[GRASS-SVN] r72974 - grass/trunk/lib/ogsf
Tue Jul 10 18:15:40 PDT 2018
Author: hcho
Date: 2018-07-10 18:15:40 -0700 (Tue, 10 Jul 2018)
New Revision: 72974
   grass/trunk/lib/ogsf/gsd_prim.c
ogsf: Rename bool to shade
Modified: grass/trunk/lib/ogsf/gsd_prim.c
--- grass/trunk/lib/ogsf/gsd_prim.c	2018-07-10 18:27:54 UTC (rev 72973)
+++ grass/trunk/lib/ogsf/gsd_prim.c	2018-07-11 01:15:40 UTC (rev 72974)
@@ -410,13 +410,13 @@
    \brief Set shaded model
-   \param bool type non-zero for GL_SMOOTH otherwise GL_FLAT
+   \param shade non-zero for GL_SMOOTH otherwise GL_FLAT
-void gsd_shademodel(int bool)
+void gsd_shademodel(int shade)
-    Shade = bool;
+    Shade = shade;
-    if (bool) {
+    if (shade) {
 	glShadeModel(GL_SMOOTH);
     else {
@@ -437,7 +437,7 @@
-   \brief ADD
+   \brief Draw to the front and back buffers
 void gsd_bothbuffers(void)
@@ -448,10 +448,7 @@
-   \brief Specify which color buffers are to be drawn
-   into
-   \param bool non-zero for enable otherwise disable front buffer
+   \brief Draw to the front buffer
 void gsd_frontbuffer(void)
@@ -462,10 +459,7 @@
-   into
-   \param bool non-zero for enable otherwise disable back buffer
+   \brief Draw to the back buffer
 void gsd_backbuffer(void)
