[GRASS-SVN] r73706 - grass/trunk/lib/python/script
svn_grass at osgeo.org
Sat Nov 24 12:25:27 PST 2018
Author: mmetz
Date: 2018-11-24 12:25:27 -0800 (Sat, 24 Nov 2018)
New Revision: 73706
grass/trunk/lib/python/script/setup.py
libpython: add functions to finish a GRASS session
Modified: grass/trunk/lib/python/script/setup.py
--- grass/trunk/lib/python/script/setup.py 2018-11-24 14:41:32 UTC (rev 73705)
+++ grass/trunk/lib/python/script/setup.py 2018-11-24 20:25:27 UTC (rev 73706)
@@ -1,7 +1,7 @@
-"""Setup and initialization functions
+"""Setup, initialization, and clean-up functions
-Function can be used in Python scripts to setup a GRASS environment
-without starting an actual GRASS session.
+Functions can be used in Python scripts to setup a GRASS environment
+and session without using grassXY.
Usage::
@@ -77,8 +77,8 @@
for vect in gscript.list_strings(type='vector'):
print vect
- # delete the rcfile
- os.remove(rcfile)
+ # clean up at the end
+ gsetup.cleanup()
(C) 2010-2012 by the GRASS Development Team
@@ -88,6 +88,7 @@
@author Martin Landa <landa.martin gmail.com>
@author Vaclav Petras <wenzeslaus gmail.com>
+ at author Markus Metz
# TODO: this should share code from lib/init/grass.py
@@ -100,6 +101,9 @@
import tempfile as tmpfile
+windows = sys.platform == 'win32'
def write_gisrc(dbase, location, mapset):
"""Write the ``gisrc`` file and return its path."""
gisrc = tmpfile.mktemp()
@@ -117,21 +121,19 @@
sys.path.insert(0, gui_path)
-# TODO: there should be a function to do the clean up
-# (unset the GISRC and delete the file)
def init(gisbase, dbase='', location='demolocation', mapset='PERMANENT'):
"""Initialize system variables to run GRASS modules
- This function is for running GRASS GIS without starting it
- explicitly. No GRASS modules shall be called before call of this
- function but any module or user script can be called afterwards
- as if it would be called in an actual GRASS session. GRASS Python
- libraries are usable as well in general but the ones using
- C libraries through ``ctypes`` are not (which is caused by
- library path not being updated for the current process
- which is a common operating system limitation).
+ This function is for running GRASS GIS without starting it with the
+ standard script grassXY. No GRASS modules shall be called before
+ call of this function but any module or user script can be called
+ afterwards because a GRASS session has been set up. GRASS Python
+ libraries are usable as well in general but the ones using C
+ libraries through ``ctypes`` are not (which is caused by library
+ path not being updated for the current process which is a common
+ operating system limitation).
- To create a (fake) GRASS session a ``gisrc`` file is created.
+ To create a GRASS session a ``gisrc`` file is created.
Caller is responsible for deleting the ``gisrc`` file.
Basic usage::
@@ -142,8 +144,8 @@
"/home/john/grassdata",
"nc_spm_08", "user1")
# ... use GRASS modules here
- # remove the session's gisrc file to end the session
- os.remove(gisrc)
+ # end the session
+ gscript.setup.finish()
:param gisbase: path to GRASS installation
:param dbase: path to GRASS database (default: '')
@@ -152,7 +154,8 @@
:returns: path to ``gisrc`` file (to be deleted later)
- # TODO: why we don't set GISBASE?
+ # Set GISBASE
+ os.environ['GISBASE'] = gisbase
mswin = sys.platform.startswith('win')
# define PATH
os.environ['PATH'] += os.pathsep + os.path.join(gisbase, 'bin')
@@ -179,6 +182,7 @@
os.environ['@LD_LIBRARY_PATH_VAR@'] = ''
os.environ['@LD_LIBRARY_PATH_VAR@'] += os.pathsep + os.path.join(gisbase, 'lib')
+ # TODO: lock the mapset?
os.environ['GIS_LOCK'] = str(os.getpid())
# Set GRASS_PYTHON and PYTHONPATH to find GRASS Python modules
@@ -207,20 +211,64 @@
# clean-up functions when terminating a GRASS session
+# these fns can only be called within a valid GRASS session
def clean_default_db():
# clean the default db if it is sqlite
from grass.script import db as gdb
from grass.script import core as gcore
conn = gdb.db_connection()
if conn and conn['driver'] == 'sqlite':
- # check if db exists
- gisenv = gcore.gisenv()
- database = conn['database']
- database = database.replace('$GISDBASE', gisenv['GISDBASE'])
- database = database.replace('$LOCATION_NAME', gisenv['LOCATION_NAME'])
- database = database.replace('$MAPSET', gisenv['MAPSET'])
- if os.path.exists(database):
- gcore.message(_("Cleaning up sqlite database ..."))
- gcore.start_command('db.execute', sql = 'VACUUM')
+ # check if db exists
+ gisenv = gcore.gisenv()
+ database = conn['database']
+ database = database.replace('$GISDBASE', gisenv['GISDBASE'])
+ database = database.replace('$LOCATION_NAME', gisenv['LOCATION_NAME'])
+ database = database.replace('$MAPSET', gisenv['MAPSET'])
+ if os.path.exists(database):
+ gcore.message(_("Cleaning up default sqlite database ..."))
+ gcore.start_command('db.execute', sql = 'VACUUM')
+ # give it some time to start
+ import time
+ time.sleep(0.1)
+def call(cmd, **kwargs):
+ import subprocess
+ """Wrapper for subprocess.call to deal with platform-specific issues"""
+ if windows:
+ kwargs['shell'] = True
+ return subprocess.call(cmd, **kwargs)
+def clean_temp():
+ from grass.script import core as gcore
+ gcore.message(_("Cleaning up temporary files..."))
+ nul = open(os.devnull, 'w')
+ gisbase = os.environ['GISBASE']
+ call([os.path.join(gisbase, "etc", "clean_temp")], stdout=nul)
+ nul.close()
+def finish():
+ """Terminate the GRASS session and clean up
+ GRASS commands can no longer be used after this function has been
+ called
+ Basic usage::
+ import grass.script as gscript
+ gscript.setup.cleanup()
+ clean_default_db()
+ clean_temp()
+ # TODO: unlock the mapset?
+ # unset the GISRC and delete the file
+ from grass.script import utils as gutils
+ gutils.try_remove(os.environ['GISRC'])
+ os.environ.pop('GISRC')
+ # remove gislock env var (not the gislock itself
+ os.environ.pop('GIS_LOCK')
