[GRASS-SVN] r72976 - grass/branches/releasebranch_7_4/vector/v.out.ogr
svn_grass at osgeo.org
Wed Jul 11 01:36:19 PDT 2018
Author: mmetz
Date: 2018-07-11 01:36:19 -0700 (Wed, 11 Jul 2018)
New Revision: 72976
grass/branches/releasebranch_7_4/vector/v.out.ogr/dsn.c
grass/branches/releasebranch_7_4/vector/v.out.ogr/main.c
v.out.ogr: do not modify OGR dsn (backport trunk r72975)
Modified: grass/branches/releasebranch_7_4/vector/v.out.ogr/dsn.c
--- grass/branches/releasebranch_7_4/vector/v.out.ogr/dsn.c 2018-07-11 08:34:31 UTC (rev 72975)
+++ grass/branches/releasebranch_7_4/vector/v.out.ogr/dsn.c 2018-07-11 08:36:19 UTC (rev 72976)
@@ -7,7 +7,13 @@
char *get_datasource_name(const char *opt_dsn, int use_ogr)
char *dsn;
+ dsn = G_store(opt_dsn);
+ return dsn;
+ /* input OGR dsn and GRASS db connections are independent of each other */
+ /* TODO: remove below code */
if (G_strncasecmp(opt_dsn, "PG:", 3) == 0) {
/* PostgreSQL/PostGIS */
size_t i;
Modified: grass/branches/releasebranch_7_4/vector/v.out.ogr/main.c
--- grass/branches/releasebranch_7_4/vector/v.out.ogr/main.c 2018-07-11 08:34:31 UTC (rev 72975)
+++ grass/branches/releasebranch_7_4/vector/v.out.ogr/main.c 2018-07-11 08:36:19 UTC (rev 72976)
@@ -277,7 +277,7 @@
dsn = NULL;
if (options.dsn->answer)
- dsn = get_datasource_name(options.dsn->answer, TRUE);
+ dsn = G_store(options.dsn->answer);
/* create new OGR layer in datasource */
if (flags.new->answer) {
