[GRASS-SVN] r72785 - in grass-addons/grass7/imagery: i.landsat8.qc i.landsat8.swlst
svn_grass at osgeo.org
Fri Jun 8 22:50:59 PDT 2018
Author: nikosa
Date: 2018-06-08 22:50:59 -0700 (Fri, 08 Jun 2018)
New Revision: 72785
grass-addons/grass7/imagery/i.landsat8.qc/i.landsat8.qc.py
grass-addons/grass7/imagery/i.landsat8.swlst/README.md
grass-addons/grass7/imagery/i.landsat8.swlst/column_water_vapor.py
grass-addons/grass7/imagery/i.landsat8.swlst/i.landsat8.swlst.py
i.landsat8.swlst: flag 'k' inverted and rename to 'e' (late sync with https://gitlab.com/NikosAlexandris/i.landsat8.swlst)
Modified: grass-addons/grass7/imagery/i.landsat8.qc/i.landsat8.qc.py
--- grass-addons/grass7/imagery/i.landsat8.qc/i.landsat8.qc.py 2018-06-07 14:45:42 UTC (rev 72784)
+++ grass-addons/grass7/imagery/i.landsat8.qc/i.landsat8.qc.py 2018-06-09 05:50:59 UTC (rev 72785)
@@ -152,7 +152,7 @@
# Define bitpattern characteristics according to
# http://landsat.usgs.gov/qualityband.php
- Currently populated bits:
+ Populated bits:
0 Designated Fill
1 Dropped Frame
@@ -202,16 +202,16 @@
'Yes': '1'}
-The double bits (4-5, 6-7, 8-9, 10-11, 12-13, and 14-15), read from left to
-right, represent levels of confidence that a condition exists:
-00 = 'Not Determined' = Algorithm did not determine the status
- of this condition
-01 = 'No' = Algorithm has low to no confidence that this condition exists
- (0-33 percent confidence)
-10 = 'Maybe' = Algorithm has medium confidence that this condition exists
- (34-66 percent confidence)
-11 = 'Yes' = Algorithm has high confidence that this condition exists
- (67-100 percent confidence).
+ The double bits (4-5, 6-7, 8-9, 10-11, 12-13, and 14-15), read from left to
+ right, represent levels of confidence that a condition exists:
+ 00 = 'Not Determined' = Algorithm did not determine the status
+ of this condition
+ 01 = 'No' = Algorithm has low to no confidence that this condition exists
+ (0-33 percent confidence)
+ 10 = 'Maybe' = Algorithm has medium confidence that this condition exists
+ (34-66 percent confidence)
+ 11 = 'Yes' = Algorithm has high confidence that this condition exists
+ (67-100 percent confidence).
# Define double bits dictionary
Modified: grass-addons/grass7/imagery/i.landsat8.swlst/README.md
--- grass-addons/grass7/imagery/i.landsat8.swlst/README.md 2018-06-07 14:45:42 UTC (rev 72784)
+++ grass-addons/grass7/imagery/i.landsat8.swlst/README.md 2018-06-09 05:50:59 UTC (rev 72785)
@@ -1,4 +1,4 @@
-*i.landsat8.swlst* is a GRASS GIS add-on, implementating a practical Split-Window (SW)
+*i.landsat8.swlst* is a GRASS GIS add-on, implementing a practical Split-Window (SW)
algorithm, estimating land surface temperature (LST), from the Thermal Infra-Red
Sensor (TIRS) aboard Landsat 8 with an accuracy of better than 1.0 K.
@@ -32,7 +32,7 @@
* The `clouds` option can be any user-defined map. Essentialy, it applies
the given map as an inverted mask.
* The emissivity maps, derived by the module itself, can be saved once
via the `emissivity_out` and `delta_emissivity_out` options and used
afterwards via the `emissivity` and `delta_emissivity` options. Expert
@@ -154,6 +154,7 @@
[Low]
+- Test for too small region?
- Deduplicate code in `split_window_lst` class, in functions
`_build_average_emissivity_mapcalc()` and
`_build_delta_emissivity_mapcalc()`
@@ -210,3 +211,4 @@
- Georgios Alexandris, Anthoula Alexandri
- Special thanks to author Huazhong Ren for commenting on questions (personal
communication)
+- Stefan Blumentrath
Modified: grass-addons/grass7/imagery/i.landsat8.swlst/column_water_vapor.py
--- grass-addons/grass7/imagery/i.landsat8.swlst/column_water_vapor.py 2018-06-07 14:45:42 UTC (rev 72784)
+++ grass-addons/grass7/imagery/i.landsat8.swlst/column_water_vapor.py 2018-06-09 05:50:59 UTC (rev 72785)
@@ -99,8 +99,8 @@
Ren, H., Du, C., Liu, R., Qin, Q., Yan, G., Li, Z. L., & Meng, J. (2015).
Atmospheric water vapor retrieval from Landsat 8 thermal infrared images.
Journal of Geophysical Research: Atmospheres, 120(5), 1723-1738.
Old reference:
Ren, H.; Du, C.; Qin, Q.; Liu, R.; Meng, J.; Li, J. Atmospheric water vapor
Modified: grass-addons/grass7/imagery/i.landsat8.swlst/i.landsat8.swlst.py
--- grass-addons/grass7/imagery/i.landsat8.swlst/i.landsat8.swlst.py 2018-06-07 14:45:42 UTC (rev 72784)
+++ grass-addons/grass7/imagery/i.landsat8.swlst/i.landsat8.swlst.py 2018-06-09 05:50:59 UTC (rev 72785)
@@ -85,12 +85,12 @@
#%Module
#% description: Practical split-window algorithm estimating Land Surface Temperature from Landsat 8 OLI/TIRS imagery (Du, Chen; Ren, Huazhong; Qin, Qiming; Meng, Jinjie; Zhao, Shaohua. 2015)
-#% keyword: imagery
-#% keyword: split window
-#% keyword: column water vapor
-#% keyword: land surface temperature
-#% keyword: lst
-#% keyword: landsat8
+#% keywords: imagery
+#% keywords: split window
+#% keywords: column water vapor
+#% keywords: land surface temperature
+#% keywords: lst
+#% keywords: landsat8
#%End
#%flag
@@ -99,8 +99,8 @@
#%end
#%flag
-#% key: k
-#% description: Keep current computational region settings
+#% key: e
+#% description: Match computational region to extent of thermal bands
#%end
#%flag
@@ -350,7 +350,7 @@
grass.run_command('g.remove', flags='f', type="rast",
pattern='tmp.{pid}*'.format(pid=os.getpid()), quiet=True)
if grass.find_file(name='MASK', element='cell')['file']:
r.mask(flags='r', verbose=True)
@@ -1009,7 +1009,7 @@
qapixel = options['qapixel']
lst_output = options['lst']
# save Brightness Temperature maps?
global brightness_temperature_prefix
if options['prefix_bt']:
@@ -1028,7 +1028,7 @@
# optional maps
average_emissivity_map = options['emissivity']
delta_emissivity_map = options['delta_emissivity']
# output for in-between maps?
global emissivity_output, delta_emissivity_output
emissivity_output = options['emissivity_out']
@@ -1041,11 +1041,10 @@
# flags
global info, null
info = flags['i']
- # keep_region = flags['k']
- scene_extent = flags['k']
+ scene_extent = flags['e']
timestamping = flags['t']
null = flags['n']
global celsius
celsius = flags['c']
@@ -1057,7 +1056,6 @@
# Set Region
- # if not keep_region:
if scene_extent:
grass.use_temp_region() # safely modify the region
msg = "\n|! Matching region extent to map {name}"
@@ -1075,7 +1073,6 @@
g.message(msg)
- # elif keep_region:
elif scene_extent:
grass.warning(_('Operating on current region'))
@@ -1243,7 +1240,6 @@
#run("g.rename", rast=(tmp_lst, lst_output))
# restore region
if scene_extent:
grass.del_temp_region() # restoring previous region settings
g.message("|! Original Region restored")
