[GRASS-SVN] r72114 - in grass/trunk: raster/r.external raster/r.in.gdal vector/v.external vector/v.in.ogr
svn_grass at osgeo.org
Mon Jan 22 12:33:02 PST 2018
Author: mmetz
Date: 2018-01-22 12:33:02 -0800 (Mon, 22 Jan 2018)
New Revision: 72114
grass/trunk/raster/r.external/proj.c
grass/trunk/raster/r.in.gdal/proj.c
grass/trunk/vector/v.external/proj.c
grass/trunk/vector/v.in.ogr/main.c
grass/trunk/vector/v.in.ogr/proj.c
retrieve and use EPSG code from GDAL/OGR input whenever possible
Modified: grass/trunk/raster/r.external/proj.c
--- grass/trunk/raster/r.external/proj.c 2018-01-22 20:28:29 UTC (rev 72113)
+++ grass/trunk/raster/r.external/proj.c 2018-01-22 20:33:02 UTC (rev 72114)
@@ -11,8 +11,8 @@
int check_only)
struct Cell_head loc_wind;
- struct Key_Value *proj_info = NULL, *proj_units = NULL;
- struct Key_Value *loc_proj_info = NULL, *loc_proj_units = NULL;
+ struct Key_Value *proj_info, *proj_units, *proj_epsg;
+ struct Key_Value *loc_proj_info, *loc_proj_units;
const char *wkt;
char error_msg[8096];
int proj_trouble;
@@ -22,6 +22,10 @@
proj_info = NULL;
proj_units = NULL;
+ proj_epsg = NULL;
+ loc_proj_info = NULL;
+ loc_proj_units = NULL;
wkt = GDALGetProjectionRef(hDS);
/* proj_trouble:
* 0: valid srs
@@ -43,6 +47,24 @@
proj_trouble = 2;
+ else{
+ const char *authkey, *authname, *authcode;
+ if (OSRIsProjected(hSRS))
+ authkey = "PROJCS";
+ else /* is geographic */
+ authkey = "GEOGCS";
+ authname = OSRGetAuthorityName(hSRS, authkey);
+ if (authname && *authname && strcmp(authname, "EPSG") == 0) {
+ authcode = OSRGetAuthorityCode(hSRS, authkey);
+ if (authcode && *authcode) {
+ G_debug(0, "found EPSG:%s", authcode);
+ proj_epsg = G_create_key_value();
+ G_set_key_value("epsg", authcode, proj_epsg);
if (hSRS)
OSRDestroySpatialReference(hSRS);
@@ -63,8 +85,8 @@
"format; cannot create new location."));
else {
- if (0 != G_make_location(outloc, cellhd,
- proj_info, proj_units)) {
+ if (0 != G_make_location_epsg(outloc, cellhd, proj_info,
+ proj_units, proj_epsg)) {
G_fatal_error(_("Unable to create new location <%s>"),
outloc);
Modified: grass/trunk/raster/r.in.gdal/proj.c
--- grass/trunk/raster/r.in.gdal/proj.c 2018-01-22 20:28:29 UTC (rev 72113)
+++ grass/trunk/raster/r.in.gdal/proj.c 2018-01-22 20:33:02 UTC (rev 72114)
@@ -11,8 +11,8 @@
int check_only)
const char *wkt;
int proj_trouble;
@@ -22,6 +22,10 @@
proj_info = NULL;
proj_units = NULL;
+ proj_epsg = NULL;
/* proj_trouble:
* 0: valid srs
@@ -43,6 +47,24 @@
proj_trouble = 2;
+ else{
if (hSRS)
@@ -63,8 +85,8 @@
else {
outloc);
Modified: grass/trunk/vector/v.external/proj.c
--- grass/trunk/vector/v.external/proj.c 2018-01-22 20:28:29 UTC (rev 72113)
+++ grass/trunk/vector/v.external/proj.c 2018-01-22 20:33:02 UTC (rev 72114)
@@ -10,15 +10,18 @@
* return 1 if no SRS available
* return 2 if SRS available but unreadable */
int get_layer_proj(OGRLayerH Ogr_layer, struct Cell_head *cellhd,
- struct Key_Value **proj_info, struct Key_Value **proj_units,
+ struct Key_Value **proj_info,
+ struct Key_Value **proj_units,
+ struct Key_Value **proj_epsg,
char *geom_col, int verbose)
- OGRSpatialReferenceH Ogr_projection;
+ OGRSpatialReferenceH hSRS;
char *pszProj4 = NULL;
- Ogr_projection = NULL;
+ hSRS = NULL;
*proj_info = NULL;
*proj_units = NULL;
+ *proj_epsg = NULL;
/* Fetch input layer projection in GRASS form. */
#if GDAL_VERSION_NUM >= 1110000
@@ -33,27 +36,27 @@
G_fatal_error(_("Geometry column <%s> not found in input layer <%s>"),
geom_col, OGR_L_GetName(Ogr_layer));
Ogr_geomdefn = OGR_FD_GetGeomFieldDefn(Ogr_featuredefn, igeom);
- Ogr_projection = OGR_GFld_GetSpatialRef(Ogr_geomdefn);
+ hSRS = OGR_GFld_GetSpatialRef(Ogr_geomdefn);
else {
- Ogr_projection = OGR_L_GetSpatialRef(Ogr_layer);
+ hSRS = OGR_L_GetSpatialRef(Ogr_layer);
#else
- Ogr_projection = OGR_L_GetSpatialRef(Ogr_layer); /* should not be freed later */
+ hSRS = OGR_L_GetSpatialRef(Ogr_layer); /* should not be freed later */
#endif
/* verbose is used only when comparing input SRS to GRASS projection,
* not when comparing SRS's of several input layers */
if (GPJ_osr_to_grass(cellhd, proj_info,
- proj_units, Ogr_projection, 0) < 0) {
+ proj_units, hSRS, 0) < 0) {
/* TODO: GPJ_osr_to_grass() does not return anything < 0
* check with GRASS 6 and GRASS 5 */
G_warning(_("Unable to convert input layer projection information to "
"GRASS format for checking"));
- if (verbose && Ogr_projection != NULL) {
+ if (verbose && hSRS != NULL) {
char *wkt = NULL;
- if (OSRExportToPrettyWkt(Ogr_projection, &wkt, FALSE) != OGRERR_NONE) {
+ if (OSRExportToPrettyWkt(hSRS, &wkt, FALSE) != OGRERR_NONE) {
G_warning(_("Can't get WKT parameter string"));
else if (wkt) {
@@ -65,23 +68,23 @@
/* custom checks because if in doubt GPJ_osr_to_grass() returns a
* xy CRS */
- if (Ogr_projection == NULL) {
+ if (hSRS == NULL) {
if (verbose) {
- G_important_message(_("No OGR projection available for layer <%s>"),
+ G_important_message(_("No projection information available for layer <%s>"),
return 1;
- if (!OSRIsProjected(Ogr_projection) && !OSRIsGeographic(Ogr_projection)) {
- G_important_message(_("OGR projection for layer <%s> does not contain a valid SRS"),
+ if (!OSRIsProjected(hSRS) && !OSRIsGeographic(hSRS)) {
+ G_important_message(_("Projection for layer <%s> does not contain a valid SRS"),
if (verbose) {
char *wkt = NULL;
G_important_message(_("Can't get WKT parameter string"));
else if (wkt) {
@@ -91,15 +94,32 @@
return 2;
+ else{
- if (OSRExportToProj4(Ogr_projection, &pszProj4) != OGRERR_NONE) {
- G_important_message(_("OGR projection for layer <%s> can not be converted to proj4"),
+ *proj_epsg = G_create_key_value();
+ G_set_key_value("epsg", authcode, *proj_epsg);
+ if (OSRExportToProj4(hSRS, &pszProj4) != OGRERR_NONE) {
+ G_important_message(_("Projection for layer <%s> can not be converted to proj4"),
if (verbose) {
char *wkt = NULL;
G_important_message(_("Can't get WKT-style parameter string"));
else if (wkt) {
@@ -119,8 +139,8 @@
int check_only)
int proj_trouble;
OGRLayerH Ogr_layer;
@@ -133,6 +153,9 @@
proj_info = NULL;
proj_units = NULL;
+ proj_epsg = NULL;
/* proj_trouble:
* 0: valid srs
@@ -142,7 +165,7 @@
/* Projection only required for checking so convert non-interactively */
proj_trouble = get_layer_proj(Ogr_layer, cellhd, &proj_info, &proj_units,
- geom_col, 1);
+ &proj_epsg, geom_col, 1);
/* Do we need to create a new location? */
@@ -155,8 +178,8 @@
else {
outloc);
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c 2018-01-22 20:28:29 UTC (rev 72113)
+++ grass/trunk/vector/v.in.ogr/main.c 2018-01-22 20:33:02 UTC (rev 72114)
@@ -1531,13 +1531,6 @@
Vect_spatial_index_destroy(&si);
- if (n_overlaps > 0) {
- G_warning(_("%d areas represent more (overlapping) features, because polygons overlap "
- "in input layer(s). Such areas are linked to more than 1 row in attribute table. "
- "The number of features for those areas is stored as category in layer %d"),
- n_overlaps, nlayers + 1);
G_message("%s", separator);
Vect_hist_write(&Map, separator);
@@ -1683,18 +1676,34 @@
G_important_message("%s", separator);
/* topological errors */
if (failed_centr || err_boundaries || err_centr_out || err_centr_dupl) {
- G_warning(_("The output contains topological errors:"));
- if (failed_centr)
- G_warning(_("Unable to calculate a centroid for %d areas"), failed_centr);
- if (err_boundaries)
- G_warning(_("Number of incorrect boundaries: %d"),
- err_boundaries);
- if (err_centr_out)
- G_warning(_("Number of centroids outside area: %d"),
- err_centr_out);
- if (err_centr_dupl)
- G_warning(_("Number of duplicate centroids: %d"),
- err_centr_dupl);
+ char error_msg[8096];
+ strcpy(error_msg, _("The output contains topological errors:"));
+ if (failed_centr) {
+ strcat(error_msg, "\n");
+ sprintf(error_msg + strlen(error_msg),
+ _("Unable to calculate a centroid for %d areas"),
+ failed_centr);
+ if (err_boundaries) {
+ _("Number of incorrect boundaries: %d"),
+ err_boundaries);
+ if (err_centr_out) {
+ _("Number of centroids outside area: %d"),
+ err_centr_out);
+ if (err_centr_dupl) {
+ _("Number of duplicate centroids: %d"),
+ err_centr_dupl);
+ G_warning(error_msg);
G_important_message(_("The input could be cleaned by snapping vertices to each other."));
@@ -1702,10 +1711,20 @@
G_important_message(_("Estimated range of snapping threshold: [%g, %g]"), min_snap, max_snap);
- if (snap < min_snap) {
+ if (snap < 0) {
+ double e1, e2;
+ /* human readable */
+ e1 = log10(min_snap);
+ e2 = log10(max_snap);
+ e1 = (int)((e1 + e2) / 2. - 0.5);
+ snap = pow(10, e1);
+ G_important_message(_("Try to import again, snapping with %g: 'snap=%g'"), snap, snap);
+ else if (snap < min_snap) {
G_important_message(_("Try to import again, snapping with at least %g: 'snap=%g'"), min_snap, min_snap);
- else if (snap < max_snap) {
+ else if (snap * 10 < max_snap) {
min_snap = snap * 10;
G_important_message(_("Try to import again, snapping with %g: 'snap=%g'"), min_snap, min_snap);
@@ -1715,26 +1734,30 @@
/* overlapping polygons */
else if (n_overlaps) {
- if (n_overlaps) {
- G_important_message(_("Some input polygons are overlapping each other."));
- G_important_message(_("If overlapping is not desired, the data need to be cleaned."));
- G_important_message(_("The input could be cleaned by snapping vertices to each other."));
+ G_important_message(_("%d areas represent multiple (overlapping) features, because polygons overlap "
+ "in input layer(s). Such areas are linked to more than 1 row in attribute table. "
+ "The number of features for those areas is stored as category in layer %d"),
+ n_overlaps, nlayers + 1);
+ G_important_message("%s", separator);
+ G_important_message(_("If overlapping is not desired, the input data can be "
+ "cleaned by snapping vertices to each other."));
- G_important_message(_("Try to import again, snapping with at least %g: 'snap=%g'"), min_snap, min_snap);
+ if (snap > 0) {
+ if (snap < min_snap) {
+ G_important_message(_("Try to import again, snapping with at least %g: 'snap=%g'"), min_snap, min_snap);
+ else if (snap * 10 <= max_snap) {
+ min_snap = snap * 10;
+ G_important_message(_("Try to import again, snapping with %g: 'snap=%g'"), min_snap, min_snap);
+ else
+ /* assume manual cleaning is required */
+ G_important_message(_("Manual cleaning may be needed."));
- min_snap = snap * 10;
- G_important_message(_("Try to import again, snapping with %g: 'snap=%g'"), min_snap, min_snap);
- else
- /* assume manual cleaning is required */
- G_important_message(_("Manual cleaning may be needed."));
/* number of centroids does not match number of input polygons */
else if (ncentr != n_polygons) {
Modified: grass/trunk/vector/v.in.ogr/proj.c
--- grass/trunk/vector/v.in.ogr/proj.c 2018-01-22 20:28:29 UTC (rev 72113)
+++ grass/trunk/vector/v.in.ogr/proj.c 2018-01-22 20:33:02 UTC (rev 72114)
@@ -10,15 +10,18 @@
+ hSRS = NULL;
*proj_info = NULL;
*proj_units = NULL;
@@ -33,27 +36,27 @@
else {
#else
#endif
char *wkt = NULL;
else if (wkt) {
@@ -65,23 +68,23 @@
* xy CRS */
if (verbose) {
return 1;
if (verbose) {
char *wkt = NULL;
else if (wkt) {
@@ -91,15 +94,32 @@
return 2;
+ else{
if (verbose) {
char *wkt = NULL;
else if (wkt) {
@@ -121,16 +141,16 @@
char **layer_names, char *geom_col)
int layer;
- struct Key_Value *proj_info1, *proj_units1;
- struct Key_Value *proj_info2, *proj_units2;
+ struct Key_Value *proj_info1, *proj_units1, *proj_epsg1;
+ struct Key_Value *proj_info2, *proj_units2, *proj_epsg2;
struct Cell_head cellhd1, cellhd2;
if (nlayers == 1)
return 0;
- proj_info1 = proj_units1 = NULL;
- proj_info2 = proj_units2 = NULL;
+ proj_info1 = proj_units1 = proj_epsg1 = NULL;
+ proj_info2 = proj_units2 = proj_epsg2 = NULL;
G_get_window(&cellhd1);
layer = 0;
@@ -139,7 +159,7 @@
Ogr_layer = ds_getlayerbyindex(Ogr_ds, layers[layer]);
if (get_layer_proj(Ogr_layer, &cellhd1, &proj_info1, &proj_units1,
- geom_col, 0) == 0) {
+ &proj_epsg1, geom_col, 0) == 0) {
break;
layer++;
@@ -153,6 +173,8 @@
G_free_key_value(proj_info1);
if (proj_units1)
G_free_key_value(proj_units1);
+ if (proj_epsg1)
+ G_free_key_value(proj_epsg1);
return 0;
@@ -165,6 +187,8 @@
if (proj_units1)
+ if (proj_epsg1)
return 1;
@@ -174,9 +198,13 @@
G_get_window(&cellhd2);
if (get_layer_proj(Ogr_layer, &cellhd2, &proj_info2, &proj_units2,
- geom_col, 0) != 0) {
- G_free_key_value(proj_info1);
- G_free_key_value(proj_units1);
+ &proj_epsg2, geom_col, 0) != 0) {
+ if (proj_info1)
+ G_free_key_value(proj_info1);
+ if (proj_units1)
+ G_free_key_value(proj_units1);
+ if (proj_epsg1)
return 1;
@@ -188,10 +216,14 @@
if (proj_units1)
+ if (proj_epsg1)
if (proj_info2)
G_free_key_value(proj_info2);
if (proj_units2)
G_free_key_value(proj_units2);
+ if (proj_epsg2)
+ G_free_key_value(proj_epsg2);
G_warning(_("Projection of layer <%s> is different from "
"projection of layer <%s>"),
@@ -203,11 +235,15 @@
if (proj_units2)
+ if (proj_epsg2)
if (proj_info1)
if (proj_units1)
+ if (proj_epsg1)
return 0;
@@ -218,8 +254,8 @@
int check_only)
int proj_trouble;
@@ -232,6 +268,9 @@
proj_info = NULL;
proj_units = NULL;
+ proj_epsg = NULL;
/* proj_trouble:
* 0: valid srs
@@ -241,7 +280,7 @@
- geom_col, 1);
@@ -254,8 +293,8 @@
else {
outloc);
