[GRASS-SVN] r72748 - sandbox/wenzeslaus/g.citation
svn_grass at osgeo.org
Mon May 28 13:54:40 PDT 2018
Author: wenzeslaus
Date: 2018-05-28 13:54:40 -0700 (Mon, 28 May 2018)
New Revision: 72748
sandbox/wenzeslaus/g.citation/g.citation.py
g.citation: parse ORCID, year, desc for options, code structure
Modified: sandbox/wenzeslaus/g.citation/g.citation.py
--- sandbox/wenzeslaus/g.citation/g.citation.py 2018-05-28 19:52:30 UTC (rev 72747)
+++ sandbox/wenzeslaus/g.citation/g.citation.py 2018-05-28 20:54:40 UTC (rev 72748)
@@ -6,7 +6,7 @@
# AUTHOR(S): Vaclav Petras <wenzeslaus AT gmail DOT com> (ORCID: 0000-0001-5566-9236)
# Peter Loewe <ploewe AT osgeo DOT org> (ORCID: 0000-0003-2257-0517)
-# Markus Neteler <mneteler AT osgeo DOT org> (ORCID:0000-0003-1916-1966)
+# Markus Neteler <mneteler AT osgeo DOT org> (ORCID: 0000-0003-1916-1966)
# PURPOSE: Provide scientific citation for GRASS modules and add-ons.
@@ -34,10 +34,11 @@
#%end
#%option
-#% key: style
+#% key: format
#% type: string
-#% description: Citation style
-#% options: bibtex,csl,datacite,dublincore,json,json-ld,narcxml
+#% description: Citation format or style
+#% options: bibtex,csl,datacite,dublincore,json,json-ld,narcxml,plain,dict
+#% descriptions: bibtex;BibTeX;csl;cls;datacite;datacite;dublincore;dublincore;json;json;json-ld;json-ld;narcxml;narcxml;plain;Plain text;dict;Pretty printed Python dictionary
#% answer: bibtex
#% required: yes
#%end
@@ -103,11 +104,25 @@
out = []
for line in lines:
line = re.sub("<br.?>", "", line)
- line = re.sub("</?[a-z]+ ?.+>", "", line)
+ line = re.sub("</?[a-z]+ ?[^>]*>", "", line)
out.append(line)
return out
+def clean_line_item(text):
+ text = text.strip()
+ text = re.sub(r"^, *", "", text)
+ text = re.sub(r",$", "", text)
+ return text
+def get_year_from_documentation(text):
+ year_capture = r"<p>\s*<i>Last changed: \$Date: ([\d]+)-\d\d-\d\d .*\$</i>"
+ match = re.search(year_capture, text,
+ re.MULTILINE | re.DOTALL)
+ if match:
+ return int(match.group(1))
def get_authors_from_documentation(text):
raw_author_capture = "<h2>.*AUTHOR.*</h2>(.*)<p>\s*<i>Last changed:"
@@ -114,7 +129,7 @@
raw_author_lines = [
line.strip()
for line in re.search(raw_author_capture, text,
- flags=re.MULTILINE | re.DOTALL)
.group(1).strip().splitlines()
if line.strip()
@@ -126,20 +141,26 @@
for line in raw_author_lines:
if not line:
continue
- ai = line.split(",", 1)
- name = ai[0].strip()
institute = None
feature = None
+ orcid = None
+ orcid_re = re.compile(r"\(?ORCID:? ?([0-9-]+)\)?", re.IGNORECASE)
+ match = re.search(orcid_re, line)
+ if match:
+ orcid = match.group(1)
+ line = re.sub(orcid_re, "", line)
+ ai = line.split(",", 1)
+ name = clean_line_item(ai[0])
if len(ai) == 2:
- institute = ai[1].strip()
+ institute = clean_line_item(ai[1])
if " by " in name:
feature, name = name.split(" by ", 1)
authors.append({'name': name, 'institute': institute,
- 'feature': feature})
+ 'feature': feature, 'orcid': orcid})
return authors
-def write_bibtex(citation):
+def print_bibtex(citation):
print("@software{", citation['module'], ",", sep="")
print("title={", "GRASS GIS: ", citation['module'], " module},", sep="")
@@ -146,10 +167,38 @@
author_names = [author['name'] for author in citation['authors']]
print("author={", " and ".join(author_names), "},", sep="")
+ print("year={", citation['year'], "},", sep="")
print("}")
+def print_plain(citation):
+ print("GRASSS GIS module", citation['module'])
+ num_authors = len(citation['authors'])
+ authors_text = ""
+ for i, author in enumerate(citation['authors']):
+ author_name = [ ]
+ authors_text += author['name']
+ if author['institute']:
+ authors_text += ", {institute}".format(**author)
+ if author['feature']:
+ authors_text += " ({feature})".format(**author)
+ if i < num_authors - 1:
+ authors_text += "\n"
+ print(authors_text)
+def print_citation(citation, output_format):
+ if output_format == 'bibtex':
+ print_bibtex(citation)
+ elif output_format == 'plain':
+ print_plain(citation)
+ elif output_format == 'dict':
+ pprint(citation)
+ else:
+ raise RuntimeError(_("Unsupported format or style"))
def citation_for_module(name):
path = documentation_filename(name)
@@ -158,11 +207,11 @@
text = open(path).read()
- authors = get_authors_from_documentation(text)
+ citation = {}
+ citation['module'] = name
+ citation['authors'] = get_authors_from_documentation(text)
+ citation['year'] = get_year_from_documentation(text)
- citation = {}
- citation['module'] = name
- citation['authors'] = authors
return citation
@@ -169,15 +218,13 @@
def main(options, flags):
name = options['module']
+ output_format = options['format']
citation = citation_for_module(name)
- if options['style'] == 'bibtex':
- write_bibtex(citation)
+ print_citation(citation, output_format)
- pprint(citation)
# TODO: consider "Extended by" versus original authors
# LASTCHANGED, COPYRIGHT-YEARS, COPRIGHT-ENTITY
