[GRASS-SVN] r72400 - grass/branches/releasebranch_7_4/imagery/i.atcorr
svn_grass at osgeo.org
Mon Mar 19 15:14:12 PDT 2018
Author: neteler
Date: 2018-03-19 15:14:12 -0700 (Mon, 19 Mar 2018)
New Revision: 72400
Added:
grass/branches/releasebranch_7_4/imagery/i.atcorr/i_atcorr_B02_atcorr.png
grass/branches/releasebranch_7_4/imagery/i.atcorr/i.atcorr.html
i.atcorr manual: added example to process Sentinel bands (contributed by Zofie Cimburova); general manual clean-up (trunk r72390)
Modified: grass/branches/releasebranch_7_4/imagery/i.atcorr/i.atcorr.html
--- grass/branches/releasebranch_7_4/imagery/i.atcorr/i.atcorr.html 2018-03-19 22:10:41 UTC (rev 72399)
+++ grass/branches/releasebranch_7_4/imagery/i.atcorr/i.atcorr.html 2018-03-19 22:14:12 UTC (rev 72400)
@@ -7,30 +7,27 @@
<a href="http://modis-sr.ltdri.org/">Land Surface
Reflectance Science Computing Facility website</a>.
-<p><em>Important note: Current region settings are ignored!</em> The region is adjusted
-to cover the input raster map before the atmospheric correction is
-performed. The previous settings are restored afterwards.
+<p><em>Important: Current region settings are ignored!</em> The
+region is adjusted to cover the input raster map before the atmospheric
+correction is performed. The previous settings are restored afterwards.
-This flag tells <em>i.atcorr</em> to try and speedup calculations.
-However, this option will increase memory requirements.
-<p>If flag <b>-r</b> is used, the input raster data are treated as
-<em>reflectance</em>. Otherwise, the input raster data are treated
-as <em>radiance</em> values and are converted to reflectance at
+<p>If the <b>-r</b> flag is used, the input raster map is treated as
+<em>reflectance</em>. Otherwise, the input raster map is treated
+as <em>radiance</em> values and it is converted to reflectance at
the <em>i.atcorr</em> runtime. The output data are always reflectance.
-<p>Note that the satellite overpass time has to be specified in Greenwich
+<p>The satellite overpass time has to be specified in Greenwich
Mean Time (GMT).
-<p>An example 6S parameters:
+<p>An example of the 6S parameters could be:
<div class="code"><pre>
8 - geometrical conditions=Landsat ETM+
2 19 13.00 -47.410 -20.234 - month day hh.ddd longitude latitude ("hh.ddd" is in decimal hours GMT)
-1 - atmospheric mode=tropical
+1 - atmospheric model=tropical
1 - aerosols model=continental
15 - visibility [km] (aerosol model concentration)
--0.600 - mean target elevation above sea level [km] (here 600m asl)
+-0.600 - mean target elevation above sea level [km] (here 600 m asl)
-1000 - sensor height (here, sensor on board a satellite)
64 - 4th band of ETM+ Landsat 7
</pre></div>
@@ -37,7 +34,7 @@
If the position is not available in longitude-latitude (WGS84), the
<em><a href="m.proj.html">m.proj</a></em> conversion module can be
-used to reproject from a different projection.
+used to reproject from a different reference system.
<h2>6S CODE PARAMETER CHOICES</h2>
@@ -371,7 +368,7 @@
<br>c(3) = volumic % of oceanic
<br>c(4) = volumic % of soot
<br>
-<br>All values between 0 and 1.</td>
+<br>All values should be between 0 and 1.</td>
</tr>
<tr>
@@ -394,9 +391,7 @@
<tr>
<td>11</td>
<td>define your own model</td>
<td>Sun-photometer measurements, 50 values max, entered as:
<br>
<br>r and d V / d (logr)
@@ -415,14 +410,14 @@
<h3>D. Aerosol concentration model (visibility)</h3>
If you have an estimate of the meteorological parameter visibility
-v, enter directly the value of v [km] (the aerosol optical depth (AOD) will be
-computed from a standard aerosol profile).
+v, enter directly the value of v [km] (the aerosol optical depth (AOD)
+will be computed from a standard aerosol profile).
<p>If you have an estimate of aerosol optical depth, enter 0 for the
visibility and in a following line enter the aerosol optical depth at 550nm
(iaer means 'i' for input and 'aer' for aerosol), for example:<br>
0 - visibility
-0.112 - aerosol optical depth 550 nm
+0.112 - aerosol optical depth at 550 nm
</pre></div>
<p>NOTE: if iaer is 0, enter -1 for visibility.
@@ -433,9 +428,9 @@
<blockquote>xps >= 0 means the target is at the sea level.
<br>otherwise xps expresses the altitude of the target (e.g., mean elevation)
in [km], given as negative value
-</blockquote>
+</blockquote><br>
-<p>Sensor platform (xpp, in negative [km] or -1000):
+Sensor platform (xpp, in negative [km] or -1000):
<blockquote>
<br>xpp = -1000 means that the sensor is on board a satellite.
<br>xpp = 0 means that the sensor is at the ground level.
@@ -450,7 +445,7 @@
surface)
<p>If these data are not available, enter negative values for all of them.
puw,po3 will then be interpolated from the us62 standard profile according
-to the values at the ground level. taerp will be computed according to a 2km
+to the values at the ground level; taerp will be computed according to a 2 km
exponential profile for aerosol.
</blockquote>
@@ -484,13 +479,13 @@
<tr>
<td>0</td>
<td>Enter wlinf, wlsup.
-<br>The filter function will be equal to 1over the whole band.</td>
+<br>The filter function will be equal to 1 over the whole band.</td>
</tr>
<tr>
<td>1</td>
-<td>Enter wlinf, wlsup and user's filter function s(lambda) by step of 0.0025
-micrometer.</td>
+<td>Enter wlinf, wlsup and user's filter function s (lambda) by step of
+0.0025 micrometer.</td>
</tr>
</table>
@@ -576,13 +571,13 @@
<tr><td>59</td><td>POLDER band 7 P1 (0.8100-0.9200)</td></tr>
<tr><td>60</td><td>POLDER band 8 (non polar) (0.8650-0.9400)</td></tr>
-<tr><td>61</td><td><b>etm+ (landsat7)</b> band 1 (0.435-0.520)</td></tr>
-<tr><td>62</td><td>etm+ (landsat7) band 2 (0.506-0.621)</td></tr>
-<tr><td>63</td><td>etm+ (landsat7) band 3 (0.622-0.702)</td></tr>
-<tr><td>64</td><td>etm+ (landsat7) band 4 (0.751-0.911)</td></tr>
-<tr><td>65</td><td>etm+ (landsat7) band 5 (1.512-1.792)</td></tr>
-<tr><td>66</td><td>etm+ (landsat7) band 7 (2.020-2.380)</td></tr>
-<tr><td>67</td><td>etm+ (landsat7) band 8 (0.504-0.909)</td></tr>
+<tr><td>61</td><td><b>etm+ (landsat7)</b> band 1 blue (0.435-0.520)</td></tr>
+<tr><td>62</td><td>etm+ (landsat7) band 2 green (0.506-0.621)</td></tr>
+<tr><td>63</td><td>etm+ (landsat7) band 3 red (0.622-0.702)</td></tr>
+<tr><td>64</td><td>etm+ (landsat7) band 4 NIR (0.751-0.911)</td></tr>
+<tr><td>65</td><td>etm+ (landsat7) band 5 SWIR (1.512-1.792)</td></tr>
+<tr><td>66</td><td>etm+ (landsat7) band 7 SWIR (2.020-2.380)</td></tr>
+<tr><td>67</td><td>etm+ (landsat7) band 8 PAN (0.504-0.909)</td></tr>
<tr><td>68</td><td><b>liss (IRC 1C)</b> band 2 (0.502-0.620)</td></tr>
<tr><td>69</td><td>liss (IRC 1C) band 3 (0.612-0.700)</td></tr>
@@ -717,21 +712,176 @@
<h2>EXAMPLES</h2>
-<h3>Atmospheric correction of a LANDSAT-7 channel</h3>
+<h3>Atmospheric correction of a Sentinel-2 band</h3>
+<p>This example illustrates how to perform atmospheric correction of a
+Sentinel-2 scene in the North Carolina location.
-The example is based on the North Carolina sample dataset (GMT -5 hours).
-First we set the computational region to the satellite map, e.g. channel 4:
+<p>Let's assume that the Sentinel-2 L1C scene
+<em>S2A_OPER_PRD_MSIL1C_PDMC_20161029T092602_R054_V20161028T155402_20161028T155402</em>
+was downloaded and imported with region cropping
+(see <a href="r.import.html">r.import</a>)
+into the <em>PERMANENT</em> mapset of the North Carolina location. The
+computational region was set to the extent of the <em>elevation</em>
+map in the North Carolina dataset. Now, we have 13 individual bands
+(<em>B01-B12</em>) that we want to apply the atmospheric correction to.
+The following steps are applied to each band separately.
+<p><b>Create the parameters file for i.atcorr</b>
+<p>In the first step we create a file containing the 6S parameters for a
+particular scene and band. To create a 6S file, we need to obtain the
+following information:
+<ul>
+ <li> geometrical conditions,
+ <li> moth, day, decimal hours in GMT, decimal longitude and latitude of measurement,
+ <li> atmospheric model,
+ <li> aerosol model,
+ <li> visibility or aerosol optical depth,
+ <li> mean target elevation above sea level,
+ <li> sensor height and,
+ <li> sensor band.
+</ul>
+<ol>
+<li><em>Geometrical conditions</em>
+<p>For Sentinel-2A, the geometrical conditions take the value <tt>25</tt> (See table A).
+Our scene comes from the Sentinel-2A mission (the file name begins with
+S2A_...).
+<br><br>
+<li><em>Day, time, longitude and latitude of measurement</em>
+<p>Day and time of the measurement are hidden in the filename (i.e., the
+second datum in the file name with format <tt>YYYYMMDDTHHMMSS</tt>),
+and are also noted in the metadata file, which is included in the
+downloaded scene (file with .xml extension). Our sample scene was taken on
+October 28th (20161028) at 15:54:02 (155402). Note
+that the time has to be specified in decimal hours in Greenwich Mean
+Time (GMT). Luckily, the time in the scene name is in GMT and we can
+convert it to decimal hours as follows: 15 + 54/60 + 2/3600 = 15.901.
+<p>Longitude and latitude refer to the centre of the computational region
+(which can be smaller than the scene), and must be in WGS84 decimal
+coordinates. To obtain the coordinates of the centre, we can run:
+g.region -bg
+</pre></div>
+<p>The longitude and latitude of the centre are stored in <em>ll_clon</em>
+and <em>ll_clat</em>. In our case, <tt>ll_clon=-78.691</tt> and
+<tt>ll_clat=35.749</tt>.
+<br><br>
+<li><em>Atmospheric model</em>
+<p>We can choose between various atmospheric models as defined at the
+beginning of this manual. For North Carolina, we can choose <tt>2 -
+midlatitude summer</tt>.
+<br><br>
+<li><em>Aerosol model</em>
+<p>We can also choose between various aerosol models as defined at the
+beginning of this manual. For North Carolina, we can choose <tt>1 -
+continental model</tt>.
+<br><br>
+<li><em>Visibility or Aerosol Optical Depth</em>
+<p>For Sentinel-2 scenes, the visibility is not measured, and therefore
+we have to estimate the aerosol optical depth instead, e.g. from
+<a href="https://aeronet.gsfc.nasa.gov">AERONET</a>. With a bit of luck,
+you can find a station nearby your location, which measured the Aerosol
+Optical Depth at 500 nm at the same time as the scene was taken. In our
+case, on 28th October 2016, the <em>EPA-Res_Triangle_Pk</em> station
+measured AOD = 0.07 (approximately).
+<br><br>
+<li><em>Mean target elevation above sea level</em>
+<p>Mean target elevation above sea level refers to the mean elevation
+of the computational region. You can estimate it from the digital
+elevation model, e.g. by running:
+<div class="code"><pre>
+r.univar -g elevation
+</pre></div>
+<p>The mean elevation is stored in <em>mean</em>. In our case,
+<tt>mean=110</tt>. In the 6S file it will be displayed in [-km],
+i.e., <tt>-0.110</tt>.
+<br><br>
+<li><em>Sensor height</em>
+<p>Since the sensor is on board a satellite, the sensor height will be
+set to <tt>-1000</tt>.
+<br><br>
+<li><em>Sensor band</em>
+<p>The overview of satellite bands can be found in table F (see above).
+For Sentinel-2A, the band numbers span from 166 to 178.
+</ol>
+<p>Finally, here is what the 6S file would look like for Band 02 of our
+scene. In order to use it in the <em>i.atcorr</em> module, we can save
+it in a text file, for example <tt>params_B02.txt</tt>.
+25
+10 28 15.901 -78.691 35.749
+2
+1
+0
+0.07
+-0.110
+-1000
+167
+</pre></div>
+<p><b>Compute atmospheric correction</b>
+<p>In the next step we run <em>i.atcorr</em> for the selected band
+<em>B02</em> of our Sentinel 2 scene. We have to specify the following
+parameters:
+<ul>
+ <li><b>input</b> = raster band to be processed,
+ <li><b>parameters</b> = path to 6S file created in the previous step (we could also enter the values directly),
+ <li><b>output</b> = name for the output corrected raster band,
+ <li><b>range</b> = from 1 to the <tt>QUANTIFICATION_VALUE</tt> stored in the metadata file. It is <tt>10000</tt> for Sentinel-2A.
+ <li><b>rescale</b> = the output range of values for the corrected bands. This is up to the user to choose, for example: 0-255, 0-1, 1-10000.
+</ul>
+<p>If the data is available, the following parameters can be specified
+as well:
+<ul>
+ <li><b>elevation</b> = raster of digital elevation model,
+ <li><b>visibility</b> = raster of visibility model.
+</ul>
+<p>Finally, this is how the command would look like to apply atmospheric
+correction to band <em>B02</em>:
+i.atcorr input=B02 parameters=params_B02.txt output=B02.atcorr range=1,10000 rescale=0,255 elevation=elevation
+</pre></div>
+<p>To apply atmospheric correction to the remaining bands, only the last
+line in the 6S parameters file (i.e., the sensor band) needs to be changed.
+The other parameters will remain the same.
+<div align="center" style="margin: 10px">
+<a href="i_atcorr_B02_atcorr.png">
+<img src="i_atcorr_B02_atcorr.png" width="600" height="486" alt="i.atcorr example" border="0">
+</a><br>
+<i>Figure: Sentinel-2A Band 02 with applied atmospheric correction (histogram equalization grayscale color scheme)</i>
+</div>
+<h3>Atmospheric correction of a Landsat-7 band</h3>
+This example is also based on the North Carolina sample dataset (GMT -5 hours).
+First we set the computational region to the satellite map, e.g. band 4:
g.region raster=lsat7_2002_40 -p
</pre></div>
-It is important to verify the available metadata for the sun position which
-has to be defined for the atmospheric correction. An option is to check the
-satellite overpass time with sun position as reported in the
+<p>It is important to verify the available metadata for the sun position
+which has to be defined for the atmospheric correction. An option is to
+check the satellite overpass time with sun position as reported in the
<a href="ftp://ftp.glcf.umd.edu/glcf/Landsat/WRS2/p016/r035/p016r035_7x20020524.ETM-EarthSat-Orthorectified/p016r035_7x20020524.met">metadata</a>
file (<a href="http://www.grassbook.org/wp-content/uploads/ncexternal/landsat/2002/p016r035_7x20020524.met">file copy</a>; North Carolina
-sample dataset). In case of the North Carolina sample dataset, values
-have been stored for each channel and can be retrieved like this:
+sample dataset). In the case of the North Carolina sample dataset, these
+values have been stored for each channel and can be retrieved with:
r.info lsat7_2002_40
@@ -738,11 +888,11 @@
</pre></div>
In this case, we have: SUN_AZIMUTH = 120.8810347, SUN_ELEVATION = 64.7730999.
-<p>
-If the sun position metadata are unavailable, we can also calculate
+<p>If the sun position metadata are unavailable, we can also calculate
them from the overpass time as follows
(<em><a href="r.sunmask.html">r.sunmask</a></em>
uses <a href="http://www.nrel.gov/midc/solpos/solpos.html">SOLPOS</a>):
r.sunmask -s elev=elevation out=dummy year=2002 month=5 day=24 hour=10 min=42 sec=7 timezone=-5
# .. reports: sun azimuth: 121.342461, sun angle above horz.(refraction corrected): 65.396652
@@ -751,20 +901,22 @@
If the overpass time is unknown, use the
<a href="http://cloudsgate2.larc.nasa.gov/cgi-bin/predict/predict.cgi">NASA LaRC Satellite Overpass Predictor</a>.
-<h4>Conversion of digital number (DN) to radiance at top-of-atmosphere (TOA)</h4>
+<h4>Convert digital numbers (DN) to radiance at top-of-atmosphere (TOA)</h4>
For Landsat and ASTER, the conversion can be conveniently done with
-<a href="i.landsat.toar.html">i.landsat.toar</a> or <a href="i.aster.toar.html">i.aster.toar</a>,
-respectively.
+<em><a href="i.landsat.toar.html">i.landsat.toar</a></em> or
+<em><a href="i.aster.toar.html">i.aster.toar</a></em>, respectively.
-<p>
-In case of different satellites, the conversion of DN (digital number = pixel values) to
-radiance at top-of-atmosphere (TOA) can also be done manually, using e.g. the formula
+<p>In case of different satellites, the conversion of DN (digital number
+= pixel values) to radiance at top-of-atmosphere (TOA) can also be done
+manually, using e.g. the formula:
# formula depends on satellite sensor, see respective metadata
Lλ = ((LMAXλ - LMINλ)/(QCALMAX-QCALMIN)) * (QCAL-QCALMIN) + LMINλ
</pre></div>
-where:
+where,
<ul>
<li> Lλ = Spectral Radiance at the sensor's aperture in Watt/(meter squared * ster * µm), the
apparent radiance as seen by the satellite sensor;</li>
@@ -775,15 +927,16 @@
<li> QCALMAX = the maximum quantized calibrated pixel value (corresponding to LMAXλ) in DN=255.</li>
</ul>
-LMINλ and LMAXλ are the radiances related to the minimal and
-maximal DN value, and are reported in the metadata file for each image, or in
-the table 1. High gain or low gain is also reported in the metadata file of each
-satellite image. For Landsat, the minimal DN value (QCALMIN) is 1 for Landsat ETM+
-images (see
-<a href="http://landsathandbook.gsfc.nasa.gov/pdfs/Landsat7_Handbook.pdf">Landsat handbook</a>, see chapter 11),
+LMINλ and LMAXλ are the radiances related to the minimal
+and maximal DN value, and they are reported in the metadata file of each
+image. High gain or low gain is also reported in the metadata file of each
+satellite image. For Landsat ETM+, the minimal DN value (QCALMIN) is 1
+(see <a href="http://landsathandbook.gsfc.nasa.gov/pdfs/Landsat7_Handbook.pdf">Landsat handbook</a>, chapter 11),
and the maximal DN value (QCALMAX) is 255. QCAL is the DN value for every
separate pixel in the Landsat image.
-<p>We extract the coefficients and apply them in order to obtain the radiance map:
+<p>We extract the coefficients and apply them in order to obtain the
+radiance map:
CHAN=4
r.info lsat7_2002_${CHAN}0 -h | tr '\n' ' ' | sed 's+ ++g' | tr ':' '\n' | grep "LMIN_BAND${CHAN}\|LMAX_BAND${CHAN}"
@@ -793,36 +946,33 @@
QCALMIN_BAND4=1.0,p016r035_7x20020524.met
</pre></div>
-Conversion to radiance (this calculation is done for band 4, for the other bands, the numbers in italics
-need to be replaced with their related values):
+Conversion to radiance (this calculation is done for band 4, for the
+other bands, the numbers will need to be replaced with their related
+values):
r.mapcalc "lsat7_2002_40_rad = ((241.1 - (-5.1)) / (255.0 - 1.0)) * (lsat7_2002_40 - 1.0) + (-5.1)"
</pre></div>
-Again, the <em>r.mapcalc</em> calculation is only needed when working with satellite data
-other than Landsat or ASTER.
+Again, the <em>r.mapcalc</em> calculation is only needed when working
+with satellite data other than Landsat or ASTER.
-<h4>Creation of parameter file for i.atcorr</h4>
+<h4>Create the parameters file for i.atcorr</h4>
-The underlying 6S model is parametrized through a control file, indicated with the
-<em>parameter</em> option. This is a text file defining geometrical and atmospherical
-conditions of the satellite overpass. Below some details:
+The underlying 6S model is parametrized through a control file,
+indicated with the <b>parameters</b> option. This is a text file
+defining geometrical and atmospherical conditions of the satellite
+overpass.
-<p>
-<div class="code"><pre>
-# find mean elevation (target above sea level, used as initialization value in control file)
-r.univar elevation
-</pre></div>
+Here we create a control file <tt>icnd_lsat4.txt</tt> for band 4 (NIR),
+based on metadata. For the overpass time, we need to define decimal
+hours: 10:42:07 NC local time = 10.70 decimal hours (decimal minutes:
+42 * 100 / 60) which is 15.70 GMT.
-Create a control file 'icnd.txt' for channel 4 (NIR), based on metadata. For the overpass time,
-we need to define decimal hours:<br>
-10:42:07 NC local time = 10.70 decimal hours (decimal minutes: 42 * 100 / 60) which is 15.70 GMT:
5 24 15.70 -78.691 35.749 - month day hh.ddd longitude latitude ("hh.ddd" is in GMT decimal hours)
-2 - atmospheric mode=midlatitude summer
+2 - atmospheric model=midlatitude summer
50 - visibility [km] (aerosol model concentration)
-0.110 - mean target elevation above sea level [km]
@@ -830,27 +980,30 @@
</pre></div>
-Finally, run the atmospheric correction (-r for reflectance input map; -a for date >July 2000):
+Finally, run the atmospheric correction (-r for reflectance input map;
+-a for date > July 2000):
-i.atcorr -r -a lsat7_2002_40_rad elev=elevation parameters=icnd_lsat4.txt output=lsat7_2002_40_atcorr
+i.atcorr -r -a lsat7_2002_40_rad elevation=elevation parameters=icnd_lsat4.txt output=lsat7_2002_40_atcorr
</pre></div>
-Note that the altitude value from 'icnd_lsat4.txt' file is read at the beginning
-to compute the initial transform. It is necessary to give a value which could
-be the mean value of the elevation model. For the atmospheric correction then
-the raster elevation values are used from the map.
-<p>Note that the process is computationally intensive.<br>
-Note also, that <em>i.atcorr</em> reports solar elevation angle above horizon rather than solar zenith angle.
+Note that the altitude value from 'icnd_lsat4.txt' file is read at the
+beginning to compute the initial transform. Therefore, it is necessary
+to provide a value that might be the mean value of the elevation model
+(<tt>r.univar elevation</tt>). For the atmospheric correction per se, the
+elevation values from the raster map are used.
+<p>Note that the process is computationally intensive. Note also, that
+<em>i.atcorr</em> reports solar elevation angle above horizon rather
+than solar zenith angle.
<h2>REMAINING DOCUMENTATION ISSUES</h2>
-1. The influence and importance of the visibility value or map should be
+The influence and importance of the visibility value or map should be
explained, also how to obtain an estimate for either visibility or aerosol
optical depth at 550nm.
<h2>SEE ALSO</h2>
-GRASS Wiki page about
- <a href="http://grasswiki.osgeo.org/wiki/Atmospheric_correction">Atmospheric correction</a>
+GRASS Wiki page about <a href="http://grasswiki.osgeo.org/wiki/Atmospheric_correction">Atmospheric correction</a>
<p>
<em>
@@ -863,7 +1016,7 @@
<h2>REFERENCES</h2>
<ul>
-<li> Vermote, E.F., Tanre, D., Deuze, J.L., Herman, M., and Morcrette, J.J., 1997,
+<li>Vermote, E.F., Tanre, D., Deuze, J.L., Herman, M., and Morcrette, J.J., 1997,
Second simulation of the satellite signal in the solar spectrum, 6S: An
overview., IEEE Trans. Geosc. and Remote Sens. 35(3):675-686.
<!-- too new:
@@ -872,14 +1025,15 @@
at the <a href="http://6s.ltdri.org">6S homepage</a> of the Land Surface Reflectance
-<li> 6S Manual: <a href="http://www.rsgis.ait.ac.th/~honda/textbooks/advrs/6smanv2.0_P1.pdf">PDF1</a>,
- <a href="http://www.rsgis.ait.ac.th/~honda/textbooks/advrs/6smanv2.0_P2.pdf">PDF2</a>,
- and <a href="http://www.rsgis.ait.ac.th/~honda/textbooks/advrs/6smanv2.0_P3.pdf">PDF3</a>
+<li>6S Manual: <a href="http://www.rsgis.ait.ac.th/~honda/textbooks/advrs/6smanv2.0_P1.pdf">PDF1</a>,
+ <a href="http://www.rsgis.ait.ac.th/~honda/textbooks/advrs/6smanv2.0_P2.pdf">PDF2</a>,
+ and <a href="http://www.rsgis.ait.ac.th/~honda/textbooks/advrs/6smanv2.0_P3.pdf">PDF3</a>
<li>RapidEye sensors have been provided by <a href="http://www.rapideye.com/">RapidEye AG, Germany</a>
-<li> Julia A. Barsi, Brian L. Markham and Jeffrey A. Pedelty "The operational land imager: spectral response and spectral uniformity", Proc. SPIE 8153, 81530G (2011); doi:10.1117/12.895438
+<li>Barsi, J.A., Markham, B.L. and Pedelty, J.A., 2011, The operational
+land imager: spectral response and spectral uniformity., Proc. SPIE 8153,
+81530G; doi:10.1117/12.895438
</ul>
<h2>AUTHORS</h2>
<p><em>Original version of the program for GRASS 5:</em>
Copied: grass/branches/releasebranch_7_4/imagery/i.atcorr/i_atcorr_B02_atcorr.png (from rev 72390, grass/trunk/imagery/i.atcorr/i_atcorr_B02_atcorr.png)
(Binary files differ)
