[GRASS-SVN] r72932 - grass-addons/grass7/raster/r.accumulate
svn_grass at osgeo.org
Fri Jun 29 08:23:06 PDT 2018
Author: hcho
Date: 2018-06-29 08:23:06 -0700 (Fri, 29 Jun 2018)
New Revision: 72932
grass-addons/grass7/raster/r.accumulate/r.accumulate.html
grass-addons/grass7/raster/r.accumulate/r_accumulate_nc_lfp_example_multiple.png
r.accumulate: Update examples with complete scripts
Modified: grass-addons/grass7/raster/r.accumulate/r.accumulate.html
--- grass-addons/grass7/raster/r.accumulate/r.accumulate.html 2018-06-29 06:17:46 UTC (rev 72931)
+++ grass-addons/grass7/raster/r.accumulate/r.accumulate.html 2018-06-29 15:23:06 UTC (rev 72932)
@@ -109,6 +109,13 @@
<p>Calculate flow accumulation and delineate stream networks at once:
<div class="code"><pre>
+# set computational region
+g.region raster=elevation -p
+# calculate positive flow accumulation and drainage directions using r.watershed
+# for comparison, use -s (SFD)
+r.watershed elevation=elevation accumulation=flow_accum drainage=drain_directions -s -a
# use r.accumulate to create flow_accum_new and streams_new at once
r.accumulate direction=drain_directions accumulation=flow_accum_new threshold=50000 stream=streams_new
@@ -139,6 +146,12 @@
<p>Create the longest flow path for one outlet:
+# calculate drainage directions using r.watershed
+r.watershed elevation=elevation drainage=drain_directions -s -a
# delineate watershed
r.water.outlet input=drain_directions output=basin coordinates=642455,222614
@@ -154,6 +167,12 @@
<p>There are different ways to calculate multiple longest flow paths in one run:
# calculate longest flow paths at two outlets
r.accumulate direction=drain_directions lfp=lfp coordinates=642455,222614,642306,222734
@@ -175,6 +194,12 @@
<p>Calculate the longest flow paths for sub-watersheds:
# get nsres
eval `r.info -g map=elevation`
Modified: grass-addons/grass7/raster/r.accumulate/r_accumulate_nc_lfp_example_multiple.png
(Binary files differ)
