[GRASS-SVN] r73311 - grass-addons/grass7/raster/r.spread.sod
svn_grass at osgeo.org
Mon Sep 10 18:53:17 PDT 2018
Author: wenzeslaus
Date: 2018-09-10 18:53:16 -0700 (Mon, 10 Sep 2018)
New Revision: 73311
grass-addons/grass7/raster/r.spread.sod/CHANGELOG.md
grass-addons/grass7/raster/r.spread.sod/Spore.cpp
grass-addons/grass7/raster/r.spread.sod/Spore.h
grass-addons/grass7/raster/r.spread.sod/main.cpp
grass-addons/grass7/raster/r.spread.sod/raster.h
r.spread.sod: seasonality fixed, history added
Plus additional code compilation improvements and sync to lanternfly branch of
https://github.com/ncsu-landscape-dynamics/r.spread.pest/
commit 1ae5993.
Modified: grass-addons/grass7/raster/r.spread.sod/CHANGELOG.md
--- grass-addons/grass7/raster/r.spread.sod/CHANGELOG.md 2018-09-11 01:10:20 UTC (rev 73310)
+++ grass-addons/grass7/raster/r.spread.sod/CHANGELOG.md 2018-09-11 01:53:16 UTC (rev 73311)
@@ -4,14 +4,33 @@
The format is based on [Keep a Changelog](http://keepachangelog.com/).
+## 2018-09-10 - Seasonality Fixes
+### Added
+- Save GRASS GIS history for all raster outputs (Vaclav Petras)
+ - The executed command with all parameters is stored in the matadata.
+### Changed
+- Seasonality parameter is checked for emptiness and empty string is
+ not allowed (Vaclav Petras)
+- Seasonality is now mostly handled in a separate class.
+### Fixed
+- Current month is now checked if it is in the season (Vaclav Petras)
## 2018-06-21 - Critical Temperature
### Added
-- Time-series of temperature raster maps specified as a text file.
-- Temperature rasters are used at a specified month to check against
- a provided critical temperature and if the condition is met,
- infected trees become susceptible again.
+- Critical temperature as the lowest temperature spores can survive
+ in a provided month (Vaclav Petras)
+ - Time-series of temperature raster maps specified as a text file.
+ - Temperature rasters are used at a specified month to check against
+ a provided critical temperature and if the condition is met,
+ infected trees become susceptible again.
### Changed
Modified: grass-addons/grass7/raster/r.spread.sod/Spore.cpp
--- grass-addons/grass7/raster/r.spread.sod/Spore.cpp 2018-09-11 01:10:20 UTC (rev 73310)
+++ grass-addons/grass7/raster/r.spread.sod/Spore.cpp 2018-09-11 01:53:16 UTC (rev 73311)
@@ -95,7 +95,7 @@
generator.seed(random_seed);
-void Sporulation::SporeRemove(Img& I, Img& S, const DImg temperature,
+void Sporulation::SporeRemove(Img& I, Img& S, const DImg& temperature,
double critical_temperature)
for (int i = 0; i < height; i++) {
Modified: grass-addons/grass7/raster/r.spread.sod/Spore.h
--- grass-addons/grass7/raster/r.spread.sod/Spore.h 2018-09-11 01:10:20 UTC (rev 73310)
+++ grass-addons/grass7/raster/r.spread.sod/Spore.h 2018-09-11 01:53:16 UTC (rev 73311)
@@ -48,7 +48,7 @@
std::default_random_engine generator;
public:
Sporulation(unsigned random_seed, const Img &size);
- void SporeRemove(Img& I, Img &S, const DImg temperature,
+ void SporeRemove(Img& I, Img& S, const DImg& temperature,
double critical_temperature);
void SporeGen(const Img& I, const double *weather,
double weather_value, double rate);
Modified: grass-addons/grass7/raster/r.spread.sod/main.cpp
--- grass-addons/grass7/raster/r.spread.sod/main.cpp 2018-09-11 01:10:20 UTC (rev 73310)
+++ grass-addons/grass7/raster/r.spread.sod/main.cpp 2018-09-11 01:53:16 UTC (rev 73311)
@@ -135,7 +135,20 @@
" value '" + text +"' provided");
-typedef std::pair<int, int> Season;
+class Season
+public:
+ Season(int start, int end)
+ : m_start_month(start), m_end_month(end)
+ inline bool month_in_season(int month)
+ return month >= m_start_month && month <= m_end_month;
+private:
+ int m_start_month;
+ int m_end_month;
inline Season seasonality_from_option(const Option* opt)
@@ -444,7 +457,8 @@
" ending at the end of September");
opt.seasonality->key_desc = "from,to";
//opt.seasonality->options = "1-12";
- opt.seasonality->answer = "1,12";
+ opt.seasonality->answer = const_cast<char*>("1,12");
+ opt.seasonality->required = YES;
opt.seasonality->multiple = NO;
opt.seasonality->guisection = _("Time");
@@ -462,7 +476,7 @@
opt.spore_rate->type = TYPE_DOUBLE;
opt.spore_rate->key = "spore_rate";
opt.spore_rate->label = _("Spore production rate per week for each infected tree");
- opt.spore_rate->answer = "4.4";
+ opt.spore_rate->answer = const_cast<char*>("4.4");
opt.spore_rate->guisection = _("Spores");
opt.radial_type = G_define_option();
@@ -469,7 +483,7 @@
opt.radial_type->type = TYPE_STRING;
opt.radial_type->key = "radial_type";
opt.radial_type->label = _("Radial distribution type");
- opt.radial_type->answer = "cauchy";
+ opt.radial_type->answer = const_cast<char*>("cauchy");
opt.radial_type->options = "cauchy,cauchy_mix";
opt.radial_type->guisection = _("Spores");
@@ -477,7 +491,7 @@
opt.scale_1->type = TYPE_DOUBLE;
opt.scale_1->key = "scale_1";
opt.scale_1->label = _("Scale parameter for the first Cauchy distribution");
- opt.scale_1->answer = "20.57";
+ opt.scale_1->answer = const_cast<char*>("20.57");
opt.scale_1->guisection = _("Spores");
opt.scale_2 = G_define_option();
@@ -490,7 +504,7 @@
opt.kappa->type = TYPE_DOUBLE;
opt.kappa->key = "kappa";
opt.kappa->label = _("Concentration parameter for the von Mises distribution");
- opt.kappa->answer = "2";
+ opt.kappa->answer = const_cast<char*>("2");
opt.kappa->guisection = _("Spores");
opt.gamma = G_define_option();
@@ -625,6 +639,9 @@
file_exists_or_fatal_error(opt.weather_file);
// Seasonality: Do you want the spread to be limited to certain months?
+ if (!opt.seasonality->answer || opt.seasonality->answer[0] == '\0')
+ G_fatal_error(_("The option %s cannot be empty"),
+ opt.seasonality->key);
Season season = seasonality_from_option(opt.seasonality);
Direction pwdir = direction_enum_from_string(opt.wind->answer);
@@ -830,7 +847,7 @@
// main simulation loop (weekly steps)
for (int current_week = 0; ; current_week++, step == "month" ? dd_current.increasedByMonth() : dd_current.increasedByWeek()) {
if (dd_current < dd_end)
- if (season.first >= dd_current.getMonth() && dd_current.getMonth() <= season.second)
+ if (season.month_in_season(dd_current.getMonth()))
unresolved_weeks.push_back(current_week);
// removal is out of sync with the actual runs but it does
Modified: grass-addons/grass7/raster/r.spread.sod/raster.h
--- grass-addons/grass7/raster/r.spread.sod/raster.h 2018-09-11 01:10:20 UTC (rev 73310)
+++ grass-addons/grass7/raster/r.spread.sod/raster.h 2018-09-11 01:53:16 UTC (rev 73311)
@@ -424,6 +424,11 @@
Rast_put_c_row(fd, data + (i * width));
Rast_close(fd);
+ /* write metadata */
+ struct History history;
+ Rast_short_history(name, "raster", &history);
+ Rast_command_history(&history);
+ Rast_write_history(name, &history);
// convenient definitions, names for backwards compatibility
