/layertree.py:65 ../gui/wxpython/menustrings.py:66
-#: ../gui/wxpython/menustrings.py:1089
-msgid "Import vector data"
+#: ../gui/wxpython/vdigit/preferences.py:526
+msgid "Select dangles"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:655
-msgid "Define output format for vector data"
+#: ../gui/wxpython/vdigit/preferences.py:582
+#: ../gui/wxpython/gui_core/preferences.py:1438
+msgid "Attributes"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:657
-msgid "Define output format for raster data"
+#: ../gui/wxpython/vdigit/preferences.py:593
+msgid "Digitize new feature"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:665
-msgid "Set external format and close dialog"
+#: ../gui/wxpython/vdigit/preferences.py:598
+msgid "Add new record into table"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:722
-msgid "No data source selected."
+#: ../gui/wxpython/vdigit/preferences.py:613
+msgid "Mode"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:737
-msgid "Import DXF layers"
+#: ../gui/wxpython/vdigit/preferences.py:645
+msgid "Next to use"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:744
-msgid "Choose DXF file to import"
+#: ../gui/wxpython/vdigit/preferences.py:627
+msgid "Category number"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:773
-msgid "No layers selected."
+#: ../gui/wxpython/vdigit/preferences.py:643
+msgid "Category mode"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:851
-msgid "Reprojection"
+msgid "Manual entry"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:863
-msgid "Name for output GRASS map"
+msgid "No category"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:881
-msgid "Projection of following layers do not match with projection of current location. "
+#: ../gui/wxpython/vdigit/preferences.py:668
+msgid "Delete existing feature(s)"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:883
-msgid "Layers to be reprojected"
+#: ../gui/wxpython/vdigit/preferences.py:673
+msgid "Delete record from table"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:897
-msgid "&Import && reproject"
+#: ../gui/wxpython/vdigit/preferences.py:691
+msgid "Geometry attributes"
msgstr ""
-#: ../gui/wxpython/modules/import_export.py:898
-msgid "Reproject selected layers"
+#: ../gui/wxpython/vdigit/preferences.py:695
+#: ../gui/wxpython/modules/vclean.py:226
+msgid "area"
msgstr ""
-#: ../gui/wxpython/modules/histogram.py:190
-#: ../gui/wxpython/mapwin/buffered.py:694
-msgid "Please wait, exporting image..."
+#: ../gui/wxpython/vdigit/preferences.py:696
+msgid "perimeter"
msgstr ""
-#: ../gui/wxpython/modules/histogram.py:292
-msgid "GRASS GIS Histogramming Tool (d.histogram)"
+#: ../gui/wxpython/vdigit/preferences.py:767
+msgid "Note: These settings are stored in the workspace not in the vector digitizer preferences."
msgstr ""
-#: ../gui/wxpython/modules/histogram.py:424
-msgid "Select font for histogram text"
+#: ../gui/wxpython/vdigit/preferences.py:796
+msgid "Digitize new line segment"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:55
-msgid "GRASS GIS Raster Map Calculator"
+#: ../gui/wxpython/vdigit/preferences.py:797
+msgid "Digitize new line/boundary"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:58
-msgid "GRASS GIS 3D Raster Map Calculator"
+#: ../gui/wxpython/vdigit/preferences.py:798
+msgid "Highlight"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:74
-msgid "mapcalc statement"
+#: ../gui/wxpython/vdigit/preferences.py:799
+msgid "Highlight (duplicates)"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:132
-msgid "Operators"
+#: ../gui/wxpython/vdigit/preferences.py:802
+msgid "Boundary (no area)"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:134
-#: ../gui/wxpython/vnet/dialogs.py:345
-msgid "Output"
+#: ../gui/wxpython/vdigit/preferences.py:803
+msgid "Boundary (one area)"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:136
-msgid "Operands"
+#: ../gui/wxpython/vdigit/preferences.py:804
+msgid "Boundary (two areas)"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:138
-msgid "Expression"
+#: ../gui/wxpython/vdigit/preferences.py:805
+msgid "Centroid (in area)"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:153
-msgid "Save expression to file"
+#: ../gui/wxpython/vdigit/preferences.py:806
+msgid "Centroid (outside area)"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:155
-#: ../gui/wxpython/gui_core/forms.py:1840
-msgid "&Load"
+#: ../gui/wxpython/vdigit/preferences.py:807
+msgid "Centroid (duplicate in area)"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:156
-msgid "Load expression from file"
+#: ../gui/wxpython/vdigit/preferences.py:808
+msgid "Node (one line)"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:159
-#: ../gui/wxpython/gui_core/forms.py:610
-msgid "Copy the current command string to the clipboard"
+#: ../gui/wxpython/vdigit/preferences.py:809
+msgid "Node (two lines)"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:163
-msgid "exponent"
+#: ../gui/wxpython/vdigit/preferences.py:810
+msgid "Vertex"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:165
-msgid "divide"
+#: ../gui/wxpython/vdigit/preferences.py:811
+msgid "Area (closed boundary + centroid)"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:167
-msgid "add"
+#: ../gui/wxpython/vdigit/preferences.py:812
+msgid "Direction"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:170
-msgid "subtract"
+#: ../gui/wxpython/vdigit/preferences.py:896
+msgid "Snapping disabled"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:172
-msgid "modulus"
+#: ../gui/wxpython/vdigit/preferences.py:900
+#, python-format
+msgid "Snapping threshold is %(value).1f %(units)s (based on comp. resolution)"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:175
-msgid "multiply"
+#: ../gui/wxpython/vdigit/preferences.py:956
+#, python-format
+msgid "Vector digitizer settings saved to file <%s>."
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:183
-msgid "left shift"
+#: ../gui/wxpython/vdigit/wxdigit.py:56
+msgid "Digitization Error"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:186
-msgid "right shift"
+#: ../gui/wxpython/vdigit/wxdigit.py:61
+#, python-format
+msgid "Unable to open vector map <%s>."
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:189
-msgid "right shift (unsigned)"
+#: ../gui/wxpython/vdigit/wxdigit.py:64
+msgid "Operation canceled."
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:191
-msgid "greater than"
+#: ../gui/wxpython/vdigit/wxdigit.py:71
+#, python-format
+msgid ""
+"Writing new feature failed. Operation canceled.\n"
+"\n"
+"Reason: %s"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:194
-msgid "greater than or equal to"
+#: ../gui/wxpython/vdigit/wxdigit.py:80
+#, python-format
+msgid "Reading feature id %d failed. Operation canceled."
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:196
-msgid "less than"
+#: ../gui/wxpython/vdigit/wxdigit.py:88
+#, python-format
+msgid "Database link %d not available. Operation canceled."
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:199
-msgid "less than or equal to"
+#: ../gui/wxpython/vdigit/wxdigit.py:96
+#, python-format
+msgid "Unable to start database driver <%s>. Operation canceled."
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:201
-msgid "equal to"
+#: ../gui/wxpython/vdigit/wxdigit.py:106
+#, python-format
+msgid "Unable to open database <%(db)s> by driver <%(driver)s>. Operation canceled."
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:204
-msgid "not equal to"
+#: ../gui/wxpython/vdigit/wxdigit.py:114
+#, python-format
+msgid "Unable to execute SQL query '%s'. Operation canceled."
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:208
-msgid "one's complement"
+#: ../gui/wxpython/vdigit/wxdigit.py:122
+#, python-format
+msgid "Feature id %d is marked as dead. Operation canceled."
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:210
-msgid "NOT"
+#: ../gui/wxpython/vdigit/wxdigit.py:130
+#, python-format
+msgid "Unsupported feature type %d. Operation canceled."
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:213
-msgid "bitwise AND"
+#: ../gui/wxpython/vdigit/wxdigit.py:500
+#, python-format
+msgid "Unknown feature type '%s'"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:216
-msgid "bitwise OR"
+#: ../gui/wxpython/vdigit/wxdigit.py:505
+msgid "Not enough points for line"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:219
-msgid "logical AND"
+#: ../gui/wxpython/animation/controller.py:234
+#, python-format
+msgid "Maximum number of animations is %s."
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:222
-msgid "logical AND (ignores NULLs)"
+#: ../gui/wxpython/animation/controller.py:262
+#: ../gui/wxpython/animation/dialogs.py:887
+msgid "More animations are using one window. Please select different window for each animation."
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:224
-msgid "logical OR"
+#: ../gui/wxpython/animation/controller.py:443
+msgid "Failed to display legend."
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:227
-msgid "logical OR (ignores NULLs)"
+#: ../gui/wxpython/animation/controller.py:475
+msgid "Inconsistent number of maps, please check input data."
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:232
-msgid "conditional"
+#: ../gui/wxpython/animation/controller.py:505
+msgid "No animation to export."
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:247
-msgid "Name for new 3D raster map to create"
+#: ../gui/wxpython/animation/controller.py:542
+msgid "Preparing export, please wait..."
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:249
-msgid "Name for new raster map to create"
+#: ../gui/wxpython/animation/controller.py:598
+#: ../gui/wxpython/animation/frame.py:605
+#, python-format
+msgid "%(from)s %(dash)s %(to)s"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:254
-msgid "Insert existing 3D raster map"
+#: ../gui/wxpython/animation/controller.py:605
+#, python-format
+msgid "%(start)s %(unit)s"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:256
-msgid "Insert existing raster map"
+#: ../gui/wxpython/animation/controller.py:624
+msgid "Exporting animation, please wait..."
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:261
-msgid "Insert mapcalc function"
+#: ../gui/wxpython/animation/data.py:66
+msgid "No animation name selected."
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:278
-msgid "Generate random seed for rand()"
+#: ../gui/wxpython/animation/data.py:132
+msgid "No workspace file selected."
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:280
-msgid "Seed:"
+#: ../gui/wxpython/animation/data.py:135
+#, python-format
+msgid "File %s not found"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:284
-msgid "Integer seed for rand() function"
+#: ../gui/wxpython/animation/data.py:144
+#, python-format
+msgid "Animation %d"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:291
-msgid "Add created raster map into layer tree"
+#: ../gui/wxpython/animation/dialogs.py:53
+msgid "Adjust speed of animation"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:628
-msgid "You must enter the name of a new raster map to create."
+#: ../gui/wxpython/animation/dialogs.py:100
+msgid "Simple mode"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:639
-msgid "You must enter an expression to create a new raster map."
+#: ../gui/wxpython/animation/dialogs.py:105
+msgid "Frame duration:"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:699
-msgid "Choose a file name to save the expression"
+#: ../gui/wxpython/animation/dialogs.py:106
+#: ../gui/wxpython/animation/dialogs.py:147
+msgid "ms"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:700
-#: ../gui/wxpython/modules/mcalc_builder.py:722
-msgid "Expression file (*)|*"
+#: ../gui/wxpython/animation/dialogs.py:139
+msgid "Temporal mode"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:721
-msgid "Choose a file name to load the expression"
+#: ../gui/wxpython/animation/dialogs.py:144
+msgid "Time unit:"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:757
-#, python-brace-format
-msgid "'{cmd}' copied to clipboard"
+#: ../gui/wxpython/animation/dialogs.py:146
+msgid "Duration of time unit:"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:49
-msgid "Data properties"
+#: ../gui/wxpython/animation/dialogs.py:218
+msgid "year"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:89 ../gui/wxpython/iclass/dialogs.py:257
-msgid "Name of raster map:"
+#: ../gui/wxpython/animation/dialogs.py:219
+msgid "month"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:91 ../gui/wxpython/iclass/dialogs.py:259
-#: ../gui/wxpython/gui_core/dialogs.py:239
-msgid "Name of vector map:"
+#: ../gui/wxpython/animation/dialogs.py:220
+msgid "day"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:94
-#: ../gui/wxpython/gmodeler/dialogs.py:112
-msgid "Name of element:"
+#: ../gui/wxpython/animation/dialogs.py:221
+msgid "hour"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:105
-msgid "Type of element:"
+#: ../gui/wxpython/animation/dialogs.py:222
+msgid "minute"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:163
-msgid "Add GRASS command to the model"
+#: ../gui/wxpython/animation/dialogs.py:223
+msgid "second"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:192
-#: ../gui/wxpython/gmodeler/dialogs.py:493
-#: ../gui/wxpython/gmodeler/dialogs.py:605
-#: ../gui/wxpython/gmodeler/preferences.py:102
-#: ../gui/wxpython/gmodeler/frame.py:1793
-msgid "Command"
+#: ../gui/wxpython/animation/dialogs.py:288
+msgid "Animation speed is too high."
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:194
-msgid "Label and comment"
+#: ../gui/wxpython/animation/dialogs.py:324
+#: ../gui/wxpython/animation/toolbars.py:51
+#: ../gui/wxpython/animation/toolbars.py:52
+msgid "Add new animation"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:235
-#: ../gui/wxpython/gmodeler/frame.py:1538
-msgid "Label:"
+#: ../gui/wxpython/animation/dialogs.py:326
+msgid "Edit animation"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:239
-#: ../gui/wxpython/gmodeler/frame.py:829 ../gui/wxpython/gmodeler/frame.py:1552
-msgid "Comment:"
+#: ../gui/wxpython/animation/dialogs.py:344
+msgid "Advanced"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:292
-msgid ""
-"Command not defined.\n"
-"\n"
-"Unable to add new action to the model."
+#: ../gui/wxpython/animation/dialogs.py:375
+msgid "top left"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:299
-#, python-format
-msgid ""
-"'%s' is not a GRASS module.\n"
-"\n"
+#: ../gui/wxpython/animation/dialogs.py:376
+msgid "top right"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:335
-msgid "Relation properties"
+#: ../gui/wxpython/animation/dialogs.py:377
+msgid "bottom left"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:357
-msgid "From"
+#: ../gui/wxpython/animation/dialogs.py:378
+msgid "bottom right"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:401
-#, python-format
-msgid "Data: %s"
+#: ../gui/wxpython/animation/dialogs.py:394
+msgid "Select 2D or 3D view"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:407
-msgid "Command:"
+#: ../gui/wxpython/animation/dialogs.py:402
+#: ../gui/wxpython/vnet/dialogs.py:1643
+#: ../gui/wxpython/gmodeler/preferences.py:706
+#: ../gui/wxpython/gui_core/gselect.py:1551
+#: ../gui/wxpython/gui_core/gselect.py:1566
+#: ../gui/wxpython/gui_core/gselect.py:1568
+#: ../gui/wxpython/gui_core/widgets.py:1279
+msgid "Name:"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:413
-msgid "Option:"
+#: ../gui/wxpython/animation/dialogs.py:409
+msgid "Window position:"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:428
-msgid ""
-"Relation doesn't start with data item.\n"
-"Unable to add relation."
+#: ../gui/wxpython/animation/dialogs.py:419
+msgid "View mode:"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:435
+#: ../gui/wxpython/animation/dialogs.py:430
msgid ""
-"Relation doesn't point to GRASS command.\n"
+"For 3D animation, please select only one space-time dataset\n"
+"or one series of map layers."
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:448
-msgid ""
-"No relevant option found.\n"
+#: ../gui/wxpython/animation/dialogs.py:496
+msgid "3D view parameters"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:487
-msgid "Condition"
+#: ../gui/wxpython/animation/dialogs.py:504
+msgid "Workspace file:"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:515
-msgid "Loop properties"
+#: ../gui/wxpython/animation/dialogs.py:506
+msgid "Choose workspace file to import 3D view parameters"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:521
-msgid "List of items in loop"
+#: ../gui/wxpython/animation/dialogs.py:515
+msgid "Parameter for animation:"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:524
-msgid "Series"
+#: ../gui/wxpython/animation/dialogs.py:554
+msgid "Animate region change (2D view only)"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:526
-msgid "Define map series as condition for the loop"
+#: ../gui/wxpython/animation/dialogs.py:558
+msgid "Start region:"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:571
-msgid "Define series of maps"
+#: ../gui/wxpython/animation/dialogs.py:568
+msgid "End region:"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:589
-msgid "If-else properties"
+#: ../gui/wxpython/animation/dialogs.py:574
+msgid "Zoom value:"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:596
-msgid "List of items in 'if' block"
+#: ../gui/wxpython/animation/dialogs.py:575
+msgid "N-S/E-W distances in map units used to gradually reduce region."
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:602
-msgid "List of items in 'else' block"
+#: ../gui/wxpython/animation/dialogs.py:582
+msgid "N-S:"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:772
-#, python-format
-msgid "Variable <%s> already exists in the model. Adding variable failed."
+#: ../gui/wxpython/animation/dialogs.py:585
+msgid "E-W:"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:803
-msgid "Do you want to delete all variables from the model?"
+#: ../gui/wxpython/animation/dialogs.py:683
+msgid "Only one series or space-time dataset is accepted for 3D mode."
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:805
-msgid "Delete variables"
+#: ../gui/wxpython/animation/dialogs.py:691
+msgid "No map series or space-time dataset added."
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:919
-#: ../gui/wxpython/gui_core/gselect.py:2084
-#: ../gui/wxpython/location_wizard/wizard.py:882
-msgid "No"
+#: ../gui/wxpython/animation/dialogs.py:719
+msgid "Region information is not complete"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:921
-#: ../gui/wxpython/gui_core/gselect.py:2086
-msgid "Yes"
+#: ../gui/wxpython/animation/dialogs.py:753
+msgid "Add, edit or remove animations"
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:66
-msgid "model"
+#: ../gui/wxpython/animation/dialogs.py:765
+msgid "List of animations"
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:67
-msgid "Script generated by wxGUI Graphical Modeler."
+#: ../gui/wxpython/animation/dialogs.py:778
+msgid "Edit"
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:492 ../gui/wxpython/gmodeler/model.py:555
+#: ../gui/wxpython/animation/dialogs.py:837
#, python-format
-msgid "undefined variable '%s'"
+msgid "Maximum number of animations is %d."
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:589
-msgid "Running model..."
+#: ../gui/wxpython/animation/dialogs.py:907
+#: ../gui/wxpython/animation/toolbars.py:59
+#: ../gui/wxpython/animation/toolbars.py:60
+msgid "Export animation"
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:608
-msgid "Model is empty. Nothing to run."
+#: ../gui/wxpython/animation/dialogs.py:988
+msgid "Add time stamp"
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:617 ../gui/wxpython/gmodeler/frame.py:607
-msgid "Validating model..."
+#: ../gui/wxpython/animation/dialogs.py:988 ../gui/wxpython/menustrings.py:2015
+msgid "Add image"
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:625
-#, python-format
-msgid ""
-"Model is not valid. Do you want to run the model anyway?\n"
-"\n"
-"%s"
+#: ../gui/wxpython/animation/dialogs.py:1030
+msgid "Add time stamp, image or text decoration by one of the buttons above."
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:628
-msgid "Run model?"
+#: ../gui/wxpython/animation/dialogs.py:1032
+msgid "Add image or text decoration by one of the buttons above."
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:667
-msgid "Variables below not defined:"
+#: ../gui/wxpython/animation/dialogs.py:1053
+msgid "Font settings:"
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:791
-msgid "Raster maps"
+#: ../gui/wxpython/animation/dialogs.py:1058
+msgid "Sample text"
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:794
-msgid "3D raster maps"
+#: ../gui/wxpython/animation/dialogs.py:1061
+#: ../gui/wxpython/gui_core/preferences.py:494
+#: ../gui/wxpython/gui_core/preferences.py:771
+msgid "Set font"
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:1501
-msgid "<not defined>"
+#: ../gui/wxpython/animation/dialogs.py:1078
+msgid "Image file:"
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:1615
-msgid "Condition: "
+#: ../gui/wxpython/animation/dialogs.py:1079
+msgid "Choose image file"
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:1617
-msgid "Condition: not defined"
+#: ../gui/wxpython/animation/dialogs.py:1095
+msgid "Text:"
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:1755
-msgid "if-else"
+#: ../gui/wxpython/animation/dialogs.py:1116
+msgid "Placement as percentage of screen coordinates (X: 0, Y: 0 is top left):"
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:1863
-msgid "empty"
+#: ../gui/wxpython/animation/dialogs.py:1151
+msgid "image sequence"
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:1865
-msgid "Details: unsupported tag name '{0}'."
+msgid "animated GIF"
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:2776
-msgid "Model parameters"
+msgid "SWF"
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:2801
-msgid "Delete intermediate data when finish"
+msgid "AVI"
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:2853 ../gui/wxpython/gmodeler/frame.py:153
-msgid "Variables"
+#: ../gui/wxpython/animation/dialogs.py:1162
+msgid "Export to:"
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:32
-#: ../gui/wxpython/menustrings.py:2028
-msgid "Modeler settings"
+#: ../gui/wxpython/animation/dialogs.py:1189
+msgid "animation_"
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:59
-msgid "Item properties"
+#: ../gui/wxpython/animation/dialogs.py:1196
+#: ../gui/wxpython/gui_core/gselect.py:1504
+#: ../gui/wxpython/gui_core/gselect.py:1587
+msgid "Directory:"
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:66
-msgid "Disabled:"
+#: ../gui/wxpython/animation/dialogs.py:1197
+msgid "Choose directory for export"
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:114
-#: ../gui/wxpython/gmodeler/preferences.py:428
-#: ../gui/wxpython/gmodeler/preferences.py:540
-msgid "Valid:"
+#: ../gui/wxpython/animation/dialogs.py:1232
+msgid "GIF file:"
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:132
-msgid "Invalid:"
+#: ../gui/wxpython/animation/dialogs.py:1233
+#: ../gui/wxpython/animation/dialogs.py:1257
+#: ../gui/wxpython/animation/dialogs.py:1288
+msgid "Choose file to save animation"
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:150
-msgid "Running:"
+#: ../gui/wxpython/animation/dialogs.py:1256
+msgid "SWF file:"
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:177
-#: ../gui/wxpython/gmodeler/preferences.py:343
-#: ../gui/wxpython/gmodeler/preferences.py:455
-#: ../gui/wxpython/gmodeler/preferences.py:571
-msgid "Shape size"
+#: ../gui/wxpython/animation/dialogs.py:1279
+msgid ""
+"Program 'ffmpeg' was not found.\n"
+"Please install it first and make sure\n"
+"it's in the PATH variable."
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:262
-msgid "Raster:"
+#: ../gui/wxpython/animation/dialogs.py:1287
+msgid "AVI file:"
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:280
-msgid "3D raster:"
+#: ../gui/wxpython/animation/dialogs.py:1295
+msgid "Video codec:"
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:298
-msgid "Vector:"
+#: ../gui/wxpython/animation/dialogs.py:1299
+msgid "Additional options:"
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:316
-msgid "Table:"
+#: ../gui/wxpython/animation/dialogs.py:1303
+msgid "Consider adding '-sameq' or '-qscale 1' if not satisfied with video quality. Options depend on ffmpeg version."
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:416
-msgid "Loop"
+#: ../gui/wxpython/animation/dialogs.py:1340
+#, python-format
+msgid "Current frame rate: %.2f fps"
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:528
-msgid "Comment"
+#: ../gui/wxpython/animation/dialogs.py:1472
+#, python-format
+msgid "File %s not found."
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:661
-#: ../gui/wxpython/menustrings.py:2044
-msgid "Model properties"
+#: ../gui/wxpython/animation/dialogs.py:1476
+msgid "Decoration image file is missing."
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:668
-#: ../gui/wxpython/lmgr/layertree.py:714 ../gui/wxpython/lmgr/layertree.py:826
-#: ../gui/wxpython/lmgr/layertree.py:860
-msgid "Metadata"
+#: ../gui/wxpython/animation/dialogs.py:1485
+#, python-format
+msgid "Directory %s not found."
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:670
-msgid "Commands"
+#: ../gui/wxpython/animation/dialogs.py:1489
+msgid "Export directory is missing."
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:694
-msgid "Apply properties"
+#: ../gui/wxpython/animation/dialogs.py:1493
+#: ../gui/wxpython/animation/dialogs.py:1497
+msgid "Export file is missing."
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:715
-msgid "Description:"
+#: ../gui/wxpython/animation/dialogs.py:1535
+msgid "Time stamp"
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:724
-msgid "Author(s):"
+#: ../gui/wxpython/animation/dialogs.py:1613
+msgid "Add space-time dataset layer"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:65
-msgid "GRASS GIS Graphical Modeler"
+#: ../gui/wxpython/animation/dialogs.py:1638
+msgid "Multiple raster maps"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:146
-msgid "Model"
+#: ../gui/wxpython/animation/dialogs.py:1639
+msgid "Multiple vector maps"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:149
-msgid "Items"
+#: ../gui/wxpython/animation/dialogs.py:1640
+msgid "Multiple 3D raster maps"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:157
-msgid "Python editor"
+#: ../gui/wxpython/animation/dialogs.py:1641
+msgid "Space time raster dataset"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:161 ../gui/wxpython/gui_core/forms.py:2228
-msgid "Command output"
+#: ../gui/wxpython/animation/dialogs.py:1642
+msgid "Space time vector dataset"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:243
-msgid "Python script contains local modifications"
+#: ../gui/wxpython/animation/dialogs.py:1643
+msgid "Space time 3D raster dataset"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:245 ../gui/wxpython/gmodeler/frame.py:2044
-msgid "Python script is up-to-date"
+#: ../gui/wxpython/animation/dialogs.py:1682
+msgid "Input data type:"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:262
-msgid "Redrawing model..."
+#: ../gui/wxpython/animation/dialogs.py:1763
+msgid "Select raster/vector maps."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:298
-msgid "Do you want to save changes in the model?"
+#: ../gui/wxpython/animation/dialogs.py:1792
+msgid "Please select maps or dataset first."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:300
-msgid "Do you want to store current model settings to model file?"
+#: ../gui/wxpython/animation/dialogs.py:1821
+msgid "Animation Tool settings"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:306
-msgid "Quit Graphical Modeler"
+#: ../gui/wxpython/animation/dialogs.py:1885
+msgid "Number of parallel processes:"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:360
-msgid "No intermediate data to delete."
+#: ../gui/wxpython/animation/dialogs.py:1914
+msgid "Text foreground color:"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:366
-#, python-format
-msgid "Do you want to permanently delete data?%s"
+#: ../gui/wxpython/animation/dialogs.py:1935
+msgid "Text background color:"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:368
-msgid "Delete intermediate data?"
+#: ../gui/wxpython/animation/dialogs.py:1977
+msgid "Absolute time format:"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:385
-#, python-format
-msgid "%d maps deleted from current mapset"
+#: ../gui/wxpython/animation/dialogs.py:1997
+msgid "Click and then press key up or down to preview different date and time formats. Type custom format string."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:403 ../gui/wxpython/gmodeler/frame.py:553
-msgid "Current model is not empty. Do you want to store current settings to model file?"
+#: ../gui/wxpython/animation/dialogs.py:2008
+msgid "Learn more about formatting options"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:406 ../gui/wxpython/gmodeler/frame.py:556
-msgid "Create new model?"
+#: ../gui/wxpython/animation/dialogs.py:2022
+msgid "Display instances with no data"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:443
-msgid "Choose model file"
+#: ../gui/wxpython/animation/dialogs.py:2025
+msgid "When animating instant-based data which have irregular timestamps you can display 'no data frame' (checked option) or keep last frame."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:445 ../gui/wxpython/gmodeler/frame.py:505
-#: ../gui/wxpython/lmgr/frame.py:596
-msgid "GRASS Model File (*.gxm)|*.gxm"
+#: ../gui/wxpython/animation/dialogs.py:2056
+msgid "Invalid"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:466
+#: ../gui/wxpython/animation/g.gui.animation.py:92
#, python-format
-msgid "%(items)d items (%(actions)d actions) loaded into model"
+msgid "%s=, %s=, %s= and %s= are mutually exclusive."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:478 ../gui/wxpython/gmodeler/frame.py:522
-#, python-format
-msgid "Model file <%s> already exists. Do you want to overwrite this file?"
+#: ../gui/wxpython/animation/utils.py:182
+msgid "The number of maps in space-time datasets has to be the same."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:481 ../gui/wxpython/menustrings.py:2015
-msgid "Save model"
+#: ../gui/wxpython/animation/utils.py:186
+msgid "The temporal type (absolute/relative) of space-time datasets has to be the same."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:490 ../gui/wxpython/gmodeler/frame.py:540
-#, python-format
-msgid "File <%s> saved"
+#: ../gui/wxpython/animation/utils.py:190
+msgid "The map type (point/interval) of space-time datasets has to be the same."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:503
-msgid "Choose file to save current model"
+#: ../gui/wxpython/animation/utils.py:194
+msgid "The temporal extents of maps in space-time datasets have to be the same."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:525 ../gui/wxpython/iclass/frame.py:1138
-msgid "File already exists"
+#: ../gui/wxpython/animation/utils.py:202
+msgid "The number of maps to animate has to be the same for each map series."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:604
-msgid "Model is empty. Nothing to validate."
+#: ../gui/wxpython/animation/utils.py:207
+msgid "The number of maps to animate has to be the same as the number of maps in temporal dataset."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:614
+#: ../gui/wxpython/animation/nviztask.py:53
#, python-format
-msgid ""
-"Model is not valid.\n"
-"\n"
-"%s"
+msgid "No 3d view information in workspace file <%s>."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:618
-msgid "Model is valid."
+#: ../gui/wxpython/animation/nviztask.py:285
+msgid "Please add only one layer in the list."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:680 ../gui/wxpython/gmodeler/frame.py:687
-#, python-format
-msgid "Model exported to <%s>"
+#: ../gui/wxpython/animation/nviztask.py:292
+msgid "No map series nor space-time dataset is added."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:830 ../gui/wxpython/menustrings.py:2040
-msgid "Add comment"
+#: ../gui/wxpython/animation/frame.py:51
+msgid "GRASS GIS Animation tool"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:840
-msgid "Empty comment. Nothing to add to the model."
+#: ../gui/wxpython/animation/frame.py:160 ../gui/wxpython/mapswipe/frame.py:303
+msgid "Main Toolbar"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:876
-msgid "wxGUI Graphical Modeler"
+#: ../gui/wxpython/animation/frame.py:170
+msgid "Animation Toolbar"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:995
+#: ../gui/wxpython/animation/frame.py:282
+msgid "Loading data"
+msgstr ""
+#: ../gui/wxpython/animation/frame.py:290
+#, python-brace-format
+msgid " ({c} out of {p})"
+msgstr ""
+#: ../gui/wxpython/animation/frame.py:610
#, python-format
-msgid ""
-"Reading model file <%s> failed.\n"
-"Invalid file, unable to parse XML document.\n"
-"\n"
-"%s"
+msgid "to %(to)s"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1007
-msgid "Please wait, loading model..."
+#: ../gui/wxpython/animation/provider.py:417
+msgid "Rendering map layers"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1073
-msgid "Writing current settings to model file failed."
+#: ../gui/wxpython/animation/provider.py:530
+msgid "Overlaying map layers"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1084 ../gui/wxpython/lmgr/frame.py:1649
-#, python-format
-msgid "Unable to open file <%s> for writing."
+#: ../gui/wxpython/animation/provider.py:757
+msgid "Directory {t} not removed."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1448
-msgid "Disable"
+#: ../gui/wxpython/animation/toolbars.py:30
+msgid "Change animation speed"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1454
-msgid "Enable"
+#: ../gui/wxpython/animation/toolbars.py:33
+msgid "Play forward"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1462
-#: ../gui/wxpython/gmodeler/frame.py:1539
-msgid "Set label"
+#: ../gui/wxpython/animation/toolbars.py:36
+msgid "Play back"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1468
-#: ../gui/wxpython/gmodeler/frame.py:1553
-msgid "Set comment"
+#: ../gui/wxpython/animation/toolbars.py:45
+msgid "Repeat"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1478
-msgid "Add control point"
+#: ../gui/wxpython/animation/toolbars.py:48
+msgid "Play back and forward"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1485
-msgid "Remove control point"
+#: ../gui/wxpython/animation/toolbars.py:55
+#: ../gui/wxpython/animation/toolbars.py:56
+msgid "Add, edit or remove animation"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1497
-msgid "Intermediate"
+#: ../gui/wxpython/animation/toolbars.py:68
+msgid "Add space-time dataset or series of map layers"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1511 ../gui/wxpython/lmgr/layertree.py:486
-msgid "Properties"
+#: ../gui/wxpython/animation/toolbars.py:69
+msgid "Add space-time dataset or series of map layers for animation"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1630
-msgid "List of variables - right-click to delete"
+#: ../gui/wxpython/animation/temporal_manager.py:110
+msgid "It is not allowed to display data with different temporal types (absolute and relative)."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1637
-#: ../gui/wxpython/gmodeler/frame.py:1695
-msgid "Default value"
+#: ../gui/wxpython/animation/temporal_manager.py:125
+#, python-format
+msgid "It is not allowed to display data with different units (%s)."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1638
-#: ../gui/wxpython/gmodeler/frame.py:1702
-#: ../gui/wxpython/location_wizard/wizard.py:433
-#: ../gui/wxpython/location_wizard/wizard.py:960
-#: ../gui/wxpython/location_wizard/wizard.py:1141
-#: ../gui/wxpython/location_wizard/wizard.py:1472
-#: ../gui/wxpython/location_wizard/wizard.py:1700
-msgid "Description"
+#: ../gui/wxpython/animation/temporal_manager.py:137
+msgid "You are going to display data with different temporal types of maps (interval and point). It is recommended to use data of one temporal type to avoid confusion."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1643
-msgid "Add new variable"
+#: ../gui/wxpython/animation/temporal_manager.py:347
+#, python-format
+msgid "Topology of Space time dataset %s is invalid."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1647
-msgid "integer"
+#: ../gui/wxpython/mapwin/decorations.py:178
+#: ../gui/wxpython/mapwin/decorations.py:265
+msgid ""
+"Please install Python Imaging Library (PIL)\n"
+"for better control of legend and other decorations."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1648
-msgid "float"
+#: ../gui/wxpython/mapwin/decorations.py:197
+msgid "Remove text"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1649
-msgid "string"
+#: ../gui/wxpython/mapwin/decorations.py:220
+msgid "Remove scale bar"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1652
-msgid "region"
+#: ../gui/wxpython/mapwin/decorations.py:232
+msgid "Remove north arrow"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1653
-msgid "mapset"
+#: ../gui/wxpython/mapwin/decorations.py:244
+msgid "Remove vector legend"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1654
-#: ../gui/wxpython/gui_core/forms.py:1800
-msgid "file"
+#: ../gui/wxpython/mapwin/decorations.py:256
+msgid "Remove legend"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1655
-msgid "dir"
+#: ../gui/wxpython/mapwin/buffered.py:252
+msgid "Copy coordinates to clipboard"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1662
-msgid "Add new variable to the model"
+#: ../gui/wxpython/mapwin/buffered.py:260
+msgid "Hide toolbars"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1785
-msgid "List of items - right-click to delete"
+#: ../gui/wxpython/mapwin/buffered.py:262
+msgid "Show toolbars"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1791
-msgid "In loop"
+#: ../gui/wxpython/mapwin/buffered.py:269
+msgid "Hide statusbar"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1792
-msgid "Parameterized"
+#: ../gui/wxpython/mapwin/buffered.py:270
+msgid "Show statusbar"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1848
-msgid "No items to selected."
+#: ../gui/wxpython/mapwin/buffered.py:287
+msgid "Resize legend"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1884
-msgid "Python script"
+#: ../gui/wxpython/mapwin/buffered.py:694
+#: ../gui/wxpython/modules/histogram.py:190
+msgid "Please wait, exporting image..."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1888
-msgid "Run python script"
+#: ../gui/wxpython/mapwin/buffered.py:985
+msgid "Unable to draw registered graphics. The graphics was unregistered."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1891
-msgid "Save python script to file"
+#: ../gui/wxpython/mapwin/buffered.py:2074
+msgid "Zoom to saved region extents"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1894
+#: ../gui/wxpython/mapwin/buffered.py:2076
+msgid "Set compulational region from named region"
+msgstr ""
+#: ../gui/wxpython/mapwin/buffered.py:2089
+#, python-format
+msgid "Region <%s> not found. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/mapwin/buffered.py:2119
+msgid "Save display extents to region file"
+msgstr ""
+#: ../gui/wxpython/mapwin/buffered.py:2121
+msgid "Save computational region to region file"
+msgstr ""
+#: ../gui/wxpython/mapwin/buffered.py:2133
+#, python-format
+msgid "Region file <%s> already exists. Do you want to overwrite it?"
+msgstr ""
+#: ../gui/wxpython/mapwin/base.py:204
+#, python-format
msgid ""
-"Refresh python script based on the model.\n"
-"It will discards all local changes."
+"Error occurred during calling of handler: %s \n"
+"Handler was unregistered."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1932
-#: ../gui/wxpython/gui_core/pyedit.py:280
+#: ../gui/wxpython/mapwin/base.py:285
#, python-format
-msgid "Unable to launch Python script. %s"
+msgid ""
+"Error occurred during unregistration of handler: %s \n"
+" Handler was unregistered."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1959
-#: ../gui/wxpython/gui_core/pyedit.py:316
-msgid "Choose file to save"
+#: ../gui/wxpython/mapwin/base.py:314
+#, python-format
+msgid "Handler: %s was not registered"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1964
-#: ../gui/wxpython/gui_core/pyedit.py:318
-#: ../gui/wxpython/gui_core/pyedit.py:380
-msgid "Python script (*.py)|*.py"
+#: ../gui/wxpython/mapwin/base.py:318
+#, python-format
+msgid ""
+" Handler was unregistered"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1981 ../gui/wxpython/wxplot/profile.py:372
-#: ../gui/wxpython/gui_core/pyedit.py:334
+#: ../gui/wxpython/mapwin/analysis.py:228
+#: ../gui/wxpython/mapwin/analysis.py:350
+msgid "Measuring finished"
+msgstr ""
+#: ../gui/wxpython/mapwin/analysis.py:246
+#: ../gui/wxpython/mapwin/analysis.py:362
#, python-format
-msgid "File <%s> already exists. Do you want to overwrite this file?"
+msgid "Click and drag with left mouse button to measure.%sDouble click with left button to clear."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1984
-#: ../gui/wxpython/gui_core/pyedit.py:336
-msgid "Save file"
+#: ../gui/wxpython/mapwin/analysis.py:252
+msgid "Measuring distance"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:2021
-msgid "Python script is locally modificated. Refresh will discard all changes. Do you really want to continue?"
+#: ../gui/wxpython/mapwin/analysis.py:255
+msgid "Measuring distance:"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:2024
-msgid "Update"
+#: ../gui/wxpython/mapwin/analysis.py:263
+#, python-format
+msgid ""
+"Geodesic distance calculation is not available.\n"
+"Reason: %s"
msgstr ""
-#: ../gui/wxpython/rdigit/dialogs.py:34
-msgid "Create new raster map"
+#: ../gui/wxpython/mapwin/analysis.py:301
+#: ../gui/wxpython/mapwin/analysis.py:308
+msgid "segment"
msgstr ""
-#: ../gui/wxpython/rdigit/dialogs.py:53
-msgid "Name for new raster map:"
+#: ../gui/wxpython/mapwin/analysis.py:302
+#: ../gui/wxpython/mapwin/analysis.py:309
+msgid "total distance"
msgstr ""
-#: ../gui/wxpython/rdigit/dialogs.py:58
-msgid "Optionally select background raster map:"
+#: ../gui/wxpython/mapwin/analysis.py:303
+msgid "bearing"
msgstr ""
-#: ../gui/wxpython/rdigit/dialogs.py:62
-msgid "New raster map type:"
+#: ../gui/wxpython/mapwin/analysis.py:304
+msgid "degrees (clockwise from grid-north)"
msgstr ""
-#: ../gui/wxpython/rdigit/dialogs.py:92
-msgid "Please specify name for a new raster map"
+#: ../gui/wxpython/mapwin/analysis.py:366
+msgid "Measuring area:"
msgstr ""
-#: ../gui/wxpython/rdigit/dialogs.py:100
+#: ../gui/wxpython/mapwin/analysis.py:386
+msgid "Units not recognized, measurement failed."
+msgstr ""
+#: ../gui/wxpython/mapwin/analysis.py:391
+#: ../gui/wxpython/mapwin/analysis.py:393
+msgid "Area: {area} {unit}\n"
+msgstr ""
+#: ../gui/wxpython/mapwin/graphics.py:277
+#: ../gui/wxpython/mapwin/graphics.py:453
#, python-format
-msgid "Raster map <%s> already exists in the current mapset. Do you want to overwrite it?"
+msgid "Property does not exist: %s"
msgstr ""
-#: ../gui/wxpython/rdigit/controller.py:123
-msgid "Please select first the raster map"
+#: ../gui/wxpython/vnet/vnet_core.py:116
+msgid "Unable to perform analysis."
msgstr ""
-#: ../gui/wxpython/rdigit/controller.py:155
-msgid "Right click to finish area"
+#: ../gui/wxpython/vnet/vnet_core.py:226
+#, python-format
+msgid ""
+"Temporary map '%s' with result was changed outside vector network analysis tool.\n"
+"Showed result may not correspond original analysis result."
msgstr ""
-#: ../gui/wxpython/rdigit/controller.py:160
-msgid "Right click to finish line"
+#: ../gui/wxpython/vnet/vnet_core.py:231
+msgid "Result changed outside"
msgstr ""
-#: ../gui/wxpython/rdigit/controller.py:303
-msgid "Do you want to save changes?"
+#: ../gui/wxpython/vnet/vnet_core.py:268
+msgid "Map can be created only in current mapset"
msgstr ""
-#: ../gui/wxpython/rdigit/controller.py:304
-msgid "Save raster map changes"
+#: ../gui/wxpython/vnet/vnet_core.py:275 ../gui/wxpython/vnet/vnet_core.py:352
+#, python-format
+msgid "Vector map %s already exists. Do you want to overwrite it?"
msgstr ""
-#: ../gui/wxpython/rdigit/controller.py:378
-msgid "Failed to create backup copy of edited raster map."
+#: ../gui/wxpython/vnet/vnet_core.py:278 ../gui/wxpython/vnet/vnet_core.py:355
+msgid "Overwrite vector map"
msgstr ""
-#: ../gui/wxpython/rdigit/controller.py:397
-msgid "Failed to create new raster map."
+#: ../gui/wxpython/vnet/vnet_core.py:304
+msgid "Creation of turntable failed."
msgstr ""
-#: ../gui/wxpython/rdigit/controller.py:488
-#: ../gui/wxpython/rdigit/controller.py:516
-msgid "Rasterizing..."
+#: ../gui/wxpython/vnet/vnet_core.py:324
+msgid "Vector map with analysis result does not exist."
msgstr ""
-#: ../gui/wxpython/rdigit/controller.py:556
-msgid "Failed to set default color table for edited raster map"
+#: ../gui/wxpython/vnet/vnet_core.py:345
+msgid "Map can be saved only to currently set mapset"
msgstr ""
-#: ../gui/wxpython/rdigit/toolbars.py:27
-msgid "Digitize area"
+#: ../gui/wxpython/vnet/vnet_core.py:427 ../gui/wxpython/vnet/vnet_core.py:632
+#, python-format
+msgid "Please choose '%s' and '%s' point."
msgstr ""
-#: ../gui/wxpython/rdigit/toolbars.py:29
-msgid "Digitize line"
+#: ../gui/wxpython/vnet/vnet_core.py:639
+msgid "Please choose at least two points."
msgstr ""
-#: ../gui/wxpython/rdigit/toolbars.py:31
-msgid "Digitize point"
+#: ../gui/wxpython/vnet/vnet_core.py:932
+#, python-format
+msgid ""
+"Input map '%s' for analysis was changed outside vector network analysis tool.\n"
+"Topology column may not correspond to changed situation."
msgstr ""
-#: ../gui/wxpython/rdigit/toolbars.py:32
-msgid "Save raster map"
+#: ../gui/wxpython/vnet/vnet_core.py:937
+msgid "Input changed outside"
msgstr ""
-#: ../gui/wxpython/rdigit/toolbars.py:34
-msgid "Quit raster digitizer"
+#: ../gui/wxpython/vnet/vnet_core.py:1011
+#, python-format
+msgid ""
+"Temporary map %s already exists.\n"
+"Do you want to continue in analysis and overwrite it?"
msgstr ""
-#: ../gui/wxpython/rdigit/toolbars.py:50
-msgid "Select raster map"
+#: ../gui/wxpython/vnet/vnet_core.py:1038
+msgid "Unable to use ctypes. \n"
msgstr ""
-#: ../gui/wxpython/rdigit/toolbars.py:65
-msgid "Set drawing color (not raster cell color)"
+#: ../gui/wxpython/vnet/vnet_core.py:1039
+#: ../gui/wxpython/vnet/vnet_core.py:1062
+msgid "Snapping mode can not be activated."
msgstr ""
-#: ../gui/wxpython/rdigit/toolbars.py:86
-msgid "Cell value:"
+#: ../gui/wxpython/vnet/vnet_core.py:1069
+msgid "Do you really want to activate snapping and overwrite it?"
msgstr ""
-#: ../gui/wxpython/rdigit/toolbars.py:99
-msgid "Width of currently digitized line or diameter of a digitized point in map units."
+#: ../gui/wxpython/vnet/vnet_core.py:1079
+#, python-format
+msgid ""
+"Temporary map '%s' was changed outside vector analysis tool.\n"
+"Do you really want to activate snapping and overwrite it? "
msgstr ""
-#: ../gui/wxpython/rdigit/toolbars.py:138
-msgid "New raster map"
+#: ../gui/wxpython/vnet/vnet_core.py:1084
+msgid "Overwrite map"
msgstr ""
#: ../gui/wxpython/vnet/dialogs.py:70
@@ -8643,9 +8638,15 @@
msgid "Iso lines:"
msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:345
+#: ../gui/wxpython/modules/mcalc_builder.py:134
+#: ../gui/wxpython/modules/vkrige.py:154
+msgid "Output"
+msgstr ""
#: ../gui/wxpython/vnet/dialogs.py:362
-#: ../gui/wxpython/location_wizard/wizard.py:1473
-#: ../gui/wxpython/location_wizard/wizard.py:1701
+#: ../gui/wxpython/location_wizard/wizard.py:1451
+#: ../gui/wxpython/location_wizard/wizard.py:1679
msgid "Parameters"
msgstr ""
@@ -8731,6 +8732,10 @@
msgid "Point width:"
msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1282 ../gui/wxpython/iscatt/dialogs.py:372
+msgid "Snapping threshold in pixels:"
+msgstr ""
#: ../gui/wxpython/vnet/dialogs.py:1283
msgid "Maximum number of results in history:"
msgstr ""
@@ -8751,97 +8756,6 @@
msgid "Define Global Turn Costs"
msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:116
-msgid "Unable to perform analysis."
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:226
-#, python-format
-msgid ""
-"Temporary map '%s' with result was changed outside vector network analysis tool.\n"
-"Showed result may not correspond original analysis result."
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:231
-msgid "Result changed outside"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:268
-msgid "Map can be created only in current mapset"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:275 ../gui/wxpython/vnet/vnet_core.py:352
-#, python-format
-msgid "Vector map %s already exists. Do you want to overwrite it?"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:278 ../gui/wxpython/vnet/vnet_core.py:355
-msgid "Overwrite vector map"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:304
-msgid "Creation of turntable failed."
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:324
-msgid "Vector map with analysis result does not exist."
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:345
-msgid "Map can be saved only to currently set mapset"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:427 ../gui/wxpython/vnet/vnet_core.py:632
-#, python-format
-msgid "Please choose '%s' and '%s' point."
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:639
-msgid "Please choose at least two points."
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:932
-#, python-format
-msgid ""
-"Input map '%s' for analysis was changed outside vector network analysis tool.\n"
-"Topology column may not correspond to changed situation."
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:937
-msgid "Input changed outside"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:1011
-#, python-format
-msgid ""
-"Temporary map %s already exists.\n"
-"Do you want to continue in analysis and overwrite it?"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:1038
-msgid "Unable to use ctypes. \n"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:1039
-#: ../gui/wxpython/vnet/vnet_core.py:1062
-msgid "Snapping mode can not be activated."
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:1069
-msgid "Do you really want to activate snapping and overwrite it?"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:1079
-#, python-format
-msgid ""
-"Temporary map '%s' was changed outside vector analysis tool.\n"
-"Do you really want to activate snapping and overwrite it? "
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:1084
-msgid "Overwrite map"
-msgstr ""
#: ../gui/wxpython/vnet/toolbars.py:52
msgid "Insert points from Map Display"
msgstr ""
@@ -8890,6 +8804,11 @@
msgid "Vector network analysis settings"
msgstr ""
+#: ../gui/wxpython/vnet/toolbars.py:137 ../gui/wxpython/gui_core/toolbars.py:71
+#: ../gui/wxpython/iscatt/toolbars.py:51
+msgid "Show manual"
+msgstr ""
#: ../gui/wxpython/vnet/toolbars.py:206
msgid "Availiable analyses"
msgstr ""
@@ -9051,4420 +8970,4569 @@
msgid "Edit point"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:61
-msgid "Unpack GRASS raster map"
+#: ../gui/wxpython/gmodeler/model.py:66
+msgid "model"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:63
-msgid "Set raster output format"
+#: ../gui/wxpython/gmodeler/model.py:67
+msgid "Script generated by wxGUI Graphical Modeler."
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:69
-msgid "Unpack GRASS vector map"
+#: ../gui/wxpython/gmodeler/model.py:492 ../gui/wxpython/gmodeler/model.py:555
+#, python-format
+msgid "undefined variable '%s'"
msgstr ""
-msgid "Set vector output format"
+#: ../gui/wxpython/gmodeler/model.py:589
+msgid "Running model..."
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:73
-msgid "Import data from WMS server"
+#: ../gui/wxpython/gmodeler/model.py:608
+msgid "Model is empty. Nothing to run."
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:75
-msgid "Add command layer"
+#: ../gui/wxpython/gmodeler/model.py:617 ../gui/wxpython/gmodeler/frame.py:607
+msgid "Validating model..."
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:77 ../gui/wxpython/gui_core/toolbars.py:73
-#: ../gui/wxpython/menustrings.py:2072
-msgid "Quit"
+#: ../gui/wxpython/gmodeler/model.py:625
+#, python-format
+msgid ""
+"Model is not valid. Do you want to run the model anyway?\n"
+"\n"
+"%s"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:79 ../gui/wxpython/gui_core/toolbars.py:75
-msgid "Add raster map layer"
+#: ../gui/wxpython/gmodeler/model.py:628
+msgid "Run model?"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:81 ../gui/wxpython/iclass/toolbars.py:58
-#: ../gui/wxpython/gui_core/simplelmgr.py:475
-msgid "Add RGB map layer"
+#: ../gui/wxpython/gmodeler/model.py:667
+msgid "Variables below not defined:"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:83
-msgid "Add HIS map layer"
+#: ../gui/wxpython/gmodeler/model.py:791
+msgid "Raster maps"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:85
-msgid "Add shaded relief map layer"
+#: ../gui/wxpython/gmodeler/model.py:794
+msgid "3D raster maps"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:87
-msgid "Add raster flow arrows"
+#: ../gui/wxpython/gmodeler/model.py:1122
+#: ../gui/wxpython/gmodeler/model.py:1228 ../gui/wxpython/core/gconsole.py:663
+#: ../gui/wxpython/gui_core/ghelp.py:232
+msgid "unknown"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:89
-msgid "Add raster cell numbers"
+#: ../gui/wxpython/gmodeler/model.py:1501
+msgid "<not defined>"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:91 ../gui/wxpython/gui_core/toolbars.py:77
-msgid "Add vector map layer"
+#: ../gui/wxpython/gmodeler/model.py:1615
+msgid "Condition: "
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:93
-msgid "Add thematic (choropleth) vector map layer"
+#: ../gui/wxpython/gmodeler/model.py:1617
+msgid "Condition: not defined"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:95
-msgid "Add thematic chart layer"
+#: ../gui/wxpython/gmodeler/model.py:1755
+msgid "if-else"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:97
-msgid "Add grid layer"
+#: ../gui/wxpython/gmodeler/model.py:1863
+msgid "empty"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:99
-msgid "Add geodesic line layer"
+#: ../gui/wxpython/gmodeler/model.py:1865
+msgid "Details: unsupported tag name '{}'."
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:101
-msgid "Add rhumbline layer"
+#: ../gui/wxpython/gmodeler/model.py:2776
+msgid "Model parameters"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:105
-#: ../gui/wxpython/gui_core/simplelmgr.py:473
-#: ../gui/wxpython/gui_core/simplelmgr.py:474
-msgid "Add 3D raster map layer"
+#: ../gui/wxpython/gmodeler/model.py:2801
+msgid "Delete intermediate data when finish"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:106
-msgid "Note that 3D raster data are rendered only in 3D view mode"
+#: ../gui/wxpython/gmodeler/model.py:2809
+#: ../gui/wxpython/gmodeler/frame.py:1887 ../gui/wxpython/gui_core/forms.py:591
+#: ../gui/wxpython/gui_core/menu.py:170
+#: ../gui/wxpython/modules/mcalc_builder.py:148
+#: ../gui/wxpython/modules/vclean.py:173 ../gui/wxpython/modules/vkrige.py:210
+msgid "&Run"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:108
-msgid "Add WMS layer."
+#: ../gui/wxpython/gmodeler/model.py:2853 ../gui/wxpython/gmodeler/frame.py:153
+msgid "Variables"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:112
-msgid "Editing mode"
+#: ../gui/wxpython/gmodeler/dialogs.py:49
+msgid "Data properties"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:114
-msgid "Background vector map"
+#: ../gui/wxpython/gmodeler/dialogs.py:94
+#: ../gui/wxpython/gmodeler/dialogs.py:112
+msgid "Name of element:"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:210
-msgid "Map Layers"
+#: ../gui/wxpython/gmodeler/dialogs.py:105
+msgid "Type of element:"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:452 ../gui/wxpython/rlisetup/frame.py:146
-#: ../gui/wxpython/menustrings.py:177 ../gui/wxpython/menustrings.py:943
-#: ../gui/wxpython/menustrings.py:1200 ../gui/wxpython/menustrings.py:1886
-msgid "Rename"
+#: ../gui/wxpython/gmodeler/dialogs.py:163
+msgid "Add GRASS command to the model"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:498
-msgid "3D view properties"
+#: ../gui/wxpython/gmodeler/dialogs.py:192
+#: ../gui/wxpython/gmodeler/dialogs.py:493
+#: ../gui/wxpython/gmodeler/dialogs.py:605
+#: ../gui/wxpython/gmodeler/frame.py:1793
+#: ../gui/wxpython/gmodeler/preferences.py:102
+msgid "Command"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:509
-msgid "Zoom to selected map(s)"
+#: ../gui/wxpython/gmodeler/dialogs.py:194
+msgid "Label and comment"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:521
-msgid "Zoom to selected map(s) (ignore NULLs)"
+#: ../gui/wxpython/gmodeler/dialogs.py:235
+#: ../gui/wxpython/gmodeler/frame.py:1538
+msgid "Label:"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:530
-msgid "Set computational region from selected map(s)"
+#: ../gui/wxpython/gmodeler/dialogs.py:239
+#: ../gui/wxpython/gmodeler/frame.py:829 ../gui/wxpython/gmodeler/frame.py:1552
+msgid "Comment:"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:543
-msgid "Align computational region to selected map"
+#: ../gui/wxpython/gmodeler/dialogs.py:292
+msgid ""
+"Command not defined.\n"
+"\n"
+"Unable to add new action to the model."
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:557
-msgid "Export common formats"
+#: ../gui/wxpython/gmodeler/dialogs.py:299
+#, python-format
+msgid ""
+"'%s' is not a GRASS module.\n"
+"\n"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:574
-msgid "Export PostGIS"
+#: ../gui/wxpython/gmodeler/dialogs.py:335
+msgid "Relation properties"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:588 ../gui/wxpython/iclass/dialogs.py:790
-msgid "Export attribute table"
+#: ../gui/wxpython/gmodeler/dialogs.py:357
+msgid "From"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:603 ../gui/wxpython/lmgr/layertree.py:743
-msgid "Create pack"
+#: ../gui/wxpython/gmodeler/dialogs.py:401
+#, python-format
+msgid "Data: %s"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:619 ../gui/wxpython/lmgr/layertree.py:759
-msgid "Make a copy in the current mapset"
+#: ../gui/wxpython/gmodeler/dialogs.py:407
+msgid "Command:"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:624 ../gui/wxpython/lmgr/layertree.py:767
-#: ../gui/wxpython/lmgr/layertree.py:840
-msgid "Set color table"
+#: ../gui/wxpython/gmodeler/dialogs.py:413
+msgid "Option:"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:633
-msgid "Show attribute data"
+#: ../gui/wxpython/gmodeler/dialogs.py:428
+msgid ""
+"Relation doesn't start with data item.\n"
+"Unable to add relation."
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:651
-msgid "Start editing"
+#: ../gui/wxpython/gmodeler/dialogs.py:435
+msgid ""
+"Relation doesn't point to GRASS command.\n"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:660
-msgid "Stop editing"
+#: ../gui/wxpython/gmodeler/dialogs.py:448
+msgid ""
+"No relevant option found.\n"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:681
-msgid "Rebuild topology"
+#: ../gui/wxpython/gmodeler/dialogs.py:487
+msgid "Condition"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:775
-msgid "Set color table interactively"
+#: ../gui/wxpython/gmodeler/dialogs.py:515
+msgid "Loop properties"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:784 ../gui/wxpython/menustrings.py:763
-#: ../gui/wxpython/menustrings.py:1706
-msgid "Histogram"
+#: ../gui/wxpython/gmodeler/dialogs.py:521
+msgid "List of items in loop"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:793 ../gui/wxpython/lmgr/layertree.py:849
-#: ../gui/wxpython/menustrings.py:531 ../gui/wxpython/menustrings.py:1474
-msgid "Univariate raster statistics"
+#: ../gui/wxpython/gmodeler/dialogs.py:524
+msgid "Series"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:805
-msgid "Report raster statistics"
+#: ../gui/wxpython/gmodeler/dialogs.py:526
+msgid "Define map series as condition for the loop"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:817
-msgid "Profile"
+#: ../gui/wxpython/gmodeler/dialogs.py:571
+msgid "Define series of maps"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:873
-msgid "Save web service layer"
+#: ../gui/wxpython/gmodeler/dialogs.py:589
+msgid "If-else properties"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:991
-msgid "Unable to create profile of raster map."
+#: ../gui/wxpython/gmodeler/dialogs.py:596
+msgid "List of items in 'if' block"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1044
-#, python-format
-msgid "Unsupported map type <%s>"
+#: ../gui/wxpython/gmodeler/dialogs.py:602
+msgid "List of items in 'else' block"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1050
+#: ../gui/wxpython/gmodeler/dialogs.py:772
#, python-format
-msgid "Enter name for the new %s in the current mapset:"
+msgid "Variable <%s> already exists in the model. Adding variable failed."
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1052
-#, python-format
-msgid "Make a copy of %s <%s>"
+#: ../gui/wxpython/gmodeler/dialogs.py:803
+msgid "Do you want to delete all variables from the model?"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1070
-#, python-format
-msgid "%s <%s> already exists in the current mapset. Do you want to overwrite it?"
+#: ../gui/wxpython/gmodeler/dialogs.py:805
+msgid "Delete variables"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1082
-#, python-format
-msgid "Unable to make copy of <%s>"
+#: ../gui/wxpython/gmodeler/dialogs.py:919
+#: ../gui/wxpython/location_wizard/wizard.py:860
+#: ../gui/wxpython/gui_core/gselect.py:2083
+msgid "No"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1090
-#, python-format
-msgid "Unable to make copy of <%s>. Mapset <%s> is not current mapset."
+#: ../gui/wxpython/gmodeler/dialogs.py:921
+#: ../gui/wxpython/gui_core/gselect.py:2085
+msgid "Yes"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1116
-msgid "Unable to display histogram of raster map. No map name defined."
+#: ../gui/wxpython/gmodeler/frame.py:65
+msgid "GRASS GIS Graphical Modeler"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1167 ../gui/wxpython/mapdisp/frame.py:281
-#, python-format
-msgid ""
-"Unable to start wxGUI vector digitizer.\n"
-"Details: %s"
+#: ../gui/wxpython/gmodeler/frame.py:146
+msgid "Model"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1226
-#: ../gui/wxpython/gui_core/simplelmgr.py:283
-#, python-format
-msgid "Set opacity of <%s>"
+#: ../gui/wxpython/gmodeler/frame.py:149
+msgid "Items"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1338
-msgid "Layer group:"
+#: ../gui/wxpython/gmodeler/frame.py:157
+msgid "Python editor"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1344
-#: ../gui/wxpython/lmgr/layertree.py:1885
-msgid "Click to edit layer settings"
+#: ../gui/wxpython/gmodeler/frame.py:161 ../gui/wxpython/gui_core/forms.py:2224
+#: ../gui/wxpython/modules/vkrige.py:135
+msgid "Command output"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1411
-msgid "(double click to set properties)"
+#: ../gui/wxpython/gmodeler/frame.py:243
+msgid "Python script contains local modifications"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1660
-msgid "Please wait, updating data..."
+#: ../gui/wxpython/gmodeler/frame.py:245 ../gui/wxpython/gmodeler/frame.py:2044
+msgid "Python script is up-to-date"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1965 ../gui/wxpython/lmgr/frame.py:2364
-msgid "opacity:"
+#: ../gui/wxpython/gmodeler/frame.py:262
+msgid "Redrawing model..."
msgstr ""
-#: ../gui/wxpython/lmgr/menudata.py:44
-msgid "Unable to parse user toolboxes XML files. Default main menu will be loaded."
+#: ../gui/wxpython/gmodeler/frame.py:298
+msgid "Do you want to save changes in the model?"
msgstr ""
-#: ../gui/wxpython/lmgr/menudata.py:68
-msgid "Unable to parse user toolboxes XML files. Default module tree will be loaded."
+#: ../gui/wxpython/gmodeler/frame.py:300
+msgid "Do you want to store current model settings to model file?"
msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:42
-#, python-format
-msgid "Welcome to wxGUI Interactive Python Shell %s"
+#: ../gui/wxpython/gmodeler/frame.py:306
+msgid "Quit Graphical Modeler"
msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:43
-#, python-format
-msgid "Type %s for more GRASS scripting related information."
+#: ../gui/wxpython/gmodeler/frame.py:360
+msgid "No intermediate data to delete."
msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:44
+#: ../gui/wxpython/gmodeler/frame.py:366
#, python-format
-msgid "Type %s to add raster or vector to the layer tree."
+msgid "Do you want to permanently delete data?%s"
msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:54
-msgid "Delete all text from the shell"
+#: ../gui/wxpython/gmodeler/frame.py:368
+msgid "Delete intermediate data?"
msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:59
-msgid "Simple &editor"
+#: ../gui/wxpython/gmodeler/frame.py:385
+#, python-format
+msgid "%d maps deleted from current mapset"
msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:62 ../gui/wxpython/lmgr/toolbars.py:165
-msgid "Open a simple Python code editor"
+#: ../gui/wxpython/gmodeler/frame.py:403 ../gui/wxpython/gmodeler/frame.py:553
+msgid "Current model is not empty. Do you want to store current settings to model file?"
msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:116
-#, python-format
-msgid "Raster or vector map <%s> not found"
+#: ../gui/wxpython/gmodeler/frame.py:406 ../gui/wxpython/gmodeler/frame.py:556
+msgid "Create new model?"
msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:123
+#: ../gui/wxpython/gmodeler/frame.py:443
+msgid "Choose model file"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:466
#, python-format
-msgid "Raster map <%s> added"
+msgid "%(items)d items (%(actions)d actions) loaded into model"
msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:125
+#: ../gui/wxpython/gmodeler/frame.py:478 ../gui/wxpython/gmodeler/frame.py:522
#, python-format
-msgid "Vector map <%s> added"
+msgid "Model file <%s> already exists. Do you want to overwrite this file?"
msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:49
-msgid "Start new map display"
+#: ../gui/wxpython/gmodeler/frame.py:481 ../gui/wxpython/menustrings.py:1940
+msgid "Save model"
msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:52
-msgid "Create new workspace (Ctrl+N)"
+#: ../gui/wxpython/gmodeler/frame.py:490 ../gui/wxpython/gmodeler/frame.py:540
+#, python-format
+msgid "File <%s> saved"
msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:55
-msgid "Open existing workspace file (Ctrl+O)"
+#: ../gui/wxpython/gmodeler/frame.py:503
+msgid "Choose file to save current model"
msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:58
-msgid "Save current workspace to file (Ctrl+S)"
+#: ../gui/wxpython/gmodeler/frame.py:604
+msgid "Model is empty. Nothing to validate."
msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:89
-msgid "Add multiple raster or vector map layers (Ctrl+Shift+L)"
+#: ../gui/wxpython/gmodeler/frame.py:614
+#, python-format
+msgid ""
+"Model is not valid.\n"
+"\n"
+"%s"
msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:91
-msgid "Add raster map layer (Ctrl+Shift+R)"
+#: ../gui/wxpython/gmodeler/frame.py:618
+msgid "Model is valid."
msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:94
-msgid "Add various raster map layers (RGB, HIS, shaded relief...)"
+#: ../gui/wxpython/gmodeler/frame.py:680 ../gui/wxpython/gmodeler/frame.py:687
+#, python-format
+msgid "Model exported to <%s>"
msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:96
-msgid "Add vector map layer (Ctrl+Shift+V)"
+#: ../gui/wxpython/gmodeler/frame.py:830 ../gui/wxpython/menustrings.py:1965
+msgid "Add comment"
msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:99
-msgid "Add various vector map layers (thematic, chart...)"
+#: ../gui/wxpython/gmodeler/frame.py:840
+msgid "Empty comment. Nothing to add to the model."
msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:102
-msgid "Add web service layer (WMS, WMTS, NASA OnEarth)"
+#: ../gui/wxpython/gmodeler/frame.py:876
+msgid "wxGUI Graphical Modeler"
msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:105
-msgid "Add group"
+#: ../gui/wxpython/gmodeler/frame.py:995
+#, python-format
+msgid ""
+"Reading model file <%s> failed.\n"
+"Invalid file, unable to parse XML document.\n"
+"\n"
+"%s"
msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:108
-msgid "Add various overlays"
+#: ../gui/wxpython/gmodeler/frame.py:1007
+msgid "Please wait, loading model..."
msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:111
-msgid "Remove selected map layer(s) from layer tree"
+#: ../gui/wxpython/gmodeler/frame.py:1073
+msgid "Writing current settings to model file failed."
msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:153
-msgid "Import/link raster or vector data"
+#: ../gui/wxpython/gmodeler/frame.py:1448
+msgid "Disable"
msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:155
-msgid "Raster Map Calculator"
+#: ../gui/wxpython/gmodeler/frame.py:1454
+msgid "Enable"
msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:157 ../gui/wxpython/gui_core/forms.py:1412
-msgid "Graphical Modeler"
+#: ../gui/wxpython/gmodeler/frame.py:1462
+#: ../gui/wxpython/gmodeler/frame.py:1539
+msgid "Set label"
msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:159
-msgid "Georectifier"
+#: ../gui/wxpython/gmodeler/frame.py:1468
+#: ../gui/wxpython/gmodeler/frame.py:1553
+msgid "Set comment"
msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:161 ../gui/wxpython/menustrings.py:208
-#: ../gui/wxpython/menustrings.py:1993
-msgid "Cartographic Composer"
+#: ../gui/wxpython/gmodeler/frame.py:1478
+msgid "Add control point"
msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:163
-msgid "Launch user-defined script"
+#: ../gui/wxpython/gmodeler/frame.py:1485
+msgid "Remove control point"
msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:203
-msgid "GUI settings"
+#: ../gui/wxpython/gmodeler/frame.py:1497
+msgid "Intermediate"
msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:204
-msgid "GRASS manual"
+#: ../gui/wxpython/gmodeler/frame.py:1630
+msgid "List of variables - right-click to delete"
msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:232
-msgid "Edit selected vector map"
+#: ../gui/wxpython/gmodeler/frame.py:1635
+#: ../gui/wxpython/gmodeler/frame.py:1682
+#: ../gui/wxpython/web_services/widgets.py:922
+#: ../gui/wxpython/gui_core/ghelp.py:398 ../gui/wxpython/gui_core/ghelp.py:400
+#: ../gui/wxpython/gui_core/ghelp.py:474
+msgid "Name"
msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:235
-msgid "Show attribute data for selected vector map"
+#: ../gui/wxpython/gmodeler/frame.py:1637
+#: ../gui/wxpython/gmodeler/frame.py:1695
+msgid "Default value"
msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:267
-msgid "Generate command for m.nviz.image"
+#: ../gui/wxpython/gmodeler/frame.py:1638
+#: ../gui/wxpython/gmodeler/frame.py:1702
+#: ../gui/wxpython/location_wizard/wizard.py:411
+#: ../gui/wxpython/location_wizard/wizard.py:938
+#: ../gui/wxpython/location_wizard/wizard.py:1119
+#: ../gui/wxpython/location_wizard/wizard.py:1450
+#: ../gui/wxpython/location_wizard/wizard.py:1678
+msgid "Description"
msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:268
-msgid "Generate command for m.nviz.image based on current state"
+#: ../gui/wxpython/gmodeler/frame.py:1643
+msgid "Add new variable"
msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:271
-msgid "3D view mode settings"
+#: ../gui/wxpython/gmodeler/frame.py:1647
+msgid "integer"
msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:272
-msgid "Show 3D view mode settings dialog"
+#: ../gui/wxpython/gmodeler/frame.py:1648
+msgid "float"
msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:275
-msgid "Show 3D view mode manual"
+#: ../gui/wxpython/gmodeler/frame.py:1649
+msgid "string"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:99 ../gui/wxpython/lmgr/frame.py:1202
-#: ../gui/wxpython/mapdisp/frame.py:258 ../gui/wxpython/gui_core/ghelp.py:113
-#: ../gui/wxpython/gui_core/ghelp.py:914
-msgid "Unable to get GRASS version\n"
+#: ../gui/wxpython/gmodeler/frame.py:1652
+msgid "region"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:101
-#, python-format
-msgid "GRASS GIS %s Layer Manager"
+#: ../gui/wxpython/gmodeler/frame.py:1653
+msgid "mapset"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:151
-msgid "Workspace Toolbar"
+#: ../gui/wxpython/gmodeler/frame.py:1654
+#: ../gui/wxpython/gui_core/forms.py:1801
+msgid "file"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:154
-msgid "Data Toolbar"
+#: ../gui/wxpython/gmodeler/frame.py:1655
+msgid "dir"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:160
-msgid "Tools Toolbar"
+#: ../gui/wxpython/gmodeler/frame.py:1662
+msgid "Add new variable to the model"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:163
-msgid "Vector Toolbar"
+#: ../gui/wxpython/gmodeler/frame.py:1785
+msgid "List of items - right-click to delete"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:166
-msgid "3D view Toolbar"
+#: ../gui/wxpython/gmodeler/frame.py:1791
+msgid "In loop"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:283 ../gui/wxpython/lmgr/frame.py:1690
-msgid "Rename Map Display"
+#: ../gui/wxpython/gmodeler/frame.py:1792
+msgid "Parameterized"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:322
-#: ../gui/wxpython/gui_core/preferences.py:1215
-msgid "Layers"
+#: ../gui/wxpython/gmodeler/frame.py:1848
+msgid "No items to selected."
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:339
-msgid "Console"
+#: ../gui/wxpython/gmodeler/frame.py:1884
+msgid "Python script"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:364
-#: ../gui/wxpython/gui_core/preferences.py:330
-#: ../gui/wxpython/gui_core/preferences.py:1104
-msgid "Modules"
+#: ../gui/wxpython/gmodeler/frame.py:1888
+msgid "Run python script"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:388
-#: ../gui/wxpython/gui_core/preferences.py:347
-msgid "Python"
+#: ../gui/wxpython/gmodeler/frame.py:1891
+msgid "Save python script to file"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:483
-#, python-format
+#: ../gui/wxpython/gmodeler/frame.py:1894
msgid ""
-"Location <%s> created.\n"
-"\n"
-"Do you want to switch to the new location?"
+"Refresh python script based on the model.\n"
+"It will discards all local changes."
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:486
-msgid "Switch to new location?"
+#: ../gui/wxpython/gmodeler/frame.py:1932
+#: ../gui/wxpython/gui_core/pyedit.py:279
+#, python-format
+msgid "Unable to launch Python script. %s"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:510
-msgid "Do you want to set the default region extents and resolution now?"
+#: ../gui/wxpython/gmodeler/frame.py:1959
+#: ../gui/wxpython/gui_core/pyedit.py:315
+msgid "Choose file to save"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:512
-#, python-format
-msgid "Location <%s> created"
+#: ../gui/wxpython/gmodeler/frame.py:1964
+#: ../gui/wxpython/gui_core/pyedit.py:317
+#: ../gui/wxpython/gui_core/pyedit.py:379
+msgid "Python script (*.py)|*.py"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:594
-msgid "Choose model to run"
+#: ../gui/wxpython/gmodeler/frame.py:1984
+#: ../gui/wxpython/gui_core/pyedit.py:335
+msgid "Save file"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:659 ../gui/wxpython/lmgr/frame.py:2454
-msgid "Do you want to save changes in the workspace?"
+#: ../gui/wxpython/gmodeler/frame.py:2021
+msgid "Python script is locally modificated. Refresh will discard all changes. Do you really want to continue?"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:661 ../gui/wxpython/lmgr/frame.py:2456
-msgid "Do you want to store current settings to workspace file?"
+#: ../gui/wxpython/gmodeler/frame.py:2024
+msgid "Update"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:669
-#, python-format
-msgid "Close Map Display %s"
+#: ../gui/wxpython/gmodeler/preferences.py:32
+#: ../gui/wxpython/menustrings.py:1953
+msgid "Modeler settings"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:745
-#, python-format
-msgid "Command '%s' not yet implemented in the WxGUI. Try adding it as a command layer instead."
+#: ../gui/wxpython/gmodeler/preferences.py:59
+msgid "Item properties"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:923 ../gui/wxpython/lmgr/frame.py:1966
-msgid "Selected map layer is not vector."
+#: ../gui/wxpython/gmodeler/preferences.py:66
+msgid "Disabled:"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:929
-msgid "Editing is allowed only for vector maps from the current mapset."
+#: ../gui/wxpython/gmodeler/preferences.py:114
+#: ../gui/wxpython/gmodeler/preferences.py:428
+#: ../gui/wxpython/gmodeler/preferences.py:540
+msgid "Valid:"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:955
-msgid "Choose script file to run"
+#: ../gui/wxpython/gmodeler/preferences.py:132
+msgid "Invalid:"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:957
-msgid "Python script (*.py)|*.py|Bash script (*.sh)|*.sh"
+#: ../gui/wxpython/gmodeler/preferences.py:150
+msgid "Running:"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:970
-msgid "Due to the limitations of your operating system, the script path cannot contain certain non-ascii characters. Please rename the script or move it to a different location."
+#: ../gui/wxpython/gmodeler/preferences.py:177
+#: ../gui/wxpython/gmodeler/preferences.py:343
+#: ../gui/wxpython/gmodeler/preferences.py:455
+#: ../gui/wxpython/gmodeler/preferences.py:571
+msgid "Shape size"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:977
-#, python-format
-msgid "Script file '%s' doesn't exist. Operation canceled."
+#: ../gui/wxpython/gmodeler/preferences.py:262
+msgid "Raster:"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:986
-#, python-format
-msgid "Script <%s> is not executable. Do you want to set the permissions that allows you to run this script (note that you must be the owner of the file)?"
+#: ../gui/wxpython/gmodeler/preferences.py:280
+msgid "3D raster:"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:991
-msgid "Set permission?"
+#: ../gui/wxpython/gmodeler/preferences.py:298
+msgid "Vector:"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1001
-msgid "Unable to set permission. Operation canceled."
+#: ../gui/wxpython/gmodeler/preferences.py:316
+msgid "Table:"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1015
-#, python-format
-msgid "Directory '%s' is not defined in GRASS_ADDON_PATH. Do you want add this directory to GRASS_ADDON_PATH?"
+#: ../gui/wxpython/gmodeler/preferences.py:416
+msgid "Loop"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1017
-msgid "Update Addons path?"
+#: ../gui/wxpython/gmodeler/preferences.py:528
+msgid "Comment"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1023
-#, python-format
-msgid "Launching script '%s'..."
+#: ../gui/wxpython/gmodeler/preferences.py:661
+#: ../gui/wxpython/menustrings.py:1969
+msgid "Model properties"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1037
-msgid "No location/mapset provided. Operation canceled."
+#: ../gui/wxpython/gmodeler/preferences.py:670
+msgid "Commands"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1065 ../gui/wxpython/lmgr/frame.py:1086
-msgid "No mapset provided. Operation canceled."
+#: ../gui/wxpython/gmodeler/preferences.py:682
+#: ../gui/wxpython/gui_core/preferences.py:1087
+#: ../gui/wxpython/modules/mcalc_builder.py:269
+#: ../gui/wxpython/modules/vclean.py:145 ../gui/wxpython/modules/vkrige.py:187
+#: ../gui/wxpython/modules/import_export.py:89
+msgid "Allow output files to overwrite existing files"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1118
-#, python-format
-msgid ""
-"Working directory changed to:\n"
-"\"%s\""
+#: ../gui/wxpython/gmodeler/preferences.py:694
+msgid "Apply properties"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1125
-msgid "Changes current working directory for this GUI."
+#: ../gui/wxpython/gmodeler/preferences.py:715
+msgid "Description:"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1127
-msgid "Usage: cd [directory]"
+#: ../gui/wxpython/gmodeler/preferences.py:724
+msgid "Author(s):"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1128
-msgid "Without parameters it opens a dialog."
+#: ../gui/wxpython/location_wizard/dialogs.py:38
+msgid "Set default region extent and resolution"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1132
-msgid "If ~ (tilde) is present as the first directory on the path, it is replaced by user's home directory."
+#: ../gui/wxpython/location_wizard/dialogs.py:109
+msgid "&Set region"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1146
-msgid "More than one parameter provided."
+#: ../gui/wxpython/location_wizard/dialogs.py:141
+msgid "Invalid location selected."
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1166
-msgid "Choose a working directory"
+#: ../gui/wxpython/location_wizard/dialogs.py:160
+msgid "Invalid region"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1211
-msgid "System Info"
+#: ../gui/wxpython/location_wizard/dialogs.py:191
+msgid "Click here to show 3D settings"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1226
-msgid "GRASS version"
+#: ../gui/wxpython/location_wizard/dialogs.py:192
+msgid "Click here to hide 3D settings"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1226 ../gui/wxpython/gui_core/ghelp.py:127
-msgid "unknown version"
+#: ../gui/wxpython/location_wizard/dialogs.py:218
+#: ../gui/wxpython/location_wizard/dialogs.py:517
+#, python-format
+msgid "Rows: %d"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1227
-msgid "GRASS SVN revision"
+#: ../gui/wxpython/location_wizard/dialogs.py:219
+#: ../gui/wxpython/location_wizard/dialogs.py:518
+#, python-format
+msgid "Cols: %d"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1229
-msgid "Build date"
+#: ../gui/wxpython/location_wizard/dialogs.py:220
+#: ../gui/wxpython/location_wizard/dialogs.py:519
+#, python-format
+msgid "Cells: %d"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1231
-msgid "Build platform"
+#: ../gui/wxpython/location_wizard/dialogs.py:268
+#: ../gui/wxpython/location_wizard/dialogs.py:521
+#, python-format
+msgid "Depth: %d"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1244
-msgid "Platform"
+#: ../gui/wxpython/location_wizard/dialogs.py:272
+#: ../gui/wxpython/location_wizard/dialogs.py:522
+#, python-format
+msgid "3D Cells: %d"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1306
-msgid "Current workspace is not empty. Do you want to store current settings to workspace file?"
+#: ../gui/wxpython/location_wizard/dialogs.py:295
+msgid "T-B resolution"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1309
-msgid "Create new workspace?"
+#: ../gui/wxpython/location_wizard/dialogs.py:360
+msgid "North"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1336
-msgid "Choose workspace file"
+#: ../gui/wxpython/location_wizard/dialogs.py:368
+msgid "West"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1338 ../gui/wxpython/lmgr/frame.py:1571
-msgid "GRASS Workspace File (*.gxw)|*.gxw"
+#: ../gui/wxpython/location_wizard/dialogs.py:390
+msgid "East"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1378 ../gui/wxpython/lmgr/frame.py:1545
-msgid "Please wait, loading workspace..."
+#: ../gui/wxpython/location_wizard/dialogs.py:399
+msgid "South"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1525
-msgid "Choose GRC file to load"
+#: ../gui/wxpython/location_wizard/dialogs.py:403
+msgid "N-S resolution"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1527
-msgid "Old GRASS Workspace File (*.grc)|*.grc"
+#: ../gui/wxpython/location_wizard/dialogs.py:411
+msgid "E-W resolution"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1569
-msgid "Choose file to save current workspace"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1589 ../gui/wxpython/lmgr/frame.py:1610
+#: ../gui/wxpython/location_wizard/dialogs.py:489
#, python-format
-msgid "Workspace file <%s> already exists. Do you want to overwrite this file?"
+msgid "Invalid value: %s"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1592 ../gui/wxpython/lmgr/frame.py:1613
-#: ../gui/wxpython/menustrings.py:11
-msgid "Save workspace"
+#: ../gui/wxpython/location_wizard/dialogs.py:577
+msgid "Select datum transformation"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1637
-msgid "Writing current settings to workspace file failed."
+#: ../gui/wxpython/location_wizard/dialogs.py:603
+msgid "Select from list of datum transformations"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1689
-msgid "Enter new name:"
+#: ../gui/wxpython/location_wizard/wizard.py:106
+msgid "Define GRASS Database and Location Name"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1698
-#, python-brace-format
-msgid "GRASS GIS {version} Map Display: {name} - Location: {loc}"
+#: ../gui/wxpython/location_wizard/wizard.py:126
+msgid "GIS Data Directory:"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1784
-#, python-format
-msgid ""
-"Unable to launch \"Supervised Classification Tool\".\n"
-"\n"
-"Reason: %s"
+msgid "Project Location"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1826
-msgid "Unable to start Timeline Tool."
+#: ../gui/wxpython/location_wizard/wizard.py:146
+msgid "Name of location directory in GIS Data Directory"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1837
-msgid "Unable to start Temporal Plot Tool."
+#: ../gui/wxpython/location_wizard/wizard.py:161
+msgid "Location Title"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:2090
-msgid "Add selected map layers into layer tree"
+#: ../gui/wxpython/location_wizard/wizard.py:163
+msgid "Optional location title, you can leave this field blank."
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:2123 ../gui/wxpython/lmgr/frame.py:2160
+#: ../gui/wxpython/location_wizard/wizard.py:185
#, python-format
-msgid "Unsupported map layer type <%s>."
+msgid "Name <%(name)s> is not a valid name for location. Please use only ASCII characters excluding %(chars)s and space."
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:2289
-msgid "Note that cell values can only be displayed for regions of less than 10,000 cells."
+#: ../gui/wxpython/location_wizard/wizard.py:193
+msgid "Invalid location name"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:2372
-#, python-format
-msgid ""
-"Do you want to remove map layer(s)\n"
-"%s\n"
-"from layer tree?"
+#: ../gui/wxpython/location_wizard/wizard.py:208
+msgid "Choose GRASS data directory:"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:2375
-msgid "Do you want to remove selected map layer(s) from layer tree?"
+#: ../gui/wxpython/location_wizard/wizard.py:222
+#: ../gui/wxpython/location_wizard/wizard.py:2482
+msgid "Location already exists in GRASS Database."
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:2381
-msgid "Remove map layer"
+#: ../gui/wxpython/location_wizard/wizard.py:226
+msgid "Unable to create location"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:2463
-msgid "Quit GRASS GUI"
+#: ../gui/wxpython/location_wizard/wizard.py:240
+msgid "Title of the location is limited only to one line and 256 characters. The rest of the text will be ignored."
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:2495
-msgid "Unable to exit GRASS shell: unknown PID"
+#: ../gui/wxpython/location_wizard/wizard.py:250
+msgid "Choose method for creating a new location"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:2505 ../gui/wxpython/mapdisp/frame.py:599
-#: ../gui/wxpython/gui_core/vselect.py:277
-msgid "No map layer selected. Operation canceled."
+#: ../gui/wxpython/location_wizard/wizard.py:257
+msgid "Select EPSG code of spatial reference system"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:2515
-msgid "Display resolution is currently not constrained to computational settings. It's suggested to constrain map to region geometry. Do you want to constrain the resolution?"
+#: ../gui/wxpython/location_wizard/wizard.py:263
+msgid "Read projection and datum terms from a georeferenced data file"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:2524
-msgid "Constrain map to region geometry?"
+#: ../gui/wxpython/location_wizard/wizard.py:267
+msgid "Read projection and datum terms from a Well Known Text (WKT) .prj file"
msgstr ""
-#: ../gui/wxpython/wxplot/base.py:37
-msgid "Draw/re-draw plot"
+#: ../gui/wxpython/location_wizard/wizard.py:270
+msgid "Select coordinate system parameters from a list"
msgstr ""
-#: ../gui/wxpython/wxplot/base.py:40
-msgid "Draw transect in map display window to profile"
+#: ../gui/wxpython/location_wizard/wizard.py:273
+msgid "Specify projection and datum terms using custom PROJ.4 parameters"
msgstr ""
-#: ../gui/wxpython/wxplot/base.py:43
-msgid "Plot options"
+#: ../gui/wxpython/location_wizard/wizard.py:276
+msgid "Create a generic Cartesian coordinate system (XY)"
msgstr ""
-#: ../gui/wxpython/wxplot/base.py:46
-msgid "Plot statistics"
+#: ../gui/wxpython/location_wizard/wizard.py:280
+msgid "Simple methods:"
msgstr ""
-#: ../gui/wxpython/wxplot/base.py:49
-msgid "Save profile data to CSV file"
+#: ../gui/wxpython/location_wizard/wizard.py:292
+msgid "Advanced methods:"
msgstr ""
-#: ../gui/wxpython/wxplot/base.py:51
-msgid "Quit plot tool"
+#: ../gui/wxpython/location_wizard/wizard.py:395
+msgid "Choose projection"
msgstr ""
-#: ../gui/wxpython/wxplot/base.py:485
-msgid "Left Mouse Down at Point:"
+#: ../gui/wxpython/location_wizard/wizard.py:1449
+#: ../gui/wxpython/location_wizard/wizard.py:1677
+msgid "Code"
msgstr ""
-#: ../gui/wxpython/wxplot/base.py:517 ../gui/wxpython/wxplot/base.py:584
-#: ../gui/wxpython/wxplot/dialogs.py:664
-msgid "Text settings"
+#: ../gui/wxpython/location_wizard/wizard.py:415
+msgid "Projection code:"
msgstr ""
-#: ../gui/wxpython/wxplot/base.py:521 ../gui/wxpython/wxplot/base.py:598
-#: ../gui/wxpython/wxplot/dialogs.py:986
-msgid "Plot settings"
+#: ../gui/wxpython/location_wizard/wizard.py:423
+#: ../gui/wxpython/location_wizard/wizard.py:951
+#: ../gui/wxpython/location_wizard/wizard.py:1136
+msgid "Search in description:"
msgstr ""
-#: ../gui/wxpython/wxplot/base.py:534
-msgid "This feature is not yet functional"
+#: ../gui/wxpython/location_wizard/wizard.py:602
+#, python-format
+msgid "Unable to read list: %s"
msgstr ""
-#: ../gui/wxpython/wxplot/base.py:535
-msgid "Under Construction"
+#: ../gui/wxpython/location_wizard/wizard.py:707
+msgid "Choose projection parameters"
msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:43
-msgid "GRASS GIS Histogramming Tool"
+#: ../gui/wxpython/location_wizard/wizard.py:721
+msgid "Select datum or ellipsoid (next page)"
msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:51
-msgid "Histogram of"
+#: ../gui/wxpython/location_wizard/wizard.py:729
+msgid "Datum with associated ellipsoid"
msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:52
-#: ../gui/wxpython/wxplot/histogram.py:156 ../gui/wxpython/wxplot/scatter.py:52
-#: ../gui/wxpython/wxplot/scatter.py:53
-msgid "Raster cell values"
+#: ../gui/wxpython/location_wizard/wizard.py:732
+msgid "Ellipsoid only"
msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:53
-#: ../gui/wxpython/wxplot/histogram.py:162
-msgid "Cell counts"
+#: ../gui/wxpython/location_wizard/wizard.py:790
+#, python-format
+msgid "You must enter a value for %s"
msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:141
+#: ../gui/wxpython/location_wizard/wizard.py:809
+#: ../gui/wxpython/location_wizard/wizard.py:830
#, python-format
-msgid "Histogram of image group <%s>"
+msgid " Enter parameters for %s projection "
msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:145
-#, python-format
-msgid "Histogram of raster map <%s>"
+#: ../gui/wxpython/location_wizard/wizard.py:915
+msgid "Specify geodetic datum"
msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:147
-msgid "Histogram of selected raster maps"
+msgid "Ellipsoid"
msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:154
-#, python-format
-msgid "Raster cell values %s"
+#: ../gui/wxpython/location_wizard/wizard.py:942
+msgid "Datum code:"
msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:164
-msgid "Percent of total cells"
+#: ../gui/wxpython/location_wizard/wizard.py:1090
+msgid "Specify ellipsoid"
msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:166
-msgid "Area"
+#: ../gui/wxpython/location_wizard/wizard.py:1107
+msgid "Earth based"
msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:252
-msgid "Statistics for Map(s) Histogrammed"
+#: ../gui/wxpython/location_wizard/wizard.py:1110
+msgid "Planetary bodies"
msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:257
-#, python-format
-msgid "Statistics for raster map <%s>"
+#: ../gui/wxpython/location_wizard/wizard.py:1124
+msgid "Ellipsoid code:"
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:49
-msgid "GRASS Profile Analysis Tool"
+#: ../gui/wxpython/location_wizard/wizard.py:1266
+#: ../gui/wxpython/location_wizard/wizard.py:1326
+msgid "Select georeferenced file"
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:65 ../gui/wxpython/wxplot/profile.py:173
-msgid "Profile of"
+#: ../gui/wxpython/location_wizard/wizard.py:1271
+msgid "Georeferenced file:"
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:94
-#, python-format
-msgid "Distance (%s)"
+#: ../gui/wxpython/location_wizard/wizard.py:1342
+#: ../gui/wxpython/location_wizard/wizard.py:1400
+msgid "Select Well Known Text (WKT) .prj file"
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:96
-msgid "Distance along transect"
+#: ../gui/wxpython/location_wizard/wizard.py:1347
+msgid "WKT .prj file:"
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:97
-msgid "Cell values"
+#: ../gui/wxpython/location_wizard/wizard.py:1418
+msgid "Choose EPSG Code"
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:166
-msgid "Not all points of profile lie inside computational region."
+#: ../gui/wxpython/location_wizard/wizard.py:1427
+msgid "Path to the EPSG-codes file:"
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:237
-msgid "Raster values"
+#: ../gui/wxpython/location_wizard/wizard.py:1430
+#: ../gui/wxpython/gui_core/preferences.py:1662
+msgid "EPSG code:"
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:290
-msgid "You must draw a transect to profile in the map display window."
+#: ../gui/wxpython/location_wizard/wizard.py:1591
+msgid "Choose EPSG codes file"
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:291
-msgid "Nothing to profile"
+#: ../gui/wxpython/location_wizard/wizard.py:1624
+#: ../gui/wxpython/gui_core/preferences.py:1850
+#, fuzzy
+msgid "Unable to read EPGS codes: {}"
+msgstr "Tidak dapat membaca kode EPSG: %s"
+#: ../gui/wxpython/location_wizard/wizard.py:1642
+msgid "Choose IAU Code"
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:359
-msgid "Choose prefix for file(s) where to save profile values..."
+#: ../gui/wxpython/location_wizard/wizard.py:1651
+msgid "Path to the IAU-codes file:"
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:361
-msgid "Comma separated value (*.csv)|*.csv"
+#: ../gui/wxpython/location_wizard/wizard.py:1654
+msgid "IAU code:"
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:375
-msgid "Overwrite file?"
+#: ../gui/wxpython/location_wizard/wizard.py:1836
+msgid "Choose IAU codes file"
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:386
-#, python-format
-msgid ""
-"Unable to open file <%s> for writing.\n"
-"Reason: %s"
+#: ../gui/wxpython/location_wizard/wizard.py:1871
+#, fuzzy
+msgid "Unable to read IAU codes: {}"
+#: ../gui/wxpython/location_wizard/wizard.py:1891
+msgid "Choose method of specifying georeferencing parameters"
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:402
-#, python-format
-msgid ""
-"%d files created:\n"
-"%s"
+#: ../gui/wxpython/location_wizard/wizard.py:1900
+msgid "Enter PROJ.4 parameters string:"
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:405
-msgid "No files generated."
+#: ../gui/wxpython/location_wizard/wizard.py:1956
+#: ../gui/wxpython/location_wizard/wizard.py:1960
+msgid "Datum transform is required."
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:413
-msgid "Statistics for Profile(s)"
+#: ../gui/wxpython/location_wizard/wizard.py:2042
+msgid "GRASS Database:"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:41
-msgid "Select raster maps to profile"
+#: ../gui/wxpython/location_wizard/wizard.py:2048
+msgid "Location Name:"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:81
-msgid "Select raster map(s) to profile:"
+#: ../gui/wxpython/location_wizard/wizard.py:2054
+msgid "Location Title:"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:132
-msgid "Select pairs of raster maps for scatterplots"
+#: ../gui/wxpython/location_wizard/wizard.py:2060
+msgid "Projection:"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:180
-msgid "Select pairs of raster maps for bivariate scatterplots:"
+#: ../gui/wxpython/location_wizard/wizard.py:2068
+msgid ""
+"PROJ.4 definition:\n"
+" (non-definitive)"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:195 ../gui/wxpython/wxplot/dialogs.py:502
-msgid "Number of bins (for FP maps)"
+#: ../gui/wxpython/location_wizard/wizard.py:2192
+#, python-format
+msgid "Do you want to create GRASS location <%s>?"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:360
-msgid "C&opy"
+#: ../gui/wxpython/location_wizard/wizard.py:2194
+msgid "Create new location?"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:362
-msgid "Copy regression statistics the clipboard (Ctrl+C)"
+#: ../gui/wxpython/location_wizard/wizard.py:2242
+msgid "Define new GRASS Location"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:403
-msgid "Regression statistics copied to clipboard"
+#: ../gui/wxpython/location_wizard/wizard.py:2339
+#, python-format
+msgid ""
+"Unable to create new location. Location <%(loc)s> not created.\n"
+"\n"
+"Details: %(err)s"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:414
-msgid "Select raster map or imagery group to histogram"
+#: ../gui/wxpython/location_wizard/wizard.py:2347
+msgid "Location wizard canceled. Location not created."
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:442
-msgid "Histogram single raster"
+#: ../gui/wxpython/location_wizard/wizard.py:2480
+msgid "Unable to create new location"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:445
-msgid "Histogram imagery group"
+#: ../gui/wxpython/location_wizard/wizard.py:2501
+#, python-format
+msgid "Location <%(loc)s> will be created in GIS data directory <%(dir)s>. You will need to change the default GIS data directory in the GRASS startup screen."
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:486
-msgid "Select image group:"
+#: ../gui/wxpython/location_wizard/wizard.py:2506
+msgid "New GIS data directory"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:515
-msgid "Histogram type"
+#: ../gui/wxpython/location_wizard/wizard.py:2537
+msgid "EPSG code missing."
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:601
-msgid "Selected group must be in current mapset"
+#: ../gui/wxpython/location_wizard/wizard.py:2547
+msgid "IAU code missing."
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:674
-msgid "Profile title:"
+#: ../gui/wxpython/location_wizard/wizard.py:2558
+#: ../gui/wxpython/location_wizard/wizard.py:2567
+#, python-format
+msgid "File <%s> not found."
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:688
-msgid "Title font size (pts):"
+#: ../gui/wxpython/core/debug.py:48
+msgid "Wx debug level {}."
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:705
-msgid "X-axis label:"
+#: ../gui/wxpython/core/debug.py:53
+msgid "WARNING: Ignoring unsupported wx debug level (must be >=0 and <=5). {}\n"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:719
-msgid "Y-axis label:"
+#: ../gui/wxpython/core/gconsole.py:502
+#, python-format
+msgid ""
+"Unable to run command:\n"
+"%(cmd)s\n"
+"\n"
+"Option <%(opt)s>: read from standard input is not supported by wxGUI"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:733
-msgid "Label font size (pts):"
+#: ../gui/wxpython/core/gconsole.py:526
+#, python-format
+msgid "Module <%s> not found."
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:761
-msgid "Font family:"
+#: ../gui/wxpython/core/gconsole.py:656
+#, python-format
+msgid "%d sec"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:777
-msgid "Style:"
+#: ../gui/wxpython/core/gconsole.py:659
+#, python-format
+msgid "%(min)d min %(sec)d sec"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:793
-msgid "Weight:"
+#: ../gui/wxpython/core/gconsole.py:667
+msgid "Please note that the data are left in inconsistent state and may be corrupted"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:832 ../gui/wxpython/wxplot/dialogs.py:1430
-msgid "Apply changes for the current session and close dialog"
+#: ../gui/wxpython/core/gconsole.py:669
+msgid "Command aborted"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:904
+#: ../gui/wxpython/core/gconsole.py:671
+msgid "Command finished"
+msgstr ""
+#: ../gui/wxpython/core/gconsole.py:747 ../gui/wxpython/gui_core/goutput.py:497
#, python-format
-msgid "Plot text sizes saved to file '%s'."
+msgid ""
+"Unable to write file '%(filePath)s'.\n"
+"\n"
+"Details: %(error)s"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:964
-msgid "No map or image group selected to plot."
+#: ../gui/wxpython/core/menutree.py:143
+#, python-format
+msgid "Unknow tag %s"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1007
-msgid "Map/image plotted"
+#: ../gui/wxpython/core/utils.py:60
+#, python-format
+msgid "Syntax error: %s"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1019
-msgid "Settings for selected map"
+#: ../gui/wxpython/core/utils.py:351
+#, python-format
+msgid "Vector map <%(map)s>: %(msg)s\n"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1037
-msgid "Line color"
+#: ../gui/wxpython/core/utils.py:535
+#, fuzzy
+msgid "failed to open '{}'"
+msgstr "Tidak dapat membuka berkas"
+#: ../gui/wxpython/core/utils.py:841
+#, python-format
+msgid "ERROR: Unable to determine GRASS version. Details: %s"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1104
-msgid "Transect segment marker settings"
+#: ../gui/wxpython/core/utils.py:882
+#, python-format
+msgid "Unable to open file '%s'\n"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1186
-msgid "Scatterplot points"
+#: ../gui/wxpython/core/utils.py:892
+#, python-format
+msgid ""
+"%s: line skipped - unable to parse '%s'\n"
+"Reason: %s\n"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1268
-msgid "Axis settings"
+#: ../gui/wxpython/core/utils.py:897
+#, python-format
+msgid "Duplicated key: %s\n"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1274
-msgid "X-Axis"
+#: ../gui/wxpython/core/utils.py:913
+#, python-format
+msgid "Unable to create file '%s'\n"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1275
-msgid "Y-Axis"
+#: ../gui/wxpython/core/utils.py:996 ../gui/wxpython/gui_core/forms.py:1712
+msgid "Select Color"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1284
-msgid "Scale"
+#: ../gui/wxpython/core/render.py:151
+#, python-format
+msgid "<%(name)s>: layer type <%(type)s> is not supported"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1296
-msgid "Automatic axis scaling, custom max and min, or scale matches data range (min)"
+#: ../gui/wxpython/core/render.py:170
+#, python-format
+msgid "Command '%s' failed\n"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1304
-msgid "Custom min"
+#: ../gui/wxpython/core/render.py:173
+#, python-format
+msgid "Details: %s\n"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1321
-msgid "Custom max"
+#: ../gui/wxpython/core/render.py:258
+#, python-format
+msgid "Unsupported map layer type '%s'"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1335
-msgid "Log scale"
+#: ../gui/wxpython/core/render.py:623
+#, python-format
+msgid "Rendering failed: %s"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1359
-msgid "Grid and Legend settings"
+#: ../gui/wxpython/core/render.py:666
+msgid "Rendering aborted"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1364
-msgid "Grid color"
+#: ../gui/wxpython/core/render.py:697
+msgid "Downloading data "
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1374
-msgid "Show grid"
+#: ../gui/wxpython/core/render.py:707
+msgid "Rendering & "
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1383
-msgid "Legend font size"
+#: ../gui/wxpython/core/render.py:709
+msgid "Rendering..."
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1397
-msgid "Show legend"
+#: ../gui/wxpython/core/render.py:754
+msgid "Trying to recover from default region..."
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1597
+#: ../gui/wxpython/core/render.py:814
#, python-format
-msgid "Plot settings saved to file '%s'."
+msgid "Error: Unable to open '%(file)s'. Reason: %(ret)s. wxGUI exited.\n"
msgstr ""
-#: ../gui/wxpython/wxplot/scatter.py:44
-msgid "GRASS Bivariate Scatterplot Tool"
+#: ../gui/wxpython/core/render.py:824
+#, python-format
+msgid ""
+"\n"
+"ERROR: Unable to read WIND file: %s\n"
msgstr ""
-#: ../gui/wxpython/wxplot/scatter.py:51
-msgid "Bivariate Scatterplot"
+#: ../gui/wxpython/core/render.py:928
+#, python-format
+msgid "Invalid map size %d,%d\n"
msgstr ""
-#: ../gui/wxpython/wxplot/scatter.py:102 ../gui/wxpython/wxplot/scatter.py:254
-msgid "Nothing to plot."
+#: ../gui/wxpython/core/render.py:1009
+#, python-format
+msgid "Unable to zoom to raster map <%s>."
msgstr ""
-#: ../gui/wxpython/wxplot/scatter.py:113
-msgid "At least 2 raster maps must be specified"
+#: ../gui/wxpython/core/render.py:1010 ../gui/wxpython/core/render.py:1013
+#: ../gui/wxpython/core/render.py:1016 ../gui/wxpython/core/gcmd.py:435
+msgid "Details:"
msgstr ""
-#: ../gui/wxpython/wxplot/scatter.py:136
-msgid "Bivariate Scatterplot of "
+#: ../gui/wxpython/core/render.py:1012
+#, python-format
+msgid "Unable to zoom to vector map <%s>."
msgstr ""
-#: ../gui/wxpython/wxplot/scatter.py:157 ../gui/wxpython/wxplot/scatter.py:158
+#: ../gui/wxpython/core/render.py:1015
#, python-format
-msgid "Raster <%s> cell values"
+msgid "Unable to zoom to 3d raster map <%s>."
msgstr ""
-#: ../gui/wxpython/wxplot/scatter.py:162 ../gui/wxpython/wxplot/scatter.py:166
-#, python-format
-msgid ": %s"
+#: ../gui/wxpython/core/render.py:1019
+msgid "Unable to get current geographic extent. Force quiting wxGUI. Please manually run g.region to fix the problem."
msgstr ""
-#: ../gui/wxpython/wxplot/scatter.py:260
-msgid "Regression Statistics for Scatterplot(s)"
+#: ../gui/wxpython/core/ws.py:51
+msgid ""
+"Unable to load GDAL Python bindings.\n"
+"WMS layers can not be displayed without the bindings.\n"
msgstr ""
-#: ../gui/wxpython/wxplot/scatter.py:271
+#: ../gui/wxpython/core/workspace.py:1608
#, python-format
+msgid "Unable to open file <%s> for reading."
+msgstr ""
+#: ../gui/wxpython/core/workspace.py:1625
+#, python-format
msgid ""
-"Regression equation for raster map <%(rast1)s> vs. <%(rast2)s>:\n"
+"Some lines were skipped when reading settings from file <%(file)s>.\n"
+"See 'Command output' window for details.\n"
"\n"
+"Number of skipped lines: %(line)d"
msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:23
-msgid "Modify the configuration file"
+#: ../gui/wxpython/core/workspace.py:1850
+#, python-format
+msgid " row %d:"
msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:37
-msgid "View and modify the configuration file '{name}'"
+#: ../gui/wxpython/core/gcmd.py:126
+msgid "Reason"
msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:89
-msgid ""
-"Are you sure that you want modify r.li configuration file {name}?\n"
-"You could broke the configuration file..."
+#: ../gui/wxpython/core/gcmd.py:432
+msgid "Execution failed:"
msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:94
-msgid "WARNING"
+#: ../gui/wxpython/core/gcmd.py:437 ../gui/wxpython/core/gcmd.py:444
+msgid "Error: "
msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:114
-msgid "GRASS GIS Setup for r.li modules"
+#: ../gui/wxpython/core/gcmd.py:521
+#, python-format
+msgid "Unable to exectute command: '%s'"
msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:132
-msgid "Available sampling area configuration files"
+#: ../gui/wxpython/core/gcmd.py:747 ../gui/wxpython/gui_core/forms.py:2709
+#, python-format
+msgid "Error in %s"
msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:141
-msgid "Remove a configuration file"
+#: ../gui/wxpython/core/settings.py:491
+msgid "Segment break"
msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:143 ../gui/wxpython/menustrings.py:941
-#: ../gui/wxpython/menustrings.py:1884
-msgid "Create"
+#: ../gui/wxpython/core/settings.py:557
+msgid "Data point"
msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:144
-msgid "Create a new configuration file"
+#: ../gui/wxpython/core/settings.py:631
+msgid "animation"
msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:147
-msgid "Rename a configuration file"
+#: ../gui/wxpython/core/settings.py:854
+msgid "Collapse all except PERMANENT and current"
msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:149
-msgid "View/Edit"
+#: ../gui/wxpython/core/settings.py:855
+msgid "Collapse all except PERMANENT"
msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:150
-msgid "View and edit a configuration file"
+#: ../gui/wxpython/core/settings.py:856
+msgid "Collapse all except current"
msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:225
-#, python-format
-msgid "Do you want remove r.li configuration file <%s>?"
+#: ../gui/wxpython/core/settings.py:857
+msgid "Collapse all"
msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:228
-msgid "Remove new r.li configuration file?"
+#: ../gui/wxpython/core/settings.py:858
+msgid "Expand all"
msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:251 ../gui/wxpython/rlisetup/frame.py:271
-msgid "You have to select a configuration file"
+#: ../gui/wxpython/core/settings.py:863
+msgid "Display selected"
msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:254
-#, python-format
-msgid "Set the new name for %s \" \"configuration file"
+#: ../gui/wxpython/core/settings.py:872
+msgid "Classic (labels only)"
msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:256
-msgid "Rename configuration file"
+#: ../gui/wxpython/core/settings.py:873
+msgid "Combined (labels and module names)"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:52
-msgid "Create new configuration file for r.li modules"
+#: ../gui/wxpython/core/settings.py:874
+msgid "Expert (module names only)"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:118
-#, python-format
-msgid "Do you want to create r.li configuration file <%s>?"
+#: ../gui/wxpython/core/settings.py:879
+msgid "Basic top"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:121
-msgid "Create new r.li configuration file?"
+#: ../gui/wxpython/core/settings.py:880
+msgid "Basic left"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:133
-msgid "r.li.setup wizard canceled. Configuration file not created."
+#: ../gui/wxpython/core/settings.py:881
+msgid "Fancy green"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:479
-msgid "Select maps and define name"
+#: ../gui/wxpython/core/settings.py:882
+msgid "List left"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:492
-msgid "Name for new configuration file to create"
+#: ../gui/wxpython/core/settings.py:889
+msgid "Zoom and recenter"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:505
-msgid "Raster map to use to select areas"
+msgid "Zoom to mouse cursor"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:516
-msgid "Vector map to use to select areas"
+msgid "Nothing"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:527
-msgid "Vector map layer to use to select areas"
+#: ../gui/wxpython/core/settings.py:891
+msgid "Scroll forward to zoom in"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:539
-msgid "Define sampling region (region for analysis)"
+msgid "Scroll back to zoom in"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:542
-#: ../gui/wxpython/rlisetup/wizard.py:877
-msgid "Whole map layer"
+#: ../gui/wxpython/core/settings.py:924 ../gui/wxpython/core/settings.py:936
+msgid "box"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:543
-msgid "Keyboard setting"
+#: ../gui/wxpython/core/settings.py:925
+msgid "sphere"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:544
-msgid "Draw the sampling frame"
+#: ../gui/wxpython/core/settings.py:926
+msgid "cube"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:586
-#, python-format
-msgid "The configuration file %s already exists, please change name"
+#: ../gui/wxpython/core/settings.py:927
+msgid "diamond"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:648
-#, python-format
-msgid "Vector %s was not found, please select another vector"
+#: ../gui/wxpython/core/settings.py:928
+msgid "aster"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:652
+#: ../gui/wxpython/core/settings.py:929
+msgid "gyro"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:930
+msgid "histogram"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:936
+msgid "cross"
+msgstr ""
+msgid "circle"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:969
#, python-format
-msgid "Vector %s has no areas, please select another vector"
+msgid "Unable to read settings file <%s>\n"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:657
+#: ../gui/wxpython/core/settings.py:995
#, python-format
-msgid "Vector %s has no table connected, please select another vector"
+msgid ""
+"Error: Reading settings from file <%(file)s> failed.\n"
+"\t\tDetails: %(detail)s\n"
+"\t\tLine: '%(line)s'\n"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:701
-msgid "Insert sampling frame parameter"
+#: ../gui/wxpython/core/settings.py:1013
+msgid "Unable to create settings directory"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:711
-msgid "Column of upper left corner"
+#: ../gui/wxpython/core/settings.py:1062
+#, python-format
+msgid ""
+"Writing settings to file <%(file)s> failed.\n"
+"\n"
+"Details: %(detail)s"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:725
-msgid "Row of upper left corner"
+#: ../gui/wxpython/core/settings.py:1168
+msgid "Unable to set "
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:740
-#: ../gui/wxpython/rlisetup/wizard.py:754
-msgid "Row length of sampling frame"
+#: ../gui/wxpython/core/settings.py:1204 ../gui/wxpython/core/settings.py:1214
+#, python-format
+msgid "Unable to parse settings '%s'"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:818
-#: ../gui/wxpython/rlisetup/sampling_frame.py:403
-msgid "Draw sampling frame"
+#: ../gui/wxpython/core/toolboxes.py:217
+msgid "Unable to parse user toolboxes XML files. Default files will be loaded."
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:870
-msgid "Insert sampling areas"
+#: ../gui/wxpython/core/toolboxes.py:261
+msgid "Unable to create toolboxes directory."
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:878
-msgid "Regions"
+#: ../gui/wxpython/core/toolboxes.py:485
+msgid "Custom toolboxes"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:879
-msgid "Sample units"
+#: ../gui/wxpython/core/toolboxes.py:509
+msgid "List of addons cannot be obtained because g.extension failed."
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:880 ../gui/wxpython/menustrings.py:336
-#: ../gui/wxpython/menustrings.py:1279
-msgid "Moving window"
+#: ../gui/wxpython/core/toolboxes.py:565
+msgid "Addons"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:881
-msgid ""
-"Select areas from the\n"
-"overlayed vector map"
+#: ../gui/wxpython/web_services/dialogs.py:95
+msgid " Server settings "
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:892
-msgid "Choose a method"
+#: ../gui/wxpython/web_services/dialogs.py:98
+msgid "Server:"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:894
-msgid "Use keyboard to enter sampling area"
+#: ../gui/wxpython/web_services/dialogs.py:102
+msgid "&Connect"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:895
-msgid "Use mouse to draw sampling area"
+#: ../gui/wxpython/web_services/dialogs.py:103
+msgid "Connect to the server"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:899
-msgid "This option is not supported yet"
+#: ../gui/wxpython/web_services/dialogs.py:107
+msgid "Show advanced connection settings"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:911
-msgid "Number of regions to draw:"
+#: ../gui/wxpython/web_services/dialogs.py:108
+msgid "Hide advanced connection settings"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:926
-msgid "Do you want to overwrite existing temporal maps if they exist?"
+#: ../gui/wxpython/web_services/dialogs.py:126
+msgid " Layer Manager Settings "
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:931
-msgid "Do you want to check vector areas?"
+#: ../gui/wxpython/web_services/dialogs.py:130
+msgid "Output layer name:"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:933
-msgid "Select if use area by area"
+#: ../gui/wxpython/web_services/dialogs.py:256
+msgid "Username:"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:935
-msgid "All the features will be used"
+#: ../gui/wxpython/web_services/dialogs.py:260
+msgid "Password:"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:952
-msgid "Analysing all vector features..."
+#: ../gui/wxpython/web_services/dialogs.py:301
+#: ../gui/wxpython/gui_core/gselect.py:1942
+msgid "No data source defined, settings are not saved."
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1050
-msgid "Analysing vector"
+#: ../gui/wxpython/web_services/dialogs.py:386
+#, python-format
+msgid "Connecting to <%s>..."
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1066
-msgid "All feature are been analyzed."
+#: ../gui/wxpython/web_services/dialogs.py:454
+msgid "Available web services"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1070
-msgid "An error occurred"
+#: ../gui/wxpython/web_services/dialogs.py:467
+#, python-format
+msgid "Connected to <%s>"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1102
-msgid "Draw sampling regions"
+#: ../gui/wxpython/web_services/dialogs.py:473
+#, python-format
+msgid "Unable to connect to <%s>"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1119
-msgid "Draw sample region "
+#: ../gui/wxpython/web_services/dialogs.py:523
+#: ../gui/wxpython/menustrings.py:27 ../gui/wxpython/menustrings.py:28
+msgid "Add web service layer"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1127
-#: ../gui/wxpython/rlisetup/wizard.py:1484
-msgid "Draw moving windows region"
+#: ../gui/wxpython/web_services/dialogs.py:538
+msgid "Add selected web service layers as map layer into layer tree"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1129
-#: ../gui/wxpython/rlisetup/wizard.py:1490
-#: ../gui/wxpython/rlisetup/sampling_frame.py:415
-msgid "Draw sampling region"
+#: ../gui/wxpython/web_services/dialogs.py:636
+msgid "Web service layer properties"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1166
-msgid "Select sample units from keyboard"
+#: ../gui/wxpython/web_services/dialogs.py:683
+msgid "&Apply"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1180
-#: ../gui/wxpython/rlisetup/wizard.py:1353
-#: ../gui/wxpython/rlisetup/wizard.py:1443
-msgid "Select type of shape"
+#: ../gui/wxpython/web_services/dialogs.py:688
+msgid "&OK"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1181
-#: ../gui/wxpython/rlisetup/wizard.py:1354
-#: ../gui/wxpython/rlisetup/wizard.py:1444
-msgid "Circle"
+#: ../gui/wxpython/web_services/dialogs.py:856
+msgid "Name for output raster map:"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1207
-#: ../gui/wxpython/rlisetup/wizard.py:1365
-#: ../gui/wxpython/rlisetup/wizard.py:1380
-msgid "Width size (in cells)?"
+#: ../gui/wxpython/web_services/dialogs.py:866
+msgid "Export region"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1208
-#: ../gui/wxpython/rlisetup/wizard.py:1381
-msgid "What radius size (in meters)?"
+#: ../gui/wxpython/web_services/dialogs.py:871
+#: ../gui/wxpython/menustrings.py:18
+msgid "Map display"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1209
-#: ../gui/wxpython/rlisetup/wizard.py:1372
-#: ../gui/wxpython/rlisetup/wizard.py:1382
-msgid "Height size (in cells)?"
+#: ../gui/wxpython/web_services/dialogs.py:875
+msgid "Named region"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1210
-#: ../gui/wxpython/rlisetup/wizard.py:1383
-msgid "Name of the circle mask"
+#: ../gui/wxpython/web_services/dialogs.py:877
+msgid "Extent and resolution are based on Map Display geometry."
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1218
-msgid "Select method of sampling unit distribution"
+#: ../gui/wxpython/web_services/dialogs.py:879
+msgid "Extent and resolution are based on computational region."
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1220
-msgid "Random non overlapping"
+#: ../gui/wxpython/web_services/dialogs.py:881
+msgid "Extent and resolution are based on named region."
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1221
-msgid "Systematic contiguos"
+#: ../gui/wxpython/web_services/dialogs.py:886
+msgid "Overwrite existing raster map"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1222
-msgid "Stratified random"
+#: ../gui/wxpython/web_services/dialogs.py:891
+msgid "Choose named region:"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1223
-msgid "Systematic non contiguos"
+#: ../gui/wxpython/web_services/dialogs.py:904
+msgid "&Save layer"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1224
-msgid "Centered over sites"
+#: ../gui/wxpython/web_services/dialogs.py:905
+msgid "Save web service layer as raster map"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1229
-#: ../gui/wxpython/rlisetup/wizard.py:1294
-msgid "What number of Sampling Units to use?"
+#: ../gui/wxpython/web_services/dialogs.py:1026
+msgid "Missing output raster."
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1308
-msgid "Insert number of row strates"
+#: ../gui/wxpython/web_services/dialogs.py:1030
+msgid "Output map can be added only to current mapset."
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1309
-msgid "Insert number of column strates"
+#: ../gui/wxpython/web_services/dialogs.py:1034
+#, python-format
+msgid "Output map <%s> already exists"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1315
-msgid "Insert distance between units"
+#: ../gui/wxpython/web_services/dialogs.py:1055
+#, python-format
+msgid "Region <%s> does not exist."
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1345
-msgid "Set sample units"
+#: ../gui/wxpython/web_services/dialogs.py:1084
+msgid "Downloading data..."
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1394
-msgid "Set moving windows"
+#: ../gui/wxpython/web_services/dialogs.py:1111
+msgid "Unable to fetch data.\n"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1437
-#: ../gui/wxpython/rlisetup/wizard.py:1535
-msgid "Draw sampling units"
+#: ../gui/wxpython/web_services/widgets.py:131
+msgid " Requested data settings "
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1455
-msgid "Number of sampling area to draw:"
+#: ../gui/wxpython/web_services/widgets.py:158
+msgid "Request"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1552
-msgid "Draw Sampling "
+#: ../gui/wxpython/web_services/widgets.py:163
+msgid "List of layers "
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1606
-msgid "Select sampling areas"
+#: ../gui/wxpython/web_services/widgets.py:181
+msgid "Source projection:"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1615
-msgid "Is this area ok?"
+#: ../gui/wxpython/web_services/widgets.py:242
+msgid "Advanced request settings"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1638
-msgid "Select sample area "
+#: ../gui/wxpython/web_services/widgets.py:250
+msgid "Order of layers in raster"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1665
-#: ../gui/wxpython/rlisetup/functions.py:138
-#, python-format
-msgid "The raster map <%s> already exists. Please remove or rename the maps with the prefix '%s' or select the option to overwrite existing maps"
+#: ../gui/wxpython/web_services/widgets.py:263
+msgid "Reprojection method:"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1706
-#: ../gui/wxpython/rlisetup/functions.py:127
-msgid "The polygon seems to have 0 areas"
+#: ../gui/wxpython/web_services/widgets.py:270
+msgid "Nearest neighbor"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1709
-msgid "Select sample area 1 of "
+#: ../gui/wxpython/web_services/widgets.py:271
+msgid "Linear interpolation"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1732
-#: ../gui/wxpython/location_wizard/wizard.py:2022
-msgid "Summary"
+#: ../gui/wxpython/web_services/widgets.py:272
+msgid "Cubic interpolation"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1739
-msgid "Configuration file name:"
+#: ../gui/wxpython/web_services/widgets.py:273
+msgid "Cubic spline interpolation"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1748
-msgid "Raster name:"
+#: ../gui/wxpython/web_services/widgets.py:277
+msgid "Maximum columns to request from server at time:"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1758
-msgid "Vector name:"
+#: ../gui/wxpython/web_services/widgets.py:283
+msgid "Maximum rows to request from server at time:"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1767
-msgid "Region type:"
+#: ../gui/wxpython/web_services/widgets.py:300
+msgid "Do not request transparent data"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1785
-msgid "Sampling area type:"
+#: ../gui/wxpython/web_services/widgets.py:315
+msgid "Additional query parameters for server:"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1848
-msgid "Region keyboard values:"
+#: ../gui/wxpython/web_services/widgets.py:528
+#, python-format
+msgid ""
+"Unable to download %s capabilities file\n"
+"from <%s>:\n"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1862
-#: ../gui/wxpython/rlisetup/wizard.py:1887
-#: ../gui/wxpython/rlisetup/wizard.py:1891
-msgid "Type of shape:"
+#: ../gui/wxpython/web_services/widgets.py:545
+#, python-format
+msgid ""
+"%s web service was not found in fetched capabilities file from <%s>:\n"
+"%s\n"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1865
-#: ../gui/wxpython/rlisetup/wizard.py:1894
-msgid "Radius size:"
+#: ../gui/wxpython/web_services/widgets.py:831
+msgid "Source image format"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1866
-#: ../gui/wxpython/rlisetup/wizard.py:1895
-msgid "Name circle mask:"
+#: ../gui/wxpython/web_services/widgets.py:867
+msgid "Select layer in layer list.\n"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1868
-#: ../gui/wxpython/rlisetup/wizard.py:1897
-msgid "Width size:"
+#: ../gui/wxpython/web_services/widgets.py:872
+msgid "Select source image format.\n"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1869
-#: ../gui/wxpython/rlisetup/wizard.py:1898
-msgid "Height size:"
+#: ../gui/wxpython/web_services/widgets.py:877
+msgid "Select source projection.\n"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1872
-msgid "Method of distribution:"
+#: ../gui/wxpython/web_services/widgets.py:881
+msgid "Choose output layer name.\n"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1875
-msgid "Number sampling units:"
+#: ../gui/wxpython/web_services/widgets.py:925
+#: ../gui/wxpython/gui_core/forms.py:2006
+#: ../gui/wxpython/modules/import_export.py:72
+msgid "Layer name"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1878
-msgid "Distance between units:"
+#: ../gui/wxpython/web_services/widgets.py:962
+msgid "layer"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1881
-msgid "Number row strates:"
+#: ../gui/wxpython/web_services/widgets.py:982
+msgid "style"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1883
-msgid "Number column strates:"
+#: ../gui/wxpython/web_services/widgets.py:1155
+msgid "Add default"
msgstr ""
-#: ../gui/wxpython/rlisetup/sampling_frame.py:217
-#: ../gui/wxpython/rlisetup/sampling_frame.py:326
+#: ../gui/wxpython/web_services/widgets.py:1172
#, python-format
-msgid "The raster file %s already exists, please change name"
+msgid ""
+"User defined server with same name as default server <%s> already exists.\n"
+"Keeping user defined server"
msgstr ""
-#: ../gui/wxpython/rlisetup/sampling_frame.py:243
-msgid "Raster map not created. Please redraw region."
+#: ../gui/wxpython/gui_core/dialogs.py:72
+msgid "Required item is not set."
msgstr ""
-#: ../gui/wxpython/rlisetup/sampling_frame.py:349
-msgid "Raster map not created. redraw region again."
+#: ../gui/wxpython/gui_core/dialogs.py:103
+msgid "Select GRASS location and mapset"
msgstr ""
-#: ../gui/wxpython/rlisetup/sampling_frame.py:404
-msgid "Draw sampling frame by clicking and dragging"
+#: ../gui/wxpython/gui_core/dialogs.py:122
+msgid "Location or mapset is not defined."
msgstr ""
-#: ../gui/wxpython/rlisetup/sampling_frame.py:407
-msgid "Draw sampling rectangle"
+#: ../gui/wxpython/gui_core/dialogs.py:132
+msgid "Name of GRASS location:"
msgstr ""
-#: ../gui/wxpython/rlisetup/sampling_frame.py:408
-msgid "Draw sampling rectangle by clicking and dragging"
+#: ../gui/wxpython/gui_core/dialogs.py:143
+#: ../gui/wxpython/gui_core/dialogs.py:200
+msgid "Name of mapset:"
msgstr ""
-#: ../gui/wxpython/rlisetup/sampling_frame.py:411
-msgid "Draw sampling circle"
+#: ../gui/wxpython/gui_core/dialogs.py:172
+msgid "Select mapset in GRASS location"
msgstr ""
-#: ../gui/wxpython/rlisetup/sampling_frame.py:412
-msgid "Draw sampling circle radius by clicking and dragging"
+#: ../gui/wxpython/gui_core/dialogs.py:192
+msgid "Name of mapset is missing."
msgstr ""
-#: ../gui/wxpython/rlisetup/sampling_frame.py:416
-msgid "Draw sampling region by polygon. Right Double click to end drawing"
+#: ../gui/wxpython/gui_core/dialogs.py:233
+msgid "Name of vector map is missing."
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:418
-msgid "Render"
+#: ../gui/wxpython/gui_core/dialogs.py:264
+#: ../gui/wxpython/gui_core/dialogs.py:402 ../gui/wxpython/menustrings.py:539
+#: ../gui/wxpython/menustrings.py:1445
+msgid "Create new vector map"
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:422
-msgid "Enable/disable auto-rendering"
+#: ../gui/wxpython/gui_core/dialogs.py:286
+msgid "Create attribute table"
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:454
-msgid "Show comp. extent"
+#: ../gui/wxpython/gui_core/dialogs.py:306
+#: ../gui/wxpython/gui_core/preferences.py:1115
+msgid "Add created map into layer tree"
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:458
-msgid "Show computational extent"
+#: ../gui/wxpython/gui_core/dialogs.py:320
+msgid "Name of new vector map is missing."
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:464
-msgid "Show/hide computational region extent (set with g.region). Display region drawn as a blue box inside the computational region, computational region inside a display region as a red box)."
+#: ../gui/wxpython/gui_core/dialogs.py:332
+msgid "Name for new vector map:"
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:515
-msgid "Display mode"
+#: ../gui/wxpython/gui_core/dialogs.py:351
+#: ../gui/wxpython/gui_core/preferences.py:1595
+msgid "Key column:"
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:520
-#: ../gui/wxpython/gui_core/preferences.py:915
-msgid "Align region extent based on display size"
+#: ../gui/wxpython/gui_core/dialogs.py:435
+#, python-format
+msgid "Unable to create vector map <%s>."
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:526
-msgid "Align region extent based on display size from center point. Default value for new map displays can be set up in 'User GUI settings' dialog."
+#: ../gui/wxpython/gui_core/dialogs.py:440
+#, python-format
+msgid ""
+"Invalid or empty key column.\n"
+"Unable to create vector map <%s>."
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:560
-msgid "Display resolution"
+#: ../gui/wxpython/gui_core/dialogs.py:471
+#, python-format
+msgid "Vector map <%s> already exists in the current mapset. Do you want to overwrite it?"
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:563
-#: ../gui/wxpython/gui_core/preferences.py:931
-msgid "Constrain display resolution to computational settings"
+#: ../gui/wxpython/gui_core/dialogs.py:561
+msgid "Load region:"
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:569
-msgid "Constrain display resolution to computational region settings. Default value for new map displays can be set up in 'User GUI settings' dialog."
+#: ../gui/wxpython/gui_core/dialogs.py:567
+msgid "Save region:"
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:607
-msgid "Map scale"
+#: ../gui/wxpython/gui_core/dialogs.py:619
+msgid "Name cannot begin with '.' and must not contain space, quotes, '/', ''', '@', ',', '=', '*', and all other non-alphanumeric characters."
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:624
-msgid "As everyone's monitors and resolutions are set differently these values are not true map scales, but should get you into the right neighborhood."
+#: ../gui/wxpython/gui_core/dialogs.py:635
+msgid "Create or edit imagery groups"
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:677
-msgid "Go to"
+#: ../gui/wxpython/gui_core/dialogs.py:669
+msgid "Apply changes to selected group and close dialog"
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:700
-#: ../gui/wxpython/mapdisp/statusbar.py:770
-#: ../gui/wxpython/mapdisp/statusbar.py:1009
-#: ../gui/wxpython/mapdisp/statusbar.py:1084
-msgid "Projection not defined (check the settings)"
+#: ../gui/wxpython/gui_core/dialogs.py:670
+msgid "Apply changes to selected group"
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:787
-#: ../gui/wxpython/mapdisp/statusbar.py:1024
-#: ../gui/wxpython/mapdisp/statusbar.py:1125
-msgid "Error in projection (check the settings)"
+#: ../gui/wxpython/gui_core/dialogs.py:671
+msgid "Close dialog, changes are not applied"
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:824
-#: ../gui/wxpython/gui_core/preferences.py:1664
-msgid "Projection"
+#: ../gui/wxpython/gui_core/dialogs.py:712
+#: ../gui/wxpython/gui_core/dialogs.py:1509
+msgid "Put here a regular expression. Characters '.*' stand for anything, character '^' stands for the beginning and '$' for the end."
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:826
-msgid "Use defined projection"
+#: ../gui/wxpython/gui_core/dialogs.py:719
+msgid "Select existing group or enter name of new group:"
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:841
-msgid "Reproject coordinates displayed in the statusbar. Projection can be defined in GUI preferences dialog (tab 'Projection')"
+#: ../gui/wxpython/gui_core/dialogs.py:730
+msgid "Edit/create subgroup"
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:873
-msgid "MASK"
+#: ../gui/wxpython/gui_core/dialogs.py:743
+msgid "Select existing subgroup or enter name of new subgroup:"
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:921
-msgid "Display geometry"
+#: ../gui/wxpython/gui_core/dialogs.py:777
+#: ../gui/wxpython/gui_core/dialogs.py:845
+#: ../gui/wxpython/gui_core/dialogs.py:1494
+msgid "Pattern:"
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:947
-msgid "Coordinates"
+#: ../gui/wxpython/gui_core/dialogs.py:795
+#: ../gui/wxpython/gui_core/dialogs.py:863
+#: ../gui/wxpython/gui_core/dialogs.py:1518
+msgid "List of maps:"
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:1039
-msgid "Extent"
+#: ../gui/wxpython/gui_core/dialogs.py:811
+msgid "Select map layers and add them to the list."
msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:70
-msgid "GRASS GIS - Map display"
+#: ../gui/wxpython/gui_core/dialogs.py:816
+msgid "Remove selected layer(s) from list."
msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:248
-#, python-format
-msgid ""
-"Failed to run command '%(command)s'. Details:\n"
-"%(error)s"
+#: ../gui/wxpython/gui_core/dialogs.py:873
+msgid "Check maps from group to be included into subgroup."
msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:262
+#: ../gui/wxpython/gui_core/dialogs.py:1037
+msgid "Add selected map layers into group"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1174
#, python-format
-msgid "GRASS GIS %(version)s Map Display: %(id)s - Location: %(loc)s@%(mapset)s"
+msgid "Group <%s> was changed, do you want to apply changes?"
msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:319
-msgid "Vector Digitizer Toolbar"
+#: ../gui/wxpython/gui_core/dialogs.py:1177
+#: ../gui/wxpython/gui_core/dialogs.py:1193
+msgid "Unapplied changes"
msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:342
+#: ../gui/wxpython/gui_core/dialogs.py:1190
#, python-format
-msgid ""
-"Unable to switch to 3D display mode.\n"
-"The Nviz python extension was not found or loaded properly.\n"
-"Switching back to 2D display mode.\n"
-"\n"
-"Details: %s"
+msgid "Subgroup <%s> was changed, do you want to apply changes?"
msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:377
-msgid "Starting 3D view mode..."
+#: ../gui/wxpython/gui_core/dialogs.py:1247
+msgid "No raster maps selected."
msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:379
-msgid "Please wait, loading data..."
+#: ../gui/wxpython/gui_core/dialogs.py:1276
+#, python-format
+msgid "No changes to apply in group <%s>."
msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:462
-msgid "Please wait, unloading data..."
+#: ../gui/wxpython/gui_core/dialogs.py:1279
+#, python-format
+msgid "Group <%s> was successfully created."
msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:464
-msgid "Switching back to 2D view mode..."
+#: ../gui/wxpython/gui_core/dialogs.py:1281
+#, python-format
+msgid "Group <%s> was successfully changed."
msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:722 ../gui/wxpython/mapdisp/frame.py:730
-#: ../gui/wxpython/mapdisp/frame.py:745
-msgid "Failed to run d.to.rast:\n"
+#: ../gui/wxpython/gui_core/dialogs.py:1284
+#, python-format
+msgid "Creating of new group <%s> failed."
msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:761
-msgid "d.to.rast can be used only in 2D mode."
+#: ../gui/wxpython/gui_core/dialogs.py:1286
+#, python-format
+msgid "Changing of group <%s> failed."
msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:893
-#, python-format
-msgid "Vector map <%s> opened for editing - skipped."
+#: ../gui/wxpython/gui_core/dialogs.py:1324
+msgid "No group selected."
msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:964
-msgid "Failed to query vector map(s) <{maps}>. Check database settings and topology."
+#: ../gui/wxpython/gui_core/dialogs.py:1329
+msgid "No subgroup selected."
msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:1393
-msgid "Set computational region extent from display"
+#: ../gui/wxpython/gui_core/dialogs.py:1436
+msgid "Use fully-qualified map names"
msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:1395
-msgid "Set computational region extent interactively"
+#: ../gui/wxpython/gui_core/dialogs.py:1462
+msgid "Map type:"
msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:1397
-msgid "Set computational region from named region"
+#: ../gui/wxpython/gui_core/dialogs.py:1477
+msgid "Select toggle"
msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:1402
-msgid "Save computational region to named region"
+#: ../gui/wxpython/gui_core/dialogs.py:1484
+msgid "Mapset:"
msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:1535
-msgid "Raster Digitizer Toolbar"
+#: ../gui/wxpython/gui_core/dialogs.py:1577
+msgid "Invert selection"
msgstr ""
-#: ../gui/wxpython/mapdisp/test_mapdisp.py:147
-msgid "Map window test frame"
+#: ../gui/wxpython/gui_core/dialogs.py:1720
+#, python-format
+msgid "Dynamic series (%s)"
msgstr ""
-#: ../gui/wxpython/mapdisp/test_mapdisp.py:166
-msgid "Map display test"
+#: ../gui/wxpython/gui_core/dialogs.py:1747
+msgid "Set Map Layer Opacity"
msgstr ""
-#: ../gui/wxpython/mapdisp/test_mapdisp.py:176
-msgid "Map window API test frame"
+#: ../gui/wxpython/gui_core/dialogs.py:1781
+msgid "opaque"
msgstr ""
-#: ../gui/wxpython/mapdisp/test_mapdisp.py:206
-msgid "Map window distance measurement test frame"
+#: ../gui/wxpython/gui_core/dialogs.py:1879
+msgid "Set image size"
msgstr ""
-#: ../gui/wxpython/mapdisp/test_mapdisp.py:237
-msgid "Map window profile tool test frame"
+#: ../gui/wxpython/gui_core/dialogs.py:1894
+msgid "Image size"
msgstr ""
-#: ../gui/wxpython/mapdisp/test_mapdisp.py:284
-msgid "Map window rlisetup test frame"
+#: ../gui/wxpython/gui_core/dialogs.py:1941
+msgid "Template:"
msgstr ""
-#: ../gui/wxpython/mapdisp/test_mapdisp.py:345
-#, python-format
-msgid "Unknown value %s of test parameter."
+#: ../gui/wxpython/gui_core/dialogs.py:1981
+msgid "GRASS GIS SQL Query Utility"
msgstr ""
-#: ../gui/wxpython/mapdisp/gprint.py:154
-msgid ""
-"There was a problem printing.\n"
-"Perhaps your current printer is not set correctly?"
+#: ../gui/wxpython/gui_core/dialogs.py:1997
+msgid " SQL statement "
msgstr ""
-#: ../gui/wxpython/mapdisp/main.py:187
-#, python-format
-msgid "Unsupported command %s."
+#: ../gui/wxpython/gui_core/dialogs.py:2045
+msgid "Symbols"
msgstr ""
-#: ../gui/wxpython/mapdisp/main.py:281
-#, python-format
-msgid "Unable to read cmdfile '%(cmd)s'. Details: %(det)s"
+#: ../gui/wxpython/gui_core/dialogs.py:2080
+msgid "Symbol directory:"
msgstr ""
-#: ../gui/wxpython/mapdisp/main.py:604
-#, python-format
-msgid "Starting map display <%s>..."
+#: ../gui/wxpython/gui_core/dialogs.py:2092
+msgid "Symbol name:"
msgstr ""
-#: ../gui/wxpython/mapdisp/main.py:610
-#, python-format
-msgid "Unable to create file <%s>"
+#: ../gui/wxpython/gui_core/dialogs.py:2326
+#: ../gui/wxpython/gui_core/dialogs.py:2351 ../gui/wxpython/menustrings.py:208
+msgid "Quit GRASS GIS"
msgstr ""
-#: ../gui/wxpython/mapdisp/main.py:626
-#, python-format
-msgid "Stopping map display <%s>..."
+#: ../gui/wxpython/gui_core/dialogs.py:2344
+msgid "Do you want to quit GRASS including shell prompt or just close the GUI?"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:32
-msgid "Select vector feature(s)"
+#: ../gui/wxpython/gui_core/dialogs.py:2348 ../gui/wxpython/menustrings.py:206
+msgid "Close GUI"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:33
-msgid "Select features interactively from vector map"
+#: ../gui/wxpython/gui_core/dialogs.py:2422
+msgid "Select font:"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:35
-msgid "Add scale bar"
+#: ../gui/wxpython/gui_core/dialogs.py:2453
+msgid "Character encoding:"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:37
-msgid "Add raster legend"
+#: ../gui/wxpython/gui_core/dialogs.py:2518
+msgid "Example"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:39
-msgid "Add vector legend"
+#: ../gui/wxpython/gui_core/forms.py:545
+msgid "Enter parameters for '"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:41 ../gui/wxpython/menustrings.py:2092
-msgid "Add north arrow"
+#: ../gui/wxpython/gui_core/forms.py:557
+#: ../gui/wxpython/mapswipe/dialogs.py:193 ../gui/wxpython/menustrings.py:14
+#: ../gui/wxpython/menustrings.py:1943
+msgid "Close"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:43
-msgid "Analyze map"
+#: ../gui/wxpython/gui_core/forms.py:561
+msgid "Close this window without executing the command (Ctrl+Q)"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:44
-msgid "Measuring, profiling, histogramming, ..."
+#: ../gui/wxpython/gui_core/forms.py:592
+msgid "Run the command (Ctrl+R)"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:46
-msgid "Measure distance"
+#: ../gui/wxpython/gui_core/forms.py:607 ../gui/wxpython/menustrings.py:166
+#: ../gui/wxpython/menustrings.py:1151
+msgid "Copy"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:48
-msgid "Measure area"
+#: ../gui/wxpython/gui_core/forms.py:611
+#: ../gui/wxpython/modules/mcalc_builder.py:159
+msgid "Copy the current command string to the clipboard"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:50
-msgid "Profile surface map"
+#: ../gui/wxpython/gui_core/forms.py:620
+msgid "Show manual page of the command (Ctrl+H)"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:52
-msgid "Create bivariate scatterplot of raster maps"
+#: ../gui/wxpython/gui_core/forms.py:659
+msgid "Add created map(s) into layer tree"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:56
-msgid "Create histogram of raster map"
+#: ../gui/wxpython/gui_core/forms.py:689
+msgid "Close dialog when command is successfully finished. Change this settings in Preferences dialog ('Command' tab)."
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:58 ../gui/wxpython/menustrings.py:650
-#: ../gui/wxpython/menustrings.py:1593
-msgid "Vector network analysis tool"
+#: ../gui/wxpython/gui_core/forms.py:865
+#, python-format
+msgid "'%s' copied to clipboard"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:64
-msgid "Rotate 3D scene"
+#: ../gui/wxpython/gui_core/forms.py:945 ../gui/wxpython/gui_core/forms.py:959
+msgid "Required"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:65
-msgid "Drag with mouse to rotate 3D scene"
+#: ../gui/wxpython/gui_core/forms.py:948 ../gui/wxpython/gui_core/forms.py:960
+msgid "Optional"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:70
-msgid "Drag with mouse, hold Ctrl down for different mode or Shift to accelerate"
+#: ../gui/wxpython/gui_core/forms.py:1043
+#: ../gui/wxpython/gui_core/forms.py:2034
+msgid "Parameterized in model"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:73
-msgid "Click mouse to zoom"
+#: ../gui/wxpython/gui_core/forms.py:1112
+msgid "This option is required"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:75
-msgid "Click mouse to unzoom"
+#: ../gui/wxpython/gui_core/forms.py:1133
+msgid "[multiple]"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:110
-msgid "3D view mode not available"
+#: ../gui/wxpython/gui_core/forms.py:1191
+msgid "valid range"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:111
-#: ../gui/wxpython/mapdisp/toolbars.py:123
-#, python-format
-msgid "Reason: %s"
+#: ../gui/wxpython/gui_core/forms.py:1301
+#: ../gui/wxpython/gui_core/forms.py:2665
+#: ../gui/wxpython/gui_core/toolbars.py:69
+msgid "Select font"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:122
-msgid "Vector digitizer not available"
+#: ../gui/wxpython/gui_core/forms.py:1419
+#: ../gui/wxpython/gui_core/preferences.py:744
+msgid "Map Display"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:126
-msgid "Note that the wxGUI's vector digitizer is currently disabled (hopefully this will be fixed soon). Please keep an eye out for updated versions of GRASS. In the meantime you can use \"v.digit\" from the Develop Vector menu."
+#: ../gui/wxpython/gui_core/forms.py:1532
+msgid "Show graphical representation of temporal extent of dataset(s) ."
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:133
-msgid "Raster digitizer"
+#: ../gui/wxpython/gui_core/forms.py:1762
+#: ../gui/wxpython/gui_core/preferences.py:1312
+#: ../gui/wxpython/gui_core/preferences.py:1347
+msgid "Transparent"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:39
+#: ../gui/wxpython/gui_core/forms.py:1798
+#: ../gui/wxpython/gui_core/forms.py:1882
#, python-format
-msgid ""
-"Loading imagery lib failed.\n"
-"%s"
+msgid "Choose %s"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:79
-msgid "GRASS GIS Supervised Classification Tool"
+#: ../gui/wxpython/gui_core/forms.py:1833
+#: ../gui/wxpython/modules/mcalc_builder.py:155
+msgid "&Load"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:325
-msgid "IClass Toolbar"
+#: ../gui/wxpython/gui_core/forms.py:1835
+msgid "Load and edit content of a file"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:337
-msgid "IClass Misc Toolbar"
+#: ../gui/wxpython/gui_core/forms.py:1838
+msgid "&Save as"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:364
-msgid "Digitization Toolbar"
+#: ../gui/wxpython/gui_core/forms.py:1840
+msgid "Save content to a file for further use"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:388
-msgid "Plots"
+#: ../gui/wxpython/gui_core/forms.py:1845
+msgid "or enter values directly:"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:408
-msgid "Preview Display"
+#: ../gui/wxpython/gui_core/forms.py:1847
+msgid "Enter file content directly instead of specifying a file. Temporary file will be automatically created."
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:411
-msgid "Training Areas Display"
+#: ../gui/wxpython/gui_core/forms.py:1885
+#: ../gui/wxpython/gui_core/gselect.py:1417
+msgid "Directory"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:485
-msgid "Adjust Training Area Display to Preview Display"
+#: ../gui/wxpython/gui_core/forms.py:2005
+#: ../gui/wxpython/modules/import_export.py:71
+#: ../gui/wxpython/modules/import_export.py:862
+msgid "Layer id"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:487
-msgid "Adjust Preview display to Training Area Display"
+#: ../gui/wxpython/gui_core/forms.py:2008
+#: ../gui/wxpython/modules/import_export.py:76
+#: ../gui/wxpython/modules/import_export.py:78
+msgid "Projection match"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:489
-msgid "Display synchronization ON"
+#: ../gui/wxpython/gui_core/forms.py:2237
+msgid "Manual"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:491
-msgid "Display synchronization OFF"
+#: ../gui/wxpython/gui_core/forms.py:2281
+msgid "Nothing to load."
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:564
-msgid "All changes will be lost. Do you want to continue?"
+#: ../gui/wxpython/gui_core/forms.py:2289
+#, python-format
+msgid ""
+"Unable to load file.\n"
+"\n"
+"Reason: %s"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:573
-msgid "Import vector map"
+#: ../gui/wxpython/gui_core/forms.py:2315
+#: ../gui/wxpython/modules/colorrules.py:690
+msgid "Nothing to save."
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:593
-#, python-format
-msgid "No areas in vector map <%s>.\n"
+#: ../gui/wxpython/gui_core/forms.py:2319
+msgid "Save input as..."
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:595
-#, python-format
-msgid "Vector map <%s> contains points or lines, these features are ignored."
+#: ../gui/wxpython/gui_core/forms.py:2652
+msgid "No dataset given."
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:622
+#: ../gui/wxpython/gui_core/forms.py:2821
+#: ../gui/wxpython/gui_core/forms.py:2838
#, python-format
-msgid "Unable to open vector map <%s>"
+msgid "Unable to parse command '%s'"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:633
+#: ../gui/wxpython/gui_core/forms.py:2845
#, python-format
-msgid "Unable to copy vector features from <%s>"
+msgid "%(cmd)s: parameter '%(key)s' not available"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:645
-msgid "Unable to open temporary vector map"
+#: ../gui/wxpython/gui_core/forms.py:2927
+msgid "Try to set up GRASS_ADDON_PATH or GRASS_ADDON_BASE variable."
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:741
-msgid "No training areas to export."
+#: ../gui/wxpython/gui_core/vselect.py:48
+msgid "category"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:754
-#, python-format
-msgid "%d training areas (%d classes) exported to vector map <%s>."
+#: ../gui/wxpython/gui_core/vselect.py:73
+msgid "Select features"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:994
-msgid "Failed to create temporary vector map."
+#: ../gui/wxpython/gui_core/vselect.py:136
+msgid "Create a new map"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:1090
+#: ../gui/wxpython/gui_core/vselect.py:265
#, python-format
-msgid "No area in category %s. Category skipped."
+msgid "Selected map <%s> has been disabled for rendering. Operation canceled."
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:1094
-msgid "Analysis failed."
+#: ../gui/wxpython/gui_core/vselect.py:297
+#, python-format
+msgid "Failed to query vector map(s) <%s>."
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:1101
-msgid "results"
+#: ../gui/wxpython/gui_core/vselect.py:322
+msgid "No features selected"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:1107
-msgid "No imagery group selected."
+#: ../gui/wxpython/gui_core/vselect.py:346
+#, python-format
+msgid "Vector map <%s> was created"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:1114
-msgid "Due to recent changes in classes, signatures can be outdated and should be recalculated. Do you still want to continue?"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:1117
-msgid "Outdated signatures"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:1135
+#: ../gui/wxpython/gui_core/vselect.py:349
#, python-format
msgid ""
-"A signature file named %s already exists.\n"
-"Do you want to replace it?"
+"Unable to create a new vector map.\n"
+"\n"
+"Reason: %s"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:1188
-msgid "No imagery group selected. Operation canceled."
+#: ../gui/wxpython/gui_core/menu.py:149
+msgid "Double-click or Ctrl-Enter to run selected module"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:1199
-#, python-format
-msgid "Group <%(group)s> does not have enough files (it has %(files)d files). Operation canceled."
+#: ../gui/wxpython/gui_core/menu.py:171
+msgid "Run selected module from the tree"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:1207
-msgid "No areas given. Operation canceled."
+#: ../gui/wxpython/gui_core/goutput.py:127
+msgid "Click here to show search module engine"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:1222
-msgid "Vector features are outside raster layers. Operation canceled."
+#: ../gui/wxpython/gui_core/goutput.py:129
+msgid "Click here to hide search module engine"
msgstr ""
-#: ../gui/wxpython/iclass/statistics.py:29
-msgid "Loading imagery lib failed"
+#: ../gui/wxpython/gui_core/goutput.py:146
+msgid "Command prompt"
msgstr ""
-#: ../gui/wxpython/iclass/digit.py:61
-msgid "You are trying to create a training area outside the computational region. Please, use g.region to set the appropriate region first."
+#: ../gui/wxpython/gui_core/goutput.py:151
+msgid "Output window"
msgstr ""
-#: ../gui/wxpython/iclass/digit.py:72
-msgid ""
-"In order to create a training area, you have to select class first.\n"
-"\n"
-"There is no class yet, do you want to create one?"
+#: ../gui/wxpython/gui_core/goutput.py:159
+msgid "Clear output window content"
msgstr ""
-#: ../gui/wxpython/iclass/plots.py:73
-msgid "Histograms"
+#: ../gui/wxpython/gui_core/goutput.py:161
+msgid "Clear command prompt content"
msgstr ""
-#: ../gui/wxpython/iclass/plots.py:74
-msgid "Coincident plots"
+#: ../gui/wxpython/gui_core/goutput.py:164
+msgid "Save output window content to the file"
msgstr ""
-#: ../gui/wxpython/iclass/plots.py:75
-msgid "Scatter plots"
+#: ../gui/wxpython/gui_core/goutput.py:166
+msgid "Abort running command"
msgstr ""
-#: ../gui/wxpython/iclass/plots.py:99
-#, python-format
-msgid ""
-"Scatter plot functionality is disabled.\n"
-"\n"
-"Reason: Unable to import packages needed for scatter plot.\n"
-"%s"
+#: ../gui/wxpython/gui_core/goutput.py:170
+msgid "&Log file"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:85
-msgid "Name of imagery group is missing."
+#: ../gui/wxpython/gui_core/goutput.py:172
+msgid "Toggle to save list of executed commands into a file; content saved when switching off."
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:92
-msgid "Name of imagery group:"
+#: ../gui/wxpython/gui_core/goutput.py:421
+#: ../gui/wxpython/gui_core/goutput.py:517
+msgid "Save file as..."
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:107
-msgid "Name of imagery subgroup:"
+#: ../gui/wxpython/gui_core/goutput.py:423
+#: ../gui/wxpython/gui_core/goutput.py:519
+#, python-format
+msgid "%(txt)s (*.txt)|*.txt|%(files)s (*)|*"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:182
-msgid "Please choose a subgroup."
+#: ../gui/wxpython/gui_core/goutput.py:424
+#: ../gui/wxpython/gui_core/goutput.py:520
+msgid "Text files"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:186
-#, python-format
-msgid "Subgroup <%s> not found in group <%s>"
+#: ../gui/wxpython/gui_core/goutput.py:425
+#: ../gui/wxpython/gui_core/goutput.py:521
+msgid "Files"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:193
+#: ../gui/wxpython/gui_core/goutput.py:438
#, python-format
msgid ""
-"No data found in subgroup <%s> of group <%s>.\n"
+"Unable to write file '%(path)s'.\n"
+"\n"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:198
+#: ../gui/wxpython/gui_core/goutput.py:443
#, python-format
-msgid ""
-"No data found in group <%s>.\n"
+msgid "Command output saved into '%s'"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:202
-#: ../gui/wxpython/iclass/g.gui.iclass.py:79
+#: ../gui/wxpython/gui_core/goutput.py:502
#, python-format
-msgid "Group <%s> not found"
+msgid "Command log saved to '%s'"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:250
-msgid "Name of map is missing."
+#: ../gui/wxpython/gui_core/ghelp.py:53 ../gui/wxpython/menustrings.py:1015
+#: ../gui/wxpython/menustrings.py:1016
+msgid "About GRASS GIS"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:280 ../gui/wxpython/iclass/toolbars.py:37
-msgid "Class manager"
+#: ../gui/wxpython/gui_core/ghelp.py:75
+msgid "Info"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:545
-msgid "Zoom to training areas of selected class"
+#: ../gui/wxpython/gui_core/ghelp.py:76
+msgid "Copyright"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:607
-msgid "Save signature file"
+#: ../gui/wxpython/gui_core/ghelp.py:77
+msgid "License"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:668
-msgid "Enter name of signature file:"
+#: ../gui/wxpython/gui_core/ghelp.py:78
+msgid "Citation"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:680
-msgid "Signature file path:"
+#: ../gui/wxpython/gui_core/ghelp.py:79
+msgid "Authors"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:730
-msgid "Export training areas"
+#: ../gui/wxpython/gui_core/ghelp.py:80
+msgid "Contributors"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:793
-msgid "Export attribute table containing computed statistical data"
+#: ../gui/wxpython/gui_core/ghelp.py:81
+msgid "Extra contributors"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:832
-#, python-format
-msgid "Vector map <%s> already exists. Do you want to overwrite it?"
+#: ../gui/wxpython/gui_core/ghelp.py:82
+msgid "Translators"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:835
-#, python-format
-msgid "Vector <%s> exists"
+#: ../gui/wxpython/gui_core/ghelp.py:83
+msgid "Translation status"
msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:34
-msgid "Set opacity level"
+#: ../gui/wxpython/gui_core/ghelp.py:148
+msgid "Official GRASS site:"
msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:43
-msgid "Run analysis, update histogram and coincidence plots"
+#: ../gui/wxpython/gui_core/ghelp.py:159
+msgid "Code Revision"
msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:46
-msgid "Save signature file for i.maxlik"
+#: ../gui/wxpython/gui_core/ghelp.py:170
+msgid "Build Date"
msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:49
-msgid "Remove selected map layer"
+#: ../gui/wxpython/gui_core/ghelp.py:224 ../gui/wxpython/gui_core/ghelp.py:482
+msgid "Language"
msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:52
-msgid "Export training areas to vector map"
+#: ../gui/wxpython/gui_core/ghelp.py:253 ../gui/wxpython/gui_core/ghelp.py:278
+#: ../gui/wxpython/gui_core/ghelp.py:329 ../gui/wxpython/gui_core/ghelp.py:392
+#: ../gui/wxpython/gui_core/ghelp.py:466 ../gui/wxpython/gui_core/ghelp.py:632
+#, python-format
+msgid "%s file missing"
msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:55
-msgid "Import training areas from vector map"
+#: ../gui/wxpython/gui_core/ghelp.py:301
+msgid "Unable to provide citation suggestion, see GRASS GIS website instead. The error was: {}"
msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:76
-msgid "Training"
+#: ../gui/wxpython/gui_core/ghelp.py:377 ../gui/wxpython/gui_core/ghelp.py:450
+#, python-format
+msgid "Error when reading file '%s'."
msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:82
-msgid "Set map canvas for "
+#: ../gui/wxpython/gui_core/ghelp.py:378 ../gui/wxpython/gui_core/ghelp.py:451
+msgid "Lines:"
msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:84
-msgid "/ Zoom to map"
+#: ../gui/wxpython/gui_core/ghelp.py:398 ../gui/wxpython/gui_core/ghelp.py:400
+#: ../gui/wxpython/gui_core/ghelp.py:478
+msgid "E-mail"
msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:260
-#: ../gui/wxpython/iclass/toolbars.py:269
-msgid "std dev"
+msgid "Country"
msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:343
-msgid "Add raster map"
+#: ../gui/wxpython/gui_core/ghelp.py:400
+msgid "OSGeo_ID"
msgstr ""
-#: ../gui/wxpython/iclass/g.gui.iclass.py:75
-msgid "Name of subgroup required"
+#: ../gui/wxpython/gui_core/ghelp.py:486
+msgid "Nation"
msgstr ""
-#: ../gui/wxpython/iclass/g.gui.iclass.py:84
+#: ../gui/wxpython/gui_core/ghelp.py:536
#, python-format
-msgid "Subgroup <%s> not found"
+msgid " %d translated"
msgstr ""
-#: ../gui/wxpython/iclass/g.gui.iclass.py:121
+#: ../gui/wxpython/gui_core/ghelp.py:540 ../gui/wxpython/gui_core/ghelp.py:566
#, python-format
-msgid "Loading raster map <%s>..."
+msgid " %d fuzzy"
msgstr ""
-#: ../gui/wxpython/iclass/g.gui.iclass.py:124
+#: ../gui/wxpython/gui_core/ghelp.py:544 ../gui/wxpython/gui_core/ghelp.py:575
#, python-format
-msgid "Loading training map <%s>..."
+msgid " %d untranslated"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:59
-msgid "User settings"
+#: ../gui/wxpython/gui_core/ghelp.py:557
+#, python-format
+msgid "%d translated"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:83
-msgid "Set to default"
+#: ../gui/wxpython/gui_core/ghelp.py:629
+#, python-format
+msgid "File <%s> not found"
msgstr ""
-msgid "Revert settings to default"
+#: ../gui/wxpython/gui_core/ghelp.py:802
+msgid "&Next"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:94
-msgid "Apply changes for the current session only and close"
+#: ../gui/wxpython/gui_core/ghelp.py:805
+msgid "&Previous"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:95
-msgid "Save for this session only"
+#: ../gui/wxpython/gui_core/toolbars.py:36
+msgid "Display map"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:165
-msgid "Settings applied to current session but not saved"
+#: ../gui/wxpython/gui_core/toolbars.py:37
+msgid "Re-render modified map layers only"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:237
-msgid "Key column cannot be empty string."
+#: ../gui/wxpython/gui_core/toolbars.py:39
+msgid "Render map"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:256
-msgid "GUI Settings"
+#: ../gui/wxpython/gui_core/toolbars.py:40
+msgid "Force re-rendering all map layers"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:291
-msgid "Layer Manager settings"
+#: ../gui/wxpython/gui_core/toolbars.py:42
+msgid "Erase display"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:301
-msgid "Ask when removing map layer from layer tree"
+#: ../gui/wxpython/gui_core/toolbars.py:43
+msgid "Erase display canvas with given background color"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:314
-msgid "Ask when quiting wxGUI or closing display"
+#: ../gui/wxpython/gui_core/toolbars.py:45
+msgid "Pointer"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:329
-#: ../gui/wxpython/gui_core/preferences.py:346
-#, python-format
-msgid "Hide '%s' tab (requires GUI restart)"
+#: ../gui/wxpython/gui_core/toolbars.py:47
+msgid "Zoom in"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:366
-msgid "Automatically copy selected text to clipboard (in the Console tab)"
+#: ../gui/wxpython/gui_core/toolbars.py:48
+msgid "Drag or click mouse to zoom"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:394
-msgid "Workspace settings"
+#: ../gui/wxpython/gui_core/toolbars.py:50
+msgid "Zoom out"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:401
-msgid "Suppress positioning Map Display Window(s)"
+#: ../gui/wxpython/gui_core/toolbars.py:51
+msgid "Drag or click mouse to unzoom"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:417
-msgid "Suppress positioning Layer Manager window"
+#: ../gui/wxpython/gui_core/toolbars.py:53
+msgid "Return to previous zoom"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:432
-msgid "Save current window layout as default"
+#: ../gui/wxpython/gui_core/toolbars.py:55
+msgid "Various zoom options"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:441
-msgid "Save current position and size of Layer Manager window and opened Map Display window(s) and use as default for next sessions."
+#: ../gui/wxpython/gui_core/toolbars.py:56
+msgid "Zoom to default or saved region, save to named region, ..."
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:463
-msgid "Region settings"
+#: ../gui/wxpython/gui_core/toolbars.py:58
+msgid "Zoom to selected map layer(s)"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:470
-msgid "Align region to resolution"
+#: ../gui/wxpython/gui_core/toolbars.py:60
+msgid "Zoom to computational region extent"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:524
-msgid "Font for command output:"
+#: ../gui/wxpython/gui_core/toolbars.py:62
+msgid "Pan"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:542
-msgid "Language settings"
+#: ../gui/wxpython/gui_core/toolbars.py:63
+msgid "Drag with mouse to pan"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:558
-msgid "Choose language (requires to save and GRASS restart):"
+#: ../gui/wxpython/gui_core/toolbars.py:65
+msgid "Save display to file"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:591
-msgid "Appearance settings"
+#: ../gui/wxpython/gui_core/toolbars.py:79
+msgid "Add map elements"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:601
-msgid "Element list:"
+#: ../gui/wxpython/gui_core/toolbars.py:80
+msgid "Overlay elements like scale and legend onto map"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:631
-msgid "Menu style (requires to save and GUI restart):"
+#: ../gui/wxpython/gui_core/toolbars.py:82
+msgid "Create histogram with d.histogram"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:666
-msgid "Height of map selection popup window (in pixels):"
+#: ../gui/wxpython/gui_core/toolbars.py:259
+msgid "Select graphics tool"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:706
-msgid "Icon theme (requires GUI restart):"
+#: ../gui/wxpython/gui_core/gselect.py:61
+#, python-format
+msgid ""
+"Unable to import pyGRASS: %s\n"
+"Some functionality will be not accessible"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:733
-msgid "Module dialog style:"
+#: ../gui/wxpython/gui_core/gselect.py:490
+msgid "Not selectable element"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:779
-#: ../gui/wxpython/gui_core/forms.py:1418
-msgid "Map Display"
+#: ../gui/wxpython/gui_core/gselect.py:527
+#: ../gui/wxpython/gui_core/preferences.py:2137
+msgid "Mapset"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:800
-msgid "Default font for GRASS displays:"
+#: ../gui/wxpython/gui_core/gselect.py:539
+msgid "Type: "
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:827
-msgid "Default display settings"
+#: ../gui/wxpython/gui_core/gselect.py:557
+#, python-format
+msgid "GSelect: invalid item: %s"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:837
-msgid "Display driver:"
+#: ../gui/wxpython/gui_core/gselect.py:1394
+msgid "Output settings"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:863
-msgid "Statusbar mode:"
+#: ../gui/wxpython/gui_core/gselect.py:1396
+msgid "Source input"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:947
-msgid "Enable auto-rendering"
+#: ../gui/wxpython/gui_core/gselect.py:1407
+msgid "Native"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:964
-msgid "Enable auto-zooming to selected map layer"
+#: ../gui/wxpython/gui_core/gselect.py:1413
+msgid "File"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:980
-msgid "Mouse wheel action:"
+#: ../gui/wxpython/gui_core/gselect.py:1425
+msgid "Protocol"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1006
-msgid "Mouse scrolling direction:"
+#: ../gui/wxpython/gui_core/gselect.py:1436
+msgid "Output type"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1047
-msgid "Advanced display settings"
+#: ../gui/wxpython/gui_core/gselect.py:1438
+msgid "Source type"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1056
-msgid "3D view depth buffer (possible values are 16, 24, 32):"
+#: ../gui/wxpython/gui_core/gselect.py:1460
+msgid "All files"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1111
-msgid "Module dialog settings"
+#: ../gui/wxpython/gui_core/gselect.py:1476
+msgid "ZIP files"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1136
-msgid "Close dialog when module is successfully finished"
+#: ../gui/wxpython/gui_core/gselect.py:1477
+msgid "GZIP files"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1150
-#: ../gui/wxpython/gui_core/dialogs.py:306
-msgid "Add created map into layer tree"
+#: ../gui/wxpython/gui_core/gselect.py:1478
+msgid "TAR files"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1165
-msgid "Allow interactive input"
+#: ../gui/wxpython/gui_core/gselect.py:1480
+msgid "TARGZ files"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1179
-msgid "Verbosity level:"
+#: ../gui/wxpython/gui_core/gselect.py:1488
+msgid "File:"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1225
-msgid "Default raster settings"
+#: ../gui/wxpython/gui_core/gselect.py:1489
+msgid "Choose file to import"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1235
-msgid "Make null cells opaque"
+#: ../gui/wxpython/gui_core/gselect.py:1505
+#: ../gui/wxpython/gui_core/gselect.py:1588
+msgid "Choose input directory"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1250
-msgid "Default color table"
+#: ../gui/wxpython/gui_core/gselect.py:1522
+msgid "Extension:"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1296
-msgid "Default vector settings"
+#: ../gui/wxpython/gui_core/gselect.py:1552
+msgid "Choose file"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1302
-msgid "Display:"
+#: ../gui/wxpython/gui_core/gselect.py:1573
+#: ../gui/wxpython/gui_core/gselect.py:2333
+msgid "Feature type:"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1327
-msgid "Feature color:"
+#: ../gui/wxpython/gui_core/gselect.py:1575
+msgid "simple features"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1347
-#: ../gui/wxpython/gui_core/preferences.py:1382
-#: ../gui/wxpython/gui_core/forms.py:1761
-msgid "Transparent"
+#: ../gui/wxpython/gui_core/gselect.py:1576
+msgid "topological"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1367
-msgid "Area fill color:"
+#: ../gui/wxpython/gui_core/gselect.py:1687
+#: ../gui/wxpython/gui_core/gselect.py:1718
+#: ../gui/wxpython/gui_core/gselect.py:1769
+#: ../gui/wxpython/gui_core/gselect.py:1807
+msgid "Creation options:"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1428
-msgid "Symbol:"
+#: ../gui/wxpython/gui_core/gselect.py:1701
+#: ../gui/wxpython/gui_core/gselect.py:1740
+#: ../gui/wxpython/gui_core/gselect.py:1792
+msgid "Format:"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1511
-msgid "Line width (in pixels):"
+#: ../gui/wxpython/gui_core/gselect.py:1799
+msgid "Protocol:"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1527
-msgid "Automatically hightlight selected features in map display"
+#: ../gui/wxpython/gui_core/gselect.py:1822
+msgid "No settings available"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1551
-msgid "Data browser"
+#: ../gui/wxpython/gui_core/gselect.py:2325
+msgid "LineString"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1559
-msgid "Left mouse double click:"
+msgid "Polygon"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1584
-msgid "Encoding (e.g. utf-8, ascii, iso8859-1, koi8-r):"
+#: ../gui/wxpython/gui_core/gselect.py:2544
+msgid "No vector map selected in layer manager. Operation canceled."
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1599
-msgid "Ask when deleting data record(s) from table"
+#: ../gui/wxpython/gui_core/gselect.py:2557
+msgid "Input vector map is not selected"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1623
-msgid "Create table"
+#: ../gui/wxpython/gui_core/gselect.py:2561
+#, python-format
+msgid "Input vector map <%s> and selected map <%s> in layer manager are different. Operation canceled."
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1630
-#: ../gui/wxpython/gui_core/dialogs.py:351
-msgid "Key column:"
+#: ../gui/wxpython/gui_core/query.py:31
+msgid "Query results"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1673
-msgid "Projection statusbar settings"
+#: ../gui/wxpython/gui_core/query.py:43
+msgid "Right click to copy selected values to clipboard."
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1682
-msgid ""
-"\n"
-"Note: This only controls the coordinates displayed in the lower-left of the Map Display\n"
-"window's status bar. It is purely cosmetic and does not affect the working location's\n"
-"projection in any way. You will need to enable the Projection check box in the drop-down\n"
-"menu located at the bottom of the Map Display window.\n"
+#: ../gui/wxpython/gui_core/query.py:49
+msgid "Feature"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1697
-#: ../gui/wxpython/location_wizard/wizard.py:1452
-msgid "EPSG code:"
+msgid "Value"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1715
-msgid "Proj.4 string (required):"
+#: ../gui/wxpython/gui_core/query.py:71
+msgid "Copy all to clipboard"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1732
-msgid "EPSG file:"
+#: ../gui/wxpython/gui_core/query.py:74
+msgid "Redirect to console"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1749
-msgid "Load EPSG codes (be patient), enter EPSG code or insert Proj.4 string directly."
+#: ../gui/wxpython/gui_core/query.py:136 ../gui/wxpython/gui_core/query.py:139
+#, python-format
+msgid "Copy from '%s' column"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1757
-msgid "&Load EPSG codes"
+#: ../gui/wxpython/gui_core/query.py:141
+msgid "Copy selected lines"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1777
-msgid "Coordinates format"
+#: ../gui/wxpython/gui_core/query.py:144 ../gui/wxpython/gui_core/query.py:149
+#, python-format
+msgid "Copy '%s'"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1785
-msgid "Lat/long projections"
+#: ../gui/wxpython/gui_core/query.py:151
+msgid "Copy line"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1806
-msgid "Precision:"
+#: ../gui/wxpython/gui_core/query.py:178
+msgid "Query results:"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1885
-#: ../gui/wxpython/location_wizard/wizard.py:1646
-#, python-brace-format
-msgid "Unable to read EPGS codes: {0}"
+#: ../gui/wxpython/gui_core/query.py:181
+msgid " "
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1892
-#, python-format
-msgid "Unable to read EPSG codes: %s"
+#: ../gui/wxpython/gui_core/query.py:270
+msgid "east, north"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1925
-#: ../gui/wxpython/gui_core/preferences.py:1937
-#: ../gui/wxpython/gui_core/preferences.py:1949
-#, python-format
-msgid "EPSG code %s not found"
+#: ../gui/wxpython/gui_core/query.py:281
+msgid "Nothing found"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1959
-msgid "Select default display font"
+#: ../gui/wxpython/gui_core/simplelmgr.py:109
+msgid "Toolbar"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1973
-msgid "Failed to set default display font. Try different font."
+#: ../gui/wxpython/gui_core/simplelmgr.py:145
+msgid "Copy map names to clipboard (top to bottom)"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1992
-msgid "Select default output font"
+#: ../gui/wxpython/gui_core/simplelmgr.py:146
+msgid "Copy map names to clipboard (bottom to top)"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:2081
-msgid "Manage access to mapsets"
+#: ../gui/wxpython/gui_core/simplelmgr.py:464
+msgid "Remove selected map(s) from list"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:2096
-msgid ""
-"Check a mapset to make it accessible, uncheck it to hide it.\n"
-" Notes:\n"
-" - The current mapset is always accessible.\n"
-" - You may only write to the current mapset.\n"
-" - You may only write to mapsets which you own."
+#: ../gui/wxpython/gui_core/simplelmgr.py:466
+msgid "Layer up"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:2172
-#: ../gui/wxpython/gui_core/gselect.py:527
-msgid "Mapset"
+#: ../gui/wxpython/gui_core/simplelmgr.py:467
+msgid "Move selected layer(s) up"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:2173
-msgid "Owner"
+#: ../gui/wxpython/gui_core/simplelmgr.py:469
+msgid "Layer down"
msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:48 ../gui/wxpython/menustrings.py:1053
-#: ../gui/wxpython/menustrings.py:1054
-msgid "About GRASS GIS"
+#: ../gui/wxpython/gui_core/simplelmgr.py:470
+msgid "Move selected layer(s) down"
msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:70
-msgid "Info"
+#: ../gui/wxpython/gui_core/simplelmgr.py:472
+#: ../gui/wxpython/gui_core/simplelmgr.py:473
+msgid "Edit layer properties"
msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:71
-msgid "Copyright"
+#: ../gui/wxpython/gui_core/simplelmgr.py:475
+msgid "Change opacity"
msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:72
-msgid "License"
+#: ../gui/wxpython/gui_core/simplelmgr.py:476
+msgid "Change layer opacity"
msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:73
-msgid "Citation"
+#: ../gui/wxpython/gui_core/pyedit.py:377
+msgid "Open file"
msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:74
-msgid "Authors"
+#: ../gui/wxpython/gui_core/pyedit.py:448
+msgid "Replace the content by the template?"
msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:75
-msgid "Contributors"
+#: ../gui/wxpython/gui_core/pyedit.py:450
+msgid "Replace the content by the example?"
msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:76
-msgid "Extra contributors"
+#: ../gui/wxpython/gui_core/pyedit.py:452
+msgid "Replace the current content by the file content?"
msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:77
-msgid "Translators"
+#: ../gui/wxpython/gui_core/pyedit.py:458
+msgid "Replace content"
msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:78
-msgid "Translation status"
+#: ../gui/wxpython/gui_core/pyedit.py:470
+msgid "Set parameters for the script"
msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:143
-msgid "Official GRASS site:"
+#: ../gui/wxpython/gui_core/pyedit.py:471
+msgid "Specify command line parameters for the script separated by spaces:"
msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:154
-msgid "Code Revision"
+#: ../gui/wxpython/gui_core/pyedit.py:521
+msgid "Open (Ctrl+O)"
msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:165
-msgid "Build Date"
+#: ../gui/wxpython/gui_core/pyedit.py:523
+msgid "Save (Ctrl+S)"
msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:219 ../gui/wxpython/gui_core/ghelp.py:477
-msgid "Language"
+#: ../gui/wxpython/gui_core/pyedit.py:525
+msgid "Run (Ctrl+R)"
msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:248 ../gui/wxpython/gui_core/ghelp.py:273
-#: ../gui/wxpython/gui_core/ghelp.py:324 ../gui/wxpython/gui_core/ghelp.py:387
-#: ../gui/wxpython/gui_core/ghelp.py:461 ../gui/wxpython/gui_core/ghelp.py:627
-#, python-format
-msgid "%s file missing"
+#: ../gui/wxpython/gui_core/pyedit.py:528
+msgid "Activate overwrite"
msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:296
-msgid "Unable to provide citation suggestion, see GRASS GIS website instead. The error was: {0}"
+#: ../gui/wxpython/gui_core/pyedit.py:530
+msgid "Deactive overwrite"
msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:372 ../gui/wxpython/gui_core/ghelp.py:445
-#, python-format
-msgid "Error when reading file '%s'."
+#: ../gui/wxpython/gui_core/pyedit.py:581
+msgid "GRASS GIS Simple Python Editor"
msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:373 ../gui/wxpython/gui_core/ghelp.py:446
-msgid "Lines:"
+#: ../gui/wxpython/gui_core/preferences.py:59
+msgid "User settings"
msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:393 ../gui/wxpython/gui_core/ghelp.py:395
-#: ../gui/wxpython/gui_core/ghelp.py:473
-msgid "E-mail"
+#: ../gui/wxpython/gui_core/preferences.py:83
+msgid "Set to default"
msgstr ""
-msgid "Country"
+#: ../gui/wxpython/gui_core/preferences.py:91
+msgid "Revert settings to default"
msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:395
-msgid "OSGeo_ID"
+#: ../gui/wxpython/gui_core/preferences.py:94
+msgid "Apply changes for the current session only and close"
msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:481
-msgid "Nation"
+#: ../gui/wxpython/gui_core/preferences.py:95
+msgid "Save for this session only"
msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:531
-#, python-format
-msgid " %d translated"
+#: ../gui/wxpython/gui_core/preferences.py:165
+msgid "Settings applied to current session but not saved"
msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:535 ../gui/wxpython/gui_core/ghelp.py:561
-#, python-format
-msgid " %d fuzzy"
+#: ../gui/wxpython/gui_core/preferences.py:237
+msgid "Key column cannot be empty string."
msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:539 ../gui/wxpython/gui_core/ghelp.py:570
-#, python-format
-msgid " %d untranslated"
+#: ../gui/wxpython/gui_core/preferences.py:256
+msgid "GUI Settings"
msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:552
-#, python-format
-msgid "%d translated"
+#: ../gui/wxpython/gui_core/preferences.py:291
+msgid "Layer Manager settings"
msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:624
+#: ../gui/wxpython/gui_core/preferences.py:301
+msgid "Ask when removing map layer from layer tree"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:314
+msgid "Ask when quiting wxGUI or closing display"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:329
+#: ../gui/wxpython/gui_core/preferences.py:346
#, python-format
-msgid "File <%s> not found"
+msgid "Hide '%s' tab (requires GUI restart)"
msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:793
-msgid "&Next"
+#: ../gui/wxpython/gui_core/preferences.py:366
+msgid "Automatically copy selected text to clipboard (in the Console tab)"
msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:796
-msgid "&Previous"
+#: ../gui/wxpython/gui_core/preferences.py:394
+msgid "Workspace settings"
msgstr ""
-#: ../gui/wxpython/gui_core/menu.py:149
-msgid "Double-click or Ctrl-Enter to run selected module"
+#: ../gui/wxpython/gui_core/preferences.py:401
+msgid "Suppress positioning Map Display Window(s)"
msgstr ""
-#: ../gui/wxpython/gui_core/menu.py:171
-msgid "Run selected module from the tree"
+#: ../gui/wxpython/gui_core/preferences.py:417
+msgid "Suppress positioning Layer Manager window"
msgstr ""
-#: ../gui/wxpython/gui_core/vselect.py:48
-msgid "category"
+#: ../gui/wxpython/gui_core/preferences.py:432
+msgid "Save current window layout as default"
msgstr ""
-#: ../gui/wxpython/gui_core/vselect.py:73
-msgid "Select features"
+#: ../gui/wxpython/gui_core/preferences.py:441
+msgid "Save current position and size of Layer Manager window and opened Map Display window(s) and use as default for next sessions."
msgstr ""
-#: ../gui/wxpython/gui_core/vselect.py:136
-msgid "Create a new map"
+#: ../gui/wxpython/gui_core/preferences.py:489
+msgid "Font for command output:"
msgstr ""
-#: ../gui/wxpython/gui_core/vselect.py:265
-#, python-format
-msgid "Selected map <%s> has been disabled for rendering. Operation canceled."
+#: ../gui/wxpython/gui_core/preferences.py:507
+msgid "Language settings"
msgstr ""
-#: ../gui/wxpython/gui_core/vselect.py:297
-#, python-format
-msgid "Failed to query vector map(s) <%s>."
+#: ../gui/wxpython/gui_core/preferences.py:523
+msgid "Choose language (requires to save and GRASS restart):"
msgstr ""
-#: ../gui/wxpython/gui_core/vselect.py:322
-msgid "No features selected"
+#: ../gui/wxpython/gui_core/preferences.py:556
+msgid "Appearance settings"
msgstr ""
-#: ../gui/wxpython/gui_core/vselect.py:346
-#, python-format
-msgid "Vector map <%s> was created"
+#: ../gui/wxpython/gui_core/preferences.py:566
+msgid "Element list:"
msgstr ""
-#: ../gui/wxpython/gui_core/vselect.py:349
-#, python-format
-msgid ""
-"Unable to create a new vector map.\n"
-"\n"
-"Reason: %s"
+#: ../gui/wxpython/gui_core/preferences.py:596
+msgid "Menu style (requires to save and GUI restart):"
msgstr ""
-#: ../gui/wxpython/gui_core/query.py:31
-msgid "Query results"
+#: ../gui/wxpython/gui_core/preferences.py:631
+msgid "Height of map selection popup window (in pixels):"
msgstr ""
-#: ../gui/wxpython/gui_core/query.py:43
-msgid "Right click to copy selected values to clipboard."
+#: ../gui/wxpython/gui_core/preferences.py:671
+msgid "Icon theme (requires GUI restart):"
msgstr ""
-#: ../gui/wxpython/gui_core/query.py:49
-msgid "Feature"
+#: ../gui/wxpython/gui_core/preferences.py:698
+msgid "Module dialog style:"
msgstr ""
-msgid "Value"
+#: ../gui/wxpython/gui_core/preferences.py:765
+msgid "Default font for GRASS displays:"
msgstr ""
-#: ../gui/wxpython/gui_core/query.py:71
-msgid "Copy all to clipboard"
+#: ../gui/wxpython/gui_core/preferences.py:792
+msgid "Default display settings"
msgstr ""
-#: ../gui/wxpython/gui_core/query.py:74
-msgid "Redirect to console"
+#: ../gui/wxpython/gui_core/preferences.py:802
+msgid "Display driver:"
msgstr ""
-#: ../gui/wxpython/gui_core/query.py:136 ../gui/wxpython/gui_core/query.py:139
-#, python-format
-msgid "Copy from '%s' column"
+#: ../gui/wxpython/gui_core/preferences.py:828
+msgid "Statusbar mode:"
msgstr ""
-#: ../gui/wxpython/gui_core/query.py:141
-msgid "Copy selected lines"
+#: ../gui/wxpython/gui_core/preferences.py:912
+msgid "Enable auto-rendering"
msgstr ""
-#: ../gui/wxpython/gui_core/query.py:144 ../gui/wxpython/gui_core/query.py:149
-#, python-format
-msgid "Copy '%s'"
+#: ../gui/wxpython/gui_core/preferences.py:929
+msgid "Enable auto-zooming to selected map layer"
msgstr ""
-#: ../gui/wxpython/gui_core/query.py:151
-msgid "Copy line"
+#: ../gui/wxpython/gui_core/preferences.py:945
+msgid "Mouse wheel action:"
msgstr ""
-#: ../gui/wxpython/gui_core/query.py:178
-msgid "Query results:"
+#: ../gui/wxpython/gui_core/preferences.py:971
+msgid "Mouse scrolling direction:"
msgstr ""
-#: ../gui/wxpython/gui_core/query.py:181
-msgid " "
+#: ../gui/wxpython/gui_core/preferences.py:1012
+msgid "Advanced display settings"
msgstr ""
-#: ../gui/wxpython/gui_core/query.py:270
-msgid "east, north"
+#: ../gui/wxpython/gui_core/preferences.py:1021
+msgid "3D view depth buffer (possible values are 16, 24, 32):"
msgstr ""
-#: ../gui/wxpython/gui_core/query.py:281
-msgid "Nothing found"
+#: ../gui/wxpython/gui_core/preferences.py:1076
+msgid "Module dialog settings"
msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:122
-msgid "Click here to show search module engine"
+#: ../gui/wxpython/gui_core/preferences.py:1101
+msgid "Close dialog when module is successfully finished"
msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:124
-msgid "Click here to hide search module engine"
+#: ../gui/wxpython/gui_core/preferences.py:1130
+msgid "Allow interactive input"
msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:141
-msgid "Command prompt"
+#: ../gui/wxpython/gui_core/preferences.py:1144
+msgid "Verbosity level:"
msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:146
-msgid "Output window"
+#: ../gui/wxpython/gui_core/preferences.py:1190
+msgid "Default raster settings"
msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:154
-msgid "Clear output window content"
+#: ../gui/wxpython/gui_core/preferences.py:1200
+msgid "Make null cells opaque"
msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:156
-msgid "Clear command prompt content"
+#: ../gui/wxpython/gui_core/preferences.py:1215
+msgid "Default color table"
msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:159
-msgid "Save output window content to the file"
+#: ../gui/wxpython/gui_core/preferences.py:1261
+msgid "Default vector settings"
msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:161
-msgid "Abort running command"
+#: ../gui/wxpython/gui_core/preferences.py:1267
+msgid "Display:"
msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:165
-msgid "&Log file"
+#: ../gui/wxpython/gui_core/preferences.py:1292
+msgid "Feature color:"
msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:167
-msgid "Toggle to save list of executed commands into a file; content saved when switching off."
+#: ../gui/wxpython/gui_core/preferences.py:1332
+msgid "Area fill color:"
msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:416
-#: ../gui/wxpython/gui_core/goutput.py:512
-msgid "Save file as..."
+#: ../gui/wxpython/gui_core/preferences.py:1393
+msgid "Symbol:"
msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:418
-#: ../gui/wxpython/gui_core/goutput.py:514
-#, python-format
-msgid "%(txt)s (*.txt)|*.txt|%(files)s (*)|*"
+#: ../gui/wxpython/gui_core/preferences.py:1476
+msgid "Line width (in pixels):"
msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:419
-#: ../gui/wxpython/gui_core/goutput.py:515
-msgid "Text files"
+#: ../gui/wxpython/gui_core/preferences.py:1492
+msgid "Automatically hightlight selected features in map display"
msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:420
-#: ../gui/wxpython/gui_core/goutput.py:516
-msgid "Files"
+#: ../gui/wxpython/gui_core/preferences.py:1516
+msgid "Data browser"
msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:433
-#, python-format
-msgid ""
-"Unable to write file '%(path)s'.\n"
-"\n"
-"Details: %(error)s"
+#: ../gui/wxpython/gui_core/preferences.py:1524
+msgid "Left mouse double click:"
msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:438
-#, python-format
-msgid "Command output saved into '%s'"
+#: ../gui/wxpython/gui_core/preferences.py:1549
+msgid "Encoding (e.g. utf-8, ascii, iso8859-1, koi8-r):"
msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:497
-#, python-format
-msgid "Command log saved to '%s'"
+#: ../gui/wxpython/gui_core/preferences.py:1564
+msgid "Ask when deleting data record(s) from table"
msgstr ""
-#: ../gui/wxpython/gui_core/simplelmgr.py:104
-msgid "Toolbar"
+#: ../gui/wxpython/gui_core/preferences.py:1588
+msgid "Create table"
msgstr ""
-#: ../gui/wxpython/gui_core/simplelmgr.py:140
-msgid "Copy map names to clipboard (top to bottom)"
+#: ../gui/wxpython/gui_core/preferences.py:1638
+msgid "Projection statusbar settings"
msgstr ""
-#: ../gui/wxpython/gui_core/simplelmgr.py:141
-msgid "Copy map names to clipboard (bottom to top)"
+#: ../gui/wxpython/gui_core/preferences.py:1647
+msgid ""
+"\n"
+"Note: This only controls the coordinates displayed in the lower-left of the Map Display\n"
+"window's status bar. It is purely cosmetic and does not affect the working location's\n"
+"projection in any way. You will need to enable the Projection check box in the drop-down\n"
+"menu located at the bottom of the Map Display window.\n"
msgstr ""
-#: ../gui/wxpython/gui_core/simplelmgr.py:459
-msgid "Remove selected map(s) from list"
+#: ../gui/wxpython/gui_core/preferences.py:1680
+msgid "Proj.4 string (required):"
msgstr ""
-#: ../gui/wxpython/gui_core/simplelmgr.py:461
-msgid "Layer up"
+#: ../gui/wxpython/gui_core/preferences.py:1697
+msgid "EPSG file:"
msgstr ""
-#: ../gui/wxpython/gui_core/simplelmgr.py:462
-msgid "Move selected layer(s) up"
+#: ../gui/wxpython/gui_core/preferences.py:1714
+msgid "Load EPSG codes (be patient), enter EPSG code or insert Proj.4 string directly."
msgstr ""
-#: ../gui/wxpython/gui_core/simplelmgr.py:464
-msgid "Layer down"
+#: ../gui/wxpython/gui_core/preferences.py:1722
+msgid "&Load EPSG codes"
msgstr ""
-#: ../gui/wxpython/gui_core/simplelmgr.py:465
-msgid "Move selected layer(s) down"
+#: ../gui/wxpython/gui_core/preferences.py:1742
+msgid "Coordinates format"
msgstr ""
-#: ../gui/wxpython/gui_core/simplelmgr.py:467
-#: ../gui/wxpython/gui_core/simplelmgr.py:468
-msgid "Edit layer properties"
+#: ../gui/wxpython/gui_core/preferences.py:1750
+msgid "Lat/long projections"
msgstr ""
-#: ../gui/wxpython/gui_core/simplelmgr.py:470
-msgid "Change opacity"
+#: ../gui/wxpython/gui_core/preferences.py:1771
+msgid "Precision:"
msgstr ""
-#: ../gui/wxpython/gui_core/simplelmgr.py:471
-msgid "Change layer opacity"
+#: ../gui/wxpython/gui_core/preferences.py:1857
+#, python-format
+msgid "Unable to read EPSG codes: %s"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:72
-msgid "Required item is not set."
+#: ../gui/wxpython/gui_core/preferences.py:1890
+#: ../gui/wxpython/gui_core/preferences.py:1902
+#: ../gui/wxpython/gui_core/preferences.py:1914
+#, python-format
+msgid "EPSG code %s not found"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:103
-msgid "Select GRASS location and mapset"
+#: ../gui/wxpython/gui_core/preferences.py:1924
+msgid "Select default display font"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:122
-msgid "Location or mapset is not defined."
+#: ../gui/wxpython/gui_core/preferences.py:1938
+msgid "Failed to set default display font. Try different font."
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:132
-msgid "Name of GRASS location:"
+#: ../gui/wxpython/gui_core/preferences.py:1957
+msgid "Select default output font"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:143
-#: ../gui/wxpython/gui_core/dialogs.py:200
-msgid "Name of mapset:"
+#: ../gui/wxpython/gui_core/preferences.py:2046
+msgid "Manage access to mapsets"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:172
-msgid "Select mapset in GRASS location"
+#: ../gui/wxpython/gui_core/preferences.py:2061
+msgid ""
+"Check a mapset to make it accessible, uncheck it to hide it.\n"
+" Notes:\n"
+" - The current mapset is always accessible.\n"
+" - You may only write to the current mapset.\n"
+" - You may only write to mapsets which you own."
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:192
-msgid "Name of mapset is missing."
+#: ../gui/wxpython/gui_core/preferences.py:2138
+msgid "Owner"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:233
-msgid "Name of vector map is missing."
+#: ../gui/wxpython/gui_core/widgets.py:101
+msgid " (...)"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:264
-#: ../gui/wxpython/gui_core/dialogs.py:402 ../gui/wxpython/menustrings.py:547
-#: ../gui/wxpython/menustrings.py:1490
-msgid "Create new vector map"
+#: ../gui/wxpython/gui_core/widgets.py:839
+#, python-format
+msgid "Name <%(name)s> is not a valid name for GRASS map. Please use only ASCII characters excluding %(chars)s and space."
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:286
-msgid "Create attribute table"
+#: ../gui/wxpython/gui_core/widgets.py:1067
+msgid "Fulltext search"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:320
-msgid "Name of new vector map is missing."
+#: ../gui/wxpython/gui_core/widgets.py:1069
+msgid "Type to search in all modules. Press Enter for next match."
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:332
-msgid "Name for new vector map:"
+#: ../gui/wxpython/gui_core/widgets.py:1136
+msgid "Searching, please type more characters."
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:435
+#: ../gui/wxpython/gui_core/widgets.py:1145
#, python-format
-msgid "Unable to create vector map <%s>."
+msgid "%d modules match"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:440
-#, python-format
-msgid ""
-"Invalid or empty key column.\n"
-"Unable to create vector map <%s>."
+#: ../gui/wxpython/gui_core/widgets.py:1215
+msgid "Profiles"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:471
-#, python-format
-msgid "Vector map <%s> already exists in the current mapset. Do you want to overwrite it?"
+#: ../gui/wxpython/gui_core/widgets.py:1221
+msgid "Save current settings"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:561
-msgid "Load region:"
+#: ../gui/wxpython/gui_core/widgets.py:1225
+msgid "Delete currently selected settings"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:567
-msgid "Save region:"
+#: ../gui/wxpython/gui_core/widgets.py:1248
+msgid "Load:"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:619
-msgid "Name cannot begin with '.' and must not contain space, quotes, '/', ''', '@', ',', '=', '*', and all other non-alphanumeric characters."
+#: ../gui/wxpython/gui_core/widgets.py:1266
+#, python-format
+msgid "Settings <%s> not found"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:635
-msgid "Create or edit imagery groups"
+#: ../gui/wxpython/gui_core/widgets.py:1280
+#: ../gui/wxpython/gui_core/widgets.py:1300
+msgid "Save settings"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:669
-msgid "Apply changes to selected group and close dialog"
+#: ../gui/wxpython/gui_core/widgets.py:1285
+msgid "Name not given, settings is not saved."
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:670
-msgid "Apply changes to selected group"
+#: ../gui/wxpython/gui_core/widgets.py:1297
+#, python-format
+msgid "Settings <%s> already exists. Do you want to overwrite the settings?"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:671
-msgid "Close dialog, changes are not applied"
+#: ../gui/wxpython/gui_core/widgets.py:1348
+msgid "No settings is defined. Operation canceled."
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:712
-#: ../gui/wxpython/gui_core/dialogs.py:1509
-msgid "Put here a regular expression. Characters '.*' stand for anything, character '^' stands for the beginning and '$' for the end."
+#: ../gui/wxpython/gui_core/widgets.py:1386
+msgid "Unable to save settings"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:719
-msgid "Select existing group or enter name of new group:"
+#: ../gui/wxpython/iscatt/dialogs.py:40
+msgid "Add scatter plots"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:730
-msgid "Edit/create subgroup"
+#: ../gui/wxpython/iscatt/dialogs.py:59
+msgid "x axis:"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:743
-msgid "Select existing subgroup or enter name of new subgroup:"
+#: ../gui/wxpython/iscatt/dialogs.py:66
+msgid "y axis:"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:777
-#: ../gui/wxpython/gui_core/dialogs.py:845
-#: ../gui/wxpython/gui_core/dialogs.py:1494
-msgid "Pattern:"
+#: ../gui/wxpython/iscatt/dialogs.py:105
+msgid "Bands of scatter plots to be added (x y):"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:795
-#: ../gui/wxpython/gui_core/dialogs.py:863
-#: ../gui/wxpython/gui_core/dialogs.py:1518
-msgid "List of maps:"
+#: ../gui/wxpython/iscatt/dialogs.py:155
+msgid "No scatter plots selected."
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:811
-msgid "Select map layers and add them to the list."
+#: ../gui/wxpython/iscatt/dialogs.py:203
+msgid "Select both x and y bands."
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:816
-msgid "Remove selected layer(s) from list."
+#: ../gui/wxpython/iscatt/dialogs.py:207
+msgid "Selected bands must be different."
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:873
-msgid "Check maps from group to be included into subgroup."
+#: ../gui/wxpython/iscatt/dialogs.py:214
+msgid "Scatter plot with same bands combination (regardless x y order) has been already added into the list."
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1037
-msgid "Add selected map layers into group"
+#: ../gui/wxpython/iscatt/dialogs.py:323
+#, python-format
+msgid "Raster map <%s> already exists. Do you want to overwrite it?"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1174
+#: ../gui/wxpython/iscatt/dialogs.py:326
#, python-format
-msgid "Group <%s> was changed, do you want to apply changes?"
+msgid "Raster <%s> exists"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1177
-#: ../gui/wxpython/gui_core/dialogs.py:1193
-msgid "Unapplied changes"
+#: ../gui/wxpython/iscatt/dialogs.py:352
+msgid "Show confidence ellipses"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1190
-#, python-format
-msgid "Subgroup <%s> was changed, do you want to apply changes?"
+#: ../gui/wxpython/iscatt/dialogs.py:359
+msgid "Selection polygon color:"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1247
-msgid "No raster maps selected."
+#: ../gui/wxpython/iscatt/dialogs.py:360
+msgid "Color of selection polygon vertex:"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1276
-#, python-format
-msgid "No changes to apply in group <%s>."
+#: ../gui/wxpython/iscatt/dialogs.py:361
+msgid "Selected area color:"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1279
-#, python-format
-msgid "Group <%s> was successfully created."
+#: ../gui/wxpython/iscatt/dialogs.py:373
+msgid "Selected area opacity:"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1281
-#, python-format
-msgid "Group <%s> was successfully changed."
+#: ../gui/wxpython/iscatt/dialogs.py:412
+msgid "Selection style:"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1284
-#, python-format
-msgid "Creating of new group <%s> failed."
+#: ../gui/wxpython/iscatt/dialogs.py:439
+msgid "Ellipses settings:"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1286
-#, python-format
-msgid "Changing of group <%s> failed."
+#: ../gui/wxpython/iscatt/iscatt_core.py:110
+#: ../gui/wxpython/iscatt/iscatt_core.py:160
+msgid "Select category for editing."
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1324
-msgid "No group selected."
+#: ../gui/wxpython/iscatt/iscatt_core.py:151
+msgid "Computing of scatter plots failed."
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1329
-msgid "No subgroup selected."
+#: ../gui/wxpython/iscatt/iscatt_core.py:298
+msgid "Patching category raster conditions file failed."
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1436
-msgid "Use fully-qualified map names"
+#: ../gui/wxpython/iscatt/iscatt_core.py:321
+#, python-format
+msgid ""
+"v.build failed:\n"
+"%s"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1462
-msgid "Map type:"
+#: ../gui/wxpython/iscatt/iscatt_core.py:339
+#, python-format
+msgid ""
+"v.to.rast failed:\n"
+"%s"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1477
-msgid "Select toggle"
+#: ../gui/wxpython/iscatt/core_c.py:23
+msgid "Loading ctypes libs failed"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1484
-msgid "Mapset:"
+#: ../gui/wxpython/iscatt/plots.py:42
+msgid "The Scatterplot Tool needs the \"matplotlib\" (python-matplotlib) package to be installed. {}"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1577
-msgid "Invert selection"
+#: ../gui/wxpython/iscatt/plots.py:617
+msgid "Zoom to scatter plot extend"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1720
-#, python-format
-msgid "Dynamic series (%s)"
+#: ../gui/wxpython/iscatt/frame.py:166
+msgid "GRASS GIS Interactive Scatter Plot Tool"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1747
-msgid "Set Map Layer Opacity"
+#: ../gui/wxpython/iscatt/frame.py:398
+msgid "scatter plot"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1781
-msgid "opaque"
+#: ../gui/wxpython/iscatt/frame.py:476
+msgid "Maximum limit of categories number was reached."
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1879
-msgid "Set image size"
+#: ../gui/wxpython/iscatt/frame.py:572
+msgid "Rename class"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1894
-msgid "Image size"
+#: ../gui/wxpython/iscatt/frame.py:576
+msgid "Set color"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1941
-msgid "Template:"
+#: ../gui/wxpython/iscatt/frame.py:584
+msgid "Hide"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1981
-msgid "GRASS GIS SQL Query Utility"
+#: ../gui/wxpython/iscatt/frame.py:586
+msgid "Show"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1997
-msgid " SQL statement "
+#: ../gui/wxpython/iscatt/frame.py:601
+msgid "Move to top"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2045
-msgid "Symbols"
+#: ../gui/wxpython/iscatt/frame.py:607
+msgid "Move to bottom"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2080
-msgid "Symbol directory:"
+#: ../gui/wxpython/iscatt/frame.py:615
+msgid "Move category up"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2092
-msgid "Symbol name:"
+#: ../gui/wxpython/iscatt/frame.py:621
+msgid "Move category down"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2326
-#: ../gui/wxpython/gui_core/dialogs.py:2351 ../gui/wxpython/menustrings.py:216
-msgid "Quit GRASS GIS"
+#: ../gui/wxpython/iscatt/frame.py:629
+msgid "Export class raster"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2344
-msgid "Do you want to quit GRASS including shell prompt or just close the GUI?"
+#: ../gui/wxpython/iscatt/frame.py:701
+#, python-format
+msgid "Change opacity of class <%s>"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2348 ../gui/wxpython/menustrings.py:214
-msgid "Close GUI"
+#: ../gui/wxpython/iscatt/frame.py:726
+msgid "Empty name was inserted."
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2422
-msgid "Select font:"
+#: ../gui/wxpython/iscatt/toolbars.py:54
+msgid "Add scatter plot"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2453
-msgid "Character encoding:"
+#: ../gui/wxpython/iscatt/toolbars.py:57
+msgid "Select area with polygon"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2518
-msgid "Example"
+#: ../gui/wxpython/iscatt/toolbars.py:60
+msgid "Pan mode for scatter plots"
msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:36
-msgid "Display map"
+#: ../gui/wxpython/iscatt/toolbars.py:63
+msgid "Zoom mode for scatter plots (left mouse button, wheel)"
msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:37
-msgid "Re-render modified map layers only"
+#: ../gui/wxpython/iscatt/toolbars.py:66
+msgid "Zoom to scatter plot data extend mode (click on scatter plot for zooming to extend)"
msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:39
-msgid "Render map"
+#: ../gui/wxpython/iscatt/toolbars.py:69
+msgid "Show/hide class manager"
msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:40
-msgid "Force re-rendering all map layers"
+#: ../gui/wxpython/iscatt/toolbars.py:175
+#: ../gui/wxpython/iscatt/toolbars.py:176
+msgid "Include selected area to class"
msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:42
-msgid "Erase display"
+#: ../gui/wxpython/iscatt/toolbars.py:178
+#: ../gui/wxpython/iscatt/toolbars.py:179
+msgid "Exclude selected area from class"
msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:43
-msgid "Erase display canvas with given background color"
+#: ../gui/wxpython/iscatt/toolbars.py:181
+msgid "Add new vertex"
msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:45
-msgid "Pointer"
+#: ../gui/wxpython/iscatt/toolbars.py:182
+msgid "Add new vertex to polygon boundary scatter plot"
msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:47
-msgid "Zoom in"
+#: ../gui/wxpython/iscatt/toolbars.py:184
+msgid "Create selection polygon"
msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:48
-msgid "Drag or click mouse to zoom"
+#: ../gui/wxpython/iscatt/toolbars.py:185
+msgid "Add new vertex between last and first points of the boundary"
msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:50
-msgid "Zoom out"
+#: ../gui/wxpython/iscatt/toolbars.py:187
+msgid "Move vertex"
msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:51
-msgid "Drag or click mouse to unzoom"
+#: ../gui/wxpython/iscatt/toolbars.py:188
+msgid "Move boundary vertex"
msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:53
-msgid "Return to previous zoom"
+#: ../gui/wxpython/iscatt/toolbars.py:190
+msgid "Remove vertex"
msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:55
-msgid "Various zoom options"
+#: ../gui/wxpython/iscatt/toolbars.py:191
+msgid "Remove boundary vertex"
msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:56
-msgid "Zoom to default or saved region, save to named region, ..."
+#: ../gui/wxpython/iscatt/toolbars.py:193
+msgid "Remove polygon (click on scatter plot for removing it's polygon)"
msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:58
-msgid "Zoom to selected map layer(s)"
+#: ../gui/wxpython/iscatt/toolbars.py:271
+msgid "Add class"
msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:60
-msgid "Zoom to computational region extent"
+#: ../gui/wxpython/iscatt/toolbars.py:273
+msgid "Remove selected class"
msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:62
-msgid "Pan"
+#: ../gui/wxpython/iscatt/controllers.py:204
+msgid "No data set."
msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:63
-msgid "Drag with mouse to pan"
+#: ../gui/wxpython/iscatt/controllers.py:222
+#, python-format
+msgid ""
+"Interactive Scatter Plot Tool can not be used.\n"
+"Number of cells (rows*cols) <%d> in current regionis higher than maximum limit <%d>.\n"
+"\n"
+"You can reduce number of cells in current region using <g.region> command."
msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:65
-msgid "Save display to file"
+#: ../gui/wxpython/iscatt/controllers.py:231
+#, python-format
+msgid ""
+"Number of cells (rows*cols) <%d> in current region is higher than recommended threshold <%d>.\n"
+"It is strongly advised to reduce number of cells in current region below recommend threshold.\n"
+" It can be done by <g.region> command.\n"
+"\n"
+"Do you want to continue using Interactive Scatter Plot Tool with this region?"
msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:69
-#: ../gui/wxpython/gui_core/forms.py:1300
-#: ../gui/wxpython/gui_core/forms.py:2669
-msgid "Select font"
+#: ../gui/wxpython/iscatt/controllers.py:288
+msgid "Scatter plot with same band combination (regardless x y order) is already displayed."
msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:79
-msgid "Add map elements"
+#: ../gui/wxpython/iscatt/controllers.py:301
+#, python-format
+msgid "Band <%s> is not CELL (integer) type.\n"
msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:80
-msgid "Overlay elements like scale and legend onto map"
+#: ../gui/wxpython/iscatt/controllers.py:304
+msgid "Scatter plot cannot be added.\n"
msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:82
-msgid "Create histogram with d.histogram"
+#: ../gui/wxpython/iscatt/controllers.py:310
+#, python-format
+msgid ""
+"Scatter plot cannot be added.\n"
+"Multiple of bands ranges <%s:%d * %s:%d = %d> is higher than maximum limit <%d>.\n"
msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:259
-msgid "Select graphics tool"
+#: ../gui/wxpython/iscatt/controllers.py:320
+#, python-format
+msgid ""
+"Multiple of bands ranges <%s:%d * %s:%d = %d> is higher than recommended limit <%d>.\n"
+"It is strongly advised to reduce range extend of bands(e. g. using r.rescale) below recommended threshold.\n"
+"\n"
+"Do you really want to add this scatter plot?"
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:61
+#: ../gui/wxpython/iscatt/controllers.py:409
+msgid ""
+"In order to select arrea in scatter plot, you have to select class first.\n"
+"\n"
+"There is no class yet, do you want to create one?"
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:444
#, python-format
msgid ""
-"Unable to import pyGRASS: %s\n"
-"Some functionality will be not accessible"
+"Error occurred during computation of scatter plot category:\n"
+"%s"
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:490
-msgid "Not selectable element"
+#: ../gui/wxpython/iscatt/controllers.py:764
+#, python-format
+msgid "Export scatter plot raster of class <%s>"
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:539
-msgid "Type: "
+#: ../gui/wxpython/iscatt/controllers.py:782
+#, python-format
+msgid "Scatter plot raster of class <%s> exported to raster map <%s>."
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:557
+#: ../gui/wxpython/iscatt/controllers.py:786
#, python-format
-msgid "GSelect: invalid item: %s"
+msgid ""
+"Export of scatter plot raster of class <%s> to map <%s> failed.\n"
+"%s"
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1395
-msgid "Output settings"
+#: ../gui/wxpython/mapswipe/dialogs.py:44
+#: ../gui/wxpython/mapswipe/toolbars.py:33
+msgid "Select raster maps"
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1397
-msgid "Source input"
+#: ../gui/wxpython/mapswipe/dialogs.py:130
+msgid "Name of top/left raster map:"
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1408
-msgid "Native"
+#: ../gui/wxpython/mapswipe/dialogs.py:139
+msgid "Name of bottom/right raster map:"
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1414
-msgid "File"
+#: ../gui/wxpython/mapswipe/dialogs.py:185
+msgid "Switch to advanced mode"
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1418
-#: ../gui/wxpython/gui_core/forms.py:1892
-msgid "Directory"
+#: ../gui/wxpython/mapswipe/dialogs.py:186
+msgid "Cancel"
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1426
-msgid "Protocol"
+#: ../gui/wxpython/mapswipe/dialogs.py:192
+msgid "Switch to simple mode"
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1437
-msgid "Output type"
+#: ../gui/wxpython/mapswipe/dialogs.py:217
+msgid "Name of the first map is missing."
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1439
-msgid "Source type"
+#: ../gui/wxpython/mapswipe/dialogs.py:220
+msgid "Name of the second map is missing."
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1461
-msgid "All files"
+#: ../gui/wxpython/mapswipe/dialogs.py:253
+msgid "Map Swipe settings"
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1477
-msgid "ZIP files"
+#: ../gui/wxpython/mapswipe/dialogs.py:269
+#: ../gui/wxpython/mapswipe/toolbars.py:118
+msgid "Mirror mode"
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1478
-msgid "GZIP files"
+#: ../gui/wxpython/mapswipe/dialogs.py:272
+msgid "Mirrored cursor"
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1479
-msgid "TAR files"
+#: ../gui/wxpython/mapswipe/dialogs.py:301
+msgid "Shape:"
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1481
-msgid "TARGZ files"
+#: ../gui/wxpython/mapswipe/frame.py:44
+msgid "GRASS GIS Map Swipe"
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1489
-msgid "File:"
+#: ../gui/wxpython/mapswipe/frame.py:417
+#, python-format
+msgid "Map <%s> not found. "
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1490
-msgid "Choose file to import"
+#: ../gui/wxpython/mapswipe/toolbars.py:29
+#: ../gui/wxpython/modules/vclean.py:518
+msgid "Tools"
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1506
-#: ../gui/wxpython/gui_core/gselect.py:1589
-msgid "Choose input directory"
+#: ../gui/wxpython/mapswipe/toolbars.py:31
+msgid "Quit Map Swipe"
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1523
-msgid "Extension:"
+#: ../gui/wxpython/mapswipe/toolbars.py:117
+msgid "Swipe mode"
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1553
-msgid "Choose file"
+#: ../gui/wxpython/mapswipe/toolbars.py:130
+msgid "Choose view mode"
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1574
-#: ../gui/wxpython/gui_core/gselect.py:2335
-msgid "Feature type:"
+#: ../gui/wxpython/mapswipe/toolbars.py:154
+msgid "Switch orientation"
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1576
-msgid "simple features"
+#: ../gui/wxpython/mapswipe/toolbars.py:157
+msgid "Switch maps"
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1577
-msgid "topological"
+#: ../gui/wxpython/modules/mcalc_builder.py:55
+msgid "GRASS GIS Raster Map Calculator"
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1688
-#: ../gui/wxpython/gui_core/gselect.py:1719
-#: ../gui/wxpython/gui_core/gselect.py:1770
-#: ../gui/wxpython/gui_core/gselect.py:1808
-msgid "Creation options:"
+#: ../gui/wxpython/modules/mcalc_builder.py:58
+msgid "GRASS GIS 3D Raster Map Calculator"
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1702
-#: ../gui/wxpython/gui_core/gselect.py:1741
-#: ../gui/wxpython/gui_core/gselect.py:1793
-msgid "Format:"
+#: ../gui/wxpython/modules/mcalc_builder.py:74
+msgid "mapcalc statement"
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1800
-msgid "Protocol:"
+#: ../gui/wxpython/modules/mcalc_builder.py:132
+msgid "Operators"
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1823
-msgid "No settings available"
+#: ../gui/wxpython/modules/mcalc_builder.py:136
+msgid "Operands"
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:2327
-msgid "LineString"
+#: ../gui/wxpython/modules/mcalc_builder.py:138
+msgid "Expression"
msgstr ""
-msgid "Polygon"
+#: ../gui/wxpython/modules/mcalc_builder.py:153
+msgid "Save expression to file"
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:2546
-msgid "No vector map selected in layer manager. Operation canceled."
+#: ../gui/wxpython/modules/mcalc_builder.py:156
+msgid "Load expression from file"
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:2559
-msgid "Input vector map is not selected"
+#: ../gui/wxpython/modules/mcalc_builder.py:163
+msgid "exponent"
msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:2563
-#, python-format
-msgid "Input vector map <%s> and selected map <%s> in layer manager are different. Operation canceled."
+#: ../gui/wxpython/modules/mcalc_builder.py:165
+msgid "divide"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:544
-msgid "Enter parameters for '"
+#: ../gui/wxpython/modules/mcalc_builder.py:167
+msgid "add"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:560
-msgid "Close this window without executing the command (Ctrl+Q)"
+#: ../gui/wxpython/modules/mcalc_builder.py:170
+msgid "subtract"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:591
-msgid "Run the command (Ctrl+R)"
+#: ../gui/wxpython/modules/mcalc_builder.py:172
+msgid "modulus"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:606 ../gui/wxpython/menustrings.py:173
-#: ../gui/wxpython/menustrings.py:1196
-msgid "Copy"
+#: ../gui/wxpython/modules/mcalc_builder.py:175
+msgid "multiply"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:619
-msgid "Show manual page of the command (Ctrl+H)"
+#: ../gui/wxpython/modules/mcalc_builder.py:183
+msgid "left shift"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:658
-msgid "Add created map(s) into layer tree"
+#: ../gui/wxpython/modules/mcalc_builder.py:186
+msgid "right shift"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:688
-msgid "Close dialog when command is successfully finished. Change this settings in Preferences dialog ('Command' tab)."
+#: ../gui/wxpython/modules/mcalc_builder.py:189
+msgid "right shift (unsigned)"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:864
-#, python-format
-msgid "'%s' copied to clipboard"
+#: ../gui/wxpython/modules/mcalc_builder.py:191
+msgid "greater than"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:944 ../gui/wxpython/gui_core/forms.py:958
-msgid "Required"
+#: ../gui/wxpython/modules/mcalc_builder.py:194
+msgid "greater than or equal to"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:947 ../gui/wxpython/gui_core/forms.py:959
-msgid "Optional"
+#: ../gui/wxpython/modules/mcalc_builder.py:196
+msgid "less than"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1042
-#: ../gui/wxpython/gui_core/forms.py:2041
-msgid "Parameterized in model"
+#: ../gui/wxpython/modules/mcalc_builder.py:199
+msgid "less than or equal to"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1111
-msgid "This option is required"
+#: ../gui/wxpython/modules/mcalc_builder.py:201
+msgid "equal to"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1132
-msgid "[multiple]"
+#: ../gui/wxpython/modules/mcalc_builder.py:204
+msgid "not equal to"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1190
-msgid "valid range"
+#: ../gui/wxpython/modules/mcalc_builder.py:208
+msgid "one's complement"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1531
-msgid "Show graphical representation of temporal extent of dataset(s) ."
+#: ../gui/wxpython/modules/mcalc_builder.py:210
+msgid "NOT"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1797
-#: ../gui/wxpython/gui_core/forms.py:1889
-#, python-format
-msgid "Choose %s"
+#: ../gui/wxpython/modules/mcalc_builder.py:213
+msgid "bitwise AND"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1842
-msgid "Load and edit content of a file"
+#: ../gui/wxpython/modules/mcalc_builder.py:216
+msgid "bitwise OR"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1845
-msgid "&Save as"
+#: ../gui/wxpython/modules/mcalc_builder.py:219
+msgid "logical AND"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1847
-msgid "Save content to a file for further use"
+#: ../gui/wxpython/modules/mcalc_builder.py:222
+msgid "logical AND (ignores NULLs)"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1852
-msgid "or enter values directly:"
+#: ../gui/wxpython/modules/mcalc_builder.py:224
+msgid "logical OR"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1854
-msgid "Enter file content directly instead of specifying a file. Temporary file will be automatically created."
+#: ../gui/wxpython/modules/mcalc_builder.py:227
+msgid "logical OR (ignores NULLs)"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:2241
-msgid "Manual"
+#: ../gui/wxpython/modules/mcalc_builder.py:232
+msgid "conditional"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:2285
-msgid "Nothing to load."
+#: ../gui/wxpython/modules/mcalc_builder.py:247
+msgid "Name for new 3D raster map to create"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:2293
-#, python-format
-msgid ""
-"Unable to load file.\n"
-"\n"
-"Reason: %s"
+#: ../gui/wxpython/modules/mcalc_builder.py:249
+msgid "Name for new raster map to create"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:2323
-msgid "Save input as..."
+#: ../gui/wxpython/modules/mcalc_builder.py:254
+msgid "Insert existing 3D raster map"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:2656
-msgid "No dataset given."
+#: ../gui/wxpython/modules/mcalc_builder.py:256
+msgid "Insert existing raster map"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:2825
-#: ../gui/wxpython/gui_core/forms.py:2842
-#, python-format
-msgid "Unable to parse command '%s'"
+#: ../gui/wxpython/modules/mcalc_builder.py:261
+msgid "Insert mapcalc function"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:2849
-#, python-format
-msgid "%(cmd)s: parameter '%(key)s' not available"
+#: ../gui/wxpython/modules/mcalc_builder.py:278
+msgid "Generate random seed for rand()"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:2931
-msgid "Try to set up GRASS_ADDON_PATH or GRASS_ADDON_BASE variable."
+#: ../gui/wxpython/modules/mcalc_builder.py:280
+msgid "Seed:"
msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:378
-msgid "Open file"
+#: ../gui/wxpython/modules/mcalc_builder.py:284
+msgid "Integer seed for rand() function"
msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:449
-msgid "Replace the content by the template?"
+#: ../gui/wxpython/modules/mcalc_builder.py:291
+msgid "Add created raster map into layer tree"
msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:451
-msgid "Replace the content by the example?"
+#: ../gui/wxpython/modules/mcalc_builder.py:628
+msgid "You must enter the name of a new raster map to create."
msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:453
-msgid "Replace the current content by the file content?"
+#: ../gui/wxpython/modules/mcalc_builder.py:639
+msgid "You must enter an expression to create a new raster map."
msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:459
-msgid "Replace content"
+#: ../gui/wxpython/modules/mcalc_builder.py:699
+msgid "Choose a file name to save the expression"
msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:471
-msgid "Set parameters for the script"
+#: ../gui/wxpython/modules/mcalc_builder.py:700
+#: ../gui/wxpython/modules/mcalc_builder.py:722
+msgid "Expression file (*)|*"
msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:472
-msgid "Specify command line parameters for the script separated by spaces:"
+#: ../gui/wxpython/modules/mcalc_builder.py:721
+msgid "Choose a file name to load the expression"
msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:522
-msgid "Open (Ctrl+O)"
+#: ../gui/wxpython/modules/mcalc_builder.py:757
+#, python-brace-format
+msgid "'{cmd}' copied to clipboard"
msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:524
-msgid "Save (Ctrl+S)"
+#: ../gui/wxpython/modules/vclean.py:34 ../gui/wxpython/modules/vclean.py:120
+msgid "Set up vector cleaning tools"
msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:526
-msgid "Run (Ctrl+R)"
+#: ../gui/wxpython/modules/vclean.py:75
+msgid "break lines/boundaries"
msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:529
-msgid "Activate overwrite"
+#: ../gui/wxpython/modules/vclean.py:76
+msgid "remove duplicates"
msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:531
-msgid "Deactive overwrite"
+#: ../gui/wxpython/modules/vclean.py:77
+msgid "remove dangles"
msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:582
-msgid "GRASS GIS Simple Python Editor"
+#: ../gui/wxpython/modules/vclean.py:78
+msgid "change boundary dangles to lines"
msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:101
-msgid " (...)"
+#: ../gui/wxpython/modules/vclean.py:79
+msgid "remove bridges"
msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:839
-#, python-format
-msgid "Name <%(name)s> is not a valid name for GRASS map. Please use only ASCII characters excluding %(chars)s and space."
+#: ../gui/wxpython/modules/vclean.py:80
+msgid "change bridges to lines"
msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1067
-msgid "Fulltext search"
+#: ../gui/wxpython/modules/vclean.py:81
+msgid "snap lines/boundaries"
msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1069
-msgid "Type to search in all modules. Press Enter for next match."
+#: ../gui/wxpython/modules/vclean.py:82
+msgid "remove duplicate area centroids"
msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1136
-msgid "Searching, please type more characters."
+#: ../gui/wxpython/modules/vclean.py:83
+msgid "break polygons"
msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1145
-#, python-format
-msgid "%d modules match"
+#: ../gui/wxpython/modules/vclean.py:84
+msgid "prune lines/boundaries"
msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1215
-msgid "Profiles"
+#: ../gui/wxpython/modules/vclean.py:85
+msgid "remove small areas"
msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1221
-msgid "Save current settings"
+#: ../gui/wxpython/modules/vclean.py:86
+msgid "remove lines/boundaries of zero length"
msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1225
-msgid "Delete currently selected settings"
+#: ../gui/wxpython/modules/vclean.py:87
+msgid "remove small angles at nodes"
msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1248
-msgid "Load:"
+#: ../gui/wxpython/modules/vclean.py:122
+msgid "Choose cleaning tools and set thresholds"
msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1266
-#, python-format
-msgid "Settings <%s> not found"
+#: ../gui/wxpython/modules/vclean.py:126
+msgid "Select input vector map:"
msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1280
-#: ../gui/wxpython/gui_core/widgets.py:1300
-msgid "Save settings"
+#: ../gui/wxpython/modules/vclean.py:132
+msgid " Feature type: "
msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1285
-msgid "Name not given, settings is not saved."
+#: ../gui/wxpython/modules/vclean.py:136
+msgid "Select output vector map:"
msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1297
-#, python-format
-msgid "Settings <%s> already exists. Do you want to overwrite the settings?"
+#: ../gui/wxpython/modules/vclean.py:177
+msgid "Copy the current command string to the clipboard (Ctrl+C)"
msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1348
-msgid "No settings is defined. Operation canceled."
+#: ../gui/wxpython/modules/vclean.py:223
+msgid "line"
msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1386
-msgid "Unable to save settings"
+#: ../gui/wxpython/modules/vclean.py:224
+msgid "boundary"
msgstr ""
-#: ../gui/wxpython/mapwin/base.py:204
-#, python-format
-msgid ""
-"Error occurred during calling of handler: %s \n"
-"Handler was unregistered."
+#: ../gui/wxpython/modules/vclean.py:225
+msgid "centroid"
msgstr ""
-#: ../gui/wxpython/mapwin/base.py:285
-#, python-format
-msgid ""
-"Error occurred during unregistration of handler: %s \n"
-" Handler was unregistered."
+#: ../gui/wxpython/modules/vclean.py:227
+msgid "face"
msgstr ""
-#: ../gui/wxpython/mapwin/base.py:314
+#: ../gui/wxpython/modules/vclean.py:401
#, python-format
-msgid "Handler: %s was not registered"
+msgid "%s. cleaning tool removed, will be ignored"
msgstr ""
-#: ../gui/wxpython/mapwin/base.py:318
-#, python-format
-msgid ""
-" Handler was unregistered"
+#: ../gui/wxpython/modules/vclean.py:404
+msgid "Please select a cleaning tool to remove"
msgstr ""
-#: ../gui/wxpython/mapwin/decorations.py:178
-#: ../gui/wxpython/mapwin/decorations.py:265
-msgid ""
-"Please install Python Imaging Library (PIL)\n"
-"for better control of legend and other decorations."
+#: ../gui/wxpython/modules/vclean.py:428
+#, python-format
+msgid "%s. cleaning tool moved up"
msgstr ""
-#: ../gui/wxpython/mapwin/decorations.py:197
-msgid "Remove text"
+#: ../gui/wxpython/modules/vclean.py:430
+msgid "1. cleaning tool can not be moved up "
msgstr ""
-#: ../gui/wxpython/mapwin/decorations.py:220
-msgid "Remove scale bar"
+#: ../gui/wxpython/modules/vclean.py:432
+msgid "Please select a cleaning tool to move up"
msgstr ""
-#: ../gui/wxpython/mapwin/decorations.py:232
-msgid "Remove north arrow"
+#: ../gui/wxpython/modules/vclean.py:460
+#, python-format
+msgid "%s. cleaning tool moved down"
msgstr ""
-#: ../gui/wxpython/mapwin/decorations.py:244
-msgid "Remove vector legend"
+#: ../gui/wxpython/modules/vclean.py:462
+msgid "Last cleaning tool can not be moved down "
msgstr ""
-#: ../gui/wxpython/mapwin/decorations.py:256
-msgid "Remove legend"
+#: ../gui/wxpython/modules/vclean.py:464
+msgid "Please select a cleaning tool to move down"
msgstr ""
-#: ../gui/wxpython/mapwin/graphics.py:277
-#: ../gui/wxpython/mapwin/graphics.py:453
+#: ../gui/wxpython/modules/vclean.py:478
#, python-format
-msgid "Property does not exist: %s"
+msgid "cleaning tool: '%s'"
msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:252
-msgid "Copy coordinates to clipboard"
+#: ../gui/wxpython/modules/vclean.py:488
+#, python-format
+msgid "Threshold for %(num)s. tool '%(tool)s': %(thresh)s"
msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:260
-msgid "Hide toolbars"
+#: ../gui/wxpython/modules/vclean.py:516
+msgid "Name of input vector map"
msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:262
-msgid "Show toolbars"
+#: ../gui/wxpython/modules/vclean.py:517
+msgid "Name for output vector map"
msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:269
-msgid "Hide statusbar"
+#: ../gui/wxpython/modules/vclean.py:519
+msgid "Threshold"
msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:270
-msgid "Show statusbar"
+#: ../gui/wxpython/modules/vclean.py:521
+#, python-format
+msgid "'%s' not defined"
msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:287
-msgid "Resize legend"
+#: ../gui/wxpython/modules/vclean.py:523
+#, python-format
+msgid ""
+"Some parameters not defined. Operation canceled.\n"
+"\n"
+"%s"
msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:985
-msgid "Unable to draw registered graphics. The graphics was unregistered."
+#: ../gui/wxpython/modules/vclean.py:528
+msgid "Executing selected cleaning operations..."
msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:2074
-msgid "Zoom to saved region extents"
+#: ../gui/wxpython/modules/vclean.py:585
+msgid "Vector cleaning command copied to clipboard"
msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:2076
-msgid "Set compulational region from named region"
+#: ../gui/wxpython/modules/histogram.py:292
+msgid "GRASS GIS Histogramming Tool (d.histogram)"
msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:2089
-#, python-format
-msgid "Region <%s> not found. Operation canceled."
+#: ../gui/wxpython/modules/histogram.py:424
+msgid "Select font for histogram text"
msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:2119
-msgid "Save display extents to region file"
+#: ../gui/wxpython/modules/colorrules.py:79
+msgid "Check all"
msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:2121
-msgid "Save computational region to region file"
+#: ../gui/wxpython/modules/colorrules.py:82
+msgid "Clear all"
msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:2133
-#, python-format
-msgid "Region file <%s> already exists. Do you want to overwrite it?"
+#: ../gui/wxpython/modules/colorrules.py:140
+msgid "Enter vector attribute values"
msgstr ""
-#: ../gui/wxpython/mapwin/analysis.py:228
-#: ../gui/wxpython/mapwin/analysis.py:350
-msgid "Measuring finished"
+#: ../gui/wxpython/modules/colorrules.py:311
+msgid "Bad color format. Use color format '0:0:0'"
msgstr ""
-#: ../gui/wxpython/mapwin/analysis.py:246
-#: ../gui/wxpython/mapwin/analysis.py:362
-#, python-format
-msgid "Click and drag with left mouse button to measure.%sDouble click with left button to clear."
+#: ../gui/wxpython/modules/colorrules.py:415
+msgid "Select vector map:"
msgstr ""
-#: ../gui/wxpython/mapwin/analysis.py:252
-msgid "Measuring distance"
+#: ../gui/wxpython/modules/colorrules.py:435
+msgid "Import or export color table:"
msgstr ""
-#: ../gui/wxpython/mapwin/analysis.py:255
-msgid "Measuring distance:"
+#: ../gui/wxpython/modules/colorrules.py:440
+msgid "Choose file to load color table"
msgstr ""
-#: ../gui/wxpython/mapwin/analysis.py:263
-#, python-format
-msgid ""
-"Geodesic distance calculation is not available.\n"
-"Reason: %s"
+#: ../gui/wxpython/modules/colorrules.py:441
+msgid "Load"
msgstr ""
-#: ../gui/wxpython/mapwin/analysis.py:301
-#: ../gui/wxpython/mapwin/analysis.py:308
-msgid "segment"
+#: ../gui/wxpython/modules/colorrules.py:443
+msgid "Type filename or click to choose file and load color table"
msgstr ""
-#: ../gui/wxpython/mapwin/analysis.py:302
-#: ../gui/wxpython/mapwin/analysis.py:309
-msgid "total distance"
+#: ../gui/wxpython/modules/colorrules.py:449
+msgid "Choose file to save color table"
msgstr ""
-#: ../gui/wxpython/mapwin/analysis.py:303
-msgid "bearing"
+#: ../gui/wxpython/modules/colorrules.py:451
+msgid "Type filename or click to choose file and save color table"
msgstr ""
-#: ../gui/wxpython/mapwin/analysis.py:304
-msgid "degrees (clockwise from grid-north)"
+#: ../gui/wxpython/modules/colorrules.py:453 ../gui/wxpython/menustrings.py:10
+#: ../gui/wxpython/menustrings.py:1939
+msgid "Save"
msgstr ""
-#: ../gui/wxpython/mapwin/analysis.py:366
-msgid "Measuring area:"
+#: ../gui/wxpython/modules/colorrules.py:465
+msgid "&Set"
msgstr ""
-#: ../gui/wxpython/mapwin/analysis.py:386
-msgid "Units not recognized, measurement failed."
+#: ../gui/wxpython/modules/colorrules.py:473
+msgid "Load color table:"
msgstr ""
-#: ../gui/wxpython/mapwin/analysis.py:391
-#: ../gui/wxpython/mapwin/analysis.py:393
-msgid "Area: {area} {unit}\n"
+#: ../gui/wxpython/modules/colorrules.py:479
+msgid "Load color table from file:"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:106
-msgid "Define GRASS Database and Location Name"
+#: ../gui/wxpython/modules/colorrules.py:487
+msgid "Save color table to file:"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:126
-#: ../gui/wxpython/location_wizard/dialogs.py:38
-msgid "Set default region extent and resolution"
+#: ../gui/wxpython/modules/colorrules.py:519
+msgid "Reload default table"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:127
-msgid "This option allows setting default computation region immediately after new location is created. Default computation region can be defined later using g.region based on imported data."
+#: ../gui/wxpython/modules/colorrules.py:587
+msgid "Show preview of map (current Map Display extent is used)."
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:133
-msgid "Create user mapset"
+#: ../gui/wxpython/modules/colorrules.py:619
+#: ../gui/wxpython/modules/colorrules.py:1889
+msgid "No valid color rules given."
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:134
-msgid "This option allows creating user mapset immediately after new location is created. Note that GRASS always creates PERMANENT mapset."
+#: ../gui/wxpython/modules/colorrules.py:676
+#, python-format
+msgid "File <%s> already already exists. Do you want to overwrite it?"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:140
-msgid "GIS Data Directory:"
+#: ../gui/wxpython/modules/colorrules.py:723
+msgid "Invalid color table format"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:159
-msgid "Project Location"
+#: ../gui/wxpython/modules/colorrules.py:804
+#, python-format
+msgid "Invalid rule value '%s'. Unable to apply color table."
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:160
-msgid "Name of location directory in GIS Data Directory"
+#: ../gui/wxpython/modules/colorrules.py:890
+msgid "Create new color table for raster map"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:174
-msgid "Location Title"
+#: ../gui/wxpython/modules/colorrules.py:968
+msgid "Enter raster category values or percents"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:176
-msgid "Optional location title, you can leave this field blank."
+#: ../gui/wxpython/modules/colorrules.py:974
+msgid "fp range"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:207
+#: ../gui/wxpython/modules/colorrules.py:976
#, python-format
-msgid "Name <%(name)s> is not a valid name for location. Please use only ASCII characters excluding %(chars)s and space."
+msgid "Enter raster category values or percents (%(range)s = %(min)d-%(max)d)"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:215
-msgid "Invalid location name"
+#: ../gui/wxpython/modules/colorrules.py:1083
+msgid "Create new color rules for vector map"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:230
-msgid "Choose GRASS data directory:"
+#: ../gui/wxpython/modules/colorrules.py:1096
+#: ../gui/wxpython/modules/colorrules.py:1673
+msgid "Enter vector attribute values or percents:"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:244
-#: ../gui/wxpython/location_wizard/wizard.py:2510
-msgid "Location already exists in GRASS Database."
+#: ../gui/wxpython/modules/colorrules.py:1098
+#: ../gui/wxpython/modules/colorrules.py:1675
+msgid "Enter vector attribute values:"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:248
-msgid "Unable to create location"
+#: ../gui/wxpython/modules/colorrules.py:1109
+msgid "Select vector columns"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:262
-msgid "Title of the location is limited only to one line and 256 characters. The rest of the text will be ignored."
+#: ../gui/wxpython/modules/colorrules.py:1111
+msgid "Layer:"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:272
-msgid "Choose method for creating a new location"
+#: ../gui/wxpython/modules/colorrules.py:1113
+msgid "Attribute column:"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:279
-msgid "Select EPSG code of spatial reference system"
+#: ../gui/wxpython/modules/colorrules.py:1116
+msgid "Load color from column:"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:285
-msgid "Read projection and datum terms from a georeferenced data file"
+msgid "Save color to column:"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:289
-msgid "Read projection and datum terms from a Well Known Text (WKT) .prj file"
+#: ../gui/wxpython/modules/colorrules.py:1118
+msgid "Load size from column:"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:292
-msgid "Select coordinate system parameters from a list"
+msgid "Save size to column:"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:295
-msgid "Specify projection and datum terms using custom PROJ.4 parameters"
+#: ../gui/wxpython/modules/colorrules.py:1120
+msgid "Load width from column:"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:298
-msgid "Create a generic Cartesian coordinate system (XY)"
+msgid "Save width to column:"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:302
-msgid "Simple methods:"
+#: ../gui/wxpython/modules/colorrules.py:1125
+msgid "Use color column instead of color table:"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:314
-msgid "Advanced methods:"
+#: ../gui/wxpython/modules/colorrules.py:1141
+msgid "Add GRASSRGB column to current attribute table."
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:417
-msgid "Choose projection"
+#: ../gui/wxpython/modules/colorrules.py:1200
+#: ../gui/wxpython/modules/colorrules.py:1256
+msgid "Import or export color table"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:433
-#: ../gui/wxpython/location_wizard/wizard.py:960
-#: ../gui/wxpython/location_wizard/wizard.py:1141
-#: ../gui/wxpython/location_wizard/wizard.py:1471
-#: ../gui/wxpython/location_wizard/wizard.py:1699
-msgid "Code"
+#: ../gui/wxpython/modules/colorrules.py:1270
+#, python-format
+msgid "Database connection for vector map <%s> is not defined in DB file. Do you want to create and connect new attribute table?"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:437
-msgid "Projection code:"
+#: ../gui/wxpython/modules/colorrules.py:1274
+msgid "No database connection defined"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:445
-#: ../gui/wxpython/location_wizard/wizard.py:973
-#: ../gui/wxpython/location_wizard/wizard.py:1158
-msgid "Search in description:"
+#: ../gui/wxpython/modules/colorrules.py:1347
+#, python-format
+msgid "Selected map <%(map)s> is not in current mapset <%(mapset)s>. Attribute table cannot be edited."
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:624
+#: ../gui/wxpython/modules/colorrules.py:1518
#, python-format
-msgid "Unable to read list: %s"
+msgid "%s column already exists."
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:729
-msgid "Choose projection parameters"
+#: ../gui/wxpython/modules/colorrules.py:1552
+msgid "Please wait, loading data from attribute table..."
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:743
-msgid "Select datum or ellipsoid (next page)"
+#: ../gui/wxpython/modules/colorrules.py:1613
+#, python-format
+msgid "Number of loaded records reached %d, displaying all the records will be time-consuming and may lead to computer freezing, do you still want to continue?"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:751
-msgid "Datum with associated ellipsoid"
+#: ../gui/wxpython/modules/colorrules.py:1617
+msgid "Too many records"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:754
-msgid "Ellipsoid only"
+#: ../gui/wxpython/modules/colorrules.py:1664
+#, python-format
+msgid "Enter vector attribute values or percents %s:"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:812
+#: ../gui/wxpython/modules/colorrules.py:1668
#, python-format
-msgid "You must enter a value for %s"
+msgid "Enter vector attribute values %s:"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:831
-#: ../gui/wxpython/location_wizard/wizard.py:852
-#, python-format
-msgid " Enter parameters for %s projection "
+#: ../gui/wxpython/modules/colorrules.py:1821
+msgid "Please select column to save values to."
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:937
-msgid "Specify geodetic datum"
+#: ../gui/wxpython/modules/colorrules.py:1857
+msgid "No color column defined. Operation canceled."
msgstr ""
-msgid "Ellipsoid"
+#: ../gui/wxpython/modules/colorrules.py:1874
+msgid "Thematic mapping for vector map in 3D view"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:964
-msgid "Datum code:"
+#: ../gui/wxpython/modules/vkrige.py:33
+msgid "No GRASS-python library found."
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1112
-msgid "Specify ellipsoid"
+#: ../gui/wxpython/modules/vkrige.py:72
+msgid "Input Data"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1129
-msgid "Earth based"
+#: ../gui/wxpython/modules/vkrige.py:82
+msgid "Point dataset:"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1132
-msgid "Planetary bodies"
+#: ../gui/wxpython/modules/vkrige.py:98
+#, fuzzy
+msgid "Numeric column:"
+msgstr "Kolom kunci"
+#: ../gui/wxpython/modules/vkrige.py:116
+#, fuzzy
+msgid "Kriging"
+msgstr "Tiling "
+#: ../gui/wxpython/modules/vkrige.py:161
+#, fuzzy
+msgid "Name for the output raster map:"
+msgstr "Nama untuk peta vektor baru:"
+#: ../gui/wxpython/modules/vkrige.py:169
+#, fuzzy
+msgid "Export variance map as well: "
+msgstr "Ekspor peta raster "
+#: ../gui/wxpython/modules/vkrige.py:404
+msgid "Kriging Module"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1146
-msgid "Ellipsoid code:"
+#: ../gui/wxpython/modules/vkrige.py:413
+#, fuzzy
+msgid "Ready."
+msgstr "Muat-ulang"
+#: ../gui/wxpython/modules/vkrige.py:443
+msgid "Variogram fitting"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1288
-#: ../gui/wxpython/location_wizard/wizard.py:1348
-msgid "Select georeferenced file"
+#: ../gui/wxpython/modules/vkrige.py:463
+msgid "Plot/refresh variogram"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1293
-msgid "Georeferenced file:"
+#: ../gui/wxpython/modules/vkrige.py:488
+#, fuzzy
+msgid ":"
+msgstr "X:"
+#: ../gui/wxpython/modules/vkrige.py:534
+msgid "Kriging techniques"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1364
-#: ../gui/wxpython/location_wizard/wizard.py:1422
-msgid "Select Well Known Text (WKT) .prj file"
+#: ../gui/wxpython/modules/vkrige.py:553
+#, fuzzy
+msgid "Block size:"
+msgstr "Tema ikon:"
+#: ../gui/wxpython/modules/vkrige.py:607
+msgid "Auto-fit variogram"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1369
-msgid "WKT .prj file:"
+#: ../gui/wxpython/modules/vkrige.py:635
+#, fuzzy
+msgid "Model: "
+msgstr "Mode"
+#: ../gui/wxpython/modules/vkrige.py:758
+msgid "Work in progress! No functionality provided."
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1440
-msgid "Choose EPSG Code"
+#: ../gui/wxpython/modules/extensions.py:41
+msgid "Fetch & install extension from GRASS Addons"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1449
-msgid "Path to the EPSG-codes file:"
+#: ../gui/wxpython/modules/extensions.py:58
+msgid "Repository (leave empty to use the official one)"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1613
-msgid "Choose EPSG codes file"
+#: ../gui/wxpython/modules/extensions.py:61
+msgid "List of extensions - double-click to install"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1664
-msgid "Choose IAU Code"
+#: ../gui/wxpython/modules/extensions.py:85
+msgid "Options"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1673
-msgid "Path to the IAU-codes file:"
+#: ../gui/wxpython/modules/extensions.py:113
+msgid "&Fetch"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1676
-msgid "IAU code:"
+#: ../gui/wxpython/modules/extensions.py:114
+msgid "Fetch list of available modules from GRASS Addons SVN repository"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1858
-msgid "Choose IAU codes file"
+#: ../gui/wxpython/modules/extensions.py:118
+msgid "&Install"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1893
-#, python-brace-format
-msgid "Unable to read IAU codes: {0}"
+#: ../gui/wxpython/modules/extensions.py:120
+msgid "Install selected add-ons GRASS module"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1913
-msgid "Choose method of specifying georeferencing parameters"
+#: ../gui/wxpython/modules/extensions.py:123
+msgid "Show g.extension manual page"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1922
-msgid "Enter PROJ.4 parameters string:"
+#: ../gui/wxpython/modules/extensions.py:187
+msgid "Extension not defined"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1978
-#: ../gui/wxpython/location_wizard/wizard.py:1982
-msgid "Datum transform is required."
+#: ../gui/wxpython/modules/extensions.py:211
+msgid "Fetching list of modules from GRASS-Addons SVN (be patient)..."
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2064
-msgid "GRASS Database:"
+#: ../gui/wxpython/modules/extensions.py:226
+#, python-format
+msgid "%d extensions loaded"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2070
-msgid "Location Name:"
+#: ../gui/wxpython/modules/extensions.py:238
+msgid "Install"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2076
-msgid "Location Title:"
+#: ../gui/wxpython/modules/extensions.py:243
+msgid "Show manual page"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2082
-msgid "Projection:"
+#: ../gui/wxpython/modules/extensions.py:344
+#, python-format
+msgid "Unable to load extensions. %s"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2090
-msgid ""
-"PROJ.4 definition:\n"
-" (non-definitive)"
+#: ../gui/wxpython/modules/extensions.py:390
+msgid "Manage installed GRASS Addons extensions"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2214
-#, python-format
-msgid "Do you want to create GRASS location <%s>?"
+#: ../gui/wxpython/modules/extensions.py:406
+msgid "List of installed extensions"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2216
-msgid "Create new location?"
+#: ../gui/wxpython/modules/extensions.py:414
+msgid "Uninstall"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2268
-msgid "Define new GRASS Location"
+#: ../gui/wxpython/modules/extensions.py:416
+msgid "Uninstall selected Addons extensions"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2367
+#: ../gui/wxpython/modules/extensions.py:420
+msgid "Reinstall"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:422
+msgid "Reinstall selected Addons extensions"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:463
+msgid "No extension selected. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:490
#, python-format
msgid ""
-"Unable to create new location. Location <%(loc)s> not created.\n"
+"List of files to be removed:\n"
+"%(files)s\n"
"\n"
-"Details: %(err)s"
+"Do you want really to remove <%(ext)s> extension?"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2375
-msgid "Location wizard canceled. Location not created."
+#: ../gui/wxpython/modules/extensions.py:494
+msgid "Remove extension"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2508
-msgid "Unable to create new location"
+#: ../gui/wxpython/modules/extensions.py:527
+msgid "Extension"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2529
+#: ../gui/wxpython/modules/import_export.py:45
+msgid "Multiple import"
+msgstr ""
+#: ../gui/wxpython/modules/import_export.py:62
+msgid "List of raster layers"
+msgstr ""
+#: ../gui/wxpython/modules/import_export.py:64
+msgid "List of vector layers"
+msgstr ""
+#: ../gui/wxpython/modules/import_export.py:66
#, python-format
-msgid "Location <%(loc)s> will be created in GIS data directory <%(dir)s>. You will need to change the default GIS data directory in the GRASS startup screen."
+msgid "List of %s layers"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2534
-msgid "New GIS data directory"
+#: ../gui/wxpython/modules/import_export.py:68
+#: ../gui/wxpython/modules/import_export.py:885
+msgid "right click to (un)select all"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2565
-msgid "EPSG code missing."
+#: ../gui/wxpython/modules/import_export.py:73
+msgid "Name for output GRASS map (editable)"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2575
-msgid "IAU code missing."
+#: ../gui/wxpython/modules/import_export.py:85
+msgid "Override projection check (use current location's projection)"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2586
-#: ../gui/wxpython/location_wizard/wizard.py:2595
-#, python-format
-msgid "File <%s> not found."
+#: ../gui/wxpython/modules/import_export.py:116
+#: ../gui/wxpython/modules/import_export.py:393
+#: ../gui/wxpython/modules/import_export.py:534
+msgid "&Import"
msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:109
-msgid "&Set region"
+#: ../gui/wxpython/modules/import_export.py:117
+#: ../gui/wxpython/modules/import_export.py:394
+#: ../gui/wxpython/modules/import_export.py:535
+msgid "Import selected layers"
msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:141
-msgid "Invalid location selected."
+#: ../gui/wxpython/modules/import_export.py:128
+msgid "Source settings"
msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:160
-msgid "Invalid region"
+#: ../gui/wxpython/modules/import_export.py:149
+msgid "Import settings"
msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:191
-msgid "Click here to show 3D settings"
+#: ../gui/wxpython/modules/import_export.py:379
+#: ../gui/wxpython/modules/import_export.py:520
+msgid "Add linked layers into layer tree"
msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:192
-msgid "Click here to hide 3D settings"
+#: ../gui/wxpython/modules/import_export.py:381
+#: ../gui/wxpython/modules/import_export.py:522
+#: ../gui/wxpython/modules/import_export.py:751
+msgid "Add imported layers into layer tree"
msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:218
-#: ../gui/wxpython/location_wizard/dialogs.py:526
-#, python-format
-msgid "Rows: %d"
+#: ../gui/wxpython/modules/import_export.py:390
+#: ../gui/wxpython/modules/import_export.py:531
+msgid "&Link"
msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:219
-#: ../gui/wxpython/location_wizard/dialogs.py:527
-#, python-format
-msgid "Cols: %d"
+#: ../gui/wxpython/modules/import_export.py:391
+#: ../gui/wxpython/modules/import_export.py:532
+msgid "Link selected layers"
msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:220
-#: ../gui/wxpython/location_wizard/dialogs.py:528
-#, python-format
-msgid "Cells: %d"
+#: ../gui/wxpython/modules/import_export.py:414
+#: ../gui/wxpython/modules/import_export.py:555
+msgid "No layers selected. Operation canceled."
msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:268
-#: ../gui/wxpython/location_wizard/dialogs.py:530
-#, python-format
-msgid "Depth: %d"
+#: ../gui/wxpython/modules/import_export.py:440
+msgid "Unable to determine number of raster bands"
msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:272
-#: ../gui/wxpython/location_wizard/dialogs.py:531
-#, python-format
-msgid "3D Cells: %d"
+#: ../gui/wxpython/modules/import_export.py:655
+msgid "Define output format for vector data"
msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:295
-msgid "T-B resolution"
+#: ../gui/wxpython/modules/import_export.py:657
+msgid "Define output format for raster data"
msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:360
-msgid "North"
+#: ../gui/wxpython/modules/import_export.py:665
+msgid "Set external format and close dialog"
msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:368
-msgid "West"
+#: ../gui/wxpython/modules/import_export.py:722
+msgid "No data source selected."
msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:390
-msgid "East"
+#: ../gui/wxpython/modules/import_export.py:737
+msgid "Import DXF layers"
msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:399
-msgid "South"
+#: ../gui/wxpython/modules/import_export.py:744
+msgid "Choose DXF file to import"
msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:403
-msgid "N-S resolution"
+#: ../gui/wxpython/modules/import_export.py:773
+msgid "No layers selected."
msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:411
-msgid "E-W resolution"
+#: ../gui/wxpython/modules/import_export.py:863
+msgid "Name for output GRASS map"
msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:489
-#, python-format
-msgid "Invalid value: %s"
+#: ../gui/wxpython/modules/import_export.py:881
+msgid "Projection of following layers do not match with projection of current location. "
msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:586
-msgid "Select datum transformation"
+#: ../gui/wxpython/modules/import_export.py:883
+msgid "Layers to be reprojected"
msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:612
-msgid "Select from list of datum transformations"
+#: ../gui/wxpython/modules/import_export.py:897
+msgid "&Import && reproject"
msgstr ""
-#: ../gui/wxpython/menustrings.py:4 ../gui/wxpython/menustrings.py:2009
-#: ../gui/wxpython/menustrings.py:2059
+#: ../gui/wxpython/modules/import_export.py:898
+msgid "Reproject selected layers"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:4 ../gui/wxpython/menustrings.py:1934
+#: ../gui/wxpython/menustrings.py:1984
msgid "&File"
msgstr ""
@@ -13476,7 +13544,7 @@
msgid "Create new workspace"
msgstr ""
-#: ../gui/wxpython/menustrings.py:8 ../gui/wxpython/menustrings.py:2012
+#: ../gui/wxpython/menustrings.py:8 ../gui/wxpython/menustrings.py:1937
msgid "Open"
msgstr ""
@@ -13484,7 +13552,7 @@
msgid "Load workspace from file"
msgstr ""
-#: ../gui/wxpython/menustrings.py:12 ../gui/wxpython/menustrings.py:2016
+#: ../gui/wxpython/menustrings.py:12 ../gui/wxpython/menustrings.py:1941
msgid "Save as"
msgstr ""
@@ -13552,3989 +13620,3864 @@
msgid "Close all open map display windows"
msgstr ""
-#: ../gui/wxpython/menustrings.py:36 ../gui/wxpython/menustrings.py:1059
+#: ../gui/wxpython/menustrings.py:36 ../gui/wxpython/menustrings.py:1021
msgid "Common formats import"
msgstr ""
-#: ../gui/wxpython/menustrings.py:37 ../gui/wxpython/menustrings.py:1060
+#: ../gui/wxpython/menustrings.py:37 ../gui/wxpython/menustrings.py:1022
msgid "Imports raster data into a GRASS raster map using GDAL library."
msgstr ""
-#: ../gui/wxpython/menustrings.py:38 ../gui/wxpython/menustrings.py:69
-#: ../gui/wxpython/menustrings.py:1061 ../gui/wxpython/menustrings.py:1092
+#: ../gui/wxpython/menustrings.py:38 ../gui/wxpython/menustrings.py:68
+#: ../gui/wxpython/menustrings.py:1023 ../gui/wxpython/menustrings.py:1053
msgid "Import of common formats with reprojection"
msgstr ""
-#: ../gui/wxpython/menustrings.py:39 ../gui/wxpython/menustrings.py:1062
+#: ../gui/wxpython/menustrings.py:39 ../gui/wxpython/menustrings.py:1024
msgid "Imports raster data into a GRASS raster map using GDAL library and reprojects on the fly."
msgstr ""
-#: ../gui/wxpython/menustrings.py:40 ../gui/wxpython/menustrings.py:1063
+#: ../gui/wxpython/menustrings.py:40 ../gui/wxpython/menustrings.py:1025
msgid "ASCII x,y,z point import and gridding"
msgstr ""
-#: ../gui/wxpython/menustrings.py:41 ../gui/wxpython/menustrings.py:1064
+#: ../gui/wxpython/menustrings.py:41 ../gui/wxpython/menustrings.py:1026
msgid "Creates a raster map from an assemblage of many coordinates using univariate statistics."
msgstr ""
-#: ../gui/wxpython/menustrings.py:42 ../gui/wxpython/menustrings.py:1065
+#: ../gui/wxpython/menustrings.py:42 ../gui/wxpython/menustrings.py:1027
msgid "ASCII grid import"
msgstr ""
-#: ../gui/wxpython/menustrings.py:43 ../gui/wxpython/menustrings.py:1066
+#: ../gui/wxpython/menustrings.py:43 ../gui/wxpython/menustrings.py:1028
msgid "Converts a GRASS ASCII raster file to binary raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:44 ../gui/wxpython/menustrings.py:1067
+#: ../gui/wxpython/menustrings.py:44 ../gui/wxpython/menustrings.py:1029
msgid "ASCII polygons, lines, and point import"
msgstr ""
-#: ../gui/wxpython/menustrings.py:45 ../gui/wxpython/menustrings.py:1068
+#: ../gui/wxpython/menustrings.py:45 ../gui/wxpython/menustrings.py:1030
msgid "Creates raster maps from ASCII polygon/line/point data files."
msgstr ""
-#: ../gui/wxpython/menustrings.py:46 ../gui/wxpython/menustrings.py:1069
+#: ../gui/wxpython/menustrings.py:46 ../gui/wxpython/menustrings.py:1031
msgid "Raw binary array import"
msgstr ""
-#: ../gui/wxpython/menustrings.py:47 ../gui/wxpython/menustrings.py:1070
+#: ../gui/wxpython/menustrings.py:47 ../gui/wxpython/menustrings.py:1032
msgid "Import a binary raster file into a GRASS raster map layer."
msgstr ""
-#: ../gui/wxpython/menustrings.py:48 ../gui/wxpython/menustrings.py:1071
+#: ../gui/wxpython/menustrings.py:48 ../gui/wxpython/menustrings.py:1033
msgid "GRIDATB.FOR import"
msgstr ""
-#: ../gui/wxpython/menustrings.py:49 ../gui/wxpython/menustrings.py:1072
+#: ../gui/wxpython/menustrings.py:49 ../gui/wxpython/menustrings.py:1034
msgid "Imports GRIDATB.FOR map file (TOPMODEL) into a GRASS raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:50 ../gui/wxpython/menustrings.py:1073
+#: ../gui/wxpython/menustrings.py:50 ../gui/wxpython/menustrings.py:1035
msgid "Matlab 2D array import"
msgstr ""
-#: ../gui/wxpython/menustrings.py:51 ../gui/wxpython/menustrings.py:1074
+#: ../gui/wxpython/menustrings.py:51 ../gui/wxpython/menustrings.py:1036
msgid "Imports a binary MAT-File(v4) to a GRASS raster."
msgstr ""
-#: ../gui/wxpython/menustrings.py:52 ../gui/wxpython/menustrings.py:1075
+#: ../gui/wxpython/menustrings.py:52 ../gui/wxpython/menustrings.py:1037
msgid "PNG import"
msgstr ""
-#: ../gui/wxpython/menustrings.py:53 ../gui/wxpython/menustrings.py:1076
+#: ../gui/wxpython/menustrings.py:53 ../gui/wxpython/menustrings.py:1038
msgid "Imports non-georeferenced PNG format image."
msgstr ""
-#: ../gui/wxpython/menustrings.py:54 ../gui/wxpython/menustrings.py:1077
+#: ../gui/wxpython/menustrings.py:54 ../gui/wxpython/menustrings.py:1039
msgid "SPOT NDVI import"
msgstr ""
-#: ../gui/wxpython/menustrings.py:55 ../gui/wxpython/menustrings.py:1078
+#: ../gui/wxpython/menustrings.py:55 ../gui/wxpython/menustrings.py:1040
msgid "Imports SPOT VGT NDVI data into a raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:56 ../gui/wxpython/menustrings.py:1079
+#: ../gui/wxpython/menustrings.py:56 ../gui/wxpython/menustrings.py:1041
msgid "SRTM HGT import"
msgstr ""
-#: ../gui/wxpython/menustrings.py:57 ../gui/wxpython/menustrings.py:1080
+#: ../gui/wxpython/menustrings.py:57 ../gui/wxpython/menustrings.py:1042
msgid "Imports SRTM HGT files into raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:58 ../gui/wxpython/menustrings.py:1081
+#: ../gui/wxpython/menustrings.py:58 ../gui/wxpython/menustrings.py:1043
msgid "Terra ASTER HDF import"
msgstr ""
-#: ../gui/wxpython/menustrings.py:59 ../gui/wxpython/menustrings.py:1082
+#: ../gui/wxpython/menustrings.py:59 ../gui/wxpython/menustrings.py:1044
msgid "Georeference, rectify, and import Terra-ASTER imagery and relative DEMs using gdalwarp."
msgstr ""
-#: ../gui/wxpython/menustrings.py:60 ../gui/wxpython/menustrings.py:85
-#: ../gui/wxpython/menustrings.py:94 ../gui/wxpython/menustrings.py:1083
-#: ../gui/wxpython/menustrings.py:1108 ../gui/wxpython/menustrings.py:1117
+#: ../gui/wxpython/menustrings.py:60 ../gui/wxpython/menustrings.py:84
+#: ../gui/wxpython/menustrings.py:1045 ../gui/wxpython/menustrings.py:1069
msgid "LAS LiDAR points import"
msgstr ""
-#: ../gui/wxpython/menustrings.py:61 ../gui/wxpython/menustrings.py:1084
-msgid "Creates a raster map from LAS LiDAR points using univariate statistics."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:62 ../gui/wxpython/menustrings.py:1085
+#: ../gui/wxpython/menustrings.py:61 ../gui/wxpython/menustrings.py:1046
msgid "Unpack raster map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:63 ../gui/wxpython/menustrings.py:1086
+#: ../gui/wxpython/menustrings.py:62 ../gui/wxpython/menustrings.py:1047
msgid "Imports a raster map as GRASS GIS specific archive file (packed with r.pack)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:64 ../gui/wxpython/menustrings.py:289
-#: ../gui/wxpython/menustrings.py:1087 ../gui/wxpython/menustrings.py:1232
+#: ../gui/wxpython/menustrings.py:63 ../gui/wxpython/menustrings.py:281
+#: ../gui/wxpython/menustrings.py:1048 ../gui/wxpython/menustrings.py:1187
msgid "Reproject raster map from different GRASS location"
msgstr ""
-#: ../gui/wxpython/menustrings.py:65 ../gui/wxpython/menustrings.py:290
-#: ../gui/wxpython/menustrings.py:1088 ../gui/wxpython/menustrings.py:1233
+#: ../gui/wxpython/menustrings.py:64 ../gui/wxpython/menustrings.py:282
+#: ../gui/wxpython/menustrings.py:1049 ../gui/wxpython/menustrings.py:1188
msgid "Re-projects a raster map from given location to the current location."
msgstr ""
-#: ../gui/wxpython/menustrings.py:67 ../gui/wxpython/menustrings.py:101
-#: ../gui/wxpython/menustrings.py:1090 ../gui/wxpython/menustrings.py:1124
+#: ../gui/wxpython/menustrings.py:66 ../gui/wxpython/menustrings.py:97
+#: ../gui/wxpython/menustrings.py:1051 ../gui/wxpython/menustrings.py:1082
msgid "Common import formats"
msgstr ""
-#: ../gui/wxpython/menustrings.py:68 ../gui/wxpython/menustrings.py:1091
+#: ../gui/wxpython/menustrings.py:67 ../gui/wxpython/menustrings.py:1052
msgid "Imports vector data into a GRASS vector map using OGR library."
msgstr ""
-#: ../gui/wxpython/menustrings.py:70 ../gui/wxpython/menustrings.py:1093
+#: ../gui/wxpython/menustrings.py:69 ../gui/wxpython/menustrings.py:1054
msgid "Imports vector data into a GRASS vector map using OGR library and reprojects on the fly."
msgstr ""
-#: ../gui/wxpython/menustrings.py:71 ../gui/wxpython/menustrings.py:1094
+#: ../gui/wxpython/menustrings.py:70 ../gui/wxpython/menustrings.py:1055
msgid "ASCII points or GRASS ASCII format"
msgstr ""
-#: ../gui/wxpython/menustrings.py:72 ../gui/wxpython/menustrings.py:1095
+#: ../gui/wxpython/menustrings.py:71 ../gui/wxpython/menustrings.py:1056
msgid "Creates a vector map from an ASCII points file or ASCII vector file."
msgstr ""
-#: ../gui/wxpython/menustrings.py:73 ../gui/wxpython/menustrings.py:1096
+#: ../gui/wxpython/menustrings.py:72 ../gui/wxpython/menustrings.py:1057
msgid "ASCII points as a vector lines"
msgstr ""
-#: ../gui/wxpython/menustrings.py:74 ../gui/wxpython/menustrings.py:1097
+#: ../gui/wxpython/menustrings.py:73 ../gui/wxpython/menustrings.py:1058
msgid "Imports ASCII x,y[,z] coordinates as a series of lines."
msgstr ""
-#: ../gui/wxpython/menustrings.py:75 ../gui/wxpython/menustrings.py:1098
+#: ../gui/wxpython/menustrings.py:74 ../gui/wxpython/menustrings.py:1059
msgid "DXF import"
msgstr ""
-#: ../gui/wxpython/menustrings.py:76 ../gui/wxpython/menustrings.py:1099
+#: ../gui/wxpython/menustrings.py:75 ../gui/wxpython/menustrings.py:1060
msgid "Converts files in DXF format to GRASS vector map format."
msgstr ""
-#: ../gui/wxpython/menustrings.py:77 ../gui/wxpython/menustrings.py:1100
+#: ../gui/wxpython/menustrings.py:76 ../gui/wxpython/menustrings.py:1061
msgid "WFS"
msgstr ""
-#: ../gui/wxpython/menustrings.py:78 ../gui/wxpython/menustrings.py:1101
+#: ../gui/wxpython/menustrings.py:77 ../gui/wxpython/menustrings.py:1062
msgid "Imports GetFeature from a WFS server."
msgstr ""
-#: ../gui/wxpython/menustrings.py:79 ../gui/wxpython/menustrings.py:1102
+#: ../gui/wxpython/menustrings.py:78 ../gui/wxpython/menustrings.py:1063
msgid "ESRI e00 import"
msgstr ""
-#: ../gui/wxpython/menustrings.py:80 ../gui/wxpython/menustrings.py:1103
+#: ../gui/wxpython/menustrings.py:79 ../gui/wxpython/menustrings.py:1064
msgid "Imports E00 file into a vector map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:81 ../gui/wxpython/menustrings.py:1104
+#: ../gui/wxpython/menustrings.py:80 ../gui/wxpython/menustrings.py:1065
msgid "Geonames import"
msgstr ""
-#: ../gui/wxpython/menustrings.py:82 ../gui/wxpython/menustrings.py:1105
+#: ../gui/wxpython/menustrings.py:81 ../gui/wxpython/menustrings.py:1066
msgid "Imports geonames.org country files into a vector points map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:83 ../gui/wxpython/menustrings.py:1106
+#: ../gui/wxpython/menustrings.py:82 ../gui/wxpython/menustrings.py:1067
msgid "Matlab array or Mapgen format import"
msgstr ""
-#: ../gui/wxpython/menustrings.py:84 ../gui/wxpython/menustrings.py:1107
+#: ../gui/wxpython/menustrings.py:83 ../gui/wxpython/menustrings.py:1068
msgid "Imports Mapgen or Matlab-ASCII vector maps into GRASS."
msgstr ""
-#: ../gui/wxpython/menustrings.py:86 ../gui/wxpython/menustrings.py:1109
-msgid "Converts LAS LiDAR point clouds to a GRASS vector map with libLAS."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:87 ../gui/wxpython/menustrings.py:1110
+#: ../gui/wxpython/menustrings.py:85 ../gui/wxpython/menustrings.py:1070
msgid "Unpack vector map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:88 ../gui/wxpython/menustrings.py:1111
+#: ../gui/wxpython/menustrings.py:86 ../gui/wxpython/menustrings.py:1071
msgid "Imports a vector map as GRASS GIS specific archive file (packed with v.pack)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:89 ../gui/wxpython/menustrings.py:567
-#: ../gui/wxpython/menustrings.py:1112 ../gui/wxpython/menustrings.py:1510
+#: ../gui/wxpython/menustrings.py:87 ../gui/wxpython/menustrings.py:559
+#: ../gui/wxpython/menustrings.py:1072 ../gui/wxpython/menustrings.py:1465
msgid "Reproject vector map from different GRASS location"
msgstr ""
-#: ../gui/wxpython/menustrings.py:90 ../gui/wxpython/menustrings.py:568
-#: ../gui/wxpython/menustrings.py:1113 ../gui/wxpython/menustrings.py:1511
+#: ../gui/wxpython/menustrings.py:88 ../gui/wxpython/menustrings.py:560
+#: ../gui/wxpython/menustrings.py:1073 ../gui/wxpython/menustrings.py:1466
msgid "Re-projects a vector map from one location to the current location."
msgstr ""
-#: ../gui/wxpython/menustrings.py:91 ../gui/wxpython/menustrings.py:1114
+#: ../gui/wxpython/menustrings.py:89 ../gui/wxpython/menustrings.py:1074
msgid "Import 3D raster data"
msgstr ""
-#: ../gui/wxpython/menustrings.py:92 ../gui/wxpython/menustrings.py:1115
+#: ../gui/wxpython/menustrings.py:90 ../gui/wxpython/menustrings.py:1075
msgid "ASCII 3D import"
msgstr ""
-#: ../gui/wxpython/menustrings.py:93 ../gui/wxpython/menustrings.py:1116
+#: ../gui/wxpython/menustrings.py:91 ../gui/wxpython/menustrings.py:1076
msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:95 ../gui/wxpython/menustrings.py:1118
-msgid "Creates a 3D raster map from LAS LiDAR points"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:96 ../gui/wxpython/menustrings.py:1119
+#: ../gui/wxpython/menustrings.py:92 ../gui/wxpython/menustrings.py:1077
msgid "Raw binary array 3D import"
msgstr ""
-#: ../gui/wxpython/menustrings.py:97 ../gui/wxpython/menustrings.py:1120
+#: ../gui/wxpython/menustrings.py:93 ../gui/wxpython/menustrings.py:1078
msgid "Imports a binary raster file into a GRASS 3D raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:98 ../gui/wxpython/menustrings.py:1121
+#: ../gui/wxpython/menustrings.py:94 ../gui/wxpython/menustrings.py:1079
msgid "Vis5D import"
msgstr ""
-#: ../gui/wxpython/menustrings.py:99 ../gui/wxpython/menustrings.py:1122
+#: ../gui/wxpython/menustrings.py:95 ../gui/wxpython/menustrings.py:1080
msgid "Import 3-dimensional Vis5D files."
msgstr ""
-#: ../gui/wxpython/menustrings.py:100 ../gui/wxpython/menustrings.py:1123
+#: ../gui/wxpython/menustrings.py:96 ../gui/wxpython/menustrings.py:1081
msgid "Import database table"
msgstr ""
-#: ../gui/wxpython/menustrings.py:102 ../gui/wxpython/menustrings.py:1125
+#: ../gui/wxpython/menustrings.py:98 ../gui/wxpython/menustrings.py:1083
msgid "Imports attribute tables in various formats."
msgstr ""
-#: ../gui/wxpython/menustrings.py:103 ../gui/wxpython/menustrings.py:1126
+#: ../gui/wxpython/menustrings.py:99 ../gui/wxpython/menustrings.py:1084
msgid "Export raster map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:104 ../gui/wxpython/menustrings.py:133
-#: ../gui/wxpython/menustrings.py:161 ../gui/wxpython/menustrings.py:1127
-#: ../gui/wxpython/menustrings.py:1156 ../gui/wxpython/menustrings.py:1184
+#: ../gui/wxpython/menustrings.py:100 ../gui/wxpython/menustrings.py:129
+#: ../gui/wxpython/menustrings.py:154 ../gui/wxpython/menustrings.py:1085
+#: ../gui/wxpython/menustrings.py:1114 ../gui/wxpython/menustrings.py:1139
msgid "Common export formats"
msgstr ""
-#: ../gui/wxpython/menustrings.py:105 ../gui/wxpython/menustrings.py:1128
+#: ../gui/wxpython/menustrings.py:101 ../gui/wxpython/menustrings.py:1086
msgid "Exports GRASS raster maps into GDAL supported formats."
msgstr ""
-#: ../gui/wxpython/menustrings.py:106 ../gui/wxpython/menustrings.py:1129
+#: ../gui/wxpython/menustrings.py:102 ../gui/wxpython/menustrings.py:1087
msgid "ASCII grid export"
msgstr ""
-#: ../gui/wxpython/menustrings.py:107 ../gui/wxpython/menustrings.py:1130
+#: ../gui/wxpython/menustrings.py:103 ../gui/wxpython/menustrings.py:1088
msgid "Converts a raster map layer into a GRASS ASCII text file."
msgstr ""
-#: ../gui/wxpython/menustrings.py:108 ../gui/wxpython/menustrings.py:1131
+#: ../gui/wxpython/menustrings.py:104 ../gui/wxpython/menustrings.py:1089
msgid "ASCII x,y,z points export"
msgstr ""
-#: ../gui/wxpython/menustrings.py:109 ../gui/wxpython/menustrings.py:1132
+#: ../gui/wxpython/menustrings.py:105 ../gui/wxpython/menustrings.py:1090
msgid "Exports a raster map to a text file as x,y,z values based on cell centers."
msgstr ""
-#: ../gui/wxpython/menustrings.py:110 ../gui/wxpython/menustrings.py:1133
+#: ../gui/wxpython/menustrings.py:106 ../gui/wxpython/menustrings.py:1091
msgid "GRIDATB.FOR export"
msgstr ""
-#: ../gui/wxpython/menustrings.py:111 ../gui/wxpython/menustrings.py:1134
+#: ../gui/wxpython/menustrings.py:107 ../gui/wxpython/menustrings.py:1092
msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:112 ../gui/wxpython/menustrings.py:1135
+#: ../gui/wxpython/menustrings.py:108 ../gui/wxpython/menustrings.py:1093
msgid "Matlab 2D array export"
msgstr ""
-#: ../gui/wxpython/menustrings.py:113 ../gui/wxpython/menustrings.py:1136
+#: ../gui/wxpython/menustrings.py:109 ../gui/wxpython/menustrings.py:1094
msgid "Exports a GRASS raster to a binary MAT-File."
msgstr ""
-#: ../gui/wxpython/menustrings.py:114 ../gui/wxpython/menustrings.py:1137
+#: ../gui/wxpython/menustrings.py:110 ../gui/wxpython/menustrings.py:1095
msgid "Raw binary array export"
msgstr ""
-#: ../gui/wxpython/menustrings.py:115 ../gui/wxpython/menustrings.py:1138
+#: ../gui/wxpython/menustrings.py:111 ../gui/wxpython/menustrings.py:1096
msgid "Exports a GRASS raster to a binary array."
msgstr ""
-#: ../gui/wxpython/menustrings.py:116 ../gui/wxpython/menustrings.py:1139
+#: ../gui/wxpython/menustrings.py:112 ../gui/wxpython/menustrings.py:1097
msgid "MPEG-1 export"
msgstr ""
-#: ../gui/wxpython/menustrings.py:117 ../gui/wxpython/menustrings.py:1140
+#: ../gui/wxpython/menustrings.py:113 ../gui/wxpython/menustrings.py:1098
msgid "Converts raster map series to MPEG movie."
msgstr ""
-#: ../gui/wxpython/menustrings.py:118 ../gui/wxpython/menustrings.py:1141
+#: ../gui/wxpython/menustrings.py:114 ../gui/wxpython/menustrings.py:1099
msgid "PNG export"
msgstr ""
-#: ../gui/wxpython/menustrings.py:119 ../gui/wxpython/menustrings.py:1142
+#: ../gui/wxpython/menustrings.py:115 ../gui/wxpython/menustrings.py:1100
msgid "Export a GRASS raster map as a non-georeferenced PNG image."
msgstr ""
-#: ../gui/wxpython/menustrings.py:120 ../gui/wxpython/menustrings.py:1143
+#: ../gui/wxpython/menustrings.py:116 ../gui/wxpython/menustrings.py:1101
msgid "PPM export"
msgstr ""
-#: ../gui/wxpython/menustrings.py:121 ../gui/wxpython/menustrings.py:1144
+#: ../gui/wxpython/menustrings.py:117 ../gui/wxpython/menustrings.py:1102
msgid "Converts a GRASS raster map to a PPM image file."
msgstr ""
-#: ../gui/wxpython/menustrings.py:122 ../gui/wxpython/menustrings.py:1145
+#: ../gui/wxpython/menustrings.py:118 ../gui/wxpython/menustrings.py:1103
msgid "PPM from RGB export"
msgstr ""
-#: ../gui/wxpython/menustrings.py:123 ../gui/wxpython/menustrings.py:1146
+#: ../gui/wxpython/menustrings.py:119 ../gui/wxpython/menustrings.py:1104
msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file."
msgstr ""
-#: ../gui/wxpython/menustrings.py:124 ../gui/wxpython/menustrings.py:143
-#: ../gui/wxpython/menustrings.py:1147 ../gui/wxpython/menustrings.py:1166
+#: ../gui/wxpython/menustrings.py:120 ../gui/wxpython/menustrings.py:136
+#: ../gui/wxpython/menustrings.py:1105 ../gui/wxpython/menustrings.py:1121
msgid "POV-Ray export"
msgstr ""
-#: ../gui/wxpython/menustrings.py:125 ../gui/wxpython/menustrings.py:1148
+#: ../gui/wxpython/menustrings.py:121 ../gui/wxpython/menustrings.py:1106
msgid "Converts a raster map layer into a height-field file for POV-Ray."
msgstr ""
-#: ../gui/wxpython/menustrings.py:126 ../gui/wxpython/menustrings.py:1149
+#: ../gui/wxpython/menustrings.py:122 ../gui/wxpython/menustrings.py:1107
msgid "VRML export"
msgstr ""
-#: ../gui/wxpython/menustrings.py:127 ../gui/wxpython/menustrings.py:1150
+#: ../gui/wxpython/menustrings.py:123 ../gui/wxpython/menustrings.py:1108
msgid "Exports a raster map to the Virtual Reality Modeling Language (VRML)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:128 ../gui/wxpython/menustrings.py:147
-#: ../gui/wxpython/menustrings.py:158 ../gui/wxpython/menustrings.py:1151
-#: ../gui/wxpython/menustrings.py:1170 ../gui/wxpython/menustrings.py:1181
+#: ../gui/wxpython/menustrings.py:124 ../gui/wxpython/menustrings.py:140
+#: ../gui/wxpython/menustrings.py:151 ../gui/wxpython/menustrings.py:1109
+#: ../gui/wxpython/menustrings.py:1125 ../gui/wxpython/menustrings.py:1136
msgid "VTK export"
msgstr ""
-#: ../gui/wxpython/menustrings.py:129 ../gui/wxpython/menustrings.py:1152
+#: ../gui/wxpython/menustrings.py:125 ../gui/wxpython/menustrings.py:1110
msgid "Converts raster maps into the VTK-ASCII format."
msgstr ""
-#: ../gui/wxpython/menustrings.py:130 ../gui/wxpython/menustrings.py:1153
+#: ../gui/wxpython/menustrings.py:126 ../gui/wxpython/menustrings.py:1111
msgid "Pack raster map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:131 ../gui/wxpython/menustrings.py:1154
+#: ../gui/wxpython/menustrings.py:127 ../gui/wxpython/menustrings.py:1112
msgid "Exports a raster map as GRASS GIS specific archive file"
msgstr ""
-#: ../gui/wxpython/menustrings.py:132 ../gui/wxpython/menustrings.py:1155
+#: ../gui/wxpython/menustrings.py:128 ../gui/wxpython/menustrings.py:1113
msgid "Export vector map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:134 ../gui/wxpython/menustrings.py:1157
+#: ../gui/wxpython/menustrings.py:130 ../gui/wxpython/menustrings.py:1115
msgid "Exports a vector map layer to any of the supported OGR vector formats. By default a vector map layer is exported to Esri Shapefile format."
msgstr ""
-#: ../gui/wxpython/menustrings.py:135 ../gui/wxpython/menustrings.py:1158
+#: ../gui/wxpython/menustrings.py:131 ../gui/wxpython/menustrings.py:1116
msgid "ASCII points or GRASS ASCII vector export"
msgstr ""
-#: ../gui/wxpython/menustrings.py:136 ../gui/wxpython/menustrings.py:1159
+#: ../gui/wxpython/menustrings.py:132 ../gui/wxpython/menustrings.py:1117
msgid "Exports a vector map to a GRASS ASCII vector representation. By default only features with category are exported. To export all features use 'layer=-1'."
msgstr ""
-#: ../gui/wxpython/menustrings.py:137 ../gui/wxpython/menustrings.py:1160
+#: ../gui/wxpython/menustrings.py:133 ../gui/wxpython/menustrings.py:1118
msgid "DXF export"
msgstr ""
-#: ../gui/wxpython/menustrings.py:138 ../gui/wxpython/menustrings.py:1161
+#: ../gui/wxpython/menustrings.py:134 ../gui/wxpython/menustrings.py:1119
msgid "Exports vector map to DXF file format."
msgstr ""
-#: ../gui/wxpython/menustrings.py:139 ../gui/wxpython/menustrings.py:1162
-msgid "LAS LiDAR points export"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:140 ../gui/wxpython/menustrings.py:1163
-msgid "Exports vector points as LAS point cloud Converts LAS LiDAR point clouds to a GRASS vector map with libLAS"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:141 ../gui/wxpython/menustrings.py:1164
+#: ../gui/wxpython/menustrings.py:135 ../gui/wxpython/menustrings.py:1120
msgid "PostGIS export"
msgstr ""
-#: ../gui/wxpython/menustrings.py:142 ../gui/wxpython/menustrings.py:1165
-msgid "Exports a vector map layer to PostGIS feature table."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:144 ../gui/wxpython/menustrings.py:1167
+#: ../gui/wxpython/menustrings.py:137 ../gui/wxpython/menustrings.py:1122
msgid "Converts GRASS x,y,z points to POV-Ray x,z,y format."
msgstr ""
-#: ../gui/wxpython/menustrings.py:145 ../gui/wxpython/menustrings.py:1168
+#: ../gui/wxpython/menustrings.py:138 ../gui/wxpython/menustrings.py:1123
msgid "SVG export"
msgstr ""
-#: ../gui/wxpython/menustrings.py:146 ../gui/wxpython/menustrings.py:1169
+#: ../gui/wxpython/menustrings.py:139 ../gui/wxpython/menustrings.py:1124
msgid "Exports a vector map to SVG file."
msgstr ""
-#: ../gui/wxpython/menustrings.py:148 ../gui/wxpython/menustrings.py:1171
+#: ../gui/wxpython/menustrings.py:141 ../gui/wxpython/menustrings.py:1126
msgid "Converts a vector map to VTK ASCII output."
msgstr ""
-#: ../gui/wxpython/menustrings.py:149 ../gui/wxpython/menustrings.py:1172
+#: ../gui/wxpython/menustrings.py:142 ../gui/wxpython/menustrings.py:1127
msgid "Pack vector map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:150 ../gui/wxpython/menustrings.py:1173
+#: ../gui/wxpython/menustrings.py:143 ../gui/wxpython/menustrings.py:1128
msgid "Exports a vector map as GRASS GIS specific archive file"
msgstr ""
-#: ../gui/wxpython/menustrings.py:151 ../gui/wxpython/menustrings.py:1174
+#: ../gui/wxpython/menustrings.py:144 ../gui/wxpython/menustrings.py:1129
msgid "Export 3D raster maps"
msgstr ""
-#: ../gui/wxpython/menustrings.py:152 ../gui/wxpython/menustrings.py:1175
+#: ../gui/wxpython/menustrings.py:145 ../gui/wxpython/menustrings.py:1130
msgid "ASCII 3D export"
msgstr ""
-#: ../gui/wxpython/menustrings.py:153 ../gui/wxpython/menustrings.py:1176
+#: ../gui/wxpython/menustrings.py:146 ../gui/wxpython/menustrings.py:1131
msgid "Converts a 3D raster map layer into a ASCII text file."
msgstr ""
-#: ../gui/wxpython/menustrings.py:154 ../gui/wxpython/menustrings.py:1177
+#: ../gui/wxpython/menustrings.py:147 ../gui/wxpython/menustrings.py:1132
msgid "Raw binary array 3D export"
msgstr ""
-#: ../gui/wxpython/menustrings.py:155 ../gui/wxpython/menustrings.py:1178
+#: ../gui/wxpython/menustrings.py:148 ../gui/wxpython/menustrings.py:1133
msgid "Exports a GRASS 3D raster map to a binary array."
msgstr ""
-#: ../gui/wxpython/menustrings.py:156 ../gui/wxpython/menustrings.py:1179
+#: ../gui/wxpython/menustrings.py:149 ../gui/wxpython/menustrings.py:1134
msgid "Vis5D export"
msgstr ""
-#: ../gui/wxpython/menustrings.py:157 ../gui/wxpython/menustrings.py:1180
+#: ../gui/wxpython/menustrings.py:150 ../gui/wxpython/menustrings.py:1135
msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
msgstr ""
-#: ../gui/wxpython/menustrings.py:159 ../gui/wxpython/menustrings.py:1182
+#: ../gui/wxpython/menustrings.py:152 ../gui/wxpython/menustrings.py:1137
msgid "Converts 3D raster maps into the VTK-ASCII format."
msgstr ""
-#: ../gui/wxpython/menustrings.py:160 ../gui/wxpython/menustrings.py:1183
+#: ../gui/wxpython/menustrings.py:153 ../gui/wxpython/menustrings.py:1138
msgid "Export database table"
msgstr ""
-#: ../gui/wxpython/menustrings.py:162 ../gui/wxpython/menustrings.py:1185
+#: ../gui/wxpython/menustrings.py:155 ../gui/wxpython/menustrings.py:1140
msgid "Exports attribute tables into various formats."
msgstr ""
-#: ../gui/wxpython/menustrings.py:163 ../gui/wxpython/menustrings.py:1186
+#: ../gui/wxpython/menustrings.py:156 ../gui/wxpython/menustrings.py:1141
msgid "Link external data"
msgstr ""
-#: ../gui/wxpython/menustrings.py:165 ../gui/wxpython/menustrings.py:1188
+#: ../gui/wxpython/menustrings.py:158 ../gui/wxpython/menustrings.py:1143
msgid "Link GDAL supported raster data as a pseudo GRASS raster map layer."
msgstr ""
-#: ../gui/wxpython/menustrings.py:167 ../gui/wxpython/menustrings.py:1190
+#: ../gui/wxpython/menustrings.py:160 ../gui/wxpython/menustrings.py:1145
msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer."
msgstr ""
-#: ../gui/wxpython/menustrings.py:168 ../gui/wxpython/menustrings.py:1191
+#: ../gui/wxpython/menustrings.py:161 ../gui/wxpython/menustrings.py:1146
msgid "Output format for raster data"
msgstr ""
-#: ../gui/wxpython/menustrings.py:169 ../gui/wxpython/menustrings.py:1192
-msgid "Redirects raster output to file utilizing GDAL library rather than storing in GRASS raster format."
+#: ../gui/wxpython/menustrings.py:162 ../gui/wxpython/menustrings.py:1147
+msgid "Defines raster output format utilizing GDAL library."
msgstr ""
-#: ../gui/wxpython/menustrings.py:170 ../gui/wxpython/menustrings.py:1193
+#: ../gui/wxpython/menustrings.py:163 ../gui/wxpython/menustrings.py:1148
msgid "Output format for vector data"
msgstr ""
-#: ../gui/wxpython/menustrings.py:171 ../gui/wxpython/menustrings.py:1194
+#: ../gui/wxpython/menustrings.py:164 ../gui/wxpython/menustrings.py:1149
msgid "Defines vector output format utilizing OGR library."
msgstr ""
-#: ../gui/wxpython/menustrings.py:172 ../gui/wxpython/menustrings.py:1195
+#: ../gui/wxpython/menustrings.py:165 ../gui/wxpython/menustrings.py:1150
msgid "Manage maps"
msgstr ""
-#: ../gui/wxpython/menustrings.py:174 ../gui/wxpython/menustrings.py:1197
+#: ../gui/wxpython/menustrings.py:167 ../gui/wxpython/menustrings.py:1152
msgid "Copies available data files in the current mapset search path to the user's current mapset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:175 ../gui/wxpython/menustrings.py:955
-#: ../gui/wxpython/menustrings.py:1198 ../gui/wxpython/menustrings.py:1898
+#: ../gui/wxpython/menustrings.py:168 ../gui/wxpython/menustrings.py:928
+#: ../gui/wxpython/menustrings.py:1153 ../gui/wxpython/menustrings.py:1834
msgid "List"
msgstr ""
-#: ../gui/wxpython/menustrings.py:176 ../gui/wxpython/menustrings.py:1199
+#: ../gui/wxpython/menustrings.py:169 ../gui/wxpython/menustrings.py:1154
msgid "Lists available GRASS data base files of the user-specified data type optionally using the search pattern."
msgstr ""
-#: ../gui/wxpython/menustrings.py:178 ../gui/wxpython/menustrings.py:1201
+#: ../gui/wxpython/menustrings.py:171 ../gui/wxpython/menustrings.py:1156
msgid "Renames data base element files in the user's current mapset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:180 ../gui/wxpython/menustrings.py:1203
+#: ../gui/wxpython/menustrings.py:173 ../gui/wxpython/menustrings.py:1158
msgid "Removes data base element files from the user's current mapset using the search pattern."
msgstr ""
-#: ../gui/wxpython/menustrings.py:181 ../gui/wxpython/menustrings.py:313
-#: ../gui/wxpython/menustrings.py:605 ../gui/wxpython/menustrings.py:852
-#: ../gui/wxpython/menustrings.py:1256 ../gui/wxpython/menustrings.py:1548
-#: ../gui/wxpython/menustrings.py:1795
+#: ../gui/wxpython/menustrings.py:174 ../gui/wxpython/menustrings.py:305
+#: ../gui/wxpython/menustrings.py:597 ../gui/wxpython/menustrings.py:829
+#: ../gui/wxpython/menustrings.py:1211 ../gui/wxpython/menustrings.py:1503
+#: ../gui/wxpython/menustrings.py:1735
msgid "Map type conversions"
msgstr ""
-#: ../gui/wxpython/menustrings.py:182 ../gui/wxpython/menustrings.py:314
-#: ../gui/wxpython/menustrings.py:1257
+#: ../gui/wxpython/menustrings.py:175 ../gui/wxpython/menustrings.py:306
+#: ../gui/wxpython/menustrings.py:1212
msgid "Raster to vector"
msgstr ""
-#: ../gui/wxpython/menustrings.py:183 ../gui/wxpython/menustrings.py:315
-#: ../gui/wxpython/menustrings.py:1258
+#: ../gui/wxpython/menustrings.py:176 ../gui/wxpython/menustrings.py:307
+#: ../gui/wxpython/menustrings.py:1213
msgid "Converts a raster map into a vector map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:184 ../gui/wxpython/menustrings.py:316
-#: ../gui/wxpython/menustrings.py:1259
+#: ../gui/wxpython/menustrings.py:177 ../gui/wxpython/menustrings.py:308
+#: ../gui/wxpython/menustrings.py:1214
msgid "Raster series to 3D raster"
msgstr ""
-#: ../gui/wxpython/menustrings.py:185 ../gui/wxpython/menustrings.py:317
-#: ../gui/wxpython/menustrings.py:1260
+#: ../gui/wxpython/menustrings.py:178 ../gui/wxpython/menustrings.py:309
+#: ../gui/wxpython/menustrings.py:1215
msgid "Converts 2D raster map slices to one 3D raster volume map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:186 ../gui/wxpython/menustrings.py:318
-#: ../gui/wxpython/menustrings.py:1261
+#: ../gui/wxpython/menustrings.py:179 ../gui/wxpython/menustrings.py:310
+#: ../gui/wxpython/menustrings.py:1216
msgid "Raster 2.5D to 3D raster"
msgstr ""
-#: ../gui/wxpython/menustrings.py:187 ../gui/wxpython/menustrings.py:319
-#: ../gui/wxpython/menustrings.py:1262
+#: ../gui/wxpython/menustrings.py:180 ../gui/wxpython/menustrings.py:311
+#: ../gui/wxpython/menustrings.py:1217
msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
msgstr ""
-#: ../gui/wxpython/menustrings.py:188 ../gui/wxpython/menustrings.py:606
-#: ../gui/wxpython/menustrings.py:1549
+#: ../gui/wxpython/menustrings.py:181 ../gui/wxpython/menustrings.py:598
+#: ../gui/wxpython/menustrings.py:1504
msgid "Vector to raster"
msgstr ""
-#: ../gui/wxpython/menustrings.py:189 ../gui/wxpython/menustrings.py:607
-#: ../gui/wxpython/menustrings.py:1550
+#: ../gui/wxpython/menustrings.py:182 ../gui/wxpython/menustrings.py:599
+#: ../gui/wxpython/menustrings.py:1505
msgid "Converts (rasterize) a vector map into a raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:190 ../gui/wxpython/menustrings.py:608
-#: ../gui/wxpython/menustrings.py:1551
+#: ../gui/wxpython/menustrings.py:183 ../gui/wxpython/menustrings.py:600
+#: ../gui/wxpython/menustrings.py:1506
msgid "Vector to 3D raster"
msgstr ""
-#: ../gui/wxpython/menustrings.py:191 ../gui/wxpython/menustrings.py:609
-#: ../gui/wxpython/menustrings.py:1552
+#: ../gui/wxpython/menustrings.py:184 ../gui/wxpython/menustrings.py:601
+#: ../gui/wxpython/menustrings.py:1507
msgid "Converts a vector map (only points) into a 3D raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:192 ../gui/wxpython/menustrings.py:610
-#: ../gui/wxpython/menustrings.py:1553
+#: ../gui/wxpython/menustrings.py:185 ../gui/wxpython/menustrings.py:602
+#: ../gui/wxpython/menustrings.py:1508
msgid "2D vector to 3D vector"
msgstr ""
-#: ../gui/wxpython/menustrings.py:193 ../gui/wxpython/menustrings.py:611
-#: ../gui/wxpython/menustrings.py:1554
+#: ../gui/wxpython/menustrings.py:186 ../gui/wxpython/menustrings.py:603
+#: ../gui/wxpython/menustrings.py:1509
msgid "Performs transformation of 2D vector features to 3D."
msgstr ""
-#: ../gui/wxpython/menustrings.py:194
+#: ../gui/wxpython/menustrings.py:187
msgid "3D raster to raster series"
msgstr ""
-#: ../gui/wxpython/menustrings.py:195 ../gui/wxpython/menustrings.py:854
-#: ../gui/wxpython/menustrings.py:1797
+#: ../gui/wxpython/menustrings.py:188 ../gui/wxpython/menustrings.py:831
+#: ../gui/wxpython/menustrings.py:1737
msgid "Converts 3D raster maps to 2D raster maps"
msgstr ""
-#: ../gui/wxpython/menustrings.py:196 ../gui/wxpython/menustrings.py:1995
+#: ../gui/wxpython/menustrings.py:189 ../gui/wxpython/menustrings.py:1920
msgid "Georectify"
msgstr ""
-#: ../gui/wxpython/menustrings.py:197 ../gui/wxpython/menustrings.py:1996
+#: ../gui/wxpython/menustrings.py:190 ../gui/wxpython/menustrings.py:1921
msgid "Manage Ground Control Points for Georectification"
msgstr ""
-#: ../gui/wxpython/menustrings.py:198 ../gui/wxpython/menustrings.py:1997
+#: ../gui/wxpython/menustrings.py:191 ../gui/wxpython/menustrings.py:1922
msgid "Graphical modeler"
msgstr ""
-#: ../gui/wxpython/menustrings.py:199 ../gui/wxpython/menustrings.py:1998
+#: ../gui/wxpython/menustrings.py:192 ../gui/wxpython/menustrings.py:1923
msgid "Launch Graphical modeler"
msgstr ""
-#: ../gui/wxpython/menustrings.py:200 ../gui/wxpython/menustrings.py:2048
+#: ../gui/wxpython/menustrings.py:193 ../gui/wxpython/menustrings.py:1973
msgid "Run model"
msgstr ""
-#: ../gui/wxpython/menustrings.py:201
+#: ../gui/wxpython/menustrings.py:194
msgid "Run model prepared by Graphical modeler"
msgstr ""
-#: ../gui/wxpython/menustrings.py:202
+#: ../gui/wxpython/menustrings.py:195
msgid "3D image rendering"
msgstr ""
-#: ../gui/wxpython/menustrings.py:203
-msgid "Creates a 3D rendering of GIS data. Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster data) in 3D."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:204 ../gui/wxpython/menustrings.py:1040
-#: ../gui/wxpython/menustrings.py:1983 ../gui/wxpython/menustrings.py:1990
+#: ../gui/wxpython/menustrings.py:196 ../gui/wxpython/menustrings.py:1002
+#: ../gui/wxpython/menustrings.py:1908 ../gui/wxpython/menustrings.py:1915
msgid "Animation tool"
msgstr ""
-#: ../gui/wxpython/menustrings.py:205 ../gui/wxpython/menustrings.py:1041
-#: ../gui/wxpython/menustrings.py:1984 ../gui/wxpython/menustrings.py:1991
+#: ../gui/wxpython/menustrings.py:197 ../gui/wxpython/menustrings.py:1003
+#: ../gui/wxpython/menustrings.py:1909 ../gui/wxpython/menustrings.py:1916
msgid "Launch animation tool."
msgstr ""
-#: ../gui/wxpython/menustrings.py:206
msgid "Bearing/distance to coordinates"
msgstr ""
-#: ../gui/wxpython/menustrings.py:207
+#: ../gui/wxpython/menustrings.py:199
msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa. It assumes a cartesian coordinate system"
msgstr ""
-#: ../gui/wxpython/menustrings.py:209 ../gui/wxpython/menustrings.py:1994
+#: ../gui/wxpython/menustrings.py:201 ../gui/wxpython/menustrings.py:1919
msgid "Launch Cartographic Composer"
msgstr ""
-#: ../gui/wxpython/menustrings.py:210 ../gui/wxpython/menustrings.py:2001
+#: ../gui/wxpython/menustrings.py:202 ../gui/wxpython/menustrings.py:1926
msgid "Map Swipe"
msgstr ""
-#: ../gui/wxpython/menustrings.py:211 ../gui/wxpython/menustrings.py:2002
+#: ../gui/wxpython/menustrings.py:203 ../gui/wxpython/menustrings.py:1927
msgid "Launch Map Swipe"
msgstr ""
-#: ../gui/wxpython/menustrings.py:212
+#: ../gui/wxpython/menustrings.py:204
msgid "Launch script"
msgstr ""
-#: ../gui/wxpython/menustrings.py:213
+#: ../gui/wxpython/menustrings.py:205
msgid "Launches script file."
msgstr ""
-#: ../gui/wxpython/menustrings.py:215
+#: ../gui/wxpython/menustrings.py:207
msgid "Quit wxGUI session."
msgstr ""
-#: ../gui/wxpython/menustrings.py:217
+#: ../gui/wxpython/menustrings.py:209
msgid "Quit wxGUI session and exit GRASS shell."
msgstr ""
-#: ../gui/wxpython/menustrings.py:218 ../gui/wxpython/menustrings.py:2026
+#: ../gui/wxpython/menustrings.py:210 ../gui/wxpython/menustrings.py:1951
msgid "&Settings"
msgstr ""
-#: ../gui/wxpython/menustrings.py:219
+#: ../gui/wxpython/menustrings.py:211
msgid "Region"
msgstr ""
-#: ../gui/wxpython/menustrings.py:220
+#: ../gui/wxpython/menustrings.py:212
msgid "Display region"
msgstr ""
-#: ../gui/wxpython/menustrings.py:221 ../gui/wxpython/menustrings.py:223
+#: ../gui/wxpython/menustrings.py:213 ../gui/wxpython/menustrings.py:215
msgid "Manages the boundary definitions for the geographic region."
msgstr ""
-#: ../gui/wxpython/menustrings.py:222
+#: ../gui/wxpython/menustrings.py:214
msgid "Set region"
msgstr ""
-#: ../gui/wxpython/menustrings.py:224
+#: ../gui/wxpython/menustrings.py:216
msgid "GRASS working environment"
msgstr ""
-#: ../gui/wxpython/menustrings.py:225
+#: ../gui/wxpython/menustrings.py:217
msgid "Mapset access"
msgstr ""
-#: ../gui/wxpython/menustrings.py:226
+#: ../gui/wxpython/menustrings.py:218
msgid "Set/unset access to other mapsets in current location"
msgstr ""
-#: ../gui/wxpython/menustrings.py:227
+#: ../gui/wxpython/menustrings.py:219
msgid "User access"
msgstr ""
-#: ../gui/wxpython/menustrings.py:228
+#: ../gui/wxpython/menustrings.py:220
msgid "Controls access to the current mapset for other users on the system. If no option given, prints current status."
msgstr ""
-#: ../gui/wxpython/menustrings.py:229
+#: ../gui/wxpython/menustrings.py:221
msgid "Change working environment"
msgstr ""
-#: ../gui/wxpython/menustrings.py:230
+#: ../gui/wxpython/menustrings.py:222
msgid "Changes/reports current mapset. Optionally create new mapset or list available mapsets in given location."
msgstr ""
-#: ../gui/wxpython/menustrings.py:231
+#: ../gui/wxpython/menustrings.py:223
msgid "Change location and mapset"
msgstr ""
-#: ../gui/wxpython/menustrings.py:232
+#: ../gui/wxpython/menustrings.py:224
msgid "Change current location and mapset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:233
+#: ../gui/wxpython/menustrings.py:225
msgid "Change mapset"
msgstr ""
-#: ../gui/wxpython/menustrings.py:234
+#: ../gui/wxpython/menustrings.py:226
msgid "Change current mapset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:235 ../gui/wxpython/menustrings.py:236
+#: ../gui/wxpython/menustrings.py:227 ../gui/wxpython/menustrings.py:228
msgid "Change working directory"
msgstr ""
-#: ../gui/wxpython/menustrings.py:237
+#: ../gui/wxpython/menustrings.py:229
msgid "Show settings"
msgstr ""
-#: ../gui/wxpython/menustrings.py:238
+#: ../gui/wxpython/menustrings.py:230
msgid "Outputs and modifies the user's current GRASS variable settings."
msgstr ""
-#: ../gui/wxpython/menustrings.py:239
+#: ../gui/wxpython/menustrings.py:231
msgid "Change settings"
msgstr ""
-#: ../gui/wxpython/menustrings.py:240
+#: ../gui/wxpython/menustrings.py:232
msgid "Outputs and modifies the user's current GRASS variable settings. Prints all defined GRASS variables if no option is given."
msgstr ""
-#: ../gui/wxpython/menustrings.py:241
+#: ../gui/wxpython/menustrings.py:233
msgid "Create new location"
msgstr ""
-#: ../gui/wxpython/menustrings.py:242
+#: ../gui/wxpython/menustrings.py:234
msgid "Launches location wizard to create new GRASS location."
msgstr ""
-#: ../gui/wxpython/menustrings.py:244
+#: ../gui/wxpython/menustrings.py:236
msgid "Creates new mapset in the current location, changes current mapset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:245
+#: ../gui/wxpython/menustrings.py:237
msgid "Version and copyright"
msgstr ""
-#: ../gui/wxpython/menustrings.py:246
+#: ../gui/wxpython/menustrings.py:238
msgid "Displays version and copyright information."
msgstr ""
-#: ../gui/wxpython/menustrings.py:247
+#: ../gui/wxpython/menustrings.py:239
msgid "Map projections"
msgstr ""
-#: ../gui/wxpython/menustrings.py:248
+#: ../gui/wxpython/menustrings.py:240
msgid "Display map projection"
msgstr ""
-#: ../gui/wxpython/menustrings.py:249
+#: ../gui/wxpython/menustrings.py:241
msgid "Converts co-ordinate system descriptions (i.e. projection information) between various formats (including GRASS format)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:250
+#: ../gui/wxpython/menustrings.py:242
msgid "Manage projections"
msgstr ""
-#: ../gui/wxpython/menustrings.py:251
+#: ../gui/wxpython/menustrings.py:243
msgid "Prints or modifies GRASS projection information files (in various co-ordinate system descriptions). Can also be used to create new GRASS locations."
msgstr ""
-#: ../gui/wxpython/menustrings.py:252
+#: ../gui/wxpython/menustrings.py:244
msgid "Convert coordinates"
msgstr ""
-#: ../gui/wxpython/menustrings.py:253
+#: ../gui/wxpython/menustrings.py:245
msgid "Converts coordinates from one projection to another (cs2cs frontend)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:254
+#: ../gui/wxpython/menustrings.py:246
msgid "Addons extensions"
msgstr ""
-#: ../gui/wxpython/menustrings.py:255
+#: ../gui/wxpython/menustrings.py:247
msgid "Install extension from addons"
msgstr ""
-#: ../gui/wxpython/menustrings.py:256
+#: ../gui/wxpython/menustrings.py:248
msgid "Installs new extension from GRASS AddOns SVN repository."
msgstr ""
-#: ../gui/wxpython/menustrings.py:257
+#: ../gui/wxpython/menustrings.py:249
msgid "Manage installed extension"
msgstr ""
-#: ../gui/wxpython/menustrings.py:258
+#: ../gui/wxpython/menustrings.py:250
msgid "Updates or removes installed GRASS AddOns extension(s)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:259 ../gui/wxpython/menustrings.py:2027
+#: ../gui/wxpython/menustrings.py:251 ../gui/wxpython/menustrings.py:1952
msgid "Preferences"
msgstr ""
-#: ../gui/wxpython/menustrings.py:260
+#: ../gui/wxpython/menustrings.py:252
msgid "User GUI preferences (display font, commands, digitizer, etc.)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:261 ../gui/wxpython/menustrings.py:1204
+#: ../gui/wxpython/menustrings.py:253 ../gui/wxpython/menustrings.py:1159
msgid "&Raster"
msgstr ""
-#: ../gui/wxpython/menustrings.py:262 ../gui/wxpython/menustrings.py:1205
+#: ../gui/wxpython/menustrings.py:254 ../gui/wxpython/menustrings.py:1160
msgid "Develop raster map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:263 ../gui/wxpython/menustrings.py:1206
+#: ../gui/wxpython/menustrings.py:255 ../gui/wxpython/menustrings.py:1161
msgid "Compress/decompress"
msgstr ""
-#: ../gui/wxpython/menustrings.py:264 ../gui/wxpython/menustrings.py:1207
+#: ../gui/wxpython/menustrings.py:256 ../gui/wxpython/menustrings.py:1162
msgid "Compresses and decompresses raster maps."
msgstr ""
-#: ../gui/wxpython/menustrings.py:265 ../gui/wxpython/menustrings.py:1208
+#: ../gui/wxpython/menustrings.py:257 ../gui/wxpython/menustrings.py:1163
msgid "Region boundaries"
msgstr ""
-#: ../gui/wxpython/menustrings.py:266 ../gui/wxpython/menustrings.py:1209
+#: ../gui/wxpython/menustrings.py:258 ../gui/wxpython/menustrings.py:1164
msgid "Sets the boundary definitions for a raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:267 ../gui/wxpython/menustrings.py:1210
+#: ../gui/wxpython/menustrings.py:259 ../gui/wxpython/menustrings.py:1165
msgid "Manage NULL values"
msgstr ""
-#: ../gui/wxpython/menustrings.py:268 ../gui/wxpython/menustrings.py:1211
+#: ../gui/wxpython/menustrings.py:260 ../gui/wxpython/menustrings.py:1166
msgid "Manages NULL-values of given raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:269 ../gui/wxpython/menustrings.py:1212
+#: ../gui/wxpython/menustrings.py:261 ../gui/wxpython/menustrings.py:1167
msgid "Quantization"
msgstr ""
-#: ../gui/wxpython/menustrings.py:270 ../gui/wxpython/menustrings.py:1213
+#: ../gui/wxpython/menustrings.py:262 ../gui/wxpython/menustrings.py:1168
msgid "Produces the quantization file for a floating-point map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:271 ../gui/wxpython/menustrings.py:1214
+#: ../gui/wxpython/menustrings.py:263 ../gui/wxpython/menustrings.py:1169
msgid "Timestamp"
msgstr ""
-#: ../gui/wxpython/menustrings.py:272 ../gui/wxpython/menustrings.py:1215
+#: ../gui/wxpython/menustrings.py:264 ../gui/wxpython/menustrings.py:1170
msgid "Modifies a timestamp for a raster map. Print/add/remove a timestamp for a raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:273 ../gui/wxpython/menustrings.py:1216
+#: ../gui/wxpython/menustrings.py:265 ../gui/wxpython/menustrings.py:1171
msgid "Resample using aggregate statistics"
msgstr ""
-#: ../gui/wxpython/menustrings.py:274 ../gui/wxpython/menustrings.py:1217
+#: ../gui/wxpython/menustrings.py:266 ../gui/wxpython/menustrings.py:1172
msgid "Resamples raster map layers to a coarser grid using aggregation."
msgstr ""
-#: ../gui/wxpython/menustrings.py:275 ../gui/wxpython/menustrings.py:1218
+#: ../gui/wxpython/menustrings.py:267 ../gui/wxpython/menustrings.py:1173
msgid "Resample using multiple methods"
msgstr ""
-#: ../gui/wxpython/menustrings.py:276 ../gui/wxpython/menustrings.py:1219
+#: ../gui/wxpython/menustrings.py:268 ../gui/wxpython/menustrings.py:1174
msgid "Resamples raster map to a finer grid using interpolation."
msgstr ""
-#: ../gui/wxpython/menustrings.py:277 ../gui/wxpython/menustrings.py:1220
+#: ../gui/wxpython/menustrings.py:269 ../gui/wxpython/menustrings.py:1175
msgid "Resample using nearest neighbor"
msgstr ""
-#: ../gui/wxpython/menustrings.py:278 ../gui/wxpython/menustrings.py:1221
+#: ../gui/wxpython/menustrings.py:270 ../gui/wxpython/menustrings.py:1176
msgid "GRASS raster map layer data resampling capability."
msgstr ""
-#: ../gui/wxpython/menustrings.py:279 ../gui/wxpython/menustrings.py:1222
+#: ../gui/wxpython/menustrings.py:271 ../gui/wxpython/menustrings.py:1177
msgid "Resample using spline tension"
msgstr ""
-#: ../gui/wxpython/menustrings.py:280 ../gui/wxpython/menustrings.py:1223
+#: ../gui/wxpython/menustrings.py:272 ../gui/wxpython/menustrings.py:1178
msgid "Reinterpolates and optionally computes topographic analysis from input raster map to a new raster map (possibly with different resolution) using regularized spline with tension and smoothing."
msgstr ""
-#: ../gui/wxpython/menustrings.py:281 ../gui/wxpython/menustrings.py:1224
+#: ../gui/wxpython/menustrings.py:273 ../gui/wxpython/menustrings.py:1179
msgid "Resample using bspline"
msgstr ""
-#: ../gui/wxpython/menustrings.py:282 ../gui/wxpython/menustrings.py:1225
+#: ../gui/wxpython/menustrings.py:274 ../gui/wxpython/menustrings.py:1180
msgid "Performs bilinear or bicubic spline interpolation with Tykhonov regularization."
msgstr ""
-#: ../gui/wxpython/menustrings.py:283 ../gui/wxpython/menustrings.py:1226
+#: ../gui/wxpython/menustrings.py:275 ../gui/wxpython/menustrings.py:1181
msgid "Resample using analytic kernel"
msgstr ""
-#: ../gui/wxpython/menustrings.py:284 ../gui/wxpython/menustrings.py:1227
+#: ../gui/wxpython/menustrings.py:276 ../gui/wxpython/menustrings.py:1182
msgid "Resamples raster map layers using an analytic kernel."
msgstr ""
-#: ../gui/wxpython/menustrings.py:285 ../gui/wxpython/menustrings.py:569
-#: ../gui/wxpython/menustrings.py:1228 ../gui/wxpython/menustrings.py:1512
+#: ../gui/wxpython/menustrings.py:277 ../gui/wxpython/menustrings.py:561
+#: ../gui/wxpython/menustrings.py:1183 ../gui/wxpython/menustrings.py:1467
msgid "Support file maintenance"
msgstr ""
-#: ../gui/wxpython/menustrings.py:286 ../gui/wxpython/menustrings.py:1229
+#: ../gui/wxpython/menustrings.py:278 ../gui/wxpython/menustrings.py:1184
msgid "Allows creation and/or modification of raster map layer support files."
msgstr ""
-#: ../gui/wxpython/menustrings.py:287 ../gui/wxpython/menustrings.py:1230
+#: ../gui/wxpython/menustrings.py:279 ../gui/wxpython/menustrings.py:1185
msgid "Update map statistics"
msgstr ""
-#: ../gui/wxpython/menustrings.py:288 ../gui/wxpython/menustrings.py:1231
+#: ../gui/wxpython/menustrings.py:280 ../gui/wxpython/menustrings.py:1186
msgid "Update raster map statistics"
msgstr ""
-#: ../gui/wxpython/menustrings.py:291 ../gui/wxpython/menustrings.py:1234
+#: ../gui/wxpython/menustrings.py:283 ../gui/wxpython/menustrings.py:1189
msgid "Tiling"
msgstr ""
-#: ../gui/wxpython/menustrings.py:292 ../gui/wxpython/menustrings.py:1235
+#: ../gui/wxpython/menustrings.py:284 ../gui/wxpython/menustrings.py:1190
msgid "Produces tilings of the source projection for use in the destination region and projection."
msgstr ""
-#: ../gui/wxpython/menustrings.py:293 ../gui/wxpython/menustrings.py:588
-#: ../gui/wxpython/menustrings.py:1236 ../gui/wxpython/menustrings.py:1531
+#: ../gui/wxpython/menustrings.py:285 ../gui/wxpython/menustrings.py:580
+#: ../gui/wxpython/menustrings.py:1191 ../gui/wxpython/menustrings.py:1486
msgid "Manage colors"
msgstr ""
-#: ../gui/wxpython/menustrings.py:294 ../gui/wxpython/menustrings.py:589
-#: ../gui/wxpython/menustrings.py:1237 ../gui/wxpython/menustrings.py:1532
+#: ../gui/wxpython/menustrings.py:286 ../gui/wxpython/menustrings.py:581
+#: ../gui/wxpython/menustrings.py:1192 ../gui/wxpython/menustrings.py:1487
msgid "Color tables"
msgstr ""
-#: ../gui/wxpython/menustrings.py:295 ../gui/wxpython/menustrings.py:1238
+#: ../gui/wxpython/menustrings.py:287 ../gui/wxpython/menustrings.py:1193
msgid "Creates/modifies the color table associated with a raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:296 ../gui/wxpython/menustrings.py:1239
+#: ../gui/wxpython/menustrings.py:288 ../gui/wxpython/menustrings.py:1194
msgid "Color tables (stddev)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:297 ../gui/wxpython/menustrings.py:1240
+#: ../gui/wxpython/menustrings.py:289 ../gui/wxpython/menustrings.py:1195
msgid "Sets color rules based on stddev from a raster map's mean value."
msgstr ""
-#: ../gui/wxpython/menustrings.py:298 ../gui/wxpython/menustrings.py:591
-#: ../gui/wxpython/menustrings.py:1241 ../gui/wxpython/menustrings.py:1534
+#: ../gui/wxpython/menustrings.py:290 ../gui/wxpython/menustrings.py:583
+#: ../gui/wxpython/menustrings.py:1196 ../gui/wxpython/menustrings.py:1489
msgid "Manage color rules interactively"
msgstr ""
-#: ../gui/wxpython/menustrings.py:299 ../gui/wxpython/menustrings.py:1242
+#: ../gui/wxpython/menustrings.py:291 ../gui/wxpython/menustrings.py:1197
msgid "Interactive management of raster color tables."
msgstr ""
-#: ../gui/wxpython/menustrings.py:300 ../gui/wxpython/menustrings.py:593
-#: ../gui/wxpython/menustrings.py:1243 ../gui/wxpython/menustrings.py:1536
+#: ../gui/wxpython/menustrings.py:292 ../gui/wxpython/menustrings.py:585
+#: ../gui/wxpython/menustrings.py:1198 ../gui/wxpython/menustrings.py:1491
msgid "Export color table"
msgstr ""
-#: ../gui/wxpython/menustrings.py:301 ../gui/wxpython/menustrings.py:1244
+#: ../gui/wxpython/menustrings.py:293 ../gui/wxpython/menustrings.py:1199
msgid "Exports the color table associated with a raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:302 ../gui/wxpython/menustrings.py:1245
+#: ../gui/wxpython/menustrings.py:294 ../gui/wxpython/menustrings.py:1200
msgid "Blend 2 color rasters"
msgstr ""
-#: ../gui/wxpython/menustrings.py:303 ../gui/wxpython/menustrings.py:1246
+#: ../gui/wxpython/menustrings.py:295 ../gui/wxpython/menustrings.py:1201
msgid "Blends color components of two raster maps by a given ratio."
msgstr ""
-#: ../gui/wxpython/menustrings.py:304 ../gui/wxpython/menustrings.py:1247
+#: ../gui/wxpython/menustrings.py:296 ../gui/wxpython/menustrings.py:1202
msgid "Create RGB"
msgstr ""
-#: ../gui/wxpython/menustrings.py:305 ../gui/wxpython/menustrings.py:1248
+#: ../gui/wxpython/menustrings.py:297 ../gui/wxpython/menustrings.py:1203
msgid "Combines red, green and blue raster maps into a single composite raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:306 ../gui/wxpython/menustrings.py:759
-#: ../gui/wxpython/menustrings.py:1249 ../gui/wxpython/menustrings.py:1702
+#: ../gui/wxpython/menustrings.py:298 ../gui/wxpython/menustrings.py:736
+#: ../gui/wxpython/menustrings.py:1204 ../gui/wxpython/menustrings.py:1642
msgid "RGB to HIS"
msgstr ""
-#: ../gui/wxpython/menustrings.py:307 ../gui/wxpython/menustrings.py:1250
+#: ../gui/wxpython/menustrings.py:299 ../gui/wxpython/menustrings.py:1205
msgid "Generates red, green and blue (RGB) raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers."
msgstr ""
-#: ../gui/wxpython/menustrings.py:308 ../gui/wxpython/menustrings.py:1251
+#: ../gui/wxpython/menustrings.py:300 ../gui/wxpython/menustrings.py:1206
msgid "Query raster maps"
msgstr ""
-#: ../gui/wxpython/menustrings.py:309 ../gui/wxpython/menustrings.py:1252
+#: ../gui/wxpython/menustrings.py:301 ../gui/wxpython/menustrings.py:1207
msgid "Query values by coordinates"
msgstr ""
-#: ../gui/wxpython/menustrings.py:310 ../gui/wxpython/menustrings.py:1253
+#: ../gui/wxpython/menustrings.py:302 ../gui/wxpython/menustrings.py:1208
msgid "Queries raster maps on their category values and category labels."
msgstr ""
-#: ../gui/wxpython/menustrings.py:311 ../gui/wxpython/menustrings.py:1254
+#: ../gui/wxpython/menustrings.py:303 ../gui/wxpython/menustrings.py:1209
msgid "Query colors by value"
msgstr ""
-#: ../gui/wxpython/menustrings.py:312 ../gui/wxpython/menustrings.py:1255
+#: ../gui/wxpython/menustrings.py:304 ../gui/wxpython/menustrings.py:1210
msgid "Queries colors for a raster map layer."
msgstr ""
-#: ../gui/wxpython/menustrings.py:320 ../gui/wxpython/menustrings.py:1263
+#: ../gui/wxpython/menustrings.py:312 ../gui/wxpython/menustrings.py:1218
msgid "Raster buffers and distance"
msgstr ""
-#: ../gui/wxpython/menustrings.py:321 ../gui/wxpython/menustrings.py:1264
+#: ../gui/wxpython/menustrings.py:313 ../gui/wxpython/menustrings.py:1219
msgid "Buffer rasters"
msgstr ""
-#: ../gui/wxpython/menustrings.py:322 ../gui/wxpython/menustrings.py:1265
+#: ../gui/wxpython/menustrings.py:314 ../gui/wxpython/menustrings.py:1220
msgid "Creates a raster map showing buffer zones surrounding cells that contain non-NULL category values."
msgstr ""
-#: ../gui/wxpython/menustrings.py:323 ../gui/wxpython/menustrings.py:1266
+#: ../gui/wxpython/menustrings.py:315 ../gui/wxpython/menustrings.py:1221
msgid "Concentric circles"
msgstr ""
-#: ../gui/wxpython/menustrings.py:324 ../gui/wxpython/menustrings.py:1267
+#: ../gui/wxpython/menustrings.py:316 ../gui/wxpython/menustrings.py:1222
msgid "Creates a raster map containing concentric rings around a given point."
msgstr ""
-#: ../gui/wxpython/menustrings.py:325 ../gui/wxpython/menustrings.py:1268
+#: ../gui/wxpython/menustrings.py:317 ../gui/wxpython/menustrings.py:1223
msgid "Closest points"
msgstr ""
-#: ../gui/wxpython/menustrings.py:326 ../gui/wxpython/menustrings.py:1269
+#: ../gui/wxpython/menustrings.py:318 ../gui/wxpython/menustrings.py:1224
msgid "Locates the closest points between objects in two raster maps."
msgstr ""
-#: ../gui/wxpython/menustrings.py:327 ../gui/wxpython/menustrings.py:1270
+#: ../gui/wxpython/menustrings.py:319 ../gui/wxpython/menustrings.py:1225
msgid "Grow by one cell"
msgstr ""
-#: ../gui/wxpython/menustrings.py:328 ../gui/wxpython/menustrings.py:391
-#: ../gui/wxpython/menustrings.py:1271 ../gui/wxpython/menustrings.py:1334
+#: ../gui/wxpython/menustrings.py:320 ../gui/wxpython/menustrings.py:383
+#: ../gui/wxpython/menustrings.py:1226 ../gui/wxpython/menustrings.py:1289
msgid "Generates a raster map layer with contiguous areas grown by one cell."
msgstr ""
-#: ../gui/wxpython/menustrings.py:329 ../gui/wxpython/menustrings.py:383
-#: ../gui/wxpython/menustrings.py:1272 ../gui/wxpython/menustrings.py:1326
+#: ../gui/wxpython/menustrings.py:321 ../gui/wxpython/menustrings.py:375
+#: ../gui/wxpython/menustrings.py:1227 ../gui/wxpython/menustrings.py:1281
msgid "Distance to features"
msgstr ""
-#: ../gui/wxpython/menustrings.py:330 ../gui/wxpython/menustrings.py:384
-#: ../gui/wxpython/menustrings.py:1273 ../gui/wxpython/menustrings.py:1327
+#: ../gui/wxpython/menustrings.py:322 ../gui/wxpython/menustrings.py:376
+#: ../gui/wxpython/menustrings.py:1228 ../gui/wxpython/menustrings.py:1282
msgid "Generates a raster map containing distances to nearest raster features."
msgstr ""
-#: ../gui/wxpython/menustrings.py:332 ../gui/wxpython/menustrings.py:1275
+#: ../gui/wxpython/menustrings.py:324 ../gui/wxpython/menustrings.py:1230
msgid "Creates a MASK for limiting raster operation."
msgstr ""
-#: ../gui/wxpython/menustrings.py:333 ../gui/wxpython/menustrings.py:334
-#: ../gui/wxpython/menustrings.py:1276 ../gui/wxpython/menustrings.py:1277
+#: ../gui/wxpython/menustrings.py:325 ../gui/wxpython/menustrings.py:326
+#: ../gui/wxpython/menustrings.py:1231 ../gui/wxpython/menustrings.py:1232
msgid "Raster map calculator"
msgstr ""
-#: ../gui/wxpython/menustrings.py:335 ../gui/wxpython/menustrings.py:1278
+#: ../gui/wxpython/menustrings.py:327 ../gui/wxpython/menustrings.py:1233
msgid "Neighborhood analysis"
msgstr ""
-#: ../gui/wxpython/menustrings.py:337 ../gui/wxpython/menustrings.py:1280
+#: ../gui/wxpython/menustrings.py:329 ../gui/wxpython/menustrings.py:1235
msgid "Makes each cell category value a function of the category values assigned to the cells around it, and stores new cell values in an output raster map layer."
msgstr ""
-#: ../gui/wxpython/menustrings.py:338 ../gui/wxpython/menustrings.py:1281
+#: ../gui/wxpython/menustrings.py:330 ../gui/wxpython/menustrings.py:1236
msgid "Neighborhood points"
msgstr ""
-#: ../gui/wxpython/menustrings.py:339 ../gui/wxpython/menustrings.py:1282
+#: ../gui/wxpython/menustrings.py:331 ../gui/wxpython/menustrings.py:1237
msgid "Neighborhood analysis tool for vector point maps. Makes each cell value a function of the attribute values assigned to the vector points or centroids around it, and stores new cell values in an output raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:340 ../gui/wxpython/menustrings.py:1283
+#: ../gui/wxpython/menustrings.py:332 ../gui/wxpython/menustrings.py:1238
msgid "Overlay rasters"
msgstr ""
-#: ../gui/wxpython/menustrings.py:341 ../gui/wxpython/menustrings.py:1284
+#: ../gui/wxpython/menustrings.py:333 ../gui/wxpython/menustrings.py:1239
msgid "Cross product"
msgstr ""
-#: ../gui/wxpython/menustrings.py:342 ../gui/wxpython/menustrings.py:1285
+#: ../gui/wxpython/menustrings.py:334 ../gui/wxpython/menustrings.py:1240
msgid "Creates a cross product of the category values from multiple raster map layers."
msgstr ""
-#: ../gui/wxpython/menustrings.py:343 ../gui/wxpython/menustrings.py:1286
+#: ../gui/wxpython/menustrings.py:335 ../gui/wxpython/menustrings.py:1241
msgid "Patch raster maps"
msgstr ""
-#: ../gui/wxpython/menustrings.py:344 ../gui/wxpython/menustrings.py:1287
+#: ../gui/wxpython/menustrings.py:336 ../gui/wxpython/menustrings.py:1242
msgid "Creates a composite raster map layer by using known category values from one (or more) map layer(s) to fill in areas of \"no data\" in another map layer."
msgstr ""
-#: ../gui/wxpython/menustrings.py:345 ../gui/wxpython/menustrings.py:1288
+#: ../gui/wxpython/menustrings.py:337 ../gui/wxpython/menustrings.py:1243
msgid "Raster series aggregation"
msgstr ""
-#: ../gui/wxpython/menustrings.py:346 ../gui/wxpython/menustrings.py:1289
+#: ../gui/wxpython/menustrings.py:338 ../gui/wxpython/menustrings.py:1244
msgid "Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers."
msgstr ""
-#: ../gui/wxpython/menustrings.py:347 ../gui/wxpython/menustrings.py:1290
+#: ../gui/wxpython/menustrings.py:339 ../gui/wxpython/menustrings.py:1245
msgid "Raster series accumulation"
msgstr ""
-#: ../gui/wxpython/menustrings.py:348 ../gui/wxpython/menustrings.py:1291
+#: ../gui/wxpython/menustrings.py:340 ../gui/wxpython/menustrings.py:1246
msgid "Makes each output cell value a accumulationfunction of the values assigned to the corresponding cells in the input raster map layers."
msgstr ""
-#: ../gui/wxpython/menustrings.py:349 ../gui/wxpython/menustrings.py:1292
+#: ../gui/wxpython/menustrings.py:341 ../gui/wxpython/menustrings.py:1247
msgid "Statistical overlay"
msgstr ""
-#: ../gui/wxpython/menustrings.py:350 ../gui/wxpython/menustrings.py:1293
+#: ../gui/wxpython/menustrings.py:342 ../gui/wxpython/menustrings.py:1248
msgid "Calculates category or object oriented statistics (accumulator-based statistics)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:351 ../gui/wxpython/menustrings.py:1294
+#: ../gui/wxpython/menustrings.py:343 ../gui/wxpython/menustrings.py:1249
msgid "Quantiles overlay"
msgstr ""
-#: ../gui/wxpython/menustrings.py:352 ../gui/wxpython/menustrings.py:1295
+#: ../gui/wxpython/menustrings.py:344 ../gui/wxpython/menustrings.py:1250
msgid "Compute category quantiles using two passes."
msgstr ""
-#: ../gui/wxpython/menustrings.py:353 ../gui/wxpython/menustrings.py:1296
+#: ../gui/wxpython/menustrings.py:345 ../gui/wxpython/menustrings.py:1251
msgid "Solar radiance and shadows"
msgstr ""
-#: ../gui/wxpython/menustrings.py:354 ../gui/wxpython/menustrings.py:1297
+#: ../gui/wxpython/menustrings.py:346 ../gui/wxpython/menustrings.py:1252
msgid "LatLong map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:355 ../gui/wxpython/menustrings.py:1298
+#: ../gui/wxpython/menustrings.py:347 ../gui/wxpython/menustrings.py:1253
msgid "Creates a latitude/longitude raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:356 ../gui/wxpython/menustrings.py:1299
+#: ../gui/wxpython/menustrings.py:348 ../gui/wxpython/menustrings.py:1254
msgid "Solar irradiance and irradiation"
msgstr ""
-#: ../gui/wxpython/menustrings.py:357 ../gui/wxpython/menustrings.py:1300
+#: ../gui/wxpython/menustrings.py:349 ../gui/wxpython/menustrings.py:1255
msgid "Solar irradiance and irradiation model. Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in the map history file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
msgstr ""
-#: ../gui/wxpython/menustrings.py:358 ../gui/wxpython/menustrings.py:1301
+#: ../gui/wxpython/menustrings.py:350 ../gui/wxpython/menustrings.py:1256
msgid "Shadows map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:359 ../gui/wxpython/menustrings.py:1302
+#: ../gui/wxpython/menustrings.py:351 ../gui/wxpython/menustrings.py:1257
msgid "Calculates cast shadow areas from sun position and elevation raster map. Either exact sun position (A) is specified, or date/time to calculate the sun position (B) by r.sunmask itself."
msgstr ""
-#: ../gui/wxpython/menustrings.py:360 ../gui/wxpython/menustrings.py:1303
+#: ../gui/wxpython/menustrings.py:352 ../gui/wxpython/menustrings.py:1258
msgid "Sunshine hours and solar angles"
msgstr ""
-#: ../gui/wxpython/menustrings.py:361 ../gui/wxpython/menustrings.py:1304
+#: ../gui/wxpython/menustrings.py:353 ../gui/wxpython/menustrings.py:1259
msgid "Calculates solar elevation, solar azimuth, and sun hours. Solar elevation: the angle between the direction of the geometric center of the sun's apparent disk and the (idealized) horizon. Solar azimuth: the angle from due north in clockwise direction."
msgstr ""
-#: ../gui/wxpython/menustrings.py:362 ../gui/wxpython/menustrings.py:1305
+#: ../gui/wxpython/menustrings.py:354 ../gui/wxpython/menustrings.py:1260
msgid "Terrain analysis"
msgstr ""
-#: ../gui/wxpython/menustrings.py:363 ../gui/wxpython/menustrings.py:1306
+#: ../gui/wxpython/menustrings.py:355 ../gui/wxpython/menustrings.py:1261
msgid "Generate contour lines"
msgstr ""
-#: ../gui/wxpython/menustrings.py:364 ../gui/wxpython/menustrings.py:1307
+#: ../gui/wxpython/menustrings.py:356 ../gui/wxpython/menustrings.py:1262
msgid "Produces a vector map of specified contours from a raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:365 ../gui/wxpython/menustrings.py:1308
+#: ../gui/wxpython/menustrings.py:357 ../gui/wxpython/menustrings.py:1263
msgid "Cost surface"
msgstr ""
-#: ../gui/wxpython/menustrings.py:366 ../gui/wxpython/menustrings.py:1309
+#: ../gui/wxpython/menustrings.py:358 ../gui/wxpython/menustrings.py:1264
msgid "Creates a raster map showing the cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
msgstr ""
-#: ../gui/wxpython/menustrings.py:367 ../gui/wxpython/menustrings.py:1310
+#: ../gui/wxpython/menustrings.py:359 ../gui/wxpython/menustrings.py:1265
msgid "Cumulative movement costs"
msgstr ""
-#: ../gui/wxpython/menustrings.py:368 ../gui/wxpython/menustrings.py:1311
+#: ../gui/wxpython/menustrings.py:360 ../gui/wxpython/menustrings.py:1266
msgid "Creates a raster map showing the anisotropic cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
msgstr ""
-#: ../gui/wxpython/menustrings.py:369 ../gui/wxpython/menustrings.py:1312
+#: ../gui/wxpython/menustrings.py:361 ../gui/wxpython/menustrings.py:1267
msgid "Least cost route or flow"
msgstr ""
-#: ../gui/wxpython/menustrings.py:370 ../gui/wxpython/menustrings.py:1313
+#: ../gui/wxpython/menustrings.py:362 ../gui/wxpython/menustrings.py:1268
msgid "Traces a flow through an elevation model or cost surface on a raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:371 ../gui/wxpython/menustrings.py:1314
+#: ../gui/wxpython/menustrings.py:363 ../gui/wxpython/menustrings.py:1269
msgid "Compute shaded relief"
msgstr ""
-#: ../gui/wxpython/menustrings.py:372 ../gui/wxpython/menustrings.py:1315
+#: ../gui/wxpython/menustrings.py:364 ../gui/wxpython/menustrings.py:1270
msgid "Creates shaded relief map from an elevation map (DEM). "
msgstr ""
-#: ../gui/wxpython/menustrings.py:373 ../gui/wxpython/menustrings.py:1316
+#: ../gui/wxpython/menustrings.py:365 ../gui/wxpython/menustrings.py:1271
msgid "Apply shade to raster"
msgstr ""
-#: ../gui/wxpython/menustrings.py:374 ../gui/wxpython/menustrings.py:1317
+#: ../gui/wxpython/menustrings.py:366 ../gui/wxpython/menustrings.py:1272
msgid "Drapes a color raster over an shaded relief or aspect map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:375 ../gui/wxpython/menustrings.py:1318
+#: ../gui/wxpython/menustrings.py:367 ../gui/wxpython/menustrings.py:1273
msgid "Slope and aspect"
msgstr ""
-#: ../gui/wxpython/menustrings.py:376 ../gui/wxpython/menustrings.py:1319
+#: ../gui/wxpython/menustrings.py:368 ../gui/wxpython/menustrings.py:1274
msgid "Generates raster maps of slope, aspect, curvatures and partial derivatives from an elevation raster map. Aspect is calculated counterclockwise from east."
msgstr ""
-#: ../gui/wxpython/menustrings.py:377 ../gui/wxpython/menustrings.py:1320
+#: ../gui/wxpython/menustrings.py:369 ../gui/wxpython/menustrings.py:1275
msgid "Terrain parameters"
msgstr ""
-#: ../gui/wxpython/menustrings.py:378 ../gui/wxpython/menustrings.py:1321
+#: ../gui/wxpython/menustrings.py:370 ../gui/wxpython/menustrings.py:1276
msgid "Extracts terrain parameters from a DEM. Uses a multi-scale approach by taking fitting quadratic parameters to any size window (via least squares)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:379 ../gui/wxpython/menustrings.py:1322
+#: ../gui/wxpython/menustrings.py:371 ../gui/wxpython/menustrings.py:1277
msgid "Textural features"
msgstr ""
-#: ../gui/wxpython/menustrings.py:380 ../gui/wxpython/menustrings.py:1323
+#: ../gui/wxpython/menustrings.py:372 ../gui/wxpython/menustrings.py:1278
msgid "Generate images with textural features from a raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:381 ../gui/wxpython/menustrings.py:1324
+#: ../gui/wxpython/menustrings.py:373 ../gui/wxpython/menustrings.py:1279
msgid "Visibility"
msgstr ""
-#: ../gui/wxpython/menustrings.py:382 ../gui/wxpython/menustrings.py:1325
+#: ../gui/wxpython/menustrings.py:374 ../gui/wxpython/menustrings.py:1280
msgid "Computes the viewshed of a point on an elevation raster map. Default format: NULL (invisible), vertical angle wrt viewpoint (visible)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:385 ../gui/wxpython/menustrings.py:1328
+#: ../gui/wxpython/menustrings.py:377 ../gui/wxpython/menustrings.py:1283
msgid "Horizon angle"
msgstr ""
-#: ../gui/wxpython/menustrings.py:386 ../gui/wxpython/menustrings.py:1329
+#: ../gui/wxpython/menustrings.py:378 ../gui/wxpython/menustrings.py:1284
msgid "Computes horizon angle height from a digital elevation model. The module has two different modes of operation: 1. Computes the entire horizon around a single point whose coordinates are given with the 'coord' option. The horizon height (in radians). 2. Computes one or more raster maps of the horizon height in a single direction. The input for this is the angle (in degrees), which is measured counterclockwise with east=0, north=90 etc. The output is the horizon height in radians."
msgstr ""
-#: ../gui/wxpython/menustrings.py:387 ../gui/wxpython/menustrings.py:1330
+#: ../gui/wxpython/menustrings.py:379 ../gui/wxpython/menustrings.py:1285
msgid "Transform features"
msgstr ""
-#: ../gui/wxpython/menustrings.py:388 ../gui/wxpython/menustrings.py:1331
+#: ../gui/wxpython/menustrings.py:380 ../gui/wxpython/menustrings.py:1286
msgid "Clump"
msgstr ""
-#: ../gui/wxpython/menustrings.py:389 ../gui/wxpython/menustrings.py:1332
+#: ../gui/wxpython/menustrings.py:381 ../gui/wxpython/menustrings.py:1287
msgid "Recategorizes data in a raster map by grouping cells that form physically discrete areas into unique categories."
msgstr ""
-#: ../gui/wxpython/menustrings.py:390 ../gui/wxpython/menustrings.py:1333
+#: ../gui/wxpython/menustrings.py:382 ../gui/wxpython/menustrings.py:1288
msgid "Grow"
msgstr ""
-#: ../gui/wxpython/menustrings.py:392 ../gui/wxpython/menustrings.py:1335
+#: ../gui/wxpython/menustrings.py:384 ../gui/wxpython/menustrings.py:1290
msgid "Thin"
msgstr ""
-#: ../gui/wxpython/menustrings.py:393 ../gui/wxpython/menustrings.py:1336
+#: ../gui/wxpython/menustrings.py:385 ../gui/wxpython/menustrings.py:1291
msgid "Thins non-null cells that denote linear features in a raster map layer."
msgstr ""
-#: ../gui/wxpython/menustrings.py:394 ../gui/wxpython/menustrings.py:1337
+#: ../gui/wxpython/menustrings.py:386 ../gui/wxpython/menustrings.py:1292
msgid "Hydrologic modeling"
msgstr ""
-#: ../gui/wxpython/menustrings.py:395 ../gui/wxpython/menustrings.py:1338
+#: ../gui/wxpython/menustrings.py:387 ../gui/wxpython/menustrings.py:1293
msgid "Carve stream channels"
msgstr ""
-#: ../gui/wxpython/menustrings.py:396 ../gui/wxpython/menustrings.py:1339
+#: ../gui/wxpython/menustrings.py:388 ../gui/wxpython/menustrings.py:1294
msgid "Generates stream channels. Takes vector stream data, transforms it to raster and subtracts depth from the output DEM."
msgstr ""
-#: ../gui/wxpython/menustrings.py:397 ../gui/wxpython/menustrings.py:1340
+#: ../gui/wxpython/menustrings.py:389 ../gui/wxpython/menustrings.py:1295
msgid "Fill lake"
msgstr ""
-#: ../gui/wxpython/menustrings.py:398 ../gui/wxpython/menustrings.py:1341
+#: ../gui/wxpython/menustrings.py:390 ../gui/wxpython/menustrings.py:1296
msgid "Fills lake at given point to given level."
msgstr ""
-#: ../gui/wxpython/menustrings.py:399 ../gui/wxpython/menustrings.py:1342
+#: ../gui/wxpython/menustrings.py:391 ../gui/wxpython/menustrings.py:1297
msgid "Depressionless map and flowlines"
msgstr ""
-#: ../gui/wxpython/menustrings.py:400 ../gui/wxpython/menustrings.py:1343
+#: ../gui/wxpython/menustrings.py:392 ../gui/wxpython/menustrings.py:1298
msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:401 ../gui/wxpython/menustrings.py:1344
+#: ../gui/wxpython/menustrings.py:393 ../gui/wxpython/menustrings.py:1299
msgid "Flow accumulation"
msgstr ""
-#: ../gui/wxpython/menustrings.py:402 ../gui/wxpython/menustrings.py:1345
+#: ../gui/wxpython/menustrings.py:394 ../gui/wxpython/menustrings.py:1300
msgid "Performs flow computation for massive grids. Float version."
msgstr ""
-#: ../gui/wxpython/menustrings.py:403 ../gui/wxpython/menustrings.py:1346
+#: ../gui/wxpython/menustrings.py:395 ../gui/wxpython/menustrings.py:1301
msgid "Flow lines"
msgstr ""
-#: ../gui/wxpython/menustrings.py:404 ../gui/wxpython/menustrings.py:1347
+#: ../gui/wxpython/menustrings.py:396 ../gui/wxpython/menustrings.py:1302
msgid "Constructs flowlines. Computes flowlines, flowpath lengths, and flowaccumulation (contributing areas) from a elevation raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:405 ../gui/wxpython/menustrings.py:1348
+#: ../gui/wxpython/menustrings.py:397 ../gui/wxpython/menustrings.py:1303
msgid "Watershed analysis"
msgstr ""
-#: ../gui/wxpython/menustrings.py:406 ../gui/wxpython/menustrings.py:1349
+#: ../gui/wxpython/menustrings.py:398 ../gui/wxpython/menustrings.py:1304
msgid "Calculates hydrological parameters and RUSLE factors."
msgstr ""
-#: ../gui/wxpython/menustrings.py:407 ../gui/wxpython/menustrings.py:1350
+#: ../gui/wxpython/menustrings.py:399 ../gui/wxpython/menustrings.py:1305
msgid "Watershed subbasins"
msgstr ""
-#: ../gui/wxpython/menustrings.py:408 ../gui/wxpython/menustrings.py:1351
+#: ../gui/wxpython/menustrings.py:400 ../gui/wxpython/menustrings.py:1306
msgid "Generates watershed subbasins raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:409 ../gui/wxpython/menustrings.py:1352
+#: ../gui/wxpython/menustrings.py:401 ../gui/wxpython/menustrings.py:1307
msgid "Watershed basin creation"
msgstr ""
-#: ../gui/wxpython/menustrings.py:410 ../gui/wxpython/menustrings.py:1353
+#: ../gui/wxpython/menustrings.py:402 ../gui/wxpython/menustrings.py:1308
msgid "Creates watershed basins from a drainage direction map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:411 ../gui/wxpython/menustrings.py:1354
+#: ../gui/wxpython/menustrings.py:403 ../gui/wxpython/menustrings.py:1309
msgid "Extraction of stream networks"
msgstr ""
-#: ../gui/wxpython/menustrings.py:412 ../gui/wxpython/menustrings.py:1355
+#: ../gui/wxpython/menustrings.py:404 ../gui/wxpython/menustrings.py:1310
msgid "Performs stream network extraction."
msgstr ""
-#: ../gui/wxpython/menustrings.py:413 ../gui/wxpython/menustrings.py:1356
+#: ../gui/wxpython/menustrings.py:405 ../gui/wxpython/menustrings.py:1311
msgid "SIMWE Overland flow modeling"
msgstr ""
-#: ../gui/wxpython/menustrings.py:414 ../gui/wxpython/menustrings.py:1357
+#: ../gui/wxpython/menustrings.py:406 ../gui/wxpython/menustrings.py:1312
msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:415 ../gui/wxpython/menustrings.py:1358
+#: ../gui/wxpython/menustrings.py:407 ../gui/wxpython/menustrings.py:1313
msgid "SIMWE Sediment flux modeling"
msgstr ""
-#: ../gui/wxpython/menustrings.py:416 ../gui/wxpython/menustrings.py:1359
+#: ../gui/wxpython/menustrings.py:408 ../gui/wxpython/menustrings.py:1314
msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:417 ../gui/wxpython/menustrings.py:1360
+#: ../gui/wxpython/menustrings.py:409 ../gui/wxpython/menustrings.py:1315
msgid "Topographic index map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:418 ../gui/wxpython/menustrings.py:1361
+#: ../gui/wxpython/menustrings.py:410 ../gui/wxpython/menustrings.py:1316
msgid "Creates a topographic index (wetness index) raster map from an elevation raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:419 ../gui/wxpython/menustrings.py:1362
+#: ../gui/wxpython/menustrings.py:411 ../gui/wxpython/menustrings.py:1317
msgid "TOPMODEL simulation"
msgstr ""
-#: ../gui/wxpython/menustrings.py:420 ../gui/wxpython/menustrings.py:1363
+#: ../gui/wxpython/menustrings.py:412 ../gui/wxpython/menustrings.py:1318
msgid "Simulates TOPMODEL which is a physically based hydrologic model."
msgstr ""
-#: ../gui/wxpython/menustrings.py:421 ../gui/wxpython/menustrings.py:1364
+#: ../gui/wxpython/menustrings.py:413 ../gui/wxpython/menustrings.py:1319
msgid "USLE K-factor"
msgstr ""
-#: ../gui/wxpython/menustrings.py:422 ../gui/wxpython/menustrings.py:1365
+#: ../gui/wxpython/menustrings.py:414 ../gui/wxpython/menustrings.py:1320
msgid "Computes USLE Soil Erodibility Factor (K)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:423 ../gui/wxpython/menustrings.py:1366
+#: ../gui/wxpython/menustrings.py:415 ../gui/wxpython/menustrings.py:1321
msgid "USLE R-factor"
msgstr ""
-#: ../gui/wxpython/menustrings.py:424 ../gui/wxpython/menustrings.py:1367
+#: ../gui/wxpython/menustrings.py:416 ../gui/wxpython/menustrings.py:1322
msgid "Computes USLE R factor, Rainfall erosivity index."
msgstr ""
-#: ../gui/wxpython/menustrings.py:425 ../gui/wxpython/menustrings.py:867
-#: ../gui/wxpython/menustrings.py:1368 ../gui/wxpython/menustrings.py:1810
+#: ../gui/wxpython/menustrings.py:417 ../gui/wxpython/menustrings.py:842
+#: ../gui/wxpython/menustrings.py:1323 ../gui/wxpython/menustrings.py:1748
msgid "Groundwater modeling"
msgstr ""
-#: ../gui/wxpython/menustrings.py:426 ../gui/wxpython/menustrings.py:1369
+#: ../gui/wxpython/menustrings.py:418 ../gui/wxpython/menustrings.py:1324
msgid "Groundwater flow"
msgstr ""
-#: ../gui/wxpython/menustrings.py:427 ../gui/wxpython/menustrings.py:1370
+#: ../gui/wxpython/menustrings.py:419 ../gui/wxpython/menustrings.py:1325
msgid "Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions."
msgstr ""
-#: ../gui/wxpython/menustrings.py:428 ../gui/wxpython/menustrings.py:1371
+#: ../gui/wxpython/menustrings.py:420 ../gui/wxpython/menustrings.py:1326
msgid "Groundwater solute transport"
msgstr ""
-#: ../gui/wxpython/menustrings.py:429 ../gui/wxpython/menustrings.py:1372
+#: ../gui/wxpython/menustrings.py:421 ../gui/wxpython/menustrings.py:1327
msgid "Numerical calculation program for transient, confined and unconfined solute transport in two dimensions"
msgstr ""
-#: ../gui/wxpython/menustrings.py:430 ../gui/wxpython/menustrings.py:1373
+#: ../gui/wxpython/menustrings.py:422 ../gui/wxpython/menustrings.py:1328
msgid "Landscape patch analysis"
msgstr ""
-#: ../gui/wxpython/menustrings.py:431 ../gui/wxpython/menustrings.py:1374
+#: ../gui/wxpython/menustrings.py:423 ../gui/wxpython/menustrings.py:1329
msgid "Set up sampling and analysis framework"
msgstr ""
-#: ../gui/wxpython/menustrings.py:432 ../gui/wxpython/menustrings.py:1375
+#: ../gui/wxpython/menustrings.py:424 ../gui/wxpython/menustrings.py:1330
msgid "Configuration editor for r.li.'index'"
msgstr ""
-#: ../gui/wxpython/menustrings.py:433 ../gui/wxpython/menustrings.py:1376
+#: ../gui/wxpython/menustrings.py:425 ../gui/wxpython/menustrings.py:1331
msgid "Edge density"
msgstr ""
-#: ../gui/wxpython/menustrings.py:434 ../gui/wxpython/menustrings.py:1377
+#: ../gui/wxpython/menustrings.py:426 ../gui/wxpython/menustrings.py:1332
msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
msgstr ""
-#: ../gui/wxpython/menustrings.py:435 ../gui/wxpython/menustrings.py:1378
+#: ../gui/wxpython/menustrings.py:427 ../gui/wxpython/menustrings.py:1333
msgid "Contrast weighted edge density"
msgstr ""
-#: ../gui/wxpython/menustrings.py:436 ../gui/wxpython/menustrings.py:1379
+#: ../gui/wxpython/menustrings.py:428 ../gui/wxpython/menustrings.py:1334
msgid "Calculates contrast weighted edge density index on a raster map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:437 ../gui/wxpython/menustrings.py:1380
+#: ../gui/wxpython/menustrings.py:429 ../gui/wxpython/menustrings.py:1335
msgid "Patch area mean"
msgstr ""
-#: ../gui/wxpython/menustrings.py:438 ../gui/wxpython/menustrings.py:1381
+#: ../gui/wxpython/menustrings.py:430 ../gui/wxpython/menustrings.py:1336
msgid "Calculates mean patch size index on a raster map, using a 4 neighbour algorithm"
msgstr ""
-#: ../gui/wxpython/menustrings.py:439 ../gui/wxpython/menustrings.py:1382
+#: ../gui/wxpython/menustrings.py:431 ../gui/wxpython/menustrings.py:1337
msgid "Patch area range"
msgstr ""
-#: ../gui/wxpython/menustrings.py:440 ../gui/wxpython/menustrings.py:1383
+#: ../gui/wxpython/menustrings.py:432 ../gui/wxpython/menustrings.py:1338
msgid "Calculates range of patch area size on a raster map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:441 ../gui/wxpython/menustrings.py:1384
+#: ../gui/wxpython/menustrings.py:433 ../gui/wxpython/menustrings.py:1339
msgid "Patch area Std Dev"
msgstr ""
-#: ../gui/wxpython/menustrings.py:442 ../gui/wxpython/menustrings.py:1385
+#: ../gui/wxpython/menustrings.py:434 ../gui/wxpython/menustrings.py:1340
msgid "Calculates standard deviation of patch area a raster map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:443 ../gui/wxpython/menustrings.py:1386
+#: ../gui/wxpython/menustrings.py:435 ../gui/wxpython/menustrings.py:1341
msgid "Patch area Coeff Var"
msgstr ""
-#: ../gui/wxpython/menustrings.py:444 ../gui/wxpython/menustrings.py:1387
+#: ../gui/wxpython/menustrings.py:436 ../gui/wxpython/menustrings.py:1342
msgid "Calculates coefficient of variation of patch area on a raster map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:445 ../gui/wxpython/menustrings.py:1388
+#: ../gui/wxpython/menustrings.py:437 ../gui/wxpython/menustrings.py:1343
msgid "Patch density"
msgstr ""
-#: ../gui/wxpython/menustrings.py:446 ../gui/wxpython/menustrings.py:1389
+#: ../gui/wxpython/menustrings.py:438 ../gui/wxpython/menustrings.py:1344
msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
msgstr ""
-#: ../gui/wxpython/menustrings.py:447 ../gui/wxpython/menustrings.py:1390
+#: ../gui/wxpython/menustrings.py:439 ../gui/wxpython/menustrings.py:1345
msgid "Patch number"
msgstr ""
-#: ../gui/wxpython/menustrings.py:448 ../gui/wxpython/menustrings.py:1391
+#: ../gui/wxpython/menustrings.py:440 ../gui/wxpython/menustrings.py:1346
msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
msgstr ""
-#: ../gui/wxpython/menustrings.py:449 ../gui/wxpython/menustrings.py:1392
+#: ../gui/wxpython/menustrings.py:441 ../gui/wxpython/menustrings.py:1347
msgid "Dominance's diversity"
msgstr ""
-#: ../gui/wxpython/menustrings.py:450 ../gui/wxpython/menustrings.py:1393
+#: ../gui/wxpython/menustrings.py:442 ../gui/wxpython/menustrings.py:1348
msgid "Calculates dominance's diversity index on a raster map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:451 ../gui/wxpython/menustrings.py:1394
+#: ../gui/wxpython/menustrings.py:443 ../gui/wxpython/menustrings.py:1349
msgid "Shannon's diversity"
msgstr ""
-#: ../gui/wxpython/menustrings.py:452 ../gui/wxpython/menustrings.py:1395
+#: ../gui/wxpython/menustrings.py:444 ../gui/wxpython/menustrings.py:1350
msgid "Calculates Shannon's diversity index on a raster map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:453 ../gui/wxpython/menustrings.py:1396
+#: ../gui/wxpython/menustrings.py:445 ../gui/wxpython/menustrings.py:1351
msgid "Simpson's diversity"
msgstr ""
-#: ../gui/wxpython/menustrings.py:454 ../gui/wxpython/menustrings.py:1397
+#: ../gui/wxpython/menustrings.py:446 ../gui/wxpython/menustrings.py:1352
msgid "Calculates Simpson's diversity index on a raster map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:455 ../gui/wxpython/menustrings.py:1398
+#: ../gui/wxpython/menustrings.py:447 ../gui/wxpython/menustrings.py:1353
msgid "Richness"
msgstr ""
-#: ../gui/wxpython/menustrings.py:456 ../gui/wxpython/menustrings.py:1399
+#: ../gui/wxpython/menustrings.py:448 ../gui/wxpython/menustrings.py:1354
msgid "Calculates richness index on a raster map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:457 ../gui/wxpython/menustrings.py:1400
+#: ../gui/wxpython/menustrings.py:449 ../gui/wxpython/menustrings.py:1355
msgid "Shape index"
msgstr ""
-#: ../gui/wxpython/menustrings.py:458 ../gui/wxpython/menustrings.py:1401
+#: ../gui/wxpython/menustrings.py:450 ../gui/wxpython/menustrings.py:1356
msgid "Calculates shape index on a raster map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:459 ../gui/wxpython/menustrings.py:1402
+#: ../gui/wxpython/menustrings.py:451 ../gui/wxpython/menustrings.py:1357
msgid "Wildfire modeling"
msgstr ""
-#: ../gui/wxpython/menustrings.py:460 ../gui/wxpython/menustrings.py:1403
+#: ../gui/wxpython/menustrings.py:452 ../gui/wxpython/menustrings.py:1358
msgid "Rate of spread"
msgstr ""
-#: ../gui/wxpython/menustrings.py:461 ../gui/wxpython/menustrings.py:1404
+#: ../gui/wxpython/menustrings.py:453 ../gui/wxpython/menustrings.py:1359
msgid "Generates rate of spread raster maps. Generates three, or four raster map layers showing the base (perpendicular) rate of spread (ROS), the maximum (forward) ROS, the direction of the maximum ROS, and optionally the maximum potential spotting distance for fire spread simulation."
msgstr ""
-#: ../gui/wxpython/menustrings.py:462 ../gui/wxpython/menustrings.py:1405
+#: ../gui/wxpython/menustrings.py:454 ../gui/wxpython/menustrings.py:1360
msgid "Least-cost spread paths"
msgstr ""
-#: ../gui/wxpython/menustrings.py:463 ../gui/wxpython/menustrings.py:1406
+#: ../gui/wxpython/menustrings.py:455 ../gui/wxpython/menustrings.py:1361
msgid "Recursively traces the least cost path backwards to cells from which the cumulative cost was determined."
msgstr ""
-#: ../gui/wxpython/menustrings.py:464 ../gui/wxpython/menustrings.py:1407
+#: ../gui/wxpython/menustrings.py:456 ../gui/wxpython/menustrings.py:1362
msgid "Anisotropic spread simulation"
msgstr ""
-#: ../gui/wxpython/menustrings.py:465 ../gui/wxpython/menustrings.py:1408
+#: ../gui/wxpython/menustrings.py:457 ../gui/wxpython/menustrings.py:1363
msgid "Simulates elliptically anisotropic spread. Generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins. It optionally produces raster maps to contain backlink UTM coordinates for tracing spread paths. Usable for fire spread simulations."
msgstr ""
-#: ../gui/wxpython/menustrings.py:466 ../gui/wxpython/menustrings.py:1409
+#: ../gui/wxpython/menustrings.py:458 ../gui/wxpython/menustrings.py:1364
msgid "Change category values and labels"
msgstr ""
-#: ../gui/wxpython/menustrings.py:467 ../gui/wxpython/menustrings.py:517
-#: ../gui/wxpython/menustrings.py:1410 ../gui/wxpython/menustrings.py:1460
+#: ../gui/wxpython/menustrings.py:459 ../gui/wxpython/menustrings.py:509
+#: ../gui/wxpython/menustrings.py:1365 ../gui/wxpython/menustrings.py:1415
msgid "Manage category information"
msgstr ""
-#: ../gui/wxpython/menustrings.py:468 ../gui/wxpython/menustrings.py:518
-#: ../gui/wxpython/menustrings.py:1411 ../gui/wxpython/menustrings.py:1461
+#: ../gui/wxpython/menustrings.py:460 ../gui/wxpython/menustrings.py:510
+#: ../gui/wxpython/menustrings.py:1366 ../gui/wxpython/menustrings.py:1416
msgid "Manages category values and labels associated with user-specified raster map layers."
msgstr ""
-#: ../gui/wxpython/menustrings.py:469 ../gui/wxpython/menustrings.py:1412
+#: ../gui/wxpython/menustrings.py:461 ../gui/wxpython/menustrings.py:1367
msgid "Interactively edit category values"
msgstr ""
-#: ../gui/wxpython/menustrings.py:470 ../gui/wxpython/menustrings.py:1413
+#: ../gui/wxpython/menustrings.py:462 ../gui/wxpython/menustrings.py:1368
msgid "Edits cell values in a raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:471 ../gui/wxpython/menustrings.py:1414
+#: ../gui/wxpython/menustrings.py:463 ../gui/wxpython/menustrings.py:1369
msgid "Reclassify by size"
msgstr ""
-#: ../gui/wxpython/menustrings.py:472 ../gui/wxpython/menustrings.py:1415
+#: ../gui/wxpython/menustrings.py:464 ../gui/wxpython/menustrings.py:1370
msgid "Reclasses a raster map greater or less than user specified area size (in hectares)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:473 ../gui/wxpython/menustrings.py:692
-#: ../gui/wxpython/menustrings.py:1416 ../gui/wxpython/menustrings.py:1635
+#: ../gui/wxpython/menustrings.py:465 ../gui/wxpython/menustrings.py:669
+#: ../gui/wxpython/menustrings.py:1371 ../gui/wxpython/menustrings.py:1575
msgid "Reclassify"
msgstr ""
-#: ../gui/wxpython/menustrings.py:474 ../gui/wxpython/menustrings.py:1417
+#: ../gui/wxpython/menustrings.py:466 ../gui/wxpython/menustrings.py:1372
msgid "Reclassify raster map based on category values. Creates a new raster map whose category values are based upon a reclassification of the categories in an existing raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:475 ../gui/wxpython/menustrings.py:1418
+#: ../gui/wxpython/menustrings.py:467 ../gui/wxpython/menustrings.py:1373
msgid "Recode"
msgstr ""
-#: ../gui/wxpython/menustrings.py:476 ../gui/wxpython/menustrings.py:1419
+#: ../gui/wxpython/menustrings.py:468 ../gui/wxpython/menustrings.py:1374
msgid "Recodes categorical raster maps."
msgstr ""
-#: ../gui/wxpython/menustrings.py:477 ../gui/wxpython/menustrings.py:1420
+#: ../gui/wxpython/menustrings.py:469 ../gui/wxpython/menustrings.py:1375
msgid "Rescale"
msgstr ""
-#: ../gui/wxpython/menustrings.py:478 ../gui/wxpython/menustrings.py:1421
+#: ../gui/wxpython/menustrings.py:470 ../gui/wxpython/menustrings.py:1376
msgid "Rescales the range of category values in a raster map layer."
msgstr ""
-#: ../gui/wxpython/menustrings.py:479 ../gui/wxpython/menustrings.py:1422
+#: ../gui/wxpython/menustrings.py:471 ../gui/wxpython/menustrings.py:1377
msgid "Rescale with histogram"
msgstr ""
-#: ../gui/wxpython/menustrings.py:480 ../gui/wxpython/menustrings.py:1423
+#: ../gui/wxpython/menustrings.py:472 ../gui/wxpython/menustrings.py:1378
msgid "Rescales histogram equalized the range of category values in a raster map layer."
msgstr ""
-#: ../gui/wxpython/menustrings.py:481 ../gui/wxpython/menustrings.py:1424
+#: ../gui/wxpython/menustrings.py:473 ../gui/wxpython/menustrings.py:1379
msgid "Generate random cells"
msgstr ""
-#: ../gui/wxpython/menustrings.py:482 ../gui/wxpython/menustrings.py:1425
+#: ../gui/wxpython/menustrings.py:474 ../gui/wxpython/menustrings.py:1380
msgid "Random cells"
msgstr ""
-#: ../gui/wxpython/menustrings.py:483 ../gui/wxpython/menustrings.py:1426
+#: ../gui/wxpython/menustrings.py:475 ../gui/wxpython/menustrings.py:1381
msgid "Generates random cell values with spatial dependence."
msgstr ""
-#: ../gui/wxpython/menustrings.py:484 ../gui/wxpython/menustrings.py:1427
+#: ../gui/wxpython/menustrings.py:476 ../gui/wxpython/menustrings.py:1382
msgid "Random cells and vector points"
msgstr ""
-#: ../gui/wxpython/menustrings.py:485 ../gui/wxpython/menustrings.py:1428
+#: ../gui/wxpython/menustrings.py:477 ../gui/wxpython/menustrings.py:1383
msgid "Creates a raster map layer and vector point map containing randomly located points."
msgstr ""
-#: ../gui/wxpython/menustrings.py:486 ../gui/wxpython/menustrings.py:1429
+#: ../gui/wxpython/menustrings.py:478 ../gui/wxpython/menustrings.py:1384
msgid "Generate surfaces"
msgstr ""
-#: ../gui/wxpython/menustrings.py:487 ../gui/wxpython/menustrings.py:1430
+#: ../gui/wxpython/menustrings.py:479 ../gui/wxpython/menustrings.py:1385
msgid "Fractal surface"
msgstr ""
-#: ../gui/wxpython/menustrings.py:488 ../gui/wxpython/menustrings.py:1431
+#: ../gui/wxpython/menustrings.py:480 ../gui/wxpython/menustrings.py:1386
msgid "Creates a fractal surface of a given fractal dimension."
msgstr ""
-#: ../gui/wxpython/menustrings.py:489 ../gui/wxpython/menustrings.py:1432
+#: ../gui/wxpython/menustrings.py:481 ../gui/wxpython/menustrings.py:1387
msgid "Gaussian kernel density surface"
msgstr ""
-#: ../gui/wxpython/menustrings.py:490 ../gui/wxpython/menustrings.py:1433
+#: ../gui/wxpython/menustrings.py:482 ../gui/wxpython/menustrings.py:1388
msgid "Generates a raster density map from vector points map. Density is computed using a moving kernel. Optionally generates a vector density map on a vector network."
msgstr ""
-#: ../gui/wxpython/menustrings.py:491 ../gui/wxpython/menustrings.py:1434
+#: ../gui/wxpython/menustrings.py:483 ../gui/wxpython/menustrings.py:1389
msgid "Gaussian deviates surface"
msgstr ""
-#: ../gui/wxpython/menustrings.py:492 ../gui/wxpython/menustrings.py:1435
+#: ../gui/wxpython/menustrings.py:484 ../gui/wxpython/menustrings.py:1390
msgid "Generates a raster map using gaussian random number generator. Mean and standard deviation of gaussian deviates can be expressed by the user."
msgstr ""
-#: ../gui/wxpython/menustrings.py:494 ../gui/wxpython/menustrings.py:1437
+#: ../gui/wxpython/menustrings.py:486 ../gui/wxpython/menustrings.py:1392
msgid "Creates raster plane map given dip (inclination), aspect (azimuth) and one point."
msgstr ""
-#: ../gui/wxpython/menustrings.py:495 ../gui/wxpython/menustrings.py:1438
+#: ../gui/wxpython/menustrings.py:487 ../gui/wxpython/menustrings.py:1393
msgid "Random deviates surface"
msgstr ""
-#: ../gui/wxpython/menustrings.py:496 ../gui/wxpython/menustrings.py:1439
+#: ../gui/wxpython/menustrings.py:488 ../gui/wxpython/menustrings.py:1394
msgid "Produces a raster surface map of uniform random deviates with defined range."
msgstr ""
-#: ../gui/wxpython/menustrings.py:497 ../gui/wxpython/menustrings.py:1440
+#: ../gui/wxpython/menustrings.py:489 ../gui/wxpython/menustrings.py:1395
msgid "Random surface with spatial dependence"
msgstr ""
-#: ../gui/wxpython/menustrings.py:498 ../gui/wxpython/menustrings.py:1441
+#: ../gui/wxpython/menustrings.py:490 ../gui/wxpython/menustrings.py:1396
msgid "Generates random surface(s) with spatial dependence."
msgstr ""
-#: ../gui/wxpython/menustrings.py:499 ../gui/wxpython/menustrings.py:1442
+#: ../gui/wxpython/menustrings.py:491 ../gui/wxpython/menustrings.py:1397
msgid "Interpolate surfaces"
msgstr ""
-#: ../gui/wxpython/menustrings.py:500 ../gui/wxpython/menustrings.py:1443
+#: ../gui/wxpython/menustrings.py:492 ../gui/wxpython/menustrings.py:1398
msgid "Bilinear and bicubic from vector points"
msgstr ""
-#: ../gui/wxpython/menustrings.py:501 ../gui/wxpython/menustrings.py:1444
+#: ../gui/wxpython/menustrings.py:493 ../gui/wxpython/menustrings.py:1399
msgid "Performs bicubic or bilinear spline interpolation with Tykhonov regularization."
msgstr ""
-#: ../gui/wxpython/menustrings.py:502 ../gui/wxpython/menustrings.py:1445
+#: ../gui/wxpython/menustrings.py:494 ../gui/wxpython/menustrings.py:1400
msgid "IDW from raster points"
msgstr ""
-#: ../gui/wxpython/menustrings.py:503 ../gui/wxpython/menustrings.py:1446
+#: ../gui/wxpython/menustrings.py:495 ../gui/wxpython/menustrings.py:1401
msgid "Provides surface interpolation from raster point data by Inverse Distance Squared Weighting."
msgstr ""
-#: ../gui/wxpython/menustrings.py:504 ../gui/wxpython/menustrings.py:1447
+#: ../gui/wxpython/menustrings.py:496 ../gui/wxpython/menustrings.py:1402
msgid "IDW from vector points"
msgstr ""
-#: ../gui/wxpython/menustrings.py:505 ../gui/wxpython/menustrings.py:1448
+#: ../gui/wxpython/menustrings.py:497 ../gui/wxpython/menustrings.py:1403
msgid "Provides surface interpolation from vector point data by Inverse Distance Squared Weighting."
msgstr ""
-#: ../gui/wxpython/menustrings.py:506 ../gui/wxpython/menustrings.py:1449
+#: ../gui/wxpython/menustrings.py:498 ../gui/wxpython/menustrings.py:1404
msgid "Raster contours"
msgstr ""
-#: ../gui/wxpython/menustrings.py:507 ../gui/wxpython/menustrings.py:1450
+#: ../gui/wxpython/menustrings.py:499 ../gui/wxpython/menustrings.py:1405
msgid "Generates surface raster map from rasterized contours."
msgstr ""
-#: ../gui/wxpython/menustrings.py:508 ../gui/wxpython/menustrings.py:1451
+#: ../gui/wxpython/menustrings.py:500 ../gui/wxpython/menustrings.py:1406
msgid "Regularized spline tension"
msgstr ""
-#: ../gui/wxpython/menustrings.py:509 ../gui/wxpython/menustrings.py:1452
+#: ../gui/wxpython/menustrings.py:501 ../gui/wxpython/menustrings.py:1407
msgid "Performs surface interpolation from vector points map by splines. Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension."
msgstr ""
-#: ../gui/wxpython/menustrings.py:510 ../gui/wxpython/menustrings.py:1453
+#: ../gui/wxpython/menustrings.py:502 ../gui/wxpython/menustrings.py:1408
msgid "Raster series interpolation"
msgstr ""
-#: ../gui/wxpython/menustrings.py:511 ../gui/wxpython/menustrings.py:1454
+#: ../gui/wxpython/menustrings.py:503 ../gui/wxpython/menustrings.py:1409
msgid "Interpolates raster maps located (temporal or spatial) in between input raster maps at specific sampling positions."
msgstr ""
-#: ../gui/wxpython/menustrings.py:512 ../gui/wxpython/menustrings.py:1455
+#: ../gui/wxpython/menustrings.py:504 ../gui/wxpython/menustrings.py:1410
msgid "Fill NULL cells"
msgstr ""
-#: ../gui/wxpython/menustrings.py:513 ../gui/wxpython/menustrings.py:1456
+#: ../gui/wxpython/menustrings.py:505 ../gui/wxpython/menustrings.py:1411
msgid "Fills no-data areas in raster maps using spline interpolation."
msgstr ""
-#: ../gui/wxpython/menustrings.py:514 ../gui/wxpython/menustrings.py:731
-#: ../gui/wxpython/menustrings.py:841 ../gui/wxpython/menustrings.py:1028
-#: ../gui/wxpython/menustrings.py:1457 ../gui/wxpython/menustrings.py:1674
-#: ../gui/wxpython/menustrings.py:1784 ../gui/wxpython/menustrings.py:1971
+#: ../gui/wxpython/menustrings.py:506 ../gui/wxpython/menustrings.py:708
+#: ../gui/wxpython/menustrings.py:818 ../gui/wxpython/menustrings.py:990
+#: ../gui/wxpython/menustrings.py:1412 ../gui/wxpython/menustrings.py:1614
+#: ../gui/wxpython/menustrings.py:1724 ../gui/wxpython/menustrings.py:1896
msgid "Reports and statistics"
msgstr ""
-#: ../gui/wxpython/menustrings.py:515 ../gui/wxpython/menustrings.py:1458
+#: ../gui/wxpython/menustrings.py:507 ../gui/wxpython/menustrings.py:1413
msgid "Basic raster metadata"
msgstr ""
-#: ../gui/wxpython/menustrings.py:516 ../gui/wxpython/menustrings.py:1459
+#: ../gui/wxpython/menustrings.py:508 ../gui/wxpython/menustrings.py:1414
msgid "Outputs basic information about a raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:519 ../gui/wxpython/menustrings.py:1462
+#: ../gui/wxpython/menustrings.py:511 ../gui/wxpython/menustrings.py:1417
msgid "General statistics"
msgstr ""
-#: ../gui/wxpython/menustrings.py:520 ../gui/wxpython/menustrings.py:1463
+#: ../gui/wxpython/menustrings.py:512 ../gui/wxpython/menustrings.py:1418
msgid "Generates area statistics for raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:521 ../gui/wxpython/menustrings.py:1464
+#: ../gui/wxpython/menustrings.py:513 ../gui/wxpython/menustrings.py:1419
msgid "Quantiles for large data sets"
msgstr ""
-#: ../gui/wxpython/menustrings.py:522 ../gui/wxpython/menustrings.py:1465
+#: ../gui/wxpython/menustrings.py:514 ../gui/wxpython/menustrings.py:1420
msgid "Compute quantiles using two passes."
msgstr ""
-#: ../gui/wxpython/menustrings.py:523 ../gui/wxpython/menustrings.py:1466
+#: ../gui/wxpython/menustrings.py:515 ../gui/wxpython/menustrings.py:1421
msgid "Range of category values"
msgstr ""
-#: ../gui/wxpython/menustrings.py:524 ../gui/wxpython/menustrings.py:1467
+#: ../gui/wxpython/menustrings.py:516 ../gui/wxpython/menustrings.py:1422
msgid "Prints terse list of category values found in a raster map layer."
msgstr ""
-#: ../gui/wxpython/menustrings.py:525 ../gui/wxpython/menustrings.py:1468
+#: ../gui/wxpython/menustrings.py:517 ../gui/wxpython/menustrings.py:1423
msgid "Sum area by raster map and category"
msgstr ""
-#: ../gui/wxpython/menustrings.py:526 ../gui/wxpython/menustrings.py:1469
+#: ../gui/wxpython/menustrings.py:518 ../gui/wxpython/menustrings.py:1424
msgid "Reports statistics for raster maps."
msgstr ""
-#: ../gui/wxpython/menustrings.py:527 ../gui/wxpython/menustrings.py:1470
+#: ../gui/wxpython/menustrings.py:519 ../gui/wxpython/menustrings.py:1425
msgid "Statistics for clumped cells"
msgstr ""
-#: ../gui/wxpython/menustrings.py:528 ../gui/wxpython/menustrings.py:1471
+#: ../gui/wxpython/menustrings.py:520 ../gui/wxpython/menustrings.py:1426
msgid "Calculates the volume of data \"clumps\". Optionally produces a GRASS vector points map containing the calculated centroids of these clumps."
msgstr ""
-#: ../gui/wxpython/menustrings.py:529 ../gui/wxpython/menustrings.py:1472
+#: ../gui/wxpython/menustrings.py:521 ../gui/wxpython/menustrings.py:1427
msgid "Total corrected area"
msgstr ""
-#: ../gui/wxpython/menustrings.py:530 ../gui/wxpython/menustrings.py:1473
+#: ../gui/wxpython/menustrings.py:522 ../gui/wxpython/menustrings.py:1428
msgid "Prints estimation of surface area for raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:532 ../gui/wxpython/menustrings.py:1475
+#: ../gui/wxpython/menustrings.py:524 ../gui/wxpython/menustrings.py:1430
msgid "Calculates univariate statistics from the non-null cells of a raster map. Statistics include number of cells counted, minimum and maximum cell values, range, arithmetic mean, population variance, standard deviation, coefficient of variation, and sum."
msgstr ""
-#: ../gui/wxpython/menustrings.py:533 ../gui/wxpython/menustrings.py:1476
+#: ../gui/wxpython/menustrings.py:525 ../gui/wxpython/menustrings.py:1431
msgid "Sample transects"
msgstr ""
-#: ../gui/wxpython/menustrings.py:534 ../gui/wxpython/menustrings.py:1477
+#: ../gui/wxpython/menustrings.py:526 ../gui/wxpython/menustrings.py:1432
msgid "Outputs the raster map layer values lying on user-defined line(s)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:535 ../gui/wxpython/menustrings.py:1478
+#: ../gui/wxpython/menustrings.py:527 ../gui/wxpython/menustrings.py:1433
msgid "Sample transects (bearing/distance)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:536 ../gui/wxpython/menustrings.py:1479
+#: ../gui/wxpython/menustrings.py:528 ../gui/wxpython/menustrings.py:1434
msgid "Outputs raster map layer values lying along user defined transect line(s)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:537 ../gui/wxpython/menustrings.py:1480
+#: ../gui/wxpython/menustrings.py:529 ../gui/wxpython/menustrings.py:1435
msgid "Covariance/correlation"
msgstr ""
-#: ../gui/wxpython/menustrings.py:538 ../gui/wxpython/menustrings.py:1481
+#: ../gui/wxpython/menustrings.py:530 ../gui/wxpython/menustrings.py:1436
msgid "Outputs a covariance/correlation matrix for user-specified raster map layer(s)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:539 ../gui/wxpython/menustrings.py:1482
+#: ../gui/wxpython/menustrings.py:531 ../gui/wxpython/menustrings.py:1437
msgid "Linear regression"
msgstr ""
-#: ../gui/wxpython/menustrings.py:540 ../gui/wxpython/menustrings.py:1483
+#: ../gui/wxpython/menustrings.py:532 ../gui/wxpython/menustrings.py:1438
msgid "Calculates linear regression from two raster maps: y = a + b*x."
msgstr ""
-#: ../gui/wxpython/menustrings.py:541 ../gui/wxpython/menustrings.py:1484
+#: ../gui/wxpython/menustrings.py:533 ../gui/wxpython/menustrings.py:1439
msgid "Multiple regression"
msgstr ""
-#: ../gui/wxpython/menustrings.py:542 ../gui/wxpython/menustrings.py:1485
+#: ../gui/wxpython/menustrings.py:534 ../gui/wxpython/menustrings.py:1440
msgid "Calculates multiple linear regression from raster maps."
msgstr ""
-#: ../gui/wxpython/menustrings.py:543 ../gui/wxpython/menustrings.py:1486
+#: ../gui/wxpython/menustrings.py:535 ../gui/wxpython/menustrings.py:1441
msgid "Mutual category occurrences"
msgstr ""
-#: ../gui/wxpython/menustrings.py:544 ../gui/wxpython/menustrings.py:1487
+#: ../gui/wxpython/menustrings.py:536 ../gui/wxpython/menustrings.py:1442
msgid "Tabulates the mutual occurrence (coincidence) of categories for two raster map layers."
msgstr ""
-#: ../gui/wxpython/menustrings.py:545 ../gui/wxpython/menustrings.py:1488
+#: ../gui/wxpython/menustrings.py:537 ../gui/wxpython/menustrings.py:1443
msgid "&Vector"
msgstr ""
-#: ../gui/wxpython/menustrings.py:546 ../gui/wxpython/menustrings.py:1489
+#: ../gui/wxpython/menustrings.py:538 ../gui/wxpython/menustrings.py:1444
msgid "Develop vector map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:548 ../gui/wxpython/menustrings.py:1491
+#: ../gui/wxpython/menustrings.py:540 ../gui/wxpython/menustrings.py:1446
msgid "Create new empty vector map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:549 ../gui/wxpython/menustrings.py:1492
+#: ../gui/wxpython/menustrings.py:541 ../gui/wxpython/menustrings.py:1447
msgid "Edit vector map (non-interactively)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:550 ../gui/wxpython/menustrings.py:1493
+#: ../gui/wxpython/menustrings.py:542 ../gui/wxpython/menustrings.py:1448
msgid "Edits a vector map, allows adding, deleting and modifying selected vector features."
msgstr ""
-#: ../gui/wxpython/menustrings.py:551 ../gui/wxpython/menustrings.py:1494
+#: ../gui/wxpython/menustrings.py:543 ../gui/wxpython/menustrings.py:1449
msgid "Convert object types"
msgstr ""
-#: ../gui/wxpython/menustrings.py:552 ../gui/wxpython/menustrings.py:1495
+#: ../gui/wxpython/menustrings.py:544 ../gui/wxpython/menustrings.py:1450
msgid "Changes type of vector features."
msgstr ""
-#: ../gui/wxpython/menustrings.py:553 ../gui/wxpython/menustrings.py:1496
+#: ../gui/wxpython/menustrings.py:545 ../gui/wxpython/menustrings.py:1451
msgid "Parallel lines"
msgstr ""
-#: ../gui/wxpython/menustrings.py:554 ../gui/wxpython/menustrings.py:1497
+#: ../gui/wxpython/menustrings.py:546 ../gui/wxpython/menustrings.py:1452
msgid "Creates parallel line to input vector lines."
msgstr ""
-#: ../gui/wxpython/menustrings.py:555 ../gui/wxpython/menustrings.py:1498
+#: ../gui/wxpython/menustrings.py:547 ../gui/wxpython/menustrings.py:1453
msgid "Dissolve boundaries"
msgstr ""
-#: ../gui/wxpython/menustrings.py:556 ../gui/wxpython/menustrings.py:1499
+#: ../gui/wxpython/menustrings.py:548 ../gui/wxpython/menustrings.py:1454
msgid "Dissolves boundaries between adjacent areas sharing a common category number or attribute."
msgstr ""
-#: ../gui/wxpython/menustrings.py:557 ../gui/wxpython/menustrings.py:1500
+#: ../gui/wxpython/menustrings.py:549 ../gui/wxpython/menustrings.py:1455
msgid "Create 3D vector over raster"
msgstr ""
-#: ../gui/wxpython/menustrings.py:558 ../gui/wxpython/menustrings.py:1501
+#: ../gui/wxpython/menustrings.py:550 ../gui/wxpython/menustrings.py:1456
msgid "Converts 2D vector features to 3D by sampling of elevation raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:559 ../gui/wxpython/menustrings.py:1502
+#: ../gui/wxpython/menustrings.py:551 ../gui/wxpython/menustrings.py:1457
msgid "Extrude 3D vector map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:560 ../gui/wxpython/menustrings.py:1503
+#: ../gui/wxpython/menustrings.py:552 ../gui/wxpython/menustrings.py:1458
msgid "Extrudes flat vector features to 3D vector features with defined height. Optionally the height can be derived from sampling of elevation raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:561 ../gui/wxpython/menustrings.py:1504
+#: ../gui/wxpython/menustrings.py:553 ../gui/wxpython/menustrings.py:1459
msgid "Create labels"
msgstr ""
-#: ../gui/wxpython/menustrings.py:562 ../gui/wxpython/menustrings.py:1505
+#: ../gui/wxpython/menustrings.py:554 ../gui/wxpython/menustrings.py:1460
msgid "Creates paint labels for a vector map from attached attributes."
msgstr ""
-#: ../gui/wxpython/menustrings.py:563 ../gui/wxpython/menustrings.py:1506
+#: ../gui/wxpython/menustrings.py:555 ../gui/wxpython/menustrings.py:1461
msgid "Reposition vector map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:564 ../gui/wxpython/menustrings.py:1507
+#: ../gui/wxpython/menustrings.py:556 ../gui/wxpython/menustrings.py:1462
msgid "Performs an affine transformation (shift, scale and rotate) on vector map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:565 ../gui/wxpython/menustrings.py:1508
+#: ../gui/wxpython/menustrings.py:557 ../gui/wxpython/menustrings.py:1463
msgid "Rectify vector map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:566 ../gui/wxpython/menustrings.py:1509
+#: ../gui/wxpython/menustrings.py:558 ../gui/wxpython/menustrings.py:1464
msgid "Rectifies a vector by computing a coordinate transformation for each object in the vector based on the control points."
msgstr ""
-#: ../gui/wxpython/menustrings.py:570 ../gui/wxpython/menustrings.py:1513
+#: ../gui/wxpython/menustrings.py:562 ../gui/wxpython/menustrings.py:1468
msgid "Updates vector map metadata."
msgstr ""
-#: ../gui/wxpython/menustrings.py:571 ../gui/wxpython/menustrings.py:1514
+#: ../gui/wxpython/menustrings.py:563 ../gui/wxpython/menustrings.py:1469
msgid "Topology maintenance"
msgstr ""
-#: ../gui/wxpython/menustrings.py:572 ../gui/wxpython/menustrings.py:1515
+#: ../gui/wxpython/menustrings.py:564 ../gui/wxpython/menustrings.py:1470
msgid "Create or rebuild topology"
msgstr ""
-#: ../gui/wxpython/menustrings.py:573 ../gui/wxpython/menustrings.py:1516
+#: ../gui/wxpython/menustrings.py:565 ../gui/wxpython/menustrings.py:1471
msgid "Creates topology for vector map. Optionally also checks for topological errors."
msgstr ""
-#: ../gui/wxpython/menustrings.py:574 ../gui/wxpython/menustrings.py:1517
+#: ../gui/wxpython/menustrings.py:566 ../gui/wxpython/menustrings.py:1472
msgid "Rebuild topology on all vector maps"
msgstr ""
-#: ../gui/wxpython/menustrings.py:575 ../gui/wxpython/menustrings.py:1518
+#: ../gui/wxpython/menustrings.py:567 ../gui/wxpython/menustrings.py:1473
msgid "Rebuilds topology on all vector maps in the current mapset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:576 ../gui/wxpython/menustrings.py:1519
+#: ../gui/wxpython/menustrings.py:568 ../gui/wxpython/menustrings.py:1474
msgid "Build polylines"
msgstr ""
-#: ../gui/wxpython/menustrings.py:577 ../gui/wxpython/menustrings.py:1520
+#: ../gui/wxpython/menustrings.py:569 ../gui/wxpython/menustrings.py:1475
msgid "Builds polylines from lines or boundaries."
msgstr ""
-#: ../gui/wxpython/menustrings.py:578 ../gui/wxpython/menustrings.py:1521
+#: ../gui/wxpython/menustrings.py:570 ../gui/wxpython/menustrings.py:1476
msgid "Split lines"
msgstr ""
-#: ../gui/wxpython/menustrings.py:579 ../gui/wxpython/menustrings.py:1522
+#: ../gui/wxpython/menustrings.py:571 ../gui/wxpython/menustrings.py:1477
msgid "Splits vector lines to shorter segments."
msgstr ""
-#: ../gui/wxpython/menustrings.py:580 ../gui/wxpython/menustrings.py:1523
+#: ../gui/wxpython/menustrings.py:572 ../gui/wxpython/menustrings.py:1478
msgid "Split polylines"
msgstr ""
-#: ../gui/wxpython/menustrings.py:581 ../gui/wxpython/menustrings.py:1524
+#: ../gui/wxpython/menustrings.py:573 ../gui/wxpython/menustrings.py:1479
msgid "Creates points/segments from input vector lines and positions."
msgstr ""
-#: ../gui/wxpython/menustrings.py:582 ../gui/wxpython/menustrings.py:1525
+#: ../gui/wxpython/menustrings.py:574 ../gui/wxpython/menustrings.py:1480
msgid "Clean vector map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:583 ../gui/wxpython/menustrings.py:1526
+#: ../gui/wxpython/menustrings.py:575 ../gui/wxpython/menustrings.py:1481
msgid "Toolset for cleaning topology of vector map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:584 ../gui/wxpython/menustrings.py:1527
+#: ../gui/wxpython/menustrings.py:576 ../gui/wxpython/menustrings.py:1482
msgid "Smooth or simplify"
msgstr ""
-#: ../gui/wxpython/menustrings.py:585 ../gui/wxpython/menustrings.py:1528
+#: ../gui/wxpython/menustrings.py:577 ../gui/wxpython/menustrings.py:1483
msgid "Performs vector based generalization."
msgstr ""
-#: ../gui/wxpython/menustrings.py:586 ../gui/wxpython/menustrings.py:1529
+#: ../gui/wxpython/menustrings.py:578 ../gui/wxpython/menustrings.py:1484
msgid "Add centroids"
msgstr ""
-#: ../gui/wxpython/menustrings.py:587 ../gui/wxpython/menustrings.py:1530
+#: ../gui/wxpython/menustrings.py:579 ../gui/wxpython/menustrings.py:1485
msgid "Adds missing centroids to closed boundaries."
msgstr ""
-#: ../gui/wxpython/menustrings.py:590 ../gui/wxpython/menustrings.py:1533
+#: ../gui/wxpython/menustrings.py:582 ../gui/wxpython/menustrings.py:1488
msgid "Creates/modifies the color table associated with a vector map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:592 ../gui/wxpython/menustrings.py:1535
+#: ../gui/wxpython/menustrings.py:584 ../gui/wxpython/menustrings.py:1490
msgid "Interactive management of vector color tables."
msgstr ""
-#: ../gui/wxpython/menustrings.py:594 ../gui/wxpython/menustrings.py:1537
+#: ../gui/wxpython/menustrings.py:586 ../gui/wxpython/menustrings.py:1492
msgid "Exports the color table associated with a vector map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:595 ../gui/wxpython/menustrings.py:1538
+#: ../gui/wxpython/menustrings.py:587 ../gui/wxpython/menustrings.py:1493
msgid "Query vector map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:596 ../gui/wxpython/menustrings.py:1539
+#: ../gui/wxpython/menustrings.py:588 ../gui/wxpython/menustrings.py:1494
msgid "Query with coordinate(s)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:597 ../gui/wxpython/menustrings.py:1540
+#: ../gui/wxpython/menustrings.py:589 ../gui/wxpython/menustrings.py:1495
msgid "Queries a vector map at given locations."
msgstr ""
-#: ../gui/wxpython/menustrings.py:598 ../gui/wxpython/menustrings.py:912
-#: ../gui/wxpython/menustrings.py:1541 ../gui/wxpython/menustrings.py:1855
+#: ../gui/wxpython/menustrings.py:590 ../gui/wxpython/menustrings.py:885
+#: ../gui/wxpython/menustrings.py:1496 ../gui/wxpython/menustrings.py:1791
msgid "Query vector attribute data"
msgstr ""
-#: ../gui/wxpython/menustrings.py:599 ../gui/wxpython/menustrings.py:913
-#: ../gui/wxpython/menustrings.py:1542 ../gui/wxpython/menustrings.py:1856
+#: ../gui/wxpython/menustrings.py:591 ../gui/wxpython/menustrings.py:886
+#: ../gui/wxpython/menustrings.py:1497 ../gui/wxpython/menustrings.py:1792
msgid "Prints vector map attributes."
msgstr ""
-#: ../gui/wxpython/menustrings.py:600 ../gui/wxpython/menustrings.py:1543
+#: ../gui/wxpython/menustrings.py:592 ../gui/wxpython/menustrings.py:1498
msgid "Feature selection"
msgstr ""
-#: ../gui/wxpython/menustrings.py:601 ../gui/wxpython/menustrings.py:1544
+#: ../gui/wxpython/menustrings.py:593 ../gui/wxpython/menustrings.py:1499
msgid "Select by attributes"
msgstr ""
-#: ../gui/wxpython/menustrings.py:602 ../gui/wxpython/menustrings.py:1545
+#: ../gui/wxpython/menustrings.py:594 ../gui/wxpython/menustrings.py:1500
msgid "Selects vector features from an existing vector map and creates a new vector map containing only the selected features."
msgstr ""
-#: ../gui/wxpython/menustrings.py:603 ../gui/wxpython/menustrings.py:1546
+#: ../gui/wxpython/menustrings.py:595 ../gui/wxpython/menustrings.py:1501
msgid "Select by another map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:604 ../gui/wxpython/menustrings.py:1547
+#: ../gui/wxpython/menustrings.py:596 ../gui/wxpython/menustrings.py:1502
msgid "Selects features from vector map (A) by features from other vector map (B)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:612 ../gui/wxpython/menustrings.py:1555
+#: ../gui/wxpython/menustrings.py:604 ../gui/wxpython/menustrings.py:1510
msgid "Buffer vectors"
msgstr ""
-#: ../gui/wxpython/menustrings.py:613 ../gui/wxpython/menustrings.py:1556
+#: ../gui/wxpython/menustrings.py:605 ../gui/wxpython/menustrings.py:1511
msgid "Creates a buffer around vector features of given type."
msgstr ""
-#: ../gui/wxpython/menustrings.py:614 ../gui/wxpython/menustrings.py:1557
-msgid "Point analysis"
+#: ../gui/wxpython/menustrings.py:606 ../gui/wxpython/menustrings.py:1512
+msgid "Lidar analysis"
msgstr ""
-#: ../gui/wxpython/menustrings.py:615 ../gui/wxpython/menustrings.py:630
-#: ../gui/wxpython/menustrings.py:1558 ../gui/wxpython/menustrings.py:1573
+#: ../gui/wxpython/menustrings.py:607 ../gui/wxpython/menustrings.py:1513
msgid "Identify and remove outliers"
msgstr ""
-#: ../gui/wxpython/menustrings.py:616 ../gui/wxpython/menustrings.py:631
-#: ../gui/wxpython/menustrings.py:728 ../gui/wxpython/menustrings.py:1559
-#: ../gui/wxpython/menustrings.py:1574 ../gui/wxpython/menustrings.py:1671
+#: ../gui/wxpython/menustrings.py:608 ../gui/wxpython/menustrings.py:705
+#: ../gui/wxpython/menustrings.py:1514 ../gui/wxpython/menustrings.py:1611
msgid "Removes outliers from vector point data."
msgstr ""
-#: ../gui/wxpython/menustrings.py:617 ../gui/wxpython/menustrings.py:1560
-msgid "Identify point clusters"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:618 ../gui/wxpython/menustrings.py:1561
-msgid "Performs cluster identification."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:619 ../gui/wxpython/menustrings.py:1562
-msgid "Indices for quadrat counts of vector point lists"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:620 ../gui/wxpython/menustrings.py:743
-#: ../gui/wxpython/menustrings.py:1563 ../gui/wxpython/menustrings.py:1686
-msgid "Indices for quadrat counts of vector point lists."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:621 ../gui/wxpython/menustrings.py:725
-#: ../gui/wxpython/menustrings.py:1564 ../gui/wxpython/menustrings.py:1668
-msgid "Perturb points"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:622 ../gui/wxpython/menustrings.py:726
-#: ../gui/wxpython/menustrings.py:1565 ../gui/wxpython/menustrings.py:1669
-msgid "Random location perturbations of vector points."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:623 ../gui/wxpython/menustrings.py:729
-#: ../gui/wxpython/menustrings.py:1566 ../gui/wxpython/menustrings.py:1672
-msgid "Test/training point sets"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:624 ../gui/wxpython/menustrings.py:730
-#: ../gui/wxpython/menustrings.py:1567 ../gui/wxpython/menustrings.py:1673
-msgid "Randomly partition points into test/train sets."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:625 ../gui/wxpython/menustrings.py:1568
-msgid "Tests for normality for vector points"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:626 ../gui/wxpython/menustrings.py:745
-#: ../gui/wxpython/menustrings.py:1569 ../gui/wxpython/menustrings.py:1688
-msgid "Tests for normality for vector points."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:627 ../gui/wxpython/menustrings.py:1570
-msgid "Lidar analysis"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:628 ../gui/wxpython/menustrings.py:1571
-msgid "Decimates a point cloud"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:629 ../gui/wxpython/menustrings.py:1572
-msgid "Decimates a point cloud Copies points from one vector to another while applying different decimations"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:632 ../gui/wxpython/menustrings.py:1575
+#: ../gui/wxpython/menustrings.py:609 ../gui/wxpython/menustrings.py:1515
msgid "Detect edges"
msgstr ""
-#: ../gui/wxpython/menustrings.py:633 ../gui/wxpython/menustrings.py:1576
+#: ../gui/wxpython/menustrings.py:610 ../gui/wxpython/menustrings.py:1516
msgid "Detects the object's edges from a LIDAR data set."
msgstr ""
-#: ../gui/wxpython/menustrings.py:634 ../gui/wxpython/menustrings.py:1577
+#: ../gui/wxpython/menustrings.py:611 ../gui/wxpython/menustrings.py:1517
msgid "Detect interiors"
msgstr ""
-#: ../gui/wxpython/menustrings.py:635 ../gui/wxpython/menustrings.py:1578
+#: ../gui/wxpython/menustrings.py:612 ../gui/wxpython/menustrings.py:1518
msgid "Building contour determination and Region Growing algorithm for determining the building inside"
msgstr ""
-#: ../gui/wxpython/menustrings.py:636 ../gui/wxpython/menustrings.py:1579
+#: ../gui/wxpython/menustrings.py:613 ../gui/wxpython/menustrings.py:1519
msgid "Correct and reclassify objects"
msgstr ""
-#: ../gui/wxpython/menustrings.py:637 ../gui/wxpython/menustrings.py:1580
+#: ../gui/wxpython/menustrings.py:614 ../gui/wxpython/menustrings.py:1520
msgid "Corrects the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering."
msgstr ""
-#: ../gui/wxpython/menustrings.py:638 ../gui/wxpython/menustrings.py:1581
+#: ../gui/wxpython/menustrings.py:615 ../gui/wxpython/menustrings.py:1521
msgid "Linear referencing"
msgstr ""
-#: ../gui/wxpython/menustrings.py:639 ../gui/wxpython/menustrings.py:1582
+#: ../gui/wxpython/menustrings.py:616 ../gui/wxpython/menustrings.py:1522
msgid "Create LRS"
msgstr ""
-#: ../gui/wxpython/menustrings.py:640 ../gui/wxpython/menustrings.py:1583
+#: ../gui/wxpython/menustrings.py:617 ../gui/wxpython/menustrings.py:1523
msgid "Creates a linear reference system."
msgstr ""
-#: ../gui/wxpython/menustrings.py:641 ../gui/wxpython/menustrings.py:1584
+#: ../gui/wxpython/menustrings.py:618 ../gui/wxpython/menustrings.py:1524
msgid "Create stationing"
msgstr ""
-#: ../gui/wxpython/menustrings.py:642 ../gui/wxpython/menustrings.py:1585
+#: ../gui/wxpython/menustrings.py:619 ../gui/wxpython/menustrings.py:1525
msgid "Creates stationing from input lines, and linear reference system."
msgstr ""
-#: ../gui/wxpython/menustrings.py:643 ../gui/wxpython/menustrings.py:1586
+#: ../gui/wxpython/menustrings.py:620 ../gui/wxpython/menustrings.py:1526
msgid "Create points/segments"
msgstr ""
-#: ../gui/wxpython/menustrings.py:644 ../gui/wxpython/menustrings.py:1587
+#: ../gui/wxpython/menustrings.py:621 ../gui/wxpython/menustrings.py:1527
msgid "Creates points/segments from input lines, linear reference system and positions read from stdin or a file."
msgstr ""
-#: ../gui/wxpython/menustrings.py:645 ../gui/wxpython/menustrings.py:1588
+#: ../gui/wxpython/menustrings.py:622 ../gui/wxpython/menustrings.py:1528
msgid "Find line id and offset"
msgstr ""
-#: ../gui/wxpython/menustrings.py:646 ../gui/wxpython/menustrings.py:1589
+#: ../gui/wxpython/menustrings.py:623 ../gui/wxpython/menustrings.py:1529
msgid "Finds line id and real km+offset for given points in vector map using linear reference system."
msgstr ""
-#: ../gui/wxpython/menustrings.py:647 ../gui/wxpython/menustrings.py:1590
+#: ../gui/wxpython/menustrings.py:624 ../gui/wxpython/menustrings.py:1530
msgid "Nearest features"
msgstr ""
-#: ../gui/wxpython/menustrings.py:648 ../gui/wxpython/menustrings.py:1591
+#: ../gui/wxpython/menustrings.py:625 ../gui/wxpython/menustrings.py:1531
msgid "Finds the nearest element in vector map 'to' for elements in vector map 'from'."
msgstr ""
-#: ../gui/wxpython/menustrings.py:649 ../gui/wxpython/menustrings.py:1592
+#: ../gui/wxpython/menustrings.py:626 ../gui/wxpython/menustrings.py:1532
msgid "Network analysis"
msgstr ""
-#: ../gui/wxpython/menustrings.py:651 ../gui/wxpython/menustrings.py:1594
+#: ../gui/wxpython/menustrings.py:628 ../gui/wxpython/menustrings.py:1534
msgid "Tool for interactive vector network analysis."
msgstr ""
-#: ../gui/wxpython/menustrings.py:652 ../gui/wxpython/menustrings.py:1595
+#: ../gui/wxpython/menustrings.py:629 ../gui/wxpython/menustrings.py:1535
msgid "Network preparation"
msgstr ""
-#: ../gui/wxpython/menustrings.py:653 ../gui/wxpython/menustrings.py:1596
+#: ../gui/wxpython/menustrings.py:630 ../gui/wxpython/menustrings.py:1536
msgid "Performs network maintenance."
msgstr ""
-#: ../gui/wxpython/menustrings.py:654 ../gui/wxpython/menustrings.py:1597
+#: ../gui/wxpython/menustrings.py:631 ../gui/wxpython/menustrings.py:1537
msgid "Allocate subnets"
msgstr ""
-#: ../gui/wxpython/menustrings.py:655 ../gui/wxpython/menustrings.py:1598
+#: ../gui/wxpython/menustrings.py:632 ../gui/wxpython/menustrings.py:1538
msgid "Allocates subnets for nearest centers (direction from center). center node must be opened (costs >= 0). Costs of center node are used in calculation"
msgstr ""
-#: ../gui/wxpython/menustrings.py:656 ../gui/wxpython/menustrings.py:1599
+#: ../gui/wxpython/menustrings.py:633 ../gui/wxpython/menustrings.py:1539
msgid "Split net"
msgstr ""
-#: ../gui/wxpython/menustrings.py:657 ../gui/wxpython/menustrings.py:1600
+#: ../gui/wxpython/menustrings.py:634 ../gui/wxpython/menustrings.py:1540
msgid "Splits net by cost isolines. Splits net to bands between cost isolines (direction from center). Center node must be opened (costs >= 0). Costs of center node are used in calculation."
msgstr ""
-#: ../gui/wxpython/menustrings.py:658 ../gui/wxpython/menustrings.py:1601
+#: ../gui/wxpython/menustrings.py:635 ../gui/wxpython/menustrings.py:1541
msgid "Shortest path"
msgstr ""
-#: ../gui/wxpython/menustrings.py:659 ../gui/wxpython/menustrings.py:1602
+#: ../gui/wxpython/menustrings.py:636 ../gui/wxpython/menustrings.py:1542
msgid "Finds shortest path on vector network."
msgstr ""
-#: ../gui/wxpython/menustrings.py:660 ../gui/wxpython/menustrings.py:1603
+#: ../gui/wxpython/menustrings.py:637 ../gui/wxpython/menustrings.py:1543
msgid "Shortest path for sets of features"
msgstr ""
-#: ../gui/wxpython/menustrings.py:661 ../gui/wxpython/menustrings.py:1604
+#: ../gui/wxpython/menustrings.py:638 ../gui/wxpython/menustrings.py:1544
msgid "Computes shortest distance via the network between the given sets of features. Finds the shortest paths from each 'from' point to the nearest 'to' feature and various information about this relation are uploaded to the attribute table."
msgstr ""
-#: ../gui/wxpython/menustrings.py:662 ../gui/wxpython/menustrings.py:1605
+#: ../gui/wxpython/menustrings.py:639 ../gui/wxpython/menustrings.py:1545
msgid "Shortest path using timetables"
msgstr ""
-#: ../gui/wxpython/menustrings.py:663 ../gui/wxpython/menustrings.py:1606
+#: ../gui/wxpython/menustrings.py:640 ../gui/wxpython/menustrings.py:1546
msgid "Finds shortest path using timetables."
msgstr ""
-#: ../gui/wxpython/menustrings.py:664 ../gui/wxpython/menustrings.py:1607
+#: ../gui/wxpython/menustrings.py:641 ../gui/wxpython/menustrings.py:1547
msgid "Shortest path for all pairs"
msgstr ""
-#: ../gui/wxpython/menustrings.py:665 ../gui/wxpython/menustrings.py:1608
+#: ../gui/wxpython/menustrings.py:642 ../gui/wxpython/menustrings.py:1548
msgid "Computes the shortest path between all pairs of nodes in the network."
msgstr ""
-#: ../gui/wxpython/menustrings.py:666 ../gui/wxpython/menustrings.py:1609
+#: ../gui/wxpython/menustrings.py:643 ../gui/wxpython/menustrings.py:1549
msgid "Visibility network"
msgstr ""
-#: ../gui/wxpython/menustrings.py:667 ../gui/wxpython/menustrings.py:1610
+#: ../gui/wxpython/menustrings.py:644 ../gui/wxpython/menustrings.py:1550
msgid "Performs visibility graph construction."
msgstr ""
-#: ../gui/wxpython/menustrings.py:668 ../gui/wxpython/menustrings.py:1611
+#: ../gui/wxpython/menustrings.py:645 ../gui/wxpython/menustrings.py:1551
msgid "Bridges and articulation points"
msgstr ""
-#: ../gui/wxpython/menustrings.py:669 ../gui/wxpython/menustrings.py:1612
+#: ../gui/wxpython/menustrings.py:646 ../gui/wxpython/menustrings.py:1552
msgid "Computes bridges and articulation points in the network."
msgstr ""
-#: ../gui/wxpython/menustrings.py:670 ../gui/wxpython/menustrings.py:1613
+#: ../gui/wxpython/menustrings.py:647 ../gui/wxpython/menustrings.py:1553
msgid "Maximum flow"
msgstr ""
-#: ../gui/wxpython/menustrings.py:671 ../gui/wxpython/menustrings.py:1614
+#: ../gui/wxpython/menustrings.py:648 ../gui/wxpython/menustrings.py:1554
msgid "Computes the maximum flow between two sets of nodes in the network."
msgstr ""
-#: ../gui/wxpython/menustrings.py:672 ../gui/wxpython/menustrings.py:1615
+#: ../gui/wxpython/menustrings.py:649 ../gui/wxpython/menustrings.py:1555
msgid "Vertex connectivity"
msgstr ""
-#: ../gui/wxpython/menustrings.py:673 ../gui/wxpython/menustrings.py:1616
+#: ../gui/wxpython/menustrings.py:650 ../gui/wxpython/menustrings.py:1556
msgid "Computes vertex connectivity between two sets of nodes in the network."
msgstr ""
-#: ../gui/wxpython/menustrings.py:674 ../gui/wxpython/menustrings.py:1617
+#: ../gui/wxpython/menustrings.py:651 ../gui/wxpython/menustrings.py:1557
msgid "Components"
msgstr ""
-#: ../gui/wxpython/menustrings.py:675 ../gui/wxpython/menustrings.py:1618
+#: ../gui/wxpython/menustrings.py:652 ../gui/wxpython/menustrings.py:1558
msgid "Computes strongly and weakly connected components in the network."
msgstr ""
-#: ../gui/wxpython/menustrings.py:676 ../gui/wxpython/menustrings.py:1619
+#: ../gui/wxpython/menustrings.py:653 ../gui/wxpython/menustrings.py:1559
msgid "Centrality"
msgstr ""
-#: ../gui/wxpython/menustrings.py:677 ../gui/wxpython/menustrings.py:1620
+#: ../gui/wxpython/menustrings.py:654 ../gui/wxpython/menustrings.py:1560
msgid "Computes degree, centrality, betweeness, closeness and eigenvector centrality measures in the network."
msgstr ""
-#: ../gui/wxpython/menustrings.py:678 ../gui/wxpython/menustrings.py:1621
+#: ../gui/wxpython/menustrings.py:655 ../gui/wxpython/menustrings.py:1561
msgid "Steiner tree"
msgstr ""
-#: ../gui/wxpython/menustrings.py:679 ../gui/wxpython/menustrings.py:1622
+#: ../gui/wxpython/menustrings.py:656 ../gui/wxpython/menustrings.py:1562
msgid "Creates Steiner tree for the network and given terminals. Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm is used in this module so the result may be sub optimal."
msgstr ""
-#: ../gui/wxpython/menustrings.py:680 ../gui/wxpython/menustrings.py:1623
+#: ../gui/wxpython/menustrings.py:657 ../gui/wxpython/menustrings.py:1563
msgid "Minimum spanning tree"
msgstr ""
-#: ../gui/wxpython/menustrings.py:681 ../gui/wxpython/menustrings.py:1624
+#: ../gui/wxpython/menustrings.py:658 ../gui/wxpython/menustrings.py:1564
msgid "Computes minimum spanning tree for the network."
msgstr ""
-#: ../gui/wxpython/menustrings.py:682 ../gui/wxpython/menustrings.py:1625
+#: ../gui/wxpython/menustrings.py:659 ../gui/wxpython/menustrings.py:1565
msgid "Traveling salesman analysis"
msgstr ""
-#: ../gui/wxpython/menustrings.py:683 ../gui/wxpython/menustrings.py:1626
+#: ../gui/wxpython/menustrings.py:660 ../gui/wxpython/menustrings.py:1566
msgid "Creates a cycle connecting given nodes (Traveling salesman problem). Note that TSP is NP-hard, heuristic algorithm is used by this module and created cycle may be sub optimal"
msgstr ""
-#: ../gui/wxpython/menustrings.py:684 ../gui/wxpython/menustrings.py:685
-#: ../gui/wxpython/menustrings.py:1627 ../gui/wxpython/menustrings.py:1628
+#: ../gui/wxpython/menustrings.py:661 ../gui/wxpython/menustrings.py:662
+#: ../gui/wxpython/menustrings.py:1567 ../gui/wxpython/menustrings.py:1568
msgid "Overlay vector maps"
msgstr ""
-#: ../gui/wxpython/menustrings.py:686 ../gui/wxpython/menustrings.py:1629
+#: ../gui/wxpython/menustrings.py:663 ../gui/wxpython/menustrings.py:1569
msgid "Overlays two vector maps offering clip, intersection, difference, symmetrical difference, union operators."
msgstr ""
-#: ../gui/wxpython/menustrings.py:687 ../gui/wxpython/menustrings.py:1630
+#: ../gui/wxpython/menustrings.py:664 ../gui/wxpython/menustrings.py:1570
msgid "Patch vector maps"
msgstr ""
-#: ../gui/wxpython/menustrings.py:688 ../gui/wxpython/menustrings.py:1631
+#: ../gui/wxpython/menustrings.py:665 ../gui/wxpython/menustrings.py:1571
msgid "Creates a new vector map by combining other vector maps."
msgstr ""
-#: ../gui/wxpython/menustrings.py:689 ../gui/wxpython/menustrings.py:1632
+#: ../gui/wxpython/menustrings.py:666 ../gui/wxpython/menustrings.py:1572
msgid "Manage categories"
msgstr ""
-#: ../gui/wxpython/menustrings.py:690 ../gui/wxpython/menustrings.py:1633
+#: ../gui/wxpython/menustrings.py:667 ../gui/wxpython/menustrings.py:1573
msgid "Change or report categories"
msgstr ""
-#: ../gui/wxpython/menustrings.py:691 ../gui/wxpython/menustrings.py:1634
+#: ../gui/wxpython/menustrings.py:668 ../gui/wxpython/menustrings.py:1574
msgid "Attaches, deletes or reports vector categories to map geometry."
msgstr ""
-#: ../gui/wxpython/menustrings.py:693 ../gui/wxpython/menustrings.py:1636
+#: ../gui/wxpython/menustrings.py:670 ../gui/wxpython/menustrings.py:1576
msgid "Changes vector category values for an existing vector map according to results of SQL queries or a value in attribute table column."
msgstr ""
-#: ../gui/wxpython/menustrings.py:695 ../gui/wxpython/menustrings.py:1638
+#: ../gui/wxpython/menustrings.py:672 ../gui/wxpython/menustrings.py:1578
msgid "Update area attributes from raster"
msgstr ""
-#: ../gui/wxpython/menustrings.py:696 ../gui/wxpython/menustrings.py:1639
+#: ../gui/wxpython/menustrings.py:673 ../gui/wxpython/menustrings.py:1579
msgid "Calculates univariate statistics from a raster map based on a vector map and uploads statistics to new attribute columns."
msgstr ""
-#: ../gui/wxpython/menustrings.py:697 ../gui/wxpython/menustrings.py:1640
+#: ../gui/wxpython/menustrings.py:674 ../gui/wxpython/menustrings.py:1580
msgid "Update area attributes from vector"
msgstr ""
-#: ../gui/wxpython/menustrings.py:698 ../gui/wxpython/menustrings.py:1641
+#: ../gui/wxpython/menustrings.py:675 ../gui/wxpython/menustrings.py:1581
msgid "Count points in areas, calculate statistics from point attributes."
msgstr ""
-#: ../gui/wxpython/menustrings.py:699 ../gui/wxpython/menustrings.py:1642
+#: ../gui/wxpython/menustrings.py:676 ../gui/wxpython/menustrings.py:1582
msgid "Update point attributes from areas"
msgstr ""
-#: ../gui/wxpython/menustrings.py:700 ../gui/wxpython/menustrings.py:1643
+#: ../gui/wxpython/menustrings.py:677 ../gui/wxpython/menustrings.py:1583
msgid "Uploads vector values at positions of vector points to the table."
msgstr ""
-#: ../gui/wxpython/menustrings.py:701 ../gui/wxpython/menustrings.py:1644
+#: ../gui/wxpython/menustrings.py:678 ../gui/wxpython/menustrings.py:1584
msgid "Update database values from vector"
msgstr ""
-#: ../gui/wxpython/menustrings.py:702 ../gui/wxpython/menustrings.py:1645
+#: ../gui/wxpython/menustrings.py:679 ../gui/wxpython/menustrings.py:1585
msgid "Populates attribute values from vector features."
msgstr ""
-#: ../gui/wxpython/menustrings.py:703 ../gui/wxpython/menustrings.py:1646
+#: ../gui/wxpython/menustrings.py:680 ../gui/wxpython/menustrings.py:1586
msgid "Sample raster maps at point locations"
msgstr ""
-#: ../gui/wxpython/menustrings.py:704 ../gui/wxpython/menustrings.py:1647
+#: ../gui/wxpython/menustrings.py:681 ../gui/wxpython/menustrings.py:1587
msgid "Uploads raster values at positions of vector points to the table."
msgstr ""
-#: ../gui/wxpython/menustrings.py:705 ../gui/wxpython/menustrings.py:1648
+#: ../gui/wxpython/menustrings.py:682 ../gui/wxpython/menustrings.py:1588
msgid "Sample raster neighborhood around points"
msgstr ""
-#: ../gui/wxpython/menustrings.py:706 ../gui/wxpython/menustrings.py:1649
+#: ../gui/wxpython/menustrings.py:683 ../gui/wxpython/menustrings.py:1589
msgid "Samples a raster map at vector point locations."
msgstr ""
-#: ../gui/wxpython/menustrings.py:707 ../gui/wxpython/menustrings.py:1650
+#: ../gui/wxpython/menustrings.py:684 ../gui/wxpython/menustrings.py:1590
msgid "Generate area for current region"
msgstr ""
-#: ../gui/wxpython/menustrings.py:708 ../gui/wxpython/menustrings.py:1651
+#: ../gui/wxpython/menustrings.py:685 ../gui/wxpython/menustrings.py:1591
msgid "Creates a vector polygon from the current region extent."
msgstr ""
-#: ../gui/wxpython/menustrings.py:709 ../gui/wxpython/menustrings.py:1652
+#: ../gui/wxpython/menustrings.py:686 ../gui/wxpython/menustrings.py:1592
msgid "Generate areas from points"
msgstr ""
-#: ../gui/wxpython/menustrings.py:710 ../gui/wxpython/menustrings.py:1653
+#: ../gui/wxpython/menustrings.py:687 ../gui/wxpython/menustrings.py:1593
msgid "Convex hull"
msgstr ""
-#: ../gui/wxpython/menustrings.py:711 ../gui/wxpython/menustrings.py:1654
+#: ../gui/wxpython/menustrings.py:688 ../gui/wxpython/menustrings.py:1594
msgid "Produces a 2D/3D convex hull for a given vector map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:712 ../gui/wxpython/menustrings.py:1655
+#: ../gui/wxpython/menustrings.py:689 ../gui/wxpython/menustrings.py:1595
msgid "Delaunay triangles"
msgstr ""
-#: ../gui/wxpython/menustrings.py:713 ../gui/wxpython/menustrings.py:1656
+#: ../gui/wxpython/menustrings.py:690 ../gui/wxpython/menustrings.py:1596
msgid "Creates a Delaunay triangulation from an input vector map containing points or centroids."
msgstr ""
-#: ../gui/wxpython/menustrings.py:714 ../gui/wxpython/menustrings.py:1657
+#: ../gui/wxpython/menustrings.py:691 ../gui/wxpython/menustrings.py:1597
msgid "Voronoi diagram/Thiessen polygons"
msgstr ""
-#: ../gui/wxpython/menustrings.py:715 ../gui/wxpython/menustrings.py:1658
+#: ../gui/wxpython/menustrings.py:692 ../gui/wxpython/menustrings.py:1598
msgid "Creates a Voronoi diagram in current region from an input vector map containing points or centroids."
msgstr ""
-#: ../gui/wxpython/menustrings.py:716 ../gui/wxpython/menustrings.py:1659
+#: ../gui/wxpython/menustrings.py:693 ../gui/wxpython/menustrings.py:1599
msgid "Generate grid"
msgstr ""
-#: ../gui/wxpython/menustrings.py:717 ../gui/wxpython/menustrings.py:1660
+#: ../gui/wxpython/menustrings.py:694 ../gui/wxpython/menustrings.py:1600
msgid "Creates a vector map of a user-defined grid."
msgstr ""
-#: ../gui/wxpython/menustrings.py:718 ../gui/wxpython/menustrings.py:1661
+#: ../gui/wxpython/menustrings.py:695 ../gui/wxpython/menustrings.py:1601
msgid "Generate points"
msgstr ""
-#: ../gui/wxpython/menustrings.py:719 ../gui/wxpython/menustrings.py:1662
+#: ../gui/wxpython/menustrings.py:696 ../gui/wxpython/menustrings.py:1602
msgid "Generate from database"
msgstr ""
-#: ../gui/wxpython/menustrings.py:720 ../gui/wxpython/menustrings.py:1663
+#: ../gui/wxpython/menustrings.py:697 ../gui/wxpython/menustrings.py:1603
msgid "Creates new vector (points) map from database table containing coordinates."
msgstr ""
-#: ../gui/wxpython/menustrings.py:721 ../gui/wxpython/menustrings.py:1664
+#: ../gui/wxpython/menustrings.py:698 ../gui/wxpython/menustrings.py:1604
msgid "Generate points along lines"
msgstr ""
-#: ../gui/wxpython/menustrings.py:722 ../gui/wxpython/menustrings.py:1665
+#: ../gui/wxpython/menustrings.py:699 ../gui/wxpython/menustrings.py:1605
msgid "Creates points along input lines in new vector map with 2 layers."
msgstr ""
-#: ../gui/wxpython/menustrings.py:723 ../gui/wxpython/menustrings.py:1666
+#: ../gui/wxpython/menustrings.py:700 ../gui/wxpython/menustrings.py:1606
msgid "Generate random points"
msgstr ""
-#: ../gui/wxpython/menustrings.py:724 ../gui/wxpython/menustrings.py:1667
+#: ../gui/wxpython/menustrings.py:701 ../gui/wxpython/menustrings.py:1607
msgid "Generates random 2D/3D vector points."
msgstr ""
-#: ../gui/wxpython/menustrings.py:727 ../gui/wxpython/menustrings.py:1670
+#: ../gui/wxpython/menustrings.py:702 ../gui/wxpython/menustrings.py:1608
+msgid "Perturb points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:703 ../gui/wxpython/menustrings.py:1609
+msgid "Random location perturbations of vector points."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:704 ../gui/wxpython/menustrings.py:1610
msgid "Remove outliers in point sets"
msgstr ""
-#: ../gui/wxpython/menustrings.py:732 ../gui/wxpython/menustrings.py:1675
+#: ../gui/wxpython/menustrings.py:706 ../gui/wxpython/menustrings.py:1612
+msgid "Test/training point sets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:707 ../gui/wxpython/menustrings.py:1613
+msgid "Randomly partition points into test/train sets."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:709 ../gui/wxpython/menustrings.py:1615
msgid "Basic vector metadata"
msgstr ""
-#: ../gui/wxpython/menustrings.py:733 ../gui/wxpython/menustrings.py:1676
+#: ../gui/wxpython/menustrings.py:710 ../gui/wxpython/menustrings.py:1616
msgid "Outputs basic information about a vector map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:734 ../gui/wxpython/menustrings.py:1677
+#: ../gui/wxpython/menustrings.py:711 ../gui/wxpython/menustrings.py:1617
msgid "Classify attribute data"
msgstr ""
-#: ../gui/wxpython/menustrings.py:735 ../gui/wxpython/menustrings.py:1678
+#: ../gui/wxpython/menustrings.py:712 ../gui/wxpython/menustrings.py:1618
msgid "Classifies attribute data, e.g. for thematic mapping"
msgstr ""
-#: ../gui/wxpython/menustrings.py:736 ../gui/wxpython/menustrings.py:1679
+#: ../gui/wxpython/menustrings.py:713 ../gui/wxpython/menustrings.py:1619
msgid "Report topology by category"
msgstr ""
-#: ../gui/wxpython/menustrings.py:737 ../gui/wxpython/menustrings.py:1680
+#: ../gui/wxpython/menustrings.py:714 ../gui/wxpython/menustrings.py:1620
msgid "Reports geometry statistics for vector maps."
msgstr ""
-#: ../gui/wxpython/menustrings.py:738 ../gui/wxpython/menustrings.py:1681
+#: ../gui/wxpython/menustrings.py:715 ../gui/wxpython/menustrings.py:1621
msgid "Univariate attribute statistics for points"
msgstr ""
-#: ../gui/wxpython/menustrings.py:739 ../gui/wxpython/menustrings.py:1682
+#: ../gui/wxpython/menustrings.py:716 ../gui/wxpython/menustrings.py:1622
msgid "Calculates univariate statistics of vector map features. Variance and standard deviation is calculated only for points if specified."
msgstr ""
-#: ../gui/wxpython/menustrings.py:740 ../gui/wxpython/menustrings.py:1683
+#: ../gui/wxpython/menustrings.py:717 ../gui/wxpython/menustrings.py:1623
msgid "Univariate statistics for attribute columns"
msgstr ""
-#: ../gui/wxpython/menustrings.py:741 ../gui/wxpython/menustrings.py:1684
+#: ../gui/wxpython/menustrings.py:718 ../gui/wxpython/menustrings.py:1624
msgid "Calculates univariate statistics on selected table column for a GRASS vector map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:742 ../gui/wxpython/menustrings.py:1685
+#: ../gui/wxpython/menustrings.py:719 ../gui/wxpython/menustrings.py:1625
msgid "Quadrat indices"
msgstr ""
-#: ../gui/wxpython/menustrings.py:744 ../gui/wxpython/menustrings.py:1687
+#: ../gui/wxpython/menustrings.py:720 ../gui/wxpython/menustrings.py:1626
+msgid "Indices for quadrat counts of vector point lists."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:721 ../gui/wxpython/menustrings.py:1627
msgid "Test normality"
msgstr ""
-#: ../gui/wxpython/menustrings.py:746 ../gui/wxpython/menustrings.py:1689
+#: ../gui/wxpython/menustrings.py:722 ../gui/wxpython/menustrings.py:1628
+msgid "Tests for normality for vector points."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:723 ../gui/wxpython/menustrings.py:1629
msgid "&Imagery"
msgstr ""
-#: ../gui/wxpython/menustrings.py:747 ../gui/wxpython/menustrings.py:1690
+#: ../gui/wxpython/menustrings.py:724 ../gui/wxpython/menustrings.py:1630
msgid "Develop images and groups"
msgstr ""
-#: ../gui/wxpython/menustrings.py:748 ../gui/wxpython/menustrings.py:1691
+#: ../gui/wxpython/menustrings.py:725 ../gui/wxpython/menustrings.py:1631
msgid "Create/edit group"
msgstr ""
-#: ../gui/wxpython/menustrings.py:749 ../gui/wxpython/menustrings.py:1692
+#: ../gui/wxpython/menustrings.py:726 ../gui/wxpython/menustrings.py:1632
msgid "Creates, edits, and lists groups of imagery files."
msgstr ""
-#: ../gui/wxpython/menustrings.py:750 ../gui/wxpython/menustrings.py:1693
+#: ../gui/wxpython/menustrings.py:727 ../gui/wxpython/menustrings.py:1633
msgid "Target group"
msgstr ""
-#: ../gui/wxpython/menustrings.py:751 ../gui/wxpython/menustrings.py:1694
+#: ../gui/wxpython/menustrings.py:728 ../gui/wxpython/menustrings.py:1634
msgid "Targets an imagery group to a GRASS location and mapset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:752 ../gui/wxpython/menustrings.py:1695
+#: ../gui/wxpython/menustrings.py:729 ../gui/wxpython/menustrings.py:1635
msgid "Mosaic images"
msgstr ""
-#: ../gui/wxpython/menustrings.py:753 ../gui/wxpython/menustrings.py:1696
+#: ../gui/wxpython/menustrings.py:730 ../gui/wxpython/menustrings.py:1636
msgid "Mosaics several images and extends colormap."
msgstr ""
-#: ../gui/wxpython/menustrings.py:754 ../gui/wxpython/menustrings.py:1697
+#: ../gui/wxpython/menustrings.py:731 ../gui/wxpython/menustrings.py:1637
msgid "Manage image colors"
msgstr ""
-#: ../gui/wxpython/menustrings.py:755 ../gui/wxpython/menustrings.py:1698
+#: ../gui/wxpython/menustrings.py:732 ../gui/wxpython/menustrings.py:1638
msgid "Color balance for RGB"
msgstr ""
-#: ../gui/wxpython/menustrings.py:756 ../gui/wxpython/menustrings.py:1699
+#: ../gui/wxpython/menustrings.py:733 ../gui/wxpython/menustrings.py:1639
msgid "Performs auto-balancing of colors for RGB images."
msgstr ""
-#: ../gui/wxpython/menustrings.py:757 ../gui/wxpython/menustrings.py:1700
+#: ../gui/wxpython/menustrings.py:734 ../gui/wxpython/menustrings.py:1640
msgid "HIS to RGB"
msgstr ""
-#: ../gui/wxpython/menustrings.py:758 ../gui/wxpython/menustrings.py:1701
+#: ../gui/wxpython/menustrings.py:735 ../gui/wxpython/menustrings.py:1641
msgid "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to RGB (Red-Green-Blue) color space."
msgstr ""
-#: ../gui/wxpython/menustrings.py:760 ../gui/wxpython/menustrings.py:1703
+#: ../gui/wxpython/menustrings.py:737 ../gui/wxpython/menustrings.py:1643
msgid "Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-Intensity-Saturation) color space."
msgstr ""
-#: ../gui/wxpython/menustrings.py:761 ../gui/wxpython/menustrings.py:1704
+#: ../gui/wxpython/menustrings.py:738 ../gui/wxpython/menustrings.py:1644
msgid "Rectify image or raster"
msgstr ""
-#: ../gui/wxpython/menustrings.py:762 ../gui/wxpython/menustrings.py:1705
+#: ../gui/wxpython/menustrings.py:739 ../gui/wxpython/menustrings.py:1645
msgid "Rectifies an image by computing a coordinate transformation for each pixel in the image based on the control points."
msgstr ""
-#: ../gui/wxpython/menustrings.py:764 ../gui/wxpython/menustrings.py:1707
+#: ../gui/wxpython/menustrings.py:741 ../gui/wxpython/menustrings.py:1647
msgid "Generate histogram of image"
msgstr ""
-#: ../gui/wxpython/menustrings.py:765 ../gui/wxpython/menustrings.py:1708
+#: ../gui/wxpython/menustrings.py:742 ../gui/wxpython/menustrings.py:1648
msgid "Spectral response"
msgstr ""
-#: ../gui/wxpython/menustrings.py:766 ../gui/wxpython/menustrings.py:1709
+#: ../gui/wxpython/menustrings.py:743 ../gui/wxpython/menustrings.py:1649
msgid "Displays spectral response at user specified locations in group or images."
msgstr ""
-#: ../gui/wxpython/menustrings.py:767 ../gui/wxpython/menustrings.py:1710
+#: ../gui/wxpython/menustrings.py:744 ../gui/wxpython/menustrings.py:1650
msgid "Pan sharpening"
msgstr ""
-#: ../gui/wxpython/menustrings.py:768 ../gui/wxpython/menustrings.py:1711
+#: ../gui/wxpython/menustrings.py:745 ../gui/wxpython/menustrings.py:1651
msgid "Image fusion algorithms to sharpen multispectral with high-res panchromatic channels"
msgstr ""
-#: ../gui/wxpython/menustrings.py:769 ../gui/wxpython/menustrings.py:1712
+#: ../gui/wxpython/menustrings.py:746 ../gui/wxpython/menustrings.py:1652
msgid "Classify image"
msgstr ""
-#: ../gui/wxpython/menustrings.py:770 ../gui/wxpython/menustrings.py:1713
+#: ../gui/wxpython/menustrings.py:747 ../gui/wxpython/menustrings.py:1653
msgid "Clustering input for unsupervised classification"
msgstr ""
-#: ../gui/wxpython/menustrings.py:771 ../gui/wxpython/menustrings.py:1714
+#: ../gui/wxpython/menustrings.py:748 ../gui/wxpython/menustrings.py:1654
msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm. The resulting signature file is used as input for i.maxlik, to generate an unsupervised image classification."
msgstr ""
-#: ../gui/wxpython/menustrings.py:772 ../gui/wxpython/menustrings.py:1715
+#: ../gui/wxpython/menustrings.py:749 ../gui/wxpython/menustrings.py:1655
msgid "Input for supervised MLC"
msgstr ""
-#: ../gui/wxpython/menustrings.py:773 ../gui/wxpython/menustrings.py:1716
+#: ../gui/wxpython/menustrings.py:750 ../gui/wxpython/menustrings.py:1656
msgid "Generates statistics for i.maxlik from raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:774 ../gui/wxpython/menustrings.py:1717
+#: ../gui/wxpython/menustrings.py:751 ../gui/wxpython/menustrings.py:1657
msgid "Maximum likelihood classification (MLC)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:775 ../gui/wxpython/menustrings.py:1718
+#: ../gui/wxpython/menustrings.py:752 ../gui/wxpython/menustrings.py:1658
msgid "Classifies the cell spectral reflectances in imagery data. Classification is based on the spectral signature information generated by either i.cluster, g.gui.iclass, or i.gensig."
msgstr ""
-#: ../gui/wxpython/menustrings.py:776 ../gui/wxpython/menustrings.py:1719
-#: ../gui/wxpython/menustrings.py:1999
+#: ../gui/wxpython/menustrings.py:753 ../gui/wxpython/menustrings.py:1659
+#: ../gui/wxpython/menustrings.py:1924
msgid "Interactive input for supervised classification"
msgstr ""
-#: ../gui/wxpython/menustrings.py:777 ../gui/wxpython/menustrings.py:1720
-#: ../gui/wxpython/menustrings.py:2000
+#: ../gui/wxpython/menustrings.py:754 ../gui/wxpython/menustrings.py:1660
+#: ../gui/wxpython/menustrings.py:1925
msgid "Generates spectral signatures by allowing the user to outline training areas."
msgstr ""
-#: ../gui/wxpython/menustrings.py:778 ../gui/wxpython/menustrings.py:1721
+#: ../gui/wxpython/menustrings.py:755 ../gui/wxpython/menustrings.py:1661
msgid "Input for supervised SMAP"
msgstr ""
-#: ../gui/wxpython/menustrings.py:779 ../gui/wxpython/menustrings.py:1722
+#: ../gui/wxpython/menustrings.py:756 ../gui/wxpython/menustrings.py:1662
msgid "Generates statistics for i.smap from raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:780 ../gui/wxpython/menustrings.py:1723
+#: ../gui/wxpython/menustrings.py:757 ../gui/wxpython/menustrings.py:1663
msgid "Sequential maximum a posteriori classification (SMAP)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:781 ../gui/wxpython/menustrings.py:1724
+#: ../gui/wxpython/menustrings.py:758 ../gui/wxpython/menustrings.py:1664
msgid "Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation."
msgstr ""
-#: ../gui/wxpython/menustrings.py:782 ../gui/wxpython/menustrings.py:1725
+#: ../gui/wxpython/menustrings.py:759 ../gui/wxpython/menustrings.py:1665
msgid "Object segmentation"
msgstr ""
-#: ../gui/wxpython/menustrings.py:783 ../gui/wxpython/menustrings.py:1726
+#: ../gui/wxpython/menustrings.py:760 ../gui/wxpython/menustrings.py:1666
msgid "Identifies segments (objects) from imagery data."
msgstr ""
-#: ../gui/wxpython/menustrings.py:784 ../gui/wxpython/menustrings.py:1727
+#: ../gui/wxpython/menustrings.py:761 ../gui/wxpython/menustrings.py:1667
msgid "Filter image"
msgstr ""
-#: ../gui/wxpython/menustrings.py:785 ../gui/wxpython/menustrings.py:1728
+#: ../gui/wxpython/menustrings.py:762 ../gui/wxpython/menustrings.py:1668
msgid "Edge detection"
msgstr ""
-#: ../gui/wxpython/menustrings.py:786 ../gui/wxpython/menustrings.py:1729
+#: ../gui/wxpython/menustrings.py:763 ../gui/wxpython/menustrings.py:1669
msgid "Zero-crossing \"edge detection\" raster function for image processing."
msgstr ""
-#: ../gui/wxpython/menustrings.py:787 ../gui/wxpython/menustrings.py:1730
+#: ../gui/wxpython/menustrings.py:764 ../gui/wxpython/menustrings.py:1670
msgid "Matrix/convolving filter"
msgstr ""
-#: ../gui/wxpython/menustrings.py:788 ../gui/wxpython/menustrings.py:1731
+#: ../gui/wxpython/menustrings.py:765 ../gui/wxpython/menustrings.py:1671
msgid "Performs raster map matrix filter."
msgstr ""
-#: ../gui/wxpython/menustrings.py:789 ../gui/wxpython/menustrings.py:1732
+#: ../gui/wxpython/menustrings.py:766 ../gui/wxpython/menustrings.py:1672
msgid "Transform image"
msgstr ""
-#: ../gui/wxpython/menustrings.py:790 ../gui/wxpython/menustrings.py:1733
+#: ../gui/wxpython/menustrings.py:767 ../gui/wxpython/menustrings.py:1673
msgid "Canonical correlation"
msgstr ""
-#: ../gui/wxpython/menustrings.py:791 ../gui/wxpython/menustrings.py:1734
+#: ../gui/wxpython/menustrings.py:768 ../gui/wxpython/menustrings.py:1674
msgid "Canonical components analysis (CCA) program for image processing."
msgstr ""
-#: ../gui/wxpython/menustrings.py:792 ../gui/wxpython/menustrings.py:1735
+#: ../gui/wxpython/menustrings.py:769 ../gui/wxpython/menustrings.py:1675
msgid "Principal components"
msgstr ""
-#: ../gui/wxpython/menustrings.py:793 ../gui/wxpython/menustrings.py:1736
+#: ../gui/wxpython/menustrings.py:770 ../gui/wxpython/menustrings.py:1676
msgid "Principal components analysis (PCA) for image processing."
msgstr ""
-#: ../gui/wxpython/menustrings.py:794 ../gui/wxpython/menustrings.py:1737
+#: ../gui/wxpython/menustrings.py:771 ../gui/wxpython/menustrings.py:1677
msgid "Fast Fourier"
msgstr ""
-#: ../gui/wxpython/menustrings.py:795 ../gui/wxpython/menustrings.py:1738
+#: ../gui/wxpython/menustrings.py:772 ../gui/wxpython/menustrings.py:1678
msgid "Fast Fourier Transform (FFT) for image processing."
msgstr ""
-#: ../gui/wxpython/menustrings.py:796 ../gui/wxpython/menustrings.py:1739
+#: ../gui/wxpython/menustrings.py:773 ../gui/wxpython/menustrings.py:1679
msgid "Inverse Fast Fourier"
msgstr ""
-#: ../gui/wxpython/menustrings.py:797 ../gui/wxpython/menustrings.py:1740
+#: ../gui/wxpython/menustrings.py:774 ../gui/wxpython/menustrings.py:1680
msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
msgstr ""
-#: ../gui/wxpython/menustrings.py:798 ../gui/wxpython/menustrings.py:1741
+#: ../gui/wxpython/menustrings.py:775 ../gui/wxpython/menustrings.py:1681
msgid "Satellite images tools"
msgstr ""
-#: ../gui/wxpython/menustrings.py:799 ../gui/wxpython/menustrings.py:1742
+#: ../gui/wxpython/menustrings.py:776 ../gui/wxpython/menustrings.py:1682
msgid "Aster DN to radiance/reflectance"
msgstr ""
-#: ../gui/wxpython/menustrings.py:800 ../gui/wxpython/menustrings.py:1743
+#: ../gui/wxpython/menustrings.py:777 ../gui/wxpython/menustrings.py:1683
msgid "Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature from ASTER DN."
msgstr ""
-#: ../gui/wxpython/menustrings.py:801 ../gui/wxpython/menustrings.py:1744
+#: ../gui/wxpython/menustrings.py:778 ../gui/wxpython/menustrings.py:1684
msgid "Landsat DN to radiance/reflectance"
msgstr ""
-#: ../gui/wxpython/menustrings.py:802 ../gui/wxpython/menustrings.py:1745
+#: ../gui/wxpython/menustrings.py:779 ../gui/wxpython/menustrings.py:1685
msgid "Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+/OLI"
msgstr ""
-#: ../gui/wxpython/menustrings.py:803 ../gui/wxpython/menustrings.py:1746
+#: ../gui/wxpython/menustrings.py:780 ../gui/wxpython/menustrings.py:1686
msgid "Landsat cloud cover assessment"
msgstr ""
-#: ../gui/wxpython/menustrings.py:804 ../gui/wxpython/menustrings.py:1747
+#: ../gui/wxpython/menustrings.py:781 ../gui/wxpython/menustrings.py:1687
msgid "Performs Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:805 ../gui/wxpython/menustrings.py:1748
+#: ../gui/wxpython/menustrings.py:782 ../gui/wxpython/menustrings.py:1688
msgid "Modis quality control"
msgstr ""
-#: ../gui/wxpython/menustrings.py:806 ../gui/wxpython/menustrings.py:1749
+#: ../gui/wxpython/menustrings.py:783 ../gui/wxpython/menustrings.py:1689
msgid "Extracts quality control parameters from MODIS QC layers."
msgstr ""
-#: ../gui/wxpython/menustrings.py:807 ../gui/wxpython/menustrings.py:1750
+#: ../gui/wxpython/menustrings.py:784 ../gui/wxpython/menustrings.py:1690
msgid "Atmospheric correction"
msgstr ""
-#: ../gui/wxpython/menustrings.py:808 ../gui/wxpython/menustrings.py:1751
+#: ../gui/wxpython/menustrings.py:785 ../gui/wxpython/menustrings.py:1691
msgid "Performs atmospheric correction using the 6S algorithm. 6S - Second Simulation of Satellite Signal in the Solar Spectrum."
msgstr ""
-#: ../gui/wxpython/menustrings.py:809 ../gui/wxpython/menustrings.py:1752
+#: ../gui/wxpython/menustrings.py:786 ../gui/wxpython/menustrings.py:1692
msgid "Topographic correction"
msgstr ""
-#: ../gui/wxpython/menustrings.py:810 ../gui/wxpython/menustrings.py:1753
+#: ../gui/wxpython/menustrings.py:787 ../gui/wxpython/menustrings.py:1693
msgid "Computes topographic correction of reflectance."
msgstr ""
-#: ../gui/wxpython/menustrings.py:811 ../gui/wxpython/menustrings.py:1754
+#: ../gui/wxpython/menustrings.py:788 ../gui/wxpython/menustrings.py:1694
msgid "Satellite images products"
msgstr ""
-#: ../gui/wxpython/menustrings.py:812 ../gui/wxpython/menustrings.py:1755
+#: ../gui/wxpython/menustrings.py:789 ../gui/wxpython/menustrings.py:1695
msgid "Vegetation indices"
msgstr ""
-#: ../gui/wxpython/menustrings.py:813 ../gui/wxpython/menustrings.py:1756
+#: ../gui/wxpython/menustrings.py:790 ../gui/wxpython/menustrings.py:1696
msgid "Calculates different types of vegetation indices. Uses red and nir bands mostly, and some indices require additional bands."
msgstr ""
-#: ../gui/wxpython/menustrings.py:814 ../gui/wxpython/menustrings.py:1757
+#: ../gui/wxpython/menustrings.py:791 ../gui/wxpython/menustrings.py:1697
msgid "Tasseled cap vegetation index"
msgstr ""
-#: ../gui/wxpython/menustrings.py:815 ../gui/wxpython/menustrings.py:1758
+#: ../gui/wxpython/menustrings.py:792 ../gui/wxpython/menustrings.py:1698
msgid "Performs Tasseled Cap (Kauth Thomas) transformation."
msgstr ""
-#: ../gui/wxpython/menustrings.py:816 ../gui/wxpython/menustrings.py:1759
+#: ../gui/wxpython/menustrings.py:793 ../gui/wxpython/menustrings.py:1699
msgid "Albedo"
msgstr ""
-#: ../gui/wxpython/menustrings.py:817 ../gui/wxpython/menustrings.py:1760
+#: ../gui/wxpython/menustrings.py:794 ../gui/wxpython/menustrings.py:1700
msgid "Computes broad band albedo from surface reflectance."
msgstr ""
-#: ../gui/wxpython/menustrings.py:818 ../gui/wxpython/menustrings.py:1761
+#: ../gui/wxpython/menustrings.py:795 ../gui/wxpython/menustrings.py:1701
msgid "Emissivity"
msgstr ""
-#: ../gui/wxpython/menustrings.py:819 ../gui/wxpython/menustrings.py:1762
+#: ../gui/wxpython/menustrings.py:796 ../gui/wxpython/menustrings.py:1702
msgid "Computes emissivity from NDVI, generic method for sparse land."
msgstr ""
-#: ../gui/wxpython/menustrings.py:820 ../gui/wxpython/menustrings.py:1763
+#: ../gui/wxpython/menustrings.py:797 ../gui/wxpython/menustrings.py:1703
msgid "Biomass growth"
msgstr ""
-#: ../gui/wxpython/menustrings.py:821 ../gui/wxpython/menustrings.py:1764
+#: ../gui/wxpython/menustrings.py:798 ../gui/wxpython/menustrings.py:1704
msgid "Computes biomass growth, precursor of crop yield calculation."
msgstr ""
-#: ../gui/wxpython/menustrings.py:822 ../gui/wxpython/menustrings.py:1765
+#: ../gui/wxpython/menustrings.py:799 ../gui/wxpython/menustrings.py:1705
msgid "Evapotranspiration calculation"
msgstr ""
-#: ../gui/wxpython/menustrings.py:823 ../gui/wxpython/menustrings.py:1766
+#: ../gui/wxpython/menustrings.py:800 ../gui/wxpython/menustrings.py:1706
msgid "Instantaneaous Net Radiation"
msgstr ""
-#: ../gui/wxpython/menustrings.py:824 ../gui/wxpython/menustrings.py:1767
+#: ../gui/wxpython/menustrings.py:801 ../gui/wxpython/menustrings.py:1707
msgid "Net radiation approximation (Bastiaanssen, 1995)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:825 ../gui/wxpython/menustrings.py:1768
+#: ../gui/wxpython/menustrings.py:802 ../gui/wxpython/menustrings.py:1708
msgid "Soil heat flux"
msgstr ""
-#: ../gui/wxpython/menustrings.py:826 ../gui/wxpython/menustrings.py:1769
+#: ../gui/wxpython/menustrings.py:803 ../gui/wxpython/menustrings.py:1709
msgid "Soil heat flux approximation (Bastiaanssen, 1995)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:827 ../gui/wxpython/menustrings.py:1770
+#: ../gui/wxpython/menustrings.py:804 ../gui/wxpython/menustrings.py:1710
msgid "Sensible heat flux"
msgstr ""
-#: ../gui/wxpython/menustrings.py:828 ../gui/wxpython/menustrings.py:1771
+#: ../gui/wxpython/menustrings.py:805 ../gui/wxpython/menustrings.py:1711
msgid "Computes sensible heat flux iteration SEBAL 01."
msgstr ""
-#: ../gui/wxpython/menustrings.py:829 ../gui/wxpython/menustrings.py:1772
+#: ../gui/wxpython/menustrings.py:806 ../gui/wxpython/menustrings.py:1712
msgid "Evaporative fraction"
msgstr ""
-#: ../gui/wxpython/menustrings.py:830 ../gui/wxpython/menustrings.py:1773
+#: ../gui/wxpython/menustrings.py:807 ../gui/wxpython/menustrings.py:1713
msgid "Computes evaporative fraction and root zone soil moisture."
msgstr ""
-#: ../gui/wxpython/menustrings.py:831 ../gui/wxpython/menustrings.py:1774
+#: ../gui/wxpython/menustrings.py:808 ../gui/wxpython/menustrings.py:1714
msgid "Actual Evapotranspiration"
msgstr ""
-#: ../gui/wxpython/menustrings.py:832 ../gui/wxpython/menustrings.py:1775
+#: ../gui/wxpython/menustrings.py:809 ../gui/wxpython/menustrings.py:1715
msgid "Actual evapotranspiration for diurnal period (Bastiaanssen, 1995)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:833 ../gui/wxpython/menustrings.py:1776
+#: ../gui/wxpython/menustrings.py:810 ../gui/wxpython/menustrings.py:1716
msgid "Temporal integration of ETa"
msgstr ""
-#: ../gui/wxpython/menustrings.py:834 ../gui/wxpython/menustrings.py:1777
+#: ../gui/wxpython/menustrings.py:811 ../gui/wxpython/menustrings.py:1717
msgid "Computes temporal integration of satellite ET actual (ETa) following the daily ET reference (ETo) from meteorological station(s)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:835 ../gui/wxpython/menustrings.py:1778
+#: ../gui/wxpython/menustrings.py:812 ../gui/wxpython/menustrings.py:1718
msgid "Hargreaves methods Evapotranspiration"
msgstr ""
-#: ../gui/wxpython/menustrings.py:836 ../gui/wxpython/menustrings.py:1779
+#: ../gui/wxpython/menustrings.py:813 ../gui/wxpython/menustrings.py:1719
msgid "Computes evapotranspiration calculation modified or original Hargreaves formulation, 2001."
msgstr ""
-#: ../gui/wxpython/menustrings.py:837 ../gui/wxpython/menustrings.py:1780
+#: ../gui/wxpython/menustrings.py:814 ../gui/wxpython/menustrings.py:1720
msgid "Penman-Monteith Evapotranspiration"
msgstr ""
-#: ../gui/wxpython/menustrings.py:838 ../gui/wxpython/menustrings.py:1781
+#: ../gui/wxpython/menustrings.py:815 ../gui/wxpython/menustrings.py:1721
msgid "Computes potential evapotranspiration calculation with hourly Penman-Monteith."
msgstr ""
-#: ../gui/wxpython/menustrings.py:839 ../gui/wxpython/menustrings.py:1782
+#: ../gui/wxpython/menustrings.py:816 ../gui/wxpython/menustrings.py:1722
msgid "Priestley-Taylor Evapotranspiration"
msgstr ""
-#: ../gui/wxpython/menustrings.py:840 ../gui/wxpython/menustrings.py:1783
+#: ../gui/wxpython/menustrings.py:817 ../gui/wxpython/menustrings.py:1723
msgid "Computes evapotranspiration calculation Priestley and Taylor formulation, 1972."
msgstr ""
-#: ../gui/wxpython/menustrings.py:842 ../gui/wxpython/menustrings.py:1785
+#: ../gui/wxpython/menustrings.py:819 ../gui/wxpython/menustrings.py:1725
msgid "Kappa analysis"
msgstr ""
-#: ../gui/wxpython/menustrings.py:843 ../gui/wxpython/menustrings.py:1786
+#: ../gui/wxpython/menustrings.py:820 ../gui/wxpython/menustrings.py:1726
msgid "Calculates error matrix and kappa parameter for accuracy assessment of classification result."
msgstr ""
-#: ../gui/wxpython/menustrings.py:844 ../gui/wxpython/menustrings.py:1787
+#: ../gui/wxpython/menustrings.py:821 ../gui/wxpython/menustrings.py:1727
msgid "OIF for LandSat TM"
msgstr ""
-#: ../gui/wxpython/menustrings.py:845 ../gui/wxpython/menustrings.py:1788
+#: ../gui/wxpython/menustrings.py:822 ../gui/wxpython/menustrings.py:1728
msgid "Calculates Optimum-Index-Factor table for spectral bands"
msgstr ""
-#: ../gui/wxpython/menustrings.py:846 ../gui/wxpython/menustrings.py:1789
+#: ../gui/wxpython/menustrings.py:823 ../gui/wxpython/menustrings.py:1729
msgid "3D r&aster"
msgstr ""
-#: ../gui/wxpython/menustrings.py:847 ../gui/wxpython/menustrings.py:1790
+#: ../gui/wxpython/menustrings.py:824 ../gui/wxpython/menustrings.py:1730
msgid "Develop 3D raster map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:848 ../gui/wxpython/menustrings.py:1791
+#: ../gui/wxpython/menustrings.py:825 ../gui/wxpython/menustrings.py:1731
msgid "Manage 3D NULL values"
msgstr ""
-#: ../gui/wxpython/menustrings.py:849 ../gui/wxpython/menustrings.py:1792
+#: ../gui/wxpython/menustrings.py:826 ../gui/wxpython/menustrings.py:1732
msgid "Explicitly create the 3D NULL-value bitmap file."
msgstr ""
-#: ../gui/wxpython/menustrings.py:850 ../gui/wxpython/menustrings.py:1793
+#: ../gui/wxpython/menustrings.py:827 ../gui/wxpython/menustrings.py:1733
msgid "Manage timestamp"
msgstr ""
-#: ../gui/wxpython/menustrings.py:851 ../gui/wxpython/menustrings.py:1794
+#: ../gui/wxpython/menustrings.py:828 ../gui/wxpython/menustrings.py:1734
msgid "Modifies a timestamp for a 3D raster map. Print/add/remove a timestamp for a 3D raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:853 ../gui/wxpython/menustrings.py:1796
+#: ../gui/wxpython/menustrings.py:830 ../gui/wxpython/menustrings.py:1736
msgid "3D rasters to raster series"
msgstr ""
-#: ../gui/wxpython/menustrings.py:855 ../gui/wxpython/menustrings.py:1798
+#: ../gui/wxpython/menustrings.py:832 ../gui/wxpython/menustrings.py:1738
msgid "3D color tables"
msgstr ""
-#: ../gui/wxpython/menustrings.py:856 ../gui/wxpython/menustrings.py:1799
+#: ../gui/wxpython/menustrings.py:833 ../gui/wxpython/menustrings.py:1739
msgid "Creates/modifies the color table associated with a 3D raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:857 ../gui/wxpython/menustrings.py:1800
+#: ../gui/wxpython/menustrings.py:834 ../gui/wxpython/menustrings.py:1740
msgid "Export 3D color table"
msgstr ""
-#: ../gui/wxpython/menustrings.py:858 ../gui/wxpython/menustrings.py:1801
+#: ../gui/wxpython/menustrings.py:835 ../gui/wxpython/menustrings.py:1741
msgid "Exports the color table associated with a 3D raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:859 ../gui/wxpython/menustrings.py:1802
+#: ../gui/wxpython/menustrings.py:836 ../gui/wxpython/menustrings.py:1742
msgid "3D mask"
msgstr ""
-#: ../gui/wxpython/menustrings.py:860 ../gui/wxpython/menustrings.py:1803
+#: ../gui/wxpython/menustrings.py:837 ../gui/wxpython/menustrings.py:1743
msgid "Establishes the current working 3D raster mask."
msgstr ""
-#: ../gui/wxpython/menustrings.py:861 ../gui/wxpython/menustrings.py:862
-#: ../gui/wxpython/menustrings.py:1804 ../gui/wxpython/menustrings.py:1805
+#: ../gui/wxpython/menustrings.py:838 ../gui/wxpython/menustrings.py:839
+#: ../gui/wxpython/menustrings.py:1744 ../gui/wxpython/menustrings.py:1745
msgid "3D raster map calculator"
msgstr ""
-#: ../gui/wxpython/menustrings.py:863 ../gui/wxpython/menustrings.py:1806
+#: ../gui/wxpython/menustrings.py:840 ../gui/wxpython/menustrings.py:1746
msgid "Cross section"
msgstr ""
-#: ../gui/wxpython/menustrings.py:864 ../gui/wxpython/menustrings.py:1807
+#: ../gui/wxpython/menustrings.py:841 ../gui/wxpython/menustrings.py:1747
msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:865 ../gui/wxpython/menustrings.py:1808
-msgid "Compute 3D flow lines"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:866 ../gui/wxpython/menustrings.py:1809
-msgid "Computes 3D flow lines and 3D flow accumulation."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:868 ../gui/wxpython/menustrings.py:1811
+#: ../gui/wxpython/menustrings.py:843 ../gui/wxpython/menustrings.py:1749
msgid "Numerical calculation program for transient, confined groundwater flow in three dimensions."
msgstr ""
-#: ../gui/wxpython/menustrings.py:869 ../gui/wxpython/menustrings.py:1812
-msgid "Compute gradient"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:870 ../gui/wxpython/menustrings.py:1813
-msgid "Computes gradient of a 3D raster map and outputs gradient components as three 3D raster maps."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:871 ../gui/wxpython/menustrings.py:1814
+#: ../gui/wxpython/menustrings.py:844 ../gui/wxpython/menustrings.py:1750
msgid "Interpolate 3D raster from points"
msgstr ""
-#: ../gui/wxpython/menustrings.py:872 ../gui/wxpython/menustrings.py:1815
+#: ../gui/wxpython/menustrings.py:845 ../gui/wxpython/menustrings.py:1751
msgid "Interpolates point data to a 3D raster map using regularized spline with tension (RST) algorithm."
msgstr ""
-#: ../gui/wxpython/menustrings.py:873 ../gui/wxpython/menustrings.py:1816
+#: ../gui/wxpython/menustrings.py:846 ../gui/wxpython/menustrings.py:1752
msgid "Reports and Statistics"
msgstr ""
-#: ../gui/wxpython/menustrings.py:874 ../gui/wxpython/menustrings.py:1817
+#: ../gui/wxpython/menustrings.py:847 ../gui/wxpython/menustrings.py:1753
msgid "Basic 3D raster metadata"
msgstr ""
-#: ../gui/wxpython/menustrings.py:875 ../gui/wxpython/menustrings.py:1818
+#: ../gui/wxpython/menustrings.py:848 ../gui/wxpython/menustrings.py:1754
msgid "Outputs basic information about a user-specified 3D raster map layer."
msgstr ""
-#: ../gui/wxpython/menustrings.py:876 ../gui/wxpython/menustrings.py:1819
+#: ../gui/wxpython/menustrings.py:849 ../gui/wxpython/menustrings.py:1755
msgid "3D raster statistics"
msgstr ""
-#: ../gui/wxpython/menustrings.py:877 ../gui/wxpython/menustrings.py:1820
+#: ../gui/wxpython/menustrings.py:850 ../gui/wxpython/menustrings.py:1756
msgid "Generates volume statistics for 3D raster maps."
msgstr ""
-#: ../gui/wxpython/menustrings.py:878 ../gui/wxpython/menustrings.py:1821
+#: ../gui/wxpython/menustrings.py:851 ../gui/wxpython/menustrings.py:1757
msgid "Univariate statistics for 3D rasters"
msgstr ""
-#: ../gui/wxpython/menustrings.py:879 ../gui/wxpython/menustrings.py:1822
+#: ../gui/wxpython/menustrings.py:852 ../gui/wxpython/menustrings.py:1758
msgid "Calculates univariate statistics from the non-null cells of a 3D raster map. Statistics include number of cells counted, minimum and maximum cell values, range, arithmetic mean, population variance, standard deviation, coefficient of variation, and sum."
msgstr ""
-#: ../gui/wxpython/menustrings.py:880 ../gui/wxpython/menustrings.py:1823
+#: ../gui/wxpython/menustrings.py:853 ../gui/wxpython/menustrings.py:1759
msgid "&Database"
msgstr ""
-#: ../gui/wxpython/menustrings.py:881 ../gui/wxpython/menustrings.py:1824
+#: ../gui/wxpython/menustrings.py:854 ../gui/wxpython/menustrings.py:1760
msgid "Database information"
msgstr ""
-#: ../gui/wxpython/menustrings.py:882 ../gui/wxpython/menustrings.py:1825
+#: ../gui/wxpython/menustrings.py:855 ../gui/wxpython/menustrings.py:1761
msgid "List databases"
msgstr ""
-#: ../gui/wxpython/menustrings.py:883 ../gui/wxpython/menustrings.py:1826
+#: ../gui/wxpython/menustrings.py:856 ../gui/wxpython/menustrings.py:1762
msgid "Lists all databases for a given driver and location."
msgstr ""
-#: ../gui/wxpython/menustrings.py:884 ../gui/wxpython/menustrings.py:1827
+#: ../gui/wxpython/menustrings.py:857 ../gui/wxpython/menustrings.py:1763
msgid "List drivers"
msgstr ""
-#: ../gui/wxpython/menustrings.py:885 ../gui/wxpython/menustrings.py:1828
+#: ../gui/wxpython/menustrings.py:858 ../gui/wxpython/menustrings.py:1764
msgid "Lists all database drivers."
msgstr ""
-#: ../gui/wxpython/menustrings.py:886 ../gui/wxpython/menustrings.py:1829
+#: ../gui/wxpython/menustrings.py:859 ../gui/wxpython/menustrings.py:1765
msgid "List tables"
msgstr ""
-#: ../gui/wxpython/menustrings.py:887 ../gui/wxpython/menustrings.py:1830
+#: ../gui/wxpython/menustrings.py:860 ../gui/wxpython/menustrings.py:1766
msgid "Lists all tables for a given database."
msgstr ""
-#: ../gui/wxpython/menustrings.py:888 ../gui/wxpython/menustrings.py:1831
+#: ../gui/wxpython/menustrings.py:861 ../gui/wxpython/menustrings.py:1767
msgid "Describe table"
msgstr ""
-#: ../gui/wxpython/menustrings.py:889 ../gui/wxpython/menustrings.py:1832
+#: ../gui/wxpython/menustrings.py:862 ../gui/wxpython/menustrings.py:1768
msgid "Describes a table in detail."
msgstr ""
-#: ../gui/wxpython/menustrings.py:890 ../gui/wxpython/menustrings.py:1833
+#: ../gui/wxpython/menustrings.py:863 ../gui/wxpython/menustrings.py:1769
msgid "List columns"
msgstr ""
-#: ../gui/wxpython/menustrings.py:891 ../gui/wxpython/menustrings.py:1834
+#: ../gui/wxpython/menustrings.py:864 ../gui/wxpython/menustrings.py:1770
msgid "List all columns for a given table."
msgstr ""
-#: ../gui/wxpython/menustrings.py:892 ../gui/wxpython/menustrings.py:1835
+#: ../gui/wxpython/menustrings.py:865 ../gui/wxpython/menustrings.py:1771
msgid "Manage databases"
msgstr ""
-#: ../gui/wxpython/menustrings.py:893 ../gui/wxpython/menustrings.py:1836
+#: ../gui/wxpython/menustrings.py:866 ../gui/wxpython/menustrings.py:1772
msgid "Connect"
msgstr ""
-#: ../gui/wxpython/menustrings.py:894 ../gui/wxpython/menustrings.py:1837
+#: ../gui/wxpython/menustrings.py:867 ../gui/wxpython/menustrings.py:1773
msgid "Prints/sets general DB connection for current mapset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:895 ../gui/wxpython/menustrings.py:1838
+#: ../gui/wxpython/menustrings.py:868 ../gui/wxpython/menustrings.py:1774
msgid "Login"
msgstr ""
-#: ../gui/wxpython/menustrings.py:896 ../gui/wxpython/menustrings.py:1839
+#: ../gui/wxpython/menustrings.py:869 ../gui/wxpython/menustrings.py:1775
msgid "Sets user/password for DB driver/database."
msgstr ""
-#: ../gui/wxpython/menustrings.py:897 ../gui/wxpython/menustrings.py:1840
+#: ../gui/wxpython/menustrings.py:870 ../gui/wxpython/menustrings.py:1776
msgid "Create database"
msgstr ""
-#: ../gui/wxpython/menustrings.py:898 ../gui/wxpython/menustrings.py:1841
+#: ../gui/wxpython/menustrings.py:871 ../gui/wxpython/menustrings.py:1777
msgid "Creates an empty database."
msgstr ""
-#: ../gui/wxpython/menustrings.py:899 ../gui/wxpython/menustrings.py:1842
+#: ../gui/wxpython/menustrings.py:872 ../gui/wxpython/menustrings.py:1778
msgid "Drop database"
msgstr ""
-#: ../gui/wxpython/menustrings.py:900 ../gui/wxpython/menustrings.py:1843
+#: ../gui/wxpython/menustrings.py:873 ../gui/wxpython/menustrings.py:1779
msgid "Removes an existing database."
msgstr ""
-#: ../gui/wxpython/menustrings.py:901 ../gui/wxpython/menustrings.py:1844
+#: ../gui/wxpython/menustrings.py:874 ../gui/wxpython/menustrings.py:1780
msgid "Drop table"
msgstr ""
-#: ../gui/wxpython/menustrings.py:902 ../gui/wxpython/menustrings.py:1845
+#: ../gui/wxpython/menustrings.py:875 ../gui/wxpython/menustrings.py:1781
msgid "Drops an attribute table."
msgstr ""
-#: ../gui/wxpython/menustrings.py:903 ../gui/wxpython/menustrings.py:1846
+#: ../gui/wxpython/menustrings.py:876 ../gui/wxpython/menustrings.py:1782
msgid "Copy table"
msgstr ""
-#: ../gui/wxpython/menustrings.py:904 ../gui/wxpython/menustrings.py:1847
+#: ../gui/wxpython/menustrings.py:877 ../gui/wxpython/menustrings.py:1783
msgid "Copy a table. Either 'from_table' (optionally with 'where') can be used or 'select' option, but not 'from_table' and 'select' at the same time."
msgstr ""
-#: ../gui/wxpython/menustrings.py:905 ../gui/wxpython/menustrings.py:925
-#: ../gui/wxpython/menustrings.py:1848 ../gui/wxpython/menustrings.py:1868
+#: ../gui/wxpython/menustrings.py:878 ../gui/wxpython/menustrings.py:898
+#: ../gui/wxpython/menustrings.py:1784 ../gui/wxpython/menustrings.py:1804
msgid "Drop column"
msgstr ""
-#: ../gui/wxpython/menustrings.py:906 ../gui/wxpython/menustrings.py:1849
+#: ../gui/wxpython/menustrings.py:879 ../gui/wxpython/menustrings.py:1785
msgid "Drops a column from selected attribute table."
msgstr ""
-#: ../gui/wxpython/menustrings.py:907 ../gui/wxpython/menustrings.py:1850
+#: ../gui/wxpython/menustrings.py:880 ../gui/wxpython/menustrings.py:1786
msgid "Test"
msgstr ""
-#: ../gui/wxpython/menustrings.py:908 ../gui/wxpython/menustrings.py:1851
+#: ../gui/wxpython/menustrings.py:881 ../gui/wxpython/menustrings.py:1787
msgid "Test database driver, database must exist and set by db.connect."
msgstr ""
-#: ../gui/wxpython/menustrings.py:910 ../gui/wxpython/menustrings.py:1853
+#: ../gui/wxpython/menustrings.py:883 ../gui/wxpython/menustrings.py:1789
msgid "Query any table"
msgstr ""
-#: ../gui/wxpython/menustrings.py:911 ../gui/wxpython/menustrings.py:1854
+#: ../gui/wxpython/menustrings.py:884 ../gui/wxpython/menustrings.py:1790
msgid "Selects data from attribute table. Performs SQL query statement(s)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:914 ../gui/wxpython/menustrings.py:1857
+#: ../gui/wxpython/menustrings.py:887 ../gui/wxpython/menustrings.py:1793
msgid "SQL statement"
msgstr ""
-#: ../gui/wxpython/menustrings.py:915 ../gui/wxpython/menustrings.py:1858
+#: ../gui/wxpython/menustrings.py:888 ../gui/wxpython/menustrings.py:1794
msgid "Executes any SQL statement. For SELECT statements use 'db.select'."
msgstr ""
-#: ../gui/wxpython/menustrings.py:916 ../gui/wxpython/menustrings.py:1859
+#: ../gui/wxpython/menustrings.py:889 ../gui/wxpython/menustrings.py:1795
msgid "Vector database connections"
msgstr ""
-#: ../gui/wxpython/menustrings.py:917 ../gui/wxpython/menustrings.py:1860
+#: ../gui/wxpython/menustrings.py:890 ../gui/wxpython/menustrings.py:1796
msgid "New table"
msgstr ""
-#: ../gui/wxpython/menustrings.py:918 ../gui/wxpython/menustrings.py:1861
+#: ../gui/wxpython/menustrings.py:891 ../gui/wxpython/menustrings.py:1797
msgid "Creates and connects a new attribute table to a given layer of an existing vector map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:919 ../gui/wxpython/menustrings.py:1862
+#: ../gui/wxpython/menustrings.py:892 ../gui/wxpython/menustrings.py:1798
msgid "Remove table"
msgstr ""
-#: ../gui/wxpython/menustrings.py:920 ../gui/wxpython/menustrings.py:1863
+#: ../gui/wxpython/menustrings.py:893 ../gui/wxpython/menustrings.py:1799
msgid "Removes existing attribute table of a vector map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:921 ../gui/wxpython/menustrings.py:1864
+#: ../gui/wxpython/menustrings.py:894 ../gui/wxpython/menustrings.py:1800
msgid "Join table"
msgstr ""
-#: ../gui/wxpython/menustrings.py:922 ../gui/wxpython/menustrings.py:1865
+#: ../gui/wxpython/menustrings.py:895 ../gui/wxpython/menustrings.py:1801
msgid "Joins a database table to a vector map table."
msgstr ""
-#: ../gui/wxpython/menustrings.py:923 ../gui/wxpython/menustrings.py:1866
+#: ../gui/wxpython/menustrings.py:896 ../gui/wxpython/menustrings.py:1802
msgid "Add columns"
msgstr ""
-#: ../gui/wxpython/menustrings.py:924 ../gui/wxpython/menustrings.py:1867
+#: ../gui/wxpython/menustrings.py:897 ../gui/wxpython/menustrings.py:1803
msgid "Adds one or more columns to the attribute table connected to a given vector map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:926 ../gui/wxpython/menustrings.py:1869
+#: ../gui/wxpython/menustrings.py:899 ../gui/wxpython/menustrings.py:1805
msgid "Drops a column from the attribute table connected to a given vector map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:928 ../gui/wxpython/menustrings.py:1871
+#: ../gui/wxpython/menustrings.py:901 ../gui/wxpython/menustrings.py:1807
msgid "Renames a column in the attribute table connected to a given vector map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:929 ../gui/wxpython/menustrings.py:1872
+#: ../gui/wxpython/menustrings.py:902 ../gui/wxpython/menustrings.py:1808
msgid "Change values"
msgstr ""
-#: ../gui/wxpython/menustrings.py:930 ../gui/wxpython/menustrings.py:1873
+#: ../gui/wxpython/menustrings.py:903 ../gui/wxpython/menustrings.py:1809
msgid "Updates a column in the attribute table connected to a vector map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:931 ../gui/wxpython/menustrings.py:1874
+#: ../gui/wxpython/menustrings.py:904 ../gui/wxpython/menustrings.py:1810
msgid "Drop row"
msgstr ""
-#: ../gui/wxpython/menustrings.py:932 ../gui/wxpython/menustrings.py:1875
+#: ../gui/wxpython/menustrings.py:905 ../gui/wxpython/menustrings.py:1811
msgid "Removes a vector feature from a vector map through attribute selection."
msgstr ""
-#: ../gui/wxpython/menustrings.py:933 ../gui/wxpython/menustrings.py:1876
+#: ../gui/wxpython/menustrings.py:906 ../gui/wxpython/menustrings.py:1812
msgid "Reconnect vectors to database"
msgstr ""
-#: ../gui/wxpython/menustrings.py:934 ../gui/wxpython/menustrings.py:1877
+#: ../gui/wxpython/menustrings.py:907 ../gui/wxpython/menustrings.py:1813
msgid "Reconnects attribute tables for all vector maps from the current mapset to a new database."
msgstr ""
-#: ../gui/wxpython/menustrings.py:935 ../gui/wxpython/menustrings.py:1878
+#: ../gui/wxpython/menustrings.py:908 ../gui/wxpython/menustrings.py:1814
msgid "Set vector map - database connection"
msgstr ""
-#: ../gui/wxpython/menustrings.py:936 ../gui/wxpython/menustrings.py:1879
+#: ../gui/wxpython/menustrings.py:909 ../gui/wxpython/menustrings.py:1815
msgid "Prints/sets DB connection for a vector map to attribute table."
msgstr ""
-#: ../gui/wxpython/menustrings.py:937 ../gui/wxpython/menustrings.py:1880
+#: ../gui/wxpython/menustrings.py:910 ../gui/wxpython/menustrings.py:1816
msgid "&Temporal"
msgstr ""
-#: ../gui/wxpython/menustrings.py:938 ../gui/wxpython/menustrings.py:1881
+#: ../gui/wxpython/menustrings.py:911 ../gui/wxpython/menustrings.py:1817
msgid "Manage datasets"
msgstr ""
-#: ../gui/wxpython/menustrings.py:939 ../gui/wxpython/menustrings.py:1882
+#: ../gui/wxpython/menustrings.py:912 ../gui/wxpython/menustrings.py:1818
msgid "Connect temporal database"
msgstr ""
-#: ../gui/wxpython/menustrings.py:940 ../gui/wxpython/menustrings.py:1883
+#: ../gui/wxpython/menustrings.py:913 ../gui/wxpython/menustrings.py:1819
msgid "Prints/sets general temporal GIS database connection for current mapset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:942 ../gui/wxpython/menustrings.py:1885
+#: ../gui/wxpython/menustrings.py:915 ../gui/wxpython/menustrings.py:1821
msgid "Creates a space time dataset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:944 ../gui/wxpython/menustrings.py:1887
+#: ../gui/wxpython/menustrings.py:917 ../gui/wxpython/menustrings.py:1823
msgid "Renames a space time dataset"
msgstr ""
-#: ../gui/wxpython/menustrings.py:946 ../gui/wxpython/menustrings.py:1889
+#: ../gui/wxpython/menustrings.py:919 ../gui/wxpython/menustrings.py:1825
msgid "Removes space time datasets from temporal database."
msgstr ""
-#: ../gui/wxpython/menustrings.py:947 ../gui/wxpython/menustrings.py:1890
+#: ../gui/wxpython/menustrings.py:920 ../gui/wxpython/menustrings.py:1826
msgid "Update metadata"
msgstr ""
-#: ../gui/wxpython/menustrings.py:948 ../gui/wxpython/menustrings.py:1891
+#: ../gui/wxpython/menustrings.py:921 ../gui/wxpython/menustrings.py:1827
msgid "Modifies the metadata of a space time dataset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:949 ../gui/wxpython/menustrings.py:1892
+#: ../gui/wxpython/menustrings.py:922 ../gui/wxpython/menustrings.py:1828
msgid "Merge"
msgstr ""
-#: ../gui/wxpython/menustrings.py:950 ../gui/wxpython/menustrings.py:1893
+#: ../gui/wxpython/menustrings.py:923 ../gui/wxpython/menustrings.py:1829
msgid "Merges several space time datasets into a single space time dataset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:951 ../gui/wxpython/menustrings.py:1894
+#: ../gui/wxpython/menustrings.py:924 ../gui/wxpython/menustrings.py:1830
msgid "Temporally shift"
msgstr ""
-#: ../gui/wxpython/menustrings.py:952 ../gui/wxpython/menustrings.py:1895
+#: ../gui/wxpython/menustrings.py:925 ../gui/wxpython/menustrings.py:1831
msgid "Shifts temporally the maps of a space time dataset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:953 ../gui/wxpython/menustrings.py:1896
+#: ../gui/wxpython/menustrings.py:926 ../gui/wxpython/menustrings.py:1832
msgid "Snap maps of dataset"
msgstr ""
-#: ../gui/wxpython/menustrings.py:954 ../gui/wxpython/menustrings.py:1897
+#: ../gui/wxpython/menustrings.py:927 ../gui/wxpython/menustrings.py:1833
msgid "Snaps temporally the maps of a space time dataset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:956 ../gui/wxpython/menustrings.py:1899
+#: ../gui/wxpython/menustrings.py:929 ../gui/wxpython/menustrings.py:1835
msgid "Lists space time datasets and maps registered in the temporal database."
msgstr ""
-#: ../gui/wxpython/menustrings.py:957 ../gui/wxpython/menustrings.py:1900
+#: ../gui/wxpython/menustrings.py:930 ../gui/wxpython/menustrings.py:1836
msgid "Manage maps in datasets"
msgstr ""
-#: ../gui/wxpython/menustrings.py:958 ../gui/wxpython/menustrings.py:1901
+#: ../gui/wxpython/menustrings.py:931 ../gui/wxpython/menustrings.py:1837
msgid "Register maps in datasets"
msgstr ""
-#: ../gui/wxpython/menustrings.py:959 ../gui/wxpython/menustrings.py:1902
-msgid "Assigns timestamps and registers raster, vector and raster3d maps in a space time dataset."
+#: ../gui/wxpython/menustrings.py:932 ../gui/wxpython/menustrings.py:1838
+msgid "Registers raster, vector and raster3d maps in a space time datasets."
msgstr ""
-#: ../gui/wxpython/menustrings.py:960 ../gui/wxpython/menustrings.py:1903
+#: ../gui/wxpython/menustrings.py:933 ../gui/wxpython/menustrings.py:1839
msgid "Unregister maps from datasets"
msgstr ""
-#: ../gui/wxpython/menustrings.py:961 ../gui/wxpython/menustrings.py:1904
+#: ../gui/wxpython/menustrings.py:934 ../gui/wxpython/menustrings.py:1840
msgid "Unregisters raster, vector and raster3d maps from the temporal database or a specific space time dataset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:962 ../gui/wxpython/menustrings.py:1905
+#: ../gui/wxpython/menustrings.py:935 ../gui/wxpython/menustrings.py:1841
msgid "List raster dataset maps"
msgstr ""
-#: ../gui/wxpython/menustrings.py:963 ../gui/wxpython/menustrings.py:1906
+#: ../gui/wxpython/menustrings.py:936 ../gui/wxpython/menustrings.py:1842
msgid "Lists registered maps of a space time raster dataset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:964 ../gui/wxpython/menustrings.py:1907
+#: ../gui/wxpython/menustrings.py:937 ../gui/wxpython/menustrings.py:1843
msgid "List vector dataset maps"
msgstr ""
-#: ../gui/wxpython/menustrings.py:965 ../gui/wxpython/menustrings.py:1908
+#: ../gui/wxpython/menustrings.py:938 ../gui/wxpython/menustrings.py:1844
msgid "Lists registered maps of a space time vector dataset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:966 ../gui/wxpython/menustrings.py:1909
+#: ../gui/wxpython/menustrings.py:939 ../gui/wxpython/menustrings.py:1845
msgid "List 3D raster dataset maps"
msgstr ""
-#: ../gui/wxpython/menustrings.py:967 ../gui/wxpython/menustrings.py:1910
+#: ../gui/wxpython/menustrings.py:940 ../gui/wxpython/menustrings.py:1846
msgid "Lists registered maps of a space time raster3d dataset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:968 ../gui/wxpython/menustrings.py:1911
+#: ../gui/wxpython/menustrings.py:941 ../gui/wxpython/menustrings.py:1847
msgid "Import"
msgstr ""
-#: ../gui/wxpython/menustrings.py:969 ../gui/wxpython/menustrings.py:1912
+#: ../gui/wxpython/menustrings.py:942 ../gui/wxpython/menustrings.py:1848
msgid "Import raster dataset"
msgstr ""
-#: ../gui/wxpython/menustrings.py:970 ../gui/wxpython/menustrings.py:1913
+#: ../gui/wxpython/menustrings.py:943 ../gui/wxpython/menustrings.py:1849
msgid "Imports space time raster dataset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:971 ../gui/wxpython/menustrings.py:1914
+#: ../gui/wxpython/menustrings.py:944 ../gui/wxpython/menustrings.py:1850
msgid "Import vector dataset"
msgstr ""
-#: ../gui/wxpython/menustrings.py:972 ../gui/wxpython/menustrings.py:1915
+#: ../gui/wxpython/menustrings.py:945 ../gui/wxpython/menustrings.py:1851
msgid "Imports a space time vector dataset from a GRASS GIS specific archive file."
msgstr ""
-#: ../gui/wxpython/menustrings.py:974 ../gui/wxpython/menustrings.py:1917
+#: ../gui/wxpython/menustrings.py:947 ../gui/wxpython/menustrings.py:1853
msgid "Export raster dataset"
msgstr ""
-#: ../gui/wxpython/menustrings.py:975 ../gui/wxpython/menustrings.py:1918
+#: ../gui/wxpython/menustrings.py:948 ../gui/wxpython/menustrings.py:1854
msgid "Exports space time raster dataset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:976 ../gui/wxpython/menustrings.py:1919
+#: ../gui/wxpython/menustrings.py:949 ../gui/wxpython/menustrings.py:1855
msgid "Export raster dataset as VTK time series"
msgstr ""
-#: ../gui/wxpython/menustrings.py:977 ../gui/wxpython/menustrings.py:1920
+#: ../gui/wxpython/menustrings.py:950 ../gui/wxpython/menustrings.py:1856
msgid "Exports space time raster dataset as VTK time series."
msgstr ""
-#: ../gui/wxpython/menustrings.py:978 ../gui/wxpython/menustrings.py:1921
+#: ../gui/wxpython/menustrings.py:951 ../gui/wxpython/menustrings.py:1857
msgid "Export vector dataset"
msgstr ""
-#: ../gui/wxpython/menustrings.py:979 ../gui/wxpython/menustrings.py:1922
+#: ../gui/wxpython/menustrings.py:952 ../gui/wxpython/menustrings.py:1858
msgid "Exports a space time vector dataset as GRASS GIS specific archive file."
msgstr ""
-#: ../gui/wxpython/menustrings.py:980 ../gui/wxpython/menustrings.py:1923
+#: ../gui/wxpython/menustrings.py:953 ../gui/wxpython/menustrings.py:1859
msgid "Convert raster dataset to 3D raster"
msgstr ""
-#: ../gui/wxpython/menustrings.py:981 ../gui/wxpython/menustrings.py:1924
+#: ../gui/wxpython/menustrings.py:954 ../gui/wxpython/menustrings.py:1860
msgid "Converts a space time raster dataset into a 3D raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:982 ../gui/wxpython/menustrings.py:1925
-msgid "Convert raster dataset to vector dataset "
-msgstr ""
-#: ../gui/wxpython/menustrings.py:983 ../gui/wxpython/menustrings.py:1926
-msgid "Converts a space time raster dataset into a space time vector dataset"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:984 ../gui/wxpython/menustrings.py:1927
+#: ../gui/wxpython/menustrings.py:955 ../gui/wxpython/menustrings.py:1861
msgid "Extraction"
msgstr ""
-#: ../gui/wxpython/menustrings.py:985 ../gui/wxpython/menustrings.py:1928
+#: ../gui/wxpython/menustrings.py:956 ../gui/wxpython/menustrings.py:1862
msgid "Extract subset of raster dataset"
msgstr ""
-#: ../gui/wxpython/menustrings.py:986 ../gui/wxpython/menustrings.py:1929
+#: ../gui/wxpython/menustrings.py:957 ../gui/wxpython/menustrings.py:1863
msgid "Extracts a subset of a space time raster datasets."
msgstr ""
-#: ../gui/wxpython/menustrings.py:987 ../gui/wxpython/menustrings.py:1930
+#: ../gui/wxpython/menustrings.py:958 ../gui/wxpython/menustrings.py:1864
msgid "Extract subset of vector dataset"
msgstr ""
-#: ../gui/wxpython/menustrings.py:988 ../gui/wxpython/menustrings.py:1931
+#: ../gui/wxpython/menustrings.py:959 ../gui/wxpython/menustrings.py:1865
msgid "Extracts a subset of a space time vector dataset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:989 ../gui/wxpython/menustrings.py:1932
+#: ../gui/wxpython/menustrings.py:960 ../gui/wxpython/menustrings.py:1866
msgid "Extract subset of 3D raster dataset"
msgstr ""
-#: ../gui/wxpython/menustrings.py:990 ../gui/wxpython/menustrings.py:1933
+#: ../gui/wxpython/menustrings.py:961 ../gui/wxpython/menustrings.py:1867
msgid "Extracts a subset of a space time 3D raster dataset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:991 ../gui/wxpython/menustrings.py:1934
+#: ../gui/wxpython/menustrings.py:962 ../gui/wxpython/menustrings.py:1868
msgid "Query vector dataset attribute data"
msgstr ""
-#: ../gui/wxpython/menustrings.py:992 ../gui/wxpython/menustrings.py:1935
+#: ../gui/wxpython/menustrings.py:963 ../gui/wxpython/menustrings.py:1869
msgid "Prints attributes of vector maps registered in a space time vector dataset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:993 ../gui/wxpython/menustrings.py:1936
+#: ../gui/wxpython/menustrings.py:964 ../gui/wxpython/menustrings.py:1870
msgid "Raster dataset color table"
msgstr ""
-#: ../gui/wxpython/menustrings.py:994 ../gui/wxpython/menustrings.py:1937
+#: ../gui/wxpython/menustrings.py:965 ../gui/wxpython/menustrings.py:1871
msgid "Creates/modifies the color table associated with each raster map of the space time raster dataset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:995 ../gui/wxpython/menustrings.py:1938
+#: ../gui/wxpython/menustrings.py:966 ../gui/wxpython/menustrings.py:1872
msgid "Raster calculations"
msgstr ""
-#: ../gui/wxpython/menustrings.py:996 ../gui/wxpython/menustrings.py:1939
+#: ../gui/wxpython/menustrings.py:967 ../gui/wxpython/menustrings.py:1873
msgid "Performs spatio-temporal mapcalc expressions on temporally sampled maps of space time raster datasets."
msgstr ""
-#: ../gui/wxpython/menustrings.py:997 ../gui/wxpython/menustrings.py:1940
+#: ../gui/wxpython/menustrings.py:968 ../gui/wxpython/menustrings.py:1874
msgid "3D raster calculations"
msgstr ""
-#: ../gui/wxpython/menustrings.py:998 ../gui/wxpython/menustrings.py:1941
+#: ../gui/wxpython/menustrings.py:969 ../gui/wxpython/menustrings.py:1875
msgid "Performs r3.mapcalc expressions on maps of sampled space time 3D raster datasets."
msgstr ""
-#: ../gui/wxpython/menustrings.py:999 ../gui/wxpython/menustrings.py:1942
+#: ../gui/wxpython/menustrings.py:970 ../gui/wxpython/menustrings.py:1876
msgid "Interpolate gaps in raster datasets"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1000 ../gui/wxpython/menustrings.py:1943
+#: ../gui/wxpython/menustrings.py:971 ../gui/wxpython/menustrings.py:1877
msgid "Replaces gaps in a space time raster dataset with interpolated raster maps."
msgstr ""
-#: ../gui/wxpython/menustrings.py:1001 ../gui/wxpython/menustrings.py:1944
-msgid "Contours from a space time raster dataset"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:1002 ../gui/wxpython/menustrings.py:1945
-msgid "Produces a space time vector dataset of specified contours from a space time raster dataset."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:1003 ../gui/wxpython/menustrings.py:1946
+#: ../gui/wxpython/menustrings.py:972 ../gui/wxpython/menustrings.py:1878
msgid "Aggregation"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1004 ../gui/wxpython/menustrings.py:1947
+#: ../gui/wxpython/menustrings.py:973 ../gui/wxpython/menustrings.py:1879
msgid "Neighborhood analysis in raster dataset"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1005 ../gui/wxpython/menustrings.py:1948
+#: ../gui/wxpython/menustrings.py:974 ../gui/wxpython/menustrings.py:1880
msgid "Performs a neighborhood analysis for each map in a space time raster dataset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:1006 ../gui/wxpython/menustrings.py:1949
+#: ../gui/wxpython/menustrings.py:975 ../gui/wxpython/menustrings.py:1881
msgid "Aggregation in raster datasets"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1007 ../gui/wxpython/menustrings.py:1950
+#: ../gui/wxpython/menustrings.py:976 ../gui/wxpython/menustrings.py:1882
msgid "Performs different aggregation algorithms from r.series on all or a subset of raster maps in a space time raster dataset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:1008 ../gui/wxpython/menustrings.py:1951
+#: ../gui/wxpython/menustrings.py:977 ../gui/wxpython/menustrings.py:1883
msgid "Temporal aggregation"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1009 ../gui/wxpython/menustrings.py:1952
+#: ../gui/wxpython/menustrings.py:978 ../gui/wxpython/menustrings.py:1884
msgid "Aggregates temporally the maps of a space time raster dataset by a user defined granularity."
msgstr ""
-#: ../gui/wxpython/menustrings.py:1010 ../gui/wxpython/menustrings.py:1953
+#: ../gui/wxpython/menustrings.py:979 ../gui/wxpython/menustrings.py:1885
msgid "Temporal aggregation by dataset"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1011 ../gui/wxpython/menustrings.py:1954
+#: ../gui/wxpython/menustrings.py:980 ../gui/wxpython/menustrings.py:1886
msgid "Aggregates data of an existing space time raster dataset using the time intervals of a second space time dataset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:1012 ../gui/wxpython/menustrings.py:1955
+#: ../gui/wxpython/menustrings.py:981 ../gui/wxpython/menustrings.py:1887
msgid "Sampling"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1013 ../gui/wxpython/menustrings.py:1956
+#: ../gui/wxpython/menustrings.py:982 ../gui/wxpython/menustrings.py:1888
msgid "Sample a space time raster dataset at point coordinates"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1014 ../gui/wxpython/menustrings.py:1957
+#: ../gui/wxpython/menustrings.py:983 ../gui/wxpython/menustrings.py:1889
msgid "Sample a space time raster dataset at specific vector point coordinates and write the output to stdout using different layouts"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1015 ../gui/wxpython/menustrings.py:1958
+#: ../gui/wxpython/menustrings.py:984 ../gui/wxpython/menustrings.py:1890
msgid "Query raster dataset by vector points dataset"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1016 ../gui/wxpython/menustrings.py:1959
+#: ../gui/wxpython/menustrings.py:985 ../gui/wxpython/menustrings.py:1891
msgid "Stores raster map values at spatial and temporal positions of vector points as vector attributes."
msgstr ""
-#: ../gui/wxpython/menustrings.py:1017 ../gui/wxpython/menustrings.py:1960
+#: ../gui/wxpython/menustrings.py:986 ../gui/wxpython/menustrings.py:1892
msgid "Observe specific locations in raster dataset"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1018 ../gui/wxpython/menustrings.py:1961
+#: ../gui/wxpython/menustrings.py:987 ../gui/wxpython/menustrings.py:1893
msgid "Observes specific locations in a space time raster dataset over a period of time using vector points."
msgstr ""
-#: ../gui/wxpython/menustrings.py:1019 ../gui/wxpython/menustrings.py:1962
+#: ../gui/wxpython/menustrings.py:988 ../gui/wxpython/menustrings.py:1894
msgid "Temporal sampling"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1020 ../gui/wxpython/menustrings.py:1963
+#: ../gui/wxpython/menustrings.py:989 ../gui/wxpython/menustrings.py:1895
msgid "Samples the input space time dataset(s) with a sample space time dataset and print the result to stdout."
msgstr ""
-#: ../gui/wxpython/menustrings.py:1021 ../gui/wxpython/menustrings.py:1964
-msgid "Temporal algebra"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:1022 ../gui/wxpython/menustrings.py:1965
-msgid "Temporal raster algebra"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:1023 ../gui/wxpython/menustrings.py:1966
-msgid "Apply temporal and spatial operations on space time raster datasets using temporal raster algebra."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:1024 ../gui/wxpython/menustrings.py:1967
-msgid "Temporal 3D raster algebra"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:1025 ../gui/wxpython/menustrings.py:1968
-msgid "Apply temporal and spatial operations on space time 3D raster datasets using temporal 3D raster algebra."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:1026 ../gui/wxpython/menustrings.py:1969
-msgid "Temporal vector algebra"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:1027 ../gui/wxpython/menustrings.py:1970
-msgid "Apply temporal and spatial operations on space time vector datasets using temporal vector algebra."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:1029 ../gui/wxpython/menustrings.py:1972
+#: ../gui/wxpython/menustrings.py:991 ../gui/wxpython/menustrings.py:1897
msgid "Space time datasets metadata"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1030 ../gui/wxpython/menustrings.py:1973
+#: ../gui/wxpython/menustrings.py:992 ../gui/wxpython/menustrings.py:1898
msgid "Lists information about space time datasets and maps."
msgstr ""
-#: ../gui/wxpython/menustrings.py:1031 ../gui/wxpython/menustrings.py:1974
+#: ../gui/wxpython/menustrings.py:993 ../gui/wxpython/menustrings.py:1899
msgid "Univariate raster dataset statistics"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1032 ../gui/wxpython/menustrings.py:1975
+#: ../gui/wxpython/menustrings.py:994 ../gui/wxpython/menustrings.py:1900
msgid "Calculates univariate statistics from the non-null cells for each registered raster map of a space time raster dataset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:1033 ../gui/wxpython/menustrings.py:1976
+#: ../gui/wxpython/menustrings.py:995 ../gui/wxpython/menustrings.py:1901
msgid "Univariate vector dataset statistics"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1034 ../gui/wxpython/menustrings.py:1977
+#: ../gui/wxpython/menustrings.py:996 ../gui/wxpython/menustrings.py:1902
msgid "Calculates univariate statistics of attributes for each registered vector map of a space time vector dataset"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1035 ../gui/wxpython/menustrings.py:1978
+#: ../gui/wxpython/menustrings.py:997 ../gui/wxpython/menustrings.py:1903
msgid "Univariate 3D raster dataset statistics"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1036 ../gui/wxpython/menustrings.py:1979
+#: ../gui/wxpython/menustrings.py:998 ../gui/wxpython/menustrings.py:1904
msgid "Calculates univariate statistics from the non-null cells for each registered 3D raster map of a space time 3D raster dataset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:1037 ../gui/wxpython/menustrings.py:1980
+#: ../gui/wxpython/menustrings.py:999 ../gui/wxpython/menustrings.py:1905
msgid "Report temporal topology"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1038 ../gui/wxpython/menustrings.py:1981
+#: ../gui/wxpython/menustrings.py:1000 ../gui/wxpython/menustrings.py:1906
msgid "Lists temporal topology of a space time dataset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:1039 ../gui/wxpython/menustrings.py:1982
-#: ../gui/wxpython/menustrings.py:1989
+#: ../gui/wxpython/menustrings.py:1001 ../gui/wxpython/menustrings.py:1907
+#: ../gui/wxpython/menustrings.py:1914
msgid "GUI tools"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1042 ../gui/wxpython/menustrings.py:1985
-#: ../gui/wxpython/menustrings.py:2005
+#: ../gui/wxpython/menustrings.py:1004 ../gui/wxpython/menustrings.py:1910
+#: ../gui/wxpython/menustrings.py:1930
msgid "Timeline tool"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1043 ../gui/wxpython/menustrings.py:1986
-#: ../gui/wxpython/menustrings.py:2006
+#: ../gui/wxpython/menustrings.py:1005 ../gui/wxpython/menustrings.py:1911
+#: ../gui/wxpython/menustrings.py:1931
msgid "Plot temporal extents."
msgstr ""
-#: ../gui/wxpython/menustrings.py:1044 ../gui/wxpython/menustrings.py:1987
-#: ../gui/wxpython/menustrings.py:2003
+#: ../gui/wxpython/menustrings.py:1006 ../gui/wxpython/menustrings.py:1912
+#: ../gui/wxpython/menustrings.py:1928
msgid "Temporal plot tool"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1045 ../gui/wxpython/menustrings.py:1988
-#: ../gui/wxpython/menustrings.py:2004
+#: ../gui/wxpython/menustrings.py:1007 ../gui/wxpython/menustrings.py:1913
+#: ../gui/wxpython/menustrings.py:1929
msgid "Plot temporal values."
msgstr ""
-#: ../gui/wxpython/menustrings.py:1046 ../gui/wxpython/menustrings.py:2052
-#: ../gui/wxpython/menustrings.py:2095
+#: ../gui/wxpython/menustrings.py:1008 ../gui/wxpython/menustrings.py:1977
+#: ../gui/wxpython/menustrings.py:2020
msgid "&Help"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1047
+#: ../gui/wxpython/menustrings.py:1009
msgid "GRASS help"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1048 ../gui/wxpython/menustrings.py:1050
+#: ../gui/wxpython/menustrings.py:1010 ../gui/wxpython/menustrings.py:1012
msgid "Display the HTML man pages of GRASS GIS"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1049
+#: ../gui/wxpython/menustrings.py:1011
msgid "GUI help"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1051
+#: ../gui/wxpython/menustrings.py:1013
msgid "About system"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1052
+#: ../gui/wxpython/menustrings.py:1014
msgid "Prints system information"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1057
+#: ../gui/wxpython/menustrings.py:1019
msgid "Import, export and link data"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1992
+#: ../gui/wxpython/menustrings.py:1917
msgid "Attribute table manager"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2011
+#: ../gui/wxpython/menustrings.py:1936
msgid "Create new model"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2013
+#: ../gui/wxpython/menustrings.py:1938
msgid "Load model from file"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2017
+#: ../gui/wxpython/menustrings.py:1942
msgid "Save model to file"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2019
+#: ../gui/wxpython/menustrings.py:1944
msgid "Close model file"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2020
+#: ../gui/wxpython/menustrings.py:1945
msgid "Export to image"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2021
+#: ../gui/wxpython/menustrings.py:1946
msgid "Export model to image"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2022
+#: ../gui/wxpython/menustrings.py:1947
msgid "Export to Python"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2023
+#: ../gui/wxpython/menustrings.py:1948
msgid "Export model to Python script"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2024
+#: ../gui/wxpython/menustrings.py:1949
msgid "Quit modeler"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2025
+#: ../gui/wxpython/menustrings.py:1950
msgid "Close modeler window"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2029
+#: ../gui/wxpython/menustrings.py:1954
msgid "&Model"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2030
+#: ../gui/wxpython/menustrings.py:1955
msgid "Add command"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2031
+#: ../gui/wxpython/menustrings.py:1956
msgid "Add action (GRASS command) to model"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2032
+#: ../gui/wxpython/menustrings.py:1957
msgid "Add data"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2033
+#: ../gui/wxpython/menustrings.py:1958
msgid "Add data item to model"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2034
+#: ../gui/wxpython/menustrings.py:1959
msgid "Define relation"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2035
+#: ../gui/wxpython/menustrings.py:1960
msgid "Define relation between data and action items"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2036
+#: ../gui/wxpython/menustrings.py:1961
msgid "Add loop / series"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2037
+#: ../gui/wxpython/menustrings.py:1962
msgid "Adds loop (series) to model"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2038
+#: ../gui/wxpython/menustrings.py:1963
msgid "Add condition"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2039
+#: ../gui/wxpython/menustrings.py:1964
msgid "Adds condition (if/else) to model"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2041
+#: ../gui/wxpython/menustrings.py:1966
msgid "Adds comment to model"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2042
+#: ../gui/wxpython/menustrings.py:1967
msgid "Remove item"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2043
+#: ../gui/wxpython/menustrings.py:1968
msgid "Remove action/data from model"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2045
+#: ../gui/wxpython/menustrings.py:1970
msgid "Model properties (name, purpose, etc.)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2046
+#: ../gui/wxpython/menustrings.py:1971
msgid "Delete intermediate data"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2047
+#: ../gui/wxpython/menustrings.py:1972
msgid "Delete intermediate data defined in the model"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2049
+#: ../gui/wxpython/menustrings.py:1974
msgid "Run entire model"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2050
+#: ../gui/wxpython/menustrings.py:1975
msgid "Validate model"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2051
+#: ../gui/wxpython/menustrings.py:1976
msgid "Validate entire model"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2054
+#: ../gui/wxpython/menustrings.py:1979
msgid "Display the HTML man pages of Graphical modeler"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2055
+#: ../gui/wxpython/menustrings.py:1980
msgid "About Graphical Modeler"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2056
+#: ../gui/wxpython/menustrings.py:1981
msgid "Display information about Graphical Modeler"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2062
+#: ../gui/wxpython/menustrings.py:1987
msgid "Load instruction file"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2064
+#: ../gui/wxpython/menustrings.py:1989
msgid "Export instruction file"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2066
+#: ../gui/wxpython/menustrings.py:1991
msgid "Export to PostScript"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2068
+#: ../gui/wxpython/menustrings.py:1993
msgid "Export to PDF"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2070 ../gui/wxpython/menustrings.py:2071
+#: ../gui/wxpython/menustrings.py:1995 ../gui/wxpython/menustrings.py:1996
msgid "Launch ps.map dialog"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2073
+#: ../gui/wxpython/menustrings.py:1998
msgid "Close Cartographic Composer"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2074
+#: ../gui/wxpython/menustrings.py:1999
msgid "&Insert"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2076
+#: ../gui/wxpython/menustrings.py:2001
msgid "Add or edit map frame"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2078
+#: ../gui/wxpython/menustrings.py:2003
msgid "Add or edit raster map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2080
+#: ../gui/wxpython/menustrings.py:2005
msgid "Add or edit vector map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2081
+#: ../gui/wxpython/menustrings.py:2006
msgid "Map legend"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2082
+#: ../gui/wxpython/menustrings.py:2007
msgid "Add or edit raster and vector legend"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2084
+#: ../gui/wxpython/menustrings.py:2009
msgid "Add or edit map info"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2086
+#: ../gui/wxpython/menustrings.py:2011
msgid "Add or edit scale bar"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2097
+#: ../gui/wxpython/menustrings.py:2022
msgid "Display the HTML man pages of Cartographic Composer"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2098
+#: ../gui/wxpython/menustrings.py:2023
msgid "About Cartographic Composer"
msgstr ""
-#: ../gui/wxpython/menustrings.py:2099
+#: ../gui/wxpython/menustrings.py:2024
msgid "Display information about Cartographic Composer"
msgstr ""
