[GRASS-SVN] r72511 - grass/trunk/display/d.grid
svn_grass at osgeo.org
Fri Mar 23 02:22:34 PDT 2018
Author: mmetz
Date: 2018-03-23 02:22:34 -0700 (Fri, 23 Mar 2018)
New Revision: 72511
grass/trunk/display/d.grid/local_proto.h
grass/trunk/display/d.grid/main.c
grass/trunk/display/d.grid/plot.c
d.grid: use new GRASS API for coordinate transformation
Modified: grass/trunk/display/d.grid/local_proto.h
--- grass/trunk/display/d.grid/local_proto.h 2018-03-23 09:21:24 UTC (rev 72510)
+++ grass/trunk/display/d.grid/local_proto.h 2018-03-23 09:22:34 UTC (rev 72511)
@@ -7,13 +7,13 @@
/* plot.c */
int plot_grid(double, double, double, int, int, int, int, int, int, double,
int);
-int plot_geogrid(double, struct pj_info, struct pj_info, int, int, int, int,
- int, int, double, int, int);
-void init_proj(struct pj_info *, struct pj_info *, int);
+int plot_geogrid(double, struct pj_info *, struct pj_info *, struct pj_info *,
+ int, int, int, int, int, int, double, int);
+void init_proj(struct pj_info *, struct pj_info *, struct pj_info *, int);
void get_ll_bounds(double *, double *, double *, double *, struct Cell_head,
- struct pj_info, struct pj_info, int);
+ struct pj_info *, struct pj_info *, struct pj_info *);
void check_coords(double, double, double *, double *, int, struct Cell_head,
float get_heading(double, double);
/* plotborder.c */
Modified: grass/trunk/display/d.grid/main.c
--- grass/trunk/display/d.grid/main.c 2018-03-23 09:21:24 UTC (rev 72510)
+++ grass/trunk/display/d.grid/main.c 2018-03-23 09:22:34 UTC (rev 72511)
@@ -42,8 +42,7 @@
*direction, *bgcolor;
struct Flag *noborder, *notext, *geogrid, *nogrid, *wgs84, *cross,
*fiducial, *dot, *align;
- struct pj_info info_in; /* Proj structures */
- struct pj_info info_out; /* Proj structures */
+ struct pj_info info_in, info_out, info_trans; /* Proj structures */
struct Cell_head wind;
/* Initialize the GIS calls */
@@ -287,10 +286,10 @@
if (!nogrid->answer) {
if (geogrid->answer) {
/* initialzie proj stuff */
- init_proj(&info_in, &info_out, wgs84->answer);
- plot_geogrid(gsize, info_in, info_out, do_text, colorg, colort,
- colorbg, fontsize, mark_type, line_width, dirn,
- wgs84->answer);
+ init_proj(&info_in, &info_out, &info_trans, wgs84->answer);
+ plot_geogrid(gsize, &info_in, &info_out, &info_trans,
+ do_text, colorg, colort, colorbg, fontsize,
+ mark_type, line_width, dirn);
else {
/* Do the grid plotting */
Modified: grass/trunk/display/d.grid/plot.c
--- grass/trunk/display/d.grid/plot.c 2018-03-23 09:21:24 UTC (rev 72510)
+++ grass/trunk/display/d.grid/plot.c 2018-03-23 09:22:34 UTC (rev 72511)
@@ -232,9 +232,10 @@
-int plot_geogrid(double size, struct pj_info info_in, struct pj_info info_out,
- int do_text, int gcolor, int tcolor, int bgcolor, int fontsize,
- int mark_type, double line_width, int direction, int wgs84)
+int plot_geogrid(double size, struct pj_info *info_in, struct pj_info *info_out,
+ struct pj_info *info_trans, int do_text, int gcolor,
+ int tcolor, int bgcolor, int fontsize, int mark_type,
+ double line_width, int direction)
double g;
double e1, e2, n1, n2;
@@ -263,7 +264,7 @@
/* get lat long min max */
/* probably need something like boardwalk ?? */
- get_ll_bounds(&west, &east, &south, &north, window, info_in, info_out, wgs84);
+ get_ll_bounds(&west, &east, &south, &north, window, info_in, info_out, info_trans);
G_debug(3, "REGION BOUNDS N=%f S=%f E=%f W=%f", north, south, east, west);
@@ -283,37 +284,18 @@
n1 = n2 = g;
e1 = west + (ll * ((east - west) / SEGS));
e2 = e1 + ((east - west) / SEGS);
-#ifdef HAVE_PROJ_H
- if (!wgs84) {
- if (GPJ_do_proj_ll(&e1, &n1, &info_out, PJ_FWD) < 0)
- G_fatal_error(_("Error in pj_do_proj"));
- else {
- if (pj_do_proj(&e1, &n1, &info_in, &info_out) < 0)
-#else
-#endif
+ if (GPJ_transform(info_in, info_out, info_trans, PJ_INV,
+ &e1, &n1, NULL) < 0)
+ G_fatal_error(_("Error in GPJ_transform()"));
- check_coords(e1, n1, &lon, &lat, 1, window, info_in, info_out, wgs84);
+ check_coords(e1, n1, &lon, &lat, 1, window, info_in, info_out, info_trans);
e1 = lon;
n1 = lat;
-#ifdef HAVE_PROJ_H
- if (!wgs84) {
- if (GPJ_do_proj_ll(&e2, &n2, &info_out, PJ_FWD) < 0)
- else {
- if (pj_do_proj(&e2, &n2, &info_in, &info_out) < 0)
-#else
-#endif
- check_coords(e2, n2, &lon, &lat, 1, window, info_in, info_out, wgs84);
+ &e2, &n2, NULL) < 0)
+ check_coords(e2, n2, &lon, &lat, 1, window, info_in, info_out, info_trans);
e2 = lon;
n2 = lat;
if (start_coord == -9999.) {
@@ -351,38 +333,18 @@
n1 = south + (ll *((north - south)/SEGS));
n2 = n1 + ((north - south)/SEGS);
-#ifdef HAVE_PROJ_H
- if (!wgs84) {
- else {
-#else
-#endif
- check_coords(e1, n1, &lon, &lat, 2, window, info_in, info_out, wgs84);
+ check_coords(e1, n1, &lon, &lat, 2, window, info_in, info_out, info_trans);
e1 = lon;
n1 = lat;
-#ifdef HAVE_PROJ_H
- if (!wgs84) {
- else {
-#else
-#endif
- check_coords(e2, n2, &lon, &lat, 2, window, info_in, info_out, wgs84);
+ check_coords(e2, n2, &lon, &lat, 2, window, info_in, info_out, info_trans);
e2 = lon;
n2 = lat;
@@ -447,7 +409,7 @@
@@ -466,38 +428,18 @@
n1 = n2 = g;
-#ifdef HAVE_PROJ_H
- if (!wgs84) {
- else {
-#else
-#endif
e1 = lon;
n1 = lat;
-#ifdef HAVE_PROJ_H
- if (!wgs84) {
- else {
-#else
-#endif
e2 = lon;
n2 = lat;
@@ -546,38 +488,18 @@
n1 = north - (ll * ((north - south) / SEGS));
n2 = n1 - ((north - south) / SEGS);
-#ifdef HAVE_PROJ_H
- if (!wgs84) {
- else {
-#else
-#endif
e1 = lon;
n1 = lat;
-#ifdef HAVE_PROJ_H
- if (!wgs84) {
- else {
-#else
-#endif
e2 = lon;
n2 = lat;
@@ -629,62 +551,57 @@
* initialze projection stuff and return proj structures
-void init_proj(struct pj_info *info_in, struct pj_info *info_out, int wgs84)
+void init_proj(struct pj_info *info_in, struct pj_info *info_out,
+ struct pj_info *info_trans, int wgs84)
- struct Key_Value *out_proj_keys, *out_unit_keys;
+ struct Key_Value *in_proj_info, *in_unit_info;
/* Proj stuff for geo grid */
- /* Out Info */
- out_proj_keys = G_get_projinfo();
- out_unit_keys = G_get_projunits();
- if (pj_get_kv(info_out, out_proj_keys, out_unit_keys) < 0)
+ /* In Info for current projection */
+ in_proj_info = G_get_projinfo();
+ in_unit_info = G_get_projunits();
+ if (pj_get_kv(info_in, in_proj_info, in_unit_info) < 0)
G_fatal_error(_("Can't get projection key values of current location"));
- /* In Info */
-#ifdef HAVE_PROJ_H
+ /* Out Info for ll projection */
+ info_out->pj = NULL;
if (wgs84) {
-#else
- if (!wgs84) {
- /* Set lat/long to same ellipsoid as location if we're not looking
- * for the WGS84 values */
- if (GPJ_get_equivalent_latlong(info_in, info_out) < 0)
- G_fatal_error(_("Unable to set up lat/long projection parameters"));
- else {
-#endif
- struct Key_Value *in_proj_info, *in_unit_info;
+ struct Key_Value *out_proj_info, *out_unit_info;
char buff[256], dum[256];
- in_proj_info = G_create_key_value();
- in_unit_info = G_create_key_value();
+ out_proj_info = G_create_key_value();
+ out_unit_info = G_create_key_value();
/* Check that datumparams are defined for this location (otherwise
* the WGS84 values would be meaningless), and if they are set the
* input datum to WGS84 */
- if (G_get_datumparams_from_projinfo(out_proj_keys, buff, dum) < 0)
+ if (G_get_datumparams_from_projinfo(in_proj_info, buff, dum) < 0)
G_fatal_error(_("WGS84 grid output not possible as this location does not contain\n"
"datum transformation parameters. Try running g.setproj."));
else
- G_set_key_value("datum", "wgs84", in_proj_info);
+ G_set_key_value("datum", "wgs84", out_proj_info);
/* set input projection to lat/long */
- G_set_key_value("proj", "ll", in_proj_info);
+ G_set_key_value("proj", "ll", out_proj_info);
- G_set_key_value("unit", "degree", in_unit_info);
- G_set_key_value("units", "degrees", in_unit_info);
- G_set_key_value("meters", "1.0", in_unit_info);
+ G_set_key_value("unit", "degree", out_unit_info);
+ G_set_key_value("units", "degrees", out_unit_info);
+ G_set_key_value("meters", "1.0", out_unit_info);
- if (pj_get_kv(info_in, in_proj_info, in_unit_info) < 0)
+ if (pj_get_kv(info_out, out_proj_info, out_unit_info) < 0)
- G_free_key_value(in_proj_info);
- G_free_key_value(in_unit_info);
+ G_free_key_value(out_proj_info);
+ G_free_key_value(out_unit_info);
- G_free_key_value(out_proj_keys);
- G_free_key_value(out_unit_keys);
+ /* else the latlong equivalent is generated by GPJ_init_transform() */
+ G_free_key_value(in_proj_info);
+ G_free_key_value(in_unit_info);
+ if (GPJ_init_transform(info_in, info_out, info_trans) < 0)
+ G_fatal_error(_("Unable to initialize coordinate transformation"));
return;
@@ -694,7 +611,8 @@
void get_ll_bounds(double *w, double *e, double *s, double *n,
struct Cell_head window,
- struct pj_info info_in, struct pj_info info_out, int wgs84)
+ struct pj_info *info_in, struct pj_info *info_out,
+ struct pj_info *info_trans)
double east, west, north, south;
double e1, w1, n1, s1;
@@ -722,19 +640,9 @@
for (ew = window.west; ew <= window.east; ew += ew_res) {
e1 = ew;
n1 = window.north;
-#ifdef HAVE_PROJ_H
- if (!wgs84) {
- if (GPJ_do_proj_ll(&e1, &n1, &info_out, PJ_INV) < 0)
- else {
- if (pj_do_proj(&e1, &n1, &info_out, &info_in) < 0)
-#else
-#endif
+ if (GPJ_transform(info_in, info_out, info_trans, PJ_FWD,
if (!first) {
north = n1;
first = 1;
@@ -749,19 +657,9 @@
e1 = ew;
s1 = window.south;
-#ifdef HAVE_PROJ_H
- if (!wgs84) {
- if (GPJ_do_proj_ll(&e1, &s1, &info_out, PJ_INV) < 0)
- else {
- if (pj_do_proj(&e1, &s1, &info_out, &info_in) < 0)
-#else
-#endif
+ &e1, &s1, NULL) < 0)
if (!first) {
south = s1;
first = 1;
@@ -777,19 +675,9 @@
for (ns = window.south; ns <= window.north; ns += ns_res) {
e1 = window.east;
n1 = ns;
-#ifdef HAVE_PROJ_H
- if (!wgs84) {
- else {
-#else
-#endif
if (!first) {
east = e1;
first = 1;
@@ -805,19 +693,9 @@
w1 = window.west;
n1 = ns;
-#ifdef HAVE_PROJ_H
- if (!wgs84) {
- if (GPJ_do_proj_ll(&w1, &n1, &info_out, PJ_INV) < 0)
- else {
- if (pj_do_proj(&w1, &n1, &info_out, &info_in) < 0)
-#else
-#endif
+ &w1, &n1, NULL) < 0)
if (!first) {
west = w1;
first = 1;
@@ -847,8 +725,9 @@
double *lat,
int par,
struct Cell_head w,
- int wgs84)
+ struct pj_info *info_out,
double x, y;
int proj = 0;
@@ -875,51 +754,22 @@
if (proj) {
/* convert original coords to ll */
-#ifdef HAVE_PROJ_H
- if (!wgs84) {
- if (GPJ_do_proj_ll(&e, &n, &info_out, PJ_INV) < 0)
- else {
- if (pj_do_proj(&e, &n, &info_in, &info_out) < 0)
-#else
- if (pj_do_proj(&e, &n, &info_out, &info_in) < 0)
- G_fatal_error(_("Error in pj_do_proj1"));
-#endif
+ &e, &n, NULL) < 0)
if (par == 1) {
/* lines of latitude -- const. northing */
/* convert correct UTM to ll */
-#ifdef HAVE_PROJ_H
- if (!wgs84) {
- if (GPJ_do_proj_ll(&x, &y, &info_out, PJ_INV) < 0)
- else {
- if (pj_do_proj(&x, &y, &info_out, &info_in) < 0)
-#else
- G_fatal_error(_("Error in pj_do_proj2"));
-#endif
+ &x, &y, NULL) < 0)
/* convert new ll back to coords */
-#ifdef HAVE_PROJ_H
- if (!wgs84) {
- if (GPJ_do_proj_ll(&x, &n, &info_out, PJ_FWD) < 0)
- else {
- if (pj_do_proj(&x, &n, &info_in, &info_out) < 0)
-#else
- G_fatal_error(_("Error in pj_do_proj3"));
-#endif
+ &x, &n, NULL) < 0)
*lat = n;
*lon = x;
@@ -926,34 +776,15 @@
if (par == 2) {
/* lines of longitude -- const. easting */
-#ifdef HAVE_PROJ_H
- if (!wgs84) {
- else {
-#else
- G_fatal_error(_("Error in pj_do_proj5"));
-#endif
-#ifdef HAVE_PROJ_H
- if (!wgs84) {
- if (GPJ_do_proj_ll(&e, &n, &info_out, PJ_FWD) < 0)
- else {
-#else
- if (pj_do_proj(&e, &y, &info_in, &info_out) < 0)
- G_fatal_error(_("Error in pj_do_proj6"));
-#endif
+ &e, &y, NULL) < 0)
*lat = y;
*lon = e;
