[GRASS-SVN] r73707 - grass/trunk/lib/init
svn_grass at osgeo.org
Sat Nov 24 12:26:56 PST 2018
Author: mmetz
Date: 2018-11-24 12:26:56 -0800 (Sat, 24 Nov 2018)
New Revision: 73707
grass/trunk/lib/init/grass.py
libinit: start rewriting to use functions in lib/python/scripts
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2018-11-24 20:25:27 UTC (rev 73706)
+++ grass/trunk/lib/init/grass.py 2018-11-24 20:26:56 UTC (rev 73707)
@@ -640,7 +640,12 @@
# Set PYTHONPATH to find GRASS Python modules
if os.path.exists(gpath('etc', 'python')):
- path_prepend(gpath('etc', 'python'), 'PYTHONPATH')
+ pythonpath = gpath('etc', 'python')
+ path_prepend(pythonpath, 'PYTHONPATH')
+ # the env var PYTHONPATH is only evaluated when python is started,
+ # thus:
+ sys.path.append(pythonpath)
+ # now we can import stuff from GRASS lib/python
# set path for the GRASS man pages
grass_man_path = gpath('docs', 'man')
@@ -1840,6 +1845,17 @@
nul.close()
+def clean_all():
+ from grass.script import setup as gsetup
+ # clean default sqlite db
+ gsetup.clean_default_db()
+ # remove leftover temp files
+ clean_temp()
+ # save 'last used' GISRC after removing variables which shouldn't
+ # be saved, e.g. d.mon related
+ clean_env(os.environ['GISRC'])
def grep(pattern, lines):
"""Search lines (list of strings) and return them when beginning matches.
@@ -2178,9 +2194,6 @@
# for first time user because the cost is low and first time user
# doesn't necessarily mean that the mapset is used for the first time.
clean_temp()
- # clean always at exit, cleans whatever is current mapset based on
- # the GISRC env variable
- atexit.register(clean_temp)
# build user fontcap if specified but not present
make_fontcap()
@@ -2192,8 +2205,12 @@
# only non-error, interactive version continues from here
if batch_job:
returncode = run_batch_job(batch_job)
+ clean_all(params.tmp_location)
sys.exit(returncode)
elif params.exit_grass:
+ # clean always at exit, cleans whatever is current mapset based on
+ # the GISRC env variable
sys.exit(0)
else:
clear_screen()
@@ -2230,15 +2247,13 @@
close_gui()
# here we are at the end of grass session
- from grass.script import setup as gsetup
- gsetup.clean_default_db()
clear_screen()
- # save 'last used' GISRC after removing variables which shouldn't
- # be saved, e.g. d.mon related
- clean_env(gisrc)
if not params.tmp_location:
writefile(gisrcrc, readfile(gisrc))
# After this point no more grass modules may be called
+ # done message at last: no atexit.register()
+ # or register done_message()
done_message()
if __name__ == '__main__':
