[GRASS-SVN] r72096 - in grass/trunk/raster/r.to.vect: . testsuite
svn_grass at osgeo.org
Thu Jan 18 08:22:14 PST 2018
Author: lucadelu
Date: 2018-01-18 08:22:14 -0800 (Thu, 18 Jan 2018)
New Revision: 72096
Added:
grass/trunk/raster/r.to.vect/testsuite/
grass/trunk/raster/r.to.vect/testsuite/test_r_to_vect.py
r.to.vect: added tests, thanks to Sunveer Singh during Google Code-in 2017
Added: grass/trunk/raster/r.to.vect/testsuite/test_r_to_vect.py
--- grass/trunk/raster/r.to.vect/testsuite/test_r_to_vect.py (rev 0)
+++ grass/trunk/raster/r.to.vect/testsuite/test_r_to_vect.py 2018-01-18 16:22:14 UTC (rev 72096)
@@ -0,0 +1,59 @@
+Name: r.to.vect test
+Purpose: Tests r.to.vect and its flags/options.
+Author: Sunveer Singh, Google Code-in 2017
+Copyright: (C) 2017 by Sunveer Singh and the GRASS Development Team
+Licence: This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+from grass.gunittest.gmodules import SimpleModule
+class Testrr(TestCase):
+ input='lakes'
+ output='testrtovect'
+ point='point'
+ area="area"
+ @classmethod
+ def setUpClass(cls):
+ cls.use_temp_region()
+ cls.runModule('g.region', raster=cls.input)
+ @classmethod
+ def tearDownClass(cls):
+ cls.del_temp_region()
+ def tearDown(cls):
+ cls.runModule('g.remove', type='vector', flags='f', name=cls.output)
+ def test_flags(self):
+ """Testing flag s"""
+ self.assertModule('r.to.vect', input=self.input, output=self.output, type=self.point, flags='s')
+ topology = dict(points=36011, lines=0, areas=0)
+ self.assertVectorFitsTopoInfo(self.output, topology)
+ def test_flagz(self):
+ """Testing flag z"""
+ self.assertModule('r.to.vect', input=self.input, output=self.output, type=self.point, flags='z')
+ def test_flagb(self):
+ """Testing flag b"""
+ self.assertModule('r.to.vect', input=self.input, output=self.output, type=self.area, flags='b')
+ topology = dict(points=0, lines=0, areas=0)
+ def test_flagt(self):
+ """Testing flag t"""
+ self.assertModule('r.to.vect', input=self.input, output=self.output, type=self.area, flags='t')
+ topology = dict(points=0, lines=0, areas=33)
+if __name__ == '__main__':
+ from grass.gunittest.main import test
+ test()
Property changes on: grass/trunk/raster/r.to.vect/testsuite/test_r_to_vect.py
___________________________________________________________________
Added: svn:mime-type
+ text/x-python
Added: svn:eol-style
+ native
