[GRASS-SVN] r72876 - in grass-addons/grass7/raster: . r.accumulate
Thu Jun 21 22:20:15 PDT 2018
Author: hcho
Date: 2018-06-21 22:20:15 -0700 (Thu, 21 Jun 2018)
New Revision: 72876
Added:
   grass-addons/grass7/raster/r.accumulate/
   grass-addons/grass7/raster/r.accumulate/Makefile
   grass-addons/grass7/raster/r.accumulate/accumulate.c
   grass-addons/grass7/raster/r.accumulate/global.h
   grass-addons/grass7/raster/r.accumulate/main.c
   grass-addons/grass7/raster/r.accumulate/r.accumulate.html
   grass-addons/grass7/raster/r.accumulate/r_accumulate_nc_comparison.png
   grass-addons/grass7/raster/r.accumulate/r_accumulate_nc_example.png
   grass-addons/grass7/raster/r.accumulate/r_accumulate_nc_r_watershed_output.png
   grass-addons/grass7/raster/r.accumulate/raster.c
   grass-addons/grass7/raster/Makefile
r.accumulate: New addon for calculating weighted flow accumulation using the flow direction map only
Modified: grass-addons/grass7/raster/Makefile
--- grass-addons/grass7/raster/Makefile	2018-06-22 03:18:43 UTC (rev 72875)
+++ grass-addons/grass7/raster/Makefile	2018-06-22 05:20:15 UTC (rev 72876)
@@ -14,6 +14,7 @@
 #	r.convert \
 SUBDIRS = \
+	r.accumulate \
 	r.agent \
 	r.area \
 	r.basin \
Added: grass-addons/grass7/raster/r.accumulate/Makefile
--- grass-addons/grass7/raster/r.accumulate/Makefile	                        (rev 0)
+++ grass-addons/grass7/raster/r.accumulate/Makefile	2018-06-22 05:20:15 UTC (rev 72876)
@@ -0,0 +1,10 @@
+MODULE_TOPDIR = ../../../trunk
+PGM = r.accumulate
+LIBES = $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(RASTERDEP) $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass-addons/grass7/raster/r.accumulate/accumulate.c
--- grass-addons/grass7/raster/r.accumulate/accumulate.c	                        (rev 0)
+++ grass-addons/grass7/raster/r.accumulate/accumulate.c	2018-06-22 05:20:15 UTC (rev 72876)
@@ -0,0 +1,102 @@
+#include <grass/raster.h>
+#include "global.h"
+double
+accumulate(CELL ** dir_buf, RASTER_MAP weight_buf, RASTER_MAP acc_buf,
+	   char **done, int row, int col)
+    int rows = weight_buf.rows, cols = weight_buf.cols;
+    int i, j, neighbor_dir, loop_dir, has_inflow;
+    double acc_flow;
+    if (done[row][col])
+	return get(acc_buf, row, col);
+    if (weight_buf.map.v)
+	acc_flow = get(weight_buf, row, col);
+    else
+	acc_flow = 1.0;
+    for (i = -1; i <= 1; i++) {
+	if (row + i < 0 || row + i >= rows)
+	    continue;
+	for (j = -1; j <= 1; j++) {
+	    if (col + j < 0 || col + j >= cols || (i == 0 && j == 0))
+		continue;
+	    has_inflow = 0;
+	    neighbor_dir = dir_buf[row + i][col + j];
+	    loop_dir = 0;
+	    switch (i) {
+	    case -1:
+		switch (j) {
+		case -1:
+		    if (neighbor_dir == 315) {
+			has_inflow = 1;
+			loop_dir = 135;
+		    break;
+		case 0:
+		    if (neighbor_dir == 270) {
+			has_inflow = 1;
+			loop_dir = 90;
+		    break;
+		case 1:
+		    if (neighbor_dir == 225) {
+			has_inflow = 1;
+			loop_dir = 45;
+		    break;
+		break;
+	    case 0:
+		switch (j) {
+		case -1:
+		    if (neighbor_dir == 360) {
+			has_inflow = 1;
+			loop_dir = 180;
+		    break;
+		case 1:
+		    if (neighbor_dir == 180) {
+			has_inflow = 1;
+			loop_dir = 360;
+		    break;
+		break;
+	    case 1:
+		switch (j) {
+		case -1:
+		    if (neighbor_dir == 45) {
+			has_inflow = 1;
+			loop_dir = 225;
+		    break;
+		case 0:
+		    if (neighbor_dir == 90) {
+			has_inflow = 1;
+			loop_dir = 270;
+		    break;
+		case 1:
+		    if (neighbor_dir == 135) {
+			has_inflow = 1;
+			loop_dir = 315;
+		    break;
+		break;
+	    if (has_inflow && dir_buf[row][col] != loop_dir)
+		acc_flow +=
+		    accumulate(dir_buf, weight_buf, acc_buf, done, row + i,
+			       col + j);
+    set(acc_buf, row, col, acc_flow);
+    done[row][col] = 1;
+    return acc_flow;
Added: grass-addons/grass7/raster/r.accumulate/global.h
--- grass-addons/grass7/raster/r.accumulate/global.h	                        (rev 0)
+++ grass-addons/grass7/raster/r.accumulate/global.h	2018-06-22 05:20:15 UTC (rev 72876)
@@ -0,0 +1,25 @@
+#define DIR_UNKNOWN 0
+#define DIR_DEG 1
+#define DIR_DEG45 2
+typedef struct
+    RASTER_MAP_TYPE type;
+    int rows, cols;
+    union
+	void **v;
+	CELL **c;
+	FCELL **f;
+	DCELL **d;
+    } map;
+} RASTER_MAP;
+/* raster.c */
+void set(RASTER_MAP, int, int, double);
+double get(RASTER_MAP, int, int);
+/* accumulate.c */
+double accumulate(CELL **, RASTER_MAP, RASTER_MAP, char **, int, int);
Added: grass-addons/grass7/raster/r.accumulate/main.c
--- grass-addons/grass7/raster/r.accumulate/main.c	                        (rev 0)
+++ grass-addons/grass7/raster/r.accumulate/main.c	2018-06-22 05:20:15 UTC (rev 72876)
@@ -0,0 +1,203 @@
+ * MODULE:       r.accumulate
+ * AUTHOR(S):    Huidae Cho <grass4u gmail.com>
+ * PURPOSE:      Calculates weighted flow accumulation using a flow direction
+ *               map.
+ * COPYRIGHT:    (C) 2018 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *               License (>=v2). Read the file COPYING that comes with GRASS
+ *               for details.
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+int main(int argc, char *argv[])
+    struct GModule *module;
+    struct
+	struct Option *dir, *format, *weight, *acc;
+    } opt;
+    char *desc;
+    char *dir_name, *weight_name, *acc_name;
+    int dir_fd, weight_fd, acc_fd;
+    double dir_format;
+    struct Range dir_range;
+    CELL dir_min, dir_max;
+    char **done;
+    CELL **dir_buf;
+    RASTER_MAP weight_buf, acc_buf;
+    int rows, cols, row, col;
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    G_add_keyword(_("raster"));
+    G_add_keyword(_("hydrology"));
+    module->description =
+	_
+	("Calculates weighted flow accumulation using a flow direction map.");
+    opt.dir = G_define_standard_option(G_OPT_R_INPUT);
+    opt.dir->label = _("Name of input direction map");
+    opt.format = G_define_option();
+    opt.format->type = TYPE_STRING;
+    opt.format->key = "format";
+    opt.format->label = _("Format of input direction map");
+    opt.format->required = YES;
+    opt.format->options = "auto,degree,45degree";
+    opt.format->answer = "auto";
+    G_asprintf(&desc, "auto;%s;degree;%s;45degree;%s",
+	       _("auto-detect direction format"),
+	       _("degrees CCW from East"),
+	       _
+	       ("degrees CCW from East divided by 45 (e.g. r.watershed directions)"));
+    opt.format->descriptions = desc;
+    opt.weight = G_define_standard_option(G_OPT_R_INPUT);
+    opt.weight->key = "weight";
+    opt.weight->required = NO;
+    opt.weight->label = _("Name of input flow weight map");
+    opt.acc = G_define_standard_option(G_OPT_R_OUTPUT);
+    opt.acc->type = TYPE_STRING;
+    opt.acc->label = _("Name for output weighted flow accumulation map");
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    dir_name = opt.dir->answer;
+    weight_name = opt.weight->answer;
+    acc_name = opt.acc->answer;
+    dir_fd = Rast_open_old(dir_name, "");
+    if (Rast_get_map_type(dir_fd) != CELL_TYPE)
+	G_fatal_error(_("Invalid directions map <%s>"), dir_name);
+    /* adapted from r.path */
+    if (Rast_read_range(dir_name, "", &dir_range) < 0)
+	G_fatal_error(_("Unable to read range file"));
+    Rast_get_range_min_max(&dir_range, &dir_min, &dir_max);
+    if (dir_max <= 0)
+    dir_format = DIR_UNKNOWN;
+    if (strcmp(opt.format->answer, "degree") == 0) {
+	if (dir_max > 360)
+	    G_fatal_error(_("Directional degrees can not be > 360"));
+	dir_format = DIR_DEG;
+    else if (strcmp(opt.format->answer, "45degree") == 0) {
+	if (dir_max > 8)
+	    G_fatal_error(_
+			  ("Directional degrees divided by 45 can not be > 8"));
+	dir_format = DIR_DEG45;
+    else if (strcmp(opt.format->answer, "auto") == 0) {
+	if (dir_max <= 8) {
+	    G_important_message(_
+				("Input direction format assumed to be degrees CCW from East divided by 45"));
+	else if (dir_max <= 360) {
+				("Input direction format assumed to be degrees CCW from East"));
+	else
+	    G_fatal_error(_
+			  ("Unable to detect format of input direction map <%s>"),
+			  dir_name);
+    if (dir_format == DIR_UNKNOWN)
+	G_fatal_error(_("Invalid directions format '%s'"),
+		      opt.format->answer);
+    /* end of r.path */
+    if (weight_name) {
+	weight_fd = Rast_open_old(weight_name, "");
+	weight_buf.type = Rast_get_map_type(weight_fd);
+    else {
+	weight_fd = -1;
+	weight_buf.type = CELL_TYPE;
+    acc_buf.type = weight_buf.type;
+    acc_fd = Rast_open_new(acc_name, acc_buf.type);
+    rows = Rast_window_rows();
+    cols = Rast_window_cols();
+    done = G_malloc(rows * sizeof(char *));
+    dir_buf = G_malloc(rows * sizeof(CELL *));
+    for (row = 0; row < rows; row++) {
+	done[row] = G_calloc(cols, 1);
+	dir_buf[row] = Rast_allocate_c_buf();
+	Rast_get_c_row(dir_fd, dir_buf[row], row);
+	if (dir_format == DIR_DEG45) {
+	    for (col = 0; col < cols; col++)
+		dir_buf[row][col] *= 45;
+    if (weight_fd >= 0) {
+	weight_buf.map.v = (void **)G_malloc(rows * sizeof(void *));
+	    weight_buf.map.v[row] =
+		(void *)Rast_allocate_buf(weight_buf.type);
+	    Rast_get_row(weight_fd, weight_buf.map.v[row], row,
+			 weight_buf.type);
+    else
+	weight_buf.map.v = NULL;
+    weight_buf.rows = rows;
+    weight_buf.cols = cols;
+    acc_buf.map.v = (void **)G_malloc(rows * sizeof(void *));
+	acc_buf.map.v[row] = (void *)Rast_allocate_buf(acc_buf.type);
+    acc_buf.rows = rows;
+    acc_buf.cols = cols;
+	    accumulate(dir_buf, weight_buf, acc_buf, done, row, col);
+	Rast_put_row(acc_fd, acc_buf.map.v[row], acc_buf.type);
+    G_free(done);
+	G_free(dir_buf[row]);
+	    G_free(weight_buf.map.v[row]);
+	G_free(acc_buf.map.v[row]);
+    G_free(dir_buf);
+	G_free(weight_buf.map.v);
+    G_free(acc_buf.map.v);
+    Rast_close(dir_fd);
+	Rast_close(weight_fd);
+    Rast_close(acc_fd);
+    exit(EXIT_SUCCESS);
Added: grass-addons/grass7/raster/r.accumulate/r.accumulate.html
--- grass-addons/grass7/raster/r.accumulate/r.accumulate.html	                        (rev 0)
+++ grass-addons/grass7/raster/r.accumulate/r.accumulate.html	2018-06-22 05:20:15 UTC (rev 72876)
@@ -0,0 +1,76 @@
+<h2>DESCRIPTION</h2>
+<em>r.accumulate</em> calculates weighted flow accumulatin using a flow
+direction map.
+<h2>NOTES</h2>
+Unlike <em>r.watershed</em>, <em>r.accumulate</em> does not require the
+elevation data to calculate weigited flow accumulation.  Instead, this module
+only uses a flow direction map to trace and accumulate the amount of flow
+draining through each cell.
+<p>The module recognizes two different formats of the flow direction map:
+<div class="code"><pre>
+Direction encoding for neighbors of x
+  135  90  45             3 2 1
+  180  x  360             4 x 8
+  225 270 315             5 6 7
+  degrees              45 degrees
+  CCW from East        CCW from East
+                   (r.watershed drainage)
+</pre></div>
+<h2>EXAMPLES</h2>
+These examples use the North Carolina sample dataset.
+<p>Create the SFD flow accumulation and drainage maps using
+<em>r.watershed</em>:
+# set computational region
+g.region raster=elevation -p
+# calculate positive flow accumulation and drainage directions using r.watershed
+r.watershed elevation=elevation accumulation=flow_accum drainage=drain_directions -sa
+# calculate flow accumulation using r.accumulate
+r.accumulate input=drain_directions output=flow_accum_new
+# copy color table
+r.colors map=flow_accum_new raster=flow_accum
+# check difference betwen flow_accum and flow_accum_new
+r.mapcalc expression="accum_diff=if(flow_accum-flow_accum_new, flow_accum-flow_accum_new, null())"
+</pre></div>
+<img src="r_accumulate_nc_example.png">
+<p>For some reaon, there are slight differences between the two output maps.
+<p><img src="r_accumulate_nc_r_watershed_output.png">
+<p>The yellow and purple cells show the difference raster map
+(<i>accum_diff</i>). The red arrows and numbers represent drainage directions
+(<i>drain_directions</i>) and flow accumulation (<i>flow_accum</i> from
+<em>r.watershed</em>), respectively. Note that some cells close to headwater
+cells are assigned 1 even if they are located downstream of other cells.
+<p><img src="r_accumulate_nc_comparison.png">
+<p>For comparison, these numbers show the new flow accumulatoin
+(<i>flow_accum_new</i> from <em>r.accumulate</em>). The same cells are properly
+accumulated from the headwater cells.
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.watershed.html">r.watershed</a>
+</em>
+<h2>AUTHOR</h2>
+<a href="mailto:grass4u at gmail com">Huidae Cho</a>
+<p><i>Last changed: $Date: 2018-06-15 21:55:50 -0400 (Fri, 15 Jun 2018) $</i>
Added: grass-addons/grass7/raster/r.accumulate/r_accumulate_nc_comparison.png
(Binary files differ)
Index: grass-addons/grass7/raster/r.accumulate/r_accumulate_nc_comparison.png
--- grass-addons/grass7/raster/r.accumulate/r_accumulate_nc_comparison.png	2018-06-22 03:18:43 UTC (rev 72875)
+++ grass-addons/grass7/raster/r.accumulate/r_accumulate_nc_comparison.png	2018-06-22 05:20:15 UTC (rev 72876)
Property changes on: grass-addons/grass7/raster/r.accumulate/r_accumulate_nc_comparison.png
___________________________________________________________________
Added: svn:mime-type
## -0,0 +1 ##
+image/png
\ No newline at end of property
Added: grass-addons/grass7/raster/r.accumulate/r_accumulate_nc_example.png
Index: grass-addons/grass7/raster/r.accumulate/r_accumulate_nc_example.png
--- grass-addons/grass7/raster/r.accumulate/r_accumulate_nc_example.png	2018-06-22 03:18:43 UTC (rev 72875)
+++ grass-addons/grass7/raster/r.accumulate/r_accumulate_nc_example.png	2018-06-22 05:20:15 UTC (rev 72876)
Property changes on: grass-addons/grass7/raster/r.accumulate/r_accumulate_nc_example.png
## -0,0 +1 ##
+image/png
Added: grass-addons/grass7/raster/r.accumulate/r_accumulate_nc_r_watershed_output.png
Index: grass-addons/grass7/raster/r.accumulate/r_accumulate_nc_r_watershed_output.png
--- grass-addons/grass7/raster/r.accumulate/r_accumulate_nc_r_watershed_output.png	2018-06-22 03:18:43 UTC (rev 72875)
+++ grass-addons/grass7/raster/r.accumulate/r_accumulate_nc_r_watershed_output.png	2018-06-22 05:20:15 UTC (rev 72876)
Property changes on: grass-addons/grass7/raster/r.accumulate/r_accumulate_nc_r_watershed_output.png
## -0,0 +1 ##
+image/png
Added: grass-addons/grass7/raster/r.accumulate/raster.c
--- grass-addons/grass7/raster/r.accumulate/raster.c	                        (rev 0)
+++ grass-addons/grass7/raster/r.accumulate/raster.c	2018-06-22 05:20:15 UTC (rev 72876)
@@ -0,0 +1,38 @@
+void set(RASTER_MAP buf, int row, int col, double value)
+    switch (buf.type) {
+    case CELL_TYPE:
+	buf.map.c[row][col] = (CELL) value;
+	break;
+    case FCELL_TYPE:
+	buf.map.f[row][col] = (FCELL) value;
+	break;
+    case DCELL_TYPE:
+	buf.map.d[row][col] = (DCELL) value;
+	break;
+    return;
+double get(RASTER_MAP buf, int row, int col)
+    double value = 0;
+    case CELL_TYPE:
+	value = (double)buf.map.c[row][col];
+	break;
+    case FCELL_TYPE:
+	value = (double)buf.map.f[row][col];
+	break;
+    case DCELL_TYPE:
+	value = buf.map.d[row][col];
+	break;
+    return value;
