[GRASS-SVN] r72934 - grass-addons/grass7/raster/r.accumulate
Fri Jun 29 08:27:16 PDT 2018
Author: hcho
Date: 2018-06-29 08:27:16 -0700 (Fri, 29 Jun 2018)
New Revision: 72934
   grass-addons/grass7/raster/r.accumulate/r.accumulate.html
r.accumulate: Update examples with complete scripts
Modified: grass-addons/grass7/raster/r.accumulate/r.accumulate.html
--- grass-addons/grass7/raster/r.accumulate/r.accumulate.html	2018-06-29 15:24:12 UTC (rev 72933)
+++ grass-addons/grass7/raster/r.accumulate/r.accumulate.html	2018-06-29 15:27:16 UTC (rev 72934)
@@ -177,18 +177,18 @@
 r.accumulate direction=drain_directions lfp=lfp coordinates=642455,222614,642306,222734
 # calculate longest flow paths at two outlets and assign IDs
-r.accumulate direction=drain_directions lfp=lfp coordinates=642455,222614,642306,222734 \
+r.accumulate direction=drain_directions lfp=lfp_w_id coordinates=642455,222614,642306,222734 \
     id=1,2 id_column=lfp_id
 # calculate longest flow paths at all points in the outlets map
-r.accumulate direction=drain_directions lfp=lfp outlet=outlets
+r.accumulate direction=drain_directions lfp=lfp_at_outlets outlet=outlets
 # calculate longest flow paths at all points in the outlets map and assign IDs using a column in this map
-r.accumulate direction=drain_directions lfp=lfp outlet=outlets \
+r.accumulate direction=drain_directions lfp=lfp_at_outlets_w_id outlet=outlets \
     id_column=lfp_id outlet_id_column=outlet_id
 # calculate longest flow paths at given coordinates and all points in the outlets map and assign IDs
-r.accumulate direction=drain_directions lfp=lfp coordinates=642455,222614,642306,222734 outlet=outlets \
+r.accumulate direction=drain_directions lfp=lfp_multi_wi_id coordinates=642455,222614,642306,222734 outlet=outlets \
     id=1,2 id_column=lfp_id outlet_id_column=outlet_id
 </pre></div>
