[GRASS-SVN] r72895 - grass/trunk/raster/r.colors
svn_grass at osgeo.org
Sun Jun 24 06:44:57 PDT 2018
Author: mmetz
Date: 2018-06-24 06:44:57 -0700 (Sun, 24 Jun 2018)
New Revision: 72895
grass/trunk/raster/r.colors/edit_colors.c
r.colors: add flag to print color name: description (type); code formatting
Modified: grass/trunk/raster/r.colors/edit_colors.c
--- grass/trunk/raster/r.colors/edit_colors.c 2018-06-24 10:15:29 UTC (rev 72894)
+++ grass/trunk/raster/r.colors/edit_colors.c 2018-06-24 13:44:57 UTC (rev 72895)
@@ -22,6 +22,22 @@
#include <sys/types.h>
#include "local_proto.h"
+struct colordesc
+ char *name;
+ char *desc;
+ char *type;
+int cmp_clrname(const void *a, const void *b)
+ struct colordesc *ca = (struct colordesc *) a;
+ struct colordesc *cb = (struct colordesc *) b;
+ return (strcmp(ca->name, cb->name));
int edit_colors(int argc, char **argv, int type, const char *maptype,
const char* Maptype)
@@ -42,9 +58,10 @@
int has_fcell_type = 0;
struct GModule *module;
struct maps_info input_maps;
+ int stat = -1;
struct {
- struct Flag *r, *w, *l, *g, *a, *n, *e;
+ struct Flag *r, *w, *l, *d, *g, *a, *n, *e;
} flag;
struct {
@@ -127,6 +144,13 @@
flag.l->suppress_required = YES;
flag.l->guisection = _("Print");
+ flag.d = G_define_flag();
+ flag.d->key = 'd';
+ flag.d->label = _("List available rules with description then exit");
+ flag.d->description = _("If a color rule is given, only this rule is listed");
+ flag.d->suppress_required = YES;
+ flag.d->guisection = _("Print");
flag.n = G_define_flag();
flag.n->key = 'n';
flag.n->description = _("Invert colors");
@@ -148,9 +172,9 @@
flag.e->guisection = _("Define");
G_option_exclusive(opt.maps, opt.file, flag.l, NULL);
- G_option_required(opt.maps, opt.file, flag.l, NULL);
+ G_option_required(opt.maps, opt.file, flag.l, flag.d, NULL);
G_option_exclusive(opt.rast, opt.volume, NULL);
- G_option_required(opt.rast, opt.volume, opt.colr, opt.rules, flag.r, flag.l, NULL);
+ G_option_required(opt.rast, opt.volume, opt.colr, opt.rules, flag.r, flag.l, flag.d, NULL);
G_option_exclusive(opt.colr, opt.rules, opt.rast, opt.volume, NULL);
G_option_exclusive(flag.g, flag.a, NULL);
@@ -162,6 +186,161 @@
return EXIT_SUCCESS;
+ if (flag.d->answer) {
+ char path[GPATH_MAX];
+ FILE *fp;
+ int ncolors;
+ struct colordesc *colordesc;
+ char **cnames;
+ /* load color rules */
+ G_snprintf(path, GPATH_MAX, "%s/etc/colors", G_gisbase());
+ ncolors = 0;
+ cnames = G_ls2(path, &ncolors);
+ colordesc = G_malloc(ncolors * sizeof(struct colordesc));
+ for (i = 0; i < ncolors; i++) {
+ char buf[1024];
+ double rmin, rmax;
+ int first;
+ int cisperc;
+ colordesc[i].name = G_store(cnames[i]);
+ colordesc[i].desc = NULL;
+ /* open color rule file */
+ G_snprintf(path, GPATH_MAX, "%s/etc/colors/%s", G_gisbase(),
+ colordesc[i].name);
+ fp = fopen(path, "r");
+ if (!fp)
+ G_fatal_error(_("Unable to open color rule"));
+ /* scan all lines */
+ first = 1;
+ rmin = rmax = 0;
+ cisperc = 0;
+ while (G_getl2(buf, sizeof(buf), fp)) {
+ char value[80], color[80];
+ double x;
+ char c;
+ G_strip(buf);
+ if (*buf == '\0')
+ continue;
+ if (*buf == '#')
+ continue;
+ if (sscanf(buf, "%s %[^\n]", value, color) != 2)
+ continue;
+ if (G_strcasecmp(value, "default") == 0) {
+ continue;
+ if (G_strcasecmp(value, "nv") == 0) {
+ continue;
+ if (sscanf(value, "%lf%c", &x, &c) == 2 && c == '%') {
+ cisperc = 1;
+ break;
+ if (sscanf(value, "%lf", &x) == 1) {
+ if (first) {
+ first = 0;
+ rmin = rmax = x;
+ else {
+ if (rmin > x)
+ rmin = x;
+ if (rmax < x)
+ rmax = x;
+ fclose(fp);
+ if (cisperc)
+ colordesc[i].type = G_store(_("relative, percent of map range"));
+ else {
+ G_snprintf(buf, sizeof(buf) - 1, _("absolute, %g to %g"), rmin, rmax);
+ colordesc[i].type = G_store(buf);
+ qsort(colordesc, ncolors, sizeof(struct colordesc), cmp_clrname);
+ /* load color descriptions */
+ G_snprintf(path, GPATH_MAX, "%s/etc/colors.desc", G_gisbase());
+ if (!fp)
+ G_fatal_error(_("Unable to open color descriptions"));
+ for (;;) {
+ char buf[1024];
+ char tok_buf[1024];
+ char *cname, *cdesc;
+ int ntokens;
+ char **tokens;
+ struct colordesc csearch, *cfound;
+ if (!G_getl2(buf, sizeof(buf), fp))
+ break;
+ strcpy(tok_buf, buf);
+ tokens = G_tokenize(tok_buf, ":");
+ ntokens = G_number_of_tokens(tokens);
+ if (ntokens != 2)
+ continue;
+ cname = G_chop(tokens[0]);
+ cdesc = G_chop(tokens[1]);
+ csearch.name = cname;
+ cfound = bsearch(&csearch, colordesc, ncolors,
+ sizeof(struct colordesc), cmp_clrname);
+ if (cfound) {
+ cfound->desc = G_store(cdesc);
+ G_free_tokens(tokens);
+ fclose(fp);
+ if (opt.colr->answer) {
+ csearch.name = opt.colr->answer;
+ if (cfound) {
+ if (cfound->desc) {
+ fprintf(stdout, "%s: %s (%s)\n", cfound->name,
+ cfound->desc, cfound->type);
+ else {
+ fprintf(stdout, "%s: (%s)\n", cfound->name,
+ cfound->type);
+ else {
+ if (colordesc[i].desc) {
+ fprintf(stdout, "%s: %s (%s)\n", colordesc[i].name,
+ colordesc[i].desc, colordesc[i].type);
+ else {
+ fprintf(stdout, "%s: (%s)\n", colordesc[i].name,
+ colordesc[i].type);
+ return EXIT_SUCCESS;
overwrite = !flag.w->answer;
remove = flag.r->answer;
style = opt.colr->answer;
@@ -179,105 +358,105 @@
/* Read the map names from the infile */
if (file) {
- FILE *in;
+ FILE *in;
+ int num_maps = 0;
+ int max_maps = 0;
- in = fopen(file, "r");
- if (!in)
- G_fatal_error(_("Unable to open %s file <%s>"), maptype, file);
+ in = fopen(file, "r");
+ if (!in)
+ G_fatal_error(_("Unable to open %s file <%s>"), maptype, file);
- int num_maps = 0;
- int max_maps = 0;
+ input_maps.names = (char **)G_calloc(100, sizeof(char *));
+ input_maps.mapsets = (char **)G_calloc(100, sizeof(char *));
+ input_maps.map_types = (int*)G_calloc(100, sizeof(int));
+ input_maps.min = (DCELL*)G_calloc(100, sizeof(DCELL));
+ input_maps.max = (DCELL*)G_calloc(100, sizeof(DCELL));
- input_maps.names = (char **)G_calloc(100, sizeof(char *));
- input_maps.mapsets = (char **)G_calloc(100, sizeof(char *));
- input_maps.map_types = (int*)G_calloc(100, sizeof(int));
- input_maps.min = (DCELL*)G_calloc(100, sizeof(DCELL));
- input_maps.max = (DCELL*)G_calloc(100, sizeof(DCELL));
+ for (;;) {
+ char buf[GNAME_MAX]; /* Name */
- for (;;) {
- char buf[GNAME_MAX]; /* Name */
+ if (!G_getl2(buf, sizeof(buf), in))
+ break;
- if (!G_getl2(buf, sizeof(buf), in))
- break;
+ name = G_chop(buf);
- name = G_chop(buf);
+ /* Ignore empty lines */
+ if (!*name)
+ continue;
- /* Ignore empty lines */
- if (!*name)
- continue;
+ /* Reallocate memory */
+ if (num_maps >= max_maps) {
+ max_maps += 100;
+ input_maps.names = (char **)G_realloc(input_maps.names, max_maps * sizeof(char *));
+ input_maps.mapsets = (char **)G_realloc(input_maps.mapsets, max_maps * sizeof(char *));
+ input_maps.map_types = (int*)G_realloc(input_maps.map_types, max_maps * sizeof(int));
+ input_maps.min = (DCELL*)G_realloc(input_maps.min, max_maps * sizeof(DCELL));
+ input_maps.max = (DCELL*)G_realloc(input_maps.max, max_maps * sizeof(DCELL));
- /* Reallocate memory */
- if (num_maps >= max_maps) {
- max_maps += 100;
- input_maps.names = (char **)G_realloc(input_maps.names, max_maps * sizeof(char *));
- input_maps.mapsets = (char **)G_realloc(input_maps.mapsets, max_maps * sizeof(char *));
- input_maps.map_types = (int*)G_realloc(input_maps.map_types, max_maps * sizeof(int));
- input_maps.min = (DCELL*)G_realloc(input_maps.min, max_maps * sizeof(DCELL));
- input_maps.max = (DCELL*)G_realloc(input_maps.max, max_maps * sizeof(DCELL));
+ /* Store the map name */
+ input_maps.names[num_maps] = G_store(name);
- /* Store the map name */
- input_maps.names[num_maps] = G_store(name);
+ /* Switch between raster and volume */
+ if (type == RASTER3D_TYPE) {
+ input_maps.mapsets[num_maps] = G_store(G_find_raster3d(input_maps.names[num_maps], ""));
+ else {
+ input_maps.mapsets[num_maps] = G_store(G_find_raster2(input_maps.names[num_maps], ""));
+ if (input_maps.mapsets[num_maps] == NULL)
+ G_fatal_error(_("%s map <%s> not found"), Maptype, input_maps.names[num_maps]);
- /* Switch between raster and volume */
- if (type == RASTER3D_TYPE) {
- input_maps.mapsets[num_maps] = G_store(G_find_raster3d(input_maps.names[num_maps], ""));
- } else {
- input_maps.mapsets[num_maps] = G_store(G_find_raster2(input_maps.names[num_maps], ""));
- if (input_maps.mapsets[num_maps] == NULL)
- G_fatal_error(_("%s map <%s> not found"), Maptype, input_maps.names[num_maps]);
+ num_maps++;
- num_maps++;
if (num_maps < 1)
G_fatal_error(_("No %s map name found in input file <%s>"), maptype, file);
- input_maps.num = num_maps;
+ input_maps.num = num_maps;
fclose(in);
- else if(opt.maps->answer) {
- input_maps.num = 0;
- while(opt.maps->answers[input_maps.num]) {
- input_maps.num++;
- input_maps.names = (char **)G_calloc(input_maps.num, sizeof(char *));
- input_maps.mapsets = (char **)G_calloc(input_maps.num, sizeof(char *));
- input_maps.map_types = (int*)G_calloc(input_maps.num, sizeof(int));
- input_maps.min = (DCELL*)G_calloc(input_maps.num, sizeof(DCELL));
- input_maps.max = (DCELL*)G_calloc(input_maps.num, sizeof(DCELL));
+ else if (opt.maps->answer) {
+ input_maps.num = 0;
+ while (opt.maps->answers[input_maps.num]) {
+ input_maps.num++;
+ input_maps.names = (char **)G_calloc(input_maps.num, sizeof(char *));
+ input_maps.mapsets = (char **)G_calloc(input_maps.num, sizeof(char *));
+ input_maps.map_types = (int*)G_calloc(input_maps.num, sizeof(int));
+ input_maps.min = (DCELL*)G_calloc(input_maps.num, sizeof(DCELL));
+ input_maps.max = (DCELL*)G_calloc(input_maps.num, sizeof(DCELL));
- for(i = 0; i < input_maps.num; i++) {
- input_maps.names[i] = G_store(opt.maps->answers[i]);
+ for (i = 0; i < input_maps.num; i++) {
+ input_maps.names[i] = G_store(opt.maps->answers[i]);
- input_maps.mapsets[i] = G_store(G_find_raster3d(input_maps.names[i], ""));
- } else {
- input_maps.mapsets[i] = G_store(G_find_raster2(input_maps.names[i], ""));
- if (input_maps.mapsets[i] == NULL)
- G_fatal_error(_("%s map <%s> not found"), Maptype, input_maps.names[i]);
+ input_maps.mapsets[i] = G_store(G_find_raster3d(input_maps.names[i], ""));
+ else {
+ input_maps.mapsets[i] = G_store(G_find_raster2(input_maps.names[i], ""));
+ if (input_maps.mapsets[i] == NULL)
+ G_fatal_error(_("%s map <%s> not found"), Maptype, input_maps.names[i]);
- int stat = -1;
if (remove) {
- name = input_maps.names[i];
- mapset = input_maps.mapsets[i];
+ name = input_maps.names[i];
+ mapset = input_maps.mapsets[i];
- stat = Rast3d_remove_color(name);
- } else {
- stat = Rast_remove_colors(name, mapset);
- if (stat < 0)
- G_fatal_error(_("Unable to remove color table of %s map <%s>"), maptype, name);
- if (stat == 0)
- G_warning(_("Color table of %s map <%s> not found"), maptype, name);
+ stat = Rast3d_remove_color(name);
+ } else {
+ stat = Rast_remove_colors(name, mapset);
+ if (stat < 0)
+ G_fatal_error(_("Unable to remove color table of %s map <%s>"), maptype, name);
+ if (stat == 0)
+ G_warning(_("Color table of %s map <%s> not found"), maptype, name);
@@ -284,72 +463,77 @@
G_suppress_warnings(TRUE);
- have_colors = Rast3d_read_colors(name, mapset, &colors);
- } else {
- have_colors = Rast_read_colors(name, mapset, &colors);
- if (have_colors >= 0)
- Rast_free_colors(&colors);
+ have_colors = Rast3d_read_colors(name, mapset, &colors);
+ else {
+ have_colors = Rast_read_colors(name, mapset, &colors);
+ if (have_colors >= 0)
+ Rast_free_colors(&colors);
- if (have_colors > 0 && !overwrite) {
- G_fatal_error(_("Color table exists for %s map <%s>. Exiting."), maptype, name);
+ if (have_colors > 0 && !overwrite) {
+ G_fatal_error(_("Color table exists for %s map <%s>. Exiting."), maptype, name);
G_suppress_warnings(FALSE);
has_fcell_type = 0;
has_cell_type = 0;
+ min = max = 0;
- input_maps.map_types[i] = 1; /* 3D raster maps are always floating point */
- has_fcell_type = 1;
- Rast3d_read_range(name, mapset, &range);
- } else {
- input_maps.map_types[i] = Rast_map_is_fp(name, mapset);
- if(input_maps.map_types[i] == 1)
- else
- has_cell_type = 1;
+ input_maps.map_types[i] = 1; /* 3D raster maps are always floating point */
+ has_fcell_type = 1;
+ Rast3d_read_range(name, mapset, &range);
+ else {
+ input_maps.map_types[i] = Rast_map_is_fp(name, mapset);
+ if(input_maps.map_types[i] == 1)
+ else
+ has_cell_type = 1;
- Rast_read_fp_range(name, mapset, &range);
+ Rast_read_fp_range(name, mapset, &range);
- if(i > 0) {
- if(has_fcell_type && has_cell_type) {
- G_fatal_error("Input maps must have the same cell type. "
- "Mixing of integer and floating point maps is not supported.");
+ if (i > 0) {
+ if(has_fcell_type && has_cell_type) {
+ G_fatal_error("Input maps must have the same cell type. "
+ "Mixing of integer and floating point maps is not supported.");
- Rast_get_fp_range_min_max(&range, &input_maps.min[i], &input_maps.max[i]);
+ Rast_get_fp_range_min_max(&range, &input_maps.min[i], &input_maps.max[i]);
- /* Compute min, max of all maps*/
- if(i == 0) {
- min = input_maps.min[i];
- max = input_maps.max[i];
- } else {
- if(input_maps.min[i] < min)
- if(input_maps.max[i] > max)
+ /* Compute min, max of all maps*/
+ if (i == 0) {
+ min = input_maps.min[i];
+ max = input_maps.max[i];
+ else {
+ if(input_maps.min[i] < min)
+ if(input_maps.max[i] > max)
if (is_from_stdin) {
if (!read_color_rules(stdin, &colors, min, max, has_fcell_type))
exit(EXIT_FAILURE);
- } else if (style) {
+ else if (style) {
* here the predefined color-table color-styles are created by GRASS library calls.
@@ -357,13 +541,15 @@
if (has_fcell_type)
G_fatal_error(_("Color table 'random' is not supported for floating point %s map"), maptype);
Rast_make_random_colors(&colors, (CELL) min, (CELL) max);
- } else if (strcmp(style, "grey.eq") == 0) {
+ else if (strcmp(style, "grey.eq") == 0) {
if (has_fcell_type)
G_fatal_error(_("Color table 'grey.eq' is not supported for floating point %s map"), maptype);
if (!have_stats)
have_stats = get_stats(&input_maps, &statf);
Rast_make_histogram_eq_colors(&colors, &statf);
- } else if (strcmp(style, "grey.log") == 0) {
+ else if (strcmp(style, "grey.log") == 0) {
if (has_fcell_type)
G_fatal_error(_("Color table 'grey.log' is not supported for floating point %s map"), maptype);
if (!have_stats)
@@ -370,11 +556,13 @@
Rast_make_histogram_log_colors(&colors, &statf, (CELL) min,
(CELL) max);
- } else if (G_find_color_rule(style))
+ else if (G_find_color_rule(style))
Rast_make_fp_colors(&colors, style, min, max);
else
G_fatal_error(_("Unknown color request '%s'"), style);
- } else if (rules) {
+ else if (rules) {
if (!Rast_load_fp_colors(&colors, rules, min, max)) {
/* for backwards compatibility try as std name; remove for GRASS 7 */
@@ -385,7 +573,8 @@
if (!Rast_load_fp_colors(&colors, path, min, max))
G_fatal_error(_("Unable to load rules file <%s>"), rules);
- } else {
+ else {
/* use color from another map (cmap) */
if (opt.rast->answer) {
cmapset = G_find_raster2(cmap, "");
@@ -394,7 +583,8 @@
if (Rast_read_colors(cmap, cmapset, &colors) < 0)
G_fatal_error(_("Unable to read color table for raster map <%s>"), cmap);
- } else {
+ else {
cmapset = G_find_raster3d(cmap, "");
if (cmapset == NULL)
G_fatal_error(_("3D raster map <%s> not found"), cmap);
@@ -413,9 +603,11 @@
if (flag.e->answer) {
if (has_fcell_type && !has_cell_type) {
struct FP_stats fpstats;
get_fp_stats(&input_maps, &fpstats, min, max, flag.g->answer, flag.a->answer, type);
Rast_histogram_eq_fp_colors(&colors_tmp, &colors, &fpstats);
- } else {
+ else {
if (!have_stats)
Rast_histogram_eq_colors(&colors_tmp, &colors, &statf);
@@ -433,21 +625,22 @@
colors = colors_tmp;
- if (input_maps.map_types[i])
- Rast_mark_colors_as_fp(&colors);
- Rast3d_write_colors(name, mapset, &colors);
- } else {
- Rast_write_colors(name, mapset, &colors);
- G_message(_("Color table for %s map <%s> set to '%s'"), maptype, name,
- is_from_stdin ? "rules" : style ? style : rules ? rules :
- cmap);
+ if (input_maps.map_types[i])
+ Rast_mark_colors_as_fp(&colors);
+ Rast3d_write_colors(name, mapset, &colors);
+ else {
+ Rast_write_colors(name, mapset, &colors);
+ G_message(_("Color table for %s map <%s> set to '%s'"), maptype, name,
+ is_from_stdin ? "rules" : style ? style : rules ? rules :
+ cmap);
exit(EXIT_SUCCESS);
