[GRASS-SVN] r72112 - in grass/trunk: include/defs lib/gis
svn_grass at osgeo.org
Mon Jan 22 06:56:43 PST 2018
Author: mmetz
Date: 2018-01-22 06:56:43 -0800 (Mon, 22 Jan 2018)
New Revision: 72112
grass/trunk/include/defs/gis.h
grass/trunk/lib/gis/make_loc.c
libgis: +G_make_location_epsg()
Modified: grass/trunk/include/defs/gis.h
--- grass/trunk/include/defs/gis.h 2018-01-22 14:28:00 UTC (rev 72111)
+++ grass/trunk/include/defs/gis.h 2018-01-22 14:56:43 UTC (rev 72112)
@@ -504,6 +504,8 @@
/* make_loc.c */
int G_make_location(const char *, struct Cell_head *, const struct Key_Value *,
const struct Key_Value *);
+int G_make_location_epsg(const char *, struct Cell_head *, const struct Key_Value *,
+ const struct Key_Value *, const struct Key_Value *);
int G_compare_projections(const struct Key_Value *, const struct Key_Value *,
Modified: grass/trunk/lib/gis/make_loc.c
--- grass/trunk/lib/gis/make_loc.c 2018-01-22 14:28:00 UTC (rev 72111)
+++ grass/trunk/lib/gis/make_loc.c 2018-01-22 14:56:43 UTC (rev 72112)
@@ -93,6 +93,59 @@
+ * \brief Create a new location
+ * This function creates a new location in the current database,
+ * initializes the projection, default window and current window,
+ * and sets the EPSG code if present
+ * \param location_name Name of the new location. Should not include
+ * the full path, the location will be created within
+ * the current database.
+ * \param wind default window setting for the new location.
+ * All fields should be set in this
+ * structure, and care should be taken to ensure that
+ * the proj/zone fields match the definition in the
+ * proj_info parameter(see G_set_cellhd_from_projinfo()).
+ * \param proj_info projection definition suitable to write to the
+ * PROJ_INFO file, or NULL for PROJECTION_XY.
+ * \param proj_units projection units suitable to write to the PROJ_UNITS
+ * file, or NULL.
+ * \param proj_epsg EPSG code suitable to write to the PROJ_EPSG
+ * file, or NULL.
+ * \return 0 on success
+ * \return -1 to indicate a system error (check errno).
+ * \return -2 failed to create projection file (currently not used)
+ * \return -3 illegal name
+int G_make_location_epsg(const char *location_name,
+ struct Cell_head *wind,
+ const struct Key_Value *proj_info,
+ const struct Key_Value *proj_units,
+ const struct Key_Value *proj_epsg)
+ int ret;
+ char path[GPATH_MAX];
+ ret = G_make_location(location_name, wind, proj_info, proj_units);
+ if (ret != 0)
+ return ret;
+ /* Write out the PROJ_EPSG if available. */
+ if (proj_epsg != NULL) {
+ G_file_name(path, "", "PROJ_EPSG", "PERMANENT");
+ G_write_key_value_file(path, proj_epsg);
+ return 0;
* \brief Compare projections including units
* \param proj_info1 projection info to compare
