[GRASS-SVN] r73258 - grass-addons/grass7/imagery/i.sentinel/i.sentinel.preproc
svn_grass at osgeo.org
Tue Sep 4 09:31:01 PDT 2018
Author: Robifag
Date: 2018-09-04 09:31:01 -0700 (Tue, 04 Sep 2018)
New Revision: 73258
grass-addons/grass7/imagery/i.sentinel/i.sentinel.preproc/i.sentinel.preproc.py
i.sentinel.preproc: add input control check and fixed a Windows syntax error in gscript.message
Modified: grass-addons/grass7/imagery/i.sentinel/i.sentinel.preproc/i.sentinel.preproc.py
--- grass-addons/grass7/imagery/i.sentinel/i.sentinel.preproc/i.sentinel.preproc.py 2018-09-04 16:30:21 UTC (rev 73257)
+++ grass-addons/grass7/imagery/i.sentinel/i.sentinel.preproc/i.sentinel.preproc.py 2018-09-04 16:31:01 UTC (rev 73258)
@@ -157,6 +157,9 @@
# Check if the input folder has old or new name
# Check if the input folder belongs to a L1C image
level_dir = os.path.basename(input_dir).split('_')
+ # Check if the input directory is a .SAFE folder
+ if not input_dir.endswith('.SAFE'):
+ gscript.fatal('The input directory is not a .SAFE folder. Please check the input directory')
if level_dir[1] == 'OPER' and level_dir[3] == 'MSIL1C':
check_odir = 1
filename = [i for i in os.listdir(input_dir) if i.startswith("S")]
@@ -367,8 +370,11 @@
gscript.warning(_('--- AOD will be ignored ---'))
check_file = 1
stats_v = gscript.parse_command('r.univar', flags='g', map=vis)
- vis_mean = int(float(stats_v['mean']))
- gscript.message(_('--- Computed visibility mean value: {} Km ---'.format(vis_mean)))
+ try:
+ vis_mean = int(float(stats_v['mean']))
+ gscript.message('--- Computed visibility mean value: {} Km ---'.format(vis_mean))
+ except:
+ gscript.fatal('The input visibility maps is not valid. It could be out of the computational region.')
elif vis=='' and (options['aod_value']!='' or aeronet_file!=''):
gscript.fatal('Check the -a flag to use AOD instead of visibility')
else:
@@ -462,14 +468,17 @@
# Compute AOD at 550 nm
alpha = math.log(aot_lower/aot_upper)/math.log(wl_upper/wl_lower)
aot550 = math.exp(math.log(aot_lower) - math.log(550.0/wl_lower)*alpha)
- gscript.message(_('--- Computed AOD at 550 nm: {} ---'.format(aot550)))
+ gscript.message('--- Computed AOD at 550 nm: {} ---'.format(aot550))
# Compute mean target elevation in km
stats_d = gscript.parse_command('r.univar', flags='g', map=dem)
- mean = (float(stats_d['mean']))
- conv_fac = -0.001
- dem_mean = mean * conv_fac
- gscript.message(_('--- Computed mean target elevation above sea level: {:.3f} m ---'.format(mean)))
+ try:
+ mean = (float(stats_d['mean']))
+ conv_fac = -0.001
+ dem_mean = mean * conv_fac
+ gscript.message('--- Computed mean target elevation above sea level: {:.3f} m ---'.format(mean))
+ except:
+ gscript.fatal('The input elevation maps is not valid. It could be out of the computational region.')
# Start compiling the control file
for key, bb in bands.items():
@@ -572,82 +581,82 @@
else:
band_n = b[10]
if band_n == 'B01' and sensor.text == 'Sentinel-2A':
- gscript.message(_(band_n))
+ gscript.message(band_n)
text.write('166')
elif band_n == 'B02' and sensor.text == 'Sentinel-2A':
text.write('167')
elif band_n == 'B03' and sensor.text == 'Sentinel-2A':
text.write('168')
elif band_n == 'B04' and sensor.text == 'Sentinel-2A':
text.write('169')
elif band_n == 'B05' and sensor.text == 'Sentinel-2A':
text.write('170')
elif band_n == 'B06' and sensor.text == 'Sentinel-2A':
text.write('171')
elif band_n == 'B07' and sensor.text == 'Sentinel-2A':
text.write('172')
elif band_n == 'B08' and sensor.text == 'Sentinel-2A':
text.write('173')
elif band_n == 'B8A' and sensor.text == 'Sentinel-2A':
text.write('174')
elif band_n == 'B09' and sensor.text == 'Sentinel-2A':
text.write('175')
elif band_n == 'B10' and sensor.text == 'Sentinel-2A':
text.write('176')
elif band_n == 'B11' and sensor.text == 'Sentinel-2A':
text.write('177')
elif band_n == 'B12' and sensor.text == 'Sentinel-2A':
text.write('178')
elif band_n == 'B01' and sensor.text == 'Sentinel-2B':
text.write('179')
elif band_n == 'B02' and sensor.text == 'Sentinel-2B':
text.write('180')
elif band_n == 'B03' and sensor.text == 'Sentinel-2B':
text.write('181')
elif band_n == 'B04' and sensor.text == 'Sentinel-2B':
text.write('182')
elif band_n == 'B05' and sensor.text == 'Sentinel-2B':
text.write('183')
elif band_n == 'B06' and sensor.text == 'Sentinel-2B':
text.write('184')
elif band_n == 'B07' and sensor.text == 'Sentinel-2B':
text.write('185')
elif band_n == 'B08' and sensor.text == 'Sentinel-2B':
text.write('186')
elif band_n == 'B8A' and sensor.text == 'Sentinel-2B':
text.write('187')
elif band_n == 'B09' and sensor.text == 'Sentinel-2B':
text.write('188')
elif band_n == 'B10' and sensor.text == 'Sentinel-2B':
text.write('189')
elif band_n == 'B11' and sensor.text == 'Sentinel-2B':
text.write('190')
elif band_n == 'B12' and sensor.text == 'Sentinel-2B':
text.write('191')
else:
gscript.fatal('Bands do not seem to belong to a Sentinel image')
@@ -691,7 +700,7 @@
txt.close()
for key, cb in cor_bands.items():
- gscript.message(_(cb))
+ gscript.message(cb)
gscript.run_command('r.colors',
map=cb,
color='grey',
