[GRASS-SVN] r72401 - grass/branches/releasebranch_7_4/lib/init
svn_grass at osgeo.org
Tue Mar 20 03:52:41 PDT 2018
Author: martinl
Date: 2018-03-20 03:52:41 -0700 (Tue, 20 Mar 2018)
New Revision: 72401
grass/branches/releasebranch_7_4/lib/init/grass.py
disable to_text_string() in grass.py, see #3508 (merge r72374 from trunk)
Modified: grass/branches/releasebranch_7_4/lib/init/grass.py
--- grass/branches/releasebranch_7_4/lib/init/grass.py 2018-03-19 22:14:12 UTC (rev 72400)
+++ grass/branches/releasebranch_7_4/lib/init/grass.py 2018-03-20 10:52:41 UTC (rev 72401)
@@ -56,7 +56,7 @@
ENCODING = 'UTF-8'
print("Default locale not found, using UTF-8") # intentionally not translatable
+# currently not used, see https://trac.osgeo.org/grass/ticket/3508
def to_text_string(obj, encoding=ENCODING):
"""Convert `obj` to (unicode) text string"""
if PY2:
@@ -613,11 +613,15 @@
pass
if sys_man_path:
- os.environ['MANPATH'] = to_text_string(sys_man_path)
+ # to_text_string disabled, see https://trac.osgeo.org/grass/ticket/3508
+ # os.environ['MANPATH'] = to_text_string(sys_man_path)
+ os.environ['MANPATH'] = sys_man_path
path_prepend(addons_man_path, 'MANPATH')
path_prepend(grass_man_path, 'MANPATH')
else:
- os.environ['MANPATH'] = to_text_string(addons_man_path)
+ # os.environ['MANPATH'] = to_text_string(addons_man_path)
+ os.environ['MANPATH'] = addons_man_path
# Set LD_LIBRARY_PATH (etc) to find GRASS shared libraries
