[GRASS-SVN] r73241 - grass/trunk/lib/init
svn_grass at osgeo.org
Mon Sep 3 14:14:23 PDT 2018
Author: annakrat
Date: 2018-09-03 14:14:23 -0700 (Mon, 03 Sep 2018)
New Revision: 73241
grass/trunk/lib/init/grass.py
init: reintroduce fixed to_text_str function to encode/decode correctly paths
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2018-09-03 21:00:40 UTC (rev 73240)
+++ grass/trunk/lib/init/grass.py 2018-09-03 21:14:23 UTC (rev 73241)
@@ -56,24 +56,66 @@
ENCODING = 'UTF-8'
print("Default locale not found, using UTF-8") # intentionally not translatable
+def decode(bytes_, encoding=None):
+ """Decode bytes with default locale and return (unicode) string
+ Adapted from lib/python/core/utils.py
+ No-op if parameter is not bytes (assumed unicode string).
+ :param bytes bytes_: the bytes to decode
+ :param encoding: encoding to be used, default value is None
+ if sys.version_info.major >= 3:
+ unicode = str
+ if isinstance(bytes_, unicode):
+ return bytes_
+ elif isinstance(bytes_, bytes):
+ if encoding is None:
+ enc = ENCODING
+ else:
+ enc = encoding
+ return bytes_.decode(enc)
+ else:
+ # if something else than text
+ raise TypeError("can only accept types str and bytes")
+def encode(string, encoding=None):
+ """Encode string with default locale and return bytes with that encoding
+ No-op if parameter is bytes (assumed already encoded).
+ This ensures garbage in, garbage out.
+ :param str string: the string to encode
+ unicode = str
+ if isinstance(string, bytes):
+ return string
+ # this also tests str in Py3:
+ elif isinstance(string, unicode):
+ enc = ENCODING
+ else:
+ enc = encoding
+ return string.encode(enc)
+ else:
# currently not used, see https://trac.osgeo.org/grass/ticket/3508
def to_text_string(obj, encoding=ENCODING):
"""Convert `obj` to (unicode) text string"""
if PY2:
# Python 2
- if encoding is None:
- return unicode(obj)
- else:
- return unicode(obj, encoding)
+ return encode(obj, encoding=encoding)
else:
# Python 3
- return str(obj)
- elif isinstance(obj, str):
- # In case this function is not used properly, this could happen
- return obj
- else:
- return str(obj, encoding)
+ return decode(obj, encoding=encoding)
if PY2:
@@ -618,15 +660,11 @@
pass
if sys_man_path:
- # to_text_string disabled, see https://trac.osgeo.org/grass/ticket/3508
- # os.environ['MANPATH'] = to_text_string(sys_man_path)
- os.environ['MANPATH'] = sys_man_path
+ os.environ['MANPATH'] = to_text_string(sys_man_path)
path_prepend(addons_man_path, 'MANPATH')
path_prepend(grass_man_path, 'MANPATH')
else:
- # os.environ['MANPATH'] = to_text_string(addons_man_path)
- os.environ['MANPATH'] = addons_man_path
+ os.environ['MANPATH'] = to_text_string(addons_man_path)
# Set LD_LIBRARY_PATH (etc) to find GRASS shared libraries
