[GRASS-SVN] r73259 - grass-addons/grass7/raster/r.neighborhoodmatrix
svn_grass at osgeo.org
Tue Sep 4 11:58:04 PDT 2018
Author: mlennert
Date: 2018-09-04 11:58:04 -0700 (Tue, 04 Sep 2018)
New Revision: 73259
grass-addons/grass7/raster/r.neighborhoodmatrix/r.neighborhoodmatrix.html
grass-addons/grass7/raster/r.neighborhoodmatrix/r.neighborhoodmatrix.py
r.neighborhoodmatrix: use r.info, not r.category to test for number of segments + add null check at the end + info about region in manual
Modified: grass-addons/grass7/raster/r.neighborhoodmatrix/r.neighborhoodmatrix.html
--- grass-addons/grass7/raster/r.neighborhoodmatrix/r.neighborhoodmatrix.html 2018-09-04 16:31:01 UTC (rev 73258)
+++ grass-addons/grass7/raster/r.neighborhoodmatrix/r.neighborhoodmatrix.html 2018-09-04 18:58:04 UTC (rev 73259)
@@ -42,7 +42,11 @@
resolution is not the same in East-West and in North-South direction
(rectangular pixels).
+<p>
+The module respects the region settings, so if the raster map is outside the
+current computational region, the resulting list of neighbors will be empty.
<h2>TODO</h2>
<ul>
Modified: grass-addons/grass7/raster/r.neighborhoodmatrix/r.neighborhoodmatrix.py
--- grass-addons/grass7/raster/r.neighborhoodmatrix/r.neighborhoodmatrix.py 2018-09-04 16:31:01 UTC (rev 73258)
+++ grass-addons/grass7/raster/r.neighborhoodmatrix/r.neighborhoodmatrix.py 2018-09-04 18:58:04 UTC (rev 73259)
@@ -111,9 +111,8 @@
if datatype != 'CELL':
gscript.fatal(_("Input map has to be of CELL (integer) type"))
- numneighbors = len(gscript.read_command('r.category',
- map_=rinput).splitlines())
- if numneighbors < 2:
+ mapinfo = gscript.raster_info(rinput)
+ if mapinfo['max'] == mapinfo['min']:
gscript.fatal(_("Need at least two different category values to determine neighbors"))
global separator
@@ -188,11 +187,12 @@
OldAcat = Acat
OldBcat = Bcat
Sum = value
- if flags['l']:
- woutput = separator.join([OldAcat, OldBcat, str(Sum)])
- else:
- woutput = separator.join([OldAcat, OldBcat])
- of.write(woutput+"\n")
+ if OldAcat and OldBcat:
+ if flags['l']:
+ woutput = separator.join([OldAcat, OldBcat, str(Sum)])
+ else:
+ woutput = separator.join([OldAcat, OldBcat])
+ of.write(woutput+"\n")
of.close()
if __name__ == "__main__":
