[GRASS-SVN] r72113 - grass/trunk/general/g.proj
svn_grass at osgeo.org
Mon Jan 22 12:28:29 PST 2018
Author: mmetz
Date: 2018-01-22 12:28:29 -0800 (Mon, 22 Jan 2018)
New Revision: 72113
grass/trunk/general/g.proj/create.c
grass/trunk/general/g.proj/input.c
grass/trunk/general/g.proj/local_proto.h
grass/trunk/general/g.proj/main.c
grass/trunk/general/g.proj/output.c
g.proj: consider EPSG code whenever possible
Modified: grass/trunk/general/g.proj/create.c
--- grass/trunk/general/g.proj/create.c 2018-01-22 14:56:43 UTC (rev 72112)
+++ grass/trunk/general/g.proj/create.c 2018-01-22 20:28:29 UTC (rev 72113)
@@ -6,11 +6,12 @@
#include "local_proto.h"
-void create_location(const char *location, const char *epsg)
+void create_location(const char *location)
int ret;
- ret = G_make_location(location, &cellhd, projinfo, projunits);
+ ret = G_make_location_epsg(location, &cellhd, projinfo, projunits,
+ projepsg);
if (ret == 0)
G_message(_("Location <%s> created"), location);
else if (ret == -1)
@@ -23,10 +24,6 @@
/* Shouldn't happen */
G_fatal_error(_("Unable to create location <%s>"), location);
- /* create also PROJ_EPSG */
- if (epsg)
- create_epsg(location, epsg);
G_message(_("You can switch to the new location by\n`%s=%s`"),
"g.mapset mapset=PERMANENT location", location);
@@ -46,7 +43,7 @@
char path[GPATH_MAX];
- /* Write out the PROJ_INFO, and PROJ_UNITS if available. */
+ /* Write out the PROJ_INFO, PROJ_UNITS, and PROJ_EPSG if available. */
if (projinfo != NULL) {
G_file_name(path, "", "PROJ_INFO", "PERMANENT");
G_write_key_value_file(path, projinfo);
@@ -57,6 +54,11 @@
G_write_key_value_file(path, projunits);
+ if (projepsg != NULL) {
+ G_file_name(path, "", "PROJ_EPSG", "PERMANENT");
+ G_write_key_value_file(path, projepsg);
if ((old_cellhd.zone != cellhd.zone) ||
(old_cellhd.proj != cellhd.proj)) {
/* Recreate the default, and current window files if projection
@@ -69,29 +71,3 @@
G_important_message(_("Projection information updated"));
-void create_epsg(const char *location, const char *epsg)
- FILE *fp;
- char path[GPATH_MAX];
- /* if inputs were not clean it should of failed by now */
- if (location) {
- G_snprintf(path, sizeof(path), "%s%c%s%c%s%c%s", G_gisdbase(), HOST_DIRSEP,
- location, HOST_DIRSEP,
- "PERMANENT", HOST_DIRSEP, "PROJ_EPSG");
- path[sizeof(path)-1] = '\0';
- else {
- G_file_name(path, "", "PROJ_EPSG", "PERMANENT");
- fp = fopen(path, "w");
- if (!fp)
- G_fatal_error(_("Unable to create PROJ_EPSG file: %s"), strerror (errno));
-#ifdef HAVE_OGR
- fprintf(fp, "epsg: %s\n", epsg);
-#endif
- fclose(fp);
Modified: grass/trunk/general/g.proj/input.c
--- grass/trunk/general/g.proj/input.c 2018-01-22 14:56:43 UTC (rev 72112)
+++ grass/trunk/general/g.proj/input.c 2018-01-22 20:28:29 UTC (rev 72113)
@@ -78,6 +78,7 @@
FILE *infd;
char buff[8000];
+ OGRSpatialReferenceH hSRS;
int ret;
if (strcmp(wktfile, "-") == 0)
@@ -100,6 +101,28 @@
ret = GPJ_wkt_to_grass(&cellhd, &projinfo, &projunits, buff, 0);
set_default_region();
+ hSRS = OSRNewSpatialReference(buff);
+ if (hSRS) {
+ const char *authkey, *authname, *authcode;
+ authkey = NULL;
+ if (OSRIsProjected(hSRS))
+ authkey = "PROJCS";
+ else if (OSRIsGeographic(hSRS))
+ authkey = "GEOGCS";
+ if (authkey) {
+ authname = OSRGetAuthorityName(hSRS, authkey);
+ if (authname && *authname && strcmp(authname, "EPSG") == 0) {
+ authcode = OSRGetAuthorityCode(hSRS, authkey);
+ if (authcode && *authcode) {
+ projepsg = G_create_key_value();
+ G_set_key_value("epsg", authcode, projepsg);
return ret;
@@ -171,6 +194,7 @@
int input_epsg(int epsg_num)
+ char epsgstr[100];
int ret = 0;
/* Set finder function for locating OGR csv co-ordinate system tables */
@@ -182,6 +206,10 @@
ret = GPJ_osr_to_grass(&cellhd, &projinfo, &projunits, hSRS, 0);
+ sprintf(epsgstr, "%d", epsg_num);
+ G_set_key_value("epsg", epsgstr, projepsg);
OSRDestroySpatialReference(hSRS);
@@ -211,6 +239,7 @@
int input_georef(char *geofile)
OGRDataSourceH ogr_ds;
int ret = 0;
/* Try opening file with OGR first because it doesn't output a
@@ -218,16 +247,16 @@
G_message(_("Trying to open with OGR..."));
OGRRegisterAll();
+ hSRS = NULL;
if ((ogr_ds = OGROpen(geofile, FALSE, NULL))
&& (OGR_DS_GetLayerCount(ogr_ds) > 0)) {
OGRLayerH ogr_layer;
- OGRSpatialReferenceH ogr_srs;
G_message(_("...succeeded."));
/* Get the first layer */
ogr_layer = OGR_DS_GetLayer(ogr_ds, 0);
- ogr_srs = OGR_L_GetSpatialRef(ogr_layer);
- ret = GPJ_osr_to_grass(&cellhd, &projinfo, &projunits, ogr_srs, 0);
+ hSRS = OGR_L_GetSpatialRef(ogr_layer);
+ ret = GPJ_osr_to_grass(&cellhd, &projinfo, &projunits, hSRS, 0);
OGR_DS_Destroy(ogr_ds);
@@ -249,6 +278,7 @@
0);
set_gdal_region(gdal_ds);
+ hSRS = OSRNewSpatialReference(wktstring);
else
G_fatal_error(_("Could not read georeferenced file %s using "
@@ -260,6 +290,27 @@
"projection information. 'XY (unprojected)' will be used"),
geofile);
+ if (hSRS) {
+ authkey = NULL;
+ if (authkey) {
return ret;
Modified: grass/trunk/general/g.proj/local_proto.h
--- grass/trunk/general/g.proj/local_proto.h 2018-01-22 14:56:43 UTC (rev 72112)
+++ grass/trunk/general/g.proj/local_proto.h 2018-01-22 20:28:29 UTC (rev 72113)
@@ -13,7 +13,7 @@
#endif
/* output.c */
-void print_projinfo(int, const char *);
+void print_projinfo(int);
void print_datuminfo(void);
void print_proj4(int);
#ifdef HAVE_OGR
@@ -25,6 +25,5 @@
int set_datumtrans(int, int);
/* create.c */
-void create_location(const char *, const char *);
+void create_location(const char *);
void modify_projinfo();
-void create_epsg(const char *, const char *);
Modified: grass/trunk/general/g.proj/main.c
--- grass/trunk/general/g.proj/main.c 2018-01-22 14:56:43 UTC (rev 72112)
+++ grass/trunk/general/g.proj/main.c 2018-01-22 20:28:29 UTC (rev 72113)
@@ -233,6 +233,7 @@
epsg = inepsg->answer;
+ projinfo = projunits = projepsg = NULL;
/* Input */
/* We can only have one input source, hence if..else construct */
@@ -292,7 +293,7 @@
create->key);
if (printinfo->answer || shellinfo->answer)
- print_projinfo(shellinfo->answer, epsg);
+ print_projinfo(shellinfo->answer);
else if (datuminfo->answer)
print_datuminfo();
else if (printproj4->answer)
@@ -302,7 +303,7 @@
print_wkt(esristyle->answer, dontprettify->answer);
#endif
else if (location->answer)
- create_location(location->answer, epsg);
+ create_location(location->answer);
else if (create->answer)
modify_projinfo();
else
@@ -316,21 +317,13 @@
printinfo->key, shellinfo->key, printproj4->key);
#endif
-#ifdef HAVE_OGR
- if (create->answer && epsg) {
-#else
- if (create->answer){
-#endif
- /* preserve epsg code for user records only (not used by grass's pj routines) */
- create_epsg(location->answer, epsg);
/* Tidy Up */
G_free_key_value(projinfo);
if (projunits != NULL)
G_free_key_value(projunits);
+ G_free_key_value(projepsg);
exit(EXIT_SUCCESS);
Modified: grass/trunk/general/g.proj/output.c
--- grass/trunk/general/g.proj/output.c 2018-01-22 14:56:43 UTC (rev 72112)
+++ grass/trunk/general/g.proj/output.c 2018-01-22 20:28:29 UTC (rev 72113)
@@ -28,10 +28,10 @@
static int check_xy(int shell);
-void print_projinfo(int shell, const char *force_epsg)
+/* print projection information gathered from one of the possible inputs */
+void print_projinfo(int shell)
int i;
if (check_xy(shell))
return;
@@ -46,22 +46,12 @@
fprintf(stdout, "%-11s: %s\n", projinfo->key[i], projinfo->value[i]);
- /* EPSG code is preserved for historical metadata interest only:
- the contents of this file are not used by pj_*() routines at all */
- if (access(path, F_OK) == 0) {
+ if (projepsg) {
const char *epsg_value, *epsg_key;
- struct Key_Value *in_epsg_key;
- if (force_epsg) {
- epsg_key = "epsg";
- epsg_value = force_epsg;
- else {
- in_epsg_key = G_read_key_value_file(path);
- epsg_key = in_epsg_key->key[0];
- epsg_value = in_epsg_key->value[0];
+ epsg_key = projepsg->key[0];
+ epsg_value = projepsg->value[0];
if (!shell) {
fprintf(stdout,
"-PROJ_EPSG-------------------------------------------------\n");
@@ -69,21 +59,20 @@
else
fprintf(stdout, "%s=%s\n", epsg_key, epsg_value);
- if (!force_epsg)
- G_free_key_value(in_epsg_key);
- if (!shell)
- fprintf(stdout,
- "-PROJ_UNITS------------------------------------------------\n");
- for (i = 0; i < projunits->nitems; i++) {
- if (shell)
- fprintf(stdout, "%s=%s\n",
- projunits->key[i], projunits->value[i]);
- else
- fprintf(stdout, "%-11s: %s\n",
+ if (projunits) {
+ if (!shell)
+ fprintf(stdout,
+ "-PROJ_UNITS------------------------------------------------\n");
+ for (i = 0; i < projunits->nitems; i++) {
+ if (shell)
+ fprintf(stdout, "%s=%s\n",
+ projunits->key[i], projunits->value[i]);
+ else
+ fprintf(stdout, "%-11s: %s\n",
return;
