[GRASS-SVN] r73597 - in grass/branches/releasebranch_7_6: lib/pngdriver locale/po
Mon Oct 22 13:59:53 PDT 2018
Author: neteler
Date: 2018-10-22 13:59:53 -0700 (Mon, 22 Oct 2018)
New Revision: 73597
   grass/branches/releasebranch_7_6/lib/pngdriver/read_png.c
   grass/branches/releasebranch_7_6/locale/po/grasslibs_ar.po
   grass/branches/releasebranch_7_6/locale/po/grasslibs_bn.po
   grass/branches/releasebranch_7_6/locale/po/grasslibs_cs.po
   grass/branches/releasebranch_7_6/locale/po/grasslibs_de.po
   grass/branches/releasebranch_7_6/locale/po/grasslibs_el.po
   grass/branches/releasebranch_7_6/locale/po/grasslibs_es.po
   grass/branches/releasebranch_7_6/locale/po/grasslibs_fi.po
   grass/branches/releasebranch_7_6/locale/po/grasslibs_fr.po
   grass/branches/releasebranch_7_6/locale/po/grasslibs_hu.po
   grass/branches/releasebranch_7_6/locale/po/grasslibs_id_ID.po
   grass/branches/releasebranch_7_6/locale/po/grasslibs_it.po
   grass/branches/releasebranch_7_6/locale/po/grasslibs_ja.po
   grass/branches/releasebranch_7_6/locale/po/grasslibs_ko.po
   grass/branches/releasebranch_7_6/locale/po/grasslibs_lv.po
   grass/branches/releasebranch_7_6/locale/po/grasslibs_ml.po
   grass/branches/releasebranch_7_6/locale/po/grasslibs_pl.po
   grass/branches/releasebranch_7_6/locale/po/grasslibs_pt.po
   grass/branches/releasebranch_7_6/locale/po/grasslibs_pt_BR.po
   grass/branches/releasebranch_7_6/locale/po/grasslibs_ro.po
   grass/branches/releasebranch_7_6/locale/po/grasslibs_ru.po
   grass/branches/releasebranch_7_6/locale/po/grasslibs_si.po
   grass/branches/releasebranch_7_6/locale/po/grasslibs_sl.po
   grass/branches/releasebranch_7_6/locale/po/grasslibs_ta.po
   grass/branches/releasebranch_7_6/locale/po/grasslibs_th.po
   grass/branches/releasebranch_7_6/locale/po/grasslibs_tr.po
   grass/branches/releasebranch_7_6/locale/po/grasslibs_uk.po
   grass/branches/releasebranch_7_6/locale/po/grasslibs_vi.po
   grass/branches/releasebranch_7_6/locale/po/grasslibs_zh.po
pngdriver: typo (trunk r73589, r73596)
Modified: grass/branches/releasebranch_7_6/lib/pngdriver/read_png.c
--- grass/branches/releasebranch_7_6/lib/pngdriver/read_png.c	2018-10-22 20:58:35 UTC (rev 73596)
+++ grass/branches/releasebranch_7_6/lib/pngdriver/read_png.c	2018-10-22 20:59:53 UTC (rev 73597)
@@ -57,7 +57,7 @@
     png_ptr =
 	png_create_read_struct(PNG_LIBPNG_VER_STRING, &jbuf, NULL, NULL);
     if (!png_ptr)
-        G_fatal_error(_("Unable allocate PNG structure"));
+        G_fatal_error(_("Unable to allocate PNG structure"));
     info_ptr = png_create_info_struct(png_ptr);
     if (!info_ptr)
Modified: grass/branches/releasebranch_7_6/locale/po/grasslibs_ar.po
--- grass/branches/releasebranch_7_6/locale/po/grasslibs_ar.po	2018-10-22 20:58:35 UTC (rev 73596)
+++ grass/branches/releasebranch_7_6/locale/po/grasslibs_ar.po	2018-10-22 20:59:53 UTC (rev 73597)
@@ -3338,7 +3338,7 @@
 #: ../lib/pngdriver/read_png.c:60
 #, fuzzy
-msgid "Unable allocate PNG structure"
+msgid "Unable to allocate PNG structure"
 msgstr "لم يمكن توفير ذاكرة كافية\n"
 #: ../lib/pngdriver/read_png.c:64 ../lib/pngdriver/write_png.c:71
Modified: grass/branches/releasebranch_7_6/locale/po/grasslibs_bn.po
--- grass/branches/releasebranch_7_6/locale/po/grasslibs_bn.po	2018-10-22 20:58:35 UTC (rev 73596)
+++ grass/branches/releasebranch_7_6/locale/po/grasslibs_bn.po	2018-10-22 20:59:53 UTC (rev 73597)
@@ -1072,7 +1072,7 @@
 msgstr ""
 msgstr ""
 #: ../lib/pngdriver/read_png.c:67
Modified: grass/branches/releasebranch_7_6/locale/po/grasslibs_cs.po
--- grass/branches/releasebranch_7_6/locale/po/grasslibs_cs.po	2018-10-22 20:58:35 UTC (rev 73596)
+++ grass/branches/releasebranch_7_6/locale/po/grasslibs_cs.po	2018-10-22 20:59:53 UTC (rev 73597)
@@ -3134,7 +3134,7 @@
 msgstr ""
 msgstr ""
Modified: grass/branches/releasebranch_7_6/locale/po/grasslibs_de.po
--- grass/branches/releasebranch_7_6/locale/po/grasslibs_de.po	2018-10-22 20:58:35 UTC (rev 73596)
+++ grass/branches/releasebranch_7_6/locale/po/grasslibs_de.po	2018-10-22 20:59:53 UTC (rev 73597)
@@ -3132,7 +3132,7 @@
 msgstr "Kann PNG nicht lesen"
 msgstr ""
Modified: grass/branches/releasebranch_7_6/locale/po/grasslibs_el.po
--- grass/branches/releasebranch_7_6/locale/po/grasslibs_el.po	2018-10-22 20:58:35 UTC (rev 73596)
+++ grass/branches/releasebranch_7_6/locale/po/grasslibs_el.po	2018-10-22 20:59:53 UTC (rev 73597)
@@ -3127,7 +3127,7 @@
 msgstr ""
 msgstr ""
Modified: grass/branches/releasebranch_7_6/locale/po/grasslibs_es.po
--- grass/branches/releasebranch_7_6/locale/po/grasslibs_es.po	2018-10-22 20:58:35 UTC (rev 73596)
+++ grass/branches/releasebranch_7_6/locale/po/grasslibs_es.po	2018-10-22 20:59:53 UTC (rev 73597)
@@ -3170,7 +3170,7 @@
 msgstr "No se puede leer PNG"
 msgstr "No ha sido posible asignar estructura PNG"
Modified: grass/branches/releasebranch_7_6/locale/po/grasslibs_fi.po
--- grass/branches/releasebranch_7_6/locale/po/grasslibs_fi.po	2018-10-22 20:58:35 UTC (rev 73596)
+++ grass/branches/releasebranch_7_6/locale/po/grasslibs_fi.po	2018-10-22 20:59:53 UTC (rev 73597)
 msgstr ""
 msgstr ""
Modified: grass/branches/releasebranch_7_6/locale/po/grasslibs_fr.po
--- grass/branches/releasebranch_7_6/locale/po/grasslibs_fr.po	2018-10-22 20:58:35 UTC (rev 73596)
+++ grass/branches/releasebranch_7_6/locale/po/grasslibs_fr.po	2018-10-22 20:59:53 UTC (rev 73597)
@@ -3165,7 +3165,7 @@
 msgstr "Impossible de lire le PNG"
 msgstr "Allocation de structure PNG impossible"
Modified: grass/branches/releasebranch_7_6/locale/po/grasslibs_hu.po
--- grass/branches/releasebranch_7_6/locale/po/grasslibs_hu.po	2018-10-22 20:58:35 UTC (rev 73596)
+++ grass/branches/releasebranch_7_6/locale/po/grasslibs_hu.po	2018-10-22 20:59:53 UTC (rev 73597)
@@ -3126,7 +3126,7 @@
 msgstr ""
 msgstr ""
Modified: grass/branches/releasebranch_7_6/locale/po/grasslibs_id_ID.po
--- grass/branches/releasebranch_7_6/locale/po/grasslibs_id_ID.po	2018-10-22 20:58:35 UTC (rev 73596)
+++ grass/branches/releasebranch_7_6/locale/po/grasslibs_id_ID.po	2018-10-22 20:59:53 UTC (rev 73597)
 msgstr ""
 msgstr ""
Modified: grass/branches/releasebranch_7_6/locale/po/grasslibs_it.po
--- grass/branches/releasebranch_7_6/locale/po/grasslibs_it.po	2018-10-22 20:58:35 UTC (rev 73596)
+++ grass/branches/releasebranch_7_6/locale/po/grasslibs_it.po	2018-10-22 20:59:53 UTC (rev 73597)
@@ -3143,7 +3143,7 @@
 msgstr "Impossibile leggere PNG"
 msgstr "Impossibile allocare struttura PNG"
Modified: grass/branches/releasebranch_7_6/locale/po/grasslibs_ja.po
--- grass/branches/releasebranch_7_6/locale/po/grasslibs_ja.po	2018-10-22 20:58:35 UTC (rev 73596)
+++ grass/branches/releasebranch_7_6/locale/po/grasslibs_ja.po	2018-10-22 20:59:53 UTC (rev 73597)
 msgstr "PNGの読み込みができません"
 msgstr ""
Modified: grass/branches/releasebranch_7_6/locale/po/grasslibs_ko.po
--- grass/branches/releasebranch_7_6/locale/po/grasslibs_ko.po	2018-10-22 20:58:35 UTC (rev 73596)
+++ grass/branches/releasebranch_7_6/locale/po/grasslibs_ko.po	2018-10-22 20:59:53 UTC (rev 73597)
 msgstr ""
 msgstr ""
Modified: grass/branches/releasebranch_7_6/locale/po/grasslibs_lv.po
--- grass/branches/releasebranch_7_6/locale/po/grasslibs_lv.po	2018-10-22 20:58:35 UTC (rev 73596)
+++ grass/branches/releasebranch_7_6/locale/po/grasslibs_lv.po	2018-10-22 20:59:53 UTC (rev 73597)
@@ -3269,7 +3269,7 @@
 msgstr "Nevar nolasīt PNG"
 msgstr ""
Modified: grass/branches/releasebranch_7_6/locale/po/grasslibs_ml.po
--- grass/branches/releasebranch_7_6/locale/po/grasslibs_ml.po	2018-10-22 20:58:35 UTC (rev 73596)
+++ grass/branches/releasebranch_7_6/locale/po/grasslibs_ml.po	2018-10-22 20:59:53 UTC (rev 73597)
 msgstr ""
 msgstr ""
Modified: grass/branches/releasebranch_7_6/locale/po/grasslibs_pl.po
--- grass/branches/releasebranch_7_6/locale/po/grasslibs_pl.po	2018-10-22 20:58:35 UTC (rev 73596)
+++ grass/branches/releasebranch_7_6/locale/po/grasslibs_pl.po	2018-10-22 20:59:53 UTC (rev 73597)
@@ -3128,7 +3128,7 @@
 msgstr ""
 msgstr ""
Modified: grass/branches/releasebranch_7_6/locale/po/grasslibs_pt.po
--- grass/branches/releasebranch_7_6/locale/po/grasslibs_pt.po	2018-10-22 20:58:35 UTC (rev 73596)
+++ grass/branches/releasebranch_7_6/locale/po/grasslibs_pt.po	2018-10-22 20:59:53 UTC (rev 73597)
@@ -3130,7 +3130,7 @@
 msgstr ""
 msgstr ""
Modified: grass/branches/releasebranch_7_6/locale/po/grasslibs_pt_BR.po
--- grass/branches/releasebranch_7_6/locale/po/grasslibs_pt_BR.po	2018-10-22 20:58:35 UTC (rev 73596)
+++ grass/branches/releasebranch_7_6/locale/po/grasslibs_pt_BR.po	2018-10-22 20:59:53 UTC (rev 73597)
 msgstr ""
 msgstr ""
Modified: grass/branches/releasebranch_7_6/locale/po/grasslibs_ro.po
--- grass/branches/releasebranch_7_6/locale/po/grasslibs_ro.po	2018-10-22 20:58:35 UTC (rev 73596)
+++ grass/branches/releasebranch_7_6/locale/po/grasslibs_ro.po	2018-10-22 20:59:53 UTC (rev 73597)
@@ -3125,7 +3125,7 @@
 msgstr ""
 msgstr ""
Modified: grass/branches/releasebranch_7_6/locale/po/grasslibs_ru.po
--- grass/branches/releasebranch_7_6/locale/po/grasslibs_ru.po	2018-10-22 20:58:35 UTC (rev 73596)
+++ grass/branches/releasebranch_7_6/locale/po/grasslibs_ru.po	2018-10-22 20:59:53 UTC (rev 73597)
 msgstr ""
 msgstr ""
Modified: grass/branches/releasebranch_7_6/locale/po/grasslibs_si.po
--- grass/branches/releasebranch_7_6/locale/po/grasslibs_si.po	2018-10-22 20:58:35 UTC (rev 73596)
+++ grass/branches/releasebranch_7_6/locale/po/grasslibs_si.po	2018-10-22 20:59:53 UTC (rev 73597)
 msgstr ""
 msgstr ""
Modified: grass/branches/releasebranch_7_6/locale/po/grasslibs_sl.po
--- grass/branches/releasebranch_7_6/locale/po/grasslibs_sl.po	2018-10-22 20:58:35 UTC (rev 73596)
+++ grass/branches/releasebranch_7_6/locale/po/grasslibs_sl.po	2018-10-22 20:59:53 UTC (rev 73597)
@@ -3359,7 +3359,7 @@
 #, fuzzy
 msgstr "Nezmožen dodeliti spomin\n"
Modified: grass/branches/releasebranch_7_6/locale/po/grasslibs_ta.po
--- grass/branches/releasebranch_7_6/locale/po/grasslibs_ta.po	2018-10-22 20:58:35 UTC (rev 73596)
+++ grass/branches/releasebranch_7_6/locale/po/grasslibs_ta.po	2018-10-22 20:59:53 UTC (rev 73597)
 msgstr ""
 msgstr ""
Modified: grass/branches/releasebranch_7_6/locale/po/grasslibs_th.po
--- grass/branches/releasebranch_7_6/locale/po/grasslibs_th.po	2018-10-22 20:58:35 UTC (rev 73596)
+++ grass/branches/releasebranch_7_6/locale/po/grasslibs_th.po	2018-10-22 20:59:53 UTC (rev 73597)
 msgstr ""
 msgstr ""
Modified: grass/branches/releasebranch_7_6/locale/po/grasslibs_tr.po
--- grass/branches/releasebranch_7_6/locale/po/grasslibs_tr.po	2018-10-22 20:58:35 UTC (rev 73596)
+++ grass/branches/releasebranch_7_6/locale/po/grasslibs_tr.po	2018-10-22 20:59:53 UTC (rev 73597)
 msgstr ""
 msgstr ""
Modified: grass/branches/releasebranch_7_6/locale/po/grasslibs_uk.po
--- grass/branches/releasebranch_7_6/locale/po/grasslibs_uk.po	2018-10-22 20:58:35 UTC (rev 73596)
+++ grass/branches/releasebranch_7_6/locale/po/grasslibs_uk.po	2018-10-22 20:59:53 UTC (rev 73597)
 msgstr ""
 msgstr ""
Modified: grass/branches/releasebranch_7_6/locale/po/grasslibs_vi.po
--- grass/branches/releasebranch_7_6/locale/po/grasslibs_vi.po	2018-10-22 20:58:35 UTC (rev 73596)
+++ grass/branches/releasebranch_7_6/locale/po/grasslibs_vi.po	2018-10-22 20:59:53 UTC (rev 73597)
 msgstr ""
 msgstr ""
Modified: grass/branches/releasebranch_7_6/locale/po/grasslibs_zh.po
--- grass/branches/releasebranch_7_6/locale/po/grasslibs_zh.po	2018-10-22 20:58:35 UTC (rev 73596)
+++ grass/branches/releasebranch_7_6/locale/po/grasslibs_zh.po	2018-10-22 20:59:53 UTC (rev 73597)
 msgstr ""
 msgstr ""
