[GRASS-SVN] r72749 - sandbox/wenzeslaus/g.citation
svn_grass at osgeo.org
Mon May 28 14:42:31 PDT 2018
Author: wenzeslaus
Date: 2018-05-28 14:42:31 -0700 (Mon, 28 May 2018)
New Revision: 72749
sandbox/wenzeslaus/g.citation/g.citation.py
g.citation: doctest and doc
Modified: sandbox/wenzeslaus/g.citation/g.citation.py
--- sandbox/wenzeslaus/g.citation/g.citation.py 2018-05-28 20:54:40 UTC (rev 72748)
+++ sandbox/wenzeslaus/g.citation/g.citation.py 2018-05-28 21:42:31 UTC (rev 72749)
@@ -62,6 +62,7 @@
from __future__ import print_function
+import sys
import os
import re
@@ -91,6 +92,11 @@
def remove_non_author_lines(lines):
+ """Remove lines which appear in the authors sec but are not authors
+ >>> remove_non_author_lines(["Ann Doe", "© 2012", "John Doe"])
+ ['Ann Doe', 'John Doe']
out = []
for line in lines:
if "©" in line:
@@ -110,6 +116,11 @@
def clean_line_item(text):
+ """Clean (commas and spaces) from beginning and end of a text
+ >>> print(clean_line_item(",Small University, "))
+ Small University
text = text.strip()
text = re.sub(r"^, *", "", text)
text = re.sub(r",$", "", text)
@@ -117,13 +128,28 @@
def get_year_from_documentation(text):
+ """Extract year from text containing SVN date entry
+ >>> text = "<p><i>Last changed: $Date: 2011-09-29 15:18:47 $</i>"
+ >>> get_year_from_documentation(text)
+ 2011
year_capture = r"<p>\s*<i>Last changed: \$Date: ([\d]+)-\d\d-\d\d .*\$</i>"
match = re.search(year_capture, text,
re.MULTILINE | re.DOTALL)
if match:
return int(match.group(1))
+ else:
+ # TODO: raise or fatal? should be in library or module?
+ raise RuntimeError("The text does not contain date entry")
def get_authors_from_documentation(text):
+ r"""Extract authors and associated info from documentation
+ >>> text = '<h2><a name="author">AUTHOR</a></h2>\nPaul Kelly\n<p><i>Last changed:'
+ >>> pprint(get_authors_from_documentation(text))
+ [{'feature': None, 'institute': None, 'name': 'Paul Kelly', 'orcid': None}]
raw_author_capture = "<h2>.*AUTHOR.*</h2>(.*)<p>\s*<i>Last changed:"
raw_author_lines = [
@@ -161,18 +187,33 @@
def print_bibtex(citation):
+ """Create BibTeX entry from citation dictionary
+ >>> print_bibtex({'module': 'g.tst', 'authors': [{'name': 'Joe Doe'}], 'year': 2011})
+ @software{g.tst,
+ title = {GRASS GIS: g.tst module},
+ author = {Joe Doe},
+ year = {2011}
print("@software{", citation['module'], ",", sep="")
- print("title={", "GRASS GIS: ", citation['module'], " module},", sep="")
+ print(" title = {", "GRASS GIS: ", citation['module'], " module},", sep="")
author_names = [author['name'] for author in citation['authors']]
- print("author={", " and ".join(author_names), "},", sep="")
- print("year={", citation['year'], "},", sep="")
+ print(" author = {", " and ".join(author_names), "},", sep="")
+ print(" year = {", citation['year'], "}", sep="")
print("}")
def print_plain(citation):
+ """Create citation from dictionary as plain text
+ >>> print_plain({'module': 'g.tst', 'authors': [{'name': 'Joe Doe'}]})
+ GRASSS GIS module g.tst
+ Joe Doe
print("GRASSS GIS module", citation['module'])
num_authors = len(citation['authors'])
authors_text = ""
@@ -179,9 +220,11 @@
for i, author in enumerate(citation['authors']):
author_name = [ ]
authors_text += author['name']
- if author['institute']:
+ # TODO: not defined if we need institute etc. or not, perhaps
+ # use default dict
+ if 'institute' in author and author['institute']:
authors_text += ", {institute}".format(**author)
- if author['feature']:
+ if 'feature' in author and author['feature']:
authors_text += " ({feature})".format(**author)
if i < num_authors - 1:
authors_text += "\n"
@@ -188,12 +231,13 @@
print(authors_text)
-def print_citation(citation, output_format):
- if output_format == 'bibtex':
+def print_citation(citation, format):
+ """Create citation from dictionary in a given format"""
+ if format == 'bibtex':
- elif output_format == 'plain':
+ elif format == 'plain':
- elif output_format == 'dict':
+ elif format == 'dict':
pprint(citation)
else:
raise RuntimeError(_("Unsupported format or style"))
@@ -200,6 +244,7 @@
def citation_for_module(name):
+ """Provide dictionary of citation values for a module"""
path = documentation_filename(name)
# derive core strings from lhmpom:
@@ -216,7 +261,12 @@
def main(options, flags):
+ """Main function to do the module's work
+ Using minimal design, just getting the input and calling other
+ functions.
name = options['module']
output_format = options['format']
@@ -242,5 +292,19 @@
# url = {http://grass.osgeo.org},
+def doc_test():
+ """Tests the module using doctest
+ :return: a number of failed tests
+ import doctest
+ from grass.gunittest.utils import do_doctest_gettext_workaround
+ do_doctest_gettext_workaround()
+ return doctest.testmod().failed
if __name__ == '__main__':
- main(*gs.parser())
+ if '--doctest' in sys.argv:
+ sys.exit(doc_test())
+ sys.exit(main(*gs.parser()))
