[GRASS-SVN] r72364 - in grass/trunk: imagery/i.ortho.photo/i.ortho.transform misc/m.transform
Wed Mar 14 03:57:02 PDT 2018
Author: mmetz
Date: 2018-03-14 03:57:02 -0700 (Wed, 14 Mar 2018)
New Revision: 72364
   grass/trunk/imagery/i.ortho.photo/i.ortho.transform/i.ortho.transform.html
   grass/trunk/misc/m.transform/m.transform.html
m.transform/i.ortho.transform: update manuals
Modified: grass/trunk/imagery/i.ortho.photo/i.ortho.transform/i.ortho.transform.html
--- grass/trunk/imagery/i.ortho.photo/i.ortho.transform/i.ortho.transform.html	2018-03-13 13:55:46 UTC (rev 72363)
+++ grass/trunk/imagery/i.ortho.photo/i.ortho.transform/i.ortho.transform.html	2018-03-14 10:57:02 UTC (rev 72364)
@@ -3,52 +3,27 @@
 <em>i.ortho.transform</em> is an utility to compute transformation
 based upon GCPs and output error measurements.
+<p>
+If coordinates are given with the <b>input</b> file option or fed from
+<tt>stdin</tt>, both the input and the output format is "x y z" with one
+coordinate pair per line. Reverse transform is performed with the
+<b>-r</b> flag.
-<h2>NOTES</h2>
+<p>
+The <b>format</b> option determines how control points are printed out.
+A summary on the control points can be printed with the <b>-s</b> flag.
+The summary includes maximum deviation observed when transforming GCPs
+and overall RMS. The <b>format</b> option is ignored when coordinates
+are given with the <b>input</b> file option.
-For coordinates given with the <b>coords</b> file option or fed from
-<tt>stdin</tt>, the input format is "x y z" with one coordinate pair per
-line.
-<p>The transformations are:
-<p>order=1:
-<div class="code"><pre>
-    e = [E0 E1][1].[1]
-        [E2  0][e] [n]
-    n = [N0 N1][1].[1]
-        [N2  0][e] [n]
-</pre></div>
+<h2>NOTES</h2>
-order=2:
-    e = [E0 E1 E3][1 ] [1 ]
-        [E2 E4  0][e ].[n ]
-        [E5  0  0][e&sup2;] [n&sup2;]
-    n = [N0 N1 N3][1 ] [1 ]
-        [N2 N4  0][e ].[n ]
-        [N5  0  0][e&sup2;] [n&sup2;]
-</pre></div>
+Ortho-transformation is a 2-step transformation. First, source
+coordinates are transformed to sensor coordinates, then sensor
+coordinates are transformed to target coordinates.
-order=3:
-    e = [E0 E1 E3 E6][1 ] [1 ]
-        [E2 E4 E7  0][e ].[n ]
-        [E5 E8  0  0][e&sup2;] [n&sup2;]
-        [E9  0  0  0][e&sup3;] [n&sup3;]
-    n = [N0 N1 N3 N6][1 ] [1 ]
-        [N2 N4 N7  0][e ].[n ]
-        [N5 N8  0  0][e&sup2;] [n&sup2;]
-        [N9  0  0  0][e&sup3;] [n&sup3;]
-</pre></div>
-["." = dot-product, (AE).N = N'EA.]
-<p>In other words, order=1 and order=2 are equivalent to order=3 with
-the higher coefficients equal to zero.
 <h2>SEE ALSO</h2>
 <em><a href="i.rectify.html">i.rectify</a></em>
Modified: grass/trunk/misc/m.transform/m.transform.html
--- grass/trunk/misc/m.transform/m.transform.html	2018-03-13 13:55:46 UTC (rev 72363)
+++ grass/trunk/misc/m.transform/m.transform.html	2018-03-14 10:57:02 UTC (rev 72364)
@@ -3,14 +3,23 @@
 <em>m.transform</em> is an utility to compute transformation
+<p>
+<tt>stdin</tt>, both the input and the output format is "x y" with one
+<b>-r</b> flag.
+<p>
 <h2>NOTES</h2>
-For coordinates given with the <b>input</b> file option or fed from
-<tt>stdin</tt>, the input format is "x y" with one coordinate pair per
-line.
+The transformations are:
 <p>order=1:
     e = [E0 E1][1].[1]
