[GRASS-SVN] r73598 - in grass/branches/releasebranch_7_6/lib/python: gunittest pygrass/gis pygrass/modules pygrass/modules/grid pygrass/modules/interface pygrass/raster temporal
svn_grass at osgeo.org
Mon Oct 22 14:04:04 PDT 2018
Author: neteler
Date: 2018-10-22 14:04:04 -0700 (Mon, 22 Oct 2018)
New Revision: 73598
grass/branches/releasebranch_7_6/lib/python/gunittest/gmodules.py
grass/branches/releasebranch_7_6/lib/python/pygrass/gis/__init__.py
grass/branches/releasebranch_7_6/lib/python/pygrass/modules/grid/grid.py
grass/branches/releasebranch_7_6/lib/python/pygrass/modules/interface/module.py
grass/branches/releasebranch_7_6/lib/python/pygrass/modules/shortcuts.py
grass/branches/releasebranch_7_6/lib/python/pygrass/raster/__init__.py
grass/branches/releasebranch_7_6/lib/python/temporal/base.py
grass/branches/releasebranch_7_6/lib/python/temporal/c_libraries_interface.py
grass/branches/releasebranch_7_6/lib/python/temporal/temporal_extent.py
pygrass library, temporal framework: Fixed doctests (bundle backport, trunk r73579:r73587)
Modified: grass/branches/releasebranch_7_6/lib/python/gunittest/gmodules.py
--- grass/branches/releasebranch_7_6/lib/python/gunittest/gmodules.py 2018-10-22 20:59:53 UTC (rev 73597)
+++ grass/branches/releasebranch_7_6/lib/python/gunittest/gmodules.py 2018-10-22 21:04:04 UTC (rev 73598)
@@ -39,7 +39,7 @@
>>> str(colors.outputs.stdout)
>>> colors.outputs.stderr.strip()
- "Color table for raster map <test_a> set to 'rules'"
+ u"Color table for raster map <test_a> set to 'rules'"
def __init__(self, cmd, *args, **kargs):
for banned in ['stdout_', 'stderr_', 'finish_', 'run_']:
Modified: grass/branches/releasebranch_7_6/lib/python/pygrass/gis/__init__.py
--- grass/branches/releasebranch_7_6/lib/python/pygrass/gis/__init__.py 2018-10-22 20:59:53 UTC (rev 73597)
+++ grass/branches/releasebranch_7_6/lib/python/pygrass/gis/__init__.py 2018-10-22 21:04:04 UTC (rev 73598)
@@ -14,6 +14,9 @@
from grass.pygrass.errors import GrassError
from grass.script.utils import encode, decode
+test_vector_name = "Gis_test_vector"
+test_raster_name = "Gis_test_raster"
libgis.G_gisinit('')
@@ -466,9 +469,6 @@
from grass.pygrass import utils
from grass.script.core import run_command
- test_vector_name = "Gis_test_vector"
- test_raster_name = "Gis_test_raster"
utils.create_test_vector_map(test_vector_name)
run_command("g.region", n=50, s=0, e=60, w=0, res=1)
run_command("r.mapcalc", expression="%s = 1" % (test_raster_name),
Modified: grass/branches/releasebranch_7_6/lib/python/pygrass/modules/grid/grid.py
--- grass/branches/releasebranch_7_6/lib/python/pygrass/modules/grid/grid.py 2018-10-22 20:59:53 UTC (rev 73597)
+++ grass/branches/releasebranch_7_6/lib/python/pygrass/modules/grid/grid.py 2018-10-22 21:04:04 UTC (rev 73598)
@@ -83,7 +83,7 @@
>>> sorted(os.listdir(path)) # doctest: +ELLIPSIS
[...'PERMANENT'...]
>>> sorted(os.listdir(os.path.join(path, 'PERMANENT')))
- [u'DEFAULT_WIND', u'PROJ_INFO', u'PROJ_UNITS', u'VAR', u'WIND']
+ [u'DEFAULT_WIND', u'PROJ_EPSG', u'PROJ_INFO', u'PROJ_UNITS', u'VAR', u'WIND']
>>> sorted(os.listdir(os.path.join(path, mname))) # doctest: +ELLIPSIS
[...u'SEARCH_PATH',...u'WIND']
>>> import shutil
Modified: grass/branches/releasebranch_7_6/lib/python/pygrass/modules/interface/module.py
--- grass/branches/releasebranch_7_6/lib/python/pygrass/modules/interface/module.py 2018-10-22 20:59:53 UTC (rev 73597)
+++ grass/branches/releasebranch_7_6/lib/python/pygrass/modules/interface/module.py 2018-10-22 21:04:04 UTC (rev 73598)
@@ -394,7 +394,7 @@
>>> colors.outputs["stdout"].value
u''
>>> colors.outputs["stderr"].value.strip()
>>> colors = Module("r.colors", map="test_a", rules="-",
... run_=False, finish_=False, stdin_=PIPE)
Modified: grass/branches/releasebranch_7_6/lib/python/pygrass/modules/shortcuts.py
--- grass/branches/releasebranch_7_6/lib/python/pygrass/modules/shortcuts.py 2018-10-22 20:59:53 UTC (rev 73597)
+++ grass/branches/releasebranch_7_6/lib/python/pygrass/modules/shortcuts.py 2018-10-22 21:04:04 UTC (rev 73598)
@@ -26,7 +26,7 @@
>>> g_list.run()
Module('g.list')
>>> g_list.outputs.stdout # doctest: +ELLIPSIS
- '...basin...soils...'
+ u'...basin...elevation...'
>>> r = MetaModule('r')
>>> what = r.what
>>> what.description
Modified: grass/branches/releasebranch_7_6/lib/python/pygrass/raster/__init__.py
--- grass/branches/releasebranch_7_6/lib/python/pygrass/raster/__init__.py 2018-10-22 20:59:53 UTC (rev 73597)
+++ grass/branches/releasebranch_7_6/lib/python/pygrass/raster/__init__.py 2018-10-22 21:04:04 UTC (rev 73598)
@@ -99,27 +99,27 @@
to interact with the raster categories.
>>> elev.cats # doctest: +ELLIPSIS +NORMALIZE_WHITESPACE
- [('A', 11, None),
- ('B', 12, None),
+ [(u'A', 11, None),
+ (u'B', 12, None),
- ('P', 44, None)]
+ (u'P', 44, None)]
>>> elev.cats.labels() # doctest: +ELLIPSIS +NORMALIZE_WHITESPACE
- ['A', 'B', 'C', 'D', 'E',
- 'F', 'G', 'H', 'I', 'J',
- 'K', 'L', 'M', 'n', 'O', 'P']
+ [u'A', u'B', u'C', u'D', u'E',
+ u'F', u'G', u'H', u'I', u'J',
+ u'K', u'L', u'M', u'n', u'O', u'P']
>>> elev.cats[0]
- ('A', 11, None)
+ (u'A', 11, None)
>>> elev.cats[2]
- ('C', 13, None)
+ (u'C', 13, None)
>>> elev.cats[0] = ('AA', 11)
>>> elev.cats[1] = ('BB', 12)
>>> elev.cats.write()
>>> elev.cats.read()
>>> elev.cats[0]
- ('AA', 11, None)
+ (u'AA', 11, None)
>>> elev.cats[1]
- ('BB', 12, None)
+ (u'BB', 12, None)
Open a raster map using the *with statement*:
Modified: grass/branches/releasebranch_7_6/lib/python/temporal/base.py
--- grass/branches/releasebranch_7_6/lib/python/temporal/base.py 2018-10-22 20:59:53 UTC (rev 73597)
+++ grass/branches/releasebranch_7_6/lib/python/temporal/base.py 2018-10-22 21:04:04 UTC (rev 73598)
@@ -563,7 +563,7 @@
mapset=PERMANENT
creator=soeren
temporal_type=absolute
- creation_time=2001-01-01 00:00:00
+ creation_time='2001-01-01 00:00:00'
@@ -860,8 +860,8 @@
mapset=PERMANENT
creator=soeren
- modification_time=2001-01-01 00:00:00
+ modification_time='2001-01-01 00:00:00'
semantic_type=average
Modified: grass/branches/releasebranch_7_6/lib/python/temporal/c_libraries_interface.py
--- grass/branches/releasebranch_7_6/lib/python/temporal/c_libraries_interface.py 2018-10-22 20:59:53 UTC (rev 73597)
+++ grass/branches/releasebranch_7_6/lib/python/temporal/c_libraries_interface.py 2018-10-22 21:04:04 UTC (rev 73598)
@@ -1075,7 +1075,7 @@
>>> kvp['area']
0
>>> kvp['lines']
- 10
+ 0
>>> kvp['line']
0
>>> 'columns' in kvp
Modified: grass/branches/releasebranch_7_6/lib/python/temporal/temporal_extent.py
--- grass/branches/releasebranch_7_6/lib/python/temporal/temporal_extent.py 2018-10-22 20:59:53 UTC (rev 73597)
+++ grass/branches/releasebranch_7_6/lib/python/temporal/temporal_extent.py 2018-10-22 21:04:04 UTC (rev 73598)
@@ -58,8 +58,8 @@
| Start time:................. 2001-01-01 00:00:00
| End time:................... 2005-01-01 00:00:00
>>> A.print_shell_info()
- start_time=2001-01-01 00:00:00
- end_time=2005-01-01 00:00:00
+ start_time='2001-01-01 00:00:00'
+ end_time='2005-01-01 00:00:00'
>>> # relative time
>>> A = TemporalExtent(table="raster_absolute_time",
... ident="soil at PERMANENT", start_time=0, end_time=1 )
@@ -73,8 +73,8 @@
| Start time:................. 0
| End time:................... 1
- start_time=0
- end_time=1
+ start_time='0'
+ end_time='1'
def __init__(self, table=None, ident=None, start_time=None, end_time=None):
@@ -1119,9 +1119,9 @@
| Granularity:................ 1 days
| Temporal type of maps:...... interval
- granularity=1 days
+ granularity='1 days'
map_time=interval
@@ -1243,8 +1243,8 @@
| Relative time unit:......... years
- start_time=0
- end_time=1
+ start_time='0'
+ end_time='1'
unit=years
@@ -1367,8 +1367,8 @@
| Granularity:................ 5
- start_time=0
- end_time=1
+ start_time='0'
+ end_time='1'
unit=years
granularity=5
map_time=interval
