[GRASS-SVN] r72907 - grass-addons/grass7/raster/r.accumulate
svn_grass at osgeo.org
Mon Jun 25 21:57:30 PDT 2018
Author: hcho
Date: 2018-06-25 21:57:30 -0700 (Mon, 25 Jun 2018)
New Revision: 72907
grass-addons/grass7/raster/r.accumulate/calculate_lfp.c
grass-addons/grass7/raster/r.accumulate/main.c
r.accumulate: Add outlet, outlet_layer, outlet_id_column options for longest flow path; Deprecating r.lfp python script
Modified: grass-addons/grass7/raster/r.accumulate/calculate_lfp.c
--- grass-addons/grass7/raster/r.accumulate/calculate_lfp.c 2018-06-26 03:08:04 UTC (rev 72906)
+++ grass-addons/grass7/raster/r.accumulate/calculate_lfp.c 2018-06-26 04:57:30 UTC (rev 72907)
@@ -1,5 +1,6 @@
#include <grass/gis.h>
#include <grass/vector.h>
+#include <grass/dbmi.h>
#include <grass/glocale.h>
#include "global.h"
@@ -19,7 +20,7 @@
static int compare_line(const void *, const void *);
void calculate_lfp(struct Map_info *Map, struct cell_map *dir_buf,
- struct raster_map *accum_buf, int *id, char *id_colname,
+ struct raster_map *accum_buf, int *id, char *idcol,
struct point_list *outlet_pl)
struct Cell_head window;
@@ -32,8 +33,8 @@
struct field_info *Fi;
dbString sql;
- if (id_colname) {
- add_table(Map, id_colname, &driver, &Fi);
+ if (idcol) {
+ add_table(Map, idcol, &driver, &Fi);
db_init_string(&sql);
@@ -83,7 +84,7 @@
char *buf;
G_asprintf(&buf, "insert into %s (%s, %s) values (%d, %d)",
- Fi->table, Fi->key, id_colname, cat, id[i]);
+ Fi->table, Fi->key, idcol, cat, id[i]);
db_set_string(&sql, buf);
if (db_execute_immediate(driver, &sql) != DB_OK)
@@ -107,8 +108,8 @@
-static void add_table(struct Map_info *Map, char *id_colname,
- dbDriver ** pdriver, struct field_info **pFi)
+static void add_table(struct Map_info *Map, char *idcol, dbDriver ** pdriver,
+ struct field_info **pFi)
dbDriver *driver;
@@ -128,7 +129,7 @@
Fi->database, Fi->driver);
G_asprintf(&buf, "create table %s (%s integer, %s integer)", Fi->table,
- Fi->key, id_colname);
+ Fi->key, idcol);
Modified: grass-addons/grass7/raster/r.accumulate/main.c
--- grass-addons/grass7/raster/r.accumulate/main.c 2018-06-26 03:08:04 UTC (rev 72906)
+++ grass-addons/grass7/raster/r.accumulate/main.c 2018-06-26 04:57:30 UTC (rev 72907)
@@ -23,6 +23,7 @@
#include <grass/raster.h>
#include "global.h"
@@ -42,9 +43,12 @@
struct Option *thresh;
struct Option *stream;
struct Option *lfp;
+ struct Option *idcol;
struct Option *coords;
- struct Option *id_column;
struct Option *id;
+ struct Option *outlet;
+ struct Option *outlet_layer;
+ struct Option *outlet_idcol;
} opt;
struct
@@ -51,7 +55,8 @@
struct Flag *neg;
} flag;
char *desc;
- char *dir_name, *weight_name, *accum_name, *stream_name, *lfp_name;
+ char *dir_name, *weight_name, *accum_name, *stream_name, *lfp_name,
+ *outlet_name;
int dir_fd;
double dir_format, thresh;
struct Range dir_range;
@@ -64,7 +69,7 @@
struct Map_info Map;
struct point_list outlet_pl;
int *id;
- char *id_colname;
+ char *idcol, *outlet_layer, *outlet_idcol;
G_gisinit(argv[0]);
@@ -118,16 +123,15 @@
opt.lfp->required = NO;
opt.lfp->description = _("Name for output longest flow path vector map");
+ opt.idcol = G_define_standard_option(G_OPT_DB_COLUMN);
+ opt.idcol->key = "id_column";
+ opt.idcol->description = _("Name for output longest flow path ID column");
opt.coords = G_define_standard_option(G_OPT_M_COORDS);
opt.coords->multiple = YES;
opt.coords->description =
_("Coordinates of longest flow path outlet point");
- opt.id_column = G_define_standard_option(G_OPT_DB_COLUMN);
- opt.id_column->key = "id_column";
- opt.id_column->description =
- _("Name for output longest flow path ID column");
opt.id = G_define_option();
opt.id->key = "id";
opt.id->type = TYPE_INTEGER;
@@ -134,8 +138,21 @@
opt.id->multiple = YES;
opt.id->description = _("ID for longest flow path");
+ opt.outlet = G_define_standard_option(G_OPT_V_INPUT);
+ opt.outlet->key = "outlet";
+ opt.outlet->required = NO;
+ opt.outlet->label =
+ _("Name of input outlet vector map for longest flow path");
+ opt.outlet_layer = G_define_standard_option(G_OPT_V_FIELD);
+ opt.outlet_layer->key = "outlet_layer";
+ opt.outlet_layer->label = _("Layer number or name for outlet points");
+ opt.outlet_idcol = G_define_standard_option(G_OPT_DB_COLUMN);
+ opt.outlet_idcol->key = "outlet_id_column";
+ opt.outlet_idcol->description =
+ _("Name of longest flow path ID column in outlet vector map");
flag.neg = G_define_flag();
flag.neg->key = 'n';
flag.neg->label =
@@ -147,9 +164,10 @@
G_option_exclusive(opt.weight, opt.lfp, flag.neg, NULL);
G_option_required(opt.accum, opt.stream, opt.lfp, NULL);
G_option_collective(opt.thresh, opt.stream, NULL);
- G_option_collective(opt.lfp, opt.coords, NULL);
- G_option_collective(opt.id_column, opt.id, NULL);
- G_option_requires(opt.id, opt.coords, NULL);
+ G_option_requires(opt.lfp, opt.coords, opt.outlet, NULL);
+ G_option_requires(opt.idcol, opt.id, opt.outlet_idcol, NULL);
+ G_option_requires_all(opt.id, opt.idcol, opt.coords, NULL);
+ G_option_requires_all(opt.outlet_idcol, opt.idcol, opt.outlet, NULL);
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -159,7 +177,20 @@
accum_name = opt.accum->answer;
stream_name = opt.stream->answer;
lfp_name = opt.lfp->answer;
+ outlet_name = opt.outlet->answer;
+ idcol = opt.idcol->answer;
+ outlet_layer = opt.outlet_layer->answer;
+ outlet_idcol = opt.outlet_idcol->answer;
+ if (opt.id->answers && outlet_name && !outlet_idcol)
+ G_fatal_error(_("Option <%s> must be specified when <%s> and <%s> are present"),
+ opt.outlet_idcol->key, opt.id->key, opt.outlet->key);
+ if (outlet_idcol && opt.coords->answers && !opt.id->answers)
+ opt.id->key, opt.outlet_idcol->key, opt.coords->key);
dir_fd = Rast_open_old(dir_name, "");
if (Rast_get_map_type(dir_fd) != CELL_TYPE)
G_fatal_error(_("Invalid directions map <%s>"), dir_name);
@@ -200,7 +231,7 @@
opt.format->answer);
/* end of r.path */
- /* read id and outlet */
+ /* read outlet coordinates and IDs */
id = NULL;
init_point_list(&outlet_pl);
if (opt.coords->answers) {
@@ -227,8 +258,72 @@
- id_colname = opt.id_column->answer;
+ /* read outlet points and IDs */
+ if (outlet_name) {
+ dbDriver *driver = NULL;
+ struct field_info *Fi;
+ struct line_pnts *Points;
+ struct line_cats *Cats;
+ int field, type;
+ int nlines, line, n;
+ if (Vect_open_old2(&Map, outlet_name, "", outlet_layer) < 0)
+ G_fatal_error(_("Unable to open vector map <%s>"), outlet_name);
+ field = Vect_get_field_number(&Map, outlet_layer);
+ type = Vect_get_num_dblinks(&Map) > 1 ? GV_MTABLE : GV_1TABLE;
+ if (outlet_idcol) {
+ Fi = Vect_default_field_info(&Map, field, NULL, type);
+ driver =
+ db_start_driver_open_database(Fi->driver,
+ Vect_subst_var(Fi->database,
+ &Map));
+ if (db_column_Ctype(driver, Fi->table, outlet_idcol) !=
+ DB_C_TYPE_INT)
+ G_fatal_error(_("Column <%s> in vector map <%s> must be of integer"),
+ outlet_idcol, outlet_name);
+ Points = Vect_new_line_struct();
+ Cats = Vect_new_cats_struct();
+ nlines = Vect_get_num_lines(&Map);
+ id = (int *)G_realloc(id, (outlet_pl.n + nlines) * sizeof(int));
+ n = outlet_pl.n;
+ for (line = 1; line <= nlines; line++) {
+ int ltype, cat;
+ ltype = Vect_read_line(&Map, Points, Cats, line);
+ Vect_cat_get(Cats, field, &cat);
+ if (ltype != GV_POINT || cat < 0)
+ continue;
+ add_point(&outlet_pl, Points->x[0], Points->y[0]);
+ if (driver) {
+ dbValue val;
+ db_select_value(driver, Fi->table, Fi->key, cat, outlet_idcol,
+ &val);
+ id[n++] = db_get_value_int(&val);
+ if (driver)
+ db_close_database_shutdown_driver(driver);
+ Vect_close(&Map);
+ if (n < outlet_pl.n)
+ G_fatal_error(_("Too few longest flow path IDs specified"));
+ if (n > outlet_pl.n)
+ G_fatal_error(_("Too many longest flow path IDs specified"));
thresh = opt.thresh->answer ? atof(opt.thresh->answer) : 0.0;
neg = flag.neg->answer;
@@ -334,7 +429,7 @@
Vect_set_map_name(&Map, "Longest flow path");
Vect_hist_command(&Map);
- calculate_lfp(&Map, &dir_buf, &accum_buf, id, id_colname, &outlet_pl);
+ calculate_lfp(&Map, &dir_buf, &accum_buf, id, idcol, &outlet_pl);
if (!Vect_build(&Map))
G_warning(_("Unable to build topology for vector map <%s>"),
