[GRASS-SVN] r73708 - grass/trunk/lib/init
Sun Nov 25 07:29:34 PST 2018
Author: mmetz
Date: 2018-11-25 07:29:34 -0800 (Sun, 25 Nov 2018)
New Revision: 73708
   grass/trunk/lib/init/grass.py
libinit: fix r73707, clean_all() takes no arguments
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py	2018-11-24 20:26:56 UTC (rev 73707)
+++ grass/trunk/lib/init/grass.py	2018-11-25 15:29:34 UTC (rev 73708)
@@ -2205,12 +2205,12 @@
     # only non-error, interactive version continues from here
     if batch_job:
         returncode = run_batch_job(batch_job)
-        clean_all(params.tmp_location)
+        clean_all()
         sys.exit(returncode)
     elif params.exit_grass:
         # clean always at exit, cleans whatever is current mapset based on
         # the GISRC env variable
+        clean_all()
         sys.exit(0)
     else:
         clear_screen()
@@ -2248,7 +2248,7 @@
         # here we are at the end of grass session
         clear_screen()
+        clean_all()
         if not params.tmp_location:
             writefile(gisrcrc, readfile(gisrc))
         # After this point no more grass modules may be called
