[GRASS-SVN] r72045 - grass/branches/releasebranch_7_4/vector/v.perturb
Sun Jan 7 07:12:07 PST 2018
Author: neteler
Date: 2018-01-07 07:12:07 -0800 (Sun, 07 Jan 2018)
New Revision: 72045
Added:
   grass/branches/releasebranch_7_4/vector/v.perturb/v_perturb_normal.png
   grass/branches/releasebranch_7_4/vector/v.perturb/v_perturb_uniform.png
   grass/branches/releasebranch_7_4/vector/v.perturb/v.perturb.html
v.perturb manual: example added (contributed by Jerry Huang and Google Code-in); examples restructured
Property changes on: grass/branches/releasebranch_7_4/vector/v.perturb
___________________________________________________________________
Modified: svn:ignore
   - OBJ.*
   + OBJ.*
*.tmp.html
Modified: grass/branches/releasebranch_7_4/vector/v.perturb/v.perturb.html
--- grass/branches/releasebranch_7_4/vector/v.perturb/v.perturb.html	2018-01-07 15:11:10 UTC (rev 72044)
+++ grass/branches/releasebranch_7_4/vector/v.perturb/v.perturb.html	2018-01-07 15:12:07 UTC (rev 72045)
@@ -2,9 +2,9 @@
 <em>v.perturb</em>
 reads a vector map of points and writes the same points but
-<em>perturbs</em> the eastings and northings by
-adding either a uniform or normal delta value. Perturbation means that
-a variating spatial deviation is added to the coordinates.
+<em>perturbs</em> the eastings and northings by adding either a uniform
+or normal delta value. Perturbation means that a variating spatial
+deviation is added to the coordinates.
 <h2>NOTES</h2>
@@ -24,12 +24,59 @@
 Output vector points are not guaranteed to be contained within the
 current geographic region.
+<h2>EXAMPLES</h2>
+<h3>Random, uniformly distributed selection</h3>
+To create a random, uniformly distributed selection of possible new points
+with a radius of 100,000 map units, use the following command:
+<div class="code"><pre>
+v.perturb input=comm_colleges output=uniform_perturb parameters=100000
+</pre></div>
+Your map should look similar to this figure:
+<div align="center" style="margin: 10px">
+<img src="v_perturb_uniform.png" alt="v.perturb uniform distribution example" border="0">
+<br>
+<i>Figure: Map showing the actual community college points and uniformly
+   random chosen points.</i>
+</div>
+<h3>Normal distributed selection</h3>
+For a normal distribution with a mean of 5000 and standard deviation of
+2000, use the following command:
+v.perturb input=comm_colleges output=normal_perturb distribution=normal parameters=5000,2000
+</pre></div>
+<img src="v_perturb_normal.png" alt="v.perturb normal distribution example" border="0">
+<br>
+<i>Figure: Map showing the actual community college points and normally
+   random chosen and colored points. Notice that each point is closer
+   to the original point.</i>
+</div>
+<h3>Normal distributed selection with a minimum value</h3>
+In order to include a minimum value of 500, use the following command:
+v.perturb input=comm_colleges output=min_perturb distribution=normal parameters=100000,1000 minimum=500
+</pre></div>
 <h2>SEE ALSO</h2>
-<em><a href="v.random.html">v.random</a></em><br>
-<em><a href="v.univar.html">v.univar</a></em><br>
+<em>
+<a href="v.random.html">v.random</a>,
+<a href="v.univar.html">v.univar</a>
+</em>
 <h2>AUTHOR</h2>
 <a href="http://mccauley-usa.com/">James Darrell McCauley</a>
Copied: grass/branches/releasebranch_7_4/vector/v.perturb/v_perturb_normal.png (from rev 72044, grass/trunk/vector/v.perturb/v_perturb_normal.png)
(Binary files differ)
Copied: grass/branches/releasebranch_7_4/vector/v.perturb/v_perturb_uniform.png (from rev 72044, grass/trunk/vector/v.perturb/v_perturb_uniform.png)
