[GRASS-SVN] r72784 - grass/trunk/lib/init
svn_grass at osgeo.org
Thu Jun 7 07:45:43 PDT 2018
Author: mmetz
Date: 2018-06-07 07:45:42 -0700 (Thu, 07 Jun 2018)
New Revision: 72784
grass/trunk/lib/init/variables.html
libinit: +ZSTD in the doc
Modified: grass/trunk/lib/init/variables.html
--- grass/trunk/lib/init/variables.html 2018-06-07 14:15:10 UTC (rev 72783)
+++ grass/trunk/lib/init/variables.html 2018-06-07 14:45:42 UTC (rev 72784)
@@ -111,9 +111,8 @@
<dd>[libraster]<br>
the compression method for new raster maps can be set with the
environment variable GRASS_COMPRESSOR. Supported methods are RLE,
- ZLIB, LZ4, and BZIP2 if GRASS has been compiled with BZIP2 support.
- The default is ZLIB which can be changed with e.g.
- <tt>GRASS_COMPRESSOR=LZ4</tt></dd>
+ ZLIB, LZ4, BZIP2, and ZSTD. The default is ZLIB which can be
+ changed with e.g. <tt>GRASS_COMPRESSOR=ZSTD</tt></dd>
<dt>GRASS_DB_ENCODING</dt>
<dd>[various modules, wxGUI]<br>
