[GRASS-SVN] r72050 - in grass/trunk/raster/r.info: . testsuite
svn_grass at osgeo.org
Sun Jan 7 13:47:42 PST 2018
Author: lucadelu
Date: 2018-01-07 13:47:42 -0800 (Sun, 07 Jan 2018)
New Revision: 72050
Added:
grass/trunk/raster/r.info/testsuite/
grass/trunk/raster/r.info/testsuite/test_r_info.py
r.info: added tests, thanks to Sunveer Singh during Google Code-in 2017
Added: grass/trunk/raster/r.info/testsuite/test_r_info.py
--- grass/trunk/raster/r.info/testsuite/test_r_info.py (rev 0)
+++ grass/trunk/raster/r.info/testsuite/test_r_info.py 2018-01-07 21:47:42 UTC (rev 72050)
@@ -0,0 +1,58 @@
+Name: r.info test
+Purpose: Tests r.info and its flags/options.
+Author: Sunveer Singh, Google Code-in 2017
+Copyright: (C) 2017 by Sunveer Singh and the GRASS Development Team
+Licence: This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+from grass.gunittest.case import TestCase
+from grass.gunittest.gmodules import SimpleModule
+class TestReport(TestCase):
+ @classmethod
+ def setUpClass(cls):
+ """Use temporary region settings"""
+ cls.use_temp_region()
+ @classmethod
+ def tearDownClass(cls):
+ """!Remove the temporary region"""
+ cls.del_temp_region()
+ def test_flagg(self):
+ """Testing flag g with map geology_30m using simple module"""
+ output_str="""north=228500
+ south=215000
+ east=645000
+ west=630000
+ nsres=10
+ ewres=10
+ rows=1350
+ cols=1500
+ cells=2025000
+ datatype=CELL
+ ncats=43600"""
+ self.assertModuleKeyValue(module='r.info', map='lakes', flags='g', reference=output_str,
+ precision=2, sep="=")
+ def test_flagr(self):
+ """Testing flag r with map landcover_1m using simple module"""
+ output_str="""min=34300
+ max=43600"""
+ self.assertModuleKeyValue(module='r.info', map='lakes', flags='r', reference=output_str,
+ def test_flage(self):
+ """Testing flag e with map lsat7_2002_50"""
+ self.assertModule('r.info', map='lakes', flags='e')
+ def test_flagh(self):
+ """Testing flag h with map zipcodes"""
+ self.assertModule('r.info', map='lakes', flags='h')
+if __name__ == '__main__':
+ from grass.gunittest.main import test
+ test()
