[GRASS-SVN] r72906 - grass-addons/grass7/raster/r.accumulate
Mon Jun 25 20:08:04 PDT 2018
Author: hcho
Date: 2018-06-25 20:08:04 -0700 (Mon, 25 Jun 2018)
New Revision: 72906
Added:
   grass-addons/grass7/raster/r.accumulate/calculate_lfp.c
   grass-addons/grass7/raster/r.accumulate/line_list.c
   grass-addons/grass7/raster/r.accumulate/Makefile
   grass-addons/grass7/raster/r.accumulate/delineate_streams.c
   grass-addons/grass7/raster/r.accumulate/global.h
   grass-addons/grass7/raster/r.accumulate/main.c
   grass-addons/grass7/raster/r.accumulate/r.accumulate.html
r.accumulate: Implement longest flow path using flow directions (no dependency on r.stream.distance addon unlike r.lfp)
Modified: grass-addons/grass7/raster/r.accumulate/Makefile
--- grass-addons/grass7/raster/r.accumulate/Makefile	2018-06-25 21:28:53 UTC (rev 72905)
+++ grass-addons/grass7/raster/r.accumulate/Makefile	2018-06-26 03:08:04 UTC (rev 72906)
@@ -2,8 +2,8 @@
 PGM = r.accumulate
-LIBES = $(RASTERLIB) $(VECTORLIB) $(GISLIB)
-DEPENDENCIES = $(RASTERDEP) $(VECTORDEP) $(GISDEP)
+LIBES = $(RASTERLIB) $(VECTORLIB) $(DBMILIB) $(GISLIB)
+DEPENDENCIES = $(RASTERDEP) $(VECTORDEP) $(DBMIDEP) $(GISDEP)
 EXTRA_INC = $(VECT_INC)
 EXTRA_CFLAGS = $(VECT_CFLAGS)
Added: grass-addons/grass7/raster/r.accumulate/calculate_lfp.c
--- grass-addons/grass7/raster/r.accumulate/calculate_lfp.c	                        (rev 0)
+++ grass-addons/grass7/raster/r.accumulate/calculate_lfp.c	2018-06-26 03:08:04 UTC (rev 72906)
@@ -0,0 +1,250 @@
+#include <grass/gis.h>
+#include <grass/vector.h>
+#include <grass/glocale.h>
+#include "global.h"
+struct neighbor_accum
+    int row;
+    int col;
+    int accum;
+static void add_table(struct Map_info *, char *, dbDriver **,
+                      struct field_info **);
+static int trace_up(struct cell_map *, struct raster_map *,
+                    struct Cell_head *, int, int, struct point_list *,
+                    struct line_list *);
+static int compare_neighbor_accum(const void *, const void *);
+static int compare_line(const void *, const void *);
+void calculate_lfp(struct Map_info *Map, struct cell_map *dir_buf,
+                   struct raster_map *accum_buf, int *id, char *id_colname,
+                   struct point_list *outlet_pl)
+    struct Cell_head window;
+    int rows = accum_buf->rows, cols = accum_buf->cols;
+    struct point_list pl;
+    struct line_list ll;
+    struct line_cats *Cats;
+    int i, cat;
+    dbDriver *driver = NULL;
+    struct field_info *Fi;
+    dbString sql;
+    if (id_colname) {
+        add_table(Map, id_colname, &driver, &Fi);
+        db_init_string(&sql);
+    G_get_set_window(&window);
+    init_point_list(&pl);
+    init_line_list(&ll);
+    Cats = Vect_new_cats_struct();
+    /* loop through all outlets and find the longest flow path for each */
+    cat = 1;
+    for (i = 0; i < outlet_pl->n; i++) {
+        int row = (int)Rast_northing_to_row(outlet_pl->y[i], &window);
+        int col = (int)Rast_easting_to_col(outlet_pl->x[i], &window);
+        int n;
+        /* if the outlet is outside the computational region, skip */
+        if (row < 0 || row >= rows || col < 0 || col >= cols) {
+            G_warning(_("Skip outlet (%f, %f) outside the current region"),
+                      outlet_pl->x[i], outlet_pl->y[i]);
+            continue;
+        /* trace up flow accumulation */
+        reset_point_list(&pl);
+        reset_line_list(&ll);
+        trace_up(dir_buf, accum_buf, &window, row, col, &pl, &ll);
+        /* sort lines by length in descending order */
+        qsort(ll.lines, ll.n, sizeof(struct line *), compare_line);
+        if (!ll.n)
+            G_fatal_error(_("Failed to calculate the longest flow path for outlet (%f, %f)"),
+        /* write out the longest flow path */
+        for (n = 0; n < ll.n && ll.lines[n]->length == ll.lines[0]->length;
+             n++) {
+            Vect_reset_cats(Cats);
+            Vect_cat_set(Cats, 1, cat);
+            Vect_write_line(Map, GV_LINE, ll.lines[n]->Points, Cats);
+            if (driver) {
+                char *buf;
+                G_asprintf(&buf, "insert into %s (%s, %s) values (%d, %d)",
+                           Fi->table, Fi->key, id_colname, cat, id[i]);
+                db_set_string(&sql, buf);
+                if (db_execute_immediate(driver, &sql) != DB_OK)
+                    G_fatal_error(_("Unable to create table: %s"),
+                                  db_get_string(&sql));
+                db_free_string(&sql);
+            cat++;
+    free_point_list(&pl);
+    free_line_list(&ll);
+    Vect_destroy_cats_struct(Cats);
+    if (driver) {
+        db_commit_transaction(driver);
+        db_close_database_shutdown_driver(driver);
+static void add_table(struct Map_info *Map, char *id_colname,
+                      dbDriver ** pdriver, struct field_info **pFi)
+    dbDriver *driver;
+    char *buf;
+    dbString sql;
+    Fi = Vect_default_field_info(Map, 1, NULL, GV_1TABLE);
+    driver =
+        db_start_driver_open_database(Fi->driver,
+                                      Vect_subst_var(Fi->database, Map));
+    db_set_error_handler_driver(driver);
+    db_begin_transaction(driver);
+    if (!driver)
+        G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+                      Fi->database, Fi->driver);
+    G_asprintf(&buf, "create table %s (%s integer, %s integer)", Fi->table,
+               Fi->key, id_colname);
+        G_fatal_error(_("Unable to create table: %s"), db_get_string(&sql));
+    if (db_grant_on_table
+        (driver, Fi->table, DB_PRIV_SELECT, DB_GROUP | DB_PUBLIC) != DB_OK)
+        G_fatal_error(_("Unable to grant privileges on table <%s>"),
+                      Fi->table);
+    if (Vect_map_add_dblink
+        (Map, 1, NULL, Fi->table, GV_KEY_COLUMN, Fi->database, Fi->driver))
+        G_fatal_error(_("Unable to add database link for vector map <%s>"),
+                      Vect_get_full_name(Map));
+    *pdriver = driver;
+    *pFi = Fi;
+static int trace_up(struct cell_map *dir_buf, struct raster_map *accum_buf,
+                    struct Cell_head *window, int row, int col,
+                    struct point_list *pl, struct line_list *ll)
+    int rows = dir_buf->rows, cols = dir_buf->cols;
+    double x, y;
+    int i, j, nup;
+    struct neighbor_accum up_accum[8];
+    /* if the current cell is outside the computational region, stop tracing */
+        return 1;
+    /* add the current cell */
+    x = Rast_col_to_easting(col + 0.5, window);
+    y = Rast_row_to_northing(row + 0.5, window);
+    add_point(pl, x, y);
+    /* if the current accumulation is 1 (headwater), stop tracing */
+    if (get(accum_buf, row, col) == 1)
+        return 1;
+    nup = 0;
+    for (i = -1; i <= 1; i++) {
+        /* skip edge cells */
+        if (row + i < 0 || row + i >= rows)
+            continue;
+        for (j = -1; j <= 1; j++) {
+            /* skip the current and edge cells */
+            if ((i == 0 && j == 0) || col + j < 0 || col + j >= cols)
+                continue;
+            /* if a neighbor cell flows into the current cell, store its
+             * accumulation in the accum array */
+            if (dir_buf->c[row + i][col + j] == dir_checks[i + 1][j + 1][0]) {
+                up_accum[nup].row = row + i;
+                up_accum[nup].col = col + j;
+                up_accum[nup++].accum = get(accum_buf, row + i, col + j);
+    if (!nup)
+        G_fatal_error(_("No upstream cells found for a non-headwater cell at (%f, %f)"),
+                      x, y);
+    /* sort upstream cells by accumulation in descending order */
+    qsort(up_accum, nup, sizeof(struct neighbor_accum),
+          compare_neighbor_accum);
+    /* trace up the largest accumulation */
+    for (i = 0; i < nup && up_accum[i].accum == up_accum[0].accum; i++) {
+        /* store pl->n to come back later */
+        int split_pl_n = pl->n;
+        /* if tracing is successful, store the line and its length */
+        if (trace_up
+            (dir_buf, accum_buf, window, up_accum[i].row, up_accum[i].col, pl,
+             ll) && pl->n > 0) {
+            struct line *line = (struct line *)G_malloc(sizeof(struct line));
+            line->Points = Vect_new_line_struct();
+            Vect_copy_xyz_to_pnts(line->Points, pl->x, pl->y, NULL, pl->n);
+            Vect_line_reverse(line->Points);
+            line->length = Vect_line_length(line->Points);
+            add_line(ll, line);
+        /* keep tracing if the next upstream cell has the same largest
+         * accumulation */
+        pl->n = split_pl_n;
+    return 0;
+static int compare_neighbor_accum(const void *a, const void *b)
+    const struct neighbor_accum *ap = (const struct neighbor_accum *)a;
+    const struct neighbor_accum *bp = (const struct neighbor_accum *)b;
+    /* descending by accum */
+    return bp->accum - ap->accum;
+static int compare_line(const void *a, const void *b)
+    const struct line **ap = (const struct line **)a;
+    const struct line **bp = (const struct line **)b;
+    /* descending by length */
+    if ((*ap)->length < (*bp)->length)
+        return 1;
+    if ((*ap)->length > (*bp)->length)
+        return -1;
+    return 0;
Modified: grass-addons/grass7/raster/r.accumulate/delineate_streams.c
--- grass-addons/grass7/raster/r.accumulate/delineate_streams.c	2018-06-25 21:28:53 UTC (rev 72905)
+++ grass-addons/grass7/raster/r.accumulate/delineate_streams.c	2018-06-26 03:08:04 UTC (rev 72906)
@@ -11,16 +11,15 @@
     int row, col;
-    int i, j;
-    char has_thresh_inflow;
     struct line_pnts *Points;
-    int stream_id = 0;
+    int stream_cat = 0;
@@ -27,6 +26,9 @@
     /* loop through all cells to find headwater cells */
     for (row = 0; row < rows; row++) {
         for (col = 0; col < cols; col++) {
+            int i, j;
+            char has_thresh_inflow = 0;
             /* if the current cell is less than the threshold, skip */
             if (get(accum_buf, row, col) < thresh)
                 continue;
@@ -33,8 +35,6 @@
             /* the current cell is greater than the threshold; check if it is
              * headwater (no upstream cells greater than the threshold) */
-            has_thresh_inflow = 0;
@@ -66,7 +66,7 @@
                     Vect_copy_xyz_to_pnts(Points, pl.x, pl.y, NULL, pl.n);
-                    Vect_cat_set(Cats, 1, ++stream_id);
+                    Vect_cat_set(Cats, 1, ++stream_cat);
                     Vect_write_line(Map, GV_LINE, Points, Cats);
@@ -74,6 +74,7 @@
     Vect_destroy_line_struct(Points);
Modified: grass-addons/grass7/raster/r.accumulate/global.h
--- grass-addons/grass7/raster/r.accumulate/global.h	2018-06-25 21:28:53 UTC (rev 72905)
+++ grass-addons/grass7/raster/r.accumulate/global.h	2018-06-26 03:08:04 UTC (rev 72906)
@@ -38,6 +38,18 @@
     double *x, *y;
+struct line
+    struct line_pnts *Points;
+    double length;
+struct line_list
+    int nalloc, n;
+    struct line **lines;
 #ifdef _MAIN_C_
 #define GLOBAL
 #else
@@ -64,6 +76,12 @@
 void free_point_list(struct point_list *);
 void add_point(struct point_list *, double, double);
+/* line_list.c */
+void init_line_list(struct line_list *);
+void reset_line_list(struct line_list *);
+void free_line_list(struct line_list *);
+void add_line(struct line_list *, struct line *);
 /* accumulate.c */
 void accumulate(struct cell_map *, struct raster_map *, struct raster_map *,
                 char **, char);
@@ -72,4 +90,8 @@
 void delineate_streams(struct Map_info *, double, struct cell_map *,
                        struct raster_map *);
+/* calculate_lfp.c */
+void calculate_lfp(struct Map_info *, struct cell_map *, struct raster_map *,
+                   int *, char *, struct point_list *);
 #endif
Added: grass-addons/grass7/raster/r.accumulate/line_list.c
--- grass-addons/grass7/raster/r.accumulate/line_list.c	                        (rev 0)
+++ grass-addons/grass7/raster/r.accumulate/line_list.c	2018-06-26 03:08:04 UTC (rev 72906)
@@ -0,0 +1,43 @@
+#define LINES_INCREMENT 1024
+void init_line_list(struct line_list *ll)
+    ll->nalloc = ll->n = 0;
+    ll->lines = NULL;
+void reset_line_list(struct line_list *ll)
+    free_line_list(ll);
+void free_line_list(struct line_list *ll)
+    if (ll->lines) {
+        int i;
+        for (i = 0; i < ll->n; i++)
+            Vect_destroy_line_struct(ll->lines[i]->Points);
+        G_free(ll->lines);
+    init_line_list(ll);
+/* adapted from r.path */
+void add_line(struct line_list *ll, struct line *l)
+    if (ll->n == ll->nalloc) {
+        ll->nalloc += LINES_INCREMENT;
+        ll->lines =
+            (struct line **)G_realloc(ll->lines,
+                                      ll->nalloc * sizeof(struct line *));
+        if (!ll->lines)
+            G_fatal_error(_("Unable to increase line list"));
+    ll->lines[ll->n] = l;
+    ll->n++;
Modified: grass-addons/grass7/raster/r.accumulate/main.c
--- grass-addons/grass7/raster/r.accumulate/main.c	2018-06-25 21:28:53 UTC (rev 72905)
+++ grass-addons/grass7/raster/r.accumulate/main.c	2018-06-26 03:08:04 UTC (rev 72906)
@@ -5,8 +5,8 @@
  * AUTHOR(S):    Huidae Cho <grass4u gmail.com>
- * PURPOSE:      Calculates weighted flow accumulation and delineates stream
- *               networks using a flow direction map.
+ * PURPOSE:      Calculates weighted flow accumulation, stream networks, and
+ *               the longest flow path using a flow direction map.
  * COPYRIGHT:    (C) 2018 by the GRASS Development Team
@@ -41,6 +41,10 @@
         struct Option *accum;
         struct Option *thresh;
         struct Option *stream;
+        struct Option *lfp;
+        struct Option *coords;
+        struct Option *id_column;
+        struct Option *id;
     } opt;
     struct
@@ -47,7 +51,7 @@
         struct Flag *neg;
     } flag;
     char *desc;
-    char *dir_name, *weight_name, *accum_name, *stream_name;
+    char *dir_name, *weight_name, *accum_name, *stream_name, *lfp_name;
     int dir_fd;
     double dir_format, thresh;
     struct Range dir_range;
@@ -57,8 +61,10 @@
     struct cell_map dir_buf;
     struct raster_map weight_buf, accum_buf;
     int rows, cols, row, col;
-    struct History hist;
     struct Map_info Map;
+    struct point_list outlet_pl;
+    int *id;
+    char *id_colname;
     G_gisinit(argv[0]);
@@ -66,7 +72,7 @@
     G_add_keyword(_("raster"));
     G_add_keyword(_("hydrology"));
     module->description =
-        _("Calculates weighted flow accumulation and delineates stream networks using a flow direction map.");
+        _("Calculates weighted flow accumulation, stream networks, and the longest flow path using a flow direction map.");
     opt.dir = G_define_standard_option(G_OPT_R_INPUT);
     opt.dir->key = "direction";
@@ -107,6 +113,29 @@
     opt.stream->required = NO;
     opt.stream->description = _("Name for output stream vector map");
+    opt.lfp = G_define_standard_option(G_OPT_V_OUTPUT);
+    opt.lfp->key = "longest_flow_path";
+    opt.lfp->required = NO;
+    opt.lfp->description = _("Name for output longest flow path vector map");
+    opt.coords = G_define_standard_option(G_OPT_M_COORDS);
+    opt.coords->multiple = YES;
+    opt.coords->description =
+        _("Coordinates of longest flow path outlet point");
+    opt.id_column = G_define_standard_option(G_OPT_DB_COLUMN);
+    opt.id_column->key = "id_column";
+    opt.id_column->description =
+        _("Name for output longest flow path ID column");
+    opt.id = G_define_option();
+    opt.id->key = "id";
+    opt.id->type = TYPE_INTEGER;
+    opt.id->multiple = YES;
+    opt.id->description = _("ID for longest flow path");
     flag.neg = G_define_flag();
     flag.neg->key = 'n';
     flag.neg->label =
@@ -113,10 +142,14 @@
         _("Use negative flow accumulation for likely underestimates");
     /* weighting doesn't support negative accumulation because weights
-     * themselves can be negative */
-    G_option_exclusive(opt.weight, flag.neg, NULL);
-    G_option_required(opt.accum, opt.stream, NULL);
+     * themselves can be negative; the longest flow path requires positive
+     * non-weighted accumulation */
+    G_option_exclusive(opt.weight, opt.lfp, flag.neg, NULL);
+    G_option_required(opt.accum, opt.stream, opt.lfp, NULL);
     G_option_collective(opt.thresh, opt.stream, NULL);
+    G_option_collective(opt.lfp, opt.coords, NULL);
+    G_option_collective(opt.id_column, opt.id, NULL);
+    G_option_requires(opt.id, opt.coords, NULL);
     if (G_parser(argc, argv))
         exit(EXIT_FAILURE);
@@ -125,6 +158,7 @@
     weight_name = opt.weight->answer;
     accum_name = opt.accum->answer;
     stream_name = opt.stream->answer;
+    lfp_name = opt.lfp->answer;
     dir_fd = Rast_open_old(dir_name, "");
     if (Rast_get_map_type(dir_fd) != CELL_TYPE)
@@ -166,6 +200,35 @@
                       opt.format->answer);
     /* end of r.path */
+    /* read id and outlet */
+    id = NULL;
+    init_point_list(&outlet_pl);
+    if (opt.coords->answers) {
+        int i = 0;
+        while (opt.coords->answers[i]) {
+            add_point(&outlet_pl, atof(opt.coords->answers[i]),
+                      atof(opt.coords->answers[i + 1]));
+            i += 2;
+        if (opt.id->answers) {
+            i = 0;
+            while (opt.id->answers[i])
+                i++;
+            if (i < outlet_pl.n)
+                G_fatal_error(_("Too few longest flow path IDs specified"));
+            if (i > outlet_pl.n)
+                G_fatal_error(_("Too many longest flow path IDs specified"));
+            id = (int *)G_malloc(outlet_pl.n * sizeof(int));
+            i = 0;
+            while (opt.id->answers[i]) {
+                id[i] = atoi(opt.id->answers[i]);
+                i++;
+    id_colname = opt.id_column->answer;
     thresh = opt.thresh->answer ? atof(opt.thresh->answer) : 0.0;
     neg = flag.neg->answer;
@@ -222,6 +285,7 @@
     /* write out buffer to the accumulatoin map if requested */
     if (accum_name) {
         int accum_fd = Rast_open_new(accum_name, accum_buf.type);
+        struct History hist;
             Rast_put_row(accum_fd, accum_buf.map.v[row], accum_buf.type);
@@ -263,6 +327,21 @@
         Vect_close(&Map);
+    /* calculate the longest flow path */
+    if (lfp_name) {
+        if (Vect_open_new(&Map, lfp_name, 0) < 0)
+            G_fatal_error(_("Unable to create vector map <%s>"), lfp_name);
+        Vect_set_map_name(&Map, "Longest flow path");
+        Vect_hist_command(&Map);
+        calculate_lfp(&Map, &dir_buf, &accum_buf, id, id_colname, &outlet_pl);
+        if (!Vect_build(&Map))
+            G_warning(_("Unable to build topology for vector map <%s>"),
+                      lfp_name);
+        Vect_close(&Map);
     /* free buffer memory */
         G_free(dir_buf.c[row]);
Modified: grass-addons/grass7/raster/r.accumulate/r.accumulate.html
--- grass-addons/grass7/raster/r.accumulate/r.accumulate.html	2018-06-25 21:28:53 UTC (rev 72905)
+++ grass-addons/grass7/raster/r.accumulate/r.accumulate.html	2018-06-26 03:08:04 UTC (rev 72906)
@@ -1,7 +1,7 @@
 <h2>DESCRIPTION</h2>
-<em>r.accumulate</em> calculates weighted flow accumulatin and delineates
-stream networks using a flow direction map.
+<em>r.accumulate</em> calculates weighted flow accumulatin, stream networks,
+and the longest flow path using a flow direction map.
 <h2>NOTES</h2>
