[GRASS-SVN] r72512 - grass/trunk/display/d.where
Fri Mar 23 02:22:49 PDT 2018
Author: mmetz
Date: 2018-03-23 02:22:49 -0700 (Fri, 23 Mar 2018)
New Revision: 72512
   grass/trunk/display/d.where/local_proto.h
   grass/trunk/display/d.where/main.c
   grass/trunk/display/d.where/where.c
d.where: use new GRASS API for coordinate transformation
Modified: grass/trunk/display/d.where/local_proto.h
--- grass/trunk/display/d.where/local_proto.h	2018-03-23 09:22:34 UTC (rev 72511)
+++ grass/trunk/display/d.where/local_proto.h	2018-03-23 09:22:49 UTC (rev 72512)
@@ -1,2 +1,2 @@
 /* where.c */
-int where_am_i(char **, FILE *, int, int, int, int);
+int where_am_i(char **, FILE *, int, int, int);
Modified: grass/trunk/display/d.where/main.c
--- grass/trunk/display/d.where/main.c	2018-03-23 09:22:34 UTC (rev 72511)
+++ grass/trunk/display/d.where/main.c	2018-03-23 09:22:49 UTC (rev 72512)
@@ -26,7 +26,7 @@
 #include "local_proto.h"
 #include <grass/glocale.h>
-struct pj_info iproj, oproj;
+struct pj_info iproj, oproj, tproj;
 int main(int argc, char **argv)
@@ -112,18 +112,7 @@
 	if (pj_get_kv(&iproj, in_proj_info, in_unit_info) < 0)
 	    G_fatal_error(_("Can't get projection key values of current location"));
-#ifdef HAVE_PROJ_H
 	if (wgs84->answer) {
-#else
-	if (!wgs84->answer) {
-	    /* Set output to same ellipsoid as input if we're not looking
-	     * for the WGS84 values */
-	    if (GPJ_get_equivalent_latlong(&oproj, &iproj) < 0)
-		G_fatal_error(_("Unable to set up lat/long projection parameters"));
-	else {
-#endif
 	    struct Key_Value *out_proj_info, *out_unit_info;
 	    out_proj_info = G_create_key_value();
@@ -151,10 +140,13 @@
 	    G_free_key_value(out_proj_info);
 	    G_free_key_value(out_unit_info);
+	/* else the latlong equivalent is generated by GPJ_init_transform() */
 	G_free_key_value(in_proj_info);
 	G_free_key_value(in_unit_info);
+	if (GPJ_init_transform(&iproj, &oproj, &tproj) < 0)
+	    G_fatal_error(_("Unable to initialize coordinate transformation"));
     if (file->answer) {
@@ -174,7 +166,7 @@
     D_setup(0);
     where_am_i(coords->answers, fp, have_spheroid, decimal->answer,
-               dcoord->answer, wgs84->answer);
+               dcoord->answer);
     D_close_driver();
Modified: grass/trunk/display/d.where/where.c
--- grass/trunk/display/d.where/where.c	2018-03-23 09:22:34 UTC (rev 72511)
+++ grass/trunk/display/d.where/where.c	2018-03-23 09:22:49 UTC (rev 72512)
@@ -5,10 +5,10 @@
 #include <grass/display.h>
-extern struct pj_info iproj, oproj;
+extern struct pj_info iproj, oproj, tproj;
 int where_am_i(char **coords, FILE *fp, int have_spheroid, int decimal,
-               int dcoord, int wgs84)
+               int dcoord)
     char buf1[50], buf2[50];
     int screen_x, screen_y;
@@ -58,19 +58,9 @@
 	    double lat = north;
 	    double lon = east;
-#ifdef HAVE_PROJ_H
-	    if (!wgs84) {
-		if (GPJ_do_proj_ll(&lon, &lat, &iproj, PJ_INV) < 0)
-		    G_fatal_error(_("Error in pj_do_proj"));
-	    else {
-		if (pj_do_proj(&lon, &lat, &iproj, &oproj) < 0)
-#else
-#endif
+	    if (GPJ_transform(&iproj, &oproj, &tproj, PJ_FWD,
+			      &lon, &lat, NULL) < 0)
+		G_fatal_error(_("Error in GPJ_transform()"));
 	    if (decimal) {
 		G_format_easting(lon, buf1, 0);
