[GRASS-SVN] r73240 - grass/branches/releasebranch_7_4/lib/python/script
svn_grass at osgeo.org
Mon Sep 3 14:00:40 PDT 2018
Author: neteler
Date: 2018-09-03 14:00:40 -0700 (Mon, 03 Sep 2018)
New Revision: 73240
grass/branches/releasebranch_7_4/lib/python/script/core.py
libpython: by default, no error output is produced even though the output in case of failure reads "Process ended with non-zero return code 1. See errors in the (error) output.", change default to cpature and report error output (backport trunk r73238)
Modified: grass/branches/releasebranch_7_4/lib/python/script/core.py
--- grass/branches/releasebranch_7_4/lib/python/script/core.py 2018-09-03 20:45:21 UTC (rev 73239)
+++ grass/branches/releasebranch_7_4/lib/python/script/core.py 2018-09-03 21:00:40 UTC (rev 73240)
@@ -78,7 +78,7 @@
raise_on_error = False # raise exception instead of calling fatal()
-_capture_stderr = False # capture stderr of subprocesses if possible
+_capture_stderr = True # capture stderr of subprocesses if possible
def call(*args, **kwargs):
