[GRASS-SVN] r73736 - in grass/branches/releasebranch_7_6/lib: init python/script
svn_grass at osgeo.org
Fri Nov 30 05:04:16 PST 2018
Author: neteler
Date: 2018-11-30 05:04:15 -0800 (Fri, 30 Nov 2018)
New Revision: 73736
grass/branches/releasebranch_7_6/lib/init/grass.py
grass/branches/releasebranch_7_6/lib/python/script/setup.py
sqlite db: automatically enable vacuum, trac #3697 (bundle backport: trunk r73692, r73703, r73704, r73706, r73707, r73708)
* lib/init: clean up sqlite db if existing, see #3697
* libpython: move clean_default_db() to setup
* libinit: use clean_default_db() from script.setup
* libpython: add functions to finish a GRASS session
* libinit: start rewriting to use functions in lib/python/scripts
* libinit: fix r73707, clean_all() takes no arguments
Modified: grass/branches/releasebranch_7_6/lib/init/grass.py
--- grass/branches/releasebranch_7_6/lib/init/grass.py 2018-11-30 12:35:19 UTC (rev 73735)
+++ grass/branches/releasebranch_7_6/lib/init/grass.py 2018-11-30 13:04:15 UTC (rev 73736)
@@ -607,7 +607,12 @@
# Set PYTHONPATH to find GRASS Python modules
if os.path.exists(gpath('etc', 'python')):
- path_prepend(gpath('etc', 'python'), 'PYTHONPATH')
+ pythonpath = gpath('etc', 'python')
+ path_prepend(pythonpath, 'PYTHONPATH')
+ # the env var PYTHONPATH is only evaluated when python is started,
+ # thus:
+ sys.path.append(pythonpath)
+ # now we can import stuff from GRASS lib/python
# set path for the GRASS man pages
grass_man_path = gpath('docs', 'man')
@@ -1779,6 +1784,17 @@
nul.close()
+def clean_all():
+ from grass.script import setup as gsetup
+ # clean default sqlite db
+ gsetup.clean_default_db()
+ # remove leftover temp files
+ clean_temp()
+ # save 'last used' GISRC after removing variables which shouldn't
+ # be saved, e.g. d.mon related
+ clean_env(os.environ['GISRC'])
def grep(pattern, lines):
"""Search lines (list of strings) and return them when beginning matches.
@@ -2128,10 +2144,12 @@
# only non-error, interactive version continues from here
if batch_job:
returncode = run_batch_job(batch_job)
- clean_temp()
+ clean_all()
sys.exit(returncode)
elif params.exit_grass:
- clean_temp()
+ # clean always at exit, cleans whatever is current mapset based on
+ # the GISRC env variable
+ clean_all()
sys.exit(0)
else:
clear_screen()
@@ -2166,17 +2184,15 @@
# close GUI if running
close_gui()
# here we are at the end of grass session
clear_screen()
- # TODO: can we just register this atexit?
- # TODO: and what is difference to deleting .tmp which we do?
- clean_temp()
- # save 'last used' GISRC after removing variables which shouldn't
- # be saved, e.g. d.mon related
- clean_env(gisrc)
+ clean_all()
if not params.tmp_location:
writefile(gisrcrc, readfile(gisrc))
# After this point no more grass modules may be called
+ # done message at last: no atexit.register()
+ # or register done_message()
done_message()
if __name__ == '__main__':
Modified: grass/branches/releasebranch_7_6/lib/python/script/setup.py
--- grass/branches/releasebranch_7_6/lib/python/script/setup.py 2018-11-30 12:35:19 UTC (rev 73735)
+++ grass/branches/releasebranch_7_6/lib/python/script/setup.py 2018-11-30 13:04:15 UTC (rev 73736)
@@ -1,7 +1,7 @@
-"""Setup and initialization functions
+"""Setup, initialization, and clean-up functions
-Function can be used in Python scripts to setup a GRASS environment
-without starting an actual GRASS session.
+Functions can be used in Python scripts to setup a GRASS environment
+and session without using grassXY.
Usage::
@@ -77,8 +77,8 @@
for vect in gscript.list_strings(type='vector'):
print vect
- # delete the rcfile
- os.remove(rcfile)
+ # clean up at the end
+ gsetup.cleanup()
(C) 2010-2012 by the GRASS Development Team
@@ -88,6 +88,7 @@
@author Martin Landa <landa.martin gmail.com>
@author Vaclav Petras <wenzeslaus gmail.com>
+ at author Markus Metz
# TODO: this should share code from lib/init/grass.py
@@ -100,6 +101,9 @@
import tempfile as tmpfile
+windows = sys.platform == 'win32'
def write_gisrc(dbase, location, mapset):
"""Write the ``gisrc`` file and return its path."""
gisrc = tmpfile.mktemp()
@@ -117,21 +121,19 @@
sys.path.insert(0, gui_path)
-# TODO: there should be a function to do the clean up
-# (unset the GISRC and delete the file)
def init(gisbase, dbase='', location='demolocation', mapset='PERMANENT'):
"""Initialize system variables to run GRASS modules
- This function is for running GRASS GIS without starting it
- explicitly. No GRASS modules shall be called before call of this
- function but any module or user script can be called afterwards
- as if it would be called in an actual GRASS session. GRASS Python
- libraries are usable as well in general but the ones using
- C libraries through ``ctypes`` are not (which is caused by
- library path not being updated for the current process
- which is a common operating system limitation).
+ This function is for running GRASS GIS without starting it with the
+ standard script grassXY. No GRASS modules shall be called before
+ call of this function but any module or user script can be called
+ afterwards because a GRASS session has been set up. GRASS Python
+ libraries are usable as well in general but the ones using C
+ libraries through ``ctypes`` are not (which is caused by library
+ path not being updated for the current process which is a common
+ operating system limitation).
- To create a (fake) GRASS session a ``gisrc`` file is created.
+ To create a GRASS session a ``gisrc`` file is created.
Caller is responsible for deleting the ``gisrc`` file.
Basic usage::
@@ -142,8 +144,8 @@
"/home/john/grassdata",
"nc_spm_08", "user1")
# ... use GRASS modules here
- # remove the session's gisrc file to end the session
- os.remove(gisrc)
+ # end the session
+ gscript.setup.finish()
:param gisbase: path to GRASS installation
:param dbase: path to GRASS database (default: '')
@@ -152,7 +154,8 @@
:returns: path to ``gisrc`` file (to be deleted later)
- # TODO: why we don't set GISBASE?
+ # Set GISBASE
+ os.environ['GISBASE'] = gisbase
mswin = sys.platform.startswith('win')
# define PATH
os.environ['PATH'] += os.pathsep + os.path.join(gisbase, 'bin')
@@ -179,6 +182,7 @@
os.environ['@LD_LIBRARY_PATH_VAR@'] = ''
os.environ['@LD_LIBRARY_PATH_VAR@'] += os.pathsep + os.path.join(gisbase, 'lib')
+ # TODO: lock the mapset?
os.environ['GIS_LOCK'] = str(os.getpid())
# Set GRASS_PYTHON and PYTHONPATH to find GRASS Python modules
@@ -204,3 +208,67 @@
os.environ['GISRC'] = write_gisrc(dbase, location, mapset)
return os.environ['GISRC']
+# clean-up functions when terminating a GRASS session
+# these fns can only be called within a valid GRASS session
+def clean_default_db():
+ # clean the default db if it is sqlite
+ from grass.script import db as gdb
+ from grass.script import core as gcore
+ conn = gdb.db_connection()
+ if conn and conn['driver'] == 'sqlite':
+ # check if db exists
+ gisenv = gcore.gisenv()
+ database = conn['database']
+ database = database.replace('$GISDBASE', gisenv['GISDBASE'])
+ database = database.replace('$LOCATION_NAME', gisenv['LOCATION_NAME'])
+ database = database.replace('$MAPSET', gisenv['MAPSET'])
+ if os.path.exists(database):
+ gcore.message(_("Cleaning up default sqlite database ..."))
+ gcore.start_command('db.execute', sql = 'VACUUM')
+ # give it some time to start
+ import time
+ time.sleep(0.1)
+def call(cmd, **kwargs):
+ import subprocess
+ """Wrapper for subprocess.call to deal with platform-specific issues"""
+ if windows:
+ kwargs['shell'] = True
+ return subprocess.call(cmd, **kwargs)
+def clean_temp():
+ gcore.message(_("Cleaning up temporary files..."))
+ nul = open(os.devnull, 'w')
+ gisbase = os.environ['GISBASE']
+ call([os.path.join(gisbase, "etc", "clean_temp")], stdout=nul)
+ nul.close()
+def finish():
+ """Terminate the GRASS session and clean up
+ GRASS commands can no longer be used after this function has been
+ called
+ Basic usage::
+ import grass.script as gscript
+ gscript.setup.cleanup()
+ clean_default_db()
+ clean_temp()
+ # TODO: unlock the mapset?
+ # unset the GISRC and delete the file
+ from grass.script import utils as gutils
+ gutils.try_remove(os.environ['GISRC'])
+ os.environ.pop('GISRC')
+ # remove gislock env var (not the gislock itself
+ os.environ.pop('GIS_LOCK')
