[GRASS-SVN] r72875 - sandbox/wenzeslaus/g.citation
svn_grass at osgeo.org
Thu Jun 21 20:18:43 PDT 2018
Author: wenzeslaus
Date: 2018-06-21 20:18:43 -0700 (Thu, 21 Jun 2018)
New Revision: 72875
sandbox/wenzeslaus/g.citation/g.citation.html
sandbox/wenzeslaus/g.citation/g.citation.py
g.citation: add plain/basic JSON outputs
Modified: sandbox/wenzeslaus/g.citation/g.citation.html
--- sandbox/wenzeslaus/g.citation/g.citation.html 2018-06-22 02:02:54 UTC (rev 72874)
+++ sandbox/wenzeslaus/g.citation/g.citation.html 2018-06-22 03:18:43 UTC (rev 72875)
@@ -8,10 +8,33 @@
<h4>Citation File Format</h4>
<a href="https://citation-file-format.github.io/">Citation File Format</a>
-(CFF)
+(CFF) is a YAML based format for citations, specifically CITATION files
+to be included with software or code as <tt>CITATION.cff</tt>.
+<h4>JSON</h4>
+Currently, the keys and the overall structure are subject to change,
+but the plan is to stabilize it or to provide existing metadata format
+in JSON. Pretty-printed version is good, e.g., for saving into files,
+while the other, compact version is good for further processing.
+<h4>Pretty printed Python dictionary</h4>
+This format is essentially a dump of the internal data structure holding
+the citation entry. It should not be used in scripts, i.e. further
+parsed, for that there are other formats such as JSON. When this is
+advantageous is exploring what information the module was able to
+acquire for the citation.
<h2>NOTES</h2>
+<ul>
+ <li>Don't use the <tt>format=dict</tt> for further processing.
+ It is meant for exploration of what information the module
+ acquired.
+ <li>The structure of the JSON output is yet not guaranteed.
+</ul>
<h2>EXAMPLES</h2>
<div class="code"><pre>
@@ -23,7 +46,10 @@
<ul>
<li>More output formats or styles are needed.
The following formats were suggested so far:
- <tt>csl,datacite,dublincore,json,json-ld,narcxml</tt>
+ <tt>csl,datacite,dublincore,json-ld,narcxml</tt>
+ <li>The structure of the JSON output is not guaranteed. It reflects
+ the internal structure (only the empty entries are removed).
+ <li>Version and date in CFF output are incomplete.
</ul>
<h2>SEE ALSO</h2>
Modified: sandbox/wenzeslaus/g.citation/g.citation.py
--- sandbox/wenzeslaus/g.citation/g.citation.py 2018-06-22 02:02:54 UTC (rev 72874)
+++ sandbox/wenzeslaus/g.citation/g.citation.py 2018-06-22 03:18:43 UTC (rev 72875)
@@ -36,8 +36,8 @@
#% key: format
#% type: string
#% description: Citation format or style
-#% options: bibtex,cff,dict,plain
-#% descriptions: bibtex;BibTeX;cff;Citation File Format;dict;Pretty printed Python dictionary;plain;Plain text
+#% options: bibtex,cff,json,pretty-json,dict,plain
+#% descriptions: bibtex;BibTeX;cff;Citation File Format;json;JSON;pretty-json;Pretty printed JSON;dict;Pretty printed Python dictionary;plain;Plain text
#% answer: bibtex
#% required: yes
#%end
@@ -80,11 +80,33 @@
import os
import re
from collections import defaultdict
+import json
from pprint import pprint
import grass.script as gs
+def remove_empty_values_from_dict(d):
+ """Removes empty entries from a nested dictionary
+ Iterates and recurses over instances of dict or list and removes
+ all empty entries. The emptiness is evaluated by conversion to bool
+ in an if-statement. Values which are instances of bool are passed
+ as is.
+ Note that plain dict and list are returned, not the original types.
+ What is not an instance of instances of dict or list is left
+ untouched.
+ if isinstance(d, dict):
+ return {k: remove_empty_values_from_dict(v)
+ for k, v in d.items() if v or isinstance(v, bool)}
+ elif isinstance(d, list):
+ return [remove_empty_values_from_dict(i)
+ for i in d if i or isinstance(v, bool)]
+ else:
+ return d
# TODO: copied from g.manual, possibly move to library
# (lib has also online ones)
def documentation_filename(entry):
@@ -298,6 +320,25 @@
print("}")
+def print_json(citation):
+ """Create JSON dump from the citation dictionary"""
+ cleaned = remove_empty_values_from_dict(citation)
+ # since the format is already compact, let's make it even more
+ # compact by omitting the spaces after separators
+ print(json.dumps(cleaned, separators=(',', ':')))
+def print_pretty_json(citation):
+ """Create pretty-printed JSON dump from the citation dictionary"""
+ # the default separator for list items would leave space at the end
+ # of each line, so providing a custom one
+ # only small indent needed, so using 2
+ # sorting keys because only that can provide consistent output
+ print(json.dumps(cleaned, separators=(',', ': '), indent=2,
+ sort_keys=True))
def print_plain(citation):
"""Create citation from dictionary as plain text
@@ -327,8 +368,10 @@
_FORMAT_FUNCTION = {
'bibtex': print_bibtex,
'cff': print_cff,
+ 'json': print_json,
+ 'pretty-json': print_pretty_json,
'plain': print_plain,
- 'dict': pprint,
+ 'dict': lambda d: pprint(dict(d)), # only plain dict pretty prints
