[GRASS-SVN] r72896 - grass-addons/grass7/raster/r.accumulate
Sun Jun 24 10:12:46 PDT 2018
Author: hcho
Date: 2018-06-24 10:12:46 -0700 (Sun, 24 Jun 2018)
New Revision: 72896
   grass-addons/grass7/raster/r.accumulate/accumulate.c
   grass-addons/grass7/raster/r.accumulate/main.c
r.accumulate: Fix a bug in flow weighting; Add more comments
Modified: grass-addons/grass7/raster/r.accumulate/accumulate.c
--- grass-addons/grass7/raster/r.accumulate/accumulate.c	2018-06-24 13:44:57 UTC (rev 72895)
+++ grass-addons/grass7/raster/r.accumulate/accumulate.c	2018-06-24 17:12:46 UTC (rev 72896)
@@ -11,9 +11,8 @@
 #define SW 225
 #define W 180
-double
-accumulate(CELL ** dir_buf, RASTER_MAP weight_buf, RASTER_MAP acc_buf,
-           char **done, char neg, int row, int col)
+double accumulate(CELL ** dir_buf, RASTER_MAP weight_buf, RASTER_MAP acc_buf,
+                  char **done, char neg, int row, int col)
     static int dir_checks[3][3][2] = {
         {{SE, NW}, {S, N}, {SW, NE}},
@@ -20,36 +19,64 @@
         {{E, W}, {0, 0}, {W, E}},
         {{NE, SW}, {N, S}, {NW, SE}}
-    int rows = weight_buf.rows, cols = weight_buf.cols;
+    int rows = acc_buf.rows, cols = acc_buf.cols;
     int i, j;
     char incomplete = 0;
     double acc;
-    if (done[row][col])
-        return fabs(get(acc_buf, row, col));
+    /* if the current cell has been calculated, just return its accumulation so
+     * that downstream cells can simply propagate and add it to themselves */
+    if (done[row][col]) {
+        acc = get(acc_buf, row, col);
+        /* for negative accumulation, always return its absolute value;
+         * otherwise return it as is */
+        return neg && acc < 0 ? -acc : acc;
+    /* if a weight map is specified (no negative accumulation is implied), use
+     * the weight value at the current cell; otherwise use 1 */
     if (weight_buf.map.v)
         acc = get(weight_buf, row, col);
     else
         acc = 1.0;
+    /* loop through all neighbor cells and see if any of them drains into the
+     * current cell (are there upstream cells?) */
     for (i = -1; i <= 1; i++) {
+        /* if a neighbor cell is outside the computational region, its
+         * downstream accumulation is incomplete */
         if (row + i < 0 || row + i >= rows) {
             incomplete = 1;
             continue;
         for (j = -1; j <= 1; j++) {
+            /* skip the current cell */
             if (i == 0 && j == 0)
                 continue;
             if (col + j < 0 || col + j >= cols) {
                 incomplete = 1;
                 continue;
+            /* if a neighbor cell drains into the current cell and the current
+             * cell doesn't flow back into the same neighbor cell (no flow
+             * loop), trace and recursively accumulate upstream cells */
             if (dir_buf[row + i][col + j] == dir_checks[i + 1][j + 1][0] &&
                 dir_buf[row][col] != dir_checks[i + 1][j + 1][1]) {
+                /* for negative accumulation, accumulate() always returns a
+                 * positive value, so acc is always positive (cell count);
+                 * otherwise, acc is weighted accumulation */
                 acc +=
                     accumulate(dir_buf, weight_buf, acc_buf, done, neg,
                                row + i, col + j);
+                /* if the neighbor cell is incomplete, the current cell also
+                 * becomes incomplete */
                 if (done[row + i][col + j] == 2)
                     incomplete = 1;
@@ -56,8 +83,15 @@
+    /* if negative accumulation is desired and the current cell is incomplete,
+     * use a negative cell count without weighting; otherwise use accumulation
+     * as is (cell count or weighted accumulation, which can be negative) */
     set(acc_buf, row, col, neg && incomplete ? -acc : acc);
+    /* the current cell is done; 1 for no likely underestimates and 2 for
+     * likely underestimates */
     done[row][col] = 1 + incomplete;
+    /* for negative accumulation, acc is already positive */
     return acc;
Modified: grass-addons/grass7/raster/r.accumulate/main.c
--- grass-addons/grass7/raster/r.accumulate/main.c	2018-06-24 13:44:57 UTC (rev 72895)
+++ grass-addons/grass7/raster/r.accumulate/main.c	2018-06-24 17:12:46 UTC (rev 72896)
@@ -90,6 +90,8 @@
     flag.neg->label =
         _("Use negative flow accumulation for likely underestimates");
+    /* weighting doesn't support negative accumulation because weights
+     * themselves can be negative */
     G_option_exclusive(opt.weight, flag.neg, NULL);
     if (G_parser(argc, argv))
@@ -139,23 +141,12 @@
                       opt.format->answer);
     /* end of r.path */
-    if (weight_name) {
-        weight_fd = Rast_open_old(weight_name, "");
-        weight_buf.type = Rast_get_map_type(weight_fd);
-    else {
-        weight_fd = -1;
-        weight_buf.type = CELL_TYPE;
-    acc_buf.type = weight_buf.type;
-    acc_fd = Rast_open_new(acc_name, acc_buf.type);
     neg = flag.neg->answer;
     rows = Rast_window_rows();
     cols = Rast_window_cols();
+    /* initialize the done array and read the direction map */
     done = G_malloc(rows * sizeof(char *));
     dir_buf = G_malloc(rows * sizeof(CELL *));
     for (row = 0; row < rows; row++) {
@@ -168,7 +159,12 @@
-    if (weight_fd >= 0) {
+    /* optionally, read a weight map */
+    if (weight_name) {
+        weight_fd = Rast_open_old(weight_name, "");
+        acc_buf.type = weight_buf.type = Rast_get_map_type(weight_fd);
+        weight_buf.rows = rows;
+        weight_buf.cols = cols;
         weight_buf.map.v = (void **)G_malloc(rows * sizeof(void *));
             weight_buf.map.v[row] =
@@ -177,42 +173,53 @@
                          weight_buf.type);
-    else
+    else {
+        weight_fd = -1;
         weight_buf.map.v = NULL;
-    weight_buf.rows = rows;
-    weight_buf.cols = cols;
+        acc_buf.type = CELL_TYPE;
+    /* create output buffer */
+    acc_buf.rows = rows;
+    acc_buf.cols = cols;
     acc_buf.map.v = (void **)G_malloc(rows * sizeof(void *));
         acc_buf.map.v[row] = (void *)Rast_allocate_buf(acc_buf.type);
-    acc_buf.rows = rows;
-    acc_buf.cols = cols;
+    /* create a new output map */
+    acc_fd = Rast_open_new(acc_name, acc_buf.type);
+    /* accumulate flows */
         for (col = 0; col < cols; col++)
             accumulate(dir_buf, weight_buf, acc_buf, done, neg, row, col);
+    /* write out output buffer to the output map */
         Rast_put_row(acc_fd, acc_buf.map.v[row], acc_buf.type);
-    G_free(done);
+    /* close all maps */
+    Rast_close(dir_fd);
+    Rast_close(acc_fd);
+    if (weight_fd >= 0)
+        Rast_close(weight_fd);
+    /* free buffer memory */
+        G_free(done[row]);
         G_free(dir_buf[row]);
+        G_free(acc_buf.map.v[row]);
         if (weight_fd >= 0)
             G_free(weight_buf.map.v[row]);
-        G_free(acc_buf.map.v[row]);
+    G_free(done);
     G_free(dir_buf);
+    G_free(acc_buf.map.v);
     if (weight_fd >= 0)
         G_free(weight_buf.map.v);
-    G_free(acc_buf.map.v);
-    Rast_close(dir_fd);
-        Rast_close(weight_fd);
-    Rast_close(acc_fd);
+    /* write history */
     Rast_put_cell_title(acc_name,
                         weight_name ? "Weighted flow accumulation" :
                         (neg ? "Flow accumulation with likely underestimates"
