[GRASS-SVN] r72933 - in grass-addons/grass7/raster/r.green: libgreen r.green.biomassfor/libforest r.green.biomassfor/r.green.biomassfor.co2 r.green.biomassfor/r.green.biomassfor.financial r.green.biomassfor/r.green.biomassfor.impact r.green.biomassfor/r.green.biomassfor.legal r.green.biomassfor/r.green.biomassfor.recommended r.green.biomassfor/r.green.biomassfor.technical r.green.biomassfor/r.green.biomassfor.theoretical r.green.gshp/libgshp r.green.gshp/libgshp/testsuite r.green.gshp/r.green.gshp.technical r.green.gshp/r.green.gshp.theoretical r.green.hydro/libhydro r.green.hydro/r.green.hydro.closest r.green.hydro/r.green.hydro.delplants r.green.hydro/r.green.hydro.discharge r.green.hydro/r.green.hydro.financial r.green.hydro/r.green.hydro.optimal r.green.hydro/r.green.hydro.planning r.green.hydro/r.green.hydro.recommended r.green.hydro/r.green.hydro.structure r.green.hydro/r.green.hydro.technical r.green.hydro/r.green.hydro.theoretical r.green.install
Fri Jun 29 08:24:12 PDT 2018
Author: zarch
Date: 2018-06-29 08:24:12 -0700 (Fri, 29 Jun 2018)
New Revision: 72933
   grass-addons/grass7/raster/r.green/libgreen/checkparameter.py
   grass-addons/grass7/raster/r.green/libgreen/utils.py
   grass-addons/grass7/raster/r.green/r.green.biomassfor/libforest/financial.py
   grass-addons/grass7/raster/r.green/r.green.biomassfor/libforest/harvesting.py
   grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.co2/r.green.biomassfor.co2.py
   grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.financial/r.green.biomassfor.financial.py
   grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.impact/r.green.biomassfor.impact.py
   grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.legal/r.green.biomassfor.legal.py
   grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.recommended/r.green.biomassfor.recommended.py
   grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.technical/biomasfor.technical.py
   grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.technical/r.green.biomassfor.technical.py
   grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.theoretical/r.green.biomassfor.theoretical.py
   grass-addons/grass7/raster/r.green/r.green.gshp/libgshp/ashrae.py
   grass-addons/grass7/raster/r.green/r.green.gshp/libgshp/testsuite/test_gpot.py
   grass-addons/grass7/raster/r.green/r.green.gshp/r.green.gshp.technical/r.green.gshp.technical.py
   grass-addons/grass7/raster/r.green/r.green.gshp/r.green.gshp.theoretical/r.green.gshp.theoretical.py
   grass-addons/grass7/raster/r.green/r.green.hydro/libhydro/basin.py
   grass-addons/grass7/raster/r.green/r.green.hydro/libhydro/optimal.py
   grass-addons/grass7/raster/r.green/r.green.hydro/libhydro/plant.py
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.closest/r.green.hydro.closest.py
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.delplants/r.green.hydro.delplants.py
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.discharge/r.green.hydro.discharge.py
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.financial/r.green.hydro.financial.py
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.optimal/r.green.hydro.optimal.py
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.planning/r.green.hydro.planning.py
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.recommended/r.green.hydro.recommended.py
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.structure/r.green.hydro.structure.py
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.py
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical/r.green.hydro.theoretical.py
   grass-addons/grass7/raster/r.green/r.green.install/r.green.install.py
Sort python imports
Modified: grass-addons/grass7/raster/r.green/libgreen/checkparameter.py
--- grass-addons/grass7/raster/r.green/libgreen/checkparameter.py	2018-06-29 15:23:06 UTC (rev 72932)
+++ grass-addons/grass7/raster/r.green/libgreen/checkparameter.py	2018-06-29 15:24:12 UTC (rev 72933)
@@ -1,8 +1,8 @@
 # -*- coding: utf-8 -*-
 from grass.exceptions import ParameterError
+from grass.pygrass.messages import get_msgr
+from grass.pygrass.raster import RasterRow
 from grass.pygrass.vector import VectorTopo
-from grass.pygrass.raster import RasterRow
-from grass.pygrass.messages import get_msgr
 def check_required_columns(vname, layer, reqcols, pname):
Modified: grass-addons/grass7/raster/r.green/libgreen/utils.py
--- grass-addons/grass7/raster/r.green/libgreen/utils.py	2018-06-29 15:23:06 UTC (rev 72932)
+++ grass-addons/grass7/raster/r.green/libgreen/utils.py	2018-06-29 15:24:12 UTC (rev 72933)
@@ -1,15 +1,18 @@
-import numpy as np
 import os
-#import pdb
+import numpy as np
+from grass.pygrass.gis.region import Region
+from grass.pygrass.raster.buffer import Buffer
+from grass.script import core as gcore
 # import grass libraries
 from grass.script import mapcalc
-from grass.script import core as gcore
-from grass.pygrass.raster.buffer import Buffer
-from grass.pygrass.gis.region import Region
+#import pdb
 try:
     from scipy.sparse import csr_matrix
 except ImportError:
Modified: grass-addons/grass7/raster/r.green/r.green.biomassfor/libforest/financial.py
--- grass-addons/grass7/raster/r.green/r.green.biomassfor/libforest/financial.py	2018-06-29 15:23:06 UTC (rev 72932)
+++ grass-addons/grass7/raster/r.green/r.green.biomassfor/libforest/financial.py	2018-06-29 15:24:12 UTC (rev 72933)
@@ -13,9 +13,9 @@
 import os
-from grass.script.core import find_file
-from grass.script.core import run_command
 from grass.pygrass.modules.shortcuts import raster as r
+from grass.script.core import find_file, run_command
 def revenues(opts, yield_surface, m1t1, m1t2, m1, m2,
Modified: grass-addons/grass7/raster/r.green/r.green.biomassfor/libforest/harvesting.py
--- grass-addons/grass7/raster/r.green/r.green.biomassfor/libforest/harvesting.py	2018-06-29 15:23:06 UTC (rev 72932)
+++ grass-addons/grass7/raster/r.green/r.green.biomassfor/libforest/harvesting.py	2018-06-29 15:24:12 UTC (rev 72933)
@@ -14,11 +14,12 @@
 import os
 import numpy as np
+from grass.pygrass.modules.shortcuts import raster as r
-from grass.pygrass.modules.shortcuts import raster as r
 def combination(management, treatment):
Modified: grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.co2/r.green.biomassfor.co2.py
--- grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.co2/r.green.biomassfor.co2.py	2018-06-29 15:23:06 UTC (rev 72932)
+++ grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.co2/r.green.biomassfor.co2.py	2018-06-29 15:24:12 UTC (rev 72933)
@@ -251,14 +251,15 @@
 #% description: Remove all operational maps
 #%end
+import pdb
+import numpy as np
 import grass.script as grass
-from grass.script.core import run_command, parser,overwrite, read_command
-import numpy as np
-import pdb
+from grass.script.core import overwrite, parser, read_command, run_command
 ow = overwrite()
Modified: grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.financial/r.green.biomassfor.financial.py
--- grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.financial/r.green.biomassfor.financial.py	2018-06-29 15:23:06 UTC (rev 72932)
+++ grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.financial/r.green.biomassfor.financial.py	2018-06-29 15:24:12 UTC (rev 72933)
@@ -344,13 +344,13 @@
 #% guisection: Output maps
 #%end
-from grass.script.core import run_command, parser, warning
+import atexit
+import os
-from grass.pygrass.utils import set_path
+from grass.script.core import parser, run_command, warning
+from grass.script.utils import set_path
-import os
-import atexit
 try:
     # set python path to the shared r.green libraries
     set_path('r.green', 'libforest', '..')
Modified: grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.impact/r.green.biomassfor.impact.py
--- grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.impact/r.green.biomassfor.impact.py	2018-06-29 15:23:06 UTC (rev 72932)
+++ grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.impact/r.green.biomassfor.impact.py	2018-06-29 15:24:12 UTC (rev 72933)
@@ -375,14 +375,15 @@
 #%end
+import pdb
+import numpy as np
-import numpy as np
-import pdb
 ow = overwrite()
Modified: grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.legal/r.green.biomassfor.legal.py
--- grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.legal/r.green.biomassfor.legal.py	2018-06-29 15:23:06 UTC (rev 72932)
+++ grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.legal/r.green.biomassfor.legal.py	2018-06-29 15:24:12 UTC (rev 72933)
@@ -93,13 +93,12 @@
 #% guisection: Energy
 #%end
-from grass.script.core import run_command, parser, overwrite
 import numpy as np
+from grass.script.core import overwrite, parser, run_command
 def main(opts, flgs):
     ow = overwrite()
Modified: grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.recommended/r.green.biomassfor.recommended.py
--- grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.recommended/r.green.biomassfor.recommended.py	2018-06-29 15:23:06 UTC (rev 72932)
+++ grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.recommended/r.green.biomassfor.recommended.py	2018-06-29 15:24:12 UTC (rev 72933)
@@ -100,12 +100,14 @@
 #%end
-import numpy as np
+import pdb
 import string
-import pdb
+import numpy as np
 #check_var checks the presence/absence of the input maps
 check_var=0
Modified: grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.technical/biomasfor.technical.py
--- grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.technical/biomasfor.technical.py	2018-06-29 15:23:06 UTC (rev 72932)
+++ grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.technical/biomasfor.technical.py	2018-06-29 15:24:12 UTC (rev 72933)
@@ -110,10 +110,8 @@
 #% key: u
 #% description: technical bioenergy can be considered to be spread uniformly over the entire surface or to be concentrated in accessible areas.
 #%end
 #CCEXTR = 'cable_crane_extraction = if(yield>0 && slope>%f && slope<=%f && extr_dist<%f, 1)'
 #FWEXTR = 'forwarder_extraction = if(yield>0 && slope<=%f && management==1 && (roughness==0 || roughness==1 || roughness==99999) && extr_dist<%f, 1)'
 #OEXTR = 'other_extraction = if(yield>0 && slope<=%f && management==2 && (roughness==0 || roughness==1 || roughness==99999) && extr_dist<%f, 1)'
Modified: grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.technical/r.green.biomassfor.technical.py
--- grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.technical/r.green.biomassfor.technical.py	2018-06-29 15:23:06 UTC (rev 72932)
+++ grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.technical/r.green.biomassfor.technical.py	2018-06-29 15:24:12 UTC (rev 72933)
@@ -185,12 +185,12 @@
 #%end
+import numpy as np
-from grass.script.core import run_command, parser, overwrite, parse_command
-import numpy as np
+from grass.script.core import overwrite, parse_command, parser, run_command
 YPIX = 'yield_pix = yield_pix1*%d + yield_pix2*%d'
Modified: grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.theoretical/r.green.biomassfor.theoretical.py
--- grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.theoretical/r.green.biomassfor.theoretical.py	2018-06-29 15:23:06 UTC (rev 72932)
+++ grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.theoretical/r.green.biomassfor.theoretical.py	2018-06-29 15:24:12 UTC (rev 72933)
@@ -93,13 +93,12 @@
 #%end
 import numpy as np
     ow = overwrite()
Modified: grass-addons/grass7/raster/r.green/r.green.gshp/libgshp/ashrae.py
--- grass-addons/grass7/raster/r.green/r.green.gshp/libgshp/ashrae.py	2018-06-29 15:23:06 UTC (rev 72932)
+++ grass-addons/grass7/raster/r.green/r.green.gshp/libgshp/ashrae.py	2018-06-29 15:24:12 UTC (rev 72933)
@@ -10,13 +10,10 @@
 from numpy import log, pi
-# import grass libraries
+from grass.pygrass.utils import get_mapset_raster
 from grass.script import raster as grast
-from grass.pygrass.utils import get_mapset_raster
 BASENAME = 'tmprgreen{pid:05d}_'.format(pid=getpid())
 # Coefficients for Tp correlation
Modified: grass-addons/grass7/raster/r.green/r.green.gshp/libgshp/testsuite/test_gpot.py
--- grass-addons/grass7/raster/r.green/r.green.gshp/libgshp/testsuite/test_gpot.py	2018-06-29 15:23:06 UTC (rev 72932)
+++ grass-addons/grass7/raster/r.green/r.green.gshp/libgshp/testsuite/test_gpot.py	2018-06-29 15:24:12 UTC (rev 72933)
@@ -5,18 +5,19 @@
 from __future__ import (absolute_import, division, generators, nested_scopes,
                         print_function, unicode_literals, with_statement)
 import os
 from numpy.testing import assert_almost_equal
+import gpot as gpot
 from grass.gunittest.case import TestCase
+from grass.gunittest.gmodules import call_module
 from grass.gunittest.main import test
-from grass.gunittest.gmodules import call_module
+# Start testing the library
-import gpot as gpot
 # Define value and results to be tested as scalar and as raster
 GRND_CONDUCTIVITY = [2.17, 2.48, 2.66, 3.39, 4.13, 4.87]
@@ -45,9 +46,6 @@
 GROUT_CONDUCTIVITY = 2.
-# Start testing the library
 def assert_raster_no_difference(reference, actual, precision):
Modified: grass-addons/grass7/raster/r.green/r.green.gshp/r.green.gshp.technical/r.green.gshp.technical.py
--- grass-addons/grass7/raster/r.green/r.green.gshp/r.green.gshp.technical/r.green.gshp.technical.py	2018-06-29 15:23:06 UTC (rev 72932)
+++ grass-addons/grass7/raster/r.green/r.green.gshp/r.green.gshp.technical/r.green.gshp.technical.py	2018-06-29 15:24:12 UTC (rev 72933)
@@ -1,4 +1,4 @@
-#!/usr/bin/env python
+#!/usr/bin/env python2
@@ -289,13 +289,12 @@
 from __future__ import print_function
+import atexit
 import os
 import sys
-import atexit
 try:
Modified: grass-addons/grass7/raster/r.green/r.green.gshp/r.green.gshp.theoretical/r.green.gshp.theoretical.py
--- grass-addons/grass7/raster/r.green/r.green.gshp/r.green.gshp.theoretical/r.green.gshp.theoretical.py	2018-06-29 15:23:06 UTC (rev 72932)
+++ grass-addons/grass7/raster/r.green/r.green.gshp/r.green.gshp.theoretical/r.green.gshp.theoretical.py	2018-06-29 15:24:12 UTC (rev 72933)
@@ -1,4 +1,4 @@
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/libhydro/basin.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/libhydro/basin.py	2018-06-29 15:23:06 UTC (rev 72932)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/libhydro/basin.py	2018-06-29 15:24:12 UTC (rev 72933)
@@ -14,21 +14,26 @@
+import itertools
+import math
 # import system libraries
 import os
 import numpy as np
-import itertools
-import math
-#import pdb
+# finally import the module in the library
+from libgreen.utils import (dissolve_lines, get_coo, raster2compressM,
+                            raster2numpy)
+#import pdb
 try:
     from scipy import integrate
 except ImportError:
@@ -37,11 +42,6 @@
 set_path('r.green', 'libhydro', '..')
 set_path('r.green', 'libgreen', os.path.join('..', '..'))
-# finally import the module in the library
-from libgreen.utils import dissolve_lines
-from libgreen.utils import raster2numpy
-from libgreen.utils import raster2compressM
-from libgreen.utils import get_coo
 def discharge_sum(list_basin, list_ID):
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/libhydro/optimal.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/libhydro/optimal.py	2018-06-29 15:23:06 UTC (rev 72932)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/libhydro/optimal.py	2018-06-29 15:24:12 UTC (rev 72933)
@@ -6,18 +6,26 @@
+import math
 import os
 import sys
 import numpy as np
-import math
+#from grass.pygrass.raster.buffer import Buffer
+from grass.pygrass.vector import VectorTopo
+from libhydro.plant import COLS, COLS_points, Intake, Plant, Restitution
 #from grass.script import mapcalc
 version = 70  # 71
 # import scientific libraries
 try:
@@ -28,21 +36,11 @@
     gcore.warning('You should install scipy to use this module: '
                   'pip install scipy')
-#from grass.pygrass.raster.buffer import Buffer
-from grass.pygrass.vector import VectorTopo
-from libhydro.plant import Plant
-from libhydro.plant import Intake
-from libhydro.plant import Restitution
-from libhydro.plant import COLS
-from libhydro.plant import COLS_points
 def f(x, *params):
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/libhydro/plant.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/libhydro/plant.py	2018-06-29 15:23:06 UTC (rev 72932)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/libhydro/plant.py	2018-06-29 15:24:12 UTC (rev 72933)
@@ -1,19 +1,18 @@
+import os
 import random
-import os
 from collections import namedtuple
 import numpy as np
+from grass.pygrass import utils
 from grass.pygrass.vector.geometry import Line
 from grass.pygrass.vector.table import Link
-from grass.pygrass import utils
 COLS = [(u'cat',       'INTEGER PRIMARY KEY'),
         (u'plant_id',  'VARCHAR(10)'),
         (u'stream_id',  'INTEGER'),
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.closest/r.green.hydro.closest.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.closest/r.green.hydro.closest.py	2018-06-29 15:23:06 UTC (rev 72932)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.closest/r.green.hydro.closest.py	2018-06-29 15:24:12 UTC (rev 72933)
@@ -44,12 +44,10 @@
 import os
 import sys
 if "GISBASE" not in os.environ:
     print("You must be in GRASS GIS to run this program.")
     sys.exit(1)
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.delplants/r.green.hydro.delplants.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.delplants/r.green.hydro.delplants.py	2018-06-29 15:23:06 UTC (rev 72932)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.delplants/r.green.hydro.delplants.py	2018-06-29 15:24:12 UTC (rev 72933)
@@ -94,19 +94,18 @@
 #%end
+import atexit
 # import stadard libraries
 import os
-import atexit
 # import GRASS libraries
-from grass.script.core import parser, overwrite, warning
+from grass.pygrass.modules.shortcuts import vector as v
-from grass.pygrass.modules.shortcuts import vector as v
+from grass.script.core import overwrite, parser, warning
 try:
@@ -136,7 +135,7 @@
     rother = ['kind_label', 'discharge', 'id_point', 'id_plant']
     ovwr = overwrite()
-    try:
+    try:
         hydro = check_required_columns(opts['hydro'], int(opts['hydro_layer']),
                                        rhydro, 'hydro')
         if opts['other']:
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.discharge/r.green.hydro.discharge.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.discharge/r.green.hydro.discharge.py	2018-06-29 15:23:06 UTC (rev 72932)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.discharge/r.green.hydro.discharge.py	2018-06-29 15:24:12 UTC (rev 72933)
@@ -160,18 +160,20 @@
 #% answer: 100000
 #%END
+import atexit
 import os
 import sys
-import atexit
-#import pdb
+#import pdb
 try:
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.financial/r.green.hydro.financial.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.financial/r.green.hydro.financial.py	2018-06-29 15:23:06 UTC (rev 72932)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.financial/r.green.hydro.financial.py	2018-06-29 15:24:12 UTC (rev 72933)
@@ -485,7 +485,7 @@
 ## VALUES
 #%option G_OPT_R_OUTPUT
 #%  key: upper
-#%  label: Output raster map with the value upper part of the soil
+#%  label: Output raster map with the value upper part of the soil
 #%  required: no
 #%end
@@ -492,23 +492,23 @@
+import atexit
 import os
 import sys
-import atexit
 import numpy as np
-from grass.script.core import parser, overwrite, warning, run_command
+from grass.pygrass.vector import geometry as geo
 from grass.pygrass.vector import VectorTopo, sql
 from grass.pygrass.vector.basic import Cats
-from grass.pygrass.vector import geometry as geo
+from grass.script.core import overwrite, parser, run_command, warning
 version = 70  # 71
@@ -601,7 +601,7 @@
 def get_cnames(expr,
                _names_cache=ne.utils.CacheDict(256) if ne else ne,
-               _numexpr_cache=ne.utils.CacheDict(256) if ne else ne,
+               _numexpr_cache=ne.utils.CacheDict(256) if ne else ne,
                **kwargs):
     if not isinstance(expr, (str, unicode)):
         raise ValueError("must specify expression as a string")
@@ -811,7 +811,7 @@
                         category.reset()
                         category.set(ncat, loutput)
                         # write geometry
-                        vout.write(line)
+                        vout.write(line, set_cats=False)
                 ncat += 1
             vout.table.conn.commit()
@@ -921,9 +921,9 @@
     comp = opts['compensation'] if opts['compensation'] else ('tmprgreen_%i_compensation' % pid)
     exc = opts['excavation'] if opts['excavation'] else ('tmprgreen_%i_excavation' % pid)
     vlayer = int(opts['struct_layer'])
     plant, mset = (opts['plant'].split('@') if '@' in opts['plant'] else (opts['plant'], ''))
     struct, mset = (opts['struct'].split('@') if '@' in opts['struct'] else (opts['struct'], ''))
     # read common scalar parameters
@@ -1089,18 +1089,18 @@
                          eco_layer=1, seg_layer=int(opts['plant_layer']),
                          eco_pid=opts['struct_column_id'],
                          seg_pid=opts['plant_column_id'],
-                         function=max_NPV,
-                         exclude=['intake_id', 'side', 'power',
+                         function=max_NPV,
+                         exclude=['intake_id', 'side', 'power',
                                   'gross_head', 'discharge'])
-    vec = VectorTopo(opts['output_struct'])
+    vec = VectorTopo(opts['output_struct'])
     vec.open('rw')
     vec.table.columns.add('max_NPV','VARCHAR(3)')
-    list_intakeid=list(set(vec.table.execute('SELECT intake_id FROM %s' %vec.table.name).fetchall()))
-    for i in range(0,len(list_intakeid)):
-        vec.rewind()
+    list_intakeid=list(set(vec.table.execute('SELECT intake_id FROM %s' %vec.table.name).fetchall()))
+    for i in range(0,len(list_intakeid)):
+        vec.rewind()
         list_npv=list(vec.table.execute('SELECT NPV FROM %s WHERE intake_id=%i;' % (vec.table.name, list_intakeid[i][0])).fetchall())
         npvmax=max(list_npv)[0]
         for line in vec:
@@ -1110,7 +1110,7 @@
                 else:
                     line.attrs['max_NPV']='no'
-    vec.table.conn.commit()
+    vec.table.conn.commit()
     vec.close()
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.optimal/r.green.hydro.optimal.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.optimal/r.green.hydro.optimal.py	2018-06-29 15:23:06 UTC (rev 72932)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.optimal/r.green.hydro.optimal.py	2018-06-29 15:24:12 UTC (rev 72933)
@@ -99,13 +99,11 @@
 import os
 import sys
 try:
@@ -166,7 +164,7 @@
     c = flags['c']
     msgr = get_msgr()
     #import ipdb; ipdb.set_trace()
     if c:
         msgr.message("\Clean rivers\n")
         TMPVECT = [("tmprgreen_%i_cleanb" % os.getpid())]
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.planning/r.green.hydro.planning.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.planning/r.green.hydro.planning.py	2018-06-29 15:23:06 UTC (rev 72932)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.planning/r.green.hydro.planning.py	2018-06-29 15:24:12 UTC (rev 72933)
@@ -186,25 +186,25 @@
 #%end
 #%rules
-#%exclusive: mfd, discharge_natural
-#%exclusive: mfd, percentage
-#%requires: discharge_natural, percentage
+#%exclusive: mfd, discharge_natural
+#%exclusive: mfd, percentage
+#%requires: discharge_natural, percentage
 #%end
+import atexit
 import os
 import sys
-import atexit
+# import grass libraries
 try:
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.recommended/r.green.hydro.recommended.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.recommended/r.green.hydro.recommended.py	2018-06-29 15:23:06 UTC (rev 72932)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.recommended/r.green.hydro.recommended.py	2018-06-29 15:24:12 UTC (rev 72933)
 #%end
 #%rules
 #%end
+import atexit
 import os
 import sys
-import atexit
 try:
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.structure/r.green.hydro.structure.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.structure/r.green.hydro.structure.py	2018-06-29 15:23:06 UTC (rev 72932)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.structure/r.green.hydro.structure.py	2018-06-29 15:24:12 UTC (rev 72933)
@@ -129,15 +129,17 @@
 #%end
+import atexit
 import os
-import atexit
+from libgreen.checkparameter import check_required_columns, exception2error
+from libhydro.optimal import conv_segpoints
+from libhydro.plant import read_plants, write_structures
 try:
@@ -151,9 +153,6 @@
     except ImportError:
         warning('libgreen and libhydro not in the python path!')
-from libhydro.optimal import conv_segpoints
-from libgreen.checkparameter import check_required_columns, exception2error
-from libhydro.plant import read_plants, write_structures
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.py	2018-06-29 15:23:06 UTC (rev 72932)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.py	2018-06-29 15:24:12 UTC (rev 72933)
@@ -220,19 +220,19 @@
+import atexit
 import os
 import sys
-import atexit
+from math import acos, asin, log10, pi, sin, sqrt
+import numpy as np
-from math import pi, log10, sin, acos, asin, sqrt
 try:
     from scipy.optimize import fsolve
 except ImportError:
@@ -239,7 +239,6 @@
-import numpy as np
 try:
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical/r.green.hydro.theoretical.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical/r.green.hydro.theoretical.py	2018-06-29 15:23:06 UTC (rev 72932)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical/r.green.hydro.theoretical.py	2018-06-29 15:24:12 UTC (rev 72933)
@@ -90,15 +90,14 @@
+import atexit
 import os
 import sys
-import atexit
 try:
@@ -151,7 +150,7 @@
     lakes = options['lakes']  # vec
     E = options['output']
     threshold = options['threshold']
     # existing plants
 #    segments = options['segments']
 #    output_segm = options['output_segm']
@@ -174,7 +173,7 @@
     if rivers:
         # cp the vector in the current mapset in order to clean it
-        tmp_river = "tmprgreen_%i_river" % pid
+        tmp_river = "tmprgreen_%i_river" % pid
         to_copy = '%s,%s' % (rivers, tmp_river)
         gcore.run_command('g.copy', vector=to_copy)
         rivers = tmp_river
Modified: grass-addons/grass7/raster/r.green/r.green.install/r.green.install.py
--- grass-addons/grass7/raster/r.green/r.green.install/r.green.install.py	2018-06-29 15:23:06 UTC (rev 72932)
+++ grass-addons/grass7/raster/r.green/r.green.install/r.green.install.py	2018-06-29 15:24:12 UTC (rev 72933)
@@ -30,29 +30,25 @@
+import imp
 import os
-from os.path import join
-from urllib2 import build_opener
+import platform
+import shutil
+import subprocess
 import sys
-import imp
-from tempfile import gettempdir
 import time
-import subprocess
-import shutil
-from HTMLParser import HTMLParser
-from htmlentitydefs import name2codepoint
 import urllib2
 import xml.etree.ElementTree as ET
-import platform
+from htmlentitydefs import name2codepoint
+from HTMLParser import HTMLParser
+from os.path import join
+from tempfile import gettempdir
+from urllib2 import build_opener
 Pkg = namedtuple('Pkg', ['name', 'version', 'py', 'un', 'platform'])
