[GRASS-SVN] r72975 - grass/trunk/vector/v.out.ogr
Wed Jul 11 01:34:31 PDT 2018
Author: mmetz
Date: 2018-07-11 01:34:31 -0700 (Wed, 11 Jul 2018)
New Revision: 72975
   grass/trunk/vector/v.out.ogr/dsn.c
   grass/trunk/vector/v.out.ogr/main.c
v.out.ogr: do not modify OGR dsn
Modified: grass/trunk/vector/v.out.ogr/dsn.c
--- grass/trunk/vector/v.out.ogr/dsn.c	2018-07-11 01:15:40 UTC (rev 72974)
+++ grass/trunk/vector/v.out.ogr/dsn.c	2018-07-11 08:34:31 UTC (rev 72975)
@@ -7,7 +7,13 @@
 char *get_datasource_name(const char *opt_dsn, int use_ogr)
     char *dsn;
+    dsn = G_store(opt_dsn);
+    return dsn;
+    /* input OGR dsn and GRASS db connections are independent of each other */
+    /* TODO: remove below code */
     if (G_strncasecmp(opt_dsn, "PG:", 3) == 0) {
         /* PostgreSQL/PostGIS */
         size_t i;
Modified: grass/trunk/vector/v.out.ogr/main.c
--- grass/trunk/vector/v.out.ogr/main.c	2018-07-11 01:15:40 UTC (rev 72974)
+++ grass/trunk/vector/v.out.ogr/main.c	2018-07-11 08:34:31 UTC (rev 72975)
@@ -278,7 +278,7 @@
     dsn = NULL;
     if (options.dsn->answer)
-        dsn = get_datasource_name(options.dsn->answer, TRUE);
+        dsn = G_store(options.dsn->answer);
     /* create new OGR layer in datasource */
     if (flags.new->answer) {
