[GRASS-SVN] r73312 - grass-addons/grass7/raster/r.spread.sod
svn_grass at osgeo.org
Mon Sep 10 19:36:57 PDT 2018
Author: wenzeslaus
Date: 2018-09-10 19:36:57 -0700 (Mon, 10 Sep 2018)
New Revision: 73312
grass-addons/grass7/raster/r.spread.sod/CHANGELOG.md
grass-addons/grass7/raster/r.spread.sod/main.cpp
r.spread.sod: use GRASS lib function for random seed value, not C++ lib one
The C++ function/class has deterministic results with MinGW on MS Windows.
Sync to commit 33fff3c, lanternfly branch of
https://github.com/ncsu-landscape-dynamics/r.spread.pest/
Modified: grass-addons/grass7/raster/r.spread.sod/CHANGELOG.md
--- grass-addons/grass7/raster/r.spread.sod/CHANGELOG.md 2018-09-11 01:53:16 UTC (rev 73311)
+++ grass-addons/grass7/raster/r.spread.sod/CHANGELOG.md 2018-09-11 02:36:57 UTC (rev 73312)
@@ -20,6 +20,11 @@
### Fixed
- Current month is now checked if it is in the season (Vaclav Petras)
+ - Fixes #1 (Metadata - missing full command used).
+- GRASS GIS library function now used to generate random seed (Vaclav Petras)
+ - Previous implementation didn't give non-deterministic outputs with
+ the -s flag on MS Windows.
+ - Fixes #2 (Stochastic runs with -s are always the same on Windows).
## 2018-06-21 - Critical Temperature
Modified: grass-addons/grass7/raster/r.spread.sod/main.cpp
--- grass-addons/grass7/raster/r.spread.sod/main.cpp 2018-09-11 01:53:16 UTC (rev 73311)
+++ grass-addons/grass7/raster/r.spread.sod/main.cpp 2018-09-11 02:36:57 UTC (rev 73312)
@@ -708,9 +708,10 @@
G_verbose_message(_("Read random seed from %s option: %ud"),
opt.seed->key, seed_value);
} else {
- // flag of option is required
- std::random_device rd;
- seed_value = rd();
+ // flag or option is required, so no check needed
+ // getting random seed using GRASS library
+ // std::random_device is deterministic in MinGW (#338)
+ seed_value = G_srand48_auto();
G_verbose_message(_("Generated random seed (-%c): %ud"),
flg.generate_seed->key, seed_value);
