[GRASS-SVN] r72044 - grass/trunk/vector/v.perturb
svn_grass at osgeo.org
Sun Jan 7 07:11:10 PST 2018
Author: neteler
Date: 2018-01-07 07:11:10 -0800 (Sun, 07 Jan 2018)
New Revision: 72044
Added:
grass/trunk/vector/v.perturb/v_perturb_normal.png
grass/trunk/vector/v.perturb/v_perturb_uniform.png
grass/trunk/vector/v.perturb/v.perturb.html
v.perturb manual: example added (contributed by Jerry Huang and Google Code-in); examples restructured
Property changes on: grass/trunk/vector/v.perturb
___________________________________________________________________
Modified: svn:ignore
- OBJ.*
+ OBJ.*
*.tmp.html
Modified: grass/trunk/vector/v.perturb/v.perturb.html
--- grass/trunk/vector/v.perturb/v.perturb.html 2018-01-07 10:27:35 UTC (rev 72043)
+++ grass/trunk/vector/v.perturb/v.perturb.html 2018-01-07 15:11:10 UTC (rev 72044)
@@ -2,9 +2,9 @@
<em>v.perturb</em>
reads a vector map of points and writes the same points but
-<em>perturbs</em> the eastings and northings by
-adding either a uniform or normal delta value. Perturbation means that
-a variating spatial deviation is added to the coordinates.
+<em>perturbs</em> the eastings and northings by adding either a uniform
+or normal delta value. Perturbation means that a variating spatial
+deviation is added to the coordinates.
<h2>NOTES</h2>
@@ -24,12 +24,59 @@
Output vector points are not guaranteed to be contained within the
current geographic region.
+<h2>EXAMPLES</h2>
+<h3>Random, uniformly distributed selection</h3>
+To create a random, uniformly distributed selection of possible new points
+with a radius of 100,000 map units, use the following command:
+<div class="code"><pre>
+v.perturb input=comm_colleges output=uniform_perturb parameters=100000
+</pre></div>
+Your map should look similar to this figure:
+<div align="center" style="margin: 10px">
+<img src="v_perturb_uniform.png" alt="v.perturb uniform distribution example" border="0">
+<br>
+<i>Figure: Map showing the actual community college points and uniformly
+ random chosen points.</i>
+</div>
+<h3>Normal distributed selection</h3>
+For a normal distribution with a mean of 5000 and standard deviation of
+2000, use the following command:
+v.perturb input=comm_colleges output=normal_perturb distribution=normal parameters=5000,2000
+</pre></div>
+<img src="v_perturb_normal.png" alt="v.perturb normal distribution example" border="0">
+<br>
+<i>Figure: Map showing the actual community college points and normally
+ random chosen and colored points. Notice that each point is closer
+ to the original point.</i>
+</div>
+<h3>Normal distributed selection with a minimum value</h3>
+In order to include a minimum value of 500, use the following command:
+v.perturb input=comm_colleges output=min_perturb distribution=normal parameters=100000,1000 minimum=500
+</pre></div>
<h2>SEE ALSO</h2>
-<em><a href="v.random.html">v.random</a></em><br>
-<em><a href="v.univar.html">v.univar</a></em><br>
+<em>
+<a href="v.random.html">v.random</a>,
+<a href="v.univar.html">v.univar</a>
+</em>
<h2>AUTHOR</h2>
<a href="http://mccauley-usa.com/">James Darrell McCauley</a>
Added: grass/trunk/vector/v.perturb/v_perturb_normal.png
(Binary files differ)
Property changes on: grass/trunk/vector/v.perturb/v_perturb_normal.png
Added: svn:mime-type
+ image/png
Added: grass/trunk/vector/v.perturb/v_perturb_uniform.png
Property changes on: grass/trunk/vector/v.perturb/v_perturb_uniform.png
+ image/png
