[GRASS-SVN] r72087 - grass/trunk/rpm
svn_grass at osgeo.org
Tue Jan 16 05:57:48 PST 2018
Author: mmetz
Date: 2018-01-16 05:57:48 -0800 (Tue, 16 Jan 2018)
New Revision: 72087
grass/trunk/rpm/grass.spec
grass/trunk/rpm/grass_unversioned.spec
rpm spec files: more tests, fix grass.pc
Modified: grass/trunk/rpm/grass.spec
--- grass/trunk/rpm/grass.spec 2018-01-15 22:19:38 UTC (rev 72086)
+++ grass/trunk/rpm/grass.spec 2018-01-16 13:57:48 UTC (rev 72087)
@@ -70,6 +70,8 @@
BuildRequires: unixODBC-devel
BuildRequires: wxGTK-devel
BuildRequires: zlib-devel
+BuildRequires: libzstd-devel
+Requires: libzstd
Requires: geos
Requires: numpy
@@ -158,7 +160,11 @@
--with-netcdf=%{_bindir}/nc-config \
%endif
--with-mysql-includes=%{_includedir}/mysql \
+%if (0%{?fedora} > 28)
--with-mysql-libs=%{_libdir} \
+%else
+ --with-mysql-libs=%{_libdir}/mysql \
+%endif
%if (0%{?rhel} > 6 || 0%{?fedora})
--with-postgres-includes=%{_includedir}/pgsql \
%else
@@ -186,14 +192,15 @@
prefix=%{buildroot}%{_libdir} \
UNIX_BIN=%{buildroot}%{_bindir}
+# libraries and headers are in GISBASE = %%{_libdir}/%%{name}
+# keep them in GISBASE
+# fix paths:
# Change GISBASE in startup script
sed -i -e 's|%{buildroot}%{_libdir}/%{name}-%{version}|%{_libdir}/%{name}-%{version}|g' \
%{buildroot}%{_bindir}/%{name}%{shortver}
-# libraries and headers are in GISBASE = %%{_libdir}/%%{name}-%%{version}
-# keep them in GISBASE
-# fix GRASS_HOME in Platform.make
+# fix GRASS_HOME and RUN_GISBASE in Platform.make
%{buildroot}%{_libdir}/%{name}-%{version}/include/Make/Platform.make
# fix ARCH_DISTDIR in Grass.make
@@ -205,8 +212,13 @@
# fix GISDBASE in demolocation
%{buildroot}%{_libdir}/%{name}-%{version}/demolocation/.grassrc%{shortver}
+# Correct font path
+sed -i -e 's|%{buildroot}%{_libdir}/%{name}-%{version}|%{_libdir}/%{name}-%{version}|' \
+ %{buildroot}%{_libdir}/%{name}-%{version}/etc/fontcap
+# fix paths in grass.pc
+sed -i -e 's|%{_prefix}/%{name}-%{version}|%{_libdir}/%{name-%{version}}|g' \
+ %{name}.pc
-# TODO: fix paths in grass.pc
mkdir -p %{buildroot}%{_libdir}/pkgconfig
install -p -m 644 %{name}.pc %{buildroot}%{_libdir}/pkgconfig
@@ -222,6 +234,11 @@
iconv -f iso8859-1 -t utf8 $man > %{buildroot}%{_mandir}/man1/$(basename $man)"%{name}"
done
+# symlink docs from GISBASE to standard system location
+mkdir -p %{buildroot}%{_docdir}
+# append shortver to destination ? man pages are unversioned
+ln -s %{_libdir}/%{name}-%{version}/docs %{buildroot}%{_docdir}/%{name}%{shortver}
for file in infrastructure.txt ; do
iconv -f ISO-8859-1 -t UTF-8 $file > ${file}.tmp && mv -f ${file}.tmp $file
done
@@ -231,14 +248,7 @@
desktop-file-validate %{buildroot}/%{_datadir}/applications/*.desktop
# EPEL7 fails on url tag, so we ignore failure:
appstream-util validate-relax --nonet %{buildroot}/%{_datadir}/appdata/*.appdata.xml || echo "Ignoring appstream-util failure"
-# Correct font path
-sed -i -e 's|%{buildroot}%{_libdir}/%{name}-%{version}|%{_libdir}/%{name}-%{version}|' \
- %{buildroot}%{_libdir}/%{name}-%{version}/etc/fontcap
-# symlink docs from GISBASE to standard system location
-mkdir -p %{buildroot}%{_docdir}
-ln -s %{_libdir}/%{name}-%{version}/docs %{buildroot}%{_docdir}/%{name}%{shortver}
# Cleanup: nothing to do
#rm -rf %%{buildroot}%%{_prefix}/%%{name}-%%{version}
Modified: grass/trunk/rpm/grass_unversioned.spec
--- grass/trunk/rpm/grass_unversioned.spec 2018-01-15 22:19:38 UTC (rev 72086)
+++ grass/trunk/rpm/grass_unversioned.spec 2018-01-16 13:57:48 UTC (rev 72087)
@@ -1,8 +1,8 @@
-%global shortver 74
+%global shortver 75
%global macrosdir %(d=%{_rpmconfigdir}/macros.d; [ -d $d ] || d=%{_sysconfdir}/rpm; echo $d)
-Version: 7.4.0
+Version: 7.5.0
Release: 1%{?dist}
Summary: GRASS GIS - Geographic Resources Analysis Support System
@@ -70,6 +70,8 @@
+Requires: libzstd
Requires: geos
Requires: numpy
%endif
+%else
+%endif
%else
@@ -236,6 +242,10 @@
done
+ln -s %{_libdir}/%{name}/docs %{buildroot}%{_docdir}/%{name}
done
@@ -246,10 +256,6 @@
-ln -s %{_libdir}/%{name}/docs %{buildroot}%{_docdir}/%{name}
#rm -rf %%{buildroot}%%{_libdir}/%%{name}
