[GRASS-SVN] r72049 - in grass/trunk/vector/v.univar: . testsuite
svn_grass at osgeo.org
Sun Jan 7 13:34:57 PST 2018
Author: lucadelu
Date: 2018-01-07 13:34:57 -0800 (Sun, 07 Jan 2018)
New Revision: 72049
Added:
grass/trunk/vector/v.univar/testsuite/
grass/trunk/vector/v.univar/testsuite/v_univar_test.py
v.univar: added tests, thanks to Sunveer Singh during Google Code-in 2017
Added: grass/trunk/vector/v.univar/testsuite/v_univar_test.py
--- grass/trunk/vector/v.univar/testsuite/v_univar_test.py (rev 0)
+++ grass/trunk/vector/v.univar/testsuite/v_univar_test.py 2018-01-07 21:34:57 UTC (rev 72049)
@@ -0,0 +1,81 @@
+Name: v.univar test
+Purpose: Tests v.univar and its flags/options.
+Author: Sunveer Singh, Google Code-in 2017
+Copyright: (C) 2017 by Sunveer Singh and the GRASS Development Team
+Licence: This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+from grass.gunittest.gmodules import SimpleModule
+class TestProfiling(TestCase):
+ def test_flagg(self):
+ """Testing flag g with map bridges"""
+ output_str="""n=2537
+ nmissing=0
+ nnull=0
+ min=1
+ max=2537
+ range=2536
+ sum=3.21945e+06
+ mean=1269
+ mean_abs=1269
+ population_stddev=732.369
+ population_variance=536364
+ population_coeff_variation=0.577123
+ sample_stddev=732.513
+ sample_variance=536576
+ kurtosis=-1.20142
+ skewness=0"""
+ v_univar = SimpleModule("v.univar", flags="g", map='census', column='cat')
+ self.assertModuleKeyValue(module='v.univar', map='census', column='cat', flags='g', reference=output_str,
+ precision=2, sep="=")
+ def test_flage(self):
+ """Testing flag e with map geology"""
+ self.assertModule('v.univar', map='geology', column='PERIMETER', flags='e')
+ def test_flagw(self):
+ """Testing flag w with map lakes"""
+ self.assertModule('v.univar', map='hospitals', column='cat', flags='w')
+ def test_flagd(self):
+ """Testing flag d with map hospitals"""
+ univar_string="""n=160
+ nmissing=0
+ nnull=0
+ min=1
+ max=160
+ range=159
+ sum=12880
+ mean=80.5
+ mean_abs=80.5"""
+ self.assertModule('v.univar', map='hospitals', column='CITY', flags='d')
+ def test_output(self):
+ """Testing output of v.univar"""
+ min=1
+ max=160
+ range=159
+ mean=80.5
+ sum=12880"""
+ self.assertVectorFitsUnivar(map='hospitals', column='cat', reference=univar_string, precision=3)
+ def test_output2(self):
+ univar_string="""n=357
+ min=1
+ max=357
+ range=356
+ mean=179.82
+ sum=63836"""
+ self.assertVectorFitsUnivar(map='roadsmajor', column='MAJORRDS_', reference=univar_string, precision=3)
+if __name__ == '__main__':
+ test()
