[GRASS-SVN] r72097 - in grass/trunk/vector/v.vect.stats: . testsuite
svn_grass at osgeo.org
Thu Jan 18 08:23:18 PST 2018
Author: lucadelu
Date: 2018-01-18 08:23:18 -0800 (Thu, 18 Jan 2018)
New Revision: 72097
Added:
grass/trunk/vector/v.vect.stats/testsuite/
grass/trunk/vector/v.vect.stats/testsuite/test_vect_stats.py
v.vect.stats: added tests, thanks to Sunveer Singh during Google Code-in 2017
Added: grass/trunk/vector/v.vect.stats/testsuite/test_vect_stats.py
--- grass/trunk/vector/v.vect.stats/testsuite/test_vect_stats.py (rev 0)
+++ grass/trunk/vector/v.vect.stats/testsuite/test_vect_stats.py 2018-01-18 16:23:18 UTC (rev 72097)
@@ -0,0 +1,143 @@
+Name: v.vect.stats test
+Purpose: Tests v.vect.stats and its flags/options.
+Author: Sunveer Singh, Google Code-in 2017
+Copyright: (C) 2017 by Sunveer Singh and the GRASS Development Team
+Licence: This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+from grass.gunittest.gmodules import SimpleModule
+class Testrr(TestCase):
+ input='hospitals'
+ areas='zipcodes_wake'
+ @classmethod
+ def setUpClass(cls):
+ cls.use_temp_region()
+ @classmethod
+ def tearDownClass(cls):
+ cls.del_temp_region()
+ def test_sum(self):
+ """Testing method sum"""
+ string="""area_cat|count|sum
+ 1|0|null
+ 2|0|null
+ 3|0|null
+ 4|0|null
+ 5|0|null
+ 6|0|null
+ 7|0|null
+ 8|0|null
+ 9|1|7
+ 10|0|null
+ v_vect_stats = SimpleModule('v.vect.stats', points=self.input, areas=self.areas, method='sum', count_column='num_points',
+ stats_column='avg_elev', points_column='cat')
+ v_vect_stats.outputs.stdout= string
+ self.assertLooksLike(reference=string, actual=v_vect_stats.outputs.stdout)
+ def test_average(self):
+ """Testing method average"""
+ string="""area_cat|count|average
+ 1|1|2681
+ 2|0|null
+ 3|2|3958.5
+ 4|0|null
+ 5|0|null
+ 6|8|4012
+ 7|7|4185.42857142857
+ 8|19|4396.78947368421
+ 9|4|4222
+ 10|3|4400.33333333333
+ v_vect_stats = SimpleModule('v.vect.stats', points=self.input, areas=self.areas, method='average', count_column='num_points',
+ def test_median(self):
+ """Testing method variance"""
+ string="""area_cat|count|variance
+ 1|1|0
+ 2|0|null
+ 3|2|702.25
+ 4|0|null
+ 5|0|null
+ 6|8|7639
+ 7|7|2661.38775510204
+ 8|19|69198.7977839335
+ 9|4|42.5
+ 10|3|3968.22222222222
+ v_vect_stats = SimpleModule('v.vect.stats', points=self.input, areas=self.areas, method='variance', count_column='num_points',
+ def test_mincat(self):
+ """Testing method min_cat"""
+ string="""area_cat|count|range
+ 1|1|0
+ 2|0|null
+ 3|2|53
+ 4|0|null
+ 5|0|null
+ 6|8|255
+ 7|7|168
+ 8|19|892
+ 9|4|17
+ 10|3|152
+ v_vect_stats = SimpleModule('v.vect.stats', points=self.input, areas=self.areas, method='range', count_column='num_points',
+ def test_maxcat(self):
+ """Testing method max_cat"""
+ string="""area_cat|count|max_cat
+ 1|0|null
+ 2|0|null
+ 3|0|null
+ 4|0|null
+ 5|0|null
+ 6|0|null
+ 7|0|null
+ 8|0|null
+ 9|1|7
+ 10|0|null
+ v_vect_stats = SimpleModule('v.vect.stats', points=self.input, areas=self.areas, method='max_cat', count_column='num_points',
+ def test_mode(self):
+ """Testing method mode """
+ string="""area_cat|count|mode
+ 1|0|null
+ 2|0|null
+ 3|0|null
+ 4|0|null
+ 5|0|null
+ 6|0|null
+ 7|0|null
+ 8|0|null
+ 9|1|7
+ 10|0|null
+ v_vect_stats = SimpleModule('v.vect.stats', points=self.input, areas=self.areas, method='mode', count_column='num_points',
+if __name__ == '__main__':
+ test()
Property changes on: grass/trunk/vector/v.vect.stats/testsuite/test_vect_stats.py
___________________________________________________________________
Added: svn:mime-type
+ text/x-python
Added: svn:eol-style
+ native
