[GRASS-SVN] r72086 - grass/trunk/rpm
svn_grass at osgeo.org
Mon Jan 15 14:19:38 PST 2018
Author: mmetz
Date: 2018-01-15 14:19:38 -0800 (Mon, 15 Jan 2018)
New Revision: 72086
Added:
grass/trunk/rpm/grass_unversioned.spec
grass/trunk/rpm/README.txt
add unversioned example RPM SPEC file
Modified: grass/trunk/rpm/README.txt
--- grass/trunk/rpm/README.txt 2018-01-15 21:40:37 UTC (rev 72085)
+++ grass/trunk/rpm/README.txt 2018-01-15 22:19:38 UTC (rev 72086)
@@ -16,4 +16,9 @@
http://download.opensuse.org/repositories/Application:/Geo/
-example SPEC file in this folder: grass.spec
+example SPEC files in this folder
+ versioned GRASS installation
+ grass.spec
+ unversioned GRASS installation
+ grass_unversioned.spec
Added: grass/trunk/rpm/grass_unversioned.spec
--- grass/trunk/rpm/grass_unversioned.spec (rev 0)
+++ grass/trunk/rpm/grass_unversioned.spec 2018-01-15 22:19:38 UTC (rev 72086)
@@ -0,0 +1,558 @@
+%global shortver 74
+%global macrosdir %(d=%{_rpmconfigdir}/macros.d; [ -d $d ] || d=%{_sysconfdir}/rpm; echo $d)
+Name: grass
+Version: 7.4.0
+Release: 1%{?dist}
+Summary: GRASS GIS - Geographic Resources Analysis Support System
+Group: Applications/Engineering
+License: GPLv2+
+URL: https://grass.osgeo.org
+Source0: https://grass.osgeo.org/%{name}%{shortver}/source/%{name}-%{version}.tar.gz
+Source2: %{name}-config.h
+# Patch0: grass72_ctypes_gcc7.diff
+BuildRequires: bison
+BuildRequires: blas-devel
+BuildRequires: desktop-file-utils
+BuildRequires: fftw-devel
+BuildRequires: flex
+%if (0%{?rhel} > 6 || 0%{?fedora})
+BuildRequires: freetype-devel
+%endif
+BuildRequires: gdal-devel
+BuildRequires: geos-devel
+BuildRequires: gettext
+BuildRequires: lapack-devel
+BuildRequires: libappstream-glib
+%endif
+%if 0%{?fedora}
+BuildRequires: liblas-devel => 1.8.0-12
+%endif
+BuildRequires: libpng-devel
+BuildRequires: libtiff-devel
+BuildRequires: libXmu-devel
+BuildRequires: mesa-libGL-devel
+BuildRequires: mesa-libGLU-devel
+BuildRequires: mysql-devel
+BuildRequires: netcdf-devel
+%endif
+BuildRequires: numpy
+BuildRequires: postgresql-devel
+%else
+# RHEL6: PG from http://yum.postgresql.org/9.6/redhat/rhel-$releasever-$basearch/
+BuildRequires: postgresql96-devel postgresql96-libs
+%endif
+BuildRequires: proj-devel
+BuildRequires: proj-epsg
+BuildRequires: proj-nad
+%if (0%{?rhel} <= 6 && !0%{?fedora})
+# argparse is included in python2.7+ but not python2.6
+BuildRequires: python-argparse
+%endif
+BuildRequires: python-dateutil
+BuildRequires: python-devel
+Requires: python-matplotlib
+#Requires: python-matplotlib-wx
+BuildRequires: python-pillow
+%else
+BuildRequires: python-imaging
+%endif
+BuildRequires: readline-devel
+BuildRequires: sqlite-devel
+BuildRequires: subversion
+BuildRequires: unixODBC-devel
+BuildRequires: wxGTK-devel
+BuildRequires: zlib-devel
+Requires: geos
+Requires: numpy
+Requires: proj-epsg
+Requires: proj-nad
+Requires: wxPython
+%if "%{_lib}" == "lib"
+%global cpuarch 32
+%else
+%global cpuarch 64
+%endif
+Requires: %{name}%{?isa}-libs = %{version}-%{release}
+%description
+GRASS (Geographic Resources Analysis Support System) is a Geographic
+Information System (GIS) used for geospatial data management and
+analysis, image processing, graphics/maps production, spatial
+modeling, and visualization. GRASS is currently used in academic and
+commercial settings around the world, as well as by many governmental
+agencies and environmental consulting companies.
+%package libs
+Summary: GRASS GIS runtime libraries
+%description libs
+GRASS GIS runtime libraries
+%package gui
+Summary: GRASS GIS GUI
+Requires: %{name}%{?isa} = %{version}-%{release}
+%description gui
+GRASS GIS GUI
+%package devel
+Summary: GRASS GIS development headers
+%description devel
+GRASS GIS development headers
+%prep
+%setup -q
+# %patch0 -p1
+# Correct mysql_config query
+sed -i -e 's/--libmysqld-libs/--libs/g' configure
+# Fixup shebangs
+find -type f | xargs sed -i -e 's,#!/usr/bin/env python,#!%{__python},'
+find -name \*.pl | xargs sed -i -e 's,#!/usr/bin/env perl,#!%{__perl},'
+%build
+# Package is not ready for -Werror=format-security or the C++11 standard
+CFLAGS="$(echo ${RPM_OPT_FLAGS} | sed -e 's/ -Werror=format-security//')"
+CXXFLAGS="-std=c++98 ${CFLAGS}"
+%configure \
+ --with-cxx \
+ --with-tiff \
+ --with-png \
+ --with-postgres \
+ --with-mysql \
+ --with-opengl \
+ --with-odbc \
+ --with-fftw \
+ --with-blas \
+ --with-lapack \
+ --with-cairo \
+ --with-freetype \
+%endif
+ --with-nls \
+ --with-readline \
+ --with-regex \
+ --with-openmp \
+ --with-gdal=%{_bindir}/gdal-config \
+ --with-wxwidgets=%{_bindir}/wx-config \
+ --with-geos=%{_bindir}/geos-config \
+ --with-netcdf=%{_bindir}/nc-config \
+%endif
+ --with-mysql-includes=%{_includedir}/mysql \
+ --with-mysql-libs=%{_libdir} \
+ --with-postgres-includes=%{_includedir}/pgsql \
+%else
+ --with-postgres-includes=%{_prefix}/pgsql-9.6/include/ \
+ --with-postgres-libs=%{_prefix}/pgsql-9.6/lib/ \
+%endif
+ --with-cairo-ldflags=-lfontconfig \
+ --with-freetype-includes=%{_includedir}/freetype2 \
+ --with-proj-share=%{_datadir}/proj \
+%if 0%{?fedora}
+ --with-liblas=%{_bindir}/liblas-config
+%endif
+make %{?_smp_mflags}
+%else
+# EPEL6: the HTML parser is too strict in Python 6, hence a few manual pages will not be generated
+make %{?_smp_mflags} || echo "EPEL6: ignoring failed manual pages"
+%endif
+# by default, grass will be installed to /usr/grass-%%{version}
+# this is not FHS compliant: hide grass-%%{version} in %%{libdir}/grass
+# version will be removed
+%install
+%make_install \
+ prefix=%{buildroot}%{_libdir} \
+ UNIX_BIN=%{buildroot}%{_bindir}
+# remove version number
+mv %{buildroot}%{_libdir}/%{name}-%{version} %{buildroot}%{_libdir}/%{name}
+mv %{buildroot}%{_bindir}/%{name}%{shortver} %{buildroot}%{_bindir}/%{name}
+# libraries and headers are in GISBASE = %%{_libdir}/%%{name}
+# keep them in GISBASE
+# fix paths:
+# Change GISBASE in startup script
+sed -i -e 's|%{buildroot}%{_libdir}/%{name}-%{version}|%{_libdir}/%{name}|g' \
+ %{buildroot}%{_bindir}/%{name}
+# fix GRASS_HOME and RUN_GISBASE in Platform.make
+ %{buildroot}%{_libdir}/%{name}/include/Make/Platform.make
+# fix INST_DIR in Platform.make
+sed -i -e 's|%{name}-%{version}|%{name}|g' \
+# fix ARCH_DISTDIR in Grass.make
+ %{buildroot}%{_libdir}/%{name}/include/Make/Grass.make
+# fix ARCH_BINDIR in Grass.make
+sed -i -e 's|%{buildroot}%{_bindir}|%{_bindir}|g' \
+# fix GISDBASE in demolocation
+sed -i -e 's|%{buildroot}%{_libdir}/%{name}|%{_libdir}/%{name}|g' \
+ %{buildroot}%{_libdir}/%{name}/demolocation/.grassrc%{shortver}
+# Correct font path
+sed -i -e 's|%{buildroot}%{_libdir}/%{name}|%{_libdir}/%{name}|' \
+ %{buildroot}%{_libdir}/%{name}/etc/fontcap
+# fix paths in grass.pc
+sed -i -e 's|%{_prefix}/%{name}-%{version}|%{_libdir}/%{name}|g' \
+ %{name}.pc
+mkdir -p %{buildroot}%{_libdir}/pkgconfig
+install -p -m 644 %{name}.pc %{buildroot}%{_libdir}/pkgconfig
+# Create multilib header
+mv %{buildroot}%{_libdir}/%{name}/include/%{name}/config.h \
+ %{buildroot}%{_libdir}/%{name}/include/%{name}/config-%{cpuarch}.h
+install -p -m 644 %{SOURCE2} %{buildroot}%{_libdir}/%{name}/include/%{name}/config.h
+# Make man pages available on the system, convert to utf8 and avoid name conflict
+mkdir -p %{buildroot}%{_mandir}/man1
+for man in $(ls %{buildroot}%{_libdir}/%{name}/docs/man/man1/*.1)
+do
+ iconv -f iso8859-1 -t utf8 $man > %{buildroot}%{_mandir}/man1/$(basename $man)"%{name}"
+done
+for file in infrastructure.txt ; do
+ iconv -f ISO-8859-1 -t UTF-8 $file > ${file}.tmp && mv -f ${file}.tmp $file
+done
+# Make desktop, appdata and icon files available on the system
+mv %{buildroot}%{_libdir}/%{name}/share/* %{buildroot}%{_datadir}
+desktop-file-validate %{buildroot}/%{_datadir}/applications/*.desktop
+# EPEL7 fails on url tag, so we ignore failure:
+appstream-util validate-relax --nonet %{buildroot}/%{_datadir}/appdata/*.appdata.xml || echo "Ignoring appstream-util failure"
+# symlink docs from GISBASE to standard system location
+mkdir -p %{buildroot}%{_docdir}
+ln -s %{_libdir}/%{name}/docs %{buildroot}%{_docdir}/%{name}
+# Cleanup: nothing to do
+#rm -rf %%{buildroot}%%{_libdir}/%%{name}
+# rpm macro for version checking
+mkdir -p ${RPM_BUILD_ROOT}%{macrosdir}
+cat > ${RPM_BUILD_ROOT}%{macrosdir}/macros.%{name} <<EOF
+# %name version is
+%%%{name}_version %{version}
+EOF
+%post
+/bin/touch --no-create %{_datadir}/icons/hicolor &>/dev/null || :
+%postun
+if [ $1 -eq 0 ] ; then
+ /bin/touch --no-create %{_datadir}/icons/hicolor &>/dev/null
+ /usr/bin/gtk-update-icon-cache %{_datadir}/icons/hicolor &>/dev/null || :
+fi
+%posttrans
+/usr/bin/gtk-update-icon-cache %{_datadir}/icons/hicolor &>/dev/null || :
+%post libs -p /sbin/ldconfig
+%postun libs -p /sbin/ldconfig
+%files
+%exclude %{_libdir}/%{name}/driver/db/*
+%exclude %{_libdir}/%{name}/lib
+%exclude %{_libdir}/%{name}/include
+%exclude %{_libdir}/%{name}/gui
+%{_libdir}/%{name}
+%{_bindir}/*
+%{_datadir}/appdata/*
+%{_datadir}/applications/*
+%{_datadir}/icons/hicolor/*/apps/*
+%{_mandir}/man1/*
+%{_docdir}/%{name}
+%files libs
+%license AUTHORS COPYING GPL.TXT CHANGES
+%{_libdir}/%{name}/lib/*.%{version}.so
+%{_libdir}/%{name}/lib/*.a
+%dir %{_libdir}/%{name}/driver
+%dir %{_libdir}/%{name}/driver/db
+%{_libdir}/%{name}/driver/db/*
+%files gui
+%{_libdir}/%{name}/gui
+%files devel
+%doc TODO doc/* SUBMITTING
+%{macrosdir}/macros.%{name}
+%{_libdir}/pkgconfig/*
+%dir %{_libdir}/%{name}/lib
+%{_libdir}/%{name}/lib/*[!%{version}].so
+%{_libdir}/%{name}/include
+%changelog
+* Mon Jan 15 2018 Markus Metz <metz at mundialis.de> - 7.4.0-1
+- New upstream version 7.4.0
+- Fix grass-devel which needs include/grass and include/Make dirs
+* Fri Jul 21 2017 Kalev Lember <klember at redhat.com> - 7.2.1-2
+- Rebuilt for Boost 1.64
+* Wed May 3 2017 Markus Neteler <neteler at mundialis.de> - 7.2.1-1
+- New upstream version 7.2.1
+* Thu Mar 2 2017 Markus Neteler <neteler at mundialis.de> - 7.2.0-3
+- Fix for g.extension which needs include/ dir in grass-devel
+* Sat Feb 4 2017 Markus Neteler <neteler at mundialis.de> - 7.2.0-2
+- Fixes for EPEL
+* Thu Jan 12 2017 Markus Neteler <neteler at mundialis.de> - 7.2.0-1
+- New upstream version 7.2.0
+* Thu Jan 12 2017 Igor Gnatenko <ignatenko at redhat.com> - 7.0.4-5
+- Rebuild for readline 7.x
+* Sun Jan 01 2017 Volker Froehlich <volker27 at gmx.at> - 7.0.4-4
+- Rebuild for libgeos
+* Fri Oct 7 2016 Orion Poplawski <orion at cora.nwra.com> - 7.0.4-3
+- Add patch to fix desktop file
+- Validate desktop and appdata files
+- Fix script interpreters
+- Convert files to UTF-8 if needed
+* Wed Sep 21 2016 Orion Poplawski <orion at cora.nwra.com> - 7.0.4-2
+- Generate rpm macro file for version tracking
+* Mon May 9 2016 Devrim Gündüz <devrim at gunduz.org> - 7.0.4-1
+- Update to 7.0.4
+* Mon Mar 07 2016 Thomas Kreuzer <thomas.kreuzer at uni-vechta.de> - 7.0.3-1
+- New SPEC file for GRASS GIS 7.0.3
+* Tue Sep 23 2014 Richard Hughes <richard at hughsie.com> - 6.4.4-5
+- Install the shipped AppData file
+* Sat Aug 16 2014 Fedora Release Engineering <rel-eng at lists.fedoraproject.org> - 6.4.4-3
+- Rebuilt for https://fedoraproject.org/wiki/Fedora_21_22_Mass_Rebuild
+* Sat Aug 09 2014 Ralf Corsépius <corsepius at fedoraproject.org> 6.4.4-2
+- Rebase patches against grass-6.4.4.
+- Convert -Werror=format-security into warnings (RHBZ#1106720).
+- Minor spec cleanup.
+* Fri Jul 25 2014 Peter Robinson <pbrobinson at fedoraproject.org> 6.4.4-1
+- Update to 6.4.4
+- Make 64bit conditionals generic
+* Sat Jun 07 2014 Fedora Release Engineering <rel-eng at lists.fedoraproject.org> - 6.4.3-8
+- Rebuilt for https://fedoraproject.org/wiki/Fedora_21_Mass_Rebuild
+* Wed May 21 2014 Jaroslav Škarvada <jskarvad at redhat.com> - 6.4.3-7
+- Rebuilt for https://fedoraproject.org/wiki/Changes/f21tcl86
+* Thu Mar 27 2014 Ville Skyttä <ville.skytta at iki.fi> - 6.4.3-6
+- Don't ship patch backup files
+* Mon Oct 14 2013 Volker Fröhlich <volker27 at gmx.at> - 6.4.3-5
+- Solve build failure on PPC tests (BZ#961838)
+* Wed Oct 9 2013 Devrim Gündüz <devrim at gunduz.org> - 6.4.3-4
+- Rebuild against new GEOS
+* Thu Oct 3 2013 Volker Fröhlich <volker27 at gmx.at> - 6.4.3-3
+- Add patch for release name encoding crash
+- Use upstream desktop file (BZ #986852)
+- Install icons of different sizes
+* Sat Sep 14 2013 Volker Fröhlich <volker27 at gmx.at> - 6.4.3-2
+- Remove gcc patch (upstream)
+- Remove useless BR for libjpeg
+- Make config.h a source file instead of defining it in the spec file
+- Truncate changelog
+* Thu Sep 12 2013 Devrim GÜNDÜZ <devrim at gunduz.org> - 6.4.3-1
+- Update to 6.4.3
+- Rebuild with new geos.
+* Tue Aug 27 2013 Orion Poplawski <orion at cora.nwra.com> - 6.4.2-11
+- Rebuild for gdal 1.10.0
+* Sat Aug 03 2013 Fedora Release Engineering <rel-eng at lists.fedoraproject.org> - 6.4.2-10
+- Rebuilt for https://fedoraproject.org/wiki/Fedora_20_Mass_Rebuild
+* Fri Apr 12 2013 Jon Ciesla <limburgher at gmail.com> - 6.4.2-9
+- Drop desktop vendor tag.
+* Wed Mar 06 2013 Devrim GÜNDÜZ <devrim at gunduz.org> - 6.4.2-8
+* Fri Jan 25 2013 Devrim GÜNDÜZ <devrim at gunduz.org> - 6.4.2-7
+- Rebuild with geos 3.3.7.
+* Sun Nov 18 2012 Volker Fröhlich <volker27 at gmx.at> - 6.4.2-6
+- Rebuild with ever newer geos
+* Wed Nov 14 2012 Devrim GÜNDÜZ <devrim at gunduz.org> - 6.4.2-5
+* Thu Jul 19 2012 Fedora Release Engineering <rel-eng at lists.fedoraproject.org> - 6.4.2-4
+- Rebuilt for https://fedoraproject.org/wiki/Fedora_18_Mass_Rebuild
+* Mon Jul 16 2012 Devrim GÜNDÜZ <devrim at gunduz.org> - 6.4.2-3
+- Rebuilt
+* Sun Mar 4 2012 Volker Fröhlich <volker27 at gmx.at> - 6.4.2-2
+- Solve name conflict with "parallel" man pages (BZ 797824)
+- Correct man page encoding conversion
+- Build with multiple workers; assumuption on race-condition was wrong
+* Fri Mar 2 2012 Tom Callaway <spot at fedoraproject.org> - 6.4.2-1
+- update to 6.4.2
+* Tue Feb 28 2012 Fedora Release Engineering <rel-eng at lists.fedoraproject.org> - 6.4.1-8
+- Rebuilt for c++ ABI breakage
+* Tue Jan 10 2012 Volker Fröhlich <volker27 at gmx.at> - 6.4.1-7
+- Race condition in build system assumed -- going back to one worker
+* Mon Jan 9 2012 Devrim GÜNDÜZ <devrim at gunduz.org> - 6.4.1-6
+- Rebuilt with new geos
+* Wed Nov 23 2011 Volker Fröhlich <volker27 at gmx.at> - 6.4.1-5
+- Move string substitution back to the install section, because
+ it causes problems otherwise
+- Add patch for libpng API change
+* Wed Nov 02 2011 Volker Fröhlich <volker27 at gmx.at> - 6.4.1-4
+- Remove encoding from desktop file
+- Remove BR on wxGTK, because wxGTK requires it anyway
+- Disable Ubuntu patches, because they don't seem to work in Fedora
+- Move all the string substitution for locales and docs to prep
+- Use name macro in Source
+- Drop custom compiler flags -- no evidence they serve a purpose
+- Remove 2 unnecessary chmods
+- Don't use sysconfdir macro in places, where etc means something different
+- Add contributors to documentation
+* Wed Nov 02 2011 Volker Fröhlich <volker27 at gmx.at> - 6.4.1-3
+- Patch locale and documentation paths properly for the GUI
+* Thu Sep 22 2011 Volker Fröhlich <volker27 at gmx.at> - 6.4.1-2
+- Remove duplicate documentation
+- Correct further documentation paths
+- Create version-less symlinks for library directory and binary
+- Supply all lang files to the files section directly
+- Add ternary operator patch for Python 2.4 (ELGIS)
+* Tue Aug 02 2011 Volker Fröhlich <volker27 at gmx.at> - 6.4.1-1
+- Update to 6.4.1
+- Remove explicit lib and include dirs, where not necessary
+- Really build with geos
+- Remove sed call on ncurses
+* Tue Aug 02 2011 Volker Fröhlich <volker27 at gmx.at> - 6.4.0-4
+- Correct license to GPLv2+
+- Update URL
+- Replace define with global macro
+- Devel package required itself
+- Simplify setup macro
+- Don't add -lm manually anymore
+- Correct FSF postal address
+- Drop cstdio patch
+- Correct Exec and Icon entry in desktop file
+- Remove wrong and unnecessary translation entries from desktop file
+ GRASS didn't start for the first issue
+- Add numpy as requirement
+- Delete defattr, as the defaults work right
+- Use name macro where possible
+- Changelog doesn't need encoding conversion anymore
+ Same goes for translators and infrastructure files
+- Use mandir macro on one occasion
+- Introduce "shortversion" macro
+- Beautify case construction for 64 bit build flags
+- Update syntax for Require on base package to guidelines
+- Don't list LOCALE files twice, own directory
+- Don't ship same documentation in different packages
+- Drop README
+- Simplify file list in devel package
+- Replace extra icon source with one from the tarball
+* Wed Mar 23 2011 Dan Horák <dan at danny.cz> - 6.4.0-3
+- rebuilt for mysql 5.5.10 (soname bump in libmysqlclient)
+* Wed Feb 09 2011 Fedora Release Engineering <rel-eng at lists.fedoraproject.org> - 6.4.0-2
+- Rebuilt for https://fedoraproject.org/wiki/Fedora_15_Mass_Rebuild
+* Mon Nov 22 2010 Viji Nair <viji [AT] fedoraproject DOT org> - 6.4.0-1
+- Rebuilt with new gdal 1.7.3.
+- Updated to upstream version 6.4.0.
+- Removed grass-gdilib.patch
+- Spec review
+* Fri Dec 4 2009 Devrim GÜNDÜZ <devrim at gunduz.org> - 6.3.0-15
+* Fri Aug 21 2009 Tomas Mraz <tmraz at redhat.com> - 6.3.0-14
+- rebuilt with new openssl
+* Fri Jul 24 2009 Fedora Release Engineering <rel-eng at lists.fedoraproject.org> - 6.3.0-13
+- Rebuilt for https://fedoraproject.org/wiki/Fedora_12_Mass_Rebuild
+* Mon Mar 23 2009 Lubomir Rintel <lkundrak at v3.sk> - 6.3.0-12
+- Fix build with GCC 4.4
+* Tue Feb 24 2009 Fedora Release Engineering <rel-eng at lists.fedoraproject.org> - 6.3.0-11
+- Rebuilt for https://fedoraproject.org/wiki/Fedora_11_Mass_Rebuild
+* Thu Jan 29 2009 Balint Cristian <cristian.balint at gmail.com> - 6.3.0-10
+- email change
+- rebuild for new mysql
+* Sun Dec 07 2008 Balint Cristian <rezso at rdsor.ro> 6.3.0-9
+- rebuild against newer gdal
+* Sun Dec 07 2008 Balint Cristian <rezso at rdsor.ro> 6.3.0-8
+* Sun Nov 30 2008 Ignacio Vazquez-Abrams <ivazqueznet+rpm at gmail.com> 6.3.0-7
+- Rebuild for Python 2.6
+* Sun Aug 24 2008 Balint Cristian <rezso at rdsor.ro> 6.3.0-6
+- bz#458427 (prelink fail)
+- bz#458563 (grass not able to display documentation)
+* Sat Jul 05 2008 Balint Cristian <rezso at rdsor.ro> 6.3.0-5
+- address bz#454146 (wxPython miss)
+* Thu Jun 12 2008 Balint Cristian <rezso at rdsor.ro> 6.3.0-4
+- address bz#341391 (multilib issue)
+* Mon May 26 2008 Balint Cristian <rezso at rdsor.ro> 6.3.0-3
+- bugfix initscripts permission
+* Thu May 15 2008 Balint Cristian <rezso at rdsor.ro> 6.3.0-2
+- require swig to build
+* Thu May 15 2008 Balint Cristian <rezso at rdsor.ro> 6.3.0-1
+- final stable release upstream
